Re: [U-Boot] [PATCH v2] armv8/ls2080a: configure PMU's PCTBENR to enable WDT
-----Original Message----- From: Yunhui Cui B56489@freescale.com Date: Sun, Apr 10, 2016 at 9:37 PM Subject: [U-Boot] [PATCH v2] armv8/ls2080a: configure PMU's PCTBENR to enable WDT To: york.sun@nxp.com Cc: yunhui.cui@nxp.com, u-boot@lists.denx.de
The SP805-WDT module on LS2080A and LS2085A, requires configuration of PMU's PCTBENR register to enable watchdog counter decrement and reset signal generation. In order not to affect the sp805wdt driver frame, we enable the watchdog clk in advance.
Signed-off-by: Yunhui Cui yunhui.cui@nxp.com
arch/arm/cpu/armv8/fsl-layerscape/soc.c | 17 +++++++++++++++++ arch/arm/include/asm/arch-fsl-layerscape/config.h | 4 ++++ arch/arm/include/asm/arch-fsl-layerscape/soc.h | 1 + board/freescale/ls2080aqds/ls2080aqds.c | 2 ++ board/freescale/ls2080ardb/ls2080ardb.c | 2 ++ 5 files changed, 26 insertions(+)
diff --git a/arch/arm/cpu/armv8/fsl-layerscape/soc.c b/arch/arm/cpu/armv8/fsl-layerscape/soc.c index a76447e..e6f3566 100644 --- a/arch/arm/cpu/armv8/fsl-layerscape/soc.c +++ b/arch/arm/cpu/armv8/fsl-layerscape/soc.c @@ -17,6 +17,23 @@ #endif
DECLARE_GLOBAL_DATA_PTR; +#if defined(CONFIG_LS2080A) || defined(CONFIG_LS2085A)
Yunhui, I thought that York recently sent patches to get rid of CONFIG_LS2085A.
See the patch: [PATCH v3] armv8: LS2080A: Consolidate LS2080A and LS2085A
- There are eight SP805 watchdog units on ls2080a/ls2085a,So
- Set PMU-Physical Core Time Base Enable Register (PCTBENR)
- low eight bits to enable clocks to eight Cortext-A57 cores
- timebase, which allows the WDT counter to decrement and raise
- a reset request (if configured in the WDTCONTROL register).
I think this is getting too specific and adds unnecessary details. What if we have A72 cores? ...as we will soon. What about other SoCs? Just say:
/* * In certain Layerscape SoCs, the clock for each core's watchdog * has an enable bit in the PMU Physical Core Time Base Enable Register * PCTBENR), which allows the watchdog to operate. */
Thanks, Stuart
Hi Stuart,
Yunhui, I thought that York recently sent patches to get rid of CONFIG_LS2085A. [Yunhui] Only need add #if defined(CONFIG_LS2080A) ?
/* * In certain Layerscape SoCs, the clock for each core's watchdog * has an enable bit in the PMU Physical Core Time Base Enable Register * PCTBENR), which allows the watchdog to operate. */ [Yunhui] That's ok ,thanks!
Thanks Yunhui
-----Original Message----- From: Stuart Yoder Sent: Friday, April 15, 2016 12:34 AM To: Yunhui Cui Cc: york sun; u-boot@lists.denx.de Subject: RE: [U-Boot] [PATCH v2] armv8/ls2080a: configure PMU's PCTBENR to enable WDT
Thanks, Stuart
-----Original Message----- From: Yunhui Cui Sent: Thursday, April 14, 2016 8:47 PM To: Stuart Yoder stuart.yoder@nxp.com Cc: york sun york.sun@nxp.com; u-boot@lists.denx.de Subject: RE: [U-Boot] [PATCH v2] armv8/ls2080a: configure PMU's PCTBENR to enable WDT
Hi Stuart,
Right.
Looks like I missed an openening parenthesis in my suggestion.
Thanks, Stuart
Hi Stuart,
Thanks for your suggestions about the patch, I will update it in v3 version.
Thanks Yunhui
-----Original Message----- From: Stuart Yoder Sent: Friday, April 15, 2016 10:16 AM To: Yunhui Cui Cc: york sun; u-boot@lists.denx.de Subject: RE: [U-Boot] [PATCH v2] armv8/ls2080a: configure PMU's PCTBENR to enable WDT
Hi Stuart,
Right.
Thanks, Stuart
Stuart Yoder
Yunhui Cui
