[U-Boot] [PATCH] ahci: Fix data abort on multiple scsi resets.
Commit 2faf5fb82ed6 introduced a regression that causes a data abort when running scsi init followed by scsi reset.
There are 2 problems with the original commit 1) ALLOC_CACHE_ALIGN_BUFFER() allocates memory on the stack but is assigned to ataid[port] and used by other functions. 2) The function ata_scsiop_inquiry() tries to free memory which was never allocated on the heap.
Fix these problems by using tmpid as a temporary cache aligned buffer. Allocate memory separately for ataid[port] and re-use it if required.
Fixes: 2faf5fb82ed6 (ahci: Fix cache align error messages)
Reported-by: Eli Nidam elini@marvell.com Signed-off-by: Roger Quadros rogerq@ti.com --- drivers/block/ahci.c | 23 ++++++++++++++++------- 1 file changed, 16 insertions(+), 7 deletions(-)
diff --git a/drivers/block/ahci.c b/drivers/block/ahci.c index a409f63..c8f6573 100644 --- a/drivers/block/ahci.c +++ b/drivers/block/ahci.c @@ -623,6 +623,7 @@ static int ata_scsiop_inquiry(ccb *pccb) 95 - 4, }; u8 fis[20]; + u16 *idbuf; ALLOC_CACHE_ALIGN_BUFFER(u16, tmpid, ATA_ID_WORDS); u8 port;
@@ -649,17 +650,25 @@ static int ata_scsiop_inquiry(ccb *pccb) return -EIO; }
- if (ataid[port]) - free(ataid[port]); - ataid[port] = tmpid; - ata_swap_buf_le16(tmpid, ATA_ID_WORDS); + if (!ataid[port]) { + ataid[port] = malloc(ATA_ID_WORDS * 2); + if (!ataid[port]) { + printf("%s: No memory for ataid[port]\n", __func__); + return -ENOMEM; + } + } + + idbuf = ataid[port]; + + memcpy(idbuf, tmpid, ATA_ID_WORDS * 2); + ata_swap_buf_le16(idbuf, ATA_ID_WORDS);
memcpy(&pccb->pdata[8], "ATA ", 8); - ata_id_strcpy((u16 *) &pccb->pdata[16], &tmpid[ATA_ID_PROD], 16); - ata_id_strcpy((u16 *) &pccb->pdata[32], &tmpid[ATA_ID_FW_REV], 4); + ata_id_strcpy((u16 *)&pccb->pdata[16], &idbuf[ATA_ID_PROD], 16); + ata_id_strcpy((u16 *)&pccb->pdata[32], &idbuf[ATA_ID_FW_REV], 4);
#ifdef DEBUG - ata_dump_id(tmpid); + ata_dump_id(idbuf); #endif return 0; }
- ALLOC_CACHE_ALIGN_BUFFER() allocates memory on the stack but is
Roger Quadros
