[U-Boot] Compiling UBOOT for MIPS (Reference AP143 board)
I am trying to get a uboot image for a AP143 reference board (Mips)
The "make" gives the error below
Can you help ?
Thank you
[root/ u-boot]# make menuconfig scripts/kconfig/mconf Kconfig configuration written to .config
*** End of the configuration. *** Execute 'make' to start the build or try 'make help'.
[root/ u-boot]# make scripts/kconfig/conf --syncconfig Kconfig CHK include/config.h UPD include/config.h CFG u-boot.cfg gcc: error: unrecognized argument in option '-mabi=32' gcc: note: valid arguments to '-mabi=' are: ms sysv gcc: error: 0: No such file or directory gcc: error: unrecognized command line option '-EB'; did you mean '-B'? gcc: error: unrecognized command line option '-G' gcc: error: unrecognized command line option '-mno-abicalls'; did you mean '-Wno-abi'? make[1]: *** [scripts/Makefile.autoconf:77: u-boot.cfg] Error 1 make: *** No rule to make target 'include/config/auto.conf', needed by 'include/config/uboot.release'. Stop.
anyone ?
Can you help ?
Thank you
[root/ u-boot]# make scripts/kconfig/conf --syncconfig Kconfig CHK include/config.h UPD include/config.h CFG u-boot.cfg gcc: error: unrecognized argument in option '-mabi=32' gcc: note: valid arguments to '-mabi=' are: ms sysv gcc: error: 0: No such file or directory gcc: error: unrecognized command line option '-EB'; did you mean '-B'? gcc: error: unrecognized command line option '-G' gcc: error: unrecognized command line option '-mno-abicalls'; did you mean '-Wno-abi'? make[1]: *** [scripts/Makefile.autoconf:77: u-boot.cfg] Error 1 make: *** No rule to make target 'include/config/auto.conf', needed by 'include/config/uboot.release'. Stop. _______________________________________________ U-Boot mailing list U-Boot@lists.denx.de https://lists.denx.de/listinfo/u-boot
Joan Moreau
