[U-Boot] [PATCH] ARC: change the default CROSS_COMPILE for ARC
As doc/README.ARC says, pre-build ARC toolchains are available at the Synopsys GitHub page.
The bin files are prefixed with arc(eb)-buildroot-linux- for earlier releases, but with arc(eb)-snps-linux- for the latest releases (arc_gnu_2014.12_prebuilt_*).
For all the releases, the symbolic link, arc(eb)-linux-* is also prepared for each bin file, so it can be used as the default CROSS_COMPILE regardless of the toolchains version.
Signed-off-by: Masahiro Yamada yamada.masahiro@socionext.com ---
arch/arc/config.mk | 4 ++-- 1 file changed, 2 insertions(+), 2 deletions(-)
diff --git a/arch/arc/config.mk b/arch/arc/config.mk index 04c034b..9aed147 100644 --- a/arch/arc/config.mk +++ b/arch/arc/config.mk @@ -11,13 +11,13 @@ CONFIG_SYS_BIG_ENDIAN = 1 endif
ifdef CONFIG_SYS_LITTLE_ENDIAN -ARC_CROSS_COMPILE := arc-buildroot-linux-uclibc- +ARC_CROSS_COMPILE := arc-linux-uclibc- PLATFORM_LDFLAGS += -EL PLATFORM_CPPFLAGS += -mlittle-endian endif
ifdef CONFIG_SYS_BIG_ENDIAN -ARC_CROSS_COMPILE := arceb-buildroot-linux-uclibc- +ARC_CROSS_COMPILE := arceb-linux-uclibc- PLATFORM_LDFLAGS += -EB PLATFORM_CPPFLAGS += -mbig-endian endif
Hello Masahiro-san,
I would propose to use even simpler and more universal prefix which could be used with both ARC pre-built toolchains, your own toolchain built by Buildroot or even pre-built Buildroot toolchain (http://autobuild.buildroot.org/toolchains/tarballs/br-arcle-hs38-full-2015.0...): [1] "arc-linux-" for little-endian [2] "arceb-linux-"
Care to re-send your patch or I may do that change myself?
-Alexey
Hi Alexey,
2015-05-13 18:36 GMT+09:00 Alexey Brodkin Alexey.Brodkin@synopsys.com:
Hello Masahiro-san,
I've posted v2. Thanks for pointing this out!
Alexey Brodkin
Masahiro Yamada
