[U-Boot] [PATCH] mmc: synchronize the sequence with enum bus_mode in mmc.h
If some configs are disabled, number of freqs array will not assigned to correct value with bus_mode. Synchornize the ordering with enum bus_mode in mmc.h.
Signed-off-by: Jaehoon Chung jh80.chung@samsung.com --- drivers/mmc/mmc.c | 11 +++-------- 1 file changed, 3 insertions(+), 8 deletions(-)
diff --git a/drivers/mmc/mmc.c b/drivers/mmc/mmc.c index 255310a8e6..81b35bbf77 100644 --- a/drivers/mmc/mmc.c +++ b/drivers/mmc/mmc.c @@ -181,23 +181,18 @@ const char *mmc_mode_name(enum bus_mode mode) static uint mmc_mode2freq(struct mmc *mmc, enum bus_mode mode) { static const int freqs[] = { + [MMC_LEGACY] = 25000000, [SD_LEGACY] = 25000000, [MMC_HS] = 26000000, [SD_HS] = 50000000, -#if CONFIG_IS_ENABLED(MMC_UHS_SUPPORT) + [MMC_HS_52] = 52000000, + [MMC_DDR_52] = 52000000, [UHS_SDR12] = 25000000, [UHS_SDR25] = 50000000, [UHS_SDR50] = 100000000, [UHS_DDR50] = 50000000, -#ifdef MMC_SUPPORTS_TUNING [UHS_SDR104] = 208000000, -#endif -#endif - [MMC_HS_52] = 52000000, - [MMC_DDR_52] = 52000000, -#if CONFIG_IS_ENABLED(MMC_HS200_SUPPORT) [MMC_HS_200] = 200000000, -#endif };
if (mode == MMC_LEGACY)
Applied to u-boot-mmc.
Best Regards, Jaehoon Chung
Jaehoon Chung
