Re: [U-Boot] [PATCH v4 1/3] net: Adds Fast Ethernet Controller driver for Armada100
----- "Marek Vasut" marek.vasut@gmail.com wrote:
On Tuesday, August 30, 2011 07:44:40 AM Ajay Bhargav wrote:
This patch adds support for Fast Ethernet Controller driver for Armada100 series.
Signed-off-by: Ajay Bhargav ajay.bhargav@einfochips.com
+static int smi_reg_read(const char *devname, u8 phy_addr, u8
phy_reg,
u16 *value)
- struct eth_device *dev = eth_get_dev_by_name(devname);
- struct armdfec_device *darmdfec = to_darmdfec(dev);
- struct armdfec_reg *regs = darmdfec->regs;
- u32 val, reg_data;
- if (phy_addr == PHY_ADR_REQ && phy_reg == PHY_ADR_REQ) {
reg_data = readl(®s->phyadr);
You use "reg_data" here and "val" below ... can't you use just one variable?
Yes.. sorry for mistake.
+static int add_del_hash_entry(struct armdfec_device *darmdfec, u32
mach,
u32 macl, u32 rd, u32 skip, int del)
- struct addr_table_entry_t *entry, *start;
- u32 newhi;
- u32 newlo;
- u32 i;
- newlo = (((mach >> 4) & 0xf) << 15)
| (((mach >> 0) & 0xf) << 11)
| (((mach >> 12) & 0xf) << 7)
| (((mach >> 8) & 0xf) << 3)
| (((macl >> 20) & 0x1) << 31)
| (((macl >> 16) & 0xf) << 27)
| (((macl >> 28) & 0xf) << 23)
| (((macl >> 24) & 0xf) << 19)
| (skip << HTESKIP) | (rd << HTERDBIT)
| HTEVALID;
- newhi = (((macl >> 4) & 0xf) << 15)
| (((macl >> 0) & 0xf) << 11)
| (((macl >> 12) & 0xf) << 7)
| (((macl >> 8) & 0xf) << 3)
| (((macl >> 21) & 0x7) << 0);
* Pick the appropriate table, start scanning for free/reusable
* entries at the index obtained by hashing the specified MAC
address
- start = (struct addr_table_entry_t *) (darmdfec->htpr);
- entry = start + hash_function(mach, macl);
- for (i = 0; i < HOP_NUMBER; i++) {
if (!(entry->lo & HTEVALID)) {
break;
} else {
/* if same address put in same position */
if (((entry->lo & 0xfffffff8) == (newlo & 0xfffffff8))
&& (entry->hi == newhi))
break;
What about
if (!(entry->lo & HTEVALID)) break;
if (((entry->lo & 0xfffffff8) == (newlo & 0xfffffff8)) && (entry->hi == newhi)) { break; }
No.. if entry is valid, we should not modify it anyways. Deleting a valid entry might break the hash chain.
if (entry == start + 0x7ff)
entry = start;
else
entry++;
- if (((entry->lo & 0xfffffff8) != (newlo & 0xfffffff8)) &&
(entry->hi != newhi) && del)
Now thinking of it, are you sure about this condition ? Shouldn't the first && be || instead ? And there should be parenthesis around that ?
if delete is requested for an address which is not present in chain, we should return immideatly. so && is fine there.
- if (i == HOP_NUMBER) {
if (!del) {
printf("ARMD100 FEC: (%s) table section is full\n",
__func__);
return -ENOSPC;
} else {
- /* 64 should work but does not -- dhcp packets NEVER get
transmitted. */
What's this about ?
- if ((mtu > MAX_PKT_SIZE) || (mtu < 64))
return -EINVAL;
+static int armdfec_send(struct eth_device *dev, volatile void
*dataptr,
int datasize)
- struct tx_desc *p_txdesc = darmdfec->p_txdesc;
- void *p = (void *) dataptr;
Is this needed?
If I use dataptr directly, sending doesnt work...
- int retry = PHY_WAIT_ITERATIONS * PHY_WAIT_MICRO_SECONDS;
- u32 cmd_sts;
- /* Copy buffer if it's misaligned */
- if ((u32) dataptr & 0x07) {
Space after typecast. Please fix globally.
will do that..
if (datasize > PKTSIZE_ALIGN) {
printf("ARMD100 FEC: Non-aligned data too large (%d)\n",
datasize);
return -1;
memcpy(darmdfec->p_aligned_txbuf, p, datasize);
p = darmdfec->p_aligned_txbuf;
The rest is really good !
Thanks!
Cheers
Thanks, Ajay Bhargav
Ajay Bhargav
