[U-Boot] [PATCH 1/5] Added documentation for CONFIG_SYS_TEXT_BASE for ARM.
Signed-off-by: Christopher Harvey charvey@matrox.com --- README | 9 +++++++++ 1 files changed, 9 insertions(+), 0 deletions(-)
diff --git a/README b/README index a760cf3..a0090ef 100644 --- a/README +++ b/README @@ -2355,6 +2355,15 @@ Configuration Settings: - CONFIG_SYS_SDRAM_BASE: Physical start address of SDRAM. _Must_ be 0 here.
+- CONFIG_SYS_TEXT_BASE: + - ARM: + Is the address of the u-boot code that is loaded in memory. + This value can be in ROM space since u-boot can run from + within ROM. CONFIG_SYS_TEXT_BASE is simply called _TEXT_BASE + in some files, like arch/arm/lib/board.c. + This value has nothing to do with the relocation destination + in RAM. See doc/README.arm-relocation for more info. + - CONFIG_SYS_MBIO_BASE: Physical start address of Motherboard I/O (if using a Cogent motherboard)
Dear Christopher Harvey,
Please don't make this ARM specific. CONFIG_SYS_TEXT_BASE has the same meaning for all architectures.
- ARM:
To be precise: it is the address of the start address of U-Boot in memory.
Please omit the "that is loaded in memory", because for example on systems booting from ROM (or NOR flash etc.) nothing gets loaded.
within ROM. ...
Again, not strictly correct. Only some parts of U-Boot (the part before relocation) can run from ROM.
... CONFIG_SYS_TEXT_BASE is simply called _TEXT_BASE
I consider this a bad idea. It should not be documented, but rather fixed.
Again, I'm unhappy to see this being ARM specific. It ain't so, on contrary - we changed ARM to do this so as ARMis in sync with other architectures.
Christopher Harvey
