[U-Boot] [PATCH] spl: fit: Fix support for loading FPGA bitstream
Move the FPGA loading from IS_ENABLED(CONFIG_SPL_OS_BOOT) && IS_ENABLED(CONFIG_SPL_GZIP) conditional. The FPGA loading can be used without OS loading and GZIP support in SPL. This issue was most likely induced by some merge conflict, so fix it.
Signed-off-by: Marek Vasut marex@denx.de Cc: Tom Rini trini@konsulko.com --- common/spl/spl_fit.c | 10 +++++----- 1 file changed, 5 insertions(+), 5 deletions(-)
diff --git a/common/spl/spl_fit.c b/common/spl/spl_fit.c index 2321ebb0dd..255959d3a9 100644 --- a/common/spl/spl_fit.c +++ b/common/spl/spl_fit.c @@ -185,16 +185,16 @@ static int spl_load_fit_image(struct spl_load_info *info, ulong sector, int ret; #endif
+ if (fit_image_get_type(fit, node, &type)) + puts("Cannot get image type.\n"); + else + debug("%s ", genimg_get_type_name(type)); + if (IS_ENABLED(CONFIG_SPL_OS_BOOT) && IS_ENABLED(CONFIG_SPL_GZIP)) { if (fit_image_get_comp(fit, node, &image_comp)) puts("Cannot get image compression format.\n"); else debug("%s ", genimg_get_comp_name(image_comp)); - - if (fit_image_get_type(fit, node, &type)) - puts("Cannot get image type.\n"); - else - debug("%s ", genimg_get_type_name(type)); }
if (fit_image_get_load(fit, node, &load_addr))
- else
- if (IS_ENABLED(CONFIG_SPL_OS_BOOT) && IS_ENABLED(CONFIG_SPL_GZIP)) { if (fit_image_get_comp(fit, node, &image_comp)) puts("Cannot get image compression format.\n"); else debug("%s ", genimg_get_comp_name(image_comp));
else
Ah, ugh. That was my fault, but also because that move causes a number of platforms to break size constraints (much of Allwinner, iirc). You need to make your new change here depend on CONFIG_SPL_FPGA_SUPPORT || (CONFIG_SPL_OS_BOOT && CONFIG_SPL_GZIP) or so, and throw it though travis to make sure no platforms break. Thanks!
