[U-Boot] am33xx : bit-flip correction in oob
we're running 2014.04-rc3 on custom am335x board (same configuration as BBB). When spl is loading u-boot from nand flash we can see a lot of messages in console: nand: bit-flip corrected @oob=0
It is always the same position (seems to be first byte in oob). Anybody experienced same problem? I've tested on 2 different flashes and result is same.
In config we're using: #define CONFIG_NAND_OMAP_ECCSCHEME OMAP_ECC_BCH8_CODE_HW #define CONFIG_NAND_OMAP_ELM
BR,
marek
CC-ing Pekon Gupta which add those changes in commit: 6e562b1106ea6afc78752f50925e87e9dd14f8b4
On Tue, Apr 15, 2014 at 12:47 PM, Belisko Marek marek.belisko@gmail.com wrote:
I was able to track down that read ecc from gpmc return always first byte as 0xFF (in omap_calculate_ecc()) and thus function omap_correct_data_bch() always trying to repair bit-flips in first oob byte. Can this be caused by flash? Any pointers?
BR,
marek
-- as simple and primitive as possible
Marek Belisko - OPEN-NANDRA Freelance Developer
Ruska Nova Ves 219 | Presov, 08005 Slovak Republic Tel: +421 915 052 184 skype: marekwhite twitter: #opennandra web: http://open-nandra.com
Thanks,
marek
Hello Marek,
From: Belisko Marek [mailto:marek.belisko@gmail.com]
This shouldn't be the case if the page is programmed. Following is the expected ECC layout of BCH8 OOB[0]: Bad block marker OOB[1]: Bad block marker OOB[2]: ecc_sector0_byte[0] = read_ecc[0] <--- OOB[3]: ecc_sector0_byte[1] OOB[4]: ecc_sector0_byte[2] OOB[5]: ecc_sector0_byte[3] OOB[6]: ecc_sector0_byte[4] OOB[7]: ecc_sector0_byte[5] OOB[8]: ecc_sector0_byte[6] OOB[9]: ecc_sector0_byte[7] OOB[10]: ecc_sector0_byte[8] OOB[11]: ecc_sector0_byte[9] OOB[12]: ecc_sector0_byte[10] OOB[13]: ecc_sector0_byte[11] OOB[14]: ecc_sector0_byte[12] OOB[15]: ecc_sector0_byte[13] OOB[13]: reserved (0x00) OOB[14]: ecc_sector1_byte[0] OOB[15]: ecc_sector1_byte[1] OOB[16]: ecc_sector2_byte[2] OOB[17]: ecc_sector3_byte[3] ....
Something seems to be wrong elsewhere. (1) please use 'nand dump' to check above layout
(2) Also please send me your device datasheet
(3) If you using x16 device, then you might need to pull-in following patch series.. http://lists.denx.de/pipermail/u-boot/2014-April/176834.html
OR Use below hack, just for testing (only for x16 devices).. ----------------------- diff --git a/arch/arm/cpu/armv7/am33xx/mem.c b/arch/arm/cpu/armv7/am33xx/mem.c index 56c9e7d..b166a94 100644 --- a/arch/arm/cpu/armv7/am33xx/mem.c +++ b/arch/arm/cpu/armv7/am33xx/mem.c @@ -64,7 +64,7 @@ void gpmc_init(void) u32 base = CONFIG_SYS_FLASH_BASE; #elif defined(CONFIG_NAND) /* configure GPMC for NAND */ - const u32 gpmc_regs[GPMC_MAX_REG] = { M_NAND_GPMC_CONFIG1, + const u32 gpmc_regs[GPMC_MAX_REG] = { M_NAND_GPMC_CONFIG1 | 0x1000, M_NAND_GPMC_CONFIG2, M_NAND_GPMC_CONFIG3, M_NAND_GPMC_CONFIG4, -----------------------
with regards, pekon
Fixed some copy paste typos in ECC layout below..
This shouldn't be the case if the page is programmed. Following is the expected ECC layout of BCH8 OOB[0]: Bad block marker OOB[1]: Bad block marker OOB[2]: ecc_sector0_byte[0] = read_ecc[0] <--- OOB[3]: ecc_sector0_byte[1] OOB[4]: ecc_sector0_byte[2] OOB[5]: ecc_sector0_byte[3] OOB[6]: ecc_sector0_byte[4] OOB[7]: ecc_sector0_byte[5] OOB[8]: ecc_sector0_byte[6] OOB[9]: ecc_sector0_byte[7] OOB[10]: ecc_sector0_byte[8] OOB[11]: ecc_sector0_byte[9] OOB[12]: ecc_sector0_byte[10] OOB[13]: ecc_sector0_byte[11] OOB[14]: ecc_sector0_byte[12] OOB[15]: reserved (0x00) = read_ecc[13] <--- OOB[16]: ecc_sector1_byte[0] OOB[17]: ecc_sector1_byte[1] OOB[18]: ecc_sector2_byte[2] OOB[19]: ecc_sector3_byte[3] ....
with regards, pekon
Hi Pekon,
On Wed, Apr 23, 2014 at 8:04 PM, Gupta, Pekon pekon@ti.com wrote:
Hello Marek,
Thanks for reply and sorry for wrong explanation. I mean read_ecc[0] byte = 0xff. What I found also is that data in read_ecc was completely different from displayed when issue nand dump. I found patch which fixes issue [1]. The u-boot doesn't anymore print bit-flips in oob. I need to fix also spl nand_read_page as when loading u-boot from nand in spl still report issues.
One more question. Shouldn;t code for bitflip in oob looks like this: --- a/drivers/mtd/nand/omap_gpmc.c +++ b/drivers/mtd/nand/omap_gpmc.c @@ -403,7 +403,7 @@ static int omap_correct_data_bch(struct mtd_info *mtd, uint8_t *dat, dat[byte_pos] ^= 1 << bit_pos; printf("nand: bit-flip corrected @data=%d\n", byte_pos); } else if (byte_pos < error_max) { - read_ecc[byte_pos - SECTOR_BYTES] = 1 << bit_pos; + read_ecc[byte_pos - SECTOR_BYTES] ^= 1 << bit_pos; debug("nand: bit-flip corrected @oob=%d\n", byte_pos - SECTOR_BYTES); } else {
with regards, pekon
[1] - http://e2e.ti.com/support/arm/sitara_arm/f/791/t/259699.aspx
BR,
marek
Hi Marek,
From: Belisko Marek [mailto:marek.belisko@gmail.com] On Wed, Apr 23, 2014 at 8:04 PM, Gupta, Pekon pekon@ti.com wrote:
Yes absolutely. Please send a patch for this. I think this got missed because read_ecc[] does not reach application layer. Above layers are only interested in data portion, so even if the read_ecc[] is uncorrected it doesn't matter to them. But yes this should be fixed. Thanks for catching this.
Ahh.. Yes, I know of this issue.. " The issue is mainly due to a NAND protocol violation in the omap driver since the Random Data Output command (05h-E0h) expects to see only the column address that should be addressed within the already loaded read page into the read buffer. Only 2 address cycles with ALE active should be provided between the 05h and E0h commands. The Page read command expects the full address footprint (2bytes for column address + 3bytes for row address), but once the page is loaded into the read buffer, Random Data Output should be used with only 2bytes for column address."
But the mentioned fix is not at right place. This issue is there in nand_base.c: nand_command_lp() which is part of generic NAND framework. So I suggest to use following patch instead.
-------------- diff --git a/drivers/mtd/nand/nand_base.c b/drivers/mtd/nand/nand_base.c index 5d3232c..80256b5 100644 --- a/drivers/mtd/nand/nand_base.c +++ b/drivers/mtd/nand/nand_base.c @@ -674,7 +674,7 @@ static void nand_command_lp(struct mtd_info *mtd, unsigned int command, ctrl &= ~NAND_CTRL_CHANGE; chip->cmd_ctrl(mtd, column >> 8, ctrl); } - if (page_addr != -1) { + if (page_addr != -11 && command != NAND_CMD_RNDOUT) { chip->cmd_ctrl(mtd, page_addr, ctrl); chip->cmd_ctrl(mtd, page_addr >> 8, NAND_NCE | NAND_ALE); --------------
I think this is issue with Micron NAND also, because even the Micron datasheet says that NAND_CMD_RNDOUT should take only 2cycles of column address. But probably Micron devices don't crib on extra address cycles, they just ignore it.
with regards, pekon
Hi Pekon,
On Thu, Apr 24, 2014 at 1:53 PM, Gupta, Pekon pekon@ti.com wrote:
Hi Marek,
OK I'll do.
With original patch (or with your) it fix only u-boot but it doesn't fix loading u-boot from SPL as it using custom nand_read_page (in am335x_spl_bch.c) and not from nand_bases there must be other update to fix this issue. Probably something like: --- a/drivers/mtd/nand/am335x_spl_bch.c +++ b/drivers/mtd/nand/am335x_spl_bch.c @@ -64,14 +64,16 @@ static int nand_command(int block, int page, uint32_t offs, NAND_CTRL_ALE | NAND_CTRL_CHANGE); /* A[7:0] */ hwctrl(&mtd, (offs >> 8) & 0xff, NAND_CTRL_ALE); /* A[11:9] */ /* Row address */ - hwctrl(&mtd, (page_addr & 0xff), NAND_CTRL_ALE); /* A[19:12] */ - hwctrl(&mtd, ((page_addr >> 8) & 0xff), - NAND_CTRL_ALE); /* A[27:20] */ -#ifdef CONFIG_SYS_NAND_5_ADDR_CYCLE - /* One more address cycle for devices > 128MiB */ - hwctrl(&mtd, (page_addr >> 16) & 0x0f, - NAND_CTRL_ALE); /* A[31:28] */ -#endif + if (cmd != NAND_CMD_RNDOUT) { + hwctrl(&mtd, (page_addr & 0xff), NAND_CTRL_ALE); /* A[19:12] */ + hwctrl(&mtd, ((page_addr >> 8) & 0xff), NAND_CTRL_ALE); /* A[27:20] */ + + #ifdef CONFIG_SYS_NAND_5_ADDR_CYCLE + /* One more address cycle for devices > 128MiB */ + hwctrl(&mtd, (page_addr >> 16) & 0x0f, NAND_CTRL_ALE); /* A[31:28] */ + #endif + } + hwctrl(&mtd, NAND_CMD_NONE, NAND_NCE | NAND_CTRL_CHANGE);
^^^small typo ;)
I've tested it also on Micron flash and it doesn't report any bit-flips (without patch).
with regards, pekon
BR,
marek
Hi Marek,
-#endif
- if (cmd != NAND_CMD_RNDOUT) {
- hwctrl(&mtd, ((page_addr >> 8) & 0xff), NAND_CTRL_ALE); /* A[27:20] */
- #ifdef CONFIG_SYS_NAND_5_ADDR_CYCLE
- hwctrl(&mtd, (page_addr >> 16) & 0x0f, NAND_CTRL_ALE); /* A[31:28] */
- #endif
Yes, SPL needs to be handled separately in both spl_simple.c and am335x_spl_bch.c. Please submit a formal patch for this, so I can test it with multiple devices.
Thanks for fixing this..
with regards, pekon
Belisko Marek
Gupta, Pekon
