[PATCH 1/3] ARM: dts: imxrt1050-evk: move all u-boot, dm-spl to imxrt1050-evk-u-boot.dtsi file
At the moment a lot of u-boot,dm-spl properties are present in board .dts file but this is not correct since u-boot,dm-spl property is u-boot specific and must be listed into the separate imrt1050-evk-u-boot.dtsi file. So let's move every u-boot,dm-spl property present in imxrt1050-evk.dts to imxrt1050-evk-u-boot.dtsi file.
Signed-off-by: Giulio Benetti giulio.benetti@benettiengineering.com --- arch/arm/dts/imxrt1050-evk-u-boot.dtsi | 38 ++++++++++++++++++++++++++ arch/arm/dts/imxrt1050.dtsi | 13 --------- 2 files changed, 38 insertions(+), 13 deletions(-)
diff --git a/arch/arm/dts/imxrt1050-evk-u-boot.dtsi b/arch/arm/dts/imxrt1050-evk-u-boot.dtsi index a4b50f0bb2..3168c2df2c 100644 --- a/arch/arm/dts/imxrt1050-evk-u-boot.dtsi +++ b/arch/arm/dts/imxrt1050-evk-u-boot.dtsi @@ -8,6 +8,42 @@ chosen { u-boot,dm-spl; }; + + clocks { + u-boot,dm-spl; + }; + + soc { + u-boot,dm-spl; + }; +}; + +&osc { + u-boot,dm-spl; +}; + +&clks { + u-boot,dm-spl; +}; + +&gpio1 { + u-boot,dm-spl; +}; + +&gpio2 { + u-boot,dm-spl; +}; + +&gpio3 { + u-boot,dm-spl; +}; + +&gpio4 { + u-boot,dm-spl; +}; + +&gpio5 { + u-boot,dm-spl; };
&gpt1 { @@ -19,6 +55,8 @@ };
&semc { + u-boot,dm-spl; + bank1: bank@0 { u-boot,dm-spl; }; diff --git a/arch/arm/dts/imxrt1050.dtsi b/arch/arm/dts/imxrt1050.dtsi index 5f5a98e19e..e21f92864f 100644 --- a/arch/arm/dts/imxrt1050.dtsi +++ b/arch/arm/dts/imxrt1050.dtsi @@ -27,10 +27,7 @@ };
clocks { - u-boot,dm-spl; - osc: osc { - u-boot,dm-spl; compatible = "fsl,imx-osc", "fixed-clock"; #clock-cells = <0>; clock-frequency = <24000000>; @@ -38,10 +35,7 @@ };
soc { - u-boot,dm-spl; - semc: semc@402f0000 { - u-boot,dm-spl; compatible = "fsl,imxrt-semc"; reg = <0x402f0000 0x4000>; clocks = <&clks IMXRT1050_CLK_SEMC>; @@ -66,7 +60,6 @@ };
clks: ccm@400fc000 { - u-boot,dm-spl; compatible = "fsl,imxrt1050-ccm"; reg = <0x400fc000 0x4000>; interrupts = <GIC_SPI 95 IRQ_TYPE_LEVEL_HIGH>, @@ -75,7 +68,6 @@ };
usdhc1: usdhc@402c0000 { - u-boot,dm-spl; compatible = "fsl,imxrt-usdhc"; reg = <0x402c0000 0x10000>; interrupts = <GIC_SPI 110 IRQ_TYPE_LEVEL_HIGH>; @@ -88,7 +80,6 @@ };
gpio1: gpio@401b8000 { - u-boot,dm-spl; compatible = "fsl,imxrt-gpio", "fsl,imx35-gpio"; reg = <0x401b8000 0x4000>; interrupts = <GIC_SPI 80 IRQ_TYPE_LEVEL_HIGH>, @@ -100,7 +91,6 @@ };
gpio2: gpio@401bc000 { - u-boot,dm-spl; compatible = "fsl,imxrt-gpio", "fsl,imx35-gpio"; reg = <0x401bc000 0x4000>; interrupts = <GIC_SPI 82 IRQ_TYPE_LEVEL_HIGH>, @@ -112,7 +102,6 @@ };
gpio3: gpio@401c0000 { - u-boot,dm-spl; compatible = "fsl,imxrt-gpio", "fsl,imx35-gpio"; reg = <0x401c0000 0x4000>; interrupts = <GIC_SPI 84 IRQ_TYPE_LEVEL_HIGH>, @@ -124,7 +113,6 @@ };
gpio4: gpio@401c4000 { - u-boot,dm-spl; compatible = "fsl,imxrt-gpio", "fsl,imx35-gpio"; reg = <0x401c4000 0x4000>; interrupts = <GIC_SPI 86 IRQ_TYPE_LEVEL_HIGH>, @@ -136,7 +124,6 @@ };
gpio5: gpio@400c0000 { - u-boot,dm-spl; compatible = "fsl,imxrt-gpio", "fsl,imx35-gpio"; reg = <0x400c0000 0x4000>; interrupts = <GIC_SPI 88 IRQ_TYPE_LEVEL_HIGH>,
At the moment a lot of u-boot,dm-spl properties are present in board .dts file but this is not correct since u-boot,dm-spl property is u-boot specific and must be listed into the separate imrt1020-evk-u-boot.dtsi file. So let's move every u-boot,dm-spl property present in imxrt1020-evk.dts to imxrt1020-evk-u-boot.dtsi file.
Signed-off-by: Giulio Benetti giulio.benetti@benettiengineering.com --- arch/arm/dts/imxrt1020-evk-u-boot.dtsi | 34 ++++++++++++++++++++++++++ arch/arm/dts/imxrt1020.dtsi | 10 -------- 2 files changed, 34 insertions(+), 10 deletions(-)
diff --git a/arch/arm/dts/imxrt1020-evk-u-boot.dtsi b/arch/arm/dts/imxrt1020-evk-u-boot.dtsi index 34d19e06c5..121665a2d2 100644 --- a/arch/arm/dts/imxrt1020-evk-u-boot.dtsi +++ b/arch/arm/dts/imxrt1020-evk-u-boot.dtsi @@ -8,6 +8,38 @@ chosen { u-boot,dm-spl; }; + + clocks { + u-boot,dm-spl; + }; + + soc { + u-boot,dm-spl; + }; +}; + +&osc { + u-boot,dm-spl; +}; + +&clks { + u-boot,dm-spl; +}; + +&gpio1 { + u-boot,dm-spl; +}; + +&gpio2 { + u-boot,dm-spl; +}; + +&gpio3 { + u-boot,dm-spl; +}; + +&gpio5 { + u-boot,dm-spl; };
&gpt1 { @@ -19,6 +51,8 @@ };
&semc { + u-boot,dm-spl; + bank1: bank@0 { u-boot,dm-spl; }; diff --git a/arch/arm/dts/imxrt1020.dtsi b/arch/arm/dts/imxrt1020.dtsi index cab608c644..884d57f614 100644 --- a/arch/arm/dts/imxrt1020.dtsi +++ b/arch/arm/dts/imxrt1020.dtsi @@ -23,7 +23,6 @@ };
clocks { - u-boot,dm-spl; ckil { compatible = "fsl,imx-ckil", "fixed-clock"; #clock-cells = <0>; @@ -37,7 +36,6 @@ };
osc: osc { - u-boot,dm-spl; compatible = "fsl,imx-osc", "fixed-clock"; #clock-cells = <0>; clock-frequency = <24000000>; @@ -45,10 +43,7 @@ };
soc { - u-boot,dm-spl; - semc: semc@402f0000 { - u-boot,dm-spl; compatible = "fsl,imxrt-semc"; reg = <0x402f0000 0x4000>; clocks = <&clks IMXRT1020_CLK_SEMC>; @@ -73,7 +68,6 @@ };
clks: ccm@400fc000 { - u-boot,dm-spl; compatible = "fsl,imxrt1020-ccm"; reg = <0x400fc000 0x4000>; interrupts = <GIC_SPI 95 IRQ_TYPE_LEVEL_HIGH>, @@ -82,7 +76,6 @@ };
usdhc1: usdhc@402c0000 { - u-boot,dm-spl; compatible = "fsl,imxrt-usdhc"; reg = <0x402c0000 0x10000>; interrupts = <GIC_SPI 110 IRQ_TYPE_LEVEL_HIGH>; @@ -95,7 +88,6 @@ };
gpio1: gpio@401b8000 { - u-boot,dm-spl; compatible = "fsl,imxrt-gpio", "fsl,imx35-gpio"; reg = <0x401b8000 0x4000>; interrupts = <GIC_SPI 80 IRQ_TYPE_LEVEL_HIGH>, @@ -107,7 +99,6 @@ };
gpio2: gpio@401bc000 { - u-boot,dm-spl; compatible = "fsl,imxrt-gpio", "fsl,imx35-gpio"; reg = <0x401bc000 0x4000>; interrupts = <GIC_SPI 82 IRQ_TYPE_LEVEL_HIGH>, @@ -119,7 +110,6 @@ };
At the moment a lot of u-boot,dm-spl properties are present in board .dts file but this is not correct since u-boot,dm-spl property is u-boot specific and must be listed into the separate imrt1020-evk-u-boot.dtsi file. So let's move every u-boot,dm-spl property present in imxrt1020-evk.dts to imxrt1020-evk-u-boot.dtsi file. Signed-off-by: Giulio Benetti giulio.benetti@benettiengineering.com
Best regards, Stefano Babic
i.MXRT1020 supports gpio5, so let's add a node for it.
Signed-off-by: Giulio Benetti giulio.benetti@benettiengineering.com --- arch/arm/dts/imxrt1020.dtsi | 11 +++++++++++ 1 file changed, 11 insertions(+)
diff --git a/arch/arm/dts/imxrt1020.dtsi b/arch/arm/dts/imxrt1020.dtsi index 884d57f614..5ba314f995 100644 --- a/arch/arm/dts/imxrt1020.dtsi +++ b/arch/arm/dts/imxrt1020.dtsi @@ -120,6 +120,17 @@ #interrupt-cells = <2>; };
+ gpio5: gpio@400c0000 { + compatible = "fsl,imxrt-gpio", "fsl,imx35-gpio"; + reg = <0x400c0000 0x4000>; + interrupts = <GIC_SPI 88 IRQ_TYPE_LEVEL_HIGH>, + <GIC_SPI 89 IRQ_TYPE_LEVEL_HIGH>; + gpio-controller; + #gpio-cells = <2>; + interrupt-controller; + #interrupt-cells = <2>; + }; + gpt1: gpt1@401ec000 { compatible = "fsl,imxrt-gpt"; reg = <0x401ec000 0x4000>;
i.MXRT1020 supports gpio5, so let's add a node for it. Signed-off-by: Giulio Benetti giulio.benetti@benettiengineering.com
At the moment a lot of u-boot,dm-spl properties are present in board .dts file but this is not correct since u-boot,dm-spl property is u-boot specific and must be listed into the separate imrt1050-evk-u-boot.dtsi file. So let's move every u-boot,dm-spl property present in imxrt1050-evk.dts to imxrt1050-evk-u-boot.dtsi file. Signed-off-by: Giulio Benetti giulio.benetti@benettiengineering.com
Giulio Benetti
sbabic@denx.de
