[U-Boot] [PATCH] arm: socfpga: Actually enable L2 cache
The L2 cache was never enabled in the v7_outer_cache_enable(), fix this and enable the L2 cache.
Signed-off-by: Marek Vasut marex@denx.de Cc: Dinh Nguyen dinguyen@opensource.altera.com Cc: Chin Liang See clsee@altera.com --- arch/arm/mach-socfpga/misc.c | 7 +++++-- 1 file changed, 5 insertions(+), 2 deletions(-)
diff --git a/arch/arm/mach-socfpga/misc.c b/arch/arm/mach-socfpga/misc.c index b110f5b..621f5d9 100644 --- a/arch/arm/mach-socfpga/misc.c +++ b/arch/arm/mach-socfpga/misc.c @@ -54,14 +54,17 @@ void enable_caches(void)
void v7_outer_cache_enable(void) { - /* disable the L2 cache */ - writel(0, &pl310->pl310_ctrl); + /* Disable the L2 cache */ + clrbits_le32(&pl310->pl310_ctrl, L2X0_CTRL_EN);
/* enable BRESP, instruction and data prefetch, full line of zeroes */ setbits_le32(&pl310->pl310_aux_ctrl, L310_AUX_CTRL_DATA_PREFETCH_MASK | L310_AUX_CTRL_INST_PREFETCH_MASK | L310_SHARED_ATT_OVERRIDE_ENABLE); + + /* Enable the L2 cache */ + setbits_le32(&pl310->pl310_ctrl, L2X0_CTRL_EN); }
Thanks Marek. I would be interested in some number here. Do you see a bigger change in the performance (ethernet driver or dhrystone) by enabling the L2 cache?
Thanks, Stefan
- /* Enable the L2 cache */
- setbits_le32(&pl310->pl310_ctrl, L2X0_CTRL_EN);
And another comment. It might be necessary to disable the L2 cache when booting into Linux by providing the v7_outer_cache_enable() function. I noticed problems in Linux with MVEBU with the L2 cache still enabled.
Thanks, Stefan
zeroes */
This is the v7_outer_cache_enable() function. Do you have anything else in mind ?
Best regards, Marek Vasut
zeroes */
Yes, I meant v7_outer_cache_disable() of course.
Thanks, Stefan
zeroes */
Got it, thanks.
Neither, but I didn't see any improvement on MX6 when I enabled L2 either.
The data corruption issue is still unresolved.
Then my feeling is, that some other configuration is needed to effectively enable the L2 cache on those platforms. Sorry, but I have no clear suggestions right now. Other than to look at Linux for the L2 cache enabling.
Thanks, Stefan
zeroes
The L2 cache is enabled, but the slowdown is not induced by the L2 cache. The L2 cache has no performance impact on other platforms either. Did you observe actual performance improvement with L2 cache ON anywhere ?
full line of
zeroes
Hmmm, here is the function for L2 cache within my development branch. Some of the latency tuning helps based on the benchmark result. Probably you can give it a try, Marek?
void v7_outer_cache_enable(void) { /* disable the L2 cache */ writel(0, &pl310_regs_base->pl310_ctrl);
/* enable BRESP, instruction and data prefetch, full line of zeroes */ setbits_le32(&pl310_regs_base->pl310_aux_ctrl, PL310_AUX_CTRL_FULL_LINE_ZERO_MASK | PL310_AUX_CTRL_DATA_PREFETCH_MASK | PL310_AUX_CTRL_INST_PREFETCH_MASK | PL310_AUX_CTRL_EARLY_BRESP_MASK);
/* setup tag ram latency */ writel(0, &pl310_regs_base->pl310_tag_latency_ctrl);
/* setup data ram latency */ writel(0x10, &pl310_regs_base->pl310_data_latency_ctrl);
/* invalidate the cache before enable */ v7_outer_cache_inval_all();
/* enable the L2 cache */ writel(0x1, &pl310_regs_base->pl310_ctrl); }
Thanks Chin Liang
full line of
zeroes
Are you _sure_ this is a good idea to set the latency to 0x0 ?
Thanks Chin Liang
Actually it still have 1 cycle of latency, just no additional
Thanks Chin Liang
zeroes */
And that's OK on socfpga ? I would've expected some latency here.
zeroes */
Yup, Linux is using the same value too https://github.com/altera-opensource/linux-socfpga/blob/master/arch/arm /boot/dts/socfpga.dtsi
Thanks Chin Liang
line of
zeroes */
I find the value a bit odd, since other CortexA9 machines which I used always configured that to something higher than 0 . Can anyone comment on that ?
Chin Liang See
Stefan Roese
