[U-Boot] [PATCH] omap3_igep00x0.h: Drop SPL MMC support on BOOT_NAND
In the case of booting from NAND on these boards, remove MMC support from SPL so that we can continue to fit into the safest partitioning of the available SRAM.
Reported-by: Heiko Schocher hs@denx.de Cc: Enric Balletbo i Serra eballetbo@gmail.com Signed-off-by: Tom Rini trini@konsulko.com --- include/configs/omap3_igep00x0.h | 10 ++++++++++ 1 file changed, 10 insertions(+)
diff --git a/include/configs/omap3_igep00x0.h b/include/configs/omap3_igep00x0.h index 5e33845..3cdee02 100644 --- a/include/configs/omap3_igep00x0.h +++ b/include/configs/omap3_igep00x0.h @@ -20,6 +20,16 @@ #include <asm/mach-types.h>
/* + * Remove non-NAND boot modes. + */ +#ifdef CONFIG_BOOT_NAND +#undef CONFIG_SPL_LIBDISK_SUPPORT +#undef CONFIG_SPL_MMC_SUPPORT +#undef CONFIG_SPL_FAT_SUPPORT +#undef CONFIG_SPL_EXT_SUPPORT +#endif + +/* * Display CPU and Board information */ #define CONFIG_DISPLAY_CPUINFO 1
Hi Tom,
2016-04-25 16:44 GMT+02:00 Tom Rini trini@konsulko.com:
- Remove non-NAND boot modes.
Hmm, this will break boot from a sdcard, on IGEP the same SPL binary is used to boot from flash or sdcard. The reason why we have two defconfigs is to select if the board has a ONENAND (igep00xx_defconfig) or a NAND (igep00xx_nand_defconfig) but both must have support for MMC.
- Display CPU and Board information
1.9.1
On Mon, Apr 25, 2016 at 05:09:50PM +0200, Enric Balletbo Serra wrote:
Hi Tom,
Ah, OK. So the next thing to do is see about changing CONFIG_SPL_MAX_SIZE. Or if you don't use SPL EXT2/4 support already, perhaps drop that?
Hi Tom,
2016-04-25 17:16 GMT+02:00 Tom Rini trini@konsulko.com:
Hi Tom,
We're really close to the limit, current size with my compiler is 57312. I saw that SPL_MAX_SIZE is set 54K in include/configs/ti_omap3_common.h, maybe we can grow a bit more the max SPL size?
I will take a look what I'm not using but indeed EXT2/4 is not used at the moment in SPL.
Regards, - Enric
-- Tom
On Tue, Apr 26, 2016 at 10:20:47AM +0200, Enric Balletbo Serra wrote:
Hi Tom,
Hi Tom,
So, the quick math I did said that if we also move stack into DDR once it is enabled, we should probably be fine using 59392 bytes of memory (0xF000-0x800) and ~4kb stack. But the thing in doc/README.SPL about counting stack should be done at least once to be sure. If you're happy about making the change just for your boards for this release, that's OK with me.
