[PATCH v2 1/2] rockchip: rk3399: fix incorrect ifdef check on SPL_DM_REGULATOR
From: Quentin Schulz quentin.schulz@theobroma-systems.com
The check to perform is on CONFIG_SPL_DM_REGULATOR and not SPL_DM_REGULATOR. Also switch to in-code check instead of ifdefs.
Fixes: 07586ee4322a ("rockchip: rk3399: Support common spl_board_init") Cc: Quentin Schulz foss+uboot@0leil.net Signed-off-by: Quentin Schulz quentin.schulz@theobroma-systems.com ---
v2: - use IS_ENABLED checks,
arch/arm/mach-rockchip/rk3399/rk3399.c | 17 +++++++++-------- 1 file changed, 9 insertions(+), 8 deletions(-)
diff --git a/arch/arm/mach-rockchip/rk3399/rk3399.c b/arch/arm/mach-rockchip/rk3399/rk3399.c index de11a3fa30..920da22307 100644 --- a/arch/arm/mach-rockchip/rk3399/rk3399.c +++ b/arch/arm/mach-rockchip/rk3399/rk3399.c @@ -275,13 +275,14 @@ void spl_board_init(void) rk3399_force_power_on_reset(); #endif
-#if defined(SPL_DM_REGULATOR) - /* - * Turning the eMMC and SPI back on (if disabled via the Qseven - * BIOS_ENABLE) signal is done through a always-on regulator). - */ - if (regulators_enable_boot_on(false)) - debug("%s: Cannot enable boot on regulator\n", __func__); -#endif + if (IS_ENABLED(CONFIG_SPL_DM_REGULATOR)) { + /* + * Turning the eMMC and SPI back on (if disabled via the Qseven + * BIOS_ENABLE) signal is done through a always-on regulator). + */ + if (regulators_enable_boot_on(false)) + debug("%s: Cannot enable boot on regulator\n", + __func__); + } } #endif
The check to perform is on CONFIG_SPL_GPIO and not SPL_GPIO. Because this was never compiled in, it missed an include of cru.h that was not detected before. Let's include it too.
Also switch to IS_ENABLED ifdef and in-code check.
arch/arm/mach-rockchip/rk3399/rk3399.c | 45 ++++++++++++++------------ 1 file changed, 24 insertions(+), 21 deletions(-)
diff --git a/arch/arm/mach-rockchip/rk3399/rk3399.c b/arch/arm/mach-rockchip/rk3399/rk3399.c index 920da22307..db8a6cb83a 100644 --- a/arch/arm/mach-rockchip/rk3399/rk3399.c +++ b/arch/arm/mach-rockchip/rk3399/rk3399.c @@ -221,7 +221,9 @@ void spl_perform_fixups(struct spl_image_info *spl_image) "u-boot,spl-boot-device", boot_ofpath); }
-#if defined(SPL_GPIO) +#if IS_ENABLED(CONFIG_SPL_GPIO) + +#include <asm/arch-rockchip/cru.h> static void rk3399_force_power_on_reset(void) { ofnode node; @@ -253,27 +255,28 @@ void spl_board_init(void) { led_setup();
-#if defined(SPL_GPIO) - struct rockchip_cru *cru = rockchip_get_cru(); + if (IS_ENABLED(CONFIG_SPL_GPIO)) { + struct rockchip_cru *cru = rockchip_get_cru();
- /* - * The RK3399 resets only 'almost all logic' (see also in the TRM - * "3.9.4 Global software reset"), when issuing a software reset. - * This may cause issues during boot-up for some configurations of - * the application software stack. - * - * To work around this, we test whether the last reset reason was - * a power-on reset and (if not) issue an overtemp-reset to reset - * the entire module. - * - * While this was previously fixed by modifying the various places - * that could generate a software reset (e.g. U-Boot's sysreset - * driver, the ATF or Linux), we now have it here to ensure that - * we no longer have to track this through the various components. - */ - if (cru->glb_rst_st != 0) - rk3399_force_power_on_reset(); -#endif + /* + * The RK3399 resets only 'almost all logic' (see also in the + * TRM "3.9.4 Global software reset"), when issuing a software + * reset. This may cause issues during boot-up for some + * configurations of the application software stack. + * + * To work around this, we test whether the last reset reason + * was a power-on reset and (if not) issue an overtemp-reset to + * reset the entire module. + * + * While this was previously fixed by modifying the various + * places that could generate a software reset (e.g. U-Boot's + * sysreset driver, the ATF or Linux), we now have it here to + * ensure that we no longer have to track this through the + * various components. + */ + if (cru->glb_rst_st != 0) + rk3399_force_power_on_reset(); + }
if (IS_ENABLED(CONFIG_SPL_DM_REGULATOR)) { /*
El Fri, Jul 15, 2022 at 05:09:49PM +0200, Quentin Schulz deia:
Thank you. That helps when CONGIF_SPL_GPIO is enabled. But in case CONFIG_SPL_GPIO is disabled...
v2:
then (if CONFIG_SPL_GPIO is disabled...) the include is not in effect, but the call to
the #endif for that #if is somewhere over here.
- if (IS_ENABLED(CONFIG_SPL_GPIO)) {
This gives me a compilation error (rock-pi-4, CONFIG_SPL_GPIO disabled), because of the missing include defining rockchip_cru (and glb_rst_st as a member of it)
This gives a warning, because the function declaration is #ifdefed out.
So we could leave the include outside the #if defined(SPL_GPIO) and add an inline dummy function in #else,
or we could change the if (IS_ENABLED(CONFIG_SPL_GPIO)) to #if (IS_ENABLED(CONFIG_SPL_GPIO))
I think the first is preferred in U-Boot, but not sure if that might somehow make SPL bigger or something. I don't think so.
I've tested this on a Rock-Pi-4B, but with the patch below on top and I haven't seen any regression. So, with this small correction:
Tested-by: Xavier Drudis Ferran xdrudis@tinet.cat
v2:
-#endif
-- 2.36.1
The small correction (now that I think of it, the include might as well go at the top of file):
--- arch/arm/mach-rockchip/rk3399/rk3399.c | 6 +++++- 1 file changed, 5 insertions(+), 1 deletion(-)
diff --git a/arch/arm/mach-rockchip/rk3399/rk3399.c b/arch/arm/mach-rockchip/rk3399/rk3399.c index fced5c7e21..10b911f998 100644 --- a/arch/arm/mach-rockchip/rk3399/rk3399.c +++ b/arch/arm/mach-rockchip/rk3399/rk3399.c @@ -221,9 +221,9 @@ void spl_perform_fixups(struct spl_image_info *spl_image) "u-boot,spl-boot-device", boot_ofpath); }
+#include <asm/arch-rockchip/cru.h> #if IS_ENABLED(CONFIG_SPL_GPIO)
-#include <asm/arch-rockchip/cru.h> static void rk3399_force_power_on_reset(void) { ofnode node; @@ -245,6 +245,10 @@ static void rk3399_force_power_on_reset(void)
dm_gpio_set_value(&sysreset_gpio, 1); } +#else +static inline void rk3399_force_power_on_reset(void) +{ +} #endif
void __weak led_setup(void)
El Fri, Jul 15, 2022 at 05:09:48PM +0200, Quentin Schulz deia:
Tested it on a Rock-Pi-4 with the patch below on top. So with the small correction:
v2:
-#endif
- if (IS_ENABLED(CONFIG_SPL_DM_REGULATOR)) {
__func__);
#endif
2.36.1
The small correction:
--- common/spl/spl.c | 2 -- include/power/regulator.h | 5 +++++ 2 files changed, 5 insertions(+), 2 deletions(-)
diff --git a/common/spl/spl.c b/common/spl/spl.c index 70c11aa275..6ab997279d 100644 --- a/common/spl/spl.c +++ b/common/spl/spl.c @@ -39,9 +39,7 @@ #include <fdt_support.h> #include <bootcount.h> #include <wdt.h> -#if CONFIG_IS_ENABLED(DM_REGULATOR) #include <power/regulator.h> -#endif
DECLARE_GLOBAL_DATA_PTR; DECLARE_BINMAN_MAGIC_SYM; diff --git a/include/power/regulator.h b/include/power/regulator.h index ff1bfc2435..4bce61dd9f 100644 --- a/include/power/regulator.h +++ b/include/power/regulator.h @@ -631,6 +631,11 @@ static inline int regulators_enable_boot_on(bool verbose) return -ENOSYS; }
+static inline int regulators_enable_boot_off(bool verbose) +{ + return -ENOSYS; +} + static inline int regulator_autoset(struct udevice *dev) { return -ENOSYS;
Quentin Schulz
