[U-Boot] [PATCH V2] imx: vf610 add get_cpu_rev
Since we need to support runtime check for different drivers, we need to add get_cpu_rev for vf610, otherwise there will be build errors.
This patch introduces a dummy CPU id which is not read from chip silicon. Later when we can get the real id from chip, can fix the value of MXC_CPU_VF610 then.
Signed-off-by: Peng Fan Peng.Fan@freescale.com Suggested-by: Stefano Babic sbabic@denx.de Cc: Stefano Babic sbabic@denx.de ---
Changes v2: Take suggestion from Stefano, get_cpu_rev for vf610 should return an ID saying dummy ID, but not 0.
arch/arm/cpu/armv7/vf610/generic.c | 6 ++++++ arch/arm/include/asm/arch-imx/cpu.h | 1 + 2 files changed, 7 insertions(+)
diff --git a/arch/arm/cpu/armv7/vf610/generic.c b/arch/arm/cpu/armv7/vf610/generic.c index 05c401d..08b9ef4 100644 --- a/arch/arm/cpu/armv7/vf610/generic.c +++ b/arch/arm/cpu/armv7/vf610/generic.c @@ -9,6 +9,7 @@ #include <asm/arch/imx-regs.h> #include <asm/arch/clock.h> #include <asm/arch/crm_regs.h> +#include <asm/imx-common/sys_proto.h> #include <netdev.h> #ifdef CONFIG_FSL_ESDHC #include <fsl_esdhc.h> @@ -266,6 +267,11 @@ void imx_get_mac_from_fuse(int dev_id, unsigned char *mac) } #endif
+u32 get_cpu_rev(void) +{ + return MXC_CPU_VF610 << 12; +} + #if defined(CONFIG_DISPLAY_CPUINFO) static char *get_reset_cause(void) { diff --git a/arch/arm/include/asm/arch-imx/cpu.h b/arch/arm/include/asm/arch-imx/cpu.h index be13b96..1c8d24e 100644 --- a/arch/arm/include/asm/arch-imx/cpu.h +++ b/arch/arm/include/asm/arch-imx/cpu.h @@ -21,6 +21,7 @@ #define MXC_CPU_MX6D 0x67 #define MXC_CPU_MX6DP 0x68 #define MXC_CPU_MX6QP 0x69 +#define MXC_CPU_VF610 0xF6 /* dummy ID */
#define CS0_128 0 #define CS0_64M_CS1_64M 1
Hi Peng,
- return MXC_CPU_VF610 << 12;
Acked-by: Stefano Babic sbabic@denx.de
Best regards, Stefano Babic
Peng Fan
Stefano Babic
