[U-Boot] [PATCH] arm64: zynqmp: Add new defconfig for zc1275 revB
From: Siva Durga Prasad Paladugu sivadur@xilinx.com
This patch enables support zc1275 revB board. It has SD added compared to revA. The same configuration will work for RevC boards aswell.
Signed-off-by: Siva Durga Prasad Paladugu sivadur@xilinx.com Signed-off-by: Michal Simek michal.simek@xilinx.com ---
arch/arm/dts/Makefile | 1 + arch/arm/dts/zynqmp-zc1275-revB.dts | 79 +++ .../zynqmp/zynqmp-zc1275-revB/psu_init_gpl.c | 523 ++++++++++++++++++ configs/xilinx_zynqmp_zc1275_revB_defconfig | 56 ++ include/configs/xilinx_zynqmp_zc1275_revB.h | 16 + 5 files changed, 675 insertions(+) create mode 100644 arch/arm/dts/zynqmp-zc1275-revB.dts create mode 100644 board/xilinx/zynqmp/zynqmp-zc1275-revB/psu_init_gpl.c create mode 100644 configs/xilinx_zynqmp_zc1275_revB_defconfig create mode 100644 include/configs/xilinx_zynqmp_zc1275_revB.h
diff --git a/arch/arm/dts/Makefile b/arch/arm/dts/Makefile index 62fbf32a62ab..e11c41da0156 100644 --- a/arch/arm/dts/Makefile +++ b/arch/arm/dts/Makefile @@ -159,6 +159,7 @@ dtb-$(CONFIG_ARCH_ZYNQMP) += \ zynqmp-zc1232-revA.dtb \ zynqmp-zc1254-revA.dtb \ zynqmp-zc1275-revA.dtb \ + zynqmp-zc1275-revB.dtb \ zynqmp-zc1751-xm015-dc1.dtb \ zynqmp-zc1751-xm016-dc2.dtb \ zynqmp-zc1751-xm017-dc3.dtb \ diff --git a/arch/arm/dts/zynqmp-zc1275-revB.dts b/arch/arm/dts/zynqmp-zc1275-revB.dts new file mode 100644 index 000000000000..f694faeeb5c2 --- /dev/null +++ b/arch/arm/dts/zynqmp-zc1275-revB.dts @@ -0,0 +1,79 @@ +// SPDX-License-Identifier: GPL-2.0 +/* + * dts file for Xilinx ZynqMP ZC1275 RevB + * + * (C) Copyright 2018, Xilinx, Inc. + * + * Michal Simek michal.simek@xilinx.com + * Siva Durga Prasad Paladugu sivadur@xilinx.com + */ + +/dts-v1/; + +#include "zynqmp.dtsi" +#include "zynqmp-clk-ccf.dtsi" + +/ { + model = "ZynqMP ZC1275 RevB"; + compatible = "xlnx,zynqmp-zc1275-revB", "xlnx,zynqmp-zc1275", "xlnx,zynqmp"; + + aliases { + serial0 = &uart0; + serial1 = &dcc; + spi0 = &qspi; + mmc0 = &sdhci1; + }; + + chosen { + bootargs = "earlycon"; + stdout-path = "serial0:115200n8"; + }; + + memory@0 { + device_type = "memory"; + reg = <0x0 0x0 0x0 0x80000000>; + }; +}; + +&dcc { + status = "okay"; +}; + +&qspi { + status = "okay"; + flash@0 { + compatible = "m25p80"; /* 32MB */ + #address-cells = <1>; + #size-cells = <1>; + reg = <0x0>; + spi-tx-bus-width = <1>; + spi-rx-bus-width = <4>; + spi-max-frequency = <108000000>; /* Based on DC1 spec */ + partition@qspi-fsbl-uboot { /* for testing purpose */ + label = "qspi-fsbl-uboot"; + reg = <0x0 0x100000>; + }; + partition@qspi-linux { /* for testing purpose */ + label = "qspi-linux"; + reg = <0x100000 0x500000>; + }; + partition@qspi-device-tree { /* for testing purpose */ + label = "qspi-device-tree"; + reg = <0x600000 0x20000>; + }; + partition@qspi-rootfs { /* for testing purpose */ + label = "qspi-rootfs"; + reg = <0x620000 0x5E0000>; + }; + }; +}; + +&uart0 { + status = "okay"; +}; + +&sdhci1 { + status = "okay"; + no-1-8-v; + xlnx,mio_bank = <1>; +}; diff --git a/board/xilinx/zynqmp/zynqmp-zc1275-revB/psu_init_gpl.c b/board/xilinx/zynqmp/zynqmp-zc1275-revB/psu_init_gpl.c new file mode 100644 index 000000000000..54cc82869820 --- /dev/null +++ b/board/xilinx/zynqmp/zynqmp-zc1275-revB/psu_init_gpl.c @@ -0,0 +1,523 @@ +/* + * (c) Copyright 2015 Xilinx, Inc. All rights reserved. + * + * SPDX-License-Identifier: GPL-2.0+ + */ + +#include <asm/arch/psu_init_gpl.h> +#include <xil_io.h> + +static unsigned long psu_pll_init_data(void) +{ + psu_mask_write(0xFF5E0034, 0xFE7FEDEFU, 0x7E4E2C62U); + psu_mask_write(0xFF5E0030, 0x00717F00U, 0x00013C00U); + psu_mask_write(0xFF5E0030, 0x00000008U, 0x00000008U); + psu_mask_write(0xFF5E0030, 0x00000001U, 0x00000001U); + psu_mask_write(0xFF5E0030, 0x00000001U, 0x00000000U); + mask_poll(0xFF5E0040, 0x00000002U); + psu_mask_write(0xFF5E0030, 0x00000008U, 0x00000000U); + psu_mask_write(0xFF5E0048, 0x00003F00U, 0x00000200U); + psu_mask_write(0xFF5E0024, 0xFE7FEDEFU, 0x7E4B0C82U); + psu_mask_write(0xFF5E0020, 0x00717F00U, 0x00015A00U); + psu_mask_write(0xFF5E0020, 0x00000008U, 0x00000008U); + psu_mask_write(0xFF5E0020, 0x00000001U, 0x00000001U); + psu_mask_write(0xFF5E0020, 0x00000001U, 0x00000000U); + mask_poll(0xFF5E0040, 0x00000001U); + psu_mask_write(0xFF5E0020, 0x00000008U, 0x00000000U); + psu_mask_write(0xFF5E0044, 0x00003F00U, 0x00000300U); + psu_mask_write(0xFD1A0024, 0xFE7FEDEFU, 0x7E4B0C62U); + psu_mask_write(0xFD1A0020, 0x00717F00U, 0x00014200U); + psu_mask_write(0xFD1A0020, 0x00000008U, 0x00000008U); + psu_mask_write(0xFD1A0020, 0x00000001U, 0x00000001U); + psu_mask_write(0xFD1A0020, 0x00000001U, 0x00000000U); + mask_poll(0xFD1A0044, 0x00000001U); + psu_mask_write(0xFD1A0020, 0x00000008U, 0x00000000U); + psu_mask_write(0xFD1A0048, 0x00003F00U, 0x00000300U); + psu_mask_write(0xFD1A0030, 0xFE7FEDEFU, 0x7E4B0C62U); + psu_mask_write(0xFD1A002C, 0x00717F00U, 0x00014800U); + psu_mask_write(0xFD1A002C, 0x00000008U, 0x00000008U); + psu_mask_write(0xFD1A002C, 0x00000001U, 0x00000001U); + psu_mask_write(0xFD1A002C, 0x00000001U, 0x00000000U); + mask_poll(0xFD1A0044, 0x00000002U); + psu_mask_write(0xFD1A002C, 0x00000008U, 0x00000000U); + psu_mask_write(0xFD1A004C, 0x00003F00U, 0x00000300U); + psu_mask_write(0xFD1A003C, 0xFE7FEDEFU, 0x7E4B0C62U); + psu_mask_write(0xFD1A0038, 0x00717F00U, 0x00014000U); + psu_mask_write(0xFD1A0038, 0x00000008U, 0x00000008U); + psu_mask_write(0xFD1A0038, 0x00000001U, 0x00000001U); + psu_mask_write(0xFD1A0038, 0x00000001U, 0x00000000U); + mask_poll(0xFD1A0044, 0x00000004U); + psu_mask_write(0xFD1A0038, 0x00000008U, 0x00000000U); + psu_mask_write(0xFD1A0050, 0x00003F00U, 0x00000200U); + + return 1; +} + +static unsigned long psu_clock_init_data(void) +{ + psu_mask_write(0xFF5E0068, 0x013F3F07U, 0x01010C00U); + psu_mask_write(0xFF5E0070, 0x013F3F07U, 0x01010502U); + psu_mask_write(0xFF18030C, 0x00020000U, 0x00000000U); + psu_mask_write(0xFF5E0074, 0x013F3F07U, 0x01010F00U); + psu_mask_write(0xFF5E0120, 0x013F3F07U, 0x01010F00U); + psu_mask_write(0xFF5E0090, 0x01003F07U, 0x01000302U); + psu_mask_write(0xFF5E009C, 0x01003F07U, 0x01000400U); + psu_mask_write(0xFF5E00A4, 0x01003F07U, 0x01000900U); + psu_mask_write(0xFF5E00A8, 0x01003F07U, 0x01000302U); + psu_mask_write(0xFF5E00AC, 0x01003F07U, 0x01000F02U); + psu_mask_write(0xFF5E00B0, 0x01003F07U, 0x01000602U); + psu_mask_write(0xFF5E00B8, 0x01003F07U, 0x01000302U); + psu_mask_write(0xFF5E00C0, 0x013F3F07U, 0x01010A02U); + psu_mask_write(0xFF5E00C4, 0x013F3F07U, 0x01010402U); + psu_mask_write(0xFF5E00C8, 0x013F3F07U, 0x01010802U); + psu_mask_write(0xFF5E0108, 0x013F3F07U, 0x01011D02U); + psu_mask_write(0xFF5E0104, 0x00000007U, 0x00000000U); + psu_mask_write(0xFF5E0128, 0x01003F07U, 0x01000104U); + psu_mask_write(0xFD1A0060, 0x03003F07U, 0x03000100U); + psu_mask_write(0xFD1A0068, 0x01003F07U, 0x01000200U); + psu_mask_write(0xFD1A0080, 0x00003F07U, 0x00000600U); + psu_mask_write(0xFD1A0084, 0x07003F07U, 0x07000203U); + psu_mask_write(0xFD1A00B8, 0x01003F07U, 0x01000203U); + psu_mask_write(0xFD1A00BC, 0x01003F07U, 0x01000203U); + psu_mask_write(0xFD1A00C0, 0x01003F07U, 0x01000202U); + psu_mask_write(0xFD1A00C4, 0x01003F07U, 0x01000502U); + psu_mask_write(0xFD1A00F8, 0x00003F07U, 0x00000200U); + psu_mask_write(0xFF180380, 0x000000FFU, 0x00000000U); + psu_mask_write(0xFD610100, 0x00000001U, 0x00000000U); + psu_mask_write(0xFF180300, 0x00000001U, 0x00000000U); + psu_mask_write(0xFF410050, 0x00000001U, 0x00000000U); + + return 1; +} + +static unsigned long psu_ddr_init_data(void) +{ + psu_mask_write(0xFD1A0108, 0x00000008U, 0x00000008U); + psu_mask_write(0xFD070000, 0xE30FBE3DU, 0x81040001U); + psu_mask_write(0xFD070010, 0x8000F03FU, 0x00000030U); + psu_mask_write(0xFD070020, 0x000003F3U, 0x00000100U); + psu_mask_write(0xFD070024, 0xFFFFFFFFU, 0x00800000U); + psu_mask_write(0xFD070030, 0x0000007FU, 0x00000000U); + psu_mask_write(0xFD070034, 0x00FFFF1FU, 0x00403210U); + psu_mask_write(0xFD070050, 0x00F1F1F4U, 0x00210000U); + psu_mask_write(0xFD070054, 0x0FFF0FFFU, 0x00000000U); + psu_mask_write(0xFD070060, 0x00000073U, 0x00000001U); + psu_mask_write(0xFD070064, 0x0FFF83FFU, 0x00308034U); + psu_mask_write(0xFD070070, 0x00000017U, 0x00000010U); + psu_mask_write(0xFD070074, 0x00000003U, 0x00000000U); + psu_mask_write(0xFD0700C4, 0x3F000391U, 0x10000200U); + psu_mask_write(0xFD0700C8, 0x01FF1F3FU, 0x0030051FU); + psu_mask_write(0xFD0700D0, 0xC3FF0FFFU, 0x00020063U); + psu_mask_write(0xFD0700D4, 0x01FF7F0FU, 0x00290000U); + psu_mask_write(0xFD0700D8, 0x0000FF0FU, 0x00000E05U); + psu_mask_write(0xFD0700DC, 0xFFFFFFFFU, 0x05200004U); + psu_mask_write(0xFD0700E0, 0xFFFFFFFFU, 0x00000000U); + psu_mask_write(0xFD0700E4, 0x00FF03FFU, 0x00110004U); + psu_mask_write(0xFD0700E8, 0xFFFFFFFFU, 0x00000000U); + psu_mask_write(0xFD0700EC, 0xFFFF0000U, 0x00000000U); + psu_mask_write(0xFD0700F0, 0x0000003FU, 0x00000010U); + psu_mask_write(0xFD0700F4, 0x00000FFFU, 0x0000066FU); + psu_mask_write(0xFD070100, 0x7F3F7F3FU, 0x07080D07U); + psu_mask_write(0xFD070104, 0x001F1F7FU, 0x0005020BU); + psu_mask_write(0xFD070108, 0x3F3F3F3FU, 0x03030607U); + psu_mask_write(0xFD07010C, 0x3FF3F3FFU, 0x00502006U); + psu_mask_write(0xFD070110, 0x1F0F0F1FU, 0x13020206U); + psu_mask_write(0xFD070114, 0x0F0F3F1FU, 0x03030202U); + psu_mask_write(0xFD070118, 0x0F0F000FU, 0x01010003U); + psu_mask_write(0xFD07011C, 0x00000F0FU, 0x00000303U); + psu_mask_write(0xFD070120, 0x7F7F7F7FU, 0x02020909U); + psu_mask_write(0xFD070124, 0x40070F3FU, 0x0004040DU); + psu_mask_write(0xFD07012C, 0x7F1F031FU, 0x440C011CU); + psu_mask_write(0xFD070130, 0x00030F1FU, 0x00020608U); + psu_mask_write(0xFD070180, 0xF7FF03FFU, 0x80800020U); + psu_mask_write(0xFD070184, 0x3FFFFFFFU, 0x02009896U); + psu_mask_write(0xFD070190, 0x1FBFBF3FU, 0x04828202U); + psu_mask_write(0xFD070194, 0xF31F0F0FU, 0x00020304U); + psu_mask_write(0xFD070198, 0x0FF1F1F1U, 0x07000101U); + psu_mask_write(0xFD07019C, 0x000000F1U, 0x00000021U); + psu_mask_write(0xFD0701A0, 0xC3FF03FFU, 0x00400003U); + psu_mask_write(0xFD0701A4, 0x00FF00FFU, 0x00C800FFU); + psu_mask_write(0xFD0701B0, 0x00000007U, 0x00000000U); + psu_mask_write(0xFD0701B4, 0x00003F3FU, 0x00000000U); + psu_mask_write(0xFD0701C0, 0x00000007U, 0x00000000U); + psu_mask_write(0xFD070200, 0x0000001FU, 0x0000001FU); + psu_mask_write(0xFD070204, 0x001F1F1FU, 0x00080808U); + psu_mask_write(0xFD070208, 0x0F0F0F0FU, 0x00000000U); + psu_mask_write(0xFD07020C, 0x0F0F0F0FU, 0x00000000U); + psu_mask_write(0xFD070210, 0x00000F0FU, 0x00000F0FU); + psu_mask_write(0xFD070214, 0x0F0F0F0FU, 0x070F0707U); + psu_mask_write(0xFD070218, 0x8F0F0F0FU, 0x0F070707U); + psu_mask_write(0xFD07021C, 0x00000F0FU, 0x00000F0FU); + psu_mask_write(0xFD070220, 0x00001F1FU, 0x00000000U); + psu_mask_write(0xFD070224, 0x0F0F0F0FU, 0x07070707U); + psu_mask_write(0xFD070228, 0x0F0F0F0FU, 0x07070707U); + psu_mask_write(0xFD07022C, 0x0000000FU, 0x00000007U); + psu_mask_write(0xFD070240, 0x0F1F0F7CU, 0x06000604U); + psu_mask_write(0xFD070244, 0x00003333U, 0x00000001U); + psu_mask_write(0xFD070250, 0x7FFF3F07U, 0x01002001U); + psu_mask_write(0xFD070264, 0xFF00FFFFU, 0x08000040U); + psu_mask_write(0xFD07026C, 0xFF00FFFFU, 0x08000040U); + psu_mask_write(0xFD070280, 0xFFFFFFFFU, 0x00000000U); + psu_mask_write(0xFD070284, 0xFFFFFFFFU, 0x00000000U); + psu_mask_write(0xFD070288, 0xFFFFFFFFU, 0x00000000U); + psu_mask_write(0xFD07028C, 0xFFFFFFFFU, 0x00000000U); + psu_mask_write(0xFD070290, 0x0000FFFFU, 0x00000000U); + psu_mask_write(0xFD070294, 0x00000001U, 0x00000001U); + psu_mask_write(0xFD070300, 0x00000011U, 0x00000000U); + psu_mask_write(0xFD07030C, 0x80000033U, 0x00000000U); + psu_mask_write(0xFD070320, 0x00000001U, 0x00000000U); + psu_mask_write(0xFD070400, 0x00000111U, 0x00000001U); + psu_mask_write(0xFD070404, 0x000073FFU, 0x0000200FU); + psu_mask_write(0xFD070408, 0x000073FFU, 0x0000200FU); + psu_mask_write(0xFD070490, 0x00000001U, 0x00000001U); + psu_mask_write(0xFD070494, 0x0033000FU, 0x0020000BU); + psu_mask_write(0xFD070498, 0x07FF07FFU, 0x00000000U); + psu_mask_write(0xFD0704B4, 0x000073FFU, 0x0000200FU); + psu_mask_write(0xFD0704B8, 0x000073FFU, 0x0000200FU); + psu_mask_write(0xFD070540, 0x00000001U, 0x00000001U); + psu_mask_write(0xFD070544, 0x03330F0FU, 0x02000B03U); + psu_mask_write(0xFD070548, 0x07FF07FFU, 0x00000000U); + psu_mask_write(0xFD070564, 0x000073FFU, 0x0000200FU); + psu_mask_write(0xFD070568, 0x000073FFU, 0x0000200FU); + psu_mask_write(0xFD0705F0, 0x00000001U, 0x00000001U); + psu_mask_write(0xFD0705F4, 0x03330F0FU, 0x02000B03U); + psu_mask_write(0xFD0705F8, 0x07FF07FFU, 0x00000000U); + psu_mask_write(0xFD070614, 0x000073FFU, 0x0000200FU); + psu_mask_write(0xFD070618, 0x000073FFU, 0x0000200FU); + psu_mask_write(0xFD0706A0, 0x00000001U, 0x00000001U); + psu_mask_write(0xFD0706A4, 0x0033000FU, 0x00100003U); + psu_mask_write(0xFD0706A8, 0x07FF07FFU, 0x0000004FU); + psu_mask_write(0xFD0706AC, 0x0033000FU, 0x00100003U); + psu_mask_write(0xFD0706B0, 0x000007FFU, 0x0000004FU); + psu_mask_write(0xFD0706C4, 0x000073FFU, 0x0000200FU); + psu_mask_write(0xFD0706C8, 0x000073FFU, 0x0000200FU); + psu_mask_write(0xFD070750, 0x00000001U, 0x00000001U); + psu_mask_write(0xFD070754, 0x0033000FU, 0x00100003U); + psu_mask_write(0xFD070758, 0x07FF07FFU, 0x0000004FU); + psu_mask_write(0xFD07075C, 0x0033000FU, 0x00100003U); + psu_mask_write(0xFD070760, 0x000007FFU, 0x0000004FU); + psu_mask_write(0xFD070774, 0x000073FFU, 0x0000200FU); + psu_mask_write(0xFD070778, 0x000073FFU, 0x0000200FU); + psu_mask_write(0xFD070800, 0x00000001U, 0x00000001U); + psu_mask_write(0xFD070804, 0x0033000FU, 0x00100003U); + psu_mask_write(0xFD070808, 0x07FF07FFU, 0x0000004FU); + psu_mask_write(0xFD07080C, 0x0033000FU, 0x00100003U); + psu_mask_write(0xFD070810, 0x000007FFU, 0x0000004FU); + psu_mask_write(0xFD070F04, 0x000001FFU, 0x00000000U); + psu_mask_write(0xFD070F08, 0x000000FFU, 0x00000000U); + psu_mask_write(0xFD070F0C, 0x000001FFU, 0x00000010U); + psu_mask_write(0xFD070F10, 0x000000FFU, 0x0000000FU); + psu_mask_write(0xFD072190, 0x1FBFBF3FU, 0x07828002U); + psu_mask_write(0xFD1A0108, 0x0000000CU, 0x00000000U); + psu_mask_write(0xFD080010, 0xFFFFFFFFU, 0x07001E00U); + psu_mask_write(0xFD080018, 0xFFFFFFFFU, 0x00F05D90U); + psu_mask_write(0xFD08001C, 0xFFFFFFFFU, 0x55AA5480U); + psu_mask_write(0xFD080024, 0xFFFFFFFFU, 0x010100F4U); + psu_mask_write(0xFD080040, 0xFFFFFFFFU, 0x1900C810U); + psu_mask_write(0xFD080044, 0xFFFFFFFFU, 0x4E200708U); + psu_mask_write(0xFD080068, 0xFFFFFFFFU, 0x06124000U); + psu_mask_write(0xFD080090, 0xFFFFFFFFU, 0x02A04061U); + psu_mask_write(0xFD0800C0, 0xFFFFFFFFU, 0x00000000U); + psu_mask_write(0xFD0800C4, 0xFFFFFFFFU, 0x000000DAU); + psu_mask_write(0xFD080100, 0xFFFFFFFFU, 0x0800040BU); + psu_mask_write(0xFD080110, 0xFFFFFFFFU, 0x040E0A04U); + psu_mask_write(0xFD080114, 0xFFFFFFFFU, 0x28100004U); + psu_mask_write(0xFD080118, 0xFFFFFFFFU, 0x000F0200U); + psu_mask_write(0xFD08011C, 0xFFFFFFFFU, 0x82000800U); + psu_mask_write(0xFD080120, 0xFFFFFFFFU, 0x00682B0AU); + psu_mask_write(0xFD080124, 0xFFFFFFFFU, 0x00152504U); + psu_mask_write(0xFD080128, 0xFFFFFFFFU, 0x00000506U); + psu_mask_write(0xFD080140, 0xFFFFFFFFU, 0x08400020U); + psu_mask_write(0xFD080144, 0xFFFFFFFFU, 0x00000C80U); + psu_mask_write(0xFD080150, 0xFFFFFFFFU, 0x00000000U); + psu_mask_write(0xFD080154, 0xFFFFFFFFU, 0x00000000U); + psu_mask_write(0xFD080180, 0xFFFFFFFFU, 0x00000520U); + psu_mask_write(0xFD080184, 0xFFFFFFFFU, 0x00000004U); + psu_mask_write(0xFD080188, 0xFFFFFFFFU, 0x00000000U); + psu_mask_write(0xFD08018C, 0xFFFFFFFFU, 0x00000000U); + psu_mask_write(0xFD080190, 0xFFFFFFFFU, 0x00000000U); + psu_mask_write(0xFD080194, 0xFFFFFFFFU, 0x00000000U); + psu_mask_write(0xFD080198, 0xFFFFFFFFU, 0x00000000U); + psu_mask_write(0xFD0801AC, 0xFFFFFFFFU, 0x00000000U); + psu_mask_write(0xFD0801B0, 0xFFFFFFFFU, 0x0000004DU); + psu_mask_write(0xFD0801B4, 0xFFFFFFFFU, 0x00000008U); + psu_mask_write(0xFD0801B8, 0xFFFFFFFFU, 0x0000004DU); + psu_mask_write(0xFD0801D8, 0xFFFFFFFFU, 0x00000000U); + psu_mask_write(0xFD080200, 0xFFFFFFFFU, 0x800081C7U); + psu_mask_write(0xFD080204, 0xFFFFFFFFU, 0x00010236U); + psu_mask_write(0xFD080240, 0xFFFFFFFFU, 0x00141054U); + psu_mask_write(0xFD080250, 0xFFFFFFFFU, 0x00088000U); + psu_mask_write(0xFD080414, 0xFFFFFFFFU, 0x12340800U); + psu_mask_write(0xFD0804F4, 0xFFFFFFFFU, 0x00000005U); + psu_mask_write(0xFD080500, 0xFFFFFFFFU, 0x30000028U); + psu_mask_write(0xFD080508, 0xFFFFFFFFU, 0x0A000000U); + psu_mask_write(0xFD08050C, 0xFFFFFFFFU, 0x00000009U); + psu_mask_write(0xFD080510, 0xFFFFFFFFU, 0x0A000000U); + psu_mask_write(0xFD080520, 0xFFFFFFFFU, 0x0300B0B0U); + psu_mask_write(0xFD080528, 0xFFFFFFFFU, 0xF1032019U); + psu_mask_write(0xFD08052C, 0xFFFFFFFFU, 0x07F001E3U); + psu_mask_write(0xFD080544, 0xFFFFFFFFU, 0x00000000U); + psu_mask_write(0xFD080548, 0xFFFFFFFFU, 0x00000000U); + psu_mask_write(0xFD080558, 0xFFFFFFFFU, 0x00000000U); + psu_mask_write(0xFD08055C, 0xFFFFFFFFU, 0x00000000U); + psu_mask_write(0xFD080560, 0xFFFFFFFFU, 0x00000000U); + psu_mask_write(0xFD080564, 0xFFFFFFFFU, 0x00000000U); + psu_mask_write(0xFD080680, 0xFFFFFFFFU, 0x0088E858U); + psu_mask_write(0xFD080684, 0xFFFFFFFFU, 0x000077BBU); + psu_mask_write(0xFD080694, 0xFFFFFFFFU, 0x01E10210U); + psu_mask_write(0xFD080698, 0xFFFFFFFFU, 0x01E10000U); + psu_mask_write(0xFD0806A4, 0xFFFFFFFFU, 0x000076BBU); + psu_mask_write(0xFD080700, 0xFFFFFFFFU, 0x40800604U); + psu_mask_write(0xFD080704, 0xFFFFFFFFU, 0x00007FFFU); + psu_mask_write(0xFD08070C, 0xFFFFFFFFU, 0x3F000008U); + psu_mask_write(0xFD080710, 0xFFFFFFFFU, 0x0E00B00CU); + psu_mask_write(0xFD080714, 0xFFFFFFFFU, 0x09093030U); + psu_mask_write(0xFD080718, 0xFFFFFFFFU, 0x09092B2BU); + psu_mask_write(0xFD080800, 0xFFFFFFFFU, 0x40800604U); + psu_mask_write(0xFD080804, 0xFFFFFFFFU, 0x00007FFFU); + psu_mask_write(0xFD08080C, 0xFFFFFFFFU, 0x3F000008U); + psu_mask_write(0xFD080810, 0xFFFFFFFFU, 0x0E00B00CU); + psu_mask_write(0xFD080814, 0xFFFFFFFFU, 0x09093030U); + psu_mask_write(0xFD080818, 0xFFFFFFFFU, 0x09092B2BU); + psu_mask_write(0xFD080900, 0xFFFFFFFFU, 0x40800604U); + psu_mask_write(0xFD080904, 0xFFFFFFFFU, 0x00007FFFU); + psu_mask_write(0xFD08090C, 0xFFFFFFFFU, 0x3F000008U); + psu_mask_write(0xFD080910, 0xFFFFFFFFU, 0x0E00B00CU); + psu_mask_write(0xFD080914, 0xFFFFFFFFU, 0x09093030U); + psu_mask_write(0xFD080918, 0xFFFFFFFFU, 0x09092B2BU); + psu_mask_write(0xFD080A00, 0xFFFFFFFFU, 0x40800604U); + psu_mask_write(0xFD080A04, 0xFFFFFFFFU, 0x00007FFFU); + psu_mask_write(0xFD080A0C, 0xFFFFFFFFU, 0x3F000008U); + psu_mask_write(0xFD080A10, 0xFFFFFFFFU, 0x0E00B00CU); + psu_mask_write(0xFD080A14, 0xFFFFFFFFU, 0x09093030U); + psu_mask_write(0xFD080A18, 0xFFFFFFFFU, 0x09092B2BU); + psu_mask_write(0xFD080B00, 0xFFFFFFFFU, 0x40800604U); + psu_mask_write(0xFD080B04, 0xFFFFFFFFU, 0x00007FFFU); + psu_mask_write(0xFD080B08, 0xFFFFFFFFU, 0x00000000U); + psu_mask_write(0xFD080B0C, 0xFFFFFFFFU, 0x3F000008U); + psu_mask_write(0xFD080B10, 0xFFFFFFFFU, 0x0E00B004U); + psu_mask_write(0xFD080B14, 0xFFFFFFFFU, 0x09093030U); + psu_mask_write(0xFD080B18, 0xFFFFFFFFU, 0x09092B2BU); + psu_mask_write(0xFD080C00, 0xFFFFFFFFU, 0x40800604U); + psu_mask_write(0xFD080C04, 0xFFFFFFFFU, 0x00007FFFU); + psu_mask_write(0xFD080C08, 0xFFFFFFFFU, 0x00000000U); + psu_mask_write(0xFD080C0C, 0xFFFFFFFFU, 0x3F000008U); + psu_mask_write(0xFD080C10, 0xFFFFFFFFU, 0x0E00B00CU); + psu_mask_write(0xFD080C14, 0xFFFFFFFFU, 0x09093030U); + psu_mask_write(0xFD080C18, 0xFFFFFFFFU, 0x09092B2BU); + psu_mask_write(0xFD080D00, 0xFFFFFFFFU, 0x40800604U); + psu_mask_write(0xFD080D04, 0xFFFFFFFFU, 0x00007FFFU); + psu_mask_write(0xFD080D08, 0xFFFFFFFFU, 0x00000000U); + psu_mask_write(0xFD080D0C, 0xFFFFFFFFU, 0x3F000008U); + psu_mask_write(0xFD080D10, 0xFFFFFFFFU, 0x0E00B004U); + psu_mask_write(0xFD080D14, 0xFFFFFFFFU, 0x09093030U); + psu_mask_write(0xFD080D18, 0xFFFFFFFFU, 0x09092B2BU); + psu_mask_write(0xFD080E00, 0xFFFFFFFFU, 0x40800604U); + psu_mask_write(0xFD080E04, 0xFFFFFFFFU, 0x00007FFFU); + psu_mask_write(0xFD080E08, 0xFFFFFFFFU, 0x00000000U); + psu_mask_write(0xFD080E0C, 0xFFFFFFFFU, 0x3F000008U); + psu_mask_write(0xFD080E10, 0xFFFFFFFFU, 0x0E00B00CU); + psu_mask_write(0xFD080E14, 0xFFFFFFFFU, 0x09093030U); + psu_mask_write(0xFD080E18, 0xFFFFFFFFU, 0x09092B2BU); + psu_mask_write(0xFD080F00, 0xFFFFFFFFU, 0x40803660U); + psu_mask_write(0xFD080F04, 0xFFFFFFFFU, 0x55556000U); + psu_mask_write(0xFD080F08, 0xFFFFFFFFU, 0xAAAAAAAAU); + psu_mask_write(0xFD080F0C, 0xFFFFFFFFU, 0x0029A4A4U); + psu_mask_write(0xFD080F10, 0xFFFFFFFFU, 0x0C00B000U); + psu_mask_write(0xFD080F14, 0xFFFFFFFFU, 0x09093030U); + psu_mask_write(0xFD080F18, 0xFFFFFFFFU, 0x09092B2BU); + psu_mask_write(0xFD081400, 0xFFFFFFFFU, 0x2A019FFEU); + psu_mask_write(0xFD081404, 0xFFFFFFFFU, 0x06124000U); + psu_mask_write(0xFD08141C, 0xFFFFFFFFU, 0x01264300U); + psu_mask_write(0xFD08142C, 0xFFFFFFFFU, 0x00041800U); + psu_mask_write(0xFD081430, 0xFFFFFFFFU, 0x70000000U); + psu_mask_write(0xFD081440, 0xFFFFFFFFU, 0x2A019FFEU); + psu_mask_write(0xFD081444, 0xFFFFFFFFU, 0x06124000U); + psu_mask_write(0xFD08145C, 0xFFFFFFFFU, 0x01264300U); + psu_mask_write(0xFD08146C, 0xFFFFFFFFU, 0x00041800U); + psu_mask_write(0xFD081470, 0xFFFFFFFFU, 0x70000000U); + psu_mask_write(0xFD081480, 0xFFFFFFFFU, 0x2A019FFEU); + psu_mask_write(0xFD081484, 0xFFFFFFFFU, 0x06124000U); + psu_mask_write(0xFD08149C, 0xFFFFFFFFU, 0x01264300U); + psu_mask_write(0xFD0814AC, 0xFFFFFFFFU, 0x00041800U); + psu_mask_write(0xFD0814B0, 0xFFFFFFFFU, 0x70000000U); + psu_mask_write(0xFD0814C0, 0xFFFFFFFFU, 0x2A019FFEU); + psu_mask_write(0xFD0814C4, 0xFFFFFFFFU, 0x06124000U); + psu_mask_write(0xFD0814DC, 0xFFFFFFFFU, 0x01264300U); + psu_mask_write(0xFD0814EC, 0xFFFFFFFFU, 0x00041800U); + psu_mask_write(0xFD0814F0, 0xFFFFFFFFU, 0x70000000U); + psu_mask_write(0xFD081500, 0xFFFFFFFFU, 0x15019FFEU); + psu_mask_write(0xFD081504, 0xFFFFFFFFU, 0x06124000U); + psu_mask_write(0xFD08151C, 0xFFFFFFFFU, 0x01264300U); + psu_mask_write(0xFD08152C, 0xFFFFFFFFU, 0x00041800U); + psu_mask_write(0xFD081530, 0xFFFFFFFFU, 0x70000000U); + psu_mask_write(0xFD0817C4, 0xFFFFFFFFU, 0x06124000U); + psu_mask_write(0xFD0817DC, 0xFFFFFFFFU, 0x012643C4U); + + return 1; +} + +static unsigned long psu_mio_init_data(void) +{ + psu_mask_write(0xFF180000, 0x000000FEU, 0x00000002U); + psu_mask_write(0xFF180004, 0x000000FEU, 0x00000002U); + psu_mask_write(0xFF180010, 0x000000FEU, 0x00000002U); + psu_mask_write(0xFF180014, 0x000000FEU, 0x00000002U); + psu_mask_write(0xFF180018, 0x000000FEU, 0x00000002U); + psu_mask_write(0xFF180088, 0x000000FEU, 0x000000C0U); + psu_mask_write(0xFF18008C, 0x000000FEU, 0x000000C0U); + psu_mask_write(0xFF18009C, 0x000000FEU, 0x00000010U); + psu_mask_write(0xFF1800A0, 0x000000FEU, 0x00000010U); + psu_mask_write(0xFF1800A4, 0x000000FEU, 0x00000010U); + psu_mask_write(0xFF1800A8, 0x000000FEU, 0x00000010U); + psu_mask_write(0xFF1800AC, 0x000000FEU, 0x00000010U); + psu_mask_write(0xFF1800B0, 0x000000FEU, 0x00000010U); + psu_mask_write(0xFF1800B4, 0x000000FEU, 0x00000010U); + psu_mask_write(0xFF1800B8, 0x000000FEU, 0x00000010U); + psu_mask_write(0xFF1800BC, 0x000000FEU, 0x00000010U); + psu_mask_write(0xFF1800C0, 0x000000FEU, 0x00000010U); + psu_mask_write(0xFF1800C4, 0x000000FEU, 0x00000010U); + psu_mask_write(0xFF1800C8, 0x000000FEU, 0x00000010U); + psu_mask_write(0xFF1800CC, 0x000000FEU, 0x00000010U); + psu_mask_write(0xFF180204, 0x0000007FU, 0x00000002U); + psu_mask_write(0xFF180208, 0x000FFF8CU, 0x00003004U); + psu_mask_write(0xFF180138, 0x03FFFFFFU, 0x03FFFFFFU); + psu_mask_write(0xFF18013C, 0x03FFFFFFU, 0x03FFFFFFU); + psu_mask_write(0xFF180140, 0x03FFFFFFU, 0x00000000U); + psu_mask_write(0xFF180144, 0x03FFFFFFU, 0x03FFFFFFU); + psu_mask_write(0xFF180148, 0x03FFFFFFU, 0x03FFFFFFU); + psu_mask_write(0xFF18014C, 0x03FFFFFFU, 0x00000000U); + psu_mask_write(0xFF180154, 0x03FFFFFFU, 0x03FFFFFFU); + psu_mask_write(0xFF180158, 0x03FFFFFFU, 0x03FFFFFFU); + psu_mask_write(0xFF18015C, 0x03FFFFFFU, 0x00000000U); + psu_mask_write(0xFF180160, 0x03FFFFFFU, 0x03FFFFFFU); + psu_mask_write(0xFF180164, 0x03FFFFFFU, 0x03FFFFFFU); + psu_mask_write(0xFF180168, 0x03FFFFFFU, 0x00000000U); + psu_mask_write(0xFF180170, 0x03FFFFFFU, 0x03FFFFFFU); + psu_mask_write(0xFF180174, 0x03FFFFFFU, 0x03FFFFFFU); + psu_mask_write(0xFF180178, 0x03FFFFFFU, 0x00000000U); + psu_mask_write(0xFF18017C, 0x03FFFFFFU, 0x03FFFFFFU); + psu_mask_write(0xFF180180, 0x03FFFFFFU, 0x03FFFFFFU); + psu_mask_write(0xFF180184, 0x03FFFFFFU, 0x00000000U); + psu_mask_write(0xFF180200, 0x0000000FU, 0x00000000U); + + return 1; +} + +static unsigned long psu_peripherals_pre_init_data(void) +{ + psu_mask_write(0xFF5E0108, 0x013F3F07U, 0x00012302U); + + return 1; +} + +static unsigned long psu_peripherals_init_data(void) +{ + psu_mask_write(0xFD1A0100, 0x0000807CU, 0x00000000U); + psu_mask_write(0xFF5E0238, 0x001A0000U, 0x00000000U); + psu_mask_write(0xFF5E023C, 0x0093C018U, 0x00000000U); + psu_mask_write(0xFF5E0238, 0x00000001U, 0x00000000U); + psu_mask_write(0xFF180390, 0x00000004U, 0x00000004U); + psu_mask_write(0xFF5E0238, 0x00000040U, 0x00000000U); + psu_mask_write(0xFF180310, 0x00008000U, 0x00000000U); + psu_mask_write(0xFF180320, 0x33800000U, 0x02800000U); + psu_mask_write(0xFF18031C, 0x7FFE0000U, 0x64500000U); + psu_mask_write(0xFF180358, 0x00000008U, 0x00000008U); + psu_mask_write(0xFF180324, 0x03C00000U, 0x00000000U); + psu_mask_write(0xFF5E0238, 0x00000200U, 0x00000000U); + psu_mask_write(0xFF5E0238, 0x00008000U, 0x00000000U); + psu_mask_write(0xFF5E0238, 0x00000800U, 0x00000000U); + psu_mask_write(0xFF5E0238, 0x00000002U, 0x00000000U); + psu_mask_write(0xFF000034, 0x000000FFU, 0x00000005U); + psu_mask_write(0xFF000018, 0x0000FFFFU, 0x0000008FU); + psu_mask_write(0xFF000000, 0x000001FFU, 0x00000017U); + psu_mask_write(0xFF000004, 0x000003FFU, 0x00000020U); + psu_mask_write(0xFF5E0238, 0x00040000U, 0x00000000U); + psu_mask_write(0xFF4B0024, 0x000000FFU, 0x000000FFU); + psu_mask_write(0xFFCA5000, 0x00001FFFU, 0x00000000U); + psu_mask_write(0xFD5C0060, 0x000F000FU, 0x00000000U); + psu_mask_write(0xFFA60040, 0x80000000U, 0x80000000U); + psu_mask_write(0xFF260020, 0xFFFFFFFFU, 0x01FC9F08U); + psu_mask_write(0xFF260000, 0x00000001U, 0x00000001U); + + return 1; +} + +static unsigned long psu_afi_config(void) +{ + psu_mask_write(0xFD1A0100, 0x00001F80U, 0x00000000U); + psu_mask_write(0xFF5E023C, 0x00080000U, 0x00000000U); + psu_mask_write(0xFD615000, 0x00000300U, 0x00000200U); + + return 1; +} + +static unsigned long psu_ddr_phybringup_data(void) +{ + unsigned int regval = 0; + unsigned int pll_retry = 10; + unsigned int pll_locked = 0; + + while ((pll_retry > 0) && (!pll_locked)) { + Xil_Out32(0xFD080004, 0x00040010); + Xil_Out32(0xFD080004, 0x00040011); + + while ((Xil_In32(0xFD080030) & 0x1) != 1) + ; + + pll_locked = (Xil_In32(0xFD080030) & 0x80000000) >> 31; + pll_locked &= (Xil_In32(0xFD0807E0) & 0x10000) >> 16; + pll_locked &= (Xil_In32(0xFD0809E0) & 0x10000) >> 16; + pll_locked &= (Xil_In32(0xFD080BE0) & 0x10000) >> 16; + pll_locked &= (Xil_In32(0xFD080DE0) & 0x10000) >> 16; + pll_retry--; + } + Xil_Out32(0xFD0800C0, Xil_In32(0xFD0800C0) | (pll_retry << 16)); + Xil_Out32(0xFD080004U, 0x00040063U); + + while ((Xil_In32(0xFD080030U) & 0x0000000FU) != 0x0000000FU) + ; + prog_reg(0xFD080004U, 0x00000001U, 0x00000000U, 0x00000001U); + + while ((Xil_In32(0xFD080030U) & 0x000000FFU) != 0x0000001FU) + ; + Xil_Out32(0xFD0701B0U, 0x00000001U); + Xil_Out32(0xFD070320U, 0x00000001U); + while ((Xil_In32(0xFD070004U) & 0x0000000FU) != 0x00000001U) + ; + prog_reg(0xFD080014U, 0x00000040U, 0x00000006U, 0x00000001U); + Xil_Out32(0xFD080004, 0x0004FE01); + regval = Xil_In32(0xFD080030); + while (regval != 0x80000FFF) + regval = Xil_In32(0xFD080030); + Xil_Out32(0xFD070180U, 0x00800020U); + Xil_Out32(0xFD070060U, 0x00000000U); + prog_reg(0xFD080014U, 0x00000040U, 0x00000006U, 0x00000000U); + + return 1; +} + +static void init_peripheral(void) +{ + psu_mask_write(0xFD5F0018, 0x8000001FU, 0x8000001FU); +} + +int psu_init(void) +{ + int status = 1; + + status &= psu_mio_init_data(); + status &= psu_peripherals_pre_init_data(); + status &= psu_pll_init_data(); + status &= psu_clock_init_data(); + status &= psu_ddr_init_data(); + status &= psu_ddr_phybringup_data(); + status &= psu_peripherals_init_data(); + init_peripheral(); + + status &= psu_afi_config(); + + if (status == 0) + return 1; + return 0; +} diff --git a/configs/xilinx_zynqmp_zc1275_revB_defconfig b/configs/xilinx_zynqmp_zc1275_revB_defconfig new file mode 100644 index 000000000000..5002d17166dc --- /dev/null +++ b/configs/xilinx_zynqmp_zc1275_revB_defconfig @@ -0,0 +1,56 @@ +CONFIG_ARM=y +CONFIG_SYS_CONFIG_NAME="xilinx_zynqmp_zc1275_revB" +CONFIG_ARCH_ZYNQMP=y +CONFIG_SYS_TEXT_BASE=0x8000000 +CONFIG_SYS_MALLOC_F_LEN=0x8000 +# CONFIG_SPL_LIBDISK_SUPPORT is not set +CONFIG_SPL=y +CONFIG_IDENT_STRING=" Xilinx ZynqMP ZC1275 revB" +# CONFIG_SPL_FAT_SUPPORT is not set +CONFIG_DEFAULT_DEVICE_TREE="zynqmp-zc1275-revB" +CONFIG_DEBUG_UART=y +CONFIG_DISTRO_DEFAULTS=y +CONFIG_FIT=y +CONFIG_FIT_VERBOSE=y +CONFIG_SPL_LOAD_FIT=y +# CONFIG_DISPLAY_CPUINFO is not set +# CONFIG_DISPLAY_BOARDINFO is not set +CONFIG_SPL_OS_BOOT=y +CONFIG_SPL_RAM_SUPPORT=y +CONFIG_SPL_RAM_DEVICE=y +CONFIG_SPL_ATF=y +CONFIG_SYS_PROMPT="ZynqMP> " +CONFIG_CMD_MEMTEST=y +CONFIG_CMD_CLK=y +# CONFIG_CMD_FLASH is not set +CONFIG_CMD_FPGA_LOADBP=y +CONFIG_CMD_FPGA_LOADP=y +CONFIG_CMD_MMC=y +# CONFIG_CMD_NET is not set +# CONFIG_CMD_NFS is not set +CONFIG_CMD_TIME=y +CONFIG_CMD_TIMER=y +CONFIG_SPL_OF_CONTROL=y +CONFIG_OF_EMBED=y +CONFIG_SPL_DM=y +CONFIG_CLK_ZYNQMP=y +CONFIG_FPGA_XILINX=y +CONFIG_FPGA_ZYNQMPPL=y +CONFIG_MISC=y +CONFIG_DM_MMC=y +CONFIG_MMC_SDHCI=y +CONFIG_MMC_SDHCI_ZYNQ=y +CONFIG_SPI_FLASH=y +CONFIG_SPI_FLASH_BAR=y +CONFIG_SF_DUAL_FLASH=y +CONFIG_SPI_FLASH_MACRONIX=y +CONFIG_SPI_FLASH_SPANSION=y +CONFIG_SPI_FLASH_STMICRO=y +CONFIG_SPI_FLASH_WINBOND=y +# CONFIG_SPI_FLASH_USE_4K_SECTORS is not set +CONFIG_DEBUG_UART_ZYNQ=y +CONFIG_DEBUG_UART_BASE=0xff000000 +CONFIG_DEBUG_UART_CLOCK=100000000 +CONFIG_DEBUG_UART_ANNOUNCE=y +CONFIG_ZYNQ_SERIAL=y +CONFIG_EFI_LOADER_BOUNCE_BUFFER=y diff --git a/include/configs/xilinx_zynqmp_zc1275_revB.h b/include/configs/xilinx_zynqmp_zc1275_revB.h new file mode 100644 index 000000000000..4cebe2100624 --- /dev/null +++ b/include/configs/xilinx_zynqmp_zc1275_revB.h @@ -0,0 +1,16 @@ +/* + * Configuration for Xilinx ZynqMP zc1275 RevB + * + * (C) Copyright 2018 Xilinx, Inc. + * + * SPDX-License-Identifier: GPL-2.0+ + */ + +#ifndef __CONFIG_ZYNQMP_ZC1275_REVB_H +#define __CONFIG_ZYNQMP_ZC1275_REVB_H + +#define CONFIG_ZYNQ_SDHCI1 + +#include <configs/xilinx_zynqmp.h> + +#endif /* __CONFIG_ZYNQMP_ZC1275_REVB_H */
Michal Simek
