[PATCH] efi_loader: correctly handle mixed hashes and signatures in db
A mix of signatures and hashes in db doesn't always work as intended. Currently if the digest algorithm is not supported we stop walking the security database and reject the image. That's problematic in case we find and try to check a signature before inspecting the sha256 hash. If the image is unsigned we will reject it even if the digest matches
Signed-off-by: Ilias Apalodimas ilias.apalodimas@linaro.org --- lib/efi_loader/efi_signature.c | 2 +- 1 file changed, 1 insertion(+), 1 deletion(-)
diff --git a/lib/efi_loader/efi_signature.c b/lib/efi_loader/efi_signature.c index 3243e2c60de0..8fa82f8cea4c 100644 --- a/lib/efi_loader/efi_signature.c +++ b/lib/efi_loader/efi_signature.c @@ -176,7 +176,7 @@ bool efi_signature_lookup_digest(struct efi_image_regions *regs, if (guidcmp(&siglist->sig_type, &efi_guid_sha256)) { EFI_PRINT("Digest algorithm is not supported: %pUs\n", &siglist->sig_type); - break; + continue; }
if (!efi_hash_regions(regs->reg, regs->num, &hash, &size)) {
According to the commit message siglist->sig_type could be EFI_CERT_RSA2048_SHA256_GUID which does not relate to a 'Digest algorithm'. So the debug message text is wrong. As we expect guidcmp() to report a mismatch we could remove the message.
break;
continue;
This still is not correct:
dbx containing a signature type that we do not support must disable the loading of any image.
The UEFI specification defines EFI_CERT_SHA1_GUID, EFI_CERT_SHA384_GUID and EFI_CERT_SHA512_GUID. We should support all of these for dbx.
For security reasons we should not support EFI_CERT_SHA1_GUID for db.
The function lacks an argument indicating if we are dealing with db or dbx which have to be treated differently.
} if (!efi_hash_regions(regs->reg, regs->num, &hash, &size)) {
The subsequent code has a performance issue:
We should not hash the image once per entry in db but once per hash algorithm.
Best regards
Heinrich
Ok
break;
continue;
I don't really think we should go and support all of those. I have doubts about why we support time based revocation to begin with.
Nor dbx, sha1 should be completely ignored imho.
How about making it a bit more generic? We can add the default value of 'ret'. So we can easily handle cases were the algorithm requested is not supported.
Yea we seem to have this kind of issue in other parts as well. I'll fix that along the way
Thanks /Ilias
Ilias Apalodimas
