[U-Boot] [PATCH v2 0/5] arm: ti: misc updates and bug fixes
This series consolidates few bug fixes on TI platforms.
Changes since v1: - Removed ifdef aroung externs
Lokesh Vutla (3): configs: k2g_evm: Allocate more space for u-boot tools: omapimage: Fix mismatch of image size in header arm: am33xx: Avoid writing into reserved DPLL divider
Rex Chang (1): board: TI K2G: FC SoC 1GHz and DDR3 1066 MT/s support
Tomi Valkeinen (1): board: ti: dra76: mux wakeup2 as gpio1_2
arch/arm/mach-keystone/include/mach/hardware.h | 3 ++ arch/arm/mach-keystone/init.c | 17 +++++++- arch/arm/mach-omap2/am33xx/clock_am33xx.c | 12 +++--- board/ti/dra7xx/mux_data.h | 2 +- board/ti/ks2_evm/board.h | 4 ++ board/ti/ks2_evm/board_k2g.c | 32 +++++++++++---- board/ti/ks2_evm/ddr3_k2g.c | 57 +++++++++++++++++++++++++- board/ti/ks2_evm/mux-k2g.h | 2 +- include/configs/k2g_evm.h | 6 ++- tools/omapimage.c | 2 +- 10 files changed, 115 insertions(+), 22 deletions(-)
Now that we have multi dtb enabled in u-boot allocate 128K space for u-boot.
Signed-off-by: Lokesh Vutla lokeshvutla@ti.com --- include/configs/k2g_evm.h | 2 +- 1 file changed, 1 insertion(+), 1 deletion(-)
diff --git a/include/configs/k2g_evm.h b/include/configs/k2g_evm.h index df81c09d86..9282a22739 100644 --- a/include/configs/k2g_evm.h +++ b/include/configs/k2g_evm.h @@ -74,7 +74,7 @@ #endif
/* SPL SPI Loader Configuration */ -#define CONFIG_SPL_TEXT_BASE 0x0c080000 +#define CONFIG_SPL_TEXT_BASE 0x0c0a0000
/* NAND Configuration */ #define CONFIG_SYS_NAND_PAGE_2K
Added support for K2G EVM with FlipChip SoC of which ARM/DDR3 runs at 1GHz/1066 MT/s. The patch is also backward compatible with old revision EVM and EVM with WireBond SoC. Their ARM/DDR3 run at 600MHz/800 MT/s.
The new SoC supports 2 different speeds at 1GHz and 600MHz. Modyfied the CPU Name to show which SoC is used in the EVM. Modified the DDR3 configuration to reflect New SoC supports 2 different CPU and DDR3 speeds, 1GHz/1066MT and 600MHz/800MT.
Added new inline function board_it_k2g_g1() for the new FlipChip 1GHz, and set the u-boot env variable board_name accordingly.
Modified findfdt script in u-boot environment variable to include new k2g board type.
Signed-off-by: Rex Chang rchang@ti.com Signed-off-by: Lokesh Vutla lokeshvutla@ti.com --- arch/arm/mach-keystone/include/mach/hardware.h | 3 ++ arch/arm/mach-keystone/init.c | 17 +++++++- board/ti/ks2_evm/board.h | 4 ++ board/ti/ks2_evm/board_k2g.c | 32 +++++++++++---- board/ti/ks2_evm/ddr3_k2g.c | 57 +++++++++++++++++++++++++- board/ti/ks2_evm/mux-k2g.h | 2 +- include/configs/k2g_evm.h | 4 +- 7 files changed, 106 insertions(+), 13 deletions(-)
diff --git a/arch/arm/mach-keystone/include/mach/hardware.h b/arch/arm/mach-keystone/include/mach/hardware.h index 6629406870..5d08418eb9 100644 --- a/arch/arm/mach-keystone/include/mach/hardware.h +++ b/arch/arm/mach-keystone/include/mach/hardware.h @@ -327,6 +327,9 @@ typedef volatile unsigned int *dv_reg_p; #define CPU_66AK2Lx 0xb9a7 #define CPU_66AK2Gx 0xbb06
+/* Variant definitions */ +#define CPU_66AK2G1x 0x08 + /* DEVSPEED register */ #define DEVSPEED_DEVSPEED_SHIFT 16 #define DEVSPEED_DEVSPEED_MASK (0xfff << 16) diff --git a/arch/arm/mach-keystone/init.c b/arch/arm/mach-keystone/init.c index 6e5a1e1af1..f9c03f1dd1 100644 --- a/arch/arm/mach-keystone/init.c +++ b/arch/arm/mach-keystone/init.c @@ -229,7 +229,19 @@ int print_cpuinfo(void) puts("66AK2Ex SR"); break; case CPU_66AK2Gx: - puts("66AK2Gx SR"); + puts("66AK2Gx"); +#ifdef CONFIG_SOC_K2G + { + int speed = get_max_arm_speed(speeds); + if (speed == SPD1000) + puts("-100 "); + else if (speed == SPD600) + puts("-60 "); + else + puts("-xx "); + } +#endif + puts("SR"); break; default: puts("Unknown\n"); @@ -241,7 +253,8 @@ int print_cpuinfo(void) puts("1.1\n"); else if (rev == 0) puts("1.0\n"); - + else if (rev == 8) + puts("1.0\n"); return 0; } #endif diff --git a/board/ti/ks2_evm/board.h b/board/ti/ks2_evm/board.h index b3ad1881fa..48d60a1c74 100644 --- a/board/ti/ks2_evm/board.h +++ b/board/ti/ks2_evm/board.h @@ -20,6 +20,10 @@ static inline int board_is_k2g_gp(void) { return board_ti_is("66AK2GGP"); } +static inline int board_is_k2g_g1(void) +{ + return board_ti_is("66AK2GG1"); +} static inline int board_is_k2g_ice(void) { return board_ti_is("66AK2GIC"); diff --git a/board/ti/ks2_evm/board_k2g.c b/board/ti/ks2_evm/board_k2g.c index 01328f1955..88df419b10 100644 --- a/board/ti/ks2_evm/board_k2g.c +++ b/board/ti/ks2_evm/board_k2g.c @@ -55,7 +55,7 @@ unsigned int get_external_clk(u32 clk) return clk_freq; }
-static int arm_speeds[DEVSPEED_NUMSPDS] = { +int speeds[DEVSPEED_NUMSPDS] = { SPD400, SPD600, SPD800, @@ -159,13 +159,20 @@ static struct pll_init_data nss_pll_config[MAX_SYSCLK] = { [SYSCLK_26MHz] = {NSS_PLL, 1000, 13, 2}, };
-static struct pll_init_data ddr3_pll_config[MAX_SYSCLK] = { +static struct pll_init_data ddr3_pll_config_800[MAX_SYSCLK] = { [SYSCLK_19MHz] = {DDR3A_PLL, 167, 1, 16}, [SYSCLK_24MHz] = {DDR3A_PLL, 133, 1, 16}, [SYSCLK_25MHz] = {DDR3A_PLL, 128, 1, 16}, [SYSCLK_26MHz] = {DDR3A_PLL, 123, 1, 16}, };
+static struct pll_init_data ddr3_pll_config_1066[MAX_SYSCLK] = { + [SYSCLK_19MHz] = {DDR3A_PLL, 194, 1, 14}, + [SYSCLK_24MHz] = {DDR3A_PLL, 156, 1, 14}, + [SYSCLK_25MHz] = {DDR3A_PLL, 149, 1, 14}, + [SYSCLK_26MHz] = {DDR3A_PLL, 144, 1, 14}, +}; + struct pll_init_data *get_pll_init_data(int pll) { int speed; @@ -178,7 +185,7 @@ struct pll_init_data *get_pll_init_data(int pll) data = &main_pll_config[sysclk_index][speed]; break; case TETRIS_PLL: - speed = get_max_arm_speed(arm_speeds); + speed = get_max_arm_speed(speeds); data = &tetris_pll_config[sysclk_index][speed]; break; case NSS_PLL: @@ -188,7 +195,15 @@ struct pll_init_data *get_pll_init_data(int pll) data = &uart_pll_config[sysclk_index]; break; case DDR3_PLL: - data = &ddr3_pll_config[sysclk_index]; + if (cpu_revision() & CPU_66AK2G1x) { + speed = get_max_arm_speed(speeds); + if (speed == SPD1000) + data = &ddr3_pll_config_1066[sysclk_index]; + else + data = &ddr3_pll_config_800[sysclk_index]; + } else { + data = &ddr3_pll_config_800[sysclk_index]; + } break; default: data = NULL; @@ -209,7 +224,7 @@ int board_mmc_init(bd_t *bis) return -1; }
- if (board_is_k2g_gp()) + if (board_is_k2g_gp() || board_is_k2g_g1()) omap_mmc_init(0, 0, 0, -1, -1);
omap_mmc_init(1, 0, 0, -1, -1); @@ -224,7 +239,8 @@ int board_fit_config_name_match(const char *name)
if (!strcmp(name, "keystone-k2g-generic") && !eeprom_read) return 0; - else if (!strcmp(name, "keystone-k2g-evm") && board_ti_is("66AK2GGP")) + else if (!strcmp(name, "keystone-k2g-evm") && + (board_ti_is("66AK2GGP") || board_ti_is("66AK2GG1"))) return 0; else if (!strcmp(name, "keystone-k2g-ice") && board_ti_is("66AK2GIC")) return 0; @@ -283,7 +299,7 @@ int embedded_dtb_select(void)
k2g_reset_mux_config();
- if (board_is_k2g_gp()) { + if (board_is_k2g_gp() || board_is_k2g_g1()) { /* deassert FLASH_HOLD */ clrbits_le32(K2G_GPIO1_BANK2_BASE + K2G_GPIO_DIR_OFFSET, BIT(9)); @@ -312,6 +328,8 @@ int board_late_init(void) #ifdef CONFIG_ENV_VARS_UBOOT_RUNTIME_CONFIG if (board_is_k2g_gp()) env_set("board_name", "66AK2GGP\0"); + else if (board_is_k2g_g1()) + env_set("board_name", "66AK2GG1\0"); else if (board_is_k2g_ice()) env_set("board_name", "66AK2GIC\0"); #endif diff --git a/board/ti/ks2_evm/ddr3_k2g.c b/board/ti/ks2_evm/ddr3_k2g.c index 44db335580..923401cfd2 100644 --- a/board/ti/ks2_evm/ddr3_k2g.c +++ b/board/ti/ks2_evm/ddr3_k2g.c @@ -10,6 +10,7 @@ #include <common.h> #include "ddr3_cfg.h" #include <asm/arch/ddr3.h> +#include <asm/arch/hardware.h> #include "board.h"
/* K2G GP EVM DDR3 Configuration */ @@ -53,6 +54,46 @@ struct ddr3_phy_config ddr3phy_800_2g = { .pir_v2 = 0x00000F81ul, };
+struct ddr3_phy_config ddr3phy_1066_2g = { + .pllcr = 0x000DC000ul, + .pgcr1_mask = (IODDRM_MASK | ZCKSEL_MASK), + .pgcr1_val = ((1 << 2) | (2 << 7) | (1 << 23)), + .ptr0 = 0x42C21590ul, + .ptr1 = 0xD05612C0ul, + .ptr2 = 0, + .ptr3 = 0x0904111Dul, + .ptr4 = 0x0859A072ul, + .dcr_mask = (PDQ_MASK | MPRDQ_MASK | BYTEMASK_MASK), + .dcr_val = ((1 << 10)), + .dtpr0 = 0x6D147744ul, + .dtpr1 = 0x32845A80ul, + .dtpr2 = 0x50023600ul, + .mr0 = 0x00001830ul, + .mr1 = 0x00000006ul, + .mr2 = 0x00000000ul, + .dtcr = 0x710035C7ul, + .pgcr2 = 0x00F05159ul, + .zq0cr1 = 0x0001005Dul, + .zq1cr1 = 0x0001005Bul, + .zq2cr1 = 0x0001005Bul, + .pir_v1 = 0x00000033ul, + .datx8_2_mask = 0, + .datx8_2_val = 0, + .datx8_3_mask = 0, + .datx8_3_val = 0, + .datx8_4_mask = 0, + .datx8_4_val = ((1 << 0)), + .datx8_5_mask = DXEN_MASK, + .datx8_5_val = 0, + .datx8_6_mask = DXEN_MASK, + .datx8_6_val = 0, + .datx8_7_mask = DXEN_MASK, + .datx8_7_val = 0, + .datx8_8_mask = DXEN_MASK, + .datx8_8_val = 0, + .pir_v2 = 0x00000F81ul, +}; + struct ddr3_emif_config ddr3_800_2g = { .sdcfg = 0x62005662ul, .sdtim1 = 0x0A385033ul, @@ -63,6 +104,16 @@ struct ddr3_emif_config ddr3_800_2g = { .sdrfc = 0x00000C34ul, };
+struct ddr3_emif_config ddr3_1066_2g = { + .sdcfg = 0x62005662ul, + .sdtim1 = 0x0E4C6843ul, + .sdtim2 = 0x00001CC6ul, + .sdtim3 = 0x323DFF32ul, + .sdtim4 = 0x533F08AFul, + .zqcfg = 0x70073200ul, + .sdrfc = 0x00001044ul, +}; + /* K2G ICE evm DDR3 Configuration */ struct ddr3_phy_config ddr3phy_800_512mb = { .pllcr = 0x000DC000ul, @@ -118,8 +169,10 @@ u32 ddr3_init(void) { /* Reset DDR3 PHY after PLL enabled */ ddr3_reset_ddrphy(); - - if (board_is_k2g_gp()) { + if (board_is_k2g_g1()) { + ddr3_init_ddrphy(KS2_DDR3A_DDRPHYC, &ddr3phy_1066_2g); + ddr3_init_ddremif(KS2_DDR3A_EMIF_CTRL_BASE, &ddr3_1066_2g); + } else if (board_is_k2g_gp()) { ddr3_init_ddrphy(KS2_DDR3A_DDRPHYC, &ddr3phy_800_2g); ddr3_init_ddremif(KS2_DDR3A_EMIF_CTRL_BASE, &ddr3_800_2g); } else if (board_is_k2g_ice()) { diff --git a/board/ti/ks2_evm/mux-k2g.h b/board/ti/ks2_evm/mux-k2g.h index 630103d0ff..9e3fa11003 100644 --- a/board/ti/ks2_evm/mux-k2g.h +++ b/board/ti/ks2_evm/mux-k2g.h @@ -345,7 +345,7 @@ void k2g_mux_config(void) { if (!board_ti_was_eeprom_read()) { configure_pin_mux(k2g_generic_pin_cfg); - } else if (board_is_k2g_gp()) { + } else if (board_is_k2g_gp() || board_is_k2g_g1()) { configure_pin_mux(k2g_evm_pin_cfg); } else if (board_is_k2g_ice()) { configure_pin_mux(k2g_ice_evm_pin_cfg); diff --git a/include/configs/k2g_evm.h b/include/configs/k2g_evm.h index 9282a22739..4e43104fac 100644 --- a/include/configs/k2g_evm.h +++ b/include/configs/k2g_evm.h @@ -34,11 +34,13 @@ "findfdt="\ "if test $board_name = 66AK2GGP; then " \ "setenv name_fdt keystone-k2g-evm.dtb; " \ + "else if test $board_name = 66AK2GG1; then " \ + "setenv name_fdt keystone-k2g-evm.dtb; " \ "else if test $board_name = 66AK2GIC; then " \ "setenv name_fdt keystone-k2g-ice.dtb; " \ "else if test $name_fdt = undefined; then " \ "echo WARNING: Could not determine device tree to use;"\ - "fi;fi;fi; setenv fdtfile ${name_fdt}\0" \ + "fi;fi;fi;fi; setenv fdtfile ${name_fdt}\0" \ "name_mon=skern-k2g.bin\0" \ "name_ubi=k2g-evm-ubifs.ubi\0" \ "name_uboot=u-boot-spi-k2g-evm.gph\0" \
[snip]
With some quick git grep'ing, this should still be static, yes? And then board/ti/ks2_evm/board_k2e.c should have its existing field marked as static too.
[snip]
[snip]
And then all of these too should be static?
[snip]
For k2g, speeds array is used in arch/arm/mach-keystone/init.c. So removed static from here. For k2e yes, it should be static. Will send a separate patch for fixing it.
[snip]
[snip]
Right, will post v3 fixing this.
Thanks and regards, Lokesh
The size field in GP header that is expected by ROM is size of the image + size of the header. But omapimage tool is updating size as image size + 2 * header size. Remove this extra header size bytes.
Reported-by: Denys Dmytriyenko denys@ti.com Debugged-by: Madan Srinivas madans@ti.com Signed-off-by: Lokesh Vutla lokeshvutla@ti.com --- tools/omapimage.c | 2 +- 1 file changed, 1 insertion(+), 1 deletion(-)
diff --git a/tools/omapimage.c b/tools/omapimage.c index e7c46388f4..01e02649e1 100644 --- a/tools/omapimage.c +++ b/tools/omapimage.c @@ -145,7 +145,7 @@ static void omapimage_set_header(void *ptr, struct stat *sbuf, int ifd, toc++; memset(toc, 0xff, sizeof(*toc));
- gph_set_header(gph, sbuf->st_size - OMAP_CH_HDR_SIZE + GPIMAGE_HDR_SIZE, + gph_set_header(gph, sbuf->st_size - OMAP_CH_HDR_SIZE, params->addr, 0);
if (strncmp(params->imagename, "byteswap", 8) == 0) {
DPLL DRR doesn't have an M4 divider. But the clock driver is trying to configure M4 divider as 4(writing into a reserved register). Fixing it by making M4 divider as -1.
Reported-by: Steve Kipisz s-kipisz2@ti.com Signed-off-by: Lokesh Vutla lokeshvutla@ti.com --- arch/arm/mach-omap2/am33xx/clock_am33xx.c | 12 ++++++------ 1 file changed, 6 insertions(+), 6 deletions(-)
diff --git a/arch/arm/mach-omap2/am33xx/clock_am33xx.c b/arch/arm/mach-omap2/am33xx/clock_am33xx.c index 1780bbdb6f..2352c37822 100644 --- a/arch/arm/mach-omap2/am33xx/clock_am33xx.c +++ b/arch/arm/mach-omap2/am33xx/clock_am33xx.c @@ -109,22 +109,22 @@ const struct dpll_params dpll_per_192MHz[NUM_CRYSTAL_FREQ] = { const struct dpll_params dpll_ddr3_303MHz[NUM_CRYSTAL_FREQ] = { {505, 15, 2, -1, -1, -1, -1}, /*19.2*/ {101, 3, 2, -1, -1, -1, -1}, /* 24 MHz */ - {303, 24, 1, -1, 4, -1, -1}, /* 25 MHz */ - {303, 12, 2, -1, 4, -1, -1} /* 26 MHz */ + {303, 24, 1, -1, -1, -1, -1}, /* 25 MHz */ + {303, 12, 2, -1, -1, -1, -1} /* 26 MHz */ };
const struct dpll_params dpll_ddr3_400MHz[NUM_CRYSTAL_FREQ] = { {125, 5, 1, -1, -1, -1, -1}, /*19.2*/ {50, 2, 1, -1, -1, -1, -1}, /* 24 MHz */ - {16, 0, 1, -1, 4, -1, -1}, /* 25 MHz */ - {200, 12, 1, -1, 4, -1, -1} /* 26 MHz */ + {16, 0, 1, -1, -1, -1, -1}, /* 25 MHz */ + {200, 12, 1, -1, -1, -1, -1} /* 26 MHz */ };
const struct dpll_params dpll_ddr2_266MHz[NUM_CRYSTAL_FREQ] = { {665, 47, 1, -1, -1, -1, -1}, /*19.2*/ {133, 11, 1, -1, -1, -1, -1}, /* 24 MHz */ - {266, 24, 1, -1, 4, -1, -1}, /* 25 MHz */ - {133, 12, 1, -1, 4, -1, -1} /* 26 MHz */ + {266, 24, 1, -1, -1, -1, -1}, /* 25 MHz */ + {133, 12, 1, -1, -1, -1, -1} /* 26 MHz */ };
__weak const struct dpll_params *get_dpll_mpu_params(void)
gpio1_2 is used for HPD interrupt with DRA76's DVI add-on board, so mux the pin as gpio and PIN_INPUT.
Signed-off-by: Tomi Valkeinen tomi.valkeinen@ti.com --- board/ti/dra7xx/mux_data.h | 2 +- 1 file changed, 1 insertion(+), 1 deletion(-)
diff --git a/board/ti/dra7xx/mux_data.h b/board/ti/dra7xx/mux_data.h index 3c3a19a0e1..b5dcaa584a 100644 --- a/board/ti/dra7xx/mux_data.h +++ b/board/ti/dra7xx/mux_data.h @@ -882,7 +882,7 @@ const struct pad_conf_entry dra76x_core_padconf_array[] = { {I2C2_SCL, (M1 | PIN_INPUT_PULLUP)}, /* i2c2_scl.hdmi1_ddc_sda */ {WAKEUP0, (M14 | PIN_OUTPUT)}, /* N/A.gpio1_0 */ {WAKEUP1, (M14 | PIN_OUTPUT)}, /* N/A.gpio1_1 */ - {WAKEUP2, (M1 | PIN_OUTPUT)}, /* N/A.sys_nirq2 */ + {WAKEUP2, (M14 | PIN_INPUT)}, /* N/A.gpio1_2 */ {WAKEUP3, (M1 | PIN_OUTPUT)}, /* N/A.sys_nirq1 */ };
Lokesh Vutla
