[U-Boot] [PATCH 1/2] Add Vitesse VSC8662 PHY support
-VSC8662 is Dual Port 10/100/1000Base-T Phy, 100Base-FX/1000/Base-X Gigabit Ethernt Transceiver Phy.
-Its register set and features are similar to other Vitesse Phys
Signed-off-by: Priyanka Jain Priyanka.Jain@freescale.com Signed-off-by: York Sun yorksun@freescale.com --- drivers/net/phy/vitesse.c | 18 ++++++++++++++---- 1 files changed, 14 insertions(+), 4 deletions(-)
diff --git a/drivers/net/phy/vitesse.c b/drivers/net/phy/vitesse.c index d48d4fe..0a0f40d 100644 --- a/drivers/net/phy/vitesse.c +++ b/drivers/net/phy/vitesse.c @@ -1,6 +1,9 @@ /* * Vitesse PHY drivers * + * Copyright 2010-2012 Freescale Semiconductor, Inc. + * Author: Andy Fleming + * Add vsc8662 phy support - Priyanka Jain * This program is free software; you can redistribute it and/or * modify it under the terms of the GNU General Public License as * published by the Free Software Foundation; either version 2 of @@ -15,10 +18,6 @@ * along with this program; if not, write to the Free Software * Foundation, Inc., 59 Temple Place, Suite 330, Boston, * MA 02111-1307 USA - * - * Copyright 2010-2011 Freescale Semiconductor, Inc. - * author Andy Fleming - * */ #include <miiphy.h>
@@ -206,6 +205,16 @@ static struct phy_driver VSC8641_driver = { .shutdown = &genphy_shutdown, };
+static struct phy_driver VSC8662_driver = { + .name = "Vitesse VSC8662", + .uid = 0x70660, + .mask = 0xffff0, + .features = PHY_GBIT_FEATURES, + .config = &genphy_config_aneg, + .startup = &vitesse_startup, + .shutdown = &genphy_shutdown, +}; + /* Vitesse bought Cicada, so we'll put these here */ static struct phy_driver cis8201_driver = { .name = "CIS8201", @@ -235,6 +244,7 @@ int phy_vitesse_init(void) phy_register(&VSC8244_driver); phy_register(&VSC8211_driver); phy_register(&VSC8221_driver); + phy_register(&VSC8662_driver); phy_register(&cis8201_driver); phy_register(&cis8204_driver);
Add code for configuring VSC3316/3308 crosspoint switches Add README to understand the APIs
- VSC 3316/3308 is a low-power, low-cost asynchronous crosspoint switch capable of data rates upto 11.5Gbps. VSC3316 has 16 input and 16 output ports whereas VSC3308 has 8 input and 8 output ports. Programming of these devices are performed by two-wire or four-wire serial interface.
Signed-off-by: Shaveta Leekha shaveta@freescale.com Signed-off-by: York Sun yorksun@freescale.com --- board/freescale/common/Makefile | 1 + board/freescale/common/vsc3316_3308.c | 184 +++++++++++++++++++++++++++++++++ board/freescale/common/vsc3316_3308.h | 34 ++++++ doc/README.VSC3316-3308 | 43 ++++++++ 4 files changed, 262 insertions(+), 0 deletions(-) create mode 100644 board/freescale/common/vsc3316_3308.c create mode 100644 board/freescale/common/vsc3316_3308.h create mode 100644 doc/README.VSC3316-3308
diff --git a/board/freescale/common/Makefile b/board/freescale/common/Makefile index 3341755..315b99e 100644 --- a/board/freescale/common/Makefile +++ b/board/freescale/common/Makefile @@ -55,6 +55,7 @@ COBJS-$(CONFIG_P3060QDS) += ics307_clk.o COBJS-$(CONFIG_P4080DS) += ics307_clk.o COBJS-$(CONFIG_P5020DS) += ics307_clk.o COBJS-$(CONFIG_P5040DS) += ics307_clk.o +COBJS-$(CONFIG_VSC_CROSSBAR) += vsc3316_3308.o
# deal with common files for P-series corenet based devices SUBLIB-$(CONFIG_P2041RDB) += p_corenet/libp_corenet.o diff --git a/board/freescale/common/vsc3316_3308.c b/board/freescale/common/vsc3316_3308.c new file mode 100644 index 0000000..7868565 --- /dev/null +++ b/board/freescale/common/vsc3316_3308.c @@ -0,0 +1,184 @@ +/* + * Copyright 2012 Freescale Semiconductor, Inc. + * + * See file CREDITS for list of people who contributed to this + * project. + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License, or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 59 Temple Place, Suite 330, Boston, + * MA 02111-1307 USA + */ + +#include "vsc3316_3308.h" + +#define REVISION_ID_REG 0x7E +#define INTERFACE_MODE_REG 0x79 +#define CURRENT_PAGE_REGISTER 0x7F +#define CONNECTION_CONFIG_PAGE 0x00 +#define INPUT_STATE_REG 0x13 +#define GLOBAL_INPUT_ISE1 0x51 +#define GLOBAL_INPUT_ISE2 0x52 +#define GLOBAL_INPUT_LOS 0x55 +#define GLOBAL_CORE_CNTRL 0x5D +#define OUTPUT_MODE_PAGE 0x23 +#define CORE_CONTROL_PAGE 0x25 +#define CORE_CONFIG_REG 0x75 + +int vsc_if_enable(unsigned int vsc_addr) +{ + u8 data; + + debug("VSC:Configuring VSC at I2C address 0x%2x" + " for 2-wire interface\n", vsc_addr); + + /* enable 2-wire Serial InterFace (I2C) */ + data = 0x02; + return i2c_write(vsc_addr, INTERFACE_MODE_REG, 1, &data, 1); +} + +int vsc3316_config(unsigned int vsc_addr, const int8_t con_arr[][2], + unsigned int num_con) +{ + unsigned int i; + u8 rev_id = 0; + int ret; + + debug("VSC:Initializing VSC3316 at I2C address 0x%2x" + " for Tx\n", vsc_addr); + + ret = i2c_read(vsc_addr, REVISION_ID_REG, 1, &rev_id, 1); + if (ret < 0) { + printf("VSC:0x%x could not read REV_ID from device.\n", + vsc_addr); + return ret; + } + + if (rev_id != 0xab) { + printf("VSC: device at address 0x%x is not VSC3316/3308.\n", + vsc_addr); + return -ENODEV; + } + + ret = vsc_if_enable(vsc_addr); + if (ret) { + printf("VSC:0x%x could not configured for 2-wire I/F.\n", + vsc_addr); + return ret; + } + + /* config connections - page 0x00 */ + i2c_reg_write(vsc_addr, CURRENT_PAGE_REGISTER, CONNECTION_CONFIG_PAGE); + + /* Making crosspoint connections, by connecting required + * input to output */ + for (i = 0; i < num_con ; i++) + i2c_reg_write(vsc_addr, con_arr[i][1], con_arr[i][0]); + + /* input state - page 0x13 */ + i2c_reg_write(vsc_addr, CURRENT_PAGE_REGISTER, INPUT_STATE_REG); + /* Configuring the required input of the switch */ + for (i = 0; i < num_con ; i++) + i2c_reg_write(vsc_addr, con_arr[i][0], 0x80); + + /* Setting Global Input LOS threshold value */ + i2c_reg_write(vsc_addr, GLOBAL_INPUT_LOS, 0x60); + + /* config output mode - page 0x23 */ + i2c_reg_write(vsc_addr, CURRENT_PAGE_REGISTER, OUTPUT_MODE_PAGE); + /* Turn ON the Output driver correspond to required output*/ + for (i = 0; i < num_con ; i++) + i2c_reg_write(vsc_addr, con_arr[i][1], 0); + + /* configure global core control register, Turn on Global core power */ + i2c_reg_write(vsc_addr, GLOBAL_CORE_CNTRL, 0); + + vsc_wp_config(vsc_addr); + + return 0; +} + +int vsc3308_config(unsigned int vsc_addr, const int8_t con_arr[][2], + unsigned int num_con) +{ + unsigned int i; + u8 rev_id = 0; + int ret; + + debug("VSC:Initializing VSC3308 at I2C address 0x%x" + " for Tx\n", vsc_addr); + + ret = i2c_read(vsc_addr, REVISION_ID_REG, 1, &rev_id, 1); + if (ret < 0) { + printf("VSC:0x%x could not read REV_ID from device.\n", + vsc_addr); + return ret; + } + + if (rev_id != 0xab) { + printf("VSC: device at address 0x%x is not VSC3316/3308.\n", + vsc_addr); + return -ENODEV; + } + + ret = vsc_if_enable(vsc_addr); + if (ret) { + printf("VSC:0x%x could not configured for 2-wire I/F.\n", + vsc_addr); + return ret; + } + + /* config connections - page 0x00 */ + i2c_reg_write(vsc_addr, CURRENT_PAGE_REGISTER, CONNECTION_CONFIG_PAGE); + + /* Making crosspoint connections, by connecting required + * input to output */ + for (i = 0; i < num_con ; i++) + i2c_reg_write(vsc_addr, con_arr[i][1], con_arr[i][0]); + + /*Configure Global Input ISE and gain */ + i2c_reg_write(vsc_addr, GLOBAL_INPUT_ISE1, 0x12); + i2c_reg_write(vsc_addr, GLOBAL_INPUT_ISE2, 0x12); + + /* input state - page 0x13 */ + i2c_reg_write(vsc_addr, CURRENT_PAGE_REGISTER, INPUT_STATE_REG); + /* Turning ON the required input of the switch */ + for (i = 0; i < num_con ; i++) + i2c_reg_write(vsc_addr, con_arr[i][0], 0); + + /* Setting Global Input LOS threshold value */ + i2c_reg_write(vsc_addr, GLOBAL_INPUT_LOS, 0x60); + + /* config output mode - page 0x23 */ + i2c_reg_write(vsc_addr, CURRENT_PAGE_REGISTER, OUTPUT_MODE_PAGE); + /* Turn ON the Output driver correspond to required output*/ + for (i = 0; i < num_con ; i++) + i2c_reg_write(vsc_addr, con_arr[i][1], 0); + + /* configure global core control register, Turn on Global core power */ + i2c_reg_write(vsc_addr, GLOBAL_CORE_CNTRL, 0); + + vsc_wp_config(vsc_addr); + + return 0; +} + +void vsc_wp_config(unsigned int vsc_addr) +{ + debug("VSC:Configuring VSC at address:0x%x for WP\n", vsc_addr); + + /* For new crosspoint configuration to occur, WP bit of + * CORE_CONFIG_REG should be set 1 and then reset to 0 */ + i2c_reg_write(vsc_addr, CORE_CONFIG_REG, 0x01); + i2c_reg_write(vsc_addr, CORE_CONFIG_REG, 0x0); +} diff --git a/board/freescale/common/vsc3316_3308.h b/board/freescale/common/vsc3316_3308.h new file mode 100644 index 0000000..effd66d --- /dev/null +++ b/board/freescale/common/vsc3316_3308.h @@ -0,0 +1,34 @@ +/* + * Copyright 2012 Freescale Semiconductor, Inc. + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License, or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 59 Temple Place, Suite 330, Boston, + * MA 02111-1307 USA + */ + +#ifndef __VSC_CROSSBAR_H_ +#define __VSC_CROSSBAR_H 1_ + +#include <common.h> +#include <i2c.h> +#include <errno.h> + +int vsc_if_enable(unsigned int vsc_addr); +int vsc3316_config(unsigned int vsc_addr, const int8_t con_arr[][2], + unsigned int num_con); +int vsc3308_config(unsigned int vsc_addr, const int8_t con_arr[][2], + unsigned int num_con); +void vsc_wp_config(unsigned int vsc_addr); + +#endif /* __VSC_CROSSBAR_H_ */ diff --git a/doc/README.VSC3316-3308 b/doc/README.VSC3316-3308 new file mode 100644 index 0000000..925663b --- /dev/null +++ b/doc/README.VSC3316-3308 @@ -0,0 +1,43 @@ +This file contains API information of the initialization code written for +Vitesse cross-point devices, VSC3316 and VSC3308 for board B4860QDS + +Author: Shaveta Leekha shaveta@freescale.com + +About Device: +============= +VSC 3316/3308 is a low-power, low-cost asynchronous crosspoint switch capable of data rates upto 11.5Gbps. + +VSC3316 has 16 input and 16 output ports whereas VSC3308 has 8 input and 8 output ports. Programming of these devices are performed by two-wire or four-wire serial interface. + +Initialization: +=============== +On reset, VSC devices are in low-power state with all inputs, outputs and connections in an off state. +First thing required is to program it to interface with either two-wire or four-wire interface. +In our case the interface is two-wire I2C serial interface. So the value in Interface mode register at address 79.h to be written is 0x02 for two-wire interface. Also for crosspoint connections to be activated, 01.h value need to be written in 75.h (core configuration register). + +API Overview: +============= + + vsc_if_enable(u8 vsc_addr): + -------------------------- + This API programs VSC to interface with either two-wire or four-wire interface. In our case the interface is two-wire I2C serial interface. So the value in Interface mode register at address 79.h to be written is 0x02 for two-wire interface. + Parameters: + vsc_addr - Address of the VSC device on board. + + + vsc3316_config(u8 vsc_addr, int con_arr[][2], u8 num_con): + --------------------------------------------------------- + This API configures the VSC3316 device for required connections. Connection through the VSC device requires the inputs and outputs to be properly configured. + Connection registers are on page 00. It Configures the selected input and output correctly and join them to make a connection. It also program Input state register, Global input ISE, Global input LOS, Global core control, Output mode register and core control registers etc. + vsc3308_config(u8 vsc_addr, int con_arr[][2], u8 num_con) does the essential configurations for VSC3308. + + Parameters: + vsc_addr - Address of the VSC device on board. + con_arr - connection array + num_con - number of connections to be configured + + vsc_wp_config(u8 vsc_addr): + -------------------------- + For crosspoint connections to be activated, 01.h value need to be written in 75.h (core configuration register), which is done by this API. + Parameters: + vsc_addr - Address of the VSC device on board.
Hi York,
Applied, thanks.
-Joe
Joe Hershberger
York Sun
