[U-Boot] [PATCH v4] mx31ads: Use the new relocation scheme
This fixes the MX31ADS build by using the new relocation scheme.
Signed-off-by: Fabio Estevam fabio.estevam@freescale.com Tested-by: Felix Radensky felix@embedded-sol.com --- Changes since v3: - Fix CONFIG_SYS_TEXT_BASE and boot is confirmed to work now Changes since v2: - Use PHYS_SDRAM_1 in get_ram_size - Remove local config.mk Changes since v1: - Fixed lines over 80 characters.
board/freescale/mx31ads/config.mk | 1 - board/freescale/mx31ads/mx31ads.c | 19 ++++++++++++--- board/freescale/mx31ads/u-boot.lds | 42 ++++++++++++++++++++++++++++------- include/configs/mx31ads.h | 11 +++++++++ 4 files changed, 59 insertions(+), 14 deletions(-) delete mode 100644 board/freescale/mx31ads/config.mk
diff --git a/board/freescale/mx31ads/config.mk b/board/freescale/mx31ads/config.mk deleted file mode 100644 index 0131edf..0000000 --- a/board/freescale/mx31ads/config.mk +++ /dev/null @@ -1 +0,0 @@ -CONFIG_SYS_TEXT_BASE = 0x87f00000 diff --git a/board/freescale/mx31ads/mx31ads.c b/board/freescale/mx31ads/mx31ads.c index a298e05..9bf9c18 100644 --- a/board/freescale/mx31ads/mx31ads.c +++ b/board/freescale/mx31ads/mx31ads.c @@ -28,15 +28,21 @@
DECLARE_GLOBAL_DATA_PTR;
-int dram_init (void) +int dram_init(void) +{ + /* dram_init must store complete ramsize in gd->ram_size */ + gd->ram_size = get_ram_size((volatile void *)PHYS_SDRAM_1, + PHYS_SDRAM_1_SIZE); + return 0; +} + +void dram_init_banksize(void) { gd->bd->bi_dram[0].start = PHYS_SDRAM_1; gd->bd->bi_dram[0].size = PHYS_SDRAM_1_SIZE; - - return 0; }
-int board_init (void) +int board_early_init_f(void) { int i;
@@ -94,6 +100,11 @@ int board_init (void) readb(CS4_BASE + 8); readb(CS4_BASE + 7);
+ return 0; +} + +int board_init(void) +{ gd->bd->bi_arch_number = MACH_TYPE_MX31ADS; /* board id for linux */ gd->bd->bi_boot_params = 0x80000100; /* adress of boot parameters */
diff --git a/board/freescale/mx31ads/u-boot.lds b/board/freescale/mx31ads/u-boot.lds index b081b21..79eb7ac 100644 --- a/board/freescale/mx31ads/u-boot.lds +++ b/board/freescale/mx31ads/u-boot.lds @@ -48,23 +48,47 @@ SECTIONS
*(.text) } - . = ALIGN(4); - .rodata : { *(SORT_BY_ALIGNMENT(SORT_BY_NAME(.rodata*))) } + .rodata : { *(.rodata) }
. = ALIGN(4); - .data : { *(.data) } + .data : { + *(.data) + }
. = ALIGN(4); - .got : { *(.got) } - - . = .; __u_boot_cmd_start = .; .u_boot_cmd : { *(.u_boot_cmd) } __u_boot_cmd_end = .;
. = ALIGN(4); - __bss_start = .; - .bss : { *(.bss) . = ALIGN(4); } - __bss_end__ = .; + + .rel.dyn : { + __rel_dyn_start = .; + *(.rel*) + __rel_dyn_end = .; + } + + .dynsym : { + __dynsym_start = .; + *(.dynsym) + } + + _end = .; + + .bss __rel_dyn_start (OVERLAY) : { + __bss_start = .; + *(.bss) + . = ALIGN(4); + __bss_end__ = .; + } + + /DISCARD/ : { *(.bss*) } + /DISCARD/ : { *(.dynstr*) } + /DISCARD/ : { *(.dynsym*) } + /DISCARD/ : { *(.dynamic*) } + /DISCARD/ : { *(.hash*) } + /DISCARD/ : { *(.plt*) } + /DISCARD/ : { *(.interp*) } + /DISCARD/ : { *(.gnu*) } } diff --git a/include/configs/mx31ads.h b/include/configs/mx31ads.h index 5ea59b4..f8be3e9 100644 --- a/include/configs/mx31ads.h +++ b/include/configs/mx31ads.h @@ -33,6 +33,8 @@ #define CONFIG_DISPLAY_CPUINFO #define CONFIG_DISPLAY_BOARDINFO
+#define CONFIG_SYS_TEXT_BASE 0xA0000000 + /* * Disabled for now due to build problems under Debian and a significant increase * in the final file size: 144260 vs. 109536 Bytes. @@ -160,6 +162,15 @@ #define CONFIG_NR_DRAM_BANKS 1 #define PHYS_SDRAM_1 CSD0_BASE #define PHYS_SDRAM_1_SIZE (128 * 1024 * 1024) +#define CONFIG_BOARD_EARLY_INIT_F + +#define CONFIG_SYS_SDRAM_BASE PHYS_SDRAM_1 +#define CONFIG_SYS_INIT_RAM_ADDR IRAM_BASE_ADDR +#define CONFIG_SYS_INIT_RAM_SIZE IRAM_SIZE +#define CONFIG_SYS_GBL_DATA_OFFSET (CONFIG_SYS_INIT_RAM_SIZE - \ + GENERATED_GBL_DATA_SIZE) +#define CONFIG_SYS_INIT_SP_ADDR (CONFIG_SYS_INIT_RAM_ADDR + \ + CONFIG_SYS_GBL_DATA_OFFSET)
/*----------------------------------------------------------------------- * FLASH and environment organization
Changes since v3:
Changes since v2:
Changes since v1:
Applied to u-boot-imx (this is a fix).
Thanks, Stefano Babic
Fabio Estevam
Stefano Babic
