[U-Boot] [PATCH] ARM: sun8i: a83t: Add device tree for Sinovoip Bananapi BPI-M3
The BPI-M3 is an Allwinner A83T based SBC in the Bananapi/Bpi family. It is roughly the same form factor as the BPI-M1+, with roughly the same peripherals and connectors:
- 2GB LPDDR3 DRAM - 8GB eMMC - Micro-SD card slot - HDMI output - Headset (stereo + mic) jack - Onboard mic - Gigabit Ethernet with RTL8211E transceiver - Ampak AP6212 WiFi + BT - USB OTG connector - USB-to-SATA bridge connected through a USB 2.0 hub - Consumer IR receiver - MIPI DSI LCD panel connector - Camera interface (parallel and MIPI CSI) connector - 3 LEDs (Red, Green, Blue), of which 2 are controllable (GB) - Raspberry Pi 2 compatible GPIO header
Signed-off-by: Chen-Yu Tsai wens@csie.org ---
Note that the file name follows the convention of most of the other bananapi boards, that is the vendor "sinovoip" is not included in the name. This deviates from what is already in U-boot.
This applies on top of my A83t USB patches.
--- arch/arm/boot/dts/Makefile | 1 + arch/arm/boot/dts/sun8i-a83t-bananapi-m3.dts | 148 +++++++++++++++++++++++++++ 2 files changed, 149 insertions(+) create mode 100644 arch/arm/boot/dts/sun8i-a83t-bananapi-m3.dts
diff --git a/arch/arm/boot/dts/Makefile b/arch/arm/boot/dts/Makefile index e0d77ab79f5f..791fecc0774a 100644 --- a/arch/arm/boot/dts/Makefile +++ b/arch/arm/boot/dts/Makefile @@ -903,6 +903,7 @@ dtb-$(CONFIG_MACH_SUN8I) += \ sun8i-a33-q8-tablet.dtb \ sun8i-a33-sinlinx-sina33.dtb \ sun8i-a83t-allwinner-h8homlet-v2.dtb \ + sun8i-a83t-bananapi-m3.dtb \ sun8i-a83t-cubietruck-plus.dtb \ sun8i-h2-plus-orangepi-zero.dtb \ sun8i-h3-bananapi-m2-plus.dtb \ diff --git a/arch/arm/boot/dts/sun8i-a83t-bananapi-m3.dts b/arch/arm/boot/dts/sun8i-a83t-bananapi-m3.dts new file mode 100644 index 000000000000..2bafd7e99ef7 --- /dev/null +++ b/arch/arm/boot/dts/sun8i-a83t-bananapi-m3.dts @@ -0,0 +1,148 @@ +/* + * Copyright 2017 Chen-Yu Tsai + * + * Chen-Yu Tsai wens@csie.org + * + * This file is dual-licensed: you can use it either under the terms + * of the GPL or the X11 license, at your option. Note that this dual + * licensing only applies to this file, and not this project as a + * whole. + * + * a) This file is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of the + * License, or (at your option) any later version. + * + * This file is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * Or, alternatively, + * + * b) Permission is hereby granted, free of charge, to any person + * obtaining a copy of this software and associated documentation + * files (the "Software"), to deal in the Software without + * restriction, including without limitation the rights to use, + * copy, modify, merge, publish, distribute, sublicense, and/or + * sell copies of the Software, and to permit persons to whom the + * Software is furnished to do so, subject to the following + * conditions: + * + * The above copyright notice and this permission notice shall be + * included in all copies or substantial portions of the Software. + * + * THE SOFTWARE IS PROVIDED "AS IS", WITHOUT WARRANTY OF ANY KIND, + * EXPRESS OR IMPLIED, INCLUDING BUT NOT LIMITED TO THE WARRANTIES + * OF MERCHANTABILITY, FITNESS FOR A PARTICULAR PURPOSE AND + * NONINFRINGEMENT. IN NO EVENT SHALL THE AUTHORS OR COPYRIGHT + * HOLDERS BE LIABLE FOR ANY CLAIM, DAMAGES OR OTHER LIABILITY, + * WHETHER IN AN ACTION OF CONTRACT, TORT OR OTHERWISE, ARISING + * FROM, OUT OF OR IN CONNECTION WITH THE SOFTWARE OR THE USE OR + * OTHER DEALINGS IN THE SOFTWARE. + */ + +/dts-v1/; +#include "sun8i-a83t.dtsi" +#include "sunxi-common-regulators.dtsi" + +#include <dt-bindings/gpio/gpio.h> + +/ { + model = "Banana Pi BPI-M3"; + compatible = "sinovoip,bpi-m3", "allwinner,sun8i-a83t"; + + aliases { + serial0 = &uart0; + }; + + chosen { + stdout-path = "serial0:115200n8"; + }; +}; + +&ehci0 { + /* Terminus Tech FE 1.1s 4-port USB 2.0 hub here */ + status = "okay"; + + /* TODO GL830 USB-to-SATA bridge downstream w/ GPIO power controls */ +}; + +&mmc0 { + pinctrl-names = "default"; + pinctrl-0 = <&mmc0_pins>; + vmmc-supply = <®_vcc3v3>; + bus-width = <4>; + cd-gpios = <&pio 5 6 GPIO_ACTIVE_HIGH>; /* PF6 */ + cd-inverted; + status = "okay"; +}; + +&mmc2 { + pinctrl-names = "default"; + pinctrl-0 = <&mmc2_8bit_emmc_pins>; + vmmc-supply = <®_vcc3v3>; + bus-width = <8>; + non-removable; + cap-mmc-hw-reset; + status = "okay"; +}; + +&r_rsb { + status = "okay"; + + axp81x: pmic@3a3 { + compatible = "x-powers,axp813"; + reg = <0x3a3>; + interrupt-parent = <&r_intc>; + interrupts = <0 IRQ_TYPE_LEVEL_LOW>; + }; + + ac100: codec@e89 { + compatible = "x-powers,ac100"; + reg = <0xe89>; + + ac100_codec: codec { + compatible = "x-powers,ac100-codec"; + interrupt-parent = <&r_pio>; + interrupts = <0 11 IRQ_TYPE_LEVEL_LOW>; /* PL11 */ + #clock-cells = <0>; + clock-output-names = "4M_adda"; + }; + + ac100_rtc: rtc { + compatible = "x-powers,ac100-rtc"; + interrupt-parent = <&r_intc>; + interrupts = <0 IRQ_TYPE_LEVEL_LOW>; + clocks = <&ac100_codec>; + #clock-cells = <1>; + clock-output-names = "cko1_rtc", + "cko2_rtc", + "cko3_rtc"; + }; + }; +}; + +®_usb1_vbus { + gpio = <&pio 3 24 GPIO_ACTIVE_HIGH>; /* PD24 */ + status = "okay"; +}; + +®_vcc3v0 { + status = "disabled"; +}; + +®_vcc5v0 { + status = "disabled"; +}; + +&uart0 { + pinctrl-names = "default"; + pinctrl-0 = <&uart0_pb_pins>; + status = "okay"; +}; + +&usbphy { + usb1_vbus-supply = <®_usb1_vbus>; + status = "okay"; +};
在 2017-08-17 11:40,Chen-Yu Tsai 写道:
- 2GB LPDDR3 DRAM
- 8GB eMMC
- HDMI output
- Onboard mic
- USB OTG connector
- sun8i-a83t-bananapi-m3.dtb \ sun8i-a83t-cubietruck-plus.dtb \ sun8i-h2-plus-orangepi-zero.dtb \ sun8i-h3-bananapi-m2-plus.dtb \
- Copyright 2017 Chen-Yu Tsai
- Chen-Yu Tsai wens@csie.org
- This file is dual-licensed: you can use it either under the terms
- of the GPL or the X11 license, at your option. Note that this dual
- licensing only applies to this file, and not this project as a
- whole.
- a) This file is free software; you can redistribute it and/or
the
- Or, alternatively,
- b) Permission is hereby granted, free of charge, to any person
conditions:
- model = "Banana Pi BPI-M3";
- compatible = "sinovoip,bpi-m3", "allwinner,sun8i-a83t";
Should we continue to use sinovoip,bpi-mx-xxx or use bananapi,mx-xxx instead?
- aliases {
serial0 = &uart0;
- chosen {
+&ehci0 {
- /* Terminus Tech FE 1.1s 4-port USB 2.0 hub here */
- status = "okay";
- /* TODO GL830 USB-to-SATA bridge downstream w/ GPIO power controls */
+&mmc0 {
- pinctrl-names = "default";
- pinctrl-0 = <&mmc0_pins>;
- vmmc-supply = <®_vcc3v3>;
- bus-width = <4>;
- cd-gpios = <&pio 5 6 GPIO_ACTIVE_HIGH>; /* PF6 */
- cd-inverted;
- status = "okay";
+&mmc2 {
- pinctrl-0 = <&mmc2_8bit_emmc_pins>;
- bus-width = <8>;
- non-removable;
- cap-mmc-hw-reset;
- status = "okay";
+&r_rsb {
- status = "okay";
- axp81x: pmic@3a3 {
reg = <0x3a3>;
- ac100: codec@e89 {
reg = <0xe89>;
#clock-cells = <0>;
ac100_rtc: rtc {
#clock-cells = <1>;
"cko2_rtc",
"cko3_rtc";
+®_usb1_vbus {
- gpio = <&pio 3 24 GPIO_ACTIVE_HIGH>; /* PD24 */
- status = "okay";
+®_vcc3v0 {
- status = "disabled";
+®_vcc5v0 {
+&uart0 {
- pinctrl-0 = <&uart0_pb_pins>;
- status = "okay";
+&usbphy {
- usb1_vbus-supply = <®_usb1_vbus>;
- status = "okay";
- 2GB LPDDR3 DRAM
- 8GB eMMC
- HDMI output
- Onboard mic
- USB OTG connector
- whole.
conditions:
The vendor listed for "bananapi" is "BIPAI KEJI LIMITED", which you and I know is probably the Chinese pronunciation of "BPi Technologies". However I can't seem to find any trademark registrations.
The dispute around the Banana Pi brand was confusing. I'd hate to see it again. I'll make some inquiries about this first.
ChenYu
Hi Chen-Yu,
[auto build test ERROR on robh/for-next] [also build test ERROR on v4.13-rc5 next-20170817] [if your patch is applied to the wrong git tree, please drop us a note to help improve the system]
url: https://github.com/0day-ci/linux/commits/Chen-Yu-Tsai/ARM-sun8i-a83t-Add-dev... base: https://git.kernel.org/pub/scm/linux/kernel/git/robh/linux.git for-next config: arm-at91_dt_defconfig (attached as .config) compiler: arm-linux-gnueabi-gcc (Debian 6.1.1-9) 6.1.1 20160705 reproduce: wget https://raw.githubusercontent.com/01org/lkp-tests/master/sbin/make.cross -O ~/bin/make.cross chmod +x ~/bin/make.cross # save the attached .config to linux build tree make.cross ARCH=arm
All errors (new ones prefixed by >>):
Error: arch/arm/boot/dts/sun8i-a83t-bananapi-m3.dts:64.1-7 Label or path ehci0 not found Error: arch/arm/boot/dts/sun8i-a83t-bananapi-m3.dts:71.1-6 Label or path mmc0 not found Error: arch/arm/boot/dts/sun8i-a83t-bananapi-m3.dts:81.1-6 Label or path mmc2 not found Error: arch/arm/boot/dts/sun8i-a83t-bananapi-m3.dts:91.1-7 Label or path r_rsb not found Error: arch/arm/boot/dts/sun8i-a83t-bananapi-m3.dts:145.1-8 Label or path usbphy not found
FATAL ERROR: Syntax error parsing input tree
--- 0-DAY kernel test infrastructure Open Source Technology Center https://lists.01.org/pipermail/kbuild-all Intel Corporation
在 2017-08-20 08:59,kbuild test robot 写道:
Hi Chen-Yu,
In fact this tree shouldn't be applied on robh's tree, but the arm-soc tree or its downstream, sunxi tree.
linux-arm-kernel mailing list linux-arm-kernel@lists.infradead.org http://lists.infradead.org/mailman/listinfo/linux-arm-kernel
Hi Chen-Yu,
Thanks for the feedback, we'll improve the system accordingly.
Thanks, Xiaolong
Chen-Yu Tsai
icenowy@aosc.io
kbuild test robot
Ye Xiaolong
