[U-Boot] DCache in designware.c brakes bf609-ezkit board build
Hi Alexey,
Your commit 50b0df814b0f75c08a3d45a017016a75af3edb5d caused drivers/net/designware.c to be dependent on dcache functionality, e.g. invalidate_dcache_range(). This brakes build for configurations that don't have this implemented. For example the blackfin based "bf609-ezkit" board does not build now since it uses designware.c but there is no dcache related stuff for the blackfin arch.
What do you see as the right solution for this? Implement some stub functions for dcache on blackfin? #ifdef the dcache calls in designware.c? If the later, what CONFIG conditions are the best to use?
Looking forward for your opinion.
Best, Vasili
Hi Vasili,
On Wed, 2014-06-25 at 15:38 +0300, Vasili Galka wrote:
Hi Alexey,
When I added dcache invalidation/flush functions in DW GMAC driver I expected that all arches have real or stub functions for cache operations.
So IMHO the simplest solution is to implement stub functions for blackfin.
But then maybe it's time to look a bit broader and implement generic stub functions for cache operations and declare them "weak". This will immediately obsolete requirement of per-arch stubs... well and hopefully all existing stubs for arches will be removed - this would also benefit entire U-Boot project making sources a bit more tiny.
Let me know if either option above works for you and if you need any help from my side.
-Alexey
Alexey Brodkin
Vasili Galka
