Re: [U-Boot] [PATCH] arm: socfpga: Fix emac1 doesn't work on socdk board
On Dec 17, 2015, at 11:28 PM, Chin Liang See clsee@altera.com wrote:
Hi Shengjiang,
On Fri, 2015-12-18 at 15:13 +0800, shengjiangwu wrote: Updated pinmux group MIXED1IO[0-13] for RGMII1. Updated EMAC1 clock.
Signed-off-by: shengjiangwu shengjiangwu@icloud.com Cc: Chin Liang See clsee@altera.com Cc: Dinh Nguyen dinguyen@opensource.altera.com Cc: Dinh Nguyen dinh.linux@gmail.com Cc: Pavel Machek pavel@denx.de Cc: Marek Vasut marex@denx.de Cc: Stefan Roese sr@denx.de
Thanks for the patch.
--- board/altera/cyclone5-socdk/qts/pinmux_config.h | 28 +++++++++++-- ---------- board/altera/cyclone5-socdk/qts/pll_config.h | 4 ++-- 2 files changed, 16 insertions(+), 16 deletions(-)
diff --git a/board/altera/cyclone5-socdk/qts/pinmux_config.h b/board/altera/cyclone5-socdk/qts/pinmux_config.h index 33cf1fd..442b1e0 100644 --- a/board/altera/cyclone5-socdk/qts/pinmux_config.h +++ b/board/altera/cyclone5-socdk/qts/pinmux_config.h @@ -72,20 +72,20 @@ const u8 sys_mgr_init_table[] = { 0, /* GENERALIO29 */ 0, /* GENERALIO30 */ 0, /* GENERALIO31 */ - 0, /* MIXED1IO0 */ - 1, /* MIXED1IO1 */ - 1, /* MIXED1IO2 */ - 1, /* MIXED1IO3 */ - 1, /* MIXED1IO4 */ - 0, /* MIXED1IO5 */ - 0, /* MIXED1IO6 */ - 0, /* MIXED1IO7 */ - 1, /* MIXED1IO8 */ - 1, /* MIXED1IO9 */ - 1, /* MIXED1IO10 */ - 1, /* MIXED1IO11 */ - 0, /* MIXED1IO12 */ - 0, /* MIXED1IO13 */ + 2, /* MIXED1IO0 */ + 2, /* MIXED1IO1 */ + 2, /* MIXED1IO2 */ + 2, /* MIXED1IO3 */ + 2, /* MIXED1IO4 */ + 2, /* MIXED1IO5 */ + 2, /* MIXED1IO6 */ + 2, /* MIXED1IO7 */ + 2, /* MIXED1IO8 */ + 2, /* MIXED1IO9 */ + 2, /* MIXED1IO10 */ + 2, /* MIXED1IO11 */ + 2, /* MIXED1IO12 */ + 2, /* MIXED1IO13 */ 0, /* MIXED1IO14 */ 1, /* MIXED1IO15 */ 1, /* MIXED1IO16 */ diff --git a/board/altera/cyclone5-socdk/qts/pll_config.h b/board/altera/cyclone5-socdk/qts/pll_config.h index 3d621ed..42905f4 100644 --- a/board/altera/cyclone5-socdk/qts/pll_config.h +++ b/board/altera/cyclone5-socdk/qts/pll_config.h @@ -31,7 +31,7 @@ #define CONFIG_HPS_PERPLLGRP_VCO_NUMER 79 #define CONFIG_HPS_PERPLLGRP_VCO_PSRC 0 #define CONFIG_HPS_PERPLLGRP_EMAC0CLK_CNT 3 -#define CONFIG_HPS_PERPLLGRP_EMAC1CLK_CNT 511 +#define CONFIG_HPS_PERPLLGRP_EMAC1CLK_CNT 3 #define CONFIG_HPS_PERPLLGRP_PERQSPICLK_CNT 511 #define CONFIG_HPS_PERPLLGRP_PERNANDSDMMCCLK_CNT 4 #define CONFIG_HPS_PERPLLGRP_PERBASECLK_CNT 4 @@ -65,7 +65,7 @@ #define CONFIG_HPS_CLK_PERVCO_HZ 1000000000 #define CONFIG_HPS_CLK_SDRVCO_HZ 666666666 #define CONFIG_HPS_CLK_EMAC0_HZ 250000000 -#define CONFIG_HPS_CLK_EMAC1_HZ 250000000 +#define CONFIG_HPS_CLK_EMAC1_HZ 50000000
I believe the EMAC1 clock is still 250MHz which result of 25MHz * (79+1) / (1+1) / (3+1).
Thanks Chin Liang Thanks for your comments, then I will restore it CONFIG_HPS_CLK_EMAC1_HZ as 250000000 Shengjiangwu
#define CONFIG_HPS_CLK_USBCLK_HZ 200000000 #define CONFIG_HPS_CLK_NAND_HZ 50000000 #define CONFIG_HPS_CLK_SDMMC_HZ 200000000
Hi Shengjiang,
Updated pinmux group MIXED1IO[0-13] for RGMII1. Updated EMAC1 clock. Signed-off-by: shengjiangwu shengjiangwu@icloud.com Cc: Chin Liang See clsee@altera.com Cc: Dinh Nguyen dinguyen@opensource.altera.com Cc: Dinh Nguyen dinh.linux@gmail.com Cc: Pavel Machek pavel@denx.de Cc: Marek Vasut marex@denx.de Cc: Stefan Roese sr@denx.de
board/altera/cyclone5-socdk/qts/pll_config.h | 4 ++-- 2 files changed, 16 insertions(+), 16 deletions(-) diff --git a/board/altera/cyclone5-socdk/qts/pinmux_config.h b/board/altera/cyclone5-socdk/qts/pinmux_config.h index 33cf1fd..442b1e0 100644 --- a/board/altera/cyclone5-socdk/qts/pinmux_config.h +++ b/board/altera/cyclone5-socdk/qts/pinmux_config.h @@ -72,20 +72,20 @@ const u8 sys_mgr_init_table[] = { 0, /* GENERALIO29 */ 0, /* GENERALIO30 */ 0, /* GENERALIO31 */
1, /* MIXED1IO1 */
1, /* MIXED1IO2 */
1, /* MIXED1IO3 */
1, /* MIXED1IO4 */
0, /* MIXED1IO5 */
0, /* MIXED1IO6 */
0, /* MIXED1IO7 */
1, /* MIXED1IO8 */
1, /* MIXED1IO9 */
1, /* MIXED1IO10 */
0, /* MIXED1IO12 */
0, /* MIXED1IO13 */
2, /* MIXED1IO0 */
- 2, /* MIXED1IO1 */
2, /* MIXED1IO2 */
2, /* MIXED1IO3 */
2, /* MIXED1IO4 */
2, /* MIXED1IO5 */
2, /* MIXED1IO6 */
2, /* MIXED1IO7 */
2, /* MIXED1IO8 */
2, /* MIXED1IO9 */
2, /* MIXED1IO10 */
- 2, /* MIXED1IO11 */
2, /* MIXED1IO12 */
Thanks Chin Liang
Thanks, looking for your v2 patch then
Chin Liang
Chin Liang See
圣江 吴
