[PATCH V2] ARM: rmobile: beacon: Set CONFIG_RZ_G2 on Beacon boards
The board detection is incorrectly stating it's an rcar3 variant instead of an RZ/G2 variant on all the r8a774*1_beacon boards. Set the flag to correctly display as RZ/G2[M/N/H]
Signed-off-by: Adam Ford aford173@gmail.com
--- V2: Move the RZ_G2 option to Kconfig from defconfig
diff --git a/arch/arm/mach-rmobile/Kconfig.64 b/arch/arm/mach-rmobile/Kconfig.64 index 3f7ec05379..c621f8a544 100644 --- a/arch/arm/mach-rmobile/Kconfig.64 +++ b/arch/arm/mach-rmobile/Kconfig.64 @@ -69,16 +69,19 @@ choice config TARGET_BEACON_RZG2H bool "Beacon EmbeddedWorks RZ/G2H Dev Kit" select R8A774E1 + select RZ_G2 select PINCTRL_PFC_R8A774E1
config TARGET_BEACON_RZG2M bool "Beacon EmbeddedWorks RZ/G2M Dev Kit" select R8A774A1 + select RZ_G2 select PINCTRL_PFC_R8A774A1
config TARGET_BEACON_RZG2N bool "Beacon EmbeddedWorks RZ/G2N Dev Kit" select R8A774B1 + select RZ_G2 select PINCTRL_PFC_R8A774B1
config TARGET_CONDOR
Adam Ford
