[U-Boot] [PATCH 0/3] arm: omap: Introduce vcores_init function
The series Introduces vcores_init function to update am57xx information after the board detection. Fixes assigning wrong value to to omap_vcores over riding the vcores_init function for am572x-idk and does a minor alignment correction.
This series is on top of the series: http://marc.info/?l=u-boot&m=146402916631764&w=2
Boot tested on beagle-x15, am572x-idk and dra7-evm. Checked for the correct PMIC voltages using i2c reads on PMIC registers.
Keerthy (3): arm: omap: Introduce vcores_init function arm: am57xx: Fix omap_vcores assignment for am572x-idk arm: am57xx: Fix alignment where necessary
arch/arm/cpu/armv7/omap-common/hwinit-common.c | 11 ++ arch/arm/include/asm/arch-omap5/sys_proto.h | 1 + board/ti/am57xx/board.c | 135 ++++++++++++++++--------- 3 files changed, 101 insertions(+), 46 deletions(-)
The pmic registers for variants of am57xx boards are different hence we need to assign them carefully based on the board type. Add a function to assign omap_vcores after the board detection.
Signed-off-by: Keerthy j-keerthy@ti.com --- arch/arm/cpu/armv7/omap-common/hwinit-common.c | 11 +++++++++++ arch/arm/include/asm/arch-omap5/sys_proto.h | 1 + 2 files changed, 12 insertions(+)
diff --git a/arch/arm/cpu/armv7/omap-common/hwinit-common.c b/arch/arm/cpu/armv7/omap-common/hwinit-common.c index 01c2d57..8ad82f6 100644 --- a/arch/arm/cpu/armv7/omap-common/hwinit-common.c +++ b/arch/arm/cpu/armv7/omap-common/hwinit-common.c @@ -94,6 +94,16 @@ void __weak do_board_detect(void) { }
+/** + * vcores_init() - Assign omap_vcores based on board + * + * Function to pick the vcores based on board. This is expected to be + * overridden in the SoC family board file where desired. + */ +void __weak vcores_init(void) +{ +} + void s_init(void) { } @@ -131,6 +141,7 @@ void early_system_init(void) #endif setup_early_clocks(); do_board_detect(); + vcores_init(); prcm_init(); }
diff --git a/arch/arm/include/asm/arch-omap5/sys_proto.h b/arch/arm/include/asm/arch-omap5/sys_proto.h index 804266a..d25e4fa 100644 --- a/arch/arm/include/asm/arch-omap5/sys_proto.h +++ b/arch/arm/include/asm/arch-omap5/sys_proto.h @@ -51,6 +51,7 @@ void sdelay(unsigned long); void setup_early_clocks(void); void prcm_init(void); void do_board_detect(void); +void vcores_init(void); void bypass_dpll(u32 const base); void freq_update_core(void); u32 get_sys_clk_freq(void);
Currently omap_vcores is wrongly assigned a default value of beagle_x15_volts. Hence populating a new structure for am572x-idk and assigning it to omap_vcores in the vcores_init function.
Fixes: c020d355c45ed40fe12a ("board: ti: am57xx: Add support for am572x idk in SPL") Reported-by: Suman Anna s-anna@ti.com Signed-off-by: Keerthy j-keerthy@ti.com --- board/ti/am57xx/board.c | 45 ++++++++++++++++++++++++++++++++++++++++++++- 1 file changed, 44 insertions(+), 1 deletion(-)
diff --git a/board/ti/am57xx/board.c b/board/ti/am57xx/board.c index a6a4ccb..5992f49 100644 --- a/board/ti/am57xx/board.c +++ b/board/ti/am57xx/board.c @@ -251,6 +251,42 @@ struct vcores_data beagle_x15_volts = { .iva.abb_tx_done_mask = OMAP_ABB_IVA_TXDONE_MASK, };
+struct vcores_data am572x_idk_volts = { + .mpu.value = VDD_MPU_DRA7, + .mpu.efuse.reg = STD_FUSE_OPP_VMIN_MPU, + .mpu.efuse.reg_bits = DRA752_EFUSE_REGBITS, + .mpu.addr = TPS659038_REG_ADDR_SMPS12, + .mpu.pmic = &tps659038, + .mpu.abb_tx_done_mask = OMAP_ABB_MPU_TXDONE_MASK, + + .eve.value = VDD_EVE_DRA7, + .eve.efuse.reg = STD_FUSE_OPP_VMIN_DSPEVE, + .eve.efuse.reg_bits = DRA752_EFUSE_REGBITS, + .eve.addr = TPS659038_REG_ADDR_SMPS45, + .eve.pmic = &tps659038, + .eve.abb_tx_done_mask = OMAP_ABB_EVE_TXDONE_MASK, + + .gpu.value = VDD_GPU_DRA7, + .gpu.efuse.reg = STD_FUSE_OPP_VMIN_GPU, + .gpu.efuse.reg_bits = DRA752_EFUSE_REGBITS, + .gpu.addr = TPS659038_REG_ADDR_SMPS6, + .gpu.pmic = &tps659038, + .gpu.abb_tx_done_mask = OMAP_ABB_GPU_TXDONE_MASK, + + .core.value = VDD_CORE_DRA7, + .core.efuse.reg = STD_FUSE_OPP_VMIN_CORE, + .core.efuse.reg_bits = DRA752_EFUSE_REGBITS, + .core.addr = TPS659038_REG_ADDR_SMPS7, + .core.pmic = &tps659038, + + .iva.value = VDD_IVA_DRA7, + .iva.efuse.reg = STD_FUSE_OPP_VMIN_IVA, + .iva.efuse.reg_bits = DRA752_EFUSE_REGBITS, + .iva.addr = TPS659038_REG_ADDR_SMPS8, + .iva.pmic = &tps659038, + .iva.abb_tx_done_mask = OMAP_ABB_IVA_TXDONE_MASK, +}; + #ifdef CONFIG_SPL_BUILD /* No env to setup for SPL */ static inline void setup_board_eeprom_env(void) { } @@ -315,11 +351,18 @@ invalid_eeprom:
#endif /* CONFIG_SPL_BUILD */
+void vcores_init(void) +{ + if (board_is_am572x_idk()) + *omap_vcores = &am572x_idk_volts; + else + *omap_vcores = &beagle_x15_volts; +} + void hw_data_init(void) { *prcm = &dra7xx_prcm; *dplls_data = &dra7xx_dplls; - *omap_vcores = &beagle_x15_volts; *ctrl = &dra7xx_ctrl; }
This just fixes alignment for better readability.
Signed-off-by: Keerthy j-keerthy@ti.com --- board/ti/am57xx/board.c | 90 ++++++++++++++++++++++++------------------------- 1 file changed, 45 insertions(+), 45 deletions(-)
diff --git a/board/ti/am57xx/board.c b/board/ti/am57xx/board.c index 5992f49..6b58722 100644 --- a/board/ti/am57xx/board.c +++ b/board/ti/am57xx/board.c @@ -63,28 +63,28 @@ void emif_get_dmm_regs(const struct dmm_lisa_map_regs **dmm_lisa_regs) }
static const struct emif_regs beagle_x15_emif1_ddr3_532mhz_emif_regs = { - .sdram_config_init = 0x61851b32, - .sdram_config = 0x61851b32, - .sdram_config2 = 0x08000000, - .ref_ctrl = 0x000040F1, - .ref_ctrl_final = 0x00001035, - .sdram_tim1 = 0xcccf36ab, - .sdram_tim2 = 0x308f7fda, - .sdram_tim3 = 0x409f88a8, - .read_idle_ctrl = 0x00050000, - .zq_config = 0x5007190b, - .temp_alert_config = 0x00000000, - .emif_ddr_phy_ctlr_1_init = 0x0024400b, - .emif_ddr_phy_ctlr_1 = 0x0e24400b, - .emif_ddr_ext_phy_ctrl_1 = 0x10040100, - .emif_ddr_ext_phy_ctrl_2 = 0x00910091, - .emif_ddr_ext_phy_ctrl_3 = 0x00950095, - .emif_ddr_ext_phy_ctrl_4 = 0x009b009b, - .emif_ddr_ext_phy_ctrl_5 = 0x009e009e, - .emif_rd_wr_lvl_rmp_win = 0x00000000, - .emif_rd_wr_lvl_rmp_ctl = 0x80000000, - .emif_rd_wr_lvl_ctl = 0x00000000, - .emif_rd_wr_exec_thresh = 0x00000305 + .sdram_config_init = 0x61851b32, + .sdram_config = 0x61851b32, + .sdram_config2 = 0x08000000, + .ref_ctrl = 0x000040F1, + .ref_ctrl_final = 0x00001035, + .sdram_tim1 = 0xcccf36ab, + .sdram_tim2 = 0x308f7fda, + .sdram_tim3 = 0x409f88a8, + .read_idle_ctrl = 0x00050000, + .zq_config = 0x5007190b, + .temp_alert_config = 0x00000000, + .emif_ddr_phy_ctlr_1_init = 0x0024400b, + .emif_ddr_phy_ctlr_1 = 0x0e24400b, + .emif_ddr_ext_phy_ctrl_1 = 0x10040100, + .emif_ddr_ext_phy_ctrl_2 = 0x00910091, + .emif_ddr_ext_phy_ctrl_3 = 0x00950095, + .emif_ddr_ext_phy_ctrl_4 = 0x009b009b, + .emif_ddr_ext_phy_ctrl_5 = 0x009e009e, + .emif_rd_wr_lvl_rmp_win = 0x00000000, + .emif_rd_wr_lvl_rmp_ctl = 0x80000000, + .emif_rd_wr_lvl_ctl = 0x00000000, + .emif_rd_wr_exec_thresh = 0x00000305 };
/* Ext phy ctrl regs 1-35 */ @@ -127,28 +127,28 @@ static const u32 beagle_x15_emif1_ddr3_ext_phy_ctrl_const_regs[] = { };
static const struct emif_regs beagle_x15_emif2_ddr3_532mhz_emif_regs = { - .sdram_config_init = 0x61851b32, - .sdram_config = 0x61851b32, - .sdram_config2 = 0x08000000, - .ref_ctrl = 0x000040F1, - .ref_ctrl_final = 0x00001035, - .sdram_tim1 = 0xcccf36b3, - .sdram_tim2 = 0x308f7fda, - .sdram_tim3 = 0x407f88a8, - .read_idle_ctrl = 0x00050000, - .zq_config = 0x5007190b, - .temp_alert_config = 0x00000000, - .emif_ddr_phy_ctlr_1_init = 0x0024400b, - .emif_ddr_phy_ctlr_1 = 0x0e24400b, - .emif_ddr_ext_phy_ctrl_1 = 0x10040100, - .emif_ddr_ext_phy_ctrl_2 = 0x00910091, - .emif_ddr_ext_phy_ctrl_3 = 0x00950095, - .emif_ddr_ext_phy_ctrl_4 = 0x009b009b, - .emif_ddr_ext_phy_ctrl_5 = 0x009e009e, - .emif_rd_wr_lvl_rmp_win = 0x00000000, - .emif_rd_wr_lvl_rmp_ctl = 0x80000000, - .emif_rd_wr_lvl_ctl = 0x00000000, - .emif_rd_wr_exec_thresh = 0x00000305 + .sdram_config_init = 0x61851b32, + .sdram_config = 0x61851b32, + .sdram_config2 = 0x08000000, + .ref_ctrl = 0x000040F1, + .ref_ctrl_final = 0x00001035, + .sdram_tim1 = 0xcccf36b3, + .sdram_tim2 = 0x308f7fda, + .sdram_tim3 = 0x407f88a8, + .read_idle_ctrl = 0x00050000, + .zq_config = 0x5007190b, + .temp_alert_config = 0x00000000, + .emif_ddr_phy_ctlr_1_init = 0x0024400b, + .emif_ddr_phy_ctlr_1 = 0x0e24400b, + .emif_ddr_ext_phy_ctrl_1 = 0x10040100, + .emif_ddr_ext_phy_ctrl_2 = 0x00910091, + .emif_ddr_ext_phy_ctrl_3 = 0x00950095, + .emif_ddr_ext_phy_ctrl_4 = 0x009b009b, + .emif_ddr_ext_phy_ctrl_5 = 0x009e009e, + .emif_rd_wr_lvl_rmp_win = 0x00000000, + .emif_rd_wr_lvl_rmp_ctl = 0x80000000, + .emif_rd_wr_lvl_ctl = 0x00000000, + .emif_rd_wr_exec_thresh = 0x00000305 };
static const u32 beagle_x15_emif2_ddr3_ext_phy_ctrl_const_regs[] = { @@ -221,7 +221,7 @@ struct vcores_data beagle_x15_volts = { .mpu.efuse.reg_bits = DRA752_EFUSE_REGBITS, .mpu.addr = TPS659038_REG_ADDR_SMPS12, .mpu.pmic = &tps659038, - .mpu.abb_tx_done_mask = OMAP_ABB_MPU_TXDONE_MASK, + .mpu.abb_tx_done_mask = OMAP_ABB_MPU_TXDONE_MASK,
.eve.value = VDD_EVE_DRA7, .eve.efuse.reg = STD_FUSE_OPP_VMIN_DSPEVE,
Keerthy
