[U-Boot] [PATCH] aspeed/watchdog: Correct timeout value
The driver was using milliseconds and programming it into a register which takes ticks of the watchdog clock, which runs at 1MHz. This meant we were off by 1000 with the desired value.
When 06985289d452 ("watchdog: Implement generic watchdog_reset() version") was added the aspeed board would leave the watchdog running, causing it to bite before u-boot was done.
Discovered by booting in qemu:
$ qemu-system-arm -M ast2500-evb -drive file=test.img,format=raw,if=mtd -nographic -no-reboot -d cpu_reset
U-Boot 2019.07-rc3-00091-g2253e40caef5 (Jun 06 2019 - 16:53:23 +0930)
Model: Aspeed BMC DRAM: 496 MiB WDT: Started with servicing (60s timeout) MMC: In: serial@1e784000 Out: serial@1e784000 Err: serial@1e784000 Watchdog timer expired.
Fixes: 06985289d452 ("watchdog: Implement generic watchdog_reset() version") Signed-off-by: Joel Stanley joel@jms.id.au --- drivers/watchdog/ast_wdt.c | 6 ++++++ 1 file changed, 6 insertions(+)
diff --git a/drivers/watchdog/ast_wdt.c b/drivers/watchdog/ast_wdt.c index 523484b1fff9..d344d54aee82 100644 --- a/drivers/watchdog/ast_wdt.c +++ b/drivers/watchdog/ast_wdt.c @@ -23,6 +23,12 @@ static int ast_wdt_start(struct udevice *dev, u64 timeout, ulong flags) ulong driver_data = dev_get_driver_data(dev); u32 reset_mode = ast_reset_mode_from_flags(flags);
+ /* 32 bits at 1MHz is 4294967ms */ + timeout = min_t(u64, timeout, 4294967); + + /* WDT counts in ticks of 1MHz clock. 1ms / 1e3 * 1e6 */ + timeout *= 1000; + clrsetbits_le32(&priv->regs->ctrl, WDT_CTRL_RESET_MASK << WDT_CTRL_RESET_MODE_SHIFT, reset_mode << WDT_CTRL_RESET_MODE_SHIFT);
Thanks for finding this. Any chance you could take a look at what we have in .travis.yml today for running QEMU platforms and add this one?
Yes, I'll give it a go.
Can we get this fix merged in the mean time?
Cheers,
Joel
Joel Stanley
