[U-Boot] [PATCH] armv8/ls1043aqds: fix DSPI/QSPI node in dts file
Fix the lost dts info when merging patches.
Fix DSPI node for 'commit e0579a5852b3 ("armv8/ls1043aqds: add DSPI support")' and QSPI node for 'commit 166ef1e90ce4 ("armv8/ls1043aqds: add QSPI support in SD boot")'.
Signed-off-by: Gong Qianyu Qianyu.Gong@nxp.com --- arch/arm/dts/fsl-ls1043a-qds.dtsi | 46 +++++++++++++++++++++++++++++++++++++++ 1 file changed, 46 insertions(+)
diff --git a/arch/arm/dts/fsl-ls1043a-qds.dtsi b/arch/arm/dts/fsl-ls1043a-qds.dtsi index b9dad72..66efe67 100644 --- a/arch/arm/dts/fsl-ls1043a-qds.dtsi +++ b/arch/arm/dts/fsl-ls1043a-qds.dtsi @@ -14,6 +14,52 @@
/ { model = "LS1043A QDS Board"; + aliases { + spi0 = &qspi; + spi1 = &dspi0; + }; +}; + +&dspi0 { + bus-num = <0>; + status = "okay"; + + dflash0: n25q128a { + #address-cells = <1>; + #size-cells = <1>; + compatible = "spi-flash"; + reg = <0>; + spi-max-frequency = <1000000>; /* input clock */ + }; + + dflash1: sst25wf040b { + #address-cells = <1>; + #size-cells = <1>; + compatible = "spi-flash"; + spi-max-frequency = <3500000>; + reg = <1>; + }; + + dflash2: en25s64 { + #address-cells = <1>; + #size-cells = <1>; + compatible = "spi-flash"; + spi-max-frequency = <3500000>; + reg = <2>; + }; +}; + +&qspi { + bus-num = <0>; + status = "okay"; + + qflash0: s25fl128s@0 { + #address-cells = <1>; + #size-cells = <1>; + compatible = "spi-flash"; + spi-max-frequency = <20000000>; + reg = <0>; + }; };
&i2c0 {
Applied to u-boot-fsl-qoriq master branch. Awaiting upstream.
Thanks.
York
Gong Qianyu
york sun
