[U-Boot] [PATCH] Convert CONFIG_CONS_INDEX to Kconfig
This converts the following to Kconfig: CONFIG_CONS_INDEX
This was already in Kconfig for the TARGET_DRA7XX_EVM, so this moves it to the common console area and allows for UARTS 0-6 and defaults to UART1
Signed-off-by: Adam Ford aford173@gmail.com
diff --git a/arch/arm/include/asm/arch-bcmcygnus/configs.h b/arch/arm/include/asm/arch-bcmcygnus/configs.h index 92b1c5e..5f0164c 100644 --- a/arch/arm/include/asm/arch-bcmcygnus/configs.h +++ b/arch/arm/include/asm/arch-bcmcygnus/configs.h @@ -19,7 +19,6 @@ #define CONFIG_SYS_NS16550_CLK 100000000 #define CONFIG_SYS_NS16550_CLK_DIV 54 #define CONFIG_SERIAL_MULTI -#define CONFIG_CONS_INDEX 3 #define CONFIG_SYS_NS16550_COM3 0x18023000
/* Ethernet */ diff --git a/arch/arm/include/asm/arch-bcmnsp/configs.h b/arch/arm/include/asm/arch-bcmnsp/configs.h index 786deae..d3f3be3 100644 --- a/arch/arm/include/asm/arch-bcmnsp/configs.h +++ b/arch/arm/include/asm/arch-bcmnsp/configs.h @@ -16,7 +16,6 @@ #define CONFIG_SYS_NS16550_REG_SIZE 1
#define CONFIG_SYS_NS16550_CLK 0x03b9aca0 -#define CONFIG_CONS_INDEX 1 #define CONFIG_SYS_NS16550_COM1 0x18000300
#endif /* __ARCH_CONFIGS_H */ diff --git a/arch/arm/include/asm/arch-lpc32xx/config.h b/arch/arm/include/asm/arch-lpc32xx/config.h index 3b7f6bd..988a851 100644 --- a/arch/arm/include/asm/arch-lpc32xx/config.h +++ b/arch/arm/include/asm/arch-lpc32xx/config.h @@ -27,12 +27,6 @@ #define CONFIG_SYS_NS16550_CLK 13000000 #endif
-#if !defined(CONFIG_LPC32XX_HSUART) -#define CONFIG_CONS_INDEX (CONFIG_SYS_LPC32XX_UART - 2) -#else -#define CONFIG_CONS_INDEX CONFIG_SYS_LPC32XX_UART -#endif - #define CONFIG_SYS_BAUDRATE_TABLE \ { 9600, 19200, 38400, 57600, 115200, 230400, 460800 }
diff --git a/board/ti/dra7xx/Kconfig b/board/ti/dra7xx/Kconfig index b642113..f6a8e07 100644 --- a/board/ti/dra7xx/Kconfig +++ b/board/ti/dra7xx/Kconfig @@ -9,15 +9,6 @@ config SYS_VENDOR config SYS_CONFIG_NAME default "dra7xx_evm"
-config CONS_INDEX - int "UART used for console" - range 1 6 - default 1 - help - The DRA7xx (and AM57x) SoC has a total of 6 UARTs available to it. - Depending on your specific board you may want something other than UART1 - here. - source "board/ti/common/Kconfig"
endif diff --git a/common/Kconfig b/common/Kconfig index b92d0e3..496ac50 100644 --- a/common/Kconfig +++ b/common/Kconfig @@ -225,6 +225,14 @@ config MENU This is the library functionality to provide a text-based menu of choices for the user to make choices with.
+config CONS_INDEX + int "UART used for console" + range 0 6 + default 1 if !OMAP34XX + default 3 if OMAP34XX + help + Set this to match the UART number of the serial console. + config CONSOLE_RECORD bool "Console recording" help diff --git a/configs/MPC8541CDS_defconfig b/configs/MPC8541CDS_defconfig index 155c5d8..9c9c7fb 100644 --- a/configs/MPC8541CDS_defconfig +++ b/configs/MPC8541CDS_defconfig @@ -1,5 +1,6 @@ CONFIG_PPC=y CONFIG_SYS_TEXT_BASE=0xfff80000 +CONFIG_CONS_INDEX=2 CONFIG_MPC85xx=y # CONFIG_CMD_ERRATA is not set CONFIG_TARGET_MPC8541CDS=y diff --git a/configs/MPC8541CDS_legacy_defconfig b/configs/MPC8541CDS_legacy_defconfig index 7f609be..5c65cd5 100644 --- a/configs/MPC8541CDS_legacy_defconfig +++ b/configs/MPC8541CDS_legacy_defconfig @@ -1,5 +1,6 @@ CONFIG_PPC=y CONFIG_SYS_TEXT_BASE=0xfff80000 +CONFIG_CONS_INDEX=2 CONFIG_MPC85xx=y # CONFIG_CMD_ERRATA is not set CONFIG_TARGET_MPC8541CDS=y diff --git a/configs/MPC8548CDS_36BIT_defconfig b/configs/MPC8548CDS_36BIT_defconfig index 24a5251..d916d14 100644 --- a/configs/MPC8548CDS_36BIT_defconfig +++ b/configs/MPC8548CDS_36BIT_defconfig @@ -1,5 +1,6 @@ CONFIG_PPC=y CONFIG_SYS_TEXT_BASE=0xFFF80000 +CONFIG_CONS_INDEX=2 CONFIG_MPC85xx=y # CONFIG_CMD_ERRATA is not set CONFIG_TARGET_MPC8548CDS=y diff --git a/configs/MPC8548CDS_defconfig b/configs/MPC8548CDS_defconfig index 287639f..1aecae1 100644 --- a/configs/MPC8548CDS_defconfig +++ b/configs/MPC8548CDS_defconfig @@ -1,5 +1,6 @@ CONFIG_PPC=y CONFIG_SYS_TEXT_BASE=0xFFF80000 +CONFIG_CONS_INDEX=2 CONFIG_MPC85xx=y # CONFIG_CMD_ERRATA is not set CONFIG_TARGET_MPC8548CDS=y diff --git a/configs/MPC8548CDS_legacy_defconfig b/configs/MPC8548CDS_legacy_defconfig index 9403d47..b14c087 100644 --- a/configs/MPC8548CDS_legacy_defconfig +++ b/configs/MPC8548CDS_legacy_defconfig @@ -1,5 +1,6 @@ CONFIG_PPC=y CONFIG_SYS_TEXT_BASE=0xFFF80000 +CONFIG_CONS_INDEX=2 CONFIG_MPC85xx=y # CONFIG_CMD_ERRATA is not set CONFIG_TARGET_MPC8548CDS=y diff --git a/configs/MPC8555CDS_defconfig b/configs/MPC8555CDS_defconfig index ce7fa65..07fa74d 100644 --- a/configs/MPC8555CDS_defconfig +++ b/configs/MPC8555CDS_defconfig @@ -1,5 +1,6 @@ CONFIG_PPC=y CONFIG_SYS_TEXT_BASE=0xfff80000 +CONFIG_CONS_INDEX=2 CONFIG_MPC85xx=y # CONFIG_CMD_ERRATA is not set CONFIG_TARGET_MPC8555CDS=y diff --git a/configs/MPC8555CDS_legacy_defconfig b/configs/MPC8555CDS_legacy_defconfig index a4b964e..bc2f136 100644 --- a/configs/MPC8555CDS_legacy_defconfig +++ b/configs/MPC8555CDS_legacy_defconfig @@ -1,5 +1,6 @@ CONFIG_PPC=y CONFIG_SYS_TEXT_BASE=0xfff80000 +CONFIG_CONS_INDEX=2 CONFIG_MPC85xx=y # CONFIG_CMD_ERRATA is not set CONFIG_TARGET_MPC8555CDS=y diff --git a/configs/am43xx_evm_defconfig b/configs/am43xx_evm_defconfig index 172b292..b90f14d 100644 --- a/configs/am43xx_evm_defconfig +++ b/configs/am43xx_evm_defconfig @@ -6,7 +6,6 @@ CONFIG_AM43XX=y CONFIG_DEFAULT_DEVICE_TREE="am437x-gp-evm" CONFIG_DISTRO_DEFAULTS=y CONFIG_SPL_LOAD_FIT=y -CONFIG_SYS_EXTRA_OPTIONS="CONS_INDEX=1" # CONFIG_USE_BOOTCOMMAND is not set CONFIG_SYS_CONSOLE_INFO_QUIET=y CONFIG_VERSION_VARIABLE=y diff --git a/configs/am43xx_evm_ethboot_defconfig b/configs/am43xx_evm_ethboot_defconfig index 835a58d..ed3b858 100644 --- a/configs/am43xx_evm_ethboot_defconfig +++ b/configs/am43xx_evm_ethboot_defconfig @@ -2,7 +2,7 @@ CONFIG_ARM=y CONFIG_ARCH_OMAP2PLUS=y CONFIG_AM43XX=y CONFIG_DISTRO_DEFAULTS=y -CONFIG_SYS_EXTRA_OPTIONS="SERIAL1,CONS_INDEX=1" +CONFIG_SYS_EXTRA_OPTIONS="SERIAL1" # CONFIG_USE_BOOTCOMMAND is not set CONFIG_SYS_CONSOLE_INFO_QUIET=y CONFIG_VERSION_VARIABLE=y diff --git a/configs/am43xx_evm_qspiboot_defconfig b/configs/am43xx_evm_qspiboot_defconfig index 2bc302c..958174f 100644 --- a/configs/am43xx_evm_qspiboot_defconfig +++ b/configs/am43xx_evm_qspiboot_defconfig @@ -4,7 +4,7 @@ CONFIG_ARCH_OMAP2PLUS=y CONFIG_SYS_TEXT_BASE=0x30000000 CONFIG_AM43XX=y CONFIG_DISTRO_DEFAULTS=y -CONFIG_SYS_EXTRA_OPTIONS="SERIAL1,CONS_INDEX=1,QSPI,QSPI_BOOT" +CONFIG_SYS_EXTRA_OPTIONS="SERIAL1,QSPI,QSPI_BOOT" CONFIG_QSPI_BOOT=y # CONFIG_USE_BOOTCOMMAND is not set CONFIG_SYS_CONSOLE_INFO_QUIET=y diff --git a/configs/am43xx_evm_usbhost_boot_defconfig b/configs/am43xx_evm_usbhost_boot_defconfig index 7ca24d5..a6a71b5 100644 --- a/configs/am43xx_evm_usbhost_boot_defconfig +++ b/configs/am43xx_evm_usbhost_boot_defconfig @@ -6,7 +6,7 @@ CONFIG_ISW_ENTRY_ADDR=0x40300350 CONFIG_DEFAULT_DEVICE_TREE="am437x-gp-evm" CONFIG_DISTRO_DEFAULTS=y CONFIG_SPL_LOAD_FIT=y -CONFIG_SYS_EXTRA_OPTIONS="SERIAL1,CONS_INDEX=1" +CONFIG_SYS_EXTRA_OPTIONS="SERIAL1" # CONFIG_USE_BOOTCOMMAND is not set CONFIG_SYS_CONSOLE_INFO_QUIET=y CONFIG_VERSION_VARIABLE=y diff --git a/configs/am43xx_hs_evm_defconfig b/configs/am43xx_hs_evm_defconfig index 170d7c0..cce4406 100644 --- a/configs/am43xx_hs_evm_defconfig +++ b/configs/am43xx_hs_evm_defconfig @@ -14,7 +14,6 @@ CONFIG_FIT_IMAGE_POST_PROCESS=y CONFIG_SPL_LOAD_FIT=y CONFIG_SPL_FIT_IMAGE_POST_PROCESS=y CONFIG_OF_BOARD_SETUP=y -CONFIG_SYS_EXTRA_OPTIONS="CONS_INDEX=1" # CONFIG_USE_BOOTCOMMAND is not set CONFIG_SYS_CONSOLE_INFO_QUIET=y CONFIG_VERSION_VARIABLE=y diff --git a/configs/apx4devkit_defconfig b/configs/apx4devkit_defconfig index ea4e18e..65ddaa2 100644 --- a/configs/apx4devkit_defconfig +++ b/configs/apx4devkit_defconfig @@ -5,6 +5,7 @@ CONFIG_SPL_GPIO_SUPPORT=y CONFIG_SPL_LIBCOMMON_SUPPORT=y CONFIG_SPL_LIBGENERIC_SUPPORT=y CONFIG_TARGET_APX4DEVKIT=y +CONFIG_CONS_INDEX=0 CONFIG_SPL_SERIAL_SUPPORT=y CONFIG_BOOTDELAY=1 CONFIG_VERSION_VARIABLE=y diff --git a/configs/bcm911360_entphn-ns_defconfig b/configs/bcm911360_entphn-ns_defconfig index 948ac1c..7441d14 100644 --- a/configs/bcm911360_entphn-ns_defconfig +++ b/configs/bcm911360_entphn-ns_defconfig @@ -1,6 +1,7 @@ CONFIG_ARM=y CONFIG_TARGET_BCMCYGNUS=y CONFIG_SYS_TEXT_BASE=0x61000000 +CONFIG_CONS_INDEX=3 CONFIG_SYS_EXTRA_OPTIONS="SYS_SDRAM_SIZE=0x20000000,ARMV7_NONSEC" CONFIG_VERSION_VARIABLE=y # CONFIG_DISPLAY_CPUINFO is not set diff --git a/configs/bcm911360_entphn_defconfig b/configs/bcm911360_entphn_defconfig index 60e9ad6..d6d8556 100644 --- a/configs/bcm911360_entphn_defconfig +++ b/configs/bcm911360_entphn_defconfig @@ -1,6 +1,7 @@ CONFIG_ARM=y CONFIG_TARGET_BCMCYGNUS=y CONFIG_SYS_TEXT_BASE=0x61000000 +CONFIG_CONS_INDEX=3 CONFIG_SYS_EXTRA_OPTIONS="SYS_SDRAM_SIZE=0x20000000" CONFIG_VERSION_VARIABLE=y # CONFIG_DISPLAY_CPUINFO is not set diff --git a/configs/bcm911360k_defconfig b/configs/bcm911360k_defconfig index d44555f..300819a 100644 --- a/configs/bcm911360k_defconfig +++ b/configs/bcm911360k_defconfig @@ -1,6 +1,7 @@ CONFIG_ARM=y CONFIG_TARGET_BCMCYGNUS=y CONFIG_SYS_TEXT_BASE=0x61000000 +CONFIG_CONS_INDEX=3 CONFIG_SYS_EXTRA_OPTIONS="SYS_SDRAM_SIZE=0x40000000" CONFIG_VERSION_VARIABLE=y # CONFIG_DISPLAY_CPUINFO is not set diff --git a/configs/bcm958300k-ns_defconfig b/configs/bcm958300k-ns_defconfig index 1e78d03..a5b8b51 100644 --- a/configs/bcm958300k-ns_defconfig +++ b/configs/bcm958300k-ns_defconfig @@ -1,6 +1,7 @@ CONFIG_ARM=y CONFIG_TARGET_BCMCYGNUS=y CONFIG_SYS_TEXT_BASE=0x61000000 +CONFIG_CONS_INDEX=3 CONFIG_SYS_EXTRA_OPTIONS="SYS_SDRAM_SIZE=0x40000000,ARMV7_NONSEC" CONFIG_VERSION_VARIABLE=y # CONFIG_DISPLAY_CPUINFO is not set diff --git a/configs/bcm958300k_defconfig b/configs/bcm958300k_defconfig index d44555f..300819a 100644 --- a/configs/bcm958300k_defconfig +++ b/configs/bcm958300k_defconfig @@ -1,6 +1,7 @@ CONFIG_ARM=y CONFIG_TARGET_BCMCYGNUS=y CONFIG_SYS_TEXT_BASE=0x61000000 +CONFIG_CONS_INDEX=3 CONFIG_SYS_EXTRA_OPTIONS="SYS_SDRAM_SIZE=0x40000000" CONFIG_VERSION_VARIABLE=y # CONFIG_DISPLAY_CPUINFO is not set diff --git a/configs/bcm958305k_defconfig b/configs/bcm958305k_defconfig index d44555f..300819a 100644 --- a/configs/bcm958305k_defconfig +++ b/configs/bcm958305k_defconfig @@ -1,6 +1,7 @@ CONFIG_ARM=y CONFIG_TARGET_BCMCYGNUS=y CONFIG_SYS_TEXT_BASE=0x61000000 +CONFIG_CONS_INDEX=3 CONFIG_SYS_EXTRA_OPTIONS="SYS_SDRAM_SIZE=0x40000000" CONFIG_VERSION_VARIABLE=y # CONFIG_DISPLAY_CPUINFO is not set diff --git a/configs/bcm958712k_defconfig b/configs/bcm958712k_defconfig index 48c772e..cb9a2fb 100644 --- a/configs/bcm958712k_defconfig +++ b/configs/bcm958712k_defconfig @@ -1,6 +1,7 @@ CONFIG_ARM=y CONFIG_TARGET_BCMNS2=y CONFIG_SYS_TEXT_BASE=0x85000000 +CONFIG_CONS_INDEX=4 CONFIG_IDENT_STRING=" Broadcom Northstar 2" CONFIG_DISTRO_DEFAULTS=y CONFIG_BOOTDELAY=5 diff --git a/configs/bg0900_defconfig b/configs/bg0900_defconfig index 797d113..8e44824 100644 --- a/configs/bg0900_defconfig +++ b/configs/bg0900_defconfig @@ -5,6 +5,7 @@ CONFIG_SPL_GPIO_SUPPORT=y CONFIG_SPL_LIBCOMMON_SUPPORT=y CONFIG_SPL_LIBGENERIC_SUPPORT=y CONFIG_TARGET_BG0900=y +CONFIG_CONS_INDEX=0 CONFIG_SPL_SERIAL_SUPPORT=y CONFIG_BOOTDELAY=3 CONFIG_USE_BOOTARGS=y diff --git a/configs/birdland_bav335a_defconfig b/configs/birdland_bav335a_defconfig index 823fc74..0ce5cc9 100644 --- a/configs/birdland_bav335a_defconfig +++ b/configs/birdland_bav335a_defconfig @@ -13,7 +13,7 @@ CONFIG_SPL_WATCHDOG_SUPPORT=y CONFIG_SPL_FAT_SUPPORT=y CONFIG_BAV_VERSION=1 CONFIG_DISTRO_DEFAULTS=y -CONFIG_SYS_EXTRA_OPTIONS="SERIAL1,CONS_INDEX=1" +CONFIG_SYS_EXTRA_OPTIONS="SERIAL1" # CONFIG_USE_BOOTCOMMAND is not set CONFIG_SYS_CONSOLE_INFO_QUIET=y CONFIG_VERSION_VARIABLE=y diff --git a/configs/birdland_bav335b_defconfig b/configs/birdland_bav335b_defconfig index 6d12aba..5316d6f 100644 --- a/configs/birdland_bav335b_defconfig +++ b/configs/birdland_bav335b_defconfig @@ -13,7 +13,7 @@ CONFIG_SPL_WATCHDOG_SUPPORT=y CONFIG_SPL_FAT_SUPPORT=y CONFIG_BAV_VERSION=2 CONFIG_DISTRO_DEFAULTS=y -CONFIG_SYS_EXTRA_OPTIONS="SERIAL1,CONS_INDEX=1" +CONFIG_SYS_EXTRA_OPTIONS="SERIAL1" # CONFIG_USE_BOOTCOMMAND is not set CONFIG_SYS_CONSOLE_INFO_QUIET=y CONFIG_VERSION_VARIABLE=y diff --git a/configs/brppt1_mmc_defconfig b/configs/brppt1_mmc_defconfig index 6de9a78..7ece8d3 100644 --- a/configs/brppt1_mmc_defconfig +++ b/configs/brppt1_mmc_defconfig @@ -10,7 +10,7 @@ CONFIG_SPL_SERIAL_SUPPORT=y # CONFIG_SPL_NAND_SUPPORT is not set CONFIG_SPL_WATCHDOG_SUPPORT=y CONFIG_OF_BOARD_SETUP=y -CONFIG_SYS_EXTRA_OPTIONS="SERIAL1,CONS_INDEX=1,EMMC_BOOT" +CONFIG_SYS_EXTRA_OPTIONS="SERIAL1,EMMC_BOOT" CONFIG_BOOTDELAY=-2 # CONFIG_CONSOLE_MUX is not set CONFIG_SYS_CONSOLE_IS_IN_ENV=y diff --git a/configs/brppt1_nand_defconfig b/configs/brppt1_nand_defconfig index a1a5590..b3ae776 100644 --- a/configs/brppt1_nand_defconfig +++ b/configs/brppt1_nand_defconfig @@ -8,7 +8,7 @@ CONFIG_TARGET_BRPPT1=y CONFIG_SPL_SERIAL_SUPPORT=y CONFIG_SPL_WATCHDOG_SUPPORT=y CONFIG_OF_BOARD_SETUP=y -CONFIG_SYS_EXTRA_OPTIONS="SERIAL1,CONS_INDEX=1" +CONFIG_SYS_EXTRA_OPTIONS="SERIAL1" CONFIG_BOOTDELAY=-2 # CONFIG_CONSOLE_MUX is not set CONFIG_SYS_CONSOLE_IS_IN_ENV=y diff --git a/configs/brppt1_spi_defconfig b/configs/brppt1_spi_defconfig index 0052d16..6d7cdbc 100644 --- a/configs/brppt1_spi_defconfig +++ b/configs/brppt1_spi_defconfig @@ -12,7 +12,7 @@ CONFIG_SPL_SPI_FLASH_SUPPORT=y CONFIG_SPL_SPI_SUPPORT=y CONFIG_SPL_WATCHDOG_SUPPORT=y CONFIG_OF_BOARD_SETUP=y -CONFIG_SYS_EXTRA_OPTIONS="SERIAL1,CONS_INDEX=1,SPI_BOOT,EMMC_BOOT" +CONFIG_SYS_EXTRA_OPTIONS="SERIAL1,SPI_BOOT,EMMC_BOOT" CONFIG_SPI_BOOT=y CONFIG_BOOTDELAY=-2 # CONFIG_CONSOLE_MUX is not set diff --git a/configs/brxre1_defconfig b/configs/brxre1_defconfig index 3f37573..d60e796 100644 --- a/configs/brxre1_defconfig +++ b/configs/brxre1_defconfig @@ -8,7 +8,7 @@ CONFIG_TARGET_BRXRE1=y CONFIG_SPL_MMC_SUPPORT=y CONFIG_SPL_SERIAL_SUPPORT=y # CONFIG_SPL_NAND_SUPPORT is not set -CONFIG_SYS_EXTRA_OPTIONS="SERIAL1,CONS_INDEX=1" +CONFIG_SYS_EXTRA_OPTIONS="SERIAL1" CONFIG_BOOTDELAY=-2 # CONFIG_CONSOLE_MUX is not set CONFIG_SYS_CONSOLE_IS_IN_ENV=y diff --git a/configs/cairo_defconfig b/configs/cairo_defconfig index 70540fb..15457ea 100644 --- a/configs/cairo_defconfig +++ b/configs/cairo_defconfig @@ -2,6 +2,7 @@ CONFIG_ARM=y CONFIG_ARCH_OMAP2PLUS=y CONFIG_SYS_TEXT_BASE=0x80100000 CONFIG_TARGET_OMAP3_CAIRO=y +CONFIG_CONS_INDEX=2 CONFIG_DISTRO_DEFAULTS=y CONFIG_BOOTDELAY=-2 # CONFIG_USE_BOOTCOMMAND is not set diff --git a/configs/cl-som-am57x_defconfig b/configs/cl-som-am57x_defconfig index 641c9b6..4ff4903 100644 --- a/configs/cl-som-am57x_defconfig +++ b/configs/cl-som-am57x_defconfig @@ -2,6 +2,7 @@ CONFIG_ARM=y CONFIG_ARCH_OMAP2PLUS=y CONFIG_OMAP54XX=y CONFIG_TARGET_CL_SOM_AM57X=y +CONFIG_CONS_INDEX=3 # CONFIG_SPL_NAND_SUPPORT is not set CONFIG_DISTRO_DEFAULTS=y # CONFIG_USE_BOOTCOMMAND is not set diff --git a/configs/cm_t54_defconfig b/configs/cm_t54_defconfig index 07a52f6..0a8ff73 100644 --- a/configs/cm_t54_defconfig +++ b/configs/cm_t54_defconfig @@ -3,6 +3,7 @@ CONFIG_ARCH_OMAP2PLUS=y CONFIG_OMAP54XX=y CONFIG_TARGET_CM_T54=y CONFIG_OMAP_PLATFORM_RESET_TIME_MAX_USEC=16296 +CONFIG_CONS_INDEX=4 # CONFIG_SPL_NAND_SUPPORT is not set CONFIG_DISTRO_DEFAULTS=y CONFIG_OF_BOARD_SETUP=y diff --git a/configs/controlcenterd_36BIT_SDCARD_DEVELOP_defconfig b/configs/controlcenterd_36BIT_SDCARD_DEVELOP_defconfig index 7136a4b..bda5a69 100644 --- a/configs/controlcenterd_36BIT_SDCARD_DEVELOP_defconfig +++ b/configs/controlcenterd_36BIT_SDCARD_DEVELOP_defconfig @@ -1,5 +1,6 @@ CONFIG_PPC=y CONFIG_SYS_TEXT_BASE=0x11000000 +CONFIG_CONS_INDEX=2 CONFIG_IDENT_STRING=" controlcenterd 0.01" CONFIG_MPC85xx=y CONFIG_TARGET_CONTROLCENTERD=y diff --git a/configs/controlcenterd_36BIT_SDCARD_defconfig b/configs/controlcenterd_36BIT_SDCARD_defconfig index 6654968..66acf5f 100644 --- a/configs/controlcenterd_36BIT_SDCARD_defconfig +++ b/configs/controlcenterd_36BIT_SDCARD_defconfig @@ -1,5 +1,6 @@ CONFIG_PPC=y CONFIG_SYS_TEXT_BASE=0x11000000 +CONFIG_CONS_INDEX=2 CONFIG_IDENT_STRING=" controlcenterd 0.01" CONFIG_MPC85xx=y CONFIG_TARGET_CONTROLCENTERD=y diff --git a/configs/controlcenterd_TRAILBLAZER_DEVELOP_defconfig b/configs/controlcenterd_TRAILBLAZER_DEVELOP_defconfig index ef1c5e0..19f3356 100644 --- a/configs/controlcenterd_TRAILBLAZER_DEVELOP_defconfig +++ b/configs/controlcenterd_TRAILBLAZER_DEVELOP_defconfig @@ -1,5 +1,6 @@ CONFIG_PPC=y CONFIG_SYS_TEXT_BASE=0xf8fc0000 +CONFIG_CONS_INDEX=2 CONFIG_IDENT_STRING=" controlcenterd trailblazer 0.01" CONFIG_MPC85xx=y # CONFIG_CMD_ERRATA is not set diff --git a/configs/controlcenterd_TRAILBLAZER_defconfig b/configs/controlcenterd_TRAILBLAZER_defconfig index 879072a..725dfef 100644 --- a/configs/controlcenterd_TRAILBLAZER_defconfig +++ b/configs/controlcenterd_TRAILBLAZER_defconfig @@ -1,5 +1,6 @@ CONFIG_PPC=y CONFIG_SYS_TEXT_BASE=0xf8fc0000 +CONFIG_CONS_INDEX=2 CONFIG_IDENT_STRING=" controlcenterd trailblazer 0.01" CONFIG_MPC85xx=y # CONFIG_CMD_ERRATA is not set diff --git a/configs/devkit3250_defconfig b/configs/devkit3250_defconfig index fcc80b2..afce854 100644 --- a/configs/devkit3250_defconfig +++ b/configs/devkit3250_defconfig @@ -42,3 +42,4 @@ CONFIG_LPC32XX_SSP=y CONFIG_USB=y CONFIG_USB_STORAGE=y CONFIG_OF_LIBFDT=y +CONFIG_CONS_INDEX=3 diff --git a/configs/duovero_defconfig b/configs/duovero_defconfig index a510294..3d8f9f3 100644 --- a/configs/duovero_defconfig +++ b/configs/duovero_defconfig @@ -2,6 +2,7 @@ CONFIG_ARM=y CONFIG_ARCH_OMAP2PLUS=y CONFIG_OMAP44XX=y CONFIG_TARGET_DUOVERO=y +CONFIG_CONS_INDEX=3 # CONFIG_SPL_NAND_SUPPORT is not set CONFIG_DISTRO_DEFAULTS=y CONFIG_BOOTCOMMAND="if test ${boot_fit} -eq 1; then run update_to_fit; fi; run findfdt; run init_console; run envboot; run distro_bootcmd" diff --git a/configs/edb9315a_defconfig b/configs/edb9315a_defconfig index d3ada21..731d1c5 100644 --- a/configs/edb9315a_defconfig +++ b/configs/edb9315a_defconfig @@ -1,6 +1,7 @@ CONFIG_ARM=y CONFIG_TARGET_EDB93XX=y CONFIG_SYS_TEXT_BASE=0x60000000 +CONFIG_CONS_INDEX=0 CONFIG_SYS_EXTRA_OPTIONS="MK_edb9315a" CONFIG_USE_BOOTARGS=y CONFIG_BOOTARGS="root=/dev/nfs console=ttyAM0,115200 ip=dhcp" diff --git a/configs/h2200_defconfig b/configs/h2200_defconfig index a07b37a..c40bc24 100644 --- a/configs/h2200_defconfig +++ b/configs/h2200_defconfig @@ -1,6 +1,7 @@ CONFIG_ARM=y CONFIG_TARGET_H2200=y CONFIG_SYS_TEXT_BASE=0xa0041000 +CONFIG_CONS_INDEX=3 CONFIG_FIT=y # CONFIG_FIT_ENABLE_SHA256_SUPPORT is not set CONFIG_USE_BOOTARGS=y diff --git a/configs/highbank_defconfig b/configs/highbank_defconfig index 55f83ed..b167139 100644 --- a/configs/highbank_defconfig +++ b/configs/highbank_defconfig @@ -2,6 +2,7 @@ CONFIG_ARM=y CONFIG_SYS_THUMB_BUILD=y CONFIG_ARCH_HIGHBANK=y CONFIG_SYS_TEXT_BASE=0x00008000 +CONFIG_CONS_INDEX=0 CONFIG_DISTRO_DEFAULTS=y CONFIG_FIT=y CONFIG_OF_BOARD_SETUP=y diff --git a/configs/hrcon_defconfig b/configs/hrcon_defconfig index 7f2fcf9..2ae45b0 100644 --- a/configs/hrcon_defconfig +++ b/configs/hrcon_defconfig @@ -1,5 +1,6 @@ CONFIG_PPC=y CONFIG_SYS_TEXT_BASE=0xFE000000 +CONFIG_CONS_INDEX=2 CONFIG_IDENT_STRING=" hrcon 0.01" CONFIG_MPC83xx=y CONFIG_TARGET_HRCON=y diff --git a/configs/hrcon_dh_defconfig b/configs/hrcon_dh_defconfig index 210c7f9..c5cd3ef 100644 --- a/configs/hrcon_dh_defconfig +++ b/configs/hrcon_dh_defconfig @@ -1,5 +1,6 @@ CONFIG_PPC=y CONFIG_SYS_TEXT_BASE=0xFE000000 +CONFIG_CONS_INDEX=2 CONFIG_IDENT_STRING=" hrcon dh 0.01" CONFIG_MPC83xx=y CONFIG_TARGET_HRCON=y diff --git a/configs/integratorap_cm720t_defconfig b/configs/integratorap_cm720t_defconfig index a406290..ed4ee50 100644 --- a/configs/integratorap_cm720t_defconfig +++ b/configs/integratorap_cm720t_defconfig @@ -3,6 +3,7 @@ CONFIG_ARCH_INTEGRATOR=y CONFIG_SYS_TEXT_BASE=0x01000000 CONFIG_ARCH_INTEGRATOR_AP=y CONFIG_CM720T=y +CONFIG_CONS_INDEX=0 CONFIG_USE_BOOTARGS=y CONFIG_BOOTARGS="root=/dev/mtdblock0 console=ttyAM0 console=tty" # CONFIG_DISPLAY_CPUINFO is not set diff --git a/configs/integratorap_cm920t_defconfig b/configs/integratorap_cm920t_defconfig index a8a1045..cb84473 100644 --- a/configs/integratorap_cm920t_defconfig +++ b/configs/integratorap_cm920t_defconfig @@ -3,6 +3,7 @@ CONFIG_ARCH_INTEGRATOR=y CONFIG_SYS_TEXT_BASE=0x01000000 CONFIG_ARCH_INTEGRATOR_AP=y CONFIG_CM920T=y +CONFIG_CONS_INDEX=0 CONFIG_USE_BOOTARGS=y CONFIG_BOOTARGS="root=/dev/mtdblock0 console=ttyAM0 console=tty" # CONFIG_DISPLAY_CPUINFO is not set diff --git a/configs/integratorap_cm926ejs_defconfig b/configs/integratorap_cm926ejs_defconfig index 126ee3d..b2cc368 100644 --- a/configs/integratorap_cm926ejs_defconfig +++ b/configs/integratorap_cm926ejs_defconfig @@ -3,6 +3,7 @@ CONFIG_ARCH_INTEGRATOR=y CONFIG_SYS_TEXT_BASE=0x01000000 CONFIG_ARCH_INTEGRATOR_AP=y CONFIG_CM926EJ_S=y +CONFIG_CONS_INDEX=0 CONFIG_USE_BOOTARGS=y CONFIG_BOOTARGS="root=/dev/mtdblock0 console=ttyAM0 console=tty" # CONFIG_DISPLAY_CPUINFO is not set diff --git a/configs/integratorap_cm946es_defconfig b/configs/integratorap_cm946es_defconfig index 2ca6959..221207a 100644 --- a/configs/integratorap_cm946es_defconfig +++ b/configs/integratorap_cm946es_defconfig @@ -3,6 +3,7 @@ CONFIG_ARCH_INTEGRATOR=y CONFIG_SYS_TEXT_BASE=0x01000000 CONFIG_ARCH_INTEGRATOR_AP=y CONFIG_CM946ES=y +CONFIG_CONS_INDEX=0 CONFIG_USE_BOOTARGS=y CONFIG_BOOTARGS="root=/dev/mtdblock0 console=ttyAM0 console=tty" # CONFIG_DISPLAY_CPUINFO is not set diff --git a/configs/integratorcp_cm1136_defconfig b/configs/integratorcp_cm1136_defconfig index cac7e25..0234871 100644 --- a/configs/integratorcp_cm1136_defconfig +++ b/configs/integratorcp_cm1136_defconfig @@ -3,6 +3,7 @@ CONFIG_ARCH_INTEGRATOR=y CONFIG_SYS_TEXT_BASE=0x01000000 CONFIG_ARCH_INTEGRATOR_CP=y CONFIG_CM1136=y +CONFIG_CONS_INDEX=0 CONFIG_USE_BOOTARGS=y CONFIG_BOOTARGS="root=/dev/mtdblock0 console=ttyAMA0 console=tty ip=dhcp netdev=27,0,0xfc800000,0xfc800010,eth0 video=clcdfb:0" # CONFIG_DISPLAY_CPUINFO is not set diff --git a/configs/integratorcp_cm920t_defconfig b/configs/integratorcp_cm920t_defconfig index 2e77ad7..da56f65 100644 --- a/configs/integratorcp_cm920t_defconfig +++ b/configs/integratorcp_cm920t_defconfig @@ -3,6 +3,7 @@ CONFIG_ARCH_INTEGRATOR=y CONFIG_SYS_TEXT_BASE=0x01000000 CONFIG_ARCH_INTEGRATOR_CP=y CONFIG_CM920T=y +CONFIG_CONS_INDEX=0 CONFIG_USE_BOOTARGS=y CONFIG_BOOTARGS="root=/dev/mtdblock0 console=ttyAMA0 console=tty ip=dhcp netdev=27,0,0xfc800000,0xfc800010,eth0 video=clcdfb:0" # CONFIG_DISPLAY_CPUINFO is not set diff --git a/configs/integratorcp_cm926ejs_defconfig b/configs/integratorcp_cm926ejs_defconfig index ef9e744..a26c2ec 100644 --- a/configs/integratorcp_cm926ejs_defconfig +++ b/configs/integratorcp_cm926ejs_defconfig @@ -3,6 +3,7 @@ CONFIG_ARCH_INTEGRATOR=y CONFIG_SYS_TEXT_BASE=0x01000000 CONFIG_ARCH_INTEGRATOR_CP=y CONFIG_CM926EJ_S=y +CONFIG_CONS_INDEX=0 CONFIG_USE_BOOTARGS=y CONFIG_BOOTARGS="root=/dev/mtdblock0 console=ttyAMA0 console=tty ip=dhcp netdev=27,0,0xfc800000,0xfc800010,eth0 video=clcdfb:0" # CONFIG_DISPLAY_CPUINFO is not set diff --git a/configs/integratorcp_cm946es_defconfig b/configs/integratorcp_cm946es_defconfig index fb1bf26..8fdfb6a 100644 --- a/configs/integratorcp_cm946es_defconfig +++ b/configs/integratorcp_cm946es_defconfig @@ -3,6 +3,7 @@ CONFIG_ARCH_INTEGRATOR=y CONFIG_SYS_TEXT_BASE=0x01000000 CONFIG_ARCH_INTEGRATOR_CP=y CONFIG_CM946ES=y +CONFIG_CONS_INDEX=0 CONFIG_USE_BOOTARGS=y CONFIG_BOOTARGS="root=/dev/mtdblock0 console=ttyAMA0 console=tty ip=dhcp netdev=27,0,0xfc800000,0xfc800010,eth0 video=clcdfb:0" # CONFIG_DISPLAY_CPUINFO is not set diff --git a/configs/kc1_defconfig b/configs/kc1_defconfig index ec5fb5e..79ed70e 100644 --- a/configs/kc1_defconfig +++ b/configs/kc1_defconfig @@ -3,6 +3,7 @@ CONFIG_ARCH_OMAP2PLUS=y CONFIG_SYS_TEXT_BASE=0x80100000 CONFIG_OMAP44XX=y CONFIG_TARGET_KC1=y +CONFIG_CONS_INDEX=3 # CONFIG_SPL_NAND_SUPPORT is not set CONFIG_DISTRO_DEFAULTS=y # CONFIG_USE_BOOTCOMMAND is not set diff --git a/configs/ls2080ardb_SECURE_BOOT_defconfig b/configs/ls2080ardb_SECURE_BOOT_defconfig index 37e1da6..ce54d63 100644 --- a/configs/ls2080ardb_SECURE_BOOT_defconfig +++ b/configs/ls2080ardb_SECURE_BOOT_defconfig @@ -2,6 +2,7 @@ CONFIG_ARM=y CONFIG_TARGET_LS2080ARDB=y CONFIG_SYS_TEXT_BASE=0x30100000 CONFIG_SECURE_BOOT=y +CONFIG_CONS_INDEX=2 CONFIG_FSL_LS_PPA=y CONFIG_DEFAULT_DEVICE_TREE="fsl-ls2080a-rdb" # CONFIG_SYS_MALLOC_F is not set diff --git a/configs/ls2080ardb_defconfig b/configs/ls2080ardb_defconfig index de3ce13..e79c9ec 100644 --- a/configs/ls2080ardb_defconfig +++ b/configs/ls2080ardb_defconfig @@ -1,6 +1,7 @@ CONFIG_ARM=y CONFIG_TARGET_LS2080ARDB=y CONFIG_SYS_TEXT_BASE=0x30100000 +CONFIG_CONS_INDEX=2 CONFIG_FSL_LS_PPA=y CONFIG_DEFAULT_DEVICE_TREE="fsl-ls2080a-rdb" # CONFIG_SYS_MALLOC_F is not set diff --git a/configs/ls2080ardb_nand_defconfig b/configs/ls2080ardb_nand_defconfig index ea0463e..86ae467 100644 --- a/configs/ls2080ardb_nand_defconfig +++ b/configs/ls2080ardb_nand_defconfig @@ -3,6 +3,7 @@ CONFIG_TARGET_LS2080ARDB=y CONFIG_SYS_TEXT_BASE=0x80400000 CONFIG_SPL_LIBCOMMON_SUPPORT=y CONFIG_SPL_LIBGENERIC_SUPPORT=y +CONFIG_CONS_INDEX=2 CONFIG_SPL_SERIAL_SUPPORT=y CONFIG_SPL_DRIVERS_MISC_SUPPORT=y CONFIG_SPL_NAND_SUPPORT=y diff --git a/configs/ls2081ardb_defconfig b/configs/ls2081ardb_defconfig index 28fa200..2faedca 100644 --- a/configs/ls2081ardb_defconfig +++ b/configs/ls2081ardb_defconfig @@ -1,6 +1,7 @@ CONFIG_ARM=y CONFIG_TARGET_LS2081ARDB=y CONFIG_SYS_TEXT_BASE=0x20100000 +CONFIG_CONS_INDEX=2 CONFIG_FSL_LS_PPA=y CONFIG_QSPI_AHB_INIT=y CONFIG_DEFAULT_DEVICE_TREE="fsl-ls2081a-rdb" diff --git a/configs/ls2088ardb_qspi_SECURE_BOOT_defconfig b/configs/ls2088ardb_qspi_SECURE_BOOT_defconfig index b405a8e..9bb400b 100644 --- a/configs/ls2088ardb_qspi_SECURE_BOOT_defconfig +++ b/configs/ls2088ardb_qspi_SECURE_BOOT_defconfig @@ -2,6 +2,7 @@ CONFIG_ARM=y CONFIG_TARGET_LS2080ARDB=y CONFIG_SYS_TEXT_BASE=0x20100000 CONFIG_SECURE_BOOT=y +CONFIG_CONS_INDEX=2 CONFIG_FSL_LS_PPA=y CONFIG_QSPI_AHB_INIT=y CONFIG_DEFAULT_DEVICE_TREE="fsl-ls2088a-rdb-qspi" diff --git a/configs/ls2088ardb_qspi_defconfig b/configs/ls2088ardb_qspi_defconfig index 4ea8a5c..777944e 100644 --- a/configs/ls2088ardb_qspi_defconfig +++ b/configs/ls2088ardb_qspi_defconfig @@ -1,6 +1,7 @@ CONFIG_ARM=y CONFIG_TARGET_LS2080ARDB=y CONFIG_SYS_TEXT_BASE=0x20100000 +CONFIG_CONS_INDEX=2 CONFIG_FSL_LS_PPA=y CONFIG_QSPI_AHB_INIT=y CONFIG_DEFAULT_DEVICE_TREE="fsl-ls2088a-rdb-qspi" diff --git a/configs/m28evk_defconfig b/configs/m28evk_defconfig index 7c53910..cc711a5 100644 --- a/configs/m28evk_defconfig +++ b/configs/m28evk_defconfig @@ -5,6 +5,7 @@ CONFIG_SPL_GPIO_SUPPORT=y CONFIG_SPL_LIBCOMMON_SUPPORT=y CONFIG_SPL_LIBGENERIC_SUPPORT=y CONFIG_TARGET_M28EVK=y +CONFIG_CONS_INDEX=0 CONFIG_SPL_SERIAL_SUPPORT=y CONFIG_FIT=y CONFIG_BOOTDELAY=3 diff --git a/configs/mt_ventoux_defconfig b/configs/mt_ventoux_defconfig index 97bbd8e..0a356ac 100644 --- a/configs/mt_ventoux_defconfig +++ b/configs/mt_ventoux_defconfig @@ -4,6 +4,7 @@ CONFIG_ARCH_OMAP2PLUS=y CONFIG_SYS_TEXT_BASE=0x80008000 CONFIG_TARGET_MT_VENTOUX=y CONFIG_EMIF4=y +CONFIG_CONS_INDEX=1 CONFIG_BOOTDELAY=10 # CONFIG_CONSOLE_MUX is not set CONFIG_SYS_CONSOLE_IS_IN_ENV=y diff --git a/configs/mx23_olinuxino_defconfig b/configs/mx23_olinuxino_defconfig index ebd95da..8964484 100644 --- a/configs/mx23_olinuxino_defconfig +++ b/configs/mx23_olinuxino_defconfig @@ -5,6 +5,7 @@ CONFIG_SPL_GPIO_SUPPORT=y CONFIG_SPL_LIBCOMMON_SUPPORT=y CONFIG_SPL_LIBGENERIC_SUPPORT=y CONFIG_TARGET_MX23_OLINUXINO=y +CONFIG_CONS_INDEX=0 CONFIG_SPL_SERIAL_SUPPORT=y CONFIG_BOOTDELAY=3 CONFIG_VERSION_VARIABLE=y diff --git a/configs/mx23evk_defconfig b/configs/mx23evk_defconfig index ebdc108..d80d9b1 100644 --- a/configs/mx23evk_defconfig +++ b/configs/mx23evk_defconfig @@ -5,6 +5,7 @@ CONFIG_SPL_GPIO_SUPPORT=y CONFIG_SPL_LIBCOMMON_SUPPORT=y CONFIG_SPL_LIBGENERIC_SUPPORT=y CONFIG_TARGET_MX23EVK=y +CONFIG_CONS_INDEX=0 CONFIG_SPL_SERIAL_SUPPORT=y # CONFIG_CONSOLE_MUX is not set CONFIG_SYS_CONSOLE_IS_IN_ENV=y diff --git a/configs/mx28evk_auart_console_defconfig b/configs/mx28evk_auart_console_defconfig index aa938a9..162154f 100644 --- a/configs/mx28evk_auart_console_defconfig +++ b/configs/mx28evk_auart_console_defconfig @@ -5,6 +5,7 @@ CONFIG_SPL_GPIO_SUPPORT=y CONFIG_SPL_LIBCOMMON_SUPPORT=y CONFIG_SPL_LIBGENERIC_SUPPORT=y CONFIG_TARGET_MX28EVK=y +CONFIG_CONS_INDEX=0 CONFIG_SPL_SERIAL_SUPPORT=y CONFIG_SYS_EXTRA_OPTIONS="MXS_AUART,MXS_AUART_BASE=MXS_UARTAPP3_BASE" # CONFIG_CONSOLE_MUX is not set diff --git a/configs/mx28evk_defconfig b/configs/mx28evk_defconfig index 2c590ce..638ac50 100644 --- a/configs/mx28evk_defconfig +++ b/configs/mx28evk_defconfig @@ -5,6 +5,7 @@ CONFIG_SPL_GPIO_SUPPORT=y CONFIG_SPL_LIBCOMMON_SUPPORT=y CONFIG_SPL_LIBGENERIC_SUPPORT=y CONFIG_TARGET_MX28EVK=y +CONFIG_CONS_INDEX=0 CONFIG_SPL_SERIAL_SUPPORT=y CONFIG_FIT=y # CONFIG_CONSOLE_MUX is not set diff --git a/configs/mx28evk_nand_defconfig b/configs/mx28evk_nand_defconfig index fe8f151..9acf174 100644 --- a/configs/mx28evk_nand_defconfig +++ b/configs/mx28evk_nand_defconfig @@ -5,6 +5,7 @@ CONFIG_SPL_GPIO_SUPPORT=y CONFIG_SPL_LIBCOMMON_SUPPORT=y CONFIG_SPL_LIBGENERIC_SUPPORT=y CONFIG_TARGET_MX28EVK=y +CONFIG_CONS_INDEX=0 CONFIG_SPL_SERIAL_SUPPORT=y # CONFIG_CONSOLE_MUX is not set CONFIG_SYS_CONSOLE_IS_IN_ENV=y diff --git a/configs/mx28evk_spi_defconfig b/configs/mx28evk_spi_defconfig index ccc4c7a..d85f2a5 100644 --- a/configs/mx28evk_spi_defconfig +++ b/configs/mx28evk_spi_defconfig @@ -5,6 +5,7 @@ CONFIG_SPL_GPIO_SUPPORT=y CONFIG_SPL_LIBCOMMON_SUPPORT=y CONFIG_SPL_LIBGENERIC_SUPPORT=y CONFIG_TARGET_MX28EVK=y +CONFIG_CONS_INDEX=0 CONFIG_SPL_SERIAL_SUPPORT=y # CONFIG_CONSOLE_MUX is not set CONFIG_SYS_CONSOLE_IS_IN_ENV=y diff --git a/configs/odroid-c2_defconfig b/configs/odroid-c2_defconfig index 49461aa..c959812 100644 --- a/configs/odroid-c2_defconfig +++ b/configs/odroid-c2_defconfig @@ -1,6 +1,7 @@ CONFIG_ARM=y CONFIG_ARCH_MESON=y CONFIG_SYS_TEXT_BASE=0x01000000 +CONFIG_CONS_INDEX=0 CONFIG_MESON_GXBB=y CONFIG_TARGET_ODROID_C2=y CONFIG_IDENT_STRING=" odroid-c2" diff --git a/configs/omap3_evm_defconfig b/configs/omap3_evm_defconfig index 3499877..b004d68 100644 --- a/configs/omap3_evm_defconfig +++ b/configs/omap3_evm_defconfig @@ -4,6 +4,7 @@ CONFIG_SYS_TEXT_BASE=0x80100000 CONFIG_SYS_MALLOC_F_LEN=0x2000 CONFIG_SYS_MPUCLK=720 CONFIG_TARGET_OMAP3_EVM=y +CONFIG_CONS_INDEX=1 CONFIG_DEFAULT_DEVICE_TREE="omap3-evm" CONFIG_DISTRO_DEFAULTS=y CONFIG_BOOTDELAY=3 diff --git a/configs/omap3_logic_defconfig b/configs/omap3_logic_defconfig index c3e999e..3462c12 100644 --- a/configs/omap3_logic_defconfig +++ b/configs/omap3_logic_defconfig @@ -3,6 +3,7 @@ CONFIG_ARCH_OMAP2PLUS=y CONFIG_TI_COMMON_CMD_OPTIONS=y CONFIG_SYS_MALLOC_F_LEN=0x2000 CONFIG_TARGET_OMAP3_LOGIC=y +CONFIG_CONS_INDEX=1 CONFIG_DEFAULT_DEVICE_TREE="logicpd-torpedo-37xx-devkit" CONFIG_DISTRO_DEFAULTS=y # CONFIG_USE_BOOTCOMMAND is not set diff --git a/configs/omap4_panda_defconfig b/configs/omap4_panda_defconfig index aa0c36e..bce1d88 100644 --- a/configs/omap4_panda_defconfig +++ b/configs/omap4_panda_defconfig @@ -2,6 +2,7 @@ CONFIG_ARM=y CONFIG_ARCH_OMAP2PLUS=y CONFIG_OMAP44XX=y CONFIG_TARGET_OMAP4_PANDA=y +CONFIG_CONS_INDEX=3 # CONFIG_SPL_NAND_SUPPORT is not set CONFIG_DISTRO_DEFAULTS=y CONFIG_BOOTCOMMAND="if test ${boot_fit} -eq 1; then run update_to_fit; fi; run findfdt; run init_console; run envboot; run distro_bootcmd" diff --git a/configs/omap4_sdp4430_defconfig b/configs/omap4_sdp4430_defconfig index 0c7c80b..fd64c4b 100644 --- a/configs/omap4_sdp4430_defconfig +++ b/configs/omap4_sdp4430_defconfig @@ -5,6 +5,7 @@ CONFIG_ARCH_OMAP2PLUS=y CONFIG_OMAP44XX=y CONFIG_TARGET_OMAP4_SDP4430=y CONFIG_CMD_BAT=y +CONFIG_CONS_INDEX=3 # CONFIG_SPL_NAND_SUPPORT is not set CONFIG_DISTRO_DEFAULTS=y CONFIG_BOOTCOMMAND="if test ${boot_fit} -eq 1; then run update_to_fit; fi; run findfdt; run init_console; run envboot; run distro_bootcmd" diff --git a/configs/omap5_uevm_defconfig b/configs/omap5_uevm_defconfig index 7e5fa82..2dd1f28 100644 --- a/configs/omap5_uevm_defconfig +++ b/configs/omap5_uevm_defconfig @@ -3,6 +3,7 @@ CONFIG_ARCH_OMAP2PLUS=y CONFIG_OMAP54XX=y CONFIG_TARGET_OMAP5_UEVM=y CONFIG_OMAP_PLATFORM_RESET_TIME_MAX_USEC=16296 +CONFIG_CONS_INDEX=3 # CONFIG_SPL_NAND_SUPPORT is not set CONFIG_ARMV7_LPAE=y CONFIG_DISTRO_DEFAULTS=y diff --git a/configs/p212_defconfig b/configs/p212_defconfig index d276e06..9a575ea 100644 --- a/configs/p212_defconfig +++ b/configs/p212_defconfig @@ -1,6 +1,7 @@ CONFIG_ARM=y CONFIG_ARCH_MESON=y CONFIG_SYS_TEXT_BASE=0x01000000 +CONFIG_CONS_INDEX=0 CONFIG_MESON_GXL=y CONFIG_TARGET_P212=y CONFIG_IDENT_STRING=" p212" diff --git a/configs/sansa_fuze_plus_defconfig b/configs/sansa_fuze_plus_defconfig index d35798f..c046bea 100644 --- a/configs/sansa_fuze_plus_defconfig +++ b/configs/sansa_fuze_plus_defconfig @@ -5,6 +5,7 @@ CONFIG_SPL_GPIO_SUPPORT=y CONFIG_SPL_LIBCOMMON_SUPPORT=y CONFIG_SPL_LIBGENERIC_SUPPORT=y CONFIG_TARGET_SANSA_FUZE_PLUS=y +CONFIG_CONS_INDEX=0 CONFIG_SPL_SERIAL_SUPPORT=y CONFIG_BOOTDELAY=3 CONFIG_USE_BOOTARGS=y diff --git a/configs/sc_sps_1_defconfig b/configs/sc_sps_1_defconfig index 8d700d6..909c262 100644 --- a/configs/sc_sps_1_defconfig +++ b/configs/sc_sps_1_defconfig @@ -5,6 +5,7 @@ CONFIG_SPL_GPIO_SUPPORT=y CONFIG_SPL_LIBCOMMON_SUPPORT=y CONFIG_SPL_LIBGENERIC_SUPPORT=y CONFIG_TARGET_SC_SPS_1=y +CONFIG_CONS_INDEX=0 CONFIG_SPL_SERIAL_SUPPORT=y CONFIG_BOOTDELAY=3 CONFIG_USE_BOOTARGS=y diff --git a/configs/spear300_defconfig b/configs/spear300_defconfig index a347f19..b508291 100644 --- a/configs/spear300_defconfig +++ b/configs/spear300_defconfig @@ -1,6 +1,7 @@ CONFIG_ARM=y CONFIG_TARGET_SPEAR300=y CONFIG_SYS_TEXT_BASE=0x00700000 +CONFIG_CONS_INDEX=0 CONFIG_IDENT_STRING="-SPEAr" CONFIG_SYS_EXTRA_OPTIONS="SPEAR300" CONFIG_BOOTDELAY=1 diff --git a/configs/spear300_nand_defconfig b/configs/spear300_nand_defconfig index 0fa4bb6..bec860f 100644 --- a/configs/spear300_nand_defconfig +++ b/configs/spear300_nand_defconfig @@ -1,6 +1,7 @@ CONFIG_ARM=y CONFIG_TARGET_SPEAR300=y CONFIG_SYS_TEXT_BASE=0x00700000 +CONFIG_CONS_INDEX=0 CONFIG_IDENT_STRING="-SPEAr" CONFIG_SYS_EXTRA_OPTIONS="SPEAR300" CONFIG_BOOTDELAY=1 diff --git a/configs/spear300_usbtty_defconfig b/configs/spear300_usbtty_defconfig index f5ad5fc..575a583 100644 --- a/configs/spear300_usbtty_defconfig +++ b/configs/spear300_usbtty_defconfig @@ -1,6 +1,7 @@ CONFIG_ARM=y CONFIG_TARGET_SPEAR300=y CONFIG_SYS_TEXT_BASE=0x00700000 +CONFIG_CONS_INDEX=0 CONFIG_IDENT_STRING="-SPEAr" CONFIG_SYS_EXTRA_OPTIONS="SPEAR300,USBTTY" CONFIG_BOOTDELAY=-1 diff --git a/configs/spear300_usbtty_nand_defconfig b/configs/spear300_usbtty_nand_defconfig index b14008a..7dc9b0d 100644 --- a/configs/spear300_usbtty_nand_defconfig +++ b/configs/spear300_usbtty_nand_defconfig @@ -1,6 +1,7 @@ CONFIG_ARM=y CONFIG_TARGET_SPEAR300=y CONFIG_SYS_TEXT_BASE=0x00700000 +CONFIG_CONS_INDEX=0 CONFIG_IDENT_STRING="-SPEAr" CONFIG_SYS_EXTRA_OPTIONS="SPEAR300,USBTTY" CONFIG_BOOTDELAY=-1 diff --git a/configs/spear310_defconfig b/configs/spear310_defconfig index a6476e7..700509d 100644 --- a/configs/spear310_defconfig +++ b/configs/spear310_defconfig @@ -1,6 +1,7 @@ CONFIG_ARM=y CONFIG_TARGET_SPEAR310=y CONFIG_SYS_TEXT_BASE=0x00700000 +CONFIG_CONS_INDEX=0 CONFIG_IDENT_STRING="-SPEAr" CONFIG_SYS_EXTRA_OPTIONS="SPEAR310" CONFIG_BOOTDELAY=1 diff --git a/configs/spear310_nand_defconfig b/configs/spear310_nand_defconfig index 1389a68..85cd871 100644 --- a/configs/spear310_nand_defconfig +++ b/configs/spear310_nand_defconfig @@ -1,6 +1,7 @@ CONFIG_ARM=y CONFIG_TARGET_SPEAR310=y CONFIG_SYS_TEXT_BASE=0x00700000 +CONFIG_CONS_INDEX=0 CONFIG_IDENT_STRING="-SPEAr" CONFIG_SYS_EXTRA_OPTIONS="SPEAR310" CONFIG_BOOTDELAY=1 diff --git a/configs/spear310_pnor_defconfig b/configs/spear310_pnor_defconfig index 83ccd5a..7f87fe2 100644 --- a/configs/spear310_pnor_defconfig +++ b/configs/spear310_pnor_defconfig @@ -1,6 +1,7 @@ CONFIG_ARM=y CONFIG_TARGET_SPEAR310=y CONFIG_SYS_TEXT_BASE=0x00700000 +CONFIG_CONS_INDEX=0 CONFIG_IDENT_STRING="-SPEAr" CONFIG_SYS_EXTRA_OPTIONS="SPEAR310,FLASH_PNOR" CONFIG_BOOTDELAY=1 diff --git a/configs/spear310_usbtty_defconfig b/configs/spear310_usbtty_defconfig index 3313633..be54f78 100644 --- a/configs/spear310_usbtty_defconfig +++ b/configs/spear310_usbtty_defconfig @@ -1,6 +1,7 @@ CONFIG_ARM=y CONFIG_TARGET_SPEAR310=y CONFIG_SYS_TEXT_BASE=0x00700000 +CONFIG_CONS_INDEX=0 CONFIG_IDENT_STRING="-SPEAr" CONFIG_SYS_EXTRA_OPTIONS="SPEAR310,USBTTY" CONFIG_BOOTDELAY=-1 diff --git a/configs/spear310_usbtty_nand_defconfig b/configs/spear310_usbtty_nand_defconfig index a4be617..d0e0fa7 100644 --- a/configs/spear310_usbtty_nand_defconfig +++ b/configs/spear310_usbtty_nand_defconfig @@ -1,6 +1,7 @@ CONFIG_ARM=y CONFIG_TARGET_SPEAR310=y CONFIG_SYS_TEXT_BASE=0x00700000 +CONFIG_CONS_INDEX=0 CONFIG_IDENT_STRING="-SPEAr" CONFIG_SYS_EXTRA_OPTIONS="SPEAR310,USBTTY" CONFIG_BOOTDELAY=-1 diff --git a/configs/spear310_usbtty_pnor_defconfig b/configs/spear310_usbtty_pnor_defconfig index 1e1ccc0..1e9258b 100644 --- a/configs/spear310_usbtty_pnor_defconfig +++ b/configs/spear310_usbtty_pnor_defconfig @@ -1,6 +1,7 @@ CONFIG_ARM=y CONFIG_TARGET_SPEAR310=y CONFIG_SYS_TEXT_BASE=0x00700000 +CONFIG_CONS_INDEX=0 CONFIG_IDENT_STRING="-SPEAr" CONFIG_SYS_EXTRA_OPTIONS="SPEAR310,USBTTY,FLASH_PNOR" CONFIG_BOOTDELAY=-1 diff --git a/configs/spear320_defconfig b/configs/spear320_defconfig index 33d2bef..b4180be 100644 --- a/configs/spear320_defconfig +++ b/configs/spear320_defconfig @@ -1,6 +1,7 @@ CONFIG_ARM=y CONFIG_TARGET_SPEAR320=y CONFIG_SYS_TEXT_BASE=0x00700000 +CONFIG_CONS_INDEX=0 CONFIG_IDENT_STRING="-SPEAr" CONFIG_SYS_EXTRA_OPTIONS="SPEAR320" CONFIG_BOOTDELAY=1 diff --git a/configs/spear320_nand_defconfig b/configs/spear320_nand_defconfig index ec6cbf0..b626516 100644 --- a/configs/spear320_nand_defconfig +++ b/configs/spear320_nand_defconfig @@ -1,6 +1,7 @@ CONFIG_ARM=y CONFIG_TARGET_SPEAR320=y CONFIG_SYS_TEXT_BASE=0x00700000 +CONFIG_CONS_INDEX=0 CONFIG_IDENT_STRING="-SPEAr" CONFIG_SYS_EXTRA_OPTIONS="SPEAR320" CONFIG_BOOTDELAY=1 diff --git a/configs/spear320_pnor_defconfig b/configs/spear320_pnor_defconfig index a3acdb2..df7db0a 100644 --- a/configs/spear320_pnor_defconfig +++ b/configs/spear320_pnor_defconfig @@ -1,6 +1,7 @@ CONFIG_ARM=y CONFIG_TARGET_SPEAR320=y CONFIG_SYS_TEXT_BASE=0x00700000 +CONFIG_CONS_INDEX=0 CONFIG_IDENT_STRING="-SPEAr" CONFIG_SYS_EXTRA_OPTIONS="SPEAR320,FLASH_PNOR" CONFIG_BOOTDELAY=1 diff --git a/configs/spear320_usbtty_defconfig b/configs/spear320_usbtty_defconfig index 4395647..5c9395e 100644 --- a/configs/spear320_usbtty_defconfig +++ b/configs/spear320_usbtty_defconfig @@ -1,6 +1,7 @@ CONFIG_ARM=y CONFIG_TARGET_SPEAR320=y CONFIG_SYS_TEXT_BASE=0x00700000 +CONFIG_CONS_INDEX=0 CONFIG_IDENT_STRING="-SPEAr" CONFIG_SYS_EXTRA_OPTIONS="SPEAR320,USBTTY" CONFIG_BOOTDELAY=-1 diff --git a/configs/spear320_usbtty_nand_defconfig b/configs/spear320_usbtty_nand_defconfig index a5fd760..8bc1c78 100644 --- a/configs/spear320_usbtty_nand_defconfig +++ b/configs/spear320_usbtty_nand_defconfig @@ -1,6 +1,7 @@ CONFIG_ARM=y CONFIG_TARGET_SPEAR320=y CONFIG_SYS_TEXT_BASE=0x00700000 +CONFIG_CONS_INDEX=0 CONFIG_IDENT_STRING="-SPEAr" CONFIG_SYS_EXTRA_OPTIONS="SPEAR320,USBTTY" CONFIG_BOOTDELAY=-1 diff --git a/configs/spear320_usbtty_pnor_defconfig b/configs/spear320_usbtty_pnor_defconfig index 6aff317..6413888 100644 --- a/configs/spear320_usbtty_pnor_defconfig +++ b/configs/spear320_usbtty_pnor_defconfig @@ -1,6 +1,7 @@ CONFIG_ARM=y CONFIG_TARGET_SPEAR320=y CONFIG_SYS_TEXT_BASE=0x00700000 +CONFIG_CONS_INDEX=0 CONFIG_IDENT_STRING="-SPEAr" CONFIG_SYS_EXTRA_OPTIONS="SPEAR320,USBTTY,FLASH_PNOR" CONFIG_BOOTDELAY=-1 diff --git a/configs/spear600_defconfig b/configs/spear600_defconfig index ac16b40..a5afd8e 100644 --- a/configs/spear600_defconfig +++ b/configs/spear600_defconfig @@ -1,6 +1,7 @@ CONFIG_ARM=y CONFIG_TARGET_SPEAR600=y CONFIG_SYS_TEXT_BASE=0x00700000 +CONFIG_CONS_INDEX=0 CONFIG_IDENT_STRING="-SPEAr" CONFIG_SYS_EXTRA_OPTIONS="SPEAR600" CONFIG_BOOTDELAY=1 diff --git a/configs/spear600_nand_defconfig b/configs/spear600_nand_defconfig index e781ba0..858f399 100644 --- a/configs/spear600_nand_defconfig +++ b/configs/spear600_nand_defconfig @@ -1,6 +1,7 @@ CONFIG_ARM=y CONFIG_TARGET_SPEAR600=y CONFIG_SYS_TEXT_BASE=0x00700000 +CONFIG_CONS_INDEX=0 CONFIG_IDENT_STRING="-SPEAr" CONFIG_SYS_EXTRA_OPTIONS="SPEAR600" CONFIG_BOOTDELAY=1 diff --git a/configs/spear600_usbtty_defconfig b/configs/spear600_usbtty_defconfig index c77229a..02ae711 100644 --- a/configs/spear600_usbtty_defconfig +++ b/configs/spear600_usbtty_defconfig @@ -1,6 +1,7 @@ CONFIG_ARM=y CONFIG_TARGET_SPEAR600=y CONFIG_SYS_TEXT_BASE=0x00700000 +CONFIG_CONS_INDEX=0 CONFIG_IDENT_STRING="-SPEAr" CONFIG_SYS_EXTRA_OPTIONS="SPEAR600,USBTTY" CONFIG_BOOTDELAY=-1 diff --git a/configs/spear600_usbtty_nand_defconfig b/configs/spear600_usbtty_nand_defconfig index dbf4d32..576c25d 100644 --- a/configs/spear600_usbtty_nand_defconfig +++ b/configs/spear600_usbtty_nand_defconfig @@ -1,6 +1,7 @@ CONFIG_ARM=y CONFIG_TARGET_SPEAR600=y CONFIG_SYS_TEXT_BASE=0x00700000 +CONFIG_CONS_INDEX=0 CONFIG_IDENT_STRING="-SPEAr" CONFIG_SYS_EXTRA_OPTIONS="SPEAR600,USBTTY" CONFIG_BOOTDELAY=-1 diff --git a/configs/strider_con_defconfig b/configs/strider_con_defconfig index 4c460ef..17fa943 100644 --- a/configs/strider_con_defconfig +++ b/configs/strider_con_defconfig @@ -1,5 +1,6 @@ CONFIG_PPC=y CONFIG_SYS_TEXT_BASE=0xFE000000 +CONFIG_CONS_INDEX=2 CONFIG_IDENT_STRING=" strider con 0.01" CONFIG_MPC83xx=y CONFIG_TARGET_STRIDER=y diff --git a/configs/strider_con_dp_defconfig b/configs/strider_con_dp_defconfig index b7cd1d8..262c5f2 100644 --- a/configs/strider_con_dp_defconfig +++ b/configs/strider_con_dp_defconfig @@ -1,5 +1,6 @@ CONFIG_PPC=y CONFIG_SYS_TEXT_BASE=0xFE000000 +CONFIG_CONS_INDEX=2 CONFIG_IDENT_STRING=" strider con dp 0.01" CONFIG_MPC83xx=y CONFIG_TARGET_STRIDER=y diff --git a/configs/strider_cpu_defconfig b/configs/strider_cpu_defconfig index b28e405..115f880 100644 --- a/configs/strider_cpu_defconfig +++ b/configs/strider_cpu_defconfig @@ -1,5 +1,6 @@ CONFIG_PPC=y CONFIG_SYS_TEXT_BASE=0xFE000000 +CONFIG_CONS_INDEX=2 CONFIG_IDENT_STRING=" strider cpu 0.01" CONFIG_MPC83xx=y CONFIG_TARGET_STRIDER=y diff --git a/configs/strider_cpu_dp_defconfig b/configs/strider_cpu_dp_defconfig index f250ea3..aca3e01 100644 --- a/configs/strider_cpu_dp_defconfig +++ b/configs/strider_cpu_dp_defconfig @@ -1,5 +1,6 @@ CONFIG_PPC=y CONFIG_SYS_TEXT_BASE=0xFE000000 +CONFIG_CONS_INDEX=2 CONFIG_IDENT_STRING=" strider cpu dp 0.01" CONFIG_MPC83xx=y CONFIG_TARGET_STRIDER=y diff --git a/configs/ts4600_defconfig b/configs/ts4600_defconfig index fac1439..af4c0ab 100644 --- a/configs/ts4600_defconfig +++ b/configs/ts4600_defconfig @@ -4,6 +4,7 @@ CONFIG_SYS_TEXT_BASE=0x40002000 CONFIG_SPL_LIBCOMMON_SUPPORT=y CONFIG_SPL_LIBGENERIC_SUPPORT=y CONFIG_TARGET_TS4600=y +CONFIG_CONS_INDEX=0 CONFIG_FIT=y CONFIG_SYS_CONSOLE_IS_IN_ENV=y # CONFIG_DISPLAY_CPUINFO is not set diff --git a/configs/twister_defconfig b/configs/twister_defconfig index 3f07756..5388c9d 100644 --- a/configs/twister_defconfig +++ b/configs/twister_defconfig @@ -4,6 +4,7 @@ CONFIG_ARCH_OMAP2PLUS=y CONFIG_SYS_TEXT_BASE=0x80008000 CONFIG_TARGET_TWISTER=y CONFIG_EMIF4=y +CONFIG_CONS_INDEX=1 CONFIG_BOOTDELAY=10 CONFIG_SPL=y # CONFIG_SPL_EXT_SUPPORT is not set diff --git a/configs/vexpress_aemv8a_dram_defconfig b/configs/vexpress_aemv8a_dram_defconfig index 8dd475d..4c7b4f9 100644 --- a/configs/vexpress_aemv8a_dram_defconfig +++ b/configs/vexpress_aemv8a_dram_defconfig @@ -2,6 +2,7 @@ CONFIG_ARM=y CONFIG_TARGET_VEXPRESS64_BASE_FVP_DRAM=y CONFIG_SYS_TEXT_BASE=0x88000000 CONFIG_SYS_MALLOC_F_LEN=0x2000 +CONFIG_CONS_INDEX=0 CONFIG_IDENT_STRING=" vexpress_aemv8a" CONFIG_DISTRO_DEFAULTS=y CONFIG_BOOTDELAY=1 diff --git a/configs/vexpress_aemv8a_juno_defconfig b/configs/vexpress_aemv8a_juno_defconfig index 382b379..3d4d21f 100644 --- a/configs/vexpress_aemv8a_juno_defconfig +++ b/configs/vexpress_aemv8a_juno_defconfig @@ -2,6 +2,7 @@ CONFIG_ARM=y CONFIG_TARGET_VEXPRESS64_JUNO=y CONFIG_SYS_TEXT_BASE=0xe0000000 CONFIG_SYS_MALLOC_F_LEN=0x2000 +CONFIG_CONS_INDEX=0 CONFIG_IDENT_STRING=" vexpress_aemv8a" CONFIG_DISTRO_DEFAULTS=y CONFIG_BOOTDELAY=1 diff --git a/configs/vexpress_aemv8a_semi_defconfig b/configs/vexpress_aemv8a_semi_defconfig index eee3034..f07b00c 100644 --- a/configs/vexpress_aemv8a_semi_defconfig +++ b/configs/vexpress_aemv8a_semi_defconfig @@ -2,6 +2,7 @@ CONFIG_ARM=y CONFIG_TARGET_VEXPRESS64_BASE_FVP=y CONFIG_SYS_TEXT_BASE=0x88000000 CONFIG_SYS_MALLOC_F_LEN=0x2000 +CONFIG_CONS_INDEX=0 CONFIG_IDENT_STRING=" vexpress_aemv8a" CONFIG_DISTRO_DEFAULTS=y CONFIG_BOOTDELAY=1 diff --git a/configs/vexpress_ca15_tc2_defconfig b/configs/vexpress_ca15_tc2_defconfig index 23aeabb..3a38cb0 100644 --- a/configs/vexpress_ca15_tc2_defconfig +++ b/configs/vexpress_ca15_tc2_defconfig @@ -1,6 +1,7 @@ CONFIG_ARM=y CONFIG_TARGET_VEXPRESS_CA15_TC2=y CONFIG_SYS_TEXT_BASE=0x80800000 +CONFIG_CONS_INDEX=0 CONFIG_DISTRO_DEFAULTS=y CONFIG_OF_BOARD_SETUP=y CONFIG_BOOTCOMMAND="run distro_bootcmd; run bootflash" diff --git a/configs/vexpress_ca5x2_defconfig b/configs/vexpress_ca5x2_defconfig index c66a8a8..fa32067 100644 --- a/configs/vexpress_ca5x2_defconfig +++ b/configs/vexpress_ca5x2_defconfig @@ -1,6 +1,7 @@ CONFIG_ARM=y CONFIG_TARGET_VEXPRESS_CA5X2=y CONFIG_SYS_TEXT_BASE=0x80800000 +CONFIG_CONS_INDEX=0 CONFIG_DISTRO_DEFAULTS=y CONFIG_BOOTCOMMAND="run distro_bootcmd; run bootflash" # CONFIG_DISPLAY_CPUINFO is not set diff --git a/configs/vexpress_ca9x4_defconfig b/configs/vexpress_ca9x4_defconfig index 063febd..fc6efb1 100644 --- a/configs/vexpress_ca9x4_defconfig +++ b/configs/vexpress_ca9x4_defconfig @@ -1,6 +1,7 @@ CONFIG_ARM=y CONFIG_TARGET_VEXPRESS_CA9X4=y CONFIG_SYS_TEXT_BASE=0x60800000 +CONFIG_CONS_INDEX=0 CONFIG_DISTRO_DEFAULTS=y CONFIG_BOOTCOMMAND="run distro_bootcmd; run bootflash" # CONFIG_DISPLAY_CPUINFO is not set diff --git a/configs/work_92105_defconfig b/configs/work_92105_defconfig index 2451b56..889fb42 100644 --- a/configs/work_92105_defconfig +++ b/configs/work_92105_defconfig @@ -38,3 +38,4 @@ CONFIG_PHYLIB=y CONFIG_DM_SERIAL=y CONFIG_SYS_NS16550=y CONFIG_LPC32XX_SSP=y +CONFIG_CONS_INDEX=3 diff --git a/configs/x600_defconfig b/configs/x600_defconfig index 0aef5b6..29edffb 100644 --- a/configs/x600_defconfig +++ b/configs/x600_defconfig @@ -6,6 +6,7 @@ CONFIG_TARGET_X600=y CONFIG_SYS_TEXT_BASE=0x00800040 CONFIG_SPL_LIBCOMMON_SUPPORT=y CONFIG_SPL_LIBGENERIC_SUPPORT=y +CONFIG_CONS_INDEX=0 CONFIG_SPL_SERIAL_SUPPORT=y CONFIG_IDENT_STRING="-SPEAr" CONFIG_BOOTDELAY=3 diff --git a/configs/xfi3_defconfig b/configs/xfi3_defconfig index acdb677..9701eea 100644 --- a/configs/xfi3_defconfig +++ b/configs/xfi3_defconfig @@ -5,6 +5,7 @@ CONFIG_SPL_GPIO_SUPPORT=y CONFIG_SPL_LIBCOMMON_SUPPORT=y CONFIG_SPL_LIBGENERIC_SUPPORT=y CONFIG_TARGET_XFI3=y +CONFIG_CONS_INDEX=0 CONFIG_SPL_SERIAL_SUPPORT=y CONFIG_BOOTDELAY=3 CONFIG_USE_BOOTARGS=y diff --git a/configs/xilinx_zynqmp_ep_defconfig b/configs/xilinx_zynqmp_ep_defconfig index a0c8f28..8b378d5 100644 --- a/configs/xilinx_zynqmp_ep_defconfig +++ b/configs/xilinx_zynqmp_ep_defconfig @@ -3,6 +3,7 @@ CONFIG_SYS_CONFIG_NAME="xilinx_zynqmp_ep" CONFIG_ARCH_ZYNQMP=y CONFIG_SYS_TEXT_BASE=0x8000000 CONFIG_SYS_MALLOC_F_LEN=0x8000 +CONFIG_CONS_INDEX=0 CONFIG_ZYNQ_SDHCI_MAX_FREQ=52000000 CONFIG_ZYNQMP_USB=y CONFIG_DEFAULT_DEVICE_TREE="zynqmp-ep108" diff --git a/configs/xilinx_zynqmp_mini_emmc_defconfig b/configs/xilinx_zynqmp_mini_emmc_defconfig index b15120e..8b06377 100644 --- a/configs/xilinx_zynqmp_mini_emmc_defconfig +++ b/configs/xilinx_zynqmp_mini_emmc_defconfig @@ -2,6 +2,7 @@ CONFIG_ARM=y CONFIG_SYS_CONFIG_NAME="xilinx_zynqmp_mini_emmc" CONFIG_ARCH_ZYNQMP=y CONFIG_SYS_TEXT_BASE=0x10000 +CONFIG_CONS_INDEX=0 CONFIG_DEFAULT_DEVICE_TREE="zynqmp-mini-emmc" CONFIG_ENV_VARS_UBOOT_CONFIG=y CONFIG_FIT=y diff --git a/configs/xilinx_zynqmp_mini_nand_defconfig b/configs/xilinx_zynqmp_mini_nand_defconfig index 55200bc..e67522f 100644 --- a/configs/xilinx_zynqmp_mini_nand_defconfig +++ b/configs/xilinx_zynqmp_mini_nand_defconfig @@ -2,6 +2,7 @@ CONFIG_ARM=y CONFIG_SYS_CONFIG_NAME="xilinx_zynqmp_mini_nand" CONFIG_ARCH_ZYNQMP=y CONFIG_SYS_TEXT_BASE=0x10000 +CONFIG_CONS_INDEX=0 CONFIG_DEFAULT_DEVICE_TREE="zynqmp-mini-nand" CONFIG_ENV_VARS_UBOOT_CONFIG=y CONFIG_FIT=y diff --git a/configs/xilinx_zynqmp_zc1751_xm015_dc1_defconfig b/configs/xilinx_zynqmp_zc1751_xm015_dc1_defconfig index 7da0ca8..0c6f7e6 100644 --- a/configs/xilinx_zynqmp_zc1751_xm015_dc1_defconfig +++ b/configs/xilinx_zynqmp_zc1751_xm015_dc1_defconfig @@ -3,6 +3,7 @@ CONFIG_SYS_CONFIG_NAME="xilinx_zynqmp_zc1751_xm015_dc1" CONFIG_ARCH_ZYNQMP=y CONFIG_SYS_TEXT_BASE=0x8000000 CONFIG_SYS_MALLOC_F_LEN=0x8000 +CONFIG_CONS_INDEX=0 CONFIG_IDENT_STRING=" Xilinx ZynqMP ZC1751 xm015 dc1" CONFIG_ZYNQMP_USB=y CONFIG_DEFAULT_DEVICE_TREE="zynqmp-zc1751-xm015-dc1" diff --git a/configs/xilinx_zynqmp_zc1751_xm016_dc2_defconfig b/configs/xilinx_zynqmp_zc1751_xm016_dc2_defconfig index 3e53166..b53a618 100644 --- a/configs/xilinx_zynqmp_zc1751_xm016_dc2_defconfig +++ b/configs/xilinx_zynqmp_zc1751_xm016_dc2_defconfig @@ -3,6 +3,7 @@ CONFIG_SYS_CONFIG_NAME="xilinx_zynqmp_zc1751_xm016_dc2" CONFIG_ARCH_ZYNQMP=y CONFIG_SYS_TEXT_BASE=0x8000000 CONFIG_SYS_MALLOC_F_LEN=0x8000 +CONFIG_CONS_INDEX=0 # CONFIG_SPL_LIBDISK_SUPPORT is not set CONFIG_IDENT_STRING=" Xilinx ZynqMP ZC1751 xm016 dc2" # CONFIG_SPL_FAT_SUPPORT is not set diff --git a/configs/xilinx_zynqmp_zc1751_xm018_dc4_defconfig b/configs/xilinx_zynqmp_zc1751_xm018_dc4_defconfig index 9bc0b77..967c909 100644 --- a/configs/xilinx_zynqmp_zc1751_xm018_dc4_defconfig +++ b/configs/xilinx_zynqmp_zc1751_xm018_dc4_defconfig @@ -2,6 +2,7 @@ CONFIG_ARM=y CONFIG_ARCH_ZYNQMP=y CONFIG_SYS_TEXT_BASE=0x8000000 CONFIG_SYS_MALLOC_F_LEN=0x8000 +CONFIG_CONS_INDEX=0 CONFIG_IDENT_STRING=" Xilinx ZynqMP ZC1751 xm018 dc4" CONFIG_DEFAULT_DEVICE_TREE="zynqmp-zc1751-xm018-dc4" CONFIG_DEBUG_UART=y diff --git a/configs/xilinx_zynqmp_zc1751_xm019_dc5_defconfig b/configs/xilinx_zynqmp_zc1751_xm019_dc5_defconfig index ac565ec..774f05d 100644 --- a/configs/xilinx_zynqmp_zc1751_xm019_dc5_defconfig +++ b/configs/xilinx_zynqmp_zc1751_xm019_dc5_defconfig @@ -3,6 +3,7 @@ CONFIG_SYS_CONFIG_NAME="xilinx_zynqmp_zc1751_xm019_dc5" CONFIG_ARCH_ZYNQMP=y CONFIG_SYS_TEXT_BASE=0x8000000 CONFIG_SYS_MALLOC_F_LEN=0x8000 +CONFIG_CONS_INDEX=0 CONFIG_IDENT_STRING=" Xilinx ZynqMP ZC1751 xm019 dc5" CONFIG_DEFAULT_DEVICE_TREE="zynqmp-zc1751-xm019-dc5" CONFIG_DEBUG_UART=y diff --git a/configs/xilinx_zynqmp_zcu102_rev1_0_defconfig b/configs/xilinx_zynqmp_zcu102_rev1_0_defconfig index 1df5b0b..dd52afe 100644 --- a/configs/xilinx_zynqmp_zcu102_rev1_0_defconfig +++ b/configs/xilinx_zynqmp_zcu102_rev1_0_defconfig @@ -3,6 +3,7 @@ CONFIG_SYS_CONFIG_NAME="xilinx_zynqmp_zcu102" CONFIG_ARCH_ZYNQMP=y CONFIG_SYS_TEXT_BASE=0x8000000 CONFIG_SYS_MALLOC_F_LEN=0x8000 +CONFIG_CONS_INDEX=0 CONFIG_IDENT_STRING=" Xilinx ZynqMP ZCU102 rev1.0" CONFIG_ZYNQMP_USB=y CONFIG_DEFAULT_DEVICE_TREE="zynqmp-zcu102-rev1.0" diff --git a/configs/xilinx_zynqmp_zcu102_revA_defconfig b/configs/xilinx_zynqmp_zcu102_revA_defconfig index c8a8362..88eb4d5 100644 --- a/configs/xilinx_zynqmp_zcu102_revA_defconfig +++ b/configs/xilinx_zynqmp_zcu102_revA_defconfig @@ -3,6 +3,7 @@ CONFIG_SYS_CONFIG_NAME="xilinx_zynqmp_zcu102" CONFIG_ARCH_ZYNQMP=y CONFIG_SYS_TEXT_BASE=0x8000000 CONFIG_SYS_MALLOC_F_LEN=0x8000 +CONFIG_CONS_INDEX=0 CONFIG_IDENT_STRING=" Xilinx ZynqMP ZCU102 revA" CONFIG_ZYNQMP_USB=y CONFIG_DEFAULT_DEVICE_TREE="zynqmp-zcu102-revA" diff --git a/configs/xilinx_zynqmp_zcu102_revB_defconfig b/configs/xilinx_zynqmp_zcu102_revB_defconfig index 8f85b5f..9c6db3a 100644 --- a/configs/xilinx_zynqmp_zcu102_revB_defconfig +++ b/configs/xilinx_zynqmp_zcu102_revB_defconfig @@ -3,6 +3,7 @@ CONFIG_SYS_CONFIG_NAME="xilinx_zynqmp_zcu102" CONFIG_ARCH_ZYNQMP=y CONFIG_SYS_TEXT_BASE=0x8000000 CONFIG_SYS_MALLOC_F_LEN=0x8000 +CONFIG_CONS_INDEX=0 CONFIG_IDENT_STRING=" Xilinx ZynqMP ZCU102 revB" CONFIG_ZYNQMP_USB=y CONFIG_DEFAULT_DEVICE_TREE="zynqmp-zcu102-revB" diff --git a/configs/zipitz2_defconfig b/configs/zipitz2_defconfig index 9f78de3..70be4a5 100644 --- a/configs/zipitz2_defconfig +++ b/configs/zipitz2_defconfig @@ -1,6 +1,7 @@ CONFIG_ARM=y CONFIG_TARGET_ZIPITZ2=y CONFIG_SYS_TEXT_BASE=0x0 +CONFIG_CONS_INDEX=2 CONFIG_USE_BOOTARGS=y CONFIG_BOOTARGS="console=tty0 console=ttyS2,115200 fbcon=rotate:3" # CONFIG_CONSOLE_MUX is not set diff --git a/include/configs/B4860QDS.h b/include/configs/B4860QDS.h index d28e003..d339c1a 100644 --- a/include/configs/B4860QDS.h +++ b/include/configs/B4860QDS.h @@ -441,7 +441,6 @@ unsigned long get_board_ddr_clk(void); * open - index 2 * shorted - index 1 */ -#define CONFIG_CONS_INDEX 1 #define CONFIG_SYS_NS16550_SERIAL #define CONFIG_SYS_NS16550_REG_SIZE 1 #define CONFIG_SYS_NS16550_CLK (get_bus_freq(0)/2) diff --git a/include/configs/BSC9131RDB.h b/include/configs/BSC9131RDB.h index 56e6e14..6ad82b8 100644 --- a/include/configs/BSC9131RDB.h +++ b/include/configs/BSC9131RDB.h @@ -204,7 +204,6 @@ extern unsigned long get_sdram_size(void); #define CONFIG_SYS_MALLOC_LEN (1024 * 1024) /* Reserved for malloc*/
/* Serial Port */ -#define CONFIG_CONS_INDEX 1 #undef CONFIG_SERIAL_SOFTWARE_FIFO #define CONFIG_SYS_NS16550_SERIAL #define CONFIG_SYS_NS16550_REG_SIZE 1 diff --git a/include/configs/BSC9132QDS.h b/include/configs/BSC9132QDS.h index 96a92f1..55e73bd 100644 --- a/include/configs/BSC9132QDS.h +++ b/include/configs/BSC9132QDS.h @@ -370,7 +370,6 @@ combinations. this should be removed later #define CONFIG_SYS_MALLOC_LEN (1024 * 1024) /* Reserved for malloc*/
/* Serial Port */ -#define CONFIG_CONS_INDEX 1 #undef CONFIG_SERIAL_SOFTWARE_FIFO #define CONFIG_SYS_NS16550_SERIAL #define CONFIG_SYS_NS16550_REG_SIZE 1 diff --git a/include/configs/C29XPCIE.h b/include/configs/C29XPCIE.h index 125a26b..a12ccce 100644 --- a/include/configs/C29XPCIE.h +++ b/include/configs/C29XPCIE.h @@ -334,7 +334,6 @@ #endif
/* Serial Port */ -#define CONFIG_CONS_INDEX 1 #define CONFIG_SYS_NS16550_SERIAL #define CONFIG_SYS_NS16550_REG_SIZE 1 #define CONFIG_SYS_NS16550_CLK get_bus_freq(0) diff --git a/include/configs/MPC8308RDB.h b/include/configs/MPC8308RDB.h index 0f94d4d..4f5d670 100644 --- a/include/configs/MPC8308RDB.h +++ b/include/configs/MPC8308RDB.h @@ -297,7 +297,6 @@ /* * Serial Port */ -#define CONFIG_CONS_INDEX 1 #define CONFIG_SYS_NS16550_SERIAL #define CONFIG_SYS_NS16550_REG_SIZE 1 #define CONFIG_SYS_NS16550_CLK get_bus_freq(0) diff --git a/include/configs/MPC8313ERDB.h b/include/configs/MPC8313ERDB.h index a1b5ad6..21ac664 100644 --- a/include/configs/MPC8313ERDB.h +++ b/include/configs/MPC8313ERDB.h @@ -347,7 +347,6 @@ /* * Serial Port */ -#define CONFIG_CONS_INDEX 1 #define CONFIG_SYS_NS16550_SERIAL #define CONFIG_SYS_NS16550_REG_SIZE 1
diff --git a/include/configs/MPC8315ERDB.h b/include/configs/MPC8315ERDB.h index b0dade5..05e631f 100644 --- a/include/configs/MPC8315ERDB.h +++ b/include/configs/MPC8315ERDB.h @@ -279,7 +279,6 @@ /* * Serial Port */ -#define CONFIG_CONS_INDEX 1 #define CONFIG_SYS_NS16550_SERIAL #define CONFIG_SYS_NS16550_REG_SIZE 1 #define CONFIG_SYS_NS16550_CLK (CONFIG_83XX_CLKIN * 2) diff --git a/include/configs/MPC8323ERDB.h b/include/configs/MPC8323ERDB.h index b00306f..3f0e87f 100644 --- a/include/configs/MPC8323ERDB.h +++ b/include/configs/MPC8323ERDB.h @@ -205,7 +205,6 @@ /* * Serial Port */ -#define CONFIG_CONS_INDEX 1 #define CONFIG_SYS_NS16550_SERIAL #define CONFIG_SYS_NS16550_REG_SIZE 1 #define CONFIG_SYS_NS16550_CLK get_bus_freq(0) diff --git a/include/configs/MPC832XEMDS.h b/include/configs/MPC832XEMDS.h index 0892000..f92346d 100644 --- a/include/configs/MPC832XEMDS.h +++ b/include/configs/MPC832XEMDS.h @@ -286,7 +286,6 @@ /* * Serial Port */ -#define CONFIG_CONS_INDEX 1 #define CONFIG_SYS_NS16550_SERIAL #define CONFIG_SYS_NS16550_REG_SIZE 1 #define CONFIG_SYS_NS16550_CLK get_bus_freq(0) diff --git a/include/configs/MPC8349EMDS.h b/include/configs/MPC8349EMDS.h index c496b23..2fa1f7a 100644 --- a/include/configs/MPC8349EMDS.h +++ b/include/configs/MPC8349EMDS.h @@ -304,7 +304,6 @@ /* * Serial Port */ -#define CONFIG_CONS_INDEX 1 #define CONFIG_SYS_NS16550_SERIAL #define CONFIG_SYS_NS16550_REG_SIZE 1 #define CONFIG_SYS_NS16550_CLK get_bus_freq(0) diff --git a/include/configs/MPC8349ITX.h b/include/configs/MPC8349ITX.h index 37dcde3..cb8bce1 100644 --- a/include/configs/MPC8349ITX.h +++ b/include/configs/MPC8349ITX.h @@ -340,7 +340,6 @@ boards, we say we have two, but don't display a message if we find only one. */ /* * Serial Port */ -#define CONFIG_CONS_INDEX 1 #define CONFIG_SYS_NS16550_SERIAL #define CONFIG_SYS_NS16550_REG_SIZE 1 #define CONFIG_SYS_NS16550_CLK get_bus_freq(0) diff --git a/include/configs/MPC837XEMDS.h b/include/configs/MPC837XEMDS.h index 182f558..0087e1d 100644 --- a/include/configs/MPC837XEMDS.h +++ b/include/configs/MPC837XEMDS.h @@ -301,7 +301,6 @@ /* * Serial Port */ -#define CONFIG_CONS_INDEX 1 #define CONFIG_SYS_NS16550_SERIAL #define CONFIG_SYS_NS16550_REG_SIZE 1 #define CONFIG_SYS_NS16550_CLK get_bus_freq(0) diff --git a/include/configs/MPC837XERDB.h b/include/configs/MPC837XERDB.h index 772ce6d..bc46698 100644 --- a/include/configs/MPC837XERDB.h +++ b/include/configs/MPC837XERDB.h @@ -322,7 +322,6 @@ /* * Serial Port */ -#define CONFIG_CONS_INDEX 1 #define CONFIG_SYS_NS16550_SERIAL #define CONFIG_SYS_NS16550_REG_SIZE 1 #define CONFIG_SYS_NS16550_CLK get_bus_freq(0) diff --git a/include/configs/MPC8536DS.h b/include/configs/MPC8536DS.h index 9f0039c..09a5eae 100644 --- a/include/configs/MPC8536DS.h +++ b/include/configs/MPC8536DS.h @@ -340,7 +340,6 @@ * open - index 2 * shorted - index 1 */ -#define CONFIG_CONS_INDEX 1 #define CONFIG_SYS_NS16550_SERIAL #define CONFIG_SYS_NS16550_REG_SIZE 1 #define CONFIG_SYS_NS16550_CLK get_bus_freq(0) diff --git a/include/configs/MPC8540ADS.h b/include/configs/MPC8540ADS.h index d44de9a..a02e20c 100644 --- a/include/configs/MPC8540ADS.h +++ b/include/configs/MPC8540ADS.h @@ -204,7 +204,6 @@ #define CONFIG_SYS_MALLOC_LEN (128 * 1024) /* Reserved for malloc */
/* Serial Port */ -#define CONFIG_CONS_INDEX 1 #define CONFIG_SYS_NS16550_SERIAL #define CONFIG_SYS_NS16550_REG_SIZE 1 #define CONFIG_SYS_NS16550_CLK get_bus_freq(0) diff --git a/include/configs/MPC8541CDS.h b/include/configs/MPC8541CDS.h index 238dd67..27153b7 100644 --- a/include/configs/MPC8541CDS.h +++ b/include/configs/MPC8541CDS.h @@ -229,7 +229,6 @@ extern unsigned long get_clock_freq(void); #define CONFIG_SYS_MALLOC_LEN (128 * 1024) /* Reserved for malloc */
/* Serial Port */ -#define CONFIG_CONS_INDEX 2 #define CONFIG_SYS_NS16550_SERIAL #define CONFIG_SYS_NS16550_REG_SIZE 1 #define CONFIG_SYS_NS16550_CLK get_bus_freq(0) diff --git a/include/configs/MPC8544DS.h b/include/configs/MPC8544DS.h index 64e0aa1..917c92e 100644 --- a/include/configs/MPC8544DS.h +++ b/include/configs/MPC8544DS.h @@ -175,7 +175,6 @@ extern unsigned long get_board_sys_clk(unsigned long dummy); * open - index 2 * shorted - index 1 */ -#define CONFIG_CONS_INDEX 1 #define CONFIG_SYS_NS16550_SERIAL #define CONFIG_SYS_NS16550_REG_SIZE 1 #define CONFIG_SYS_NS16550_CLK get_bus_freq(0) diff --git a/include/configs/MPC8548CDS.h b/include/configs/MPC8548CDS.h index cdd70a1..5b6373e 100644 --- a/include/configs/MPC8548CDS.h +++ b/include/configs/MPC8548CDS.h @@ -299,7 +299,6 @@ extern unsigned long get_clock_freq(void); #define CONFIG_SYS_MALLOC_LEN (1024 * 1024) /* Reserved for malloc */
/* Serial Port */ -#define CONFIG_CONS_INDEX 2 #define CONFIG_SYS_NS16550_SERIAL #define CONFIG_SYS_NS16550_REG_SIZE 1 #define CONFIG_SYS_NS16550_CLK get_bus_freq(0) diff --git a/include/configs/MPC8555CDS.h b/include/configs/MPC8555CDS.h index bcef1e7..28cbdc5 100644 --- a/include/configs/MPC8555CDS.h +++ b/include/configs/MPC8555CDS.h @@ -227,7 +227,6 @@ extern unsigned long get_clock_freq(void); #define CONFIG_SYS_MALLOC_LEN (128 * 1024) /* Reserved for malloc */
/* Serial Port */ -#define CONFIG_CONS_INDEX 2 #define CONFIG_SYS_NS16550_SERIAL #define CONFIG_SYS_NS16550_REG_SIZE 1 #define CONFIG_SYS_NS16550_CLK get_bus_freq(0) diff --git a/include/configs/MPC8560ADS.h b/include/configs/MPC8560ADS.h index 7f854c5..b76d2e8 100644 --- a/include/configs/MPC8560ADS.h +++ b/include/configs/MPC8560ADS.h @@ -205,7 +205,6 @@ /* Serial Port */ #define CONFIG_CONS_ON_SCC /* define if console on SCC */ #undef CONFIG_CONS_NONE /* define if console on something else */ -#define CONFIG_CONS_INDEX 1 /* which serial channel for console */
#define CONFIG_SYS_BAUDRATE_TABLE \ {300, 600, 1200, 2400, 4800, 9600, 19200, 38400,115200} diff --git a/include/configs/MPC8568MDS.h b/include/configs/MPC8568MDS.h index 6d9a964..c27e7a3 100644 --- a/include/configs/MPC8568MDS.h +++ b/include/configs/MPC8568MDS.h @@ -207,7 +207,6 @@ extern unsigned long get_clock_freq(void); #define CONFIG_SYS_MALLOC_LEN (512 * 1024) /* Reserved for malloc */
/* Serial Port */ -#define CONFIG_CONS_INDEX 1 #define CONFIG_SYS_NS16550_SERIAL #define CONFIG_SYS_NS16550_REG_SIZE 1 #define CONFIG_SYS_NS16550_CLK get_bus_freq(0) diff --git a/include/configs/MPC8569MDS.h b/include/configs/MPC8569MDS.h index ae92c37..da9370b 100644 --- a/include/configs/MPC8569MDS.h +++ b/include/configs/MPC8569MDS.h @@ -214,7 +214,6 @@ extern unsigned long get_clock_freq(void); #define CONFIG_SYS_MALLOC_LEN (512 * 1024) /* Reserved for malloc */
/* Serial Port */ -#define CONFIG_CONS_INDEX 1 #define CONFIG_SYS_NS16550_SERIAL #define CONFIG_SYS_NS16550_REG_SIZE 1 #define CONFIG_SYS_NS16550_CLK get_bus_freq(0) diff --git a/include/configs/MPC8572DS.h b/include/configs/MPC8572DS.h index 303922a..c1ff6e1 100644 --- a/include/configs/MPC8572DS.h +++ b/include/configs/MPC8572DS.h @@ -338,7 +338,6 @@ * open - index 2 * shorted - index 1 */ -#define CONFIG_CONS_INDEX 1 #define CONFIG_SYS_NS16550_SERIAL #define CONFIG_SYS_NS16550_REG_SIZE 1 #define CONFIG_SYS_NS16550_CLK get_bus_freq(0) diff --git a/include/configs/MPC8610HPCD.h b/include/configs/MPC8610HPCD.h index fb5dc9a..0fc0d11 100644 --- a/include/configs/MPC8610HPCD.h +++ b/include/configs/MPC8610HPCD.h @@ -201,7 +201,6 @@ #define CONFIG_SYS_MALLOC_LEN (6 * 1024 * 1024) /* Reserved for malloc */
/* Serial Port */ -#define CONFIG_CONS_INDEX 1 #define CONFIG_SYS_NS16550_SERIAL #define CONFIG_SYS_NS16550_REG_SIZE 1 #define CONFIG_SYS_NS16550_CLK get_bus_freq(0) diff --git a/include/configs/MPC8641HPCN.h b/include/configs/MPC8641HPCN.h index 954896c..02fdd02 100644 --- a/include/configs/MPC8641HPCN.h +++ b/include/configs/MPC8641HPCN.h @@ -246,7 +246,6 @@ extern unsigned long get_board_sys_clk(unsigned long dummy); #define CONFIG_SYS_MALLOC_LEN (1024 * 1024) /* Reserved for malloc */
/* Serial Port */ -#define CONFIG_CONS_INDEX 1 #define CONFIG_SYS_NS16550_SERIAL #define CONFIG_SYS_NS16550_REG_SIZE 1 #define CONFIG_SYS_NS16550_CLK get_bus_freq(0) diff --git a/include/configs/P1010RDB.h b/include/configs/P1010RDB.h index 344d99d..f604258 100644 --- a/include/configs/P1010RDB.h +++ b/include/configs/P1010RDB.h @@ -529,7 +529,6 @@ extern unsigned long get_sdram_size(void); #endif
/* Serial Port */ -#define CONFIG_CONS_INDEX 1 #undef CONFIG_SERIAL_SOFTWARE_FIFO #define CONFIG_SYS_NS16550_SERIAL #define CONFIG_SYS_NS16550_REG_SIZE 1 diff --git a/include/configs/P1022DS.h b/include/configs/P1022DS.h index 62165df..b4b4d83 100644 --- a/include/configs/P1022DS.h +++ b/include/configs/P1022DS.h @@ -338,7 +338,6 @@ /* * Serial Port */ -#define CONFIG_CONS_INDEX 1 #define CONFIG_SYS_NS16550_SERIAL #define CONFIG_SYS_NS16550_REG_SIZE 1 #define CONFIG_SYS_NS16550_CLK get_bus_freq(0) diff --git a/include/configs/P1023RDB.h b/include/configs/P1023RDB.h index 8dbfb06..1328e02 100644 --- a/include/configs/P1023RDB.h +++ b/include/configs/P1023RDB.h @@ -143,7 +143,6 @@ extern unsigned long get_clock_freq(void); #define CONFIG_SYS_OR1_PRELIM CONFIG_SYS_NAND_OR_PRELIM /* NAND Options */
/* Serial Port */ -#define CONFIG_CONS_INDEX 1 #undef CONFIG_SERIAL_SOFTWARE_FIFO #define CONFIG_SYS_NS16550_SERIAL #define CONFIG_SYS_NS16550_REG_SIZE 1 diff --git a/include/configs/P2041RDB.h b/include/configs/P2041RDB.h index bf9b1c4..0b5cde6 100644 --- a/include/configs/P2041RDB.h +++ b/include/configs/P2041RDB.h @@ -293,7 +293,6 @@ unsigned long get_board_sys_clk(unsigned long dummy); * open - index 2 * shorted - index 1 */ -#define CONFIG_CONS_INDEX 1 #define CONFIG_SYS_NS16550_SERIAL #define CONFIG_SYS_NS16550_REG_SIZE 1 #define CONFIG_SYS_NS16550_CLK (get_bus_freq(0)/2) diff --git a/include/configs/T102xQDS.h b/include/configs/T102xQDS.h index 8001e70..cd980bc 100644 --- a/include/configs/T102xQDS.h +++ b/include/configs/T102xQDS.h @@ -454,7 +454,6 @@ unsigned long get_board_ddr_clk(void); #define CONFIG_SYS_MALLOC_LEN (10 * 1024 * 1024)
/* Serial Port */ -#define CONFIG_CONS_INDEX 1 #define CONFIG_SYS_NS16550_SERIAL #define CONFIG_SYS_NS16550_REG_SIZE 1 #define CONFIG_SYS_NS16550_CLK (get_bus_freq(0)/2) diff --git a/include/configs/T102xRDB.h b/include/configs/T102xRDB.h index e80ba14..378ed18 100644 --- a/include/configs/T102xRDB.h +++ b/include/configs/T102xRDB.h @@ -463,7 +463,6 @@ unsigned long get_board_ddr_clk(void); #define CONFIG_SYS_MALLOC_LEN (10 * 1024 * 1024)
/* Serial Port */ -#define CONFIG_CONS_INDEX 1 #define CONFIG_SYS_NS16550_SERIAL #define CONFIG_SYS_NS16550_REG_SIZE 1 #define CONFIG_SYS_NS16550_CLK (get_bus_freq(0)/2) diff --git a/include/configs/T1040QDS.h b/include/configs/T1040QDS.h index c0a1bb4..6880510 100644 --- a/include/configs/T1040QDS.h +++ b/include/configs/T1040QDS.h @@ -367,7 +367,6 @@ unsigned long get_board_ddr_clk(void); * open - index 2 * shorted - index 1 */ -#define CONFIG_CONS_INDEX 1 #define CONFIG_SYS_NS16550_SERIAL #define CONFIG_SYS_NS16550_REG_SIZE 1 #define CONFIG_SYS_NS16550_CLK (get_bus_freq(0)/2) diff --git a/include/configs/T104xRDB.h b/include/configs/T104xRDB.h index a8f7885..a45bf40 100644 --- a/include/configs/T104xRDB.h +++ b/include/configs/T104xRDB.h @@ -473,7 +473,6 @@ $(SRCTREE)/board/freescale/t104xrdb/t1042d4_sd_rcw.cfg * open - index 2 * shorted - index 1 */ -#define CONFIG_CONS_INDEX 1 #define CONFIG_SYS_NS16550_SERIAL #define CONFIG_SYS_NS16550_REG_SIZE 1 #define CONFIG_SYS_NS16550_CLK (get_bus_freq(0)/2) diff --git a/include/configs/T208xQDS.h b/include/configs/T208xQDS.h index 50413eb..14a329f 100644 --- a/include/configs/T208xQDS.h +++ b/include/configs/T208xQDS.h @@ -419,7 +419,6 @@ unsigned long get_board_ddr_clk(void); /* * Serial Port */ -#define CONFIG_CONS_INDEX 1 #define CONFIG_SYS_NS16550_SERIAL #define CONFIG_SYS_NS16550_REG_SIZE 1 #define CONFIG_SYS_NS16550_CLK (get_bus_freq(0)/2) diff --git a/include/configs/T208xRDB.h b/include/configs/T208xRDB.h index ca1916a..03d933b 100644 --- a/include/configs/T208xRDB.h +++ b/include/configs/T208xRDB.h @@ -367,7 +367,6 @@ unsigned long get_board_ddr_clk(void); /* * Serial Port */ -#define CONFIG_CONS_INDEX 1 #define CONFIG_SYS_NS16550_SERIAL #define CONFIG_SYS_NS16550_REG_SIZE 1 #define CONFIG_SYS_NS16550_CLK (get_bus_freq(0)/2) diff --git a/include/configs/T4240RDB.h b/include/configs/T4240RDB.h index 87d65e4..35e96b2 100644 --- a/include/configs/T4240RDB.h +++ b/include/configs/T4240RDB.h @@ -161,7 +161,6 @@ * open - index 2 * shorted - index 1 */ -#define CONFIG_CONS_INDEX 1 #define CONFIG_SYS_NS16550_SERIAL #define CONFIG_SYS_NS16550_REG_SIZE 1 #define CONFIG_SYS_NS16550_CLK (get_bus_freq(0)/2) diff --git a/include/configs/TQM834x.h b/include/configs/TQM834x.h index f4d8012..98a7c48 100644 --- a/include/configs/TQM834x.h +++ b/include/configs/TQM834x.h @@ -151,7 +151,6 @@ /* * Serial Port */ -#define CONFIG_CONS_INDEX 1 #define CONFIG_SYS_NS16550_SERIAL #define CONFIG_SYS_NS16550_REG_SIZE 1 #define CONFIG_SYS_NS16550_CLK get_bus_freq(0) diff --git a/include/configs/UCP1020.h b/include/configs/UCP1020.h index 499319f..14d7868 100644 --- a/include/configs/UCP1020.h +++ b/include/configs/UCP1020.h @@ -274,7 +274,6 @@ * open - index 2 * shorted - index 1 */ -#define CONFIG_CONS_INDEX 1 #undef CONFIG_SERIAL_SOFTWARE_FIFO #define CONFIG_SYS_NS16550_SERIAL #define CONFIG_SYS_NS16550_REG_SIZE 1 diff --git a/include/configs/adp-ae3xx.h b/include/configs/adp-ae3xx.h index f95b1ff..f5a8dec 100644 --- a/include/configs/adp-ae3xx.h +++ b/include/configs/adp-ae3xx.h @@ -73,7 +73,6 @@ */
/* FTUART is a high speed NS 16C550A compatible UART, addr: 0x99600000 */ -#define CONFIG_CONS_INDEX 1 #define CONFIG_SYS_NS16550_SERIAL #define CONFIG_SYS_NS16550_COM1 CONFIG_FTUART010_02_BASE #ifndef CONFIG_DM_SERIAL diff --git a/include/configs/adp-ag101p.h b/include/configs/adp-ag101p.h index fb5fa21..6ae6fb4 100644 --- a/include/configs/adp-ag101p.h +++ b/include/configs/adp-ag101p.h @@ -75,7 +75,6 @@ */
/* FTUART is a high speed NS 16C550A compatible UART, addr: 0x99600000 */ -#define CONFIG_CONS_INDEX 1 #define CONFIG_SYS_NS16550_SERIAL #define CONFIG_SYS_NS16550_COM1 CONFIG_FTUART010_02_BASE #ifndef CONFIG_DM_SERIAL diff --git a/include/configs/advantech_dms-ba16.h b/include/configs/advantech_dms-ba16.h index aba2fc6..826cb45 100644 --- a/include/configs/advantech_dms-ba16.h +++ b/include/configs/advantech_dms-ba16.h @@ -76,7 +76,6 @@
/* allow to overwrite serial and ethaddr */ #define CONFIG_ENV_OVERWRITE -#define CONFIG_CONS_INDEX 1
#define CONFIG_LOADADDR 0x12000000
diff --git a/include/configs/am335x_igep003x.h b/include/configs/am335x_igep003x.h index d5b63e6..50fd46a 100644 --- a/include/configs/am335x_igep003x.h +++ b/include/configs/am335x_igep003x.h @@ -107,7 +107,6 @@
/* NS16550 Configuration */ #define CONFIG_SYS_NS16550_COM1 0x44e09000 /* UART0 */ -#define CONFIG_CONS_INDEX 1
/* Ethernet support */ #define CONFIG_PHY_SMSC diff --git a/include/configs/am335x_shc.h b/include/configs/am335x_shc.h index 55e803b..c177b86 100644 --- a/include/configs/am335x_shc.h +++ b/include/configs/am335x_shc.h @@ -236,7 +236,6 @@ #define CONFIG_SYS_NS16550_COM4 0x481a6000 /* UART3 */ #define CONFIG_SYS_NS16550_COM5 0x481a8000 /* UART4 */ #define CONFIG_SYS_NS16550_COM6 0x481aa000 /* UART5 */ -#define CONFIG_CONS_INDEX 1
/* PMIC support */ #define CONFIG_POWER_TPS65217 diff --git a/include/configs/am3517_crane.h b/include/configs/am3517_crane.h index 03b7c26..b97a761 100644 --- a/include/configs/am3517_crane.h +++ b/include/configs/am3517_crane.h @@ -58,7 +58,6 @@ /* * select serial console configuration */ -#define CONFIG_CONS_INDEX 3 #define CONFIG_SYS_NS16550_COM3 OMAP34XX_UART3 #define CONFIG_SERIAL3 3 /* UART3 on CRANEBOARD */
diff --git a/include/configs/apalis_imx6.h b/include/configs/apalis_imx6.h index 21a79e1..9e5a7e5 100644 --- a/include/configs/apalis_imx6.h +++ b/include/configs/apalis_imx6.h @@ -117,7 +117,6 @@
/* Command definition */ #undef CONFIG_CMD_LOADB diff --git a/include/configs/apf27.h b/include/configs/apf27.h index 1b52cc3..e1d4aa6 100644 --- a/include/configs/apf27.h +++ b/include/configs/apf27.h @@ -155,7 +155,6 @@ * Serial Driver */ #define CONFIG_MXC_UART -#define CONFIG_CONS_INDEX 1 #define CONFIG_MXC_UART_BASE UART1_BASE
/* diff --git a/include/configs/bcm23550_w1d.h b/include/configs/bcm23550_w1d.h index 9c23c9b..2062e9a 100644 --- a/include/configs/bcm23550_w1d.h +++ b/include/configs/bcm23550_w1d.h @@ -76,7 +76,6 @@ /* Post pad 3 bytes after each reg addr */ #define CONFIG_SYS_NS16550_REG_SIZE (-4) #define CONFIG_SYS_NS16550_CLK 13000000 -#define CONFIG_CONS_INDEX 1 #define CONFIG_SYS_NS16550_COM1 0x3e000000
/* must fit into GPT:u-boot-env partition */ diff --git a/include/configs/bcm28155_ap.h b/include/configs/bcm28155_ap.h index bd6d9ae..f15b94c 100644 --- a/include/configs/bcm28155_ap.h +++ b/include/configs/bcm28155_ap.h @@ -75,7 +75,6 @@ /* Post pad 3 bytes after each reg addr */ #define CONFIG_SYS_NS16550_REG_SIZE (-4) #define CONFIG_SYS_NS16550_CLK 13000000 -#define CONFIG_CONS_INDEX 1 #define CONFIG_SYS_NS16550_COM1 0x3e000000
/* must fit into GPT:u-boot-env partition */ diff --git a/include/configs/bcm_northstar2.h b/include/configs/bcm_northstar2.h index 634186a..9c66643 100644 --- a/include/configs/bcm_northstar2.h +++ b/include/configs/bcm_northstar2.h @@ -33,7 +33,6 @@ #define CONFIG_SYS_NS16550_COM2 0x66110000 #define CONFIG_SYS_NS16550_COM3 0x66120000 #define CONFIG_SYS_NS16550_COM4 0x66130000 -#define CONFIG_CONS_INDEX 4 #define CONFIG_BAUDRATE 115200
#define CONFIG_ENV_SIZE SZ_8K diff --git a/include/configs/calimain.h b/include/configs/calimain.h index 364066f..d55ef3e 100644 --- a/include/configs/calimain.h +++ b/include/configs/calimain.h @@ -133,7 +133,6 @@ #define CONFIG_SYS_NS16550_REG_SIZE -4 /* NS16550 register size */ #define CONFIG_SYS_NS16550_COM1 DAVINCI_UART2_BASE /* Base address of UART2 */ #define CONFIG_SYS_NS16550_CLK clk_get(DAVINCI_UART2_CLKID) -#define CONFIG_CONS_INDEX 1 /* use UART0 for console */
#define CONFIG_FLASH_CFI_DRIVER #define CONFIG_SYS_FLASH_CFI diff --git a/include/configs/chiliboard.h b/include/configs/chiliboard.h index 92e0479..5a69f3c 100644 --- a/include/configs/chiliboard.h +++ b/include/configs/chiliboard.h @@ -9,8 +9,6 @@
#include <configs/ti_am335x_common.h>
-#define CONFIG_CONS_INDEX 1 - #ifndef CONFIG_SPL_BUILD # define CONFIG_TIMESTAMP #endif diff --git a/include/configs/cl-som-am57x.h b/include/configs/cl-som-am57x.h index eaf2754..596e060 100644 --- a/include/configs/cl-som-am57x.h +++ b/include/configs/cl-som-am57x.h @@ -15,7 +15,6 @@
#define CONSOLEDEV "ttyO2" #define CONFIG_SYS_NS16550_COM3 UART3_BASE /* UART3 */ -#define CONFIG_CONS_INDEX 3
#define CONFIG_SYS_OMAP_ABE_SYSCK
diff --git a/include/configs/cm_t335.h b/include/configs/cm_t335.h index bd41a56..641bdb7 100644 --- a/include/configs/cm_t335.h +++ b/include/configs/cm_t335.h @@ -83,7 +83,6 @@ #define CONFIG_SYS_AUTOLOAD "no"
/* Serial console configuration */ -#define CONFIG_CONS_INDEX 1 #define CONFIG_SERIAL1 1 /* UART0 */
/* NS16550 Configuration */ diff --git a/include/configs/cm_t35.h b/include/configs/cm_t35.h index 400edf0..e464e40 100644 --- a/include/configs/cm_t35.h +++ b/include/configs/cm_t35.h @@ -62,7 +62,6 @@ /* * select serial console configuration */ -#define CONFIG_CONS_INDEX 3 #define CONFIG_SYS_NS16550_COM3 OMAP34XX_UART3 #define CONFIG_SERIAL3 3 /* UART3 */
diff --git a/include/configs/cm_t3517.h b/include/configs/cm_t3517.h index 19117a0..a57715e 100644 --- a/include/configs/cm_t3517.h +++ b/include/configs/cm_t3517.h @@ -66,7 +66,6 @@ /* * select serial console configuration */ -#define CONFIG_CONS_INDEX 3 #define CONFIG_SYS_NS16550_COM3 OMAP34XX_UART3 #define CONFIG_SERIAL3 3 /* UART3 */
diff --git a/include/configs/cm_t43.h b/include/configs/cm_t43.h index 1b057ef..da78519 100644 --- a/include/configs/cm_t43.h +++ b/include/configs/cm_t43.h @@ -128,8 +128,6 @@ "run emmcboot; " \ "fi;"
-#define CONFIG_CONS_INDEX 1 - /* SPL defines. */ #define CONFIG_SPL_TEXT_BASE 0x40300350 #define CONFIG_SYS_SPL_ARGS_ADDR (CONFIG_SYS_SDRAM_BASE + (128 << 20)) diff --git a/include/configs/cm_t54.h b/include/configs/cm_t54.h index 1351eb8..6123cd3 100644 --- a/include/configs/cm_t54.h +++ b/include/configs/cm_t54.h @@ -25,7 +25,6 @@ #define OMAP_HSMMC_USE_GPIO
/* UART setup */ -#define CONFIG_CONS_INDEX 4 #define CONFIG_SYS_NS16550_COM4 UART4_BASE
/* MMC ENV related defines */ diff --git a/include/configs/colibri_imx6.h b/include/configs/colibri_imx6.h index b810384..72db44d 100644 --- a/include/configs/colibri_imx6.h +++ b/include/configs/colibri_imx6.h @@ -105,7 +105,6 @@
/* Command definition */ #undef CONFIG_CMD_LOADB diff --git a/include/configs/controlcenterd.h b/include/configs/controlcenterd.h index 276c733..9261eb4 100644 --- a/include/configs/controlcenterd.h +++ b/include/configs/controlcenterd.h @@ -155,7 +155,6 @@ /* * Serial Port */ -#define CONFIG_CONS_INDEX 2 #define CONFIG_SYS_NS16550_SERIAL #define CONFIG_SYS_NS16550_REG_SIZE 1 #define CONFIG_SYS_NS16550_CLK get_bus_freq(0) diff --git a/include/configs/corenet_ds.h b/include/configs/corenet_ds.h index 83c2642..d325bc9 100644 --- a/include/configs/corenet_ds.h +++ b/include/configs/corenet_ds.h @@ -301,7 +301,6 @@ * open - index 2 * shorted - index 1 */ -#define CONFIG_CONS_INDEX 1 #define CONFIG_SYS_NS16550_SERIAL #define CONFIG_SYS_NS16550_REG_SIZE 1 #define CONFIG_SYS_NS16550_CLK (get_bus_freq(0)/2) diff --git a/include/configs/cyrus.h b/include/configs/cyrus.h index dde0dc3..c3b5845 100644 --- a/include/configs/cyrus.h +++ b/include/configs/cyrus.h @@ -186,7 +186,6 @@ * open - index 2 * shorted - index 1 */ -#define CONFIG_CONS_INDEX 1 #define CONFIG_SYS_NS16550_SERIAL #define CONFIG_SYS_NS16550_REG_SIZE 1 #define CONFIG_SYS_NS16550_CLK (get_bus_freq(0)/2) diff --git a/include/configs/da850evm.h b/include/configs/da850evm.h index a58a54e..dcae282 100644 --- a/include/configs/da850evm.h +++ b/include/configs/da850evm.h @@ -126,7 +126,6 @@ #define CONFIG_SYS_NS16550_COM1 DAVINCI_UART2_BASE /* Base address of UART2 */ #endif #define CONFIG_SYS_NS16550_CLK clk_get(DAVINCI_UART2_CLKID) -#define CONFIG_CONS_INDEX 1 /* use UART0 for console */
#define CONFIG_SPI #define CONFIG_SYS_SPI_CLK clk_get(DAVINCI_SPI1_CLKID) diff --git a/include/configs/dh_imx6.h b/include/configs/dh_imx6.h index abe393e..3ee50e2 100644 --- a/include/configs/dh_imx6.h +++ b/include/configs/dh_imx6.h @@ -91,7 +91,6 @@ /* UART */ #define CONFIG_MXC_UART #define CONFIG_MXC_UART_BASE UART1_BASE -#define CONFIG_CONS_INDEX 1 #define CONFIG_BAUDRATE 115200
/* USB Configs */ diff --git a/include/configs/ea20.h b/include/configs/ea20.h index d27323a..75353cd 100644 --- a/include/configs/ea20.h +++ b/include/configs/ea20.h @@ -54,7 +54,6 @@ #define CONFIG_SYS_NS16550_REG_SIZE -4 /* NS16550 register size */ #define CONFIG_SYS_NS16550_COM1 DAVINCI_UART0_BASE /* Base address of UART0 */ #define CONFIG_SYS_NS16550_CLK clk_get(DAVINCI_UART2_CLKID) -#define CONFIG_CONS_INDEX 1 /* use UART0 for console */
#define CONFIG_SPI #define CONFIG_SYS_SPI_BASE DAVINCI_SPI1_BASE diff --git a/include/configs/eco5pk.h b/include/configs/eco5pk.h index 3c4ec17..63568ca 100644 --- a/include/configs/eco5pk.h +++ b/include/configs/eco5pk.h @@ -16,11 +16,9 @@ #include "tam3517-common.h"
/* Our console port is port3 */ -#undef CONFIG_CONS_INDEX #undef CONFIG_SYS_NS16550_COM1 #undef CONFIG_SERIAL1
diff --git a/include/configs/edb93xx.h b/include/configs/edb93xx.h index 6e024d1..9ea8fd3 100644 --- a/include/configs/edb93xx.h +++ b/include/configs/edb93xx.h @@ -79,7 +79,6 @@ #define CONFIG_SYS_CBSIZE 1024 /* Console I/O buffer size */
/* Serial port hardware configuration */ -#define CONFIG_CONS_INDEX 0 #define CONFIG_SYS_BAUDRATE_TABLE {9600, 19200, 38400, 57600, \ 115200, 230400} #define CONFIG_SYS_SERIAL0 0x808C0000 diff --git a/include/configs/edminiv2.h b/include/configs/edminiv2.h index b262b37..6a92e7f 100644 --- a/include/configs/edminiv2.h +++ b/include/configs/edminiv2.h @@ -84,7 +84,6 @@ * for your console driver. */
-#define CONFIG_CONS_INDEX 1 /*Console on UART0 */ #define CONFIG_SYS_BAUDRATE_TABLE \ { 9600, 19200, 38400, 57600, 115200, 230400, 460800, 921600 }
diff --git a/include/configs/flea3.h b/include/configs/flea3.h index 067d836..2ce8720 100644 --- a/include/configs/flea3.h +++ b/include/configs/flea3.h @@ -55,7 +55,6 @@
/* * Command definition diff --git a/include/configs/ge_bx50v3.h b/include/configs/ge_bx50v3.h index cbfe30d..8a0ac61 100644 --- a/include/configs/ge_bx50v3.h +++ b/include/configs/ge_bx50v3.h @@ -100,7 +100,6 @@
diff --git a/include/configs/h2200.h b/include/configs/h2200.h index 608f5ee..1324345 100644 --- a/include/configs/h2200.h +++ b/include/configs/h2200.h @@ -101,7 +101,6 @@ * Serial port */ #define CONFIG_FFUART -#define CONFIG_CONS_INDEX 3
#define CONFIG_SYS_BAUDRATE_TABLE { 9600, 38400, 115200 }
diff --git a/include/configs/highbank.h b/include/configs/highbank.h index 785cad7..038ffcd 100644 --- a/include/configs/highbank.h +++ b/include/configs/highbank.h @@ -22,7 +22,6 @@
#define CONFIG_PL011_CLOCK 150000000 #define CONFIG_PL01x_PORTS { (void *)(0xFFF36000) } -#define CONFIG_CONS_INDEX 0
#define CONFIG_SYS_BOOTCOUNT_LE /* Use little-endian accessors */
diff --git a/include/configs/hrcon.h b/include/configs/hrcon.h index 4491085..eadc3c1 100644 --- a/include/configs/hrcon.h +++ b/include/configs/hrcon.h @@ -277,7 +277,6 @@ /* * Serial Port */ -#define CONFIG_CONS_INDEX 2 #define CONFIG_SYS_NS16550_SERIAL #define CONFIG_SYS_NS16550_REG_SIZE 1 #define CONFIG_SYS_NS16550_CLK get_bus_freq(0) diff --git a/include/configs/ids8313.h b/include/configs/ids8313.h index a4acaa6..e107109 100644 --- a/include/configs/ids8313.h +++ b/include/configs/ids8313.h @@ -315,7 +315,6 @@ /* * Serial Port */ -#define CONFIG_CONS_INDEX 1 #define CONFIG_SYS_NS16550_SERIAL #define CONFIG_SYS_NS16550_REG_SIZE 1
diff --git a/include/configs/imx27lite-common.h b/include/configs/imx27lite-common.h index dca910f..4754614 100644 --- a/include/configs/imx27lite-common.h +++ b/include/configs/imx27lite-common.h @@ -82,7 +82,6 @@ */ #define CONFIG_MXC_UART #define CONFIG_MXC_UART_BASE UART1_BASE -#define CONFIG_CONS_INDEX 1 /* use UART0 for console */
/* * Flash & Environment diff --git a/include/configs/imx31_phycore.h b/include/configs/imx31_phycore.h index 3b5eb4f..e651410 100644 --- a/include/configs/imx31_phycore.h +++ b/include/configs/imx31_phycore.h @@ -43,7 +43,6 @@
/*********************************************************** * Command definition diff --git a/include/configs/integrator-common.h b/include/configs/integrator-common.h index 63aa8df..cf74052 100644 --- a/include/configs/integrator-common.h +++ b/include/configs/integrator-common.h @@ -13,8 +13,6 @@ #define CONFIG_SYS_LOAD_ADDR 0x7fc0 /* default load address */ #define CONFIG_SYS_MALLOC_LEN (CONFIG_ENV_SIZE + 128*1024) /* Size of malloc() pool */
-#define CONFIG_CONS_INDEX 0 - #define CONFIG_CMDLINE_TAG /* enable passing of ATAGs */ #define CONFIG_SETUP_MEMORY_TAGS #define CONFIG_MISC_INIT_R /* call misc_init_r during start up */ diff --git a/include/configs/ipam390.h b/include/configs/ipam390.h index 82ab24c..16c9637 100644 --- a/include/configs/ipam390.h +++ b/include/configs/ipam390.h @@ -115,7 +115,6 @@ #define CONFIG_SYS_NS16550_REG_SIZE -4 /* NS16550 register size */ #define CONFIG_SYS_NS16550_COM1 DAVINCI_UART0_BASE /* Base address of UART0 */ #define CONFIG_SYS_NS16550_CLK clk_get(DAVINCI_UART2_CLKID) -#define CONFIG_CONS_INDEX 1 /* use UART0 for console */
/* * Flash & Environment diff --git a/include/configs/kc1.h b/include/configs/kc1.h index 061303d..b7d510e 100644 --- a/include/configs/kc1.h +++ b/include/configs/kc1.h @@ -97,7 +97,6 @@ #define CONFIG_SYS_NS16550_REG_SIZE (-4) #define CONFIG_SYS_NS16550_CLK 48000000 #define CONFIG_SYS_NS16550_COM3 UART3_BASE -#define CONFIG_CONS_INDEX 3
#define CONFIG_SYS_BAUDRATE_TABLE { 4800, 9600, 19200, 38400, 57600, \ 115200 } diff --git a/include/configs/km/km83xx-common.h b/include/configs/km/km83xx-common.h index f0ec5cf..f315062 100644 --- a/include/configs/km/km83xx-common.h +++ b/include/configs/km/km83xx-common.h @@ -128,7 +128,6 @@ /* * Serial Port */ -#define CONFIG_CONS_INDEX 1 #define CONFIG_SYS_NS16550_SERIAL #define CONFIG_SYS_NS16550_REG_SIZE 1 #define CONFIG_SYS_NS16550_CLK get_bus_freq(0) diff --git a/include/configs/km/km_arm.h b/include/configs/km/km_arm.h index cc36a68..379224d 100644 --- a/include/configs/km/km_arm.h +++ b/include/configs/km/km_arm.h @@ -98,8 +98,6 @@ * for your console driver. */
-#define CONFIG_CONS_INDEX 1 /* Console on UART0 */ - /* * For booting Linux, the board info and command line data * have to be in the first 8 MB of memory, since this is diff --git a/include/configs/km/kmp204x-common.h b/include/configs/km/kmp204x-common.h index f49f436..89e18c5 100644 --- a/include/configs/km/kmp204x-common.h +++ b/include/configs/km/kmp204x-common.h @@ -219,7 +219,6 @@ unsigned long get_board_sys_clk(unsigned long dummy); * open - index 2 * shorted - index 1 */ -#define CONFIG_CONS_INDEX 1 #define CONFIG_SYS_NS16550_SERIAL #define CONFIG_SYS_NS16550_REG_SIZE 1 #define CONFIG_SYS_NS16550_CLK (get_bus_freq(0)/2) diff --git a/include/configs/legoev3.h b/include/configs/legoev3.h index 1d3fd96..3e5689a 100644 --- a/include/configs/legoev3.h +++ b/include/configs/legoev3.h @@ -102,7 +102,6 @@ #define CONFIG_SYS_NS16550_REG_SIZE -4 /* NS16550 register size */ #define CONFIG_SYS_NS16550_COM1 DAVINCI_UART1_BASE /* Base address of UART1 */ #define CONFIG_SYS_NS16550_CLK clk_get(DAVINCI_UART2_CLKID) -#define CONFIG_CONS_INDEX 1 /* use UART0 for console */
#define CONFIG_SPI #define CONFIG_SYS_SPI_BASE DAVINCI_SPI0_BASE diff --git a/include/configs/ls1012a_common.h b/include/configs/ls1012a_common.h index 46b3566..a58b867 100644 --- a/include/configs/ls1012a_common.h +++ b/include/configs/ls1012a_common.h @@ -81,7 +81,6 @@ #define CONFIG_SYS_I2C_MXC_I2C1 /* enable I2C bus 1 */ #define CONFIG_SYS_I2C_MXC_I2C2 /* enable I2C bus 2 */
-#define CONFIG_CONS_INDEX 1 #define CONFIG_SYS_NS16550_SERIAL #define CONFIG_SYS_NS16550_REG_SIZE 1 #define CONFIG_SYS_NS16550_CLK (get_serial_clock()) diff --git a/include/configs/ls1021aiot.h b/include/configs/ls1021aiot.h index 20c50ff..88f44ca 100644 --- a/include/configs/ls1021aiot.h +++ b/include/configs/ls1021aiot.h @@ -92,7 +92,6 @@ /* * Serial Port */ -#define CONFIG_CONS_INDEX 1 #define CONFIG_SYS_NS16550_SERIAL #define CONFIG_SYS_NS16550_REG_SIZE 1 #define CONFIG_SYS_NS16550_CLK get_serial_clock() diff --git a/include/configs/ls1021aqds.h b/include/configs/ls1021aqds.h index d1c0acb..5f59f1e 100644 --- a/include/configs/ls1021aqds.h +++ b/include/configs/ls1021aqds.h @@ -336,7 +336,6 @@ unsigned long get_board_ddr_clk(void); #ifdef CONFIG_LPUART #define CONFIG_LPUART_32B_REG #else -#define CONFIG_CONS_INDEX 1 #define CONFIG_SYS_NS16550_SERIAL #ifndef CONFIG_DM_SERIAL #define CONFIG_SYS_NS16550_REG_SIZE 1 diff --git a/include/configs/ls1021atwr.h b/include/configs/ls1021atwr.h index 8f27d9e..5c4da8d 100644 --- a/include/configs/ls1021atwr.h +++ b/include/configs/ls1021atwr.h @@ -209,7 +209,6 @@ #ifdef CONFIG_LPUART #define CONFIG_LPUART_32B_REG #else -#define CONFIG_CONS_INDEX 1 #define CONFIG_SYS_NS16550_SERIAL #ifndef CONFIG_DM_SERIAL #define CONFIG_SYS_NS16550_REG_SIZE 1 diff --git a/include/configs/ls1043a_common.h b/include/configs/ls1043a_common.h index 4c96186..687e987 100644 --- a/include/configs/ls1043a_common.h +++ b/include/configs/ls1043a_common.h @@ -54,7 +54,6 @@ #define CONFIG_SYS_MALLOC_LEN (CONFIG_ENV_SIZE + 1024 * 1024)
/* Serial Port */ -#define CONFIG_CONS_INDEX 1 #define CONFIG_SYS_NS16550_SERIAL #define CONFIG_SYS_NS16550_REG_SIZE 1 #define CONFIG_SYS_NS16550_CLK (get_serial_clock()) diff --git a/include/configs/ls1046a_common.h b/include/configs/ls1046a_common.h index b5af4b0..e1ad927 100644 --- a/include/configs/ls1046a_common.h +++ b/include/configs/ls1046a_common.h @@ -52,7 +52,6 @@ #define CONFIG_SYS_MALLOC_LEN (CONFIG_ENV_SIZE + 1024 * 1024)
/* Serial Port */ -#define CONFIG_CONS_INDEX 1 #define CONFIG_SYS_NS16550_SERIAL #define CONFIG_SYS_NS16550_REG_SIZE 1 #define CONFIG_SYS_NS16550_CLK (get_serial_clock()) diff --git a/include/configs/ls1088a_common.h b/include/configs/ls1088a_common.h index a3a393e..211059a 100644 --- a/include/configs/ls1088a_common.h +++ b/include/configs/ls1088a_common.h @@ -74,7 +74,6 @@ #define CONFIG_SYS_I2C_MXC_I2C4 /* enable I2C bus 4 */
/* Serial Port */ -#define CONFIG_CONS_INDEX 1 #define CONFIG_SYS_NS16550_SERIAL #define CONFIG_SYS_NS16550_REG_SIZE 1 #define CONFIG_SYS_NS16550_CLK (get_bus_freq(0) / 2) diff --git a/include/configs/ls2080a_common.h b/include/configs/ls2080a_common.h index edf954d..4e6a26c 100644 --- a/include/configs/ls2080a_common.h +++ b/include/configs/ls2080a_common.h @@ -84,7 +84,6 @@ #define CONFIG_SYS_I2C_MXC_I2C4 /* enable I2C bus 4 */
/* Serial Port */ -#define CONFIG_CONS_INDEX 1 #define CONFIG_SYS_NS16550_SERIAL #define CONFIG_SYS_NS16550_REG_SIZE 1 #define CONFIG_SYS_NS16550_CLK (get_serial_clock()) diff --git a/include/configs/ls2080ardb.h b/include/configs/ls2080ardb.h index 3f9794f..692f642 100644 --- a/include/configs/ls2080ardb.h +++ b/include/configs/ls2080ardb.h @@ -10,9 +10,6 @@
#include "ls2080a_common.h"
-#undef CONFIG_CONS_INDEX -#define CONFIG_CONS_INDEX 2 - #ifdef CONFIG_FSL_QSPI #ifdef CONFIG_TARGET_LS2081ARDB #define CONFIG_QIXIS_I2C_ACCESS diff --git a/include/configs/m53evk.h b/include/configs/m53evk.h index bd36a8d..171056d 100644 --- a/include/configs/m53evk.h +++ b/include/configs/m53evk.h @@ -50,7 +50,6 @@ */ #define CONFIG_MXC_UART #define CONFIG_MXC_UART_BASE UART2_BASE -#define CONFIG_CONS_INDEX 1
/* * MMC Driver diff --git a/include/configs/mcx.h b/include/configs/mcx.h index a624671..045f602 100644 --- a/include/configs/mcx.h +++ b/include/configs/mcx.h @@ -60,7 +60,6 @@ /* * select serial console configuration */ -#define CONFIG_CONS_INDEX 3 #define CONFIG_SYS_NS16550_COM3 OMAP34XX_UART3 #define CONFIG_SERIAL3 3 /* UART3 */
diff --git a/include/configs/mpc8308_p1m.h b/include/configs/mpc8308_p1m.h index dfed513..87afe3f 100644 --- a/include/configs/mpc8308_p1m.h +++ b/include/configs/mpc8308_p1m.h @@ -283,7 +283,6 @@ /* * Serial Port */ -#define CONFIG_CONS_INDEX 1 #undef CONFIG_SERIAL_SOFTWARE_FIFO #define CONFIG_SYS_NS16550_SERIAL #define CONFIG_SYS_NS16550_REG_SIZE 1 diff --git a/include/configs/mv-common.h b/include/configs/mv-common.h index 3035a11..62a303c 100644 --- a/include/configs/mv-common.h +++ b/include/configs/mv-common.h @@ -49,7 +49,6 @@ * for your console driver. */
-#define CONFIG_CONS_INDEX 1 /*Console on UART0 */ #define CONFIG_SYS_BAUDRATE_TABLE { 9600, 19200, 38400, 57600, \ 115200,230400, 460800, 921600 } /* auto boot */ diff --git a/include/configs/mx25pdk.h b/include/configs/mx25pdk.h index 74346cf..6c603ea 100644 --- a/include/configs/mx25pdk.h +++ b/include/configs/mx25pdk.h @@ -49,7 +49,6 @@ /* Serial Info */ #define CONFIG_MXC_UART #define CONFIG_MXC_UART_BASE UART1_BASE -#define CONFIG_CONS_INDEX 1 /* use UART0 for console */
/* No NOR flash present */ #define CONFIG_ENV_OFFSET (6 * 64 * 1024) diff --git a/include/configs/mx31ads.h b/include/configs/mx31ads.h index 0fe37c7..651b998 100644 --- a/include/configs/mx31ads.h +++ b/include/configs/mx31ads.h @@ -49,7 +49,6 @@
#define CONFIG_LOADADDR 0x80800000 /* loadaddr env var */
diff --git a/include/configs/mx31pdk.h b/include/configs/mx31pdk.h index fe04ca7..899f477 100644 --- a/include/configs/mx31pdk.h +++ b/include/configs/mx31pdk.h @@ -63,7 +63,6 @@
#define CONFIG_EXTRA_ENV_SETTINGS \ "bootargs_base=setenv bootargs console=ttymxc0,115200\0" \ diff --git a/include/configs/mx35pdk.h b/include/configs/mx35pdk.h index 0ec28ff..23cb64e 100644 --- a/include/configs/mx35pdk.h +++ b/include/configs/mx35pdk.h @@ -65,7 +65,6 @@
/* * Command definition diff --git a/include/configs/mx51evk.h b/include/configs/mx51evk.h index e3b33a0..8a5b1c4 100644 --- a/include/configs/mx51evk.h +++ b/include/configs/mx51evk.h @@ -79,7 +79,6 @@
#define CONFIG_ETHPRIME "FEC0"
diff --git a/include/configs/mx53ard.h b/include/configs/mx53ard.h index 1214ffd..43cb97c 100644 --- a/include/configs/mx53ard.h +++ b/include/configs/mx53ard.h @@ -52,7 +52,6 @@
diff --git a/include/configs/mx53cx9020.h b/include/configs/mx53cx9020.h index 7965125..c3f5f57 100644 --- a/include/configs/mx53cx9020.h +++ b/include/configs/mx53cx9020.h @@ -51,7 +51,6 @@
diff --git a/include/configs/mx53evk.h b/include/configs/mx53evk.h index 9fa8031..8703a61 100644 --- a/include/configs/mx53evk.h +++ b/include/configs/mx53evk.h @@ -55,7 +55,6 @@
diff --git a/include/configs/mx53loco.h b/include/configs/mx53loco.h index e1aa7b8..dfa1cdf 100644 --- a/include/configs/mx53loco.h +++ b/include/configs/mx53loco.h @@ -64,7 +64,6 @@
diff --git a/include/configs/mx53ppd.h b/include/configs/mx53ppd.h index ed8ac48..5b973bb 100644 --- a/include/configs/mx53ppd.h +++ b/include/configs/mx53ppd.h @@ -77,7 +77,6 @@
/* allow to overwrite serial and ethaddr */ #define CONFIG_ENV_OVERWRITE -#define CONFIG_CONS_INDEX 1 #define CONFIG_BAUDRATE 115200
/* Command definition */ diff --git a/include/configs/mx53smd.h b/include/configs/mx53smd.h index 8de89c7..dadc7b4 100644 --- a/include/configs/mx53smd.h +++ b/include/configs/mx53smd.h @@ -48,7 +48,6 @@
diff --git a/include/configs/mx6_common.h b/include/configs/mx6_common.h index 2dc10c6..3245f00 100644 --- a/include/configs/mx6_common.h +++ b/include/configs/mx6_common.h @@ -51,7 +51,6 @@
/* Filesystems and image support */
diff --git a/include/configs/mx7_common.h b/include/configs/mx7_common.h index defb38c..ef76c2f 100644 --- a/include/configs/mx7_common.h +++ b/include/configs/mx7_common.h @@ -32,7 +32,6 @@
/* Miscellaneous configurable options */ #define CONFIG_SYS_CBSIZE 512 diff --git a/include/configs/mx7ulp_evk.h b/include/configs/mx7ulp_evk.h index 31b6d3e..9c58c29 100644 --- a/include/configs/mx7ulp_evk.h +++ b/include/configs/mx7ulp_evk.h @@ -65,7 +65,6 @@
#define CONFIG_SYS_CACHELINE_SIZE 64 diff --git a/include/configs/mxs.h b/include/configs/mxs.h index 5d07c9f..f07f81c 100644 --- a/include/configs/mxs.h +++ b/include/configs/mxs.h @@ -105,7 +105,6 @@ */ #define CONFIG_PL011_CLOCK 24000000 #define CONFIG_PL01x_PORTS { (void *)MXS_UARTDBG_BASE } -#define CONFIG_CONS_INDEX 0 /* Default baudrate can be overridden by board! */
/* FEC Ethernet on SoC */ diff --git a/include/configs/nokia_rx51.h b/include/configs/nokia_rx51.h index c853e8d..3cf78d4 100644 --- a/include/configs/nokia_rx51.h +++ b/include/configs/nokia_rx51.h @@ -73,7 +73,6 @@ /* * select serial console configuration */ -#define CONFIG_CONS_INDEX 3 #define CONFIG_SYS_NS16550_COM3 OMAP34XX_UART3 #define CONFIG_SERIAL3 3 /* UART3 on RX-51 */
diff --git a/include/configs/nx25-ae250.h b/include/configs/nx25-ae250.h index a357d71..73c3c33 100644 --- a/include/configs/nx25-ae250.h +++ b/include/configs/nx25-ae250.h @@ -64,7 +64,6 @@ /* * Serial console configuration */ -#define CONFIG_CONS_INDEX 1 #define CONFIG_SYS_NS16550_SERIAL #ifndef CONFIG_DM_SERIAL #define CONFIG_SYS_NS16550_REG_SIZE -4 diff --git a/include/configs/odroid-c2.h b/include/configs/odroid-c2.h index 117c0e4..ff30a8a 100644 --- a/include/configs/odroid-c2.h +++ b/include/configs/odroid-c2.h @@ -11,7 +11,6 @@ #define CONFIG_MISC_INIT_R
/* Serial setup */ -#define CONFIG_CONS_INDEX 0
#define MESON_FDTFILE_SETTING "fdtfile=amlogic/meson-gxbb-odroidc2.dtb\0"
diff --git a/include/configs/omap3_cairo.h b/include/configs/omap3_cairo.h index b1f957b..1fa02a5 100644 --- a/include/configs/omap3_cairo.h +++ b/include/configs/omap3_cairo.h @@ -203,8 +203,6 @@ * are needed and peripheral clocks for UART2 must be enabled in * function per_clocks_enable(). */ -#undef CONFIG_CONS_INDEX -#define CONFIG_CONS_INDEX 2 #ifdef CONFIG_SPL_BUILD #undef CONFIG_SYS_NS16550_COM3 #define CONFIG_SYS_NS16550_COM2 OMAP34XX_UART2 diff --git a/include/configs/omap3_evm.h b/include/configs/omap3_evm.h index 1392593..173e072 100644 --- a/include/configs/omap3_evm.h +++ b/include/configs/omap3_evm.h @@ -35,8 +35,6 @@ #define CONFIG_REVISION_TAG
/* Override OMAP3 serial console configuration */ -#undef CONFIG_CONS_INDEX -#define CONFIG_CONS_INDEX 1 #define CONFIG_SYS_NS16550_COM1 OMAP34XX_UART1
/* NAND */ diff --git a/include/configs/omap3_logic.h b/include/configs/omap3_logic.h index 7ffc4f7..c9a154c 100644 --- a/include/configs/omap3_logic.h +++ b/include/configs/omap3_logic.h @@ -19,8 +19,6 @@
#ifdef CONFIG_SPL_BUILD /* select serial console configuration for SPL */ -#undef CONFIG_CONS_INDEX -#define CONFIG_CONS_INDEX 1 #define CONFIG_SYS_NS16550_COM1 OMAP34XX_UART1 #endif
diff --git a/include/configs/omap5_uevm.h b/include/configs/omap5_uevm.h index 38a0055..266dac9 100644 --- a/include/configs/omap5_uevm.h +++ b/include/configs/omap5_uevm.h @@ -29,7 +29,6 @@
#include <configs/ti_omap5_common.h>
-#define CONFIG_CONS_INDEX 3 #define CONFIG_SYS_NS16550_COM3 UART3_BASE
#define CONFIG_MISC_INIT_R diff --git a/include/configs/omapl138_lcdk.h b/include/configs/omapl138_lcdk.h index 837286b..d565864 100644 --- a/include/configs/omapl138_lcdk.h +++ b/include/configs/omapl138_lcdk.h @@ -109,7 +109,6 @@ #define CONFIG_SYS_NS16550_REG_SIZE -4 /* NS16550 register size */ #define CONFIG_SYS_NS16550_COM1 DAVINCI_UART2_BASE /* Base address of UART2 */ #define CONFIG_SYS_NS16550_CLK clk_get(DAVINCI_UART2_CLKID) -#define CONFIG_CONS_INDEX 1 /* use UART0 for console */ #define CONFIG_SYS_BAUDRATE_TABLE { 9600, 19200, 38400, 57600, 115200 }
#define CONFIG_SPI diff --git a/include/configs/p1_p2_rdb_pc.h b/include/configs/p1_p2_rdb_pc.h index d0f5529..a2921fd 100644 --- a/include/configs/p1_p2_rdb_pc.h +++ b/include/configs/p1_p2_rdb_pc.h @@ -554,7 +554,6 @@ * open - index 2 * shorted - index 1 */ -#define CONFIG_CONS_INDEX 1 #undef CONFIG_SERIAL_SOFTWARE_FIFO #define CONFIG_SYS_NS16550_SERIAL #define CONFIG_SYS_NS16550_REG_SIZE 1 diff --git a/include/configs/p1_twr.h b/include/configs/p1_twr.h index e02c31d..964d2db 100644 --- a/include/configs/p1_twr.h +++ b/include/configs/p1_twr.h @@ -191,7 +191,6 @@ extern unsigned long get_board_sys_clk(unsigned long dummy); * open - index 2 * shorted - index 1 */ -#define CONFIG_CONS_INDEX 1 #undef CONFIG_SERIAL_SOFTWARE_FIFO #define CONFIG_SYS_NS16550_SERIAL #define CONFIG_SYS_NS16550_REG_SIZE 1 diff --git a/include/configs/p212.h b/include/configs/p212.h index 793b556..7efe075 100644 --- a/include/configs/p212.h +++ b/include/configs/p212.h @@ -15,7 +15,6 @@ #define CONFIG_PHY_ADDR 8
#define MESON_FDTFILE_SETTING "fdtfile=amlogic/meson-gxl-s905x-p212.dtb\0"
diff --git a/include/configs/pcm051.h b/include/configs/pcm051.h index c6ff1e1..411403e 100644 --- a/include/configs/pcm051.h +++ b/include/configs/pcm051.h @@ -98,7 +98,6 @@
#define CONFIG_SF_DEFAULT_SPEED 24000000
-#define CONFIG_CONS_INDEX 1 /* NS16550 Configuration */ #define CONFIG_SYS_NS16550_COM1 0x44e09000 /* Base EVM has UART0 */ #define CONFIG_SYS_NS16550_COM2 0x48022000 /* UART1 */ diff --git a/include/configs/pengwyn.h b/include/configs/pengwyn.h index d9a50ca..74bfde7 100644 --- a/include/configs/pengwyn.h +++ b/include/configs/pengwyn.h @@ -12,7 +12,6 @@ #define __CONFIG_PENGWYN_H
#define CONFIG_SERIAL1 -#define CONFIG_CONS_INDEX 1
diff --git a/include/configs/pepper.h b/include/configs/pepper.h index 7ef2529..6743fd1 100644 --- a/include/configs/pepper.h +++ b/include/configs/pepper.h @@ -72,7 +72,6 @@ "fi;" \
/* Serial console configuration */ -#define CONFIG_CONS_INDEX 1 /* UART0 */ #define CONFIG_SERIAL1 1 #define CONFIG_SYS_NS16550_COM1 0x44e09000
diff --git a/include/configs/qemu-mips.h b/include/configs/qemu-mips.h index 58895a8..c133a33 100644 --- a/include/configs/qemu-mips.h +++ b/include/configs/qemu-mips.h @@ -44,7 +44,6 @@ #define CONFIG_SYS_NS16550_REG_SIZE 1 #define CONFIG_SYS_NS16550_CLK 115200 #define CONFIG_SYS_NS16550_COM1 0xb40003f8 -#define CONFIG_CONS_INDEX 1
#ifdef CONFIG_SYS_BIG_ENDIAN #define CONFIG_IDE_SWAP_IO diff --git a/include/configs/qemu-mips64.h b/include/configs/qemu-mips64.h index 382c580..24ddfe0 100644 --- a/include/configs/qemu-mips64.h +++ b/include/configs/qemu-mips64.h @@ -44,7 +44,6 @@ #define CONFIG_SYS_NS16550_REG_SIZE 1 #define CONFIG_SYS_NS16550_CLK 115200 #define CONFIG_SYS_NS16550_COM1 0xffffffffb40003f8 -#define CONFIG_CONS_INDEX 1
#ifdef CONFIG_SYS_BIG_ENDIAN #define CONFIG_IDE_SWAP_IO diff --git a/include/configs/qemu-ppce500.h b/include/configs/qemu-ppce500.h index f718704..ca4b6ec 100644 --- a/include/configs/qemu-ppce500.h +++ b/include/configs/qemu-ppce500.h @@ -83,7 +83,6 @@ extern unsigned long long get_phys_ccsrbar_addr_early(void); #define CONFIG_SYS_MONITOR_LEN (512 * 1024) #define CONFIG_SYS_MALLOC_LEN (4 * 1024 * 1024)
-#define CONFIG_CONS_INDEX 1 #define CONFIG_SYS_NS16550_SERIAL #define CONFIG_SYS_NS16550_REG_SIZE 1 #define CONFIG_SYS_NS16550_CLK (get_bus_freq(0)) diff --git a/include/configs/sbc8349.h b/include/configs/sbc8349.h index 5b5689a..c0b2aa7 100644 --- a/include/configs/sbc8349.h +++ b/include/configs/sbc8349.h @@ -259,7 +259,6 @@ /* * Serial Port */ -#define CONFIG_CONS_INDEX 1 #define CONFIG_SYS_NS16550_SERIAL #define CONFIG_SYS_NS16550_REG_SIZE 1 #define CONFIG_SYS_NS16550_CLK get_bus_freq(0) diff --git a/include/configs/sbc8548.h b/include/configs/sbc8548.h index e52b3a9..5ef452a 100644 --- a/include/configs/sbc8548.h +++ b/include/configs/sbc8548.h @@ -386,7 +386,6 @@ #define CONFIG_SYS_MALLOC_LEN (1024 * 1024) /* Reserved for malloc */
/* Serial Port */ -#define CONFIG_CONS_INDEX 1 #define CONFIG_SYS_NS16550_SERIAL #define CONFIG_SYS_NS16550_REG_SIZE 1 #define CONFIG_SYS_NS16550_CLK (400000000 / CONFIG_SYS_CLK_DIV) diff --git a/include/configs/sbc8641d.h b/include/configs/sbc8641d.h index 1d31d3a..44b6da3 100644 --- a/include/configs/sbc8641d.h +++ b/include/configs/sbc8641d.h @@ -232,7 +232,6 @@ #define CONFIG_SYS_MALLOC_LEN (1024 * 1024) /* Reserved for malloc */
/* Serial Port */ -#define CONFIG_CONS_INDEX 1 #define CONFIG_SYS_NS16550_SERIAL #define CONFIG_SYS_NS16550_REG_SIZE 1 #define CONFIG_SYS_NS16550_CLK get_bus_freq(0) diff --git a/include/configs/siemens-am33x-common.h b/include/configs/siemens-am33x-common.h index 0e77ccb..b23e20a 100644 --- a/include/configs/siemens-am33x-common.h +++ b/include/configs/siemens-am33x-common.h @@ -87,7 +87,6 @@ #define CONFIG_SYS_NS16550_COM4 0x481a6000
#define CONFIG_SERIAL1 1 -#define CONFIG_CONS_INDEX 1
/* I2C Configuration */ #define CONFIG_I2C diff --git a/include/configs/sniper.h b/include/configs/sniper.h index 2322326..29b5e6e 100644 --- a/include/configs/sniper.h +++ b/include/configs/sniper.h @@ -95,7 +95,6 @@
#define CONFIG_SYS_NS16550_CLK V_NS16550_CLK #define CONFIG_SYS_NS16550_COM3 OMAP34XX_UART3 -#define CONFIG_CONS_INDEX 3
#define CONFIG_SYS_BAUDRATE_TABLE { 4800, 9600, 19200, 38400, 57600, \ 115200 } diff --git a/include/configs/socfpga_common.h b/include/configs/socfpga_common.h index 6644ef6..7833f17 100644 --- a/include/configs/socfpga_common.h +++ b/include/configs/socfpga_common.h @@ -192,7 +192,6 @@ unsigned int cm_get_qspi_controller_clk_hz(void); #define CONFIG_SYS_NS16550_COM1 SOCFPGA_UART1_ADDRESS #define CONFIG_SYS_NS16550_CLK 50000000 #endif -#define CONFIG_CONS_INDEX 1
/* * USB diff --git a/include/configs/socrates.h b/include/configs/socrates.h index 3491944..29e6c68 100644 --- a/include/configs/socrates.h +++ b/include/configs/socrates.h @@ -174,7 +174,6 @@
/* Serial Port */
-#define CONFIG_CONS_INDEX 1 #define CONFIG_SYS_NS16550_SERIAL #define CONFIG_SYS_NS16550_REG_SIZE 1 #define CONFIG_SYS_NS16550_CLK get_bus_freq(0) diff --git a/include/configs/spear-common.h b/include/configs/spear-common.h index 45e226d..ae6a216 100644 --- a/include/configs/spear-common.h +++ b/include/configs/spear-common.h @@ -76,7 +76,6 @@ * CONFIG_PL01x_PORTS is defined in specific files */ #define CONFIG_PL011_CLOCK (48 * 1000 * 1000) -#define CONFIG_CONS_INDEX 0 #define CONFIG_SYS_BAUDRATE_TABLE { 9600, 19200, 38400, \ 57600, 115200 }
diff --git a/include/configs/strider.h b/include/configs/strider.h index 14b03c8..5d7b213 100644 --- a/include/configs/strider.h +++ b/include/configs/strider.h @@ -278,7 +278,6 @@ /* * Serial Port */ -#define CONFIG_CONS_INDEX 2 #define CONFIG_SYS_NS16550_SERIAL #define CONFIG_SYS_NS16550_REG_SIZE 1 #define CONFIG_SYS_NS16550_CLK get_bus_freq(0) diff --git a/include/configs/t4qds.h b/include/configs/t4qds.h index 0e735be..faea339 100644 --- a/include/configs/t4qds.h +++ b/include/configs/t4qds.h @@ -121,7 +121,6 @@ * open - index 2 * shorted - index 1 */ -#define CONFIG_CONS_INDEX 1 #define CONFIG_SYS_NS16550_SERIAL #define CONFIG_SYS_NS16550_REG_SIZE 1 #define CONFIG_SYS_NS16550_CLK (get_bus_freq(0)/2) diff --git a/include/configs/tam3517-common.h b/include/configs/tam3517-common.h index 02bfca1..72da301 100644 --- a/include/configs/tam3517-common.h +++ b/include/configs/tam3517-common.h @@ -53,7 +53,6 @@ /* * select serial console configuration */ -#define CONFIG_CONS_INDEX 1 #define CONFIG_SYS_NS16550_COM1 OMAP34XX_UART1 #define CONFIG_SERIAL1 /* UART1 */
diff --git a/include/configs/tao3530.h b/include/configs/tao3530.h index 5a7f207..8038c9f 100644 --- a/include/configs/tao3530.h +++ b/include/configs/tao3530.h @@ -53,7 +53,6 @@ /* * select serial console configuration */ -#define CONFIG_CONS_INDEX 3 #define CONFIG_SYS_NS16550_COM3 OMAP34XX_UART3
/* allow to overwrite serial and ethaddr */ diff --git a/include/configs/tbs2910.h b/include/configs/tbs2910.h index abd0e18..18208b1 100644 --- a/include/configs/tbs2910.h +++ b/include/configs/tbs2910.h @@ -42,8 +42,6 @@ #define CONFIG_MXC_UART #define CONFIG_MXC_UART_BASE UART1_BASE /* select UART1/UART2 */
-#define CONFIG_CONS_INDEX 1 - /* Filesystems / image support */
/* MMC */ diff --git a/include/configs/tegra-common.h b/include/configs/tegra-common.h index 3ead2e4..cd3db1a 100644 --- a/include/configs/tegra-common.h +++ b/include/configs/tegra-common.h @@ -43,7 +43,6 @@ /* * select serial console configuration */ -#define CONFIG_CONS_INDEX 1
/* allow to overwrite serial and ethaddr */ #define CONFIG_ENV_OVERWRITE diff --git a/include/configs/thunderx_88xx.h b/include/configs/thunderx_88xx.h index 51e1e4e..67b00eb 100644 --- a/include/configs/thunderx_88xx.h +++ b/include/configs/thunderx_88xx.h @@ -35,7 +35,6 @@ /* PL011 Serial Configuration */
#define CONFIG_PL011_CLOCK 24000000 -#define CONFIG_CONS_INDEX 1
/* Generic Interrupt Controller Definitions */ #define GICD_BASE (0x801000000000) diff --git a/include/configs/ti814x_evm.h b/include/configs/ti814x_evm.h index 61d0b80..2f9056c 100644 --- a/include/configs/ti814x_evm.h +++ b/include/configs/ti814x_evm.h @@ -122,7 +122,6 @@ #define CONFIG_ARCH_CPU_INIT
/* Defines for SPL */ #define CONFIG_SPL_TEXT_BASE 0x40300000 diff --git a/include/configs/ti816x_evm.h b/include/configs/ti816x_evm.h index 35c7a91..e424983 100644 --- a/include/configs/ti816x_evm.h +++ b/include/configs/ti816x_evm.h @@ -56,7 +56,6 @@ #define CONFIG_SERIAL1 #define CONFIG_SERIAL2 #define CONFIG_SERIAL3 -#define CONFIG_CONS_INDEX 1
/* * GPMC NAND block. We support 1 device and the physical address to diff --git a/include/configs/ti_armv7_keystone2.h b/include/configs/ti_armv7_keystone2.h index 2fe8d9d..2592014 100644 --- a/include/configs/ti_armv7_keystone2.h +++ b/include/configs/ti_armv7_keystone2.h @@ -66,7 +66,6 @@ #endif #define CONFIG_SYS_NS16550_COM1 KS2_UART0_BASE #define CONFIG_SYS_NS16550_COM2 KS2_UART1_BASE -#define CONFIG_CONS_INDEX 1
#ifndef CONFIG_SOC_K2G #define CONFIG_SYS_NS16550_CLK ks_clk_get_rate(KS2_CLK1_6) diff --git a/include/configs/ti_omap3_common.h b/include/configs/ti_omap3_common.h index cd6a9c2..3439a27 100644 --- a/include/configs/ti_omap3_common.h +++ b/include/configs/ti_omap3_common.h @@ -38,7 +38,6 @@ 115200}
/* Select serial console configuration */ -#define CONFIG_CONS_INDEX 3 #ifdef CONFIG_SPL_BUILD #define CONFIG_SYS_NS16550_COM3 OMAP34XX_UART3 #define CONFIG_SERIAL3 3 diff --git a/include/configs/ti_omap4_common.h b/include/configs/ti_omap4_common.h index 844a9e5..3a87192 100644 --- a/include/configs/ti_omap4_common.h +++ b/include/configs/ti_omap4_common.h @@ -53,7 +53,6 @@ #define CONFIG_SYS_NS16550_REG_SIZE (-4) #define CONFIG_SYS_NS16550_COM3 UART3_BASE #endif -#define CONFIG_CONS_INDEX 3
/* TWL6030 */ #ifndef CONFIG_SPL_BUILD diff --git a/include/configs/tricorder.h b/include/configs/tricorder.h index 80dfe12..87eb9ac 100644 --- a/include/configs/tricorder.h +++ b/include/configs/tricorder.h @@ -49,7 +49,6 @@ #define CONFIG_SYS_NS16550_CLK 48000000 /* 48MHz (APLL96/2) */
/* select serial console configuration */ -#define CONFIG_CONS_INDEX 3 #define CONFIG_SYS_NS16550_COM3 OMAP34XX_UART3 #define CONFIG_SERIAL3 3 #define CONFIG_SYS_BAUDRATE_TABLE {4800, 9600, 19200, 38400, 57600,\ diff --git a/include/configs/ts4800.h b/include/configs/ts4800.h index d71baab..2fe57e4 100644 --- a/include/configs/ts4800.h +++ b/include/configs/ts4800.h @@ -67,7 +67,6 @@
/* allow to overwrite serial and ethaddr */ #define CONFIG_ENV_OVERWRITE /* disable vendor parameters protection (serial#, ethaddr) */ -#define CONFIG_CONS_INDEX 1 /* use UART0 : used by serial driver */
/*********************************************************** * Command definition diff --git a/include/configs/uniphier.h b/include/configs/uniphier.h index 8aeda4e..e2a8b63 100644 --- a/include/configs/uniphier.h +++ b/include/configs/uniphier.h @@ -52,8 +52,6 @@ /* Boot Argument Buffer Size */ #define CONFIG_SYS_BARGSIZE (CONFIG_SYS_CBSIZE)
-#define CONFIG_CONS_INDEX 1 - #define CONFIG_ENV_OFFSET 0x100000 #define CONFIG_ENV_SIZE 0x2000 /* #define CONFIG_ENV_OFFSET_REDUND (CONFIG_ENV_OFFSET + CONFIG_ENV_SIZE) */ diff --git a/include/configs/usbarmory.h b/include/configs/usbarmory.h index 836dbb7..492aeb4 100644 --- a/include/configs/usbarmory.h +++ b/include/configs/usbarmory.h @@ -26,7 +26,6 @@ /* UART */ #define CONFIG_MXC_UART #define CONFIG_MXC_UART_BASE UART1_BASE -#define CONFIG_CONS_INDEX 1
/* SD/MMC */ #define CONFIG_FSL_ESDHC diff --git a/include/configs/vct.h b/include/configs/vct.h index 2168279..4780c2c 100644 --- a/include/configs/vct.h +++ b/include/configs/vct.h @@ -52,7 +52,6 @@ #define CONFIG_SYS_NS16550_SERIAL #define CONFIG_SYS_NS16550_REG_SIZE -4 #define CONFIG_SYS_NS16550_COM1 UART_1_BASE -#define CONFIG_CONS_INDEX 1 #define CONFIG_SYS_NS16550_CLK 921600
/* diff --git a/include/configs/ve8313.h b/include/configs/ve8313.h index 580a08b..5159568 100644 --- a/include/configs/ve8313.h +++ b/include/configs/ve8313.h @@ -234,7 +234,6 @@ /* * Serial Port */ -#define CONFIG_CONS_INDEX 1 #define CONFIG_SYS_NS16550_SERIAL #define CONFIG_SYS_NS16550_REG_SIZE 1 #define CONFIG_SYS_NS16550_CLK get_bus_freq(0) diff --git a/include/configs/vexpress_aemv8a.h b/include/configs/vexpress_aemv8a.h index d3422a5..208a315 100644 --- a/include/configs/vexpress_aemv8a.h +++ b/include/configs/vexpress_aemv8a.h @@ -105,7 +105,6 @@ #endif
/* PL011 Serial Configuration */ -#define CONFIG_CONS_INDEX 0 #ifdef CONFIG_TARGET_VEXPRESS64_JUNO #define CONFIG_PL011_CLOCK 7273800 #else diff --git a/include/configs/vexpress_common.h b/include/configs/vexpress_common.h index 6a10edb..3e2d410 100644 --- a/include/configs/vexpress_common.h +++ b/include/configs/vexpress_common.h @@ -134,7 +134,6 @@ #define CONFIG_PL011_CLOCK 24000000 #define CONFIG_PL01x_PORTS {(void *)CONFIG_SYS_SERIAL0, \ (void *)CONFIG_SYS_SERIAL1} -#define CONFIG_CONS_INDEX 0
#define CONFIG_SYS_BAUDRATE_TABLE { 9600, 19200, 38400, 57600, 115200 } #define CONFIG_SYS_SERIAL0 V2M_UART0 diff --git a/include/configs/vme8349.h b/include/configs/vme8349.h index 6bbf364..ec15a44 100644 --- a/include/configs/vme8349.h +++ b/include/configs/vme8349.h @@ -194,7 +194,6 @@ /* * Serial Port */ -#define CONFIG_CONS_INDEX 1 #define CONFIG_SYS_NS16550_SERIAL #define CONFIG_SYS_NS16550_REG_SIZE 1 #define CONFIG_SYS_NS16550_CLK get_bus_freq(0) diff --git a/include/configs/woodburn_common.h b/include/configs/woodburn_common.h index af06548..fa8e9a2 100644 --- a/include/configs/woodburn_common.h +++ b/include/configs/woodburn_common.h @@ -65,7 +65,6 @@
/* * Command definition diff --git a/include/configs/x600.h b/include/configs/x600.h index bfa6f5e..627f7bb 100644 --- a/include/configs/x600.h +++ b/include/configs/x600.h @@ -38,7 +38,6 @@ #define CONFIG_PL01x_PORTS { (void *)CONFIG_SYS_SERIAL0, \ (void *)CONFIG_SYS_SERIAL1 } #define CONFIG_PL011_CLOCK (48 * 1000 * 1000) -#define CONFIG_CONS_INDEX 0 #define CONFIG_SYS_BAUDRATE_TABLE { 9600, 19200, 38400, \ 57600, 115200 } #define CONFIG_SYS_LOADS_BAUD_CHANGE diff --git a/include/configs/xilinx_zynqmp.h b/include/configs/xilinx_zynqmp.h index f5fc245..e23b0f2 100644 --- a/include/configs/xilinx_zynqmp.h +++ b/include/configs/xilinx_zynqmp.h @@ -43,7 +43,6 @@ #define CONFIG_ARM_DCC #define CONFIG_CPU_ARMV8
-#define CONFIG_CONS_INDEX 0 #define CONFIG_SYS_BAUDRATE_TABLE \ { 4800, 9600, 19200, 38400, 57600, 115200 }
diff --git a/include/configs/xpedite517x.h b/include/configs/xpedite517x.h index de10d8c..5c8342e 100644 --- a/include/configs/xpedite517x.h +++ b/include/configs/xpedite517x.h @@ -191,7 +191,6 @@ extern unsigned long get_board_sys_clk(unsigned long dummy); /* * Serial Port */ -#define CONFIG_CONS_INDEX 1 #define CONFIG_SYS_NS16550_SERIAL #define CONFIG_SYS_NS16550_REG_SIZE 1 #define CONFIG_SYS_NS16550_CLK get_bus_freq(0) diff --git a/include/configs/xpedite520x.h b/include/configs/xpedite520x.h index dfacd2a..b159d91 100644 --- a/include/configs/xpedite520x.h +++ b/include/configs/xpedite520x.h @@ -162,7 +162,6 @@ /* * Serial Port */ -#define CONFIG_CONS_INDEX 1 #define CONFIG_SYS_NS16550_SERIAL #define CONFIG_SYS_NS16550_REG_SIZE 1 #define CONFIG_SYS_NS16550_CLK get_bus_freq(0) diff --git a/include/configs/xpedite537x.h b/include/configs/xpedite537x.h index ea4773c..9f4a920 100644 --- a/include/configs/xpedite537x.h +++ b/include/configs/xpedite537x.h @@ -187,7 +187,6 @@ extern unsigned long get_board_ddr_clk(unsigned long dummy); /* * Serial Port */ -#define CONFIG_CONS_INDEX 1 #define CONFIG_SYS_NS16550_SERIAL #define CONFIG_SYS_NS16550_REG_SIZE 1 #define CONFIG_SYS_NS16550_CLK get_bus_freq(0) diff --git a/include/configs/xpedite550x.h b/include/configs/xpedite550x.h index 883843a..3627aed 100644 --- a/include/configs/xpedite550x.h +++ b/include/configs/xpedite550x.h @@ -188,7 +188,6 @@ extern unsigned long get_board_ddr_clk(unsigned long dummy); /* * Serial Port */ -#define CONFIG_CONS_INDEX 1 #define CONFIG_SYS_NS16550_SERIAL #define CONFIG_SYS_NS16550_REG_SIZE 1 #define CONFIG_SYS_NS16550_CLK get_bus_freq(0) diff --git a/include/configs/xtfpga.h b/include/configs/xtfpga.h index 691adda..8a920fa 100644 --- a/include/configs/xtfpga.h +++ b/include/configs/xtfpga.h @@ -182,7 +182,6 @@
/* Input clk to NS16550 (in Hz; the SYS_CLK_FREQ is in kHz) */ #define CONFIG_SYS_NS16550_CLK CONFIG_SYS_CLK_FREQ -#define CONFIG_CONS_INDEX 1 /* use UART0 for console */ #define CONFIG_SYS_BAUDRATE_TABLE { 9600, 19200, 38400, 57600, 115200 }
/*======================*/ diff --git a/include/configs/zipitz2.h b/include/configs/zipitz2.h index b5a326b..0860a50 100644 --- a/include/configs/zipitz2.h +++ b/include/configs/zipitz2.h @@ -43,7 +43,6 @@ * STUART - the lower serial port on Colibri board */ #define CONFIG_STUART 1 -#define CONFIG_CONS_INDEX 2
/* * Bootloader Components Configuration diff --git a/include/configs/zmx25.h b/include/configs/zmx25.h index 124431b..1dafda3 100644 --- a/include/configs/zmx25.h +++ b/include/configs/zmx25.h @@ -40,7 +40,6 @@ */ #define CONFIG_MXC_UART #define CONFIG_MXC_UART_BASE UART2_BASE -#define CONFIG_CONS_INDEX 1 /* use UART2 for console */
/* * Ethernet
Adam Ford
