[U-Boot] CONFIG_DELAY_ENVIRONMENT usage
Simon, I had a question about your CONFIG_DELAY_ENVIRONMENT patch. In the commit description it says:
When CONFIG_DELAY_ENVIRONMENT is defined, it is convenient to have a run-time way of enabling loading of the environment. Add this to the fdt as /config/delay-environment.
In the code, it's actually reading /config/load-environment, and it defaults to prevent loading environment regardless if CONFIG_DELAY_ENVIRONMENT is set or not:
static int should_load_env(void) { #ifdef CONFIG_OF_CONTROL return fdtdec_get_config_int(gd->fdt_blob, "load-environment", 0); #elif defined CONFIG_DELAY_ENVIRONMENT return 0; #else return 1; #endif }
The problem I'm seeing is that this regressed environment loading on all boards that use fdt, because none of them have /config/load-environment defined. If I read the commit message correctly, I think the actual intention is:
static int should_load_env(void) { #ifdef CONFIG_DELAY_ENVIRONMENT #ifdef CONFIG_OF_CONTROL return fdtdec_get_config_int(gd->fdt_blob, "load-environment", 0); #else return 0; #endif #else return 1; #endif }
Is my understanding correct?
-Allen
Hi Allen,
Am Dienstag, den 29.01.2013, 19:05 -0800 schrieb Allen Martin:
There is already a patch for that on the mailing list. See http://www.mail-archive.com/u-boot@lists.denx.de/msg103841.html
We agreed that just swapping around the default value for the FDT case is the right thing to do.
Regards, Lucas
On Tue, Jan 29, 2013 at 10:08:39PM -0800, Lucas Stach wrote:
Hi Allen,
Thanks for the pointer Lucas, I didn't notice the previous patch.
-Allen
Allen Martin
Lucas Stach
