[U-Boot] [PATCH] armv8: fsl: Use correct conditional compile for ls1012a
According current code base, CONFIG_LS1012A should be CONFIG_ARCH_LS1012A, or function fsl_fdt_disable(blob) will be wrongly called to disable all dwc3 USB nodes on LS1012A, which cause Linux USB function stop working at all.
Signed-off-by: Ran Wang ran.wang_1@nxp.com --- arch/arm/cpu/armv8/fsl-layerscape/fdt.c | 2 +- 1 file changed, 1 insertion(+), 1 deletion(-)
diff --git a/arch/arm/cpu/armv8/fsl-layerscape/fdt.c b/arch/arm/cpu/armv8/fsl-layerscape/fdt.c index f5f4840f19..09b2cb1002 100644 --- a/arch/arm/cpu/armv8/fsl-layerscape/fdt.c +++ b/arch/arm/cpu/armv8/fsl-layerscape/fdt.c @@ -387,7 +387,7 @@ void ft_cpu_setup(void *blob, bd_t *bd) #ifdef CONFIG_SYS_DPAA_FMAN fdt_fixup_fman_firmware(blob); #endif -#ifndef CONFIG_LS1012A +#ifndef CONFIG_ARCH_LS1012A fsl_fdt_disable_usb(blob); #endif #ifdef CONFIG_HAS_FEATURE_GIC64K_ALIGN
Applied to fsl-qoriq master. Thanks.
York
Ran Wang
York Sun
