[U-Boot] [PATCH v2 00/17] bmips: convert to use live-dt
Convert bmips drivers to use live device tree instead of flattened device tree.
v2: Introduce changes suggested by Daniel Schwierzeck and Simon Glass: - Add generic dev_remap_addr/dev_remap_addr_index functions. - Fix bcm63xx_spi conversion. - Convert remaining bmips drivers (cpu, usbh-phy).
Álvaro Fernández Rojas (17): dm: core: add functions to get memory-mapped I/O addreses watchdog: bcm6345: convert to use live dt serial: bcm6345: convert to use live dt clk: bcm6345: convert to use live dt reset: bcm6345: convert to use live dt gpio: bcm6345: convert to use live dt led: bcm6358: convert to use live dt led: bcm6328: convert to use live dt power: domain: bcm6328: convert to use live dt spi: bcm63xx_spi: convert to use live dt spi: bcm63xx_hsspi: convert to use live dt ram: bmips: convert to use live dt cpu: bmips: convert to use live dt phy: bcm6348-usbh: convert to use live dt phy: bcm6358-usbh: convert to use live dt phy: bcm6368-usbh: convert to use live dt phy: bcm6318-usbh: convert to use live dt
drivers/clk/clk_bcm6345.c | 8 ++--- drivers/core/fdtaddr.c | 12 +++++++ drivers/core/read.c | 12 +++++++ drivers/cpu/bmips_cpu.c | 12 ++----- drivers/gpio/bcm6345_gpio.c | 18 +++------- drivers/led/led_bcm6328.c | 52 ++++++++++------------------- drivers/led/led_bcm6358.c | 44 +++++++++--------------- drivers/phy/bcm6318-usbh-phy.c | 10 ++---- drivers/phy/bcm6348-usbh-phy.c | 10 ++---- drivers/phy/bcm6358-usbh-phy.c | 10 ++---- drivers/phy/bcm6368-usbh-phy.c | 9 ++--- drivers/power/domain/bcm6328-power-domain.c | 8 ++--- drivers/ram/bmips_ram.c | 7 ++-- drivers/reset/reset-bcm6345.c | 8 ++--- drivers/serial/serial_bcm6345.c | 8 ++--- drivers/spi/bcm63xx_hsspi.c | 12 ++----- drivers/spi/bcm63xx_spi.c | 12 ++----- drivers/watchdog/bcm6345_wdt.c | 8 ++--- include/dm/fdtaddr.h | 22 ++++++++++++ include/dm/read.h | 32 ++++++++++++++++++ 20 files changed, 148 insertions(+), 166 deletions(-)
Signed-off-by: Álvaro Fernández Rojas noltari@gmail.com --- drivers/core/fdtaddr.c | 12 ++++++++++++ drivers/core/read.c | 12 ++++++++++++ include/dm/fdtaddr.h | 22 ++++++++++++++++++++++ include/dm/read.h | 32 ++++++++++++++++++++++++++++++++ 4 files changed, 78 insertions(+)
diff --git a/drivers/core/fdtaddr.c b/drivers/core/fdtaddr.c index 3847dd836e..8a80000332 100644 --- a/drivers/core/fdtaddr.c +++ b/drivers/core/fdtaddr.c @@ -132,6 +132,18 @@ void *devfdt_get_addr_ptr(struct udevice *dev) return (void *)(uintptr_t)devfdt_get_addr_index(dev, 0); }
+void *devfdt_remap_addr_index(struct udevice *dev, int index) +{ + fdt_addr_t addr = devfdt_get_addr_index(dev, index); + + return (addr == FDT_ADDR_T_NONE) ? NULL : ioremap(addr, 0); +} + +void *devfdt_remap_addr(struct udevice *dev) +{ + return devfdt_remap_addr_index(dev, 0); +} + void *devfdt_map_physmem(struct udevice *dev, unsigned long size) { fdt_addr_t addr = devfdt_get_addr(dev); diff --git a/drivers/core/read.c b/drivers/core/read.c index 601d1322d6..0d338563ad 100644 --- a/drivers/core/read.c +++ b/drivers/core/read.c @@ -58,6 +58,13 @@ fdt_addr_t dev_read_addr_index(struct udevice *dev, int index) return devfdt_get_addr_index(dev, index); }
+void *dev_remap_addr_index(struct udevice *dev, int index) +{ + fdt_addr_t addr = dev_read_addr_index(dev, index); + + return (addr == FDT_ADDR_T_NONE) ? NULL : ioremap(addr, 0); +} + fdt_addr_t dev_read_addr(struct udevice *dev) { return dev_read_addr_index(dev, 0); @@ -70,6 +77,11 @@ void *dev_read_addr_ptr(struct udevice *dev) return (addr == FDT_ADDR_T_NONE) ? NULL : map_sysmem(addr, 0); }
+void * dev_remap_addr(struct udevice *dev) +{ + return dev_remap_addr_index(dev, 0); +} + fdt_addr_t dev_read_addr_size(struct udevice *dev, const char *property, fdt_size_t *sizep) { diff --git a/include/dm/fdtaddr.h b/include/dm/fdtaddr.h index c46f0e91d0..82fc5f931d 100644 --- a/include/dm/fdtaddr.h +++ b/include/dm/fdtaddr.h @@ -35,6 +35,28 @@ fdt_addr_t devfdt_get_addr(struct udevice *dev); void *devfdt_get_addr_ptr(struct udevice *dev);
/** + * devfdt_remap_addr() - Return pointer to the memory-mapped I/O address + * of the reg property of a device + * + * @dev: Pointer to a device + * + * @return Pointer to addr, or NULL if there is no such property + */ +void *devfdt_remap_addr(struct udevice *dev); + +/** + * devfdt_remap_addr_index() - Return indexed pointer to the memory-mapped + * I/O address of the reg property of a device + * @index: the 'reg' property can hold a list of <addr, size> pairs + * and @index is used to select which one is required + * + * @dev: Pointer to a device + * + * @return Pointer to addr, or NULL if there is no such property + */ +void *devfdt_remap_addr_index(struct udevice *dev, int index); + +/** * devfdt_map_physmem() - Read device address from reg property of the * device node and map the address into CPU address * space. diff --git a/include/dm/read.h b/include/dm/read.h index f14c7a7ba8..42eb585137 100644 --- a/include/dm/read.h +++ b/include/dm/read.h @@ -114,6 +114,18 @@ int dev_read_size(struct udevice *dev, const char *propname); fdt_addr_t dev_read_addr_index(struct udevice *dev, int index);
/** + * dev_remap_addr_index() - Get the indexed reg property of a device + * as a memory-mapped I/O pointer + * + * @dev: Device to read from + * @index: the 'reg' property can hold a list of <addr, size> pairs + * and @index is used to select which one is required + * + * @return pointer or NULL if not found + */ +void * dev_remap_addr_index(struct udevice *dev, int index); + +/** * dev_read_addr() - Get the reg property of a device * * @dev: Device to read from @@ -133,6 +145,16 @@ fdt_addr_t dev_read_addr(struct udevice *dev); void *dev_read_addr_ptr(struct udevice *dev);
/** + * dev_remap_addr() - Get the reg property of a device as a + * memory-mapped I/O pointer + * + * @dev: Device to read from + * + * @return pointer or NULL if not found + */ +void * dev_remap_addr(struct udevice *dev); + +/** * dev_read_addr_size() - get address and size from a device property * * This does no address translation. It simply reads an property that contains @@ -483,6 +505,16 @@ static inline void *dev_read_addr_ptr(struct udevice *dev) return devfdt_get_addr_ptr(dev); }
+static inline void *dev_remap_addr(struct udevice *dev) +{ + return devfdt_remap_addr(dev); +} + +static inline void *dev_remap_addr_index(struct udevice *dev, int index) +{ + return devfdt_remap_addr_index(dev, index); +} + static inline fdt_addr_t dev_read_addr_size(struct udevice *dev, const char *propname, fdt_size_t *sizep)
- fdt_addr_t addr = devfdt_get_addr_index(dev, index);
- return (addr == FDT_ADDR_T_NONE) ? NULL : ioremap(addr, 0);
hm, grepping through all arch's include directories it seems that ioremap() is not available on all archs but map_physmem() is. Maybe you should switch to map_physmem().
- return devfdt_remap_addr_index(dev, 0);
- fdt_addr_t addr = dev_read_addr_index(dev, index);
- return dev_remap_addr_index(dev, 0);
- devfdt_remap_addr() - Return pointer to the memory-mapped I/O address
- @dev: Pointer to a device
- @return Pointer to addr, or NULL if there is no such property
- devfdt_remap_addr_index() - Return indexed pointer to the memory-mapped
- @index: the 'reg' property can hold a list of <addr, size> pairs
- devfdt_map_physmem() - Read device address from reg property of the
space.
- dev_remap_addr_index() - Get the indexed reg property of a device
- @dev: Device to read from
- @return pointer or NULL if not found
- dev_read_addr() - Get the reg property of a device
- dev_remap_addr() - Get the reg property of a device as a
- dev_read_addr_size() - get address and size from a device property
- This does no address translation. It simply reads an property that contains
- return devfdt_remap_addr(dev);
- return devfdt_remap_addr_index(dev, index);
Hi Daniel,
According to this it should be safe to use ioremap: https://github.com/Noltari/u-boot/commit/9a387128e341debb6d7e32df8e0f72669a3...
- void *devfdt_map_physmem(struct udevice *dev, unsigned long size) { fdt_addr_t addr = devfdt_get_addr(dev);
- fdt_addr_t dev_read_addr(struct udevice *dev) { return dev_read_addr_index(dev, 0);
- fdt_addr_t dev_read_addr_size(struct udevice *dev, const char *property, fdt_size_t *sizep) {
space.
- static inline fdt_addr_t dev_read_addr_size(struct udevice *dev, const char *propname, fdt_size_t *sizep)
On 23.03.2018 18:15, Álvaro Fernández Rojas wrote:
Hi Daniel,
diff --git a/drivers/core/fdtaddr.c b/drivers/core/fdtaddr.c index 3847dd836e..8a80000332 100644 --- a/drivers/core/fdtaddr.c +++ b/drivers/core/fdtaddr.c @@ -132,6 +132,18 @@ void *devfdt_get_addr_ptr(struct udevice *dev) return (void *)(uintptr_t)devfdt_get_addr_index(dev, 0); } +void *devfdt_remap_addr_index(struct udevice *dev, int index) +{ + fdt_addr_t addr = devfdt_get_addr_index(dev, index);
ah ok, I forgot this one ;)
void *devfdt_map_physmem(struct udevice *dev, unsigned long size) { fdt_addr_t addr = devfdt_get_addr(dev); diff --git a/drivers/core/read.c b/drivers/core/read.c index 601d1322d6..0d338563ad 100644 --- a/drivers/core/read.c +++ b/drivers/core/read.c @@ -58,6 +58,13 @@ fdt_addr_t dev_read_addr_index(struct udevice *dev, int index) return devfdt_get_addr_index(dev, index); } +void *dev_remap_addr_index(struct udevice *dev, int index) +{ + fdt_addr_t addr = dev_read_addr_index(dev, index);
fdt_addr_t dev_read_addr(struct udevice *dev) { return dev_read_addr_index(dev, 0); @@ -70,6 +77,11 @@ void *dev_read_addr_ptr(struct udevice *dev) return (addr == FDT_ADDR_T_NONE) ? NULL : map_sysmem(addr, 0); } +void * dev_remap_addr(struct udevice *dev) +{ + return dev_remap_addr_index(dev, 0); +}
fdt_addr_t dev_read_addr_size(struct udevice *dev, const char *property, fdt_size_t *sizep) { diff --git a/include/dm/fdtaddr.h b/include/dm/fdtaddr.h index c46f0e91d0..82fc5f931d 100644 --- a/include/dm/fdtaddr.h +++ b/include/dm/fdtaddr.h @@ -35,6 +35,28 @@ fdt_addr_t devfdt_get_addr(struct udevice *dev); void *devfdt_get_addr_ptr(struct udevice *dev); /**
address
- * of the reg property of a device
memory-mapped
- * I/O address of the reg property
of a device
- * and @index is used to select which one is required
+/** * devfdt_map_physmem() - Read device address from reg property of the * device node and map the address into CPU address * space. diff --git a/include/dm/read.h b/include/dm/read.h index f14c7a7ba8..42eb585137 100644 --- a/include/dm/read.h +++ b/include/dm/read.h @@ -114,6 +114,18 @@ int dev_read_size(struct udevice *dev, const char *propname); fdt_addr_t dev_read_addr_index(struct udevice *dev, int index); /**
- * as a memory-mapped I/O pointer
+/** * dev_read_addr() - Get the reg property of a device * * @dev: Device to read from @@ -133,6 +145,16 @@ fdt_addr_t dev_read_addr(struct udevice *dev); void *dev_read_addr_ptr(struct udevice *dev); /**
- * memory-mapped I/O pointer
+/** * dev_read_addr_size() - get address and size from a device property * * This does no address translation. It simply reads an property that contains @@ -483,6 +505,16 @@ static inline void *dev_read_addr_ptr(struct udevice *dev) return devfdt_get_addr_ptr(dev); } +static inline void *dev_remap_addr(struct udevice *dev) +{ + return devfdt_remap_addr(dev); +}
Reviewed-by: Daniel Schwierzeck daniel.schwierzeck@gmail.com
Hi Simon,
are you okay with these changes? I'd like to have your ACK for this patch before applying. Thanks.
space.
Hi Daniel,
On 6 April 2018 at 20:45, Daniel Schwierzeck daniel.schwierzeck@gmail.com wrote:
Hi Simon,
It looks fine to me. I'd like to see these functions called from a sandbox test though - e.g. test/dm/test-fdt.c
Signed-off-by: Álvaro Fernández Rojas noltari@gmail.com --- v2: Introduce changes suggested by Daniel Schwierzeck: - Use generic dev_remap_addr function.
drivers/watchdog/bcm6345_wdt.c | 8 ++------ 1 file changed, 2 insertions(+), 6 deletions(-)
diff --git a/drivers/watchdog/bcm6345_wdt.c b/drivers/watchdog/bcm6345_wdt.c index 3ef7d438a6..2e33b24331 100644 --- a/drivers/watchdog/bcm6345_wdt.c +++ b/drivers/watchdog/bcm6345_wdt.c @@ -86,15 +86,11 @@ static const struct udevice_id bcm6345_wdt_ids[] = { static int bcm6345_wdt_probe(struct udevice *dev) { struct bcm6345_wdt_priv *priv = dev_get_priv(dev); - fdt_addr_t addr; - fdt_size_t size;
- addr = devfdt_get_addr_size_index(dev, 0, &size); - if (addr == FDT_ADDR_T_NONE) + priv->regs = dev_remap_addr(dev); + if (!priv->regs) return -EINVAL;
- priv->regs = ioremap(addr, size); - bcm6345_wdt_stop(dev);
Signed-off-by: Álvaro Fernández Rojas noltari@gmail.com Reviewed-by: Simon Glass sjg@chromium.org --- v2: Introduce changes suggested by Daniel Schwierzeck: - Use generic dev_remap_addr function.
drivers/serial/serial_bcm6345.c | 8 ++------ 1 file changed, 2 insertions(+), 6 deletions(-)
diff --git a/drivers/serial/serial_bcm6345.c b/drivers/serial/serial_bcm6345.c index 20f67f4b7e..4b8d09d241 100644 --- a/drivers/serial/serial_bcm6345.c +++ b/drivers/serial/serial_bcm6345.c @@ -228,17 +228,13 @@ static int bcm6345_serial_probe(struct udevice *dev) { struct bcm6345_serial_priv *priv = dev_get_priv(dev); struct clk clk; - fdt_addr_t addr; - fdt_size_t size; int ret;
/* get address */ - addr = devfdt_get_addr_size_index(dev, 0, &size); - if (addr == FDT_ADDR_T_NONE) + priv->base = dev_remap_addr(dev); + if (!priv->base) return -EINVAL;
- priv->base = ioremap(addr, size); - /* get clock rate */ ret = clk_get_by_index(dev, 0, &clk); if (ret < 0)
drivers/clk/clk_bcm6345.c | 8 ++------ 1 file changed, 2 insertions(+), 6 deletions(-)
diff --git a/drivers/clk/clk_bcm6345.c b/drivers/clk/clk_bcm6345.c index 93603fa825..7c31ca325e 100644 --- a/drivers/clk/clk_bcm6345.c +++ b/drivers/clk/clk_bcm6345.c @@ -56,15 +56,11 @@ static const struct udevice_id bcm6345_clk_ids[] = { static int bcm63xx_clk_probe(struct udevice *dev) { struct bcm6345_clk_priv *priv = dev_get_priv(dev); - fdt_addr_t addr; - fdt_size_t size;
- priv->regs = ioremap(addr, size); - return 0; }
drivers/reset/reset-bcm6345.c | 8 ++------ 1 file changed, 2 insertions(+), 6 deletions(-)
diff --git a/drivers/reset/reset-bcm6345.c b/drivers/reset/reset-bcm6345.c index ebf6bee9e6..fb9978a116 100644 --- a/drivers/reset/reset-bcm6345.c +++ b/drivers/reset/reset-bcm6345.c @@ -67,15 +67,11 @@ static const struct udevice_id bcm6345_reset_ids[] = { static int bcm6345_reset_probe(struct udevice *dev) { struct bcm6345_reset_priv *priv = dev_get_priv(dev); - fdt_addr_t addr; - fdt_size_t size;
Signed-off-by: Álvaro Fernández Rojas noltari@gmail.com Reviewed-by: Simon Glass sjg@chromium.org --- v2: Introduce changes suggested by Daniel Schwierzeck: - Use generic dev_remap_addr_index function.
drivers/gpio/bcm6345_gpio.c | 18 +++++------------- 1 file changed, 5 insertions(+), 13 deletions(-)
diff --git a/drivers/gpio/bcm6345_gpio.c b/drivers/gpio/bcm6345_gpio.c index b9100cdc58..847b6ca076 100644 --- a/drivers/gpio/bcm6345_gpio.c +++ b/drivers/gpio/bcm6345_gpio.c @@ -14,8 +14,6 @@ #include <asm/gpio.h> #include <asm/io.h>
-DECLARE_GLOBAL_DATA_PTR; - struct bcm6345_gpio_priv { void __iomem *reg_dirout; void __iomem *reg_data; @@ -91,22 +89,16 @@ static int bcm6345_gpio_probe(struct udevice *dev) { struct gpio_dev_priv *uc_priv = dev_get_uclass_priv(dev); struct bcm6345_gpio_priv *priv = dev_get_priv(dev); - fdt_addr_t data_addr, dirout_addr; - fdt_size_t data_size, dirout_size;
- dirout_addr = devfdt_get_addr_size_index(dev, 0, &dirout_size); - if (dirout_addr == FDT_ADDR_T_NONE) + priv->reg_dirout = dev_remap_addr_index(dev, 0); + if (!priv->reg_dirout) return -EINVAL;
- data_addr = devfdt_get_addr_size_index(dev, 1, &data_size); - if (data_addr == FDT_ADDR_T_NONE) + priv->reg_data = dev_remap_addr_index(dev, 1); + if (!priv->reg_data) return -EINVAL;
- priv->reg_data = ioremap(data_addr, data_size); - priv->reg_dirout = ioremap(dirout_addr, dirout_size); - - uc_priv->gpio_count = fdtdec_get_uint(gd->fdt_blob, dev_of_offset(dev), - "ngpios", 32); + uc_priv->gpio_count = dev_read_u32_default(dev, "ngpios", 32); uc_priv->bank_name = dev->name;
drivers/led/led_bcm6358.c | 44 +++++++++++++++----------------------------- 1 file changed, 15 insertions(+), 29 deletions(-)
diff --git a/drivers/led/led_bcm6358.c b/drivers/led/led_bcm6358.c index e8a3b64e68..86ec7aba75 100644 --- a/drivers/led/led_bcm6358.c +++ b/drivers/led/led_bcm6358.c @@ -32,8 +32,6 @@ #define LED_CTRL_BUSY_SHIFT 3 #define LED_CTRL_BUSY_MASK (1 << LED_CTRL_BUSY_SHIFT)
-DECLARE_GLOBAL_DATA_PTR; - struct bcm6358_led_priv { void __iomem *regs; uint8_t pin; @@ -115,8 +113,6 @@ static const struct led_ops bcm6358_led_ops = { static int bcm6358_led_probe(struct udevice *dev) { struct led_uc_plat *uc_plat = dev_get_uclass_platdata(dev); - fdt_addr_t addr; - fdt_size_t size;
/* Top-level LED node */ if (!uc_plat->label) { @@ -124,17 +120,14 @@ static int bcm6358_led_probe(struct udevice *dev) unsigned int clk_div; u32 set_bits = 0;
- addr = devfdt_get_addr_size_index(dev, 0, &size); - if (addr == FDT_ADDR_T_NONE) + regs = dev_remap_addr(dev); + if (!regs) return -EINVAL;
- regs = ioremap(addr, size); - - if (fdtdec_get_bool(gd->fdt_blob, dev_of_offset(dev), - "brcm,clk-dat-low")) + if (dev_read_bool(dev, "brcm,clk-dat-low")) set_bits |= LED_CTRL_POL_MASK; - clk_div = fdtdec_get_uint(gd->fdt_blob, dev_of_offset(dev), - "brcm,clk-div", LED_CTRL_CLK_1); + clk_div = dev_read_u32_default(dev, "brcm,clk-div", + LED_CTRL_CLK_1); switch (clk_div) { case 8: set_bits |= LED_CTRL_CLK_8; @@ -158,21 +151,17 @@ static int bcm6358_led_probe(struct udevice *dev) struct bcm6358_led_priv *priv = dev_get_priv(dev); unsigned int pin;
- addr = devfdt_get_addr_size_index(dev_get_parent(dev), 0, - &size); - if (addr == FDT_ADDR_T_NONE) + priv->regs = dev_remap_addr(dev); + if (!priv->regs) return -EINVAL;
- pin = fdtdec_get_uint(gd->fdt_blob, dev_of_offset(dev), "reg", - LEDS_MAX); + pin = dev_read_u32_default(dev, "reg", LEDS_MAX); if (pin >= LEDS_MAX) return -EINVAL;
- priv->regs = ioremap(addr, size); priv->pin = pin;
- if (fdtdec_get_bool(gd->fdt_blob, dev_of_offset(dev), - "active-low")) + if (dev_read_bool(dev, "active-low")) priv->active_low = true; }
@@ -181,27 +170,24 @@ static int bcm6358_led_probe(struct udevice *dev)
static int bcm6358_led_bind(struct udevice *parent) { - const void *blob = gd->fdt_blob; - int node; + ofnode node;
- for (node = fdt_first_subnode(blob, dev_of_offset(parent)); - node > 0; - node = fdt_next_subnode(blob, node)) { + dev_for_each_subnode(node, parent) { struct led_uc_plat *uc_plat; struct udevice *dev; const char *label; int ret;
- label = fdt_getprop(blob, node, "label", NULL); + label = ofnode_read_string(node, "label"); if (!label) { debug("%s: node %s has no label\n", __func__, - fdt_get_name(blob, node, NULL)); + ofnode_get_name(node)); return -EINVAL; }
ret = device_bind_driver_to_node(parent, "bcm6358-led", - fdt_get_name(blob, node, NULL), - offset_to_ofnode(node), &dev); + ofnode_get_name(node), + node, &dev); if (ret) return ret;
drivers/led/led_bcm6328.c | 52 ++++++++++++++++------------------------------- 1 file changed, 17 insertions(+), 35 deletions(-)
diff --git a/drivers/led/led_bcm6328.c b/drivers/led/led_bcm6328.c index 5d545c5096..a8cc5c5167 100644 --- a/drivers/led/led_bcm6328.c +++ b/drivers/led/led_bcm6328.c @@ -38,8 +38,6 @@ #define LED_MODE_OFF 3 #define LED_MODE_MASK 0x3
-DECLARE_GLOBAL_DATA_PTR; - struct bcm6328_led_priv { void __iomem *regs; void __iomem *mode; @@ -150,34 +148,25 @@ static const struct led_ops bcm6328_led_ops = { static int bcm6328_led_probe(struct udevice *dev) { struct led_uc_plat *uc_plat = dev_get_uclass_platdata(dev); - fdt_addr_t addr; - fdt_size_t size;
/* Top-level LED node */ if (!uc_plat->label) { void __iomem *regs; u32 set_bits = 0;
- regs = ioremap(addr, size); - - if (fdtdec_get_bool(gd->fdt_blob, dev_of_offset(dev), - "brcm,serial-leds")) + if (dev_read_bool(dev, "brcm,serial-leds")) set_bits |= LED_INIT_SLEDEN_MASK; - if (fdtdec_get_bool(gd->fdt_blob, dev_of_offset(dev), - "brcm,serial-mux")) + if (dev_read_bool(dev, "brcm,serial-mux")) set_bits |= LED_INIT_SLEDMUX_MASK; - if (fdtdec_get_bool(gd->fdt_blob, dev_of_offset(dev), - "brcm,serial-clk-low")) + if (dev_read_bool(dev, "brcm,serial-clk-low")) set_bits |= LED_INIT_SLEDCLKNPOL_MASK; - if (!fdtdec_get_bool(gd->fdt_blob, dev_of_offset(dev), - "brcm,serial-dat-low")) + if (!dev_read_bool(dev, "brcm,serial-dat-low")) set_bits |= LED_INIT_SLEDDATANPOL_MASK; - if (!fdtdec_get_bool(gd->fdt_blob, dev_of_offset(dev), - "brcm,serial-shift-inv")) + if (!dev_read_bool(dev, "brcm,serial-shift-inv")) set_bits |= LED_INIT_SLEDSHIFTDIR_MASK;
clrsetbits_be32(regs + LED_INIT_REG, ~0, set_bits); @@ -185,17 +174,14 @@ static int bcm6328_led_probe(struct udevice *dev) struct bcm6328_led_priv *priv = dev_get_priv(dev); unsigned int pin;
- priv->regs = ioremap(addr, size); if (pin < 8) { /* LEDs 0-7 (bits 47:32) */ priv->mode = priv->regs + LED_MODE_REG_HI; @@ -206,8 +192,7 @@ static int bcm6328_led_probe(struct udevice *dev) priv->shift = ((pin - 8) << 1); }
@@ -216,27 +201,24 @@ static int bcm6328_led_probe(struct udevice *dev)
static int bcm6328_led_bind(struct udevice *parent) { - const void *blob = gd->fdt_blob; - int node; + ofnode node;
ret = device_bind_driver_to_node(parent, "bcm6328-led", - fdt_get_name(blob, node, NULL), - offset_to_ofnode(node), &dev); + ofnode_get_name(node), + node, &dev); if (ret) return ret;
drivers/power/domain/bcm6328-power-domain.c | 8 ++------ 1 file changed, 2 insertions(+), 6 deletions(-)
diff --git a/drivers/power/domain/bcm6328-power-domain.c b/drivers/power/domain/bcm6328-power-domain.c index 776afa3d43..6a64f6bb2c 100644 --- a/drivers/power/domain/bcm6328-power-domain.c +++ b/drivers/power/domain/bcm6328-power-domain.c @@ -49,15 +49,11 @@ static int bcm6328_power_domain_off(struct power_domain *power_domain) static int bcm6328_power_domain_probe(struct udevice *dev) { struct bcm6328_power_domain *priv = dev_get_priv(dev); - fdt_addr_t addr; - fdt_size_t size;
Signed-off-by: Álvaro Fernández Rojas noltari@gmail.com Reviewed-by: Simon Glass sjg@chromium.org --- v2: Introduce changes suggested by Daniel Schwierzeck and Simon Glass: - Use generic dev_remap_addr function. - Fix bcm63xx_spi conversion.
drivers/spi/bcm63xx_spi.c | 12 +++--------- 1 file changed, 3 insertions(+), 9 deletions(-)
diff --git a/drivers/spi/bcm63xx_spi.c b/drivers/spi/bcm63xx_spi.c index f0df6871d8..c61c5d49b4 100644 --- a/drivers/spi/bcm63xx_spi.c +++ b/drivers/spi/bcm63xx_spi.c @@ -16,8 +16,6 @@ #include <wait_bit.h> #include <asm/io.h>
-DECLARE_GLOBAL_DATA_PTR; - /* BCM6348 SPI core */ #define SPI_6348_CLK 0x06 #define SPI_6348_CMD 0x00 @@ -374,18 +372,14 @@ static int bcm63xx_spi_probe(struct udevice *dev) (const unsigned long *)dev_get_driver_data(dev); struct reset_ctl rst_ctl; struct clk clk; - fdt_addr_t addr; - fdt_size_t size; int ret;
priv->regs = regs; - priv->base = ioremap(addr, size); - priv->num_cs = fdtdec_get_uint(gd->fdt_blob, dev_of_offset(dev), - "num-cs", 8); + priv->num_cs = dev_read_u32_default(dev, "num-cs", 8);
/* enable clock */ ret = clk_get_by_index(dev, 0, &clk);
drivers/spi/bcm63xx_hsspi.c | 12 +++--------- 1 file changed, 3 insertions(+), 9 deletions(-)
diff --git a/drivers/spi/bcm63xx_hsspi.c b/drivers/spi/bcm63xx_hsspi.c index 3393166a1e..a4eecc9b19 100644 --- a/drivers/spi/bcm63xx_hsspi.c +++ b/drivers/spi/bcm63xx_hsspi.c @@ -16,8 +16,6 @@ #include <wait_bit.h> #include <asm/io.h>
-DECLARE_GLOBAL_DATA_PTR; - #define HSSPI_PP 0
#define SPI_MAX_SYNC_CLOCK 30000000 @@ -338,17 +336,13 @@ static int bcm63xx_hsspi_probe(struct udevice *dev) struct bcm63xx_hsspi_priv *priv = dev_get_priv(dev); struct reset_ctl rst_ctl; struct clk clk; - fdt_addr_t addr; - fdt_size_t size; int ret;
- priv->regs = ioremap(addr, size); - priv->num_cs = fdtdec_get_uint(gd->fdt_blob, dev_of_offset(dev), - "num-cs", 8); + priv->num_cs = dev_read_u32_default(dev, "num-cs", 8);
/* enable clock */ ret = clk_get_by_name(dev, "hsspi", &clk);
drivers/ram/bmips_ram.c | 7 ++----- 1 file changed, 2 insertions(+), 5 deletions(-)
diff --git a/drivers/ram/bmips_ram.c b/drivers/ram/bmips_ram.c index 7a5dfac4ab..22b08715a5 100644 --- a/drivers/ram/bmips_ram.c +++ b/drivers/ram/bmips_ram.c @@ -151,14 +151,11 @@ static int bmips_ram_probe(struct udevice *dev) struct bmips_ram_priv *priv = dev_get_priv(dev); const struct bmips_ram_hw *hw = (const struct bmips_ram_hw *)dev_get_driver_data(dev); - fdt_addr_t addr; - fdt_size_t size;
- priv->regs = ioremap(addr, size); priv->hw = hw;
Signed-off-by: Álvaro Fernández Rojas noltari@gmail.com --- drivers/cpu/bmips_cpu.c | 12 +++--------- 1 file changed, 3 insertions(+), 9 deletions(-)
diff --git a/drivers/cpu/bmips_cpu.c b/drivers/cpu/bmips_cpu.c index 6c612bacdc..f766be22e6 100644 --- a/drivers/cpu/bmips_cpu.c +++ b/drivers/cpu/bmips_cpu.c @@ -14,8 +14,6 @@ #include <errno.h> #include <asm/io.h>
-DECLARE_GLOBAL_DATA_PTR; - #define REV_CHIPID_SHIFT 16 #define REV_CHIPID_MASK (0xffff << REV_CHIPID_SHIFT) #define REV_LONG_CHIPID_SHIFT 12 @@ -398,8 +396,7 @@ int bmips_cpu_bind(struct udevice *dev) { struct cpu_platdata *plat = dev_get_parent_platdata(dev);
- plat->cpu_id = fdtdec_get_int(gd->fdt_blob, dev_of_offset(dev), - "reg", -1); + plat->cpu_id = dev_read_u32_default(dev, "reg", -1); plat->device_id = read_c0_prid();
return 0; @@ -410,14 +407,11 @@ int bmips_cpu_probe(struct udevice *dev) struct bmips_cpu_priv *priv = dev_get_priv(dev); const struct bmips_cpu_hw *hw = (const struct bmips_cpu_hw *)dev_get_driver_data(dev); - fdt_addr_t addr; - fdt_size_t size;
- addr = devfdt_get_addr_size_index(dev_get_parent(dev), 0, &size); - if (addr == FDT_ADDR_T_NONE) + priv->regs = dev_remap_addr(dev); + if (!priv->regs) return -EINVAL;
Also fix bad accents in my name.
Signed-off-by: Álvaro Fernández Rojas noltari@gmail.com --- drivers/phy/bcm6348-usbh-phy.c | 10 +++------- 1 file changed, 3 insertions(+), 7 deletions(-)
diff --git a/drivers/phy/bcm6348-usbh-phy.c b/drivers/phy/bcm6348-usbh-phy.c index 169ee0ecec..a0134c3e43 100644 --- a/drivers/phy/bcm6348-usbh-phy.c +++ b/drivers/phy/bcm6348-usbh-phy.c @@ -1,5 +1,5 @@ /* - * Copyright (C) 2018 Ãlvaro Fernández Rojas noltari@gmail.com + * Copyright (C) 2018 Álvaro Fernández Rojas noltari@gmail.com * * Derived from linux/arch/mips/bcm63xx/usb-common.c: * Copyright 2008 Maxime Bizon mbizon@freebox.fr @@ -45,16 +45,12 @@ static int bcm6348_usbh_probe(struct udevice *dev) struct bcm6348_usbh_priv *priv = dev_get_priv(dev); struct reset_ctl rst_ctl; struct clk clk; - fdt_addr_t addr; - fdt_size_t size; int ret;
- priv->regs = ioremap(addr, size); - /* enable usbh clock */ ret = clk_get_by_name(dev, "usbh", &clk); if (ret < 0)
not sure why but some of the downloaded patches from Patchwork seemed to be messed up. I also had to fix the author field in the commit message when I applied your patches.
Signed-off-by: Álvaro Fernández Rojas noltari@gmail.com --- drivers/phy/bcm6358-usbh-phy.c | 10 +++------- 1 file changed, 3 insertions(+), 7 deletions(-)
diff --git a/drivers/phy/bcm6358-usbh-phy.c b/drivers/phy/bcm6358-usbh-phy.c index e000316a93..00637ece51 100644 --- a/drivers/phy/bcm6358-usbh-phy.c +++ b/drivers/phy/bcm6358-usbh-phy.c @@ -1,5 +1,5 @@ /* - * Copyright (C) 2018 Ãlvaro Fernández Rojas noltari@gmail.com + * Copyright (C) 2018 Álvaro Fernández Rojas noltari@gmail.com * * Derived from linux/arch/mips/bcm63xx/usb-common.c: * Copyright 2008 Maxime Bizon mbizon@freebox.fr @@ -58,16 +58,12 @@ static int bcm6358_usbh_probe(struct udevice *dev) { struct bcm6358_usbh_priv *priv = dev_get_priv(dev); struct reset_ctl rst_ctl; - fdt_addr_t addr; - fdt_size_t size; int ret;
- priv->regs = ioremap(addr, size); - /* perform reset */ ret = reset_get_by_index(dev, 0, &rst_ctl); if (ret < 0)
Signed-off-by: Álvaro Fernández Rojas noltari@gmail.com --- drivers/phy/bcm6368-usbh-phy.c | 9 +++------ 1 file changed, 3 insertions(+), 6 deletions(-)
diff --git a/drivers/phy/bcm6368-usbh-phy.c b/drivers/phy/bcm6368-usbh-phy.c index 71abc0fcc4..2c4288c9b8 100644 --- a/drivers/phy/bcm6368-usbh-phy.c +++ b/drivers/phy/bcm6368-usbh-phy.c @@ -1,5 +1,5 @@ /* - * Copyright (C) 2018 Ãlvaro Fernández Rojas noltari@gmail.com + * Copyright (C) 2018 Álvaro Fernández Rojas noltari@gmail.com * * Derived from linux/arch/mips/bcm63xx/usb-common.c: * Copyright 2008 Maxime Bizon mbizon@freebox.fr @@ -117,15 +117,12 @@ static int bcm6368_usbh_probe(struct udevice *dev) #endif struct reset_ctl rst_ctl; struct clk clk; - fdt_addr_t addr; - fdt_size_t size; int ret;
Signed-off-by: Álvaro Fernández Rojas noltari@gmail.com --- drivers/phy/bcm6318-usbh-phy.c | 10 +++------- 1 file changed, 3 insertions(+), 7 deletions(-)
diff --git a/drivers/phy/bcm6318-usbh-phy.c b/drivers/phy/bcm6318-usbh-phy.c index 6d54214581..043d8ff842 100644 --- a/drivers/phy/bcm6318-usbh-phy.c +++ b/drivers/phy/bcm6318-usbh-phy.c @@ -1,5 +1,5 @@ /* - * Copyright (C) 2018 Ãlvaro Fernández Rojas noltari@gmail.com + * Copyright (C) 2018 Álvaro Fernández Rojas noltari@gmail.com * * Derived from linux/arch/mips/bcm63xx/usb-common.c: * Copyright 2008 Maxime Bizon mbizon@freebox.fr @@ -80,16 +80,12 @@ static int bcm6318_usbh_probe(struct udevice *dev) struct power_domain pwr_dom; struct reset_ctl rst_ctl; struct clk clk; - fdt_addr_t addr; - fdt_size_t size; int ret;
applied to u-boot-mips/next and scheduled for 2018.07-rc1
Patch 01/17 has been replaced with https://patchwork.ozlabs.org/patch/906412/
Daniel Schwierzeck
