[U-Boot] [PATCH 1/6] GRETH: removed unneccesary register write and one clean up.
Signed-off-by: Daniel Hellstrom daniel@gaisler.com --- drivers/net/greth.c | 4 +--- 1 files changed, 1 insertions(+), 3 deletions(-)
diff --git a/drivers/net/greth.c b/drivers/net/greth.c index 79bc4d9..4f1973c 100644 --- a/drivers/net/greth.c +++ b/drivers/net/greth.c @@ -45,7 +45,7 @@ /* ByPass Cache when reading regs */ #define GRETH_REGLOAD(addr) SPARC_NOCACHE_READ(addr) /* Write-through cache ==> no bypassing needed on writes */ -#define GRETH_REGSAVE(addr,data) (*(unsigned int *)(addr) = (data)) +#define GRETH_REGSAVE(addr,data) (*(volatile unsigned int *)(addr) = (data)) #define GRETH_REGORIN(addr,data) GRETH_REGSAVE(addr,GRETH_REGLOAD(addr)|data) #define GRETH_REGANDIN(addr,data) GRETH_REGSAVE(addr,GRETH_REGLOAD(addr)&data)
@@ -146,8 +146,6 @@ int greth_init(struct eth_device *dev, bd_t * bis) printf("greth_init\n"); #endif
- GRETH_REGSAVE(®s->control, 0); - if (!greth->rxbd_base) {
/* allocate descriptors */
Signed-off-by: Daniel Hellstrom daniel@gaisler.com --- drivers/net/greth.c | 66 +++++++++++++++++++------------------------------- 1 files changed, 25 insertions(+), 41 deletions(-)
diff --git a/drivers/net/greth.c b/drivers/net/greth.c index 4f1973c..788aac8 100644 --- a/drivers/net/greth.c +++ b/drivers/net/greth.c @@ -24,6 +24,8 @@ * MA 02111-1307 USA */
+/* #define DEBUG */ + #include <common.h> #include <command.h> #include <net.h> @@ -33,8 +35,6 @@ #include <ambapp.h> #include <asm/leon.h>
-/* #define DEBUG */ - #include "greth.h"
/* Default to 3s timeout on autonegotiation */ @@ -142,9 +142,8 @@ int greth_init(struct eth_device *dev, bd_t * bis)
greth_priv *greth = dev->priv; greth_regs *regs = greth->regs; -#ifdef DEBUG - printf("greth_init\n"); -#endif + + debug("greth_init\n");
@@ -199,9 +198,7 @@ int greth_init(struct eth_device *dev, bd_t * bis)
/* Enable Transmitter, GRETH will now scan descriptors for packets * to transmitt */ -#ifdef DEBUG - printf("greth_init: enabling receiver\n"); -#endif + debug("greth_init: enabling receiver\n"); GRETH_REGORIN(®s->control, GRETH_RXEN);
return 0; @@ -306,10 +303,8 @@ int greth_init_phy(greth_priv * dev, bd_t * bis)
} auto_neg_done: -#ifdef DEBUG - printf("%s GRETH Ethermac at [0x%x] irq %d. Running \ + debug("%s GRETH Ethermac at [0x%x] irq %d. Running \ %d Mbps %s duplex\n", dev->gbit_mac ? "10/100/1000" : "10/100", (unsigned int)(regs), (unsigned int)(dev->irq), dev->gb ? 1000 : (dev->sp ? 100 : 10), dev->fd ? "full" : "half"); -#endif /* Read out PHY info if extended registers are available */ if (tmp & 1) { tmp1 = read_mii(2, regs); @@ -318,10 +313,8 @@ int greth_init_phy(greth_priv * dev, bd_t * bis) tmp = tmp2 & 0xF;
tmp2 = (tmp2 >> 4) & 0x3F; -#ifdef DEBUG - printf("PHY: Vendor %x Device %x Revision %d\n", tmp1, + debug("PHY: Vendor %x Device %x Revision %d\n", tmp1, tmp2, tmp); -#endif } else { printf("PHY info not available\n"); } @@ -338,9 +331,9 @@ void greth_halt(struct eth_device *dev) greth_priv *greth; greth_regs *regs; int i; -#ifdef DEBUG - printf("greth_halt\n"); -#endif + + debug("greth_halt\n"); + if (!dev || !dev->priv) return;
@@ -376,9 +369,9 @@ int greth_send(struct eth_device *dev, volatile void *eth_data, int data_length) greth_bd *txbd; void *txbuf; unsigned int status; -#ifdef DEBUG - printf("greth_send\n"); -#endif + + debug("greth_send\n"); + /* send data, wait for data to be sent, then return */ if (((unsigned int)eth_data & (GRETH_BUF_ALIGN - 1)) && !greth->gbit_mac) { @@ -387,9 +380,6 @@ int greth_send(struct eth_device *dev, volatile void *eth_data, int data_length) */ if (!greth->txbuf) { greth->txbuf = malloc(GRETH_RXBUF_SIZE); -#ifdef DEBUG - printf("GRETH: allocated aligned tx-buf\n"); -#endif }
txbuf = greth->txbuf; @@ -455,9 +445,7 @@ int greth_recv(struct eth_device *dev) unsigned char *d; int enable = 0; int i; -#ifdef DEBUG -/* printf("greth_recv\n"); */ -#endif + /* Receive One packet only, but clear as many error packets as there are * available. */ @@ -474,10 +462,9 @@ int greth_recv(struct eth_device *dev) if (status & GRETH_BD_EN) { goto done; } -#ifdef DEBUG - printf("greth_recv: packet 0x%lx, 0x%lx, len: %d\n", + + debug("greth_recv: packet 0x%lx, 0x%lx, len: %d\n", (unsigned int)rxbd, status, status & GRETH_BD_LEN); -#endif
/* Check status for errors. */ @@ -512,12 +499,12 @@ int greth_recv(struct eth_device *dev) /* Process the incoming packet. */ len = status & GRETH_BD_LEN; d = (char *)rxbd->addr; -#ifdef DEBUG - printf + + debug ("greth_recv: new packet, length: %d. data: %x %x %x %x %x %x %x %x\n", len, d[0], d[1], d[2], d[3], d[4], d[5], d[6], d[7]); -#endif + /* flush all data cache to make sure we're not reading old packet data */ sparc_dcache_flush_all();
@@ -565,10 +552,9 @@ void greth_set_hwaddr(greth_priv * greth, unsigned char *mac) greth->regs->esa_msb = (mac[0] << 8) | mac[1]; greth->regs->esa_lsb = (mac[2] << 24) | (mac[3] << 16) | (mac[4] << 8) | mac[5]; -#ifdef DEBUG - printf("GRETH: New MAC address: %02x:%02x:%02x:%02x:%02x:%02x\n", + + debug("GRETH: New MAC address: %02x:%02x:%02x:%02x:%02x:%02x\n", mac[0], mac[1], mac[2], mac[3], mac[4], mac[5]); -#endif }
int greth_initialize(bd_t * bis) @@ -579,9 +565,9 @@ int greth_initialize(bd_t * bis) int i; char *addr_str, *end; unsigned char addr[6]; -#ifdef DEBUG - printf("Scanning for GRETH\n"); -#endif + + debug("Scanning for GRETH\n"); + /* Find Device & IRQ via AMBA Plug&Play information */ if (ambapp_apb_first(VENDOR_GAISLER, GAISLER_ETHMAC, &apbdev) != 1) { return -1; /* GRETH not found */ @@ -594,9 +580,7 @@ int greth_initialize(bd_t * bis)
greth->regs = (greth_regs *) apbdev.address; greth->irq = apbdev.irq; -#ifdef DEBUG - printf("Found GRETH at 0x%lx, irq %d\n", greth->regs, greth->irq); -#endif + debug("Found GRETH at 0x%lx, irq %d\n", greth->regs, greth->irq); dev->priv = (void *)greth; dev->iobase = (unsigned int)greth->regs; dev->init = greth_init;
Signed-off-by: Daniel Hellstrom daniel@gaisler.com --- drivers/net/greth.c | 78 ++++++++++++++++++++++++++++++++++++--------------- 1 files changed, 55 insertions(+), 23 deletions(-)
diff --git a/drivers/net/greth.c b/drivers/net/greth.c index 788aac8..cb68d45 100644 --- a/drivers/net/greth.c +++ b/drivers/net/greth.c @@ -42,6 +42,13 @@ #define GRETH_PHY_TIMEOUT_MS 3000 #endif
+/* Default to PHY adrress 0 not not specified */ +#ifdef CONFIG_SYS_GRLIB_GRETH_PHYADDR +#define GRETH_PHY_ADR_DEFAULT CONFIG_SYS_GRLIB_GRETH_PHYADDR +#else +#define GRETH_PHY_ADR_DEFAULT 0 +#endif + /* ByPass Cache when reading regs */ #define GRETH_REGLOAD(addr) SPARC_NOCACHE_READ(addr) /* Write-through cache ==> no bypassing needed on writes */ @@ -102,12 +109,12 @@ typedef struct { } greth_priv;
/* Read MII register 'addr' from core 'regs' */ -static int read_mii(int addr, volatile greth_regs * regs) +static int read_mii(int phyaddr, int regaddr, volatile greth_regs * regs) { while (GRETH_REGLOAD(®s->mdio) & GRETH_MII_BUSY) { }
- GRETH_REGSAVE(®s->mdio, (0 << 11) | ((addr & 0x1F) << 6) | 2); + GRETH_REGSAVE(®s->mdio, ((phyaddr & 0x1F) << 11) | ((regaddr & 0x1F) << 6) | 2);
while (GRETH_REGLOAD(®s->mdio) & GRETH_MII_BUSY) { } @@ -119,14 +126,14 @@ static int read_mii(int addr, volatile greth_regs * regs) } }
-static void write_mii(int addr, int data, volatile greth_regs * regs) +static void write_mii(int phyaddr, int regaddr, int data, volatile greth_regs * regs) { while (GRETH_REGLOAD(®s->mdio) & GRETH_MII_BUSY) { }
GRETH_REGSAVE(®s->mdio, - ((data & 0xFFFF) << 16) | (0 << 11) | ((addr & 0x1F) << 6) - | 1); + ((data & 0xFFFF) << 16) | ((phyaddr & 0x1F) << 11) | + ((regaddr & 0x1F) << 6) | 1);
while (GRETH_REGLOAD(®s->mdio) & GRETH_MII_BUSY) { } @@ -214,6 +221,26 @@ int greth_init_phy(greth_priv * dev, bd_t * bis) greth_regs *regs = dev->regs; int tmp, tmp1, tmp2, i; unsigned int start, timeout; + int phyaddr = GRETH_PHY_ADR_DEFAULT; + +#ifndef CONFIG_SYS_GRLIB_GRETH_PHYADDR + /* If BSP doesn't provide a hardcoded PHY address the driver will + * try to autodetect PHY address by stopping the search on the first + * PHY address which has REG0 implemented. + */ + for (i=0; i<32; i++) { + tmp = read_mii(i, 0, regs); + if ( (tmp != 0) && (tmp != 0xffff) ) { + phyaddr = i; + break; + } + } +#endif + + /* Save PHY Address */ + dev->phyaddr = phyaddr; + + debug("GRETH PHY ADDRESS: %d\n", phyaddr);
/* X msecs to ticks */ timeout = usec2ticks(GRETH_PHY_TIMEOUT_MS * 1000); @@ -225,17 +252,21 @@ int greth_init_phy(greth_priv * dev, bd_t * bis)
/* get phy control register default values */
- while ((tmp = read_mii(0, regs)) & 0x8000) { - if (get_timer(start) > timeout) + while ((tmp = read_mii(phyaddr, 0, regs)) & 0x8000) { + if (get_timer(start) > timeout) { + debug("greth_init_phy: PHY read 1 failed\n"); return 1; /* Fail */ + } }
/* reset PHY and wait for completion */ - write_mii(0, 0x8000 | tmp, regs); + write_mii(phyaddr, 0, 0x8000 | tmp, regs);
- while (((tmp = read_mii(0, regs))) & 0x8000) { - if (get_timer(start) > timeout) + while (((tmp = read_mii(phyaddr, 0, regs))) & 0x8000) { + if (get_timer(start) > timeout) { + debug("greth_init_phy: PHY read 2 failed\n"); return 1; /* Fail */ + } }
/* Check if PHY is autoneg capable and then determine operating @@ -246,16 +277,16 @@ int greth_init_phy(greth_priv * dev, bd_t * bis) dev->sp = 0; dev->auto_neg = 0; if (!((tmp >> 12) & 1)) { - write_mii(0, 0, regs); + write_mii(phyaddr, 0, 0, regs); } else { /* wait for auto negotiation to complete and then check operating mode */ dev->auto_neg = 1; i = 0; - while (!(((tmp = read_mii(1, regs)) >> 5) & 1)) { + while (!(((tmp = read_mii(phyaddr, 1, regs)) >> 5) & 1)) { if (get_timer(start) > timeout) { printf("Auto negotiation timed out. " "Selecting default config\n"); - tmp = read_mii(0, regs); + tmp = read_mii(phyaddr, 0, regs); dev->gb = ((tmp >> 6) & 1) && !((tmp >> 13) & 1); dev->sp = !((tmp >> 6) & 1) @@ -265,8 +296,8 @@ int greth_init_phy(greth_priv * dev, bd_t * bis) } } if ((tmp >> 8) & 1) { - tmp1 = read_mii(9, regs); - tmp2 = read_mii(10, regs); + tmp1 = read_mii(phyaddr, 9, regs); + tmp2 = read_mii(phyaddr, 10, regs); if ((tmp1 & GRETH_MII_EXTADV_1000FD) && (tmp2 & GRETH_MII_EXTPRT_1000FD)) { dev->gb = 1; @@ -279,8 +310,8 @@ int greth_init_phy(greth_priv * dev, bd_t * bis) } } if ((dev->gb == 0) || ((dev->gb == 1) && (dev->gbit_mac == 0))) { - tmp1 = read_mii(4, regs); - tmp2 = read_mii(5, regs); + tmp1 = read_mii(phyaddr, 4, regs); + tmp2 = read_mii(phyaddr, 5, regs); if ((tmp1 & GRETH_MII_100TXFD) && (tmp2 & GRETH_MII_100TXFD)) { dev->sp = 1; @@ -297,7 +328,7 @@ int greth_init_phy(greth_priv * dev, bd_t * bis) if ((dev->gb == 1) && (dev->gbit_mac == 0)) { dev->gb = 0; dev->fd = 0; - write_mii(0, dev->sp << 13, regs); + write_mii(phyaddr, 0, dev->sp << 13, regs); } }
@@ -307,8 +338,8 @@ int greth_init_phy(greth_priv * dev, bd_t * bis) %d Mbps %s duplex\n", dev->gbit_mac ? "10/100/1000" : "10/100", (unsigned int)(regs), (unsigned int)(dev->irq), dev->gb ? 1000 : (dev->sp ? 100 : 10), dev->fd ? "full" : "half"); /* Read out PHY info if extended registers are available */ if (tmp & 1) { - tmp1 = read_mii(2, regs); - tmp2 = read_mii(3, regs); + tmp1 = read_mii(phyaddr, 2, regs); + tmp2 = read_mii(phyaddr, 3, regs); tmp1 = (tmp1 << 6) | ((tmp2 >> 10) & 0x3F); tmp = tmp2 & 0xF;
@@ -492,8 +523,7 @@ int greth_recv(struct eth_device *dev) for (i = 0; i < GRETH_RXBD_CNT; i++) { printf("[%d]: Stat=0x%lx, Addr=0x%lx\n", i, GRETH_REGLOAD(&greth->rxbd_base[i].stat), - GRETH_REGLOAD(&greth->rxbd_base[i]. - addr)); + GRETH_REGLOAD(&greth->rxbd_base[i].addr)); } } else { /* Process the incoming packet. */ @@ -530,7 +560,7 @@ int greth_recv(struct eth_device *dev) (unsigned int)greth->rxbd_max) ? greth-> rxbd_base : (greth->rxbd_curr + 1);
if (enable) { GRETH_REGORIN(®s->control, GRETH_RXEN); @@ -612,6 +642,7 @@ int greth_initialize(bd_t * bis) /* initiate PHY, select speed/duplex depending on connected PHY */ if (greth_init_phy(greth, bis)) { /* Failed to init PHY (timedout) */ + debug("GRETH[0x%08x]: Failed to init PHY\n", greth->regs); return -1; }
@@ -640,5 +671,6 @@ int greth_initialize(bd_t * bis) /* set and remember MAC address */ greth_set_hwaddr(greth, addr);
+ debug("GRETH[0x%08x]: Initialized successfully\n", greth->regs); return 0; }
Signed-off-by: Daniel Hellstrom daniel@gaisler.com --- drivers/net/greth.c | 10 ++++++++++ 1 files changed, 10 insertions(+), 0 deletions(-)
diff --git a/drivers/net/greth.c b/drivers/net/greth.c index cb68d45..f081855 100644 --- a/drivers/net/greth.c +++ b/drivers/net/greth.c @@ -152,6 +152,16 @@ int greth_init(struct eth_device *dev, bd_t * bis)
+ /* Reset core */ + GRETH_REGSAVE(®s->control, (GRETH_RESET | (greth->gb << 8) | + (greth->sp << 7) | (greth->fd << 4))); + + /* Wait for Reset to complete */ + while ( GRETH_REGLOAD(®s->control) & GRETH_RESET) ; + + GRETH_REGSAVE(®s->control, + ((greth->gb << 8) | (greth->sp << 7) | (greth->fd << 4))); + if (!greth->rxbd_base) {
Signed-off-by: Daniel Hellstrom daniel@gaisler.com --- drivers/net/greth.c | 4 ++-- 1 files changed, 2 insertions(+), 2 deletions(-)
diff --git a/drivers/net/greth.c b/drivers/net/greth.c index f081855..0566e68 100644 --- a/drivers/net/greth.c +++ b/drivers/net/greth.c @@ -168,7 +168,7 @@ int greth_init(struct eth_device *dev, bd_t * bis) greth->rxbd_base = (greth_bd *) memalign(0x1000, GRETH_RXBD_CNT * sizeof(greth_bd)); greth->txbd_base = (greth_bd *) - memalign(0x1000, GRETH_RXBD_CNT * sizeof(greth_bd)); + memalign(0x1000, GRETH_TXBD_CNT * sizeof(greth_bd));
/* allocate buffers to all descriptors */ greth->rxbuf_base = @@ -200,7 +200,7 @@ int greth_init(struct eth_device *dev, bd_t * bis) for (i = 0; i < GRETH_TXBD_CNT; i++) { greth->txbd_base[i].addr = 0; /* enable desciptor & set wrap bit if last descriptor */ - if (i >= (GRETH_RXBD_CNT - 1)) { + if (i >= (GRETH_TXBD_CNT - 1)) { greth->txbd_base[i].stat = GRETH_BD_WR; } else { greth->txbd_base[i].stat = 0;
diff --git a/drivers/net/greth.c b/drivers/net/greth.c index 0566e68..6c32226 100644 --- a/drivers/net/greth.c +++ b/drivers/net/greth.c @@ -644,9 +644,9 @@ int greth_initialize(bd_t * bis)
/* Make descriptor string */ if (greth->gbit_mac) { - sprintf(dev->name, "GRETH 10/100/GB"); + sprintf(dev->name, "GRETH_10/100/GB"); } else { - sprintf(dev->name, "GRETH 10/100"); + sprintf(dev->name, "GRETH_10/100"); }
Daniel Hellstrom
