[U-Boot] [PATCH 1/2] ARM: OMAP3: am3517_evm: Move header to ti_omap3_common.h
Much of the AM3517 functions are copies of the standard definitions used in ti_omap3_common.h. Moving to include a common file reduces the amount of duplicative code and clutter. A few AM3517 specific functions (like EMIF4) are explictly defined and a few items are undefined or redefined, but overall the number of lines of code shink.
Signed-off-by: Adam Ford aford173@gmail.com --- include/configs/am3517_evm.h | 48 +++++--------------------------------------- 1 file changed, 5 insertions(+), 43 deletions(-)
diff --git a/include/configs/am3517_evm.h b/include/configs/am3517_evm.h index e957a28..9bf50e6 100644 --- a/include/configs/am3517_evm.h +++ b/include/configs/am3517_evm.h @@ -14,7 +14,6 @@ #define __CONFIG_H
#define CONFIG_NR_DRAM_BANKS 2 /* CS1 may or may not be populated */ - #define CONFIG_EMIF4 /* The chip has EMIF4 controller */
/* @@ -27,39 +26,26 @@ #define CONFIG_SYS_SPL_MALLOC_START 0x80208000 #define CONFIG_SYS_SPL_MALLOC_SIZE 0x100000
-#include <asm/arch/cpu.h> /* get chip and board defs */ -#include <asm/arch/omap.h> +#include <configs/ti_omap3_common.h> +#undef CONFIG_SDRC /* Disable SDRC since we have EMIF4 */
#define CONFIG_MISC_INIT_R -#define CONFIG_CMDLINE_TAG /* enable passing of ATAGs */ -#define CONFIG_SETUP_MEMORY_TAGS -#define CONFIG_INITRD_TAG #define CONFIG_REVISION_TAG
-/* Clock Defines */ -#define V_OSCK 26000000 /* Clock output from T2 */ -#define V_SCLK (V_OSCK >> 1) - -/* Size of malloc() pool */ -#define CONFIG_SYS_MALLOC_LEN (16 << 20) - /* Hardware drivers */
/* NS16550 Configuration */ -#define V_NS16550_CLK 48000000 /* 48MHz (APLL96/2) */ #define CONFIG_SYS_NS16550_SERIAL #define CONFIG_SYS_NS16550_REG_SIZE (-4) -#define CONFIG_SYS_NS16550_CLK V_NS16550_CLK
/* select serial console configuration */ #define CONFIG_CONS_INDEX 3 #define CONFIG_SYS_NS16550_COM3 OMAP34XX_UART3 #define CONFIG_SERIAL3 3 /* UART3 on AM3517 EVM */
+ /* allow to overwrite serial and ethaddr */ #define CONFIG_ENV_OVERWRITE -#define CONFIG_SYS_BAUDRATE_TABLE {4800, 9600, 19200, 38400, 57600,\ - 115200}
/* * USB configuration @@ -104,16 +90,10 @@
/* Board NAND Info. */ #ifdef CONFIG_NAND -#define CONFIG_NAND_OMAP_GPMC #define CONFIG_NAND_OMAP_GPMC_PREFETCH #define CONFIG_BCH #define CONFIG_SYS_NAND_ADDR NAND_BASE /* physical address */ /* to access nand */ -#define CONFIG_SYS_NAND_BASE NAND_BASE /* physical address */ - /* to access */ - /* nand at CS0 */ -#define CONFIG_SYS_MAX_NAND_DEVICE 1 /* Max number of */ - /* NAND devices */ #define CONFIG_SYS_NAND_BUSWIDTH_16BIT #define CONFIG_SYS_NAND_5_ADDR_CYCLE #define CONFIG_SYS_NAND_PAGE_COUNT 64 @@ -233,8 +213,6 @@ /* We set the max number of command args high to avoid HUSH bugs. */ #define CONFIG_SYS_MAXARGS 64
-/* Console I/O Buffer Size */ -#define CONFIG_SYS_CBSIZE 512 /* Print Buffer Size */ #define CONFIG_SYS_PBSIZE (CONFIG_SYS_CBSIZE \ + sizeof(CONFIG_SYS_PROMPT) + 16) @@ -246,27 +224,10 @@ #define CONFIG_SYS_MEMTEST_END (OMAP34XX_SDRC_CS0 + \ 0x01F00000) /* 31MB */
-#define CONFIG_SYS_LOAD_ADDR (OMAP34XX_SDRC_CS0) /* default load */ - /* address */ - -/* - * AM3517 has 12 GP timers, they can be driven by the system clock - * (12/13/16.8/19.2/38.4MHz) or by 32KHz clock. We use 13MHz (V_SCLK). - * This rate is divided by a local divisor. - */ -#define CONFIG_SYS_TIMERBASE OMAP34XX_GPT2 -#define CONFIG_SYS_PTV 2 /* Divisor: 2^(PTV+1) => 8 */ - /* Physical Memory Map */ -#define PHYS_SDRAM_1 OMAP34XX_SDRC_CS0 -#define PHYS_SDRAM_2 OMAP34XX_SDRC_CS1 #define CONFIG_SYS_CS0_SIZE (256 * 1024 * 1024) -#define CONFIG_SYS_SDRAM_BASE PHYS_SDRAM_1 #define CONFIG_SYS_INIT_RAM_ADDR 0x4020f800 #define CONFIG_SYS_INIT_RAM_SIZE 0x800 -#define CONFIG_SYS_INIT_SP_ADDR (CONFIG_SYS_INIT_RAM_ADDR + \ - CONFIG_SYS_INIT_RAM_SIZE - \ - GENERATED_GBL_DATA_SIZE)
/* FLASH and environment organization */
@@ -291,11 +252,12 @@
/* Defines for SPL */ #define CONFIG_SPL_FRAMEWORK -#define CONFIG_SPL_NAND_SIMPLE +#undef CONFIG_SPL_TEXT_BASE #define CONFIG_SPL_TEXT_BASE 0x40200000 #define CONFIG_SPL_MAX_SIZE (SRAM_SCRATCH_SPACE_ADDR - \ CONFIG_SPL_TEXT_BASE)
+#undef CONFIG_SPL_BSS_START_ADDR #define CONFIG_SPL_BSS_START_ADDR 0x80000000 #define CONFIG_SPL_BSS_MAX_SIZE 0x80000 /* 512 KB */
Enable TI_COMMON_CMD_OPTIONS and remove similar options from the defconfig. Updated with savedefconfig.
Signed-off-by: Adam Ford aford173@gmail.com --- board/logicpd/am3517evm/Kconfig | 2 ++ configs/am3517_evm_defconfig | 23 ++++++++--------------- 2 files changed, 10 insertions(+), 15 deletions(-)
diff --git a/board/logicpd/am3517evm/Kconfig b/board/logicpd/am3517evm/Kconfig index 901f609..743e500 100644 --- a/board/logicpd/am3517evm/Kconfig +++ b/board/logicpd/am3517evm/Kconfig @@ -9,4 +9,6 @@ config SYS_VENDOR config SYS_CONFIG_NAME default "am3517_evm"
+source "board/ti/common/Kconfig" + endif diff --git a/configs/am3517_evm_defconfig b/configs/am3517_evm_defconfig index e37d8cf..34043f8 100644 --- a/configs/am3517_evm_defconfig +++ b/configs/am3517_evm_defconfig @@ -2,9 +2,9 @@ CONFIG_ARM=y # CONFIG_SYS_THUMB_BUILD is not set CONFIG_ARCH_OMAP2PLUS=y CONFIG_SYS_TEXT_BASE=0x80100000 +CONFIG_TI_COMMON_CMD_OPTIONS=y # CONFIG_SPL_GPIO_SUPPORT is not set CONFIG_TARGET_AM3517_EVM=y -CONFIG_ENV_IS_IN_NAND=y CONFIG_BOOTDELAY=10 CONFIG_VERSION_VARIABLE=y CONFIG_SPL=y @@ -12,33 +12,26 @@ CONFIG_SPL=y CONFIG_SPL_MTD_SUPPORT=y CONFIG_HUSH_PARSER=y CONFIG_SYS_PROMPT="AM3517_EVM # " -CONFIG_CMD_BOOTZ=y # CONFIG_CMD_IMI is not set # CONFIG_CMD_IMLS is not set -CONFIG_CMD_ASKENV=y +# CONFIG_CMD_EEPROM is not set # CONFIG_CMD_FLASH is not set # CONFIG_CMD_FPGA is not set -CONFIG_CMD_GPIO=y -CONFIG_CMD_I2C=y -CONFIG_CMD_MMC=y +# CONFIG_CMD_GPT is not set CONFIG_CMD_NAND=y -CONFIG_CMD_PART=y -CONFIG_CMD_USB=y +# CONFIG_CMD_SPI is not set # CONFIG_CMD_SETEXPR is not set -CONFIG_CMD_DHCP=y -CONFIG_CMD_PING=y +# CONFIG_CMD_MII is not set CONFIG_CMD_CACHE=y -CONFIG_CMD_EXT2=y -CONFIG_CMD_EXT4=y -CONFIG_CMD_EXT4_WRITE=y -CONFIG_CMD_FAT=y -CONFIG_CMD_FS_GENERIC=y +# CONFIG_CMD_TIME is not set CONFIG_CMD_UBI=y CONFIG_SPL_PARTITION_UUIDS=y +CONFIG_ENV_IS_IN_NAND=y CONFIG_MMC_OMAP_HS=y CONFIG_NAND=y CONFIG_SYS_NS16550=y CONFIG_USB=y CONFIG_USB_MUSB_HOST=y CONFIG_USB_STORAGE=y +# CONFIG_FAT_WRITE is not set CONFIG_OF_LIBFDT=y
Tested-by: Derald D. Woods woods.technical@gmail.com
endif diff --git a/configs/am3517_evm_defconfig b/configs/am3517_evm_defconfig index e37d8cf..34043f8 100644 --- a/configs/am3517_evm_defconfig +++ b/configs/am3517_evm_defconfig @@ -2,9 +2,9 @@ CONFIG_ARM=y # CONFIG_SYS_THUMB_BUILD is not set CONFIG_ARCH_OMAP2PLUS=y CONFIG_SYS_TEXT_BASE=0x80100000 +CONFIG_TI_COMMON_CMD_OPTIONS=y # CONFIG_SPL_GPIO_SUPPORT is not set CONFIG_TARGET_AM3517_EVM=y -CONFIG_ENV_IS_IN_NAND=y CONFIG_BOOTDELAY=10 CONFIG_VERSION_VARIABLE=y CONFIG_SPL=y @@ -12,33 +12,26 @@ CONFIG_SPL=y CONFIG_SPL_MTD_SUPPORT=y CONFIG_HUSH_PARSER=y CONFIG_SYS_PROMPT="AM3517_EVM # " -CONFIG_CMD_BOOTZ=y # CONFIG_CMD_IMI is not set # CONFIG_CMD_IMLS is not set -CONFIG_CMD_ASKENV=y +# CONFIG_CMD_EEPROM is not set # CONFIG_CMD_FLASH is not set # CONFIG_CMD_FPGA is not set -CONFIG_CMD_GPIO=y -CONFIG_CMD_I2C=y -CONFIG_CMD_MMC=y +# CONFIG_CMD_GPT is not set CONFIG_CMD_NAND=y -CONFIG_CMD_PART=y -CONFIG_CMD_USB=y +# CONFIG_CMD_SPI is not set # CONFIG_CMD_SETEXPR is not set -CONFIG_CMD_DHCP=y -CONFIG_CMD_PING=y +# CONFIG_CMD_MII is not set CONFIG_CMD_CACHE=y -CONFIG_CMD_EXT2=y -CONFIG_CMD_EXT4=y -CONFIG_CMD_EXT4_WRITE=y -CONFIG_CMD_FAT=y -CONFIG_CMD_FS_GENERIC=y +# CONFIG_CMD_TIME is not set CONFIG_CMD_UBI=y CONFIG_SPL_PARTITION_UUIDS=y +CONFIG_ENV_IS_IN_NAND=y CONFIG_MMC_OMAP_HS=y CONFIG_NAND=y CONFIG_SYS_NS16550=y CONFIG_USB=y CONFIG_USB_MUSB_HOST=y CONFIG_USB_STORAGE=y +# CONFIG_FAT_WRITE is not set CONFIG_OF_LIBFDT=y -- 2.7.4
Signed-off-by: Adam Ford aford173@gmail.com Tested-by: Derald D. Woods woods.technical@gmail.com
115200}
- USB configuration
/* to access */
/* nand at CS0 */
/* NAND devices */
/* address */
- AM3517 has 12 GP timers, they can be driven by the system clock
- (12/13/16.8/19.2/38.4MHz) or by 32KHz clock. We use 13MHz (V_SCLK).
- This rate is divided by a local divisor.
-- 2.7.4
Adam Ford
Derald D. Woods
