[U-Boot] [PATCH v2 3/4] sf: Add dual memories support - DUAL_PARALLEL
This patch added support for accessing dual memories in parallel connection with single chipselect line from controller.
For more info - see doc/SPI/README.nr-flash
Signed-off-by: Jagannadha Sutradharudu Teki jaganna@xilinx.com --- doc/SPI/README.nr-flash | 27 +++++++++++++++++++++++++++ drivers/mtd/spi/sf_ops.c | 8 ++++++-- drivers/mtd/spi/sf_probe.c | 11 ++++++----- include/spi.h | 3 ++- include/spi_flash.h | 5 ++++- 5 files changed, 45 insertions(+), 9 deletions(-)
diff --git a/doc/SPI/README.nr-flash b/doc/SPI/README.nr-flash index 65a5370..e8b099e 100644 --- a/doc/SPI/README.nr-flash +++ b/doc/SPI/README.nr-flash @@ -54,6 +54,33 @@ SF_NRF_DUAL_STACKED: by default, if U_PAGE is unset lower memory should accessible, once user wants to access upper memory need to set U_PAGE.
+SPI_FLASH_CONN_DUALPARALLEL: + - dual spi/qspi flash memories are connected with a single chipselect + line and these two memories are operating parallel with separate buses. + - xilinx zynq qspi controller has implemented this feature [1] + + +-------------+ CS +---------------+ + | |---------------------->| | + | | I0[3:0] | Upper Flash | + | |<=====================>| memory | + | | CLK | (SPI/QSPI) | + | |---------------------->| | + | Controller | CS +---------------+ + | SPI/QSPI |---------------------->| | + | | I0[3:0] | Lower Flash | + | |<=====================>| memory | + | | CLK | (SPI/QSPI) | + | |---------------------->| | + +-------------+ +---------------+ + + - two memory flash devices should has same hw part attributes (like size, + vendor..etc) + - Configurations: + Need to enable SEP_BUS[BIT:29],TWO_MEM[BIT:30] on LQSPI_CFG register. + - Operation: + Even bits, i.e. bit 0, 2, 4 ., of a data word is located in the lower memory + and odd bits, i.e. bit 1, 3, 5, ., of a data word is located in the upper memory. + Note: Technically there is only one CS line from the controller, but zynq qspi controller has an internal hw logic to enable additional CS when controller is configured for dual memories. diff --git a/drivers/mtd/spi/sf_ops.c b/drivers/mtd/spi/sf_ops.c index d96a69e..4fafbc6 100644 --- a/drivers/mtd/spi/sf_ops.c +++ b/drivers/mtd/spi/sf_ops.c @@ -119,7 +119,7 @@ static int spi_flash_bank(struct spi_flash *flash, u32 offset) u8 bank_sel; int ret;
- bank_sel = offset / SPI_FLASH_16MB_BOUN; + bank_sel = offset / (SPI_FLASH_16MB_BOUN << flash->shift);
ret = spi_flash_cmd_bankaddr_write(flash, bank_sel); if (ret) { @@ -142,6 +142,9 @@ static void spi_flash_nr_flash(struct spi_flash *flash, u32 *addr) flash->spi->flags &= ~SPI_XFER_U_PAGE; } break; + case SF_NRF_DUAL_PARALLEL: + *addr >>= flash->shift; + break; default: debug("SF: Unsupported nr_flash=%d\n", flash->nr_flash); break; @@ -387,7 +390,8 @@ int spi_flash_cmd_read_ops(struct spi_flash *flash, u32 offset, if (bank_sel < 0) return ret; #endif - remain_len = (SPI_FLASH_16MB_BOUN * (bank_sel + 1)) - offset; + remain_len = ((SPI_FLASH_16MB_BOUN << flash->shift) * + (bank_sel + 1)) - offset; if (len < remain_len) read_len = len; else diff --git a/drivers/mtd/spi/sf_probe.c b/drivers/mtd/spi/sf_probe.c index 248050c..0dc20f9 100644 --- a/drivers/mtd/spi/sf_probe.c +++ b/drivers/mtd/spi/sf_probe.c @@ -146,19 +146,20 @@ static struct spi_flash *spi_flash_validate_params(struct spi_slave *spi, flash->read = spi_flash_cmd_read_ops;
/* Compute the flash size */ - flash->page_size = (ext_jedec == 0x4d00) ? 512 : 256; - flash->sector_size = params->sector_size; - flash->size = flash->sector_size * params->nr_sectors; + flash->shift = (flash->nr_flash & SF_NRF_DUAL_PARALLEL) ? 1 : 0; + flash->page_size = ((ext_jedec == 0x4d00) ? 512 : 256) << flash->shift; + flash->sector_size = params->sector_size << flash->shift; + flash->size = flash->sector_size * params->nr_sectors << flash->shift; if (flash->nr_flash & SF_NRF_DUAL_STACKED) flash->size <<= 1;
/* Compute erase sector and command */ if (params->flags & SECT_4K) { flash->erase_cmd = CMD_ERASE_4K; - flash->erase_size = 4096; + flash->erase_size = 4096 << flash->shift; } else if (params->flags & SECT_32K) { flash->erase_cmd = CMD_ERASE_32K; - flash->erase_size = 32768; + flash->erase_size = 32768 << flash->shift; } else { flash->erase_cmd = CMD_ERASE_64K; flash->erase_size = flash->sector_size; diff --git a/include/spi.h b/include/spi.h index d214d82..ffd6647 100644 --- a/include/spi.h +++ b/include/spi.h @@ -47,6 +47,7 @@
/* SPI bus connection options */ #define SPI_CONN_DUAL_SHARED 1 << 0 +#define SPI_CONN_DUAL_SEPARATED 1 << 1
/* Header byte that marks the start of the message */ #define SPI_PREAMBLE_END_BYTE 0xec @@ -66,7 +67,7 @@ * @max_write_size: If non-zero, the maximum number of bytes which can * be written at once, excluding command bytes. * @memory_map: Address of read-only SPI flash access. - * @option: Varies SPI bus options - separate bus. + * @option: Varies SPI bus options - separate, shared bus. * @flags: Indication of SPI flags. */ struct spi_slave { diff --git a/include/spi_flash.h b/include/spi_flash.h index bb6eb0c..4f99ea6 100644 --- a/include/spi_flash.h +++ b/include/spi_flash.h @@ -37,6 +37,7 @@ enum spi_read_cmds { enum spi_nr_flash { SF_NRF_SINGLE = 0, SF_NRF_DUAL_STACKED = 1 << 0, + SF_NRF_DUAL_PARALLEL = 1 << 1, };
/** @@ -67,7 +68,8 @@ extern const struct spi_flash_params spi_flash_params_table[]; * * @spi: SPI slave * @name: Name of SPI flash - * @nr_flash: Indicates no.of flash memories - dual stacked + * @nr_flash: Indicates no.of flash memories - dual stacked, parallel + * @shift: Flash shift useful in dual parallel * @size: Total flash size * @page_size: Write (page) size * @sector_size: Sector size @@ -93,6 +95,7 @@ struct spi_flash { struct spi_slave *spi; const char *name; u8 nr_flash; + u8 shift;
u32 size; u32 page_size;
