[U-Boot] [PATCH 07/15] spl: atf: introduce spl_invoke_atf and make bl31_entry private
This adds a new interface spl_invoke_atf() that takes a spl_image_info argument and then derives the necessary parameters for the ATF entry. Based on the additional information recorded (into /fit-images) from the FIT loadables, we can now easily locate the next boot stage.
We now pass a pointer to a FDT as the platform-specific parameter pointer to ATF (so we don't run into the future headache of every board/platform defining their own proprietary tag-structure), as FDT access is already available in ATF.
With the necessary infrastructure in place, we can now update the support for the ARM Trusted Firmware to dispatch into the spl_invoke_atf function only if a IH_OS_ARM_TRUSTED_FIRMWARE image is loaded.
Signed-off-by: Philipp Tomsich philipp.tomsich@theobroma-systems.com ---
common/spl/spl.c | 11 +++---- common/spl/spl_atf.c | 84 +++++++++++++++++++++++++++++++++++++++++++++++----- 2 files changed, 82 insertions(+), 13 deletions(-)
diff --git a/common/spl/spl.c b/common/spl/spl.c index 8b219ba..32198ef 100644 --- a/common/spl/spl.c +++ b/common/spl/spl.c @@ -410,6 +410,12 @@ void board_init_r(gd_t *dummy1, ulong dummy2) case IH_OS_U_BOOT: debug("Jumping to U-Boot\n"); break; +#if CONFIG_IS_ENABLED(ATF) + case IH_OS_ARM_TRUSTED_FIRMWARE: + debug("Jumping to U-Boot via ARM Trusted Firmware\n"); + spl_invoke_atf(&spl_image); + break; +#endif #ifdef CONFIG_SPL_OS_BOOT case IH_OS_LINUX: debug("Jumping to Linux\n"); @@ -425,11 +431,6 @@ void board_init_r(gd_t *dummy1, ulong dummy2) gd->malloc_ptr / 1024); #endif
- if (CONFIG_IS_ENABLED(ATF_SUPPORT)) { - debug("loaded - jumping to U-Boot via ATF BL31.\n"); - bl31_entry(); - } - debug("loaded - jumping to U-Boot...\n"); #ifdef CONFIG_BOOTSTAGE_STASH int ret; diff --git a/common/spl/spl_atf.c b/common/spl/spl_atf.c index 6e8f928..63557c0 100644 --- a/common/spl/spl_atf.c +++ b/common/spl/spl_atf.c @@ -5,6 +5,7 @@ * reserved. * Copyright (C) 2016 Rockchip Electronic Co.,Ltd * Written by Kever Yang kever.yang@rock-chips.com + * Copyright (C) 2017 Theobroma Systems Design und Consulting GmbH * * SPDX-License-Identifier: BSD-3-Clause */ @@ -30,7 +31,7 @@ static struct bl31_params *bl2_to_bl31_params; * * @return bl31 params structure pointer */ -struct bl31_params *bl2_plat_get_bl31_params(void) +static struct bl31_params *bl2_plat_get_bl31_params(uintptr_t bl33_entry) { struct entry_point_info *bl33_ep_info;
@@ -66,7 +67,7 @@ struct bl31_params *bl2_plat_get_bl31_params(void)
/* BL33 expects to receive the primary CPU MPID (through x0) */ bl33_ep_info->args.arg0 = 0xffff & read_mpidr(); - bl33_ep_info->pc = CONFIG_SYS_TEXT_BASE; + bl33_ep_info->pc = bl33_entry; bl33_ep_info->spsr = SPSR_64(MODE_EL2, MODE_SP_ELX, DISABLE_ALL_EXECPTIONS);
@@ -77,21 +78,88 @@ struct bl31_params *bl2_plat_get_bl31_params(void) return bl2_to_bl31_params; }
-void raw_write_daif(unsigned int daif) +static inline void raw_write_daif(unsigned int daif) { __asm__ __volatile__("msr DAIF, %0\n\t" : : "r" (daif) : "memory"); }
-void bl31_entry(void) +typedef void (*atf_entry_t)(struct bl31_params *params, void *plat_params); + +static void bl31_entry(uintptr_t bl31_entry, uintptr_t bl33_entry, + uintptr_t fdt_addr) { struct bl31_params *bl31_params; - void (*entry)(struct bl31_params *params, void *plat_params) = NULL; + atf_entry_t atf_entry = (atf_entry_t)bl31_entry;
- bl31_params = bl2_plat_get_bl31_params(); - entry = (void *)CONFIG_SPL_ATF_TEXT_BASE; + bl31_params = bl2_plat_get_bl31_params(bl33_entry);
raw_write_daif(SPSR_EXCEPTION_MASK); dcache_disable();
- entry(bl31_params, NULL); + atf_entry((void *)bl31_params, (void *)fdt_addr); +} + +static int spl_fit_images_find_uboot(void *blob) +{ + int parent, node, ndepth; + const void *data; + + if (!blob) + return -FDT_ERR_BADMAGIC; + + parent = fdt_path_offset(blob, "/fit-images"); + if (parent < 0) + return -FDT_ERR_NOTFOUND; + + for (node = fdt_next_node(blob, parent, &ndepth); + (node >= 0) && (ndepth > 0); + node = fdt_next_node(blob, node, &ndepth)) { + if (ndepth != 1) + continue; + + data = fdt_getprop(blob, node, FIT_OS_PROP, NULL); + if (!data) + continue; + + if (genimg_get_os_id(data) == IH_OS_U_BOOT) + return node; + }; + + return -FDT_ERR_NOTFOUND; +} + +uintptr_t spl_fit_images_get_entry(void *blob, int node) +{ + ulong val; + + val = fdt_getprop_u32(blob, node, "entry-point"); + if (val == FDT_ERROR) + val = fdt_getprop_u32(blob, node, "load-addr"); + + debug("%s: entry point 0x%lx\n", __func__, val); + return val; +} + +void spl_invoke_atf(struct spl_image_info *spl_image) +{ + uintptr_t bl33_entry = CONFIG_SYS_TEXT_BASE; + void *blob = spl_image->fdt_addr; + int node; + + /* + * Find the U-Boot binary (in /fit-images) load addreess or + * entry point (if different) and pass it as the BL3-3 entry + * point. + * This will need to be extended to support Falcon mode. + */ + + node = spl_fit_images_find_uboot(blob); + if (node >= 0) + bl33_entry = spl_fit_images_get_entry(blob, node); + + /* + * We don't provide a BL3-2 entry yet, but this will be possible + * using similar logic. + */ + bl31_entry(spl_image->entry_point, bl33_entry, (uintptr_t)blob); }
Hi Philipp,
On 13 September 2017 at 13:29, Philipp Tomsich philipp.tomsich@theobroma-systems.com wrote:
Please see question below
- reserved.
- Copyright (C) 2016 Rockchip Electronic Co.,Ltd
- Written by Kever Yang kever.yang@rock-chips.com
- Copyright (C) 2017 Theobroma Systems Design und Consulting GmbH
- SPDX-License-Identifier: BSD-3-Clause
- @return bl31 params structure pointer
uintptr_t fdt_addr)
bl31_params = bl2_plat_get_bl31_params(bl33_entry); raw_write_daif(SPSR_EXCEPTION_MASK); dcache_disable();
const void *data;
if (!blob)
if (parent < 0)
if (ndepth != 1)
continue;
if (!data)
continue;
return node;
How come this is in 'data' instead of the 'type' property?
On 17 Sep 2017, at 19:53, Simon Glass sjg@chromium.org wrote:
Hi Philipp,
On 13 September 2017 at 13:29, Philipp Tomsich <philipp.tomsich@theobroma-systems.com mailto:philipp.tomsich@theobroma-systems.com> wrote:
Reviewed-by: Simon Glass <sjg@chromium.org mailto:sjg@chromium.org>
- reserved.
- Written by Kever Yang <kever.yang@rock-chips.com mailto:kever.yang@rock-chips.com>
uintptr_t fdt_addr)
const void *data;
if (!blob)
if (parent < 0)
if (ndepth != 1)
continue;
if (!data)
continue;
return node;
In fact it’s in FIT_OS_PROP (which expands to “os”). Naming this variable ‘data' may have not been the best choice, but ‘prop’ didn’t seem much better…
Regards, Philipp.
Signed-off-by: Philipp Tomsich philipp.tomsich@theobroma-systems.com Reviewed-by: Simon Glass sjg@chromium.org
Applied to u-boot-rockchip, thanks!
Hi Philipp,
This patch use fdt_addr as plat_params, break the compatible with upstream
ATF, and get error:
"ERROR: not expected type found 6410029648624618960"
The ATF do have a requirement for plat_params structure, and fdt_addr does not match this:
/* common header for all plat parameter type */ struct bl31_plat_param {
-------uint64_t type; -------void *next;
Thanks, - Kever
Applied to u-boot-rockchip, thanks! _______________________________________________ U-Boot mailing list U-Boot@lists.denx.de https://lists.denx.de/listinfo/u-boot
Dr. Philipp Tomsich
Kever Yang
Philipp Tomsich
