[PATCH] efi_loader: disk: remove unused field
The field, ifname, in efi_disk_obj is set but never used anywhere. Just remove it.
Signed-off-by: AKASHI Takahiro takahiro.akashi@linaro.org --- lib/efi_loader/efi_disk.c | 13 ++----------- 1 file changed, 2 insertions(+), 11 deletions(-)
diff --git a/lib/efi_loader/efi_disk.c b/lib/efi_loader/efi_disk.c index 1d700b2a6be3..7d9e973e5672 100644 --- a/lib/efi_loader/efi_disk.c +++ b/lib/efi_loader/efi_disk.c @@ -29,7 +29,6 @@ const efi_guid_t efi_system_partition_guid = PARTITION_SYSTEM_GUID; * * @header: EFI object header * @ops: EFI disk I/O protocol interface - * @ifname: interface name for block device * @dev_index: device index of block device * @media: block I/O media information * @dp: device path to the block device @@ -40,7 +39,6 @@ const efi_guid_t efi_system_partition_guid = PARTITION_SYSTEM_GUID; struct efi_disk_obj { struct efi_object header; struct efi_block_io ops; - const char *ifname; int dev_index; struct efi_block_io_media media; struct efi_device_path *dp; @@ -380,7 +378,6 @@ static int efi_fs_exists(struct blk_desc *desc, int part) * * @parent: parent handle * @dp_parent: parent device path - * @if_typename: interface name for block device * @desc: internal block device * @dev_index: device index for block device * @part_info: partition info @@ -391,7 +388,6 @@ static int efi_fs_exists(struct blk_desc *desc, int part) static efi_status_t efi_disk_add_dev( efi_handle_t parent, struct efi_device_path *dp_parent, - const char *if_typename, struct blk_desc *desc, int dev_index, struct disk_partition *part_info, @@ -476,7 +472,6 @@ static efi_status_t efi_disk_add_dev( return ret; } diskobj->ops = block_io_disk_template; - diskobj->ifname = if_typename; diskobj->dev_index = dev_index;
/* Fill in EFI IO Media info (for read/write callbacks) */ @@ -534,15 +529,13 @@ static int efi_disk_create_raw(struct udevice *dev) { struct efi_disk_obj *disk; struct blk_desc *desc; - const char *if_typename; int diskid; efi_status_t ret;
desc = dev_get_uclass_plat(dev); - if_typename = blk_get_if_type_name(desc->if_type); diskid = desc->devnum;
- ret = efi_disk_add_dev(NULL, NULL, if_typename, desc, + ret = efi_disk_add_dev(NULL, NULL, desc, diskid, NULL, 0, &disk); if (ret != EFI_SUCCESS) { if (ret == EFI_NOT_READY) @@ -577,7 +570,6 @@ static int efi_disk_create_part(struct udevice *dev) { efi_handle_t parent; struct blk_desc *desc; - const char *if_typename; struct disk_part *part_data; struct disk_partition *info; unsigned int part; @@ -591,7 +583,6 @@ static int efi_disk_create_part(struct udevice *dev) return -1;
desc = dev_get_uclass_plat(dev_get_parent(dev)); - if_typename = blk_get_if_type_name(desc->if_type); diskid = desc->devnum;
part_data = dev_get_uclass_plat(dev); @@ -603,7 +594,7 @@ static int efi_disk_create_part(struct udevice *dev) return -1; dp_parent = (struct efi_device_path *)handler->protocol_interface;
- ret = efi_disk_add_dev(parent, dp_parent, if_typename, desc, diskid, + ret = efi_disk_add_dev(parent, dp_parent, desc, diskid, info, part, &disk); if (ret != EFI_SUCCESS) { log_err("Adding partition for %s failed\n", dev->name);
Reviewed-by: Heinrich Schuchardt xypron.glpk@gmx.de
AKASHI Takahiro
