[PATCH v2] board: gateworks: venice: add imx8mn-gw7902 support
The GW7902 is based on the i.MX 8M Mini / Nano SoC featuring: - LPDDR4 DRAM - eMMC FLASH - Gateworks System Controller - LTE CAT M1 modem - USB 2.0 HUB - M.2 Socket with USB2.0, PCIe, and dual-SIM - IMX8M FEC - PCIe based GbE - RS232/RS485/RS422 serial transceiver - GPS - CAN bus - WiFi / Bluetooth - MIPI header (DSI/CSI/GPIO/PWM/I2S) - PMIC
To add support for the i.MX8M Nano GW7902: - Add imx8mn-venice dts/defconfig/include - Add imx8mn-gw7902 dts - Add imx8mn-2gb lpddr4 dram configs - Add misc support for IMX8M Nano SoC - rename imx8mm-venice.c to venice.c as it is no longer imx8mm specific - update README with differences for IMX8MN vs IMX8MM
Signed-off-by: Tim Harvey tharvey@gateworks.com --- v2: - rebase on origin/master - remove unused fdt_pack_reg function --- arch/arm/dts/Makefile | 2 + arch/arm/dts/imx8mn-venice-gw7902-u-boot.dtsi | 29 + arch/arm/dts/imx8mn-venice-gw7902.dts | 888 ++++++++++ arch/arm/dts/imx8mn-venice-u-boot.dtsi | 222 +++ arch/arm/dts/imx8mn-venice.dts | 152 ++ arch/arm/mach-imx/imx8m/Kconfig | 7 + board/gateworks/venice/Kconfig | 15 + board/gateworks/venice/MAINTAINERS | 6 +- board/gateworks/venice/Makefile | 10 +- board/gateworks/venice/README | 3 +- board/gateworks/venice/gsc.c | 13 + .../gateworks/venice/imximage-8mn-lpddr4.cfg | 10 + board/gateworks/venice/lpddr4_timing.h | 5 + ...lpddr4_timing.c => lpddr4_timing_imx8mm.c} | 0 .../lpddr4_timing_imx8mn_2gb_dual_die.c | 1444 ++++++++++++++++ .../lpddr4_timing_imx8mn_2gb_single_die.c | 1445 +++++++++++++++++ board/gateworks/venice/spl.c | 31 +- .../venice/{imx8mm_venice.c => venice.c} | 0 configs/imx8mn_venice_defconfig | 114 ++ include/configs/imx8mn_venice.h | 114 ++ 20 files changed, 4503 insertions(+), 7 deletions(-) create mode 100644 arch/arm/dts/imx8mn-venice-gw7902-u-boot.dtsi create mode 100644 arch/arm/dts/imx8mn-venice-gw7902.dts create mode 100644 arch/arm/dts/imx8mn-venice-u-boot.dtsi create mode 100644 arch/arm/dts/imx8mn-venice.dts create mode 100644 board/gateworks/venice/imximage-8mn-lpddr4.cfg rename board/gateworks/venice/{lpddr4_timing.c => lpddr4_timing_imx8mm.c} (100%) create mode 100644 board/gateworks/venice/lpddr4_timing_imx8mn_2gb_dual_die.c create mode 100644 board/gateworks/venice/lpddr4_timing_imx8mn_2gb_single_die.c rename board/gateworks/venice/{imx8mm_venice.c => venice.c} (100%) create mode 100644 configs/imx8mn_venice_defconfig create mode 100644 include/configs/imx8mn_venice.h
diff --git a/arch/arm/dts/Makefile b/arch/arm/dts/Makefile index 9438bf735a..a338814d2c 100644 --- a/arch/arm/dts/Makefile +++ b/arch/arm/dts/Makefile @@ -881,6 +881,8 @@ dtb-$(CONFIG_ARCH_IMX8M) += \ imx8mn-ddr4-evk.dtb \ imx8mq-cm.dtb \ imx8mn-evk.dtb \ + imx8mn-venice.dtb \ + imx8mn-venice-gw7902.dtb \ imx8mq-evk.dtb \ imx8mm-beacon-kit.dtb \ imx8mn-beacon-kit.dtb \ diff --git a/arch/arm/dts/imx8mn-venice-gw7902-u-boot.dtsi b/arch/arm/dts/imx8mn-venice-gw7902-u-boot.dtsi new file mode 100644 index 0000000000..f6f0aa7cb5 --- /dev/null +++ b/arch/arm/dts/imx8mn-venice-gw7902-u-boot.dtsi @@ -0,0 +1,29 @@ +// SPDX-License-Identifier: GPL-2.0+ +/* + * Copyright 2021 Gateworks Corporation + */ + +#include "imx8mn-venice-u-boot.dtsi" + +&fec1 { + phy-reset-gpios = <&gpio1 10 GPIO_ACTIVE_LOW>; + phy-reset-duration = <1>; + phy-reset-post-delay = <1>; +}; + +&pinctrl_fec1 { + u-boot,dm-spl; +}; + +&{/soc@0/bus@30800000/i2c@30a20000/pmic@4b} { + u-boot,dm-spl; +}; + +&{/soc@0/bus@30800000/i2c@30a20000/pmic@4b/regulators} { + u-boot,dm-spl; +}; + +&pinctrl_pmic { + u-boot,dm-spl; +}; + diff --git a/arch/arm/dts/imx8mn-venice-gw7902.dts b/arch/arm/dts/imx8mn-venice-gw7902.dts new file mode 100644 index 0000000000..06ee4cf794 --- /dev/null +++ b/arch/arm/dts/imx8mn-venice-gw7902.dts @@ -0,0 +1,888 @@ +// SPDX-License-Identifier: (GPL-2.0+ OR MIT) +/* + * Copyright 2021 Gateworks Corporation + */ + +/dts-v1/; + +#include <dt-bindings/gpio/gpio.h> +#include <dt-bindings/input/linux-event-codes.h> +#include <dt-bindings/leds/common.h> +#include <dt-bindings/net/ti-dp83867.h> + +#include "imx8mn.dtsi" + +/ { + model = "Gateworks Venice GW7902 i.MX8MN board"; + compatible = "gw,imx8mn-gw7902", "fsl,imx8mn"; + + aliases { + usb0 = &usbotg1; + }; + + chosen { + stdout-path = &uart2; + }; + + memory@40000000 { + device_type = "memory"; + reg = <0x0 0x40000000 0 0x80000000>; + }; + + can20m: can20m { + compatible = "fixed-clock"; + #clock-cells = <0>; + clock-frequency = <20000000>; + clock-output-names = "can20m"; + }; + + gpio-keys { + compatible = "gpio-keys"; + + user-pb { + label = "user_pb"; + gpios = <&gpio 2 GPIO_ACTIVE_LOW>; + linux,code = <BTN_0>; + }; + + user-pb1x { + label = "user_pb1x"; + linux,code = <BTN_1>; + interrupt-parent = <&gsc>; + interrupts = <0>; + }; + + key-erased { + label = "key_erased"; + linux,code = <BTN_2>; + interrupt-parent = <&gsc>; + interrupts = <1>; + }; + + eeprom-wp { + label = "eeprom_wp"; + linux,code = <BTN_3>; + interrupt-parent = <&gsc>; + interrupts = <2>; + }; + + tamper { + label = "tamper"; + linux,code = <BTN_4>; + interrupt-parent = <&gsc>; + interrupts = <5>; + }; + + switch-hold { + label = "switch_hold"; + linux,code = <BTN_5>; + interrupt-parent = <&gsc>; + interrupts = <7>; + }; + }; + + led-controller { + compatible = "gpio-leds"; + pinctrl-names = "default"; + pinctrl-0 = <&pinctrl_gpio_leds>; + + led-0 { + function = LED_FUNCTION_STATUS; + color = <LED_COLOR_ID_GREEN>; + label = "panel1"; + gpios = <&gpio3 21 GPIO_ACTIVE_LOW>; + default-state = "off"; + }; + + led-1 { + function = LED_FUNCTION_STATUS; + color = <LED_COLOR_ID_GREEN>; + label = "panel2"; + gpios = <&gpio3 23 GPIO_ACTIVE_LOW>; + default-state = "off"; + }; + + led-2 { + function = LED_FUNCTION_STATUS; + color = <LED_COLOR_ID_GREEN>; + label = "panel3"; + gpios = <&gpio3 22 GPIO_ACTIVE_LOW>; + default-state = "off"; + }; + + led-3 { + function = LED_FUNCTION_STATUS; + color = <LED_COLOR_ID_GREEN>; + label = "panel4"; + gpios = <&gpio3 20 GPIO_ACTIVE_LOW>; + default-state = "off"; + }; + + led-4 { + function = LED_FUNCTION_STATUS; + color = <LED_COLOR_ID_GREEN>; + label = "panel5"; + gpios = <&gpio3 25 GPIO_ACTIVE_LOW>; + default-state = "off"; + }; + }; + + pps { + compatible = "pps-gpio"; + pinctrl-names = "default"; + pinctrl-0 = <&pinctrl_pps>; + gpios = <&gpio3 24 GPIO_ACTIVE_HIGH>; + status = "okay"; + }; + + reg_3p3v: regulator-3p3v { + compatible = "regulator-fixed"; + regulator-name = "3P3V"; + regulator-min-microvolt = <3300000>; + regulator-max-microvolt = <3300000>; + }; + + reg_usb1_vbus: regulator-usb1 { + pinctrl-names = "default"; + pinctrl-0 = <&pinctrl_reg_usb1>; + compatible = "regulator-fixed"; + regulator-name = "usb_usb1_vbus"; + gpio = <&gpio2 7 GPIO_ACTIVE_HIGH>; + enable-active-high; + regulator-min-microvolt = <5000000>; + regulator-max-microvolt = <5000000>; + }; + + reg_wifi: regulator-wifi { + pinctrl-names = "default"; + pinctrl-0 = <&pinctrl_reg_wl>; + compatible = "regulator-fixed"; + regulator-name = "wifi"; + gpio = <&gpio2 19 GPIO_ACTIVE_HIGH>; + enable-active-high; + startup-delay-us = <100>; + regulator-min-microvolt = <3300000>; + regulator-max-microvolt = <3300000>; + }; +}; + +&A53_0 { + cpu-supply = <&buck2>; +}; + +&A53_1 { + cpu-supply = <&buck2>; +}; + +&A53_2 { + cpu-supply = <&buck2>; +}; + +&A53_3 { + cpu-supply = <&buck2>; +}; + +&ddrc { + operating-points-v2 = <&ddrc_opp_table>; + + ddrc_opp_table: opp-table { + compatible = "operating-points-v2"; + + opp-25M { + opp-hz = /bits/ 64 <25000000>; + }; + + opp-100M { + opp-hz = /bits/ 64 <100000000>; + }; + + opp-750M { + opp-hz = /bits/ 64 <750000000>; + }; + }; +}; + +&ecspi1 { + pinctrl-names = "default"; + pinctrl-0 = <&pinctrl_spi1>; + cs-gpios = <&gpio5 9 GPIO_ACTIVE_LOW>; + status = "okay"; + + can@0 { + compatible = "microchip,mcp2515"; + reg = <0>; + clocks = <&can20m>; + oscillator-frequency = <20000000>; + interrupt-parent = <&gpio2>; + interrupts = <3 IRQ_TYPE_LEVEL_LOW>; + spi-max-frequency = <10000000>; + }; +}; + +/* off-board header */ +&ecspi2 { + pinctrl-names = "default"; + pinctrl-0 = <&pinctrl_spi2>; + cs-gpios = <&gpio5 13 GPIO_ACTIVE_LOW>; + status = "okay"; +}; + +&fec1 { + pinctrl-names = "default"; + pinctrl-0 = <&pinctrl_fec1>; + phy-mode = "rgmii-id"; + phy-handle = <ðphy0>; + local-mac-address = [00 00 00 00 00 00]; + status = "okay"; + + mdio { + #address-cells = <1>; + #size-cells = <0>; + + ethphy0: ethernet-phy@0 { + compatible = "ethernet-phy-ieee802.3-c22"; + reg = <0>; + ti,rx-internal-delay = <DP83867_RGMIIDCTL_2_00_NS>; + ti,tx-internal-delay = <DP83867_RGMIIDCTL_2_00_NS>; + tx-fifo-depth = <DP83867_PHYCR_FIFO_DEPTH_4_B_NIB>; + rx-fifo-depth = <DP83867_PHYCR_FIFO_DEPTH_4_B_NIB>; + }; + }; +}; + +&i2c1 { + clock-frequency = <100000>; + pinctrl-names = "default"; + pinctrl-0 = <&pinctrl_i2c1>; + status = "okay"; + + gsc: gsc@20 { + compatible = "gw,gsc"; + reg = <0x20>; + pinctrl-0 = <&pinctrl_gsc>; + interrupt-parent = <&gpio2>; + interrupts = <6 IRQ_TYPE_EDGE_FALLING>; + interrupt-controller; + #interrupt-cells = <1>; + + adc { + compatible = "gw,gsc-adc"; + #address-cells = <1>; + #size-cells = <0>; + + channel@6 { + gw,mode = <0>; + reg = <0x06>; + label = "temp"; + }; + + channel@8 { + gw,mode = <1>; + reg = <0x08>; + label = "vdd_bat"; + }; + + channel@82 { + gw,mode = <2>; + reg = <0x82>; + label = "vin"; + gw,voltage-divider-ohms = <22100 1000>; + gw,voltage-offset-microvolt = <700000>; + }; + + channel@84 { + gw,mode = <2>; + reg = <0x84>; + label = "vin_4p0"; + gw,voltage-divider-ohms = <10000 10000>; + }; + + channel@86 { + gw,mode = <2>; + reg = <0x86>; + label = "vdd_3p3"; + gw,voltage-divider-ohms = <10000 10000>; + }; + + channel@88 { + gw,mode = <2>; + reg = <0x88>; + label = "vdd_0p9"; + }; + + channel@8c { + gw,mode = <2>; + reg = <0x8c>; + label = "vdd_soc"; + }; + + channel@8e { + gw,mode = <2>; + reg = <0x8e>; + label = "vdd_arm"; + }; + + channel@90 { + gw,mode = <2>; + reg = <0x90>; + label = "vdd_1p8"; + }; + + channel@92 { + gw,mode = <2>; + reg = <0x92>; + label = "vdd_dram"; + }; + + channel@98 { + gw,mode = <2>; + reg = <0x98>; + label = "vdd_1p0"; + }; + + channel@9a { + gw,mode = <2>; + reg = <0x9a>; + label = "vdd_2p5"; + gw,voltage-divider-ohms = <10000 10000>; + }; + + channel@a2 { + gw,mode = <2>; + reg = <0xa2>; + label = "vdd_gsc"; + gw,voltage-divider-ohms = <10000 10000>; + }; + }; + }; + + gpio: gpio@23 { + compatible = "nxp,pca9555"; + reg = <0x23>; + gpio-controller; + #gpio-cells = <2>; + interrupt-parent = <&gsc>; + interrupts = <4>; + }; + + pmic@4b { + compatible = "rohm,bd71847"; + reg = <0x4b>; + pinctrl-names = "default"; + pinctrl-0 = <&pinctrl_pmic>; + interrupt-parent = <&gpio3>; + interrupts = <8 IRQ_TYPE_LEVEL_LOW>; + rohm,reset-snvs-powered; + #clock-cells = <0>; + clocks = <&osc_32k 0>; + clock-output-names = "clk-32k-out"; + + regulators { + /* vdd_soc: 0.805-0.900V (typ=0.8V) */ + BUCK1 { + regulator-name = "buck1"; + regulator-min-microvolt = <700000>; + regulator-max-microvolt = <1300000>; + regulator-boot-on; + regulator-always-on; + regulator-ramp-delay = <1250>; + }; + + /* vdd_arm: 0.805-1.0V (typ=0.9V) */ + buck2: BUCK2 { + regulator-name = "buck2"; + regulator-min-microvolt = <700000>; + regulator-max-microvolt = <1300000>; + regulator-boot-on; + regulator-always-on; + regulator-ramp-delay = <1250>; + rohm,dvs-run-voltage = <1000000>; + rohm,dvs-idle-voltage = <900000>; + }; + + /* vdd_0p9: 0.805-1.0V (typ=0.9V) */ + BUCK3 { + regulator-name = "buck3"; + regulator-min-microvolt = <700000>; + regulator-max-microvolt = <1350000>; + regulator-boot-on; + regulator-always-on; + }; + + /* vdd_3p3 */ + BUCK4 { + regulator-name = "buck4"; + regulator-min-microvolt = <3000000>; + regulator-max-microvolt = <3300000>; + regulator-boot-on; + regulator-always-on; + }; + + /* vdd_1p8 */ + BUCK5 { + regulator-name = "buck5"; + regulator-min-microvolt = <1605000>; + regulator-max-microvolt = <1995000>; + regulator-boot-on; + regulator-always-on; + }; + + /* vdd_dram */ + BUCK6 { + regulator-name = "buck6"; + regulator-min-microvolt = <800000>; + regulator-max-microvolt = <1400000>; + regulator-boot-on; + regulator-always-on; + }; + + /* nvcc_snvs_1p8 */ + LDO1 { + regulator-name = "ldo1"; + regulator-min-microvolt = <1600000>; + regulator-max-microvolt = <1900000>; + regulator-boot-on; + regulator-always-on; + }; + + /* vdd_snvs_0p8 */ + LDO2 { + regulator-name = "ldo2"; + regulator-min-microvolt = <800000>; + regulator-max-microvolt = <900000>; + regulator-boot-on; + regulator-always-on; + }; + + /* vdda_1p8 */ + LDO3 { + regulator-name = "ldo3"; + regulator-min-microvolt = <1800000>; + regulator-max-microvolt = <3300000>; + regulator-boot-on; + regulator-always-on; + }; + + LDO4 { + regulator-name = "ldo4"; + regulator-min-microvolt = <900000>; + regulator-max-microvolt = <1800000>; + regulator-boot-on; + regulator-always-on; + }; + + LDO6 { + regulator-name = "ldo6"; + regulator-min-microvolt = <900000>; + regulator-max-microvolt = <1800000>; + regulator-boot-on; + regulator-always-on; + }; + }; + }; + + eeprom@50 { + compatible = "atmel,24c02"; + reg = <0x50>; + pagesize = <16>; + }; + + eeprom@51 { + compatible = "atmel,24c02"; + reg = <0x51>; + pagesize = <16>; + }; + + eeprom@52 { + compatible = "atmel,24c02"; + reg = <0x52>; + pagesize = <16>; + }; + + eeprom@53 { + compatible = "atmel,24c02"; + reg = <0x53>; + pagesize = <16>; + }; + + rtc@68 { + compatible = "dallas,ds1672"; + reg = <0x68>; + }; +}; + +&i2c2 { + clock-frequency = <400000>; + pinctrl-names = "default"; + pinctrl-0 = <&pinctrl_i2c2>; + status = "okay"; + + accelerometer@19 { + pinctrl-names = "default"; + pinctrl-0 = <&pinctrl_accel>; + compatible = "st,lis2de12"; + reg = <0x19>; + st,drdy-int-pin = <1>; + interrupt-parent = <&gpio1>; + interrupts = <12 IRQ_TYPE_LEVEL_LOW>; + interrupt-names = "INT1"; + }; + + secure-element@60 { + compatible = "nxp,se050"; + reg = <0x60>; + }; +}; + +/* off-board header */ +&i2c3 { + clock-frequency = <400000>; + pinctrl-names = "default"; + pinctrl-0 = <&pinctrl_i2c3>; + status = "okay"; +}; + +/* off-board header */ +&i2c4 { + clock-frequency = <400000>; + pinctrl-names = "default"; + pinctrl-0 = <&pinctrl_i2c4>; + status = "okay"; +}; + +/* off-board header */ +&sai3 { + pinctrl-names = "default"; + pinctrl-0 = <&pinctrl_sai3>; + assigned-clocks = <&clk IMX8MN_CLK_SAI3>; + assigned-clock-parents = <&clk IMX8MN_AUDIO_PLL1_OUT>; + assigned-clock-rates = <24576000>; + status = "okay"; +}; + +/* RS232/RS485/RS422 selectable */ +&uart1 { + pinctrl-names = "default"; + pinctrl-0 = <&pinctrl_uart1>, <&pinctrl_uart1_gpio>; + status = "okay"; +}; + +/* RS232 console */ +&uart2 { + pinctrl-names = "default"; + pinctrl-0 = <&pinctrl_uart2>; + status = "okay"; +}; + +/* bluetooth HCI */ +&uart3 { + pinctrl-names = "default"; + pinctrl-0 = <&pinctrl_uart3>, <&pinctrl_uart3_gpio>; + rts-gpios = <&gpio2 1 GPIO_ACTIVE_LOW>; + cts-gpios = <&gpio2 0 GPIO_ACTIVE_LOW>; + status = "okay"; + + bluetooth { + compatible = "brcm,bcm4330-bt"; + shutdown-gpios = <&gpio2 12 GPIO_ACTIVE_HIGH>; + }; +}; + +/* LTE Cat M1/NB1/EGPRS modem or GPS (loading option) */ +&uart4 { + pinctrl-names = "default"; + pinctrl-0 = <&pinctrl_uart4>; + status = "okay"; +}; + +&usbotg1 { + dr_mode = "host"; + vbus-supply = <®_usb1_vbus>; + disable-over-current; + status = "okay"; +}; + +/* SDIO WiFi */ +&usdhc2 { + pinctrl-names = "default"; + pinctrl-0 = <&pinctrl_usdhc2>; + bus-width = <4>; + non-removable; + vmmc-supply = <®_wifi>; + status = "okay"; +}; + +/* eMMC */ +&usdhc3 { + pinctrl-names = "default", "state_100mhz", "state_200mhz"; + pinctrl-0 = <&pinctrl_usdhc3>; + pinctrl-1 = <&pinctrl_usdhc3_100mhz>; + pinctrl-2 = <&pinctrl_usdhc3_200mhz>; + bus-width = <8>; + non-removable; + status = "okay"; +}; + +&wdog1 { + pinctrl-names = "default"; + pinctrl-0 = <&pinctrl_wdog>; + fsl,ext-reset-output; + status = "okay"; +}; + +&iomuxc { + pinctrl-names = "default"; + pinctrl-0 = <&pinctrl_hog>; + + pinctrl_hog: hoggrp { + fsl,pins = < + MX8MN_IOMUXC_NAND_CE0_B_GPIO3_IO1 0x40000159 /* M2_GDIS# */ + MX8MN_IOMUXC_GPIO1_IO13_GPIO1_IO13 0x40000041 /* M2_RST# */ + MX8MN_IOMUXC_NAND_DATA01_GPIO3_IO7 0x40000119 /* M2_OFF# */ + MX8MN_IOMUXC_GPIO1_IO15_GPIO1_IO15 0x40000159 /* M2_WDIS# */ + MX8MN_IOMUXC_SAI2_RXFS_GPIO4_IO21 0x40000041 /* APP GPIO1 */ + MX8MN_IOMUXC_SAI2_MCLK_GPIO4_IO27 0x40000041 /* APP GPIO2 */ + MX8MN_IOMUXC_SD1_DATA6_GPIO2_IO8 0x40000041 /* UART2_EN# */ + MX8MN_IOMUXC_SAI3_RXFS_GPIO4_IO28 0x40000041 /* MIPI_GPIO1 */ + MX8MN_IOMUXC_SPDIF_EXT_CLK_GPIO5_IO5 0x40000041 /* MIPI_GPIO2 */ + MX8MN_IOMUXC_SPDIF_RX_GPIO5_IO4 0x40000041 /* MIPI_GPIO3/PWM2 */ + MX8MN_IOMUXC_SPDIF_TX_GPIO5_IO3 0x40000041 /* MIPI_GPIO4/PWM3 */ + >; + }; + + pinctrl_accel: accelgrp { + fsl,pins = < + MX8MN_IOMUXC_GPIO1_IO12_GPIO1_IO12 0x159 + >; + }; + + pinctrl_fec1: fec1grp { + fsl,pins = < + MX8MN_IOMUXC_ENET_MDC_ENET1_MDC 0x3 + MX8MN_IOMUXC_ENET_MDIO_ENET1_MDIO 0x3 + MX8MN_IOMUXC_ENET_TD3_ENET1_RGMII_TD3 0x1f + MX8MN_IOMUXC_ENET_TD2_ENET1_RGMII_TD2 0x1f + MX8MN_IOMUXC_ENET_TD1_ENET1_RGMII_TD1 0x1f + MX8MN_IOMUXC_ENET_TD0_ENET1_RGMII_TD0 0x1f + MX8MN_IOMUXC_ENET_RD3_ENET1_RGMII_RD3 0x91 + MX8MN_IOMUXC_ENET_RD2_ENET1_RGMII_RD2 0x91 + MX8MN_IOMUXC_ENET_RD1_ENET1_RGMII_RD1 0x91 + MX8MN_IOMUXC_ENET_RD0_ENET1_RGMII_RD0 0x91 + MX8MN_IOMUXC_ENET_TXC_ENET1_RGMII_TXC 0x1f + MX8MN_IOMUXC_ENET_RXC_ENET1_RGMII_RXC 0x91 + MX8MN_IOMUXC_ENET_RX_CTL_ENET1_RGMII_RX_CTL 0x91 + MX8MN_IOMUXC_ENET_TX_CTL_ENET1_RGMII_TX_CTL 0x1f + MX8MN_IOMUXC_GPIO1_IO10_GPIO1_IO10 0x19 /* RST# */ + MX8MN_IOMUXC_GPIO1_IO11_GPIO1_IO11 0x19 /* IRQ# */ + MX8MN_IOMUXC_GPIO1_IO08_ENET1_1588_EVENT0_IN 0x141 + MX8MN_IOMUXC_GPIO1_IO09_ENET1_1588_EVENT0_OUT 0x141 + >; + }; + + pinctrl_gsc: gscgrp { + fsl,pins = < + MX8MN_IOMUXC_SD1_DATA4_GPIO2_IO6 0x40 + >; + }; + + pinctrl_i2c1: i2c1grp { + fsl,pins = < + MX8MN_IOMUXC_I2C1_SCL_I2C1_SCL 0x400001c3 + MX8MN_IOMUXC_I2C1_SDA_I2C1_SDA 0x400001c3 + >; + }; + + pinctrl_i2c2: i2c2grp { + fsl,pins = < + MX8MN_IOMUXC_I2C2_SCL_I2C2_SCL 0x400001c3 + MX8MN_IOMUXC_I2C2_SDA_I2C2_SDA 0x400001c3 + >; + }; + + pinctrl_i2c3: i2c3grp { + fsl,pins = < + MX8MN_IOMUXC_I2C3_SCL_I2C3_SCL 0x400001c3 + MX8MN_IOMUXC_I2C3_SDA_I2C3_SDA 0x400001c3 + >; + }; + + pinctrl_i2c4: i2c4grp { + fsl,pins = < + MX8MN_IOMUXC_I2C4_SCL_I2C4_SCL 0x400001c3 + MX8MN_IOMUXC_I2C4_SDA_I2C4_SDA 0x400001c3 + >; + }; + + pinctrl_gpio_leds: gpioledgrp { + fsl,pins = < + MX8MN_IOMUXC_SAI5_RXD0_GPIO3_IO21 0x40000019 + MX8MN_IOMUXC_SAI5_RXD2_GPIO3_IO23 0x40000019 + MX8MN_IOMUXC_SAI5_RXD1_GPIO3_IO22 0x40000019 + MX8MN_IOMUXC_SAI5_RXC_GPIO3_IO20 0x40000019 + MX8MN_IOMUXC_SAI5_MCLK_GPIO3_IO25 0x40000019 + >; + }; + + pinctrl_pmic: pmicgrp { + fsl,pins = < + MX8MN_IOMUXC_NAND_DATA02_GPIO3_IO8 0x41 + >; + }; + + pinctrl_pps: ppsgrp { + fsl,pins = < + MX8MN_IOMUXC_SAI5_RXD3_GPIO3_IO24 0x141 /* PPS */ + >; + }; + + pinctrl_reg_wl: regwlgrp { + fsl,pins = < + MX8MN_IOMUXC_SD2_RESET_B_GPIO2_IO19 0x41 /* WLAN_WLON */ + >; + }; + + pinctrl_reg_usb1: regusb1grp { + fsl,pins = < + MX8MN_IOMUXC_SD1_DATA5_GPIO2_IO7 0x41 + >; + }; + + pinctrl_sai3: sai3grp { + fsl,pins = < + MX8MN_IOMUXC_SAI3_MCLK_SAI3_MCLK 0xd6 + MX8MN_IOMUXC_SAI3_RXD_SAI3_RX_DATA0 0xd6 + MX8MN_IOMUXC_SAI3_TXC_SAI3_TX_BCLK 0xd6 + MX8MN_IOMUXC_SAI3_TXD_SAI3_TX_DATA0 0xd6 + MX8MN_IOMUXC_SAI3_TXFS_SAI3_TX_SYNC 0xd6 + >; + }; + + pinctrl_spi1: spi1grp { + fsl,pins = < + MX8MN_IOMUXC_ECSPI1_SCLK_ECSPI1_SCLK 0x82 + MX8MN_IOMUXC_ECSPI1_MOSI_ECSPI1_MOSI 0x82 + MX8MN_IOMUXC_ECSPI1_MISO_ECSPI1_MISO 0x82 + MX8MN_IOMUXC_ECSPI1_SS0_GPIO5_IO9 0x40 + MX8MN_IOMUXC_SD1_DATA1_GPIO2_IO3 0x140 /* CAN_IRQ# */ + >; + }; + + pinctrl_spi2: spi2grp { + fsl,pins = < + MX8MN_IOMUXC_ECSPI2_SCLK_ECSPI2_SCLK 0x82 + MX8MN_IOMUXC_ECSPI2_MOSI_ECSPI2_MOSI 0x82 + MX8MN_IOMUXC_ECSPI2_MISO_ECSPI2_MISO 0x82 + MX8MN_IOMUXC_ECSPI2_SS0_GPIO5_IO13 0x40 /* SS0 */ + >; + }; + + pinctrl_uart1: uart1grp { + fsl,pins = < + MX8MN_IOMUXC_UART1_RXD_UART1_DCE_RX 0x140 + MX8MN_IOMUXC_UART1_TXD_UART1_DCE_TX 0x140 + >; + }; + + pinctrl_uart1_gpio: uart1gpiogrp { + fsl,pins = < + MX8MN_IOMUXC_SAI2_TXD0_GPIO4_IO26 0x40000110 /* HALF */ + MX8MN_IOMUXC_SAI2_TXC_GPIO4_IO25 0x40000110 /* TERM */ + MX8MN_IOMUXC_SAI2_RXD0_GPIO4_IO23 0x40000110 /* RS485 */ + >; + }; + + pinctrl_uart2: uart2grp { + fsl,pins = < + MX8MN_IOMUXC_UART2_RXD_UART2_DCE_RX 0x140 + MX8MN_IOMUXC_UART2_TXD_UART2_DCE_TX 0x140 + >; + }; + + pinctrl_uart3_gpio: uart3_gpiogrp { + fsl,pins = < + MX8MN_IOMUXC_SD2_CD_B_GPIO2_IO12 0x41 /* BT_EN# */ + >; + }; + + pinctrl_uart3: uart3grp { + fsl,pins = < + MX8MN_IOMUXC_UART3_RXD_UART3_DCE_RX 0x140 + MX8MN_IOMUXC_UART3_TXD_UART3_DCE_TX 0x140 + MX8MN_IOMUXC_SD1_CLK_GPIO2_IO0 0x140 /* CTS */ + MX8MN_IOMUXC_SD1_CMD_GPIO2_IO1 0x140 /* RTS */ + >; + }; + + pinctrl_uart4: uart4grp { + fsl,pins = < + MX8MN_IOMUXC_UART4_RXD_UART4_DCE_RX 0x140 + MX8MN_IOMUXC_UART4_TXD_UART4_DCE_TX 0x140 + MX8MN_IOMUXC_GPIO1_IO06_GPIO1_IO6 0x141 /* GNSS_GASP */ + >; + }; + + pinctrl_usdhc2: usdhc2grp { + fsl,pins = < + MX8MN_IOMUXC_SD2_CLK_USDHC2_CLK 0x190 + MX8MN_IOMUXC_SD2_CMD_USDHC2_CMD 0x1d0 + MX8MN_IOMUXC_SD2_DATA0_USDHC2_DATA0 0x1d0 + MX8MN_IOMUXC_SD2_DATA1_USDHC2_DATA1 0x1d0 + MX8MN_IOMUXC_SD2_DATA2_USDHC2_DATA2 0x1d0 + MX8MN_IOMUXC_SD2_DATA3_USDHC2_DATA3 0x1d0 + >; + }; + + pinctrl_usdhc3: usdhc3grp { + fsl,pins = < + MX8MN_IOMUXC_NAND_WE_B_USDHC3_CLK 0x190 + MX8MN_IOMUXC_NAND_WP_B_USDHC3_CMD 0x1d0 + MX8MN_IOMUXC_NAND_DATA04_USDHC3_DATA0 0x1d0 + MX8MN_IOMUXC_NAND_DATA05_USDHC3_DATA1 0x1d0 + MX8MN_IOMUXC_NAND_DATA06_USDHC3_DATA2 0x1d0 + MX8MN_IOMUXC_NAND_DATA07_USDHC3_DATA3 0x1d0 + MX8MN_IOMUXC_NAND_RE_B_USDHC3_DATA4 0x1d0 + MX8MN_IOMUXC_NAND_CE2_B_USDHC3_DATA5 0x1d0 + MX8MN_IOMUXC_NAND_CE3_B_USDHC3_DATA6 0x1d0 + MX8MN_IOMUXC_NAND_CLE_USDHC3_DATA7 0x1d0 + MX8MN_IOMUXC_NAND_CE1_B_USDHC3_STROBE 0x190 + >; + }; + + pinctrl_usdhc3_100mhz: usdhc3-100mhzgrp { + fsl,pins = < + MX8MN_IOMUXC_NAND_WE_B_USDHC3_CLK 0x194 + MX8MN_IOMUXC_NAND_WP_B_USDHC3_CMD 0x1d4 + MX8MN_IOMUXC_NAND_DATA04_USDHC3_DATA0 0x1d4 + MX8MN_IOMUXC_NAND_DATA05_USDHC3_DATA1 0x1d4 + MX8MN_IOMUXC_NAND_DATA06_USDHC3_DATA2 0x1d4 + MX8MN_IOMUXC_NAND_DATA07_USDHC3_DATA3 0x1d4 + MX8MN_IOMUXC_NAND_RE_B_USDHC3_DATA4 0x1d4 + MX8MN_IOMUXC_NAND_CE2_B_USDHC3_DATA5 0x1d4 + MX8MN_IOMUXC_NAND_CE3_B_USDHC3_DATA6 0x1d4 + MX8MN_IOMUXC_NAND_CLE_USDHC3_DATA7 0x1d4 + MX8MN_IOMUXC_NAND_CE1_B_USDHC3_STROBE 0x194 + >; + }; + + pinctrl_usdhc3_200mhz: usdhc3-200mhzgrp { + fsl,pins = < + MX8MN_IOMUXC_NAND_WE_B_USDHC3_CLK 0x196 + MX8MN_IOMUXC_NAND_WP_B_USDHC3_CMD 0x1d6 + MX8MN_IOMUXC_NAND_DATA04_USDHC3_DATA0 0x1d6 + MX8MN_IOMUXC_NAND_DATA05_USDHC3_DATA1 0x1d6 + MX8MN_IOMUXC_NAND_DATA06_USDHC3_DATA2 0x1d6 + MX8MN_IOMUXC_NAND_DATA07_USDHC3_DATA3 0x1d6 + MX8MN_IOMUXC_NAND_RE_B_USDHC3_DATA4 0x1d6 + MX8MN_IOMUXC_NAND_CE2_B_USDHC3_DATA5 0x1d6 + MX8MN_IOMUXC_NAND_CE3_B_USDHC3_DATA6 0x1d6 + MX8MN_IOMUXC_NAND_CLE_USDHC3_DATA7 0x1d6 + MX8MN_IOMUXC_NAND_CE1_B_USDHC3_STROBE 0x196 + >; + }; + + pinctrl_wdog: wdoggrp { + fsl,pins = < + MX8MN_IOMUXC_GPIO1_IO02_WDOG1_WDOG_B 0xc6 + >; + }; +}; diff --git a/arch/arm/dts/imx8mn-venice-u-boot.dtsi b/arch/arm/dts/imx8mn-venice-u-boot.dtsi new file mode 100644 index 0000000000..77b1663be1 --- /dev/null +++ b/arch/arm/dts/imx8mn-venice-u-boot.dtsi @@ -0,0 +1,222 @@ +// SPDX-License-Identifier: GPL-2.0+ +/* + * Copyright 2021 Gateworks Corporation + */ + +/ { + binman: binman { + multiple-images; + }; + + wdt-reboot { + compatible = "wdt-reboot"; + wdt = <&wdog1>; + u-boot,dm-spl; + }; +}; + +&{/soc@0} { + u-boot,dm-pre-reloc; + u-boot,dm-spl; +}; + +&clk { + u-boot,dm-spl; + u-boot,dm-pre-reloc; + /delete-property/ assigned-clocks; + /delete-property/ assigned-clock-parents; + /delete-property/ assigned-clock-rates; +}; + +&osc_24m { + u-boot,dm-spl; + u-boot,dm-pre-reloc; +}; + +&aips1 { + u-boot,dm-spl; + u-boot,dm-pre-reloc; +}; + +&aips2 { + u-boot,dm-spl; +}; + +&aips3 { + u-boot,dm-spl; +}; + +&iomuxc { + u-boot,dm-spl; +}; + +&gpio1 { + u-boot,dm-spl; +}; + +&gpio2 { + u-boot,dm-spl; +}; + +&gpio3 { + u-boot,dm-spl; +}; + +&gpio4 { + u-boot,dm-spl; +}; + +&gpio5 { + u-boot,dm-spl; +}; + +&uart2 { + u-boot,dm-spl; +}; + +&pinctrl_uart2 { + u-boot,dm-spl; +}; + +&usdhc3 { + u-boot,dm-spl; +}; + +&pinctrl_usdhc3 { + u-boot,dm-spl; +}; + +&i2c1 { + u-boot,dm-spl; +}; + +&pinctrl_i2c1 { + u-boot,dm-spl; +}; + +&i2c2 { + u-boot,dm-spl; +}; + +&pinctrl_i2c2 { + u-boot,dm-spl; +}; + +&wdog1 { + u-boot,dm-spl; +}; + +&binman { + u-boot-spl-ddr { + filename = "u-boot-spl-ddr.bin"; + pad-byte = <0xff>; + align-size = <4>; + align = <4>; + + u-boot-spl { + align-end = <4>; + }; + + blob_1: blob-ext@1 { + filename = "lpddr4_pmu_train_1d_imem.bin"; + size = <0x8000>; + }; + + blob_2: blob-ext@2 { + filename = "lpddr4_pmu_train_1d_dmem.bin"; + size = <0x4000>; + }; + + blob_3: blob-ext@3 { + filename = "lpddr4_pmu_train_2d_imem.bin"; + size = <0x8000>; + }; + + blob_4: blob-ext@4 { + filename = "lpddr4_pmu_train_2d_dmem.bin"; + size = <0x4000>; + }; + }; + + spl { + filename = "spl.bin"; + + mkimage { + args = "-n spl/u-boot-spl.cfgout -T imx8mimage -e 0x912000"; + + blob { + filename = "u-boot-spl-ddr.bin"; + }; + }; + }; + + itb { + filename = "u-boot.itb"; + + fit { + description = "Configuration to load ATF before U-Boot"; + #address-cells = <1>; + fit,external-offset = <CONFIG_FIT_EXTERNAL_OFFSET>; + fit,fdt-list = "of-list"; + + images { + uboot { + description = "U-Boot (64-bit)"; + type = "standalone"; + arch = "arm64"; + compression = "none"; + load = <CONFIG_SYS_TEXT_BASE>; + + uboot_blob: blob-ext { + filename = "u-boot-nodtb.bin"; + }; + }; + + atf { + description = "ARM Trusted Firmware"; + type = "firmware"; + arch = "arm64"; + compression = "none"; + load = <0x960000>; + entry = <0x960000>; + + atf_blob: blob-ext { + filename = "bl31.bin"; + }; + }; + + @fdt-SEQ { + description = "NAME"; + type = "flat_dt"; + compression = "none"; + }; + }; + + configurations { + default = "@config-DEFAULT-SEQ"; + + @config-SEQ { + description = "NAME"; + firmware = "uboot"; + loadables = "atf"; + fdt = "fdt-SEQ"; + }; + }; + }; + }; + + imx-boot { + filename = "flash.bin"; + pad-byte = <0x00>; + + spl: blob-ext@1 { + filename = "spl.bin"; + offset = <0x0>; + }; + + uboot: blob-ext@2 { + filename = "u-boot.itb"; + offset = <0x58000>; + }; + }; +}; diff --git a/arch/arm/dts/imx8mn-venice.dts b/arch/arm/dts/imx8mn-venice.dts new file mode 100644 index 0000000000..989f3ded4a --- /dev/null +++ b/arch/arm/dts/imx8mn-venice.dts @@ -0,0 +1,152 @@ +// SPDX-License-Identifier: GPL-2.0+ +/* + * Copyright 2021 Gateworks Corporation + */ + +/dts-v1/; + +#include "imx8mn.dtsi" + +/ { + model = "Gateworks Venice i.MX8MM board"; + compatible = "gw,imx8mn-venice", "fsl,imx8mn"; + + chosen { + stdout-path = &uart2; + }; + + memory@40000000 { + device_type = "memory"; + reg = <0x0 0x40000000 0 0x80000000>; + }; +}; + +&i2c1 { + clock-frequency = <100000>; + pinctrl-names = "default"; + pinctrl-0 = <&pinctrl_i2c1>; + status = "okay"; + + eeprom@51 { + compatible = "atmel,24c02"; + reg = <0x51>; + pagesize = <16>; + }; +}; + +&i2c2 { + clock-frequency = <400000>; + pinctrl-names = "default"; + pinctrl-0 = <&pinctrl_i2c2>; + status = "okay"; + + eeprom@52 { + compatible = "atmel,24c32"; + reg = <0x52>; + pagesize = <32>; + }; +}; + +/* console */ +&uart2 { + pinctrl-names = "default"; + pinctrl-0 = <&pinctrl_uart2>; + status = "okay"; +}; + +/* eMMC */ +&usdhc3 { + assigned-clocks = <&clk IMX8MN_CLK_USDHC3_ROOT>; + assigned-clock-rates = <400000000>; + pinctrl-names = "default", "state_100mhz", "state_200mhz"; + pinctrl-0 = <&pinctrl_usdhc3>; + pinctrl-1 = <&pinctrl_usdhc3_100mhz>; + pinctrl-2 = <&pinctrl_usdhc3_200mhz>; + bus-width = <8>; + non-removable; + status = "okay"; +}; + +&wdog1 { + pinctrl-names = "default"; + pinctrl-0 = <&pinctrl_wdog>; + fsl,ext-reset-output; + status = "okay"; +}; + +&iomuxc { + pinctrl_i2c1: i2c1grp { + fsl,pins = < + MX8MN_IOMUXC_I2C1_SCL_I2C1_SCL 0x400001c3 + MX8MN_IOMUXC_I2C1_SDA_I2C1_SDA 0x400001c3 + >; + }; + + pinctrl_i2c2: i2c2grp { + fsl,pins = < + MX8MN_IOMUXC_I2C2_SCL_I2C2_SCL 0x400001c3 + MX8MN_IOMUXC_I2C2_SDA_I2C2_SDA 0x400001c3 + >; + }; + + pinctrl_uart2: uart2grp { + fsl,pins = < + MX8MN_IOMUXC_UART2_RXD_UART2_DCE_RX 0x140 + MX8MN_IOMUXC_UART2_TXD_UART2_DCE_TX 0x140 + >; + }; + + pinctrl_usdhc3: usdhc3grp { + fsl,pins = < + MX8MN_IOMUXC_NAND_WE_B_USDHC3_CLK 0x190 + MX8MN_IOMUXC_NAND_WP_B_USDHC3_CMD 0x1d0 + MX8MN_IOMUXC_NAND_DATA04_USDHC3_DATA0 0x1d0 + MX8MN_IOMUXC_NAND_DATA05_USDHC3_DATA1 0x1d0 + MX8MN_IOMUXC_NAND_DATA06_USDHC3_DATA2 0x1d0 + MX8MN_IOMUXC_NAND_DATA07_USDHC3_DATA3 0x1d0 + MX8MN_IOMUXC_NAND_RE_B_USDHC3_DATA4 0x1d0 + MX8MN_IOMUXC_NAND_CE2_B_USDHC3_DATA5 0x1d0 + MX8MN_IOMUXC_NAND_CE3_B_USDHC3_DATA6 0x1d0 + MX8MN_IOMUXC_NAND_CLE_USDHC3_DATA7 0x1d0 + MX8MN_IOMUXC_NAND_CE1_B_USDHC3_STROBE 0x190 + >; + }; + + pinctrl_usdhc3_100mhz: usdhc3grp100mhz { + fsl,pins = < + MX8MN_IOMUXC_NAND_WE_B_USDHC3_CLK 0x194 + MX8MN_IOMUXC_NAND_WP_B_USDHC3_CMD 0x1d4 + MX8MN_IOMUXC_NAND_DATA04_USDHC3_DATA0 0x1d4 + MX8MN_IOMUXC_NAND_DATA05_USDHC3_DATA1 0x1d4 + MX8MN_IOMUXC_NAND_DATA06_USDHC3_DATA2 0x1d4 + MX8MN_IOMUXC_NAND_DATA07_USDHC3_DATA3 0x1d4 + MX8MN_IOMUXC_NAND_RE_B_USDHC3_DATA4 0x1d4 + MX8MN_IOMUXC_NAND_CE2_B_USDHC3_DATA5 0x1d4 + MX8MN_IOMUXC_NAND_CE3_B_USDHC3_DATA6 0x1d4 + MX8MN_IOMUXC_NAND_CLE_USDHC3_DATA7 0x1d4 + MX8MN_IOMUXC_NAND_CE1_B_USDHC3_STROBE 0x194 + >; + }; + + pinctrl_usdhc3_200mhz: usdhc3grp200mhz { + fsl,pins = < + MX8MN_IOMUXC_NAND_WE_B_USDHC3_CLK 0x196 + MX8MN_IOMUXC_NAND_WP_B_USDHC3_CMD 0x1d6 + MX8MN_IOMUXC_NAND_DATA04_USDHC3_DATA0 0x1d6 + MX8MN_IOMUXC_NAND_DATA05_USDHC3_DATA1 0x1d6 + MX8MN_IOMUXC_NAND_DATA06_USDHC3_DATA2 0x1d6 + MX8MN_IOMUXC_NAND_DATA07_USDHC3_DATA3 0x1d6 + MX8MN_IOMUXC_NAND_RE_B_USDHC3_DATA4 0x1d6 + MX8MN_IOMUXC_NAND_CE2_B_USDHC3_DATA5 0x1d6 + MX8MN_IOMUXC_NAND_CE3_B_USDHC3_DATA6 0x1d6 + MX8MN_IOMUXC_NAND_CLE_USDHC3_DATA7 0x1d6 + MX8MN_IOMUXC_NAND_CE1_B_USDHC3_STROBE 0x196 + >; + }; + + pinctrl_wdog: wdoggrp { + fsl,pins = < + MX8MN_IOMUXC_GPIO1_IO02_WDOG1_WDOG_B 0xc6 + >; + }; +}; diff --git a/arch/arm/mach-imx/imx8m/Kconfig b/arch/arm/mach-imx/imx8m/Kconfig index 43901f15d2..3960f8817b 100644 --- a/arch/arm/mach-imx/imx8m/Kconfig +++ b/arch/arm/mach-imx/imx8m/Kconfig @@ -90,6 +90,13 @@ config TARGET_IMX8MN_DDR4_EVK select SUPPORT_SPL select IMX8M_DDR4
+config TARGET_IMX8MN_VENICE + bool "Support Gateworks Venice iMX8M Nano module" + select BINMAN + select IMX8MN + select SUPPORT_SPL + select IMX8M_LPDDR4 + config TARGET_IMX8MP_EVK bool "imx8mp LPDDR4 EVK board" select BINMAN diff --git a/board/gateworks/venice/Kconfig b/board/gateworks/venice/Kconfig index 687b94f24d..3034275ac2 100644 --- a/board/gateworks/venice/Kconfig +++ b/board/gateworks/venice/Kconfig @@ -12,3 +12,18 @@ config SYS_CONFIG_NAME config IMX_CONFIG default "board/gateworks/venice/imximage-8mm-lpddr4.cfg" endif + +if TARGET_IMX8MN_VENICE + +config SYS_BOARD + default "venice" + +config SYS_VENDOR + default "gateworks" + +config SYS_CONFIG_NAME + default "imx8mn_venice" + +config IMX_CONFIG + default "board/gateworks/venice/imximage-8mn-lpddr4.cfg" +endif diff --git a/board/gateworks/venice/MAINTAINERS b/board/gateworks/venice/MAINTAINERS index 07b9e2a60f..cfdea0cb8a 100644 --- a/board/gateworks/venice/MAINTAINERS +++ b/board/gateworks/venice/MAINTAINERS @@ -1,7 +1,7 @@ i.MX8MM Venice M: Tim Harvey tharvey@gateworks.com S: Maintained -F: arch/arm/dts/imx8mm-venice* +F: arch/arm/dts/imx8m*-venice* F: board/gateworks/venice/ -F: include/configs/venice.h -F: configs/imx8mm_venice_defconfig +F: include/configs/imx8m*_venice.h +F: configs/imx8m*_venice_defconfig diff --git a/board/gateworks/venice/Makefile b/board/gateworks/venice/Makefile index 08f5c62db7..4ef8ae9188 100644 --- a/board/gateworks/venice/Makefile +++ b/board/gateworks/venice/Makefile @@ -4,9 +4,15 @@ # SPDX-License-Identifier: GPL-2.0+ #
-obj-y += imx8mm_venice.o gsc.o +obj-y += venice.o gsc.o
ifdef CONFIG_SPL_BUILD obj-y += spl.o -obj-$(CONFIG_IMX8M_LPDDR4) += lpddr4_timing.o +ifdef CONFIG_IMX8MM +obj-$(CONFIG_IMX8M_LPDDR4) += lpddr4_timing_imx8mm.o +endif +ifdef CONFIG_IMX8MN +obj-$(CONFIG_IMX8M_LPDDR4) += lpddr4_timing_imx8mn_2gb_dual_die.o +obj-$(CONFIG_IMX8M_LPDDR4) += lpddr4_timing_imx8mn_2gb_single_die.o +endif endif diff --git a/board/gateworks/venice/README b/board/gateworks/venice/README index 773cc09e87..9f3a250bb6 100644 --- a/board/gateworks/venice/README +++ b/board/gateworks/venice/README @@ -31,4 +31,5 @@ Update eMMC =========== => tftpboot $loadaddr flash.bin => setexpr blkcnt $filesize + 0x1ff && setexpr blkcnt $blkcnt / 0x200 -=> mmc dev 2 && mmc write $loadaddr 0x42 $blkcnt +=> mmc dev 2 && mmc write $loadaddr 0x42 $blkcnt # for IMX8MM +=> mmc dev 2 && mmc write $loadaddr 0x40 $blkcnt # for IMX8MN diff --git a/board/gateworks/venice/gsc.c b/board/gateworks/venice/gsc.c index 065d1fb8cc..a184ce8228 100644 --- a/board/gateworks/venice/gsc.c +++ b/board/gateworks/venice/gsc.c @@ -378,7 +378,11 @@ char get_pcb_rev(const char *str) snprintf((dest) + strlen(dest), (sz) - strlen(dest), fmt, ##__VA_ARGS__) const char *gsc_get_dtb_name(int level, char *buf, int sz) { +#ifdef CONFIG_IMX8MM const char *pre = "imx8mm-venice-gw"; +#else + const char *pre = "imx8mn-venice-gw"; +#endif int model, rev_pcb, rev_bom;
model = ((som_info.model[2] - '0') * 1000) @@ -544,6 +548,15 @@ int gsc_init(int quiet) * board may be ready to probe the GSC before its firmware is * running. We will wait here indefinately for the GSC/EEPROM. */ +#ifdef CONFIG_IMX8MN + // TODO: + // IMX8MN boots quicker than IMX8MM and exposes issue + // where because GSC I2C state machine isn't running and its + // SCL/SDA are driven low spams i2c errors + // + // Put a loop here that somehow waits for I2C CLK/DAT to be high + mdelay(40); +#endif while (1) { /* probe device */ dev = gsc_get_dev(GSC_BUSNO, GSC_SC_ADDR); diff --git a/board/gateworks/venice/imximage-8mn-lpddr4.cfg b/board/gateworks/venice/imximage-8mn-lpddr4.cfg new file mode 100644 index 0000000000..8aaaaaf8a8 --- /dev/null +++ b/board/gateworks/venice/imximage-8mn-lpddr4.cfg @@ -0,0 +1,10 @@ +/* SPDX-License-Identifier: GPL-2.0+ */ +/* + * Copyright 2021 Gateworks Corporation + */ + +#define __ASSEMBLY__ + +ROM_VERSION v2 +BOOT_FROM sd +LOADER u-boot-spl-ddr.bin 0x912000 diff --git a/board/gateworks/venice/lpddr4_timing.h b/board/gateworks/venice/lpddr4_timing.h index b73d067f7d..21dd158abf 100644 --- a/board/gateworks/venice/lpddr4_timing.h +++ b/board/gateworks/venice/lpddr4_timing.h @@ -6,8 +6,13 @@ #ifndef __LPDDR4_TIMING_H__ #define __LPDDR4_TIMING_H__
+#ifdef CONFIG_IMX8MM extern struct dram_timing_info dram_timing_1gb; extern struct dram_timing_info dram_timing_2gb; extern struct dram_timing_info dram_timing_4gb; +#elif CONFIG_IMX8MN +extern struct dram_timing_info dram_timing_2gb_single_die; +extern struct dram_timing_info dram_timing_2gb_dual_die; +#endif
#endif /* __LPDDR4_TIMING_H__ */ diff --git a/board/gateworks/venice/lpddr4_timing.c b/board/gateworks/venice/lpddr4_timing_imx8mm.c similarity index 100% rename from board/gateworks/venice/lpddr4_timing.c rename to board/gateworks/venice/lpddr4_timing_imx8mm.c diff --git a/board/gateworks/venice/lpddr4_timing_imx8mn_2gb_dual_die.c b/board/gateworks/venice/lpddr4_timing_imx8mn_2gb_dual_die.c new file mode 100644 index 0000000000..fc12ad8c13 --- /dev/null +++ b/board/gateworks/venice/lpddr4_timing_imx8mn_2gb_dual_die.c @@ -0,0 +1,1444 @@ +// SPDX-License-Identifier: GPL-2.0+ +/* + * Generated code from MX8M_DDR_tool v3.20 using RPAv5 + * - 2x Kingston C1612PC2WDGTKR 16bit dual-die for total of 2GiB + * - imx8mn-gw7902 + * + * Align with uboot version: + * imx_v2019.04_5.4.x and above version + * For imx_v2018.03_4.14.78_1.0.0_ga ~ imx_v2018.04_4.19.35_1.1.0_ga: + * please replace #include <asm/arch/ddr.h> with #include <asm/arch/imx8m_ddr.h> + */ + +#include <linux/kernel.h> +#include <asm/arch/ddr.h> + +static struct dram_cfg_param ddr_ddrc_cfg[] = { + /** Initialize DDRC registers **/ + { 0x3d400304, 0x1 }, + { 0x3d400030, 0x1 }, + { 0x3d400000, 0xa3080020 }, + { 0x3d400020, 0x203 }, + { 0x3d400024, 0x3e800 }, + { 0x3d400064, 0x6100e0 }, + { 0x3d4000d0, 0xc003061c }, + { 0x3d4000d4, 0x9e0000 }, + { 0x3d4000dc, 0xd4002d }, + { 0x3d4000e0, 0x310000 }, + { 0x3d4000e8, 0x66004d }, + { 0x3d4000ec, 0x16004d }, + { 0x3d400100, 0x1a201b22 }, + { 0x3d400104, 0x60633 }, + { 0x3d40010c, 0xc0c000 }, + { 0x3d400110, 0xf04080f }, + { 0x3d400114, 0x2040c0c }, + { 0x3d400118, 0x1010007 }, + { 0x3d40011c, 0x401 }, + { 0x3d400130, 0x20600 }, + { 0x3d400134, 0xc100002 }, + { 0x3d400138, 0xe6 }, + { 0x3d400144, 0xa00050 }, + { 0x3d400180, 0x3200018 }, + { 0x3d400184, 0x28061a8 }, + { 0x3d400188, 0x0 }, + { 0x3d400190, 0x497820a }, + { 0x3d400194, 0x80303 }, + { 0x3d4001b4, 0x170a }, + { 0x3d4001a0, 0xe0400018 }, + { 0x3d4001a4, 0xdf00e4 }, + { 0x3d4001a8, 0x80000000 }, + { 0x3d4001b0, 0x11 }, + { 0x3d4001c0, 0x1 }, + { 0x3d4001c4, 0x1 }, + { 0x3d4000f4, 0xc99 }, + { 0x3d400108, 0x70e1617 }, + { 0x3d400200, 0x17 }, + { 0x3d40020c, 0x0 }, + { 0x3d400210, 0x1f1f }, + { 0x3d400204, 0x80808 }, + { 0x3d400214, 0x7070707 }, + { 0x3d400218, 0x7070707 }, + { 0x3d400250, 0x29001701 }, + { 0x3d400254, 0x2c }, + { 0x3d40025c, 0x4000030 }, + { 0x3d400264, 0x900093e7 }, + { 0x3d40026c, 0x2005574 }, + { 0x3d400400, 0x111 }, + { 0x3d400408, 0x72ff }, + { 0x3d400494, 0x2100e07 }, + { 0x3d400498, 0x620096 }, + { 0x3d40049c, 0x1100e07 }, + { 0x3d4004a0, 0xc8012c }, + { 0x3d402020, 0x1 }, + { 0x3d402024, 0x7d00 }, + { 0x3d402050, 0x20d040 }, + { 0x3d402064, 0xc001c }, + { 0x3d4020dc, 0x840000 }, + { 0x3d4020e0, 0x310000 }, + { 0x3d4020e8, 0x66004d }, + { 0x3d4020ec, 0x16004d }, + { 0x3d402100, 0xa040305 }, + { 0x3d402104, 0x30407 }, + { 0x3d402108, 0x203060b }, + { 0x3d40210c, 0x505000 }, + { 0x3d402110, 0x2040202 }, + { 0x3d402114, 0x2030202 }, + { 0x3d402118, 0x1010004 }, + { 0x3d40211c, 0x301 }, + { 0x3d402130, 0x20300 }, + { 0x3d402134, 0xa100002 }, + { 0x3d402138, 0x1d }, + { 0x3d402144, 0x14000a }, + { 0x3d402180, 0x640004 }, + { 0x3d402190, 0x3818200 }, + { 0x3d402194, 0x80303 }, + { 0x3d4021b4, 0x100 }, + { 0x3d4020f4, 0xc99 }, + { 0x3d403020, 0x1 }, + { 0x3d403024, 0x1f40 }, + { 0x3d403050, 0x20d040 }, + { 0x3d403064, 0x30007 }, + { 0x3d4030dc, 0x840000 }, + { 0x3d4030e0, 0x310000 }, + { 0x3d4030e8, 0x66004d }, + { 0x3d4030ec, 0x16004d }, + { 0x3d403100, 0xa010102 }, + { 0x3d403104, 0x30404 }, + { 0x3d403108, 0x203060b }, + { 0x3d40310c, 0x505000 }, + { 0x3d403110, 0x2040202 }, + { 0x3d403114, 0x2030202 }, + { 0x3d403118, 0x1010004 }, + { 0x3d40311c, 0x301 }, + { 0x3d403130, 0x20300 }, + { 0x3d403134, 0xa100002 }, + { 0x3d403138, 0x8 }, + { 0x3d403144, 0x50003 }, + { 0x3d403180, 0x190004 }, + { 0x3d403190, 0x3818200 }, + { 0x3d403194, 0x80303 }, + { 0x3d4031b4, 0x100 }, + { 0x3d4030f4, 0xc99 }, + { 0x3d400028, 0x0 }, +}; + +/* PHY Initialize Configuration */ +static struct dram_cfg_param ddr_ddrphy_cfg[] = { + { 0x100a0, 0x0 }, + { 0x100a1, 0x1 }, + { 0x100a2, 0x2 }, + { 0x100a3, 0x3 }, + { 0x100a4, 0x4 }, + { 0x100a5, 0x5 }, + { 0x100a6, 0x6 }, + { 0x100a7, 0x7 }, + { 0x110a0, 0x0 }, + { 0x110a1, 0x1 }, + { 0x110a2, 0x3 }, + { 0x110a3, 0x4 }, + { 0x110a4, 0x5 }, + { 0x110a5, 0x2 }, + { 0x110a6, 0x7 }, + { 0x110a7, 0x6 }, + { 0x1005f, 0x1ff }, + { 0x1015f, 0x1ff }, + { 0x1105f, 0x1ff }, + { 0x1115f, 0x1ff }, + { 0x11005f, 0x1ff }, + { 0x11015f, 0x1ff }, + { 0x11105f, 0x1ff }, + { 0x11115f, 0x1ff }, + { 0x21005f, 0x1ff }, + { 0x21015f, 0x1ff }, + { 0x21105f, 0x1ff }, + { 0x21115f, 0x1ff }, + { 0x55, 0x1ff }, + { 0x1055, 0x1ff }, + { 0x2055, 0x1ff }, + { 0x3055, 0x1ff }, + { 0x4055, 0x1ff }, + { 0x5055, 0x1ff }, + { 0x6055, 0x1ff }, + { 0x7055, 0x1ff }, + { 0x8055, 0x1ff }, + { 0x9055, 0x1ff }, + { 0x200c5, 0x19 }, + { 0x1200c5, 0x7 }, + { 0x2200c5, 0x7 }, + { 0x2002e, 0x2 }, + { 0x12002e, 0x2 }, + { 0x22002e, 0x2 }, + { 0x90204, 0x0 }, + { 0x190204, 0x0 }, + { 0x290204, 0x0 }, + { 0x20024, 0x1a3 }, + { 0x2003a, 0x2 }, + { 0x120024, 0x1a3 }, + { 0x2003a, 0x2 }, + { 0x220024, 0x1a3 }, + { 0x2003a, 0x2 }, + { 0x20056, 0x3 }, + { 0x120056, 0x3 }, + { 0x220056, 0x3 }, + { 0x1004d, 0xe00 }, + { 0x1014d, 0xe00 }, + { 0x1104d, 0xe00 }, + { 0x1114d, 0xe00 }, + { 0x11004d, 0xe00 }, + { 0x11014d, 0xe00 }, + { 0x11104d, 0xe00 }, + { 0x11114d, 0xe00 }, + { 0x21004d, 0xe00 }, + { 0x21014d, 0xe00 }, + { 0x21104d, 0xe00 }, + { 0x21114d, 0xe00 }, + { 0x10049, 0xeba }, + { 0x10149, 0xeba }, + { 0x11049, 0xeba }, + { 0x11149, 0xeba }, + { 0x110049, 0xeba }, + { 0x110149, 0xeba }, + { 0x111049, 0xeba }, + { 0x111149, 0xeba }, + { 0x210049, 0xeba }, + { 0x210149, 0xeba }, + { 0x211049, 0xeba }, + { 0x211149, 0xeba }, + { 0x43, 0x63 }, + { 0x1043, 0x63 }, + { 0x2043, 0x63 }, + { 0x3043, 0x63 }, + { 0x4043, 0x63 }, + { 0x5043, 0x63 }, + { 0x6043, 0x63 }, + { 0x7043, 0x63 }, + { 0x8043, 0x63 }, + { 0x9043, 0x63 }, + { 0x20018, 0x1 }, + { 0x20075, 0x4 }, + { 0x20050, 0x0 }, + { 0x20008, 0x320 }, + { 0x120008, 0x64 }, + { 0x220008, 0x19 }, + { 0x20088, 0x9 }, + { 0x200b2, 0xdc }, + { 0x10043, 0x5a1 }, + { 0x10143, 0x5a1 }, + { 0x11043, 0x5a1 }, + { 0x11143, 0x5a1 }, + { 0x1200b2, 0xdc }, + { 0x110043, 0x5a1 }, + { 0x110143, 0x5a1 }, + { 0x111043, 0x5a1 }, + { 0x111143, 0x5a1 }, + { 0x2200b2, 0xdc }, + { 0x210043, 0x5a1 }, + { 0x210143, 0x5a1 }, + { 0x211043, 0x5a1 }, + { 0x211143, 0x5a1 }, + { 0x200fa, 0x1 }, + { 0x1200fa, 0x1 }, + { 0x2200fa, 0x1 }, + { 0x20019, 0x1 }, + { 0x120019, 0x1 }, + { 0x220019, 0x1 }, + { 0x200f0, 0x660 }, + { 0x200f1, 0x0 }, + { 0x200f2, 0x4444 }, + { 0x200f3, 0x8888 }, + { 0x200f4, 0x5665 }, + { 0x200f5, 0x0 }, + { 0x200f6, 0x0 }, + { 0x200f7, 0xf000 }, + { 0x20025, 0x0 }, + { 0x2002d, 0x0 }, + { 0x12002d, 0x0 }, + { 0x22002d, 0x0 }, + { 0x2005b, 0x7529 }, + { 0x2005c, 0x0 }, + { 0x200c7, 0x21 }, + { 0x200ca, 0x24 }, + { 0x200cc, 0x1f7 }, + { 0x1200c7, 0x21 }, + { 0x1200ca, 0x24 }, + { 0x1200cc, 0x1f7 }, + { 0x2200c7, 0x21 }, + { 0x2200ca, 0x24 }, + { 0x2200cc, 0x1f7 }, + { 0x2007d, 0x212 }, + { 0x12007d, 0x212 }, + { 0x22007d, 0x212 }, + { 0x2007c, 0x61 }, + { 0x12007c, 0x61 }, + { 0x22007c, 0x61 }, + { 0x1004a, 0x500 }, + { 0x1104a, 0x500 }, + { 0x2002c, 0x0 }, +}; + +/* ddr phy trained csr */ +static struct dram_cfg_param ddr_ddrphy_trained_csr[] = { + {0x0200b2, 0x0}, + {0x1200b2, 0x0}, + {0x2200b2, 0x0}, + {0x0200cb, 0x0}, + {0x010043, 0x0}, + {0x110043, 0x0}, + {0x210043, 0x0}, + {0x010143, 0x0}, + {0x110143, 0x0}, + {0x210143, 0x0}, + {0x011043, 0x0}, + {0x111043, 0x0}, + {0x211043, 0x0}, + {0x011143, 0x0}, + {0x111143, 0x0}, + {0x211143, 0x0}, + {0x000080, 0x0}, + {0x100080, 0x0}, + {0x200080, 0x0}, + {0x001080, 0x0}, + {0x101080, 0x0}, + {0x201080, 0x0}, + {0x002080, 0x0}, + {0x102080, 0x0}, + {0x202080, 0x0}, + {0x003080, 0x0}, + {0x103080, 0x0}, + {0x203080, 0x0}, + {0x004080, 0x0}, + {0x104080, 0x0}, + {0x204080, 0x0}, + {0x005080, 0x0}, + {0x105080, 0x0}, + {0x205080, 0x0}, + {0x006080, 0x0}, + {0x106080, 0x0}, + {0x206080, 0x0}, + {0x007080, 0x0}, + {0x107080, 0x0}, + {0x207080, 0x0}, + {0x008080, 0x0}, + {0x108080, 0x0}, + {0x208080, 0x0}, + {0x009080, 0x0}, + {0x109080, 0x0}, + {0x209080, 0x0}, + {0x010080, 0x0}, + {0x110080, 0x0}, + {0x210080, 0x0}, + {0x010180, 0x0}, + {0x110180, 0x0}, + {0x210180, 0x0}, + {0x011080, 0x0}, + {0x111080, 0x0}, + {0x211080, 0x0}, + {0x011180, 0x0}, + {0x111180, 0x0}, + {0x211180, 0x0}, + {0x010081, 0x0}, + {0x110081, 0x0}, + {0x210081, 0x0}, + {0x010181, 0x0}, + {0x110181, 0x0}, + {0x210181, 0x0}, + {0x011081, 0x0}, + {0x111081, 0x0}, + {0x211081, 0x0}, + {0x011181, 0x0}, + {0x111181, 0x0}, + {0x211181, 0x0}, + {0x0100d0, 0x0}, + {0x1100d0, 0x0}, + {0x2100d0, 0x0}, + {0x0101d0, 0x0}, + {0x1101d0, 0x0}, + {0x2101d0, 0x0}, + {0x0110d0, 0x0}, + {0x1110d0, 0x0}, + {0x2110d0, 0x0}, + {0x0111d0, 0x0}, + {0x1111d0, 0x0}, + {0x2111d0, 0x0}, + {0x0100d1, 0x0}, + {0x1100d1, 0x0}, + {0x2100d1, 0x0}, + {0x0101d1, 0x0}, + {0x1101d1, 0x0}, + {0x2101d1, 0x0}, + {0x0110d1, 0x0}, + {0x1110d1, 0x0}, + {0x2110d1, 0x0}, + {0x0111d1, 0x0}, + {0x1111d1, 0x0}, + {0x2111d1, 0x0}, + {0x010068, 0x0}, + {0x010168, 0x0}, + {0x010268, 0x0}, + {0x010368, 0x0}, + {0x010468, 0x0}, + {0x010568, 0x0}, + {0x010668, 0x0}, + {0x010768, 0x0}, + {0x010868, 0x0}, + {0x011068, 0x0}, + {0x011168, 0x0}, + {0x011268, 0x0}, + {0x011368, 0x0}, + {0x011468, 0x0}, + {0x011568, 0x0}, + {0x011668, 0x0}, + {0x011768, 0x0}, + {0x011868, 0x0}, + {0x010069, 0x0}, + {0x010169, 0x0}, + {0x010269, 0x0}, + {0x010369, 0x0}, + {0x010469, 0x0}, + {0x010569, 0x0}, + {0x010669, 0x0}, + {0x010769, 0x0}, + {0x010869, 0x0}, + {0x011069, 0x0}, + {0x011169, 0x0}, + {0x011269, 0x0}, + {0x011369, 0x0}, + {0x011469, 0x0}, + {0x011569, 0x0}, + {0x011669, 0x0}, + {0x011769, 0x0}, + {0x011869, 0x0}, + {0x01008c, 0x0}, + {0x11008c, 0x0}, + {0x21008c, 0x0}, + {0x01018c, 0x0}, + {0x11018c, 0x0}, + {0x21018c, 0x0}, + {0x01108c, 0x0}, + {0x11108c, 0x0}, + {0x21108c, 0x0}, + {0x01118c, 0x0}, + {0x11118c, 0x0}, + {0x21118c, 0x0}, + {0x01008d, 0x0}, + {0x11008d, 0x0}, + {0x21008d, 0x0}, + {0x01018d, 0x0}, + {0x11018d, 0x0}, + {0x21018d, 0x0}, + {0x01108d, 0x0}, + {0x11108d, 0x0}, + {0x21108d, 0x0}, + {0x01118d, 0x0}, + {0x11118d, 0x0}, + {0x21118d, 0x0}, + {0x0100c0, 0x0}, + {0x1100c0, 0x0}, + {0x2100c0, 0x0}, + {0x0101c0, 0x0}, + {0x1101c0, 0x0}, + {0x2101c0, 0x0}, + {0x0102c0, 0x0}, + {0x1102c0, 0x0}, + {0x2102c0, 0x0}, + {0x0103c0, 0x0}, + {0x1103c0, 0x0}, + {0x2103c0, 0x0}, + {0x0104c0, 0x0}, + {0x1104c0, 0x0}, + {0x2104c0, 0x0}, + {0x0105c0, 0x0}, + {0x1105c0, 0x0}, + {0x2105c0, 0x0}, + {0x0106c0, 0x0}, + {0x1106c0, 0x0}, + {0x2106c0, 0x0}, + {0x0107c0, 0x0}, + {0x1107c0, 0x0}, + {0x2107c0, 0x0}, + {0x0108c0, 0x0}, + {0x1108c0, 0x0}, + {0x2108c0, 0x0}, + {0x0110c0, 0x0}, + {0x1110c0, 0x0}, + {0x2110c0, 0x0}, + {0x0111c0, 0x0}, + {0x1111c0, 0x0}, + {0x2111c0, 0x0}, + {0x0112c0, 0x0}, + {0x1112c0, 0x0}, + {0x2112c0, 0x0}, + {0x0113c0, 0x0}, + {0x1113c0, 0x0}, + {0x2113c0, 0x0}, + {0x0114c0, 0x0}, + {0x1114c0, 0x0}, + {0x2114c0, 0x0}, + {0x0115c0, 0x0}, + {0x1115c0, 0x0}, + {0x2115c0, 0x0}, + {0x0116c0, 0x0}, + {0x1116c0, 0x0}, + {0x2116c0, 0x0}, + {0x0117c0, 0x0}, + {0x1117c0, 0x0}, + {0x2117c0, 0x0}, + {0x0118c0, 0x0}, + {0x1118c0, 0x0}, + {0x2118c0, 0x0}, + {0x0100c1, 0x0}, + {0x1100c1, 0x0}, + {0x2100c1, 0x0}, + {0x0101c1, 0x0}, + {0x1101c1, 0x0}, + {0x2101c1, 0x0}, + {0x0102c1, 0x0}, + {0x1102c1, 0x0}, + {0x2102c1, 0x0}, + {0x0103c1, 0x0}, + {0x1103c1, 0x0}, + {0x2103c1, 0x0}, + {0x0104c1, 0x0}, + {0x1104c1, 0x0}, + {0x2104c1, 0x0}, + {0x0105c1, 0x0}, + {0x1105c1, 0x0}, + {0x2105c1, 0x0}, + {0x0106c1, 0x0}, + {0x1106c1, 0x0}, + {0x2106c1, 0x0}, + {0x0107c1, 0x0}, + {0x1107c1, 0x0}, + {0x2107c1, 0x0}, + {0x0108c1, 0x0}, + {0x1108c1, 0x0}, + {0x2108c1, 0x0}, + {0x0110c1, 0x0}, + {0x1110c1, 0x0}, + {0x2110c1, 0x0}, + {0x0111c1, 0x0}, + {0x1111c1, 0x0}, + {0x2111c1, 0x0}, + {0x0112c1, 0x0}, + {0x1112c1, 0x0}, + {0x2112c1, 0x0}, + {0x0113c1, 0x0}, + {0x1113c1, 0x0}, + {0x2113c1, 0x0}, + {0x0114c1, 0x0}, + {0x1114c1, 0x0}, + {0x2114c1, 0x0}, + {0x0115c1, 0x0}, + {0x1115c1, 0x0}, + {0x2115c1, 0x0}, + {0x0116c1, 0x0}, + {0x1116c1, 0x0}, + {0x2116c1, 0x0}, + {0x0117c1, 0x0}, + {0x1117c1, 0x0}, + {0x2117c1, 0x0}, + {0x0118c1, 0x0}, + {0x1118c1, 0x0}, + {0x2118c1, 0x0}, + {0x010020, 0x0}, + {0x110020, 0x0}, + {0x210020, 0x0}, + {0x011020, 0x0}, + {0x111020, 0x0}, + {0x211020, 0x0}, + {0x020072, 0x0}, + {0x020073, 0x0}, + {0x020074, 0x0}, + {0x0100aa, 0x0}, + {0x0110aa, 0x0}, + {0x020010, 0x0}, + {0x120010, 0x0}, + {0x220010, 0x0}, + {0x020011, 0x0}, + {0x120011, 0x0}, + {0x220011, 0x0}, + {0x0100ae, 0x0}, + {0x1100ae, 0x0}, + {0x2100ae, 0x0}, + {0x0100af, 0x0}, + {0x1100af, 0x0}, + {0x2100af, 0x0}, + {0x0110ae, 0x0}, + {0x1110ae, 0x0}, + {0x2110ae, 0x0}, + {0x0110af, 0x0}, + {0x1110af, 0x0}, + {0x2110af, 0x0}, + {0x020020, 0x0}, + {0x120020, 0x0}, + {0x220020, 0x0}, + {0x0100a0, 0x0}, + {0x0100a1, 0x0}, + {0x0100a2, 0x0}, + {0x0100a3, 0x0}, + {0x0100a4, 0x0}, + {0x0100a5, 0x0}, + {0x0100a6, 0x0}, + {0x0100a7, 0x0}, + {0x0110a0, 0x0}, + {0x0110a1, 0x0}, + {0x0110a2, 0x0}, + {0x0110a3, 0x0}, + {0x0110a4, 0x0}, + {0x0110a5, 0x0}, + {0x0110a6, 0x0}, + {0x0110a7, 0x0}, + {0x02007c, 0x0}, + {0x12007c, 0x0}, + {0x22007c, 0x0}, + {0x02007d, 0x0}, + {0x12007d, 0x0}, + {0x22007d, 0x0}, + {0x0400fd, 0x0}, + {0x0400c0, 0x0}, + {0x090201, 0x0}, + {0x190201, 0x0}, + {0x290201, 0x0}, + {0x090202, 0x0}, + {0x190202, 0x0}, + {0x290202, 0x0}, + {0x090203, 0x0}, + {0x190203, 0x0}, + {0x290203, 0x0}, + {0x090204, 0x0}, + {0x190204, 0x0}, + {0x290204, 0x0}, + {0x090205, 0x0}, + {0x190205, 0x0}, + {0x290205, 0x0}, + {0x090206, 0x0}, + {0x190206, 0x0}, + {0x290206, 0x0}, + {0x090207, 0x0}, + {0x190207, 0x0}, + {0x290207, 0x0}, + {0x090208, 0x0}, + {0x190208, 0x0}, + {0x290208, 0x0}, + {0x010062, 0x0}, + {0x010162, 0x0}, + {0x010262, 0x0}, + {0x010362, 0x0}, + {0x010462, 0x0}, + {0x010562, 0x0}, + {0x010662, 0x0}, + {0x010762, 0x0}, + {0x010862, 0x0}, + {0x011062, 0x0}, + {0x011162, 0x0}, + {0x011262, 0x0}, + {0x011362, 0x0}, + {0x011462, 0x0}, + {0x011562, 0x0}, + {0x011662, 0x0}, + {0x011762, 0x0}, + {0x011862, 0x0}, + {0x020077, 0x0}, + {0x010001, 0x0}, + {0x011001, 0x0}, + {0x010040, 0x0}, + {0x010140, 0x0}, + {0x010240, 0x0}, + {0x010340, 0x0}, + {0x010440, 0x0}, + {0x010540, 0x0}, + {0x010640, 0x0}, + {0x010740, 0x0}, + {0x010840, 0x0}, + {0x010030, 0x0}, + {0x010130, 0x0}, + {0x010230, 0x0}, + {0x010330, 0x0}, + {0x010430, 0x0}, + {0x010530, 0x0}, + {0x010630, 0x0}, + {0x010730, 0x0}, + {0x010830, 0x0}, + {0x011040, 0x0}, + {0x011140, 0x0}, + {0x011240, 0x0}, + {0x011340, 0x0}, + {0x011440, 0x0}, + {0x011540, 0x0}, + {0x011640, 0x0}, + {0x011740, 0x0}, + {0x011840, 0x0}, + {0x011030, 0x0}, + {0x011130, 0x0}, + {0x011230, 0x0}, + {0x011330, 0x0}, + {0x011430, 0x0}, + {0x011530, 0x0}, + {0x011630, 0x0}, + {0x011730, 0x0}, + {0x011830, 0x0}, +}; + +/* P0 message block paremeter for training firmware */ +static struct dram_cfg_param ddr_fsp0_cfg[] = { + { 0xd0000, 0x0 }, + { 0x54003, 0xc80 }, + { 0x54004, 0x2 }, + { 0x54005, 0x2228 }, + { 0x54006, 0x11 }, + { 0x54008, 0x131f }, + { 0x54009, 0xc8 }, + { 0x5400b, 0x2 }, + { 0x5400f, 0x100 }, + { 0x54012, 0x310 }, + { 0x54019, 0x2dd4 }, + { 0x5401a, 0x31 }, + { 0x5401b, 0x4d66 }, + { 0x5401c, 0x4d00 }, + { 0x5401e, 0x16 }, + { 0x5401f, 0x2dd4 }, + { 0x54020, 0x31 }, + { 0x54021, 0x4d66 }, + { 0x54022, 0x4d00 }, + { 0x54024, 0x16 }, + { 0x54032, 0xd400 }, + { 0x54033, 0x312d }, + { 0x54034, 0x6600 }, + { 0x54035, 0x4d }, + { 0x54036, 0x4d }, + { 0x54037, 0x1600 }, + { 0x54038, 0xd400 }, + { 0x54039, 0x312d }, + { 0x5403a, 0x6600 }, + { 0x5403b, 0x4d }, + { 0x5403c, 0x4d }, + { 0x5403d, 0x1600 }, + { 0xd0000, 0x1 }, +}; + +/* P1 message block paremeter for training firmware */ +static struct dram_cfg_param ddr_fsp1_cfg[] = { + { 0xd0000, 0x0 }, + { 0x54002, 0x101 }, + { 0x54003, 0x190 }, + { 0x54004, 0x2 }, + { 0x54005, 0x2228 }, + { 0x54006, 0x11 }, + { 0x54008, 0x121f }, + { 0x54009, 0xc8 }, + { 0x5400b, 0x2 }, + { 0x5400f, 0x100 }, + { 0x54012, 0x310 }, + { 0x54019, 0x84 }, + { 0x5401a, 0x31 }, + { 0x5401b, 0x4d66 }, + { 0x5401c, 0x4d00 }, + { 0x5401e, 0x16 }, + { 0x5401f, 0x84 }, + { 0x54020, 0x31 }, + { 0x54021, 0x4d66 }, + { 0x54022, 0x4d00 }, + { 0x54024, 0x16 }, + { 0x54032, 0x8400 }, + { 0x54033, 0x3100 }, + { 0x54034, 0x6600 }, + { 0x54035, 0x4d }, + { 0x54036, 0x4d }, + { 0x54037, 0x1600 }, + { 0x54038, 0x8400 }, + { 0x54039, 0x3100 }, + { 0x5403a, 0x6600 }, + { 0x5403b, 0x4d }, + { 0x5403c, 0x4d }, + { 0x5403d, 0x1600 }, + { 0xd0000, 0x1 }, +}; + +/* P2 message block paremeter for training firmware */ +static struct dram_cfg_param ddr_fsp2_cfg[] = { + { 0xd0000, 0x0 }, + { 0x54002, 0x102 }, + { 0x54003, 0x64 }, + { 0x54004, 0x2 }, + { 0x54005, 0x2228 }, + { 0x54006, 0x11 }, + { 0x54008, 0x121f }, + { 0x54009, 0xc8 }, + { 0x5400b, 0x2 }, + { 0x5400f, 0x100 }, + { 0x54012, 0x310 }, + { 0x54019, 0x84 }, + { 0x5401a, 0x31 }, + { 0x5401b, 0x4d66 }, + { 0x5401c, 0x4d00 }, + { 0x5401e, 0x16 }, + { 0x5401f, 0x84 }, + { 0x54020, 0x31 }, + { 0x54021, 0x4d66 }, + { 0x54022, 0x4d00 }, + { 0x54024, 0x16 }, + { 0x54032, 0x8400 }, + { 0x54033, 0x3100 }, + { 0x54034, 0x6600 }, + { 0x54035, 0x4d }, + { 0x54036, 0x4d }, + { 0x54037, 0x1600 }, + { 0x54038, 0x8400 }, + { 0x54039, 0x3100 }, + { 0x5403a, 0x6600 }, + { 0x5403b, 0x4d }, + { 0x5403c, 0x4d }, + { 0x5403d, 0x1600 }, + { 0xd0000, 0x1 }, +}; + +/* P0 2D message block paremeter for training firmware */ +static struct dram_cfg_param ddr_fsp0_2d_cfg[] = { + { 0xd0000, 0x0 }, + { 0x54003, 0xc80 }, + { 0x54004, 0x2 }, + { 0x54005, 0x2228 }, + { 0x54006, 0x11 }, + { 0x54008, 0x61 }, + { 0x54009, 0xc8 }, + { 0x5400b, 0x2 }, + { 0x5400f, 0x100 }, + { 0x54010, 0x1f7f }, + { 0x54012, 0x310 }, + { 0x54019, 0x2dd4 }, + { 0x5401a, 0x31 }, + { 0x5401b, 0x4d66 }, + { 0x5401c, 0x4d00 }, + { 0x5401e, 0x16 }, + { 0x5401f, 0x2dd4 }, + { 0x54020, 0x31 }, + { 0x54021, 0x4d66 }, + { 0x54022, 0x4d00 }, + { 0x54024, 0x16 }, + { 0x54032, 0xd400 }, + { 0x54033, 0x312d }, + { 0x54034, 0x6600 }, + { 0x54035, 0x4d }, + { 0x54036, 0x4d }, + { 0x54037, 0x1600 }, + { 0x54038, 0xd400 }, + { 0x54039, 0x312d }, + { 0x5403a, 0x6600 }, + { 0x5403b, 0x4d }, + { 0x5403c, 0x4d }, + { 0x5403d, 0x1600 }, + { 0xd0000, 0x1 }, +}; + +/* DRAM PHY init engine image */ +static struct dram_cfg_param ddr_phy_pie[] = { + { 0xd0000, 0x0 }, + { 0x90000, 0x10 }, + { 0x90001, 0x400 }, + { 0x90002, 0x10e }, + { 0x90003, 0x0 }, + { 0x90004, 0x0 }, + { 0x90005, 0x8 }, + { 0x90029, 0xb }, + { 0x9002a, 0x480 }, + { 0x9002b, 0x109 }, + { 0x9002c, 0x8 }, + { 0x9002d, 0x448 }, + { 0x9002e, 0x139 }, + { 0x9002f, 0x8 }, + { 0x90030, 0x478 }, + { 0x90031, 0x109 }, + { 0x90032, 0x0 }, + { 0x90033, 0xe8 }, + { 0x90034, 0x109 }, + { 0x90035, 0x2 }, + { 0x90036, 0x10 }, + { 0x90037, 0x139 }, + { 0x90038, 0xb }, + { 0x90039, 0x7c0 }, + { 0x9003a, 0x139 }, + { 0x9003b, 0x44 }, + { 0x9003c, 0x633 }, + { 0x9003d, 0x159 }, + { 0x9003e, 0x14f }, + { 0x9003f, 0x630 }, + { 0x90040, 0x159 }, + { 0x90041, 0x47 }, + { 0x90042, 0x633 }, + { 0x90043, 0x149 }, + { 0x90044, 0x4f }, + { 0x90045, 0x633 }, + { 0x90046, 0x179 }, + { 0x90047, 0x8 }, + { 0x90048, 0xe0 }, + { 0x90049, 0x109 }, + { 0x9004a, 0x0 }, + { 0x9004b, 0x7c8 }, + { 0x9004c, 0x109 }, + { 0x9004d, 0x0 }, + { 0x9004e, 0x1 }, + { 0x9004f, 0x8 }, + { 0x90050, 0x0 }, + { 0x90051, 0x45a }, + { 0x90052, 0x9 }, + { 0x90053, 0x0 }, + { 0x90054, 0x448 }, + { 0x90055, 0x109 }, + { 0x90056, 0x40 }, + { 0x90057, 0x633 }, + { 0x90058, 0x179 }, + { 0x90059, 0x1 }, + { 0x9005a, 0x618 }, + { 0x9005b, 0x109 }, + { 0x9005c, 0x40c0 }, + { 0x9005d, 0x633 }, + { 0x9005e, 0x149 }, + { 0x9005f, 0x8 }, + { 0x90060, 0x4 }, + { 0x90061, 0x48 }, + { 0x90062, 0x4040 }, + { 0x90063, 0x633 }, + { 0x90064, 0x149 }, + { 0x90065, 0x0 }, + { 0x90066, 0x4 }, + { 0x90067, 0x48 }, + { 0x90068, 0x40 }, + { 0x90069, 0x633 }, + { 0x9006a, 0x149 }, + { 0x9006b, 0x10 }, + { 0x9006c, 0x4 }, + { 0x9006d, 0x18 }, + { 0x9006e, 0x0 }, + { 0x9006f, 0x4 }, + { 0x90070, 0x78 }, + { 0x90071, 0x549 }, + { 0x90072, 0x633 }, + { 0x90073, 0x159 }, + { 0x90074, 0xd49 }, + { 0x90075, 0x633 }, + { 0x90076, 0x159 }, + { 0x90077, 0x94a }, + { 0x90078, 0x633 }, + { 0x90079, 0x159 }, + { 0x9007a, 0x441 }, + { 0x9007b, 0x633 }, + { 0x9007c, 0x149 }, + { 0x9007d, 0x42 }, + { 0x9007e, 0x633 }, + { 0x9007f, 0x149 }, + { 0x90080, 0x1 }, + { 0x90081, 0x633 }, + { 0x90082, 0x149 }, + { 0x90083, 0x0 }, + { 0x90084, 0xe0 }, + { 0x90085, 0x109 }, + { 0x90086, 0xa }, + { 0x90087, 0x10 }, + { 0x90088, 0x109 }, + { 0x90089, 0x9 }, + { 0x9008a, 0x3c0 }, + { 0x9008b, 0x149 }, + { 0x9008c, 0x9 }, + { 0x9008d, 0x3c0 }, + { 0x9008e, 0x159 }, + { 0x9008f, 0x18 }, + { 0x90090, 0x10 }, + { 0x90091, 0x109 }, + { 0x90092, 0x0 }, + { 0x90093, 0x3c0 }, + { 0x90094, 0x109 }, + { 0x90095, 0x18 }, + { 0x90096, 0x4 }, + { 0x90097, 0x48 }, + { 0x90098, 0x18 }, + { 0x90099, 0x4 }, + { 0x9009a, 0x58 }, + { 0x9009b, 0xb }, + { 0x9009c, 0x10 }, + { 0x9009d, 0x109 }, + { 0x9009e, 0x1 }, + { 0x9009f, 0x10 }, + { 0x900a0, 0x109 }, + { 0x900a1, 0x5 }, + { 0x900a2, 0x7c0 }, + { 0x900a3, 0x109 }, + { 0x40000, 0x811 }, + { 0x40020, 0x880 }, + { 0x40040, 0x0 }, + { 0x40060, 0x0 }, + { 0x40001, 0x4008 }, + { 0x40021, 0x83 }, + { 0x40041, 0x4f }, + { 0x40061, 0x0 }, + { 0x40002, 0x4040 }, + { 0x40022, 0x83 }, + { 0x40042, 0x51 }, + { 0x40062, 0x0 }, + { 0x40003, 0x811 }, + { 0x40023, 0x880 }, + { 0x40043, 0x0 }, + { 0x40063, 0x0 }, + { 0x40004, 0x720 }, + { 0x40024, 0xf }, + { 0x40044, 0x1740 }, + { 0x40064, 0x0 }, + { 0x40005, 0x16 }, + { 0x40025, 0x83 }, + { 0x40045, 0x4b }, + { 0x40065, 0x0 }, + { 0x40006, 0x716 }, + { 0x40026, 0xf }, + { 0x40046, 0x2001 }, + { 0x40066, 0x0 }, + { 0x40007, 0x716 }, + { 0x40027, 0xf }, + { 0x40047, 0x2800 }, + { 0x40067, 0x0 }, + { 0x40008, 0x716 }, + { 0x40028, 0xf }, + { 0x40048, 0xf00 }, + { 0x40068, 0x0 }, + { 0x40009, 0x720 }, + { 0x40029, 0xf }, + { 0x40049, 0x1400 }, + { 0x40069, 0x0 }, + { 0x4000a, 0xe08 }, + { 0x4002a, 0xc15 }, + { 0x4004a, 0x0 }, + { 0x4006a, 0x0 }, + { 0x4000b, 0x625 }, + { 0x4002b, 0x15 }, + { 0x4004b, 0x0 }, + { 0x4006b, 0x0 }, + { 0x4000c, 0x4028 }, + { 0x4002c, 0x80 }, + { 0x4004c, 0x0 }, + { 0x4006c, 0x0 }, + { 0x4000d, 0xe08 }, + { 0x4002d, 0xc1a }, + { 0x4004d, 0x0 }, + { 0x4006d, 0x0 }, + { 0x4000e, 0x625 }, + { 0x4002e, 0x1a }, + { 0x4004e, 0x0 }, + { 0x4006e, 0x0 }, + { 0x4000f, 0x4040 }, + { 0x4002f, 0x80 }, + { 0x4004f, 0x0 }, + { 0x4006f, 0x0 }, + { 0x40010, 0x2604 }, + { 0x40030, 0x15 }, + { 0x40050, 0x0 }, + { 0x40070, 0x0 }, + { 0x40011, 0x708 }, + { 0x40031, 0x5 }, + { 0x40051, 0x0 }, + { 0x40071, 0x2002 }, + { 0x40012, 0x8 }, + { 0x40032, 0x80 }, + { 0x40052, 0x0 }, + { 0x40072, 0x0 }, + { 0x40013, 0x2604 }, + { 0x40033, 0x1a }, + { 0x40053, 0x0 }, + { 0x40073, 0x0 }, + { 0x40014, 0x708 }, + { 0x40034, 0xa }, + { 0x40054, 0x0 }, + { 0x40074, 0x2002 }, + { 0x40015, 0x4040 }, + { 0x40035, 0x80 }, + { 0x40055, 0x0 }, + { 0x40075, 0x0 }, + { 0x40016, 0x60a }, + { 0x40036, 0x15 }, + { 0x40056, 0x1200 }, + { 0x40076, 0x0 }, + { 0x40017, 0x61a }, + { 0x40037, 0x15 }, + { 0x40057, 0x1300 }, + { 0x40077, 0x0 }, + { 0x40018, 0x60a }, + { 0x40038, 0x1a }, + { 0x40058, 0x1200 }, + { 0x40078, 0x0 }, + { 0x40019, 0x642 }, + { 0x40039, 0x1a }, + { 0x40059, 0x1300 }, + { 0x40079, 0x0 }, + { 0x4001a, 0x4808 }, + { 0x4003a, 0x880 }, + { 0x4005a, 0x0 }, + { 0x4007a, 0x0 }, + { 0x900a4, 0x0 }, + { 0x900a5, 0x790 }, + { 0x900a6, 0x11a }, + { 0x900a7, 0x8 }, + { 0x900a8, 0x7aa }, + { 0x900a9, 0x2a }, + { 0x900aa, 0x10 }, + { 0x900ab, 0x7b2 }, + { 0x900ac, 0x2a }, + { 0x900ad, 0x0 }, + { 0x900ae, 0x7c8 }, + { 0x900af, 0x109 }, + { 0x900b0, 0x10 }, + { 0x900b1, 0x10 }, + { 0x900b2, 0x109 }, + { 0x900b3, 0x10 }, + { 0x900b4, 0x2a8 }, + { 0x900b5, 0x129 }, + { 0x900b6, 0x8 }, + { 0x900b7, 0x370 }, + { 0x900b8, 0x129 }, + { 0x900b9, 0xa }, + { 0x900ba, 0x3c8 }, + { 0x900bb, 0x1a9 }, + { 0x900bc, 0xc }, + { 0x900bd, 0x408 }, + { 0x900be, 0x199 }, + { 0x900bf, 0x14 }, + { 0x900c0, 0x790 }, + { 0x900c1, 0x11a }, + { 0x900c2, 0x8 }, + { 0x900c3, 0x4 }, + { 0x900c4, 0x18 }, + { 0x900c5, 0xe }, + { 0x900c6, 0x408 }, + { 0x900c7, 0x199 }, + { 0x900c8, 0x8 }, + { 0x900c9, 0x8568 }, + { 0x900ca, 0x108 }, + { 0x900cb, 0x18 }, + { 0x900cc, 0x790 }, + { 0x900cd, 0x16a }, + { 0x900ce, 0x8 }, + { 0x900cf, 0x1d8 }, + { 0x900d0, 0x169 }, + { 0x900d1, 0x10 }, + { 0x900d2, 0x8558 }, + { 0x900d3, 0x168 }, + { 0x900d4, 0x70 }, + { 0x900d5, 0x788 }, + { 0x900d6, 0x16a }, + { 0x900d7, 0x1ff8 }, + { 0x900d8, 0x85a8 }, + { 0x900d9, 0x1e8 }, + { 0x900da, 0x50 }, + { 0x900db, 0x798 }, + { 0x900dc, 0x16a }, + { 0x900dd, 0x60 }, + { 0x900de, 0x7a0 }, + { 0x900df, 0x16a }, + { 0x900e0, 0x8 }, + { 0x900e1, 0x8310 }, + { 0x900e2, 0x168 }, + { 0x900e3, 0x8 }, + { 0x900e4, 0xa310 }, + { 0x900e5, 0x168 }, + { 0x900e6, 0xa }, + { 0x900e7, 0x408 }, + { 0x900e8, 0x169 }, + { 0x900e9, 0x6e }, + { 0x900ea, 0x0 }, + { 0x900eb, 0x68 }, + { 0x900ec, 0x0 }, + { 0x900ed, 0x408 }, + { 0x900ee, 0x169 }, + { 0x900ef, 0x0 }, + { 0x900f0, 0x8310 }, + { 0x900f1, 0x168 }, + { 0x900f2, 0x0 }, + { 0x900f3, 0xa310 }, + { 0x900f4, 0x168 }, + { 0x900f5, 0x1ff8 }, + { 0x900f6, 0x85a8 }, + { 0x900f7, 0x1e8 }, + { 0x900f8, 0x68 }, + { 0x900f9, 0x798 }, + { 0x900fa, 0x16a }, + { 0x900fb, 0x78 }, + { 0x900fc, 0x7a0 }, + { 0x900fd, 0x16a }, + { 0x900fe, 0x68 }, + { 0x900ff, 0x790 }, + { 0x90100, 0x16a }, + { 0x90101, 0x8 }, + { 0x90102, 0x8b10 }, + { 0x90103, 0x168 }, + { 0x90104, 0x8 }, + { 0x90105, 0xab10 }, + { 0x90106, 0x168 }, + { 0x90107, 0xa }, + { 0x90108, 0x408 }, + { 0x90109, 0x169 }, + { 0x9010a, 0x58 }, + { 0x9010b, 0x0 }, + { 0x9010c, 0x68 }, + { 0x9010d, 0x0 }, + { 0x9010e, 0x408 }, + { 0x9010f, 0x169 }, + { 0x90110, 0x0 }, + { 0x90111, 0x8b10 }, + { 0x90112, 0x168 }, + { 0x90113, 0x0 }, + { 0x90114, 0xab10 }, + { 0x90115, 0x168 }, + { 0x90116, 0x0 }, + { 0x90117, 0x1d8 }, + { 0x90118, 0x169 }, + { 0x90119, 0x80 }, + { 0x9011a, 0x790 }, + { 0x9011b, 0x16a }, + { 0x9011c, 0x18 }, + { 0x9011d, 0x7aa }, + { 0x9011e, 0x6a }, + { 0x9011f, 0xa }, + { 0x90120, 0x0 }, + { 0x90121, 0x1e9 }, + { 0x90122, 0x8 }, + { 0x90123, 0x8080 }, + { 0x90124, 0x108 }, + { 0x90125, 0xf }, + { 0x90126, 0x408 }, + { 0x90127, 0x169 }, + { 0x90128, 0xc }, + { 0x90129, 0x0 }, + { 0x9012a, 0x68 }, + { 0x9012b, 0x9 }, + { 0x9012c, 0x0 }, + { 0x9012d, 0x1a9 }, + { 0x9012e, 0x0 }, + { 0x9012f, 0x408 }, + { 0x90130, 0x169 }, + { 0x90131, 0x0 }, + { 0x90132, 0x8080 }, + { 0x90133, 0x108 }, + { 0x90134, 0x8 }, + { 0x90135, 0x7aa }, + { 0x90136, 0x6a }, + { 0x90137, 0x0 }, + { 0x90138, 0x8568 }, + { 0x90139, 0x108 }, + { 0x9013a, 0xb7 }, + { 0x9013b, 0x790 }, + { 0x9013c, 0x16a }, + { 0x9013d, 0x1f }, + { 0x9013e, 0x0 }, + { 0x9013f, 0x68 }, + { 0x90140, 0x8 }, + { 0x90141, 0x8558 }, + { 0x90142, 0x168 }, + { 0x90143, 0xf }, + { 0x90144, 0x408 }, + { 0x90145, 0x169 }, + { 0x90146, 0xd }, + { 0x90147, 0x0 }, + { 0x90148, 0x68 }, + { 0x90149, 0x0 }, + { 0x9014a, 0x408 }, + { 0x9014b, 0x169 }, + { 0x9014c, 0x0 }, + { 0x9014d, 0x8558 }, + { 0x9014e, 0x168 }, + { 0x9014f, 0x8 }, + { 0x90150, 0x3c8 }, + { 0x90151, 0x1a9 }, + { 0x90152, 0x3 }, + { 0x90153, 0x370 }, + { 0x90154, 0x129 }, + { 0x90155, 0x20 }, + { 0x90156, 0x2aa }, + { 0x90157, 0x9 }, + { 0x90158, 0x0 }, + { 0x90159, 0x400 }, + { 0x9015a, 0x10e }, + { 0x9015b, 0x8 }, + { 0x9015c, 0xe8 }, + { 0x9015d, 0x109 }, + { 0x9015e, 0x0 }, + { 0x9015f, 0x8140 }, + { 0x90160, 0x10c }, + { 0x90161, 0x10 }, + { 0x90162, 0x8138 }, + { 0x90163, 0x10c }, + { 0x90164, 0x8 }, + { 0x90165, 0x7c8 }, + { 0x90166, 0x101 }, + { 0x90167, 0x8 }, + { 0x90168, 0x448 }, + { 0x90169, 0x109 }, + { 0x9016a, 0xf }, + { 0x9016b, 0x7c0 }, + { 0x9016c, 0x109 }, + { 0x9016d, 0x0 }, + { 0x9016e, 0xe8 }, + { 0x9016f, 0x109 }, + { 0x90170, 0x47 }, + { 0x90171, 0x630 }, + { 0x90172, 0x109 }, + { 0x90173, 0x8 }, + { 0x90174, 0x618 }, + { 0x90175, 0x109 }, + { 0x90176, 0x8 }, + { 0x90177, 0xe0 }, + { 0x90178, 0x109 }, + { 0x90179, 0x0 }, + { 0x9017a, 0x7c8 }, + { 0x9017b, 0x109 }, + { 0x9017c, 0x8 }, + { 0x9017d, 0x8140 }, + { 0x9017e, 0x10c }, + { 0x9017f, 0x0 }, + { 0x90180, 0x1 }, + { 0x90181, 0x8 }, + { 0x90182, 0x8 }, + { 0x90183, 0x4 }, + { 0x90184, 0x8 }, + { 0x90185, 0x8 }, + { 0x90186, 0x7c8 }, + { 0x90187, 0x101 }, + { 0x90006, 0x0 }, + { 0x90007, 0x0 }, + { 0x90008, 0x8 }, + { 0x90009, 0x0 }, + { 0x9000a, 0x0 }, + { 0x9000b, 0x0 }, + { 0xd00e7, 0x400 }, + { 0x90017, 0x0 }, + { 0x9001f, 0x29 }, + { 0x90026, 0x6a }, + { 0x400d0, 0x0 }, + { 0x400d1, 0x101 }, + { 0x400d2, 0x105 }, + { 0x400d3, 0x107 }, + { 0x400d4, 0x10f }, + { 0x400d5, 0x202 }, + { 0x400d6, 0x20a }, + { 0x400d7, 0x20b }, + { 0x2003a, 0x2 }, + { 0x2000b, 0x64 }, + { 0x2000c, 0xc8 }, + { 0x2000d, 0x7d0 }, + { 0x2000e, 0x2c }, + { 0x12000b, 0xc }, + { 0x12000c, 0x19 }, + { 0x12000d, 0xfa }, + { 0x12000e, 0x10 }, + { 0x22000b, 0x3 }, + { 0x22000c, 0x6 }, + { 0x22000d, 0x3e }, + { 0x22000e, 0x10 }, + { 0x9000c, 0x0 }, + { 0x9000d, 0x173 }, + { 0x9000e, 0x60 }, + { 0x9000f, 0x6110 }, + { 0x90010, 0x2152 }, + { 0x90011, 0xdfbd }, + { 0x90012, 0x2060 }, + { 0x90013, 0x6152 }, + { 0x20010, 0x5a }, + { 0x20011, 0x3 }, + { 0x120010, 0x5a }, + { 0x120011, 0x3 }, + { 0x220010, 0x5a }, + { 0x220011, 0x3 }, + { 0x40080, 0xe0 }, + { 0x40081, 0x12 }, + { 0x40082, 0xe0 }, + { 0x40083, 0x12 }, + { 0x40084, 0xe0 }, + { 0x40085, 0x12 }, + { 0x140080, 0xe0 }, + { 0x140081, 0x12 }, + { 0x140082, 0xe0 }, + { 0x140083, 0x12 }, + { 0x140084, 0xe0 }, + { 0x140085, 0x12 }, + { 0x240080, 0xe0 }, + { 0x240081, 0x12 }, + { 0x240082, 0xe0 }, + { 0x240083, 0x12 }, + { 0x240084, 0xe0 }, + { 0x240085, 0x12 }, + { 0x400fd, 0xf }, + { 0x10011, 0x1 }, + { 0x10012, 0x1 }, + { 0x10013, 0x180 }, + { 0x10018, 0x1 }, + { 0x10002, 0x6209 }, + { 0x100b2, 0x1 }, + { 0x101b4, 0x1 }, + { 0x102b4, 0x1 }, + { 0x103b4, 0x1 }, + { 0x104b4, 0x1 }, + { 0x105b4, 0x1 }, + { 0x106b4, 0x1 }, + { 0x107b4, 0x1 }, + { 0x108b4, 0x1 }, + { 0x11011, 0x1 }, + { 0x11012, 0x1 }, + { 0x11013, 0x180 }, + { 0x11018, 0x1 }, + { 0x11002, 0x6209 }, + { 0x110b2, 0x1 }, + { 0x111b4, 0x1 }, + { 0x112b4, 0x1 }, + { 0x113b4, 0x1 }, + { 0x114b4, 0x1 }, + { 0x115b4, 0x1 }, + { 0x116b4, 0x1 }, + { 0x117b4, 0x1 }, + { 0x118b4, 0x1 }, + { 0x20089, 0x1 }, + { 0x20088, 0x19 }, + { 0xc0080, 0x2 }, + { 0xd0000, 0x1 } +}; + +static struct dram_fsp_msg ddr_dram_fsp_msg[] = { + { + /* P0 3200mts 1D */ + .drate = 3200, + .fw_type = FW_1D_IMAGE, + .fsp_cfg = ddr_fsp0_cfg, + .fsp_cfg_num = ARRAY_SIZE(ddr_fsp0_cfg), + }, + { + /* P1 400mts 1D */ + .drate = 400, + .fw_type = FW_1D_IMAGE, + .fsp_cfg = ddr_fsp1_cfg, + .fsp_cfg_num = ARRAY_SIZE(ddr_fsp1_cfg), + }, + { + /* P2 100mts 1D */ + .drate = 100, + .fw_type = FW_1D_IMAGE, + .fsp_cfg = ddr_fsp2_cfg, + .fsp_cfg_num = ARRAY_SIZE(ddr_fsp2_cfg), + }, + { + /* P0 3200mts 2D */ + .drate = 3200, + .fw_type = FW_2D_IMAGE, + .fsp_cfg = ddr_fsp0_2d_cfg, + .fsp_cfg_num = ARRAY_SIZE(ddr_fsp0_2d_cfg), + }, +}; + +/* ddr timing config params */ +struct dram_timing_info dram_timing_2gb_dual_die = { + .ddrc_cfg = ddr_ddrc_cfg, + .ddrc_cfg_num = ARRAY_SIZE(ddr_ddrc_cfg), + .ddrphy_cfg = ddr_ddrphy_cfg, + .ddrphy_cfg_num = ARRAY_SIZE(ddr_ddrphy_cfg), + .fsp_msg = ddr_dram_fsp_msg, + .fsp_msg_num = ARRAY_SIZE(ddr_dram_fsp_msg), + .ddrphy_trained_csr = ddr_ddrphy_trained_csr, + .ddrphy_trained_csr_num = ARRAY_SIZE(ddr_ddrphy_trained_csr), + .ddrphy_pie = ddr_phy_pie, + .ddrphy_pie_num = ARRAY_SIZE(ddr_phy_pie), + .fsp_table = { 3200, 400, 100, }, +}; + diff --git a/board/gateworks/venice/lpddr4_timing_imx8mn_2gb_single_die.c b/board/gateworks/venice/lpddr4_timing_imx8mn_2gb_single_die.c new file mode 100644 index 0000000000..9e94a81bb6 --- /dev/null +++ b/board/gateworks/venice/lpddr4_timing_imx8mn_2gb_single_die.c @@ -0,0 +1,1445 @@ +// SPDX-License-Identifier: GPL-2.0+ +/* + * Generated code from MX8M_DDR_tool v3.20 using RPAv5 + * - 2x Micron MT53E1G16D1FW-046 WT:A 16bit single-die for total of 2GiB + * - imx8mn-gw7902 + * + * Align with uboot version: + * imx_v2019.04_5.4.x and above version + * For imx_v2018.03_4.14.78_1.0.0_ga ~ imx_v2018.04_4.19.35_1.1.0_ga: + * please replace #include <asm/arch/ddr.h> with #include <asm/arch/imx8m_ddr.h> + */ + +#include <linux/kernel.h> +#include <asm/arch/ddr.h> + +static struct dram_cfg_param ddr_ddrc_cfg[] = { + /** Initialize DDRC registers **/ + { 0x3d400304, 0x1 }, + { 0x3d400030, 0x1 }, + { 0x3d400000, 0xa1080020 }, + { 0x3d400020, 0x203 }, + { 0x3d400024, 0x3e800 }, + { 0x3d400064, 0x610130 }, + { 0x3d4000d0, 0xc003061c }, + { 0x3d4000d4, 0x9e0000 }, + { 0x3d4000dc, 0xd4002d }, + { 0x3d4000e0, 0x310000 }, + { 0x3d4000e8, 0x66004d }, + { 0x3d4000ec, 0x16004d }, + { 0x3d400100, 0x1a201b22 }, + { 0x3d400104, 0x60633 }, + { 0x3d40010c, 0xc0c000 }, + { 0x3d400110, 0xf04080f }, + { 0x3d400114, 0x2040c0c }, + { 0x3d400118, 0x1010007 }, + { 0x3d40011c, 0x401 }, + { 0x3d400130, 0x20600 }, + { 0x3d400134, 0xc100002 }, + { 0x3d400138, 0x136 }, + { 0x3d400144, 0xa00050 }, + { 0x3d400180, 0x3200018 }, + { 0x3d400184, 0x28061a8 }, + { 0x3d400188, 0x0 }, + { 0x3d400190, 0x497820a }, + { 0x3d400194, 0x80303 }, + { 0x3d4001b4, 0x170a }, + { 0x3d4001a0, 0xe0400018 }, + { 0x3d4001a4, 0xdf00e4 }, + { 0x3d4001a8, 0x80000000 }, + { 0x3d4001b0, 0x11 }, + { 0x3d4001c0, 0x1 }, + { 0x3d4001c4, 0x1 }, + { 0x3d4000f4, 0xc99 }, + { 0x3d400108, 0x70e1617 }, + { 0x3d400200, 0x1f }, + { 0x3d40020c, 0x0 }, + { 0x3d400210, 0x1f1f }, + { 0x3d400204, 0x80808 }, + { 0x3d400214, 0x7070707 }, + { 0x3d400218, 0x7070707 }, + { 0x3d40021c, 0x7 }, + { 0x3d400250, 0x29001701 }, + { 0x3d400254, 0x2c }, + { 0x3d40025c, 0x4000030 }, + { 0x3d400264, 0x900093e7 }, + { 0x3d40026c, 0x2005574 }, + { 0x3d400400, 0x111 }, + { 0x3d400408, 0x72ff }, + { 0x3d400494, 0x2100e07 }, + { 0x3d400498, 0x620096 }, + { 0x3d40049c, 0x1100e07 }, + { 0x3d4004a0, 0xc8012c }, + { 0x3d402020, 0x1 }, + { 0x3d402024, 0x7d00 }, + { 0x3d402050, 0x20d040 }, + { 0x3d402064, 0xc0026 }, + { 0x3d4020dc, 0x840000 }, + { 0x3d4020e0, 0x310000 }, + { 0x3d4020e8, 0x66004d }, + { 0x3d4020ec, 0x16004d }, + { 0x3d402100, 0xa040305 }, + { 0x3d402104, 0x30407 }, + { 0x3d402108, 0x203060b }, + { 0x3d40210c, 0x505000 }, + { 0x3d402110, 0x2040202 }, + { 0x3d402114, 0x2030202 }, + { 0x3d402118, 0x1010004 }, + { 0x3d40211c, 0x301 }, + { 0x3d402130, 0x20300 }, + { 0x3d402134, 0xa100002 }, + { 0x3d402138, 0x27 }, + { 0x3d402144, 0x14000a }, + { 0x3d402180, 0x640004 }, + { 0x3d402190, 0x3818200 }, + { 0x3d402194, 0x80303 }, + { 0x3d4021b4, 0x100 }, + { 0x3d4020f4, 0xc99 }, + { 0x3d403020, 0x1 }, + { 0x3d403024, 0x1f40 }, + { 0x3d403050, 0x20d040 }, + { 0x3d403064, 0x3000a }, + { 0x3d4030dc, 0x840000 }, + { 0x3d4030e0, 0x310000 }, + { 0x3d4030e8, 0x66004d }, + { 0x3d4030ec, 0x16004d }, + { 0x3d403100, 0xa010102 }, + { 0x3d403104, 0x30404 }, + { 0x3d403108, 0x203060b }, + { 0x3d40310c, 0x505000 }, + { 0x3d403110, 0x2040202 }, + { 0x3d403114, 0x2030202 }, + { 0x3d403118, 0x1010004 }, + { 0x3d40311c, 0x301 }, + { 0x3d403130, 0x20300 }, + { 0x3d403134, 0xa100002 }, + { 0x3d403138, 0xa }, + { 0x3d403144, 0x50003 }, + { 0x3d403180, 0x190004 }, + { 0x3d403190, 0x3818200 }, + { 0x3d403194, 0x80303 }, + { 0x3d4031b4, 0x100 }, + { 0x3d4030f4, 0xc99 }, + { 0x3d400028, 0x0 }, +}; + +/* PHY Initialize Configuration */ +static struct dram_cfg_param ddr_ddrphy_cfg[] = { + { 0x100a0, 0x0 }, + { 0x100a1, 0x1 }, + { 0x100a2, 0x2 }, + { 0x100a3, 0x3 }, + { 0x100a4, 0x4 }, + { 0x100a5, 0x5 }, + { 0x100a6, 0x6 }, + { 0x100a7, 0x7 }, + { 0x110a0, 0x0 }, + { 0x110a1, 0x1 }, + { 0x110a2, 0x3 }, + { 0x110a3, 0x4 }, + { 0x110a4, 0x5 }, + { 0x110a5, 0x2 }, + { 0x110a6, 0x7 }, + { 0x110a7, 0x6 }, + { 0x1005f, 0x1ff }, + { 0x1015f, 0x1ff }, + { 0x1105f, 0x1ff }, + { 0x1115f, 0x1ff }, + { 0x11005f, 0x1ff }, + { 0x11015f, 0x1ff }, + { 0x11105f, 0x1ff }, + { 0x11115f, 0x1ff }, + { 0x21005f, 0x1ff }, + { 0x21015f, 0x1ff }, + { 0x21105f, 0x1ff }, + { 0x21115f, 0x1ff }, + { 0x55, 0x1ff }, + { 0x1055, 0x1ff }, + { 0x2055, 0x1ff }, + { 0x3055, 0x1ff }, + { 0x4055, 0x1ff }, + { 0x5055, 0x1ff }, + { 0x6055, 0x1ff }, + { 0x7055, 0x1ff }, + { 0x8055, 0x1ff }, + { 0x9055, 0x1ff }, + { 0x200c5, 0x19 }, + { 0x1200c5, 0x7 }, + { 0x2200c5, 0x7 }, + { 0x2002e, 0x2 }, + { 0x12002e, 0x2 }, + { 0x22002e, 0x2 }, + { 0x90204, 0x0 }, + { 0x190204, 0x0 }, + { 0x290204, 0x0 }, + { 0x20024, 0x1a3 }, + { 0x2003a, 0x2 }, + { 0x120024, 0x1a3 }, + { 0x2003a, 0x2 }, + { 0x220024, 0x1a3 }, + { 0x2003a, 0x2 }, + { 0x20056, 0x3 }, + { 0x120056, 0x3 }, + { 0x220056, 0x3 }, + { 0x1004d, 0xe00 }, + { 0x1014d, 0xe00 }, + { 0x1104d, 0xe00 }, + { 0x1114d, 0xe00 }, + { 0x11004d, 0xe00 }, + { 0x11014d, 0xe00 }, + { 0x11104d, 0xe00 }, + { 0x11114d, 0xe00 }, + { 0x21004d, 0xe00 }, + { 0x21014d, 0xe00 }, + { 0x21104d, 0xe00 }, + { 0x21114d, 0xe00 }, + { 0x10049, 0xeba }, + { 0x10149, 0xeba }, + { 0x11049, 0xeba }, + { 0x11149, 0xeba }, + { 0x110049, 0xeba }, + { 0x110149, 0xeba }, + { 0x111049, 0xeba }, + { 0x111149, 0xeba }, + { 0x210049, 0xeba }, + { 0x210149, 0xeba }, + { 0x211049, 0xeba }, + { 0x211149, 0xeba }, + { 0x43, 0x63 }, + { 0x1043, 0x63 }, + { 0x2043, 0x63 }, + { 0x3043, 0x63 }, + { 0x4043, 0x63 }, + { 0x5043, 0x63 }, + { 0x6043, 0x63 }, + { 0x7043, 0x63 }, + { 0x8043, 0x63 }, + { 0x9043, 0x63 }, + { 0x20018, 0x1 }, + { 0x20075, 0x4 }, + { 0x20050, 0x0 }, + { 0x20008, 0x320 }, + { 0x120008, 0x64 }, + { 0x220008, 0x19 }, + { 0x20088, 0x9 }, + { 0x200b2, 0xdc }, + { 0x10043, 0x5a1 }, + { 0x10143, 0x5a1 }, + { 0x11043, 0x5a1 }, + { 0x11143, 0x5a1 }, + { 0x1200b2, 0xdc }, + { 0x110043, 0x5a1 }, + { 0x110143, 0x5a1 }, + { 0x111043, 0x5a1 }, + { 0x111143, 0x5a1 }, + { 0x2200b2, 0xdc }, + { 0x210043, 0x5a1 }, + { 0x210143, 0x5a1 }, + { 0x211043, 0x5a1 }, + { 0x211143, 0x5a1 }, + { 0x200fa, 0x1 }, + { 0x1200fa, 0x1 }, + { 0x2200fa, 0x1 }, + { 0x20019, 0x1 }, + { 0x120019, 0x1 }, + { 0x220019, 0x1 }, + { 0x200f0, 0x660 }, + { 0x200f1, 0x0 }, + { 0x200f2, 0x4444 }, + { 0x200f3, 0x8888 }, + { 0x200f4, 0x5665 }, + { 0x200f5, 0x0 }, + { 0x200f6, 0x0 }, + { 0x200f7, 0xf000 }, + { 0x20025, 0x0 }, + { 0x2002d, 0x0 }, + { 0x12002d, 0x0 }, + { 0x22002d, 0x0 }, + { 0x2005b, 0x7529 }, + { 0x2005c, 0x0 }, + { 0x200c7, 0x21 }, + { 0x200ca, 0x24 }, + { 0x200cc, 0x1f7 }, + { 0x1200c7, 0x21 }, + { 0x1200ca, 0x24 }, + { 0x1200cc, 0x1f7 }, + { 0x2200c7, 0x21 }, + { 0x2200ca, 0x24 }, + { 0x2200cc, 0x1f7 }, + { 0x2007d, 0x212 }, + { 0x12007d, 0x212 }, + { 0x22007d, 0x212 }, + { 0x2007c, 0x61 }, + { 0x12007c, 0x61 }, + { 0x22007c, 0x61 }, + { 0x1004a, 0x500 }, + { 0x1104a, 0x500 }, + { 0x2002c, 0x0 }, +}; + +/* ddr phy trained csr */ +static struct dram_cfg_param ddr_ddrphy_trained_csr[] = { + {0x0200b2, 0x0}, + {0x1200b2, 0x0}, + {0x2200b2, 0x0}, + {0x0200cb, 0x0}, + {0x010043, 0x0}, + {0x110043, 0x0}, + {0x210043, 0x0}, + {0x010143, 0x0}, + {0x110143, 0x0}, + {0x210143, 0x0}, + {0x011043, 0x0}, + {0x111043, 0x0}, + {0x211043, 0x0}, + {0x011143, 0x0}, + {0x111143, 0x0}, + {0x211143, 0x0}, + {0x000080, 0x0}, + {0x100080, 0x0}, + {0x200080, 0x0}, + {0x001080, 0x0}, + {0x101080, 0x0}, + {0x201080, 0x0}, + {0x002080, 0x0}, + {0x102080, 0x0}, + {0x202080, 0x0}, + {0x003080, 0x0}, + {0x103080, 0x0}, + {0x203080, 0x0}, + {0x004080, 0x0}, + {0x104080, 0x0}, + {0x204080, 0x0}, + {0x005080, 0x0}, + {0x105080, 0x0}, + {0x205080, 0x0}, + {0x006080, 0x0}, + {0x106080, 0x0}, + {0x206080, 0x0}, + {0x007080, 0x0}, + {0x107080, 0x0}, + {0x207080, 0x0}, + {0x008080, 0x0}, + {0x108080, 0x0}, + {0x208080, 0x0}, + {0x009080, 0x0}, + {0x109080, 0x0}, + {0x209080, 0x0}, + {0x010080, 0x0}, + {0x110080, 0x0}, + {0x210080, 0x0}, + {0x010180, 0x0}, + {0x110180, 0x0}, + {0x210180, 0x0}, + {0x011080, 0x0}, + {0x111080, 0x0}, + {0x211080, 0x0}, + {0x011180, 0x0}, + {0x111180, 0x0}, + {0x211180, 0x0}, + {0x010081, 0x0}, + {0x110081, 0x0}, + {0x210081, 0x0}, + {0x010181, 0x0}, + {0x110181, 0x0}, + {0x210181, 0x0}, + {0x011081, 0x0}, + {0x111081, 0x0}, + {0x211081, 0x0}, + {0x011181, 0x0}, + {0x111181, 0x0}, + {0x211181, 0x0}, + {0x0100d0, 0x0}, + {0x1100d0, 0x0}, + {0x2100d0, 0x0}, + {0x0101d0, 0x0}, + {0x1101d0, 0x0}, + {0x2101d0, 0x0}, + {0x0110d0, 0x0}, + {0x1110d0, 0x0}, + {0x2110d0, 0x0}, + {0x0111d0, 0x0}, + {0x1111d0, 0x0}, + {0x2111d0, 0x0}, + {0x0100d1, 0x0}, + {0x1100d1, 0x0}, + {0x2100d1, 0x0}, + {0x0101d1, 0x0}, + {0x1101d1, 0x0}, + {0x2101d1, 0x0}, + {0x0110d1, 0x0}, + {0x1110d1, 0x0}, + {0x2110d1, 0x0}, + {0x0111d1, 0x0}, + {0x1111d1, 0x0}, + {0x2111d1, 0x0}, + {0x010068, 0x0}, + {0x010168, 0x0}, + {0x010268, 0x0}, + {0x010368, 0x0}, + {0x010468, 0x0}, + {0x010568, 0x0}, + {0x010668, 0x0}, + {0x010768, 0x0}, + {0x010868, 0x0}, + {0x011068, 0x0}, + {0x011168, 0x0}, + {0x011268, 0x0}, + {0x011368, 0x0}, + {0x011468, 0x0}, + {0x011568, 0x0}, + {0x011668, 0x0}, + {0x011768, 0x0}, + {0x011868, 0x0}, + {0x010069, 0x0}, + {0x010169, 0x0}, + {0x010269, 0x0}, + {0x010369, 0x0}, + {0x010469, 0x0}, + {0x010569, 0x0}, + {0x010669, 0x0}, + {0x010769, 0x0}, + {0x010869, 0x0}, + {0x011069, 0x0}, + {0x011169, 0x0}, + {0x011269, 0x0}, + {0x011369, 0x0}, + {0x011469, 0x0}, + {0x011569, 0x0}, + {0x011669, 0x0}, + {0x011769, 0x0}, + {0x011869, 0x0}, + {0x01008c, 0x0}, + {0x11008c, 0x0}, + {0x21008c, 0x0}, + {0x01018c, 0x0}, + {0x11018c, 0x0}, + {0x21018c, 0x0}, + {0x01108c, 0x0}, + {0x11108c, 0x0}, + {0x21108c, 0x0}, + {0x01118c, 0x0}, + {0x11118c, 0x0}, + {0x21118c, 0x0}, + {0x01008d, 0x0}, + {0x11008d, 0x0}, + {0x21008d, 0x0}, + {0x01018d, 0x0}, + {0x11018d, 0x0}, + {0x21018d, 0x0}, + {0x01108d, 0x0}, + {0x11108d, 0x0}, + {0x21108d, 0x0}, + {0x01118d, 0x0}, + {0x11118d, 0x0}, + {0x21118d, 0x0}, + {0x0100c0, 0x0}, + {0x1100c0, 0x0}, + {0x2100c0, 0x0}, + {0x0101c0, 0x0}, + {0x1101c0, 0x0}, + {0x2101c0, 0x0}, + {0x0102c0, 0x0}, + {0x1102c0, 0x0}, + {0x2102c0, 0x0}, + {0x0103c0, 0x0}, + {0x1103c0, 0x0}, + {0x2103c0, 0x0}, + {0x0104c0, 0x0}, + {0x1104c0, 0x0}, + {0x2104c0, 0x0}, + {0x0105c0, 0x0}, + {0x1105c0, 0x0}, + {0x2105c0, 0x0}, + {0x0106c0, 0x0}, + {0x1106c0, 0x0}, + {0x2106c0, 0x0}, + {0x0107c0, 0x0}, + {0x1107c0, 0x0}, + {0x2107c0, 0x0}, + {0x0108c0, 0x0}, + {0x1108c0, 0x0}, + {0x2108c0, 0x0}, + {0x0110c0, 0x0}, + {0x1110c0, 0x0}, + {0x2110c0, 0x0}, + {0x0111c0, 0x0}, + {0x1111c0, 0x0}, + {0x2111c0, 0x0}, + {0x0112c0, 0x0}, + {0x1112c0, 0x0}, + {0x2112c0, 0x0}, + {0x0113c0, 0x0}, + {0x1113c0, 0x0}, + {0x2113c0, 0x0}, + {0x0114c0, 0x0}, + {0x1114c0, 0x0}, + {0x2114c0, 0x0}, + {0x0115c0, 0x0}, + {0x1115c0, 0x0}, + {0x2115c0, 0x0}, + {0x0116c0, 0x0}, + {0x1116c0, 0x0}, + {0x2116c0, 0x0}, + {0x0117c0, 0x0}, + {0x1117c0, 0x0}, + {0x2117c0, 0x0}, + {0x0118c0, 0x0}, + {0x1118c0, 0x0}, + {0x2118c0, 0x0}, + {0x0100c1, 0x0}, + {0x1100c1, 0x0}, + {0x2100c1, 0x0}, + {0x0101c1, 0x0}, + {0x1101c1, 0x0}, + {0x2101c1, 0x0}, + {0x0102c1, 0x0}, + {0x1102c1, 0x0}, + {0x2102c1, 0x0}, + {0x0103c1, 0x0}, + {0x1103c1, 0x0}, + {0x2103c1, 0x0}, + {0x0104c1, 0x0}, + {0x1104c1, 0x0}, + {0x2104c1, 0x0}, + {0x0105c1, 0x0}, + {0x1105c1, 0x0}, + {0x2105c1, 0x0}, + {0x0106c1, 0x0}, + {0x1106c1, 0x0}, + {0x2106c1, 0x0}, + {0x0107c1, 0x0}, + {0x1107c1, 0x0}, + {0x2107c1, 0x0}, + {0x0108c1, 0x0}, + {0x1108c1, 0x0}, + {0x2108c1, 0x0}, + {0x0110c1, 0x0}, + {0x1110c1, 0x0}, + {0x2110c1, 0x0}, + {0x0111c1, 0x0}, + {0x1111c1, 0x0}, + {0x2111c1, 0x0}, + {0x0112c1, 0x0}, + {0x1112c1, 0x0}, + {0x2112c1, 0x0}, + {0x0113c1, 0x0}, + {0x1113c1, 0x0}, + {0x2113c1, 0x0}, + {0x0114c1, 0x0}, + {0x1114c1, 0x0}, + {0x2114c1, 0x0}, + {0x0115c1, 0x0}, + {0x1115c1, 0x0}, + {0x2115c1, 0x0}, + {0x0116c1, 0x0}, + {0x1116c1, 0x0}, + {0x2116c1, 0x0}, + {0x0117c1, 0x0}, + {0x1117c1, 0x0}, + {0x2117c1, 0x0}, + {0x0118c1, 0x0}, + {0x1118c1, 0x0}, + {0x2118c1, 0x0}, + {0x010020, 0x0}, + {0x110020, 0x0}, + {0x210020, 0x0}, + {0x011020, 0x0}, + {0x111020, 0x0}, + {0x211020, 0x0}, + {0x020072, 0x0}, + {0x020073, 0x0}, + {0x020074, 0x0}, + {0x0100aa, 0x0}, + {0x0110aa, 0x0}, + {0x020010, 0x0}, + {0x120010, 0x0}, + {0x220010, 0x0}, + {0x020011, 0x0}, + {0x120011, 0x0}, + {0x220011, 0x0}, + {0x0100ae, 0x0}, + {0x1100ae, 0x0}, + {0x2100ae, 0x0}, + {0x0100af, 0x0}, + {0x1100af, 0x0}, + {0x2100af, 0x0}, + {0x0110ae, 0x0}, + {0x1110ae, 0x0}, + {0x2110ae, 0x0}, + {0x0110af, 0x0}, + {0x1110af, 0x0}, + {0x2110af, 0x0}, + {0x020020, 0x0}, + {0x120020, 0x0}, + {0x220020, 0x0}, + {0x0100a0, 0x0}, + {0x0100a1, 0x0}, + {0x0100a2, 0x0}, + {0x0100a3, 0x0}, + {0x0100a4, 0x0}, + {0x0100a5, 0x0}, + {0x0100a6, 0x0}, + {0x0100a7, 0x0}, + {0x0110a0, 0x0}, + {0x0110a1, 0x0}, + {0x0110a2, 0x0}, + {0x0110a3, 0x0}, + {0x0110a4, 0x0}, + {0x0110a5, 0x0}, + {0x0110a6, 0x0}, + {0x0110a7, 0x0}, + {0x02007c, 0x0}, + {0x12007c, 0x0}, + {0x22007c, 0x0}, + {0x02007d, 0x0}, + {0x12007d, 0x0}, + {0x22007d, 0x0}, + {0x0400fd, 0x0}, + {0x0400c0, 0x0}, + {0x090201, 0x0}, + {0x190201, 0x0}, + {0x290201, 0x0}, + {0x090202, 0x0}, + {0x190202, 0x0}, + {0x290202, 0x0}, + {0x090203, 0x0}, + {0x190203, 0x0}, + {0x290203, 0x0}, + {0x090204, 0x0}, + {0x190204, 0x0}, + {0x290204, 0x0}, + {0x090205, 0x0}, + {0x190205, 0x0}, + {0x290205, 0x0}, + {0x090206, 0x0}, + {0x190206, 0x0}, + {0x290206, 0x0}, + {0x090207, 0x0}, + {0x190207, 0x0}, + {0x290207, 0x0}, + {0x090208, 0x0}, + {0x190208, 0x0}, + {0x290208, 0x0}, + {0x010062, 0x0}, + {0x010162, 0x0}, + {0x010262, 0x0}, + {0x010362, 0x0}, + {0x010462, 0x0}, + {0x010562, 0x0}, + {0x010662, 0x0}, + {0x010762, 0x0}, + {0x010862, 0x0}, + {0x011062, 0x0}, + {0x011162, 0x0}, + {0x011262, 0x0}, + {0x011362, 0x0}, + {0x011462, 0x0}, + {0x011562, 0x0}, + {0x011662, 0x0}, + {0x011762, 0x0}, + {0x011862, 0x0}, + {0x020077, 0x0}, + {0x010001, 0x0}, + {0x011001, 0x0}, + {0x010040, 0x0}, + {0x010140, 0x0}, + {0x010240, 0x0}, + {0x010340, 0x0}, + {0x010440, 0x0}, + {0x010540, 0x0}, + {0x010640, 0x0}, + {0x010740, 0x0}, + {0x010840, 0x0}, + {0x010030, 0x0}, + {0x010130, 0x0}, + {0x010230, 0x0}, + {0x010330, 0x0}, + {0x010430, 0x0}, + {0x010530, 0x0}, + {0x010630, 0x0}, + {0x010730, 0x0}, + {0x010830, 0x0}, + {0x011040, 0x0}, + {0x011140, 0x0}, + {0x011240, 0x0}, + {0x011340, 0x0}, + {0x011440, 0x0}, + {0x011540, 0x0}, + {0x011640, 0x0}, + {0x011740, 0x0}, + {0x011840, 0x0}, + {0x011030, 0x0}, + {0x011130, 0x0}, + {0x011230, 0x0}, + {0x011330, 0x0}, + {0x011430, 0x0}, + {0x011530, 0x0}, + {0x011630, 0x0}, + {0x011730, 0x0}, + {0x011830, 0x0}, +}; + +/* P0 message block paremeter for training firmware */ +static struct dram_cfg_param ddr_fsp0_cfg[] = { + { 0xd0000, 0x0 }, + { 0x54003, 0xc80 }, + { 0x54004, 0x2 }, + { 0x54005, 0x2228 }, + { 0x54006, 0x11 }, + { 0x54008, 0x131f }, + { 0x54009, 0xc8 }, + { 0x5400b, 0x2 }, + { 0x5400f, 0x100 }, + { 0x54012, 0x110 }, + { 0x54019, 0x2dd4 }, + { 0x5401a, 0x31 }, + { 0x5401b, 0x4d66 }, + { 0x5401c, 0x4d00 }, + { 0x5401e, 0x16 }, + { 0x5401f, 0x2dd4 }, + { 0x54020, 0x31 }, + { 0x54021, 0x4d66 }, + { 0x54022, 0x4d00 }, + { 0x54024, 0x16 }, + { 0x54032, 0xd400 }, + { 0x54033, 0x312d }, + { 0x54034, 0x6600 }, + { 0x54035, 0x4d }, + { 0x54036, 0x4d }, + { 0x54037, 0x1600 }, + { 0x54038, 0xd400 }, + { 0x54039, 0x312d }, + { 0x5403a, 0x6600 }, + { 0x5403b, 0x4d }, + { 0x5403c, 0x4d }, + { 0x5403d, 0x1600 }, + { 0xd0000, 0x1 }, +}; + +/* P1 message block paremeter for training firmware */ +static struct dram_cfg_param ddr_fsp1_cfg[] = { + { 0xd0000, 0x0 }, + { 0x54002, 0x101 }, + { 0x54003, 0x190 }, + { 0x54004, 0x2 }, + { 0x54005, 0x2228 }, + { 0x54006, 0x11 }, + { 0x54008, 0x121f }, + { 0x54009, 0xc8 }, + { 0x5400b, 0x2 }, + { 0x5400f, 0x100 }, + { 0x54012, 0x110 }, + { 0x54019, 0x84 }, + { 0x5401a, 0x31 }, + { 0x5401b, 0x4d66 }, + { 0x5401c, 0x4d00 }, + { 0x5401e, 0x16 }, + { 0x5401f, 0x84 }, + { 0x54020, 0x31 }, + { 0x54021, 0x4d66 }, + { 0x54022, 0x4d00 }, + { 0x54024, 0x16 }, + { 0x54032, 0x8400 }, + { 0x54033, 0x3100 }, + { 0x54034, 0x6600 }, + { 0x54035, 0x4d }, + { 0x54036, 0x4d }, + { 0x54037, 0x1600 }, + { 0x54038, 0x8400 }, + { 0x54039, 0x3100 }, + { 0x5403a, 0x6600 }, + { 0x5403b, 0x4d }, + { 0x5403c, 0x4d }, + { 0x5403d, 0x1600 }, + { 0xd0000, 0x1 }, +}; + +/* P2 message block paremeter for training firmware */ +static struct dram_cfg_param ddr_fsp2_cfg[] = { + { 0xd0000, 0x0 }, + { 0x54002, 0x102 }, + { 0x54003, 0x64 }, + { 0x54004, 0x2 }, + { 0x54005, 0x2228 }, + { 0x54006, 0x11 }, + { 0x54008, 0x121f }, + { 0x54009, 0xc8 }, + { 0x5400b, 0x2 }, + { 0x5400f, 0x100 }, + { 0x54012, 0x110 }, + { 0x54019, 0x84 }, + { 0x5401a, 0x31 }, + { 0x5401b, 0x4d66 }, + { 0x5401c, 0x4d00 }, + { 0x5401e, 0x16 }, + { 0x5401f, 0x84 }, + { 0x54020, 0x31 }, + { 0x54021, 0x4d66 }, + { 0x54022, 0x4d00 }, + { 0x54024, 0x16 }, + { 0x54032, 0x8400 }, + { 0x54033, 0x3100 }, + { 0x54034, 0x6600 }, + { 0x54035, 0x4d }, + { 0x54036, 0x4d }, + { 0x54037, 0x1600 }, + { 0x54038, 0x8400 }, + { 0x54039, 0x3100 }, + { 0x5403a, 0x6600 }, + { 0x5403b, 0x4d }, + { 0x5403c, 0x4d }, + { 0x5403d, 0x1600 }, + { 0xd0000, 0x1 }, +}; + +/* P0 2D message block paremeter for training firmware */ +static struct dram_cfg_param ddr_fsp0_2d_cfg[] = { + { 0xd0000, 0x0 }, + { 0x54003, 0xc80 }, + { 0x54004, 0x2 }, + { 0x54005, 0x2228 }, + { 0x54006, 0x11 }, + { 0x54008, 0x61 }, + { 0x54009, 0xc8 }, + { 0x5400b, 0x2 }, + { 0x5400f, 0x100 }, + { 0x54010, 0x1f7f }, + { 0x54012, 0x110 }, + { 0x54019, 0x2dd4 }, + { 0x5401a, 0x31 }, + { 0x5401b, 0x4d66 }, + { 0x5401c, 0x4d00 }, + { 0x5401e, 0x16 }, + { 0x5401f, 0x2dd4 }, + { 0x54020, 0x31 }, + { 0x54021, 0x4d66 }, + { 0x54022, 0x4d00 }, + { 0x54024, 0x16 }, + { 0x54032, 0xd400 }, + { 0x54033, 0x312d }, + { 0x54034, 0x6600 }, + { 0x54035, 0x4d }, + { 0x54036, 0x4d }, + { 0x54037, 0x1600 }, + { 0x54038, 0xd400 }, + { 0x54039, 0x312d }, + { 0x5403a, 0x6600 }, + { 0x5403b, 0x4d }, + { 0x5403c, 0x4d }, + { 0x5403d, 0x1600 }, + { 0xd0000, 0x1 }, +}; + +/* DRAM PHY init engine image */ +static struct dram_cfg_param ddr_phy_pie[] = { + { 0xd0000, 0x0 }, + { 0x90000, 0x10 }, + { 0x90001, 0x400 }, + { 0x90002, 0x10e }, + { 0x90003, 0x0 }, + { 0x90004, 0x0 }, + { 0x90005, 0x8 }, + { 0x90029, 0xb }, + { 0x9002a, 0x480 }, + { 0x9002b, 0x109 }, + { 0x9002c, 0x8 }, + { 0x9002d, 0x448 }, + { 0x9002e, 0x139 }, + { 0x9002f, 0x8 }, + { 0x90030, 0x478 }, + { 0x90031, 0x109 }, + { 0x90032, 0x0 }, + { 0x90033, 0xe8 }, + { 0x90034, 0x109 }, + { 0x90035, 0x2 }, + { 0x90036, 0x10 }, + { 0x90037, 0x139 }, + { 0x90038, 0xb }, + { 0x90039, 0x7c0 }, + { 0x9003a, 0x139 }, + { 0x9003b, 0x44 }, + { 0x9003c, 0x633 }, + { 0x9003d, 0x159 }, + { 0x9003e, 0x14f }, + { 0x9003f, 0x630 }, + { 0x90040, 0x159 }, + { 0x90041, 0x47 }, + { 0x90042, 0x633 }, + { 0x90043, 0x149 }, + { 0x90044, 0x4f }, + { 0x90045, 0x633 }, + { 0x90046, 0x179 }, + { 0x90047, 0x8 }, + { 0x90048, 0xe0 }, + { 0x90049, 0x109 }, + { 0x9004a, 0x0 }, + { 0x9004b, 0x7c8 }, + { 0x9004c, 0x109 }, + { 0x9004d, 0x0 }, + { 0x9004e, 0x1 }, + { 0x9004f, 0x8 }, + { 0x90050, 0x0 }, + { 0x90051, 0x45a }, + { 0x90052, 0x9 }, + { 0x90053, 0x0 }, + { 0x90054, 0x448 }, + { 0x90055, 0x109 }, + { 0x90056, 0x40 }, + { 0x90057, 0x633 }, + { 0x90058, 0x179 }, + { 0x90059, 0x1 }, + { 0x9005a, 0x618 }, + { 0x9005b, 0x109 }, + { 0x9005c, 0x40c0 }, + { 0x9005d, 0x633 }, + { 0x9005e, 0x149 }, + { 0x9005f, 0x8 }, + { 0x90060, 0x4 }, + { 0x90061, 0x48 }, + { 0x90062, 0x4040 }, + { 0x90063, 0x633 }, + { 0x90064, 0x149 }, + { 0x90065, 0x0 }, + { 0x90066, 0x4 }, + { 0x90067, 0x48 }, + { 0x90068, 0x40 }, + { 0x90069, 0x633 }, + { 0x9006a, 0x149 }, + { 0x9006b, 0x10 }, + { 0x9006c, 0x4 }, + { 0x9006d, 0x18 }, + { 0x9006e, 0x0 }, + { 0x9006f, 0x4 }, + { 0x90070, 0x78 }, + { 0x90071, 0x549 }, + { 0x90072, 0x633 }, + { 0x90073, 0x159 }, + { 0x90074, 0xd49 }, + { 0x90075, 0x633 }, + { 0x90076, 0x159 }, + { 0x90077, 0x94a }, + { 0x90078, 0x633 }, + { 0x90079, 0x159 }, + { 0x9007a, 0x441 }, + { 0x9007b, 0x633 }, + { 0x9007c, 0x149 }, + { 0x9007d, 0x42 }, + { 0x9007e, 0x633 }, + { 0x9007f, 0x149 }, + { 0x90080, 0x1 }, + { 0x90081, 0x633 }, + { 0x90082, 0x149 }, + { 0x90083, 0x0 }, + { 0x90084, 0xe0 }, + { 0x90085, 0x109 }, + { 0x90086, 0xa }, + { 0x90087, 0x10 }, + { 0x90088, 0x109 }, + { 0x90089, 0x9 }, + { 0x9008a, 0x3c0 }, + { 0x9008b, 0x149 }, + { 0x9008c, 0x9 }, + { 0x9008d, 0x3c0 }, + { 0x9008e, 0x159 }, + { 0x9008f, 0x18 }, + { 0x90090, 0x10 }, + { 0x90091, 0x109 }, + { 0x90092, 0x0 }, + { 0x90093, 0x3c0 }, + { 0x90094, 0x109 }, + { 0x90095, 0x18 }, + { 0x90096, 0x4 }, + { 0x90097, 0x48 }, + { 0x90098, 0x18 }, + { 0x90099, 0x4 }, + { 0x9009a, 0x58 }, + { 0x9009b, 0xb }, + { 0x9009c, 0x10 }, + { 0x9009d, 0x109 }, + { 0x9009e, 0x1 }, + { 0x9009f, 0x10 }, + { 0x900a0, 0x109 }, + { 0x900a1, 0x5 }, + { 0x900a2, 0x7c0 }, + { 0x900a3, 0x109 }, + { 0x40000, 0x811 }, + { 0x40020, 0x880 }, + { 0x40040, 0x0 }, + { 0x40060, 0x0 }, + { 0x40001, 0x4008 }, + { 0x40021, 0x83 }, + { 0x40041, 0x4f }, + { 0x40061, 0x0 }, + { 0x40002, 0x4040 }, + { 0x40022, 0x83 }, + { 0x40042, 0x51 }, + { 0x40062, 0x0 }, + { 0x40003, 0x811 }, + { 0x40023, 0x880 }, + { 0x40043, 0x0 }, + { 0x40063, 0x0 }, + { 0x40004, 0x720 }, + { 0x40024, 0xf }, + { 0x40044, 0x1740 }, + { 0x40064, 0x0 }, + { 0x40005, 0x16 }, + { 0x40025, 0x83 }, + { 0x40045, 0x4b }, + { 0x40065, 0x0 }, + { 0x40006, 0x716 }, + { 0x40026, 0xf }, + { 0x40046, 0x2001 }, + { 0x40066, 0x0 }, + { 0x40007, 0x716 }, + { 0x40027, 0xf }, + { 0x40047, 0x2800 }, + { 0x40067, 0x0 }, + { 0x40008, 0x716 }, + { 0x40028, 0xf }, + { 0x40048, 0xf00 }, + { 0x40068, 0x0 }, + { 0x40009, 0x720 }, + { 0x40029, 0xf }, + { 0x40049, 0x1400 }, + { 0x40069, 0x0 }, + { 0x4000a, 0xe08 }, + { 0x4002a, 0xc15 }, + { 0x4004a, 0x0 }, + { 0x4006a, 0x0 }, + { 0x4000b, 0x625 }, + { 0x4002b, 0x15 }, + { 0x4004b, 0x0 }, + { 0x4006b, 0x0 }, + { 0x4000c, 0x4028 }, + { 0x4002c, 0x80 }, + { 0x4004c, 0x0 }, + { 0x4006c, 0x0 }, + { 0x4000d, 0xe08 }, + { 0x4002d, 0xc1a }, + { 0x4004d, 0x0 }, + { 0x4006d, 0x0 }, + { 0x4000e, 0x625 }, + { 0x4002e, 0x1a }, + { 0x4004e, 0x0 }, + { 0x4006e, 0x0 }, + { 0x4000f, 0x4040 }, + { 0x4002f, 0x80 }, + { 0x4004f, 0x0 }, + { 0x4006f, 0x0 }, + { 0x40010, 0x2604 }, + { 0x40030, 0x15 }, + { 0x40050, 0x0 }, + { 0x40070, 0x0 }, + { 0x40011, 0x708 }, + { 0x40031, 0x5 }, + { 0x40051, 0x0 }, + { 0x40071, 0x2002 }, + { 0x40012, 0x8 }, + { 0x40032, 0x80 }, + { 0x40052, 0x0 }, + { 0x40072, 0x0 }, + { 0x40013, 0x2604 }, + { 0x40033, 0x1a }, + { 0x40053, 0x0 }, + { 0x40073, 0x0 }, + { 0x40014, 0x708 }, + { 0x40034, 0xa }, + { 0x40054, 0x0 }, + { 0x40074, 0x2002 }, + { 0x40015, 0x4040 }, + { 0x40035, 0x80 }, + { 0x40055, 0x0 }, + { 0x40075, 0x0 }, + { 0x40016, 0x60a }, + { 0x40036, 0x15 }, + { 0x40056, 0x1200 }, + { 0x40076, 0x0 }, + { 0x40017, 0x61a }, + { 0x40037, 0x15 }, + { 0x40057, 0x1300 }, + { 0x40077, 0x0 }, + { 0x40018, 0x60a }, + { 0x40038, 0x1a }, + { 0x40058, 0x1200 }, + { 0x40078, 0x0 }, + { 0x40019, 0x642 }, + { 0x40039, 0x1a }, + { 0x40059, 0x1300 }, + { 0x40079, 0x0 }, + { 0x4001a, 0x4808 }, + { 0x4003a, 0x880 }, + { 0x4005a, 0x0 }, + { 0x4007a, 0x0 }, + { 0x900a4, 0x0 }, + { 0x900a5, 0x790 }, + { 0x900a6, 0x11a }, + { 0x900a7, 0x8 }, + { 0x900a8, 0x7aa }, + { 0x900a9, 0x2a }, + { 0x900aa, 0x10 }, + { 0x900ab, 0x7b2 }, + { 0x900ac, 0x2a }, + { 0x900ad, 0x0 }, + { 0x900ae, 0x7c8 }, + { 0x900af, 0x109 }, + { 0x900b0, 0x10 }, + { 0x900b1, 0x10 }, + { 0x900b2, 0x109 }, + { 0x900b3, 0x10 }, + { 0x900b4, 0x2a8 }, + { 0x900b5, 0x129 }, + { 0x900b6, 0x8 }, + { 0x900b7, 0x370 }, + { 0x900b8, 0x129 }, + { 0x900b9, 0xa }, + { 0x900ba, 0x3c8 }, + { 0x900bb, 0x1a9 }, + { 0x900bc, 0xc }, + { 0x900bd, 0x408 }, + { 0x900be, 0x199 }, + { 0x900bf, 0x14 }, + { 0x900c0, 0x790 }, + { 0x900c1, 0x11a }, + { 0x900c2, 0x8 }, + { 0x900c3, 0x4 }, + { 0x900c4, 0x18 }, + { 0x900c5, 0xe }, + { 0x900c6, 0x408 }, + { 0x900c7, 0x199 }, + { 0x900c8, 0x8 }, + { 0x900c9, 0x8568 }, + { 0x900ca, 0x108 }, + { 0x900cb, 0x18 }, + { 0x900cc, 0x790 }, + { 0x900cd, 0x16a }, + { 0x900ce, 0x8 }, + { 0x900cf, 0x1d8 }, + { 0x900d0, 0x169 }, + { 0x900d1, 0x10 }, + { 0x900d2, 0x8558 }, + { 0x900d3, 0x168 }, + { 0x900d4, 0x70 }, + { 0x900d5, 0x788 }, + { 0x900d6, 0x16a }, + { 0x900d7, 0x1ff8 }, + { 0x900d8, 0x85a8 }, + { 0x900d9, 0x1e8 }, + { 0x900da, 0x50 }, + { 0x900db, 0x798 }, + { 0x900dc, 0x16a }, + { 0x900dd, 0x60 }, + { 0x900de, 0x7a0 }, + { 0x900df, 0x16a }, + { 0x900e0, 0x8 }, + { 0x900e1, 0x8310 }, + { 0x900e2, 0x168 }, + { 0x900e3, 0x8 }, + { 0x900e4, 0xa310 }, + { 0x900e5, 0x168 }, + { 0x900e6, 0xa }, + { 0x900e7, 0x408 }, + { 0x900e8, 0x169 }, + { 0x900e9, 0x6e }, + { 0x900ea, 0x0 }, + { 0x900eb, 0x68 }, + { 0x900ec, 0x0 }, + { 0x900ed, 0x408 }, + { 0x900ee, 0x169 }, + { 0x900ef, 0x0 }, + { 0x900f0, 0x8310 }, + { 0x900f1, 0x168 }, + { 0x900f2, 0x0 }, + { 0x900f3, 0xa310 }, + { 0x900f4, 0x168 }, + { 0x900f5, 0x1ff8 }, + { 0x900f6, 0x85a8 }, + { 0x900f7, 0x1e8 }, + { 0x900f8, 0x68 }, + { 0x900f9, 0x798 }, + { 0x900fa, 0x16a }, + { 0x900fb, 0x78 }, + { 0x900fc, 0x7a0 }, + { 0x900fd, 0x16a }, + { 0x900fe, 0x68 }, + { 0x900ff, 0x790 }, + { 0x90100, 0x16a }, + { 0x90101, 0x8 }, + { 0x90102, 0x8b10 }, + { 0x90103, 0x168 }, + { 0x90104, 0x8 }, + { 0x90105, 0xab10 }, + { 0x90106, 0x168 }, + { 0x90107, 0xa }, + { 0x90108, 0x408 }, + { 0x90109, 0x169 }, + { 0x9010a, 0x58 }, + { 0x9010b, 0x0 }, + { 0x9010c, 0x68 }, + { 0x9010d, 0x0 }, + { 0x9010e, 0x408 }, + { 0x9010f, 0x169 }, + { 0x90110, 0x0 }, + { 0x90111, 0x8b10 }, + { 0x90112, 0x168 }, + { 0x90113, 0x0 }, + { 0x90114, 0xab10 }, + { 0x90115, 0x168 }, + { 0x90116, 0x0 }, + { 0x90117, 0x1d8 }, + { 0x90118, 0x169 }, + { 0x90119, 0x80 }, + { 0x9011a, 0x790 }, + { 0x9011b, 0x16a }, + { 0x9011c, 0x18 }, + { 0x9011d, 0x7aa }, + { 0x9011e, 0x6a }, + { 0x9011f, 0xa }, + { 0x90120, 0x0 }, + { 0x90121, 0x1e9 }, + { 0x90122, 0x8 }, + { 0x90123, 0x8080 }, + { 0x90124, 0x108 }, + { 0x90125, 0xf }, + { 0x90126, 0x408 }, + { 0x90127, 0x169 }, + { 0x90128, 0xc }, + { 0x90129, 0x0 }, + { 0x9012a, 0x68 }, + { 0x9012b, 0x9 }, + { 0x9012c, 0x0 }, + { 0x9012d, 0x1a9 }, + { 0x9012e, 0x0 }, + { 0x9012f, 0x408 }, + { 0x90130, 0x169 }, + { 0x90131, 0x0 }, + { 0x90132, 0x8080 }, + { 0x90133, 0x108 }, + { 0x90134, 0x8 }, + { 0x90135, 0x7aa }, + { 0x90136, 0x6a }, + { 0x90137, 0x0 }, + { 0x90138, 0x8568 }, + { 0x90139, 0x108 }, + { 0x9013a, 0xb7 }, + { 0x9013b, 0x790 }, + { 0x9013c, 0x16a }, + { 0x9013d, 0x1f }, + { 0x9013e, 0x0 }, + { 0x9013f, 0x68 }, + { 0x90140, 0x8 }, + { 0x90141, 0x8558 }, + { 0x90142, 0x168 }, + { 0x90143, 0xf }, + { 0x90144, 0x408 }, + { 0x90145, 0x169 }, + { 0x90146, 0xd }, + { 0x90147, 0x0 }, + { 0x90148, 0x68 }, + { 0x90149, 0x0 }, + { 0x9014a, 0x408 }, + { 0x9014b, 0x169 }, + { 0x9014c, 0x0 }, + { 0x9014d, 0x8558 }, + { 0x9014e, 0x168 }, + { 0x9014f, 0x8 }, + { 0x90150, 0x3c8 }, + { 0x90151, 0x1a9 }, + { 0x90152, 0x3 }, + { 0x90153, 0x370 }, + { 0x90154, 0x129 }, + { 0x90155, 0x20 }, + { 0x90156, 0x2aa }, + { 0x90157, 0x9 }, + { 0x90158, 0x0 }, + { 0x90159, 0x400 }, + { 0x9015a, 0x10e }, + { 0x9015b, 0x8 }, + { 0x9015c, 0xe8 }, + { 0x9015d, 0x109 }, + { 0x9015e, 0x0 }, + { 0x9015f, 0x8140 }, + { 0x90160, 0x10c }, + { 0x90161, 0x10 }, + { 0x90162, 0x8138 }, + { 0x90163, 0x10c }, + { 0x90164, 0x8 }, + { 0x90165, 0x7c8 }, + { 0x90166, 0x101 }, + { 0x90167, 0x8 }, + { 0x90168, 0x448 }, + { 0x90169, 0x109 }, + { 0x9016a, 0xf }, + { 0x9016b, 0x7c0 }, + { 0x9016c, 0x109 }, + { 0x9016d, 0x0 }, + { 0x9016e, 0xe8 }, + { 0x9016f, 0x109 }, + { 0x90170, 0x47 }, + { 0x90171, 0x630 }, + { 0x90172, 0x109 }, + { 0x90173, 0x8 }, + { 0x90174, 0x618 }, + { 0x90175, 0x109 }, + { 0x90176, 0x8 }, + { 0x90177, 0xe0 }, + { 0x90178, 0x109 }, + { 0x90179, 0x0 }, + { 0x9017a, 0x7c8 }, + { 0x9017b, 0x109 }, + { 0x9017c, 0x8 }, + { 0x9017d, 0x8140 }, + { 0x9017e, 0x10c }, + { 0x9017f, 0x0 }, + { 0x90180, 0x1 }, + { 0x90181, 0x8 }, + { 0x90182, 0x8 }, + { 0x90183, 0x4 }, + { 0x90184, 0x8 }, + { 0x90185, 0x8 }, + { 0x90186, 0x7c8 }, + { 0x90187, 0x101 }, + { 0x90006, 0x0 }, + { 0x90007, 0x0 }, + { 0x90008, 0x8 }, + { 0x90009, 0x0 }, + { 0x9000a, 0x0 }, + { 0x9000b, 0x0 }, + { 0xd00e7, 0x400 }, + { 0x90017, 0x0 }, + { 0x9001f, 0x29 }, + { 0x90026, 0x6a }, + { 0x400d0, 0x0 }, + { 0x400d1, 0x101 }, + { 0x400d2, 0x105 }, + { 0x400d3, 0x107 }, + { 0x400d4, 0x10f }, + { 0x400d5, 0x202 }, + { 0x400d6, 0x20a }, + { 0x400d7, 0x20b }, + { 0x2003a, 0x2 }, + { 0x2000b, 0x64 }, + { 0x2000c, 0xc8 }, + { 0x2000d, 0x7d0 }, + { 0x2000e, 0x2c }, + { 0x12000b, 0xc }, + { 0x12000c, 0x19 }, + { 0x12000d, 0xfa }, + { 0x12000e, 0x10 }, + { 0x22000b, 0x3 }, + { 0x22000c, 0x6 }, + { 0x22000d, 0x3e }, + { 0x22000e, 0x10 }, + { 0x9000c, 0x0 }, + { 0x9000d, 0x173 }, + { 0x9000e, 0x60 }, + { 0x9000f, 0x6110 }, + { 0x90010, 0x2152 }, + { 0x90011, 0xdfbd }, + { 0x90012, 0x2060 }, + { 0x90013, 0x6152 }, + { 0x20010, 0x5a }, + { 0x20011, 0x3 }, + { 0x120010, 0x5a }, + { 0x120011, 0x3 }, + { 0x220010, 0x5a }, + { 0x220011, 0x3 }, + { 0x40080, 0xe0 }, + { 0x40081, 0x12 }, + { 0x40082, 0xe0 }, + { 0x40083, 0x12 }, + { 0x40084, 0xe0 }, + { 0x40085, 0x12 }, + { 0x140080, 0xe0 }, + { 0x140081, 0x12 }, + { 0x140082, 0xe0 }, + { 0x140083, 0x12 }, + { 0x140084, 0xe0 }, + { 0x140085, 0x12 }, + { 0x240080, 0xe0 }, + { 0x240081, 0x12 }, + { 0x240082, 0xe0 }, + { 0x240083, 0x12 }, + { 0x240084, 0xe0 }, + { 0x240085, 0x12 }, + { 0x400fd, 0xf }, + { 0x10011, 0x1 }, + { 0x10012, 0x1 }, + { 0x10013, 0x180 }, + { 0x10018, 0x1 }, + { 0x10002, 0x6209 }, + { 0x100b2, 0x1 }, + { 0x101b4, 0x1 }, + { 0x102b4, 0x1 }, + { 0x103b4, 0x1 }, + { 0x104b4, 0x1 }, + { 0x105b4, 0x1 }, + { 0x106b4, 0x1 }, + { 0x107b4, 0x1 }, + { 0x108b4, 0x1 }, + { 0x11011, 0x1 }, + { 0x11012, 0x1 }, + { 0x11013, 0x180 }, + { 0x11018, 0x1 }, + { 0x11002, 0x6209 }, + { 0x110b2, 0x1 }, + { 0x111b4, 0x1 }, + { 0x112b4, 0x1 }, + { 0x113b4, 0x1 }, + { 0x114b4, 0x1 }, + { 0x115b4, 0x1 }, + { 0x116b4, 0x1 }, + { 0x117b4, 0x1 }, + { 0x118b4, 0x1 }, + { 0x20089, 0x1 }, + { 0x20088, 0x19 }, + { 0xc0080, 0x2 }, + { 0xd0000, 0x1 } +}; + +static struct dram_fsp_msg ddr_dram_fsp_msg[] = { + { + /* P0 3200mts 1D */ + .drate = 3200, + .fw_type = FW_1D_IMAGE, + .fsp_cfg = ddr_fsp0_cfg, + .fsp_cfg_num = ARRAY_SIZE(ddr_fsp0_cfg), + }, + { + /* P1 400mts 1D */ + .drate = 400, + .fw_type = FW_1D_IMAGE, + .fsp_cfg = ddr_fsp1_cfg, + .fsp_cfg_num = ARRAY_SIZE(ddr_fsp1_cfg), + }, + { + /* P2 100mts 1D */ + .drate = 100, + .fw_type = FW_1D_IMAGE, + .fsp_cfg = ddr_fsp2_cfg, + .fsp_cfg_num = ARRAY_SIZE(ddr_fsp2_cfg), + }, + { + /* P0 3200mts 2D */ + .drate = 3200, + .fw_type = FW_2D_IMAGE, + .fsp_cfg = ddr_fsp0_2d_cfg, + .fsp_cfg_num = ARRAY_SIZE(ddr_fsp0_2d_cfg), + }, +}; + +/* ddr timing config params */ +struct dram_timing_info dram_timing_2gb_single_die = { + .ddrc_cfg = ddr_ddrc_cfg, + .ddrc_cfg_num = ARRAY_SIZE(ddr_ddrc_cfg), + .ddrphy_cfg = ddr_ddrphy_cfg, + .ddrphy_cfg_num = ARRAY_SIZE(ddr_ddrphy_cfg), + .fsp_msg = ddr_dram_fsp_msg, + .fsp_msg_num = ARRAY_SIZE(ddr_dram_fsp_msg), + .ddrphy_trained_csr = ddr_ddrphy_trained_csr, + .ddrphy_trained_csr_num = ARRAY_SIZE(ddr_ddrphy_trained_csr), + .ddrphy_pie = ddr_phy_pie, + .ddrphy_pie_num = ARRAY_SIZE(ddr_phy_pie), + .fsp_table = { 3200, 400, 100, }, +}; + diff --git a/board/gateworks/venice/spl.c b/board/gateworks/venice/spl.c index b819c6846d..9956958c20 100644 --- a/board/gateworks/venice/spl.c +++ b/board/gateworks/venice/spl.c @@ -16,6 +16,7 @@ #include <asm/mach-imx/iomux-v3.h> #include <asm/arch/clock.h> #include <asm/arch/imx8mm_pins.h> +#include <asm/arch/imx8mn_pins.h> #include <asm/arch/sys_proto.h> #include <asm/mach-imx/boot_mode.h> #include <asm/arch/ddr.h> @@ -41,6 +42,7 @@ static void spl_dram_init(int size) struct dram_timing_info *dram_timing;
switch (size) { +#ifdef CONFIG_IMX8MM case 1: dram_timing = &dram_timing_1gb; break; @@ -54,16 +56,32 @@ static void spl_dram_init(int size) printf("Unknown DDR configuration: %d GiB\n", size); dram_timing = &dram_timing_1gb; size = 1; +#endif +#ifdef CONFIG_IMX8MN + case 2: + if (!strcmp(gsc_get_model(), "GW7902-SP466-A") || + !strcmp(gsc_get_model(), "GW7902-SP466-B")) { + dram_timing = &dram_timing_2gb_dual_die; + } else { + dram_timing = &dram_timing_2gb_single_die; + } + break; + default: + printf("Unknown DDR configuration: %d GiB\n", size); + dram_timing = &dram_timing_2gb_dual_die; + size = 2; +#endif }
printf("DRAM : LPDDR4 %d GiB\n", size); ddr_init(dram_timing); - writel(size, M4_BOOTROM_BASE_ADDR); + gd->ram_size = size; }
#define UART_PAD_CTRL (PAD_CTL_DSE6 | PAD_CTL_FSEL1) #define WDOG_PAD_CTRL (PAD_CTL_DSE6 | PAD_CTL_ODE | PAD_CTL_PUE | PAD_CTL_PE)
+#ifdef CONFIG_IMX8MM static iomux_v3_cfg_t const uart_pads[] = { IMX8MM_PAD_UART2_RXD_UART2_RX | MUX_PAD_CTRL(UART_PAD_CTRL), IMX8MM_PAD_UART2_TXD_UART2_TX | MUX_PAD_CTRL(UART_PAD_CTRL), @@ -72,6 +90,17 @@ static iomux_v3_cfg_t const uart_pads[] = { static iomux_v3_cfg_t const wdog_pads[] = { IMX8MM_PAD_GPIO1_IO02_WDOG1_WDOG_B | MUX_PAD_CTRL(WDOG_PAD_CTRL), }; +#endif +#ifdef CONFIG_IMX8MN +static const iomux_v3_cfg_t uart_pads[] = { + IMX8MN_PAD_UART2_RXD__UART2_DCE_RX | MUX_PAD_CTRL(UART_PAD_CTRL), + IMX8MN_PAD_UART2_TXD__UART2_DCE_TX | MUX_PAD_CTRL(UART_PAD_CTRL), +}; + +static const iomux_v3_cfg_t wdog_pads[] = { + IMX8MN_PAD_GPIO1_IO02__WDOG1_WDOG_B | MUX_PAD_CTRL(WDOG_PAD_CTRL), +}; +#endif
int board_early_init_f(void) { diff --git a/board/gateworks/venice/imx8mm_venice.c b/board/gateworks/venice/venice.c similarity index 100% rename from board/gateworks/venice/imx8mm_venice.c rename to board/gateworks/venice/venice.c diff --git a/configs/imx8mn_venice_defconfig b/configs/imx8mn_venice_defconfig new file mode 100644 index 0000000000..88e4e3721b --- /dev/null +++ b/configs/imx8mn_venice_defconfig @@ -0,0 +1,114 @@ +CONFIG_ARM=y +CONFIG_ARCH_IMX8M=y +CONFIG_SYS_TEXT_BASE=0x40200000 +CONFIG_SPL_GPIO=y +CONFIG_SPL_LIBCOMMON_SUPPORT=y +CONFIG_SPL_LIBGENERIC_SUPPORT=y +CONFIG_SYS_MALLOC_F_LEN=0x10000 +CONFIG_SYS_MEMTEST_START=0x40000000 +CONFIG_SYS_MEMTEST_END=0x80000000 +CONFIG_ENV_SIZE=0x8000 +CONFIG_ENV_OFFSET=0xff0000 +CONFIG_SYS_MALLOC_LEN=0x2000000 +CONFIG_DM_GPIO=y +CONFIG_DEFAULT_DEVICE_TREE="imx8mn-venice" +CONFIG_SPL_TEXT_BASE=0x912000 +CONFIG_TARGET_IMX8MN_VENICE=y +CONFIG_SPL_MMC=y +CONFIG_SPL_SERIAL=y +CONFIG_SPL=y +CONFIG_ENV_OFFSET_REDUND=0xff8000 +CONFIG_SPL_IMX_ROMAPI_LOADADDR=0x48000000 +CONFIG_LTO=y +CONFIG_DISTRO_DEFAULTS=y +CONFIG_SYS_LOAD_ADDR=0x40480000 +CONFIG_FIT=y +CONFIG_FIT_EXTERNAL_OFFSET=0x3000 +CONFIG_SPL_LOAD_FIT=y +# CONFIG_USE_SPL_FIT_GENERATOR is not set +CONFIG_OF_BOARD_SETUP=y +CONFIG_OF_SYSTEM_SETUP=y +# CONFIG_USE_BOOTCOMMAND is not set +CONFIG_USE_PREBOOT=y +CONFIG_PREBOOT="gsc wd-disable" +CONFIG_BOARD_LATE_INIT=y +CONFIG_SPL_BOOTROM_SUPPORT=y +CONFIG_SPL_SEPARATE_BSS=y +CONFIG_SPL_I2C=y +CONFIG_SPL_WATCHDOG=y +CONFIG_SYS_PROMPT="u-boot=> " +# CONFIG_CMD_EXPORTENV is not set +# CONFIG_CMD_IMPORTENV is not set +# CONFIG_CMD_CRC32 is not set +CONFIG_CMD_MEMTEST=y +CONFIG_CMD_CLK=y +CONFIG_CMD_FUSE=y +CONFIG_CMD_GPIO=y +CONFIG_CMD_I2C=y +CONFIG_CMD_MMC=y +CONFIG_CMD_CACHE=y +CONFIG_CMD_TIME=y +CONFIG_CMD_UUID=y +CONFIG_CMD_PMIC=y +CONFIG_CMD_REGULATOR=y +CONFIG_CMD_EXT4_WRITE=y +# CONFIG_ISO_PARTITION is not set +# CONFIG_SPL_EFI_PARTITION is not set +CONFIG_OF_CONTROL=y +CONFIG_SPL_OF_CONTROL=y +CONFIG_OF_LIST="imx8mn-venice imx8mn-venice-gw7902" +CONFIG_ENV_IS_IN_MMC=y +CONFIG_SYS_REDUNDAND_ENVIRONMENT=y +CONFIG_ENV_VARS_UBOOT_RUNTIME_CONFIG=y +CONFIG_NET_RANDOM_ETHADDR=y +CONFIG_IP_DEFRAG=y +CONFIG_TFTP_BLOCKSIZE=4096 +CONFIG_SPL_DM=y +CONFIG_SPL_CLK_COMPOSITE_CCF=y +CONFIG_CLK_COMPOSITE_CCF=y +CONFIG_SPL_CLK_IMX8MN=y +CONFIG_CLK_IMX8MN=y +CONFIG_MXC_GPIO=y +CONFIG_DM_I2C=y +CONFIG_LED=y +CONFIG_LED_BLINK=y +CONFIG_LED_GPIO=y +CONFIG_SUPPORT_EMMC_BOOT=y +CONFIG_MMC_IO_VOLTAGE=y +CONFIG_SPL_MMC_IO_VOLTAGE=y +CONFIG_MMC_UHS_SUPPORT=y +CONFIG_SPL_MMC_UHS_SUPPORT=y +CONFIG_MMC_HS400_ES_SUPPORT=y +CONFIG_MMC_HS400_SUPPORT=y +CONFIG_SPL_MMC_HS400_SUPPORT=y +CONFIG_FSL_USDHC=y +CONFIG_PHYLIB=y +CONFIG_PHY_TI_DP83867=y +CONFIG_PHY_FIXED=y +CONFIG_DM_ETH=y +CONFIG_DM_MDIO=y +CONFIG_DM_DSA=y +CONFIG_PHY_GIGE=y +CONFIG_FEC_MXC=y +CONFIG_KSZ9477=y +CONFIG_MII=y +CONFIG_PINCTRL=y +CONFIG_SPL_PINCTRL=y +CONFIG_PINCTRL_IMX8M=y +CONFIG_DM_PMIC=y +CONFIG_DM_PMIC_BD71837=y +CONFIG_SPL_DM_PMIC_BD71837=y +CONFIG_DM_PMIC_MP5416=y +CONFIG_SPL_DM_PMIC_MP5416=y +CONFIG_DM_REGULATOR=y +CONFIG_DM_REGULATOR_FIXED=y +CONFIG_DM_REGULATOR_GPIO=y +CONFIG_MXC_UART=y +CONFIG_SYSRESET=y +CONFIG_SPL_SYSRESET=y +CONFIG_SYSRESET_PSCI=y +CONFIG_SYSRESET_WATCHDOG=y +CONFIG_DM_THERMAL=y +CONFIG_IMX_TMU=y +CONFIG_IMX_WATCHDOG=y +CONFIG_HEXDUMP=y diff --git a/include/configs/imx8mn_venice.h b/include/configs/imx8mn_venice.h new file mode 100644 index 0000000000..1140fc476f --- /dev/null +++ b/include/configs/imx8mn_venice.h @@ -0,0 +1,114 @@ +/* SPDX-License-Identifier: GPL-2.0+ */ +/* + * Copyright 2021 Gateworks Corporation + */ + +#ifndef __IMX8MM_VENICE_H +#define __IMX8MM_VENICE_H + +#include <asm/arch/imx-regs.h> +#include <linux/sizes.h> + +#define CONFIG_SPL_MAX_SIZE (148 * 1024) +#define CONFIG_SYS_MONITOR_LEN SZ_512K +#define CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_USE_SECTOR +#define CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_SECTOR 0x300 +#define CONFIG_SYS_UBOOT_BASE \ + (QSPI0_AMBA_BASE + CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_SECTOR * 512) + +#ifdef CONFIG_SPL_BUILD +#define CONFIG_SPL_STACK 0x980000 +#define CONFIG_SPL_BSS_START_ADDR 0x950000 +#define CONFIG_SPL_BSS_MAX_SIZE SZ_8K /* 8 KB */ +#define CONFIG_SYS_SPL_MALLOC_START 0x42200000 +#define CONFIG_SYS_SPL_MALLOC_SIZE SZ_512K /* 512 KB */ + +/* For RAW image gives a error info not panic */ +#define CONFIG_SPL_ABORT_ON_RAW_IMAGE + +#endif + +#define MEM_LAYOUT_ENV_SETTINGS \ + "fdt_addr_r=0x44000000\0" \ + "kernel_addr_r=0x42000000\0" \ + "ramdisk_addr_r=0x46400000\0" \ + "scriptaddr=0x46000000\0" + +/* Enable Distro Boot */ +#ifndef CONFIG_SPL_BUILD +#define BOOT_TARGET_DEVICES(func) \ + func(MMC, mmc, 1) \ + func(MMC, mmc, 2) \ + func(DHCP, dhcp, na) +#include <config_distro_bootcmd.h> +#undef CONFIG_ISO_PARTITION +#else +#define BOOTENV +#endif + +/* Initial environment variables */ +#define CONFIG_EXTRA_ENV_SETTINGS \ + BOOTENV \ + MEM_LAYOUT_ENV_SETTINGS \ + "script=boot.scr\0" \ + "bootm_size=0x10000000\0" \ + "ipaddr=192.168.1.22\0" \ + "serverip=192.168.1.146\0" \ + "dev=2\0" \ + "preboot=gsc wd-disable\0" \ + "console=ttymxc1,115200\0" \ + "update_firmware=" \ + "tftpboot $loadaddr $image && " \ + "setexpr blkcnt $filesize + 0x1ff && " \ + "setexpr blkcnt $blkcnt / 0x200 && " \ + "mmc dev $dev && " \ + "mmc write $loadaddr 0x40 $blkcnt\0" \ + "boot_net=" \ + "tftpboot $kernel_addr_r $image && " \ + "booti $kernel_addr_r - $fdtcontroladdr\0" \ + "update_rootfs=" \ + "tftpboot $loadaddr $image && " \ + "gzwrite mmc $dev $loadaddr $filesize 100000 1000000\0" \ + "update_all=" \ + "tftpboot $loadaddr $image && " \ + "gzwrite mmc $dev $loadaddr $filesize\0" \ + "erase_env=mmc dev $dev; mmc erase 0x7f08 0x40\0" + +#define CONFIG_SYS_INIT_RAM_ADDR 0x40000000 +#define CONFIG_SYS_INIT_RAM_SIZE SZ_2M +#define CONFIG_SYS_INIT_SP_OFFSET \ + (CONFIG_SYS_INIT_RAM_SIZE - GENERATED_GBL_DATA_SIZE) +#define CONFIG_SYS_INIT_SP_ADDR \ + (CONFIG_SYS_INIT_RAM_ADDR + CONFIG_SYS_INIT_SP_OFFSET) + +#define CONFIG_SYS_SDRAM_BASE 0x40000000 + +/* SDRAM configuration */ +#define PHYS_SDRAM 0x40000000 +#define PHYS_SDRAM_SIZE SZ_1G /* 1GB DDR */ +#define CONFIG_SYS_BOOTM_LEN SZ_256M + +/* UART */ +#define CONFIG_MXC_UART_BASE UART2_BASE_ADDR + +/* Monitor Command Prompt */ +#define CONFIG_SYS_PROMPT_HUSH_PS2 "> " +#define CONFIG_SYS_CBSIZE SZ_2K +#define CONFIG_SYS_MAXARGS 64 +#define CONFIG_SYS_BARGSIZE CONFIG_SYS_CBSIZE +#define CONFIG_SYS_PBSIZE (CONFIG_SYS_CBSIZE + \ + sizeof(CONFIG_SYS_PROMPT) + 16) + +/* USDHC */ +#define CONFIG_SYS_FSL_USDHC_NUM 2 +#define CONFIG_SYS_FSL_ESDHC_ADDR 0 +#define CONFIG_SYS_MMC_IMG_LOAD_PART 1 + +/* FEC */ +#define CONFIG_ETHPRIME "eth0" +#define CONFIG_FEC_XCV_TYPE RGMII +#define CONFIG_FEC_MXC_PHYADDR 0 +#define FEC_QUIRK_ENET_MAC +#define IMX_FEC_BASE 0x30BE0000 + +#endif
On Wed, Oct 6, 2021 at 4:45 PM Tim Harvey tharvey@gateworks.com wrote:
The GW7902 is based on the i.MX 8M Mini / Nano SoC featuring:
- LPDDR4 DRAM
- eMMC FLASH
- Gateworks System Controller
- LTE CAT M1 modem
- USB 2.0 HUB
- M.2 Socket with USB2.0, PCIe, and dual-SIM
- IMX8M FEC
- PCIe based GbE
- RS232/RS485/RS422 serial transceiver
- GPS
- CAN bus
- WiFi / Bluetooth
- MIPI header (DSI/CSI/GPIO/PWM/I2S)
- PMIC
To add support for the i.MX8M Nano GW7902:
- Add imx8mn-venice dts/defconfig/include
- Add imx8mn-gw7902 dts
- Add imx8mn-2gb lpddr4 dram configs
- Add misc support for IMX8M Nano SoC
- rename imx8mm-venice.c to venice.c as it is no longer imx8mm specific
- update README with differences for IMX8MN vs IMX8MM
Signed-off-by: Tim Harvey tharvey@gateworks.com
v2:
- rebase on origin/master
- remove unused fdt_pack_reg function
arch/arm/dts/Makefile | 2 + arch/arm/dts/imx8mn-venice-gw7902-u-boot.dtsi | 29 + arch/arm/dts/imx8mn-venice-gw7902.dts | 888 ++++++++++ arch/arm/dts/imx8mn-venice-u-boot.dtsi | 222 +++ arch/arm/dts/imx8mn-venice.dts | 152 ++ arch/arm/mach-imx/imx8m/Kconfig | 7 + board/gateworks/venice/Kconfig | 15 + board/gateworks/venice/MAINTAINERS | 6 +- board/gateworks/venice/Makefile | 10 +- board/gateworks/venice/README | 3 +- board/gateworks/venice/gsc.c | 13 + .../gateworks/venice/imximage-8mn-lpddr4.cfg | 10 + board/gateworks/venice/lpddr4_timing.h | 5 + ...lpddr4_timing.c => lpddr4_timing_imx8mm.c} | 0 .../lpddr4_timing_imx8mn_2gb_dual_die.c | 1444 ++++++++++++++++ .../lpddr4_timing_imx8mn_2gb_single_die.c | 1445 +++++++++++++++++ board/gateworks/venice/spl.c | 31 +- .../venice/{imx8mm_venice.c => venice.c} | 0 configs/imx8mn_venice_defconfig | 114 ++ include/configs/imx8mn_venice.h | 114 ++ 20 files changed, 4503 insertions(+), 7 deletions(-) create mode 100644 arch/arm/dts/imx8mn-venice-gw7902-u-boot.dtsi create mode 100644 arch/arm/dts/imx8mn-venice-gw7902.dts create mode 100644 arch/arm/dts/imx8mn-venice-u-boot.dtsi create mode 100644 arch/arm/dts/imx8mn-venice.dts create mode 100644 board/gateworks/venice/imximage-8mn-lpddr4.cfg rename board/gateworks/venice/{lpddr4_timing.c => lpddr4_timing_imx8mm.c} (100%) create mode 100644 board/gateworks/venice/lpddr4_timing_imx8mn_2gb_dual_die.c create mode 100644 board/gateworks/venice/lpddr4_timing_imx8mn_2gb_single_die.c rename board/gateworks/venice/{imx8mm_venice.c => venice.c} (100%) create mode 100644 configs/imx8mn_venice_defconfig create mode 100644 include/configs/imx8mn_venice.h
Stefano,
I noticed you have applied my first version of this patch into your imx master-next tree which is now broken because of some other patches that required it to be rebased: 7abf178bb815 power: Tidy up #undef of CONFIG_DM_PMIC 2a7360666871 serial: Rename SERIAL_SUPPORT to SERIAL 103c5f180694 mmc: Rename MMC_SUPPORT to MMC 7cfbba36e9f8 Convert CONFIG_SYS_MALLOC_LEN to Kconfig 148b8bb4b6bd imx: Finish migration of IMX_CONFIG to Kconfig 49c8ef0e45a9 Convert CONFIG_SYS_LOAD_ADDR to Kconfig 72d81360aabd global: Convert CONFIG_LOADADDR to CONFIG_SYS_LOADADDR 15e7b7682474 Convert CONFIG_SYS_I2C_MXC et al to Kconfig
This v2 patch here was rebased on top of origin/master to take care of this.
A grep for SERIAL_SUPPORT (which was renamed to SERIAL) shows all the boards in your master-next that got merged like mine that currently likely need fixups: $ git grep SERIAL_SUPPORT configs/ configs/imx8mm-cl-iot-gate-optee_defconfig:CONFIG_SPL_SERIAL_SUPPORT=y configs/imx8mn_venice_defconfig:CONFIG_SPL_SERIAL_SUPPORT=y configs/iot2050_defconfig:CONFIG_SPL_SERIAL_SUPPORT=y configs/kontron-sl-mx6ul_defconfig:CONFIG_SPL_SERIAL_SUPPORT=y configs/kontron-sl-mx8mm_defconfig:CONFIG_SPL_SERIAL_SUPPORT=y
A quick test shows all the above with the exception of perhaps iot2050_defconfig are not buildable.
How do you wish us to proceed? I have a set of patches that I can submit to resolve this but I'm not clear if I should squash them and if you should perhaps squash them into the original commit before requesting a git pull to master? imx8mn_venice: fix SERIAL imx8mn_venice: fix MMC_SUPPORT imx8mn_venice: fix SYS_MALLOC_LEN imx8mn-venice: fix IMX_CONFIG imx8mn_venice: fix loadaddr imx8mn-venice: fix I2C
Or should you revert and instead apply this v2 version that takes care of these things?
What are your plans for requesting a git pull to master?
Tim [1] https://source.denx.de/u-boot/custodians/u-boot-imx/-/tree/master-next
-- 2.17.1
Thanks, but this board was already fixed in master (ce543d0d).
Jan
Jan Kiszka
Tim Harvey
