[PATCH] ddr: socfpga: Fix integer overflow
dramaddrw data structure are defined as u32. Compiler assume 32-bit arithmetic on expression and the shifting operation to be done on a 32-bit value. So, the expression would overflow if the shifting is more than 32-bit.
Signed-off-by: Tien Fong Chee tien.fong.chee@intel.com --- drivers/ddr/altera/sdram_soc64.c | 2 +- 1 file changed, 1 insertion(+), 1 deletion(-)
diff --git a/drivers/ddr/altera/sdram_soc64.c b/drivers/ddr/altera/sdram_soc64.c index 9b1710c135..81ad02118b 100644 --- a/drivers/ddr/altera/sdram_soc64.c +++ b/drivers/ddr/altera/sdram_soc64.c @@ -246,7 +246,7 @@ phys_size_t sdram_calculate_size(struct altera_sdram_plat *plat) DRAMADDRW_CFG_ROW_ADDR_WIDTH(dramaddrw) + DRAMADDRW_CFG_COL_ADDR_WIDTH(dramaddrw));
- size *= (2 << (hmc_ecc_readl(plat, DDRIOCTRL) & + size *= ((phys_size_t)2 << (hmc_ecc_readl(plat, DDRIOCTRL) & DDR_HMC_DDRIOCTRL_IOSIZE_MSK));
return size;
- size *= ((phys_size_t)2 << (hmc_ecc_readl(plat, DDRIOCTRL) &
What about using 2UL or 2ULL here, would that work too ?
Jit Loon Lim
