[U-Boot-Users] Re: u-boot debugging boot with gdb and bdi2000 in lubbock(PXA255) board
Dear Wolfgang
I followed your advice, but they doesn't work for me:
[u-boot-0.4.6]$ arm-linux-gdb u-boot GNU gdb 5.1.1 Copyright 2002 Free Software Foundation, Inc. GDB is free software, covered by the GNU General Public License, and you are welcome to change it and/or distribute copies of it under certain conditions. Type "show copying" to see the conditions. There is absolutely no warranty for GDB. Type "show warranty" for details. This GDB was configured as "--host=i386-redhat-linux --target=arm-linux"... (gdb) target remote bdi:2001 Remote debugging using bdi:2001 0x00000000 in ?? () (gdb) symbol-file Discard symbol table from `/home/sorio/Devel/UBoot/u-boot-0.4.6/u-boot'? (y or n) y No symbol file now. (gdb) add-symbol-file u-boot 0x0 add symbol table from file "u-boot" at .text_addr = 0x0 (y or n) y Reading symbols from u-boot...done. (gdb) b start_armboot Breakpoint 1 at 0x80000cb4: file board.c, line 214. (gdb) x/16i 0x0 0x0: b 0x54 0x4: ldr pc, [pc, #20] ; 0x20 0x8: ldr pc, [pc, #20] ; 0x24 0xc: ldr pc, [pc, #20] ; 0x28 0x10: ldr pc, [pc, #20] ; 0x2c 0x14: ldr pc, [pc, #20] ; 0x30 0x18: ldr pc, [pc, #20] ; 0x34 0x1c: ldr pc, [pc, #20] ; 0x38 0x20: andmi r0, r0, r0, lsl #2 0x24: andmi r0, r0, r0, ror #2 0x28: andmi r0, r0, r0, asr #3 0x2c: andmi r0, r0, r0, lsr #4 0x30: andmi r0, r0, r0, lsl #5 0x34: andmi r0, r0, r0, ror #5 0x38: andmi r0, r0, r0, asr #6 0x3c: cdple 14, 10, cr11, cr13, cr15, {7} (gdb)
The breackpoint is set to "0x80000cb4", so the bdi never stop! My code is built to run on 0x40000000 address. Any idea?
Thank you in advance
Best Regards
Andrea Sorio
In message <3F575E48.1060507@na...> you wrote:
Thanks Wolfgang and Kyle for your advice. Now, I can debug the boot process from the first instruction. Finally I've created two binaries: u-boot to execute and u-boot.debug (with TEXTBASE=0x0), to debug the first part of boot process. When the boot process arrives to the start_armboot function, I discard the current symbol file(u-boot.debug) and load the new one(u-boot).
You don't need to recompile or relink with TEXTBASE=0x0; the "add-symbol-file" GDB command allows you to specify an arbitrary target address.
Dear Andrea,
Well, I can only speculate...
Where did you get this version of a cross debugger from?
It seems to me that your GDB is broken.
Some versions don't know how to deal with a 0x0 address because they confuse this with a NULL pointer.
That's a bug in GDB.
Dear Wolfgang
I installed your ELDK! :-)
Best regards
Andrea
Dear Andrea,
Yes, this version is still broken.
I think it will be fixed in the next release of the ELDK.
Hello Andrea,
It is just something I seem to remember, but can you try to do the symbol-file manipulations _before_ you give the "target remote" command? I know it sounds unlikely, but I think I stumbled across something like this before.
Cheers Detlev
Andrea Sorio
Detlev Zundel
