[PATCH] firmware: psci: Do not bind driver if U-Boot runs in EL3
There is no reason to bind psci driver if U-Boot runs in EL3 because SMC/HVC instructions can't be called. That's why detect this state and don't let user to crash from prompt by performing reset or poweroff commands (if enabled).
Maybe there is a better way how to do it. Maybe do it in probe instead of bind. Feel free to comment but this doesn't look right behavior.
U-Boot SPL 2020.10-rc1-00046-g5fade0c9d867 (Aug 05 2020 - 14:36:03 +0200) PMUFW: v1.1 Loading new PMUFW cfg obj (2024 bytes) EL Level: EL3 Multiboot: 0 Trying to boot from MMC2 spl: could not initialize mmc. error: -19 Trying to boot from MMC1 spl_load_image_fat_os: error reading image u-boot.bin, err - -2
U-Boot 2020.10-rc1-00046-g5fade0c9d867 (Aug 05 2020 - 14:36:03 +0200)
Model: ZynqMP ZCU104 RevC Board: Xilinx ZynqMP DRAM: 2 GiB PMUFW: v1.1 EL Level: EL3 Chip ID: zu7e Multiboot: 0 WDT: Started with servicing (60s timeout) NAND: 0 MiB MMC: mmc@ff170000: 0 In: serial@ff000000 Out: serial@ff000000 Err: serial@ff000000 Bootmode: LVL_SHFT_SD_MODE1 Reset reason: EXTERNAL Net: ZYNQ GEM: ff0e0000, mdio bus ff0e0000, phyaddr 12, interface rgmii-id eth0: ethernet@ff0e0000 Hit any key to stop autoboot: 0 ZynqMP> ZynqMP> reset resetting ... "Synchronous Abort" handler, esr 0x5e000000 elr: 0000000008000194 lr : 0000000008000220 (reloc) elr: 000000007fec9194 lr : 000000007fec9220 x0 : 0000000084000009 x1 : 0000000000000000 x2 : 0000000000000000 x3 : 0000000000000000 x4 : 0000000000000000 x5 : 0000000000000000 x6 : 0000000000000000 x7 : 0000000000000000 x8 : 000000007deaedb0 x9 : 000000000000000c x10: 00000000000007c4 x11: 000000007deae92c x12: 0000000000000006 x13: 000000000001869f x14: 000000007deaedb0 x15: 0000000000000002 x16: 000000007ff2af5c x17: 0000000000000000 x18: 000000007deb8db0 x19: 0000000000000000 x20: 000000007ffb0268 x21: 0000000000000000 x22: 000000007debc600 x23: 0000000000000001 x24: 000000007ffc7898 x25: 0000000000000000 x26: 0000000000000000 x27: 0000000000000000 x28: 000000007debc640 x29: 000000007deaeaf0
Code: 00000000 f9020000 00000000 d4000003 (f94003e4) Resetting CPU ...
### ERROR ### Please RESET the board ###
--- drivers/firmware/psci.c | 3 +++ 1 file changed, 3 insertions(+)
diff --git a/drivers/firmware/psci.c b/drivers/firmware/psci.c index 23cf807591c4..1bef7eea56fc 100644 --- a/drivers/firmware/psci.c +++ b/drivers/firmware/psci.c @@ -69,6 +69,9 @@ static int psci_probe(struct udevice *dev) { const char *method;
+ if (current_el() == 3) + return -EINVAL; + method = ofnode_read_string(dev_ofnode(dev), "method"); if (!method) { pr_warn("missing "method" property\n");
- if (current_el() == 3)
return -EINVAL;
- method = ofnode_read_string(dev_ofnode(dev), "method"); if (!method) { pr_warn("missing "method" property\n");
Just a note: #include <asm/system.h> is missing on latest. But let's discussed this before I send v2.
Thanks, Michal
Michal Simek
