[U-Boot] [PATCH] configs: rockchip: remove CONFIG_ROCKCHIP_COMMON
The CONFIG_ROCKCHIP_COMMON is no use now, remove it.
Signed-off-by: Kever Yang kever.yang@rock-chips.com ---
include/configs/rk3036_common.h | 2 -- include/configs/rk3288_common.h | 1 - 2 files changed, 3 deletions(-)
diff --git a/include/configs/rk3036_common.h b/include/configs/rk3036_common.h index ae4b101..b003baa 100644 --- a/include/configs/rk3036_common.h +++ b/include/configs/rk3036_common.h @@ -40,8 +40,6 @@ #define CONFIG_ROCKCHIP_MAX_INIT_SIZE (4 << 10) #define CONFIG_ROCKCHIP_CHIP_TAG "RK30"
-#define CONFIG_ROCKCHIP_COMMON - /* MMC/SD IP block */ #define CONFIG_MMC #define CONFIG_GENERIC_MMC diff --git a/include/configs/rk3288_common.h b/include/configs/rk3288_common.h index 2a36c17..faefd55 100644 --- a/include/configs/rk3288_common.h +++ b/include/configs/rk3288_common.h @@ -44,7 +44,6 @@ #define CONFIG_SPL_STACK 0xff718000 #define CONFIG_SPL_TEXT_BASE 0xff704004
-#define CONFIG_ROCKCHIP_COMMON #define CONFIG_SPL_ROCKCHIP_COMMON
#define CONFIG_SILENT_CONSOLE
Hi kever, If you intend to remove CONFIG_ROCKCHIP_COMMON, please also remove it in Kconfig.(arch/arm/mach-rockchip/rk3036/Kconfig) And CONFIG_SPL_ROCKCHIP_COMMON? On 2016年07月20日 11:31, Kever Yang wrote:
Kever Yang
Ziyuan Xu
