[U-Boot] [PATCH 3/5] ARM: EXYNOS: add exynos lcd clock interface
To get lcd source clock in EXYNOS display driver, added get_lcd_clk() interface.
Signed-off-by: Donghwa Lee dh09.lee@samsung.com Signed-off-by: Inki Dae inki.dae@samsung.com Signed-off-by: Kyungmin Park kyungmin.park@samsung.com --- arch/arm/cpu/armv7/exynos/clock.c | 50 +++++++++++++++++++++++++++++++++++++ 1 files changed, 50 insertions(+), 0 deletions(-)
diff --git a/arch/arm/cpu/armv7/exynos/clock.c b/arch/arm/cpu/armv7/exynos/clock.c index 2f7048b..af66d5c 100644 --- a/arch/arm/cpu/armv7/exynos/clock.c +++ b/arch/arm/cpu/armv7/exynos/clock.c @@ -414,6 +414,51 @@ static void exynos5_set_mmc_clk(int dev_index, unsigned int div) writel(val, addr); }
+/* get_lcd_clk: return lcd clock frequency */ +static unsigned long exynos4_get_lcd_clk(void) +{ + struct exynos4_clock *clk = + (struct exynos4_clock *)samsung_get_base_clock(); + unsigned long pclk, sclk; + unsigned int sel; + unsigned int ratio; + + /* + * CLK_SRC_LCD0 + * FIMD0_SEL [3:0] + */ +#if defined(CONFIG_EXYNOS4210) + sel = readl(&clk->src_lcd0); +#else + sel = readl(&clk->src_lcd); +#endif + sel = sel & 0xf; + + if (sel == 0x6) + sclk = get_pll_clk(MPLL); + else if (sel == 0x7) + sclk = get_pll_clk(EPLL); + else if (sel == 0x8) + sclk = get_pll_clk(VPLL); + else + return 0; + + /* + * CLK_DIV_LCD0 + * FIMD0_RATIO [3:0] + */ +#if defined(CONFIG_EXYNOS4210) + ratio = readl(&clk->div_lcd0); +#else + ratio = readl(&clk->div_lcd); +#endif + ratio = ratio & 0xf; + + pclk = sclk / (ratio + 1); + + return pclk; +} + unsigned long get_pll_clk(int pllreg) { if (cpu_is_exynos5()) @@ -453,3 +498,8 @@ void set_mmc_clk(int dev_index, unsigned int div) else exynos4_set_mmc_clk(dev_index, div); } + +unsigned long get_lcd_clk(void) +{ + return exynos4_get_lcd_clk(); +}
Donghwa,
- struct exynos4_clock *clk =
- (struct exynos4_clock *)samsung_get_base_clock();
- unsigned long pclk, sclk;
- unsigned int sel;
- unsigned int ratio;
- * CLK_SRC_LCD0
- * FIMD0_SEL [3:0]
- sel = readl(&clk->src_lcd0);
+#else
- sel = readl(&clk->src_lcd);
You should split the function for exynos4 and exynos5. Please don't use ifdef.
- sel = sel & 0xf;
- if (sel == 0x6)
- sclk = get_pll_clk(MPLL);
- else if (sel == 0x7)
- sclk = get_pll_clk(EPLL);
- else if (sel == 0x8)
- sclk = get_pll_clk(VPLL);
- else
- * CLK_DIV_LCD0
- * FIMD0_RATIO [3:0]
- ratio = readl(&clk->div_lcd0);
+#else
- ratio = readl(&clk->div_lcd);
- ratio = ratio & 0xf;
- pclk = sclk / (ratio + 1);
- return pclk;
- return exynos4_get_lcd_clk();
Thanks. Minkyu Kang.
Donghwa Lee
Minkyu Kang
