Hi Tom,
some minor fixes from i.MX side - please pull from u-boot-imx, thanks !
The following changes since commit 125738e819a3b9d15210794b3dcef9f4d9bcf866:
Prepare v2015.01-rc4 (2014-12-29 21:22:38 -0500)
git://www.denx.de/git/u-boot-imx.git master
for you to fetch changes up to 87e47e905887b91c0505495cc6bbab70ba266d51:
mx6slevk: Remove get_board_rev() (2014-12-30 14:10:39 +0100)
---------------------------------------------------------------- Christian Gmeiner (2): ot1200: add fsuuid command ot1200: enable support for USB_STORAGE
Fabio Estevam (2): mx51evk: Fix MX51EVK_USB_CLK_EN_B definition mx6slevk: Remove get_board_rev()
Iain Paton (2): embestmx6boards: convert to use config_distro_defaults.h embestmx6boards: convert to use config_distro_bootcmd.h
Jan Luebbe (1): arm: mxs: olinuxino: move DRAM config tuning to SPL
Marek Vasut (8): imx: i2c: Zap unnecessary malloc() calls arm: mx6: gw_ventana: Define CONFIG_SYS_MALLOC_F_LEN arm: mx6: novena: Define CONFIG_SYS_MALLOC_F_LEN arm: mx6: novena: Minor coding style fix arm: mx6: novena: Minor config file fix arm: mx6: novena: Pull GPIO definitions into header arm: mx6: novena: Pull video handling into separate file arm: mx6: novena: Add proper LVDS display support
Peng Fan (3): imx:mx6 fix return value of mxc_get_clock imx:mx6sabresd add board level support for usb imx:mx6qarm2 add board level support for usb
Pierre Aubert (1): imx SPL: enable boot from eMMC boot partitions.
Stefan Roese (1): arm: mx6: gw_ventana: Change clock init to enable NAND related clocks
Stefano Babic (1): Merge branch 'master' of git://git.denx.de/u-boot
arch/arm/cpu/armv7/mx6/clock.c | 3 +- arch/arm/imx-common/i2c-mxv7.c | 24 +- arch/arm/imx-common/spl.c | 4 +- board/freescale/mx51evk/mx51evk.c | 2 +- board/freescale/mx6qarm2/mx6qarm2.c | 42 +++ board/freescale/mx6sabresd/mx6sabresd.c | 68 ++++ board/freescale/mx6slevk/mx6slevk.c | 5 - board/gateworks/gw_ventana/gw_ventana_spl.c | 2 +- board/kosagi/novena/Makefile | 1 + board/kosagi/novena/novena.c | 93 +----- board/kosagi/novena/novena.h | 33 ++ board/kosagi/novena/novena_spl.c | 17 +- board/kosagi/novena/video.c | 456 +++++++++++++++++++++++++++ board/olimex/mx23_olinuxino/mx23_olinuxino.c | 30 -- board/olimex/mx23_olinuxino/spl_boot.c | 30 ++ include/configs/embestmx6boards.h | 189 +++-------- include/configs/gw_ventana.h | 1 + include/configs/mx6qarm2.h | 14 + include/configs/mx6sabresd.h | 14 + include/configs/novena.h | 3 +- include/configs/ot1200.h | 3 + 21 files changed, 742 insertions(+), 292 deletions(-) create mode 100644 board/kosagi/novena/novena.h create mode 100644 board/kosagi/novena/video.c
On Tue, Dec 30, 2014 at 05:55:37PM +0100, Stefano Babic wrote:
Hi Tom,
Stefano Babic
