[U-Boot] Please pull u-boot-ti master
The following changes since commit 5415337f0746123c75b28044ea487171b79a86a2: Simon Kagstrom (1): arm: Correct build with CONFIG_SYS_HUSH_PARSER set
git://git.denx.de/u-boot-ti master
David Brownell (1): TI OMAP3 SDP3430: Initial Support
Nishanth Menon (4): OMAP3: export enable_gpmc_cs_config to board files OMAP3: fix warnings when NAND/ONENAND is not used OMAP3: Fix SDRC init TI OMAP3: make gpmc_config as const
Sandeep Paulraj (13): TI DaVinci DM355: Fix Compilation warning for DM355 EVM TI DaVinci DM365: Fix Compilation warning for DM365 EVM TI DaVinci DM646x: Adding initial support for DM6467 EVM TI: DaVinci: DM355 Leopard board support TI DaVinci: Maintainer for DM355 and DM365 EVM TI: OMAP3: Remove SZ_xx references TI DaVinci DM355: Add Config option for 64 bit Support TI DaVinci DM365: Add Config option for 64 bit Support TI DaVinci DVEVM: Add Config option for 64 bit Support TI DaVinci Sonata: Add Config option for 64 bit Support TI DaVinci: DM355 Leopard: Fix compilation warning TI DaVinci: Fix DM6467 EVM Compilation Warning TI DaVinci: Adding Copyright for DM365 EVM
Steve Sakoman (2): TI: OMAP3: Refactors the SM911x driver OMAP3: Update Overo and Beagle environment
Tom Rix (1): Zoom2 Fix serial gpmc setup
MAINTAINERS | 8 + MAKEALL | 3 + Makefile | 9 + board/davinci/dm355evm/dm355evm.c | 4 +- board/davinci/dm355leopard/Makefile | 52 ++++ board/davinci/dm355leopard/config.mk | 6 + board/davinci/dm355leopard/dm355leopard.c | 98 +++++++ board/davinci/dm365evm/dm365evm.c | 5 +- board/davinci/dm6467evm/Makefile | 52 ++++ board/davinci/dm6467evm/config.mk | 2 + board/davinci/dm6467evm/dm6467evm.c | 31 +++ board/logicpd/zoom2/zoom2.c | 5 +- board/ti/sdp3430/Makefile | 49 ++++ board/ti/sdp3430/config.mk | 33 +++ board/ti/sdp3430/sdp.c | 204 ++++++++++++++ board/ti/sdp3430/sdp.h | 417 +++++++++++++++++++++++++++++ cpu/arm_cortexa8/omap3/mem.c | 21 +- cpu/arm_cortexa8/omap3/sys_info.c | 2 +- drivers/net/smc911x.c | 12 +- include/asm-arm/arch-davinci/hardware.h | 2 + include/asm-arm/arch-omap3/cpu.h | 1 + include/asm-arm/arch-omap3/mem.h | 8 +- include/asm-arm/arch-omap3/sys_proto.h | 2 + include/configs/davinci_dm355evm.h | 1 + include/configs/davinci_dm355leopard.h | 162 +++++++++++ include/configs/davinci_dm365evm.h | 2 + include/configs/davinci_dm6467evm.h | 132 +++++++++ include/configs/davinci_dvevm.h | 1 + include/configs/davinci_sonata.h | 1 + include/configs/devkit8000.h | 15 +- include/configs/omap3_beagle.h | 42 ++-- include/configs/omap3_evm.h | 15 +- include/configs/omap3_overo.h | 42 ++-- include/configs/omap3_pandora.h | 15 +- include/configs/omap3_sdp3430.h | 369 +++++++++++++++++++++++++ include/configs/omap3_zoom1.h | 15 +- include/configs/omap3_zoom2.h | 15 +- 37 files changed, 1754 insertions(+), 99 deletions(-) create mode 100644 board/davinci/dm355leopard/Makefile create mode 100644 board/davinci/dm355leopard/config.mk create mode 100644 board/davinci/dm355leopard/dm355leopard.c create mode 100644 board/davinci/dm6467evm/Makefile create mode 100644 board/davinci/dm6467evm/config.mk create mode 100644 board/davinci/dm6467evm/dm6467evm.c create mode 100644 board/ti/sdp3430/Makefile create mode 100644 board/ti/sdp3430/config.mk create mode 100644 board/ti/sdp3430/sdp.c create mode 100644 board/ti/sdp3430/sdp.h create mode 100644 include/configs/davinci_dm355leopard.h create mode 100644 include/configs/davinci_dm6467evm.h create mode 100644 include/configs/omap3_sdp3430.h
I will try to do this asap, likely tonight. There are some singleton patches that also need to be merged and then I think will will be good for v4 of the pull request to mainline.
Tom
s-paulraj@ti.com
Tom Rix
