[U-Boot] [PATCH] cmd_ide: Remove unused AmigaOneG3SE code
The output_data_short() and input_data_short() functions for the AmigaOneG3SE are unused and result in compiler warnings.
Signed-off-by: Peter Tyser ptyser@xes-inc.com --- common/cmd_ide.c | 44 -------------------------------------------- 1 files changed, 0 insertions(+), 44 deletions(-)
diff --git a/common/cmd_ide.c b/common/cmd_ide.c index 9bc6b4a..782ad1c 100644 --- a/common/cmd_ide.c +++ b/common/cmd_ide.c @@ -851,28 +851,6 @@ set_pcmcia_timing (int pmode)
-#ifdef __PPC__ -# ifdef CONFIG_AMIGAONEG3SE -static void -output_data_short(int dev, ulong *sect_buf, int words) -{ - ushort *dbuf; - volatile ushort *pbuf; - - pbuf = (ushort *)(ATA_CURR_BASE(dev)+ATA_DATA_REG); - dbuf = (ushort *)sect_buf; - while (words--) { - EIEIO; - *pbuf = *dbuf++; - EIEIO; - } - - if (words&1) - *pbuf = 0; -} -# endif /* CONFIG_AMIGAONEG3SE */ -#endif /* __PPC_ */ - /* We only need to swap data if we are running on a big endian cpu. */ /* But Au1x00 cpu:s already swaps data in big endian mode! */ #if defined(__LITTLE_ENDIAN) || ( defined(CONFIG_AU1X00) && !defined(CONFIG_GTH2) ) @@ -1028,28 +1006,6 @@ input_data(int dev, ulong *sect_buf, int words)
#endif /* __PPC__ */
-#ifdef CONFIG_AMIGAONEG3SE -static void -input_data_short(int dev, ulong *sect_buf, int words) -{ - ushort *dbuf; - volatile ushort *pbuf; - - pbuf = (ushort *)(ATA_CURR_BASE(dev)+ATA_DATA_REG); - dbuf = (ushort *)sect_buf; - while (words--) { - EIEIO; - *dbuf++ = *pbuf; - EIEIO; - } - - if (words&1) { - ushort dummy; - dummy = *pbuf; - } -} -#endif - /* ------------------------------------------------------------------------- */ static void ide_ident (block_dev_desc_t *dev_desc)
Dear Peter Tyser,
Applied, thanks.
Peter Tyser
