[PATCH 0/6] introduce Arm FF-A support
From: Abdellatif El Khlifi abdellatif.elkhlifi@arm.com
This patchset adds support for Arm FF-A (Arm Firmware Framework for Armv8-A v1.0).
FF-A support is generic by design and can be used by any Arm platform.
The features added are as follows:
1/ FF-A device driver 2/ armffa command 3/ FF-A Sandbox driver 4/ FF-A Sandbox test cases 5/ FF-A MM communication
The suggested design sees FF-A as a data bus allowing data exchange with the firmware running under TrustZone HW (such as Optee). The same approach was followed in the FF-A driver in Linux kernel (https://git.kernel.org/pub/scm/linux/kernel/git/torvalds/linux.git/tree/driv...))
u-boot boards using FF-A can provide a device tree node in a <board>-u-boot.dtsi file. Since the node can not be hosted in Linux device tree, we suggest using u-boot device tree.
As a use case, we will send a commit enabling FF-A for the Corstone-1000 platform and providing the FF-A node in u-boot.dtsi files.
Corstone-1000: https://lore.kernel.org/u-boot/20220322104118.573537-1-rui.silva@linaro.org/
Cc: Tom Rini trini@konsulko.com
Abdellatif El Khlifi (6): arm_ffa: introduce Arm FF-A low-level driver arm_ffa: introduce armffa command arm_ffa: introduce the FF-A Sandbox driver arm_ffa: introduce Sandbox test cases for UCLASS_FFA arm_ffa: introduce armffa command Sandbox test arm_ffa: introduce FF-A MM communication
MAINTAINERS | 15 + arch/arm/cpu/armv8/cache.S | 16 + arch/arm/cpu/armv8/cache_v8.c | 3 +- arch/arm/cpu/armv8/smccc-call.S | 27 + arch/arm/lib/asm-offsets.c | 6 + arch/sandbox/dts/sandbox.dtsi | 10 + arch/sandbox/dts/test.dts | 10 + cmd/Kconfig | 10 + cmd/Makefile | 2 + cmd/armffa.c | 266 +++++ common/board_r.c | 7 + configs/sandbox64_defconfig | 2 + configs/sandbox_defconfig | 2 + doc/arch/sandbox.rst | 1 + drivers/Kconfig | 2 + drivers/Makefile | 1 + drivers/arm-ffa/Kconfig | 32 + drivers/arm-ffa/Makefile | 7 + drivers/arm-ffa/arm-ffa-uclass.c | 102 ++ drivers/arm-ffa/arm_ffa_prv.h | 200 ++++ drivers/arm-ffa/core.c | 1463 +++++++++++++++++++++++++ drivers/arm-ffa/sandbox.c | 735 +++++++++++++ drivers/arm-ffa/sandbox_arm_ffa_prv.h | 128 +++ include/arm_ffa.h | 197 ++++ include/arm_ffa_helper.h | 45 + include/dm/uclass-id.h | 1 + include/linux/arm-smccc.h | 28 +- include/mm_communication.h | 4 +- include/sandbox_arm_ffa.h | 31 + include/sandbox_arm_ffa_helper.h | 26 + lib/Kconfig | 1 + lib/Makefile | 1 + lib/arm-ffa/Kconfig | 6 + lib/arm-ffa/Makefile | 9 + lib/arm-ffa/arm_ffa_helper.c | 188 ++++ lib/arm-ffa/sandbox_arm_ffa_helper.c | 23 + lib/efi_loader/Kconfig | 14 +- lib/efi_loader/efi_boottime.c | 17 + lib/efi_loader/efi_variable_tee.c | 294 ++++- test/cmd/Makefile | 1 + test/cmd/armffa.c | 33 + test/cmd/armffa.h | 13 + test/dm/Makefile | 1 + test/dm/ffa.c | 424 +++++++ test/dm/ffa.h | 22 + 45 files changed, 4415 insertions(+), 11 deletions(-) create mode 100644 cmd/armffa.c create mode 100644 drivers/arm-ffa/Kconfig create mode 100644 drivers/arm-ffa/Makefile create mode 100644 drivers/arm-ffa/arm-ffa-uclass.c create mode 100644 drivers/arm-ffa/arm_ffa_prv.h create mode 100644 drivers/arm-ffa/core.c create mode 100644 drivers/arm-ffa/sandbox.c create mode 100644 drivers/arm-ffa/sandbox_arm_ffa_prv.h create mode 100644 include/arm_ffa.h create mode 100644 include/arm_ffa_helper.h create mode 100644 include/sandbox_arm_ffa.h create mode 100644 include/sandbox_arm_ffa_helper.h create mode 100644 lib/arm-ffa/Kconfig create mode 100644 lib/arm-ffa/Makefile create mode 100644 lib/arm-ffa/arm_ffa_helper.c create mode 100644 lib/arm-ffa/sandbox_arm_ffa_helper.c create mode 100644 test/cmd/armffa.c create mode 100644 test/cmd/armffa.h create mode 100644 test/dm/ffa.c create mode 100644 test/dm/ffa.h
Add the driver implementing Arm Firmware Framework for Armv8-A v1.0
The Firmware Framework for Arm A-profile processors (FF-A) describes interfaces (ABIs) that standardize communication between the Secure World and Normal World leveraging TrustZone technology. This driver uses SMC32 calling convention.
The driver provides helper FF-A interfaces for user layers. These helper functions allow clients to pass data and select the FF-A function to use for the communication with secure world.
Signed-off-by: Abdellatif El Khlifi abdellatif.elkhlifi@arm.com Cc: Tom Rini trini@konsulko.com --- MAINTAINERS | 8 + arch/arm/cpu/armv8/smccc-call.S | 27 + arch/arm/lib/asm-offsets.c | 6 + common/board_r.c | 7 + drivers/Kconfig | 2 + drivers/Makefile | 1 + drivers/arm-ffa/Kconfig | 25 + drivers/arm-ffa/Makefile | 6 + drivers/arm-ffa/arm-ffa-uclass.c | 65 ++ drivers/arm-ffa/arm_ffa_prv.h | 200 +++++ drivers/arm-ffa/core.c | 1427 ++++++++++++++++++++++++++++++ include/arm_ffa.h | 190 ++++ include/arm_ffa_helper.h | 45 + include/dm/uclass-id.h | 1 + include/linux/arm-smccc.h | 28 +- lib/Kconfig | 1 + lib/Makefile | 1 + lib/arm-ffa/Kconfig | 6 + lib/arm-ffa/Makefile | 8 + lib/arm-ffa/arm_ffa_helper.c | 188 ++++ lib/efi_loader/efi_boottime.c | 17 + 21 files changed, 2258 insertions(+), 1 deletion(-) create mode 100644 drivers/arm-ffa/Kconfig create mode 100644 drivers/arm-ffa/Makefile create mode 100644 drivers/arm-ffa/arm-ffa-uclass.c create mode 100644 drivers/arm-ffa/arm_ffa_prv.h create mode 100644 drivers/arm-ffa/core.c create mode 100644 include/arm_ffa.h create mode 100644 include/arm_ffa_helper.h create mode 100644 lib/arm-ffa/Kconfig create mode 100644 lib/arm-ffa/Makefile create mode 100644 lib/arm-ffa/arm_ffa_helper.c
diff --git a/MAINTAINERS b/MAINTAINERS index 74d5263fb1..c5b608eb60 100644 --- a/MAINTAINERS +++ b/MAINTAINERS @@ -232,6 +232,14 @@ F: board/CZ.NIC/ F: configs/turris_*_defconfig F: include/configs/turris_*.h
+ARM FF-A +M: Abdellatif El Khlifi abdellatif.elkhlifi@arm.com +S: Maintained +F: drivers/arm-ffa/ +F: include/arm_ffa.h +F: include/arm_ffa_helper.h +F: lib/arm-ffa/ + ARM FREESCALE IMX M: Stefano Babic sbabic@denx.de M: Fabio Estevam festevam@gmail.com diff --git a/arch/arm/cpu/armv8/smccc-call.S b/arch/arm/cpu/armv8/smccc-call.S index dc92b28777..9a6aebf194 100644 --- a/arch/arm/cpu/armv8/smccc-call.S +++ b/arch/arm/cpu/armv8/smccc-call.S @@ -1,6 +1,8 @@ /* SPDX-License-Identifier: GPL-2.0 */ /* * Copyright (c) 2015, Linaro Limited + * (C) Copyright 2022 ARM Limited + * Abdellatif El Khlifi abdellatif.elkhlifi@arm.com */ #include <linux/linkage.h> #include <linux/arm-smccc.h> @@ -45,3 +47,28 @@ ENDPROC(__arm_smccc_smc) ENTRY(__arm_smccc_hvc) SMCCC hvc ENDPROC(__arm_smccc_hvc) + +#if (IS_ENABLED(CONFIG_ARM_FFA_TRANSPORT)) + + .macro FFASMCCC instr + .cfi_startproc + \instr #0 + ldr x9, [sp] + stp x0, x1, [x9, #ARM_SMCCC_RES_X0_OFFS] + stp x2, x3, [x9, #ARM_SMCCC_RES_X2_OFFS] + stp x4, x5, [x9, #ARM_SMCCC_RES_X4_OFFS] + stp x6, x7, [x9, #ARM_SMCCC_RES_X6_OFFS] + ret + .cfi_endproc + .endm + +/* + * void arm_ffa_smccc_smc(unsigned long a0, unsigned long a1, unsigned long a2, + * unsigned long a3, unsigned long a4, unsigned long a5, + * unsigned long a6, unsigned long a7, struct arm_smccc_res *res) + */ +ENTRY(__arm_ffa_smccc_smc) + FFASMCCC smc +ENDPROC(__arm_ffa_smccc_smc) + +#endif diff --git a/arch/arm/lib/asm-offsets.c b/arch/arm/lib/asm-offsets.c index 22fd541f9a..02a4a42fe6 100644 --- a/arch/arm/lib/asm-offsets.c +++ b/arch/arm/lib/asm-offsets.c @@ -9,6 +9,8 @@ * generate asm statements containing #defines, * compile this file to assembler, and then extract the * #defines from the assembly-language output. + * + * (C) Copyright 2022 ARM Limited */
#include <common.h> @@ -115,6 +117,10 @@ int main(void) #ifdef CONFIG_ARM_SMCCC DEFINE(ARM_SMCCC_RES_X0_OFFS, offsetof(struct arm_smccc_res, a0)); DEFINE(ARM_SMCCC_RES_X2_OFFS, offsetof(struct arm_smccc_res, a2)); +#if (IS_ENABLED(CONFIG_ARM_FFA_TRANSPORT)) + DEFINE(ARM_SMCCC_RES_X4_OFFS, offsetof(struct arm_smccc_res, a4)); + DEFINE(ARM_SMCCC_RES_X6_OFFS, offsetof(struct arm_smccc_res, a6)); +#endif DEFINE(ARM_SMCCC_QUIRK_ID_OFFS, offsetof(struct arm_smccc_quirk, id)); DEFINE(ARM_SMCCC_QUIRK_STATE_OFFS, offsetof(struct arm_smccc_quirk, state)); #endif diff --git a/common/board_r.c b/common/board_r.c index b92c1bb0be..7866ec3ad5 100644 --- a/common/board_r.c +++ b/common/board_r.c @@ -62,6 +62,10 @@ #include <asm-generic/gpio.h> #include <efi_loader.h>
+#ifdef CONFIG_ARM_FFA_TRANSPORT +#include <arm_ffa_helper.h> +#endif + DECLARE_GLOBAL_DATA_PTR;
ulong monitor_flash_len; @@ -771,6 +775,9 @@ static init_fnc_t init_sequence_r[] = { INIT_FUNC_WATCHDOG_RESET initr_net, #endif +#ifdef CONFIG_ARM_FFA_TRANSPORT + ffa_helper_init_device, +#endif #ifdef CONFIG_POST initr_post, #endif diff --git a/drivers/Kconfig b/drivers/Kconfig index b26ca8cf70..e83c23789d 100644 --- a/drivers/Kconfig +++ b/drivers/Kconfig @@ -6,6 +6,8 @@ source "drivers/core/Kconfig"
source "drivers/adc/Kconfig"
+source "drivers/arm-ffa/Kconfig" + source "drivers/ata/Kconfig"
source "drivers/axi/Kconfig" diff --git a/drivers/Makefile b/drivers/Makefile index 4e7cf28440..6671d2a604 100644 --- a/drivers/Makefile +++ b/drivers/Makefile @@ -107,6 +107,7 @@ obj-y += iommu/ obj-y += smem/ obj-y += thermal/ obj-$(CONFIG_TEE) += tee/ +obj-$(CONFIG_ARM_FFA_TRANSPORT) += arm-ffa/ obj-y += axi/ obj-y += ufs/ obj-$(CONFIG_W1) += w1/ diff --git a/drivers/arm-ffa/Kconfig b/drivers/arm-ffa/Kconfig new file mode 100644 index 0000000000..e503dfaebf --- /dev/null +++ b/drivers/arm-ffa/Kconfig @@ -0,0 +1,25 @@ +# SPDX-License-Identifier: GPL-2.0 + +config ARM_FFA_TRANSPORT + bool "Enable Arm Firmware Framework for Armv8-A driver" + depends on DM && ARM64 + select ARM_SMCCC if ARM64 + select LIB_UUID + select ARM_FFA_TRANSPORT_HELPERS + help + The Firmware Framework for Arm A-profile processors (FF-A) + describes interfaces (ABIs) that standardize communication + between the Secure World and Normal World leveraging TrustZone + technology. + + This driver is based on FF-A specification v1.0 and uses SMC32 + calling convention. + + FF-A specification: + + https://developer.arm.com/documentation/den0077/a/?lang=en + + In u-boot FF-A design, the Secure World is considered as one + entity to communicate with. FF-A communication is handled by + one device and one instance. This device takes care of + all the interactions between Normal world and Secure World. diff --git a/drivers/arm-ffa/Makefile b/drivers/arm-ffa/Makefile new file mode 100644 index 0000000000..7bc9a336a9 --- /dev/null +++ b/drivers/arm-ffa/Makefile @@ -0,0 +1,6 @@ +# SPDX-License-Identifier: GPL-2.0+ +# +# (C) Copyright 2022 Abdellatif El Khlifi abdellatif.elkhlifi@arm.com +# + +obj-y += arm-ffa-uclass.o core.o diff --git a/drivers/arm-ffa/arm-ffa-uclass.c b/drivers/arm-ffa/arm-ffa-uclass.c new file mode 100644 index 0000000000..0bf661d397 --- /dev/null +++ b/drivers/arm-ffa/arm-ffa-uclass.c @@ -0,0 +1,65 @@ +// SPDX-License-Identifier: GPL-2.0+ +/* + * (C) Copyright 2022 ARM Limited + * Abdellatif El Khlifi abdellatif.elkhlifi@arm.com + */ + +#include <common.h> +#include <dm.h> +#include <arm_ffa.h> +#include <errno.h> +#include <log.h> +#include <asm/global_data.h> + +DECLARE_GLOBAL_DATA_PTR; + +UCLASS_DRIVER(ffa) = { + .name = "ffa", + .id = UCLASS_FFA, +}; + +/** + * ffa_get_invoke_func - performs a call to the FF-A driver dispatcher + * @func_id: The FF-A function to be used + * @func_data: Pointer to the FF-A function arguments + * container structure. This also includes + * pointers to the returned data needed by + * clients. + * + * This runtime function passes the FF-A function ID and its arguments to + * the FF-A driver dispatcher. + * This function is called by the FF-A helper functions. + * + * Return: + * + * FFA_ERR_STAT_SUCCESS on success. Otherwise, failure + */ +int __ffa_runtime ffa_get_invoke_func(u32 func_id, struct ffa_interface_data *func_data) +{ + if (!ffa_device_get_ops()->invoke_func) + return -EINVAL; + + return ffa_device_get_ops()->invoke_func(func_id, func_data); +} + +/** + * ffa_init_device - probes the arm_ffa device + * + * This boot time function makes sure the arm_ffa device is probed + * and ready for use. + * This function is called automatically at initcalls + * level (after u-boot relocation). + * + * Arm FF-A transport is implemented through a single u-boot + * device (arm_ffa). So, there is only one device belonging to UCLASS_FFA. + * All FF-A clients should use the arm_ffa device to use the FF-A + * transport. + * + * Return: + * + * FFA_ERR_STAT_SUCCESS on success. Otherwise, failure + */ +int ffa_init_device(void) +{ + return ffa_get_device(); +} diff --git a/drivers/arm-ffa/arm_ffa_prv.h b/drivers/arm-ffa/arm_ffa_prv.h new file mode 100644 index 0000000000..c788d0bd53 --- /dev/null +++ b/drivers/arm-ffa/arm_ffa_prv.h @@ -0,0 +1,200 @@ +/* SPDX-License-Identifier: GPL-2.0+ */ +/* + * (C) Copyright 2022 ARM Limited + * Abdellatif El Khlifi abdellatif.elkhlifi@arm.com + */ + +#ifndef __ARM_FFA_PRV_H +#define __ARM_FFA_PRV_H + +#include <arm_ffa.h> +#include <linux/bitfield.h> +#include <linux/bitops.h> +#include <dm/read.h> + +/* + * This header is private. It is exclusively used by the FF-A driver + */ + +/* FF-A driver version definitions */ + +#define MAJOR_VERSION_MASK GENMASK(30, 16) +#define MINOR_VERSION_MASK GENMASK(15, 0) +#define GET_FFA_MAJOR_VERSION(x) \ + ((u16)(FIELD_GET(MAJOR_VERSION_MASK, (x)))) +#define GET_FFA_MINOR_VERSION(x) \ + ((u16)(FIELD_GET(MINOR_VERSION_MASK, (x)))) +#define PACK_VERSION_INFO(major, minor) \ + (FIELD_PREP(MAJOR_VERSION_MASK, (major)) | \ + FIELD_PREP(MINOR_VERSION_MASK, (minor))) + +#define FFA_MAJOR_VERSION (1) +#define FFA_MINOR_VERSION (0) +#define FFA_VERSION_1_0 \ + PACK_VERSION_INFO(FFA_MAJOR_VERSION, FFA_MINOR_VERSION) + +/* Endpoint ID mask (u-boot endpoint ID) */ + +#define GET_SELF_ENDPOINT_ID_MASK GENMASK(15, 0) +#define GET_SELF_ENDPOINT_ID(x) \ + ((u16)(FIELD_GET(GET_SELF_ENDPOINT_ID_MASK, (x)))) + +#define PREP_SELF_ENDPOINT_ID_MASK GENMASK(31, 16) +#define PREP_SELF_ENDPOINT_ID(x) \ + (FIELD_PREP(PREP_SELF_ENDPOINT_ID_MASK, (x))) + +/* Partition endpoint ID mask (partition with which u-boot communicates with) */ + +#define PREP_PART_ENDPOINT_ID_MASK GENMASK(15, 0) +#define PREP_PART_ENDPOINT_ID(x) \ + (FIELD_PREP(PREP_PART_ENDPOINT_ID_MASK, (x))) + +/* The FF-A SMC function prototype definition */ + +typedef void (*invoke_ffa_fn_t)(unsigned long a0, unsigned long a1, + unsigned long a2, unsigned long a3, unsigned long a4, + unsigned long a5, unsigned long a6, unsigned long a7, + struct arm_smccc_res *res); + +/** + * enum ffa_conduit - Arm FF-A conduits supported by the Arm FF-A driver + * Currently only SMC32 is supported. + */ +enum ffa_conduit { + FFA_CONDUIT_SMC = 0, +}; + +/** + * FFA_DECLARE_ARGS - FF-A functions local variables + * @a0-a7: local variables used to set registers x0-x7 + * @res: the structure hosting the FF-A function return data + * + * A helper macro for declaring local variables for the FF-A functions arguments. + * The x0-x7 registers are used to exchange data with the secure world. + * But, only the bottom 32-bit of thes registers contains the data. + */ +#define FFA_DECLARE_ARGS \ + unsigned long a0 = 0; \ + unsigned long a1 = 0; \ + unsigned long a2 = 0; \ + unsigned long a3 = 0; \ + unsigned long a4 = 0; \ + unsigned long a5 = 0; \ + unsigned long a6 = 0; \ + unsigned long a7 = 0; \ + struct arm_smccc_res res = {0} + +/* FF-A error codes */ +#define FFA_ERR_STAT_NOT_SUPPORTED (-1) +#define FFA_ERR_STAT_INVALID_PARAMETERS (-2) +#define FFA_ERR_STAT_NO_MEMORY (-3) +#define FFA_ERR_STAT_BUSY (-4) +#define FFA_ERR_STAT_INTERRUPTED (-5) +#define FFA_ERR_STAT_DENIED (-6) +#define FFA_ERR_STAT_RETRY (-7) +#define FFA_ERR_STAT_ABORTED (-8) + +/** + * struct ffa_features_desc - FF-A functions features + * @func_id: FF-A function + * @field1: features read from register w2 + * @field2: features read from register w3 + * + * Data structure describing the features of the FF-A functions queried by + * FFA_FEATURES + */ +struct ffa_features_desc { + u32 func_id; + u32 field1; + u32 field2; +}; + +/** + * enum ffa_rxtx_buf_sizes - minimum sizes supported + * for the RX/TX buffers + */ +enum ffa_rxtx_buf_sizes { + RXTX_4K, + RXTX_64K, + RXTX_16K +}; + +/* + * Number of the FF-A interfaces features descriptors + * currently only FFA_RXTX_MAP descriptor is supported + */ +#define FFA_FEATURE_DESC_CNT (1) + +/** + * struct ffa_pdata - platform data for the arm_ffa device + * @conduit: The FF-A conduit used + * + * Platform data structure read from the device tree + */ +struct ffa_pdata { + enum ffa_conduit conduit; +}; + +/** + * struct ffa_rxtxpair - structure hosting the RX/TX buffers virtual addresses + * @rxbuf: virtual address of the RX buffer + * @txbuf: virtual address of the TX buffer + * + * Data structure hosting the virtual addresses of the mapped RX/TX buffers + * These addresses are used by the FF-A functions that use the RX/TX buffers + */ +struct ffa_rxtxpair { + u64 rxbuf; /* virtual address */ + u64 txbuf; /* virtual address */ +}; + +/** + * struct ffa_partition_desc - the secure partition descriptor + * @info: partition information + * @UUID: UUID + * + * Each partition has its descriptor containing the partitions information and the UUID + */ +struct ffa_partition_desc { + struct ffa_partition_info info; + union ffa_partition_uuid UUID; +}; + +/** + * struct ffa_partitions - descriptors for all secure partitions + * @count: The number of partitions descriptors + * @descs The partitions descriptors table + * + * This data structure contains the partitions descriptors table + */ +struct ffa_partitions { + u32 count; + struct ffa_partition_desc *descs; /* virtual address */ +}; + +/** + * struct ffa_prvdata - the driver private data structure + * + * @dev: The arm_ffa device under u-boot driver model + * @fwk_version: FF-A framework version + * @id: u-boot endpoint ID + * @partitions: The partitions descriptors structure + * @pair: The RX/TX buffers pair + * @conduit: The selected conduit + * @invoke_ffa_fn: The function executing the FF-A function + * @features: Table of the FF-A functions having features + * + * The driver data structure hosting all resident data. + */ +struct ffa_prvdata { + struct udevice *dev; + u32 fwk_version; + u16 id; + struct ffa_partitions partitions; + struct ffa_rxtxpair pair; + enum ffa_conduit conduit; + invoke_ffa_fn_t invoke_ffa_fn; + struct ffa_features_desc features[FFA_FEATURE_DESC_CNT]; +}; + +#endif diff --git a/drivers/arm-ffa/core.c b/drivers/arm-ffa/core.c new file mode 100644 index 0000000000..9d0dab1d36 --- /dev/null +++ b/drivers/arm-ffa/core.c @@ -0,0 +1,1427 @@ +// SPDX-License-Identifier: GPL-2.0+ +/* + * (C) Copyright 2022 ARM Limited + * Abdellatif El Khlifi abdellatif.elkhlifi@arm.com + */ + +#include "arm_ffa_prv.h" +#include <asm/global_data.h> +#include <asm/io.h> +#include <common.h> +#include <dm.h> +#include <linux/errno.h> +#include <linux/sizes.h> +#include <log.h> +#include <malloc.h> +#include <mapmem.h> +#include <string.h> + +DECLARE_GLOBAL_DATA_PTR; + +/** + * The device private data structure containing all the resident + * data read from secure world + */ +struct ffa_prvdata __ffa_runtime_data ffa_priv_data = {0}; + +/* + * Driver functions + */ + +/** + * ffa_get_device - probes the arm_ffa device + * + * This boot time function makes sure the arm_ffa device is probed + * and ready for use. This is done using uclass_get_device. + * The arm_ffa driver belongs to UCLASS_FFA. + * This function should be called before using the driver. + * + * Arm FF-A transport is implemented through a single u-boot + * device (arm_ffa). So, there is only one device belonging to UCLASS_FFA. + * All FF-A clients should use the arm_ffa device to use the FF-A + * transport. + * + * Return: + * + * FFA_ERR_STAT_SUCCESS on success. Otherwise, failure + */ +int ffa_get_device(void) +{ + int ret; + int devnum = 0; + + if (ffa_priv_data.dev) + return FFA_ERR_STAT_SUCCESS; + + /* + * searching and probing the device + */ + ret = uclass_get_device(UCLASS_FFA, devnum, &ffa_priv_data.dev); + if (ret) { + ffa_err("can not find the device"); + ffa_priv_data.dev = NULL; + return -ENODEV; + } + + return FFA_ERR_STAT_SUCCESS; +} + +/** + * ffa_get_version - FFA_VERSION handler function + * + * This is the boot time function that implements FFA_VERSION FF-A function + * to get from the secure world the FF-A framework version + * + * Return: + * + * FFA_ERR_STAT_SUCCESS on success. Otherwise, failure + */ +static int ffa_get_version(void) +{ + u16 major, minor; + + FFA_DECLARE_ARGS; + + if (!ffa_priv_data.invoke_ffa_fn) + panic("[FFA] no private data found\n"); + + a0 = FFA_VERSION; + a1 = FFA_VERSION_1_0; + ffa_priv_data.invoke_ffa_fn(a0, a1, a2, a3, a4, a5, a6, a7, &res); + + if (res.a0 == FFA_ERR_STAT_NOT_SUPPORTED) { + ffa_err("A Firmware Framework implementation does not exist"); + return -EOPNOTSUPP; + } + + major = GET_FFA_MAJOR_VERSION(res.a0); + minor = GET_FFA_MINOR_VERSION(res.a0); + + ffa_info("FF-A driver %d.%d\nFF-A framework %d.%d", + FFA_MAJOR_VERSION, FFA_MINOR_VERSION, major, minor); + + if ((major == FFA_MAJOR_VERSION && minor >= FFA_MINOR_VERSION)) { + ffa_info("Versions are compatible "); + + ffa_priv_data.fwk_version = res.a0; + + return FFA_ERR_STAT_SUCCESS; + } + + ffa_info("Versions are incompatible "); + return -EPROTONOSUPPORT; +} + +/** + * ffa_get_endpoint_id - FFA_ID_GET handler function + * + * This is the boot time function that implements FFA_ID_GET FF-A function + * to get from the secure world u-boot endpoint ID + * + * Return: + * + * FFA_ERR_STAT_SUCCESS on success. Otherwise, failure + */ +static int ffa_get_endpoint_id(void) +{ + FFA_DECLARE_ARGS; + + if (!ffa_priv_data.invoke_ffa_fn) + panic("[FFA] no private data found\n"); + + a0 = FFA_ID_GET; + + ffa_priv_data.invoke_ffa_fn(a0, a1, a2, a3, a4, a5, a6, a7, &res); + + switch (res.a0) { + case FFA_ERROR: + { + if (((int)res.a2) == FFA_ERR_STAT_NOT_SUPPORTED) { + ffa_err("This function is not implemented at this FF-A instance"); + return -EOPNOTSUPP; + } + + ffa_err("Undefined error code (%d)", ((int)res.a2)); + return -EINVAL; + } + case FFA_SUCCESS: + { + ffa_priv_data.id = GET_SELF_ENDPOINT_ID(res.a2); + ffa_info("endpoint ID is %u", ffa_priv_data.id); + + return FFA_ERR_STAT_SUCCESS; + } + default: + { + ffa_err("Undefined response function (0x%lx)", res.a0); + return -EINVAL; + } + } +} + +/** + * ffa_get_features_desc - returns the features descriptor of the specified + * FF-A function + * @func_id: the FF-A function which the features are to be retrieved + * + * This is a boot time function that searches the features descriptor of the + * specified FF-A function + * + * Return: + * + * When found, the address of the features descriptor is returned. Otherwise, NULL. + */ +static struct ffa_features_desc *ffa_get_features_desc(u32 func_id) +{ + u32 desc_idx; + + /* + * search for the descriptor of the selected FF-A interface + */ + for (desc_idx = 0; desc_idx < FFA_FEATURE_DESC_CNT ; desc_idx++) + if (ffa_priv_data.features[desc_idx].func_id == func_id) + return &ffa_priv_data.features[desc_idx]; + + return NULL; +} + +/** + * ffa_get_rxtx_map_features - FFA_FEATURES handler function with FFA_RXTX_MAP + * argument + * + * This is the boot time function that implements FFA_FEATURES FF-A function + * to retrieve the FFA_RXTX_MAP features + * + * Return: + * + * FFA_ERR_STAT_SUCCESS on success. Otherwise, failure + */ +static int ffa_get_rxtx_map_features(void) +{ + FFA_DECLARE_ARGS; + + if (!ffa_priv_data.invoke_ffa_fn) + panic("[FFA] no private data found\n"); + + a0 = FFA_FEATURES; + a1 = FFA_RXTX_MAP; + + ffa_priv_data.invoke_ffa_fn(a0, a1, a2, a3, a4, a5, a6, a7, &res); + + switch (res.a0) { + case FFA_ERROR: + { + if (((int)res.a2) == FFA_ERR_STAT_NOT_SUPPORTED) { + ffa_err("FFA_RXTX_MAP is not implemented at this FF-A instance"); + return -EOPNOTSUPP; + } + + ffa_err("Undefined error code (%d)", ((int)res.a2)); + return -EINVAL; + } + case FFA_SUCCESS: + { + u32 desc_idx; + + /* + * search for an empty descriptor + */ + for (desc_idx = 0; desc_idx < FFA_FEATURE_DESC_CNT ; desc_idx++) + if (!ffa_priv_data.features[desc_idx].func_id) { + /* + * populate the descriptor with + * the interface features data + */ + ffa_priv_data.features[desc_idx].func_id = + FFA_RXTX_MAP; + ffa_priv_data.features[desc_idx].field1 = + res.a2; + + ffa_info("FFA_RXTX_MAP features data 0x%lx", + res.a2); + + return FFA_ERR_STAT_SUCCESS; + } + + ffa_err("Cannot save FFA_RXTX_MAP features data. Descriptors table full"); + return -ENOBUFS; + } + default: + { + ffa_err("Undefined response function (0x%lx)", + res.a0); + return -EINVAL; + } + } +} + +/** + * ffa_get_rxtx_buffers_pages_cnt - reads from the features data descriptors + * the minimum number of pages in each of the RX/TX + * buffers + * @buf_4k_pages: Pointer to the minimum number of pages + * + * This is the boot time function that returns the minimum number of pages + * in each of the RX/TX buffers + * + * Return: + * + * buf_4k_pages points to the returned number of pages + * FFA_ERR_STAT_SUCCESS on success. Otherwise, failure + */ +static int ffa_get_rxtx_buffers_pages_cnt(size_t *buf_4k_pages) +{ + struct ffa_features_desc *desc = NULL; + + if (!buf_4k_pages) + return -EINVAL; + + desc = ffa_get_features_desc(FFA_RXTX_MAP); + if (!desc) + return -EINVAL; + + switch (desc->field1) { + case RXTX_4K: + *buf_4k_pages = 1; + break; + case RXTX_16K: + *buf_4k_pages = 4; + break; + case RXTX_64K: + *buf_4k_pages = 16; + break; + default: + ffa_err("RX/TX buffer size not supported"); + return -EINVAL; + } + + return FFA_ERR_STAT_SUCCESS; +} + +/** + * ffa_free_rxtx_buffers - frees the RX/TX buffers + * @buf_4k_pages: the minimum number of pages in each of the RX/TX + * buffers + * + * This is the boot time function used to free the RX/TX buffers + * + * Return: + * + * FFA_ERR_STAT_SUCCESS on success. Otherwise, failure + */ +static int ffa_free_rxtx_buffers(size_t buf_4k_pages) +{ + efi_status_t free_rxbuf_ret, free_txbuf_ret; + + ffa_info("Freeing RX/TX buffers"); + + free_rxbuf_ret = efi_free_pages(ffa_priv_data.pair.rxbuf, buf_4k_pages); + free_txbuf_ret = efi_free_pages(ffa_priv_data.pair.txbuf, buf_4k_pages); + + if (free_rxbuf_ret != EFI_SUCCESS || free_txbuf_ret != EFI_SUCCESS) { + ffa_err("Failed to free RX/TX buffers (rx: %lu , tx: %lu)", + free_rxbuf_ret, + free_txbuf_ret); + return -EINVAL; + } + + ffa_priv_data.pair.rxbuf = 0; + ffa_priv_data.pair.txbuf = 0; + + return FFA_ERR_STAT_SUCCESS; +} + +/** + * ffa_alloc_rxtx_buffers - allocates the RX/TX buffers + * @buf_4k_pages: the minimum number of pages in each of the RX/TX + * buffers + * + * This is the boot time function used by ffa_map_rxtx_buffers to allocate + * the RX/TX buffers before mapping them + * + * Return: + * + * FFA_ERR_STAT_SUCCESS on success. Otherwise, failure + */ +static int ffa_alloc_rxtx_buffers(size_t buf_4k_pages) +{ +#if CONFIG_IS_ENABLED(EFI_LOADER) + + efi_status_t efi_ret; + void *virt_txbuf; + void *virt_rxbuf; + + ffa_info("Using %lu 4KB page(s) for RX/TX buffers size", + buf_4k_pages); + + efi_ret = efi_allocate_pages(EFI_ALLOCATE_ANY_PAGES, + EFI_BOOT_SERVICES_DATA, + buf_4k_pages, + &ffa_priv_data.pair.rxbuf); + + if (efi_ret != EFI_SUCCESS) { + ffa_priv_data.pair.rxbuf = 0; + ffa_err("Failure to allocate RX buffer (EFI error: 0x%lx)", + efi_ret); + + return -ENOBUFS; + } + + ffa_info("RX buffer at virtual address 0x%llx", + ffa_priv_data.pair.rxbuf); + + virt_rxbuf = (void *)ffa_priv_data.pair.rxbuf; + + /* + * make sure the buffer is clean before use + */ + memset(virt_rxbuf, 0, buf_4k_pages * SZ_4K); + + efi_ret = efi_allocate_pages(EFI_ALLOCATE_ANY_PAGES, + EFI_RUNTIME_SERVICES_DATA, + buf_4k_pages, + &ffa_priv_data.pair.txbuf); + + if (efi_ret != EFI_SUCCESS) { + efi_free_pages(ffa_priv_data.pair.rxbuf, buf_4k_pages); + ffa_priv_data.pair.rxbuf = 0; + ffa_priv_data.pair.txbuf = 0; + ffa_err("Failure to allocate the TX buffer (EFI error: 0x%lx)" + , efi_ret); + + return -ENOBUFS; + } + + ffa_info("TX buffer at virtual address 0x%llx", + ffa_priv_data.pair.txbuf); + + virt_txbuf = (void *)ffa_priv_data.pair.txbuf; + + /* + * make sure the buffer is clean before use + */ + memset(virt_txbuf, 0, buf_4k_pages * SZ_4K); + + return FFA_ERR_STAT_SUCCESS; + +#else + return -ENOBUFS; +#endif +} + +/** + * ffa_map_rxtx_buffers - FFA_RXTX_MAP handler function + * @buf_4k_pages: the minimum number of pages in each of the RX/TX + * buffers + * + * This is the boot time function that implements FFA_RXTX_MAP FF-A function + * to map the RX/TX buffers + * + * Return: + * + * FFA_ERR_STAT_SUCCESS on success. Otherwise, failure + */ +static int ffa_map_rxtx_buffers(size_t buf_4k_pages) +{ + int ret; + + FFA_DECLARE_ARGS; + + if (!ffa_priv_data.invoke_ffa_fn) + panic("[FFA] no private data found\n"); + + ret = ffa_alloc_rxtx_buffers(buf_4k_pages); + if (ret != FFA_ERR_STAT_SUCCESS) + return ret; + + a0 = FFA_RXTX_MAP; + a1 = ffa_priv_data.pair.txbuf; + a2 = ffa_priv_data.pair.rxbuf; + a3 = buf_4k_pages; + + ffa_priv_data.invoke_ffa_fn(a0, a1, a2, a3, a4, a5, a6, a7, &res); + + switch (res.a0) { + case FFA_ERROR: + { + switch (((int)res.a2)) { + case FFA_ERR_STAT_INVALID_PARAMETERS: + ffa_err("One or more fields in input parameters is incorrectly encoded"); + ret = -EPERM; + break; + case FFA_ERR_STAT_NO_MEMORY: + ffa_err("Not enough memory"); + ret = -ENOMEM; + break; + case FFA_ERR_STAT_DENIED: + ffa_err("Buffer pair already registered"); + ret = -EACCES; + break; + case FFA_ERR_STAT_NOT_SUPPORTED: + ffa_err("This function is not implemented at this FF-A instance"); + ret = -EOPNOTSUPP; + break; + default: + ffa_err("Undefined error (%d)", + ((int)res.a2)); + ret = -EINVAL; + } + break; + } + case FFA_SUCCESS: + ffa_info("RX/TX buffers mapped"); + return FFA_ERR_STAT_SUCCESS; + default: + ffa_err("Undefined response function (0x%lx)", + res.a0); + ret = -EINVAL; + } + + ffa_free_rxtx_buffers(buf_4k_pages); + + return ret; +} + +/** + * ffa_unmap_rxtx_buffers - FFA_RXTX_UNMAP handler function + * + * This is the boot time function that implements FFA_RXTX_UNMAP FF-A function + * to unmap the RX/TX buffers + * + * Return: + * + * FFA_ERR_STAT_SUCCESS on success. Otherwise, failure + */ +static int ffa_unmap_rxtx_buffers(void) +{ + FFA_DECLARE_ARGS; + + if (!ffa_priv_data.invoke_ffa_fn) + panic("[FFA] no private data found\n"); + + a0 = FFA_RXTX_UNMAP; + a1 = PREP_SELF_ENDPOINT_ID(ffa_priv_data.id); + + ffa_priv_data.invoke_ffa_fn(a0, a1, a2, a3, a4, a5, a6, a7, &res); + + switch (res.a0) { + case FFA_ERROR: + { + if (((int)res.a2) == FFA_ERR_STAT_NOT_SUPPORTED) + panic("[FFA] FFA_RXTX_UNMAP is not implemented at this FF-A instance\n"); + else if (((int)res.a2) == FFA_ERR_STAT_INVALID_PARAMETERS) + panic("[FFA] There is no buffer pair registered on behalf of the caller\n"); + else + panic("[FFA] Undefined error (%d)\n", ((int)res.a2)); + } + case FFA_SUCCESS: + { + size_t buf_4k_pages = 0; + int ret; + + ret = ffa_get_rxtx_buffers_pages_cnt(&buf_4k_pages); + if (ret != FFA_ERR_STAT_SUCCESS) + panic("[FFA] RX/TX buffers unmapped but failure in getting pages count\n"); + + ret = ffa_free_rxtx_buffers(buf_4k_pages); + if (ret != FFA_ERR_STAT_SUCCESS) + panic("[FFA] RX/TX buffers unmapped but failure in freeing the memory\n"); + + ffa_info("RX/TX buffers unmapped and memory freed"); + + return FFA_ERR_STAT_SUCCESS; + } + default: + panic("[FFA] Undefined response function (0x%lx)", res.a0); + } +} + +/** + * ffa_release_rx_buffer - FFA_RX_RELEASE handler function + * + * This is the boot time function that invokes FFA_RX_RELEASE FF-A function + * to release the ownership of the RX buffer + * + * Return: + * + * FFA_ERR_STAT_SUCCESS on success. Otherwise, failure + */ +static int ffa_release_rx_buffer(void) +{ + FFA_DECLARE_ARGS; + + if (!ffa_priv_data.invoke_ffa_fn) + panic("[FFA] no private data found\n"); + + a0 = FFA_RX_RELEASE; + + ffa_priv_data.invoke_ffa_fn(a0, a1, a2, a3, a4, a5, a6, a7, &res); + + switch (res.a0) { + case FFA_ERROR: + { + if (((int)res.a2) == FFA_ERR_STAT_NOT_SUPPORTED) + panic("[FFA] FFA_RX_RELEASE is not implemented at this FF-A instance\n"); + else if (((int)res.a2) == FFA_ERR_STAT_DENIED) + panic("[FFA] Caller did not have ownership of the RX buffer\n"); + else + panic("[FFA] Undefined error (%d)\n", ((int)res.a2)); + } + case FFA_SUCCESS: + return FFA_ERR_STAT_SUCCESS; + + default: + panic("[FFA] Undefined response function (0x%lx)\n", res.a0); + } +} + +/** + * ffa_uuid_are_identical - checks whether two given UUIDs are identical + * @uuid1: first UUID + * @uuid2: second UUID + * + * This is a boot time function used by ffa_read_partitions_info to search + * for a UUID in the partitions descriptors table + * + * Return: + * + * 1 when UUIDs match. Otherwise, 0 + */ +int ffa_uuid_are_identical(const union ffa_partition_uuid *uuid1, + const union ffa_partition_uuid *uuid2) +{ + if (!uuid1 || !uuid2) + return 0; + + return (!memcmp(uuid1, uuid2, sizeof(union ffa_partition_uuid))); +} + +/** + * ffa_read_partitions_info - reads the data queried by FFA_PARTITION_INFO_GET + * and saves it in the private structure + * @count: The number of partitions queried + * @part_uuid: Pointer to the partition(s) UUID + * + * This is the boot time function that reads the partitions information + * returned by the FFA_PARTITION_INFO_GET and saves it in the private + * data structure. + * + * Return: + * + * The private data structure is updated with the partition(s) information + * FFA_ERR_STAT_SUCCESS is returned on success. Otherwise, failure + */ +static int ffa_read_partitions_info(u32 count, union ffa_partition_uuid *part_uuid) +{ + if (!count) { + ffa_err("No partition detected"); + return -ENODATA; + } + + ffa_info("Reading partitions data from the RX buffer"); + +#if CONFIG_IS_ENABLED(EFI_LOADER) + + if (!part_uuid) { + /* + * querying information of all partitions + */ + u64 data_pages; + u64 data_bytes; + efi_status_t efi_ret; + size_t buf_4k_pages = 0; + u32 desc_idx; + struct ffa_partition_info *parts_info; + int ret; + + data_bytes = count * sizeof(struct ffa_partition_desc); + data_pages = efi_size_in_pages(data_bytes); + + /* + * get the RX buffer size in pages + */ + ret = ffa_get_rxtx_buffers_pages_cnt(&buf_4k_pages); + if (ret != FFA_ERR_STAT_SUCCESS) { + ffa_err("Can not get the RX buffer size (error %d)", ret); + return ret; + } + + if (data_pages > buf_4k_pages) { + ffa_err("Partitions data size exceeds the RX buffer size:"); + ffa_err(" Sizes in pages: data %llu , RX buffer %lu ", + data_pages, + buf_4k_pages); + + return -ENOMEM; + } + + efi_ret = efi_allocate_pages(EFI_ALLOCATE_ANY_PAGES, + EFI_RUNTIME_SERVICES_DATA, + data_pages, + (u64 *)&ffa_priv_data.partitions.descs); + + if (efi_ret != EFI_SUCCESS) { + ffa_priv_data.partitions.descs = NULL; + + ffa_err("Cannot allocate partitions data buffer (EFI error 0x%lx)", + efi_ret); + + return -ENOBUFS; + } + + /* + * make sure the buffer is clean before use + */ + memset(ffa_priv_data.partitions.descs, 0, + data_pages * SZ_4K); + + parts_info = (struct ffa_partition_info *)ffa_priv_data.pair.rxbuf; + + for (desc_idx = 0 ; desc_idx < count ; desc_idx++) { + ffa_priv_data.partitions.descs[desc_idx].info = + parts_info[desc_idx]; + + ffa_info("Partition ID %x : info cached", + ffa_priv_data.partitions.descs[desc_idx].info.id); + } + + ffa_priv_data.partitions.count = count; + + ffa_info("%d partition(s) found and cached", count); + + } else { + u32 rx_desc_idx, cached_desc_idx; + struct ffa_partition_info *parts_info; + u8 desc_found; + + parts_info = (struct ffa_partition_info *)ffa_priv_data.pair.rxbuf; + + /* + * search for the SP IDs read from the RX buffer + * in the already cached SPs. + * Update the UUID when ID found. + */ + for (rx_desc_idx = 0; rx_desc_idx < count ; rx_desc_idx++) { + desc_found = 0; + + /* + * search the current ID in the cached partitions + */ + for (cached_desc_idx = 0; + cached_desc_idx < ffa_priv_data.partitions.count; + cached_desc_idx++) { + /* + * save the UUID + */ + if (ffa_priv_data.partitions.descs[cached_desc_idx].info.id == + parts_info[rx_desc_idx].id) { + ffa_priv_data.partitions.descs[cached_desc_idx].UUID = + *part_uuid; + + desc_found = 1; + break; + } + } + + if (!desc_found) + return -ENODATA; + } + } +#else +#warning "arm_ffa: reading FFA_PARTITION_INFO_GET data not implemented" +#endif + + return FFA_ERR_STAT_SUCCESS; +} + +/** + * ffa_query_partitions_info - invokes FFA_PARTITION_INFO_GET + * and saves partitions data + * @part_uuid: Pointer to the partition(s) UUID + * @pcount: Pointer to the number of partitions variable filled when querying + * + * This is the boot time function that executes the FFA_PARTITION_INFO_GET + * to query the partitions data. Then, it calls ffa_read_partitions_info + * to save the data in the private data structure. + * + * After reading the data the RX buffer is released using ffa_release_rx_buffer + * + * Return: + * + * When part_uuid is NULL, all partitions data are retrieved from secure world + * When part_uuid is non NULL, data for partitions matching the given UUID are + * retrieved and the number of partitions is returned + * FFA_ERR_STAT_SUCCESS is returned on success. Otherwise, failure + */ +static int ffa_query_partitions_info(union ffa_partition_uuid *part_uuid, + u32 *pcount) +{ + unsigned long a0 = 0; + union ffa_partition_uuid query_uuid = {0}; + unsigned long a5 = 0; + unsigned long a6 = 0; + unsigned long a7 = 0; + struct arm_smccc_res res = {0}; + + if (!ffa_priv_data.invoke_ffa_fn) + panic("[FFA] no private data found\n"); + + a0 = FFA_PARTITION_INFO_GET; + + /* + * If a UUID is specified. Information for one or more + * partitions in the system is queried. Otherwise, information + * for all installed partitions is queried + */ + + if (part_uuid) { + if (!pcount) + return -EINVAL; + + query_uuid = *part_uuid; + } + + ffa_priv_data.invoke_ffa_fn(a0, query_uuid.words.a1, query_uuid.words.a2, + query_uuid.words.a3, query_uuid.words.a4, + a5, a6, a7, &res); + + switch (res.a0) { + case FFA_ERROR: + { + switch (((int)res.a2)) { + case FFA_ERR_STAT_INVALID_PARAMETERS: + ffa_err("Unrecognized UUID"); + return -EPERM; + case FFA_ERR_STAT_NO_MEMORY: + ffa_err("Results cannot fit in RX buffer of the caller"); + return -ENOMEM; + case FFA_ERR_STAT_DENIED: + ffa_err("Callee is not in a state to handle this request"); + return -EACCES; + case FFA_ERR_STAT_NOT_SUPPORTED: + ffa_err("This function is not implemented at this FF-A instance"); + return -EOPNOTSUPP; + case FFA_ERR_STAT_BUSY: + ffa_err("RX buffer of the caller is not free"); + return -EBUSY; + default: + ffa_err("Undefined error (%d)", ((int)res.a2)); + return -EINVAL; + } + } + case FFA_SUCCESS: + { + int ret; + + /* + * res.a2 contains the count of partition information descriptors + * populated in the RX buffer + */ + if (res.a2) { + ret = ffa_read_partitions_info(res.a2, part_uuid); + if (ret) + ffa_err("Failed to read partition(s) data , error (%d)", ret); + } + + /* + * return the SP count + */ + if (part_uuid) { + if (!ret) + *pcount = res.a2; + else + *pcount = 0; + } + /* + * After calling FFA_PARTITION_INFO_GET the buffer ownership + * is assigned to the consumer (u-boot). So, we need to give + * the ownership back to the secure world + */ + ret = ffa_release_rx_buffer(); + + if (!part_uuid && !res.a2) { + ffa_err("[FFA] no partition installed in the system"); + return -ENODEV; + } + + return ret; + } + default: + ffa_err("Undefined response function (0x%lx)", res.a0); + return -EINVAL; + } +} + +/** + * ffa_get_partitions_info - FFA_PARTITION_INFO_GET handler function + * @func_data: Pointer to the FF-A function arguments container structure. + * The passed arguments: + * Mode 1: When getting from the driver the number of + * secure partitions: + * @data0_size: UUID size + * @data0: pointer to the UUID (little endian) + * @data1_size: size of the number of partitions + * variable + * @data1: pointer to the number of partitions + * variable. The variable will be set + * by the driver + * Mode 2: When requesting the driver to return the + * partitions information: + * @data0_size: UUID size + * @data0: pointer to the UUID (little endian) + * @data1_size: size of the SPs information buffer + * @data1: pointer to SPs information buffer + * (allocated by the client). + * The buffer will be filled by the driver + * + * This is the boot time function that queries the secure partition data from + * the private data structure. If not found, it invokes FFA_PARTITION_INFO_GET + * FF-A function to query the partition information from secure world. + * + * A client of the FF-A driver should know the UUID of the service it wants to + * access. It should use the UUID to request the FF-A driver to provide the + * partition(s) information of the service. The FF-A driver uses + * PARTITION_INFO_GET to obtain this information. This is implemented through + * ffa_get_partitions_info function. + * A new FFA_PARTITION_INFO_GET call is issued (first one performed through + * ffa_cache_partitions_info) allowing to retrieve the partition(s) information. + * They are not saved (already done). We only update the UUID in the cached area. + * This assumes that partitions data does not change in the secure world. + * Otherwise u-boot will have an outdated partition data. The benefit of caching + * the information in the FF-A driver is to accommodate discovery after + * ExitBootServices(). + * + * When invoked through a client request, ffa_get_partitions_info should be + * called twice. First call is to get from the driver the number of secure + * partitions (SPs) associated to a particular UUID. + * Then, the caller (client) allocates the buffer to host the SPs data and + * issues a 2nd call. Then, the driver fills the SPs data in the pre-allocated + * buffer. + * + * To achieve the mechanism described above, ffa_get_partitions_info uses the + * following functions: + * ffa_read_partitions_info + * ffa_query_partitions_info + * + * Return: + * + * @data1: When pointing to the number of partitions variable, the number is + * set by the driver. + * When pointing to the partitions information buffer, the buffer will be + * filled by the driver. + * + * On success FFA_ERR_STAT_SUCCESS is returned. Otherwise, failure + */ +static int ffa_get_partitions_info(struct ffa_interface_data *func_data) +{ + /* + * fill_data: + * 0: return the SP count + * 1: fill SP data and return it to the caller + * -1: undefined mode + */ + int fill_data = -1; + u32 desc_idx, client_desc_idx; + union ffa_partition_uuid *part_uuid; + u32 client_desc_max_cnt; + u32 parts_found = 0; + + if (!func_data) { + ffa_err("No function data provided"); + return -EINVAL; + } + + if (!ffa_priv_data.partitions.count || !ffa_priv_data.partitions.descs) + panic("[FFA] No partition installed\n"); + + if (func_data->data0_size == sizeof(union ffa_partition_uuid) && + func_data->data0 && + func_data->data1_size == sizeof(u32) && + func_data->data1) { + /* + * data0 (in): pointer to UUID + * data1 (in): pointer to SP count + * Out: SP count returned in the count variable pointed by data1 + */ + + fill_data = 0; + + ffa_info("Preparing for checking partitions count"); + + } else if ((func_data->data0_size == sizeof(union ffa_partition_uuid)) && + func_data->data0 && + (func_data->data1_size >= sizeof(struct ffa_partition_info)) && + !(func_data->data1_size % sizeof(struct ffa_partition_info)) && + func_data->data1) { + /* + * data0 (in): pointer to UUID + * data1 (in): pointer to SPs descriptors buffer + * (created by the client) + * Out: SPs descriptors returned in the buffer + * pointed by data1 + */ + + fill_data = 1; + + client_desc_idx = 0; + + /* + * number of empty descriptors preallocated by the caller + */ + client_desc_max_cnt = + func_data->data1_size / sizeof(struct ffa_partition_info); + + ffa_info("Preparing for filling partitions info"); + + } else { + ffa_err("Invalid function arguments provided"); + return -EINVAL; + } + + part_uuid = (union ffa_partition_uuid *)func_data->data0; + + ffa_info("Searching partitions using the provided UUID"); + + /* + * search in the cached partitions + */ + for (desc_idx = 0; + desc_idx < ffa_priv_data.partitions.count; + desc_idx++) { + if (ffa_uuid_are_identical(&ffa_priv_data.partitions.descs[desc_idx].UUID, + part_uuid)) { + ffa_info("Partition ID %x matches the provided UUID", + ffa_priv_data.partitions.descs[desc_idx].info.id); + + parts_found++; + + if (fill_data) { + /* + * trying to fill the partition info in data1 + */ + + if (client_desc_idx < client_desc_max_cnt) { + ((struct ffa_partition_info *) + func_data->data1)[client_desc_idx++] = + ffa_priv_data.partitions.descs[desc_idx].info; + continue; + } + + ffa_err("Failed to fill the current descriptor client buffer full"); + return -ENOBUFS; + } + } + } + + if (!parts_found) { + int ret; + + ffa_info("No partition found. Querying framework ..."); + + ret = ffa_query_partitions_info(part_uuid, &parts_found); + + if (ret == FFA_ERR_STAT_SUCCESS) { + if (!fill_data) { + *((u32 *)func_data->data1) = parts_found; + + ffa_info("Number of partition(s) found matching the UUID: %d", + parts_found); + } else { + /* + * we want to read SPs info + */ + + /* + * If SPs data filled, retry searching SP info again + */ + if (parts_found) + ret = ffa_get_partitions_info(func_data); + else + ret = -ENODATA; + } + } + + return ret; + } + + /* partition(s) found */ + if (!fill_data) + *((u32 *)func_data->data1) = parts_found; + + return FFA_ERR_STAT_SUCCESS; +} + +/** + * ffa_cache_partitions_info - Queries and saves all secure partitions data + * + * This is a boot time function that invokes FFA_PARTITION_INFO_GET FF-A + * function to query from secure world all partitions information. + * + * The FFA_PARTITION_INFO_GET call is issued with nil UUID as an argument. + * All installed partitions information are returned. We cache them in the + * resident private data structure and we keep the UUID field empty + * (in FF-A 1.0 UUID is not provided by the partition descriptor) + * + * This function is called at the device probing level. + * ffa_cache_partitions_info uses ffa_query_partitions_info to get the data + * + * Return: + * + * FFA_ERR_STAT_SUCCESS on success. Otherwise, failure + */ +static int ffa_cache_partitions_info(void) +{ + return ffa_query_partitions_info(NULL, NULL); +} + +/** + * ffa_msg_send_direct_req - FFA_MSG_SEND_DIRECT_{REQ,RESP} handler function + * @func_data: Pointer to the FF-A function arguments container structure. + * The passed arguments: + * @data0_size: partition ID size + * @data0: pointer to the partition ID + * @data1_size: exchanged data size + * @data1: pointer to the data buffer preallocated by + * the client (in/out) + * + * This is the runtime function that implements FFA_MSG_SEND_DIRECT_{REQ,RESP} + * FF-A functions. + * + * FFA_MSG_SEND_DIRECT_REQ is used to send the data to the secure partition. + * The response from the secure partition is handled by reading the + * FFA_MSG_SEND_DIRECT_RESP arguments. + * + * The maximum size of the data that can be exchanged is 20 bytes which is + * sizeof(struct ffa_send_direct_data) as defined by the FF-A specification 1.0 + * in the section relevant to FFA_MSG_SEND_DIRECT_{REQ,RESP} + * + * Return: + * + * FFA_ERR_STAT_SUCCESS on success. Otherwise, failure + */ +static int __ffa_runtime ffa_msg_send_direct_req(struct ffa_interface_data + *func_data) +{ + u16 dst_part_id; + unsigned long a0 = 0; + unsigned long a1 = 0; + unsigned long a2 = 0; + struct ffa_send_direct_data *msg; + struct arm_smccc_res res = {0}; + + if (!ffa_priv_data.invoke_ffa_fn) + return -ENODEV; + + if (!func_data) + return -EINVAL; + + /* No partition installed */ + if (!ffa_priv_data.partitions.count || !ffa_priv_data.partitions.descs) + return -ENODEV; + + /* Undefined interface parameters */ + if (func_data->data0_size != sizeof(u16) || + !func_data->data0 || + func_data->data1_size != FFA_MSG_SEND_DIRECT_MAX_SIZE || + !func_data->data1) + return -EINVAL; + + dst_part_id = *((u16 *)func_data->data0); + msg = func_data->data1; + + a0 = FFA_MSG_SEND_DIRECT_REQ; + + a1 = PREP_SELF_ENDPOINT_ID(ffa_priv_data.id) | + PREP_PART_ENDPOINT_ID(dst_part_id); + + ffa_priv_data.invoke_ffa_fn(a0, a1, a2, + msg->a3, + msg->a4, + msg->a5, + msg->a6, + msg->a7, + &res); + + while (res.a0 == FFA_INTERRUPT) + ffa_priv_data.invoke_ffa_fn(FFA_RUN, res.a1, + 0, 0, 0, 0, 0, 0, + &res); + + switch (res.a0) { + case FFA_ERROR: + { + switch (((int)res.a2)) { + case FFA_ERR_STAT_INVALID_PARAMETERS: + /* Invalid endpoint ID or non-zero reserved register */ + return -EPERM; + case FFA_ERR_STAT_ABORTED: + /* Message target ran into unexpected error and has aborted */ + return -ECONNABORTED; + case FFA_ERR_STAT_DENIED: + /* Callee is not in a state to handle this request */ + return -EACCES; + case FFA_ERR_STAT_NOT_SUPPORTED: + /* This function is not implemented at this FF-A instance */ + return -EOPNOTSUPP; + case FFA_ERR_STAT_BUSY: + /* Message target is busy */ + return -EBUSY; + default: + /* Undefined error */ + return -ENXIO; + } + } + case FFA_SUCCESS: + + /* Message sent with no response */ + return FFA_ERR_STAT_SUCCESS; + + case FFA_MSG_SEND_DIRECT_RESP: + + /* + * Message sent with response + * extract the 32-bit wide return data + */ + msg->a3 = (u32)res.a3; + msg->a4 = (u32)res.a4; + msg->a5 = (u32)res.a5; + msg->a6 = (u32)res.a6; + msg->a7 = (u32)res.a7; + + return FFA_ERR_STAT_SUCCESS; + + default: + /* Undefined response function */ + return -ENOENT; + } +} + +/** + * invoke_ffa_drv_api - The driver dispatcher function + * @func_id: The FF-A function to be used + * @func_data: Pointer to the FF-A function arguments container + * structure. This also includes pointers to the + * returned data needed by clients. + * The dispatcher is a runtime function that selects the FF-A function handler + * based on the input FF-A function ID. + * The input arguments are passed to the handler function. + * + * Return: + * + * FFA_ERR_STAT_SUCCESS on success. Otherwise, failure + */ +int __ffa_runtime invoke_ffa_drv_api(u32 func_id, + struct ffa_interface_data *func_data) +{ + if (!ffa_priv_data.dev) + return -ENODEV; + + switch (func_id) { + case FFA_PARTITION_INFO_GET: + return ffa_get_partitions_info(func_data); + case FFA_RXTX_UNMAP: + return ffa_unmap_rxtx_buffers(); + case FFA_MSG_SEND_DIRECT_REQ: + return ffa_msg_send_direct_req(func_data); + default: + /* Undefined FF-A interface */ + return -EINVAL; + } +} + +/** + * ffa_init_private_data - Initialization of the private data + * @dev: the arm_ffa device + * + * This boot time function reads data from the platform data structure + * and populates the private data structure + * + * Return: + * + * FFA_ERR_STAT_SUCCESS on success. Otherwise, failure + */ +static int ffa_init_private_data(struct udevice *dev) +{ + struct ffa_pdata *pdata = dev_get_plat(dev); + + ffa_priv_data.conduit = pdata->conduit; + + if (ffa_priv_data.conduit == FFA_CONDUIT_SMC) { + ffa_priv_data.invoke_ffa_fn = arm_ffa_smccc_smc; + } else { + ffa_err("Undefined FF-A conduit (%d)", ffa_priv_data.conduit); + return -EINVAL; + } + + ffa_info("Conduit is %s", + ((ffa_priv_data.conduit == FFA_CONDUIT_SMC) ? + "SMC" : "NOT SUPPORTED")); + + return FFA_ERR_STAT_SUCCESS; +} + +/** + * ffa_bind - The driver bind function + * @dev: the arm_ffa device + * + * Called when the driver is bound with the device based on the DTB node. + * The private data structure is cleared before use. + * This makes sure that when the device added/removed multiple times the previous + * private structure is cleared. + * + * Return: + * + * FFA_ERR_STAT_SUCCESS + */ +static int ffa_bind(struct udevice *dev) +{ + memset(&ffa_priv_data, 0, sizeof(ffa_priv_data)); + + return FFA_ERR_STAT_SUCCESS; +} + +/** + * ffa_probe - The driver probe function + * @dev: the arm_ffa device + * + * Probing is done at boot time and triggered by the uclass device discovery. + * At probe level the following actions are done: + * - initialization of the driver private data structure + * - querying from secure world the FF-A framework version + * - querying from secure world the u-boot endpoint ID + * - querying from secure world the supported features of the specified FF-A calls + * - mapping the RX/TX buffers + * - querying from secure world all the partitions information + * + * All data queried from secure world is saved in the resident private data structure. + * + * The probe will fail if either FF-A framework is not detected or the + * FF-A requests are not behaving correctly. This ensures that the + * driver is not installed and its operations are not exported to the clients. + * However, once the driver is successfully probed and an FF-A anomaly is + * detected when clients invoke the driver operations, the driver cause + * u-boot to panic because the client would not know what to do in such conditions. + * + * Return: + * + * FFA_ERR_STAT_SUCCESS on success. Otherwise, failure + */ +static int ffa_probe(struct udevice *dev) +{ + int ret; + size_t buf_4k_pages = 0; + + ret = ffa_init_private_data(dev); + + if (ret != FFA_ERR_STAT_SUCCESS) + return ret; + + ret = ffa_get_version(); + + if (ret != FFA_ERR_STAT_SUCCESS) + return ret; + + ret = ffa_get_endpoint_id(); + + if (ret != FFA_ERR_STAT_SUCCESS) + return ret; + + ret = ffa_get_rxtx_map_features(); + + if (ret != FFA_ERR_STAT_SUCCESS) + return ret; + + ret = ffa_get_rxtx_buffers_pages_cnt(&buf_4k_pages); + + if (ret != FFA_ERR_STAT_SUCCESS) + return ret; + + ret = ffa_map_rxtx_buffers(buf_4k_pages); + + if (ret != FFA_ERR_STAT_SUCCESS) + return ret; + + ret = ffa_cache_partitions_info(); + + if (ret != FFA_ERR_STAT_SUCCESS) { + ffa_free_rxtx_buffers(buf_4k_pages); + return ret; + } + + return FFA_ERR_STAT_SUCCESS; +} + +/** + * ffa_of_to_plat - Reads the device tree node + * @dev: the arm_ffa device + * + * This boot time function reads data from the device tree node and populates + * the platform data structure + * + * Return: + * + * FFA_ERR_STAT_SUCCESS on success. Otherwise, failure + */ +static int ffa_of_to_plat(struct udevice *dev) +{ + struct ffa_pdata *pdata = dev_get_plat(dev); + const char *conduit = NULL; + + conduit = dev_read_string(dev, "method"); + + if (!conduit) { + ffa_err("Failure to read the conduit from device tree"); + return -EINVAL; + } + + if (strcmp("smc", conduit)) { + ffa_err("Unsupported conduit"); + return -EINVAL; + } + + pdata->conduit = FFA_CONDUIT_SMC; + + return FFA_ERR_STAT_SUCCESS; +} + +/** + * ffa_drv_ops - The driver operations runtime structure + * @invoke_func: The driver dispatcher + */ +struct ffa_ops __ffa_runtime_data ffa_drv_ops = { + .invoke_func = invoke_ffa_drv_api +}; + +/** + * ffa_device_get_ops - driver operations getter + * + * Return: + * This runtime function returns a pointer to the driver operations structure + */ +const struct ffa_ops * __ffa_runtime ffa_device_get_ops(void) +{ + return &ffa_drv_ops; +} + +/** + * Defining the device tree compatible string + */ + +static const struct udevice_id ffa_match_id[] = { + {"arm,ffa", 0}, + {}, +}; + +/** + * Declaring the arm_ffa driver under UCLASS_FFA + */ + +U_BOOT_DRIVER(arm_ffa) = { + .name = "arm_ffa", + .of_match = ffa_match_id, + .id = UCLASS_FFA, + .of_to_plat = ffa_of_to_plat, + .probe = ffa_probe, + .bind = ffa_bind, + .plat_auto = sizeof(struct ffa_pdata), +}; diff --git a/include/arm_ffa.h b/include/arm_ffa.h new file mode 100644 index 0000000000..5a2151f8e4 --- /dev/null +++ b/include/arm_ffa.h @@ -0,0 +1,190 @@ +/* SPDX-License-Identifier: GPL-2.0+ */ +/* + * (C) Copyright 2022 ARM Limited + * Abdellatif El Khlifi abdellatif.elkhlifi@arm.com + */ + +#ifndef __ARM_FFA_H +#define __ARM_FFA_H + +#include <linux/arm-smccc.h> +#include <linux/printk.h> + +/* + * This header is public. It can be used by clients to access + * data structures and definitions they need + */ + +/* + * Macros for displaying logs + */ + +#define ffa_info(fmt, ...) pr_info("[FFA] " fmt "\n", ##__VA_ARGS__) +#define ffa_err(fmt, ...) pr_err("[FFA] " fmt "\n", ##__VA_ARGS__) + +/* + * The driver operations success error code + */ +#define FFA_ERR_STAT_SUCCESS (0) + +#if CONFIG_IS_ENABLED(EFI_LOADER) + +#include <efi_loader.h> + +/* + * __ffa_runtime_data and __ffa_runtime - controls whether data/code are + * available after calling the EFI ExitBootServices service. + * Data/code tagged with these keywords are resident (available at boot time and + * at runtime) + */ + +#define __ffa_runtime_data __efi_runtime_data +#define __ffa_runtime __efi_runtime + +#else + +#define __ffa_runtime_data +#define __ffa_runtime + +#endif + +/* + * Definitions of the Arm FF-A interfaces supported by the Arm FF-A driver + */ + +#define FFA_SMC(calling_convention, func_num) \ + ARM_SMCCC_CALL_VAL(ARM_SMCCC_FAST_CALL, (calling_convention), \ + ARM_SMCCC_OWNER_STANDARD, (func_num)) + +#define FFA_SMC_32(func_num) FFA_SMC(ARM_SMCCC_SMC_32, (func_num)) + +#define FFA_VERSION FFA_SMC_32(0x63) +#define FFA_ID_GET FFA_SMC_32(0x69) +#define FFA_FEATURES FFA_SMC_32(0x64) +#define FFA_PARTITION_INFO_GET FFA_SMC_32(0x68) +#define FFA_RXTX_MAP FFA_SMC_32(0x66) +#define FFA_RXTX_UNMAP FFA_SMC_32(0x67) +#define FFA_RX_RELEASE FFA_SMC_32(0x65) +#define FFA_MSG_SEND_DIRECT_REQ FFA_SMC_32(0x6F) +#define FFA_MSG_SEND_DIRECT_RESP FFA_SMC_32(0x70) +#define FFA_RUN FFA_SMC_32(0x6D) +#define FFA_ERROR FFA_SMC_32(0x60) +#define FFA_SUCCESS FFA_SMC_32(0x61) +#define FFA_INTERRUPT FFA_SMC_32(0x62) + +/* + * struct ffa_partition_info - Partition information descriptor + * @id: Partition ID + * @exec_ctxt: Execution context count + * @properties: Partition properties + * + * Data structure containing information about partitions instantiated in the system + * This structure is filled with the data queried by FFA_PARTITION_INFO_GET + */ +struct __packed ffa_partition_info { + u16 id; + u16 exec_ctxt; +/* partition supports receipt of direct requests */ +#define FFA_PARTITION_DIRECT_RECV BIT(0) +/* partition can send direct requests. */ +#define FFA_PARTITION_DIRECT_SEND BIT(1) +/* partition can send and receive indirect messages. */ +#define FFA_PARTITION_INDIRECT_MSG BIT(2) + u32 properties; +}; + +/* + * struct ffa_send_direct_data - Data structure hosting the data + * used by FFA_MSG_SEND_DIRECT_{REQ,RESP} + * @a3-a7: Data read/written from/to w3-w7 registers + * + * Data structure containing the data to be sent by FFA_MSG_SEND_DIRECT_REQ + * or read from FFA_MSG_SEND_DIRECT_RESP + */ +struct __packed ffa_send_direct_data { + u32 a3; /* w3 */ + u32 a4; /* w4 */ + u32 a5; /* w5 */ + u32 a6; /* w6 */ + u32 a7; /* w7 */ +}; + +#define FFA_MSG_SEND_DIRECT_MAX_SIZE (sizeof(struct ffa_send_direct_data)) + +/* UUID data size */ +#define UUID_SIZE (16) + +/* + * union ffa_partition_uuid - Data union hosting the UUID + * transmitted by FFA_PARTITION_INFO_GET + * @words: data structure giving 32-bit words access to the UUID data + * @bytes: data structure giving byte access to the UUID data + * + * The structure holds little-endian UUID data. + */ +union ffa_partition_uuid { + struct __packed words { + u32 a1; /* w1 */ + u32 a2; /* w2 */ + u32 a3; /* w3 */ + u32 a4; /* w4 */ + } words; + u8 bytes[UUID_SIZE]; +}; + +/** + * struct ffa_interface_data - generic FF-A interface data structure used to exchange + * data between user layers and the driver + * @data0_size: size of the first argument + * @data0: pointer to the first argument + * @data1_size>: size of the second argument + * @data1: pointer to the second argument + * + * Using this structure user layers can pass various types of data with different sizes. + * The driver internal functions can detect the nature of this data, verfy compliance + * then execute the request when appropriate. + */ +struct ffa_interface_data { + u32 data0_size; /* size of the first argument */ + void *data0; /* pointer to the first argument */ + u32 data1_size; /* size of the second argument */ + void *data1; /* pointer to the second argument */ +}; + +/** + * struct ffa_ops - The driver operations structure + * @invoke_func: function pointer to the invoke function + * + * The data structure providing all the operations supported by the driver. + * This structure is resident. + */ +struct ffa_ops { + /* the driver dispatcher */ + int (*invoke_func)(u32 func_id, struct ffa_interface_data *func_data); +}; + +/** + * The device driver and the Uclass driver public functions + */ + +/** + * ffa_get_invoke_func - performs a call to the FF-A driver dispatcher + */ +int __ffa_runtime ffa_get_invoke_func(u32 func_id, + struct ffa_interface_data *func_data); + +/** + * ffa_device_get_ops - driver operations getter + */ +const struct ffa_ops * __ffa_runtime ffa_device_get_ops(void); + +/** + * ffa_get_device - probes the arm_ffa device + */ +int ffa_get_device(void); + +/** + * ffa_init_device - probes the arm_ffa device + */ +int ffa_init_device(void); +#endif diff --git a/include/arm_ffa_helper.h b/include/arm_ffa_helper.h new file mode 100644 index 0000000000..76f7a9fd29 --- /dev/null +++ b/include/arm_ffa_helper.h @@ -0,0 +1,45 @@ +/* SPDX-License-Identifier: GPL-2.0+ */ +/* + * (C) Copyright 2022 ARM Limited + * Abdellatif El Khlifi abdellatif.elkhlifi@arm.com + */ + +#ifndef __ARM_FFA_HELPER_H +#define __ARM_FFA_HELPER_H + +#include <arm_ffa.h> + +/* + * This header is public. Including this header provides all data structures + * and definitions needed by clients to use the FF-A transport driver + * + * It also provides helper functions allowing to pass data and invoke FF-A functions + */ + +/** + * ffa_helper_get_partitions_info - Wrapper function for FFA_PARTITION_INFO_GET + */ +int ffa_helper_get_partitions_info(struct ffa_interface_data *func_data); + +/** + * ffa_helper_unmap_rxtx_buffers - Wrapper function for FFA_RXTX_UNMAP + */ +int ffa_helper_unmap_rxtx_buffers(void); + +/** + * ffa_helper_msg_send_direct_req - Wrapper function for + * FFA_MSG_SEND_DIRECT_{REQ,RESP} + */ +int __ffa_runtime ffa_helper_msg_send_direct_req(struct ffa_interface_data + *func_data); + +/** + * ffa_helper_init_device - Wrapper function for probing the arm_ffa device + */ +int ffa_helper_init_device(void); + +/** + * ffa_uuid_str_to_bin - Converts a big endian UUID string to a little endian buffer + */ +int ffa_uuid_str_to_bin(const char *uuid_str, unsigned char *uuid_bin); +#endif diff --git a/include/dm/uclass-id.h b/include/dm/uclass-id.h index 0e26e1d138..a1181b8f48 100644 --- a/include/dm/uclass-id.h +++ b/include/dm/uclass-id.h @@ -52,6 +52,7 @@ enum uclass_id { UCLASS_EFI_MEDIA, /* Devices provided by UEFI firmware */ UCLASS_ETH, /* Ethernet device */ UCLASS_ETH_PHY, /* Ethernet PHY device */ + UCLASS_FFA, /* Arm Firmware Framework for Armv8-A */ UCLASS_FIRMWARE, /* Firmware */ UCLASS_FS_FIRMWARE_LOADER, /* Generic loader */ UCLASS_GPIO, /* Bank of general-purpose I/O pins */ diff --git a/include/linux/arm-smccc.h b/include/linux/arm-smccc.h index 7f2be23394..d58c7c104b 100644 --- a/include/linux/arm-smccc.h +++ b/include/linux/arm-smccc.h @@ -1,6 +1,8 @@ /* SPDX-License-Identifier: GPL-2.0 */ /* * Copyright (c) 2015, Linaro Limited + * (C) Copyright 2022 ARM Limited + * Abdellatif El Khlifi abdellatif.elkhlifi@arm.com */ #ifndef __LINUX_ARM_SMCCC_H #define __LINUX_ARM_SMCCC_H @@ -57,13 +59,17 @@ #include <linux/types.h> /** * struct arm_smccc_res - Result from SMC/HVC call - * @a0-a3 result values from registers 0 to 3 + * @a0-a7 result values from registers 0 to 7 */ struct arm_smccc_res { unsigned long a0; unsigned long a1; unsigned long a2; unsigned long a3; + unsigned long a4; + unsigned long a5; + unsigned long a6; + unsigned long a7; };
/** @@ -113,6 +119,26 @@ asmlinkage void __arm_smccc_hvc(unsigned long a0, unsigned long a1, unsigned long a5, unsigned long a6, unsigned long a7, struct arm_smccc_res *res, struct arm_smccc_quirk *quirk);
+#if (IS_ENABLED(CONFIG_ARM_FFA_TRANSPORT)) +/** + * __arm_ffa_smccc_smc() - make SMC calls used for FF-A transport + * @a0-a7: arguments passed in 64-bit registers x0 to x7 + * @res: result values from 64-bit registers x0 to x7 + * + * This function is used to make SMC calls following SMC32 Calling Convention. + * The content of the supplied parameters is copied to registers x0 to x7 prior + * to the SMC instruction. The SMC call return data is 32-bit data read from + * registers x0 tp x7. + */ +asmlinkage void __arm_ffa_smccc_smc(unsigned long a0, unsigned long a1, + unsigned long a2, unsigned long a3, unsigned long a4, + unsigned long a5, unsigned long a6, unsigned long a7, + struct arm_smccc_res *res); + +#define arm_ffa_smccc_smc __arm_ffa_smccc_smc + +#endif + #define arm_smccc_smc(...) __arm_smccc_smc(__VA_ARGS__, NULL)
#define arm_smccc_smc_quirk(...) __arm_smccc_smc(__VA_ARGS__) diff --git a/lib/Kconfig b/lib/Kconfig index 3c6fa99b1a..473821b882 100644 --- a/lib/Kconfig +++ b/lib/Kconfig @@ -810,6 +810,7 @@ config SMBIOS_PARSER source lib/efi/Kconfig source lib/efi_loader/Kconfig source lib/optee/Kconfig +source lib/arm-ffa/Kconfig
config TEST_FDTDEC bool "enable fdtdec test" diff --git a/lib/Makefile b/lib/Makefile index 11b03d1cbe..8e6fad6130 100644 --- a/lib/Makefile +++ b/lib/Makefile @@ -9,6 +9,7 @@ obj-$(CONFIG_EFI) += efi/ obj-$(CONFIG_EFI_LOADER) += efi_driver/ obj-$(CONFIG_EFI_LOADER) += efi_loader/ obj-$(CONFIG_CMD_BOOTEFI_SELFTEST) += efi_selftest/ +obj-$(CONFIG_ARM_FFA_TRANSPORT_HELPERS) += arm-ffa/ obj-$(CONFIG_LZMA) += lzma/ obj-$(CONFIG_BZIP2) += bzip2/ obj-$(CONFIG_TIZEN) += tizen/ diff --git a/lib/arm-ffa/Kconfig b/lib/arm-ffa/Kconfig new file mode 100644 index 0000000000..79acbc5a8f --- /dev/null +++ b/lib/arm-ffa/Kconfig @@ -0,0 +1,6 @@ +config ARM_FFA_TRANSPORT_HELPERS + bool "Enable interface helpers for Arm Firmware Framework for Armv8-A" + depends on ARM_FFA_TRANSPORT + help + User layers call FF-A interfaces using helper functions which + pass the data and the FF-A function ID to the low level driver diff --git a/lib/arm-ffa/Makefile b/lib/arm-ffa/Makefile new file mode 100644 index 0000000000..cba625fde4 --- /dev/null +++ b/lib/arm-ffa/Makefile @@ -0,0 +1,8 @@ +# SPDX-License-Identifier: GPL-2.0+ +# +# (C) Copyright 2022 Abdellatif El Khlifi abdellatif.elkhlifi@arm.com +# + +# This file only gets included when CONFIG_ARM_FFA_TRANSPORT_HELPERS is set + +obj-y += arm_ffa_helper.o diff --git a/lib/arm-ffa/arm_ffa_helper.c b/lib/arm-ffa/arm_ffa_helper.c new file mode 100644 index 0000000000..67a3a4e9ab --- /dev/null +++ b/lib/arm-ffa/arm_ffa_helper.c @@ -0,0 +1,188 @@ +// SPDX-License-Identifier: GPL-2.0+ +/* + * (C) Copyright 2022 ARM Limited + * Abdellatif El Khlifi abdellatif.elkhlifi@arm.com + */ + +#include <common.h> +#include <arm_ffa_helper.h> +#include <uuid.h> + +/** + * ffa_helper_get_partitions_info - Wrapper function for FFA_PARTITION_INFO_GET + * + * @func_data: Pointer to the FF-A function arguments container + * structure. + * The passed arguments: + * Mode 1: When getting from the driver the number of + * secure partitions: + * @data0_size: UUID size + * @data0: pointer to the UUID (little endian) + * @data1_size: size of the number of partitions + * variable + * @data1: pointer to the number of partitions + * variable. The variable will be set + * by the driver + * Mode 2: When requesting the driver to return the + * partitions information: + * @data0_size: UUID size + * @data0: pointer to the UUID (little endian) + * @data1_size: size of the SPs information buffer + * @data1: pointer to SPs information buffer + * (allocated by the client). + * The buffer will be filled by the driver + * + * This is the boot time function used by clients who wants to get from secure + * world the partition(s) information. + * + * A client of the FF-A driver should know the UUID of the service it wants to + * access. It should use the UUID to request the FF-A driver to provide the + * partition(s) information of the service. The client should use + * ffa_helper_get_partitions_info to pass the UUID information to the driver + * which uses PARTITION_INFO_GET to obtain the partition(s) information. + * + * ffa_helper_get_partitions_info should be called twice. First call is to get + * from the driver the number of secure partitions (SPs) associated to a + * particular UUID. Then, the caller (client) allocates the buffer to host the + * SPs data and issues a 2nd call. Then, the driver fills the SPs data in the + * pre-allocated buffer. + * + * Return: + * + * FFA_ERR_STAT_SUCCESS on success. Otherwise, failure + */ +int ffa_helper_get_partitions_info(struct ffa_interface_data *func_data) +{ + return ffa_get_invoke_func(FFA_PARTITION_INFO_GET, func_data); +} + +/** + * ffa_helper_unmap_rxtx_buffers - Wrapper function for FFA_RXTX_UNMAP + * + * This is the boot time function that allows clients to unmap the RX/TX + * buffers + * + * Return: + * + * FFA_ERR_STAT_SUCCESS on success. Otherwise, failure + */ +int ffa_helper_unmap_rxtx_buffers(void) +{ + return ffa_get_invoke_func(FFA_RXTX_UNMAP, NULL); +} + +/** + * ffa_helper_msg_send_direct_req - Wrapper function for + * FFA_MSG_SEND_DIRECT_{REQ,RESP} + * @func_data: Pointer to the FF-A function arguments container structure. + * The passed arguments: + * @data0_size: partition ID size + * @data0: pointer to the partition ID + * @data1_size: exchanged data size + * @data1: pointer to the data buffer preallocated by the client (in/out) + * + * This is the runtime function that allows clients to send data to the secure + * world partitions. The arm_ffa driver uses FFA_MSG_SEND_DIRECT_REQ to send the + * data to the secure partition. The response from the secure partition is + * handled internally by the driver using FFA_MSG_SEND_DIRECT_RESP and returned + * to ffa_helper_msg_send_direct_req through @func_data + * + * The maximum size of the data that can be exchanged is 20 bytes which is + * sizeof(struct ffa_send_direct_data) as defined by the FF-A specification 1.0 + * in the section relevant to FFA_MSG_SEND_DIRECT_{REQ,RESP} + * + * The client should pre-allocate a buffer pointed by @data1 which the size + * is sizeof(struct ffa_send_direct_data) + * + * Return: + * + * FFA_ERR_STAT_SUCCESS on success. Otherwise, failure + */ +int __ffa_runtime ffa_helper_msg_send_direct_req(struct ffa_interface_data + *func_data) +{ + return ffa_get_invoke_func(FFA_MSG_SEND_DIRECT_REQ, func_data); +} + +/** + * ffa_helper_init_device - Wrapper function for probing the arm_ffa device + * + * This boot time function should be called to probe the arm_ffa device so + * it becomes ready for use. + * To achieve that, this function is called automatically at initcalls + * level (after u-boot relocation). + * + * Return: + * + * FFA_ERR_STAT_SUCCESS on success. Otherwise, failure + */ +int ffa_helper_init_device(void) +{ + return ffa_init_device(); +} + +/** + * ffa_uuid_str_to_bin - Converts a big endian UUID string to a little endian buffer + * @uuid_str: UUID string in big endian format (36 bytes wide + '/0') + * @uuid_bin: preallocated 16 bytes UUID buffer in little endian format + * + * UUID binary format used by the FF-A framework (16 bytes): + * + * [LSB] 4B-2B-2B-2B-6B (little endian data fields) + * + * UUID string is 36 length of characters (36 bytes): + * + * xxxxxxxx-xxxx-xxxx-xxxx-xxxxxxxxxxxx + * be be be be be + * + * where x is a hexadecimal character. Fields are separated by '-'s. + * When converting to a binary UUID, these endianness rules apply: + * be: means the field in the string is considered a big endian hex number + * and should be converted to little endian binary format + * + * Return: + * + * uuid_bin filled with little endian UUID data + * On success 0 is returned. Otherwise, failure code. + */ +int ffa_uuid_str_to_bin(const char *uuid_str, unsigned char *uuid_bin) +{ + u16 tmp16 = 0; + u32 tmp32 = 0; + u64 tmp64 = 0; + + if (!uuid_str_valid(uuid_str) || !uuid_bin) + return -EINVAL; + + /* + * reverse bytes from big to little endian + */ + tmp32 = simple_strtoul(uuid_str, NULL, 16); + memcpy(uuid_bin, &tmp32, 4); + + /* + * reverse bytes from big to little endian + */ + tmp16 = simple_strtoul(uuid_str + 9, NULL, 16); + memcpy(uuid_bin + 4, &tmp16, 2); + + /* + * reverse bytes from big to little endian + */ + tmp16 = simple_strtoul(uuid_str + 14, NULL, 16); + memcpy(uuid_bin + 6, &tmp16, 2); + + /* + * reverse bytes from big to little endian + */ + tmp16 = simple_strtoul(uuid_str + 19, NULL, 16); + memcpy(uuid_bin + 8, &tmp16, 2); + + /* + * reverse bytes from big to little endian + */ + tmp64 = simple_strtoull(uuid_str + 24, NULL, 16); + memcpy(uuid_bin + 10, (char *)&tmp64, 6); + + return 0; +} diff --git a/lib/efi_loader/efi_boottime.c b/lib/efi_loader/efi_boottime.c index 5bcb8253ed..cffa2c69d6 100644 --- a/lib/efi_loader/efi_boottime.c +++ b/lib/efi_loader/efi_boottime.c @@ -23,6 +23,10 @@ #include <asm/setjmp.h> #include <linux/libfdt_env.h>
+#if defined(CONFIG_ARM_FFA_TRANSPORT) +#include <arm_ffa_helper.h> +#endif + DECLARE_GLOBAL_DATA_PTR;
/* Task priority level */ @@ -2114,6 +2118,10 @@ static efi_status_t EFIAPI efi_exit_boot_services(efi_handle_t image_handle, struct efi_event *evt, *next_event; efi_status_t ret = EFI_SUCCESS;
+#if defined(CONFIG_ARM_FFA_TRANSPORT) + int ffa_ret; +#endif + EFI_ENTRY("%p, %zx", image_handle, map_key);
/* Check that the caller has read the current memory map */ @@ -2174,6 +2182,15 @@ static efi_status_t EFIAPI efi_exit_boot_services(efi_handle_t image_handle, dm_remove_devices_flags(DM_REMOVE_ACTIVE_ALL); }
+#if defined(CONFIG_ARM_FFA_TRANSPORT) + /* unmap FF-A RX/TX buffers */ + ffa_ret = ffa_helper_unmap_rxtx_buffers(); + if (ffa_ret) + debug("[efi_boottime][ERROR]: can not unmap FF-A RX/TX buffers\n"); + else + debug("[efi_boottime][INFO]: FF-A RX/TX buffers unmapped\n"); +#endif + /* Patch out unsupported runtime function */ efi_runtime_detach();
From: Abdellatif El Khlifi abdellatif.elkhlifi@arm.com
Provide armffa command showcasing the use of the FF-A driver
The armffa command allows to query secure partitions data from the secure world and exchanging messages with the partitions.
Signed-off-by: Abdellatif El Khlifi abdellatif.elkhlifi@arm.com Cc: Tom Rini trini@konsulko.com --- MAINTAINERS | 1 + cmd/Kconfig | 10 ++ cmd/Makefile | 2 + cmd/armffa.c | 266 ++++++++++++++++++++++++++++++++++++++++ drivers/arm-ffa/Kconfig | 1 + 5 files changed, 280 insertions(+) create mode 100644 cmd/armffa.c
diff --git a/MAINTAINERS b/MAINTAINERS index c5b608eb60..50ccd6a7ba 100644 --- a/MAINTAINERS +++ b/MAINTAINERS @@ -235,6 +235,7 @@ F: include/configs/turris_*.h ARM FF-A M: Abdellatif El Khlifi abdellatif.elkhlifi@arm.com S: Maintained +F: cmd/armffa.c F: drivers/arm-ffa/ F: include/arm_ffa.h F: include/arm_ffa_helper.h diff --git a/cmd/Kconfig b/cmd/Kconfig index 79219bcb74..de5bea1404 100644 --- a/cmd/Kconfig +++ b/cmd/Kconfig @@ -813,6 +813,16 @@ endmenu
menu "Device access commands"
+config CMD_ARMFFA + bool "Arm FF-A test command" + depends on ARM_FFA_TRANSPORT + help + Provides a test command for the Arm FF-A driver + supported options: + - Listing the partition(s) info + - Sending a data pattern to the specified partition + - Displaying the arm_ffa device info + config CMD_ARMFLASH #depends on FLASH_CFI_DRIVER bool "armflash" diff --git a/cmd/Makefile b/cmd/Makefile index ede634d731..2905ce63cf 100644 --- a/cmd/Makefile +++ b/cmd/Makefile @@ -12,6 +12,8 @@ obj-y += panic.o obj-y += version.o
# command + +obj-$(CONFIG_CMD_ARMFFA) += armffa.o obj-$(CONFIG_CMD_ACPI) += acpi.o obj-$(CONFIG_CMD_ADDRMAP) += addrmap.o obj-$(CONFIG_CMD_AES) += aes.o diff --git a/cmd/armffa.c b/cmd/armffa.c new file mode 100644 index 0000000000..fcfc3a06bd --- /dev/null +++ b/cmd/armffa.c @@ -0,0 +1,266 @@ +// SPDX-License-Identifier: GPL-2.0+ +/* + * (C) Copyright 2022 ARM Limited + * Abdellatif El Khlifi abdellatif.elkhlifi@arm.com + */ + +#include <arm_ffa_helper.h> +#include <asm/io.h> +#include <common.h> +#include <command.h> +#include <dm.h> +#include <mapmem.h> +#include <stdlib.h> + +/** + * do_ffa_get_singular_partition_info - implementation of the getpart subcommand + * @cmdtp: Command Table + * @flag: flags + * @argc: number of arguments + * @argv: arguments + * + * This function queries the secure partition information which the UUID is provided + * as an argument. The function uses the arm_ffa driver helper function + * to retrieve the data. + * The input UUID string is expected to be in big endian format. + * + * Return: + * + * CMD_RET_SUCCESS: on success, otherwise failure + */ +static int do_ffa_get_singular_partition_info(struct cmd_tbl *cmdtp, int flag, int argc, + char *const argv[]) +{ + struct ffa_interface_data func_data = {0}; + u32 count = 0; + int ret; + union ffa_partition_uuid service_uuid = {0}; + struct ffa_partition_info *parts_info; + u32 info_idx; + + if (argc != 1) + return -EINVAL; + + if (ffa_uuid_str_to_bin(argv[0], (unsigned char *)&service_uuid)) { + ffa_err("Invalid UUID"); + return -EINVAL; + } + + /* + * get from the driver the count of the SPs matching the UUID + */ + func_data.data0_size = sizeof(service_uuid); + func_data.data0 = &service_uuid; + func_data.data1_size = sizeof(count); + func_data.data1 = &count; + + ret = ffa_helper_get_partitions_info(&func_data); + if (ret != FFA_ERR_STAT_SUCCESS) { + ffa_err("Failure in querying partitions count (error code: %d)", ret); + return ret; + } + + if (!count) { + ffa_info("No secure partition found"); + return ret; + } + + /* + * pre-allocate a buffer to be filled by the driver + * with ffa_partition_info structs + */ + + parts_info = calloc(count, sizeof(struct ffa_partition_info)); + if (!parts_info) + return -EINVAL; + + ffa_info("Pre-allocating %d partition(s) info structures", count); + + func_data.data1_size = count * sizeof(struct ffa_partition_info); + func_data.data1 = parts_info; + + /* + * ask the driver to fill the buffer with the SPs info + */ + ret = ffa_helper_get_partitions_info(&func_data); + if (ret != FFA_ERR_STAT_SUCCESS) { + ffa_err("Failure in querying partition(s) info (error code: %d)", ret); + free(parts_info); + return ret; + } + + /* + * SPs found , show the partition information + */ + for (info_idx = 0; info_idx < count ; info_idx++) { + ffa_info("Partition: id = 0x%x , exec_ctxt 0x%x , properties 0x%x", + parts_info[info_idx].id, + parts_info[info_idx].exec_ctxt, + parts_info[info_idx].properties); + } + + free(parts_info); + + return 0; +} + +/** + * do_ffa_msg_send_direct_req - implementation of the ping subcommand + * @cmdtp: Command Table + * @flag: flags + * @argc: number of arguments + * @argv: arguments + * + * This function sends data to the secure partition which the ID is provided + * as an argument. The function uses the arm_ffa driver helper function + * to send data. + * + * Return: + * + * CMD_RET_SUCCESS: on success, otherwise failure + */ +int do_ffa_msg_send_direct_req(struct cmd_tbl *cmdtp, int flag, int argc, + char *const argv[]) +{ + struct ffa_interface_data func_data = {0}; + struct ffa_send_direct_data msg = {0}; + u32 pattern = 0xaabbccd0; + u16 part_id; + int ret; + + if (argc != 1) + return -EINVAL; + + errno = 0; + part_id = strtoul(argv[0], NULL, 16); + + if (errno) { + ffa_err("Invalid partition ID"); + return -EINVAL; + } + + /* + * telling the driver which partition to use + */ + func_data.data0_size = sizeof(part_id); + func_data.data0 = &part_id; + + /* + * filling the message data + */ + msg.a3 = ++pattern; + msg.a4 = ++pattern; + msg.a5 = ++pattern; + msg.a6 = ++pattern; + msg.a7 = ++pattern; + func_data.data1_size = sizeof(msg); + func_data.data1 = &msg; + + ret = ffa_helper_msg_send_direct_req(&func_data); + if (ret == FFA_ERR_STAT_SUCCESS) { + u8 cnt; + + ffa_info("SP response:\n[LSB]"); + for (cnt = 0; + cnt < sizeof(struct ffa_send_direct_data) / sizeof(u32); + cnt++) + ffa_info("0x%x", ((u32 *)&msg)[cnt]); + } else { + ffa_err("Sending direct request error (%d)", ret); + } + + return ret; +} + +/** + *do_ffa_dev_list - implementation of the devlist subcommand + * @cmdtp: [in] Command Table + * @flag: flags + * @argc: number of arguments + * @argv: arguments + * + * This function queries the devices belonging to the UCLASS_FFA + * class. Currently, one device is expected to show up: the arm_ffa device + * + * Return: + * + * CMD_RET_SUCCESS: on success, otherwise failure + */ +int do_ffa_dev_list(struct cmd_tbl *cmdtp, int flag, int argc, char *const argv[]) +{ + struct udevice *dev = NULL; + int i, ret; + + ffa_info("arm_ffa uclass entries:"); + + for (i = 0, ret = uclass_first_device(UCLASS_FFA, &dev); + dev; + ret = uclass_next_device(&dev), i++) { + if (ret) + break; + + ffa_info("entry %d - instance %08x, ops %08x, plat %08x", + i, + (u32)map_to_sysmem(dev), + (u32)map_to_sysmem(dev->driver->ops), + (u32)map_to_sysmem(dev_get_plat(dev))); + } + + return cmd_process_error(cmdtp, ret); +} + +static struct cmd_tbl armffa_commands[] = { + U_BOOT_CMD_MKENT(getpart, 1, 1, do_ffa_get_singular_partition_info, "", ""), + U_BOOT_CMD_MKENT(ping, 1, 1, do_ffa_msg_send_direct_req, "", ""), + U_BOOT_CMD_MKENT(devlist, 0, 1, do_ffa_dev_list, "", ""), +}; + +/** + * do_armffa - the armffa command main function + * @cmdtp: Command Table + * @flag: flags + * @argc: number of arguments + * @argv: arguments + * + * This function identifies which armffa subcommand to run. + * Then, it makes sure the arm_ffa device is probed and + * ready for use. + * Then, it runs the subcommand. + * + * Return: + * + * CMD_RET_SUCCESS: on success, otherwise failure + */ +static int do_armffa(struct cmd_tbl *cmdtp, int flag, int argc, char *const argv[]) +{ + struct cmd_tbl *armffa_cmd; + int ret; + + if (argc < 2) + return CMD_RET_USAGE; + + armffa_cmd = find_cmd_tbl(argv[1], armffa_commands, ARRAY_SIZE(armffa_commands)); + + argc -= 2; + argv += 2; + + if (!armffa_cmd || argc > armffa_cmd->maxargs) + return CMD_RET_USAGE; + + ret = ffa_helper_init_device(); + if (ret != FFA_ERR_STAT_SUCCESS) + return cmd_process_error(cmdtp, ret); + + ret = armffa_cmd->cmd(armffa_cmd, flag, argc, argv); + + return cmd_process_error(armffa_cmd, ret); +} + +U_BOOT_CMD(armffa, 4, 1, do_armffa, + "Arm FF-A operations test command", + "getpart <partition UUID>\n" + " - lists the partition(s) info\n" + "ping <partition ID>\n" + " - sends a data pattern to the specified partition\n" + "devlist\n" + " - displays the arm_ffa device info\n"); diff --git a/drivers/arm-ffa/Kconfig b/drivers/arm-ffa/Kconfig index e503dfaebf..7b7cfe26b1 100644 --- a/drivers/arm-ffa/Kconfig +++ b/drivers/arm-ffa/Kconfig @@ -4,6 +4,7 @@ config ARM_FFA_TRANSPORT bool "Enable Arm Firmware Framework for Armv8-A driver" depends on DM && ARM64 select ARM_SMCCC if ARM64 + select CMD_ARMFFA select LIB_UUID select ARM_FFA_TRANSPORT_HELPERS help
We want to have all commands to be documented in /doc/usage/cmd/.
Could you, please, provide the missing /doc/usage/cmd/armffa.rst file.
Best regards
Heinrich
+config CMD_ARMFFA
- bool "Arm FF-A test command"
- depends on ARM_FFA_TRANSPORT
- help
supported options:
- config CMD_ARMFLASH #depends on FLASH_CFI_DRIVER bool "armflash"
# command
- (C) Copyright 2022 ARM Limited
- Abdellatif El Khlifi abdellatif.elkhlifi@arm.com
- do_ffa_get_singular_partition_info - implementation of the getpart subcommand
- @cmdtp: Command Table
- @flag: flags
- @argc: number of arguments
- @argv: arguments
- This function queries the secure partition information which the UUID is provided
- as an argument. The function uses the arm_ffa driver helper function
- to retrieve the data.
- The input UUID string is expected to be in big endian format.
- Return:
- CMD_RET_SUCCESS: on success, otherwise failure
char *const argv[])
- struct ffa_interface_data func_data = {0};
- u32 count = 0;
- int ret;
- union ffa_partition_uuid service_uuid = {0};
- struct ffa_partition_info *parts_info;
- u32 info_idx;
- if (argc != 1)
return -EINVAL;
- if (ffa_uuid_str_to_bin(argv[0], (unsigned char *)&service_uuid)) {
return -EINVAL;
- func_data.data0_size = sizeof(service_uuid);
- func_data.data0 = &service_uuid;
- func_data.data1_size = sizeof(count);
- func_data.data1 = &count;
- ret = ffa_helper_get_partitions_info(&func_data);
- if (ret != FFA_ERR_STAT_SUCCESS) {
return ret;
- if (!count) {
return ret;
- parts_info = calloc(count, sizeof(struct ffa_partition_info));
- if (!parts_info)
return -EINVAL;
- ffa_info("Pre-allocating %d partition(s) info structures", count);
- func_data.data1_size = count * sizeof(struct ffa_partition_info);
- func_data.data1 = parts_info;
free(parts_info);
return ret;
- for (info_idx = 0; info_idx < count ; info_idx++) {
- free(parts_info);
- do_ffa_msg_send_direct_req - implementation of the ping subcommand
- @flag: flags
- @argv: arguments
- This function sends data to the secure partition which the ID is provided
- to send data.
- Return:
char *const argv[])
- struct ffa_send_direct_data msg = {0};
- u32 pattern = 0xaabbccd0;
- u16 part_id;
- int ret;
- if (argc != 1)
return -EINVAL;
- errno = 0;
- part_id = strtoul(argv[0], NULL, 16);
- if (errno) {
return -EINVAL;
- func_data.data0_size = sizeof(part_id);
- func_data.data0 = &part_id;
- msg.a3 = ++pattern;
- msg.a4 = ++pattern;
- msg.a5 = ++pattern;
- msg.a6 = ++pattern;
- msg.a7 = ++pattern;
- func_data.data1_size = sizeof(msg);
- func_data.data1 = &msg;
- ret = ffa_helper_msg_send_direct_req(&func_data);
- if (ret == FFA_ERR_STAT_SUCCESS) {
u8 cnt;
for (cnt = 0;
cnt++)
- } else {
- return ret;
- *do_ffa_dev_list - implementation of the devlist subcommand
- @cmdtp: [in] Command Table
- @flag: flags
- @argv: arguments
- This function queries the devices belonging to the UCLASS_FFA
- class. Currently, one device is expected to show up: the arm_ffa device
- Return:
- struct udevice *dev = NULL;
- int i, ret;
- ffa_info("arm_ffa uclass entries:");
- for (i = 0, ret = uclass_first_device(UCLASS_FFA, &dev);
dev;
if (ret)
break;
i,
- return cmd_process_error(cmdtp, ret);
- U_BOOT_CMD_MKENT(getpart, 1, 1, do_ffa_get_singular_partition_info, "", ""),
- U_BOOT_CMD_MKENT(ping, 1, 1, do_ffa_msg_send_direct_req, "", ""),
- U_BOOT_CMD_MKENT(devlist, 0, 1, do_ffa_dev_list, "", ""),
- do_armffa - the armffa command main function
- @flag: flags
- @argv: arguments
- This function identifies which armffa subcommand to run.
- Then, it makes sure the arm_ffa device is probed and
- ready for use.
- Then, it runs the subcommand.
- Return:
- struct cmd_tbl *armffa_cmd;
- int ret;
- if (argc < 2)
- armffa_cmd = find_cmd_tbl(argv[1], armffa_commands, ARRAY_SIZE(armffa_commands));
- argc -= 2;
- argv += 2;
- if (!armffa_cmd || argc > armffa_cmd->maxargs)
- ret = ffa_helper_init_device();
- ret = armffa_cmd->cmd(armffa_cmd, flag, argc, argv);
- return cmd_process_error(armffa_cmd, ret);
"devlist\n"
- select CMD_ARMFFA select LIB_UUID select ARM_FFA_TRANSPORT_HELPERS help
Hi Heinrich,
It's here [1].
[1]: https://lore.kernel.org/all/20230726094503.100497-6-abdellatif.elkhlifi@arm....
Cheers, Abdellatif
Hi Abdellatif,
On Thu, 27 Jul 2023 at 03:00, Abdellatif El Khlifi abdellatif.elkhlifi@arm.com wrote:
Hi Heinrich,
It's here [1].
I'd suggest mentioning that in the commit message for this patch, or even putting the testin the same patch, along with the test for the command. I find it hard to keep track of this too.
Cheers, Abdellatif
Hi Simon, Heinrich,
On Thu, Jul 27, 2023 at 07:52:00PM -0600, Simon Glass wrote:
Hi Abdellatif,
Hi Heinrich,
It's here [1].
Please refer to the commit provided by the latest version (v17).
In the commit message the path to doc/usage/cmd/armffa.rst is already given.
Please refer to the commit [A].
The commit log says: For more details please refer to the command documentation [1].
[A]: https://lore.kernel.org/all/20230727160712.81477-6-abdellatif.elkhlifi@arm.c...
Cheers Abdellatif
Cheers, Abdellatif
Provide a Sandbox driver to emulate the FF-A ABIs
The emulated ABIs are those supported by the FF-A core driver and according to FF-A specification v1.0.
The Sandbox driver provides operations allowing the test application to read the status of all the inspected ABIs and perform functional tests based on that.
Signed-off-by: Abdellatif El Khlifi abdellatif.elkhlifi@arm.com Cc: Tom Rini trini@konsulko.com --- MAINTAINERS | 2 + arch/sandbox/dts/sandbox.dtsi | 10 + arch/sandbox/dts/test.dts | 10 + common/board_r.c | 2 +- configs/sandbox64_defconfig | 2 + configs/sandbox_defconfig | 2 + doc/arch/sandbox.rst | 1 + drivers/arm-ffa/Kconfig | 8 +- drivers/arm-ffa/Makefile | 1 + drivers/arm-ffa/arm-ffa-uclass.c | 51 +- drivers/arm-ffa/core.c | 94 +++- drivers/arm-ffa/sandbox.c | 735 ++++++++++++++++++++++++++ drivers/arm-ffa/sandbox_arm_ffa_prv.h | 128 +++++ include/arm_ffa.h | 9 +- include/sandbox_arm_ffa.h | 31 ++ include/sandbox_arm_ffa_helper.h | 26 + lib/arm-ffa/Makefile | 1 + lib/arm-ffa/arm_ffa_helper.c | 6 +- lib/arm-ffa/sandbox_arm_ffa_helper.c | 23 + lib/efi_loader/efi_boottime.c | 4 +- 20 files changed, 1102 insertions(+), 44 deletions(-) create mode 100644 drivers/arm-ffa/sandbox.c create mode 100644 drivers/arm-ffa/sandbox_arm_ffa_prv.h create mode 100644 include/sandbox_arm_ffa.h create mode 100644 include/sandbox_arm_ffa_helper.h create mode 100644 lib/arm-ffa/sandbox_arm_ffa_helper.c
diff --git a/MAINTAINERS b/MAINTAINERS index 50ccd6a7ba..84524d7caf 100644 --- a/MAINTAINERS +++ b/MAINTAINERS @@ -239,6 +239,8 @@ F: cmd/armffa.c F: drivers/arm-ffa/ F: include/arm_ffa.h F: include/arm_ffa_helper.h +F: include/sandbox_arm_ffa.h +F: include/sandbox_arm_ffa_helper.h F: lib/arm-ffa/
ARM FREESCALE IMX diff --git a/arch/sandbox/dts/sandbox.dtsi b/arch/sandbox/dts/sandbox.dtsi index 66b813faad..523ffcc27d 100644 --- a/arch/sandbox/dts/sandbox.dtsi +++ b/arch/sandbox/dts/sandbox.dtsi @@ -416,6 +416,16 @@ sandbox_tee { compatible = "sandbox,tee"; }; + + arm_ffa { + compatible = "arm,ffa"; + method = "smc"; + }; + + sandbox_arm_ffa { + compatible = "sandbox,ffa"; + method = "smc"; + }; };
&cros_ec { diff --git a/arch/sandbox/dts/test.dts b/arch/sandbox/dts/test.dts index 3d206fdb3c..2c638af042 100644 --- a/arch/sandbox/dts/test.dts +++ b/arch/sandbox/dts/test.dts @@ -1598,6 +1598,16 @@ compatible = "sandbox,regmap_test"; }; }; + + arm_ffa { + compatible = "arm,ffa"; + method = "smc"; + }; + + sandbox_arm_ffa { + compatible = "sandbox,ffa"; + method = "smc"; + }; };
#include "sandbox_pmic.dtsi" diff --git a/common/board_r.c b/common/board_r.c index 7866ec3ad5..3b82f74bb0 100644 --- a/common/board_r.c +++ b/common/board_r.c @@ -775,7 +775,7 @@ static init_fnc_t init_sequence_r[] = { INIT_FUNC_WATCHDOG_RESET initr_net, #endif -#ifdef CONFIG_ARM_FFA_TRANSPORT +#if defined(CONFIG_ARM_FFA_TRANSPORT) && !defined(CONFIG_SANDBOX_FFA) ffa_helper_init_device, #endif #ifdef CONFIG_POST diff --git a/configs/sandbox64_defconfig b/configs/sandbox64_defconfig index 40d1422a37..301c6f320f 100644 --- a/configs/sandbox64_defconfig +++ b/configs/sandbox64_defconfig @@ -252,3 +252,5 @@ CONFIG_TEST_FDTDEC=y CONFIG_UNIT_TEST=y CONFIG_UT_TIME=y CONFIG_UT_DM=y +CONFIG_ARM_FFA_TRANSPORT=y +CONFIG_SANDBOX_FFA=y \ No newline at end of file diff --git a/configs/sandbox_defconfig b/configs/sandbox_defconfig index 0f43101ab5..a2f273056f 100644 --- a/configs/sandbox_defconfig +++ b/configs/sandbox_defconfig @@ -324,3 +324,5 @@ CONFIG_TEST_FDTDEC=y CONFIG_UNIT_TEST=y CONFIG_UT_TIME=y CONFIG_UT_DM=y +CONFIG_ARM_FFA_TRANSPORT=y +CONFIG_SANDBOX_FFA=y \ No newline at end of file diff --git a/doc/arch/sandbox.rst b/doc/arch/sandbox.rst index f8804e1f41..7cb5ea307c 100644 --- a/doc/arch/sandbox.rst +++ b/doc/arch/sandbox.rst @@ -203,6 +203,7 @@ Supported Drivers
U-Boot sandbox supports these emulations:
+- Arm FF-A - Block devices - Chrome OS EC - GPIO diff --git a/drivers/arm-ffa/Kconfig b/drivers/arm-ffa/Kconfig index 7b7cfe26b1..61103daa42 100644 --- a/drivers/arm-ffa/Kconfig +++ b/drivers/arm-ffa/Kconfig @@ -2,7 +2,7 @@
config ARM_FFA_TRANSPORT bool "Enable Arm Firmware Framework for Armv8-A driver" - depends on DM && ARM64 + depends on DM && (ARM64 || SANDBOX) select ARM_SMCCC if ARM64 select CMD_ARMFFA select LIB_UUID @@ -24,3 +24,9 @@ config ARM_FFA_TRANSPORT entity to communicate with. FF-A communication is handled by one device and one instance. This device takes care of all the interactions between Normal world and Secure World. + +config SANDBOX_FFA + bool "FF-A Sandbox driver" + depends on ARM_FFA_TRANSPORT && SANDBOX + help + This emulates the FF-A handling under Sandbox and allows to test the FF-A driver diff --git a/drivers/arm-ffa/Makefile b/drivers/arm-ffa/Makefile index 7bc9a336a9..df1cfe6ef0 100644 --- a/drivers/arm-ffa/Makefile +++ b/drivers/arm-ffa/Makefile @@ -4,3 +4,4 @@ #
obj-y += arm-ffa-uclass.o core.o +obj-$(CONFIG_SANDBOX_FFA) += sandbox.o diff --git a/drivers/arm-ffa/arm-ffa-uclass.c b/drivers/arm-ffa/arm-ffa-uclass.c index 0bf661d397..a5945afb9d 100644 --- a/drivers/arm-ffa/arm-ffa-uclass.c +++ b/drivers/arm-ffa/arm-ffa-uclass.c @@ -11,6 +11,10 @@ #include <log.h> #include <asm/global_data.h>
+#if CONFIG_IS_ENABLED(SANDBOX_FFA) +#include <sandbox_arm_ffa.h> +#endif + DECLARE_GLOBAL_DATA_PTR;
UCLASS_DRIVER(ffa) = { @@ -42,18 +46,42 @@ int __ffa_runtime ffa_get_invoke_func(u32 func_id, struct ffa_interface_data *fu return ffa_device_get_ops()->invoke_func(func_id, func_data); }
+#if CONFIG_IS_ENABLED(SANDBOX_FFA) + /** - * ffa_init_device - probes the arm_ffa device + * sandbox_ffa_get_invoke_func - performs a call to the Sandbox FF-A driver dispatcher + * @func_id: The FF-A function to be queried + * @func_data: Pointer to the query arguments + * container structure. + * + * This function passes the FF-A function ID to be queried during sandbox test cases + * and its arguments to the Sandbox FF-A driver dispatcher. + * This function is called by the Sandbox FF-A helper function. + * + * Return: * - * This boot time function makes sure the arm_ffa device is probed + * FFA_ERR_STAT_SUCCESS on success. Otherwise, failure + */ +int sandbox_ffa_get_invoke_func(u32 func_id, struct ffa_interface_data *func_data) +{ + if (!sandbox_ffa_device_get_ops()->invoke_func) + return -EINVAL; + + return sandbox_ffa_device_get_ops()->invoke_func(func_id, func_data); +} +#endif + +/** + * ffa_init_device - probes the arm_ffa and sandbox_arm_ffa devices + * + * This boot time function makes sure the arm_ffa and sandbox_arm_ffa devices are probed * and ready for use. * This function is called automatically at initcalls * level (after u-boot relocation). * - * Arm FF-A transport is implemented through a single u-boot - * device (arm_ffa). So, there is only one device belonging to UCLASS_FFA. - * All FF-A clients should use the arm_ffa device to use the FF-A - * transport. + * Arm FF-A transport is implemented through arm_ffa u-boot device managing the FF-A + * communication. In Sandbox mode sandbox_arm_ffa is used to test arm_ffa driver. + * All FF-A clients should use the arm_ffa device to use the FF-A transport. * * Return: * @@ -61,5 +89,14 @@ int __ffa_runtime ffa_get_invoke_func(u32 func_id, struct ffa_interface_data *fu */ int ffa_init_device(void) { - return ffa_get_device(); + int ret; + + ret = ffa_get_device(); + +#if CONFIG_IS_ENABLED(SANDBOX_FFA) + if (ret == FFA_ERR_STAT_SUCCESS) + ret = sandbox_ffa_get_device(); +#endif + + return ret; } diff --git a/drivers/arm-ffa/core.c b/drivers/arm-ffa/core.c index 9d0dab1d36..a4d9c08482 100644 --- a/drivers/arm-ffa/core.c +++ b/drivers/arm-ffa/core.c @@ -5,6 +5,11 @@ */
#include "arm_ffa_prv.h" + +#if CONFIG_IS_ENABLED(SANDBOX_FFA) +#include "sandbox_arm_ffa_prv.h" +#endif + #include <asm/global_data.h> #include <asm/io.h> #include <common.h> @@ -82,8 +87,10 @@ static int ffa_get_version(void)
FFA_DECLARE_ARGS;
- if (!ffa_priv_data.invoke_ffa_fn) - panic("[FFA] no private data found\n"); + if (!ffa_priv_data.invoke_ffa_fn) { + ffa_panic("no private data found\n"); + return -ENODEV; + }
a0 = FFA_VERSION; a1 = FFA_VERSION_1_0; @@ -126,8 +133,10 @@ static int ffa_get_endpoint_id(void) { FFA_DECLARE_ARGS;
a0 = FFA_ID_GET;
@@ -200,8 +209,10 @@ static int ffa_get_rxtx_map_features(void) { FFA_DECLARE_ARGS;
a0 = FFA_FEATURES; a1 = FFA_RXTX_MAP; @@ -427,8 +438,10 @@ static int ffa_map_rxtx_buffers(size_t buf_4k_pages)
FFA_DECLARE_ARGS;
ret = ffa_alloc_rxtx_buffers(buf_4k_pages); if (ret != FFA_ERR_STAT_SUCCESS) @@ -496,8 +509,10 @@ static int ffa_unmap_rxtx_buffers(void) { FFA_DECLARE_ARGS;
a0 = FFA_RXTX_UNMAP; a1 = PREP_SELF_ENDPOINT_ID(ffa_priv_data.id); @@ -508,11 +523,12 @@ static int ffa_unmap_rxtx_buffers(void) case FFA_ERROR: { if (((int)res.a2) == FFA_ERR_STAT_NOT_SUPPORTED) - panic("[FFA] FFA_RXTX_UNMAP is not implemented at this FF-A instance\n"); + ffa_panic("FFA_RXTX_UNMAP is not implemented at this FF-A instance\n"); else if (((int)res.a2) == FFA_ERR_STAT_INVALID_PARAMETERS) - panic("[FFA] There is no buffer pair registered on behalf of the caller\n"); + ffa_panic("There is no buffer pair registered on behalf of the caller\n"); else - panic("[FFA] Undefined error (%d)\n", ((int)res.a2)); + ffa_panic("Undefined error (%d)\n", ((int)res.a2)); + return -ENODEV; } case FFA_SUCCESS: { @@ -520,19 +536,24 @@ static int ffa_unmap_rxtx_buffers(void) int ret;
ret = ffa_get_rxtx_buffers_pages_cnt(&buf_4k_pages); - if (ret != FFA_ERR_STAT_SUCCESS) - panic("[FFA] RX/TX buffers unmapped but failure in getting pages count\n"); + if (ret != FFA_ERR_STAT_SUCCESS) { + ffa_panic("RX/TX buffers unmapped but failure in getting pages count\n"); + return -ENODEV; + }
ret = ffa_free_rxtx_buffers(buf_4k_pages); - if (ret != FFA_ERR_STAT_SUCCESS) - panic("[FFA] RX/TX buffers unmapped but failure in freeing the memory\n"); + if (ret != FFA_ERR_STAT_SUCCESS) { + ffa_panic("RX/TX buffers unmapped but failure in freeing the memory\n"); + return -ENODEV; + }
ffa_info("RX/TX buffers unmapped and memory freed");
return FFA_ERR_STAT_SUCCESS; } default: - panic("[FFA] Undefined response function (0x%lx)", res.a0); + ffa_panic("Undefined response function (0x%lx)", res.a0); + return -ENODEV; } }
@@ -550,8 +571,10 @@ static int ffa_release_rx_buffer(void) { FFA_DECLARE_ARGS;
a0 = FFA_RX_RELEASE;
@@ -561,17 +584,19 @@ static int ffa_release_rx_buffer(void) case FFA_ERROR: { if (((int)res.a2) == FFA_ERR_STAT_NOT_SUPPORTED) - panic("[FFA] FFA_RX_RELEASE is not implemented at this FF-A instance\n"); + ffa_panic("FFA_RX_RELEASE is not implemented at this FF-A instance\n"); else if (((int)res.a2) == FFA_ERR_STAT_DENIED) - panic("[FFA] Caller did not have ownership of the RX buffer\n"); + ffa_panic("Caller did not have ownership of the RX buffer\n"); else - panic("[FFA] Undefined error (%d)\n", ((int)res.a2)); + ffa_panic("Undefined error (%d)\n", ((int)res.a2)); + return -ENODEV; } case FFA_SUCCESS: return FFA_ERR_STAT_SUCCESS;
default: - panic("[FFA] Undefined response function (0x%lx)\n", res.a0); + ffa_panic("Undefined response function (0x%lx)\n", res.a0); + return -ENODEV; } }
@@ -763,8 +788,10 @@ static int ffa_query_partitions_info(union ffa_partition_uuid *part_uuid, unsigned long a7 = 0; struct arm_smccc_res res = {0};
a0 = FFA_PARTITION_INFO_GET;
@@ -840,7 +867,7 @@ static int ffa_query_partitions_info(union ffa_partition_uuid *part_uuid, ret = ffa_release_rx_buffer();
if (!part_uuid && !res.a2) { - ffa_err("[FFA] no partition installed in the system"); + ffa_err("no partition installed in the system"); return -ENODEV; }
@@ -931,8 +958,10 @@ static int ffa_get_partitions_info(struct ffa_interface_data *func_data) return -EINVAL; }
- if (!ffa_priv_data.partitions.count || !ffa_priv_data.partitions.descs) - panic("[FFA] No partition installed\n"); + if (!ffa_priv_data.partitions.count || !ffa_priv_data.partitions.descs) { + ffa_panic("No partition installed\n"); + return -ENODEV; + }
if (func_data->data0_size == sizeof(union ffa_partition_uuid) && func_data->data0 && @@ -1170,6 +1199,7 @@ static int __ffa_runtime ffa_msg_send_direct_req(struct ffa_interface_data /* Undefined error */ return -ENXIO; } + return -ENODEV; } case FFA_SUCCESS:
@@ -1247,7 +1277,13 @@ static int ffa_init_private_data(struct udevice *dev) ffa_priv_data.conduit = pdata->conduit;
if (ffa_priv_data.conduit == FFA_CONDUIT_SMC) { +#if CONFIG_IS_ENABLED(SANDBOX_FFA) + ffa_priv_data.invoke_ffa_fn = sandbox_arm_ffa_smccc_smc; + ffa_info("Using SMC emulation"); +#else ffa_priv_data.invoke_ffa_fn = arm_ffa_smccc_smc; +#endif + } else { ffa_err("Undefined FF-A conduit (%d)", ffa_priv_data.conduit); return -EINVAL; diff --git a/drivers/arm-ffa/sandbox.c b/drivers/arm-ffa/sandbox.c new file mode 100644 index 0000000000..fcabd4b59b --- /dev/null +++ b/drivers/arm-ffa/sandbox.c @@ -0,0 +1,735 @@ +// SPDX-License-Identifier: GPL-2.0+ +/* + * (C) Copyright 2022 ARM Limited + * Abdellatif El Khlifi abdellatif.elkhlifi@arm.com + */ + +#include "sandbox_arm_ffa_prv.h" +#include <asm/global_data.h> +#include <common.h> +#include <dm.h> +#include <linux/errno.h> +#include <linux/sizes.h> +#include <mapmem.h> +#include <string.h> + +DECLARE_GLOBAL_DATA_PTR; + +/** + * The device private data structure containing all the emulated secure world data + */ +static struct sandbox_ffa_prvdata sandbox_ffa_priv_data = {0}; + +/* The partitions (SPs) table */ +static struct ffa_partition_desc sandbox_partitions[SANDBOX_PARTITIONS_CNT] = { + { + .info = { .id = 0x1245, .exec_ctxt = 0x5687, .properties = 0x89325621 }, + .UUID = { .bytes = {SANDBOX_SERVICE1_UUID_DATA}} + }, + { + .info = { .id = 0x9836, .exec_ctxt = 0x9587, .properties = 0x45325621 }, + .UUID = { .bytes = {SANDBOX_SERVICE2_UUID_DATA}} + }, + { + .info = { .id = 0x6452, .exec_ctxt = 0x7687, .properties = 0x23325621 }, + .UUID = { .bytes = {SANDBOX_SERVICE1_UUID_DATA}} + }, + { + .info = { .id = 0x7814, .exec_ctxt = 0x1487, .properties = 0x70325621 }, + .UUID = { .bytes = {SANDBOX_SERVICE2_UUID_DATA}} + } + +}; + +/* + * Driver functions + */ + +/** + * sandbox_ffa_get_device - probes the sandbox_arm_ffa device + * + * This function makes sure the sandbox_arm_ffa device is probed + * and ready for use. This is done using uclass_get_device. + * The arm_ffa driver belongs to UCLASS_FFA. + * This function should be called before using the driver. + * + * sandbox_arm_ffa depends on arm_ffa device. This dependency is + * handled by ffa_init_device function. arm_ffa is probed first then + * it probes sandbox_arm_ffa using sandbox_ffa_get_device. + * + * Return: + * + * FFA_ERR_STAT_SUCCESS on success. Otherwise, failure + */ +int sandbox_ffa_get_device(void) +{ + int ret; + int devnum = 1; + + if (sandbox_ffa_priv_data.dev) + return FFA_ERR_STAT_SUCCESS; + + /* + * searching and probing the device + */ + ret = uclass_get_device(UCLASS_FFA, devnum, &sandbox_ffa_priv_data.dev); + if (ret) { + ffa_err("[Sandbox] Can not find the FF-A Sandbox device"); + sandbox_ffa_priv_data.dev = NULL; + return -ENODEV; + } + + return FFA_ERR_STAT_SUCCESS; +} + +/** + * sandbox_ffa_version - Emulated FFA_VERSION handler function + * @{a0-a7} , res: The SMC call arguments and return structure. + * + * This is the function that emulates FFA_VERSION FF-A function. + * + * Return: + * + * FFA_ERR_STAT_SUCCESS on success. Otherwise, failure + */ +SANDBOX_SMC_FFA_ABI(ffa_version) +{ + sandbox_ffa_priv_data.fwk_version = FFA_VERSION_1_0; + res->a0 = sandbox_ffa_priv_data.fwk_version; + + /* w1-w7 MBZ */ + memset(FFA_W1W7_MBZ_REG_START, 0, FFA_W1W7_MBZ_CNT * sizeof(unsigned long)); + + return FFA_ERR_STAT_SUCCESS; +} + +/** + * sandbox_ffa_id_get - Emulated FFA_ID_GET handler function + * @{a0-a7} , res: The SMC call arguments and return structure. + * + * This is the function that emulates FFA_ID_GET FF-A function. + * + * Return: + * + * FFA_ERR_STAT_SUCCESS on success. Otherwise, failure + */ +SANDBOX_SMC_FFA_ABI(ffa_id_get) +{ + res->a0 = FFA_SUCCESS; + res->a1 = 0; + + sandbox_ffa_priv_data.id = NS_PHYS_ENDPOINT_ID; + res->a2 = sandbox_ffa_priv_data.id; + + /* w3-w7 MBZ */ + memset(FFA_W3_MBZ_REG_START, 0, FFA_W3W7_MBZ_CNT * sizeof(unsigned long)); + + return FFA_ERR_STAT_SUCCESS; +} + +/** + * sandbox_ffa_features - Emulated FFA_FEATURES handler function + * @{a0-a7} , res: The SMC call arguments and return structure. + * + * This is the function that emulates FFA_FEATURES FF-A function. + * + * Return: + * + * FFA_ERR_STAT_SUCCESS on success. Otherwise, failure + */ +SANDBOX_SMC_FFA_ABI(ffa_features) +{ + switch (a1) { + case FFA_RXTX_MAP: + { + res->a0 = FFA_SUCCESS; + res->a2 = RXTX_BUFFERS_MIN_SIZE; + res->a3 = 0; + /* w4-w7 MBZ */ + memset(FFA_W4W7_MBZ_REG_START, + 0, FFA_W4W7_MBZ_CNT * sizeof(unsigned long)); + break; + } + default: + { + res->a0 = FFA_ERROR; + res->a2 = FFA_ERR_STAT_NOT_SUPPORTED; + /* w3-w7 MBZ */ + memset(FFA_W3_MBZ_REG_START, + 0, FFA_W3W7_MBZ_CNT * sizeof(unsigned long)); + ffa_err("[Sandbox] FF-A interface 0x%lx not implemented", a1); + } + } + + res->a1 = 0; + + return FFA_ERR_STAT_SUCCESS; +} + +/** + * sandbox_ffa_partition_info_get - Emulated FFA_PARTITION_INFO_GET handler function + * @{a0-a7} , res: The SMC call arguments and return structure. + * + * This is the function that emulates FFA_PARTITION_INFO_GET FF-A function. + * + * Return: + * + * FFA_ERR_STAT_SUCCESS on success. Otherwise, failure + */ +SANDBOX_SMC_FFA_ABI(ffa_partition_info_get) +{ + struct ffa_partition_info *rxbuf_desc_info = NULL; + u32 descs_cnt; + u32 descs_size_bytes; + + res->a0 = FFA_ERROR; + + if (!sandbox_ffa_priv_data.pair.rxbuf) { + res->a2 = FFA_ERR_STAT_DENIED; + goto cleanup; + } + + if (sandbox_ffa_priv_data.pair_info.rxbuf_owned) { + res->a2 = FFA_ERR_STAT_BUSY; + goto cleanup; + } + + if (!sandbox_ffa_priv_data.partitions.descs) { + sandbox_ffa_priv_data.partitions.descs = sandbox_partitions; + sandbox_ffa_priv_data.partitions.count = SANDBOX_PARTITIONS_CNT; + } + + descs_size_bytes = SANDBOX_PARTITIONS_CNT * sizeof(struct ffa_partition_desc); + + /* Abort if the RX buffer size is smaller than the descriptors buffer size */ + if ((sandbox_ffa_priv_data.pair_info.rxtx_buf_size * SZ_4K) < descs_size_bytes) { + res->a2 = FFA_ERR_STAT_NO_MEMORY; + goto cleanup; + } + + rxbuf_desc_info = (struct ffa_partition_info *)sandbox_ffa_priv_data.pair.rxbuf; + + /* No UUID specified. Return the information of all partitions */ + if (!a1 && !a2 && !a3 && !a4) { + for (descs_cnt = 0 ; descs_cnt < SANDBOX_PARTITIONS_CNT ; descs_cnt++) + *(rxbuf_desc_info++) = + sandbox_ffa_priv_data.partitions.descs[descs_cnt].info; + + res->a0 = FFA_SUCCESS; + res->a2 = SANDBOX_PARTITIONS_CNT; + /* transfer ownership to the consumer: the non secure world */ + sandbox_ffa_priv_data.pair_info.rxbuf_owned = 1; + + goto cleanup; + } + + /* + * A UUID is specified. Return the information of all partitions matching + * the UUID + */ + + for (descs_cnt = 0 ; descs_cnt < SANDBOX_PARTITIONS_CNT ; descs_cnt++) + if (a1 == sandbox_ffa_priv_data.partitions.descs[descs_cnt].UUID.words.a1 && + a2 == sandbox_ffa_priv_data.partitions.descs[descs_cnt].UUID.words.a2 && + a3 == sandbox_ffa_priv_data.partitions.descs[descs_cnt].UUID.words.a3 && + a4 == sandbox_ffa_priv_data.partitions.descs[descs_cnt].UUID.words.a4) { + *(rxbuf_desc_info++) = + sandbox_ffa_priv_data.partitions.descs[descs_cnt].info; + } + + if (rxbuf_desc_info != ((struct ffa_partition_info *)sandbox_ffa_priv_data.pair.rxbuf)) { + res->a0 = FFA_SUCCESS; + /* store the partitions count */ + res->a2 = (unsigned long) + (rxbuf_desc_info - (struct ffa_partition_info *) + sandbox_ffa_priv_data.pair.rxbuf); + + /* transfer ownership to the consumer: the non secure world */ + sandbox_ffa_priv_data.pair_info.rxbuf_owned = 1; + } else { + res->a2 = FFA_ERR_STAT_INVALID_PARAMETERS; + } + +cleanup: + + ffa_err("[Sandbox] FFA_PARTITION_INFO_GET (%ld)", res->a2); + + res->a1 = 0; + + /* w3-w7 MBZ */ + memset(FFA_W3_MBZ_REG_START, 0, FFA_W3W7_MBZ_CNT * sizeof(unsigned long)); + + return FFA_ERR_STAT_SUCCESS; +} + +/** + * sandbox_ffa_rxtx_map - Emulated FFA_RXTX_MAP handler function + * @{a0-a7} , res: The SMC call arguments and return structure. + * + * This is the function that emulates FFA_RXTX_MAP FF-A function. + * + * Return: + * + * FFA_ERR_STAT_SUCCESS on success. Otherwise, failure + */ +SANDBOX_SMC_FFA_ABI(ffa_rxtx_map) +{ + res->a0 = FFA_ERROR; + + if (sandbox_ffa_priv_data.pair.txbuf && sandbox_ffa_priv_data.pair.rxbuf) { + res->a2 = FFA_ERR_STAT_DENIED; + goto feedback; + } + + if (a3 >= RXTX_BUFFERS_MIN_PAGES && a1 && a2) { + sandbox_ffa_priv_data.pair.txbuf = a1; + sandbox_ffa_priv_data.pair.rxbuf = a2; + sandbox_ffa_priv_data.pair_info.rxtx_buf_size = a3; + sandbox_ffa_priv_data.pair_info.rxbuf_mapped = 1; + res->a0 = FFA_SUCCESS; + res->a2 = 0; + goto feedback; + } + + if (!a1 || !a2) + res->a2 = FFA_ERR_STAT_INVALID_PARAMETERS; + else + res->a2 = FFA_ERR_STAT_NO_MEMORY; + + ffa_err("[Sandbox] error in FFA_RXTX_MAP arguments (%d)", (int)res->a2); + +feedback: + + res->a1 = 0; + + /* w3-w7 MBZ */ + memset(FFA_W3_MBZ_REG_START, + 0, FFA_W3W7_MBZ_CNT * sizeof(unsigned long)); + + return FFA_ERR_STAT_SUCCESS; +} + +/** + * sandbox_ffa_rxtx_unmap - Emulated FFA_RXTX_UNMAP handler function + * @{a0-a7} , res: The SMC call arguments and return structure. + * + * This is the function that emulates FFA_RXTX_UNMAP FF-A function. + * + * Return: + * + * FFA_ERR_STAT_SUCCESS on success. Otherwise, failure + */ +SANDBOX_SMC_FFA_ABI(ffa_rxtx_unmap) +{ + res->a0 = FFA_ERROR; + res->a2 = FFA_ERR_STAT_INVALID_PARAMETERS; + + if (GET_NS_PHYS_ENDPOINT_ID(a1) != sandbox_ffa_priv_data.id) + goto feedback; + + if (sandbox_ffa_priv_data.pair.txbuf && sandbox_ffa_priv_data.pair.rxbuf) { + sandbox_ffa_priv_data.pair.txbuf = 0; + sandbox_ffa_priv_data.pair.rxbuf = 0; + sandbox_ffa_priv_data.pair_info.rxtx_buf_size = 0; + sandbox_ffa_priv_data.pair_info.rxbuf_mapped = 0; + res->a0 = FFA_SUCCESS; + res->a2 = 0; + goto feedback; + } + + ffa_err("[Sandbox] No buffer pair registered on behalf of the caller"); + +feedback: + + res->a1 = 0; + + /* w3-w7 MBZ */ + memset(FFA_W3_MBZ_REG_START, + 0, FFA_W3W7_MBZ_CNT * sizeof(unsigned long)); + + return FFA_ERR_STAT_SUCCESS; +} + +/** + * sandbox_ffa_rx_release - Emulated FFA_RX_RELEASE handler function + * @{a0-a7} , res: The SMC call arguments and return structure. + * + * This is the function that emulates FFA_RX_RELEASE FF-A function. + * + * Return: + * + * FFA_ERR_STAT_SUCCESS on success. Otherwise, failure + */ +SANDBOX_SMC_FFA_ABI(ffa_rx_release) +{ + if (!sandbox_ffa_priv_data.pair_info.rxbuf_owned) { + res->a0 = FFA_ERROR; + res->a2 = FFA_ERR_STAT_DENIED; + } else { + sandbox_ffa_priv_data.pair_info.rxbuf_owned = 0; + res->a0 = FFA_SUCCESS; + res->a2 = 0; + } + + res->a1 = 0; + + /* w3-w7 MBZ */ + memset(FFA_W3_MBZ_REG_START, + 0, FFA_W3W7_MBZ_CNT * sizeof(unsigned long)); + + return FFA_ERR_STAT_SUCCESS; +} + +/** + * sandbox_ffa_sp_valid - Checks SP validity + * @part_id: partition ID to check + * + * This is the function searches the input ID in the descriptors table. + * + * Return: + * + * 1 on success (Partition found). Otherwise, failure + */ +int sandbox_ffa_sp_valid(u16 part_id) +{ + u32 descs_cnt; + + for (descs_cnt = 0 ; descs_cnt < SANDBOX_PARTITIONS_CNT ; descs_cnt++) + if (sandbox_ffa_priv_data.partitions.descs[descs_cnt].info.id == part_id) + return 1; + + return 0; +} + +/** + * sandbox_ffa_msg_send_direct_req - Emulated FFA_MSG_SEND_DIRECT_{REQ,RESP} handler function + * @{a0-a7} , res: The SMC call arguments and return structure. + * + * This is the function that emulates FFA_MSG_SEND_DIRECT_{REQ,RESP} + * FF-A functions. + * + * Emulating interrupts is not supported. So, FFA_RUN and FFA_INTERRUPT are not supported. + * + * Return: + * + * FFA_ERR_STAT_SUCCESS on success. Otherwise, failure + */ +SANDBOX_SMC_FFA_ABI(ffa_msg_send_direct_req) +{ + u16 part_id; + + part_id = GET_DST_SP_ID(a1); + + if ((GET_NS_PHYS_ENDPOINT_ID(a1) != sandbox_ffa_priv_data.id) || + !sandbox_ffa_sp_valid(part_id) || + a2) { + res->a0 = FFA_ERROR; + res->a1 = 0; + res->a2 = FFA_ERR_STAT_INVALID_PARAMETERS; + + /* w3-w7 MBZ */ + memset(FFA_W3_MBZ_REG_START, + 0, FFA_W3W7_MBZ_CNT * sizeof(unsigned long)); + + return FFA_ERR_STAT_SUCCESS; + } + + res->a0 = FFA_MSG_SEND_DIRECT_RESP; + + res->a1 = PREP_SRC_SP_ID(part_id) | + PREP_NS_PHYS_ENDPOINT_ID(sandbox_ffa_priv_data.id); + + res->a2 = 0; + + /* + * return 0xff bytes as a response + */ + res->a3 = 0xffffffff; + res->a4 = 0xffffffff; + res->a5 = 0xffffffff; + res->a6 = 0xffffffff; + res->a7 = 0xffffffff; + + return FFA_ERR_STAT_SUCCESS; +} + +/** + * sandbox_ffa_get_prv_data - Returns the pointer to FF-A core pivate data + * @func_data: Pointer to the FF-A function arguments container structure + * + * This is the handler that returns the address of the FF-A core pivate data. + * + * Return: + * + * FFA_ERR_STAT_SUCCESS on success. Otherwise, failure + */ +int sandbox_ffa_get_prv_data(struct ffa_interface_data *func_data) +{ + if (!func_data) + return -EINVAL; + + if (!func_data->data0 || func_data->data0_size != sizeof(struct ffa_prvdata **)) + return -EINVAL; + + if (!func_data->data1 || func_data->data1_size != sizeof(struct sandbox_ffa_prvdata **)) + return -EINVAL; + + *((struct ffa_prvdata **)func_data->data0) = &ffa_priv_data; + *((struct sandbox_ffa_prvdata **)func_data->data1) = &sandbox_ffa_priv_data; + + return FFA_ERR_STAT_SUCCESS; +} + +/** + * sandbox_ffa_get_rxbuf_flags - Reading the mapping/ownership flags + * @queried_func_id: The FF-A function to be queried + * @func_data: Pointer to the FF-A function arguments container structure + * + * This is the handler that queries the status flags of the following emulated ABIs: + * FFA_RXTX_MAP, FFA_RXTX_UNMAP, FFA_RX_RELEASE + * + * Return: + * + * FFA_ERR_STAT_SUCCESS on success. Otherwise, failure + */ +int sandbox_ffa_get_rxbuf_flags(u32 queried_func_id, struct ffa_interface_data *func_data) +{ + if (!func_data) + return -EINVAL; + + if (!func_data->data0 || func_data->data0_size != sizeof(u8)) + return -EINVAL; + + switch (queried_func_id) { + case FFA_RXTX_MAP: + case FFA_RXTX_UNMAP: + *((u8 *)func_data->data0) = sandbox_ffa_priv_data.pair_info.rxbuf_mapped; + return FFA_ERR_STAT_SUCCESS; + case FFA_RX_RELEASE: + *((u8 *)func_data->data0) = sandbox_ffa_priv_data.pair_info.rxbuf_owned; + return FFA_ERR_STAT_SUCCESS; + default: + ffa_err("[Sandbox] The querried FF-A interface flag (%d) undefined", + queried_func_id); + return -EINVAL; + } +} + +/** + * invoke_sandbox_ffa_drv_api - The driver dispatcher function + * @queried_func_id: The FF-A function to be queried + * @func_data: Pointer to the FF-A function arguments container structure + * + * The dispatcher function that selects the handler that queries the + * status of FF-A ABIs given in the input argument. + * + * Return: + * + * FFA_ERR_STAT_SUCCESS on success. Otherwise, failure + */ +int invoke_sandbox_ffa_drv_api(u32 queried_func_id, struct ffa_interface_data *func_data) +{ + switch (queried_func_id) { + case FFA_VERSION: + case FFA_ID_GET: + case FFA_FEATURES: + return sandbox_ffa_get_prv_data(func_data); + case FFA_RXTX_MAP: + case FFA_RXTX_UNMAP: + case FFA_RX_RELEASE: + return sandbox_ffa_get_rxbuf_flags(queried_func_id, func_data); + default: + ffa_err("[Sandbox] The querried FF-A interface (%d) undefined", queried_func_id); + return -EINVAL; + } +} + +/** + * sandbox_ffa_init_prv_data_from_dtb - init private data fields from DTB + * @dev: the sandbox_arm_ffa device + * + * The value of the conduit field in the private data structure is read from the DTB. + * + * Return: + * + * FFA_ERR_STAT_SUCCESS on success. Otherwise, failure + */ +static int sandbox_ffa_init_prv_data_from_dtb(struct udevice *dev) +{ + struct ffa_pdata *pdata = dev_get_plat(dev); + + sandbox_ffa_priv_data.conduit = pdata->conduit; + + if (sandbox_ffa_priv_data.conduit != FFA_CONDUIT_SMC) { + ffa_err("[Sandbox] Undefined FF-A conduit (%d)", sandbox_ffa_priv_data.conduit); + return -EINVAL; + } + + ffa_info("[Sandbox] Conduit is SMC"); + + return FFA_ERR_STAT_SUCCESS; +} + +/** + * sandbox_arm_ffa_smccc_smc - FF-A SMC call emulation + * @dev: the SMC arguments to be passed to the FF-A ABI + * + * Sandbox driver emulates the FF-A ABIs SMC call using this function. + * The emulated FF-A ABI is identified and invoked. + * FF-A emulation is based on the FF-A specification 1.0 + * + * Return: + * + * FFA_ERR_STAT_SUCCESS on success. Otherwise, failure. + * FF-A protocol error codes are returned using the registers arguments as described + * by the specification + */ +void sandbox_arm_ffa_smccc_smc(unsigned long a0, unsigned long a1, + unsigned long a2, unsigned long a3, unsigned long a4, + unsigned long a5, unsigned long a6, unsigned long a7, + struct arm_smccc_res *res) +{ + int ret = FFA_ERR_STAT_SUCCESS; + + switch (a0) { + case FFA_VERSION: + ret = sandbox_ffa_version(a0, a1, a2, a3, a4, a5, a6, a7, res); + break; + case FFA_PARTITION_INFO_GET: + ret = sandbox_ffa_partition_info_get(a0, a1, a2, a3, a4, a5, a6, a7, res); + break; + case FFA_RXTX_UNMAP: + ret = sandbox_ffa_rxtx_unmap(a0, a1, a2, a3, a4, a5, a6, a7, res); + break; + case FFA_MSG_SEND_DIRECT_REQ: + ret = sandbox_ffa_msg_send_direct_req(a0, a1, a2, a3, a4, a5, a6, a7, res); + break; + case FFA_ID_GET: + ret = sandbox_ffa_id_get(a0, a1, a2, a3, a4, a5, a6, a7, res); + break; + case FFA_FEATURES: + ret = sandbox_ffa_features(a0, a1, a2, a3, a4, a5, a6, a7, res); + break; + case FFA_RXTX_MAP: + ret = sandbox_ffa_rxtx_map(a0, a1, a2, a3, a4, a5, a6, a7, res); + break; + case FFA_RX_RELEASE: + ret = sandbox_ffa_rx_release(a0, a1, a2, a3, a4, a5, a6, a7, res); + break; + default: + ffa_err("[Sandbox] Undefined FF-A interface (0x%x)", (unsigned int)a0); + } + + if (ret != FFA_ERR_STAT_SUCCESS) + ffa_err("[Sandbox] FF-A ABI internal failure (%d)", ret); +} + +/** + * sandbox_ffa_bind - The driver bind function + * @dev: the arm_ffa device + * + * Called when the driver is bound with the device based on the DTB node. + * The private data structure is cleared before use. + * This makes sure that when the device added/removed multiple times the previous + * private structure is cleared. + * + * Return: + * + * FFA_ERR_STAT_SUCCESS + */ +static int sandbox_ffa_bind(struct udevice *dev) +{ + memset(&sandbox_ffa_priv_data, 0, sizeof(sandbox_ffa_priv_data)); + + return FFA_ERR_STAT_SUCCESS; +} + +/** + * sandbox_ffa_probe - The driver probe function + * @dev: the sandbox_arm_ffa device + * + * Probing is triggered by the uclass device discovery. + * At probe level the device tree conduit in the private structure + * is read from the DTB. + * + * Return: + * + * FFA_ERR_STAT_SUCCESS on success. Otherwise, failure + */ +static int sandbox_ffa_probe(struct udevice *dev) +{ + return sandbox_ffa_init_prv_data_from_dtb(dev); +} + +/** + * sandbox_ffa_of_to_plat - Reads the device tree node + * @dev: the sandbox_arm_ffa device + * + * This function reads data from the device tree node and populates + * the platform data structure + * + * Return: + * + * FFA_ERR_STAT_SUCCESS on success. Otherwise, failure + */ +static int sandbox_ffa_of_to_plat(struct udevice *dev) +{ + struct ffa_pdata *pdata = dev_get_plat(dev); + const char *conduit; + + conduit = dev_read_string(dev, "method"); + + if (!conduit) { + ffa_err("[Sandbox] Failure to read the conduit from device tree"); + return -EINVAL; + } + + if (strcmp("smc", conduit)) { + ffa_err("[Sandbox] Unsupported conduit"); + return -EINVAL; + } + + pdata->conduit = FFA_CONDUIT_SMC; + + return FFA_ERR_STAT_SUCCESS; +} + +/** + * sandbox_ffa_drv_ops - The driver operations structure + * @invoke_func: The driver dispatcher + */ +struct ffa_ops sandbox_ffa_drv_ops = { + .invoke_func = invoke_sandbox_ffa_drv_api +}; + +/** + * sandbox_ffa_device_get_ops - driver operations getter + * + * Return: + * This function returns a pointer to the driver operations structure + */ +const struct ffa_ops *sandbox_ffa_device_get_ops(void) +{ + return &sandbox_ffa_drv_ops; +} + +/** + * Defining the device tree compatible string + */ +static const struct udevice_id sandbox_ffa_match_id[] = { + {"sandbox,ffa", 0}, + {}, +}; + +/** + * Declaring the sandbox_arm_ffa driver under UCLASS_FFA + */ +U_BOOT_DRIVER(sandbox_arm_ffa) = { + .name = "sandbox_arm_ffa", + .of_match = sandbox_ffa_match_id, + .id = UCLASS_FFA, + .of_to_plat = sandbox_ffa_of_to_plat, + .probe = sandbox_ffa_probe, + .bind = sandbox_ffa_bind, + .plat_auto = sizeof(struct ffa_pdata), +}; diff --git a/drivers/arm-ffa/sandbox_arm_ffa_prv.h b/drivers/arm-ffa/sandbox_arm_ffa_prv.h new file mode 100644 index 0000000000..9f5085f098 --- /dev/null +++ b/drivers/arm-ffa/sandbox_arm_ffa_prv.h @@ -0,0 +1,128 @@ +/* SPDX-License-Identifier: GPL-2.0+ */ +/* + * (C) Copyright 2022 ARM Limited + * Abdellatif El Khlifi abdellatif.elkhlifi@arm.com + */ + +#ifndef __SANDBOX_ARM_FFA_PRV_H +#define __SANDBOX_ARM_FFA_PRV_H + +#include "arm_ffa_prv.h" + +/* + * This header is private. It is exclusively used by the Sandbox FF-A driver + */ + +/* Non-secure physical FF-A instance */ +#define NS_PHYS_ENDPOINT_ID (0) + +#define GET_NS_PHYS_ENDPOINT_ID_MASK GENMASK(31, 16) +#define GET_NS_PHYS_ENDPOINT_ID(x) \ + ((u16)(FIELD_GET(GET_NS_PHYS_ENDPOINT_ID_MASK, (x)))) + +/* Helper macro for reading the destination partition ID */ +#define GET_DST_SP_ID_MASK GENMASK(15, 0) +#define GET_DST_SP_ID(x) \ + ((u16)(FIELD_GET(GET_DST_SP_ID_MASK, (x)))) + +/* Helper macro for setting the source partition ID */ +#define PREP_SRC_SP_ID_MASK GENMASK(31, 16) +#define PREP_SRC_SP_ID(x) \ + (FIELD_PREP(PREP_SRC_SP_ID_MASK, (x))) + +/* Helper macro for setting the destination endpoint ID */ +#define PREP_NS_PHYS_ENDPOINT_ID_MASK GENMASK(15, 0) +#define PREP_NS_PHYS_ENDPOINT_ID(x) \ + (FIELD_PREP(PREP_NS_PHYS_ENDPOINT_ID_MASK, (x))) + +/* RX/TX buffers minimum size */ +#define RXTX_BUFFERS_MIN_SIZE (RXTX_4K) +#define RXTX_BUFFERS_MIN_PAGES (1) + +/* MBZ registers info */ + +/* w1-w7 MBZ */ +#define FFA_W1W7_MBZ_CNT (7) +#define FFA_W1W7_MBZ_REG_START (&res->a1) + +/* w4-w7 MBZ */ +#define FFA_W4W7_MBZ_CNT (4) +#define FFA_W4W7_MBZ_REG_START (&res->a4) + +/* w3-w7 MBZ */ +#define FFA_W3W7_MBZ_CNT (5) +#define FFA_W3_MBZ_REG_START (&res->a3) + +/* secure partitions count */ +#define SANDBOX_PARTITIONS_CNT (4) + +/* service 1 UUID binary data (little-endian format) */ +#define SANDBOX_SERVICE1_UUID_DATA \ + 0xed, 0x32, 0xd5, 0x33, \ + 0x99, 0xe6, 0x42, 0x09, \ + 0x9c, 0xc0, 0x2d, 0x72, \ + 0xcd, 0xd9, 0x98, 0xa7 + +/* service 2 UUID binary data (little-endian format) */ +#define SANDBOX_SERVICE2_UUID_DATA \ + 0xab, 0xcd, 0xd5, 0x33, \ + 0x99, 0xe6, 0x42, 0x09, \ + 0x9c, 0xc0, 0x2d, 0x72, \ + 0xcd, 0xd9, 0x98, 0xa7 + +/** + * struct ffa_rxtxpair_info - structure hosting the RX/TX buffers flags + * @rxbuf_owned: RX buffer ownership flag (the owner is non secure world: the consumer) + * @rxbuf_mapped: RX buffer mapping flag + * @txbuf_owned TX buffer ownership flag + * @txbuf_mapped: TX buffer mapping flag + * @rxtx_buf_size: RX/TX buffers size as set by the FF-A core driver + * + * Data structure hosting the ownership/mapping flags of the RX/TX buffers + * When a buffer is owned/mapped its corresponding flag is set to 1 otherwise 0. + */ +struct ffa_rxtxpair_info { + u8 rxbuf_owned; + u8 rxbuf_mapped; + u8 txbuf_owned; + u8 txbuf_mapped; + u32 rxtx_buf_size; +}; + +/** + * struct sandbox_ffa_prvdata - the driver private data structure + * + * @dev: The arm_ffa device under u-boot driver model + * @fwk_version: FF-A framework version + * @id: u-boot endpoint ID + * @partitions: The partitions descriptors structure + * @pair: The RX/TX buffers pair + * @pair_info: The RX/TX buffers pair flags and size + * @conduit: The selected conduit + * + * The driver data structure hosting all the emulated secure world data. + */ +struct sandbox_ffa_prvdata { + struct udevice *dev; + u32 fwk_version; + u16 id; + struct ffa_partitions partitions; + struct ffa_rxtxpair pair; + struct ffa_rxtxpair_info pair_info; + enum ffa_conduit conduit; +}; + +void sandbox_arm_ffa_smccc_smc(unsigned long a0, unsigned long a1, + unsigned long a2, unsigned long a3, unsigned long a4, + unsigned long a5, unsigned long a6, unsigned long a7, + struct arm_smccc_res *res); + +#define SANDBOX_SMC_FFA_ABI(ffabi) static int sandbox_##ffabi(unsigned long a0, unsigned long a1, \ + unsigned long a2, unsigned long a3, unsigned long a4, \ + unsigned long a5, unsigned long a6, unsigned long a7, \ + struct arm_smccc_res *res) + +/* The core FF-A private data structure to inspect */ +extern struct ffa_prvdata ffa_priv_data; + +#endif diff --git a/include/arm_ffa.h b/include/arm_ffa.h index 5a2151f8e4..bff565f2af 100644 --- a/include/arm_ffa.h +++ b/include/arm_ffa.h @@ -22,6 +22,13 @@ #define ffa_info(fmt, ...) pr_info("[FFA] " fmt "\n", ##__VA_ARGS__) #define ffa_err(fmt, ...) pr_err("[FFA] " fmt "\n", ##__VA_ARGS__)
+/* panic only on real HW. On sandbox mode return an error code */ +#if CONFIG_IS_ENABLED(SANDBOX_FFA) +#define ffa_panic(fmt, ...) ffa_err("[FFA] " fmt "\n", ##__VA_ARGS__) +#else +#define ffa_panic(fmt, ...) panic("[FFA] " fmt "\n", ##__VA_ARGS__) +#endif + /* * The driver operations success error code */ @@ -184,7 +191,7 @@ const struct ffa_ops * __ffa_runtime ffa_device_get_ops(void); int ffa_get_device(void);
/** - * ffa_init_device - probes the arm_ffa device + * ffa_init_device - probes the arm_ffa and arm_ffa devices */ int ffa_init_device(void); #endif diff --git a/include/sandbox_arm_ffa.h b/include/sandbox_arm_ffa.h new file mode 100644 index 0000000000..fc681018ff --- /dev/null +++ b/include/sandbox_arm_ffa.h @@ -0,0 +1,31 @@ +/* SPDX-License-Identifier: GPL-2.0+ */ +/* + * (C) Copyright 2022 ARM Limited + * Abdellatif El Khlifi abdellatif.elkhlifi@arm.com + */ + +#ifndef __SANDBOX_ARM_FFA_H +#define __SANDBOX_ARM_FFA_H + +#include <arm_ffa.h> + +/** + * The device driver and the Uclass driver public functions + */ + +/** + * sandbox_ffa_get_invoke_func - performs a call to the Sandbox FF-A driver dispatcher + */ +int sandbox_ffa_get_invoke_func(u32 func_id, struct ffa_interface_data *func_data); + +/** + * sandbox_ffa_device_get_ops - driver operations getter + */ +const struct ffa_ops *sandbox_ffa_device_get_ops(void); + +/** + * sandbox_ffa_get_device - probes the sandbox_arm_ffa device + */ +int sandbox_ffa_get_device(void); + +#endif diff --git a/include/sandbox_arm_ffa_helper.h b/include/sandbox_arm_ffa_helper.h new file mode 100644 index 0000000000..f0fcd04536 --- /dev/null +++ b/include/sandbox_arm_ffa_helper.h @@ -0,0 +1,26 @@ +/* SPDX-License-Identifier: GPL-2.0+ */ +/* + * (C) Copyright 2022 ARM Limited + * Abdellatif El Khlifi abdellatif.elkhlifi@arm.com + */ + +#ifndef __SANDBOX_ARM_FFA_HELPER_H +#define __SANDBOX_ARM_FFA_HELPER_H + +#include <arm_ffa_helper.h> +#include <sandbox_arm_ffa.h> +#include "../drivers/arm-ffa/sandbox_arm_ffa_prv.h" + +/* + * This header is public. Including this header provides all FF-A Sandbox data structures + * It also provides the helper function allowing to pass data and invoke Sandbox FF-A functions + * used for testing the FF-A core driver + */ + +/** + * sandbox_ffa_helper_query_core_state - Wrapper function for + * reading the FF-A core driver data + */ +int sandbox_ffa_helper_query_core_state(u32 queried_func_id, struct ffa_interface_data *func_data); + +#endif diff --git a/lib/arm-ffa/Makefile b/lib/arm-ffa/Makefile index cba625fde4..04159da8eb 100644 --- a/lib/arm-ffa/Makefile +++ b/lib/arm-ffa/Makefile @@ -6,3 +6,4 @@ # This file only gets included when CONFIG_ARM_FFA_TRANSPORT_HELPERS is set
obj-y += arm_ffa_helper.o +obj-$(CONFIG_SANDBOX_FFA) += sandbox_arm_ffa_helper.o diff --git a/lib/arm-ffa/arm_ffa_helper.c b/lib/arm-ffa/arm_ffa_helper.c index 67a3a4e9ab..32ee3b4486 100644 --- a/lib/arm-ffa/arm_ffa_helper.c +++ b/lib/arm-ffa/arm_ffa_helper.c @@ -105,10 +105,10 @@ int __ffa_runtime ffa_helper_msg_send_direct_req(struct ffa_interface_data }
/** - * ffa_helper_init_device - Wrapper function for probing the arm_ffa device + * ffa_helper_init_device - Wrapper function for probing the arm_ffa and sandbox_arm_ffa devices * - * This boot time function should be called to probe the arm_ffa device so - * it becomes ready for use. + * This boot time function should be called to probe the arm_ffa and sandbox_arm_ffa devices so + * they become ready for use. * To achieve that, this function is called automatically at initcalls * level (after u-boot relocation). * diff --git a/lib/arm-ffa/sandbox_arm_ffa_helper.c b/lib/arm-ffa/sandbox_arm_ffa_helper.c new file mode 100644 index 0000000000..7859f30fc7 --- /dev/null +++ b/lib/arm-ffa/sandbox_arm_ffa_helper.c @@ -0,0 +1,23 @@ +// SPDX-License-Identifier: GPL-2.0+ +/* + * (C) Copyright 2022 ARM Limited + * Abdellatif El Khlifi abdellatif.elkhlifi@arm.com + */ + +#include <common.h> +#include <sandbox_arm_ffa_helper.h> + +/** + * sandbox_ffa_helper_query_core_state - Wrapper function for querying FF-A implementation + * + * A helper function used for querying the status of FF-A ABIs given in the input argument + * and the FF-A core driver. + * + * Return: + * + * FFA_ERR_STAT_SUCCESS on success. Otherwise, failure + */ +int sandbox_ffa_helper_query_core_state(u32 queried_func_id, struct ffa_interface_data *func_data) +{ + return sandbox_ffa_get_invoke_func(queried_func_id, func_data); +} diff --git a/lib/efi_loader/efi_boottime.c b/lib/efi_loader/efi_boottime.c index cffa2c69d6..12fc28fd82 100644 --- a/lib/efi_loader/efi_boottime.c +++ b/lib/efi_loader/efi_boottime.c @@ -2118,7 +2118,7 @@ static efi_status_t EFIAPI efi_exit_boot_services(efi_handle_t image_handle, struct efi_event *evt, *next_event; efi_status_t ret = EFI_SUCCESS;
-#if defined(CONFIG_ARM_FFA_TRANSPORT) +#if defined(CONFIG_ARM_FFA_TRANSPORT) && !defined(CONFIG_SANDBOX_FFA) int ffa_ret; #endif
@@ -2182,7 +2182,7 @@ static efi_status_t EFIAPI efi_exit_boot_services(efi_handle_t image_handle, dm_remove_devices_flags(DM_REMOVE_ACTIVE_ALL); }
-#if defined(CONFIG_ARM_FFA_TRANSPORT) +#if defined(CONFIG_ARM_FFA_TRANSPORT) && !defined(CONFIG_SANDBOX_FFA) /* unmap FF-A RX/TX buffers */ ffa_ret = ffa_helper_unmap_rxtx_buffers(); if (ffa_ret)
Add functional test cases for the FF-A core driver
These tests rely on the FF-A Sandbox driver which helps in inspecting the FF-A core driver.
Signed-off-by: Abdellatif El Khlifi abdellatif.elkhlifi@arm.com Cc: Tom Rini trini@konsulko.com --- MAINTAINERS | 2 + test/dm/Makefile | 1 + test/dm/ffa.c | 424 +++++++++++++++++++++++++++++++++++++++++++++++ test/dm/ffa.h | 22 +++ 4 files changed, 449 insertions(+) create mode 100644 test/dm/ffa.c create mode 100644 test/dm/ffa.h
diff --git a/MAINTAINERS b/MAINTAINERS index 84524d7caf..52274b2fac 100644 --- a/MAINTAINERS +++ b/MAINTAINERS @@ -242,6 +242,8 @@ F: include/arm_ffa_helper.h F: include/sandbox_arm_ffa.h F: include/sandbox_arm_ffa_helper.h F: lib/arm-ffa/ +F: test/dm/ffa.c +F: test/dm/ffa.h
ARM FREESCALE IMX M: Stefano Babic sbabic@denx.de diff --git a/test/dm/Makefile b/test/dm/Makefile index d46552fbf3..48eab1b1ff 100644 --- a/test/dm/Makefile +++ b/test/dm/Makefile @@ -79,6 +79,7 @@ obj-$(CONFIG_POWER_DOMAIN) += power-domain.o obj-$(CONFIG_ACPI_PMC) += pmc.o obj-$(CONFIG_DM_PMIC) += pmic.o obj-$(CONFIG_DM_PWM) += pwm.o +obj-$(CONFIG_SANDBOX_FFA) += ffa.o obj-$(CONFIG_QFW) += qfw.o obj-$(CONFIG_RAM) += ram.o obj-y += regmap.o diff --git a/test/dm/ffa.c b/test/dm/ffa.c new file mode 100644 index 0000000000..82875705c6 --- /dev/null +++ b/test/dm/ffa.c @@ -0,0 +1,424 @@ +// SPDX-License-Identifier: GPL-2.0+ +/* + * Functional tests for UCLASS_FFA class + * + * (C) Copyright 2022 ARM Limited + * Abdellatif El Khlifi abdellatif.elkhlifi@arm.com + */ + +#include <common.h> +#include <console.h> +#include <dm.h> +#include <dm/test.h> +#include "ffa.h" +#include <test/test.h> +#include <test/ut.h> +#include <sandbox_arm_ffa_helper.h> +#include <string.h> + +/* Functional tests for the UCLASS_FFA */ + +int dm_test_ffa_log(struct unit_test_state *uts, char *msg) +{ + char cmd[LOG_CMD_SZ] = {0}; + + console_record_reset(); + + snprintf(cmd, LOG_CMD_SZ, "echo "%s"", msg); + run_command(cmd, 0); + + ut_assert_console_end(); + + return CMD_RET_SUCCESS; +} + +static int check_fwk_version(struct ffa_prvdata *prvdata, struct unit_test_state *uts) +{ + if (prvdata->fwk_version != SANDBOX_FWK_VERSION) { + char msg[LOG_MSG_SZ] = {0}; + + snprintf(msg, LOG_MSG_SZ, "[%s]: Error: prvdata->fwk_version = 0x%x", __func__, + prvdata->fwk_version); + dm_test_ffa_log(uts, msg); + return CMD_RET_FAILURE; + } + return CMD_RET_SUCCESS; +} + +static int check_endpoint_id(struct ffa_prvdata *prvdata, struct unit_test_state *uts) +{ + if (prvdata->id) { + char msg[LOG_MSG_SZ] = {0}; + + snprintf(msg, LOG_MSG_SZ, "[%s]: Error: prvdata->id = 0x%x", __func__, prvdata->id); + dm_test_ffa_log(uts, msg); + return CMD_RET_FAILURE; + } + return CMD_RET_SUCCESS; +} + +static int check_dev(struct ffa_prvdata *prvdata, struct unit_test_state *uts) +{ + if (!prvdata->dev) { + char msg[LOG_MSG_SZ] = {0}; + + snprintf(msg, LOG_MSG_SZ, "[%s]: Error: device = 0x%p", __func__, prvdata->dev); + dm_test_ffa_log(uts, msg); + return CMD_RET_FAILURE; + } + return CMD_RET_SUCCESS; +} + +static int check_prvdata_null(struct ffa_prvdata *prvdata) +{ + u32 idx; + u8 *byte = (u8 *)prvdata; + + for (idx = 0 ; idx < sizeof(struct ffa_prvdata) ; idx++) + if (*(byte++)) + return CMD_RET_FAILURE; + + return CMD_RET_SUCCESS; +} + +static int check_rxtxbuf(struct ffa_prvdata *prvdata, struct unit_test_state *uts) +{ + if (!prvdata->pair.rxbuf && prvdata->pair.txbuf) { + char msg[LOG_MSG_SZ] = {0}; + + snprintf(msg, LOG_MSG_SZ, "[%s]: Error: rxbuf = 0x%llx txbuf = 0x%llx", __func__, + prvdata->pair.rxbuf, + prvdata->pair.txbuf); + dm_test_ffa_log(uts, msg); + return CMD_RET_FAILURE; + } + return CMD_RET_SUCCESS; +} + +static int check_features(struct ffa_prvdata *prvdata, struct unit_test_state *uts) +{ + u32 desc_idx; + char msg[LOG_MSG_SZ] = {0}; + + snprintf(msg, + LOG_MSG_SZ, + "[%s]: Error: FFA_RXTX_MAP features not found", + __func__); + + for (desc_idx = 0; desc_idx < FFA_FEATURE_DESC_CNT ; desc_idx++) + if (prvdata->features[desc_idx].func_id == FFA_RXTX_MAP) { + if (prvdata->features[desc_idx].field1 != RXTX_4K && + prvdata->features[desc_idx].field1 != RXTX_16K && + prvdata->features[desc_idx].field1 != RXTX_64K) { + snprintf(msg, + LOG_MSG_SZ, + "[%s]: Error: FFA_RXTX_MAP features = 0x%x", + __func__, + prvdata->features[desc_idx].field1); + break; + } + return CMD_RET_SUCCESS; + } + + dm_test_ffa_log(uts, msg); + return CMD_RET_FAILURE; +} + +static int check_rxbuf_mapped_flag(u32 queried_func_id, + u8 rxbuf_mapped, + struct unit_test_state *uts) +{ + char msg[LOG_MSG_SZ] = {0}; + + switch (queried_func_id) { + case FFA_RXTX_MAP: + { + if (rxbuf_mapped) + return CMD_RET_SUCCESS; + break; + } + case FFA_RXTX_UNMAP: + { + if (!rxbuf_mapped) + return CMD_RET_SUCCESS; + break; + } + default: + return CMD_RET_FAILURE; + } + + snprintf(msg, LOG_MSG_SZ, "[%s]: Error: %s mapping issue", __func__, + (queried_func_id == FFA_RXTX_MAP ? "FFA_RXTX_MAP" : "FFA_RXTX_UNMAP")); + dm_test_ffa_log(uts, msg); + + return CMD_RET_FAILURE; +} + +static int check_rxbuf_release_flag(u8 rxbuf_owned, struct unit_test_state *uts) +{ + if (rxbuf_owned) { + char msg[LOG_MSG_SZ] = {0}; + + snprintf(msg, LOG_MSG_SZ, "[%s]: Error: RX buffer not released", __func__); + dm_test_ffa_log(uts, msg); + return CMD_RET_FAILURE; + } + return CMD_RET_SUCCESS; +} + +static int test_ffa_msg_send_direct_req(u16 part_id, struct unit_test_state *uts) +{ + struct ffa_interface_data func_data = {0}; + struct ffa_send_direct_data msg = {0}; + u32 pattern = 0xaabbccdd; + u8 cnt; + + /* + * telling the driver which partition to use + */ + func_data.data0_size = sizeof(part_id); + func_data.data0 = &part_id; + + /* + * filling the message data + */ + msg.a3 = pattern; + msg.a4 = pattern; + msg.a5 = pattern; + msg.a6 = pattern; + msg.a7 = pattern; + func_data.data1_size = sizeof(msg); + func_data.data1 = &msg; + + ut_assertok(ffa_helper_msg_send_direct_req(&func_data)); + + for (cnt = 0; cnt < sizeof(struct ffa_send_direct_data) / sizeof(u32); cnt++) + ut_assertok(((u32 *)&msg)[cnt] != 0xffffffff); + + return CMD_RET_SUCCESS; +} + +static int test_partitions_and_comms(union ffa_partition_uuid *service_uuid, + struct sandbox_ffa_prvdata *sdx_prvdata, + struct unit_test_state *uts) +{ + struct ffa_interface_data func_data = {0}; + u32 count = 0; + struct ffa_partition_info *parts_info; + u32 info_idx, exp_info_idx; + int ret; + + /* + * get from the driver the count of the SPs matching the UUID + */ + func_data.data0_size = sizeof(*service_uuid); + func_data.data0 = service_uuid; + func_data.data1_size = sizeof(count); + func_data.data1 = &count; + + ut_assertok(ffa_helper_get_partitions_info(&func_data)); + + /* make sure partitions are detected */ + ut_assertok(!count); + + /* + * pre-allocate a buffer to be filled by the driver + * with ffa_partition_info structs + */ + + parts_info = calloc(count, sizeof(struct ffa_partition_info)); + ut_assertok(!parts_info); + + func_data.data1_size = count * sizeof(struct ffa_partition_info); + func_data.data1 = parts_info; + + /* + * ask the driver to fill the buffer with the SPs info + */ + ret = ffa_helper_get_partitions_info(&func_data); + if (ret != FFA_ERR_STAT_SUCCESS) { + free(parts_info); + ut_assertok(ret != FFA_ERR_STAT_SUCCESS); + } + + /* + * SPs found , verify the partitions information + */ + + ret = CMD_RET_FAILURE; + + for (info_idx = 0; info_idx < count ; info_idx++) { + for (exp_info_idx = 0; + exp_info_idx < sdx_prvdata->partitions.count; + exp_info_idx++) { + if (parts_info[info_idx].id == + sdx_prvdata->partitions.descs[exp_info_idx].info.id) { + ret = memcmp(&parts_info[info_idx], + &sdx_prvdata->partitions.descs[exp_info_idx] + .info, + sizeof(struct ffa_partition_info)); + if (ret) + free(parts_info); + ut_assertok(ret != 0); + /* send and receive data from the current partition */ + test_ffa_msg_send_direct_req(parts_info[info_idx].id, uts); + } + ret = CMD_RET_SUCCESS; + } + } + + free(parts_info); + + /* Verify expected partitions found in the emulated secure world*/ + ut_assertok(ret != CMD_RET_SUCCESS); + + return CMD_RET_SUCCESS; +} + +static int dm_test_ffa_ack(struct unit_test_state *uts) +{ + struct ffa_prvdata *prvdata = NULL; + struct sandbox_ffa_prvdata *sdx_prvdata = NULL; + struct ffa_interface_data func_data = {0}; + u8 rxbuf_flag = 0; + union ffa_partition_uuid svc1_uuid = { .bytes = {SANDBOX_SERVICE1_UUID_DATA}}; + union ffa_partition_uuid svc2_uuid = { .bytes = {SANDBOX_SERVICE2_UUID_DATA}}; + int ret; + + /* get a pointer to the FF-A core and sandbox drivers private data */ + func_data.data0 = &prvdata; + func_data.data0_size = sizeof(prvdata); + func_data.data1 = &sdx_prvdata; + func_data.data1_size = sizeof(sdx_prvdata); + + ut_assertok(sandbox_ffa_helper_query_core_state(FFA_VERSION, &func_data)); + + /* make sure the core private data is cleared before use */ + ut_assertok(check_prvdata_null(prvdata)); + + /* test probing FF-A devices */ + ut_assertok(ffa_helper_init_device()); + ut_assertok(check_dev(prvdata, uts)); + + /* test FFA_VERSION */ + ut_assertok(check_fwk_version(prvdata, uts)); + + /* test FFA_ID_GET */ + ut_assertok(check_endpoint_id(prvdata, uts)); + + /* test FFA_FEATURES */ + ut_assertok(check_features(prvdata, uts)); + + /* test core RX/TX buffers */ + ut_assertok(check_rxtxbuf(prvdata, uts)); + + /* test FFA_RXTX_MAP */ + func_data.data0 = &rxbuf_flag; + func_data.data0_size = sizeof(rxbuf_flag); + + rxbuf_flag = 0; + ut_assertok(sandbox_ffa_helper_query_core_state(FFA_RXTX_MAP, &func_data)); + ut_assertok(check_rxbuf_mapped_flag(FFA_RXTX_MAP, rxbuf_flag, uts)); + + /* FFA_PARTITION_INFO_GET / FFA_MSG_SEND_DIRECT_REQ */ + ret = test_partitions_and_comms(&svc1_uuid, sdx_prvdata, uts); + ut_assertok(ret != CMD_RET_SUCCESS); + + /* test FFA_RX_RELEASE */ + rxbuf_flag = 1; + ut_assertok(sandbox_ffa_helper_query_core_state(FFA_RX_RELEASE, &func_data)); + ut_assertok(check_rxbuf_release_flag(rxbuf_flag, uts)); + + /* FFA_PARTITION_INFO_GET / FFA_MSG_SEND_DIRECT_REQ */ + ret = test_partitions_and_comms(&svc2_uuid, sdx_prvdata, uts); + ut_assertok(ret != CMD_RET_SUCCESS); + + /* test FFA_RX_RELEASE */ + rxbuf_flag = 1; + ut_assertok(sandbox_ffa_helper_query_core_state(FFA_RX_RELEASE, &func_data)); + ut_assertok(check_rxbuf_release_flag(rxbuf_flag, uts)); + + /* test FFA_RXTX_UNMAP */ + ut_assertok(ffa_helper_unmap_rxtx_buffers()); + + rxbuf_flag = 1; + ut_assertok(sandbox_ffa_helper_query_core_state(FFA_RXTX_UNMAP, &func_data)); + ut_assertok(check_rxbuf_mapped_flag(FFA_RXTX_UNMAP, rxbuf_flag, uts)); + + return CMD_RET_SUCCESS; +} + +DM_TEST(dm_test_ffa_ack, UT_TESTF_SCAN_FDT | UT_TESTF_CONSOLE_REC); + +static int dm_test_ffa_nack(struct unit_test_state *uts) +{ + struct ffa_prvdata *prvdata = NULL; + struct sandbox_ffa_prvdata *sdx_prvdata = NULL; + + struct ffa_interface_data func_data = {0}; + union ffa_partition_uuid valid_svc_uuid = { .bytes = {SANDBOX_SERVICE1_UUID_DATA}}; + union ffa_partition_uuid unvalid_svc_uuid = { .bytes = {SANDBOX_SERVICE3_UUID_DATA}}; + struct ffa_send_direct_data msg = {0}; + int ret; + u32 count = 0; + u16 part_id = 0; + + /* get partitions info before probing the core driver */ + func_data.data0_size = sizeof(union ffa_partition_uuid); + func_data.data0 = &unvalid_svc_uuid; + func_data.data1_size = sizeof(count); + func_data.data1 = &count; + + ret = ffa_helper_get_partitions_info(&func_data); + ut_assertok(ret != -ENODEV); + + /* get a pointer to the FF-A core and sandbox drivers private data */ + func_data.data0 = &prvdata; + func_data.data0_size = sizeof(prvdata); + func_data.data1 = &sdx_prvdata; + func_data.data1_size = sizeof(sdx_prvdata); + ut_assertok(sandbox_ffa_helper_query_core_state(FFA_VERSION, &func_data)); + + /* probing FF-A devices */ + ut_assertok(ffa_helper_init_device()); + ut_assertok(check_dev(prvdata, uts)); + + /* query partition info using invalid arguments */ + ret = ffa_helper_get_partitions_info(&func_data); + ut_assertok(ret != -EINVAL); + + /* query partition info using an invalid UUID */ + func_data.data0_size = sizeof(union ffa_partition_uuid); + func_data.data0 = &unvalid_svc_uuid; + func_data.data1_size = sizeof(count); + func_data.data1 = &count; + + ret = ffa_helper_get_partitions_info(&func_data); + ut_assertok(ret != -EPERM); + + /* query partition info using a valid UUID */ + func_data.data0 = &valid_svc_uuid; + count = 0; + ret = ffa_helper_get_partitions_info(&func_data); + /* make sure partitions are detected */ + ut_assertok(ret != FFA_ERR_STAT_SUCCESS); + ut_assertok(!count); + + /* send data to an invalid partition */ + func_data.data0_size = sizeof(part_id); + func_data.data0 = &part_id; + func_data.data1_size = sizeof(msg); + func_data.data1 = &msg; + + ret = ffa_helper_msg_send_direct_req(&func_data); + ut_assertok(ret != -EPERM); + + /* send data to a valid partition */ + part_id = ffa_priv_data.partitions.descs[0].info.id; + ret = ffa_helper_msg_send_direct_req(&func_data); + ut_assertok(ret != FFA_ERR_STAT_SUCCESS); + + return CMD_RET_SUCCESS; +} + +DM_TEST(dm_test_ffa_nack, UT_TESTF_SCAN_FDT | UT_TESTF_CONSOLE_REC); diff --git a/test/dm/ffa.h b/test/dm/ffa.h new file mode 100644 index 0000000000..11c7980fcf --- /dev/null +++ b/test/dm/ffa.h @@ -0,0 +1,22 @@ +/* SPDX-License-Identifier: GPL-2.0+ */ +/* + * (C) Copyright 2022 ARM Limited + * Abdellatif El Khlifi abdellatif.elkhlifi@arm.com + */ + +#ifndef __TEST_DM_FFA_H +#define __TEST_DM_FFA_H + +#define SANDBOX_FWK_VERSION (0x10000) + +#define LOG_MSG_SZ (100) +#define LOG_CMD_SZ (LOG_MSG_SZ * 2) + +/* service 3 UUID binary data (little-endian format) */ +#define SANDBOX_SERVICE3_UUID_DATA \ + 0xfd, 0x42, 0xd5, 0x33, \ + 0x19, 0xa6, 0x42, 0x09, \ + 0x9c, 0xc1, 0x2d, 0x72, \ + 0xcd, 0xd9, 0x98, 0x89 + +#endif /*__TEST_DM_FFA_H */
From: Abdellatif El Khlifi abdellatif.elkhlifi@arm.com
Add Sandbox test for the armffa command
Signed-off-by: Abdellatif El Khlifi abdellatif.elkhlifi@arm.com Cc: Tom Rini trini@konsulko.com --- MAINTAINERS | 2 ++ test/cmd/Makefile | 1 + test/cmd/armffa.c | 33 +++++++++++++++++++++++++++++++++ test/cmd/armffa.h | 13 +++++++++++++ 4 files changed, 49 insertions(+) create mode 100644 test/cmd/armffa.c create mode 100644 test/cmd/armffa.h
diff --git a/MAINTAINERS b/MAINTAINERS index 52274b2fac..9828095837 100644 --- a/MAINTAINERS +++ b/MAINTAINERS @@ -242,6 +242,8 @@ F: include/arm_ffa_helper.h F: include/sandbox_arm_ffa.h F: include/sandbox_arm_ffa_helper.h F: lib/arm-ffa/ +F: test/cmd/armffa.c +F: test/cmd/armffa.h F: test/dm/ffa.c F: test/dm/ffa.h
diff --git a/test/cmd/Makefile b/test/cmd/Makefile index a59adb1e6d..d9dc0809d6 100644 --- a/test/cmd/Makefile +++ b/test/cmd/Makefile @@ -11,3 +11,4 @@ obj-$(CONFIG_CMD_MEM_SEARCH) += mem_search.o obj-$(CONFIG_CMD_PINMUX) += pinmux.o obj-$(CONFIG_CMD_PWM) += pwm.o obj-$(CONFIG_CMD_SETEXPR) += setexpr.o +obj-$(CONFIG_SANDBOX_FFA) += armffa.o diff --git a/test/cmd/armffa.c b/test/cmd/armffa.c new file mode 100644 index 0000000000..d35032047b --- /dev/null +++ b/test/cmd/armffa.c @@ -0,0 +1,33 @@ +// SPDX-License-Identifier: GPL-2.0+ +/* + * Test for armffa command + * + * (C) Copyright 2022 ARM Limited + * Abdellatif El Khlifi abdellatif.elkhlifi@arm.com + */ + +#include "armffa.h" +#include <arm_ffa_helper.h> +#include <dm.h> +#include <dm/test.h> +#include <test/test.h> +#include <test/ut.h> + +/* Basic test of 'armffa' command */ +static int dm_test_armffa_cmd(struct unit_test_state *uts) +{ + ut_assertok(ffa_helper_init_device()); + + /* armffa getpart <UUID> */ + ut_assertok(run_command("armffa getpart " SE_PROXY_PARTITION_UUID, 0)); + + /* armffa ping <ID> */ + ut_assertok(run_command("armffa ping " SE_PROXY_PARTITION_ID, 0)); + + /* armffa devlist */ + ut_assertok(run_command("armffa devlist", 0)); + + return CMD_RET_SUCCESS; +} + +DM_TEST(dm_test_armffa_cmd, UT_TESTF_SCAN_FDT | UT_TESTF_CONSOLE_REC); diff --git a/test/cmd/armffa.h b/test/cmd/armffa.h new file mode 100644 index 0000000000..630dc75e25 --- /dev/null +++ b/test/cmd/armffa.h @@ -0,0 +1,13 @@ +/* SPDX-License-Identifier: GPL-2.0+ */ +/* + * (C) Copyright 2022 ARM Limited + * Abdellatif El Khlifi abdellatif.elkhlifi@arm.com + */ + +#ifndef __TEST_CMD_FFA_H +#define __TEST_CMD_FFA_H + +#define SE_PROXY_PARTITION_ID "0x1245" +#define SE_PROXY_PARTITION_UUID "33d532ed-e699-0942-c09c-a798d9cd722d" + +#endif /*__TEST_CMD_FFA_H */
Add MM communication support using FF-A transport
FF-A MM communication allows exchanging data with StandAlonneMM or smm-gateway secure partitions which run in OP-TEE.
An MM shared buffer and a door bell event are used to exchange this data.
The data is used by EFI services such as GetVariable()/SetVariable() and copied from the communication buffer to the MM shared buffer.
The secure partition is notified about availability of data in the MM shared buffer by an FF-A message (door bell).
On such event, MM SP can read the data and updates the MM shared buffer with the response data.
The response data is copied back to the communication buffer and consumed by the EFI subsystem.
Signed-off-by: Abdellatif El Khlifi abdellatif.elkhlifi@arm.com Signed-off-by: Gowtham Suresh Kumar gowtham.sureshkumar@arm.com Cc: Tom Rini trini@konsulko.com --- arch/arm/cpu/armv8/cache.S | 16 ++ arch/arm/cpu/armv8/cache_v8.c | 3 +- include/mm_communication.h | 4 +- lib/efi_loader/Kconfig | 14 +- lib/efi_loader/efi_variable_tee.c | 294 +++++++++++++++++++++++++++++- 5 files changed, 321 insertions(+), 10 deletions(-)
diff --git a/arch/arm/cpu/armv8/cache.S b/arch/arm/cpu/armv8/cache.S index d1cee23437..bdbe89e0c5 100644 --- a/arch/arm/cpu/armv8/cache.S +++ b/arch/arm/cpu/armv8/cache.S @@ -21,7 +21,11 @@ * x1: 0 clean & invalidate, 1 invalidate only * x2~x9: clobbered */ +#ifdef CONFIG_ARM_FFA_TRANSPORT +.pushsection .text.efi_runtime, "ax" +#else .pushsection .text.__asm_dcache_level, "ax" +#endif ENTRY(__asm_dcache_level) lsl x12, x0, #1 msr csselr_el1, x12 /* select cache level */ @@ -65,7 +69,11 @@ ENDPROC(__asm_dcache_level) * * flush or invalidate all data cache by SET/WAY. */ +#ifdef CONFIG_ARM_FFA_TRANSPORT +.pushsection .text.efi_runtime, "ax" +#else .pushsection .text.__asm_dcache_all, "ax" +#endif ENTRY(__asm_dcache_all) mov x1, x0 dsb sy @@ -109,7 +117,11 @@ ENTRY(__asm_flush_dcache_all) ENDPROC(__asm_flush_dcache_all) .popsection
+#ifdef CONFIG_ARM_FFA_TRANSPORT +.pushsection .text.efi_runtime, "ax" +#else .pushsection .text.__asm_invalidate_dcache_all, "ax" +#endif ENTRY(__asm_invalidate_dcache_all) mov x0, #0x1 b __asm_dcache_all @@ -182,7 +194,11 @@ ENTRY(__asm_invalidate_icache_all) ENDPROC(__asm_invalidate_icache_all) .popsection
+#ifdef CONFIG_ARM_FFA_TRANSPORT +.pushsection .text.efi_runtime, "ax" +#else .pushsection .text.__asm_invalidate_l3_dcache, "ax" +#endif WEAK(__asm_invalidate_l3_dcache) mov x0, #0 /* return status as success */ ret diff --git a/arch/arm/cpu/armv8/cache_v8.c b/arch/arm/cpu/armv8/cache_v8.c index 3de18c7675..187a4497a7 100644 --- a/arch/arm/cpu/armv8/cache_v8.c +++ b/arch/arm/cpu/armv8/cache_v8.c @@ -9,6 +9,7 @@
#include <common.h> #include <cpu_func.h> +#include <efi_loader.h> #include <hang.h> #include <log.h> #include <asm/cache.h> @@ -425,7 +426,7 @@ __weak void mmu_setup(void) /* * Performs a invalidation of the entire data cache at all levels */ -void invalidate_dcache_all(void) +void __efi_runtime invalidate_dcache_all(void) { __asm_invalidate_dcache_all(); __asm_invalidate_l3_dcache(); diff --git a/include/mm_communication.h b/include/mm_communication.h index e65fbde60d..bb99190956 100644 --- a/include/mm_communication.h +++ b/include/mm_communication.h @@ -123,7 +123,7 @@ struct __packed efi_mm_communicate_header { * * Defined in EDK2 as SMM_VARIABLE_COMMUNICATE_HEADER. */ -struct smm_variable_communicate_header { +struct __packed smm_variable_communicate_header { efi_uintn_t function; efi_status_t ret_status; u8 data[]; @@ -145,7 +145,7 @@ struct smm_variable_communicate_header { * Defined in EDK2 as SMM_VARIABLE_COMMUNICATE_ACCESS_VARIABLE. * */ -struct smm_variable_access { +struct __packed smm_variable_access { efi_guid_t guid; efi_uintn_t data_size; efi_uintn_t name_size; diff --git a/lib/efi_loader/Kconfig b/lib/efi_loader/Kconfig index 28657f50c9..0d69133595 100644 --- a/lib/efi_loader/Kconfig +++ b/lib/efi_loader/Kconfig @@ -55,13 +55,23 @@ config EFI_VARIABLE_FILE_STORE stored as file /ubootefi.var on the EFI system partition.
config EFI_MM_COMM_TEE - bool "UEFI variables storage service via OP-TEE" - depends on OPTEE + bool "UEFI variables storage service via the trusted world" + depends on OPTEE || ARM_FFA_TRANSPORT help + The MM SP (also called partition) can be StandAlonneMM or smm-gateway. + When using the u-boot OP-TEE driver, StandAlonneMM is supported. + When using the u-boot FF-A driver, StandAlonneMM and smm-gateway are supported. + If OP-TEE is present and running StandAloneMM, dispatch all UEFI variable related operations to that. The application will verify, authenticate and store the variables on an RPMB.
+ When ARM_FFA_TRANSPORT is used, dispatch all UEFI variable related + operations to the MM SP running under Optee in the trusted world. + A door bell mechanism is used to notify the SP when there is data in the shared + MM buffer. The data is copied by u-boot to the shared buffer before issuing + the door bell event. + endchoice
config EFI_VARIABLES_PRESEED diff --git a/lib/efi_loader/efi_variable_tee.c b/lib/efi_loader/efi_variable_tee.c index dfef18435d..3d01985662 100644 --- a/lib/efi_loader/efi_variable_tee.c +++ b/lib/efi_loader/efi_variable_tee.c @@ -15,6 +15,53 @@ #include <malloc.h> #include <mm_communication.h>
+#if (IS_ENABLED(CONFIG_ARM_FFA_TRANSPORT)) + +#include <arm_ffa_helper.h> +#include <cpu_func.h> +#include <mapmem.h> + +#ifndef FFA_SHARED_MM_BUFFER_SIZE + +#include <linux/sizes.h> +#define FFA_SHARED_MM_BUFFER_SIZE SZ_4K /* 4 KB */ + +#endif + +#ifndef FFA_SHARED_MM_BUFFER_ADDR + +/* + * shared buffer physical address used for communication between + * u-boot and the MM SP + */ +#define FFA_SHARED_MM_BUFFER_ADDR (0x023F8000) + +#endif + +/* MM return codes */ +#define MM_SUCCESS (0) + +#define ARM_SVC_ID_SP_EVENT_COMPLETE_AARCH64 (0xC4000061) +#define ARM_SVC_ID_SP_EVENT_COMPLETE ARM_SVC_ID_SP_EVENT_COMPLETE_AARCH64 + +#ifndef MM_SP_UUID_DATA + +/* MM SP UUID binary data (little-endian format) */ +#define MM_SP_UUID_DATA \ + 0xed, 0x32, 0xd5, 0x33, \ + 0x99, 0xe6, 0x42, 0x09, \ + 0x9c, 0xc0, 0x2d, 0x72, \ + 0xcd, 0xd9, 0x98, 0xa7 + +#endif + +/* MM_SP_UUID_DATA defined by the platform */ +union ffa_partition_uuid mm_sp_svc_uuid = {.bytes = {MM_SP_UUID_DATA}}; + +static __efi_runtime_data u16 mm_sp_id; + +#endif + extern struct efi_var_file __efi_runtime_data *efi_var_buf; static efi_uintn_t max_buffer_size; /* comm + var + func + data */ static efi_uintn_t max_payload_size; /* func + data */ @@ -24,6 +71,7 @@ struct mm_connection { u32 session; };
+#if (IS_ENABLED(CONFIG_OPTEE)) /** * get_connection() - Retrieve OP-TEE session for a specific UUID. * @@ -143,16 +191,238 @@ static efi_status_t optee_mm_communicate(void *comm_buf, ulong dsize)
return ret; } +#endif + +#if (IS_ENABLED(CONFIG_ARM_FFA_TRANSPORT)) + +/** + * ffa_notify_mm_sp() - Announce there is data in the shared buffer + * + * Notifies the MM partition in the trusted world that + * data is available in the shared buffer. + * This is a blocking call during which trusted world has exclusive access + * to the MM shared buffer. + * + * Return: + * + * 0 on success + */ +static int __efi_runtime ffa_notify_mm_sp(void) +{ + struct ffa_interface_data func_data = {0}; + struct ffa_send_direct_data msg = {0}; + int ret; + u32 sp_event_complete; + int sp_event_ret; + + func_data.data0_size = sizeof(mm_sp_id); + func_data.data0 = &mm_sp_id; + + msg.a3 = FFA_SHARED_MM_BUFFER_ADDR; + msg.a4 = FFA_SHARED_MM_BUFFER_SIZE; + func_data.data1_size = sizeof(msg); + func_data.data1 = &msg; + + ret = ffa_helper_msg_send_direct_req(&func_data); + if (ret != FFA_ERR_STAT_SUCCESS) + return ret; + + sp_event_complete = msg.a3; + sp_event_ret = (int)msg.a4; + + if (sp_event_complete == ARM_SVC_ID_SP_EVENT_COMPLETE && sp_event_ret == MM_SUCCESS) + return 0; + + /* + * Failure to notify the MM SP + */ + + return -EACCES; +} + +/** + * ffa_discover_mm_sp_id() - Query the MM partition ID + * + * Use the FF-A driver to get the MM partition ID. + * If multiple partitions are found, use the first one. + * This is a boot time function. + * + * Return: + * + * 0 on success + */ +static int ffa_discover_mm_sp_id(void) +{ + struct ffa_interface_data func_data = {0}; + u32 count = 0; + int ret; + struct ffa_partition_info *parts_info; + + /* + * get from the driver the count of the SPs matching the UUID + */ + func_data.data0_size = sizeof(mm_sp_svc_uuid); + func_data.data0 = &mm_sp_svc_uuid; + func_data.data1_size = sizeof(count); + func_data.data1 = &count; + + ret = ffa_helper_get_partitions_info(&func_data); + if (ret != FFA_ERR_STAT_SUCCESS) { + log_err("EFI: Failure in querying partitions count (error code: %d)\n", ret); + return ret; + } + + if (!count) { + log_info("EFI: No MM partition found\n"); + return ret; + } + + /* + * pre-allocate a buffer to be filled by the driver + * with ffa_partition_info structs + */ + + parts_info = calloc(count, sizeof(struct ffa_partition_info)); + if (!parts_info) + return -EINVAL; + + log_info("EFI: Pre-allocating %d partition(s) info structures\n", count); + + func_data.data1_size = count * + sizeof(struct ffa_partition_info); + func_data.data1 = parts_info; + + /* + * ask the driver to fill the + * buffer with the SPs info + */ + ret = ffa_helper_get_partitions_info(&func_data); + if (ret != FFA_ERR_STAT_SUCCESS) { + log_err("EFI: Failure in querying partition(s) info (error code: %d)\n", ret); + free(parts_info); + return ret; + } + + /* + * MM SPs found , use the first one + */ + + mm_sp_id = parts_info[0].id; + + log_info("EFI: MM partition ID 0x%x\n", mm_sp_id); + + free(parts_info); + + return 0; +}
/** - * mm_communicate() - Adjust the cmonnucation buffer to StandAlonneMM and send + * ffa_mm_communicate() - Exchange EFI services data with the MM partition using FF-A + * @comm_buf: locally allocated communication buffer used for rx/tx + * @dsize: communication buffer size + * + * Issues a door bell event to notify the MM partition (SP) running in OP-TEE + * that there is data to read from the shared buffer. + * Communication with the MM SP is performed using FF-A transport. + * On the event, MM SP can read the data from the buffer and + * update the MM shared buffer with response data. + * The response data is copied back to the communication buffer. + * + * Return: + * + * EFI status code + */ +static efi_status_t __efi_runtime ffa_mm_communicate(void *comm_buf, ulong comm_buf_size) +{ + ulong tx_data_size; + int ffa_ret; + struct efi_mm_communicate_header *mm_hdr; + void *virt_shared_buf; + + if (!comm_buf) + return EFI_INVALID_PARAMETER; + + /* Discover MM partition ID at boot time */ + if (!mm_sp_id && ffa_discover_mm_sp_id() != FFA_ERR_STAT_SUCCESS) { + log_err("EFI: Failure to discover MM partition ID at boot time\n"); + return EFI_UNSUPPORTED; + } + + mm_hdr = (struct efi_mm_communicate_header *)comm_buf; + tx_data_size = mm_hdr->message_len + sizeof(efi_guid_t) + sizeof(size_t); + + if (comm_buf_size != tx_data_size || tx_data_size > FFA_SHARED_MM_BUFFER_SIZE) + return EFI_INVALID_PARAMETER; + + /* Copy the data to the shared buffer */ + + virt_shared_buf = (void *)map_sysmem((phys_addr_t)FFA_SHARED_MM_BUFFER_ADDR, 0); + efi_memcpy_runtime(virt_shared_buf, comm_buf, tx_data_size); + + /* + * The secure world has cache disabled for device region which we use for shared buffer. + * So, the secure world reads the data from DRAM. Let's flush the cache so the DRAM is + * updated with the latest data. + */ + #ifdef CONFIG_ARM64 + invalidate_dcache_all(); + #endif + + /* Announce there is data in the shared buffer */ + + ffa_ret = ffa_notify_mm_sp(); + if (ffa_ret) + unmap_sysmem(virt_shared_buf); + + switch (ffa_ret) { + case 0: + { + ulong rx_data_size; + /* Copy the MM SP response from the shared buffer to the communication buffer */ + rx_data_size = ((struct efi_mm_communicate_header *)virt_shared_buf)->message_len + + sizeof(efi_guid_t) + + sizeof(size_t); + + if (rx_data_size > comm_buf_size) { + efi_memcpy_runtime(comm_buf, virt_shared_buf, comm_buf_size); + unmap_sysmem(virt_shared_buf); + return EFI_BUFFER_TOO_SMALL; + } + + efi_memcpy_runtime(comm_buf, virt_shared_buf, rx_data_size); + unmap_sysmem(virt_shared_buf); + + return EFI_SUCCESS; + } + case -EINVAL: + return EFI_DEVICE_ERROR; + case -EPERM: + return EFI_INVALID_PARAMETER; + case -EACCES: + return EFI_ACCESS_DENIED; + case -EBUSY: + return EFI_OUT_OF_RESOURCES; + default: + return EFI_ACCESS_DENIED; + } +} +#endif + +/** + * mm_communicate() - Adjust the communication buffer to the MM SP and send * it to OP-TEE * - * @comm_buf: locally allocted communcation buffer + * @comm_buf: locally allocated communication buffer * @dsize: buffer size + * + * The MM SP (also called partition) can be StandAlonneMM or smm-gateway. + * The comm_buf format is the same for both partitions. + * When using the u-boot OP-TEE driver, StandAlonneMM is supported. + * When using the u-boot FF-A driver, StandAlonneMM and smm-gateway are supported. + * * Return: status code */ -static efi_status_t mm_communicate(u8 *comm_buf, efi_uintn_t dsize) +static efi_status_t __efi_runtime mm_communicate(u8 *comm_buf, efi_uintn_t dsize) { efi_status_t ret; struct efi_mm_communicate_header *mm_hdr; @@ -162,9 +432,16 @@ static efi_status_t mm_communicate(u8 *comm_buf, efi_uintn_t dsize) mm_hdr = (struct efi_mm_communicate_header *)comm_buf; var_hdr = (struct smm_variable_communicate_header *)mm_hdr->data;
+ #if (IS_ENABLED(CONFIG_OPTEE)) ret = optee_mm_communicate(comm_buf, dsize); + #elif (IS_ENABLED(CONFIG_ARM_FFA_TRANSPORT)) + ret = ffa_mm_communicate(comm_buf, dsize); + #endif if (ret != EFI_SUCCESS) { - log_err("%s failed!\n", __func__); + /* No need for showing a log here. mm_communicate failure happens + * when getVariable() is called with data size set to 0. + * This is not expected so no log shown. + */ return ret; }
@@ -258,6 +535,13 @@ efi_status_t EFIAPI get_max_payload(efi_uintn_t *size) goto out; } *size = var_payload->size; + + #if (IS_ENABLED(CONFIG_ARM_FFA_TRANSPORT)) + if (*size > FFA_SHARED_MM_BUFFER_SIZE) + *size = FFA_SHARED_MM_BUFFER_SIZE - MM_COMMUNICATE_HEADER_SIZE - + MM_VARIABLE_COMMUNICATE_SIZE; + #endif + /* * There seems to be a bug in EDK2 miscalculating the boundaries and * size checks, so deduct 2 more bytes to fulfill this requirement. Fix @@ -697,7 +981,7 @@ void efi_variables_boot_exit_notify(void) ret = EFI_NOT_FOUND;
if (ret != EFI_SUCCESS) - log_err("Unable to notify StMM for ExitBootServices\n"); + log_err("Unable to notify the MM partition for ExitBootServices\n"); free(comm_buf);
Hi Abdellatif,
Can you please keep me cc'ed in future revisions?
What I am missing from all this is a description on how to test this and what's needed in OP-TEE and EDK2.
Unless I am reading this wrong, there is a "new" Secure Partition that will handle both the efi variables (along with all the EFI rules you need to update those and the crypto checks you need for authenticated variables). But StMM includes the hardware drivers as well. How is that handled in the SP context?
- x1: 0 clean & invalidate, 1 invalidate only
- x2~x9: clobbered
- flush or invalidate all data cache by SET/WAY.
- Performs a invalidation of the entire data cache at all levels
- Defined in EDK2 as SMM_VARIABLE_COMMUNICATE_HEADER.
Why is this converted to packed?
- Defined in EDK2 as SMM_VARIABLE_COMMUNICATE_ACCESS_VARIABLE.
Ditto
- depends on OPTEE
The naming is a bit misleading imho. FF-A is the transport mechanism between the secure and non-secure world. You may as well have FF-A along with OP-TEE. That doesn't automatically mean the SP is used instead of StMM.
This code is complicated already, I don't think we want the additional ifdefery. Wouldn't it be better to have this discover to what kind of protocol (e.g FF-A vs SMC calling conventions) it talks to? SPs are discoverable, so we could reason about those as well without asking the user to understand Arm protocol internals.
endchoice
- shared buffer physical address used for communication between
- u-boot and the MM SP
Can you explain what this is used for ?
- 0xed, 0x32, 0xd5, 0x33, \
- 0x99, 0xe6, 0x42, 0x09, \
- 0x9c, 0xc0, 0x2d, 0x72, \
- 0xcd, 0xd9, 0x98, 0xa7
- /* Announce there is data in the shared buffer */
- ffa_ret = ffa_notify_mm_sp();
- if (ffa_ret)
There are several calls around on runtime code which call functions not marked as runtime. This will just crash when called.
- switch (ffa_ret) {
- case 0:
ulong rx_data_size;
sizeof(size_t);
return EFI_SUCCESS;
- case -EINVAL:
- case -EPERM:
- case -EACCES:
- case -EBUSY:
- default:
+} +#endif
- mm_communicate() - Adjust the communication buffer to the MM SP and send
- it to OP-TEE
- @comm_buf: locally allocted communcation buffer
- @comm_buf: locally allocated communication buffer
- @dsize: buffer size
- The MM SP (also called partition) can be StandAlonneMM or smm-gateway.
- The comm_buf format is the same for both partitions.
- When using the u-boot OP-TEE driver, StandAlonneMM is supported.
- When using the u-boot FF-A driver, StandAlonneMM and smm-gateway are supported.
- Return: status code
- #if (IS_ENABLED(CONFIG_OPTEE)) ret = optee_mm_communicate(comm_buf, dsize);
- #elif (IS_ENABLED(CONFIG_ARM_FFA_TRANSPORT))
- ret = ffa_mm_communicate(comm_buf, dsize);
- #endif if (ret != EFI_SUCCESS) {
It can also fail on normal cases were the size is != 0
return ret;
- #if (IS_ENABLED(CONFIG_ARM_FFA_TRANSPORT))
- #endif
- There seems to be a bug in EDK2 miscalculating the boundaries and
- size checks, so deduct 2 more bytes to fulfill this requirement. Fix
free(comm_buf);
-- 2.17.1
Thanks /Ilias
On Thu, Apr 14, 2022 at 10:54:08PM +0300, Ilias Apalodimas wrote:
Hi Abdellatif,
In the v4 patchset the MM SPs are discovered at runtime. All MM SPs have the same UUID and use the same communication protocol. From v4, FF-A MM communication in u-boot is not tied to any MM SP. Please check: https://lore.kernel.org/all/20220926101723.9965-10-abdellatif.elkhlifi@arm.c...
- x2~x9: clobbered
no need to add the attribute packed for efi_mm_communicate_header and smm_variable_communicate_header structures because all fields sizes are multiple of 8 bytes. This has been addressed in v4 patchset. However, the smm_variable_access structure still needs to be packed because attr is u32 and a 4 bytes padding is added by the compiler which breaks the communication with the secure world.
Ditto
- depends on OPTEE
From patchset v4, when using the u-boot FF-A driver all MM SPs are supported
because the agreement is that they all use the same UUID. Please check: https://lore.kernel.org/all/20220926101723.9965-10-abdellatif.elkhlifi@arm.c...
endchoice
FF-A MM communication is implemented by ffa_mm_communicate(). It allows exchanging EFI services data with the MM partition using FF-A transport. The mechanism is based on a shared buffer and a door bell event.
When u-boot wants to send data to the MM partition the data is written to the shared buffer and a door bell event is issued.
A door bell event means that there is data to read from the shared buffer.
The MM partition writes its response in the same shared buffer and u-boot reads the response from the shared buffer at ffa_mm_communicate() level.
The shared buffer address is specified by FFA_SHARED_MM_BUFFER_ADDR and should be defined by the board.
- if (ffa_ret)
This has been addressed from v2 patchset. Please refer to the latest work on v4: https://lore.kernel.org/all/20220926101723.9965-10-abdellatif.elkhlifi@arm.c...
- case 0:
ulong rx_data_size;
sizeof(size_t);
return EFI_SUCCESS;
- case -EINVAL:
- case -EPERM:
- case -EACCES:
- case -EBUSY:
- default:
+} +#endif
- it to OP-TEE
This has been addressed on v4 patchset: https://lore.kernel.org/all/20220926101723.9965-10-abdellatif.elkhlifi@arm.c...
return ret;
- #endif
free(comm_buf);
-- 2.17.1
Thanks /Ilias
Hello guys, gentle ping, any thoughts about these changes ?
This patchset adds support for Arm FF-A (Arm Firmware Framework for Armv8-A v1.0).
FF-A support is generic by design and can be used by any Arm platform.
The features added are as follows:
1/ FF-A device driver 2/ armffa command 3/ FF-A Sandbox driver 4/ FF-A Sandbox test cases 5/ FF-A MM communication
The suggested design sees FF-A as a data bus allowing data exchange with the firmware running under TrustZone HW (such as Optee). The same approach was followed in the FF-A driver in Linux kernel (https://git.kernel.org/pub/scm/linux/kernel/git/torvalds/linux.git/tree/driv...))
u-boot boards using FF-A can provide a device tree node in a <board>-u-boot.dtsi file. Since the node can not be hosted in Linux device tree, we suggest using u-boot device tree.
As a use case, we will send a commit enabling FF-A for the Corstone-1000 platform and providing the FF-A node in u-boot.dtsi files.
Corstone-1000: https://lore.kernel.org/u-boot/20220322104118.573537-1-rui.silva@linaro.org/
Abdellatif El Khlifi (6): arm_ffa: introduce Arm FF-A low-level driver arm_ffa: introduce armffa command arm_ffa: introduce the FF-A Sandbox driver arm_ffa: introduce Sandbox test cases for UCLASS_FFA arm_ffa: introduce armffa command Sandbox test arm_ffa: introduce FF-A MM communication
MAINTAINERS | 15 + arch/arm/cpu/armv8/cache.S | 16 + arch/arm/cpu/armv8/cache_v8.c | 3 +- arch/arm/cpu/armv8/smccc-call.S | 27 + arch/arm/lib/asm-offsets.c | 6 + arch/sandbox/dts/sandbox.dtsi | 10 + arch/sandbox/dts/test.dts | 10 + cmd/Kconfig | 10 + cmd/Makefile | 2 + cmd/armffa.c | 266 +++++ common/board_r.c | 7 + configs/sandbox64_defconfig | 2 + configs/sandbox_defconfig | 2 + doc/arch/sandbox.rst | 1 + drivers/Kconfig | 2 + drivers/Makefile | 1 + drivers/arm-ffa/Kconfig | 32 + drivers/arm-ffa/Makefile | 7 + drivers/arm-ffa/arm-ffa-uclass.c | 102 ++ drivers/arm-ffa/arm_ffa_prv.h | 200 ++++ drivers/arm-ffa/core.c | 1463 +++++++++++++++++++++++++ drivers/arm-ffa/sandbox.c | 735 +++++++++++++ drivers/arm-ffa/sandbox_arm_ffa_prv.h | 128 +++ include/arm_ffa.h | 197 ++++ include/arm_ffa_helper.h | 45 + include/dm/uclass-id.h | 1 + include/linux/arm-smccc.h | 28 +- include/mm_communication.h | 4 +- include/sandbox_arm_ffa.h | 31 + include/sandbox_arm_ffa_helper.h | 26 + lib/Kconfig | 1 + lib/Makefile | 1 + lib/arm-ffa/Kconfig | 6 + lib/arm-ffa/Makefile | 9 + lib/arm-ffa/arm_ffa_helper.c | 188 ++++ lib/arm-ffa/sandbox_arm_ffa_helper.c | 23 + lib/efi_loader/Kconfig | 14 +- lib/efi_loader/efi_boottime.c | 17 + lib/efi_loader/efi_variable_tee.c | 294 ++++- test/cmd/Makefile | 1 + test/cmd/armffa.c | 33 + test/cmd/armffa.h | 13 + test/dm/Makefile | 1 + test/dm/ffa.c | 424 +++++++ test/dm/ffa.h | 22 + 45 files changed, 4415 insertions(+), 11 deletions(-) create mode 100644 cmd/armffa.c create mode 100644 drivers/arm-ffa/Kconfig create mode 100644 drivers/arm-ffa/Makefile create mode 100644 drivers/arm-ffa/arm-ffa-uclass.c create mode 100644 drivers/arm-ffa/arm_ffa_prv.h create mode 100644 drivers/arm-ffa/core.c create mode 100644 drivers/arm-ffa/sandbox.c create mode 100644 drivers/arm-ffa/sandbox_arm_ffa_prv.h create mode 100644 include/arm_ffa.h create mode 100644 include/arm_ffa_helper.h create mode 100644 include/sandbox_arm_ffa.h create mode 100644 include/sandbox_arm_ffa_helper.h create mode 100644 lib/arm-ffa/Kconfig create mode 100644 lib/arm-ffa/Makefile create mode 100644 lib/arm-ffa/arm_ffa_helper.c create mode 100644 lib/arm-ffa/sandbox_arm_ffa_helper.c create mode 100644 test/cmd/armffa.c create mode 100644 test/cmd/armffa.h create mode 100644 test/dm/ffa.c create mode 100644 test/dm/ffa.h
-- 2.17.1
Why can't the node be in the upstream tree? It should be, so that it can be shared between all users. Especially since there's in-Linux users?
-- Tom
Linux already has an FF-A bus driver and doesn't use a device tree node for FF-A.
The Linux driver registers FF-A as a bus:
int arm_ffa_bus_init(void) { return bus_register(&ffa_bus_type); }
So, there is no user for the node in Linux. That's why we suggest hosting the node in the u-boot device tree (a u-boot.dtsi file)
-- Tom
OK, but you can still push it upstream as it's not required to have an in tree user.
-- Tom
-- Tom
During the review of Corstone-1000 patchset, Rui Silva had a discussion with the Linux device tree maintainer (Rob Herring). Rob is not in favour of an FFA node in the kernel device tree. This is why we are including the FFA node in u-boot device tree (u-boot.dtsi files).
-- Abdellatif
-- Tom
I'm a bit confused now, can you please link to the kernel thread? Or Rob, can you chime in here please?
-- Tom
Sigh. There is not a 'kernel device tree' and a 'u-boot device tree'. There is only 1. For SystemReadyIR compliance, that is a hard requirement.
The FFA DT binding was rejected in favor of making FFA discoverable. The FFA spec was amended to address that. DT is only for what we failed to make discoverable. For hardware, we're stuck with it. We shouldn't repeat that for software interfaces.
Rob
On Tue, Mar 29, 2022 at 04:16:53PM +0100, abdellatif.elkhlifi@arm.com wrote: > From: Abdellatif El Khlifi abdellatif.elkhlifi@arm.com > > This patchset adds support for Arm FF-A (Arm Firmware Framework for Armv8-A v1.0). > > FF-A support is generic by design and can be used by any Arm platform. > > The features added are as follows: > > 1/ FF-A device driver > 2/ armffa command > 3/ FF-A Sandbox driver > 4/ FF-A Sandbox test cases > 5/ FF-A MM communication > > > The suggested design sees FF-A as a data bus allowing data exchange with the firmware > running under TrustZone HW (such as Optee). The same approach was followed in the > FF-A driver in Linux kernel (https://git.kernel.org/pub/scm/linux/kernel/git/torvalds/linux.git/tree/driv...)) > > u-boot boards using FF-A can provide a device tree node in a <board>-u-boot.dtsi file. > Since the node can not be hosted in Linux device tree, we suggest using u-boot device tree.
-- Tom
Rob
Guys,
Since we can not add an FFA node in the device tree, we will make FFA a discoverable bus. So, we will manually create the udevice, binding it to the driver and probing it. Manually means directly calling device_bind and device_probe APIs.
Any thoughts about this approach ?
Abdellatif
On Wed, Apr 06, 2022 at 03:47:11PM -0400, Tom Rini wrote: > On Tue, Mar 29, 2022 at 04:16:53PM +0100, abdellatif.elkhlifi@arm.com wrote: > > From: Abdellatif El Khlifi abdellatif.elkhlifi@arm.com > > > > This patchset adds support for Arm FF-A (Arm Firmware Framework for Armv8-A v1.0). > > > > FF-A support is generic by design and can be used by any Arm platform. > > > > The features added are as follows: > > > > 1/ FF-A device driver > > 2/ armffa command > > 3/ FF-A Sandbox driver > > 4/ FF-A Sandbox test cases > > 5/ FF-A MM communication > > > > > > The suggested design sees FF-A as a data bus allowing data exchange with the firmware > > running under TrustZone HW (such as Optee). The same approach was followed in the > > FF-A driver in Linux kernel (https://git.kernel.org/pub/scm/linux/kernel/git/torvalds/linux.git/tree/driv...)) > > > > u-boot boards using FF-A can provide a device tree node in a <board>-u-boot.dtsi file. > > Since the node can not be hosted in Linux device tree, we suggest using u-boot device tree. > > Why can't the node be in the upstream tree? It should be, so that it > can be shared between all users. Especially since there's in-Linux > users? > > -- > Tom
Rob
Guys,
How is it both discoverable and doesn't have a device tree node, in the kernel?
I don't clearly understand your query here fully. Generally if some h/w is discoverable, then we don't need to have device node in the DT as it may result in conflicts.
In this we can query f/w to check if a particular feature is implemented or not before we initialise the FF-A bus. One we discover the partitions we add devices for each and the individual device and associated driver gets probed based on UUID.
I have neither seen the u-boot implementation nor fully understand how device/driver model differs from the kernel one to comment on details. I am happy to provide any more details if required.
-- Regards, Sudeep
1/ FF-A bus driver 2/ armffa command 3/ FF-A Sandbox driver 4/ FF-A Sandbox test cases 5/ FF-A MM communication
The suggested design considers FF-A as a discoverable bus. The Secure World is considered as one entity to communicate with using the FF-A bus. FF-A communication is handled by one device and one instance (the bus). This FF-A driver takes care of all the interactions between Normal world and Secure World.
The Secure World firmware runs under TrustZone HW (such as Optee). The same approach was followed in the FF-A driver in Linux kernel (https://git.kernel.org/pub/scm/linux/kernel/git/torvalds/linux.git/tree/driv...))
Cc: Tom Rini trini@konsulko.com Cc: Rob Herring robh@kernel.org Cc: Ilias Apalodimas ilias.apalodimas@linaro.org Cc: Achin Gupta achin.gupta@arm.com Cc: Simon Glass sjg@chromium.org Cc: Vishnu Banavath vishnu.banavath@arm.com
MAINTAINERS | 15 + arch/arm/cpu/armv8/cache.S | 16 + arch/arm/cpu/armv8/cache_v8.c | 3 +- arch/arm/cpu/armv8/smccc-call.S | 27 + arch/arm/lib/asm-offsets.c | 6 + cmd/Kconfig | 10 + cmd/Makefile | 2 + cmd/armffa.c | 266 +++++ common/board_r.c | 7 + configs/sandbox64_defconfig | 2 + configs/sandbox_defconfig | 2 + doc/arch/sandbox.rst | 1 + drivers/Kconfig | 2 + drivers/Makefile | 1 + drivers/arm-ffa/Kconfig | 34 + drivers/arm-ffa/Makefile | 7 + drivers/arm-ffa/arm-ffa-uclass.c | 103 ++ drivers/arm-ffa/arm_ffa_prv.h | 193 ++++ drivers/arm-ffa/core.c | 1384 +++++++++++++++++++++++++ drivers/arm-ffa/sandbox.c | 669 ++++++++++++ drivers/arm-ffa/sandbox_arm_ffa_prv.h | 131 +++ include/arm_ffa.h | 197 ++++ include/arm_ffa_helper.h | 45 + include/dm/uclass-id.h | 1 + include/linux/arm-smccc.h | 28 +- include/mm_communication.h | 4 +- include/sandbox_arm_ffa.h | 31 + include/sandbox_arm_ffa_helper.h | 26 + lib/Kconfig | 1 + lib/Makefile | 1 + lib/arm-ffa/Kconfig | 6 + lib/arm-ffa/Makefile | 9 + lib/arm-ffa/arm_ffa_helper.c | 188 ++++ lib/arm-ffa/sandbox_arm_ffa_helper.c | 23 + lib/efi_loader/Kconfig | 14 +- lib/efi_loader/efi_boottime.c | 17 + lib/efi_loader/efi_variable_tee.c | 281 ++++- test/cmd/Makefile | 1 + test/cmd/armffa.c | 33 + test/cmd/armffa.h | 13 + test/dm/Makefile | 1 + test/dm/ffa.c | 418 ++++++++ test/dm/ffa.h | 22 + 43 files changed, 4230 insertions(+), 11 deletions(-) create mode 100644 cmd/armffa.c create mode 100644 drivers/arm-ffa/Kconfig create mode 100644 drivers/arm-ffa/Makefile create mode 100644 drivers/arm-ffa/arm-ffa-uclass.c create mode 100644 drivers/arm-ffa/arm_ffa_prv.h create mode 100644 drivers/arm-ffa/core.c create mode 100644 drivers/arm-ffa/sandbox.c create mode 100644 drivers/arm-ffa/sandbox_arm_ffa_prv.h create mode 100644 include/arm_ffa.h create mode 100644 include/arm_ffa_helper.h create mode 100644 include/sandbox_arm_ffa.h create mode 100644 include/sandbox_arm_ffa_helper.h create mode 100644 lib/arm-ffa/Kconfig create mode 100644 lib/arm-ffa/Makefile create mode 100644 lib/arm-ffa/arm_ffa_helper.c create mode 100644 lib/arm-ffa/sandbox_arm_ffa_helper.c create mode 100644 test/cmd/armffa.c create mode 100644 test/cmd/armffa.h create mode 100644 test/dm/ffa.c create mode 100644 test/dm/ffa.h
Add the driver implementing Arm Firmware Framework for Armv8-A v1.0
The Firmware Framework for Arm A-profile processors (FF-A) describes interfaces (ABIs) that standardize communication between the Secure World and Normal World leveraging TrustZone technology. This driver uses SMC32 calling convention.
In u-boot FF-A design, FF-A is considered as a discoverable bus. The Secure World is considered as one entity to communicate with using the FF-A bus. FF-A communication is handled by one device and one instance (the bus). This FF-A driver takes care of all the interactions between Normal world and Secure World.
The driver provides helper FF-A interfaces for user layers. These helper functions allow clients to pass data and select the FF-A function to use for the communication with secure world.
Signed-off-by: Abdellatif El Khlifi abdellatif.elkhlifi@arm.com --- MAINTAINERS | 8 + arch/arm/cpu/armv8/smccc-call.S | 27 + arch/arm/lib/asm-offsets.c | 6 + common/board_r.c | 7 + drivers/Kconfig | 2 + drivers/Makefile | 1 + drivers/arm-ffa/Kconfig | 27 + drivers/arm-ffa/Makefile | 6 + drivers/arm-ffa/arm-ffa-uclass.c | 64 ++ drivers/arm-ffa/arm_ffa_prv.h | 193 +++++ drivers/arm-ffa/core.c | 1349 ++++++++++++++++++++++++++++++ include/arm_ffa.h | 190 +++++ include/arm_ffa_helper.h | 45 + include/dm/uclass-id.h | 1 + include/linux/arm-smccc.h | 28 +- lib/Kconfig | 1 + lib/Makefile | 1 + lib/arm-ffa/Kconfig | 6 + lib/arm-ffa/Makefile | 8 + lib/arm-ffa/arm_ffa_helper.c | 188 +++++ lib/efi_loader/efi_boottime.c | 17 + 21 files changed, 2174 insertions(+), 1 deletion(-) create mode 100644 drivers/arm-ffa/Kconfig create mode 100644 drivers/arm-ffa/Makefile create mode 100644 drivers/arm-ffa/arm-ffa-uclass.c create mode 100644 drivers/arm-ffa/arm_ffa_prv.h create mode 100644 drivers/arm-ffa/core.c create mode 100644 include/arm_ffa.h create mode 100644 include/arm_ffa_helper.h create mode 100644 lib/arm-ffa/Kconfig create mode 100644 lib/arm-ffa/Makefile create mode 100644 lib/arm-ffa/arm_ffa_helper.c
diff --git a/MAINTAINERS b/MAINTAINERS index aca97cd2a3..efa17206b8 100644 --- a/MAINTAINERS +++ b/MAINTAINERS @@ -232,6 +232,14 @@ F: board/CZ.NIC/ F: configs/turris_*_defconfig F: include/configs/turris_*.h
+ARM FF-A +M: Abdellatif El Khlifi abdellatif.elkhlifi@arm.com +S: Maintained +F: drivers/arm-ffa/ +F: include/arm_ffa.h +F: include/arm_ffa_helper.h +F: lib/arm-ffa/ + ARM FREESCALE IMX M: Stefano Babic sbabic@denx.de M: Fabio Estevam festevam@gmail.com diff --git a/arch/arm/cpu/armv8/smccc-call.S b/arch/arm/cpu/armv8/smccc-call.S index dc92b28777..9a6aebf194 100644 --- a/arch/arm/cpu/armv8/smccc-call.S +++ b/arch/arm/cpu/armv8/smccc-call.S @@ -1,6 +1,8 @@ /* SPDX-License-Identifier: GPL-2.0 */ /* * Copyright (c) 2015, Linaro Limited + * (C) Copyright 2022 ARM Limited + * Abdellatif El Khlifi abdellatif.elkhlifi@arm.com */ #include <linux/linkage.h> #include <linux/arm-smccc.h> @@ -45,3 +47,28 @@ ENDPROC(__arm_smccc_smc) ENTRY(__arm_smccc_hvc) SMCCC hvc ENDPROC(__arm_smccc_hvc) + +#if (IS_ENABLED(CONFIG_ARM_FFA_TRANSPORT)) + + .macro FFASMCCC instr + .cfi_startproc + \instr #0 + ldr x9, [sp] + stp x0, x1, [x9, #ARM_SMCCC_RES_X0_OFFS] + stp x2, x3, [x9, #ARM_SMCCC_RES_X2_OFFS] + stp x4, x5, [x9, #ARM_SMCCC_RES_X4_OFFS] + stp x6, x7, [x9, #ARM_SMCCC_RES_X6_OFFS] + ret + .cfi_endproc + .endm + +/* + * void arm_ffa_smccc_smc(unsigned long a0, unsigned long a1, unsigned long a2, + * unsigned long a3, unsigned long a4, unsigned long a5, + * unsigned long a6, unsigned long a7, struct arm_smccc_res *res) + */ +ENTRY(__arm_ffa_smccc_smc) + FFASMCCC smc +ENDPROC(__arm_ffa_smccc_smc) + +#endif diff --git a/arch/arm/lib/asm-offsets.c b/arch/arm/lib/asm-offsets.c index 22fd541f9a..02a4a42fe6 100644 --- a/arch/arm/lib/asm-offsets.c +++ b/arch/arm/lib/asm-offsets.c @@ -9,6 +9,8 @@ * generate asm statements containing #defines, * compile this file to assembler, and then extract the * #defines from the assembly-language output. + * + * (C) Copyright 2022 ARM Limited */
#include <common.h> @@ -115,6 +117,10 @@ int main(void) #ifdef CONFIG_ARM_SMCCC DEFINE(ARM_SMCCC_RES_X0_OFFS, offsetof(struct arm_smccc_res, a0)); DEFINE(ARM_SMCCC_RES_X2_OFFS, offsetof(struct arm_smccc_res, a2)); +#if (IS_ENABLED(CONFIG_ARM_FFA_TRANSPORT)) + DEFINE(ARM_SMCCC_RES_X4_OFFS, offsetof(struct arm_smccc_res, a4)); + DEFINE(ARM_SMCCC_RES_X6_OFFS, offsetof(struct arm_smccc_res, a6)); +#endif DEFINE(ARM_SMCCC_QUIRK_ID_OFFS, offsetof(struct arm_smccc_quirk, id)); DEFINE(ARM_SMCCC_QUIRK_STATE_OFFS, offsetof(struct arm_smccc_quirk, state)); #endif diff --git a/common/board_r.c b/common/board_r.c index b92c1bb0be..bb5f1d0aa6 100644 --- a/common/board_r.c +++ b/common/board_r.c @@ -62,6 +62,10 @@ #include <asm-generic/gpio.h> #include <efi_loader.h>
+#ifdef CONFIG_ARM_FFA_TRANSPORT +#include <arm_ffa_helper.h> +#endif + DECLARE_GLOBAL_DATA_PTR;
ulong monitor_flash_len; @@ -771,6 +775,9 @@ static init_fnc_t init_sequence_r[] = { INIT_FUNC_WATCHDOG_RESET initr_net, #endif +#ifdef CONFIG_ARM_FFA_TRANSPORT + ffa_helper_bus_discover, +#endif #ifdef CONFIG_POST initr_post, #endif diff --git a/drivers/Kconfig b/drivers/Kconfig index b26ca8cf70..e83c23789d 100644 --- a/drivers/Kconfig +++ b/drivers/Kconfig @@ -6,6 +6,8 @@ source "drivers/core/Kconfig"
source "drivers/adc/Kconfig"
+source "drivers/arm-ffa/Kconfig" + source "drivers/ata/Kconfig"
source "drivers/axi/Kconfig" diff --git a/drivers/Makefile b/drivers/Makefile index 4e7cf28440..6671d2a604 100644 --- a/drivers/Makefile +++ b/drivers/Makefile @@ -107,6 +107,7 @@ obj-y += iommu/ obj-y += smem/ obj-y += thermal/ obj-$(CONFIG_TEE) += tee/ +obj-$(CONFIG_ARM_FFA_TRANSPORT) += arm-ffa/ obj-y += axi/ obj-y += ufs/ obj-$(CONFIG_W1) += w1/ diff --git a/drivers/arm-ffa/Kconfig b/drivers/arm-ffa/Kconfig new file mode 100644 index 0000000000..23815534c4 --- /dev/null +++ b/drivers/arm-ffa/Kconfig @@ -0,0 +1,27 @@ +# SPDX-License-Identifier: GPL-2.0 + +config ARM_FFA_TRANSPORT + bool "Enable Arm Firmware Framework for Armv8-A driver" + depends on DM && ARM64 + select ARM_SMCCC if ARM64 + select LIB_UUID + select ARM_FFA_TRANSPORT_HELPERS + help + The Firmware Framework for Arm A-profile processors (FF-A) + describes interfaces (ABIs) that standardize communication + between the Secure World and Normal World leveraging TrustZone + technology. + + This driver is based on FF-A specification v1.0 and uses SMC32 + calling convention. + + FF-A specification: + + https://developer.arm.com/documentation/den0077/a/?lang=en + + In u-boot FF-A design, FF-A is considered as a discoverable bus. + The Secure World is considered as one entity to communicate with + using the FF-A bus. + FF-A communication is handled by one device and one instance (the bus). + This FF-A driver takes care of all the interactions between Normal world + and Secure World. diff --git a/drivers/arm-ffa/Makefile b/drivers/arm-ffa/Makefile new file mode 100644 index 0000000000..7bc9a336a9 --- /dev/null +++ b/drivers/arm-ffa/Makefile @@ -0,0 +1,6 @@ +# SPDX-License-Identifier: GPL-2.0+ +# +# (C) Copyright 2022 Abdellatif El Khlifi abdellatif.elkhlifi@arm.com +# + +obj-y += arm-ffa-uclass.o core.o diff --git a/drivers/arm-ffa/arm-ffa-uclass.c b/drivers/arm-ffa/arm-ffa-uclass.c new file mode 100644 index 0000000000..2439f87586 --- /dev/null +++ b/drivers/arm-ffa/arm-ffa-uclass.c @@ -0,0 +1,64 @@ +// SPDX-License-Identifier: GPL-2.0+ +/* + * (C) Copyright 2022 ARM Limited + * Abdellatif El Khlifi abdellatif.elkhlifi@arm.com + */ + +#include <common.h> +#include <dm.h> +#include <arm_ffa.h> +#include <errno.h> +#include <log.h> +#include <asm/global_data.h> + +DECLARE_GLOBAL_DATA_PTR; + +UCLASS_DRIVER(ffa) = { + .name = "ffa", + .id = UCLASS_FFA, +}; + +/** + * ffa_get_invoke_func - performs a call to the FF-A driver dispatcher + * @func_id: The FF-A function to be used + * @func_data: Pointer to the FF-A function arguments + * container structure. This also includes + * pointers to the returned data needed by + * clients. + * + * This runtime function passes the FF-A function ID and its arguments to + * the FF-A driver dispatcher. + * This function is called by the FF-A helper functions. + * + * Return: + * + * FFA_ERR_STAT_SUCCESS on success. Otherwise, failure + */ +int __ffa_runtime ffa_get_invoke_func(u32 func_id, struct ffa_interface_data *func_data) +{ + if (!ffa_device_get_ops()->invoke_func) + return -EINVAL; + + return ffa_device_get_ops()->invoke_func(func_id, func_data); +} + +/** + * ffa_bus_discover - discover FF-A bus and probe the arm_ffa device + * + * This boot time function makes sure the FF-A bus is discoverable. + * Then, the arm_ffa device is probed and ready to use. + * This function is called automatically at initcalls + * level (after u-boot relocation). + * + * Arm FF-A transport is implemented through arm_ffa u-boot device managing the FF-A + * communication. + * All FF-A clients should use the arm_ffa device to use the FF-A transport. + * + * Return: + * + * FFA_ERR_STAT_SUCCESS on success. Otherwise, failure + */ +int ffa_bus_discover(void) +{ + return ffa_get_device(); +} diff --git a/drivers/arm-ffa/arm_ffa_prv.h b/drivers/arm-ffa/arm_ffa_prv.h new file mode 100644 index 0000000000..44f258addb --- /dev/null +++ b/drivers/arm-ffa/arm_ffa_prv.h @@ -0,0 +1,193 @@ +/* SPDX-License-Identifier: GPL-2.0+ */ +/* + * (C) Copyright 2022 ARM Limited + * Abdellatif El Khlifi abdellatif.elkhlifi@arm.com + */ + +#ifndef __ARM_FFA_PRV_H +#define __ARM_FFA_PRV_H + +#include <arm_ffa.h> +#include <linux/bitfield.h> +#include <linux/bitops.h> +#include <dm/read.h> + +/* + * This header is private. It is exclusively used by the FF-A driver + */ + +/* FF-A core driver name */ +#define FFA_DRV_NAME "arm_ffa" + +/* FF-A driver version definitions */ + +#define MAJOR_VERSION_MASK GENMASK(30, 16) +#define MINOR_VERSION_MASK GENMASK(15, 0) +#define GET_FFA_MAJOR_VERSION(x) \ + ((u16)(FIELD_GET(MAJOR_VERSION_MASK, (x)))) +#define GET_FFA_MINOR_VERSION(x) \ + ((u16)(FIELD_GET(MINOR_VERSION_MASK, (x)))) +#define PACK_VERSION_INFO(major, minor) \ + (FIELD_PREP(MAJOR_VERSION_MASK, (major)) | \ + FIELD_PREP(MINOR_VERSION_MASK, (minor))) + +#define FFA_MAJOR_VERSION (1) +#define FFA_MINOR_VERSION (0) +#define FFA_VERSION_1_0 \ + PACK_VERSION_INFO(FFA_MAJOR_VERSION, FFA_MINOR_VERSION) + +/* Endpoint ID mask (u-boot endpoint ID) */ + +#define GET_SELF_ENDPOINT_ID_MASK GENMASK(15, 0) +#define GET_SELF_ENDPOINT_ID(x) \ + ((u16)(FIELD_GET(GET_SELF_ENDPOINT_ID_MASK, (x)))) + +#define PREP_SELF_ENDPOINT_ID_MASK GENMASK(31, 16) +#define PREP_SELF_ENDPOINT_ID(x) \ + (FIELD_PREP(PREP_SELF_ENDPOINT_ID_MASK, (x))) + +/* Partition endpoint ID mask (partition with which u-boot communicates with) */ + +#define PREP_PART_ENDPOINT_ID_MASK GENMASK(15, 0) +#define PREP_PART_ENDPOINT_ID(x) \ + (FIELD_PREP(PREP_PART_ENDPOINT_ID_MASK, (x))) + +/* The FF-A SMC function prototype definition */ + +typedef void (*invoke_ffa_fn_t)(unsigned long a0, unsigned long a1, + unsigned long a2, unsigned long a3, unsigned long a4, + unsigned long a5, unsigned long a6, unsigned long a7, + struct arm_smccc_res *res); + +/** + * enum ffa_conduit - Arm FF-A conduits supported by the Arm FF-A driver + * Currently only SMC32 is supported. + */ +enum ffa_conduit { + FFA_CONDUIT_SMC = 0, +}; + +/** + * FFA_DECLARE_ARGS - FF-A functions local variables + * @a0-a7: local variables used to set registers x0-x7 + * @res: the structure hosting the FF-A function return data + * + * A helper macro for declaring local variables for the FF-A functions arguments. + * The x0-x7 registers are used to exchange data with the secure world. + * But, only the bottom 32-bit of thes registers contains the data. + */ +#define FFA_DECLARE_ARGS \ + unsigned long a0 = 0; \ + unsigned long a1 = 0; \ + unsigned long a2 = 0; \ + unsigned long a3 = 0; \ + unsigned long a4 = 0; \ + unsigned long a5 = 0; \ + unsigned long a6 = 0; \ + unsigned long a7 = 0; \ + struct arm_smccc_res res = {0} + +/* FF-A error codes */ +#define FFA_ERR_STAT_NOT_SUPPORTED (-1) +#define FFA_ERR_STAT_INVALID_PARAMETERS (-2) +#define FFA_ERR_STAT_NO_MEMORY (-3) +#define FFA_ERR_STAT_BUSY (-4) +#define FFA_ERR_STAT_INTERRUPTED (-5) +#define FFA_ERR_STAT_DENIED (-6) +#define FFA_ERR_STAT_RETRY (-7) +#define FFA_ERR_STAT_ABORTED (-8) + +/** + * struct ffa_features_desc - FF-A functions features + * @func_id: FF-A function + * @field1: features read from register w2 + * @field2: features read from register w3 + * + * Data structure describing the features of the FF-A functions queried by + * FFA_FEATURES + */ +struct ffa_features_desc { + u32 func_id; + u32 field1; + u32 field2; +}; + +/** + * enum ffa_rxtx_buf_sizes - minimum sizes supported + * for the RX/TX buffers + */ +enum ffa_rxtx_buf_sizes { + RXTX_4K, + RXTX_64K, + RXTX_16K +}; + +/* + * Number of the FF-A interfaces features descriptors + * currently only FFA_RXTX_MAP descriptor is supported + */ +#define FFA_FEATURE_DESC_CNT (1) + +/** + * struct ffa_rxtxpair - structure hosting the RX/TX buffers virtual addresses + * @rxbuf: virtual address of the RX buffer + * @txbuf: virtual address of the TX buffer + * + * Data structure hosting the virtual addresses of the mapped RX/TX buffers + * These addresses are used by the FF-A functions that use the RX/TX buffers + */ +struct ffa_rxtxpair { + u64 rxbuf; /* virtual address */ + u64 txbuf; /* virtual address */ +}; + +/** + * struct ffa_partition_desc - the secure partition descriptor + * @info: partition information + * @UUID: UUID + * + * Each partition has its descriptor containing the partitions information and the UUID + */ +struct ffa_partition_desc { + struct ffa_partition_info info; + union ffa_partition_uuid UUID; +}; + +/** + * struct ffa_partitions - descriptors for all secure partitions + * @count: The number of partitions descriptors + * @descs The partitions descriptors table + * + * This data structure contains the partitions descriptors table + */ +struct ffa_partitions { + u32 count; + struct ffa_partition_desc *descs; /* virtual address */ +}; + +/** + * struct ffa_prvdata - the driver private data structure + * + * @dev: The arm_ffa device under u-boot driver model + * @fwk_version: FF-A framework version + * @id: u-boot endpoint ID + * @partitions: The partitions descriptors structure + * @pair: The RX/TX buffers pair + * @conduit: The selected conduit + * @invoke_ffa_fn: The function executing the FF-A function + * @features: Table of the FF-A functions having features + * + * The driver data structure hosting all resident data. + */ +struct ffa_prvdata { + struct udevice *dev; + u32 fwk_version; + u16 id; + struct ffa_partitions partitions; + struct ffa_rxtxpair pair; + enum ffa_conduit conduit; + invoke_ffa_fn_t invoke_ffa_fn; + struct ffa_features_desc features[FFA_FEATURE_DESC_CNT]; +}; + +#endif diff --git a/drivers/arm-ffa/core.c b/drivers/arm-ffa/core.c new file mode 100644 index 0000000000..09e4eb753a --- /dev/null +++ b/drivers/arm-ffa/core.c @@ -0,0 +1,1349 @@ +// SPDX-License-Identifier: GPL-2.0+ +/* + * (C) Copyright 2022 ARM Limited + * Abdellatif El Khlifi abdellatif.elkhlifi@arm.com + */ + +#include "arm_ffa_prv.h" +#include <asm/global_data.h> +#include <asm/io.h> +#include <common.h> +#include <dm.h> +#include <dm/device-internal.h> +#include <dm/root.h> +#include <linux/errno.h> +#include <linux/sizes.h> +#include <log.h> +#include <malloc.h> +#include <mapmem.h> +#include <string.h> + +DECLARE_GLOBAL_DATA_PTR; + +/** + * The device private data structure containing all the resident + * data read from secure world + */ +struct ffa_prvdata __ffa_runtime_data ffa_priv_data = {0}; + +/* + * Driver functions + */ + +/** + * ffa_get_device - create, bind and probe the arm_ffa device + * + * This boot time function makes sure the arm_ffa device is + * created, bound to this driver, probed and ready to use. + * Arm FF-A transport is implemented through a single u-boot + * device managing the FF-A bus (arm_ffa). + * + * Return: + * + * FFA_ERR_STAT_SUCCESS on success. Otherwise, failure + */ +int ffa_get_device(void) +{ + int ret; + + if (ffa_priv_data.dev) + return FFA_ERR_STAT_SUCCESS; + + ret = device_bind(dm_root(), + DM_DRIVER_GET(arm_ffa), + FFA_DRV_NAME, + NULL, + ofnode_null(), + &ffa_priv_data.dev); + if (ret) { + ffa_priv_data.dev = NULL; + return ret; + } + + /* The FF-A bus discovery succeeds when probing is successful */ + ret = device_probe(ffa_priv_data.dev); + if (ret) { + ffa_err("can not probe the device"); + device_unbind(ffa_priv_data.dev); + ffa_priv_data.dev = NULL; + return ret; + } + + return FFA_ERR_STAT_SUCCESS; +} + +/** + * ffa_get_version - FFA_VERSION handler function + * + * This is the boot time function that implements FFA_VERSION FF-A function + * to get from the secure world the FF-A framework version + * + * Return: + * + * FFA_ERR_STAT_SUCCESS on success. Otherwise, failure + */ +static int ffa_get_version(void) +{ + u16 major, minor; + + FFA_DECLARE_ARGS; + + if (!ffa_priv_data.invoke_ffa_fn) + panic("[FFA] no private data found\n"); + + a0 = FFA_VERSION; + a1 = FFA_VERSION_1_0; + ffa_priv_data.invoke_ffa_fn(a0, a1, a2, a3, a4, a5, a6, a7, &res); + + if (res.a0 == FFA_ERR_STAT_NOT_SUPPORTED) { + ffa_err("A Firmware Framework implementation does not exist"); + return -EOPNOTSUPP; + } + + major = GET_FFA_MAJOR_VERSION(res.a0); + minor = GET_FFA_MINOR_VERSION(res.a0); + + ffa_info("FF-A driver %d.%d\nFF-A framework %d.%d", + FFA_MAJOR_VERSION, FFA_MINOR_VERSION, major, minor); + + if ((major == FFA_MAJOR_VERSION && minor >= FFA_MINOR_VERSION)) { + ffa_info("Versions are compatible "); + + ffa_priv_data.fwk_version = res.a0; + + return FFA_ERR_STAT_SUCCESS; + } + + ffa_info("Versions are incompatible "); + return -EPROTONOSUPPORT; +} + +/** + * ffa_get_endpoint_id - FFA_ID_GET handler function + * + * This is the boot time function that implements FFA_ID_GET FF-A function + * to get from the secure world u-boot endpoint ID + * + * Return: + * + * FFA_ERR_STAT_SUCCESS on success. Otherwise, failure + */ +static int ffa_get_endpoint_id(void) +{ + FFA_DECLARE_ARGS; + + if (!ffa_priv_data.invoke_ffa_fn) + panic("[FFA] no private data found\n"); + + a0 = FFA_ID_GET; + + ffa_priv_data.invoke_ffa_fn(a0, a1, a2, a3, a4, a5, a6, a7, &res); + + switch (res.a0) { + case FFA_ERROR: + { + if (((int)res.a2) == FFA_ERR_STAT_NOT_SUPPORTED) { + ffa_err("This function is not implemented at this FF-A instance"); + return -EOPNOTSUPP; + } + + ffa_err("Undefined error code (%d)", ((int)res.a2)); + return -EINVAL; + } + case FFA_SUCCESS: + { + ffa_priv_data.id = GET_SELF_ENDPOINT_ID(res.a2); + ffa_info("endpoint ID is %u", ffa_priv_data.id); + + return FFA_ERR_STAT_SUCCESS; + } + default: + { + ffa_err("Undefined response function (0x%lx)", res.a0); + return -EINVAL; + } + } +} + +/** + * ffa_get_features_desc - returns the features descriptor of the specified + * FF-A function + * @func_id: the FF-A function which the features are to be retrieved + * + * This is a boot time function that searches the features descriptor of the + * specified FF-A function + * + * Return: + * + * When found, the address of the features descriptor is returned. Otherwise, NULL. + */ +static struct ffa_features_desc *ffa_get_features_desc(u32 func_id) +{ + u32 desc_idx; + + /* + * search for the descriptor of the selected FF-A interface + */ + for (desc_idx = 0; desc_idx < FFA_FEATURE_DESC_CNT ; desc_idx++) + if (ffa_priv_data.features[desc_idx].func_id == func_id) + return &ffa_priv_data.features[desc_idx]; + + return NULL; +} + +/** + * ffa_get_rxtx_map_features - FFA_FEATURES handler function with FFA_RXTX_MAP + * argument + * + * This is the boot time function that implements FFA_FEATURES FF-A function + * to retrieve the FFA_RXTX_MAP features + * + * Return: + * + * FFA_ERR_STAT_SUCCESS on success. Otherwise, failure + */ +static int ffa_get_rxtx_map_features(void) +{ + FFA_DECLARE_ARGS; + + if (!ffa_priv_data.invoke_ffa_fn) + panic("[FFA] no private data found\n"); + + a0 = FFA_FEATURES; + a1 = FFA_RXTX_MAP; + + ffa_priv_data.invoke_ffa_fn(a0, a1, a2, a3, a4, a5, a6, a7, &res); + + switch (res.a0) { + case FFA_ERROR: + { + if (((int)res.a2) == FFA_ERR_STAT_NOT_SUPPORTED) { + ffa_err("FFA_RXTX_MAP is not implemented at this FF-A instance"); + return -EOPNOTSUPP; + } + + ffa_err("Undefined error code (%d)", ((int)res.a2)); + return -EINVAL; + } + case FFA_SUCCESS: + { + u32 desc_idx; + + /* + * search for an empty descriptor + */ + for (desc_idx = 0; desc_idx < FFA_FEATURE_DESC_CNT ; desc_idx++) + if (!ffa_priv_data.features[desc_idx].func_id) { + /* + * populate the descriptor with + * the interface features data + */ + ffa_priv_data.features[desc_idx].func_id = + FFA_RXTX_MAP; + ffa_priv_data.features[desc_idx].field1 = + res.a2; + + ffa_info("FFA_RXTX_MAP features data 0x%lx", + res.a2); + + return FFA_ERR_STAT_SUCCESS; + } + + ffa_err("Cannot save FFA_RXTX_MAP features data. Descriptors table full"); + return -ENOBUFS; + } + default: + { + ffa_err("Undefined response function (0x%lx)", + res.a0); + return -EINVAL; + } + } +} + +/** + * ffa_get_rxtx_buffers_pages_cnt - reads from the features data descriptors + * the minimum number of pages in each of the RX/TX + * buffers + * @buf_4k_pages: Pointer to the minimum number of pages + * + * This is the boot time function that returns the minimum number of pages + * in each of the RX/TX buffers + * + * Return: + * + * buf_4k_pages points to the returned number of pages + * FFA_ERR_STAT_SUCCESS on success. Otherwise, failure + */ +static int ffa_get_rxtx_buffers_pages_cnt(size_t *buf_4k_pages) +{ + struct ffa_features_desc *desc = NULL; + + if (!buf_4k_pages) + return -EINVAL; + + desc = ffa_get_features_desc(FFA_RXTX_MAP); + if (!desc) + return -EINVAL; + + switch (desc->field1) { + case RXTX_4K: + *buf_4k_pages = 1; + break; + case RXTX_16K: + *buf_4k_pages = 4; + break; + case RXTX_64K: + *buf_4k_pages = 16; + break; + default: + ffa_err("RX/TX buffer size not supported"); + return -EINVAL; + } + + return FFA_ERR_STAT_SUCCESS; +} + +/** + * ffa_free_rxtx_buffers - frees the RX/TX buffers + * @buf_4k_pages: the minimum number of pages in each of the RX/TX + * buffers + * + * This is the boot time function used to free the RX/TX buffers + * + * Return: + * + * FFA_ERR_STAT_SUCCESS on success. Otherwise, failure + */ +static int ffa_free_rxtx_buffers(size_t buf_4k_pages) +{ + efi_status_t free_rxbuf_ret, free_txbuf_ret; + + ffa_info("Freeing RX/TX buffers"); + + free_rxbuf_ret = efi_free_pages(ffa_priv_data.pair.rxbuf, buf_4k_pages); + free_txbuf_ret = efi_free_pages(ffa_priv_data.pair.txbuf, buf_4k_pages); + + if (free_rxbuf_ret != EFI_SUCCESS || free_txbuf_ret != EFI_SUCCESS) { + ffa_err("Failed to free RX/TX buffers (rx: %lu , tx: %lu)", + free_rxbuf_ret, + free_txbuf_ret); + return -EINVAL; + } + + ffa_priv_data.pair.rxbuf = 0; + ffa_priv_data.pair.txbuf = 0; + + return FFA_ERR_STAT_SUCCESS; +} + +/** + * ffa_alloc_rxtx_buffers - allocates the RX/TX buffers + * @buf_4k_pages: the minimum number of pages in each of the RX/TX + * buffers + * + * This is the boot time function used by ffa_map_rxtx_buffers to allocate + * the RX/TX buffers before mapping them + * + * Return: + * + * FFA_ERR_STAT_SUCCESS on success. Otherwise, failure + */ +static int ffa_alloc_rxtx_buffers(size_t buf_4k_pages) +{ +#if CONFIG_IS_ENABLED(EFI_LOADER) + + efi_status_t efi_ret; + void *virt_txbuf; + void *virt_rxbuf; + + ffa_info("Using %lu 4KB page(s) for RX/TX buffers size", + buf_4k_pages); + + efi_ret = efi_allocate_pages(EFI_ALLOCATE_ANY_PAGES, + EFI_BOOT_SERVICES_DATA, + buf_4k_pages, + &ffa_priv_data.pair.rxbuf); + + if (efi_ret != EFI_SUCCESS) { + ffa_priv_data.pair.rxbuf = 0; + ffa_err("Failure to allocate RX buffer (EFI error: 0x%lx)", + efi_ret); + + return -ENOBUFS; + } + + ffa_info("RX buffer at virtual address 0x%llx", + ffa_priv_data.pair.rxbuf); + + virt_rxbuf = (void *)ffa_priv_data.pair.rxbuf; + + /* + * make sure the buffer is clean before use + */ + memset(virt_rxbuf, 0, buf_4k_pages * SZ_4K); + + efi_ret = efi_allocate_pages(EFI_ALLOCATE_ANY_PAGES, + EFI_RUNTIME_SERVICES_DATA, + buf_4k_pages, + &ffa_priv_data.pair.txbuf); + + if (efi_ret != EFI_SUCCESS) { + efi_free_pages(ffa_priv_data.pair.rxbuf, buf_4k_pages); + ffa_priv_data.pair.rxbuf = 0; + ffa_priv_data.pair.txbuf = 0; + ffa_err("Failure to allocate the TX buffer (EFI error: 0x%lx)" + , efi_ret); + + return -ENOBUFS; + } + + ffa_info("TX buffer at virtual address 0x%llx", + ffa_priv_data.pair.txbuf); + + virt_txbuf = (void *)ffa_priv_data.pair.txbuf; + + /* + * make sure the buffer is clean before use + */ + memset(virt_txbuf, 0, buf_4k_pages * SZ_4K); + + return FFA_ERR_STAT_SUCCESS; + +#else + return -ENOBUFS; +#endif +} + +/** + * ffa_map_rxtx_buffers - FFA_RXTX_MAP handler function + * @buf_4k_pages: the minimum number of pages in each of the RX/TX + * buffers + * + * This is the boot time function that implements FFA_RXTX_MAP FF-A function + * to map the RX/TX buffers + * + * Return: + * + * FFA_ERR_STAT_SUCCESS on success. Otherwise, failure + */ +static int ffa_map_rxtx_buffers(size_t buf_4k_pages) +{ + int ret; + + FFA_DECLARE_ARGS; + + if (!ffa_priv_data.invoke_ffa_fn) + panic("[FFA] no private data found\n"); + + ret = ffa_alloc_rxtx_buffers(buf_4k_pages); + if (ret != FFA_ERR_STAT_SUCCESS) + return ret; + + a0 = FFA_RXTX_MAP; + a1 = ffa_priv_data.pair.txbuf; + a2 = ffa_priv_data.pair.rxbuf; + a3 = buf_4k_pages; + + ffa_priv_data.invoke_ffa_fn(a0, a1, a2, a3, a4, a5, a6, a7, &res); + + switch (res.a0) { + case FFA_ERROR: + { + switch (((int)res.a2)) { + case FFA_ERR_STAT_INVALID_PARAMETERS: + ffa_err("One or more fields in input parameters is incorrectly encoded"); + ret = -EPERM; + break; + case FFA_ERR_STAT_NO_MEMORY: + ffa_err("Not enough memory"); + ret = -ENOMEM; + break; + case FFA_ERR_STAT_DENIED: + ffa_err("Buffer pair already registered"); + ret = -EACCES; + break; + case FFA_ERR_STAT_NOT_SUPPORTED: + ffa_err("This function is not implemented at this FF-A instance"); + ret = -EOPNOTSUPP; + break; + default: + ffa_err("Undefined error (%d)", + ((int)res.a2)); + ret = -EINVAL; + } + break; + } + case FFA_SUCCESS: + ffa_info("RX/TX buffers mapped"); + return FFA_ERR_STAT_SUCCESS; + default: + ffa_err("Undefined response function (0x%lx)", + res.a0); + ret = -EINVAL; + } + + ffa_free_rxtx_buffers(buf_4k_pages); + + return ret; +} + +/** + * ffa_unmap_rxtx_buffers - FFA_RXTX_UNMAP handler function + * + * This is the boot time function that implements FFA_RXTX_UNMAP FF-A function + * to unmap the RX/TX buffers + * + * Return: + * + * FFA_ERR_STAT_SUCCESS on success. Otherwise, failure + */ +static int ffa_unmap_rxtx_buffers(void) +{ + FFA_DECLARE_ARGS; + + if (!ffa_priv_data.invoke_ffa_fn) + panic("[FFA] no private data found\n"); + + a0 = FFA_RXTX_UNMAP; + a1 = PREP_SELF_ENDPOINT_ID(ffa_priv_data.id); + + ffa_priv_data.invoke_ffa_fn(a0, a1, a2, a3, a4, a5, a6, a7, &res); + + switch (res.a0) { + case FFA_ERROR: + { + if (((int)res.a2) == FFA_ERR_STAT_NOT_SUPPORTED) + panic("[FFA] FFA_RXTX_UNMAP is not implemented at this FF-A instance\n"); + else if (((int)res.a2) == FFA_ERR_STAT_INVALID_PARAMETERS) + panic("[FFA] There is no buffer pair registered on behalf of the caller\n"); + else + panic("[FFA] Undefined error (%d)\n", ((int)res.a2)); + } + case FFA_SUCCESS: + { + size_t buf_4k_pages = 0; + int ret; + + ret = ffa_get_rxtx_buffers_pages_cnt(&buf_4k_pages); + if (ret != FFA_ERR_STAT_SUCCESS) + panic("[FFA] RX/TX buffers unmapped but failure in getting pages count\n"); + + ret = ffa_free_rxtx_buffers(buf_4k_pages); + if (ret != FFA_ERR_STAT_SUCCESS) + panic("[FFA] RX/TX buffers unmapped but failure in freeing the memory\n"); + + ffa_info("RX/TX buffers unmapped and memory freed"); + + return FFA_ERR_STAT_SUCCESS; + } + default: + panic("[FFA] Undefined response function (0x%lx)", res.a0); + } +} + +/** + * ffa_release_rx_buffer - FFA_RX_RELEASE handler function + * + * This is the boot time function that invokes FFA_RX_RELEASE FF-A function + * to release the ownership of the RX buffer + * + * Return: + * + * FFA_ERR_STAT_SUCCESS on success. Otherwise, failure + */ +static int ffa_release_rx_buffer(void) +{ + FFA_DECLARE_ARGS; + + if (!ffa_priv_data.invoke_ffa_fn) + panic("[FFA] no private data found\n"); + + a0 = FFA_RX_RELEASE; + + ffa_priv_data.invoke_ffa_fn(a0, a1, a2, a3, a4, a5, a6, a7, &res); + + switch (res.a0) { + case FFA_ERROR: + { + if (((int)res.a2) == FFA_ERR_STAT_NOT_SUPPORTED) + panic("[FFA] FFA_RX_RELEASE is not implemented at this FF-A instance\n"); + else if (((int)res.a2) == FFA_ERR_STAT_DENIED) + panic("[FFA] Caller did not have ownership of the RX buffer\n"); + else + panic("[FFA] Undefined error (%d)\n", ((int)res.a2)); + } + case FFA_SUCCESS: + return FFA_ERR_STAT_SUCCESS; + + default: + panic("[FFA] Undefined response function (0x%lx)\n", res.a0); + } +} + +/** + * ffa_uuid_are_identical - checks whether two given UUIDs are identical + * @uuid1: first UUID + * @uuid2: second UUID + * + * This is a boot time function used by ffa_read_partitions_info to search + * for a UUID in the partitions descriptors table + * + * Return: + * + * 1 when UUIDs match. Otherwise, 0 + */ +int ffa_uuid_are_identical(const union ffa_partition_uuid *uuid1, + const union ffa_partition_uuid *uuid2) +{ + if (!uuid1 || !uuid2) + return 0; + + return (!memcmp(uuid1, uuid2, sizeof(union ffa_partition_uuid))); +} + +/** + * ffa_read_partitions_info - reads the data queried by FFA_PARTITION_INFO_GET + * and saves it in the private structure + * @count: The number of partitions queried + * @part_uuid: Pointer to the partition(s) UUID + * + * This is the boot time function that reads the partitions information + * returned by the FFA_PARTITION_INFO_GET and saves it in the private + * data structure. + * + * Return: + * + * The private data structure is updated with the partition(s) information + * FFA_ERR_STAT_SUCCESS is returned on success. Otherwise, failure + */ +static int ffa_read_partitions_info(u32 count, union ffa_partition_uuid *part_uuid) +{ + if (!count) { + ffa_err("No partition detected"); + return -ENODATA; + } + + ffa_info("Reading partitions data from the RX buffer"); + +#if CONFIG_IS_ENABLED(EFI_LOADER) + + if (!part_uuid) { + /* + * querying information of all partitions + */ + u64 data_pages; + u64 data_bytes; + efi_status_t efi_ret; + size_t buf_4k_pages = 0; + u32 desc_idx; + struct ffa_partition_info *parts_info; + int ret; + + data_bytes = count * sizeof(struct ffa_partition_desc); + data_pages = efi_size_in_pages(data_bytes); + + /* + * get the RX buffer size in pages + */ + ret = ffa_get_rxtx_buffers_pages_cnt(&buf_4k_pages); + if (ret != FFA_ERR_STAT_SUCCESS) { + ffa_err("Can not get the RX buffer size (error %d)", ret); + return ret; + } + + if (data_pages > buf_4k_pages) { + ffa_err("Partitions data size exceeds the RX buffer size:"); + ffa_err(" Sizes in pages: data %llu , RX buffer %lu ", + data_pages, + buf_4k_pages); + + return -ENOMEM; + } + + efi_ret = efi_allocate_pages(EFI_ALLOCATE_ANY_PAGES, + EFI_RUNTIME_SERVICES_DATA, + data_pages, + (u64 *)&ffa_priv_data.partitions.descs); + + if (efi_ret != EFI_SUCCESS) { + ffa_priv_data.partitions.descs = NULL; + + ffa_err("Cannot allocate partitions data buffer (EFI error 0x%lx)", + efi_ret); + + return -ENOBUFS; + } + + /* + * make sure the buffer is clean before use + */ + memset(ffa_priv_data.partitions.descs, 0, + data_pages * SZ_4K); + + parts_info = (struct ffa_partition_info *)ffa_priv_data.pair.rxbuf; + + for (desc_idx = 0 ; desc_idx < count ; desc_idx++) { + ffa_priv_data.partitions.descs[desc_idx].info = + parts_info[desc_idx]; + + ffa_info("Partition ID %x : info cached", + ffa_priv_data.partitions.descs[desc_idx].info.id); + } + + ffa_priv_data.partitions.count = count; + + ffa_info("%d partition(s) found and cached", count); + + } else { + u32 rx_desc_idx, cached_desc_idx; + struct ffa_partition_info *parts_info; + u8 desc_found; + + parts_info = (struct ffa_partition_info *)ffa_priv_data.pair.rxbuf; + + /* + * search for the SP IDs read from the RX buffer + * in the already cached SPs. + * Update the UUID when ID found. + */ + for (rx_desc_idx = 0; rx_desc_idx < count ; rx_desc_idx++) { + desc_found = 0; + + /* + * search the current ID in the cached partitions + */ + for (cached_desc_idx = 0; + cached_desc_idx < ffa_priv_data.partitions.count; + cached_desc_idx++) { + /* + * save the UUID + */ + if (ffa_priv_data.partitions.descs[cached_desc_idx].info.id == + parts_info[rx_desc_idx].id) { + ffa_priv_data.partitions.descs[cached_desc_idx].UUID = + *part_uuid; + + desc_found = 1; + break; + } + } + + if (!desc_found) + return -ENODATA; + } + } +#else +#warning "arm_ffa: reading FFA_PARTITION_INFO_GET data not implemented" +#endif + + return FFA_ERR_STAT_SUCCESS; +} + +/** + * ffa_query_partitions_info - invokes FFA_PARTITION_INFO_GET + * and saves partitions data + * @part_uuid: Pointer to the partition(s) UUID + * @pcount: Pointer to the number of partitions variable filled when querying + * + * This is the boot time function that executes the FFA_PARTITION_INFO_GET + * to query the partitions data. Then, it calls ffa_read_partitions_info + * to save the data in the private data structure. + * + * After reading the data the RX buffer is released using ffa_release_rx_buffer + * + * Return: + * + * When part_uuid is NULL, all partitions data are retrieved from secure world + * When part_uuid is non NULL, data for partitions matching the given UUID are + * retrieved and the number of partitions is returned + * FFA_ERR_STAT_SUCCESS is returned on success. Otherwise, failure + */ +static int ffa_query_partitions_info(union ffa_partition_uuid *part_uuid, + u32 *pcount) +{ + unsigned long a0 = 0; + union ffa_partition_uuid query_uuid = {0}; + unsigned long a5 = 0; + unsigned long a6 = 0; + unsigned long a7 = 0; + struct arm_smccc_res res = {0}; + + if (!ffa_priv_data.invoke_ffa_fn) + panic("[FFA] no private data found\n"); + + a0 = FFA_PARTITION_INFO_GET; + + /* + * If a UUID is specified. Information for one or more + * partitions in the system is queried. Otherwise, information + * for all installed partitions is queried + */ + + if (part_uuid) { + if (!pcount) + return -EINVAL; + + query_uuid = *part_uuid; + } + + ffa_priv_data.invoke_ffa_fn(a0, query_uuid.words.a1, query_uuid.words.a2, + query_uuid.words.a3, query_uuid.words.a4, + a5, a6, a7, &res); + + switch (res.a0) { + case FFA_ERROR: + { + switch (((int)res.a2)) { + case FFA_ERR_STAT_INVALID_PARAMETERS: + ffa_err("Unrecognized UUID"); + return -EPERM; + case FFA_ERR_STAT_NO_MEMORY: + ffa_err("Results cannot fit in RX buffer of the caller"); + return -ENOMEM; + case FFA_ERR_STAT_DENIED: + ffa_err("Callee is not in a state to handle this request"); + return -EACCES; + case FFA_ERR_STAT_NOT_SUPPORTED: + ffa_err("This function is not implemented at this FF-A instance"); + return -EOPNOTSUPP; + case FFA_ERR_STAT_BUSY: + ffa_err("RX buffer of the caller is not free"); + return -EBUSY; + default: + ffa_err("Undefined error (%d)", ((int)res.a2)); + return -EINVAL; + } + } + case FFA_SUCCESS: + { + int ret; + + /* + * res.a2 contains the count of partition information descriptors + * populated in the RX buffer + */ + if (res.a2) { + ret = ffa_read_partitions_info(res.a2, part_uuid); + if (ret) + ffa_err("Failed to read partition(s) data , error (%d)", ret); + } + + /* + * return the SP count + */ + if (part_uuid) { + if (!ret) + *pcount = res.a2; + else + *pcount = 0; + } + /* + * After calling FFA_PARTITION_INFO_GET the buffer ownership + * is assigned to the consumer (u-boot). So, we need to give + * the ownership back to the secure world + */ + ret = ffa_release_rx_buffer(); + + if (!part_uuid && !res.a2) { + ffa_err("[FFA] no partition installed in the system"); + return -ENODEV; + } + + return ret; + } + default: + ffa_err("Undefined response function (0x%lx)", res.a0); + return -EINVAL; + } +} + +/** + * ffa_get_partitions_info - FFA_PARTITION_INFO_GET handler function + * @func_data: Pointer to the FF-A function arguments container structure. + * The passed arguments: + * Mode 1: When getting from the driver the number of + * secure partitions: + * @data0_size: UUID size + * @data0: pointer to the UUID (little endian) + * @data1_size: size of the number of partitions + * variable + * @data1: pointer to the number of partitions + * variable. The variable will be set + * by the driver + * Mode 2: When requesting the driver to return the + * partitions information: + * @data0_size: UUID size + * @data0: pointer to the UUID (little endian) + * @data1_size: size of the SPs information buffer + * @data1: pointer to SPs information buffer + * (allocated by the client). + * The buffer will be filled by the driver + * + * This is the boot time function that queries the secure partition data from + * the private data structure. If not found, it invokes FFA_PARTITION_INFO_GET + * FF-A function to query the partition information from secure world. + * + * A client of the FF-A driver should know the UUID of the service it wants to + * access. It should use the UUID to request the FF-A driver to provide the + * partition(s) information of the service. The FF-A driver uses + * PARTITION_INFO_GET to obtain this information. This is implemented through + * ffa_get_partitions_info function. + * A new FFA_PARTITION_INFO_GET call is issued (first one performed through + * ffa_cache_partitions_info) allowing to retrieve the partition(s) information. + * They are not saved (already done). We only update the UUID in the cached area. + * This assumes that partitions data does not change in the secure world. + * Otherwise u-boot will have an outdated partition data. The benefit of caching + * the information in the FF-A driver is to accommodate discovery after + * ExitBootServices(). + * + * When invoked through a client request, ffa_get_partitions_info should be + * called twice. First call is to get from the driver the number of secure + * partitions (SPs) associated to a particular UUID. + * Then, the caller (client) allocates the buffer to host the SPs data and + * issues a 2nd call. Then, the driver fills the SPs data in the pre-allocated + * buffer. + * + * To achieve the mechanism described above, ffa_get_partitions_info uses the + * following functions: + * ffa_read_partitions_info + * ffa_query_partitions_info + * + * Return: + * + * @data1: When pointing to the number of partitions variable, the number is + * set by the driver. + * When pointing to the partitions information buffer, the buffer will be + * filled by the driver. + * + * On success FFA_ERR_STAT_SUCCESS is returned. Otherwise, failure + */ +static int ffa_get_partitions_info(struct ffa_interface_data *func_data) +{ + /* + * fill_data: + * 0: return the SP count + * 1: fill SP data and return it to the caller + * -1: undefined mode + */ + int fill_data = -1; + u32 desc_idx, client_desc_idx; + union ffa_partition_uuid *part_uuid; + u32 client_desc_max_cnt; + u32 parts_found = 0; + + if (!func_data) { + ffa_err("No function data provided"); + return -EINVAL; + } + + if (!ffa_priv_data.partitions.count || !ffa_priv_data.partitions.descs) + panic("[FFA] No partition installed\n"); + + if (func_data->data0_size == sizeof(union ffa_partition_uuid) && + func_data->data0 && + func_data->data1_size == sizeof(u32) && + func_data->data1) { + /* + * data0 (in): pointer to UUID + * data1 (in): pointer to SP count + * Out: SP count returned in the count variable pointed by data1 + */ + + fill_data = 0; + + ffa_info("Preparing for checking partitions count"); + + } else if ((func_data->data0_size == sizeof(union ffa_partition_uuid)) && + func_data->data0 && + (func_data->data1_size >= sizeof(struct ffa_partition_info)) && + !(func_data->data1_size % sizeof(struct ffa_partition_info)) && + func_data->data1) { + /* + * data0 (in): pointer to UUID + * data1 (in): pointer to SPs descriptors buffer + * (created by the client) + * Out: SPs descriptors returned in the buffer + * pointed by data1 + */ + + fill_data = 1; + + client_desc_idx = 0; + + /* + * number of empty descriptors preallocated by the caller + */ + client_desc_max_cnt = + func_data->data1_size / sizeof(struct ffa_partition_info); + + ffa_info("Preparing for filling partitions info"); + + } else { + ffa_err("Invalid function arguments provided"); + return -EINVAL; + } + + part_uuid = (union ffa_partition_uuid *)func_data->data0; + + ffa_info("Searching partitions using the provided UUID"); + + /* + * search in the cached partitions + */ + for (desc_idx = 0; + desc_idx < ffa_priv_data.partitions.count; + desc_idx++) { + if (ffa_uuid_are_identical(&ffa_priv_data.partitions.descs[desc_idx].UUID, + part_uuid)) { + ffa_info("Partition ID %x matches the provided UUID", + ffa_priv_data.partitions.descs[desc_idx].info.id); + + parts_found++; + + if (fill_data) { + /* + * trying to fill the partition info in data1 + */ + + if (client_desc_idx < client_desc_max_cnt) { + ((struct ffa_partition_info *) + func_data->data1)[client_desc_idx++] = + ffa_priv_data.partitions.descs[desc_idx].info; + continue; + } + + ffa_err("Failed to fill the current descriptor client buffer full"); + return -ENOBUFS; + } + } + } + + if (!parts_found) { + int ret; + + ffa_info("No partition found. Querying framework ..."); + + ret = ffa_query_partitions_info(part_uuid, &parts_found); + + if (ret == FFA_ERR_STAT_SUCCESS) { + if (!fill_data) { + *((u32 *)func_data->data1) = parts_found; + + ffa_info("Number of partition(s) found matching the UUID: %d", + parts_found); + } else { + /* + * we want to read SPs info + */ + + /* + * If SPs data filled, retry searching SP info again + */ + if (parts_found) + ret = ffa_get_partitions_info(func_data); + else + ret = -ENODATA; + } + } + + return ret; + } + + /* partition(s) found */ + if (!fill_data) + *((u32 *)func_data->data1) = parts_found; + + return FFA_ERR_STAT_SUCCESS; +} + +/** + * ffa_cache_partitions_info - Queries and saves all secure partitions data + * + * This is a boot time function that invokes FFA_PARTITION_INFO_GET FF-A + * function to query from secure world all partitions information. + * + * The FFA_PARTITION_INFO_GET call is issued with nil UUID as an argument. + * All installed partitions information are returned. We cache them in the + * resident private data structure and we keep the UUID field empty + * (in FF-A 1.0 UUID is not provided by the partition descriptor) + * + * This function is called at the device probing level. + * ffa_cache_partitions_info uses ffa_query_partitions_info to get the data + * + * Return: + * + * FFA_ERR_STAT_SUCCESS on success. Otherwise, failure + */ +static int ffa_cache_partitions_info(void) +{ + return ffa_query_partitions_info(NULL, NULL); +} + +/** + * ffa_msg_send_direct_req - FFA_MSG_SEND_DIRECT_{REQ,RESP} handler function + * @func_data: Pointer to the FF-A function arguments container structure. + * The passed arguments: + * @data0_size: partition ID size + * @data0: pointer to the partition ID + * @data1_size: exchanged data size + * @data1: pointer to the data buffer preallocated by + * the client (in/out) + * + * This is the runtime function that implements FFA_MSG_SEND_DIRECT_{REQ,RESP} + * FF-A functions. + * + * FFA_MSG_SEND_DIRECT_REQ is used to send the data to the secure partition. + * The response from the secure partition is handled by reading the + * FFA_MSG_SEND_DIRECT_RESP arguments. + * + * The maximum size of the data that can be exchanged is 20 bytes which is + * sizeof(struct ffa_send_direct_data) as defined by the FF-A specification 1.0 + * in the section relevant to FFA_MSG_SEND_DIRECT_{REQ,RESP} + * + * Return: + * + * FFA_ERR_STAT_SUCCESS on success. Otherwise, failure + */ +static int __ffa_runtime ffa_msg_send_direct_req(struct ffa_interface_data + *func_data) +{ + u16 dst_part_id; + unsigned long a0 = 0; + unsigned long a1 = 0; + unsigned long a2 = 0; + struct ffa_send_direct_data *msg; + struct arm_smccc_res res = {0}; + + if (!ffa_priv_data.invoke_ffa_fn) + return -ENODEV; + + if (!func_data) + return -EINVAL; + + /* No partition installed */ + if (!ffa_priv_data.partitions.count || !ffa_priv_data.partitions.descs) + return -ENODEV; + + /* Undefined interface parameters */ + if (func_data->data0_size != sizeof(u16) || + !func_data->data0 || + func_data->data1_size != FFA_MSG_SEND_DIRECT_MAX_SIZE || + !func_data->data1) + return -EINVAL; + + dst_part_id = *((u16 *)func_data->data0); + msg = func_data->data1; + + a0 = FFA_MSG_SEND_DIRECT_REQ; + + a1 = PREP_SELF_ENDPOINT_ID(ffa_priv_data.id) | + PREP_PART_ENDPOINT_ID(dst_part_id); + + ffa_priv_data.invoke_ffa_fn(a0, a1, a2, + msg->a3, + msg->a4, + msg->a5, + msg->a6, + msg->a7, + &res); + + while (res.a0 == FFA_INTERRUPT) + ffa_priv_data.invoke_ffa_fn(FFA_RUN, res.a1, + 0, 0, 0, 0, 0, 0, + &res); + + switch (res.a0) { + case FFA_ERROR: + { + switch (((int)res.a2)) { + case FFA_ERR_STAT_INVALID_PARAMETERS: + /* Invalid endpoint ID or non-zero reserved register */ + return -EPERM; + case FFA_ERR_STAT_ABORTED: + /* Message target ran into unexpected error and has aborted */ + return -ECONNABORTED; + case FFA_ERR_STAT_DENIED: + /* Callee is not in a state to handle this request */ + return -EACCES; + case FFA_ERR_STAT_NOT_SUPPORTED: + /* This function is not implemented at this FF-A instance */ + return -EOPNOTSUPP; + case FFA_ERR_STAT_BUSY: + /* Message target is busy */ + return -EBUSY; + default: + /* Undefined error */ + return -ENXIO; + } + } + case FFA_SUCCESS: + + /* Message sent with no response */ + return FFA_ERR_STAT_SUCCESS; + + case FFA_MSG_SEND_DIRECT_RESP: + + /* + * Message sent with response + * extract the 32-bit wide return data + */ + msg->a3 = (u32)res.a3; + msg->a4 = (u32)res.a4; + msg->a5 = (u32)res.a5; + msg->a6 = (u32)res.a6; + msg->a7 = (u32)res.a7; + + return FFA_ERR_STAT_SUCCESS; + + default: + /* Undefined response function */ + return -ENOENT; + } +} + +/** + * invoke_ffa_drv_api - The driver dispatcher function + * @func_id: The FF-A function to be used + * @func_data: Pointer to the FF-A function arguments container + * structure. This also includes pointers to the + * returned data needed by clients. + * The dispatcher is a runtime function that selects the FF-A function handler + * based on the input FF-A function ID. + * The input arguments are passed to the handler function. + * + * Return: + * + * FFA_ERR_STAT_SUCCESS on success. Otherwise, failure + */ +int __ffa_runtime invoke_ffa_drv_api(u32 func_id, + struct ffa_interface_data *func_data) +{ + if (!ffa_priv_data.dev) + return -ENODEV; + + switch (func_id) { + case FFA_PARTITION_INFO_GET: + return ffa_get_partitions_info(func_data); + case FFA_RXTX_UNMAP: + return ffa_unmap_rxtx_buffers(); + case FFA_MSG_SEND_DIRECT_REQ: + return ffa_msg_send_direct_req(func_data); + default: + /* Undefined FF-A interface */ + return -EINVAL; + } +} + +/** + * ffa_set_conduit - Set the conduit + * + * This boot time function clears the private data structure and sets the conduit + * + * Return: + * + * FFA_ERR_STAT_SUCCESS on success. Otherwise, failure + */ +static int ffa_set_conduit(void) +{ + ffa_priv_data.conduit = FFA_CONDUIT_SMC; + + ffa_priv_data.invoke_ffa_fn = arm_ffa_smccc_smc; + + ffa_info("Conduit is SMC"); + + return FFA_ERR_STAT_SUCCESS; +} + +/** + * ffa_probe - The driver probe function + * @dev: the arm_ffa device + * + * Probing is done at boot time and triggered by the uclass device discovery. + * At probe level the following actions are done: + * - setting the conduit + * - querying the FF-A framework version + * - querying from secure world the u-boot endpoint ID + * - querying from secure world the supported features of the specified FF-A calls + * - mapping the RX/TX buffers + * - querying from secure world all the partitions information + * + * All data queried from secure world is saved in the resident private data structure. + * + * The probe will fail if either FF-A framework is not detected or the + * FF-A requests are not behaving correctly. This ensures that the + * driver is not installed and its operations are not exported to the clients. + * However, once the driver is successfully probed and an FF-A anomaly is + * detected when clients invoke the driver operations, the driver cause + * u-boot to panic because the client would not know what to do in such conditions. + * + * Return: + * + * FFA_ERR_STAT_SUCCESS on success. Otherwise, failure + */ +static int ffa_probe(struct udevice *dev) +{ + int ret; + size_t buf_4k_pages = 0; + + ret = ffa_set_conduit(); + if (ret != FFA_ERR_STAT_SUCCESS) + return ret; + + ret = ffa_get_version(); + if (ret != FFA_ERR_STAT_SUCCESS) + return ret; + + ret = ffa_get_endpoint_id(); + if (ret != FFA_ERR_STAT_SUCCESS) + return ret; + + ret = ffa_get_rxtx_map_features(); + if (ret != FFA_ERR_STAT_SUCCESS) + return ret; + + ret = ffa_get_rxtx_buffers_pages_cnt(&buf_4k_pages); + if (ret != FFA_ERR_STAT_SUCCESS) + return ret; + + ret = ffa_map_rxtx_buffers(buf_4k_pages); + if (ret != FFA_ERR_STAT_SUCCESS) + return ret; + + ret = ffa_cache_partitions_info(); + if (ret != FFA_ERR_STAT_SUCCESS) { + ffa_free_rxtx_buffers(buf_4k_pages); + return ret; + } + + return FFA_ERR_STAT_SUCCESS; +} + +/** + * ffa_drv_ops - The driver operations runtime structure + * @invoke_func: The driver dispatcher + */ +struct ffa_ops __ffa_runtime_data ffa_drv_ops = { + .invoke_func = invoke_ffa_drv_api +}; + +/** + * ffa_device_get_ops - driver operations getter + * + * Return: + * This runtime function returns a pointer to the driver operations structure + */ +const struct ffa_ops * __ffa_runtime ffa_device_get_ops(void) +{ + return &ffa_drv_ops; +} + +/** + * Declaring the arm_ffa driver under UCLASS_FFA + */ + +U_BOOT_DRIVER(arm_ffa) = { + .name = FFA_DRV_NAME, + .id = UCLASS_FFA, + .probe = ffa_probe, +}; diff --git a/include/arm_ffa.h b/include/arm_ffa.h new file mode 100644 index 0000000000..98db01ee72 --- /dev/null +++ b/include/arm_ffa.h @@ -0,0 +1,190 @@ +/* SPDX-License-Identifier: GPL-2.0+ */ +/* + * (C) Copyright 2022 ARM Limited + * Abdellatif El Khlifi abdellatif.elkhlifi@arm.com + */ + +#ifndef __ARM_FFA_H +#define __ARM_FFA_H + +#include <linux/arm-smccc.h> +#include <linux/printk.h> + +/* + * This header is public. It can be used by clients to access + * data structures and definitions they need + */ + +/* + * Macros for displaying logs + */ + +#define ffa_info(fmt, ...) pr_info("[FFA] " fmt "\n", ##__VA_ARGS__) +#define ffa_err(fmt, ...) pr_err("[FFA] " fmt "\n", ##__VA_ARGS__) + +/* + * The driver operations success error code + */ +#define FFA_ERR_STAT_SUCCESS (0) + +#if CONFIG_IS_ENABLED(EFI_LOADER) + +#include <efi_loader.h> + +/* + * __ffa_runtime_data and __ffa_runtime - controls whether data/code are + * available after calling the EFI ExitBootServices service. + * Data/code tagged with these keywords are resident (available at boot time and + * at runtime) + */ + +#define __ffa_runtime_data __efi_runtime_data +#define __ffa_runtime __efi_runtime + +#else + +#define __ffa_runtime_data +#define __ffa_runtime + +#endif + +/* + * Definitions of the Arm FF-A interfaces supported by the Arm FF-A driver + */ + +#define FFA_SMC(calling_convention, func_num) \ + ARM_SMCCC_CALL_VAL(ARM_SMCCC_FAST_CALL, (calling_convention), \ + ARM_SMCCC_OWNER_STANDARD, (func_num)) + +#define FFA_SMC_32(func_num) FFA_SMC(ARM_SMCCC_SMC_32, (func_num)) + +#define FFA_VERSION FFA_SMC_32(0x63) +#define FFA_ID_GET FFA_SMC_32(0x69) +#define FFA_FEATURES FFA_SMC_32(0x64) +#define FFA_PARTITION_INFO_GET FFA_SMC_32(0x68) +#define FFA_RXTX_MAP FFA_SMC_32(0x66) +#define FFA_RXTX_UNMAP FFA_SMC_32(0x67) +#define FFA_RX_RELEASE FFA_SMC_32(0x65) +#define FFA_MSG_SEND_DIRECT_REQ FFA_SMC_32(0x6F) +#define FFA_MSG_SEND_DIRECT_RESP FFA_SMC_32(0x70) +#define FFA_RUN FFA_SMC_32(0x6D) +#define FFA_ERROR FFA_SMC_32(0x60) +#define FFA_SUCCESS FFA_SMC_32(0x61) +#define FFA_INTERRUPT FFA_SMC_32(0x62) + +/* + * struct ffa_partition_info - Partition information descriptor + * @id: Partition ID + * @exec_ctxt: Execution context count + * @properties: Partition properties + * + * Data structure containing information about partitions instantiated in the system + * This structure is filled with the data queried by FFA_PARTITION_INFO_GET + */ +struct __packed ffa_partition_info { + u16 id; + u16 exec_ctxt; +/* partition supports receipt of direct requests */ +#define FFA_PARTITION_DIRECT_RECV BIT(0) +/* partition can send direct requests. */ +#define FFA_PARTITION_DIRECT_SEND BIT(1) +/* partition can send and receive indirect messages. */ +#define FFA_PARTITION_INDIRECT_MSG BIT(2) + u32 properties; +}; + +/* + * struct ffa_send_direct_data - Data structure hosting the data + * used by FFA_MSG_SEND_DIRECT_{REQ,RESP} + * @a3-a7: Data read/written from/to w3-w7 registers + * + * Data structure containing the data to be sent by FFA_MSG_SEND_DIRECT_REQ + * or read from FFA_MSG_SEND_DIRECT_RESP + */ +struct __packed ffa_send_direct_data { + u32 a3; /* w3 */ + u32 a4; /* w4 */ + u32 a5; /* w5 */ + u32 a6; /* w6 */ + u32 a7; /* w7 */ +}; + +#define FFA_MSG_SEND_DIRECT_MAX_SIZE (sizeof(struct ffa_send_direct_data)) + +/* UUID data size */ +#define UUID_SIZE (16) + +/* + * union ffa_partition_uuid - Data union hosting the UUID + * transmitted by FFA_PARTITION_INFO_GET + * @words: data structure giving 32-bit words access to the UUID data + * @bytes: data structure giving byte access to the UUID data + * + * The structure holds little-endian UUID data. + */ +union ffa_partition_uuid { + struct __packed words { + u32 a1; /* w1 */ + u32 a2; /* w2 */ + u32 a3; /* w3 */ + u32 a4; /* w4 */ + } words; + u8 bytes[UUID_SIZE]; +}; + +/** + * struct ffa_interface_data - generic FF-A interface data structure used to exchange + * data between user layers and the driver + * @data0_size: size of the first argument + * @data0: pointer to the first argument + * @data1_size>: size of the second argument + * @data1: pointer to the second argument + * + * Using this structure user layers can pass various types of data with different sizes. + * The driver internal functions can detect the nature of this data, verfy compliance + * then execute the request when appropriate. + */ +struct ffa_interface_data { + u32 data0_size; /* size of the first argument */ + void *data0; /* pointer to the first argument */ + u32 data1_size; /* size of the second argument */ + void *data1; /* pointer to the second argument */ +}; + +/** + * struct ffa_ops - The driver operations structure + * @invoke_func: function pointer to the invoke function + * + * The data structure providing all the operations supported by the driver. + * This structure is resident. + */ +struct ffa_ops { + /* the driver dispatcher */ + int (*invoke_func)(u32 func_id, struct ffa_interface_data *func_data); +}; + +/** + * The device driver and the Uclass driver public functions + */ + +/** + * ffa_get_invoke_func - performs a call to the FF-A driver dispatcher + */ +int __ffa_runtime ffa_get_invoke_func(u32 func_id, + struct ffa_interface_data *func_data); + +/** + * ffa_device_get_ops - driver operations getter + */ +const struct ffa_ops * __ffa_runtime ffa_device_get_ops(void); + +/** + * ffa_get_device - create, bind and probe the arm_ffa device + */ +int ffa_get_device(void); + +/** + * ffa_bus_discover - discover FF-A bus and probes the arm_ffa device + */ +int ffa_bus_discover(void); +#endif diff --git a/include/arm_ffa_helper.h b/include/arm_ffa_helper.h new file mode 100644 index 0000000000..1cf68748f0 --- /dev/null +++ b/include/arm_ffa_helper.h @@ -0,0 +1,45 @@ +/* SPDX-License-Identifier: GPL-2.0+ */ +/* + * (C) Copyright 2022 ARM Limited + * Abdellatif El Khlifi abdellatif.elkhlifi@arm.com + */ + +#ifndef __ARM_FFA_HELPER_H +#define __ARM_FFA_HELPER_H + +#include <arm_ffa.h> + +/* + * This header is public. Including this header provides all data structures + * and definitions needed by clients to use the FF-A transport driver + * + * It also provides helper functions allowing to pass data and invoke FF-A functions + */ + +/** + * ffa_helper_get_partitions_info - Wrapper function for FFA_PARTITION_INFO_GET + */ +int ffa_helper_get_partitions_info(struct ffa_interface_data *func_data); + +/** + * ffa_helper_unmap_rxtx_buffers - Wrapper function for FFA_RXTX_UNMAP + */ +int ffa_helper_unmap_rxtx_buffers(void); + +/** + * ffa_helper_msg_send_direct_req - Wrapper function for + * FFA_MSG_SEND_DIRECT_{REQ,RESP} + */ +int __ffa_runtime ffa_helper_msg_send_direct_req(struct ffa_interface_data + *func_data); + +/** + * ffa_helper_bus_discover - Wrapper function for FF-A bus discovery + */ +int ffa_helper_bus_discover(void); + +/** + * ffa_uuid_str_to_bin - Converts a big endian UUID string to a little endian buffer + */ +int ffa_uuid_str_to_bin(const char *uuid_str, unsigned char *uuid_bin); +#endif diff --git a/include/dm/uclass-id.h b/include/dm/uclass-id.h index 0e26e1d138..a1181b8f48 100644 --- a/include/dm/uclass-id.h +++ b/include/dm/uclass-id.h @@ -52,6 +52,7 @@ enum uclass_id { UCLASS_EFI_MEDIA, /* Devices provided by UEFI firmware */ UCLASS_ETH, /* Ethernet device */ UCLASS_ETH_PHY, /* Ethernet PHY device */ + UCLASS_FFA, /* Arm Firmware Framework for Armv8-A */ UCLASS_FIRMWARE, /* Firmware */ UCLASS_FS_FIRMWARE_LOADER, /* Generic loader */ UCLASS_GPIO, /* Bank of general-purpose I/O pins */ diff --git a/include/linux/arm-smccc.h b/include/linux/arm-smccc.h index 7f2be23394..d58c7c104b 100644 --- a/include/linux/arm-smccc.h +++ b/include/linux/arm-smccc.h @@ -1,6 +1,8 @@ /* SPDX-License-Identifier: GPL-2.0 */ /* * Copyright (c) 2015, Linaro Limited + * (C) Copyright 2022 ARM Limited + * Abdellatif El Khlifi abdellatif.elkhlifi@arm.com */ #ifndef __LINUX_ARM_SMCCC_H #define __LINUX_ARM_SMCCC_H @@ -57,13 +59,17 @@ #include <linux/types.h> /** * struct arm_smccc_res - Result from SMC/HVC call - * @a0-a3 result values from registers 0 to 3 + * @a0-a7 result values from registers 0 to 7 */ struct arm_smccc_res { unsigned long a0; unsigned long a1; unsigned long a2; unsigned long a3; + unsigned long a4; + unsigned long a5; + unsigned long a6; + unsigned long a7; };
/** @@ -113,6 +119,26 @@ asmlinkage void __arm_smccc_hvc(unsigned long a0, unsigned long a1, unsigned long a5, unsigned long a6, unsigned long a7, struct arm_smccc_res *res, struct arm_smccc_quirk *quirk);
+#if (IS_ENABLED(CONFIG_ARM_FFA_TRANSPORT)) +/** + * __arm_ffa_smccc_smc() - make SMC calls used for FF-A transport + * @a0-a7: arguments passed in 64-bit registers x0 to x7 + * @res: result values from 64-bit registers x0 to x7 + * + * This function is used to make SMC calls following SMC32 Calling Convention. + * The content of the supplied parameters is copied to registers x0 to x7 prior + * to the SMC instruction. The SMC call return data is 32-bit data read from + * registers x0 tp x7. + */ +asmlinkage void __arm_ffa_smccc_smc(unsigned long a0, unsigned long a1, + unsigned long a2, unsigned long a3, unsigned long a4, + unsigned long a5, unsigned long a6, unsigned long a7, + struct arm_smccc_res *res); + +#define arm_ffa_smccc_smc __arm_ffa_smccc_smc + +#endif + #define arm_smccc_smc(...) __arm_smccc_smc(__VA_ARGS__, NULL)
#define arm_smccc_smc_quirk(...) __arm_smccc_smc(__VA_ARGS__) diff --git a/lib/Kconfig b/lib/Kconfig index effe735365..9006e8d44c 100644 --- a/lib/Kconfig +++ b/lib/Kconfig @@ -845,6 +845,7 @@ config SMBIOS_PARSER source lib/efi/Kconfig source lib/efi_loader/Kconfig source lib/optee/Kconfig +source lib/arm-ffa/Kconfig
config TEST_FDTDEC bool "enable fdtdec test" diff --git a/lib/Makefile b/lib/Makefile index 13fe5fb7a4..36f67cd94e 100644 --- a/lib/Makefile +++ b/lib/Makefile @@ -9,6 +9,7 @@ obj-$(CONFIG_EFI) += efi/ obj-$(CONFIG_EFI_LOADER) += efi_driver/ obj-$(CONFIG_EFI_LOADER) += efi_loader/ obj-$(CONFIG_CMD_BOOTEFI_SELFTEST) += efi_selftest/ +obj-$(CONFIG_ARM_FFA_TRANSPORT_HELPERS) += arm-ffa/ obj-$(CONFIG_LZMA) += lzma/ obj-$(CONFIG_BZIP2) += bzip2/ obj-$(CONFIG_TIZEN) += tizen/ diff --git a/lib/arm-ffa/Kconfig b/lib/arm-ffa/Kconfig new file mode 100644 index 0000000000..79acbc5a8f --- /dev/null +++ b/lib/arm-ffa/Kconfig @@ -0,0 +1,6 @@ +config ARM_FFA_TRANSPORT_HELPERS + bool "Enable interface helpers for Arm Firmware Framework for Armv8-A" + depends on ARM_FFA_TRANSPORT + help + User layers call FF-A interfaces using helper functions which + pass the data and the FF-A function ID to the low level driver diff --git a/lib/arm-ffa/Makefile b/lib/arm-ffa/Makefile new file mode 100644 index 0000000000..cba625fde4 --- /dev/null +++ b/lib/arm-ffa/Makefile @@ -0,0 +1,8 @@ +# SPDX-License-Identifier: GPL-2.0+ +# +# (C) Copyright 2022 Abdellatif El Khlifi abdellatif.elkhlifi@arm.com +# + +# This file only gets included when CONFIG_ARM_FFA_TRANSPORT_HELPERS is set + +obj-y += arm_ffa_helper.o diff --git a/lib/arm-ffa/arm_ffa_helper.c b/lib/arm-ffa/arm_ffa_helper.c new file mode 100644 index 0000000000..a291b000a7 --- /dev/null +++ b/lib/arm-ffa/arm_ffa_helper.c @@ -0,0 +1,188 @@ +// SPDX-License-Identifier: GPL-2.0+ +/* + * (C) Copyright 2022 ARM Limited + * Abdellatif El Khlifi abdellatif.elkhlifi@arm.com + */ + +#include <common.h> +#include <arm_ffa_helper.h> +#include <uuid.h> + +/** + * ffa_helper_get_partitions_info - Wrapper function for FFA_PARTITION_INFO_GET + * + * @func_data: Pointer to the FF-A function arguments container + * structure. + * The passed arguments: + * Mode 1: When getting from the driver the number of + * secure partitions: + * @data0_size: UUID size + * @data0: pointer to the UUID (little endian) + * @data1_size: size of the number of partitions + * variable + * @data1: pointer to the number of partitions + * variable. The variable will be set + * by the driver + * Mode 2: When requesting the driver to return the + * partitions information: + * @data0_size: UUID size + * @data0: pointer to the UUID (little endian) + * @data1_size: size of the SPs information buffer + * @data1: pointer to SPs information buffer + * (allocated by the client). + * The buffer will be filled by the driver + * + * This is the boot time function used by clients who wants to get from secure + * world the partition(s) information. + * + * A client of the FF-A driver should know the UUID of the service it wants to + * access. It should use the UUID to request the FF-A driver to provide the + * partition(s) information of the service. The client should use + * ffa_helper_get_partitions_info to pass the UUID information to the driver + * which uses PARTITION_INFO_GET to obtain the partition(s) information. + * + * ffa_helper_get_partitions_info should be called twice. First call is to get + * from the driver the number of secure partitions (SPs) associated to a + * particular UUID. Then, the caller (client) allocates the buffer to host the + * SPs data and issues a 2nd call. Then, the driver fills the SPs data in the + * pre-allocated buffer. + * + * Return: + * + * FFA_ERR_STAT_SUCCESS on success. Otherwise, failure + */ +int ffa_helper_get_partitions_info(struct ffa_interface_data *func_data) +{ + return ffa_get_invoke_func(FFA_PARTITION_INFO_GET, func_data); +} + +/** + * ffa_helper_unmap_rxtx_buffers - Wrapper function for FFA_RXTX_UNMAP + * + * This is the boot time function that allows clients to unmap the RX/TX + * buffers + * + * Return: + * + * FFA_ERR_STAT_SUCCESS on success. Otherwise, failure + */ +int ffa_helper_unmap_rxtx_buffers(void) +{ + return ffa_get_invoke_func(FFA_RXTX_UNMAP, NULL); +} + +/** + * ffa_helper_msg_send_direct_req - Wrapper function for + * FFA_MSG_SEND_DIRECT_{REQ,RESP} + * @func_data: Pointer to the FF-A function arguments container structure. + * The passed arguments: + * @data0_size: partition ID size + * @data0: pointer to the partition ID + * @data1_size: exchanged data size + * @data1: pointer to the data buffer preallocated by the client (in/out) + * + * This is the runtime function that allows clients to send data to the secure + * world partitions. The arm_ffa driver uses FFA_MSG_SEND_DIRECT_REQ to send the + * data to the secure partition. The response from the secure partition is + * handled internally by the driver using FFA_MSG_SEND_DIRECT_RESP and returned + * to ffa_helper_msg_send_direct_req through @func_data + * + * The maximum size of the data that can be exchanged is 20 bytes which is + * sizeof(struct ffa_send_direct_data) as defined by the FF-A specification 1.0 + * in the section relevant to FFA_MSG_SEND_DIRECT_{REQ,RESP} + * + * The client should pre-allocate a buffer pointed by @data1 which the size + * is sizeof(struct ffa_send_direct_data) + * + * Return: + * + * FFA_ERR_STAT_SUCCESS on success. Otherwise, failure + */ +int __ffa_runtime ffa_helper_msg_send_direct_req(struct ffa_interface_data + *func_data) +{ + return ffa_get_invoke_func(FFA_MSG_SEND_DIRECT_REQ, func_data); +} + +/** + * ffa_helper_bus_discover - Wrapper function for FF-A bus discovery + * + * This boot time function should be called to discover the FF-A bus and + * probe the FF-A device. + * To achieve that, this function is called automatically at initcalls + * level (after u-boot relocation). + * + * Return: + * + * FFA_ERR_STAT_SUCCESS on success. Otherwise, failure + */ +int ffa_helper_bus_discover(void) +{ + return ffa_bus_discover(); +} + +/** + * ffa_uuid_str_to_bin - Converts a big endian UUID string to a little endian buffer + * @uuid_str: UUID string in big endian format (36 bytes wide + '/0') + * @uuid_bin: preallocated 16 bytes UUID buffer in little endian format + * + * UUID binary format used by the FF-A framework (16 bytes): + * + * [LSB] 4B-2B-2B-2B-6B (little endian data fields) + * + * UUID string is 36 length of characters (36 bytes): + * + * xxxxxxxx-xxxx-xxxx-xxxx-xxxxxxxxxxxx + * be be be be be + * + * where x is a hexadecimal character. Fields are separated by '-'s. + * When converting to a binary UUID, these endianness rules apply: + * be: means the field in the string is considered a big endian hex number + * and should be converted to little endian binary format + * + * Return: + * + * uuid_bin filled with little endian UUID data + * On success 0 is returned. Otherwise, failure code. + */ +int ffa_uuid_str_to_bin(const char *uuid_str, unsigned char *uuid_bin) +{ + u16 tmp16 = 0; + u32 tmp32 = 0; + u64 tmp64 = 0; + + if (!uuid_str_valid(uuid_str) || !uuid_bin) + return -EINVAL; + + /* + * reverse bytes from big to little endian + */ + tmp32 = simple_strtoul(uuid_str, NULL, 16); + memcpy(uuid_bin, &tmp32, 4); + + /* + * reverse bytes from big to little endian + */ + tmp16 = simple_strtoul(uuid_str + 9, NULL, 16); + memcpy(uuid_bin + 4, &tmp16, 2); + + /* + * reverse bytes from big to little endian + */ + tmp16 = simple_strtoul(uuid_str + 14, NULL, 16); + memcpy(uuid_bin + 6, &tmp16, 2); + + /* + * reverse bytes from big to little endian + */ + tmp16 = simple_strtoul(uuid_str + 19, NULL, 16); + memcpy(uuid_bin + 8, &tmp16, 2); + + /* + * reverse bytes from big to little endian + */ + tmp64 = simple_strtoull(uuid_str + 24, NULL, 16); + memcpy(uuid_bin + 10, (char *)&tmp64, 6); + + return 0; +} diff --git a/lib/efi_loader/efi_boottime.c b/lib/efi_loader/efi_boottime.c index 5bcb8253ed..cffa2c69d6 100644 --- a/lib/efi_loader/efi_boottime.c +++ b/lib/efi_loader/efi_boottime.c @@ -23,6 +23,10 @@ #include <asm/setjmp.h> #include <linux/libfdt_env.h>
+#if defined(CONFIG_ARM_FFA_TRANSPORT) +#include <arm_ffa_helper.h> +#endif + DECLARE_GLOBAL_DATA_PTR;
/* Task priority level */ @@ -2114,6 +2118,10 @@ static efi_status_t EFIAPI efi_exit_boot_services(efi_handle_t image_handle, struct efi_event *evt, *next_event; efi_status_t ret = EFI_SUCCESS;
+#if defined(CONFIG_ARM_FFA_TRANSPORT) + int ffa_ret; +#endif + EFI_ENTRY("%p, %zx", image_handle, map_key);
/* Check that the caller has read the current memory map */ @@ -2174,6 +2182,15 @@ static efi_status_t EFIAPI efi_exit_boot_services(efi_handle_t image_handle, dm_remove_devices_flags(DM_REMOVE_ACTIVE_ALL); }
+#if defined(CONFIG_ARM_FFA_TRANSPORT) + /* unmap FF-A RX/TX buffers */ + ffa_ret = ffa_helper_unmap_rxtx_buffers(); + if (ffa_ret) + debug("[efi_boottime][ERROR]: can not unmap FF-A RX/TX buffers\n"); + else + debug("[efi_boottime][INFO]: FF-A RX/TX buffers unmapped\n"); +#endif + /* Patch out unsupported runtime function */ efi_runtime_detach();
Hi Abdellatif On Fri, Apr 15, 2022 at 01:27:58PM +0100, abdellatif.elkhlifi@arm.com wrote:
From: Abdellatif El Khlifi abdellatif.elkhlifi@arm.com
Add the driver implementing Arm Firmware Framework for Armv8-A v1.0
The Firmware Framework for Arm A-profile processors (FF-A) describes interfaces (ABIs) that standardize communication between the Secure World and Normal World leveraging TrustZone technology. This driver uses SMC32 calling convention.
In u-boot FF-A design, FF-A is considered as a discoverable bus. The Secure World is considered as one entity to communicate with using the FF-A bus. FF-A communication is handled by one device and one instance (the bus). This FF-A driver takes care of all the interactions between Normal world and Secure World.
The driver provides helper FF-A interfaces for user layers. These helper functions allow clients to pass data and select the FF-A function to use for the communication with secure world.
Signed-off-by: Abdellatif El Khlifi abdellatif.elkhlifi@arm.com +++ b/arch/arm/cpu/armv8/smccc-call.S @@ -1,6 +1,8 @@ /* SPDX-License-Identifier: GPL-2.0 */ /*
- Copyright (c) 2015, Linaro Limited
- (C) Copyright 2022 ARM Limited
- Abdellatif El Khlifi abdellatif.elkhlifi@arm.com
#include <linux/linkage.h> #include <linux/arm-smccc.h> @@ -45,3 +47,28 @@ ENDPROC(__arm_smccc_smc) ENTRY(__arm_smccc_hvc) SMCCC hvc ENDPROC(__arm_smccc_hvc)
- .macro FFASMCCC instr
- .cfi_startproc
- \instr #0
- ldr x9, [sp]
- stp x0, x1, [x9, #ARM_SMCCC_RES_X0_OFFS]
- stp x2, x3, [x9, #ARM_SMCCC_RES_X2_OFFS]
- stp x4, x5, [x9, #ARM_SMCCC_RES_X4_OFFS]
- stp x6, x7, [x9, #ARM_SMCCC_RES_X6_OFFS]
- ret
- .cfi_endproc
- .endm
- void arm_ffa_smccc_smc(unsigned long a0, unsigned long a1, unsigned long a2,
unsigned long a3, unsigned long a4, unsigned long a5,
unsigned long a6, unsigned long a7, struct arm_smccc_res *res)
+ENTRY(__arm_ffa_smccc_smc)
- FFASMCCC smc
+ENDPROC(__arm_ffa_smccc_smc)
+#endif diff --git a/arch/arm/lib/asm-offsets.c b/arch/arm/lib/asm-offsets.c index 22fd541f9a..02a4a42fe6 100644 --- a/arch/arm/lib/asm-offsets.c +++ b/arch/arm/lib/asm-offsets.c @@ -9,6 +9,8 @@
- generate asm statements containing #defines,
- compile this file to assembler, and then extract the
- #defines from the assembly-language output.
#include <common.h> @@ -115,6 +117,10 @@ int main(void) #ifdef CONFIG_ARM_SMCCC DEFINE(ARM_SMCCC_RES_X0_OFFS, offsetof(struct arm_smccc_res, a0)); DEFINE(ARM_SMCCC_RES_X2_OFFS, offsetof(struct arm_smccc_res, a2)); +#if (IS_ENABLED(CONFIG_ARM_FFA_TRANSPORT))
- DEFINE(ARM_SMCCC_RES_X4_OFFS, offsetof(struct arm_smccc_res, a4));
- DEFINE(ARM_SMCCC_RES_X6_OFFS, offsetof(struct arm_smccc_res, a6));
+#endif DEFINE(ARM_SMCCC_QUIRK_ID_OFFS, offsetof(struct arm_smccc_quirk, id)); DEFINE(ARM_SMCCC_QUIRK_STATE_OFFS, offsetof(struct arm_smccc_quirk, state)); #endif diff --git a/common/board_r.c b/common/board_r.c index b92c1bb0be..bb5f1d0aa6 100644 --- a/common/board_r.c +++ b/common/board_r.c @@ -62,6 +62,10 @@ #include <asm-generic/gpio.h> #include <efi_loader.h>
+#ifdef CONFIG_ARM_FFA_TRANSPORT +#include <arm_ffa_helper.h> +#endif
ulong monitor_flash_len; @@ -771,6 +775,9 @@ static init_fnc_t init_sequence_r[] = { INIT_FUNC_WATCHDOG_RESET initr_net, #endif +#ifdef CONFIG_ARM_FFA_TRANSPORT
- ffa_helper_bus_discover,
+#endif #ifdef CONFIG_POST initr_post, #endif diff --git a/drivers/Kconfig b/drivers/Kconfig index b26ca8cf70..e83c23789d 100644 --- a/drivers/Kconfig +++ b/drivers/Kconfig @@ -6,6 +6,8 @@ source "drivers/core/Kconfig"
source "drivers/adc/Kconfig"
+source "drivers/arm-ffa/Kconfig"
source "drivers/ata/Kconfig"
source "drivers/axi/Kconfig" diff --git a/drivers/Makefile b/drivers/Makefile index 4e7cf28440..6671d2a604 100644 --- a/drivers/Makefile +++ b/drivers/Makefile @@ -107,6 +107,7 @@ obj-y += iommu/ obj-y += smem/ obj-y += thermal/ obj-$(CONFIG_TEE) += tee/ +obj-$(CONFIG_ARM_FFA_TRANSPORT) += arm-ffa/ obj-y += axi/ obj-y += ufs/ obj-$(CONFIG_W1) += w1/ diff --git a/drivers/arm-ffa/Kconfig b/drivers/arm-ffa/Kconfig new file mode 100644 index 0000000000..23815534c4 --- /dev/null +++ b/drivers/arm-ffa/Kconfig @@ -0,0 +1,27 @@ +# SPDX-License-Identifier: GPL-2.0
- bool "Enable Arm Firmware Framework for Armv8-A driver"
- depends on DM && ARM64
- select ARM_SMCCC if ARM64
- select LIB_UUID
- select ARM_FFA_TRANSPORT_HELPERS
- help
technology.
This driver is based on FF-A specification v1.0 and uses SMC32
calling convention.
FF-A specification:
https://developer.arm.com/documentation/den0077/a/?lang=en
using the FF-A bus.
and Secure World.
diff --git a/drivers/arm-ffa/Makefile b/drivers/arm-ffa/Makefile new file mode 100644 index 0000000000..7bc9a336a9 --- /dev/null +++ b/drivers/arm-ffa/Makefile @@ -0,0 +1,6 @@ +# SPDX-License-Identifier: GPL-2.0+ +# +# (C) Copyright 2022 Abdellatif El Khlifi abdellatif.elkhlifi@arm.com +#
+obj-y += arm-ffa-uclass.o core.o diff --git a/drivers/arm-ffa/arm-ffa-uclass.c b/drivers/arm-ffa/arm-ffa-uclass.c new file mode 100644 index 0000000000..2439f87586 --- /dev/null +++ b/drivers/arm-ffa/arm-ffa-uclass.c @@ -0,0 +1,64 @@ +// SPDX-License-Identifier: GPL-2.0+ +/*
+#include <common.h> +#include <dm.h> +#include <arm_ffa.h> +#include <errno.h> +#include <log.h> +#include <asm/global_data.h>
+UCLASS_DRIVER(ffa) = {
- .name = "ffa",
- .id = UCLASS_FFA,
- ffa_get_invoke_func - performs a call to the FF-A driver dispatcher
- @func_id: The FF-A function to be used
- @func_data: Pointer to the FF-A function arguments
container structure. This also includes
pointers to the returned data needed by
clients.
- This runtime function passes the FF-A function ID and its arguments to
- the FF-A driver dispatcher.
- This function is called by the FF-A helper functions.
- Return:
- FFA_ERR_STAT_SUCCESS on success. Otherwise, failure
+int __ffa_runtime ffa_get_invoke_func(u32 func_id, struct ffa_interface_data *func_data) +{
- if (!ffa_device_get_ops()->invoke_func)
return -EINVAL;
- return ffa_device_get_ops()->invoke_func(func_id, func_data);
- ffa_bus_discover - discover FF-A bus and probe the arm_ffa device
- This boot time function makes sure the FF-A bus is discoverable.
- Then, the arm_ffa device is probed and ready to use.
- This function is called automatically at initcalls
- level (after u-boot relocation).
- Arm FF-A transport is implemented through arm_ffa u-boot device managing the FF-A
- communication.
- All FF-A clients should use the arm_ffa device to use the FF-A transport.
- Return:
+int ffa_bus_discover(void) +{
- return ffa_get_device();
+} diff --git a/drivers/arm-ffa/arm_ffa_prv.h b/drivers/arm-ffa/arm_ffa_prv.h new file mode 100644 index 0000000000..44f258addb --- /dev/null +++ b/drivers/arm-ffa/arm_ffa_prv.h @@ -0,0 +1,193 @@ +/* SPDX-License-Identifier: GPL-2.0+ */ +/*
+#ifndef __ARM_FFA_PRV_H +#define __ARM_FFA_PRV_H
+#include <arm_ffa.h> +#include <linux/bitfield.h> +#include <linux/bitops.h> +#include <dm/read.h>
- This header is private. It is exclusively used by the FF-A driver
+/* FF-A core driver name */ +#define FFA_DRV_NAME "arm_ffa"
+/* FF-A driver version definitions */
+#define MAJOR_VERSION_MASK GENMASK(30, 16) +#define MINOR_VERSION_MASK GENMASK(15, 0) +#define GET_FFA_MAJOR_VERSION(x) \
((u16)(FIELD_GET(MAJOR_VERSION_MASK, (x))))
+#define GET_FFA_MINOR_VERSION(x) \
((u16)(FIELD_GET(MINOR_VERSION_MASK, (x))))
+#define PACK_VERSION_INFO(major, minor) \
- (FIELD_PREP(MAJOR_VERSION_MASK, (major)) | \
FIELD_PREP(MINOR_VERSION_MASK, (minor)))
+#define FFA_MAJOR_VERSION (1) +#define FFA_MINOR_VERSION (0) +#define FFA_VERSION_1_0 \
PACK_VERSION_INFO(FFA_MAJOR_VERSION, FFA_MINOR_VERSION)
+/* Endpoint ID mask (u-boot endpoint ID) */
+#define GET_SELF_ENDPOINT_ID_MASK GENMASK(15, 0) +#define GET_SELF_ENDPOINT_ID(x) \
((u16)(FIELD_GET(GET_SELF_ENDPOINT_ID_MASK, (x))))
+#define PREP_SELF_ENDPOINT_ID_MASK GENMASK(31, 16) +#define PREP_SELF_ENDPOINT_ID(x) \
(FIELD_PREP(PREP_SELF_ENDPOINT_ID_MASK, (x)))
+/* Partition endpoint ID mask (partition with which u-boot communicates with) */
+#define PREP_PART_ENDPOINT_ID_MASK GENMASK(15, 0) +#define PREP_PART_ENDPOINT_ID(x) \
(FIELD_PREP(PREP_PART_ENDPOINT_ID_MASK, (x)))
+/* The FF-A SMC function prototype definition */
+typedef void (*invoke_ffa_fn_t)(unsigned long a0, unsigned long a1,
- enum ffa_conduit - Arm FF-A conduits supported by the Arm FF-A driver
- Currently only SMC32 is supported.
+enum ffa_conduit {
- FFA_CONDUIT_SMC = 0,
- FFA_DECLARE_ARGS - FF-A functions local variables
- @a0-a7: local variables used to set registers x0-x7
- @res: the structure hosting the FF-A function return data
- A helper macro for declaring local variables for the FF-A functions arguments.
- The x0-x7 registers are used to exchange data with the secure world.
- But, only the bottom 32-bit of thes registers contains the data.
+#define FFA_DECLARE_ARGS \
- unsigned long a0 = 0; \
- unsigned long a1 = 0; \
- unsigned long a2 = 0; \
- unsigned long a3 = 0; \
- unsigned long a4 = 0; \
- unsigned long a5 = 0; \
- unsigned long a6 = 0; \
- unsigned long a7 = 0; \
- struct arm_smccc_res res = {0}
+/* FF-A error codes */ +#define FFA_ERR_STAT_NOT_SUPPORTED (-1) +#define FFA_ERR_STAT_INVALID_PARAMETERS (-2) +#define FFA_ERR_STAT_NO_MEMORY (-3) +#define FFA_ERR_STAT_BUSY (-4) +#define FFA_ERR_STAT_INTERRUPTED (-5) +#define FFA_ERR_STAT_DENIED (-6) +#define FFA_ERR_STAT_RETRY (-7) +#define FFA_ERR_STAT_ABORTED (-8)
- struct ffa_features_desc - FF-A functions features
- @func_id: FF-A function
- @field1: features read from register w2
- @field2: features read from register w3
- Data structure describing the features of the FF-A functions queried by
- FFA_FEATURES
+struct ffa_features_desc {
- u32 func_id;
- u32 field1;
- u32 field2;
- enum ffa_rxtx_buf_sizes - minimum sizes supported
- for the RX/TX buffers
+enum ffa_rxtx_buf_sizes {
- RXTX_4K,
- RXTX_64K,
- RXTX_16K
- Number of the FF-A interfaces features descriptors
- currently only FFA_RXTX_MAP descriptor is supported
+#define FFA_FEATURE_DESC_CNT (1)
- struct ffa_rxtxpair - structure hosting the RX/TX buffers virtual addresses
- @rxbuf: virtual address of the RX buffer
- @txbuf: virtual address of the TX buffer
- Data structure hosting the virtual addresses of the mapped RX/TX buffers
- These addresses are used by the FF-A functions that use the RX/TX buffers
+struct ffa_rxtxpair {
- u64 rxbuf; /* virtual address */
- u64 txbuf; /* virtual address */
- struct ffa_partition_desc - the secure partition descriptor
- @info: partition information
- @UUID: UUID
- Each partition has its descriptor containing the partitions information and the UUID
+struct ffa_partition_desc {
- struct ffa_partition_info info;
- union ffa_partition_uuid UUID;
- struct ffa_partitions - descriptors for all secure partitions
- @count: The number of partitions descriptors
- @descs The partitions descriptors table
- This data structure contains the partitions descriptors table
+struct ffa_partitions {
- u32 count;
- struct ffa_partition_desc *descs; /* virtual address */
- struct ffa_prvdata - the driver private data structure
- @dev: The arm_ffa device under u-boot driver model
- @fwk_version: FF-A framework version
- @id: u-boot endpoint ID
- @partitions: The partitions descriptors structure
- @pair: The RX/TX buffers pair
- @conduit: The selected conduit
- @invoke_ffa_fn: The function executing the FF-A function
- @features: Table of the FF-A functions having features
- The driver data structure hosting all resident data.
+struct ffa_prvdata {
- struct udevice *dev;
- u32 fwk_version;
- u16 id;
- struct ffa_partitions partitions;
- struct ffa_rxtxpair pair;
- enum ffa_conduit conduit;
- invoke_ffa_fn_t invoke_ffa_fn;
- struct ffa_features_desc features[FFA_FEATURE_DESC_CNT];
+#endif diff --git a/drivers/arm-ffa/core.c b/drivers/arm-ffa/core.c new file mode 100644 index 0000000000..09e4eb753a --- /dev/null +++ b/drivers/arm-ffa/core.c @@ -0,0 +1,1349 @@ +// SPDX-License-Identifier: GPL-2.0+ +/*
+#include "arm_ffa_prv.h" +#include <asm/global_data.h> +#include <asm/io.h> +#include <common.h> +#include <dm.h> +#include <dm/device-internal.h> +#include <dm/root.h> +#include <linux/errno.h> +#include <linux/sizes.h> +#include <log.h> +#include <malloc.h> +#include <mapmem.h> +#include <string.h>
+DECLARE_GLOBAL_DATA_PTR;
- The device private data structure containing all the resident
- data read from secure world
+struct ffa_prvdata __ffa_runtime_data ffa_priv_data = {0};
- Driver functions
- ffa_get_device - create, bind and probe the arm_ffa device
- This boot time function makes sure the arm_ffa device is
- created, bound to this driver, probed and ready to use.
- Arm FF-A transport is implemented through a single u-boot
- device managing the FF-A bus (arm_ffa).
- Return:
+int ffa_get_device(void) +{
- int ret;
- if (ffa_priv_data.dev)
- ret = device_bind(dm_root(),
DM_DRIVER_GET(arm_ffa),
FFA_DRV_NAME,
NULL,
ofnode_null(),
&ffa_priv_data.dev);
- if (ret) {
ffa_priv_data.dev = NULL;
return ret;
- /* The FF-A bus discovery succeeds when probing is successful */
- ret = device_probe(ffa_priv_data.dev);
- if (ret) {
ffa_err("can not probe the device");
device_unbind(ffa_priv_data.dev);
return ret;
- return FFA_ERR_STAT_SUCCESS;
- ffa_get_version - FFA_VERSION handler function
- This is the boot time function that implements FFA_VERSION FF-A function
- to get from the secure world the FF-A framework version
- Return:
+static int ffa_get_version(void) +{
- u16 major, minor;
- FFA_DECLARE_ARGS;
- if (!ffa_priv_data.invoke_ffa_fn)
- a0 = FFA_VERSION;
- a1 = FFA_VERSION_1_0;
- ffa_priv_data.invoke_ffa_fn(a0, a1, a2, a3, a4, a5, a6, a7, &res);
- if (res.a0 == FFA_ERR_STAT_NOT_SUPPORTED) {
ffa_err("A Firmware Framework implementation does not exist");
return -EOPNOTSUPP;
- major = GET_FFA_MAJOR_VERSION(res.a0);
- minor = GET_FFA_MINOR_VERSION(res.a0);
- ffa_info("FF-A driver %d.%d\nFF-A framework %d.%d",
FFA_MAJOR_VERSION, FFA_MINOR_VERSION, major, minor);
- if ((major == FFA_MAJOR_VERSION && minor >= FFA_MINOR_VERSION)) {
ffa_info("Versions are compatible ");
ffa_priv_data.fwk_version = res.a0;
- ffa_info("Versions are incompatible ");
- return -EPROTONOSUPPORT;
- ffa_get_endpoint_id - FFA_ID_GET handler function
- This is the boot time function that implements FFA_ID_GET FF-A function
- to get from the secure world u-boot endpoint ID
- Return:
+static int ffa_get_endpoint_id(void) +{
- FFA_DECLARE_ARGS;
- a0 = FFA_ID_GET;
- switch (res.a0) {
- case FFA_ERROR:
if (((int)res.a2) == FFA_ERR_STAT_NOT_SUPPORTED) {
return -EOPNOTSUPP;
ffa_err("Undefined error code (%d)", ((int)res.a2));
return -EINVAL;
- case FFA_SUCCESS:
ffa_priv_data.id = GET_SELF_ENDPOINT_ID(res.a2);
ffa_info("endpoint ID is %u", ffa_priv_data.id);
- default:
return -EINVAL;
- ffa_get_features_desc - returns the features descriptor of the specified
FF-A function
- @func_id: the FF-A function which the features are to be retrieved
- This is a boot time function that searches the features descriptor of the
- specified FF-A function
- Return:
- When found, the address of the features descriptor is returned. Otherwise, NULL.
+static struct ffa_features_desc *ffa_get_features_desc(u32 func_id) +{
- u32 desc_idx;
* search for the descriptor of the selected FF-A interface
- for (desc_idx = 0; desc_idx < FFA_FEATURE_DESC_CNT ; desc_idx++)
if (ffa_priv_data.features[desc_idx].func_id == func_id)
return &ffa_priv_data.features[desc_idx];
- return NULL;
- ffa_get_rxtx_map_features - FFA_FEATURES handler function with FFA_RXTX_MAP
argument
- This is the boot time function that implements FFA_FEATURES FF-A function
- to retrieve the FFA_RXTX_MAP features
- Return:
+static int ffa_get_rxtx_map_features(void) +{
- FFA_DECLARE_ARGS;
- a0 = FFA_FEATURES;
- a1 = FFA_RXTX_MAP;
- switch (res.a0) {
- case FFA_ERROR:
ffa_err("FFA_RXTX_MAP is not implemented at this FF-A instance");
return -EOPNOTSUPP;
return -EINVAL;
This happens quite a few times throughout the code. Why is -EINVAL used here instead of -FFA_ERR_STAT_INVALID_PARAMETERS for example?
We should either use FFA_* errors consistently of get rid of those entirely and stick to standard ones, but let's not mix and match
- case FFA_SUCCESS:
u32 desc_idx;
* search for an empty descriptor
if (!ffa_priv_data.features[desc_idx].func_id) {
* populate the descriptor with
* the interface features data
FFA_RXTX_MAP;
ffa_priv_data.features[desc_idx].field1 =
res.a2;
ffa_info("FFA_RXTX_MAP features data 0x%lx",
res.a2);
ffa_err("Cannot save FFA_RXTX_MAP features data. Descriptors table full");
return -ENOBUFS;
Similarly -FFA_ERR_STAT_NO_MEMORY or something?
- default:
res.a0);
return -EINVAL;
- ffa_get_rxtx_buffers_pages_cnt - reads from the features data descriptors
the minimum number of pages in each of the RX/TX
buffers
- @buf_4k_pages: Pointer to the minimum number of pages
- This is the boot time function that returns the minimum number of pages
- in each of the RX/TX buffers
- Return:
- buf_4k_pages points to the returned number of pages
+static int ffa_get_rxtx_buffers_pages_cnt(size_t *buf_4k_pages) +{
- struct ffa_features_desc *desc = NULL;
- if (!buf_4k_pages)
return -EINVAL;
- desc = ffa_get_features_desc(FFA_RXTX_MAP);
- if (!desc)
return -EINVAL;
- switch (desc->field1) {
- case RXTX_4K:
*buf_4k_pages = 1;
break;
- case RXTX_16K:
*buf_4k_pages = 4;
break;
- case RXTX_64K:
*buf_4k_pages = 16;
break;
- default:
ffa_err("RX/TX buffer size not supported");
return -EINVAL;
- ffa_free_rxtx_buffers - frees the RX/TX buffers
- @buf_4k_pages: the minimum number of pages in each of the RX/TX
buffers
- This is the boot time function used to free the RX/TX buffers
- Return:
+static int ffa_free_rxtx_buffers(size_t buf_4k_pages) +{
- efi_status_t free_rxbuf_ret, free_txbuf_ret;
- ffa_info("Freeing RX/TX buffers");
- free_rxbuf_ret = efi_free_pages(ffa_priv_data.pair.rxbuf, buf_4k_pages);
- free_txbuf_ret = efi_free_pages(ffa_priv_data.pair.txbuf, buf_4k_pages);
- if (free_rxbuf_ret != EFI_SUCCESS || free_txbuf_ret != EFI_SUCCESS) {
ffa_err("Failed to free RX/TX buffers (rx: %lu , tx: %lu)",
free_rxbuf_ret,
free_txbuf_ret);
return -EINVAL;
- ffa_priv_data.pair.rxbuf = 0;
- ffa_priv_data.pair.txbuf = 0;
Should those be set to 0 regardless of the efi_free_pages() outcome? If not then you probably need to handle those one by one. As is it right now one failure to free a buffer means both of those won't be set
- ffa_alloc_rxtx_buffers - allocates the RX/TX buffers
buffers
- This is the boot time function used by ffa_map_rxtx_buffers to allocate
- the RX/TX buffers before mapping them
- Return:
+static int ffa_alloc_rxtx_buffers(size_t buf_4k_pages) +{ +#if CONFIG_IS_ENABLED(EFI_LOADER)
- efi_status_t efi_ret;
- void *virt_txbuf;
- void *virt_rxbuf;
- ffa_info("Using %lu 4KB page(s) for RX/TX buffers size",
buf_4k_pages);
- efi_ret = efi_allocate_pages(EFI_ALLOCATE_ANY_PAGES,
EFI_BOOT_SERVICES_DATA,
buf_4k_pages,
&ffa_priv_data.pair.rxbuf);
Why are we specifically limiting this to EFI? I understand using efi allocated memory for potential runtime operations, were we need the memory preserved, but why here?
There's also a side effect with this allocation. The EFI subsystem doesn't usually come up until u-boot is fully up and running. This call will force it to start way earlier
- if (efi_ret != EFI_SUCCESS) {
ffa_err("Failure to allocate RX buffer (EFI error: 0x%lx)",
efi_ret);
return -ENOBUFS;
- ffa_info("RX buffer at virtual address 0x%llx",
- virt_rxbuf = (void *)ffa_priv_data.pair.rxbuf;
- memset(virt_rxbuf, 0, buf_4k_pages * SZ_4K);
buf_4k_pages,
&ffa_priv_data.pair.txbuf);
ffa_err("Failure to allocate the TX buffer (EFI error: 0x%lx)"
, efi_ret);
return -ENOBUFS;
- ffa_info("TX buffer at virtual address 0x%llx",
- virt_txbuf = (void *)ffa_priv_data.pair.txbuf;
- memset(virt_txbuf, 0, buf_4k_pages * SZ_4K);
+#else
- return -ENOBUFS;
+#endif +}
- ffa_map_rxtx_buffers - FFA_RXTX_MAP handler function
buffers
- This is the boot time function that implements FFA_RXTX_MAP FF-A function
- to map the RX/TX buffers
- Return:
+static int ffa_map_rxtx_buffers(size_t buf_4k_pages) +{
- int ret;
- FFA_DECLARE_ARGS;
- ret = ffa_alloc_rxtx_buffers(buf_4k_pages);
- if (ret != FFA_ERR_STAT_SUCCESS)
return ret;
- a0 = FFA_RXTX_MAP;
- a1 = ffa_priv_data.pair.txbuf;
- a2 = ffa_priv_data.pair.rxbuf;
- a3 = buf_4k_pages;
- switch (res.a0) {
- case FFA_ERROR:
ffa_err("One or more fields in input parameters is incorrectly encoded");
ret = -EPERM;
break;
ffa_err("Not enough memory");
ret = -ENOMEM;
break;
ffa_err("Buffer pair already registered");
ret = -EACCES;
break;
ret = -EOPNOTSUPP;
break;
default:
((int)res.a2));
ret = -EINVAL;
Can we have an array with string literals for the errors and do a lookup instead of nested case switches?
break;
- case FFA_SUCCESS:
ffa_info("RX/TX buffers mapped");
- default:
res.a0);
ret = -EINVAL;
- ffa_free_rxtx_buffers(buf_4k_pages);
- return ret;
- ffa_unmap_rxtx_buffers - FFA_RXTX_UNMAP handler function
- This is the boot time function that implements FFA_RXTX_UNMAP FF-A function
- to unmap the RX/TX buffers
- Return:
+static int ffa_unmap_rxtx_buffers(void) +{
- FFA_DECLARE_ARGS;
- a0 = FFA_RXTX_UNMAP;
- a1 = PREP_SELF_ENDPOINT_ID(ffa_priv_data.id);
- switch (res.a0) {
- case FFA_ERROR:
panic("[FFA] FFA_RXTX_UNMAP is not implemented at this FF-A instance\n");
else if (((int)res.a2) == FFA_ERR_STAT_INVALID_PARAMETERS)
panic("[FFA] There is no buffer pair registered on behalf of the caller\n");
else
panic("[FFA] Undefined error (%d)\n", ((int)res.a2));
There's panics sprinkled around the code. Are all those cases really fatal?
- case FFA_SUCCESS:
int ret;
panic("[FFA] RX/TX buffers unmapped but failure in getting pages count\n");
ret = ffa_free_rxtx_buffers(buf_4k_pages);
panic("[FFA] RX/TX buffers unmapped but failure in freeing the memory\n");
ffa_info("RX/TX buffers unmapped and memory freed");
- default:
panic("[FFA] Undefined response function (0x%lx)", res.a0);
- ffa_release_rx_buffer - FFA_RX_RELEASE handler function
- This is the boot time function that invokes FFA_RX_RELEASE FF-A function
- to release the ownership of the RX buffer
- Return:
+static int ffa_release_rx_buffer(void) +{
- FFA_DECLARE_ARGS;
- a0 = FFA_RX_RELEASE;
- switch (res.a0) {
- case FFA_ERROR:
panic("[FFA] FFA_RX_RELEASE is not implemented at this FF-A instance\n");
else if (((int)res.a2) == FFA_ERR_STAT_DENIED)
panic("[FFA] Caller did not have ownership of the RX buffer\n");
else
- case FFA_SUCCESS:
- default:
panic("[FFA] Undefined response function (0x%lx)\n", res.a0);
- ffa_uuid_are_identical - checks whether two given UUIDs are identical
- @uuid1: first UUID
- @uuid2: second UUID
- This is a boot time function used by ffa_read_partitions_info to search
- for a UUID in the partitions descriptors table
- Return:
- 1 when UUIDs match. Otherwise, 0
+int ffa_uuid_are_identical(const union ffa_partition_uuid *uuid1,
const union ffa_partition_uuid *uuid2)
- if (!uuid1 || !uuid2)
- return (!memcmp(uuid1, uuid2, sizeof(union ffa_partition_uuid)));
- ffa_read_partitions_info - reads the data queried by FFA_PARTITION_INFO_GET
and saves it in the private structure
- @count: The number of partitions queried
- @part_uuid: Pointer to the partition(s) UUID
- This is the boot time function that reads the partitions information
- returned by the FFA_PARTITION_INFO_GET and saves it in the private
- data structure.
- Return:
- The private data structure is updated with the partition(s) information
- FFA_ERR_STAT_SUCCESS is returned on success. Otherwise, failure
+static int ffa_read_partitions_info(u32 count, union ffa_partition_uuid *part_uuid) +{
- if (!count) {
ffa_err("No partition detected");
return -ENODATA;
- ffa_info("Reading partitions data from the RX buffer");
- if (!part_uuid) {
* querying information of all partitions
u64 data_pages;
u64 data_bytes;
u32 desc_idx;
struct ffa_partition_info *parts_info;
int ret;
data_bytes = count * sizeof(struct ffa_partition_desc);
data_pages = efi_size_in_pages(data_bytes);
* get the RX buffer size in pages
ffa_err("Can not get the RX buffer size (error %d)", ret);
return ret;
if (data_pages > buf_4k_pages) {
ffa_err("Partitions data size exceeds the RX buffer size:");
ffa_err(" Sizes in pages: data %llu , RX buffer %lu ",
data_pages,
buf_4k_pages);
return -ENOMEM;
EFI_RUNTIME_SERVICES_DATA,
data_pages,
(u64 *)&ffa_priv_data.partitions.descs);
Same questions here. Why are we using the EFI APIs to allocate buffers?
ffa_priv_data.partitions.descs = NULL;
ffa_err("Cannot allocate partitions data buffer (EFI error 0x%lx)",
efi_ret);
return -ENOBUFS;
* make sure the buffer is clean before use
memset(ffa_priv_data.partitions.descs, 0,
data_pages * SZ_4K);
parts_info = (struct ffa_partition_info *)ffa_priv_data.pair.rxbuf;
for (desc_idx = 0 ; desc_idx < count ; desc_idx++) {
ffa_priv_data.partitions.descs[desc_idx].info =
parts_info[desc_idx];
ffa_info("Partition ID %x : info cached",
ffa_priv_data.partitions.count = count;
ffa_info("%d partition(s) found and cached", count);
- } else {
u32 rx_desc_idx, cached_desc_idx;
u8 desc_found;
* search for the SP IDs read from the RX buffer
* in the already cached SPs.
* Update the UUID when ID found.
for (rx_desc_idx = 0; rx_desc_idx < count ; rx_desc_idx++) {
desc_found = 0;
* search the current ID in the cached partitions
for (cached_desc_idx = 0;
cached_desc_idx < ffa_priv_data.partitions.count;
cached_desc_idx++) {
* save the UUID
if (ffa_priv_data.partitions.descs[cached_desc_idx].info.id ==
parts_info[rx_desc_idx].id) {
ffa_priv_data.partitions.descs[cached_desc_idx].UUID =
*part_uuid;
desc_found = 1;
break;
if (!desc_found)
return -ENODATA;
+#else +#warning "arm_ffa: reading FFA_PARTITION_INFO_GET data not implemented" +#endif
- ffa_query_partitions_info - invokes FFA_PARTITION_INFO_GET
and saves partitions data
- @pcount: Pointer to the number of partitions variable filled when querying
- This is the boot time function that executes the FFA_PARTITION_INFO_GET
- to query the partitions data. Then, it calls ffa_read_partitions_info
- to save the data in the private data structure.
- After reading the data the RX buffer is released using ffa_release_rx_buffer
- Return:
- When part_uuid is NULL, all partitions data are retrieved from secure world
- When part_uuid is non NULL, data for partitions matching the given UUID are
- retrieved and the number of partitions is returned
+static int ffa_query_partitions_info(union ffa_partition_uuid *part_uuid,
u32 *pcount)
- union ffa_partition_uuid query_uuid = {0};
- struct arm_smccc_res res = {0};
panic("[FFA] no private data found\n");
- a0 = FFA_PARTITION_INFO_GET;
* If a UUID is specified. Information for one or more
* partitions in the system is queried. Otherwise, information
* for all installed partitions is queried
- if (part_uuid) {
if (!pcount)
return -EINVAL;
query_uuid = *part_uuid;
- ffa_priv_data.invoke_ffa_fn(a0, query_uuid.words.a1, query_uuid.words.a2,
query_uuid.words.a3, query_uuid.words.a4,
a5, a6, a7, &res);
- switch (res.a0) {
- case FFA_ERROR:
ffa_err("Unrecognized UUID");
return -EPERM;
case FFA_ERR_STAT_NO_MEMORY:
ffa_err("Results cannot fit in RX buffer of the caller");
return -ENOMEM;
ffa_err("Callee is not in a state to handle this request");
return -EACCES;
ffa_err("This function is not implemented at this FF-A instance");
return -EOPNOTSUPP;
ffa_err("RX buffer of the caller is not free");
return -EBUSY;
default:
ffa_err("Undefined error (%d)", ((int)res.a2));
return -EINVAL;
Same cases as above. Please map those in an array or something and just do a lookup to print an error
- case FFA_SUCCESS:
int ret;
* res.a2 contains the count of partition information descriptors
* populated in the RX buffer
if (res.a2) {
ret = ffa_read_partitions_info(res.a2, part_uuid);
if (ret)
ffa_err("Failed to read partition(s) data , error (%d)", ret);
* return the SP count
if (part_uuid) {
if (!ret)
*pcount = res.a2;
else
*pcount = 0;
If I am following the code correctly this can be called with (NULL, NULL), which means that the previous !pcount check won't apply. Is there any other check I am missing?
* After calling FFA_PARTITION_INFO_GET the buffer ownership
* is assigned to the consumer (u-boot). So, we need to give
* the ownership back to the secure world
ret = ffa_release_rx_buffer();
if (!part_uuid && !res.a2) {
ffa_err("[FFA] no partition installed in the system");
return -ENODEV;
return ret;
- default:
ffa_err("Undefined response function (0x%lx)", res.a0);
return -EINVAL;
Regards /Ilias
- .cfi_startproc
- \instr #0
- ldr x9, [sp]
- ret
- .cfi_endproc
- .endm
- FFASMCCC smc
- select LIB_UUID
- help
technology.
calling convention.
FF-A specification:
using the FF-A bus.
and Secure World.
- .name = "ffa",
- .id = UCLASS_FFA,
clients.
- Return:
return -EINVAL;
- communication.
- Return:
+enum ffa_conduit {
- FFA_FEATURES
- u32 func_id;
- u32 field1;
- u32 field2;
- RXTX_4K,
- RXTX_64K,
- RXTX_16K
- @UUID: UUID
- u32 count;
- u32 fwk_version;
- u16 id;
- Driver functions
- Return:
- int ret;
FFA_DRV_NAME,
NULL,
ofnode_null(),
- if (ret) {
return ret;
- if (ret) {
return ret;
- Return:
- u16 major, minor;
- FFA_DECLARE_ARGS;
- a0 = FFA_VERSION;
return -EOPNOTSUPP;
- Return:
- FFA_DECLARE_ARGS;
- a0 = FFA_ID_GET;
- switch (res.a0) {
- case FFA_ERROR:
return -EOPNOTSUPP;
return -EINVAL;
- case FFA_SUCCESS:
- default:
return -EINVAL;
FF-A function
- Return:
- u32 desc_idx;
- return NULL;
argument
- Return:
- FFA_DECLARE_ARGS;
- switch (res.a0) {
- case FFA_ERROR:
return -EOPNOTSUPP;
return -EINVAL;
Thanks for all your feedbacks. Error handling and panics removal have been addressed in v4 patchset. Now we use a mapping mechanism and no panics anymore. please check: https://lore.kernel.org/all/20220926101723.9965-5-abdellatif.elkhlifi@arm.co...
- case FFA_SUCCESS:
u32 desc_idx;
FFA_RXTX_MAP;
res.a2;
res.a2);
return -ENOBUFS;
- default:
res.a0);
return -EINVAL;
buffers
- Return:
return -EINVAL;
- if (!desc)
return -EINVAL;
- case RXTX_4K:
*buf_4k_pages = 1;
break;
- case RXTX_16K:
*buf_4k_pages = 4;
break;
- case RXTX_64K:
*buf_4k_pages = 16;
break;
- default:
return -EINVAL;
buffers
- Return:
free_rxbuf_ret,
free_txbuf_ret);
return -EINVAL;
addressed in v4 patchset, please check: https://lore.kernel.org/all/20220926101723.9965-5-abdellatif.elkhlifi@arm.co...
buffers
- Return:
- void *virt_txbuf;
- void *virt_rxbuf;
buf_4k_pages);
buf_4k_pages,
In v4 the core driver is no longer dependent on EFI. The intent is to be able to compile it without EFI support. The use of EFI APIs has been dropped and replaced with generic u-boot APIs. When using EFI, FF-A core driver data needs to be copied to the EFI runtime section so it can be accessed at runtime. For that specific case, a new CONFIG_ARM_FFA_EFI_RUNTIME_MODE has been created to enable the feature of copying the data to the runtime section. The code that copies the data is provided by drivers/firmware/arm-ffa/efi_ffa_runtime_data_mgr.c When EFI is needed CONFIG_ARM_FFA_EFI_RUNTIME_MODE should be turned on. If no EFI needed the FF-A driver can still be used independently.
efi_ret);
return -ENOBUFS;
buf_4k_pages,
, efi_ret);
return -ENOBUFS;
+#else
- return -ENOBUFS;
+#endif +}
buffers
- Return:
- int ret;
- FFA_DECLARE_ARGS;
return ret;
- switch (res.a0) {
- case FFA_ERROR:
ret = -EPERM;
break;
ret = -ENOMEM;
break;
ret = -EACCES;
break;
ret = -EOPNOTSUPP;
break;
default:
((int)res.a2));
ret = -EINVAL;
break;
- case FFA_SUCCESS:
- default:
res.a0);
ret = -EINVAL;
- return ret;
- Return:
- FFA_DECLARE_ARGS;
- switch (res.a0) {
- case FFA_ERROR:
else
- case FFA_SUCCESS:
int ret;
- default:
- Return:
- FFA_DECLARE_ARGS;
- switch (res.a0) {
- case FFA_ERROR:
else
- case FFA_SUCCESS:
- default:
- Return:
- data structure.
- Return:
- if (!count) {
return -ENODATA;
- if (!part_uuid) {
u64 data_pages;
u64 data_bytes;
u32 desc_idx;
int ret;
return ret;
data_pages,
buf_4k_pages);
return -ENOMEM;
data_pages,
efi_ret);
return -ENOBUFS;
- } else {
u8 desc_found;
desc_found = 0;
* save the UUID
*part_uuid;
desc_found = 1;
break;
if (!desc_found)
return -ENODATA;
- Return:
u32 *pcount)
- if (part_uuid) {
if (!pcount)
return -EINVAL;
a5, a6, a7, &res);
- switch (res.a0) {
- case FFA_ERROR:
return -EPERM;
return -ENOMEM;
return -EACCES;
return -EOPNOTSUPP;
return -EBUSY;
default:
return -EINVAL;
- case FFA_SUCCESS:
int ret;
if (res.a2) {
if (ret)
if (part_uuid) {
if (!ret)
*pcount = res.a2;
else
*pcount = 0;
return -ENODEV;
return ret;
- default:
return -EINVAL;
Regards /Ilias
How come only the SMC32 calling convention is used? What if you need 64-bit pointers for some reason (RXTX_MAP comes to mind) ? Doing the 64-bit calling convention at the same time can't be much more work.
MAINTAINERS | 8 + arch/arm/cpu/armv8/smccc-call.S | 27 + arch/arm/lib/asm-offsets.c | 6 + common/board_r.c | 7 + drivers/Kconfig | 2 + drivers/Makefile | 1 + drivers/arm-ffa/Kconfig | 27 + drivers/arm-ffa/Makefile | 6 + drivers/arm-ffa/arm-ffa-uclass.c | 64 ++ drivers/arm-ffa/arm_ffa_prv.h | 193 +++++ drivers/arm-ffa/core.c | 1349 ++++++++++++++++++++++++++++++ include/arm_ffa.h | 190 +++++ include/arm_ffa_helper.h | 45 + include/dm/uclass-id.h | 1 + include/linux/arm-smccc.h | 28 +- lib/Kconfig | 1 + lib/Makefile | 1 + lib/arm-ffa/Kconfig | 6 + lib/arm-ffa/Makefile | 8 + lib/arm-ffa/arm_ffa_helper.c | 188 +++++ lib/efi_loader/efi_boottime.c | 17 + 21 files changed, 2174 insertions(+), 1 deletion(-) create mode 100644 drivers/arm-ffa/Kconfig create mode 100644 drivers/arm-ffa/Makefile create mode 100644 drivers/arm-ffa/arm-ffa-uclass.c create mode 100644 drivers/arm-ffa/arm_ffa_prv.h create mode 100644 drivers/arm-ffa/core.c create mode 100644 include/arm_ffa.h create mode 100644 include/arm_ffa_helper.h create mode 100644 lib/arm-ffa/Kconfig create mode 100644 lib/arm-ffa/Makefile create mode 100644 lib/arm-ffa/arm_ffa_helper.c
diff --git a/MAINTAINERS b/MAINTAINERS index aca97cd2a3..efa17206b8 100644 --- a/MAINTAINERS +++ b/MAINTAINERS @@ -232,6 +232,14 @@ F: board/CZ.NIC/ F: configs/turris_*_defconfig F: include/configs/turris_*.h
+ARM FF-A +M: Abdellatif El Khlifi abdellatif.elkhlifi@arm.com +S: Maintained +F: drivers/arm-ffa/ +F: include/arm_ffa.h +F: include/arm_ffa_helper.h +F: lib/arm-ffa/
ARM FREESCALE IMX M: Stefano Babic sbabic@denx.de M: Fabio Estevam festevam@gmail.com diff --git a/arch/arm/cpu/armv8/smccc-call.S b/arch/arm/cpu/armv8/smccc-call.S index dc92b28777..9a6aebf194 100644 --- a/arch/arm/cpu/armv8/smccc-call.S +++ b/arch/arm/cpu/armv8/smccc-call.S @@ -1,6 +1,8 @@ /* SPDX-License-Identifier: GPL-2.0 */ /*
- .cfi_startproc
- \instr #0
- ldr x9, [sp]
- ret
- .cfi_endproc
- .endm
- FFASMCCC smc
- select LIB_UUID
- help
technology.
calling convention.
FF-A specification:
using the FF-A bus.
and Secure World.
- .name = "ffa",
- .id = UCLASS_FFA,
clients.
- Return:
return -EINVAL;
- communication.
- Return:
+enum ffa_conduit {
Why is this enum needed?
- FFA_FEATURES
- u32 func_id;
- u32 field1;
- u32 field2;
- RXTX_4K,
- RXTX_64K,
- RXTX_16K
- @UUID: UUID
- u32 count;
- u32 fwk_version;
- u16 id;
- Driver functions
- Return:
- int ret;
FFA_DRV_NAME,
NULL,
ofnode_null(),
- if (ret) {
return ret;
- if (ret) {
return ret;
- Return:
- u16 major, minor;
- FFA_DECLARE_ARGS;
- a0 = FFA_VERSION;
return -EOPNOTSUPP;
This is an error, perhaps better to use ffa_err() instead. And mention the versions in question also since the info level might be disabled.
This is to get the vm id from an eventual hypervisor, or 0 if there isn't any hypervisor.
- Return:
- FFA_DECLARE_ARGS;
- a0 = FFA_ID_GET;
- switch (res.a0) {
- case FFA_ERROR:
return -EOPNOTSUPP;
return -EINVAL;
Are these extra braces really needed? Same below.
- case FFA_SUCCESS:
- default:
return -EINVAL;
FF-A function
- Return:
- u32 desc_idx;
- return NULL;
argument
- Return:
- FFA_DECLARE_ARGS;
- switch (res.a0) {
- case FFA_ERROR:
return -EOPNOTSUPP;
return -EINVAL;
- case FFA_SUCCESS:
u32 desc_idx;
FFA_RXTX_MAP;
res.a2;
res.a2);
This seems a bit more complicated than necessary. How about just save the block size in a separate fields in ffa_priv_data? That would also make it easier to understand what this value is without looking it up in the spec to remind oneself.
return -ENOBUFS;
- default:
res.a0);
return -EINVAL;
buffers
- Return:
return -EINVAL;
- if (!desc)
return -EINVAL;
- case RXTX_4K:
*buf_4k_pages = 1;
break;
- case RXTX_16K:
*buf_4k_pages = 4;
break;
- case RXTX_64K:
*buf_4k_pages = 16;
break;
- default:
return -EINVAL;
buffers
- Return:
free_rxbuf_ret,
free_txbuf_ret);
return -EINVAL;
buffers
- Return:
- void *virt_txbuf;
- void *virt_rxbuf;
buf_4k_pages);
buf_4k_pages,
efi_ret);
return -ENOBUFS;
buf_4k_pages,
, efi_ret);
return -ENOBUFS;
+#else
- return -ENOBUFS;
+#endif +}
buffers
- Return:
- int ret;
- FFA_DECLARE_ARGS;
return ret;
- switch (res.a0) {
- case FFA_ERROR:
switch (((int)res.a2)) {
case FFA_ERR_STAT_INVALID_PARAMETERS:
ret = -EPERM;
break;
ret = -ENOMEM;
break;
case FFA_ERR_STAT_DENIED:
ret = -EACCES;
break;
case FFA_ERR_STAT_NOT_SUPPORTED:
ret = -EOPNOTSUPP;
break;
default:
((int)res.a2));
ret = -EINVAL;
How about lookup table like in the kernel instead? It seems that this kind of translation will be needed a few times.
break;
- case FFA_SUCCESS:
- default:
res.a0);
ret = -EINVAL;
- return ret;
- Return:
- FFA_DECLARE_ARGS;
- switch (res.a0) {
- case FFA_ERROR:
else
- case FFA_SUCCESS:
int ret;
- default:
- Return:
- FFA_DECLARE_ARGS;
- switch (res.a0) {
- case FFA_ERROR:
else
- case FFA_SUCCESS:
- default:
- Return:
- data structure.
- Return:
- if (!count) {
return -ENODATA;
- if (!part_uuid) {
u64 data_pages;
u64 data_bytes;
u32 desc_idx;
int ret;
return ret;
data_pages,
buf_4k_pages);
return -ENOMEM;
data_pages,
efi_ret);
return -ENOBUFS;
ffa_priv_data.partitions.descs[desc_idx].info.id);
- } else {
u8 desc_found;
desc_found = 0;
* save the UUID
*part_uuid;
desc_found = 1;
break;
if (!desc_found)
return -ENODATA;
Strange indentation.
- Return:
u32 *pcount)
Why no initialize a0 with with value above instead?
- if (part_uuid) {
if (!pcount)
return -EINVAL;
a5, a6, a7, &res);
- switch (res.a0) {
- case FFA_ERROR:
return -EPERM;
return -ENOMEM;
return -EACCES;
return -EOPNOTSUPP;
case FFA_ERR_STAT_BUSY:
return -EBUSY;
default:
return -EINVAL;
- case FFA_SUCCESS:
int ret;
if (res.a2) {
if (ret)
if (part_uuid) {
if (!ret)
*pcount = res.a2;
else
*pcount = 0;
if there's a hypervisor we're returning the buffer to the hypervisor instead. how about "... back to the SPM or hypervisor"?
return -ENODEV;
return ret;
- default:
return -EINVAL;
- ffa_get_partitions_info - FFA_PARTITION_INFO_GET handler function
- @func_data: Pointer to the FF-A function arguments container structure.
- The passed arguments:
- Mode 1: When getting from the driver the number of
- secure partitions:
- @data0_size: UUID size
- @data0: pointer to the UUID (little endian)
- @data1_size: size of the number of partitions
variable
- @data1: pointer to the number of partitions
by the driver
- Mode 2: When requesting the driver to return the
- partitions information:
- @data1_size: size of the SPs information buffer
- @data1: pointer to SPs information buffer
- This is the boot time function that queries the secure partition data from
- the private data structure. If not found, it invokes FFA_PARTITION_INFO_GET
- FF-A function to query the partition information from secure world.
- A client of the FF-A driver should know the UUID of the service it wants to
- access. It should use the UUID to request the FF-A driver to provide the
- partition(s) information of the service. The FF-A driver uses
- PARTITION_INFO_GET to obtain this information. This is implemented through
- ffa_get_partitions_info function.
- A new FFA_PARTITION_INFO_GET call is issued (first one performed through
- ffa_cache_partitions_info) allowing to retrieve the partition(s) information.
- They are not saved (already done). We only update the UUID in the cached area.
- This assumes that partitions data does not change in the secure world.
- Otherwise u-boot will have an outdated partition data. The benefit of caching
- the information in the FF-A driver is to accommodate discovery after
- ExitBootServices().
- When invoked through a client request, ffa_get_partitions_info should be
- called twice. First call is to get from the driver the number of secure
- partitions (SPs) associated to a particular UUID.
- Then, the caller (client) allocates the buffer to host the SPs data and
- issues a 2nd call. Then, the driver fills the SPs data in the pre-allocated
- buffer.
- To achieve the mechanism described above, ffa_get_partitions_info uses the
- following functions:
- Return:
- @data1: When pointing to the number of partitions variable, the number is
- set by the driver.
- When pointing to the partitions information buffer, the buffer will be
- filled by the driver.
- On success FFA_ERR_STAT_SUCCESS is returned. Otherwise, failure
+static int ffa_get_partitions_info(struct ffa_interface_data *func_data) +{
* fill_data:
* 0: return the SP count
* 1: fill SP data and return it to the caller
* -1: undefined mode
- int fill_data = -1;
- u32 desc_idx, client_desc_idx;
- union ffa_partition_uuid *part_uuid;
- u32 client_desc_max_cnt;
- u32 parts_found = 0;
- if (!func_data) {
ffa_err("No function data provided");
return -EINVAL;
- if (!ffa_priv_data.partitions.count || !ffa_priv_data.partitions.descs)
panic("[FFA] No partition installed\n");
- if (func_data->data0_size == sizeof(union ffa_partition_uuid) &&
func_data->data0 &&
func_data->data1_size == sizeof(u32) &&
func_data->data1) {
* data0 (in): pointer to UUID
* data1 (in): pointer to SP count
* Out: SP count returned in the count variable pointed by data1
fill_data = 0;
ffa_info("Preparing for checking partitions count");
- } else if ((func_data->data0_size == sizeof(union ffa_partition_uuid)) &&
func_data->data0 &&
(func_data->data1_size >= sizeof(struct ffa_partition_info)) &&
!(func_data->data1_size % sizeof(struct ffa_partition_info)) &&
func_data->data1) {
* data1 (in): pointer to SPs descriptors buffer
* (created by the client)
* Out: SPs descriptors returned in the buffer
* pointed by data1
fill_data = 1;
client_desc_idx = 0;
* number of empty descriptors preallocated by the caller
client_desc_max_cnt =
func_data->data1_size / sizeof(struct ffa_partition_info);
ffa_info("Preparing for filling partitions info");
- } else {
ffa_err("Invalid function arguments provided");
return -EINVAL;
- part_uuid = (union ffa_partition_uuid *)func_data->data0;
- ffa_info("Searching partitions using the provided UUID");
* search in the cached partitions
desc_idx++) {
if (ffa_uuid_are_identical(&ffa_priv_data.partitions.descs[desc_idx].UUID,
part_uuid)) {
ffa_info("Partition ID %x matches the provided UUID",
parts_found++;
if (fill_data) {
* trying to fill the partition info in data1
if (client_desc_idx < client_desc_max_cnt) {
((struct ffa_partition_info *)
func_data->data1)[client_desc_idx++] =
ffa_priv_data.partitions.descs[desc_idx].info;
continue;
ffa_err("Failed to fill the current descriptor client buffer full");
return -ENOBUFS;
- if (!parts_found) {
int ret;
ffa_info("No partition found. Querying framework ...");
ret = ffa_query_partitions_info(part_uuid, &parts_found);
if (ret == FFA_ERR_STAT_SUCCESS) {
if (!fill_data) {
*((u32 *)func_data->data1) = parts_found;
ffa_info("Number of partition(s) found matching the UUID: %d",
parts_found);
} else {
* we want to read SPs info
* If SPs data filled, retry searching SP info again
if (parts_found)
ret = ffa_get_partitions_info(func_data);
else
ret = -ENODATA;
return ret;
- /* partition(s) found */
- if (!fill_data)
- ffa_cache_partitions_info - Queries and saves all secure partitions data
- This is a boot time function that invokes FFA_PARTITION_INFO_GET FF-A
- function to query from secure world all partitions information.
- The FFA_PARTITION_INFO_GET call is issued with nil UUID as an argument.
- All installed partitions information are returned. We cache them in the
- resident private data structure and we keep the UUID field empty
- (in FF-A 1.0 UUID is not provided by the partition descriptor)
- This function is called at the device probing level.
- ffa_cache_partitions_info uses ffa_query_partitions_info to get the data
- Return:
+static int ffa_cache_partitions_info(void) +{
- return ffa_query_partitions_info(NULL, NULL);
- ffa_msg_send_direct_req - FFA_MSG_SEND_DIRECT_{REQ,RESP} handler function
the client (in/out)
- This is the runtime function that implements FFA_MSG_SEND_DIRECT_{REQ,RESP}
- FF-A functions.
- FFA_MSG_SEND_DIRECT_REQ is used to send the data to the secure partition.
- The response from the secure partition is handled by reading the
- FFA_MSG_SEND_DIRECT_RESP arguments.
- The maximum size of the data that can be exchanged is 20 bytes which is
- sizeof(struct ffa_send_direct_data) as defined by the FF-A specification 1.0
- in the section relevant to FFA_MSG_SEND_DIRECT_{REQ,RESP}
- Return:
This API looks quite complicated. Wouldn't it be easier to let the caller supply the struct ffa_send_direct_data *msg pointer directly instead, like in the Linux kernel driver. The approach here prevents the compiler from helping with type checks etc.
+static int __ffa_runtime ffa_msg_send_direct_req(struct ffa_interface_data
*func_data)
- u16 dst_part_id;
- struct ffa_send_direct_data *msg;
return -ENODEV;
- if (!func_data)
return -EINVAL;
- /* No partition installed */
return -ENODEV;
- /* Undefined interface parameters */
- if (func_data->data0_size != sizeof(u16) ||
!func_data->data0 ||
func_data->data1_size != FFA_MSG_SEND_DIRECT_MAX_SIZE ||
FFA_MSG_SEND_DIRECT_MAX_SIZE? It's more like FFA_MSG_SEND_DIRECT_ONLY_SIZE.
!func_data->data1)
return -EINVAL;
- dst_part_id = *((u16 *)func_data->data0);
- msg = func_data->data1;
- a0 = FFA_MSG_SEND_DIRECT_REQ;
- a1 = PREP_SELF_ENDPOINT_ID(ffa_priv_data.id) |
PREP_PART_ENDPOINT_ID(dst_part_id);
msg->a3,
msg->a4,
msg->a5,
msg->a6,
msg->a7,
&res);
- while (res.a0 == FFA_INTERRUPT)
ffa_priv_data.invoke_ffa_fn(FFA_RUN, res.a1,
0, 0, 0, 0, 0, 0,
&res);
- switch (res.a0) {
- case FFA_ERROR:
/* Invalid endpoint ID or non-zero reserved register */
return -EPERM;
case FFA_ERR_STAT_ABORTED:
/* Message target ran into unexpected error and has aborted */
return -ECONNABORTED;
/* Callee is not in a state to handle this request */
return -EACCES;
/* This function is not implemented at this FF-A instance */
return -EOPNOTSUPP;
/* Message target is busy */
return -EBUSY;
default:
/* Undefined error */
return -ENXIO;
- case FFA_SUCCESS:
/* Message sent with no response */
- case FFA_MSG_SEND_DIRECT_RESP:
* Message sent with response
* extract the 32-bit wide return data
msg->a3 = (u32)res.a3;
msg->a4 = (u32)res.a4;
msg->a5 = (u32)res.a5;
msg->a6 = (u32)res.a6;
msg->a7 = (u32)res.a7;
- default:
/* Undefined response function */
return -ENOENT;
- invoke_ffa_drv_api - The driver dispatcher function
structure. This also includes pointers to the
returned data needed by clients.
- The dispatcher is a runtime function that selects the FF-A function handler
- based on the input FF-A function ID.
- The input arguments are passed to the handler function.
- Return:
+int __ffa_runtime invoke_ffa_drv_api(u32 func_id,
- if (!ffa_priv_data.dev)
return -ENODEV;
I don't see the point with this funnel layer. It would in my opinion be easier to have one function pointer for each of the provided FF-A functions.
I wouldn't mind if the interface was a bit more like the interface provided in the Linux kernel, at least the parts we're going to support here. It would for sure help later when updating the OP-TEE driver to use this FF-A driver.
- switch (func_id) {
- case FFA_PARTITION_INFO_GET:
return ffa_get_partitions_info(func_data);
- case FFA_RXTX_UNMAP:
return ffa_unmap_rxtx_buffers();
- case FFA_MSG_SEND_DIRECT_REQ:
return ffa_msg_send_direct_req(func_data);
- default:
/* Undefined FF-A interface */
return -EINVAL;
- ffa_set_conduit - Set the conduit
- This boot time function clears the private data structure and sets the conduit
- Return:
+static int ffa_set_conduit(void) +{
- ffa_priv_data.conduit = FFA_CONDUIT_SMC;
- ffa_priv_data.invoke_ffa_fn = arm_ffa_smccc_smc;
- ffa_info("Conduit is SMC");
What if there's a hypervisor? Then HVC should be used instead.
- ffa_probe - The driver probe function
- @dev: the arm_ffa device
- Probing is done at boot time and triggered by the uclass device discovery.
- At probe level the following actions are done:
- setting the conduit
- querying the FF-A framework version
- querying from secure world the u-boot endpoint ID
- querying from secure world the supported features of the specified FF-A calls
- mapping the RX/TX buffers
- querying from secure world all the partitions information
- All data queried from secure world is saved in the resident private data structure.
- The probe will fail if either FF-A framework is not detected or the
- FF-A requests are not behaving correctly. This ensures that the
- driver is not installed and its operations are not exported to the clients.
- However, once the driver is successfully probed and an FF-A anomaly is
- detected when clients invoke the driver operations, the driver cause
- u-boot to panic because the client would not know what to do in such conditions.
- Return:
+static int ffa_probe(struct udevice *dev) +{
- int ret;
- size_t buf_4k_pages = 0;
- ret = ffa_set_conduit();
return ret;
- ret = ffa_get_version();
return ret;
- ret = ffa_get_endpoint_id();
return ret;
- ret = ffa_get_rxtx_map_features();
return ret;
- ret = ffa_get_rxtx_buffers_pages_cnt(&buf_4k_pages);
return ret;
- ret = ffa_map_rxtx_buffers(buf_4k_pages);
This function only suceeds if compiled with EFI runtime support, so probing will always fail without EFI runtime support.
If compiled with EFI runtime support, how is this supposed to work with the kernel FF-A driver? The FF-A framework only supports one buffer pair per component and I don't see where the buffer pair is freed when U-Boot is done.
return ret;
- ret = ffa_cache_partitions_info();
- if (ret != FFA_ERR_STAT_SUCCESS) {
return ret;
- ffa_drv_ops - The driver operations runtime structure
- @invoke_func: The driver dispatcher
+struct ffa_ops __ffa_runtime_data ffa_drv_ops = {
- .invoke_func = invoke_ffa_drv_api
- ffa_device_get_ops - driver operations getter
- Return:
- This runtime function returns a pointer to the driver operations structure
+const struct ffa_ops * __ffa_runtime ffa_device_get_ops(void) +{
- return &ffa_drv_ops;
- Declaring the arm_ffa driver under UCLASS_FFA
+U_BOOT_DRIVER(arm_ffa) = {
- .name = FFA_DRV_NAME,
- .id = UCLASS_FFA,
- .probe = ffa_probe,
+}; diff --git a/include/arm_ffa.h b/include/arm_ffa.h new file mode 100644 index 0000000000..98db01ee72 --- /dev/null +++ b/include/arm_ffa.h @@ -0,0 +1,190 @@ +/* SPDX-License-Identifier: GPL-2.0+ */ +/*
+#ifndef __ARM_FFA_H +#define __ARM_FFA_H
+#include <linux/arm-smccc.h> +#include <linux/printk.h>
- This header is public. It can be used by clients to access
- data structures and definitions they need
- Macros for displaying logs
+#define ffa_info(fmt, ...) pr_info("[FFA] " fmt "\n", ##__VA_ARGS__) +#define ffa_err(fmt, ...) pr_err("[FFA] " fmt "\n", ##__VA_ARGS__)
- The driver operations success error code
+#define FFA_ERR_STAT_SUCCESS (0)
+#include <efi_loader.h>
- __ffa_runtime_data and __ffa_runtime - controls whether data/code are
- available after calling the EFI ExitBootServices service.
- Data/code tagged with these keywords are resident (available at boot time and
- at runtime)
+#define __ffa_runtime_data __efi_runtime_data +#define __ffa_runtime __efi_runtime
+#else
+#define __ffa_runtime_data +#define __ffa_runtime
- Definitions of the Arm FF-A interfaces supported by the Arm FF-A driver
+#define FFA_SMC(calling_convention, func_num) \
- ARM_SMCCC_CALL_VAL(ARM_SMCCC_FAST_CALL, (calling_convention), \
ARM_SMCCC_OWNER_STANDARD, (func_num))
+#define FFA_SMC_32(func_num) FFA_SMC(ARM_SMCCC_SMC_32, (func_num))
+#define FFA_VERSION FFA_SMC_32(0x63) +#define FFA_ID_GET FFA_SMC_32(0x69) +#define FFA_FEATURES FFA_SMC_32(0x64) +#define FFA_PARTITION_INFO_GET FFA_SMC_32(0x68)
Too much indentation, same below
+#define FFA_RXTX_MAP FFA_SMC_32(0x66) +#define FFA_RXTX_UNMAP FFA_SMC_32(0x67) +#define FFA_RX_RELEASE FFA_SMC_32(0x65) +#define FFA_MSG_SEND_DIRECT_REQ FFA_SMC_32(0x6F) +#define FFA_MSG_SEND_DIRECT_RESP FFA_SMC_32(0x70) +#define FFA_RUN FFA_SMC_32(0x6D) +#define FFA_ERROR FFA_SMC_32(0x60) +#define FFA_SUCCESS FFA_SMC_32(0x61) +#define FFA_INTERRUPT FFA_SMC_32(0x62)
- struct ffa_partition_info - Partition information descriptor
- @id: Partition ID
- @exec_ctxt: Execution context count
- @properties: Partition properties
- Data structure containing information about partitions instantiated in the system
- This structure is filled with the data queried by FFA_PARTITION_INFO_GET
+struct __packed ffa_partition_info {
- u16 id;
- u16 exec_ctxt;
+/* partition supports receipt of direct requests */ +#define FFA_PARTITION_DIRECT_RECV BIT(0) +/* partition can send direct requests. */ +#define FFA_PARTITION_DIRECT_SEND BIT(1) +/* partition can send and receive indirect messages. */ +#define FFA_PARTITION_INDIRECT_MSG BIT(2)
- u32 properties;
- struct ffa_send_direct_data - Data structure hosting the data
used by FFA_MSG_SEND_DIRECT_{REQ,RESP}
- @a3-a7: Data read/written from/to w3-w7 registers
- Data structure containing the data to be sent by FFA_MSG_SEND_DIRECT_REQ
- or read from FFA_MSG_SEND_DIRECT_RESP
+struct __packed ffa_send_direct_data {
- u32 a3; /* w3 */
- u32 a4; /* w4 */
- u32 a5; /* w5 */
- u32 a6; /* w6 */
- u32 a7; /* w7 */
+#define FFA_MSG_SEND_DIRECT_MAX_SIZE (sizeof(struct ffa_send_direct_data))
+/* UUID data size */ +#define UUID_SIZE (16)
- union ffa_partition_uuid - Data union hosting the UUID
transmitted by FFA_PARTITION_INFO_GET
- @words: data structure giving 32-bit words access to the UUID data
- @bytes: data structure giving byte access to the UUID data
- The structure holds little-endian UUID data.
+union ffa_partition_uuid {
- struct __packed words {
- u32 a1; /* w1 */
- u32 a2; /* w2 */
- u32 a3; /* w3 */
- u32 a4; /* w4 */
- } words;
- u8 bytes[UUID_SIZE];
- struct ffa_interface_data - generic FF-A interface data structure used to exchange
data between user layers and the driver
- @data0_size: size of the first argument
- @data0: pointer to the first argument
- @data1_size>: size of the second argument
- @data1: pointer to the second argument
- Using this structure user layers can pass various types of data with different sizes.
- The driver internal functions can detect the nature of this data, verfy compliance
- then execute the request when appropriate.
+struct ffa_interface_data {
- u32 data0_size; /* size of the first argument */
- void *data0; /* pointer to the first argument */
- u32 data1_size; /* size of the second argument */
- void *data1; /* pointer to the second argument */
- struct ffa_ops - The driver operations structure
- @invoke_func: function pointer to the invoke function
- The data structure providing all the operations supported by the driver.
- This structure is resident.
+struct ffa_ops {
- /* the driver dispatcher */
- int (*invoke_func)(u32 func_id, struct ffa_interface_data *func_data);
- The device driver and the Uclass driver public functions
+const struct ffa_ops * __ffa_runtime ffa_device_get_ops(void);
+int ffa_get_device(void);
- ffa_bus_discover - discover FF-A bus and probes the arm_ffa device
+int ffa_bus_discover(void); +#endif diff --git a/include/arm_ffa_helper.h b/include/arm_ffa_helper.h new file mode 100644 index 0000000000..1cf68748f0 --- /dev/null +++ b/include/arm_ffa_helper.h @@ -0,0 +1,45 @@ +/* SPDX-License-Identifier: GPL-2.0+ */ +/*
+#ifndef __ARM_FFA_HELPER_H +#define __ARM_FFA_HELPER_H
- This header is public. Including this header provides all data structures
- and definitions needed by clients to use the FF-A transport driver
- It also provides helper functions allowing to pass data and invoke FF-A functions
- ffa_helper_get_partitions_info - Wrapper function for FFA_PARTITION_INFO_GET
+int ffa_helper_get_partitions_info(struct ffa_interface_data *func_data);
- ffa_helper_unmap_rxtx_buffers - Wrapper function for FFA_RXTX_UNMAP
+int ffa_helper_unmap_rxtx_buffers(void);
- ffa_helper_msg_send_direct_req - Wrapper function for
+int __ffa_runtime ffa_helper_msg_send_direct_req(struct ffa_interface_data
*func_data);
- ffa_helper_bus_discover - Wrapper function for FF-A bus discovery
+int ffa_helper_bus_discover(void);
- ffa_uuid_str_to_bin - Converts a big endian UUID string to a little endian buffer
+int ffa_uuid_str_to_bin(const char *uuid_str, unsigned char *uuid_bin); +#endif diff --git a/include/dm/uclass-id.h b/include/dm/uclass-id.h index 0e26e1d138..a1181b8f48 100644 --- a/include/dm/uclass-id.h +++ b/include/dm/uclass-id.h @@ -52,6 +52,7 @@ enum uclass_id { UCLASS_EFI_MEDIA, /* Devices provided by UEFI firmware */ UCLASS_ETH, /* Ethernet device */ UCLASS_ETH_PHY, /* Ethernet PHY device */
- UCLASS_FFA, /* Arm Firmware Framework for Armv8-A */ UCLASS_FIRMWARE, /* Firmware */ UCLASS_FS_FIRMWARE_LOADER, /* Generic loader */ UCLASS_GPIO, /* Bank of general-purpose I/O pins */
diff --git a/include/linux/arm-smccc.h b/include/linux/arm-smccc.h index 7f2be23394..d58c7c104b 100644 --- a/include/linux/arm-smccc.h +++ b/include/linux/arm-smccc.h @@ -1,6 +1,8 @@ /* SPDX-License-Identifier: GPL-2.0 */ /*
#ifndef __LINUX_ARM_SMCCC_H #define __LINUX_ARM_SMCCC_H @@ -57,13 +59,17 @@ #include <linux/types.h> /**
- struct arm_smccc_res - Result from SMC/HVC call
- @a0-a3 result values from registers 0 to 3
- @a0-a7 result values from registers 0 to 7
struct arm_smccc_res { unsigned long a0; unsigned long a1; unsigned long a2; unsigned long a3;
- unsigned long a4;
- unsigned long a5;
- unsigned long a6;
- unsigned long a7;
/** @@ -113,6 +119,26 @@ asmlinkage void __arm_smccc_hvc(unsigned long a0, unsigned long a1, unsigned long a5, unsigned long a6, unsigned long a7, struct arm_smccc_res *res, struct arm_smccc_quirk *quirk);
+#if (IS_ENABLED(CONFIG_ARM_FFA_TRANSPORT)) +/**
- __arm_ffa_smccc_smc() - make SMC calls used for FF-A transport
- @a0-a7: arguments passed in 64-bit registers x0 to x7
- @res: result values from 64-bit registers x0 to x7
- This function is used to make SMC calls following SMC32 Calling Convention.
- The content of the supplied parameters is copied to registers x0 to x7 prior
- to the SMC instruction. The SMC call return data is 32-bit data read from
- registers x0 tp x7.
+asmlinkage void __arm_ffa_smccc_smc(unsigned long a0, unsigned long a1,
unsigned long a2, unsigned long a3, unsigned long a4,
struct arm_smccc_res *res);
+#define arm_ffa_smccc_smc __arm_ffa_smccc_smc
How about leaving the FF-A bit out of this and only have generic SMCCC support? That would make it easier to bring in updates from Linux without reinventing the wheel. I would also be nice to know which version of the SMCCC we're using.
Cheers, Jens
#define arm_smccc_smc(...) __arm_smccc_smc(__VA_ARGS__, NULL)
#define arm_smccc_smc_quirk(...) __arm_smccc_smc(__VA_ARGS__) diff --git a/lib/Kconfig b/lib/Kconfig index effe735365..9006e8d44c 100644 --- a/lib/Kconfig +++ b/lib/Kconfig @@ -845,6 +845,7 @@ config SMBIOS_PARSER source lib/efi/Kconfig source lib/efi_loader/Kconfig source lib/optee/Kconfig +source lib/arm-ffa/Kconfig
config TEST_FDTDEC bool "enable fdtdec test" diff --git a/lib/Makefile b/lib/Makefile index 13fe5fb7a4..36f67cd94e 100644 --- a/lib/Makefile +++ b/lib/Makefile @@ -9,6 +9,7 @@ obj-$(CONFIG_EFI) += efi/ obj-$(CONFIG_EFI_LOADER) += efi_driver/ obj-$(CONFIG_EFI_LOADER) += efi_loader/ obj-$(CONFIG_CMD_BOOTEFI_SELFTEST) += efi_selftest/ +obj-$(CONFIG_ARM_FFA_TRANSPORT_HELPERS) += arm-ffa/ obj-$(CONFIG_LZMA) += lzma/ obj-$(CONFIG_BZIP2) += bzip2/ obj-$(CONFIG_TIZEN) += tizen/ diff --git a/lib/arm-ffa/Kconfig b/lib/arm-ffa/Kconfig new file mode 100644 index 0000000000..79acbc5a8f --- /dev/null +++ b/lib/arm-ffa/Kconfig @@ -0,0 +1,6 @@ +config ARM_FFA_TRANSPORT_HELPERS
- bool "Enable interface helpers for Arm Firmware Framework for Armv8-A"
- depends on ARM_FFA_TRANSPORT
- help
User layers call FF-A interfaces using helper functions which
pass the data and the FF-A function ID to the low level driver
diff --git a/lib/arm-ffa/Makefile b/lib/arm-ffa/Makefile new file mode 100644 index 0000000000..cba625fde4 --- /dev/null +++ b/lib/arm-ffa/Makefile @@ -0,0 +1,8 @@ +# SPDX-License-Identifier: GPL-2.0+ +# +# (C) Copyright 2022 Abdellatif El Khlifi abdellatif.elkhlifi@arm.com +#
+# This file only gets included when CONFIG_ARM_FFA_TRANSPORT_HELPERS is set
+obj-y += arm_ffa_helper.o diff --git a/lib/arm-ffa/arm_ffa_helper.c b/lib/arm-ffa/arm_ffa_helper.c new file mode 100644 index 0000000000..a291b000a7 --- /dev/null +++ b/lib/arm-ffa/arm_ffa_helper.c @@ -0,0 +1,188 @@ +// SPDX-License-Identifier: GPL-2.0+ +/*
+#include <common.h> +#include <arm_ffa_helper.h> +#include <uuid.h>
structure.
secure partitions:
variable
variable. The variable will be set
by the driver
(allocated by the client).
The buffer will be filled by the driver
- This is the boot time function used by clients who wants to get from secure
- world the partition(s) information.
- partition(s) information of the service. The client should use
- ffa_helper_get_partitions_info to pass the UUID information to the driver
- which uses PARTITION_INFO_GET to obtain the partition(s) information.
- ffa_helper_get_partitions_info should be called twice. First call is to get
- from the driver the number of secure partitions (SPs) associated to a
- particular UUID. Then, the caller (client) allocates the buffer to host the
- SPs data and issues a 2nd call. Then, the driver fills the SPs data in the
- pre-allocated buffer.
- Return:
+int ffa_helper_get_partitions_info(struct ffa_interface_data *func_data) +{
- return ffa_get_invoke_func(FFA_PARTITION_INFO_GET, func_data);
- This is the boot time function that allows clients to unmap the RX/TX
- buffers
- Return:
+int ffa_helper_unmap_rxtx_buffers(void) +{
- return ffa_get_invoke_func(FFA_RXTX_UNMAP, NULL);
- @data0_size: partition ID size
- @data0: pointer to the partition ID
- @data1_size: exchanged data size
- @data1: pointer to the data buffer preallocated by the client (in/out)
- This is the runtime function that allows clients to send data to the secure
- world partitions. The arm_ffa driver uses FFA_MSG_SEND_DIRECT_REQ to send the
- data to the secure partition. The response from the secure partition is
- handled internally by the driver using FFA_MSG_SEND_DIRECT_RESP and returned
- to ffa_helper_msg_send_direct_req through @func_data
- The client should pre-allocate a buffer pointed by @data1 which the size
- is sizeof(struct ffa_send_direct_data)
- Return:
*func_data)
- return ffa_get_invoke_func(FFA_MSG_SEND_DIRECT_REQ, func_data);
- This boot time function should be called to discover the FF-A bus and
- probe the FF-A device.
- To achieve that, this function is called automatically at initcalls
- Return:
+int ffa_helper_bus_discover(void) +{
- return ffa_bus_discover();
- @uuid_str: UUID string in big endian format (36 bytes wide + '/0')
- @uuid_bin: preallocated 16 bytes UUID buffer in little endian format
- UUID binary format used by the FF-A framework (16 bytes):
- [LSB] 4B-2B-2B-2B-6B (little endian data fields)
- UUID string is 36 length of characters (36 bytes):
- xxxxxxxx-xxxx-xxxx-xxxx-xxxxxxxxxxxx
- be be be be be
- where x is a hexadecimal character. Fields are separated by '-'s.
- When converting to a binary UUID, these endianness rules apply:
be: means the field in the string is considered a big endian hex number
and should be converted to little endian binary format
- Return:
- uuid_bin filled with little endian UUID data
- On success 0 is returned. Otherwise, failure code.
+int ffa_uuid_str_to_bin(const char *uuid_str, unsigned char *uuid_bin) +{
- u16 tmp16 = 0;
- u32 tmp32 = 0;
- u64 tmp64 = 0;
- if (!uuid_str_valid(uuid_str) || !uuid_bin)
return -EINVAL;
* reverse bytes from big to little endian
- tmp32 = simple_strtoul(uuid_str, NULL, 16);
- memcpy(uuid_bin, &tmp32, 4);
- tmp16 = simple_strtoul(uuid_str + 9, NULL, 16);
- memcpy(uuid_bin + 4, &tmp16, 2);
- tmp16 = simple_strtoul(uuid_str + 14, NULL, 16);
- memcpy(uuid_bin + 6, &tmp16, 2);
- tmp16 = simple_strtoul(uuid_str + 19, NULL, 16);
- memcpy(uuid_bin + 8, &tmp16, 2);
- tmp64 = simple_strtoull(uuid_str + 24, NULL, 16);
- memcpy(uuid_bin + 10, (char *)&tmp64, 6);
+} diff --git a/lib/efi_loader/efi_boottime.c b/lib/efi_loader/efi_boottime.c index 5bcb8253ed..cffa2c69d6 100644 --- a/lib/efi_loader/efi_boottime.c +++ b/lib/efi_loader/efi_boottime.c @@ -23,6 +23,10 @@ #include <asm/setjmp.h> #include <linux/libfdt_env.h>
+#if defined(CONFIG_ARM_FFA_TRANSPORT) +#include <arm_ffa_helper.h> +#endif
/* Task priority level */ @@ -2114,6 +2118,10 @@ static efi_status_t EFIAPI efi_exit_boot_services(efi_handle_t image_handle, struct efi_event *evt, *next_event; efi_status_t ret = EFI_SUCCESS;
- int ffa_ret;
EFI_ENTRY("%p, %zx", image_handle, map_key);
/* Check that the caller has read the current memory map */
@@ -2174,6 +2182,15 @@ static efi_status_t EFIAPI efi_exit_boot_services(efi_handle_t image_handle, dm_remove_devices_flags(DM_REMOVE_ACTIVE_ALL); }
- /* unmap FF-A RX/TX buffers */
- ffa_ret = ffa_helper_unmap_rxtx_buffers();
- if (ffa_ret)
debug("[efi_boottime][ERROR]: can not unmap FF-A RX/TX buffers\n");
- else
debug("[efi_boottime][INFO]: FF-A RX/TX buffers unmapped\n");
- /* Patch out unsupported runtime function */ efi_runtime_detach();
-- 2.17.1
On Fri, May 13, 2022 at 04:40:36PM +0200, Jens Wiklander wrote:
On Fri, Apr 15, 2022 at 01:27:58PM +0100, abdellatif.elkhlifi@arm.com wrote:
From: Abdellatif El Khlifi abdellatif.elkhlifi@arm.com
Add the driver implementing Arm Firmware Framework for Armv8-A v1.0
The Firmware Framework for Arm A-profile processors (FF-A) describes interfaces (ABIs) that standardize communication between the Secure World and Normal World leveraging TrustZone technology. This driver uses SMC32 calling convention.
Thanks for the feedback. SMC64 support has been added in v3 patchset. Please refer to the latest work provided by v4: https://lore.kernel.org/all/20220926101723.9965-2-abdellatif.elkhlifi@arm.co...
In u-boot FF-A design, FF-A is considered as a discoverable bus. The Secure World is considered as one entity to communicate with using the FF-A bus. FF-A communication is handled by one device and one instance (the bus). This FF-A driver takes care of all the interactions between Normal world and Secure World.
The driver provides helper FF-A interfaces for user layers. These helper functions allow clients to pass data and select the FF-A function to use for the communication with secure world.
Signed-off-by: Abdellatif El Khlifi abdellatif.elkhlifi@arm.com
- Copyright (c) 2015, Linaro Limited
- (C) Copyright 2022 ARM Limited
- Abdellatif El Khlifi abdellatif.elkhlifi@arm.com
#include <linux/linkage.h> #include <linux/arm-smccc.h> @@ -45,3 +47,28 @@ ENDPROC(__arm_smccc_smc) ENTRY(__arm_smccc_hvc) SMCCC hvc ENDPROC(__arm_smccc_hvc)
- .macro FFASMCCC instr
- .cfi_startproc
- \instr #0
- ldr x9, [sp]
- stp x0, x1, [x9, #ARM_SMCCC_RES_X0_OFFS]
- stp x2, x3, [x9, #ARM_SMCCC_RES_X2_OFFS]
- stp x4, x5, [x9, #ARM_SMCCC_RES_X4_OFFS]
- stp x6, x7, [x9, #ARM_SMCCC_RES_X6_OFFS]
- ret
- .cfi_endproc
- .endm
- void arm_ffa_smccc_smc(unsigned long a0, unsigned long a1, unsigned long a2,
unsigned long a3, unsigned long a4, unsigned long a5,
unsigned long a6, unsigned long a7, struct arm_smccc_res *res)
+ENTRY(__arm_ffa_smccc_smc)
- FFASMCCC smc
+ENDPROC(__arm_ffa_smccc_smc)
+#endif diff --git a/arch/arm/lib/asm-offsets.c b/arch/arm/lib/asm-offsets.c index 22fd541f9a..02a4a42fe6 100644 --- a/arch/arm/lib/asm-offsets.c +++ b/arch/arm/lib/asm-offsets.c @@ -9,6 +9,8 @@
- generate asm statements containing #defines,
- compile this file to assembler, and then extract the
- #defines from the assembly-language output.
#include <common.h> @@ -115,6 +117,10 @@ int main(void) #ifdef CONFIG_ARM_SMCCC DEFINE(ARM_SMCCC_RES_X0_OFFS, offsetof(struct arm_smccc_res, a0)); DEFINE(ARM_SMCCC_RES_X2_OFFS, offsetof(struct arm_smccc_res, a2)); +#if (IS_ENABLED(CONFIG_ARM_FFA_TRANSPORT))
- DEFINE(ARM_SMCCC_RES_X4_OFFS, offsetof(struct arm_smccc_res, a4));
- DEFINE(ARM_SMCCC_RES_X6_OFFS, offsetof(struct arm_smccc_res, a6));
+#endif DEFINE(ARM_SMCCC_QUIRK_ID_OFFS, offsetof(struct arm_smccc_quirk, id)); DEFINE(ARM_SMCCC_QUIRK_STATE_OFFS, offsetof(struct arm_smccc_quirk, state)); #endif diff --git a/common/board_r.c b/common/board_r.c index b92c1bb0be..bb5f1d0aa6 100644 --- a/common/board_r.c +++ b/common/board_r.c @@ -62,6 +62,10 @@ #include <asm-generic/gpio.h> #include <efi_loader.h>
+#ifdef CONFIG_ARM_FFA_TRANSPORT +#include <arm_ffa_helper.h> +#endif
ulong monitor_flash_len; @@ -771,6 +775,9 @@ static init_fnc_t init_sequence_r[] = { INIT_FUNC_WATCHDOG_RESET initr_net, #endif +#ifdef CONFIG_ARM_FFA_TRANSPORT
- ffa_helper_bus_discover,
+#endif #ifdef CONFIG_POST initr_post, #endif diff --git a/drivers/Kconfig b/drivers/Kconfig index b26ca8cf70..e83c23789d 100644 --- a/drivers/Kconfig +++ b/drivers/Kconfig @@ -6,6 +6,8 @@ source "drivers/core/Kconfig"
source "drivers/adc/Kconfig"
+source "drivers/arm-ffa/Kconfig"
source "drivers/ata/Kconfig"
source "drivers/axi/Kconfig" diff --git a/drivers/Makefile b/drivers/Makefile index 4e7cf28440..6671d2a604 100644 --- a/drivers/Makefile +++ b/drivers/Makefile @@ -107,6 +107,7 @@ obj-y += iommu/ obj-y += smem/ obj-y += thermal/ obj-$(CONFIG_TEE) += tee/ +obj-$(CONFIG_ARM_FFA_TRANSPORT) += arm-ffa/ obj-y += axi/ obj-y += ufs/ obj-$(CONFIG_W1) += w1/ diff --git a/drivers/arm-ffa/Kconfig b/drivers/arm-ffa/Kconfig new file mode 100644 index 0000000000..23815534c4 --- /dev/null +++ b/drivers/arm-ffa/Kconfig @@ -0,0 +1,27 @@ +# SPDX-License-Identifier: GPL-2.0
- bool "Enable Arm Firmware Framework for Armv8-A driver"
- depends on DM && ARM64
- select ARM_SMCCC if ARM64
- select LIB_UUID
- select ARM_FFA_TRANSPORT_HELPERS
- help
technology.
This driver is based on FF-A specification v1.0 and uses SMC32
calling convention.
FF-A specification:
https://developer.arm.com/documentation/den0077/a/?lang=en
using the FF-A bus.
and Secure World.
diff --git a/drivers/arm-ffa/Makefile b/drivers/arm-ffa/Makefile new file mode 100644 index 0000000000..7bc9a336a9 --- /dev/null +++ b/drivers/arm-ffa/Makefile @@ -0,0 +1,6 @@ +# SPDX-License-Identifier: GPL-2.0+ +# +# (C) Copyright 2022 Abdellatif El Khlifi abdellatif.elkhlifi@arm.com +#
+obj-y += arm-ffa-uclass.o core.o diff --git a/drivers/arm-ffa/arm-ffa-uclass.c b/drivers/arm-ffa/arm-ffa-uclass.c new file mode 100644 index 0000000000..2439f87586 --- /dev/null +++ b/drivers/arm-ffa/arm-ffa-uclass.c @@ -0,0 +1,64 @@ +// SPDX-License-Identifier: GPL-2.0+ +/*
+#include <common.h> +#include <dm.h> +#include <arm_ffa.h> +#include <errno.h> +#include <log.h> +#include <asm/global_data.h>
+UCLASS_DRIVER(ffa) = {
- .name = "ffa",
- .id = UCLASS_FFA,
- ffa_get_invoke_func - performs a call to the FF-A driver dispatcher
- @func_id: The FF-A function to be used
container structure. This also includes
pointers to the returned data needed by
clients.
- This runtime function passes the FF-A function ID and its arguments to
- the FF-A driver dispatcher.
- This function is called by the FF-A helper functions.
- Return:
- FFA_ERR_STAT_SUCCESS on success. Otherwise, failure
+int __ffa_runtime ffa_get_invoke_func(u32 func_id, struct ffa_interface_data *func_data) +{
- if (!ffa_device_get_ops()->invoke_func)
return -EINVAL;
- return ffa_device_get_ops()->invoke_func(func_id, func_data);
- ffa_bus_discover - discover FF-A bus and probe the arm_ffa device
- This boot time function makes sure the FF-A bus is discoverable.
- Then, the arm_ffa device is probed and ready to use.
- This function is called automatically at initcalls
- level (after u-boot relocation).
- Arm FF-A transport is implemented through arm_ffa u-boot device managing the FF-A
- communication.
- All FF-A clients should use the arm_ffa device to use the FF-A transport.
- Return:
+int ffa_bus_discover(void) +{
- return ffa_get_device();
+} diff --git a/drivers/arm-ffa/arm_ffa_prv.h b/drivers/arm-ffa/arm_ffa_prv.h new file mode 100644 index 0000000000..44f258addb --- /dev/null +++ b/drivers/arm-ffa/arm_ffa_prv.h @@ -0,0 +1,193 @@ +/* SPDX-License-Identifier: GPL-2.0+ */ +/*
+#ifndef __ARM_FFA_PRV_H +#define __ARM_FFA_PRV_H
+#include <arm_ffa.h> +#include <linux/bitfield.h> +#include <linux/bitops.h> +#include <dm/read.h>
- This header is private. It is exclusively used by the FF-A driver
+/* FF-A core driver name */ +#define FFA_DRV_NAME "arm_ffa"
+/* FF-A driver version definitions */
+#define MAJOR_VERSION_MASK GENMASK(30, 16) +#define MINOR_VERSION_MASK GENMASK(15, 0) +#define GET_FFA_MAJOR_VERSION(x) \
((u16)(FIELD_GET(MAJOR_VERSION_MASK, (x))))
+#define GET_FFA_MINOR_VERSION(x) \
((u16)(FIELD_GET(MINOR_VERSION_MASK, (x))))
+#define PACK_VERSION_INFO(major, minor) \
- (FIELD_PREP(MAJOR_VERSION_MASK, (major)) | \
FIELD_PREP(MINOR_VERSION_MASK, (minor)))
+#define FFA_MAJOR_VERSION (1) +#define FFA_MINOR_VERSION (0) +#define FFA_VERSION_1_0 \
PACK_VERSION_INFO(FFA_MAJOR_VERSION, FFA_MINOR_VERSION)
+/* Endpoint ID mask (u-boot endpoint ID) */
+#define GET_SELF_ENDPOINT_ID_MASK GENMASK(15, 0) +#define GET_SELF_ENDPOINT_ID(x) \
((u16)(FIELD_GET(GET_SELF_ENDPOINT_ID_MASK, (x))))
+#define PREP_SELF_ENDPOINT_ID_MASK GENMASK(31, 16) +#define PREP_SELF_ENDPOINT_ID(x) \
(FIELD_PREP(PREP_SELF_ENDPOINT_ID_MASK, (x)))
+/* Partition endpoint ID mask (partition with which u-boot communicates with) */
+#define PREP_PART_ENDPOINT_ID_MASK GENMASK(15, 0) +#define PREP_PART_ENDPOINT_ID(x) \
(FIELD_PREP(PREP_PART_ENDPOINT_ID_MASK, (x)))
+/* The FF-A SMC function prototype definition */
+typedef void (*invoke_ffa_fn_t)(unsigned long a0, unsigned long a1,
- enum ffa_conduit - Arm FF-A conduits supported by the Arm FF-A driver
- Currently only SMC32 is supported.
+enum ffa_conduit {
- FFA_CONDUIT_SMC = 0,
Removed in v4. Please check https://lore.kernel.org/all/20220926101723.9965-5-abdellatif.elkhlifi@arm.co...
- FFA_DECLARE_ARGS - FF-A functions local variables
- @a0-a7: local variables used to set registers x0-x7
- @res: the structure hosting the FF-A function return data
- A helper macro for declaring local variables for the FF-A functions arguments.
- The x0-x7 registers are used to exchange data with the secure world.
- But, only the bottom 32-bit of thes registers contains the data.
+#define FFA_DECLARE_ARGS \
- unsigned long a0 = 0; \
- unsigned long a1 = 0; \
- unsigned long a2 = 0; \
- unsigned long a3 = 0; \
- unsigned long a4 = 0; \
- unsigned long a5 = 0; \
- unsigned long a6 = 0; \
- unsigned long a7 = 0; \
+/* FF-A error codes */ +#define FFA_ERR_STAT_NOT_SUPPORTED (-1) +#define FFA_ERR_STAT_INVALID_PARAMETERS (-2) +#define FFA_ERR_STAT_NO_MEMORY (-3) +#define FFA_ERR_STAT_BUSY (-4) +#define FFA_ERR_STAT_INTERRUPTED (-5) +#define FFA_ERR_STAT_DENIED (-6) +#define FFA_ERR_STAT_RETRY (-7) +#define FFA_ERR_STAT_ABORTED (-8)
- struct ffa_features_desc - FF-A functions features
- @func_id: FF-A function
- @field1: features read from register w2
- @field2: features read from register w3
- Data structure describing the features of the FF-A functions queried by
- FFA_FEATURES
+struct ffa_features_desc {
- u32 func_id;
- u32 field1;
- u32 field2;
- enum ffa_rxtx_buf_sizes - minimum sizes supported
- for the RX/TX buffers
+enum ffa_rxtx_buf_sizes {
- RXTX_4K,
- RXTX_64K,
- RXTX_16K
- Number of the FF-A interfaces features descriptors
- currently only FFA_RXTX_MAP descriptor is supported
+#define FFA_FEATURE_DESC_CNT (1)
- struct ffa_rxtxpair - structure hosting the RX/TX buffers virtual addresses
- @rxbuf: virtual address of the RX buffer
- @txbuf: virtual address of the TX buffer
- Data structure hosting the virtual addresses of the mapped RX/TX buffers
- These addresses are used by the FF-A functions that use the RX/TX buffers
+struct ffa_rxtxpair {
- u64 rxbuf; /* virtual address */
- u64 txbuf; /* virtual address */
- struct ffa_partition_desc - the secure partition descriptor
- @info: partition information
- @UUID: UUID
- Each partition has its descriptor containing the partitions information and the UUID
+struct ffa_partition_desc {
- struct ffa_partition_info info;
- union ffa_partition_uuid UUID;
- struct ffa_partitions - descriptors for all secure partitions
- @count: The number of partitions descriptors
- @descs The partitions descriptors table
- This data structure contains the partitions descriptors table
+struct ffa_partitions {
- u32 count;
- struct ffa_partition_desc *descs; /* virtual address */
- struct ffa_prvdata - the driver private data structure
- @dev: The arm_ffa device under u-boot driver model
- @fwk_version: FF-A framework version
- @id: u-boot endpoint ID
- @partitions: The partitions descriptors structure
- @pair: The RX/TX buffers pair
- @conduit: The selected conduit
- @invoke_ffa_fn: The function executing the FF-A function
- @features: Table of the FF-A functions having features
- The driver data structure hosting all resident data.
+struct ffa_prvdata {
- struct udevice *dev;
- u32 fwk_version;
- u16 id;
- struct ffa_partitions partitions;
- struct ffa_rxtxpair pair;
- enum ffa_conduit conduit;
- invoke_ffa_fn_t invoke_ffa_fn;
- struct ffa_features_desc features[FFA_FEATURE_DESC_CNT];
+#endif diff --git a/drivers/arm-ffa/core.c b/drivers/arm-ffa/core.c new file mode 100644 index 0000000000..09e4eb753a --- /dev/null +++ b/drivers/arm-ffa/core.c @@ -0,0 +1,1349 @@ +// SPDX-License-Identifier: GPL-2.0+ +/*
+#include "arm_ffa_prv.h" +#include <asm/global_data.h> +#include <asm/io.h> +#include <common.h> +#include <dm.h> +#include <dm/device-internal.h> +#include <dm/root.h> +#include <linux/errno.h> +#include <linux/sizes.h> +#include <log.h> +#include <malloc.h> +#include <mapmem.h> +#include <string.h>
+DECLARE_GLOBAL_DATA_PTR;
- The device private data structure containing all the resident
- data read from secure world
+struct ffa_prvdata __ffa_runtime_data ffa_priv_data = {0};
- Driver functions
- ffa_get_device - create, bind and probe the arm_ffa device
- This boot time function makes sure the arm_ffa device is
- created, bound to this driver, probed and ready to use.
- Arm FF-A transport is implemented through a single u-boot
- device managing the FF-A bus (arm_ffa).
- Return:
+int ffa_get_device(void) +{
- int ret;
- if (ffa_priv_data.dev)
return FFA_ERR_STAT_SUCCESS;
- ret = device_bind(dm_root(),
DM_DRIVER_GET(arm_ffa),
FFA_DRV_NAME,
NULL,
ofnode_null(),
&ffa_priv_data.dev);
- if (ret) {
ffa_priv_data.dev = NULL;
return ret;
- /* The FF-A bus discovery succeeds when probing is successful */
- ret = device_probe(ffa_priv_data.dev);
- if (ret) {
ffa_err("can not probe the device");
device_unbind(ffa_priv_data.dev);
return ret;
- return FFA_ERR_STAT_SUCCESS;
- ffa_get_version - FFA_VERSION handler function
- This is the boot time function that implements FFA_VERSION FF-A function
- to get from the secure world the FF-A framework version
- Return:
+static int ffa_get_version(void) +{
- u16 major, minor;
- FFA_DECLARE_ARGS;
- if (!ffa_priv_data.invoke_ffa_fn)
- a0 = FFA_VERSION;
- a1 = FFA_VERSION_1_0;
- ffa_priv_data.invoke_ffa_fn(a0, a1, a2, a3, a4, a5, a6, a7, &res);
- if (res.a0 == FFA_ERR_STAT_NOT_SUPPORTED) {
ffa_err("A Firmware Framework implementation does not exist");
return -EOPNOTSUPP;
- major = GET_FFA_MAJOR_VERSION(res.a0);
- minor = GET_FFA_MINOR_VERSION(res.a0);
- ffa_info("FF-A driver %d.%d\nFF-A framework %d.%d",
FFA_MAJOR_VERSION, FFA_MINOR_VERSION, major, minor);
- if ((major == FFA_MAJOR_VERSION && minor >= FFA_MINOR_VERSION)) {
ffa_info("Versions are compatible ");
ffa_priv_data.fwk_version = res.a0;
- ffa_info("Versions are incompatible ");
Done. Please refer to v4 for the latest updates on that part.
- return -EPROTONOSUPPORT;
- ffa_get_endpoint_id - FFA_ID_GET handler function
- This is the boot time function that implements FFA_ID_GET FF-A function
- to get from the secure world u-boot endpoint ID
The FF-A 1.0 spec says: ID value 0 must be returned at the Non-secure physical FF-A instance. In our case the Non-secure physical FF-A instance is u-boot. The comment in the function header is trying to be as close as possible to what the spec is saying.
- Return:
+static int ffa_get_endpoint_id(void) +{
- FFA_DECLARE_ARGS;
- a0 = FFA_ID_GET;
- switch (res.a0) {
- case FFA_ERROR:
if (((int)res.a2) == FFA_ERR_STAT_NOT_SUPPORTED) {
return -EOPNOTSUPP;
ffa_err("Undefined error code (%d)", ((int)res.a2));
return -EINVAL;
error handling has been redesigned to use error mappings. Please refer to v4: https://lore.kernel.org/all/20220926101723.9965-5-abdellatif.elkhlifi@arm.co...
- case FFA_SUCCESS:
ffa_priv_data.id = GET_SELF_ENDPOINT_ID(res.a2);
ffa_info("endpoint ID is %u", ffa_priv_data.id);
- default:
return -EINVAL;
- ffa_get_features_desc - returns the features descriptor of the specified
FF-A function
- @func_id: the FF-A function which the features are to be retrieved
- This is a boot time function that searches the features descriptor of the
- specified FF-A function
- Return:
- When found, the address of the features descriptor is returned. Otherwise, NULL.
+static struct ffa_features_desc *ffa_get_features_desc(u32 func_id) +{
- u32 desc_idx;
* search for the descriptor of the selected FF-A interface
- for (desc_idx = 0; desc_idx < FFA_FEATURE_DESC_CNT ; desc_idx++)
if (ffa_priv_data.features[desc_idx].func_id == func_id)
return &ffa_priv_data.features[desc_idx];
- return NULL;
- ffa_get_rxtx_map_features - FFA_FEATURES handler function with FFA_RXTX_MAP
argument
- This is the boot time function that implements FFA_FEATURES FF-A function
- to retrieve the FFA_RXTX_MAP features
- Return:
+static int ffa_get_rxtx_map_features(void) +{
- FFA_DECLARE_ARGS;
- a0 = FFA_FEATURES;
- a1 = FFA_RXTX_MAP;
- switch (res.a0) {
- case FFA_ERROR:
ffa_err("FFA_RXTX_MAP is not implemented at this FF-A instance");
return -EOPNOTSUPP;
return -EINVAL;
- case FFA_SUCCESS:
u32 desc_idx;
* search for an empty descriptor
if (!ffa_priv_data.features[desc_idx].func_id) {
* populate the descriptor with
* the interface features data
FFA_RXTX_MAP;
ffa_priv_data.features[desc_idx].field1 =
res.a2;
ffa_info("FFA_RXTX_MAP features data 0x%lx",
res.a2);
Done in v4. rxtx_min_pages field has been added in the ffa_rxtxpair structure and replaces the older logic.
ffa_err("Cannot save FFA_RXTX_MAP features data. Descriptors table full");
return -ENOBUFS;
- default:
res.a0);
return -EINVAL;
- ffa_get_rxtx_buffers_pages_cnt - reads from the features data descriptors
the minimum number of pages in each of the RX/TX
buffers
- @buf_4k_pages: Pointer to the minimum number of pages
- This is the boot time function that returns the minimum number of pages
- in each of the RX/TX buffers
- Return:
- buf_4k_pages points to the returned number of pages
+static int ffa_get_rxtx_buffers_pages_cnt(size_t *buf_4k_pages) +{
- struct ffa_features_desc *desc = NULL;
- if (!buf_4k_pages)
return -EINVAL;
- desc = ffa_get_features_desc(FFA_RXTX_MAP);
- if (!desc)
return -EINVAL;
- switch (desc->field1) {
- case RXTX_4K:
*buf_4k_pages = 1;
break;
- case RXTX_16K:
*buf_4k_pages = 4;
break;
- case RXTX_64K:
*buf_4k_pages = 16;
break;
- default:
ffa_err("RX/TX buffer size not supported");
return -EINVAL;
- ffa_free_rxtx_buffers - frees the RX/TX buffers
- @buf_4k_pages: the minimum number of pages in each of the RX/TX
buffers
- This is the boot time function used to free the RX/TX buffers
- Return:
+static int ffa_free_rxtx_buffers(size_t buf_4k_pages) +{
- efi_status_t free_rxbuf_ret, free_txbuf_ret;
- ffa_info("Freeing RX/TX buffers");
- free_rxbuf_ret = efi_free_pages(ffa_priv_data.pair.rxbuf, buf_4k_pages);
- free_txbuf_ret = efi_free_pages(ffa_priv_data.pair.txbuf, buf_4k_pages);
- if (free_rxbuf_ret != EFI_SUCCESS || free_txbuf_ret != EFI_SUCCESS) {
ffa_err("Failed to free RX/TX buffers (rx: %lu , tx: %lu)",
free_rxbuf_ret,
free_txbuf_ret);
return -EINVAL;
- ffa_priv_data.pair.rxbuf = 0;
- ffa_priv_data.pair.txbuf = 0;
- ffa_alloc_rxtx_buffers - allocates the RX/TX buffers
buffers
- This is the boot time function used by ffa_map_rxtx_buffers to allocate
- the RX/TX buffers before mapping them
- Return:
+static int ffa_alloc_rxtx_buffers(size_t buf_4k_pages) +{ +#if CONFIG_IS_ENABLED(EFI_LOADER)
- efi_status_t efi_ret;
- void *virt_txbuf;
- void *virt_rxbuf;
- ffa_info("Using %lu 4KB page(s) for RX/TX buffers size",
buf_4k_pages);
- efi_ret = efi_allocate_pages(EFI_ALLOCATE_ANY_PAGES,
EFI_BOOT_SERVICES_DATA,
buf_4k_pages,
&ffa_priv_data.pair.rxbuf);
- if (efi_ret != EFI_SUCCESS) {
ffa_err("Failure to allocate RX buffer (EFI error: 0x%lx)",
efi_ret);
return -ENOBUFS;
- ffa_info("RX buffer at virtual address 0x%llx",
- virt_rxbuf = (void *)ffa_priv_data.pair.rxbuf;
* make sure the buffer is clean before use
- memset(virt_rxbuf, 0, buf_4k_pages * SZ_4K);
EFI_RUNTIME_SERVICES_DATA,
buf_4k_pages,
&ffa_priv_data.pair.txbuf);
ffa_err("Failure to allocate the TX buffer (EFI error: 0x%lx)"
, efi_ret);
return -ENOBUFS;
- ffa_info("TX buffer at virtual address 0x%llx",
- virt_txbuf = (void *)ffa_priv_data.pair.txbuf;
- memset(virt_txbuf, 0, buf_4k_pages * SZ_4K);
+#else
- return -ENOBUFS;
+#endif +}
- ffa_map_rxtx_buffers - FFA_RXTX_MAP handler function
buffers
- This is the boot time function that implements FFA_RXTX_MAP FF-A function
- to map the RX/TX buffers
- Return:
+static int ffa_map_rxtx_buffers(size_t buf_4k_pages) +{
- int ret;
- FFA_DECLARE_ARGS;
- ret = ffa_alloc_rxtx_buffers(buf_4k_pages);
return ret;
- a0 = FFA_RXTX_MAP;
- a1 = ffa_priv_data.pair.txbuf;
- a2 = ffa_priv_data.pair.rxbuf;
- a3 = buf_4k_pages;
- switch (res.a0) {
- case FFA_ERROR:
ffa_err("One or more fields in input parameters is incorrectly encoded");
ret = -EPERM;
break;
ffa_err("Not enough memory");
ret = -ENOMEM;
break;
ffa_err("Buffer pair already registered");
ret = -EACCES;
break;
ret = -EOPNOTSUPP;
break;
default:
((int)res.a2));
ret = -EINVAL;
Done in v4.
break;
- case FFA_SUCCESS:
ffa_info("RX/TX buffers mapped");
- default:
res.a0);
ret = -EINVAL;
- ffa_free_rxtx_buffers(buf_4k_pages);
- return ret;
- ffa_unmap_rxtx_buffers - FFA_RXTX_UNMAP handler function
- This is the boot time function that implements FFA_RXTX_UNMAP FF-A function
- to unmap the RX/TX buffers
- Return:
+static int ffa_unmap_rxtx_buffers(void) +{
- FFA_DECLARE_ARGS;
panic("[FFA] no private data found\n");
- a0 = FFA_RXTX_UNMAP;
- a1 = PREP_SELF_ENDPOINT_ID(ffa_priv_data.id);
- switch (res.a0) {
- case FFA_ERROR:
panic("[FFA] FFA_RXTX_UNMAP is not implemented at this FF-A instance\n");
else if (((int)res.a2) == FFA_ERR_STAT_INVALID_PARAMETERS)
panic("[FFA] There is no buffer pair registered on behalf of the caller\n");
else
panic("[FFA] Undefined error (%d)\n", ((int)res.a2));
- case FFA_SUCCESS:
int ret;
panic("[FFA] RX/TX buffers unmapped but failure in getting pages count\n");
ret = ffa_free_rxtx_buffers(buf_4k_pages);
panic("[FFA] RX/TX buffers unmapped but failure in freeing the memory\n");
ffa_info("RX/TX buffers unmapped and memory freed");
- default:
panic("[FFA] Undefined response function (0x%lx)", res.a0);
- ffa_release_rx_buffer - FFA_RX_RELEASE handler function
- This is the boot time function that invokes FFA_RX_RELEASE FF-A function
- to release the ownership of the RX buffer
- Return:
+static int ffa_release_rx_buffer(void) +{
- FFA_DECLARE_ARGS;
- a0 = FFA_RX_RELEASE;
- switch (res.a0) {
- case FFA_ERROR:
panic("[FFA] FFA_RX_RELEASE is not implemented at this FF-A instance\n");
else if (((int)res.a2) == FFA_ERR_STAT_DENIED)
panic("[FFA] Caller did not have ownership of the RX buffer\n");
else
- case FFA_SUCCESS:
- default:
panic("[FFA] Undefined response function (0x%lx)\n", res.a0);
- ffa_uuid_are_identical - checks whether two given UUIDs are identical
- @uuid1: first UUID
- @uuid2: second UUID
- This is a boot time function used by ffa_read_partitions_info to search
- for a UUID in the partitions descriptors table
- Return:
- 1 when UUIDs match. Otherwise, 0
+int ffa_uuid_are_identical(const union ffa_partition_uuid *uuid1,
const union ffa_partition_uuid *uuid2)
- if (!uuid1 || !uuid2)
- return (!memcmp(uuid1, uuid2, sizeof(union ffa_partition_uuid)));
- ffa_read_partitions_info - reads the data queried by FFA_PARTITION_INFO_GET
and saves it in the private structure
- @count: The number of partitions queried
- @part_uuid: Pointer to the partition(s) UUID
- This is the boot time function that reads the partitions information
- returned by the FFA_PARTITION_INFO_GET and saves it in the private
- data structure.
- Return:
- The private data structure is updated with the partition(s) information
- FFA_ERR_STAT_SUCCESS is returned on success. Otherwise, failure
+static int ffa_read_partitions_info(u32 count, union ffa_partition_uuid *part_uuid) +{
- if (!count) {
ffa_err("No partition detected");
return -ENODATA;
- ffa_info("Reading partitions data from the RX buffer");
- if (!part_uuid) {
* querying information of all partitions
u64 data_pages;
u64 data_bytes;
u32 desc_idx;
struct ffa_partition_info *parts_info;
int ret;
data_bytes = count * sizeof(struct ffa_partition_desc);
data_pages = efi_size_in_pages(data_bytes);
* get the RX buffer size in pages
ffa_err("Can not get the RX buffer size (error %d)", ret);
return ret;
if (data_pages > buf_4k_pages) {
ffa_err("Partitions data size exceeds the RX buffer size:");
ffa_err(" Sizes in pages: data %llu , RX buffer %lu ",
data_pages,
buf_4k_pages);
return -ENOMEM;
data_pages,
(u64 *)&ffa_priv_data.partitions.descs);
ffa_priv_data.partitions.descs = NULL;
ffa_err("Cannot allocate partitions data buffer (EFI error 0x%lx)",
efi_ret);
return -ENOBUFS;
memset(ffa_priv_data.partitions.descs, 0,
data_pages * SZ_4K);
parts_info = (struct ffa_partition_info *)ffa_priv_data.pair.rxbuf;
for (desc_idx = 0 ; desc_idx < count ; desc_idx++) {
ffa_priv_data.partitions.descs[desc_idx].info =
parts_info[desc_idx];
ffa_info("Partition ID %x : info cached",
ffa_priv_data.partitions.count = count;
ffa_info("%d partition(s) found and cached", count);
- } else {
u32 rx_desc_idx, cached_desc_idx;
u8 desc_found;
* search for the SP IDs read from the RX buffer
* in the already cached SPs.
* Update the UUID when ID found.
for (rx_desc_idx = 0; rx_desc_idx < count ; rx_desc_idx++) {
desc_found = 0;
* search the current ID in the cached partitions
for (cached_desc_idx = 0;
cached_desc_idx < ffa_priv_data.partitions.count;
cached_desc_idx++) {
* save the UUID
if (ffa_priv_data.partitions.descs[cached_desc_idx].info.id ==
parts_info[rx_desc_idx].id) {
ffa_priv_data.partitions.descs[cached_desc_idx].UUID =
*part_uuid;
desc_found = 1;
break;
if (!desc_found)
return -ENODATA;
+#else +#warning "arm_ffa: reading FFA_PARTITION_INFO_GET data not implemented" +#endif
- ffa_query_partitions_info - invokes FFA_PARTITION_INFO_GET
and saves partitions data
- @pcount: Pointer to the number of partitions variable filled when querying
- This is the boot time function that executes the FFA_PARTITION_INFO_GET
- to query the partitions data. Then, it calls ffa_read_partitions_info
- to save the data in the private data structure.
- After reading the data the RX buffer is released using ffa_release_rx_buffer
- Return:
- When part_uuid is NULL, all partitions data are retrieved from secure world
- When part_uuid is non NULL, data for partitions matching the given UUID are
- retrieved and the number of partitions is returned
+static int ffa_query_partitions_info(union ffa_partition_uuid *part_uuid,
u32 *pcount)
- union ffa_partition_uuid query_uuid = {0};
- struct arm_smccc_res res = {0};
- a0 = FFA_PARTITION_INFO_GET;
following the new interface design a0 is set at the invoke_ffa_fn callback call. Please refer to v4 for the latest update on that.
* If a UUID is specified. Information for one or more
* partitions in the system is queried. Otherwise, information
* for all installed partitions is queried
- if (part_uuid) {
if (!pcount)
return -EINVAL;
query_uuid = *part_uuid;
- ffa_priv_data.invoke_ffa_fn(a0, query_uuid.words.a1, query_uuid.words.a2,
query_uuid.words.a3, query_uuid.words.a4,
a5, a6, a7, &res);
- switch (res.a0) {
- case FFA_ERROR:
ffa_err("Unrecognized UUID");
return -EPERM;
case FFA_ERR_STAT_NO_MEMORY:
ffa_err("Results cannot fit in RX buffer of the caller");
return -ENOMEM;
ffa_err("Callee is not in a state to handle this request");
return -EACCES;
ffa_err("This function is not implemented at this FF-A instance");
return -EOPNOTSUPP;
ffa_err("RX buffer of the caller is not free");
return -EBUSY;
default:
ffa_err("Undefined error (%d)", ((int)res.a2));
return -EINVAL;
- case FFA_SUCCESS:
int ret;
* res.a2 contains the count of partition information descriptors
* populated in the RX buffer
if (res.a2) {
ret = ffa_read_partitions_info(res.a2, part_uuid);
if (ret)
ffa_err("Failed to read partition(s) data , error (%d)", ret);
* return the SP count
if (part_uuid) {
if (!ret)
*pcount = res.a2;
else
*pcount = 0;
* After calling FFA_PARTITION_INFO_GET the buffer ownership
* is assigned to the consumer (u-boot). So, we need to give
* the ownership back to the secure world
Done
ret = ffa_release_rx_buffer();
if (!part_uuid && !res.a2) {
ffa_err("[FFA] no partition installed in the system");
return -ENODEV;
return ret;
- default:
ffa_err("Undefined response function (0x%lx)", res.a0);
return -EINVAL;
variable
by the driver
- buffer.
- Return:
* fill_data:
- if (!func_data) {
return -EINVAL;
func_data->data0 &&
func_data->data1) {
fill_data = 0;
func_data->data0 &&
func_data->data1) {
* pointed by data1
fill_data = 1;
- } else {
return -EINVAL;
desc_idx++) {
part_uuid)) {
parts_found++;
if (fill_data) {
continue;
return -ENOBUFS;
int ret;
if (!fill_data) {
parts_found);
} else {
if (parts_found)
else
ret = -ENODATA;
return ret;
- if (!fill_data)
- Return:
the client (in/out)
- FF-A functions.
- Return:
This has been addressed following the new interface design and alignment with the kernel driver. Please refer to v4 for the latest updates on that.
*func_data)
- u16 dst_part_id;
return -ENODEV;
- if (!func_data)
return -EINVAL;
return -ENODEV;
!func_data->data1)
return -EINVAL;
msg->a3,
msg->a4,
msg->a5,
msg->a6,
msg->a7,
&res);
0, 0, 0, 0, 0, 0,
&res);
- switch (res.a0) {
- case FFA_ERROR:
return -EPERM;
return -EACCES;
return -EOPNOTSUPP;
return -EBUSY;
default:
return -ENXIO;
- case FFA_SUCCESS:
- default:
return -ENOENT;
- Return:
return -ENODEV;
This has been addressed following the new interface design and alignment with the kernel driver. Please refer to v4 for the latest updates on that. ffa_bus_ops has been introduced and contains all the exported callbacks.
- default:
return -EINVAL;
- Return:
We are only supporting SMC at this stage
- Return:
- int ret;
return ret;
return ret;
return ret;
return ret;
return ret;
From patchset v3, FF-A core driver has been decoupled from EFI. It can
be compiled without EFI support. Please refer to v4 for the latest work on that. Freeing the RX/TX buffers is done in 2 locations.
1/ When RX/TX buffers are unmapped at ExitBootServices(). At EFI runtime RX/TX buffers created by u-boot do not exist anymore. 2/ When the arm_ffa device is removed (please see ffa_remove function)
return ret;
return ret;
- Return:
- .id = UCLASS_FFA,
- at runtime)
+#else
- @id: Partition ID
- u16 id;
- u16 exec_ctxt;
- u32 properties;
- u32 a3; /* w3 */
- u32 a4; /* w4 */
- u32 a5; /* w5 */
- u32 a6; /* w6 */
- u32 a7; /* w7 */
- u32 a1; /* w1 */
- u32 a2; /* w2 */
- u32 a3; /* w3 */
- u32 a4; /* w4 */
- } words;
+struct ffa_ops {
*func_data);
- unsigned long a4;
- unsigned long a5;
- unsigned long a6;
- unsigned long a7;
Done through this patch: https://lore.kernel.org/all/20220926101723.9965-2-abdellatif.elkhlifi@arm.co...
Cheers, Jens
- help
structure.
secure partitions:
variable
by the driver
- Return:
- buffers
- Return:
- Return:
*func_data)
- Return:
- be be be be be
- Return:
- u16 tmp16 = 0;
- u32 tmp32 = 0;
- u64 tmp64 = 0;
return -EINVAL;
- int ffa_ret;
- if (ffa_ret)
- else
-- 2.17.1
Provide armffa command showcasing the use of the FF-A driver
The armffa command allows to query secure partitions data from the secure world and exchanging messages with the partitions.
Signed-off-by: Abdellatif El Khlifi abdellatif.elkhlifi@arm.com --- MAINTAINERS | 1 + cmd/Kconfig | 10 ++ cmd/Makefile | 2 + cmd/armffa.c | 266 ++++++++++++++++++++++++++++++++++++++++ drivers/arm-ffa/Kconfig | 1 + 5 files changed, 280 insertions(+) create mode 100644 cmd/armffa.c
diff --git a/MAINTAINERS b/MAINTAINERS index efa17206b8..ca2e13b9ec 100644 --- a/MAINTAINERS +++ b/MAINTAINERS @@ -235,6 +235,7 @@ F: include/configs/turris_*.h ARM FF-A M: Abdellatif El Khlifi abdellatif.elkhlifi@arm.com S: Maintained +F: cmd/armffa.c F: drivers/arm-ffa/ F: include/arm_ffa.h F: include/arm_ffa_helper.h diff --git a/cmd/Kconfig b/cmd/Kconfig index 516c6bbe2d..0d16e8cb14 100644 --- a/cmd/Kconfig +++ b/cmd/Kconfig @@ -823,6 +823,16 @@ endmenu
menu "Device access commands"
+config CMD_ARMFFA + bool "Arm FF-A test command" + depends on ARM_FFA_TRANSPORT + help + Provides a test command for the Arm FF-A driver + supported options: + - Listing the partition(s) info + - Sending a data pattern to the specified partition + - Displaying the arm_ffa device info + config CMD_ARMFLASH #depends on FLASH_CFI_DRIVER bool "armflash" diff --git a/cmd/Makefile b/cmd/Makefile index ede634d731..2905ce63cf 100644 --- a/cmd/Makefile +++ b/cmd/Makefile @@ -12,6 +12,8 @@ obj-y += panic.o obj-y += version.o
# command + +obj-$(CONFIG_CMD_ARMFFA) += armffa.o obj-$(CONFIG_CMD_ACPI) += acpi.o obj-$(CONFIG_CMD_ADDRMAP) += addrmap.o obj-$(CONFIG_CMD_AES) += aes.o diff --git a/cmd/armffa.c b/cmd/armffa.c new file mode 100644 index 0000000000..4b74bf5f31 --- /dev/null +++ b/cmd/armffa.c @@ -0,0 +1,266 @@ +// SPDX-License-Identifier: GPL-2.0+ +/* + * (C) Copyright 2022 ARM Limited + * Abdellatif El Khlifi abdellatif.elkhlifi@arm.com + */ + +#include <arm_ffa_helper.h> +#include <asm/io.h> +#include <common.h> +#include <command.h> +#include <dm.h> +#include <mapmem.h> +#include <stdlib.h> + +/** + * do_ffa_get_singular_partition_info - implementation of the getpart subcommand + * @cmdtp: Command Table + * @flag: flags + * @argc: number of arguments + * @argv: arguments + * + * This function queries the secure partition information which the UUID is provided + * as an argument. The function uses the arm_ffa driver helper function + * to retrieve the data. + * The input UUID string is expected to be in big endian format. + * + * Return: + * + * CMD_RET_SUCCESS: on success, otherwise failure + */ +static int do_ffa_get_singular_partition_info(struct cmd_tbl *cmdtp, int flag, int argc, + char *const argv[]) +{ + struct ffa_interface_data func_data = {0}; + u32 count = 0; + int ret; + union ffa_partition_uuid service_uuid = {0}; + struct ffa_partition_info *parts_info; + u32 info_idx; + + if (argc != 1) + return -EINVAL; + + if (ffa_uuid_str_to_bin(argv[0], (unsigned char *)&service_uuid)) { + ffa_err("Invalid UUID"); + return -EINVAL; + } + + /* + * get from the driver the count of the SPs matching the UUID + */ + func_data.data0_size = sizeof(service_uuid); + func_data.data0 = &service_uuid; + func_data.data1_size = sizeof(count); + func_data.data1 = &count; + + ret = ffa_helper_get_partitions_info(&func_data); + if (ret != FFA_ERR_STAT_SUCCESS) { + ffa_err("Failure in querying partitions count (error code: %d)", ret); + return ret; + } + + if (!count) { + ffa_info("No secure partition found"); + return ret; + } + + /* + * pre-allocate a buffer to be filled by the driver + * with ffa_partition_info structs + */ + + parts_info = calloc(count, sizeof(struct ffa_partition_info)); + if (!parts_info) + return -EINVAL; + + ffa_info("Pre-allocating %d partition(s) info structures", count); + + func_data.data1_size = count * sizeof(struct ffa_partition_info); + func_data.data1 = parts_info; + + /* + * ask the driver to fill the buffer with the SPs info + */ + ret = ffa_helper_get_partitions_info(&func_data); + if (ret != FFA_ERR_STAT_SUCCESS) { + ffa_err("Failure in querying partition(s) info (error code: %d)", ret); + free(parts_info); + return ret; + } + + /* + * SPs found , show the partition information + */ + for (info_idx = 0; info_idx < count ; info_idx++) { + ffa_info("Partition: id = 0x%x , exec_ctxt 0x%x , properties 0x%x", + parts_info[info_idx].id, + parts_info[info_idx].exec_ctxt, + parts_info[info_idx].properties); + } + + free(parts_info); + + return 0; +} + +/** + * do_ffa_msg_send_direct_req - implementation of the ping subcommand + * @cmdtp: Command Table + * @flag: flags + * @argc: number of arguments + * @argv: arguments + * + * This function sends data to the secure partition which the ID is provided + * as an argument. The function uses the arm_ffa driver helper function + * to send data. + * + * Return: + * + * CMD_RET_SUCCESS: on success, otherwise failure + */ +int do_ffa_msg_send_direct_req(struct cmd_tbl *cmdtp, int flag, int argc, + char *const argv[]) +{ + struct ffa_interface_data func_data = {0}; + struct ffa_send_direct_data msg = {0}; + u32 pattern = 0xaabbccd0; + u16 part_id; + int ret; + + if (argc != 1) + return -EINVAL; + + errno = 0; + part_id = strtoul(argv[0], NULL, 16); + + if (errno) { + ffa_err("Invalid partition ID"); + return -EINVAL; + } + + /* + * telling the driver which partition to use + */ + func_data.data0_size = sizeof(part_id); + func_data.data0 = &part_id; + + /* + * filling the message data + */ + msg.a3 = ++pattern; + msg.a4 = ++pattern; + msg.a5 = ++pattern; + msg.a6 = ++pattern; + msg.a7 = ++pattern; + func_data.data1_size = sizeof(msg); + func_data.data1 = &msg; + + ret = ffa_helper_msg_send_direct_req(&func_data); + if (ret == FFA_ERR_STAT_SUCCESS) { + u8 cnt; + + ffa_info("SP response:\n[LSB]"); + for (cnt = 0; + cnt < sizeof(struct ffa_send_direct_data) / sizeof(u32); + cnt++) + ffa_info("0x%x", ((u32 *)&msg)[cnt]); + } else { + ffa_err("Sending direct request error (%d)", ret); + } + + return ret; +} + +/** + *do_ffa_dev_list - implementation of the devlist subcommand + * @cmdtp: [in] Command Table + * @flag: flags + * @argc: number of arguments + * @argv: arguments + * + * This function queries the devices belonging to the UCLASS_FFA + * class. Currently, one device is expected to show up: the arm_ffa device + * + * Return: + * + * CMD_RET_SUCCESS: on success, otherwise failure + */ +int do_ffa_dev_list(struct cmd_tbl *cmdtp, int flag, int argc, char *const argv[]) +{ + struct udevice *dev = NULL; + int i, ret; + + ffa_info("arm_ffa uclass entries:"); + + for (i = 0, ret = uclass_first_device(UCLASS_FFA, &dev); + dev; + ret = uclass_next_device(&dev), i++) { + if (ret) + break; + + ffa_info("entry %d - instance %08x, ops %08x, plat %08x", + i, + (u32)map_to_sysmem(dev), + (u32)map_to_sysmem(dev->driver->ops), + (u32)map_to_sysmem(dev_get_plat(dev))); + } + + return cmd_process_error(cmdtp, ret); +} + +static struct cmd_tbl armffa_commands[] = { + U_BOOT_CMD_MKENT(getpart, 1, 1, do_ffa_get_singular_partition_info, "", ""), + U_BOOT_CMD_MKENT(ping, 1, 1, do_ffa_msg_send_direct_req, "", ""), + U_BOOT_CMD_MKENT(devlist, 0, 1, do_ffa_dev_list, "", ""), +}; + +/** + * do_armffa - the armffa command main function + * @cmdtp: Command Table + * @flag: flags + * @argc: number of arguments + * @argv: arguments + * + * This function identifies which armffa subcommand to run. + * Then, it makes sure the arm_ffa device is probed and + * ready for use. + * Then, it runs the subcommand. + * + * Return: + * + * CMD_RET_SUCCESS: on success, otherwise failure + */ +static int do_armffa(struct cmd_tbl *cmdtp, int flag, int argc, char *const argv[]) +{ + struct cmd_tbl *armffa_cmd; + int ret; + + if (argc < 2) + return CMD_RET_USAGE; + + armffa_cmd = find_cmd_tbl(argv[1], armffa_commands, ARRAY_SIZE(armffa_commands)); + + argc -= 2; + argv += 2; + + if (!armffa_cmd || argc > armffa_cmd->maxargs) + return CMD_RET_USAGE; + + ret = ffa_helper_bus_discover(); + if (ret != FFA_ERR_STAT_SUCCESS) + return cmd_process_error(cmdtp, ret); + + ret = armffa_cmd->cmd(armffa_cmd, flag, argc, argv); + + return cmd_process_error(armffa_cmd, ret); +} + +U_BOOT_CMD(armffa, 4, 1, do_armffa, + "Arm FF-A operations test command", + "getpart <partition UUID>\n" + " - lists the partition(s) info\n" + "ping <partition ID>\n" + " - sends a data pattern to the specified partition\n" + "devlist\n" + " - displays the arm_ffa device info\n"); diff --git a/drivers/arm-ffa/Kconfig b/drivers/arm-ffa/Kconfig index 23815534c4..fa2b2fecfb 100644 --- a/drivers/arm-ffa/Kconfig +++ b/drivers/arm-ffa/Kconfig @@ -4,6 +4,7 @@ config ARM_FFA_TRANSPORT bool "Enable Arm Firmware Framework for Armv8-A driver" depends on DM && ARM64 select ARM_SMCCC if ARM64 + select CMD_ARMFFA select LIB_UUID select ARM_FFA_TRANSPORT_HELPERS help
Provide a Sandbox driver to emulate the FF-A ABIs
The emulated ABIs are those supported by the FF-A core driver and according to FF-A specification v1.0.
The Sandbox driver provides operations allowing the test application to read the status of all the inspected ABIs and perform functional tests based on that.
Signed-off-by: Abdellatif El Khlifi abdellatif.elkhlifi@arm.com --- MAINTAINERS | 2 + common/board_r.c | 2 +- configs/sandbox64_defconfig | 2 + configs/sandbox_defconfig | 2 + doc/arch/sandbox.rst | 1 + drivers/arm-ffa/Kconfig | 8 +- drivers/arm-ffa/Makefile | 1 + drivers/arm-ffa/arm-ffa-uclass.c | 47 +- drivers/arm-ffa/core.c | 97 ++-- drivers/arm-ffa/sandbox.c | 669 ++++++++++++++++++++++++++ drivers/arm-ffa/sandbox_arm_ffa_prv.h | 131 +++++ include/arm_ffa.h | 9 +- include/sandbox_arm_ffa.h | 31 ++ include/sandbox_arm_ffa_helper.h | 26 + lib/arm-ffa/Makefile | 1 + lib/arm-ffa/arm_ffa_helper.c | 2 +- lib/arm-ffa/sandbox_arm_ffa_helper.c | 23 + lib/efi_loader/efi_boottime.c | 4 +- 18 files changed, 1017 insertions(+), 41 deletions(-) create mode 100644 drivers/arm-ffa/sandbox.c create mode 100644 drivers/arm-ffa/sandbox_arm_ffa_prv.h create mode 100644 include/sandbox_arm_ffa.h create mode 100644 include/sandbox_arm_ffa_helper.h create mode 100644 lib/arm-ffa/sandbox_arm_ffa_helper.c
diff --git a/MAINTAINERS b/MAINTAINERS index ca2e13b9ec..7c439ed1fd 100644 --- a/MAINTAINERS +++ b/MAINTAINERS @@ -239,6 +239,8 @@ F: cmd/armffa.c F: drivers/arm-ffa/ F: include/arm_ffa.h F: include/arm_ffa_helper.h +F: include/sandbox_arm_ffa.h +F: include/sandbox_arm_ffa_helper.h F: lib/arm-ffa/
ARM FREESCALE IMX diff --git a/common/board_r.c b/common/board_r.c index bb5f1d0aa6..a03b5254b7 100644 --- a/common/board_r.c +++ b/common/board_r.c @@ -775,7 +775,7 @@ static init_fnc_t init_sequence_r[] = { INIT_FUNC_WATCHDOG_RESET initr_net, #endif -#ifdef CONFIG_ARM_FFA_TRANSPORT +#if defined(CONFIG_ARM_FFA_TRANSPORT) && !defined(CONFIG_SANDBOX_FFA) ffa_helper_bus_discover, #endif #ifdef CONFIG_POST diff --git a/configs/sandbox64_defconfig b/configs/sandbox64_defconfig index 4fbe148074..d6b3a137e3 100644 --- a/configs/sandbox64_defconfig +++ b/configs/sandbox64_defconfig @@ -252,3 +252,5 @@ CONFIG_TEST_FDTDEC=y CONFIG_UNIT_TEST=y CONFIG_UT_TIME=y CONFIG_UT_DM=y +CONFIG_ARM_FFA_TRANSPORT=y +CONFIG_SANDBOX_FFA=y \ No newline at end of file diff --git a/configs/sandbox_defconfig b/configs/sandbox_defconfig index 1826cf0195..161ff221bf 100644 --- a/configs/sandbox_defconfig +++ b/configs/sandbox_defconfig @@ -326,3 +326,5 @@ CONFIG_TEST_FDTDEC=y CONFIG_UNIT_TEST=y CONFIG_UT_TIME=y CONFIG_UT_DM=y +CONFIG_ARM_FFA_TRANSPORT=y +CONFIG_SANDBOX_FFA=y \ No newline at end of file diff --git a/doc/arch/sandbox.rst b/doc/arch/sandbox.rst index f8804e1f41..7cb5ea307c 100644 --- a/doc/arch/sandbox.rst +++ b/doc/arch/sandbox.rst @@ -203,6 +203,7 @@ Supported Drivers
U-Boot sandbox supports these emulations:
+- Arm FF-A - Block devices - Chrome OS EC - GPIO diff --git a/drivers/arm-ffa/Kconfig b/drivers/arm-ffa/Kconfig index fa2b2fecfb..5774ae6496 100644 --- a/drivers/arm-ffa/Kconfig +++ b/drivers/arm-ffa/Kconfig @@ -2,7 +2,7 @@
config ARM_FFA_TRANSPORT bool "Enable Arm Firmware Framework for Armv8-A driver" - depends on DM && ARM64 + depends on DM && (ARM64 || SANDBOX) select ARM_SMCCC if ARM64 select CMD_ARMFFA select LIB_UUID @@ -26,3 +26,9 @@ config ARM_FFA_TRANSPORT FF-A communication is handled by one device and one instance (the bus). This FF-A driver takes care of all the interactions between Normal world and Secure World. + +config SANDBOX_FFA + bool "FF-A Sandbox driver" + depends on ARM_FFA_TRANSPORT && SANDBOX + help + This emulates the FF-A handling under Sandbox and allows to test the FF-A driver diff --git a/drivers/arm-ffa/Makefile b/drivers/arm-ffa/Makefile index 7bc9a336a9..df1cfe6ef0 100644 --- a/drivers/arm-ffa/Makefile +++ b/drivers/arm-ffa/Makefile @@ -4,3 +4,4 @@ #
obj-y += arm-ffa-uclass.o core.o +obj-$(CONFIG_SANDBOX_FFA) += sandbox.o diff --git a/drivers/arm-ffa/arm-ffa-uclass.c b/drivers/arm-ffa/arm-ffa-uclass.c index 2439f87586..418aa06dd6 100644 --- a/drivers/arm-ffa/arm-ffa-uclass.c +++ b/drivers/arm-ffa/arm-ffa-uclass.c @@ -11,6 +11,10 @@ #include <log.h> #include <asm/global_data.h>
+#if CONFIG_IS_ENABLED(SANDBOX_FFA) +#include <sandbox_arm_ffa.h> +#endif + DECLARE_GLOBAL_DATA_PTR;
UCLASS_DRIVER(ffa) = { @@ -42,16 +46,42 @@ int __ffa_runtime ffa_get_invoke_func(u32 func_id, struct ffa_interface_data *fu return ffa_device_get_ops()->invoke_func(func_id, func_data); }
+#if CONFIG_IS_ENABLED(SANDBOX_FFA) + +/** + * sandbox_ffa_get_invoke_func - performs a call to the Sandbox FF-A driver dispatcher + * @func_id: The FF-A function to be queried + * @func_data: Pointer to the query arguments + * container structure. + * + * This function passes the FF-A function ID to be queried during sandbox test cases + * and its arguments to the Sandbox FF-A driver dispatcher. + * This function is called by the Sandbox FF-A helper function. + * + * Return: + * + * FFA_ERR_STAT_SUCCESS on success. Otherwise, failure + */ +int sandbox_ffa_get_invoke_func(u32 func_id, struct ffa_interface_data *func_data) +{ + if (!sandbox_ffa_device_get_ops()->invoke_func) + return -EINVAL; + + return sandbox_ffa_device_get_ops()->invoke_func(func_id, func_data); +} +#endif + /** - * ffa_bus_discover - discover FF-A bus and probe the arm_ffa device + * ffa_bus_discover - discover FF-A bus and probe arm_ffa and sandbox_arm_ffa devices * * This boot time function makes sure the FF-A bus is discoverable. - * Then, the arm_ffa device is probed and ready to use. + * Then, the arm_ffa and sandbox_arm_ffa devices are ready to use. + * * This function is called automatically at initcalls * level (after u-boot relocation). * * Arm FF-A transport is implemented through arm_ffa u-boot device managing the FF-A - * communication. + * communication. In Sandbox mode sandbox_arm_ffa is used to test arm_ffa driver. * All FF-A clients should use the arm_ffa device to use the FF-A transport. * * Return: @@ -60,5 +90,14 @@ int __ffa_runtime ffa_get_invoke_func(u32 func_id, struct ffa_interface_data *fu */ int ffa_bus_discover(void) { - return ffa_get_device(); + int ret; + + ret = ffa_get_device(); + +#if CONFIG_IS_ENABLED(SANDBOX_FFA) + if (ret == FFA_ERR_STAT_SUCCESS) + ret = sandbox_ffa_get_device(); +#endif + + return ret; } diff --git a/drivers/arm-ffa/core.c b/drivers/arm-ffa/core.c index 09e4eb753a..246abc1473 100644 --- a/drivers/arm-ffa/core.c +++ b/drivers/arm-ffa/core.c @@ -5,6 +5,11 @@ */
#include "arm_ffa_prv.h" + +#if CONFIG_IS_ENABLED(SANDBOX_FFA) +#include "sandbox_arm_ffa_prv.h" +#endif + #include <asm/global_data.h> #include <asm/io.h> #include <common.h> @@ -88,8 +93,10 @@ static int ffa_get_version(void)
FFA_DECLARE_ARGS;
- if (!ffa_priv_data.invoke_ffa_fn) - panic("[FFA] no private data found\n"); + if (!ffa_priv_data.invoke_ffa_fn) { + ffa_panic("no private data found\n"); + return -ENODEV; + }
a0 = FFA_VERSION; a1 = FFA_VERSION_1_0; @@ -132,8 +139,10 @@ static int ffa_get_endpoint_id(void) { FFA_DECLARE_ARGS;
a0 = FFA_ID_GET;
@@ -206,8 +215,10 @@ static int ffa_get_rxtx_map_features(void) { FFA_DECLARE_ARGS;
a0 = FFA_FEATURES; a1 = FFA_RXTX_MAP; @@ -433,8 +444,10 @@ static int ffa_map_rxtx_buffers(size_t buf_4k_pages)
FFA_DECLARE_ARGS;
ret = ffa_alloc_rxtx_buffers(buf_4k_pages); if (ret != FFA_ERR_STAT_SUCCESS) @@ -502,8 +515,10 @@ static int ffa_unmap_rxtx_buffers(void) { FFA_DECLARE_ARGS;
a0 = FFA_RXTX_UNMAP; a1 = PREP_SELF_ENDPOINT_ID(ffa_priv_data.id); @@ -514,11 +529,12 @@ static int ffa_unmap_rxtx_buffers(void) case FFA_ERROR: { if (((int)res.a2) == FFA_ERR_STAT_NOT_SUPPORTED) - panic("[FFA] FFA_RXTX_UNMAP is not implemented at this FF-A instance\n"); + ffa_panic("FFA_RXTX_UNMAP is not implemented at this FF-A instance\n"); else if (((int)res.a2) == FFA_ERR_STAT_INVALID_PARAMETERS) - panic("[FFA] There is no buffer pair registered on behalf of the caller\n"); + ffa_panic("There is no buffer pair registered on behalf of the caller\n"); else - panic("[FFA] Undefined error (%d)\n", ((int)res.a2)); + ffa_panic("Undefined error (%d)\n", ((int)res.a2)); + return -ENODEV; } case FFA_SUCCESS: { @@ -526,19 +542,24 @@ static int ffa_unmap_rxtx_buffers(void) int ret;
ret = ffa_get_rxtx_buffers_pages_cnt(&buf_4k_pages); - if (ret != FFA_ERR_STAT_SUCCESS) - panic("[FFA] RX/TX buffers unmapped but failure in getting pages count\n"); + if (ret != FFA_ERR_STAT_SUCCESS) { + ffa_panic("RX/TX buffers unmapped but failure in getting pages count\n"); + return -ENODEV; + }
ret = ffa_free_rxtx_buffers(buf_4k_pages); - if (ret != FFA_ERR_STAT_SUCCESS) - panic("[FFA] RX/TX buffers unmapped but failure in freeing the memory\n"); + if (ret != FFA_ERR_STAT_SUCCESS) { + ffa_panic("RX/TX buffers unmapped but failure in freeing the memory\n"); + return -ENODEV; + }
return FFA_ERR_STAT_SUCCESS; } default: - panic("[FFA] Undefined response function (0x%lx)", res.a0); + ffa_panic("Undefined response function (0x%lx)", res.a0); + return -ENODEV; } }
@@ -556,8 +577,10 @@ static int ffa_release_rx_buffer(void) { FFA_DECLARE_ARGS;
@@ -567,17 +590,19 @@ static int ffa_release_rx_buffer(void) case FFA_ERROR: { if (((int)res.a2) == FFA_ERR_STAT_NOT_SUPPORTED) - panic("[FFA] FFA_RX_RELEASE is not implemented at this FF-A instance\n"); + ffa_panic("FFA_RX_RELEASE is not implemented at this FF-A instance\n"); else if (((int)res.a2) == FFA_ERR_STAT_DENIED) - panic("[FFA] Caller did not have ownership of the RX buffer\n"); + ffa_panic("Caller did not have ownership of the RX buffer\n"); else - panic("[FFA] Undefined error (%d)\n", ((int)res.a2)); + ffa_panic("Undefined error (%d)\n", ((int)res.a2)); + return -ENODEV; } case FFA_SUCCESS: return FFA_ERR_STAT_SUCCESS;
default: - panic("[FFA] Undefined response function (0x%lx)\n", res.a0); + ffa_panic("Undefined response function (0x%lx)\n", res.a0); + return -ENODEV; } }
@@ -769,8 +794,10 @@ static int ffa_query_partitions_info(union ffa_partition_uuid *part_uuid, unsigned long a7 = 0; struct arm_smccc_res res = {0};
@@ -846,7 +873,7 @@ static int ffa_query_partitions_info(union ffa_partition_uuid *part_uuid, ret = ffa_release_rx_buffer();
if (!part_uuid && !res.a2) { - ffa_err("[FFA] no partition installed in the system"); + ffa_err("no partition installed in the system"); return -ENODEV; }
@@ -937,8 +964,10 @@ static int ffa_get_partitions_info(struct ffa_interface_data *func_data) return -EINVAL; }
- if (!ffa_priv_data.partitions.count || !ffa_priv_data.partitions.descs) - panic("[FFA] No partition installed\n"); + if (!ffa_priv_data.partitions.count || !ffa_priv_data.partitions.descs) { + ffa_panic("No partition installed\n"); + return -ENODEV; + }
if (func_data->data0_size == sizeof(union ffa_partition_uuid) && func_data->data0 && @@ -1176,6 +1205,7 @@ static int __ffa_runtime ffa_msg_send_direct_req(struct ffa_interface_data /* Undefined error */ return -ENXIO; } + return -ENODEV; } case FFA_SUCCESS:
@@ -1238,7 +1268,7 @@ int __ffa_runtime invoke_ffa_drv_api(u32 func_id, /** * ffa_set_conduit - Set the conduit * - * This boot time function clears the private data structure and sets the conduit + * This boot time function sets the conduit * * Return: * @@ -1248,7 +1278,12 @@ static int ffa_set_conduit(void) { ffa_priv_data.conduit = FFA_CONDUIT_SMC;
- ffa_priv_data.invoke_ffa_fn = arm_ffa_smccc_smc; +#if CONFIG_IS_ENABLED(SANDBOX_FFA) + ffa_priv_data.invoke_ffa_fn = sandbox_arm_ffa_smccc_smc; + ffa_info("Using SMC emulation"); +#else + ffa_priv_data.invoke_ffa_fn = arm_ffa_smccc_smc; +#endif
ffa_info("Conduit is SMC");
diff --git a/drivers/arm-ffa/sandbox.c b/drivers/arm-ffa/sandbox.c new file mode 100644 index 0000000000..d4a953fc3b --- /dev/null +++ b/drivers/arm-ffa/sandbox.c @@ -0,0 +1,669 @@ +// SPDX-License-Identifier: GPL-2.0+ +/* + * (C) Copyright 2022 ARM Limited + * Abdellatif El Khlifi abdellatif.elkhlifi@arm.com + */ + +#include "sandbox_arm_ffa_prv.h" +#include <asm/global_data.h> +#include <common.h> +#include <dm.h> +#include <dm/device-internal.h> +#include <dm/root.h> +#include <linux/errno.h> +#include <linux/sizes.h> +#include <mapmem.h> +#include <string.h> + +DECLARE_GLOBAL_DATA_PTR; + +/** + * The device private data structure containing all the emulated secure world data + */ +static struct sandbox_ffa_prvdata sandbox_ffa_priv_data = {0}; + +/* The partitions (SPs) table */ +static struct ffa_partition_desc sandbox_partitions[SANDBOX_PARTITIONS_CNT] = { + { + .info = { .id = 0x1245, .exec_ctxt = 0x5687, .properties = 0x89325621 }, + .UUID = { .bytes = {SANDBOX_SERVICE1_UUID_DATA}} + }, + { + .info = { .id = 0x9836, .exec_ctxt = 0x9587, .properties = 0x45325621 }, + .UUID = { .bytes = {SANDBOX_SERVICE2_UUID_DATA}} + }, + { + .info = { .id = 0x6452, .exec_ctxt = 0x7687, .properties = 0x23325621 }, + .UUID = { .bytes = {SANDBOX_SERVICE1_UUID_DATA}} + }, + { + .info = { .id = 0x7814, .exec_ctxt = 0x1487, .properties = 0x70325621 }, + .UUID = { .bytes = {SANDBOX_SERVICE2_UUID_DATA}} + } + +}; + +/* + * Driver functions + */ + +/** + * sandbox_ffa_get_device - probes the sandbox_arm_ffa device + * + * This function makes sure the sandbox_arm_ffa device is probed + * This function makes sure the sandbox_arm_ffa device is + * created, bound to this driver, probed and ready to use. + * + * sandbox_arm_ffa depends on arm_ffa device. This dependency is + * handled by ffa_bus_discover function. arm_ffa is probed first then + * sandbox_arm_ffa. + * + * Return: + * + * FFA_ERR_STAT_SUCCESS on success. Otherwise, failure + */ +int sandbox_ffa_get_device(void) +{ + int ret; + + if (sandbox_ffa_priv_data.dev) + return FFA_ERR_STAT_SUCCESS; + + ret = device_bind(dm_root(), + DM_DRIVER_GET(sandbox_arm_ffa), + FFA_SANDBOX_DRV_NAME, + NULL, + ofnode_null(), + &sandbox_ffa_priv_data.dev); + if (ret) { + sandbox_ffa_priv_data.dev = NULL; + return ret; + } + + ret = device_probe(sandbox_ffa_priv_data.dev); + if (ret) { + ffa_err("[Sandbox] can not probe the device"); + device_unbind(sandbox_ffa_priv_data.dev); + sandbox_ffa_priv_data.dev = NULL; + return ret; + } + + return FFA_ERR_STAT_SUCCESS; +} + +/** + * sandbox_ffa_version - Emulated FFA_VERSION handler function + * @{a0-a7} , res: The SMC call arguments and return structure. + * + * This is the function that emulates FFA_VERSION FF-A function. + * + * Return: + * + * FFA_ERR_STAT_SUCCESS on success. Otherwise, failure + */ +SANDBOX_SMC_FFA_ABI(ffa_version) +{ + sandbox_ffa_priv_data.fwk_version = FFA_VERSION_1_0; + res->a0 = sandbox_ffa_priv_data.fwk_version; + + /* w1-w7 MBZ */ + memset(FFA_W1W7_MBZ_REG_START, 0, FFA_W1W7_MBZ_CNT * sizeof(unsigned long)); + + return FFA_ERR_STAT_SUCCESS; +} + +/** + * sandbox_ffa_id_get - Emulated FFA_ID_GET handler function + * @{a0-a7} , res: The SMC call arguments and return structure. + * + * This is the function that emulates FFA_ID_GET FF-A function. + * + * Return: + * + * FFA_ERR_STAT_SUCCESS on success. Otherwise, failure + */ +SANDBOX_SMC_FFA_ABI(ffa_id_get) +{ + res->a0 = FFA_SUCCESS; + res->a1 = 0; + + sandbox_ffa_priv_data.id = NS_PHYS_ENDPOINT_ID; + res->a2 = sandbox_ffa_priv_data.id; + + /* w3-w7 MBZ */ + memset(FFA_W3_MBZ_REG_START, 0, FFA_W3W7_MBZ_CNT * sizeof(unsigned long)); + + return FFA_ERR_STAT_SUCCESS; +} + +/** + * sandbox_ffa_features - Emulated FFA_FEATURES handler function + * @{a0-a7} , res: The SMC call arguments and return structure. + * + * This is the function that emulates FFA_FEATURES FF-A function. + * + * Return: + * + * FFA_ERR_STAT_SUCCESS on success. Otherwise, failure + */ +SANDBOX_SMC_FFA_ABI(ffa_features) +{ + switch (a1) { + case FFA_RXTX_MAP: + { + res->a0 = FFA_SUCCESS; + res->a2 = RXTX_BUFFERS_MIN_SIZE; + res->a3 = 0; + /* w4-w7 MBZ */ + memset(FFA_W4W7_MBZ_REG_START, + 0, FFA_W4W7_MBZ_CNT * sizeof(unsigned long)); + break; + } + default: + { + res->a0 = FFA_ERROR; + res->a2 = FFA_ERR_STAT_NOT_SUPPORTED; + /* w3-w7 MBZ */ + memset(FFA_W3_MBZ_REG_START, + 0, FFA_W3W7_MBZ_CNT * sizeof(unsigned long)); + ffa_err("[Sandbox] FF-A interface 0x%lx not implemented", a1); + } + } + + res->a1 = 0; + + return FFA_ERR_STAT_SUCCESS; +} + +/** + * sandbox_ffa_partition_info_get - Emulated FFA_PARTITION_INFO_GET handler function + * @{a0-a7} , res: The SMC call arguments and return structure. + * + * This is the function that emulates FFA_PARTITION_INFO_GET FF-A function. + * + * Return: + * + * FFA_ERR_STAT_SUCCESS on success. Otherwise, failure + */ +SANDBOX_SMC_FFA_ABI(ffa_partition_info_get) +{ + struct ffa_partition_info *rxbuf_desc_info = NULL; + u32 descs_cnt; + u32 descs_size_bytes; + + res->a0 = FFA_ERROR; + + if (!sandbox_ffa_priv_data.pair.rxbuf) { + res->a2 = FFA_ERR_STAT_DENIED; + goto cleanup; + } + + if (sandbox_ffa_priv_data.pair_info.rxbuf_owned) { + res->a2 = FFA_ERR_STAT_BUSY; + goto cleanup; + } + + if (!sandbox_ffa_priv_data.partitions.descs) { + sandbox_ffa_priv_data.partitions.descs = sandbox_partitions; + sandbox_ffa_priv_data.partitions.count = SANDBOX_PARTITIONS_CNT; + } + + descs_size_bytes = SANDBOX_PARTITIONS_CNT * sizeof(struct ffa_partition_desc); + + /* Abort if the RX buffer size is smaller than the descriptors buffer size */ + if ((sandbox_ffa_priv_data.pair_info.rxtx_buf_size * SZ_4K) < descs_size_bytes) { + res->a2 = FFA_ERR_STAT_NO_MEMORY; + goto cleanup; + } + + rxbuf_desc_info = (struct ffa_partition_info *)sandbox_ffa_priv_data.pair.rxbuf; + + /* No UUID specified. Return the information of all partitions */ + if (!a1 && !a2 && !a3 && !a4) { + for (descs_cnt = 0 ; descs_cnt < SANDBOX_PARTITIONS_CNT ; descs_cnt++) + *(rxbuf_desc_info++) = + sandbox_ffa_priv_data.partitions.descs[descs_cnt].info; + + res->a0 = FFA_SUCCESS; + res->a2 = SANDBOX_PARTITIONS_CNT; + /* transfer ownership to the consumer: the non secure world */ + sandbox_ffa_priv_data.pair_info.rxbuf_owned = 1; + + goto cleanup; + } + + /* + * A UUID is specified. Return the information of all partitions matching + * the UUID + */ + + for (descs_cnt = 0 ; descs_cnt < SANDBOX_PARTITIONS_CNT ; descs_cnt++) + if (a1 == sandbox_ffa_priv_data.partitions.descs[descs_cnt].UUID.words.a1 && + a2 == sandbox_ffa_priv_data.partitions.descs[descs_cnt].UUID.words.a2 && + a3 == sandbox_ffa_priv_data.partitions.descs[descs_cnt].UUID.words.a3 && + a4 == sandbox_ffa_priv_data.partitions.descs[descs_cnt].UUID.words.a4) { + *(rxbuf_desc_info++) = + sandbox_ffa_priv_data.partitions.descs[descs_cnt].info; + } + + if (rxbuf_desc_info != ((struct ffa_partition_info *)sandbox_ffa_priv_data.pair.rxbuf)) { + res->a0 = FFA_SUCCESS; + /* store the partitions count */ + res->a2 = (unsigned long) + (rxbuf_desc_info - (struct ffa_partition_info *) + sandbox_ffa_priv_data.pair.rxbuf); + + /* transfer ownership to the consumer: the non secure world */ + sandbox_ffa_priv_data.pair_info.rxbuf_owned = 1; + } else { + res->a2 = FFA_ERR_STAT_INVALID_PARAMETERS; + } + +cleanup: + + ffa_err("[Sandbox] FFA_PARTITION_INFO_GET (%ld)", res->a2); + + res->a1 = 0; + + /* w3-w7 MBZ */ + memset(FFA_W3_MBZ_REG_START, 0, FFA_W3W7_MBZ_CNT * sizeof(unsigned long)); + + return FFA_ERR_STAT_SUCCESS; +} + +/** + * sandbox_ffa_rxtx_map - Emulated FFA_RXTX_MAP handler function + * @{a0-a7} , res: The SMC call arguments and return structure. + * + * This is the function that emulates FFA_RXTX_MAP FF-A function. + * + * Return: + * + * FFA_ERR_STAT_SUCCESS on success. Otherwise, failure + */ +SANDBOX_SMC_FFA_ABI(ffa_rxtx_map) +{ + res->a0 = FFA_ERROR; + + if (sandbox_ffa_priv_data.pair.txbuf && sandbox_ffa_priv_data.pair.rxbuf) { + res->a2 = FFA_ERR_STAT_DENIED; + goto feedback; + } + + if (a3 >= RXTX_BUFFERS_MIN_PAGES && a1 && a2) { + sandbox_ffa_priv_data.pair.txbuf = a1; + sandbox_ffa_priv_data.pair.rxbuf = a2; + sandbox_ffa_priv_data.pair_info.rxtx_buf_size = a3; + sandbox_ffa_priv_data.pair_info.rxbuf_mapped = 1; + res->a0 = FFA_SUCCESS; + res->a2 = 0; + goto feedback; + } + + if (!a1 || !a2) + res->a2 = FFA_ERR_STAT_INVALID_PARAMETERS; + else + res->a2 = FFA_ERR_STAT_NO_MEMORY; + + ffa_err("[Sandbox] error in FFA_RXTX_MAP arguments (%d)", (int)res->a2); + +feedback: + + res->a1 = 0; + + /* w3-w7 MBZ */ + memset(FFA_W3_MBZ_REG_START, + 0, FFA_W3W7_MBZ_CNT * sizeof(unsigned long)); + + return FFA_ERR_STAT_SUCCESS; +} + +/** + * sandbox_ffa_rxtx_unmap - Emulated FFA_RXTX_UNMAP handler function + * @{a0-a7} , res: The SMC call arguments and return structure. + * + * This is the function that emulates FFA_RXTX_UNMAP FF-A function. + * + * Return: + * + * FFA_ERR_STAT_SUCCESS on success. Otherwise, failure + */ +SANDBOX_SMC_FFA_ABI(ffa_rxtx_unmap) +{ + res->a0 = FFA_ERROR; + res->a2 = FFA_ERR_STAT_INVALID_PARAMETERS; + + if (GET_NS_PHYS_ENDPOINT_ID(a1) != sandbox_ffa_priv_data.id) + goto feedback; + + if (sandbox_ffa_priv_data.pair.txbuf && sandbox_ffa_priv_data.pair.rxbuf) { + sandbox_ffa_priv_data.pair.txbuf = 0; + sandbox_ffa_priv_data.pair.rxbuf = 0; + sandbox_ffa_priv_data.pair_info.rxtx_buf_size = 0; + sandbox_ffa_priv_data.pair_info.rxbuf_mapped = 0; + res->a0 = FFA_SUCCESS; + res->a2 = 0; + goto feedback; + } + + ffa_err("[Sandbox] No buffer pair registered on behalf of the caller"); + +feedback: + + res->a1 = 0; + + /* w3-w7 MBZ */ + memset(FFA_W3_MBZ_REG_START, + 0, FFA_W3W7_MBZ_CNT * sizeof(unsigned long)); + + return FFA_ERR_STAT_SUCCESS; +} + +/** + * sandbox_ffa_rx_release - Emulated FFA_RX_RELEASE handler function + * @{a0-a7} , res: The SMC call arguments and return structure. + * + * This is the function that emulates FFA_RX_RELEASE FF-A function. + * + * Return: + * + * FFA_ERR_STAT_SUCCESS on success. Otherwise, failure + */ +SANDBOX_SMC_FFA_ABI(ffa_rx_release) +{ + if (!sandbox_ffa_priv_data.pair_info.rxbuf_owned) { + res->a0 = FFA_ERROR; + res->a2 = FFA_ERR_STAT_DENIED; + } else { + sandbox_ffa_priv_data.pair_info.rxbuf_owned = 0; + res->a0 = FFA_SUCCESS; + res->a2 = 0; + } + + res->a1 = 0; + + /* w3-w7 MBZ */ + memset(FFA_W3_MBZ_REG_START, + 0, FFA_W3W7_MBZ_CNT * sizeof(unsigned long)); + + return FFA_ERR_STAT_SUCCESS; +} + +/** + * sandbox_ffa_sp_valid - Checks SP validity + * @part_id: partition ID to check + * + * This is the function searches the input ID in the descriptors table. + * + * Return: + * + * 1 on success (Partition found). Otherwise, failure + */ +int sandbox_ffa_sp_valid(u16 part_id) +{ + u32 descs_cnt; + + for (descs_cnt = 0 ; descs_cnt < SANDBOX_PARTITIONS_CNT ; descs_cnt++) + if (sandbox_ffa_priv_data.partitions.descs[descs_cnt].info.id == part_id) + return 1; + + return 0; +} + +/** + * sandbox_ffa_msg_send_direct_req - Emulated FFA_MSG_SEND_DIRECT_{REQ,RESP} handler function + * @{a0-a7} , res: The SMC call arguments and return structure. + * + * This is the function that emulates FFA_MSG_SEND_DIRECT_{REQ,RESP} + * FF-A functions. + * + * Emulating interrupts is not supported. So, FFA_RUN and FFA_INTERRUPT are not supported. + * + * Return: + * + * FFA_ERR_STAT_SUCCESS on success. Otherwise, failure + */ +SANDBOX_SMC_FFA_ABI(ffa_msg_send_direct_req) +{ + u16 part_id; + + part_id = GET_DST_SP_ID(a1); + + if ((GET_NS_PHYS_ENDPOINT_ID(a1) != sandbox_ffa_priv_data.id) || + !sandbox_ffa_sp_valid(part_id) || + a2) { + res->a0 = FFA_ERROR; + res->a1 = 0; + res->a2 = FFA_ERR_STAT_INVALID_PARAMETERS; + + /* w3-w7 MBZ */ + memset(FFA_W3_MBZ_REG_START, + 0, FFA_W3W7_MBZ_CNT * sizeof(unsigned long)); + + return FFA_ERR_STAT_SUCCESS; + } + + res->a0 = FFA_MSG_SEND_DIRECT_RESP; + + res->a1 = PREP_SRC_SP_ID(part_id) | + PREP_NS_PHYS_ENDPOINT_ID(sandbox_ffa_priv_data.id); + + res->a2 = 0; + + /* + * return 0xff bytes as a response + */ + res->a3 = 0xffffffff; + res->a4 = 0xffffffff; + res->a5 = 0xffffffff; + res->a6 = 0xffffffff; + res->a7 = 0xffffffff; + + return FFA_ERR_STAT_SUCCESS; +} + +/** + * sandbox_ffa_get_prv_data - Returns the pointer to FF-A core pivate data + * @func_data: Pointer to the FF-A function arguments container structure + * + * This is the handler that returns the address of the FF-A core pivate data. + * + * Return: + * + * FFA_ERR_STAT_SUCCESS on success. Otherwise, failure + */ +int sandbox_ffa_get_prv_data(struct ffa_interface_data *func_data) +{ + if (!func_data) + return -EINVAL; + + if (!func_data->data0 || func_data->data0_size != sizeof(struct ffa_prvdata **)) + return -EINVAL; + + if (!func_data->data1 || func_data->data1_size != sizeof(struct sandbox_ffa_prvdata **)) + return -EINVAL; + + *((struct ffa_prvdata **)func_data->data0) = &ffa_priv_data; + *((struct sandbox_ffa_prvdata **)func_data->data1) = &sandbox_ffa_priv_data; + + return FFA_ERR_STAT_SUCCESS; +} + +/** + * sandbox_ffa_get_rxbuf_flags - Reading the mapping/ownership flags + * @queried_func_id: The FF-A function to be queried + * @func_data: Pointer to the FF-A function arguments container structure + * + * This is the handler that queries the status flags of the following emulated ABIs: + * FFA_RXTX_MAP, FFA_RXTX_UNMAP, FFA_RX_RELEASE + * + * Return: + * + * FFA_ERR_STAT_SUCCESS on success. Otherwise, failure + */ +int sandbox_ffa_get_rxbuf_flags(u32 queried_func_id, struct ffa_interface_data *func_data) +{ + if (!func_data) + return -EINVAL; + + if (!func_data->data0 || func_data->data0_size != sizeof(u8)) + return -EINVAL; + + switch (queried_func_id) { + case FFA_RXTX_MAP: + case FFA_RXTX_UNMAP: + *((u8 *)func_data->data0) = sandbox_ffa_priv_data.pair_info.rxbuf_mapped; + return FFA_ERR_STAT_SUCCESS; + case FFA_RX_RELEASE: + *((u8 *)func_data->data0) = sandbox_ffa_priv_data.pair_info.rxbuf_owned; + return FFA_ERR_STAT_SUCCESS; + default: + ffa_err("[Sandbox] The querried FF-A interface flag (%d) undefined", + queried_func_id); + return -EINVAL; + } +} + +/** + * invoke_sandbox_ffa_drv_api - The driver dispatcher function + * @queried_func_id: The FF-A function to be queried + * @func_data: Pointer to the FF-A function arguments container structure + * + * The dispatcher function that selects the handler that queries the + * status of FF-A ABIs given in the input argument. + * + * Return: + * + * FFA_ERR_STAT_SUCCESS on success. Otherwise, failure + */ +int invoke_sandbox_ffa_drv_api(u32 queried_func_id, struct ffa_interface_data *func_data) +{ + switch (queried_func_id) { + case FFA_VERSION: + case FFA_ID_GET: + case FFA_FEATURES: + return sandbox_ffa_get_prv_data(func_data); + case FFA_RXTX_MAP: + case FFA_RXTX_UNMAP: + case FFA_RX_RELEASE: + return sandbox_ffa_get_rxbuf_flags(queried_func_id, func_data); + default: + ffa_err("[Sandbox] The querried FF-A interface (%d) undefined", queried_func_id); + return -EINVAL; + } +} + +/** + * sandbox_ffa_set_conduit - Set the conduit used by Sandbox + * + * Sets the conduit in the private data structure + * + * Return: + * + * FFA_ERR_STAT_SUCCESS on success. Otherwise, failure + */ +static int sandbox_ffa_set_conduit(void) +{ + sandbox_ffa_priv_data.conduit = FFA_CONDUIT_SMC; + + ffa_info("[Sandbox] Conduit is SMC"); + + return FFA_ERR_STAT_SUCCESS; +} + +/** + * sandbox_arm_ffa_smccc_smc - FF-A SMC call emulation + * @dev: the SMC arguments to be passed to the FF-A ABI + * + * Sandbox driver emulates the FF-A ABIs SMC call using this function. + * The emulated FF-A ABI is identified and invoked. + * FF-A emulation is based on the FF-A specification 1.0 + * + * Return: + * + * FFA_ERR_STAT_SUCCESS on success. Otherwise, failure. + * FF-A protocol error codes are returned using the registers arguments as described + * by the specification + */ +void sandbox_arm_ffa_smccc_smc(unsigned long a0, unsigned long a1, + unsigned long a2, unsigned long a3, unsigned long a4, + unsigned long a5, unsigned long a6, unsigned long a7, + struct arm_smccc_res *res) +{ + int ret = FFA_ERR_STAT_SUCCESS; + + switch (a0) { + case FFA_VERSION: + ret = sandbox_ffa_version(a0, a1, a2, a3, a4, a5, a6, a7, res); + break; + case FFA_PARTITION_INFO_GET: + ret = sandbox_ffa_partition_info_get(a0, a1, a2, a3, a4, a5, a6, a7, res); + break; + case FFA_RXTX_UNMAP: + ret = sandbox_ffa_rxtx_unmap(a0, a1, a2, a3, a4, a5, a6, a7, res); + break; + case FFA_MSG_SEND_DIRECT_REQ: + ret = sandbox_ffa_msg_send_direct_req(a0, a1, a2, a3, a4, a5, a6, a7, res); + break; + case FFA_ID_GET: + ret = sandbox_ffa_id_get(a0, a1, a2, a3, a4, a5, a6, a7, res); + break; + case FFA_FEATURES: + ret = sandbox_ffa_features(a0, a1, a2, a3, a4, a5, a6, a7, res); + break; + case FFA_RXTX_MAP: + ret = sandbox_ffa_rxtx_map(a0, a1, a2, a3, a4, a5, a6, a7, res); + break; + case FFA_RX_RELEASE: + ret = sandbox_ffa_rx_release(a0, a1, a2, a3, a4, a5, a6, a7, res); + break; + default: + ffa_err("[Sandbox] Undefined FF-A interface (0x%x)", (unsigned int)a0); + } + + if (ret != FFA_ERR_STAT_SUCCESS) + ffa_err("[Sandbox] FF-A ABI internal failure (%d)", ret); +} + +/** + * sandbox_ffa_probe - The driver probe function + * @dev: the sandbox_arm_ffa device + * + * At probe level the conduit is set + * + * Return: + * + * FFA_ERR_STAT_SUCCESS on success. Otherwise, failure + */ +static int sandbox_ffa_probe(struct udevice *dev) +{ + return sandbox_ffa_set_conduit(); +} + +/** + * sandbox_ffa_drv_ops - The driver operations structure + * @invoke_func: The driver dispatcher + */ +struct ffa_ops sandbox_ffa_drv_ops = { + .invoke_func = invoke_sandbox_ffa_drv_api +}; + +/** + * sandbox_ffa_device_get_ops - driver operations getter + * + * Return: + * This function returns a pointer to the driver operations structure + */ +const struct ffa_ops *sandbox_ffa_device_get_ops(void) +{ + return &sandbox_ffa_drv_ops; +} + +/** + * Declaring the sandbox_arm_ffa driver under UCLASS_FFA + */ +U_BOOT_DRIVER(sandbox_arm_ffa) = { + .name = FFA_SANDBOX_DRV_NAME, + .id = UCLASS_FFA, + .probe = sandbox_ffa_probe, +}; diff --git a/drivers/arm-ffa/sandbox_arm_ffa_prv.h b/drivers/arm-ffa/sandbox_arm_ffa_prv.h new file mode 100644 index 0000000000..56b8d50a96 --- /dev/null +++ b/drivers/arm-ffa/sandbox_arm_ffa_prv.h @@ -0,0 +1,131 @@ +/* SPDX-License-Identifier: GPL-2.0+ */ +/* + * (C) Copyright 2022 ARM Limited + * Abdellatif El Khlifi abdellatif.elkhlifi@arm.com + */ + +#ifndef __SANDBOX_ARM_FFA_PRV_H +#define __SANDBOX_ARM_FFA_PRV_H + +#include "arm_ffa_prv.h" + +/* + * This header is private. It is exclusively used by the Sandbox FF-A driver + */ + +/* FF-A core driver name */ +#define FFA_SANDBOX_DRV_NAME "sandbox_arm_ffa" + +/* Non-secure physical FF-A instance */ +#define NS_PHYS_ENDPOINT_ID (0) + +#define GET_NS_PHYS_ENDPOINT_ID_MASK GENMASK(31, 16) +#define GET_NS_PHYS_ENDPOINT_ID(x) \ + ((u16)(FIELD_GET(GET_NS_PHYS_ENDPOINT_ID_MASK, (x)))) + +/* Helper macro for reading the destination partition ID */ +#define GET_DST_SP_ID_MASK GENMASK(15, 0) +#define GET_DST_SP_ID(x) \ + ((u16)(FIELD_GET(GET_DST_SP_ID_MASK, (x)))) + +/* Helper macro for setting the source partition ID */ +#define PREP_SRC_SP_ID_MASK GENMASK(31, 16) +#define PREP_SRC_SP_ID(x) \ + (FIELD_PREP(PREP_SRC_SP_ID_MASK, (x))) + +/* Helper macro for setting the destination endpoint ID */ +#define PREP_NS_PHYS_ENDPOINT_ID_MASK GENMASK(15, 0) +#define PREP_NS_PHYS_ENDPOINT_ID(x) \ + (FIELD_PREP(PREP_NS_PHYS_ENDPOINT_ID_MASK, (x))) + +/* RX/TX buffers minimum size */ +#define RXTX_BUFFERS_MIN_SIZE (RXTX_4K) +#define RXTX_BUFFERS_MIN_PAGES (1) + +/* MBZ registers info */ + +/* w1-w7 MBZ */ +#define FFA_W1W7_MBZ_CNT (7) +#define FFA_W1W7_MBZ_REG_START (&res->a1) + +/* w4-w7 MBZ */ +#define FFA_W4W7_MBZ_CNT (4) +#define FFA_W4W7_MBZ_REG_START (&res->a4) + +/* w3-w7 MBZ */ +#define FFA_W3W7_MBZ_CNT (5) +#define FFA_W3_MBZ_REG_START (&res->a3) + +/* secure partitions count */ +#define SANDBOX_PARTITIONS_CNT (4) + +/* service 1 UUID binary data (little-endian format) */ +#define SANDBOX_SERVICE1_UUID_DATA \ + 0xed, 0x32, 0xd5, 0x33, \ + 0x99, 0xe6, 0x42, 0x09, \ + 0x9c, 0xc0, 0x2d, 0x72, \ + 0xcd, 0xd9, 0x98, 0xa7 + +/* service 2 UUID binary data (little-endian format) */ +#define SANDBOX_SERVICE2_UUID_DATA \ + 0xab, 0xcd, 0xd5, 0x33, \ + 0x99, 0xe6, 0x42, 0x09, \ + 0x9c, 0xc0, 0x2d, 0x72, \ + 0xcd, 0xd9, 0x98, 0xa7 + +/** + * struct ffa_rxtxpair_info - structure hosting the RX/TX buffers flags + * @rxbuf_owned: RX buffer ownership flag (the owner is non secure world: the consumer) + * @rxbuf_mapped: RX buffer mapping flag + * @txbuf_owned TX buffer ownership flag + * @txbuf_mapped: TX buffer mapping flag + * @rxtx_buf_size: RX/TX buffers size as set by the FF-A core driver + * + * Data structure hosting the ownership/mapping flags of the RX/TX buffers + * When a buffer is owned/mapped its corresponding flag is set to 1 otherwise 0. + */ +struct ffa_rxtxpair_info { + u8 rxbuf_owned; + u8 rxbuf_mapped; + u8 txbuf_owned; + u8 txbuf_mapped; + u32 rxtx_buf_size; +}; + +/** + * struct sandbox_ffa_prvdata - the driver private data structure + * + * @dev: The arm_ffa device under u-boot driver model + * @fwk_version: FF-A framework version + * @id: u-boot endpoint ID + * @partitions: The partitions descriptors structure + * @pair: The RX/TX buffers pair + * @pair_info: The RX/TX buffers pair flags and size + * @conduit: The selected conduit + * + * The driver data structure hosting all the emulated secure world data. + */ +struct sandbox_ffa_prvdata { + struct udevice *dev; + u32 fwk_version; + u16 id; + struct ffa_partitions partitions; + struct ffa_rxtxpair pair; + struct ffa_rxtxpair_info pair_info; + enum ffa_conduit conduit; +}; + +void sandbox_arm_ffa_smccc_smc(unsigned long a0, unsigned long a1, + unsigned long a2, unsigned long a3, unsigned long a4, + unsigned long a5, unsigned long a6, unsigned long a7, + struct arm_smccc_res *res); + +#define SANDBOX_SMC_FFA_ABI(ffabi) static int sandbox_##ffabi(unsigned long a0, unsigned long a1, \ + unsigned long a2, unsigned long a3, unsigned long a4, \ + unsigned long a5, unsigned long a6, unsigned long a7, \ + struct arm_smccc_res *res) + +/* The core FF-A private data structure to inspect */ +extern struct ffa_prvdata ffa_priv_data; + +#endif diff --git a/include/arm_ffa.h b/include/arm_ffa.h index 98db01ee72..c400de4a70 100644 --- a/include/arm_ffa.h +++ b/include/arm_ffa.h @@ -22,6 +22,13 @@ #define ffa_info(fmt, ...) pr_info("[FFA] " fmt "\n", ##__VA_ARGS__) #define ffa_err(fmt, ...) pr_err("[FFA] " fmt "\n", ##__VA_ARGS__)
+/* panic only on real HW. On sandbox mode return an error code */ +#if CONFIG_IS_ENABLED(SANDBOX_FFA) +#define ffa_panic(fmt, ...) ffa_err("[FFA] " fmt "\n", ##__VA_ARGS__) +#else +#define ffa_panic(fmt, ...) panic("[FFA] " fmt "\n", ##__VA_ARGS__) +#endif + /* * The driver operations success error code */ @@ -184,7 +191,7 @@ const struct ffa_ops * __ffa_runtime ffa_device_get_ops(void); int ffa_get_device(void);
/** - * ffa_bus_discover - discover FF-A bus and probes the arm_ffa device + * ffa_bus_discover - discover FF-A bus and probes the arm_ffa and sandbox_arm_ffa devices */ int ffa_bus_discover(void); #endif diff --git a/include/sandbox_arm_ffa.h b/include/sandbox_arm_ffa.h new file mode 100644 index 0000000000..aa7a3454b9 --- /dev/null +++ b/include/sandbox_arm_ffa.h @@ -0,0 +1,31 @@ +/* SPDX-License-Identifier: GPL-2.0+ */ +/* + * (C) Copyright 2022 ARM Limited + * Abdellatif El Khlifi abdellatif.elkhlifi@arm.com + */ + +#ifndef __SANDBOX_ARM_FFA_H +#define __SANDBOX_ARM_FFA_H + +#include <arm_ffa.h> + +/** + * The device driver and the Uclass driver public functions + */ + +/** + * sandbox_ffa_get_invoke_func - performs a call to the Sandbox FF-A driver dispatcher + */ +int sandbox_ffa_get_invoke_func(u32 func_id, struct ffa_interface_data *func_data); + +/** + * sandbox_ffa_device_get_ops - driver operations getter + */ +const struct ffa_ops *sandbox_ffa_device_get_ops(void); + +/** + * sandbox_ffa_get_device - create, bind and probe the sandbox_arm_ffa device + */ +int sandbox_ffa_get_device(void); + +#endif diff --git a/include/sandbox_arm_ffa_helper.h b/include/sandbox_arm_ffa_helper.h new file mode 100644 index 0000000000..f0fcd04536 --- /dev/null +++ b/include/sandbox_arm_ffa_helper.h @@ -0,0 +1,26 @@ +/* SPDX-License-Identifier: GPL-2.0+ */ +/* + * (C) Copyright 2022 ARM Limited + * Abdellatif El Khlifi abdellatif.elkhlifi@arm.com + */ + +#ifndef __SANDBOX_ARM_FFA_HELPER_H +#define __SANDBOX_ARM_FFA_HELPER_H + +#include <arm_ffa_helper.h> +#include <sandbox_arm_ffa.h> +#include "../drivers/arm-ffa/sandbox_arm_ffa_prv.h" + +/* + * This header is public. Including this header provides all FF-A Sandbox data structures + * It also provides the helper function allowing to pass data and invoke Sandbox FF-A functions + * used for testing the FF-A core driver + */ + +/** + * sandbox_ffa_helper_query_core_state - Wrapper function for + * reading the FF-A core driver data + */ +int sandbox_ffa_helper_query_core_state(u32 queried_func_id, struct ffa_interface_data *func_data); + +#endif diff --git a/lib/arm-ffa/Makefile b/lib/arm-ffa/Makefile index cba625fde4..04159da8eb 100644 --- a/lib/arm-ffa/Makefile +++ b/lib/arm-ffa/Makefile @@ -6,3 +6,4 @@ # This file only gets included when CONFIG_ARM_FFA_TRANSPORT_HELPERS is set
obj-y += arm_ffa_helper.o +obj-$(CONFIG_SANDBOX_FFA) += sandbox_arm_ffa_helper.o diff --git a/lib/arm-ffa/arm_ffa_helper.c b/lib/arm-ffa/arm_ffa_helper.c index a291b000a7..3ee6ee304f 100644 --- a/lib/arm-ffa/arm_ffa_helper.c +++ b/lib/arm-ffa/arm_ffa_helper.c @@ -108,7 +108,7 @@ int __ffa_runtime ffa_helper_msg_send_direct_req(struct ffa_interface_data * ffa_helper_bus_discover - Wrapper function for FF-A bus discovery * * This boot time function should be called to discover the FF-A bus and - * probe the FF-A device. + * probe the arm_ffa and sandbox_arm_ffa devices. * To achieve that, this function is called automatically at initcalls * level (after u-boot relocation). * diff --git a/lib/arm-ffa/sandbox_arm_ffa_helper.c b/lib/arm-ffa/sandbox_arm_ffa_helper.c new file mode 100644 index 0000000000..7859f30fc7 --- /dev/null +++ b/lib/arm-ffa/sandbox_arm_ffa_helper.c @@ -0,0 +1,23 @@ +// SPDX-License-Identifier: GPL-2.0+ +/* + * (C) Copyright 2022 ARM Limited + * Abdellatif El Khlifi abdellatif.elkhlifi@arm.com + */ + +#include <common.h> +#include <sandbox_arm_ffa_helper.h> + +/** + * sandbox_ffa_helper_query_core_state - Wrapper function for querying FF-A implementation + * + * A helper function used for querying the status of FF-A ABIs given in the input argument + * and the FF-A core driver. + * + * Return: + * + * FFA_ERR_STAT_SUCCESS on success. Otherwise, failure + */ +int sandbox_ffa_helper_query_core_state(u32 queried_func_id, struct ffa_interface_data *func_data) +{ + return sandbox_ffa_get_invoke_func(queried_func_id, func_data); +} diff --git a/lib/efi_loader/efi_boottime.c b/lib/efi_loader/efi_boottime.c index cffa2c69d6..12fc28fd82 100644 --- a/lib/efi_loader/efi_boottime.c +++ b/lib/efi_loader/efi_boottime.c @@ -2118,7 +2118,7 @@ static efi_status_t EFIAPI efi_exit_boot_services(efi_handle_t image_handle, struct efi_event *evt, *next_event; efi_status_t ret = EFI_SUCCESS;
-#if defined(CONFIG_ARM_FFA_TRANSPORT) +#if defined(CONFIG_ARM_FFA_TRANSPORT) && !defined(CONFIG_SANDBOX_FFA) int ffa_ret; #endif
@@ -2182,7 +2182,7 @@ static efi_status_t EFIAPI efi_exit_boot_services(efi_handle_t image_handle, dm_remove_devices_flags(DM_REMOVE_ACTIVE_ALL); }
-#if defined(CONFIG_ARM_FFA_TRANSPORT) +#if defined(CONFIG_ARM_FFA_TRANSPORT) && !defined(CONFIG_SANDBOX_FFA) /* unmap FF-A RX/TX buffers */ ffa_ret = ffa_helper_unmap_rxtx_buffers(); if (ffa_ret)
From: Abdellatif El Khlifi abdellatif.elkhlifi@arm.com
Add functional test cases for the FF-A core driver
These tests rely on the FF-A Sandbox driver which helps in inspecting the FF-A core driver.
Signed-off-by: Abdellatif El Khlifi abdellatif.elkhlifi@arm.com --- MAINTAINERS | 2 + test/dm/Makefile | 1 + test/dm/ffa.c | 418 +++++++++++++++++++++++++++++++++++++++++++++++ test/dm/ffa.h | 22 +++ 4 files changed, 443 insertions(+) create mode 100644 test/dm/ffa.c create mode 100644 test/dm/ffa.h
diff --git a/MAINTAINERS b/MAINTAINERS index 7c439ed1fd..74b7ed9388 100644 --- a/MAINTAINERS +++ b/MAINTAINERS @@ -242,6 +242,8 @@ F: include/arm_ffa_helper.h F: include/sandbox_arm_ffa.h F: include/sandbox_arm_ffa_helper.h F: lib/arm-ffa/ +F: test/dm/ffa.c +F: test/dm/ffa.h
ARM FREESCALE IMX M: Stefano Babic sbabic@denx.de diff --git a/test/dm/Makefile b/test/dm/Makefile index d46552fbf3..48eab1b1ff 100644 --- a/test/dm/Makefile +++ b/test/dm/Makefile @@ -79,6 +79,7 @@ obj-$(CONFIG_POWER_DOMAIN) += power-domain.o obj-$(CONFIG_ACPI_PMC) += pmc.o obj-$(CONFIG_DM_PMIC) += pmic.o obj-$(CONFIG_DM_PWM) += pwm.o +obj-$(CONFIG_SANDBOX_FFA) += ffa.o obj-$(CONFIG_QFW) += qfw.o obj-$(CONFIG_RAM) += ram.o obj-y += regmap.o diff --git a/test/dm/ffa.c b/test/dm/ffa.c new file mode 100644 index 0000000000..85b71bd808 --- /dev/null +++ b/test/dm/ffa.c @@ -0,0 +1,418 @@ +// SPDX-License-Identifier: GPL-2.0+ +/* + * Functional tests for UCLASS_FFA class + * + * (C) Copyright 2022 ARM Limited + * Abdellatif El Khlifi abdellatif.elkhlifi@arm.com + */ + +#include <common.h> +#include <console.h> +#include <dm.h> +#include <dm/test.h> +#include "ffa.h" +#include <test/test.h> +#include <test/ut.h> +#include <sandbox_arm_ffa_helper.h> +#include <string.h> + +/* Functional tests for the UCLASS_FFA */ + +static int dm_test_ffa_log(struct unit_test_state *uts, char *msg) +{ + char cmd[LOG_CMD_SZ] = {0}; + + console_record_reset(); + + snprintf(cmd, LOG_CMD_SZ, "echo "%s"", msg); + run_command(cmd, 0); + + ut_assert_console_end(); + + return CMD_RET_SUCCESS; +} + +static int check_fwk_version(struct ffa_prvdata *prvdata, struct unit_test_state *uts) +{ + if (prvdata->fwk_version != SANDBOX_FWK_VERSION) { + char msg[LOG_MSG_SZ] = {0}; + + snprintf(msg, LOG_MSG_SZ, "[%s]: Error: prvdata->fwk_version = 0x%x", __func__, + prvdata->fwk_version); + dm_test_ffa_log(uts, msg); + return CMD_RET_FAILURE; + } + return CMD_RET_SUCCESS; +} + +static int check_endpoint_id(struct ffa_prvdata *prvdata, struct unit_test_state *uts) +{ + if (prvdata->id) { + char msg[LOG_MSG_SZ] = {0}; + + snprintf(msg, LOG_MSG_SZ, "[%s]: Error: prvdata->id = 0x%x", __func__, prvdata->id); + dm_test_ffa_log(uts, msg); + return CMD_RET_FAILURE; + } + return CMD_RET_SUCCESS; +} + +static int check_dev(struct ffa_prvdata *prvdata, struct unit_test_state *uts) +{ + if (!prvdata->dev) { + char msg[LOG_MSG_SZ] = {0}; + + snprintf(msg, LOG_MSG_SZ, "[%s]: Error: device = 0x%p", __func__, prvdata->dev); + dm_test_ffa_log(uts, msg); + return CMD_RET_FAILURE; + } + return CMD_RET_SUCCESS; +} + +static int check_rxtxbuf(struct ffa_prvdata *prvdata, struct unit_test_state *uts) +{ + if (!prvdata->pair.rxbuf && prvdata->pair.txbuf) { + char msg[LOG_MSG_SZ] = {0}; + + snprintf(msg, LOG_MSG_SZ, "[%s]: Error: rxbuf = 0x%llx txbuf = 0x%llx", __func__, + prvdata->pair.rxbuf, + prvdata->pair.txbuf); + dm_test_ffa_log(uts, msg); + return CMD_RET_FAILURE; + } + return CMD_RET_SUCCESS; +} + +static int check_features(struct ffa_prvdata *prvdata, struct unit_test_state *uts) +{ + u32 desc_idx; + char msg[LOG_MSG_SZ] = {0}; + + snprintf(msg, + LOG_MSG_SZ, + "[%s]: Error: FFA_RXTX_MAP features not found", + __func__); + + for (desc_idx = 0; desc_idx < FFA_FEATURE_DESC_CNT ; desc_idx++) + if (prvdata->features[desc_idx].func_id == FFA_RXTX_MAP) { + if (prvdata->features[desc_idx].field1 != RXTX_4K && + prvdata->features[desc_idx].field1 != RXTX_16K && + prvdata->features[desc_idx].field1 != RXTX_64K) { + snprintf(msg, + LOG_MSG_SZ, + "[%s]: Error: FFA_RXTX_MAP features = 0x%x", + __func__, + prvdata->features[desc_idx].field1); + break; + } + return CMD_RET_SUCCESS; + } + + dm_test_ffa_log(uts, msg); + return CMD_RET_FAILURE; +} + +static int check_rxbuf_mapped_flag(u32 queried_func_id, + u8 rxbuf_mapped, + struct unit_test_state *uts) +{ + char msg[LOG_MSG_SZ] = {0}; + + switch (queried_func_id) { + case FFA_RXTX_MAP: + { + if (rxbuf_mapped) + return CMD_RET_SUCCESS; + break; + } + case FFA_RXTX_UNMAP: + { + if (!rxbuf_mapped) + return CMD_RET_SUCCESS; + break; + } + default: + return CMD_RET_FAILURE; + } + + snprintf(msg, LOG_MSG_SZ, "[%s]: Error: %s mapping issue", __func__, + (queried_func_id == FFA_RXTX_MAP ? "FFA_RXTX_MAP" : "FFA_RXTX_UNMAP")); + dm_test_ffa_log(uts, msg); + + return CMD_RET_FAILURE; +} + +static int check_rxbuf_release_flag(u8 rxbuf_owned, struct unit_test_state *uts) +{ + if (rxbuf_owned) { + char msg[LOG_MSG_SZ] = {0}; + + snprintf(msg, LOG_MSG_SZ, "[%s]: Error: RX buffer not released", __func__); + dm_test_ffa_log(uts, msg); + return CMD_RET_FAILURE; + } + return CMD_RET_SUCCESS; +} + +static int test_ffa_msg_send_direct_req(u16 part_id, struct unit_test_state *uts) +{ + struct ffa_interface_data func_data = {0}; + struct ffa_send_direct_data msg = {0}; + u32 pattern = 0xaabbccdd; + u8 cnt; + + /* + * telling the driver which partition to use + */ + func_data.data0_size = sizeof(part_id); + func_data.data0 = &part_id; + + /* + * filling the message data + */ + msg.a3 = pattern; + msg.a4 = pattern; + msg.a5 = pattern; + msg.a6 = pattern; + msg.a7 = pattern; + func_data.data1_size = sizeof(msg); + func_data.data1 = &msg; + + ut_assertok(ffa_helper_msg_send_direct_req(&func_data)); + + for (cnt = 0; cnt < sizeof(struct ffa_send_direct_data) / sizeof(u32); cnt++) + ut_assertok(((u32 *)&msg)[cnt] != 0xffffffff); + + return CMD_RET_SUCCESS; +} + +static int test_partitions_and_comms(union ffa_partition_uuid *service_uuid, + struct sandbox_ffa_prvdata *sdx_prvdata, + struct unit_test_state *uts) +{ + struct ffa_interface_data func_data = {0}; + u32 count = 0; + struct ffa_partition_info *parts_info; + u32 info_idx, exp_info_idx; + int ret; + + /* + * get from the driver the count of the SPs matching the UUID + */ + func_data.data0_size = sizeof(*service_uuid); + func_data.data0 = service_uuid; + func_data.data1_size = sizeof(count); + func_data.data1 = &count; + + ut_assertok(ffa_helper_get_partitions_info(&func_data)); + + /* make sure partitions are detected */ + ut_assertok(!count); + + /* + * pre-allocate a buffer to be filled by the driver + * with ffa_partition_info structs + */ + + parts_info = calloc(count, sizeof(struct ffa_partition_info)); + ut_assertok(!parts_info); + + func_data.data1_size = count * sizeof(struct ffa_partition_info); + func_data.data1 = parts_info; + + /* + * ask the driver to fill the buffer with the SPs info + */ + ret = ffa_helper_get_partitions_info(&func_data); + if (ret != FFA_ERR_STAT_SUCCESS) { + free(parts_info); + ut_assertok(ret != FFA_ERR_STAT_SUCCESS); + } + + /* + * SPs found , verify the partitions information + */ + + ret = CMD_RET_FAILURE; + + for (info_idx = 0; info_idx < count ; info_idx++) { + for (exp_info_idx = 0; + exp_info_idx < sdx_prvdata->partitions.count; + exp_info_idx++) { + if (parts_info[info_idx].id == + sdx_prvdata->partitions.descs[exp_info_idx].info.id) { + ret = memcmp(&parts_info[info_idx], + &sdx_prvdata->partitions.descs[exp_info_idx] + .info, + sizeof(struct ffa_partition_info)); + if (ret) + free(parts_info); + ut_assertok(ret != 0); + /* send and receive data from the current partition */ + test_ffa_msg_send_direct_req(parts_info[info_idx].id, uts); + } + ret = CMD_RET_SUCCESS; + } + } + + free(parts_info); + + /* Verify expected partitions found in the emulated secure world*/ + ut_assertok(ret != CMD_RET_SUCCESS); + + return CMD_RET_SUCCESS; +} + +static int dm_test_ffa_ack(struct unit_test_state *uts) +{ + struct ffa_prvdata *prvdata = NULL; + struct sandbox_ffa_prvdata *sdx_prvdata = NULL; + struct ffa_interface_data func_data = {0}; + u8 rxbuf_flag = 0; + union ffa_partition_uuid svc1_uuid = { .bytes = {SANDBOX_SERVICE1_UUID_DATA}}; + union ffa_partition_uuid svc2_uuid = { .bytes = {SANDBOX_SERVICE2_UUID_DATA}}; + int ret; + + /* get a pointer to the FF-A core and sandbox drivers private data */ + func_data.data0 = &prvdata; + func_data.data0_size = sizeof(prvdata); + func_data.data1 = &sdx_prvdata; + func_data.data1_size = sizeof(sdx_prvdata); + + ut_assertok(sandbox_ffa_helper_query_core_state(FFA_VERSION, &func_data)); + + /* clear private data before the new test */ + memset(prvdata, 0, sizeof(struct ffa_prvdata)); + memset(sdx_prvdata, 0, sizeof(struct sandbox_ffa_prvdata)); + + /* test probing FF-A devices */ + ut_assertok(ffa_helper_bus_discover()); + ut_assertok(check_dev(prvdata, uts)); + + /* test FFA_VERSION */ + ut_assertok(check_fwk_version(prvdata, uts)); + + /* test FFA_ID_GET */ + ut_assertok(check_endpoint_id(prvdata, uts)); + + /* test FFA_FEATURES */ + ut_assertok(check_features(prvdata, uts)); + + /* test core RX/TX buffers */ + ut_assertok(check_rxtxbuf(prvdata, uts)); + + /* test FFA_RXTX_MAP */ + func_data.data0 = &rxbuf_flag; + func_data.data0_size = sizeof(rxbuf_flag); + + rxbuf_flag = 0; + ut_assertok(sandbox_ffa_helper_query_core_state(FFA_RXTX_MAP, &func_data)); + ut_assertok(check_rxbuf_mapped_flag(FFA_RXTX_MAP, rxbuf_flag, uts)); + + /* FFA_PARTITION_INFO_GET / FFA_MSG_SEND_DIRECT_REQ */ + ret = test_partitions_and_comms(&svc1_uuid, sdx_prvdata, uts); + ut_assertok(ret != CMD_RET_SUCCESS); + + /* test FFA_RX_RELEASE */ + rxbuf_flag = 1; + ut_assertok(sandbox_ffa_helper_query_core_state(FFA_RX_RELEASE, &func_data)); + ut_assertok(check_rxbuf_release_flag(rxbuf_flag, uts)); + + /* FFA_PARTITION_INFO_GET / FFA_MSG_SEND_DIRECT_REQ */ + ret = test_partitions_and_comms(&svc2_uuid, sdx_prvdata, uts); + ut_assertok(ret != CMD_RET_SUCCESS); + + /* test FFA_RX_RELEASE */ + rxbuf_flag = 1; + ut_assertok(sandbox_ffa_helper_query_core_state(FFA_RX_RELEASE, &func_data)); + ut_assertok(check_rxbuf_release_flag(rxbuf_flag, uts)); + + /* test FFA_RXTX_UNMAP */ + ut_assertok(ffa_helper_unmap_rxtx_buffers()); + + rxbuf_flag = 1; + ut_assertok(sandbox_ffa_helper_query_core_state(FFA_RXTX_UNMAP, &func_data)); + ut_assertok(check_rxbuf_mapped_flag(FFA_RXTX_UNMAP, rxbuf_flag, uts)); + + return CMD_RET_SUCCESS; +} + +DM_TEST(dm_test_ffa_ack, UT_TESTF_SCAN_FDT | UT_TESTF_CONSOLE_REC); + +static int dm_test_ffa_nack(struct unit_test_state *uts) +{ + struct ffa_prvdata *prvdata = NULL; + struct sandbox_ffa_prvdata *sdx_prvdata = NULL; + + struct ffa_interface_data func_data = {0}; + union ffa_partition_uuid valid_svc_uuid = { .bytes = {SANDBOX_SERVICE1_UUID_DATA}}; + union ffa_partition_uuid unvalid_svc_uuid = { .bytes = {SANDBOX_SERVICE3_UUID_DATA}}; + struct ffa_send_direct_data msg = {0}; + int ret; + u32 count = 0; + u16 part_id = 0; + + /* get a pointer to the FF-A core and sandbox drivers private data */ + func_data.data0 = &prvdata; + func_data.data0_size = sizeof(prvdata); + func_data.data1 = &sdx_prvdata; + func_data.data1_size = sizeof(sdx_prvdata); + ut_assertok(sandbox_ffa_helper_query_core_state(FFA_VERSION, &func_data)); + + /* clear private data before the new test */ + memset(prvdata, 0, sizeof(struct ffa_prvdata)); + memset(sdx_prvdata, 0, sizeof(struct sandbox_ffa_prvdata)); + + /* get partitions info before probing the core driver */ + func_data.data0_size = sizeof(union ffa_partition_uuid); + func_data.data0 = &unvalid_svc_uuid; + func_data.data1_size = sizeof(count); + func_data.data1 = &count; + + ret = ffa_helper_get_partitions_info(&func_data); + ut_assertok(ret != -ENODEV); + + /* probing FF-A devices */ + ut_assertok(ffa_helper_bus_discover()); + ut_assertok(check_dev(prvdata, uts)); + + /* query partition info using invalid arguments */ + func_data.data0_size = 0; + ret = ffa_helper_get_partitions_info(&func_data); + ut_assertok(ret != -EINVAL); + + /* query partition info using an invalid UUID */ + func_data.data0_size = sizeof(union ffa_partition_uuid); + func_data.data0 = &unvalid_svc_uuid; + func_data.data1_size = sizeof(count); + func_data.data1 = &count; + + ret = ffa_helper_get_partitions_info(&func_data); + ut_assertok(ret != -EPERM); + + /* query partition info using a valid UUID */ + func_data.data0 = &valid_svc_uuid; + count = 0; + ret = ffa_helper_get_partitions_info(&func_data); + /* make sure partitions are detected */ + ut_assertok(ret != FFA_ERR_STAT_SUCCESS); + ut_assertok(!count); + + /* send data to an invalid partition */ + func_data.data0_size = sizeof(part_id); + func_data.data0 = &part_id; + func_data.data1_size = sizeof(msg); + func_data.data1 = &msg; + + ret = ffa_helper_msg_send_direct_req(&func_data); + ut_assertok(ret != -EPERM); + + /* send data to a valid partition */ + part_id = ffa_priv_data.partitions.descs[0].info.id; + ret = ffa_helper_msg_send_direct_req(&func_data); + ut_assertok(ret != FFA_ERR_STAT_SUCCESS); + + return CMD_RET_SUCCESS; +} + +DM_TEST(dm_test_ffa_nack, UT_TESTF_SCAN_FDT | UT_TESTF_CONSOLE_REC); diff --git a/test/dm/ffa.h b/test/dm/ffa.h new file mode 100644 index 0000000000..11c7980fcf --- /dev/null +++ b/test/dm/ffa.h @@ -0,0 +1,22 @@ +/* SPDX-License-Identifier: GPL-2.0+ */ +/* + * (C) Copyright 2022 ARM Limited + * Abdellatif El Khlifi abdellatif.elkhlifi@arm.com + */ + +#ifndef __TEST_DM_FFA_H +#define __TEST_DM_FFA_H + +#define SANDBOX_FWK_VERSION (0x10000) + +#define LOG_MSG_SZ (100) +#define LOG_CMD_SZ (LOG_MSG_SZ * 2) + +/* service 3 UUID binary data (little-endian format) */ +#define SANDBOX_SERVICE3_UUID_DATA \ + 0xfd, 0x42, 0xd5, 0x33, \ + 0x19, 0xa6, 0x42, 0x09, \ + 0x9c, 0xc1, 0x2d, 0x72, \ + 0xcd, 0xd9, 0x98, 0x89 + +#endif /*__TEST_DM_FFA_H */
Add Sandbox test for the armffa command
Signed-off-by: Abdellatif El Khlifi abdellatif.elkhlifi@arm.com --- MAINTAINERS | 2 ++ test/cmd/Makefile | 1 + test/cmd/armffa.c | 33 +++++++++++++++++++++++++++++++++ test/cmd/armffa.h | 13 +++++++++++++ 4 files changed, 49 insertions(+) create mode 100644 test/cmd/armffa.c create mode 100644 test/cmd/armffa.h
diff --git a/MAINTAINERS b/MAINTAINERS index 74b7ed9388..eb9c3886e6 100644 --- a/MAINTAINERS +++ b/MAINTAINERS @@ -242,6 +242,8 @@ F: include/arm_ffa_helper.h F: include/sandbox_arm_ffa.h F: include/sandbox_arm_ffa_helper.h F: lib/arm-ffa/ +F: test/cmd/armffa.c +F: test/cmd/armffa.h F: test/dm/ffa.c F: test/dm/ffa.h
diff --git a/test/cmd/Makefile b/test/cmd/Makefile index a59adb1e6d..d9dc0809d6 100644 --- a/test/cmd/Makefile +++ b/test/cmd/Makefile @@ -11,3 +11,4 @@ obj-$(CONFIG_CMD_MEM_SEARCH) += mem_search.o obj-$(CONFIG_CMD_PINMUX) += pinmux.o obj-$(CONFIG_CMD_PWM) += pwm.o obj-$(CONFIG_CMD_SETEXPR) += setexpr.o +obj-$(CONFIG_SANDBOX_FFA) += armffa.o diff --git a/test/cmd/armffa.c b/test/cmd/armffa.c new file mode 100644 index 0000000000..fc41571cf0 --- /dev/null +++ b/test/cmd/armffa.c @@ -0,0 +1,33 @@ +// SPDX-License-Identifier: GPL-2.0+ +/* + * Test for armffa command + * + * (C) Copyright 2022 ARM Limited + * Abdellatif El Khlifi abdellatif.elkhlifi@arm.com + */ + +#include "armffa.h" +#include <arm_ffa_helper.h> +#include <dm.h> +#include <dm/test.h> +#include <test/test.h> +#include <test/ut.h> + +/* Basic test of 'armffa' command */ +static int dm_test_armffa_cmd(struct unit_test_state *uts) +{ + ut_assertok(ffa_helper_bus_discover()); + + /* armffa getpart <UUID> */ + ut_assertok(run_command("armffa getpart " SE_PROXY_PARTITION_UUID, 0)); + + /* armffa ping <ID> */ + ut_assertok(run_command("armffa ping " SE_PROXY_PARTITION_ID, 0)); + + /* armffa devlist */ + ut_assertok(run_command("armffa devlist", 0)); + + return CMD_RET_SUCCESS; +} + +DM_TEST(dm_test_armffa_cmd, UT_TESTF_SCAN_FDT | UT_TESTF_CONSOLE_REC); diff --git a/test/cmd/armffa.h b/test/cmd/armffa.h new file mode 100644 index 0000000000..630dc75e25 --- /dev/null +++ b/test/cmd/armffa.h @@ -0,0 +1,13 @@ +/* SPDX-License-Identifier: GPL-2.0+ */ +/* + * (C) Copyright 2022 ARM Limited + * Abdellatif El Khlifi abdellatif.elkhlifi@arm.com + */ + +#ifndef __TEST_CMD_FFA_H +#define __TEST_CMD_FFA_H + +#define SE_PROXY_PARTITION_ID "0x1245" +#define SE_PROXY_PARTITION_UUID "33d532ed-e699-0942-c09c-a798d9cd722d" + +#endif /*__TEST_CMD_FFA_H */
Add MM communication support using FF-A transport
FF-A MM communication allows exchanging data with StandAlonneMM or smm-gateway secure partitions which run in OP-TEE.
An MM shared buffer and a door bell event are used to exchange this data.
The data is used by EFI services such as GetVariable()/SetVariable() and copied from the communication buffer to the MM shared buffer.
The secure partition is notified about availability of data in the MM shared buffer by an FF-A message (door bell).
On such event, MM SP can read the data and updates the MM shared buffer with the response data.
The response data is copied back to the communication buffer and consumed by the EFI subsystem.
Signed-off-by: Abdellatif El Khlifi abdellatif.elkhlifi@arm.com Signed-off-by: Gowtham Suresh Kumar gowtham.sureshkumar@arm.com --- arch/arm/cpu/armv8/cache.S | 16 ++ arch/arm/cpu/armv8/cache_v8.c | 3 +- include/mm_communication.h | 4 +- lib/efi_loader/Kconfig | 14 +- lib/efi_loader/efi_variable_tee.c | 281 +++++++++++++++++++++++++++++- 5 files changed, 308 insertions(+), 10 deletions(-)
diff --git a/arch/arm/cpu/armv8/cache.S b/arch/arm/cpu/armv8/cache.S index d1cee23437..bdbe89e0c5 100644 --- a/arch/arm/cpu/armv8/cache.S +++ b/arch/arm/cpu/armv8/cache.S @@ -21,7 +21,11 @@ * x1: 0 clean & invalidate, 1 invalidate only * x2~x9: clobbered */ +#ifdef CONFIG_ARM_FFA_TRANSPORT +.pushsection .text.efi_runtime, "ax" +#else .pushsection .text.__asm_dcache_level, "ax" +#endif ENTRY(__asm_dcache_level) lsl x12, x0, #1 msr csselr_el1, x12 /* select cache level */ @@ -65,7 +69,11 @@ ENDPROC(__asm_dcache_level) * * flush or invalidate all data cache by SET/WAY. */ +#ifdef CONFIG_ARM_FFA_TRANSPORT +.pushsection .text.efi_runtime, "ax" +#else .pushsection .text.__asm_dcache_all, "ax" +#endif ENTRY(__asm_dcache_all) mov x1, x0 dsb sy @@ -109,7 +117,11 @@ ENTRY(__asm_flush_dcache_all) ENDPROC(__asm_flush_dcache_all) .popsection
+#ifdef CONFIG_ARM_FFA_TRANSPORT +.pushsection .text.efi_runtime, "ax" +#else .pushsection .text.__asm_invalidate_dcache_all, "ax" +#endif ENTRY(__asm_invalidate_dcache_all) mov x0, #0x1 b __asm_dcache_all @@ -182,7 +194,11 @@ ENTRY(__asm_invalidate_icache_all) ENDPROC(__asm_invalidate_icache_all) .popsection
+#ifdef CONFIG_ARM_FFA_TRANSPORT +.pushsection .text.efi_runtime, "ax" +#else .pushsection .text.__asm_invalidate_l3_dcache, "ax" +#endif WEAK(__asm_invalidate_l3_dcache) mov x0, #0 /* return status as success */ ret diff --git a/arch/arm/cpu/armv8/cache_v8.c b/arch/arm/cpu/armv8/cache_v8.c index 3de18c7675..187a4497a7 100644 --- a/arch/arm/cpu/armv8/cache_v8.c +++ b/arch/arm/cpu/armv8/cache_v8.c @@ -9,6 +9,7 @@
#include <common.h> #include <cpu_func.h> +#include <efi_loader.h> #include <hang.h> #include <log.h> #include <asm/cache.h> @@ -425,7 +426,7 @@ __weak void mmu_setup(void) /* * Performs a invalidation of the entire data cache at all levels */ -void invalidate_dcache_all(void) +void __efi_runtime invalidate_dcache_all(void) { __asm_invalidate_dcache_all(); __asm_invalidate_l3_dcache(); diff --git a/include/mm_communication.h b/include/mm_communication.h index e65fbde60d..bb99190956 100644 --- a/include/mm_communication.h +++ b/include/mm_communication.h @@ -123,7 +123,7 @@ struct __packed efi_mm_communicate_header { * * Defined in EDK2 as SMM_VARIABLE_COMMUNICATE_HEADER. */ -struct smm_variable_communicate_header { +struct __packed smm_variable_communicate_header { efi_uintn_t function; efi_status_t ret_status; u8 data[]; @@ -145,7 +145,7 @@ struct smm_variable_communicate_header { * Defined in EDK2 as SMM_VARIABLE_COMMUNICATE_ACCESS_VARIABLE. * */ -struct smm_variable_access { +struct __packed smm_variable_access { efi_guid_t guid; efi_uintn_t data_size; efi_uintn_t name_size; diff --git a/lib/efi_loader/Kconfig b/lib/efi_loader/Kconfig index 28657f50c9..0d69133595 100644 --- a/lib/efi_loader/Kconfig +++ b/lib/efi_loader/Kconfig @@ -55,13 +55,23 @@ config EFI_VARIABLE_FILE_STORE stored as file /ubootefi.var on the EFI system partition.
config EFI_MM_COMM_TEE - bool "UEFI variables storage service via OP-TEE" - depends on OPTEE + bool "UEFI variables storage service via the trusted world" + depends on OPTEE || ARM_FFA_TRANSPORT help + The MM SP (also called partition) can be StandAlonneMM or smm-gateway. + When using the u-boot OP-TEE driver, StandAlonneMM is supported. + When using the u-boot FF-A driver, StandAlonneMM and smm-gateway are supported. + If OP-TEE is present and running StandAloneMM, dispatch all UEFI variable related operations to that. The application will verify, authenticate and store the variables on an RPMB.
+ When ARM_FFA_TRANSPORT is used, dispatch all UEFI variable related + operations to the MM SP running under Optee in the trusted world. + A door bell mechanism is used to notify the SP when there is data in the shared + MM buffer. The data is copied by u-boot to the shared buffer before issuing + the door bell event. + endchoice
config EFI_VARIABLES_PRESEED diff --git a/lib/efi_loader/efi_variable_tee.c b/lib/efi_loader/efi_variable_tee.c index dfef18435d..915ccdafc2 100644 --- a/lib/efi_loader/efi_variable_tee.c +++ b/lib/efi_loader/efi_variable_tee.c @@ -15,6 +15,40 @@ #include <malloc.h> #include <mm_communication.h>
+#if (IS_ENABLED(CONFIG_ARM_FFA_TRANSPORT)) + +#include <arm_ffa_helper.h> +#include <cpu_func.h> +#include <mapmem.h> + +#ifndef FFA_SHARED_MM_BUFFER_SIZE +#warning "FFA_SHARED_MM_BUFFER_SIZE must be defined in include/configs/<board>.h" +#define FFA_SHARED_MM_BUFFER_SIZE 0 +#endif + +#ifndef FFA_SHARED_MM_BUFFER_ADDR +#warning "FFA_SHARED_MM_BUFFER_ADDR must be defined in include/configs/<board>.h" +#define FFA_SHARED_MM_BUFFER_ADDR 0 +#endif + +/* MM return codes */ +#define MM_SUCCESS (0) + +#define ARM_SVC_ID_SP_EVENT_COMPLETE_AARCH64 (0xC4000061) +#define ARM_SVC_ID_SP_EVENT_COMPLETE ARM_SVC_ID_SP_EVENT_COMPLETE_AARCH64 + +#ifndef MM_SP_UUID_DATA +#warning "MM_SP_UUID_DATA must be defined in include/configs/<board>.h" +#define MM_SP_UUID_DATA 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0 +#endif + +/* MM_SP_UUID_DATA defined by the platform */ +union ffa_partition_uuid mm_sp_svc_uuid = {.bytes = {MM_SP_UUID_DATA}}; + +static __efi_runtime_data u16 mm_sp_id; + +#endif + extern struct efi_var_file __efi_runtime_data *efi_var_buf; static efi_uintn_t max_buffer_size; /* comm + var + func + data */ static efi_uintn_t max_payload_size; /* func + data */ @@ -24,6 +58,7 @@ struct mm_connection { u32 session; };
+#if (IS_ENABLED(CONFIG_OPTEE)) /** * get_connection() - Retrieve OP-TEE session for a specific UUID. * @@ -143,16 +178,238 @@ static efi_status_t optee_mm_communicate(void *comm_buf, ulong dsize)
return ret; } +#endif + +#if (IS_ENABLED(CONFIG_ARM_FFA_TRANSPORT)) + +/** + * ffa_notify_mm_sp() - Announce there is data in the shared buffer + * + * Notifies the MM partition in the trusted world that + * data is available in the shared buffer. + * This is a blocking call during which trusted world has exclusive access + * to the MM shared buffer. + * + * Return: + * + * 0 on success + */ +static int __efi_runtime ffa_notify_mm_sp(void) +{ + struct ffa_interface_data func_data = {0}; + struct ffa_send_direct_data msg = {0}; + int ret; + u32 sp_event_complete; + int sp_event_ret; + + func_data.data0_size = sizeof(mm_sp_id); + func_data.data0 = &mm_sp_id; + + msg.a3 = FFA_SHARED_MM_BUFFER_ADDR; + msg.a4 = FFA_SHARED_MM_BUFFER_SIZE; + func_data.data1_size = sizeof(msg); + func_data.data1 = &msg; + + ret = ffa_helper_msg_send_direct_req(&func_data); + if (ret != FFA_ERR_STAT_SUCCESS) + return ret; + + sp_event_complete = msg.a3; + sp_event_ret = (int)msg.a4; + + if (sp_event_complete == ARM_SVC_ID_SP_EVENT_COMPLETE && sp_event_ret == MM_SUCCESS) + return 0; + + /* + * Failure to notify the MM SP + */ + + return -EACCES; +} + +/** + * ffa_discover_mm_sp_id() - Query the MM partition ID + * + * Use the FF-A driver to get the MM partition ID. + * If multiple partitions are found, use the first one. + * This is a boot time function. + * + * Return: + * + * 0 on success + */ +static int ffa_discover_mm_sp_id(void) +{ + struct ffa_interface_data func_data = {0}; + u32 count = 0; + int ret; + struct ffa_partition_info *parts_info; + + /* + * get from the driver the count of the SPs matching the UUID + */ + func_data.data0_size = sizeof(mm_sp_svc_uuid); + func_data.data0 = &mm_sp_svc_uuid; + func_data.data1_size = sizeof(count); + func_data.data1 = &count; + + ret = ffa_helper_get_partitions_info(&func_data); + if (ret != FFA_ERR_STAT_SUCCESS) { + log_err("EFI: Failure in querying partitions count (error code: %d)\n", ret); + return ret; + } + + if (!count) { + log_info("EFI: No MM partition found\n"); + return ret; + } + + /* + * pre-allocate a buffer to be filled by the driver + * with ffa_partition_info structs + */ + + parts_info = calloc(count, sizeof(struct ffa_partition_info)); + if (!parts_info) + return -EINVAL; + + log_info("EFI: Pre-allocating %d partition(s) info structures\n", count); + + func_data.data1_size = count * + sizeof(struct ffa_partition_info); + func_data.data1 = parts_info; + + /* + * ask the driver to fill the + * buffer with the SPs info + */ + ret = ffa_helper_get_partitions_info(&func_data); + if (ret != FFA_ERR_STAT_SUCCESS) { + log_err("EFI: Failure in querying partition(s) info (error code: %d)\n", ret); + free(parts_info); + return ret; + } + + /* + * MM SPs found , use the first one + */ + + mm_sp_id = parts_info[0].id; + + log_info("EFI: MM partition ID 0x%x\n", mm_sp_id); + + free(parts_info); + + return 0; +}
/** - * mm_communicate() - Adjust the cmonnucation buffer to StandAlonneMM and send + * ffa_mm_communicate() - Exchange EFI services data with the MM partition using FF-A + * @comm_buf: locally allocated communication buffer used for rx/tx + * @dsize: communication buffer size + * + * Issues a door bell event to notify the MM partition (SP) running in OP-TEE + * that there is data to read from the shared buffer. + * Communication with the MM SP is performed using FF-A transport. + * On the event, MM SP can read the data from the buffer and + * update the MM shared buffer with response data. + * The response data is copied back to the communication buffer. + * + * Return: + * + * EFI status code + */ +static efi_status_t __efi_runtime ffa_mm_communicate(void *comm_buf, ulong comm_buf_size) +{ + ulong tx_data_size; + int ffa_ret; + struct efi_mm_communicate_header *mm_hdr; + void *virt_shared_buf; + + if (!comm_buf) + return EFI_INVALID_PARAMETER; + + /* Discover MM partition ID at boot time */ + if (!mm_sp_id && ffa_discover_mm_sp_id() != FFA_ERR_STAT_SUCCESS) { + log_err("EFI: Failure to discover MM partition ID at boot time\n"); + return EFI_UNSUPPORTED; + } + + mm_hdr = (struct efi_mm_communicate_header *)comm_buf; + tx_data_size = mm_hdr->message_len + sizeof(efi_guid_t) + sizeof(size_t); + + if (comm_buf_size != tx_data_size || tx_data_size > FFA_SHARED_MM_BUFFER_SIZE) + return EFI_INVALID_PARAMETER; + + /* Copy the data to the shared buffer */ + + virt_shared_buf = (void *)map_sysmem((phys_addr_t)FFA_SHARED_MM_BUFFER_ADDR, 0); + efi_memcpy_runtime(virt_shared_buf, comm_buf, tx_data_size); + + /* + * The secure world has cache disabled for device region which we use for shared buffer. + * So, the secure world reads the data from DRAM. Let's flush the cache so the DRAM is + * updated with the latest data. + */ + #ifdef CONFIG_ARM64 + invalidate_dcache_all(); + #endif + + /* Announce there is data in the shared buffer */ + + ffa_ret = ffa_notify_mm_sp(); + if (ffa_ret) + unmap_sysmem(virt_shared_buf); + + switch (ffa_ret) { + case 0: + { + ulong rx_data_size; + /* Copy the MM SP response from the shared buffer to the communication buffer */ + rx_data_size = ((struct efi_mm_communicate_header *)virt_shared_buf)->message_len + + sizeof(efi_guid_t) + + sizeof(size_t); + + if (rx_data_size > comm_buf_size) { + efi_memcpy_runtime(comm_buf, virt_shared_buf, comm_buf_size); + unmap_sysmem(virt_shared_buf); + return EFI_BUFFER_TOO_SMALL; + } + + efi_memcpy_runtime(comm_buf, virt_shared_buf, rx_data_size); + unmap_sysmem(virt_shared_buf); + + return EFI_SUCCESS; + } + case -EINVAL: + return EFI_DEVICE_ERROR; + case -EPERM: + return EFI_INVALID_PARAMETER; + case -EACCES: + return EFI_ACCESS_DENIED; + case -EBUSY: + return EFI_OUT_OF_RESOURCES; + default: + return EFI_ACCESS_DENIED; + } +} +#endif + +/** + * mm_communicate() - Adjust the communication buffer to the MM SP and send * it to OP-TEE * - * @comm_buf: locally allocted communcation buffer + * @comm_buf: locally allocated communication buffer * @dsize: buffer size + * + * The MM SP (also called partition) can be StandAlonneMM or smm-gateway. + * The comm_buf format is the same for both partitions. + * When using the u-boot OP-TEE driver, StandAlonneMM is supported. + * When using the u-boot FF-A driver, StandAlonneMM and smm-gateway are supported. + * * Return: status code */ -static efi_status_t mm_communicate(u8 *comm_buf, efi_uintn_t dsize) +static efi_status_t __efi_runtime mm_communicate(u8 *comm_buf, efi_uintn_t dsize) { efi_status_t ret; struct efi_mm_communicate_header *mm_hdr; @@ -162,9 +419,16 @@ static efi_status_t mm_communicate(u8 *comm_buf, efi_uintn_t dsize) mm_hdr = (struct efi_mm_communicate_header *)comm_buf; var_hdr = (struct smm_variable_communicate_header *)mm_hdr->data;
+ #if (IS_ENABLED(CONFIG_OPTEE)) ret = optee_mm_communicate(comm_buf, dsize); + #elif (IS_ENABLED(CONFIG_ARM_FFA_TRANSPORT)) + ret = ffa_mm_communicate(comm_buf, dsize); + #endif if (ret != EFI_SUCCESS) { - log_err("%s failed!\n", __func__); + /* No need for showing a log here. mm_communicate failure happens + * when getVariable() is called with data size set to 0. + * This is not expected so no log shown. + */ return ret; }
@@ -258,6 +522,13 @@ efi_status_t EFIAPI get_max_payload(efi_uintn_t *size) goto out; } *size = var_payload->size; + + #if (IS_ENABLED(CONFIG_ARM_FFA_TRANSPORT)) + if (*size > FFA_SHARED_MM_BUFFER_SIZE) + *size = FFA_SHARED_MM_BUFFER_SIZE - MM_COMMUNICATE_HEADER_SIZE - + MM_VARIABLE_COMMUNICATE_SIZE; + #endif + /* * There seems to be a bug in EDK2 miscalculating the boundaries and * size checks, so deduct 2 more bytes to fulfill this requirement. Fix @@ -697,7 +968,7 @@ void efi_variables_boot_exit_notify(void) ret = EFI_NOT_FOUND;
if (ret != EFI_SUCCESS) - log_err("Unable to notify StMM for ExitBootServices\n"); + log_err("Unable to notify the MM partition for ExitBootServices\n"); free(comm_buf);
This patchset adds support for Arm FF-A (Arm Firmware Framework for Armv8-A v1.0).
FF-A support is generic by design and can be used by any Arm platform.
The features added are as follows:
1/ FF-A bus driver 2/ armffa command 3/ FF-A Sandbox driver 4/ FF-A Sandbox test cases 5/ FF-A MM communication
The suggested design considers FF-A as a discoverable bus. The Secure World is considered as one entity to communicate with using the FF-A bus. FF-A communication is handled by one device and one instance (the bus). This FF-A driver takes care of all the interactions between Normal world and Secure World.
The Secure World firmware runs under TrustZone HW (such as Optee). The same approach was followed in the FF-A driver in Linux kernel (https://git.kernel.org/pub/scm/linux/kernel/git/torvalds/linux.git/tree/driv...))
Cc: Tom Rini trini@konsulko.com Cc: Rob Herring robh@kernel.org Cc: Ilias Apalodimas ilias.apalodimas@linaro.org Cc: Achin Gupta achin.gupta@arm.com Cc: Simon Glass sjg@chromium.org Cc: Vishnu Banavath vishnu.banavath@arm.com
I don't see a changelog compared with v1. Are any of the comments there addressed? Thanks.
-- Tom
Thanks Tom. I'll add a changelog for future versions.
The current Changelog:
Changelog: =============== v2 (15 Apr 2022) * Make FF-A bus discoverable (remove device tree support, bind and probe FF-A device using device_bind and device_probe)
v1 (29 Mar 2022) * FF-A bus driver with device tree support * armffa command * FF-A Sandbox driver * FF-A Sandbox test cases * FF-A MM communication
-- Tom
Changelog:
v2 (15 Apr 2022)
- Make FF-A bus discoverable (remove device tree support, bind and probe FF-A device using device_bind and device_probe)
v1 (29 Mar 2022)
- FF-A bus driver with device tree support
- armffa command
- FF-A Sandbox driver
- FF-A Sandbox test cases
- FF-A MM communication
Hello guys, gentle ping, any feedback about the implementation of FF-A as a discoverable bus ?
Hi Abdellatif,
-- Tom
Changelog:
v2 (15 Apr 2022)
v1 (29 Mar 2022)
- armffa command
Apologies for the late reply, I was on vacation. I'll try having a closer look on patch #1-5 in the upcoming days. Can you take a look at my comments on patch #6 and reply?
Thanks /Ilias
This new version of the patchset provides improvements to the FF-A driver design.
The FF-A driver is a discoverable bus and brings these new features:
* support for the 64-bit x0-x17 registers in SMC arguments passing * align with the FF-A kernel driver interfaces * make the driver EFI independent
This patchset will be followed by further updates (work in progress):
* discover MM partitions at runtime * align with the FF-A kernel driver error handling * align Sandbox driver and tests with the new interfaces
v3:
* port x0-x17 registers support from linux kernel as defined by SMCCCv1.2 * align the interfaces of the u-boot FF-A driver with those in the linux FF-A driver * remove the FF-A helper layer * make the u-boot FF-A driver independent from EFI * provide an optional config that enables copying the driver data to EFI runtime section at ExitBootServices service * use 64-bit version of FFA_RXTX_MAP, FFA_MSG_SEND_DIRECT_{REQ, RESP} * update armffa command with the new driver interfaces
v2 [2]:
* make FF-A bus discoverable using device_{bind, probe} APIs * remove device tree support
v1 [1]:
* introduce FF-A bus driver with device tree support * introduce armffa command * introduce FF-A Sandbox driver * add FF-A Sandbox test cases * introduce FF-A MM communication
Cheers, Abdellatif
[1]: https://lore.kernel.org/all/20220329151659.16894-1-abdellatif.elkhlifi@arm.c... [2]: https://lore.kernel.org/all/20220415122803.16666-1-abdellatif.elkhlifi@arm.c...
Cc: Tom Rini trini@konsulko.com Cc: Ilias Apalodimas ilias.apalodimas@linaro.org Cc: Jens Wiklander jens.wiklander@linaro.org Cc: Achin Gupta achin.gupta@arm.com Cc: Vishnu Banavath vishnu.banavath@arm.com Cc: Xueliang Zhong Xueliang.Zhong@arm.com
Abdellatif El Khlifi (4): arm64: smccc: add Xn registers support used by SMC calls arm64: smccc: clear the Xn registers after SMC calls arm_ffa: introduce Arm FF-A low-level driver arm_ffa: introduce armffa command
MAINTAINERS | 7 + arch/arm/cpu/armv8/smccc-call.S | 73 ++ arch/arm/lib/asm-offsets.c | 13 + cmd/Kconfig | 10 + cmd/Makefile | 2 + cmd/armffa.c | 246 ++++ common/board_r.c | 7 + drivers/Kconfig | 2 + drivers/Makefile | 1 + drivers/arm-ffa/Kconfig | 34 + drivers/arm-ffa/Makefile | 7 + drivers/arm-ffa/arm-ffa-uclass.c | 16 + drivers/arm-ffa/arm_ffa_prv.h | 219 ++++ drivers/arm-ffa/core.c | 1338 ++++++++++++++++++++ drivers/arm-ffa/efi_ffa_runtime_data_mgr.c | 94 ++ include/arm_ffa.h | 132 ++ include/dm/uclass-id.h | 1 + include/linux/arm-smccc.h | 43 + include/uuid.h | 8 + lib/efi_loader/efi_boottime.c | 17 + lib/uuid.c | 65 + 21 files changed, 2335 insertions(+) create mode 100644 cmd/armffa.c create mode 100644 drivers/arm-ffa/Kconfig create mode 100644 drivers/arm-ffa/Makefile create mode 100644 drivers/arm-ffa/arm-ffa-uclass.c create mode 100644 drivers/arm-ffa/arm_ffa_prv.h create mode 100644 drivers/arm-ffa/core.c create mode 100644 drivers/arm-ffa/efi_ffa_runtime_data_mgr.c create mode 100644 include/arm_ffa.h
use x0-x17 registers in the SMC32/SMC64 calls according to SMCCCv1.2
Signed-off-by: Sudeep Holla sudeep.holla@arm.com Signed-off-by: Abdellatif El Khlifi abdellatif.elkhlifi@arm.com Cc: Tom Rini trini@konsulko.com Cc: Ilias Apalodimas ilias.apalodimas@linaro.org Cc: Jens Wiklander jens.wiklander@linaro.org --- arch/arm/cpu/armv8/smccc-call.S | 53 +++++++++++++++++++++++++++++++++ arch/arm/lib/asm-offsets.c | 13 ++++++++ include/linux/arm-smccc.h | 43 ++++++++++++++++++++++++++ 3 files changed, 109 insertions(+)
diff --git a/arch/arm/cpu/armv8/smccc-call.S b/arch/arm/cpu/armv8/smccc-call.S index dc92b28777..ec6f299bc9 100644 --- a/arch/arm/cpu/armv8/smccc-call.S +++ b/arch/arm/cpu/armv8/smccc-call.S @@ -1,6 +1,8 @@ /* SPDX-License-Identifier: GPL-2.0 */ /* * Copyright (c) 2015, Linaro Limited + * (C) Copyright 2022 ARM Limited + * Abdellatif El Khlifi abdellatif.elkhlifi@arm.com */ #include <linux/linkage.h> #include <linux/arm-smccc.h> @@ -45,3 +47,54 @@ ENDPROC(__arm_smccc_smc) ENTRY(__arm_smccc_hvc) SMCCC hvc ENDPROC(__arm_smccc_hvc) + +#ifdef CONFIG_ARM64 + + .macro SMCCC_1_2 instr + /* Save `res` and free a GPR that won't be clobbered */ + stp x1, x19, [sp, #-16]! + + /* Ensure `args` won't be clobbered while loading regs in next step */ + mov x19, x0 + + /* Load the registers x0 - x17 from the struct arm_smccc_1_2_regs */ + ldp x0, x1, [x19, #ARM_SMCCC_1_2_REGS_X0_OFFS] + ldp x2, x3, [x19, #ARM_SMCCC_1_2_REGS_X2_OFFS] + ldp x4, x5, [x19, #ARM_SMCCC_1_2_REGS_X4_OFFS] + ldp x6, x7, [x19, #ARM_SMCCC_1_2_REGS_X6_OFFS] + ldp x8, x9, [x19, #ARM_SMCCC_1_2_REGS_X8_OFFS] + ldp x10, x11, [x19, #ARM_SMCCC_1_2_REGS_X10_OFFS] + ldp x12, x13, [x19, #ARM_SMCCC_1_2_REGS_X12_OFFS] + ldp x14, x15, [x19, #ARM_SMCCC_1_2_REGS_X14_OFFS] + ldp x16, x17, [x19, #ARM_SMCCC_1_2_REGS_X16_OFFS] + + \instr #0 + + /* Load the `res` from the stack */ + ldr x19, [sp] + + /* Store the registers x0 - x17 into the result structure */ + stp x0, x1, [x19, #ARM_SMCCC_1_2_REGS_X0_OFFS] + stp x2, x3, [x19, #ARM_SMCCC_1_2_REGS_X2_OFFS] + stp x4, x5, [x19, #ARM_SMCCC_1_2_REGS_X4_OFFS] + stp x6, x7, [x19, #ARM_SMCCC_1_2_REGS_X6_OFFS] + stp x8, x9, [x19, #ARM_SMCCC_1_2_REGS_X8_OFFS] + stp x10, x11, [x19, #ARM_SMCCC_1_2_REGS_X10_OFFS] + stp x12, x13, [x19, #ARM_SMCCC_1_2_REGS_X12_OFFS] + stp x14, x15, [x19, #ARM_SMCCC_1_2_REGS_X14_OFFS] + stp x16, x17, [x19, #ARM_SMCCC_1_2_REGS_X16_OFFS] + + /* Restore original x19 */ + ldp xzr, x19, [sp], #16 + ret + .endm + +/* + * void arm_smccc_1_2_smc(const struct arm_smccc_1_2_regs *args, + * struct arm_smccc_1_2_regs *res); + */ +ENTRY(arm_smccc_1_2_smc) + SMCCC_1_2 smc +ENDPROC(arm_smccc_1_2_smc) + +#endif diff --git a/arch/arm/lib/asm-offsets.c b/arch/arm/lib/asm-offsets.c index 22fd541f9a..b6bd1b32b0 100644 --- a/arch/arm/lib/asm-offsets.c +++ b/arch/arm/lib/asm-offsets.c @@ -9,6 +9,8 @@ * generate asm statements containing #defines, * compile this file to assembler, and then extract the * #defines from the assembly-language output. + * + * (C) Copyright 2022 ARM Limited */
#include <common.h> @@ -117,6 +119,17 @@ int main(void) DEFINE(ARM_SMCCC_RES_X2_OFFS, offsetof(struct arm_smccc_res, a2)); DEFINE(ARM_SMCCC_QUIRK_ID_OFFS, offsetof(struct arm_smccc_quirk, id)); DEFINE(ARM_SMCCC_QUIRK_STATE_OFFS, offsetof(struct arm_smccc_quirk, state)); + #ifdef CONFIG_ARM64 + DEFINE(ARM_SMCCC_1_2_REGS_X0_OFFS, offsetof(struct arm_smccc_1_2_regs, a0)); + DEFINE(ARM_SMCCC_1_2_REGS_X2_OFFS, offsetof(struct arm_smccc_1_2_regs, a2)); + DEFINE(ARM_SMCCC_1_2_REGS_X4_OFFS, offsetof(struct arm_smccc_1_2_regs, a4)); + DEFINE(ARM_SMCCC_1_2_REGS_X6_OFFS, offsetof(struct arm_smccc_1_2_regs, a6)); + DEFINE(ARM_SMCCC_1_2_REGS_X8_OFFS, offsetof(struct arm_smccc_1_2_regs, a8)); + DEFINE(ARM_SMCCC_1_2_REGS_X10_OFFS, offsetof(struct arm_smccc_1_2_regs, a10)); + DEFINE(ARM_SMCCC_1_2_REGS_X12_OFFS, offsetof(struct arm_smccc_1_2_regs, a12)); + DEFINE(ARM_SMCCC_1_2_REGS_X14_OFFS, offsetof(struct arm_smccc_1_2_regs, a14)); + DEFINE(ARM_SMCCC_1_2_REGS_X16_OFFS, offsetof(struct arm_smccc_1_2_regs, a16)); + #endif #endif
return 0; diff --git a/include/linux/arm-smccc.h b/include/linux/arm-smccc.h index e1d09884a1..9105031d55 100644 --- a/include/linux/arm-smccc.h +++ b/include/linux/arm-smccc.h @@ -1,6 +1,8 @@ /* SPDX-License-Identifier: GPL-2.0 */ /* * Copyright (c) 2015, Linaro Limited + * (C) Copyright 2022 ARM Limited + * Abdellatif El Khlifi abdellatif.elkhlifi@arm.com */ #ifndef __LINUX_ARM_SMCCC_H #define __LINUX_ARM_SMCCC_H @@ -70,6 +72,47 @@ struct arm_smccc_res { unsigned long a3; };
+#ifdef CONFIG_ARM64 +/** + * struct arm_smccc_1_2_regs - Arguments for or Results from SMC call + * @a0-a17 argument values from registers 0 to 17 + */ +struct arm_smccc_1_2_regs { + unsigned long a0; + unsigned long a1; + unsigned long a2; + unsigned long a3; + unsigned long a4; + unsigned long a5; + unsigned long a6; + unsigned long a7; + unsigned long a8; + unsigned long a9; + unsigned long a10; + unsigned long a11; + unsigned long a12; + unsigned long a13; + unsigned long a14; + unsigned long a15; + unsigned long a16; + unsigned long a17; +}; + +/** + * arm_smccc_1_2_smc() - make SMC calls + * @args: arguments passed via struct arm_smccc_1_2_regs + * @res: result values via struct arm_smccc_1_2_regs + * + * This function is used to make SMC calls following SMC Calling Convention + * v1.2 or above. The content of the supplied param are copied from the + * structure to registers prior to the SMC instruction. The return values + * are updated with the content from registers on return from the SMC + * instruction. + */ +asmlinkage void arm_smccc_1_2_smc(const struct arm_smccc_1_2_regs *args, + struct arm_smccc_1_2_regs *res); +#endif + /** * struct arm_smccc_quirk - Contains quirk information * @id: quirk identification
Please drop my signed-off as I didn't. I am seeing this patch on the list for the first time and AFAIK I haven't posted any previous version of the patch that you are picking up.
IIUC, you are importing this code from the Linux kernel tree which I assume is fine. You can just mention the same and must not add anyone's sign-off without consulting them.
OTH, if you cherry-pick the commit as is and use it in u-boot tree(e.g. DTS patches), then you can retain them. That is my understanding. Happy to be corrected if my assumptions are not correct here.
-- Regards, Sudeep
-- Regards, Sudeep
No worries. I'll remove the signed-off. I just wanted to give credit to the original author :)
For the FF-A driver in u-boot, only the SMC part of the kernel patch is needed. No need for HVC support at the moment. The SMC part has been tested and proven to work. Hence, this patch.
I'll rename this commit to:
arm64: smccc: add support for SMCCCv1.2 x0-x17 registers
I'll also state in the commit description that this work is inspired from the following kernel commit:
arm64: smccc: Add support for SMCCCv1.2 extended input/output registers
You're welcome to provide review comments.
Cheers, Abdellatif
set to zero the x0-x17 registers
As per the SMCCC v1.2 spec, unused result and scratch registers can leak information after an SMC call. We can mitigate against this risk by returning zero in each register.
Signed-off-by: Abdellatif El Khlifi abdellatif.elkhlifi@arm.com Cc: Tom Rini trini@konsulko.com Cc: Ilias Apalodimas ilias.apalodimas@linaro.org Cc: Jens Wiklander jens.wiklander@linaro.org --- arch/arm/cpu/armv8/smccc-call.S | 20 ++++++++++++++++++++ 1 file changed, 20 insertions(+)
diff --git a/arch/arm/cpu/armv8/smccc-call.S b/arch/arm/cpu/armv8/smccc-call.S index ec6f299bc9..8ac3e461e4 100644 --- a/arch/arm/cpu/armv8/smccc-call.S +++ b/arch/arm/cpu/armv8/smccc-call.S @@ -84,6 +84,26 @@ ENDPROC(__arm_smccc_hvc) stp x14, x15, [x19, #ARM_SMCCC_1_2_REGS_X14_OFFS] stp x16, x17, [x19, #ARM_SMCCC_1_2_REGS_X16_OFFS]
+ /* x0-x17 registers can leak information after an SMC or HVC call. Let's clear them */ + mov x0, xzr + mov x1, xzr + mov x2, xzr + mov x3, xzr + mov x4, xzr + mov x5, xzr + mov x6, xzr + mov x7, xzr + mov x8, xzr + mov x9, xzr + mov x10, xzr + mov x11, xzr + mov x12, xzr + mov x13, xzr + mov x14, xzr + mov x15, xzr + mov x16, xzr + mov x17, xzr + /* Restore original x19 */ ldp xzr, x19, [sp], #16 ret
On Mon, Aug 1, 2022 at 7:21 PM Abdellatif El Khlifi abdellatif.elkhlifi@arm.com wrote:
mov x0, xzr
mov x1, xzr
mov x2, xzr
mov x3, xzr
mov x4, xzr
mov x5, xzr
mov x6, xzr
mov x7, xzr
mov x8, xzr
mov x9, xzr
mov x10, xzr
mov x11, xzr
mov x12, xzr
mov x13, xzr
mov x14, xzr
mov x15, xzr
mov x16, xzr
mov x17, xzr
Is this information leakage worse than the information leakage from an ordinary C function? My point is, is this needed?
Thanks, Jens
-- 2.17.1
mov x0, xzr
mov x1, xzr
mov x2, xzr
mov x3, xzr
mov x4, xzr
mov x5, xzr
mov x6, xzr
mov x7, xzr
mov x8, xzr
mov x9, xzr
mov x10, xzr
mov x11, xzr
mov x12, xzr
mov x13, xzr
mov x14, xzr
mov x15, xzr
mov x16, xzr
mov x17, xzr
The leakage we are referring to is data leakage across exception levels. The intent is to prevent lower exception levels (EL1/EL0) to read the data exchanged at EL2.
The linux kernel clears the general purpose registers before switching to EL0. As far as I know u-boot doesn't.
So, the code above makes sure the registers are cleared. An improved version of this has been releases in this patch: https://lore.kernel.org/all/20220926101723.9965-3-abdellatif.elkhlifi@arm.co...
Thanks, Jens
-- 2.17.1
Add the driver implementing Arm Firmware Framework for Armv8-A v1.0
The Firmware Framework for Arm A-profile processors (FF-A) describes interfaces (ABIs) that standardize communication between the Secure World and Normal World leveraging TrustZone technology.
This driver uses 64-bit registers as per SMCCCv1.2 spec and comes on top of the SMCCC layer. The driver provides the FF-A ABIs needed for querying the FF-A framework from the secure world.
32-bit version of the ABIs is supported and 64-bit version of FFA_RXTX_MAP and FFA_MSG_SEND_DIRECT_{REQ, RESP}.
In u-boot FF-A design, FF-A is considered as a discoverable bus. The Secure World is considered as one entity to communicate with using the FF-A bus. FF-A communication is handled by one device and one instance (the bus). This FF-A driver takes care of all the interactions between Normal world and Secure World.
The driver exports its operations to be used by upper layers.
Exported operations:
- partition_info_get - sync_send_receive - rxtx_unmap
This implementation provides an optional feature to copy the driver data to EFI runtime area.
Signed-off-by: Abdellatif El Khlifi abdellatif.elkhlifi@arm.com Cc: Tom Rini trini@konsulko.com Cc: Ilias Apalodimas ilias.apalodimas@linaro.org Cc: Jens Wiklander jens.wiklander@linaro.org --- MAINTAINERS | 6 + common/board_r.c | 7 + drivers/Kconfig | 2 + drivers/Makefile | 1 + drivers/arm-ffa/Kconfig | 33 + drivers/arm-ffa/Makefile | 7 + drivers/arm-ffa/arm-ffa-uclass.c | 16 + drivers/arm-ffa/arm_ffa_prv.h | 219 ++++ drivers/arm-ffa/core.c | 1338 ++++++++++++++++++++ drivers/arm-ffa/efi_ffa_runtime_data_mgr.c | 94 ++ include/arm_ffa.h | 132 ++ include/dm/uclass-id.h | 1 + include/uuid.h | 8 + lib/efi_loader/efi_boottime.c | 17 + lib/uuid.c | 65 + 15 files changed, 1946 insertions(+) create mode 100644 drivers/arm-ffa/Kconfig create mode 100644 drivers/arm-ffa/Makefile create mode 100644 drivers/arm-ffa/arm-ffa-uclass.c create mode 100644 drivers/arm-ffa/arm_ffa_prv.h create mode 100644 drivers/arm-ffa/core.c create mode 100644 drivers/arm-ffa/efi_ffa_runtime_data_mgr.c create mode 100644 include/arm_ffa.h
diff --git a/MAINTAINERS b/MAINTAINERS index f371d864f2..93a57f4df2 100644 --- a/MAINTAINERS +++ b/MAINTAINERS @@ -248,6 +248,12 @@ F: drivers/net/cortina_ni.h F: drivers/net/phy/ca_phy.c F: configs/cortina_presidio-asic-pnand_defconfig
+ARM FF-A +M: Abdellatif El Khlifi abdellatif.elkhlifi@arm.com +S: Maintained +F: drivers/arm-ffa/ +F: include/arm_ffa.h + ARM FREESCALE IMX M: Stefano Babic sbabic@denx.de M: Fabio Estevam festevam@gmail.com diff --git a/common/board_r.c b/common/board_r.c index ed29069d2d..2d3f359b96 100644 --- a/common/board_r.c +++ b/common/board_r.c @@ -63,6 +63,10 @@ #include <efi_loader.h> #include <relocate.h>
+#ifdef CONFIG_ARM_FFA_TRANSPORT +#include <arm_ffa.h> +#endif + DECLARE_GLOBAL_DATA_PTR;
ulong monitor_flash_len; @@ -767,6 +771,9 @@ static init_fnc_t init_sequence_r[] = { INIT_FUNC_WATCHDOG_RESET initr_net, #endif +#ifdef CONFIG_ARM_FFA_TRANSPORT + ffa_bus_discover, +#endif #ifdef CONFIG_POST initr_post, #endif diff --git a/drivers/Kconfig b/drivers/Kconfig index 8b6fead351..60b5fd4d9d 100644 --- a/drivers/Kconfig +++ b/drivers/Kconfig @@ -6,6 +6,8 @@ source "drivers/core/Kconfig"
source "drivers/adc/Kconfig"
+source "drivers/arm-ffa/Kconfig" + source "drivers/ata/Kconfig"
source "drivers/axi/Kconfig" diff --git a/drivers/Makefile b/drivers/Makefile index eba9940231..dfde371381 100644 --- a/drivers/Makefile +++ b/drivers/Makefile @@ -110,6 +110,7 @@ obj-y += iommu/ obj-y += smem/ obj-y += thermal/ obj-$(CONFIG_TEE) += tee/ +obj-$(CONFIG_ARM_FFA_TRANSPORT) += arm-ffa/ obj-y += axi/ obj-y += ufs/ obj-$(CONFIG_W1) += w1/ diff --git a/drivers/arm-ffa/Kconfig b/drivers/arm-ffa/Kconfig new file mode 100644 index 0000000000..882ffde90f --- /dev/null +++ b/drivers/arm-ffa/Kconfig @@ -0,0 +1,33 @@ +# SPDX-License-Identifier: GPL-2.0 + +config ARM_FFA_TRANSPORT + bool "Enable Arm Firmware Framework for Armv8-A driver" + depends on DM && ARM64 + select ARM_SMCCC + select LIB_UUID + select DEVRES + help + The Firmware Framework for Arm A-profile processors (FF-A) + describes interfaces (ABIs) that standardize communication + between the Secure World and Normal World leveraging TrustZone + technology. + + This driver is based on FF-A specification v1.0 and uses SMC32 + calling convention. + + FF-A specification: + + https://developer.arm.com/documentation/den0077/a/?lang=en + + In u-boot FF-A design, FF-A is considered as a discoverable bus. + The Secure World is considered as one entity to communicate with + using the FF-A bus. + FF-A communication is handled by one device and one instance (the bus). + This FF-A driver takes care of all the interactions between Normal world + and Secure World. + +config ARM_FFA_EFI_RUNTIME_MODE + bool "Enable EFI runtime support for FF-A data and code " + depends on ARM_FFA_TRANSPORT && EFI_LOADER + help + Allows FF-A driver data structures and code to be accessible at EFI runtime diff --git a/drivers/arm-ffa/Makefile b/drivers/arm-ffa/Makefile new file mode 100644 index 0000000000..0b9b0a61b4 --- /dev/null +++ b/drivers/arm-ffa/Makefile @@ -0,0 +1,7 @@ +# SPDX-License-Identifier: GPL-2.0+ +# +# (C) Copyright 2022 Abdellatif El Khlifi abdellatif.elkhlifi@arm.com +# + +obj-y += arm-ffa-uclass.o core.o +obj-$(CONFIG_ARM_FFA_EFI_RUNTIME_MODE) += efi_ffa_runtime_data_mgr.o diff --git a/drivers/arm-ffa/arm-ffa-uclass.c b/drivers/arm-ffa/arm-ffa-uclass.c new file mode 100644 index 0000000000..7d9695d289 --- /dev/null +++ b/drivers/arm-ffa/arm-ffa-uclass.c @@ -0,0 +1,16 @@ +// SPDX-License-Identifier: GPL-2.0+ +/* + * (C) Copyright 2022 ARM Limited + * Abdellatif El Khlifi abdellatif.elkhlifi@arm.com + */ + +#include <common.h> +#include <dm.h> +#include <asm/global_data.h> + +DECLARE_GLOBAL_DATA_PTR; + +UCLASS_DRIVER(ffa) = { + .name = "ffa", + .id = UCLASS_FFA, +}; diff --git a/drivers/arm-ffa/arm_ffa_prv.h b/drivers/arm-ffa/arm_ffa_prv.h new file mode 100644 index 0000000000..1133c02400 --- /dev/null +++ b/drivers/arm-ffa/arm_ffa_prv.h @@ -0,0 +1,219 @@ +/* SPDX-License-Identifier: GPL-2.0+ */ +/* + * (C) Copyright 2022 ARM Limited + * Abdellatif El Khlifi abdellatif.elkhlifi@arm.com + */ + +#ifndef __ARM_FFA_PRV_H +#define __ARM_FFA_PRV_H + +#include <arm_ffa.h> +#include <linux/bitfield.h> +#include <linux/bitops.h> +#include <linux/arm-smccc.h> + +/* + * This header is private. It is exclusively used by the FF-A driver + */ + +/* FF-A core driver name */ +#define FFA_DRV_NAME "arm_ffa" + +/* FF-A driver version definitions */ + +#define MAJOR_VERSION_MASK GENMASK(30, 16) +#define MINOR_VERSION_MASK GENMASK(15, 0) +#define GET_FFA_MAJOR_VERSION(x) \ + ((u16)(FIELD_GET(MAJOR_VERSION_MASK, (x)))) +#define GET_FFA_MINOR_VERSION(x) \ + ((u16)(FIELD_GET(MINOR_VERSION_MASK, (x)))) +#define PACK_VERSION_INFO(major, minor) \ + (FIELD_PREP(MAJOR_VERSION_MASK, (major)) | \ + FIELD_PREP(MINOR_VERSION_MASK, (minor))) + +#define FFA_MAJOR_VERSION (1) +#define FFA_MINOR_VERSION (0) +#define FFA_VERSION_1_0 \ + PACK_VERSION_INFO(FFA_MAJOR_VERSION, FFA_MINOR_VERSION) + +/* Endpoint ID mask (u-boot endpoint ID) */ + +#define GET_SELF_ENDPOINT_ID_MASK GENMASK(15, 0) +#define GET_SELF_ENDPOINT_ID(x) \ + ((u16)(FIELD_GET(GET_SELF_ENDPOINT_ID_MASK, (x)))) + +#define PREP_SELF_ENDPOINT_ID_MASK GENMASK(31, 16) +#define PREP_SELF_ENDPOINT_ID(x) \ + (FIELD_PREP(PREP_SELF_ENDPOINT_ID_MASK, (x))) + +/* Partition endpoint ID mask (partition with which u-boot communicates with) */ + +#define PREP_PART_ENDPOINT_ID_MASK GENMASK(15, 0) +#define PREP_PART_ENDPOINT_ID(x) \ + (FIELD_PREP(PREP_PART_ENDPOINT_ID_MASK, (x))) + +/* + * Definitions of the Arm FF-A interfaces supported by the Arm FF-A driver + */ + +#define FFA_SMC(calling_convention, func_num) \ + ARM_SMCCC_CALL_VAL(ARM_SMCCC_FAST_CALL, (calling_convention), \ + ARM_SMCCC_OWNER_STANDARD, (func_num)) + +#define FFA_SMC_32(func_num) FFA_SMC(ARM_SMCCC_SMC_32, (func_num)) +#define FFA_SMC_64(func_num) FFA_SMC(ARM_SMCCC_SMC_64, (func_num)) + +#define FFA_VERSION FFA_SMC_32(0x63) +#define FFA_ID_GET FFA_SMC_32(0x69) +#define FFA_FEATURES FFA_SMC_32(0x64) +#define FFA_PARTITION_INFO_GET FFA_SMC_32(0x68) +#define FFA_RXTX_UNMAP FFA_SMC_32(0x67) +#define FFA_RX_RELEASE FFA_SMC_32(0x65) +#define FFA_RUN FFA_SMC_32(0x6D) +#define FFA_ERROR FFA_SMC_32(0x60) +#define FFA_SUCCESS FFA_SMC_32(0x61) +#define FFA_INTERRUPT FFA_SMC_32(0x62) +#define FFA_RXTX_MAP FFA_SMC_64(0x66) +#define FFA_MSG_SEND_DIRECT_REQ FFA_SMC_64(0x6F) +#define FFA_MSG_SEND_DIRECT_RESP FFA_SMC_64(0x70) + +/* The FF-A SMC function definitions */ + +typedef struct arm_smccc_1_2_regs ffa_value_t; +typedef void (*invoke_ffa_fn_t)(ffa_value_t args, ffa_value_t *res); + +/* FF-A error codes */ +#define FFA_ERR_STAT_NOT_SUPPORTED (-1) +#define FFA_ERR_STAT_INVALID_PARAMETERS (-2) +#define FFA_ERR_STAT_NO_MEMORY (-3) +#define FFA_ERR_STAT_BUSY (-4) +#define FFA_ERR_STAT_INTERRUPTED (-5) +#define FFA_ERR_STAT_DENIED (-6) +#define FFA_ERR_STAT_RETRY (-7) +#define FFA_ERR_STAT_ABORTED (-8) + +/* UUID data size */ +#define UUID_SIZE (16) + +/* + * union ffa_partition_uuid - Data union hosting the UUID + * transmitted by FFA_PARTITION_INFO_GET + * @words: data structure giving 32-bit words access to the UUID data + * @bytes: data structure giving byte access to the UUID data + * + * The structure holds little-endian UUID data. + */ +union ffa_partition_uuid { + struct __packed words { + u32 a1; /* w1 */ + u32 a2; /* w2 */ + u32 a3; /* w3 */ + u32 a4; /* w4 */ + } words; + u8 bytes[UUID_SIZE]; +}; + +/** + * struct ffa_features_desc - FF-A functions features + * @func_id: FF-A function + * @field1: features read from register w2 + * @field2: features read from register w3 + * + * Data structure describing the features of the FF-A functions queried by + * FFA_FEATURES + */ +struct ffa_features_desc { + u32 func_id; + u32 field1; + u64 field2; +}; + +/** + * enum ffa_rxtx_buf_sizes - minimum sizes supported + * for the RX/TX buffers + */ +enum ffa_rxtx_buf_sizes { + RXTX_4K, + RXTX_64K, + RXTX_16K +}; + +/* + * Number of the FF-A interfaces features descriptors + * currently only FFA_RXTX_MAP descriptor is supported + */ +#define FFA_FEATURE_DESC_CNT (1) + +/** + * struct ffa_rxtxpair - structure hosting the RX/TX buffers virtual addresses + * @rxbuf: virtual address of the RX buffer + * @txbuf: virtual address of the TX buffer + * + * Data structure hosting the virtual addresses of the mapped RX/TX buffers + * These addresses are used by the FF-A functions that use the RX/TX buffers + */ +struct ffa_rxtxpair { + u64 rxbuf; /* virtual address */ + u64 txbuf; /* virtual address */ +}; + +/** + * struct ffa_partition_desc - the secure partition descriptor + * @info: partition information + * @UUID: UUID + * + * Each partition has its descriptor containing the partitions information and the UUID + */ +struct ffa_partition_desc { + struct ffa_partition_info info; + union ffa_partition_uuid UUID; +}; + +/** + * struct ffa_partitions - descriptors for all secure partitions + * @count: The number of partitions descriptors + * @descs The partitions descriptors table + * + * This data structure contains the partitions descriptors table + */ +struct ffa_partitions { + u32 count; + struct ffa_partition_desc *descs; /* virtual address */ +}; + +/** + * struct ffa_prvdata - the driver private data structure + * + * @dev: The arm_ffa device under u-boot driver model + * @ffa_ops: The driver operations structure + * @fwk_version: FF-A framework version + * @id: u-boot endpoint ID + * @partitions: The partitions descriptors structure + * @pair: The RX/TX buffers pair + * @invoke_ffa_fn: The function executing the FF-A function + * @features: Table of the FF-A functions having features + * + * The driver data structure hosting all resident data. + */ +struct ffa_prvdata { + struct udevice *dev; + struct ffa_bus_ops ffa_ops; + u32 fwk_version; + u16 id; + struct ffa_partitions partitions; + struct ffa_rxtxpair pair; + invoke_ffa_fn_t invoke_ffa_fn; + struct ffa_features_desc features[FFA_FEATURE_DESC_CNT]; +}; + +/** + * ffa_device_get - create, bind and probe the arm_ffa device + */ +int ffa_device_get(void); + +/** + * ffa_bus_prvdata_get - bus driver private data getter + */ +struct ffa_prvdata **ffa_bus_prvdata_get(void); + +#endif diff --git a/drivers/arm-ffa/core.c b/drivers/arm-ffa/core.c new file mode 100644 index 0000000000..40d140fc3e --- /dev/null +++ b/drivers/arm-ffa/core.c @@ -0,0 +1,1338 @@ +// SPDX-License-Identifier: GPL-2.0+ +/* + * (C) Copyright 2022 ARM Limited + * Abdellatif El Khlifi abdellatif.elkhlifi@arm.com + */ + +#include "arm_ffa_prv.h" +#include <asm/global_data.h> +#include <common.h> +#include <dm.h> +#include <dm/device-internal.h> +#include <dm/devres.h> +#include <dm/root.h> +#include <linux/errno.h> +#include <linux/sizes.h> +#include <log.h> +#include <malloc.h> +#include <string.h> +#include <uuid.h> + +DECLARE_GLOBAL_DATA_PTR; + +/** + * The device private data structure containing all the resident + * data read from secure world + */ +__ffa_runtime_data struct ffa_prvdata *ffa_priv_data; + +/* + * Driver functions + */ + +/** + * ffa_remove_device - removes the arm_ffa device + * @dev: the device to be removed + * + * This boot time function makes sure the arm_ffa device is removed + * No need to free the kmalloced data when the device is destroyed. + * It's automatically done by devm management. + * + * Return: + * + * FFA_ERR_STAT_SUCCESS on success. Otherwise, failure + */ +int ffa_remove_device(struct udevice *dev) +{ + int ret; + + if (!dev) + return -ENODEV; + + ret = device_remove(dev, DM_REMOVE_NORMAL); + if (ret) { + ffa_err("Unable to remove. err:%d\n", ret); + return ret; + } + + ret = device_unbind(dev); + if (ret) { + ffa_err("Unable to unbind. err:%d\n", ret); + return ret; + } + + return FFA_ERR_STAT_SUCCESS; +} + +/** + * ffa_device_get - create, bind and probe the arm_ffa device + * + * This boot time function makes sure the arm_ffa device is + * created, bound to this driver, probed and ready to use. + * Arm FF-A transport is implemented through a single u-boot + * device managing the FF-A bus (arm_ffa). + * + * Return: + * + * FFA_ERR_STAT_SUCCESS on success. Otherwise, failure + */ +int ffa_device_get(void) +{ + int ret; + struct udevice *dev = NULL; + + if (ffa_priv_data && ffa_priv_data->dev) + return FFA_ERR_STAT_SUCCESS; + + ret = device_bind(dm_root(), + DM_DRIVER_GET(arm_ffa), + FFA_DRV_NAME, + NULL, + ofnode_null(), + &dev); + if (ret) + return ret; + + /* The FF-A bus discovery succeeds when probing is successful */ + ret = device_probe(dev); + if (ret) { + ffa_err("arm_ffa device probing failed"); + ffa_remove_device(dev); + return ret; + } + + return FFA_ERR_STAT_SUCCESS; +} + +/** + * ffa_get_version - FFA_VERSION handler function + * + * This is the boot time function that implements FFA_VERSION FF-A function + * to get from the secure world the FF-A framework version + * + * Return: + * + * FFA_ERR_STAT_SUCCESS on success. Otherwise, failure + */ +static int ffa_get_version(void) +{ + u16 major, minor; + ffa_value_t res = {0}; + + if (!ffa_priv_data->invoke_ffa_fn) + panic("[FFA] no private data found\n"); + + ffa_priv_data->invoke_ffa_fn((ffa_value_t){ + .a0 = FFA_VERSION, + .a1 = FFA_VERSION_1_0, .a2 = 0, .a3 = 0, .a4 = 0, .a5 = 0, .a6 = 0, .a7 = 0, + }, &res); + + if (((int)res.a0) == FFA_ERR_STAT_NOT_SUPPORTED) { + ffa_err("A Firmware Framework implementation does not exist"); + return -EOPNOTSUPP; + } + + major = GET_FFA_MAJOR_VERSION((u32)res.a0); + minor = GET_FFA_MINOR_VERSION((u32)res.a0); + + ffa_info("FF-A driver %d.%d\nFF-A framework %d.%d", + FFA_MAJOR_VERSION, FFA_MINOR_VERSION, major, minor); + + if ((major == FFA_MAJOR_VERSION && minor >= FFA_MINOR_VERSION)) { + ffa_info("Versions are compatible "); + + ffa_priv_data->fwk_version = (u32)res.a0; + + return FFA_ERR_STAT_SUCCESS; + } + + ffa_err("Versions are incompatible\nExpected: %d.%d , Found: %d.%d\n", + FFA_MAJOR_VERSION, FFA_MINOR_VERSION, major, minor); + + return -EPROTONOSUPPORT; +} + +/** + * ffa_get_endpoint_id - FFA_ID_GET handler function + * + * This is the boot time function that implements FFA_ID_GET FF-A function + * to get from the secure world u-boot endpoint ID + * + * Return: + * + * FFA_ERR_STAT_SUCCESS on success. Otherwise, failure + */ +static int ffa_get_endpoint_id(void) +{ + ffa_value_t res = {0}; + + if (!ffa_priv_data->invoke_ffa_fn) + panic("[FFA] no private data found\n"); + + ffa_priv_data->invoke_ffa_fn((ffa_value_t){ + .a0 = FFA_ID_GET, + .a1 = 0, .a2 = 0, .a3 = 0, .a4 = 0, .a5 = 0, .a6 = 0, .a7 = 0, + }, &res); + + switch (res.a0) { + case FFA_ERROR: + + if (((int)res.a2) == FFA_ERR_STAT_NOT_SUPPORTED) { + ffa_err("This function is not implemented at this FF-A instance"); + return -EOPNOTSUPP; + } + + ffa_err("Undefined error code (%d)", ((int)res.a2)); + return -EINVAL; + + case FFA_SUCCESS: + + ffa_priv_data->id = GET_SELF_ENDPOINT_ID((u32)res.a2); + ffa_info("endpoint ID is %u", ffa_priv_data->id); + + return FFA_ERR_STAT_SUCCESS; + + default: + + ffa_err("Undefined response function (0x%lx)", res.a0); + return -EINVAL; + } +} + +/** + * ffa_get_features_desc - returns the features descriptor of the specified + * FF-A function + * @func_id: the FF-A function which the features are to be retrieved + * + * This is a boot time function that searches the features descriptor of the + * specified FF-A function + * + * Return: + * + * When found, the address of the features descriptor is returned. Otherwise, NULL. + */ +static struct ffa_features_desc *ffa_get_features_desc(u32 func_id) +{ + u32 desc_idx; + + /* + * search for the descriptor of the selected FF-A interface + */ + for (desc_idx = 0; desc_idx < FFA_FEATURE_DESC_CNT ; desc_idx++) + if (ffa_priv_data->features[desc_idx].func_id == func_id) + return &ffa_priv_data->features[desc_idx]; + + return NULL; +} + +/** + * ffa_get_rxtx_map_features - FFA_FEATURES handler function with FFA_RXTX_MAP + * argument + * + * This is the boot time function that implements FFA_FEATURES FF-A function + * to retrieve the FFA_RXTX_MAP features + * + * Return: + * + * FFA_ERR_STAT_SUCCESS on success. Otherwise, failure + */ +static int ffa_get_rxtx_map_features(void) +{ + ffa_value_t res = {0}; + + if (!ffa_priv_data->invoke_ffa_fn) + panic("[FFA] no private data found\n"); + + ffa_priv_data->invoke_ffa_fn((ffa_value_t){ + .a0 = FFA_FEATURES, + .a1 = FFA_RXTX_MAP, + .a2 = 0, .a3 = 0, .a4 = 0, .a5 = 0, .a6 = 0, .a7 = 0, + }, &res); + + switch (res.a0) { + case FFA_ERROR: + { + if (((int)res.a2) == FFA_ERR_STAT_NOT_SUPPORTED) { + ffa_err("FFA_RXTX_MAP is not implemented at this FF-A instance"); + return -EOPNOTSUPP; + } + + ffa_err("Undefined error code (%d)", ((int)res.a2)); + return -EINVAL; + } + case FFA_SUCCESS: + { + u32 desc_idx; + + /* + * search for an empty descriptor + */ + for (desc_idx = 0; desc_idx < FFA_FEATURE_DESC_CNT ; desc_idx++) + if (!ffa_priv_data->features[desc_idx].func_id) { + /* + * populate the descriptor with + * the interface features data + */ + ffa_priv_data->features[desc_idx].func_id = + FFA_RXTX_MAP; + ffa_priv_data->features[desc_idx].field1 = + (u32)res.a2; + + ffa_info("FFA_RXTX_MAP features data 0x%x", + ffa_priv_data->features[desc_idx].field1); + + return FFA_ERR_STAT_SUCCESS; + } + + ffa_err("Cannot save FFA_RXTX_MAP features data. Descriptors table full"); + return -ENOBUFS; + } + default: + { + ffa_err("Undefined response function (0x%lx)", + res.a0); + return -EINVAL; + } + } +} + +/** + * ffa_get_rxtx_buffers_pages_cnt - reads from the features data descriptors + * the minimum number of pages in each of the RX/TX + * buffers + * @buf_4k_pages: Pointer to the minimum number of pages + * + * This is the boot time function that returns the minimum number of pages + * in each of the RX/TX buffers + * + * Return: + * + * buf_4k_pages points to the returned number of pages + * FFA_ERR_STAT_SUCCESS on success. Otherwise, failure + */ +static int ffa_get_rxtx_buffers_pages_cnt(size_t *buf_4k_pages) +{ + struct ffa_features_desc *desc = NULL; + + if (!buf_4k_pages) + return -EINVAL; + + desc = ffa_get_features_desc(FFA_RXTX_MAP); + if (!desc) + return -EINVAL; + + switch (desc->field1) { + case RXTX_4K: + *buf_4k_pages = 1; + break; + case RXTX_16K: + *buf_4k_pages = 4; + break; + case RXTX_64K: + *buf_4k_pages = 16; + break; + default: + ffa_err("RX/TX buffer size not supported"); + return -EINVAL; + } + + return FFA_ERR_STAT_SUCCESS; +} + +/** + * ffa_free_rxtx_buffers - frees the RX/TX buffers + * @buf_4k_pages: the minimum number of pages in each of the RX/TX + * buffers + * + * This is the boot time function used to free the RX/TX buffers + * + */ +static void ffa_free_rxtx_buffers(void) +{ + ffa_info("Freeing RX/TX buffers"); + + if (ffa_priv_data->pair.rxbuf) { + free((void *)ffa_priv_data->pair.rxbuf); + ffa_priv_data->pair.rxbuf = 0; + } + + if (ffa_priv_data->pair.txbuf) { + free((void *)ffa_priv_data->pair.txbuf); + ffa_priv_data->pair.txbuf = 0; + } +} + +/** + * ffa_alloc_rxtx_buffers - allocates the RX/TX buffers + * @buf_4k_pages: the minimum number of pages in each of the RX/TX + * buffers + * + * This is the boot time function used by ffa_map_rxtx_buffers to allocate + * the RX/TX buffers before mapping them. The allocated memory is physically + * contiguous since memalign ends up calling malloc which allocates + * contiguous memory in u-boot. + * + * Return: + * + * FFA_ERR_STAT_SUCCESS on success. Otherwise, failure + */ +static int ffa_alloc_rxtx_buffers(size_t buf_4k_pages) +{ + u64 bytes; + + ffa_info("Using %lu 4KB page(s) for RX/TX buffers size", buf_4k_pages); + + bytes = buf_4k_pages * SZ_4K; + + /* RX/TX buffers addresses should be PAGE_SIZE aligned */ + + ffa_priv_data->pair.rxbuf = (u64)memalign(PAGE_SIZE, bytes); + if (!ffa_priv_data->pair.rxbuf) { + ffa_err("Failure to allocate RX buffer"); + return -ENOBUFS; + } + + ffa_info("RX buffer at virtual address 0x%llx", ffa_priv_data->pair.rxbuf); + + ffa_priv_data->pair.txbuf = (u64)memalign(PAGE_SIZE, bytes); + if (!ffa_priv_data->pair.txbuf) { + free((void *)ffa_priv_data->pair.rxbuf); + ffa_priv_data->pair.rxbuf = 0; + ffa_err("Failure to allocate the TX buffer"); + return -ENOBUFS; + } + + ffa_info("TX buffer at virtual address 0x%llx", ffa_priv_data->pair.txbuf); + + /* + * make sure the buffers are cleared before use + */ + memset((void *)ffa_priv_data->pair.rxbuf, 0, bytes); + memset((void *)ffa_priv_data->pair.txbuf, 0, bytes); + + return FFA_ERR_STAT_SUCCESS; +} + +/** + * ffa_map_rxtx_buffers - FFA_RXTX_MAP handler function + * @buf_4k_pages: the minimum number of pages in each of the RX/TX + * buffers + * + * This is the boot time function that implements FFA_RXTX_MAP FF-A function + * to map the RX/TX buffers + * + * Return: + * + * FFA_ERR_STAT_SUCCESS on success. Otherwise, failure + */ +static int ffa_map_rxtx_buffers(size_t buf_4k_pages) +{ + int ret; + ffa_value_t res = {0}; + + if (!ffa_priv_data->invoke_ffa_fn) + panic("[FFA] no private data found\n"); + + ret = ffa_alloc_rxtx_buffers(buf_4k_pages); + if (ret != FFA_ERR_STAT_SUCCESS) + return ret; + + /* + * we need to pass the physical addresses of the RX/TX buffers + * in u-boot physical/virtual mapping is 1:1 + *no need to convert from virtual to physical + */ + + ffa_priv_data->invoke_ffa_fn((ffa_value_t){ + .a0 = FFA_RXTX_MAP, + .a1 = ffa_priv_data->pair.txbuf, + .a2 = ffa_priv_data->pair.rxbuf, + .a3 = buf_4k_pages, + .a4 = 0, .a5 = 0, .a6 = 0, .a7 = 0, + }, &res); + + switch (res.a0) { + case FFA_ERROR: + { + switch (((int)res.a2)) { + case FFA_ERR_STAT_INVALID_PARAMETERS: + ffa_err("One or more fields in input parameters is incorrectly encoded"); + ret = -EPERM; + break; + case FFA_ERR_STAT_NO_MEMORY: + ffa_err("Not enough memory"); + ret = -ENOMEM; + break; + case FFA_ERR_STAT_DENIED: + ffa_err("Buffer pair already registered"); + ret = -EACCES; + break; + case FFA_ERR_STAT_NOT_SUPPORTED: + ffa_err("This function is not implemented at this FF-A instance"); + ret = -EOPNOTSUPP; + break; + default: + ffa_err("Undefined error (%d)", + ((int)res.a2)); + ret = -EINVAL; + } + break; + } + case FFA_SUCCESS: + ffa_info("RX/TX buffers mapped"); + return FFA_ERR_STAT_SUCCESS; + default: + ffa_err("Undefined response function (0x%lx)", + res.a0); + ret = -EINVAL; + } + + ffa_free_rxtx_buffers(); + + return ret; +} + +/** + * ffa_unmap_rxtx_buffers - FFA_RXTX_UNMAP handler function + * + * This is the boot time function that implements FFA_RXTX_UNMAP FF-A function + * to unmap the RX/TX buffers + * + * Return: + * + * FFA_ERR_STAT_SUCCESS on success. Otherwise, failure + */ +static int ffa_unmap_rxtx_buffers(void) +{ + ffa_value_t res = {0}; + + if (!ffa_priv_data->invoke_ffa_fn) + panic("[FFA] no private data found\n"); + + ffa_priv_data->invoke_ffa_fn((ffa_value_t){ + .a0 = FFA_RXTX_UNMAP, + .a1 = PREP_SELF_ENDPOINT_ID(ffa_priv_data->id), + .a2 = 0, .a3 = 0, .a4 = 0, .a5 = 0, .a6 = 0, .a7 = 0, + }, &res); + + switch (res.a0) { + case FFA_ERROR: + { + if (((int)res.a2) == FFA_ERR_STAT_NOT_SUPPORTED) + panic("[FFA] FFA_RXTX_UNMAP is not implemented at this FF-A instance\n"); + else if (((int)res.a2) == FFA_ERR_STAT_INVALID_PARAMETERS) + panic("[FFA] There is no buffer pair registered on behalf of the caller\n"); + else + panic("[FFA] Undefined error (%d)\n", ((int)res.a2)); + } + case FFA_SUCCESS: + { + ffa_free_rxtx_buffers(); + + return FFA_ERR_STAT_SUCCESS; + } + default: + panic("[FFA] Undefined response function (0x%lx)", res.a0); + return -ENODEV; + } +} + +/** + * ffa_release_rx_buffer - FFA_RX_RELEASE handler function + * + * This is the boot time function that invokes FFA_RX_RELEASE FF-A function + * to release the ownership of the RX buffer + * + * Return: + * + * FFA_ERR_STAT_SUCCESS on success. Otherwise, failure + */ +static int ffa_release_rx_buffer(void) +{ + ffa_value_t res = {0}; + + if (!ffa_priv_data->invoke_ffa_fn) + panic("[FFA] no private data found\n"); + + ffa_priv_data->invoke_ffa_fn((ffa_value_t){ + .a0 = FFA_RX_RELEASE, + .a1 = 0, .a2 = 0, .a3 = 0, .a4 = 0, .a5 = 0, .a6 = 0, .a7 = 0, + }, &res); + + switch (res.a0) { + case FFA_ERROR: + { + if (((int)res.a2) == FFA_ERR_STAT_NOT_SUPPORTED) + panic("[FFA] FFA_RX_RELEASE is not implemented at this FF-A instance\n"); + else if (((int)res.a2) == FFA_ERR_STAT_DENIED) + panic("[FFA] Caller did not have ownership of the RX buffer\n"); + else + panic("[FFA] Undefined error (%d)\n", ((int)res.a2)); + } + case FFA_SUCCESS: + return FFA_ERR_STAT_SUCCESS; + + default: + panic("[FFA] Undefined response function (0x%lx)\n", res.a0); + return -ENODEV; + } +} + +/** + * ffa_uuid_are_identical - checks whether two given UUIDs are identical + * @uuid1: first UUID + * @uuid2: second UUID + * + * This is a boot time function used by ffa_read_partitions_info to search + * for a UUID in the partitions descriptors table + * + * Return: + * + * 1 when UUIDs match. Otherwise, 0 + */ +int ffa_uuid_are_identical(const union ffa_partition_uuid *uuid1, + const union ffa_partition_uuid *uuid2) +{ + if (!uuid1 || !uuid2) + return 0; + + return (!memcmp(uuid1, uuid2, sizeof(union ffa_partition_uuid))); +} + +/** + * ffa_read_partitions_info - reads the data queried by FFA_PARTITION_INFO_GET + * and saves it in the private structure + * @count: The number of partitions queried + * @part_uuid: Pointer to the partition(s) UUID + * + * This is the boot time function that reads the partitions information + * returned by the FFA_PARTITION_INFO_GET and saves it in the private + * data structure. + * + * Return: + * + * The private data structure is updated with the partition(s) information + * FFA_ERR_STAT_SUCCESS is returned on success. Otherwise, failure + */ +static int ffa_read_partitions_info(u32 count, union ffa_partition_uuid *part_uuid) +{ + if (!count) { + ffa_err("No partition detected"); + return -ENODATA; + } + + ffa_info("Reading partitions data from the RX buffer"); + + if (!part_uuid) { + /* + * querying information of all partitions + */ + u64 buf_bytes; + u64 data_bytes; + size_t buf_4k_pages = 0; + u32 desc_idx; + struct ffa_partition_info *parts_info; + int ret; + + data_bytes = count * sizeof(struct ffa_partition_desc); + + /* + * get the RX buffer size in pages + */ + ret = ffa_get_rxtx_buffers_pages_cnt(&buf_4k_pages); + if (ret != FFA_ERR_STAT_SUCCESS) { + ffa_err("Can not get the RX buffer size (error %d)", ret); + return ret; + } + + buf_bytes = buf_4k_pages * SZ_4K; + + if (data_bytes > buf_bytes) { + ffa_err("Partitions data size exceeds the RX buffer size:"); + ffa_err(" Sizes in bytes: data %llu , RX buffer %llu ", + data_bytes, + buf_bytes); + + return -ENOMEM; + } + + ffa_priv_data->partitions.descs = (struct ffa_partition_desc *) + devm_kmalloc(ffa_priv_data->dev, data_bytes, __GFP_ZERO); + if (!ffa_priv_data->partitions.descs) { + ffa_err("Cannot allocate partitions data buffer"); + return -ENOMEM; + } + + parts_info = (struct ffa_partition_info *)ffa_priv_data->pair.rxbuf; + + for (desc_idx = 0 ; desc_idx < count ; desc_idx++) { + ffa_priv_data->partitions.descs[desc_idx].info = + parts_info[desc_idx]; + + ffa_info("Partition ID %x : info cached", + ffa_priv_data->partitions.descs[desc_idx].info.id); + } + + ffa_priv_data->partitions.count = count; + + ffa_info("%d partition(s) found and cached", count); + + } else { + u32 rx_desc_idx, cached_desc_idx; + struct ffa_partition_info *parts_info; + u8 desc_found; + + parts_info = (struct ffa_partition_info *)ffa_priv_data->pair.rxbuf; + + /* + * search for the SP IDs read from the RX buffer + * in the already cached SPs. + * Update the UUID when ID found. + */ + for (rx_desc_idx = 0; rx_desc_idx < count ; rx_desc_idx++) { + desc_found = 0; + + /* + * search the current ID in the cached partitions + */ + for (cached_desc_idx = 0; + cached_desc_idx < ffa_priv_data->partitions.count; + cached_desc_idx++) { + /* + * save the UUID + */ + if (ffa_priv_data->partitions.descs[cached_desc_idx].info.id == + parts_info[rx_desc_idx].id) { + ffa_priv_data->partitions.descs[cached_desc_idx].UUID = + *part_uuid; + + desc_found = 1; + break; + } + } + + if (!desc_found) + return -ENODATA; + } + } + + return FFA_ERR_STAT_SUCCESS; +} + +/** + * ffa_query_partitions_info - invokes FFA_PARTITION_INFO_GET and saves partitions data + * + * @part_uuid: Pointer to the partition(s) UUID + * @pcount: Pointer to the number of partitions variable filled when querying + * + * This is the boot time function that executes the FFA_PARTITION_INFO_GET + * to query the partitions data. Then, it calls ffa_read_partitions_info + * to save the data in the private data structure. + * + * After reading the data the RX buffer is released using ffa_release_rx_buffer + * + * Return: + * + * When part_uuid is NULL, all partitions data are retrieved from secure world + * When part_uuid is non NULL, data for partitions matching the given UUID are + * retrieved and the number of partitions is returned + * FFA_ERR_STAT_SUCCESS is returned on success. Otherwise, failure + */ +static int ffa_query_partitions_info(union ffa_partition_uuid *part_uuid, + u32 *pcount) +{ + union ffa_partition_uuid query_uuid = {0}; + ffa_value_t res = {0}; + + if (!ffa_priv_data->invoke_ffa_fn) + panic("[FFA] no private data found\n"); + + /* + * If a UUID is specified. Information for one or more + * partitions in the system is queried. Otherwise, information + * for all installed partitions is queried + */ + + if (part_uuid) { + if (!pcount) + return -EINVAL; + + query_uuid = *part_uuid; + } + + ffa_priv_data->invoke_ffa_fn((ffa_value_t){ + .a0 = FFA_PARTITION_INFO_GET, + .a1 = query_uuid.words.a1, + .a2 = query_uuid.words.a2, + .a3 = query_uuid.words.a3, + .a4 = query_uuid.words.a4, + .a5 = 0, + .a6 = 0, + .a7 = 0, + }, &res); + + switch (res.a0) { + case FFA_ERROR: + { + switch (((int)res.a2)) { + case FFA_ERR_STAT_INVALID_PARAMETERS: + ffa_err("Unrecognized UUID"); + return -EPERM; + case FFA_ERR_STAT_NO_MEMORY: + ffa_err("Results cannot fit in RX buffer of the caller"); + return -ENOMEM; + case FFA_ERR_STAT_DENIED: + ffa_err("Callee is not in a state to handle this request"); + return -EACCES; + case FFA_ERR_STAT_NOT_SUPPORTED: + ffa_err("This function is not implemented at this FF-A instance"); + return -EOPNOTSUPP; + case FFA_ERR_STAT_BUSY: + ffa_err("RX buffer of the caller is not free"); + return -EBUSY; + default: + ffa_err("Undefined error (%d)", ((int)res.a2)); + return -EINVAL; + } + } + case FFA_SUCCESS: + { + int ret; + + /* + * res.a2 contains the count of partition information descriptors + * populated in the RX buffer + */ + if (res.a2) { + ret = ffa_read_partitions_info((u32)res.a2, part_uuid); + if (ret) + ffa_err("Failed to read partition(s) data , error (%d)", ret); + } + + /* + * return the SP count + */ + if (part_uuid) { + if (!ret) + *pcount = (u32)res.a2; + else + *pcount = 0; + } + /* + * After calling FFA_PARTITION_INFO_GET the buffer ownership + * is assigned to the consumer (u-boot). So, we need to give + * the ownership back to the SPM or hypervisor + */ + ret = ffa_release_rx_buffer(); + + if (!part_uuid && !res.a2) { + ffa_err("[FFA] no partition installed in the system"); + return -ENODEV; + } + + return ret; + } + default: + ffa_err("Undefined response function (0x%lx)", res.a0); + return -EINVAL; + } +} + +/** + * ffa_get_partitions_info - FFA_PARTITION_INFO_GET handler function + * + * The passed arguments: + * Mode 1: When getting from the driver the number of + * secure partitions: + * @uuid_str: pointer to the UUID string + * @parts_size: pointer to the variable that contains the number of partitions + * The variable will be set by the driver + * @buffer: NULL + * + * Mode 2: When requesting the driver to return the + * partitions information: + * @uuid_str: pointer to the UUID string + * @parts_size: pointer to the size of the SPs information buffer in bytes + * @buffer: pointer to SPs information buffer + * (allocated by the client). + * The buffer will be filled by the driver + * + * This is the boot time function that queries the secure partition data from + * the private data structure. If not found, it invokes FFA_PARTITION_INFO_GET + * FF-A function to query the partition information from secure world. + * + * A client of the FF-A driver should know the UUID of the service it wants to + * access. It should use the UUID to request the FF-A driver to provide the + * partition(s) information of the service. The FF-A driver uses + * PARTITION_INFO_GET to obtain this information. This is implemented through + * ffa_get_partitions_info function. + * A new FFA_PARTITION_INFO_GET call is issued (first one performed through + * ffa_cache_partitions_info) allowing to retrieve the partition(s) information. + * They are not saved (already done). We only update the UUID in the cached area. + * This assumes that partitions data does not change in the secure world. + * Otherwise u-boot will have an outdated partition data. The benefit of caching + * the information in the FF-A driver is to accommodate discovery after + * ExitBootServices(). + * + * When invoked through a client request, ffa_get_partitions_info should be + * called twice. First call is to get from the driver the number of secure + * partitions (SPs) associated to a particular UUID. + * Then, the caller (client) allocates the buffer to host the SPs data and + * issues a 2nd call. Then, the driver fills the SPs data in the pre-allocated + * buffer. + * + * To achieve the mechanism described above, ffa_get_partitions_info uses the + * following functions: + * ffa_read_partitions_info + * ffa_query_partitions_info + * + * Return: + * + * @parts_size: When pointing to the number of partitions variable, the number is + * set by the driver. + * When pointing to the partitions information buffer size, the buffer will be + * filled by the driver. + * + * On success FFA_ERR_STAT_SUCCESS is returned. Otherwise, failure + */ +static int ffa_get_partitions_info(const char *uuid_str, + u32 *parts_size, struct ffa_partition_info *buffer) +{ + /* + * fill_data: + * 0: return the SP count + * 1: fill SP data and return it to the caller + * -1: undefined mode + */ + int fill_data = -1; + u32 desc_idx, client_desc_idx; + union ffa_partition_uuid part_uuid = {0}; + u32 client_desc_max_cnt; + u32 parts_found = 0; + + if (!ffa_priv_data->partitions.count || !ffa_priv_data->partitions.descs) + panic("[FFA] No partition installed\n"); + + if (!uuid_str) { + ffa_err("No UUID provided"); + return -EINVAL; + } + + if (!parts_size) { + ffa_err("No size/count provided"); + return -EINVAL; + } + + if (ffa_uuid_str_to_bin(uuid_str, (unsigned char *)&part_uuid)) { + ffa_err("Invalid UUID"); + return -EINVAL; + } + + if (!buffer) { + /* Mode 1: getting the number of secure partitions */ + + fill_data = 0; + + ffa_info("Preparing for checking partitions count"); + + } else if ((*parts_size >= sizeof(struct ffa_partition_info)) && + !(*parts_size % sizeof(struct ffa_partition_info))) { + /* Mode 2: retrieving the partitions information */ + + fill_data = 1; + + client_desc_idx = 0; + + /* + * number of empty descriptors preallocated by the caller + */ + client_desc_max_cnt = *parts_size / sizeof(struct ffa_partition_info); + + ffa_info("Preparing for filling partitions info"); + + } else { + ffa_err("Invalid function arguments provided"); + return -EINVAL; + } + + ffa_info("Searching partitions using the provided UUID"); + + /* + * search in the cached partitions + */ + for (desc_idx = 0; + desc_idx < ffa_priv_data->partitions.count; + desc_idx++) { + if (ffa_uuid_are_identical(&ffa_priv_data->partitions.descs[desc_idx].UUID, + &part_uuid)) { + ffa_info("Partition ID %x matches the provided UUID", + ffa_priv_data->partitions.descs[desc_idx].info.id); + + parts_found++; + + if (fill_data) { + /* + * trying to fill the partition info in the input buffer + */ + + if (client_desc_idx < client_desc_max_cnt) { + buffer[client_desc_idx++] = + ffa_priv_data->partitions.descs[desc_idx].info; + continue; + } + + ffa_err("Failed to fill the current descriptor client buffer full"); + return -ENOBUFS; + } + } + } + + if (!parts_found) { + int ret; + + ffa_info("No partition found. Querying framework ..."); + + ret = ffa_query_partitions_info(&part_uuid, &parts_found); + + if (ret == FFA_ERR_STAT_SUCCESS) { + if (!fill_data) { + *parts_size = parts_found; + + ffa_info("Number of partition(s) found matching the UUID: %d", + parts_found); + } else { + /* + * If SPs data detected, they are already in the private data + * structure, retry searching SP data again to return them + * to the caller + */ + if (parts_found) + ret = ffa_get_partitions_info(uuid_str, parts_size, buffer); + else + ret = -ENODATA; + } + } + + return ret; + } + + /* partition(s) found */ + if (!fill_data) + *parts_size = parts_found; + + return FFA_ERR_STAT_SUCCESS; +} + +/** + * ffa_cache_partitions_info - Queries and saves all secure partitions data + * + * This is a boot time function that invokes FFA_PARTITION_INFO_GET FF-A + * function to query from secure world all partitions information. + * + * The FFA_PARTITION_INFO_GET call is issued with nil UUID as an argument. + * All installed partitions information are returned. We cache them in the + * resident private data structure and we keep the UUID field empty + * (in FF-A 1.0 UUID is not provided by the partition descriptor) + * + * This function is called at the device probing level. + * ffa_cache_partitions_info uses ffa_query_partitions_info to get the data + * + * Return: + * + * FFA_ERR_STAT_SUCCESS on success. Otherwise, failure + */ +static int ffa_cache_partitions_info(void) +{ + return ffa_query_partitions_info(NULL, NULL); +} + +/** + * ffa_msg_send_direct_req - FFA_MSG_SEND_DIRECT_{REQ,RESP} handler function + * @dst_part_id: destination partition ID + * @msg: pointer to the message data preallocated by the client (in/out) + * + * This is the runtime function that implements FFA_MSG_SEND_DIRECT_{REQ,RESP} + * FF-A functions. + * + * FFA_MSG_SEND_DIRECT_REQ is used to send the data to the secure partition. + * The response from the secure partition is handled by reading the + * FFA_MSG_SEND_DIRECT_RESP arguments. + * + * The maximum size of the data that can be exchanged is 40 bytes which is + * sizeof(struct ffa_send_direct_data) as defined by the FF-A specification 1.0 + * in the section relevant to FFA_MSG_SEND_DIRECT_{REQ,RESP} + * + * Return: + * + * FFA_ERR_STAT_SUCCESS on success. Otherwise, failure + */ +static int __ffa_runtime ffa_msg_send_direct_req(u16 dst_part_id, struct ffa_send_direct_data *msg) +{ + ffa_value_t res = {0}; + + if (!ffa_priv_data->invoke_ffa_fn) + return -ENODEV; + + /* No partition installed */ + if (!ffa_priv_data->partitions.count || !ffa_priv_data->partitions.descs) + return -ENODEV; + + ffa_priv_data->invoke_ffa_fn((ffa_value_t){ + .a0 = FFA_MSG_SEND_DIRECT_REQ, + .a1 = PREP_SELF_ENDPOINT_ID(ffa_priv_data->id) | + PREP_PART_ENDPOINT_ID(dst_part_id), + .a2 = 0, + .a3 = msg->data0, + .a4 = msg->data1, + .a5 = msg->data2, + .a6 = msg->data3, + .a7 = msg->data4, + }, &res); + + while (res.a0 == FFA_INTERRUPT) + ffa_priv_data->invoke_ffa_fn((ffa_value_t){ + .a0 = FFA_RUN, + .a1 = res.a1, .a2 = 0, .a3 = 0, .a4 = 0, .a5 = 0, .a6 = 0, .a7 = 0, + }, &res); + + switch (res.a0) { + case FFA_ERROR: + { + switch (((int)res.a2)) { + case FFA_ERR_STAT_INVALID_PARAMETERS: + /* Invalid endpoint ID or non-zero reserved register */ + return -EPERM; + case FFA_ERR_STAT_ABORTED: + /* Message target ran into unexpected error and has aborted */ + return -ECONNABORTED; + case FFA_ERR_STAT_DENIED: + /* Callee is not in a state to handle this request */ + return -EACCES; + case FFA_ERR_STAT_NOT_SUPPORTED: + /* This function is not implemented at this FF-A instance */ + return -EOPNOTSUPP; + case FFA_ERR_STAT_BUSY: + /* Message target is busy */ + return -EBUSY; + default: + /* Undefined error */ + return -ENXIO; + } + } + case FFA_SUCCESS: + + /* Message sent with no response */ + return FFA_ERR_STAT_SUCCESS; + + case FFA_MSG_SEND_DIRECT_RESP: + /* + * Message sent with response + * extract the return data + */ + msg->data0 = res.a3; + msg->data1 = res.a4; + msg->data2 = res.a5; + msg->data3 = res.a6; + msg->data4 = res.a7; + + return FFA_ERR_STAT_SUCCESS; + + default: + /* Undefined response function */ + return -ENOENT; + } +} + +/** + * __arm_ffa_fn_smc - SMC wrapper + * + * Calls low level SMC function + * + * Return: void + */ +void __ffa_runtime __arm_ffa_fn_smc(ffa_value_t args, ffa_value_t *res) +{ + arm_smccc_1_2_smc(&args, res); +} + +/** + * ffa_set_conduit - Set the conduit + * + * This boot time function clears the private data structure and sets the conduit + * + * Return: + * + * FFA_ERR_STAT_SUCCESS on success. Otherwise, failure + */ +static int ffa_set_conduit(void) +{ + ffa_priv_data->invoke_ffa_fn = __arm_ffa_fn_smc; + + ffa_info("Conduit is SMC"); + + return FFA_ERR_STAT_SUCCESS; +} + +/** + * ffa_set_bus_ops - Set the bus driver operations + * + * Setting the driver callbacks. + * + */ +static void ffa_set_bus_ops(void) +{ + ffa_priv_data->ffa_ops.partition_info_get = ffa_get_partitions_info; + ffa_priv_data->ffa_ops.sync_send_receive = ffa_msg_send_direct_req; + ffa_priv_data->ffa_ops.rxtx_unmap = ffa_unmap_rxtx_buffers; +} + +/** + * ffa_alloc_prvdata - allocate the driver main data structure + * @dev: the arm_ffa device + * + * This boot time function creates the main data structure embedding all the driver data. + * + * Return: + * + * FFA_ERR_STAT_SUCCESS on success. Otherwise, failure + */ +static int ffa_alloc_prvdata(struct udevice *dev) +{ + if (!dev) + return -ENODEV; + + /* The device is registered with the DM. Let's create the driver main data structure*/ + + ffa_priv_data = devm_kmalloc(dev, sizeof(struct ffa_prvdata), __GFP_ZERO); + if (!ffa_priv_data) { + ffa_err("can not allocate the driver main data structure"); + return -ENOMEM; + } + + ffa_priv_data->dev = dev; + + return FFA_ERR_STAT_SUCCESS; +} + +/** + * ffa_probe - The driver probe function + * @dev: the arm_ffa device + * + * Probing is done at boot time and triggered by the uclass device discovery. + * At probe level the following actions are done: + * - setting the conduit + * - querying the FF-A framework version + * - querying from secure world the u-boot endpoint ID + * - querying from secure world the supported features of the specified FF-A calls + * - mapping the RX/TX buffers + * - querying from secure world all the partitions information + * + * All data queried from secure world is saved in the resident private data structure. + * + * The probe will fail if either FF-A framework is not detected or the + * FF-A requests are not behaving correctly. This ensures that the + * driver is not installed and its operations are not exported to the clients. + * However, once the driver is successfully probed and an FF-A anomaly is + * detected when clients invoke the driver operations, the driver cause + * u-boot to panic because the client would not know what to do in such conditions. + * + * Return: + * + * FFA_ERR_STAT_SUCCESS on success. Otherwise, failure + */ +static int ffa_probe(struct udevice *dev) +{ + int ret; + size_t buf_4k_pages = 0; + + ret = ffa_alloc_prvdata(dev); + if (ret != FFA_ERR_STAT_SUCCESS) + return ret; + + ffa_set_bus_ops(); + + ret = ffa_set_conduit(); + if (ret != FFA_ERR_STAT_SUCCESS) + return ret; + + ret = ffa_get_version(); + if (ret != FFA_ERR_STAT_SUCCESS) + return ret; + + ret = ffa_get_endpoint_id(); + if (ret != FFA_ERR_STAT_SUCCESS) + return ret; + + ret = ffa_get_rxtx_map_features(); + if (ret != FFA_ERR_STAT_SUCCESS) + return ret; + + ret = ffa_get_rxtx_buffers_pages_cnt(&buf_4k_pages); + if (ret != FFA_ERR_STAT_SUCCESS) + return ret; + + ret = ffa_map_rxtx_buffers(buf_4k_pages); + if (ret != FFA_ERR_STAT_SUCCESS) + return ret; + + ret = ffa_cache_partitions_info(); + if (ret != FFA_ERR_STAT_SUCCESS) { + ffa_free_rxtx_buffers(); + return ret; + } + + return FFA_ERR_STAT_SUCCESS; +} + +/** + * ffa_bus_ops_get - bus driver operations getter + * + * Return: + * This runtime function returns a pointer to the driver operations structure + */ +const struct ffa_bus_ops * __ffa_runtime ffa_bus_ops_get(void) +{ + return &ffa_priv_data->ffa_ops; +} + +/** + * ffa_bus_prvdata_get - bus driver private data getter + * + * Return: + * This boot time function returns a pointer to the main private data structure + */ +struct ffa_prvdata **ffa_bus_prvdata_get(void) +{ + return &ffa_priv_data; +} + +/** + * ffa_bus_discover - discover FF-A bus and probe the arm_ffa device + * + * This boot time function makes sure the FF-A bus is discoverable. + * Then, the arm_ffa device is probed and ready to use. + * This function is called automatically at initcalls + * level (after u-boot relocation). + * + * Arm FF-A transport is implemented through arm_ffa u-boot device managing the FF-A + * communication. + * All FF-A clients should use the arm_ffa device to use the FF-A transport. + * + * Return: + * + * FFA_ERR_STAT_SUCCESS on success. Otherwise, failure + */ +int ffa_bus_discover(void) +{ + return ffa_device_get(); +} + +/** + * Declaring the arm_ffa driver under UCLASS_FFA + */ + +U_BOOT_DRIVER(arm_ffa) = { + .name = FFA_DRV_NAME, + .id = UCLASS_FFA, + .probe = ffa_probe, +}; diff --git a/drivers/arm-ffa/efi_ffa_runtime_data_mgr.c b/drivers/arm-ffa/efi_ffa_runtime_data_mgr.c new file mode 100644 index 0000000000..942601a7ba --- /dev/null +++ b/drivers/arm-ffa/efi_ffa_runtime_data_mgr.c @@ -0,0 +1,94 @@ +// SPDX-License-Identifier: GPL-2.0+ +/* + * (C) Copyright 2022 ARM Limited + * Abdellatif El Khlifi abdellatif.elkhlifi@arm.com + */ + +#include "arm_ffa_prv.h" + +/** + * ffa_copy_runtime_data - copy the private data structure to the runtime area + * + * This boot time function copies the arm_ffa driver data structures including + * partitions data to the EFI runtime data section. + * + * Return: + * + * FFA_ERR_STAT_SUCCESS on success. Otherwise, failure + */ +efi_status_t ffa_copy_runtime_data(void) +{ + efi_status_t efi_ret; + efi_uintn_t prvdata_pages; + efi_uintn_t descs_pages; + struct ffa_prvdata **prvdata = NULL; /* Pointer to the current structure */ + struct ffa_prvdata *runtime_prvdata = NULL; /* Pointer to the structure runtime copy */ + u64 runtime_descs = 0; + + prvdata = ffa_bus_prvdata_get(); + + printf("INFO: EFI: FFA: prv data area at 0x%llx\n", (u64)prvdata); + + /* allocate private data runtime area */ + + prvdata_pages = efi_size_in_pages(sizeof(struct ffa_prvdata)); + efi_ret = efi_allocate_pages(EFI_ALLOCATE_ANY_PAGES, + EFI_RUNTIME_SERVICES_DATA, + prvdata_pages, + (u64 *)&runtime_prvdata); + + if (efi_ret != EFI_SUCCESS) { + printf("ERROR: EFI: FFA: allocating runtime data (err: 0x%lx, addr 0x%llx)\n", + efi_ret, (u64)runtime_prvdata); + + return efi_ret; + } + + printf("INFO: EFI: FFA: runtime data area at 0x%llx\n", (u64)runtime_prvdata); + + if (!runtime_prvdata) + return EFI_INVALID_PARAMETER; + + /* allocate the partition data runtime area */ + + descs_pages = efi_size_in_pages((*prvdata)->partitions.count * + sizeof(struct ffa_partition_desc)); + efi_ret = efi_allocate_pages(EFI_ALLOCATE_ANY_PAGES, + EFI_RUNTIME_SERVICES_DATA, + descs_pages, + &runtime_descs); + + if (efi_ret != EFI_SUCCESS) { + printf("ERROR: EFI: FFA: allocating runtime SPs data (err: 0x%lx, addr 0x%llx)\n", + efi_ret, runtime_descs); + + efi_free_pages((u64)runtime_prvdata, prvdata_pages); + + return efi_ret; + } + + printf("INFO: EFI: FFA: SPs runtime area at 0x%llx\n", (u64)runtime_descs); + + if (!runtime_descs) + return EFI_INVALID_PARAMETER; + + *runtime_prvdata = **prvdata; + + runtime_prvdata->dev = NULL; + runtime_prvdata->ffa_ops.partition_info_get = NULL; + runtime_prvdata->ffa_ops.rxtx_unmap = NULL; + runtime_prvdata->partitions.descs = (struct ffa_partition_desc *)runtime_descs; + runtime_prvdata->pair.rxbuf = 0; + runtime_prvdata->pair.txbuf = 0; + + /* + * Update the private data structure pointer in the driver + * no need to free the old structure. devm takes care of that + */ + *prvdata = runtime_prvdata; + + printf("INFO: EFI: FFA: runtime prv data now at 0x%llx , SPs count %d\n", + (u64)*prvdata, (*prvdata)->partitions.count); + + return FFA_ERR_STAT_SUCCESS; +} diff --git a/include/arm_ffa.h b/include/arm_ffa.h new file mode 100644 index 0000000000..ee9ce2d99d --- /dev/null +++ b/include/arm_ffa.h @@ -0,0 +1,132 @@ +/* SPDX-License-Identifier: GPL-2.0+ */ +/* + * (C) Copyright 2022 ARM Limited + * Abdellatif El Khlifi abdellatif.elkhlifi@arm.com + */ + +#ifndef __ARM_FFA_H +#define __ARM_FFA_H + +#include <linux/printk.h> + +/* + * This header is public. It can be used by clients to access + * data structures and definitions they need + */ + +/* + * Macros for displaying logs + */ + +#define ffa_info(fmt, ...) pr_info("[FFA] " fmt "\n", ##__VA_ARGS__) +#define ffa_err(fmt, ...) pr_err("[FFA] " fmt "\n", ##__VA_ARGS__) + +/* + * The driver operations success error code + */ +#define FFA_ERR_STAT_SUCCESS (0) + +/* + * struct ffa_partition_info - Partition information descriptor + * @id: Partition ID + * @exec_ctxt: Execution context count + * @properties: Partition properties + * + * Data structure containing information about partitions instantiated in the system + * This structure is filled with the data queried by FFA_PARTITION_INFO_GET + */ +struct __packed ffa_partition_info { + u16 id; + u16 exec_ctxt; +/* partition supports receipt of direct requests */ +#define FFA_PARTITION_DIRECT_RECV BIT(0) +/* partition can send direct requests. */ +#define FFA_PARTITION_DIRECT_SEND BIT(1) +/* partition can send and receive indirect messages. */ +#define FFA_PARTITION_INDIRECT_MSG BIT(2) + u32 properties; +}; + +/* + * struct ffa_send_direct_data - Data structure hosting the data + * used by FFA_MSG_SEND_DIRECT_{REQ,RESP} + * @data0-4: Data read/written from/to x3-x7 registers + * + * Data structure containing the data to be sent by FFA_MSG_SEND_DIRECT_REQ + * or read from FFA_MSG_SEND_DIRECT_RESP + */ + +/* For use with FFA_MSG_SEND_DIRECT_{REQ,RESP} which pass data via registers */ +struct __packed ffa_send_direct_data { + unsigned long data0; /* w3/x3 */ + unsigned long data1; /* w4/x4 */ + unsigned long data2; /* w5/x5 */ + unsigned long data3; /* w6/x6 */ + unsigned long data4; /* w7/x7 */ +}; + +#if CONFIG_IS_ENABLED(ARM_FFA_EFI_RUNTIME_MODE) + +#include <efi_loader.h> + +/* + * __ffa_runtime - controls whether functions are + * available after calling the EFI ExitBootServices service. + * Functions tagged with these keywords are resident (available at boot time and + * at runtime) + */ + +#define __ffa_runtime_data __efi_runtime_data +#define __ffa_runtime __efi_runtime + +#else + +/* + * The FF-A driver is independent from EFI + */ + +#define __ffa_runtime_data +#define __ffa_runtime + +#endif + +/** + * struct ffa_bus_ops - The driver operations structure + * @partition_info_get: callback for the FFA_PARTITION_INFO_GET + * @sync_send_receive: callback for the FFA_MSG_SEND_DIRECT_REQ + * @rxtx_unmap: callback for the FFA_RXTX_UNMAP + * + * The data structure providing all the operations supported by the driver. + * This structure is EFI runtime resident. + */ +struct ffa_bus_ops { + int (*partition_info_get)(const char *uuid_str, + u32 *parts_size, struct ffa_partition_info *buffer); + int (*sync_send_receive)(u16 dst_part_id, struct ffa_send_direct_data *msg); + int (*rxtx_unmap)(void); +}; + +/** + * The device driver and the Uclass driver public functions + */ + +/** + * ffa_bus_ops_get - driver operations getter + */ +const struct ffa_bus_ops * __ffa_runtime ffa_bus_ops_get(void); + +/** + * ffa_bus_discover - discover FF-A bus and probes the arm_ffa device + */ +int ffa_bus_discover(void); + +#if CONFIG_IS_ENABLED(ARM_FFA_EFI_RUNTIME_MODE) + +/** + * ffa_copy_runtime_data - copy the private data structure and the SPs data to the runtime area + */ +efi_status_t ffa_copy_runtime_data(void); + +#endif + +#endif diff --git a/include/dm/uclass-id.h b/include/dm/uclass-id.h index a432e43871..6eebbe9c7d 100644 --- a/include/dm/uclass-id.h +++ b/include/dm/uclass-id.h @@ -55,6 +55,7 @@ enum uclass_id { UCLASS_EFI_MEDIA, /* Devices provided by UEFI firmware */ UCLASS_ETH, /* Ethernet device */ UCLASS_ETH_PHY, /* Ethernet PHY device */ + UCLASS_FFA, /* Arm Firmware Framework for Armv8-A */ UCLASS_FIRMWARE, /* Firmware */ UCLASS_FUZZING_ENGINE, /* Fuzzing engine */ UCLASS_FS_FIRMWARE_LOADER, /* Generic loader */ diff --git a/include/uuid.h b/include/uuid.h index 4a4883d3b5..789f8e0f15 100644 --- a/include/uuid.h +++ b/include/uuid.h @@ -44,4 +44,12 @@ int uuid_guid_get_bin(const char *guid_str, unsigned char *guid_bin); const char *uuid_guid_get_str(const unsigned char *guid_bin); void gen_rand_uuid(unsigned char *uuid_bin); void gen_rand_uuid_str(char *uuid_str, int str_format); + +#ifdef CONFIG_ARM_FFA_TRANSPORT +/** + * ffa_uuid_str_to_bin - Converts a big endian UUID string to a little endian buffer + */ +int ffa_uuid_str_to_bin(const char *uuid_str, unsigned char *uuid_bin); +#endif + #endif diff --git a/lib/efi_loader/efi_boottime.c b/lib/efi_loader/efi_boottime.c index 4da64b5d29..e02bb445f5 100644 --- a/lib/efi_loader/efi_boottime.c +++ b/lib/efi_loader/efi_boottime.c @@ -23,6 +23,10 @@ #include <asm/setjmp.h> #include <linux/libfdt_env.h>
+#if defined(CONFIG_ARM_FFA_TRANSPORT) +#include <arm_ffa.h> +#endif + DECLARE_GLOBAL_DATA_PTR;
/* Task priority level */ @@ -2113,6 +2117,10 @@ static efi_status_t EFIAPI efi_exit_boot_services(efi_handle_t image_handle, struct efi_event *evt, *next_event; efi_status_t ret = EFI_SUCCESS;
+#if defined(CONFIG_ARM_FFA_TRANSPORT) + int ffa_ret; +#endif + EFI_ENTRY("%p, %zx", image_handle, map_key);
/* Check that the caller has read the current memory map */ @@ -2173,6 +2181,15 @@ static efi_status_t EFIAPI efi_exit_boot_services(efi_handle_t image_handle, dm_remove_devices_flags(DM_REMOVE_ACTIVE_ALL); }
+#if defined(CONFIG_ARM_FFA_TRANSPORT) + /* unmap FF-A RX/TX buffers */ + ffa_ret = ffa_bus_ops_get()->rxtx_unmap(); + if (ffa_ret) + debug("[efi_boottime][ERROR]: can not unmap FF-A RX/TX buffers\n"); + else + debug("[efi_boottime][INFO]: FF-A RX/TX buffers unmapped\n"); +#endif + /* Patch out unsupported runtime function */ efi_runtime_detach();
diff --git a/lib/uuid.c b/lib/uuid.c index 284f8113ff..50b3e61d59 100644 --- a/lib/uuid.c +++ b/lib/uuid.c @@ -1,6 +1,7 @@ // SPDX-License-Identifier: GPL-2.0+ /* * Copyright 2011 Calxeda, Inc. + * Copyright 2022 ARM Limited */
#include <common.h> @@ -342,6 +343,70 @@ int uuid_str_to_bin(const char *uuid_str, unsigned char *uuid_bin, return 0; }
+#ifdef CONFIG_ARM_FFA_TRANSPORT +/** + * ffa_uuid_str_to_bin - Converts a big endian UUID string to a little endian buffer + * @uuid_str: UUID string in big endian format (36 bytes wide + '/0') + * @uuid_bin: preallocated 16 bytes UUID buffer in little endian format + * + * UUID string is 36 characters (36 bytes): + * + * xxxxxxxx-xxxx-xxxx-xxxx-xxxxxxxxxxxx + * be be be be be + * + * where x is a hexadecimal character. Fields are separated by '-'s. + * When converting to a binary UUID, these endianness rules apply: + * be: means the field in the string is considered a big endian hex number + * and should be converted to little endian binary format + * + * Return: + * + * uuid_bin filled with little endian UUID data + * On success 0 is returned. Otherwise, failure code. + */ +int ffa_uuid_str_to_bin(const char *uuid_str, unsigned char *uuid_bin) +{ + u16 tmp16 = 0; + u32 tmp32 = 0; + u64 tmp64 = 0; + + if (!uuid_str_valid(uuid_str) || !uuid_bin) + return -EINVAL; + + /* + * reverse bytes from big to little endian + */ + tmp32 = simple_strtoul(uuid_str, NULL, 16); + memcpy(uuid_bin, &tmp32, 4); + + /* + * reverse bytes from big to little endian + */ + tmp16 = simple_strtoul(uuid_str + 9, NULL, 16); + memcpy(uuid_bin + 4, &tmp16, 2); + + /* + * reverse bytes from big to little endian + */ + tmp16 = simple_strtoul(uuid_str + 14, NULL, 16); + memcpy(uuid_bin + 6, &tmp16, 2); + + /* + * reverse bytes from big to little endian + */ + tmp16 = simple_strtoul(uuid_str + 19, NULL, 16); + memcpy(uuid_bin + 8, &tmp16, 2); + + /* + * reverse bytes from big to little endian + */ + tmp64 = simple_strtoull(uuid_str + 24, NULL, 16); + memcpy(uuid_bin + 10, (char *)&tmp64, 6); + + return 0; +} +#endif + /* * uuid_bin_to_str() - convert big endian binary data to string UUID or GUID. *
Hi Abdellatif,
On Mon, 1 Aug 2022 at 20:21, Abdellatif El Khlifi abdellatif.elkhlifi@arm.com wrote:
- sync_send_receive
- rxtx_unmap
select ARM_SMCCC
select LIB_UUID
select DEVRES
help
technology.
calling convention.
FF-A specification:
using the FF-A bus.
and Secure World.
help
Is there a reason we want to opt-in on that? What prevents it from always being there?
- Definitions of the Arm FF-A interfaces supported by the Arm FF-A driver
Please drop () on these
- union ffa_partition_uuid - Data union hosting the UUID
- @words: data structure giving 32-bit words access to the UUID data
- @bytes: data structure giving byte access to the UUID data
- The structure holds little-endian UUID data.
u32 a1; /* w1 */
u32 a2; /* w2 */
u32 a3; /* w3 */
u32 a4; /* w4 */
} words;
is the bytes field used anywhere?
- Each partition has its descriptor containing the partitions information and the UUID
lower case please and perhaps a better name e.g partition_uuid
- struct ffa_partitions - descriptors for all secure partitions
- @count: The number of partitions descriptors
- @descs The partitions descriptors table
- This data structure contains the partitions descriptors table
u32 count;
- struct ffa_prvdata - the driver private data structure
- @dev: The arm_ffa device under u-boot driver model
- @ffa_ops: The driver operations structure
- @fwk_version: FF-A framework version
- @id: u-boot endpoint ID
- @partitions: The partitions descriptors structure
- @pair: The RX/TX buffers pair
- @invoke_ffa_fn: The function executing the FF-A function
- @features: Table of the FF-A functions having features
- The driver data structure hosting all resident data.
u32 fwk_version;
u16 id;
- ffa_device_get - create, bind and probe the arm_ffa device
- ffa_bus_prvdata_get - bus driver private data getter
- (C) Copyright 2022 ARM Limited
- Abdellatif El Khlifi abdellatif.elkhlifi@arm.com
- The device private data structure containing all the resident
- data read from secure world
I think it's better if we just keep this as efi_runtime, especially since the rest of the declarations you use are marked as efi_*
- This boot time function makes sure the arm_ffa device is
- created, bound to this driver, probed and ready to use.
- Arm FF-A transport is implemented through a single u-boot
- device managing the FF-A bus (arm_ffa).
- Return:
- FFA_ERR_STAT_SUCCESS on success. Otherwise, failure
int ret;
FFA_DRV_NAME,
NULL,
ofnode_null(),
&dev);
if (ret)
return ret;
if (ret) {
return ret;
The return values in most of the functions are confusing. I think you should just get rid of FFA_ERR_STAT_SUCCESS and just return 0
Get rid of all the panicking please. We've discussed this on a previous email. Isn't an error message enough?
- ffa_map_rxtx_buffers - FFA_RXTX_MAP handler function
- @buf_4k_pages: the minimum number of pages in each of the RX/TX
buffers
- This is the boot time function that implements FFA_RXTX_MAP FF-A function
- to map the RX/TX buffers
- Return:
int ret;
return ret;
.a0 = FFA_RXTX_MAP,
.a3 = buf_4k_pages,
}, &res);
switch (res.a0) {
case FFA_ERROR:
There are comments in v2 that are ignored throughout the patchset. Please check the remarks in v2 before sending a new patchset
ret = -EPERM;
break;
ret = -ENOMEM;
break;
ret = -EACCES;
break;
ret = -EOPNOTSUPP;
break;
default:
((int)res.a2));
ret = -EINVAL;
break;
case FFA_SUCCESS:
default:
res.a0);
ret = -EINVAL;
return ret;
Regards /Ilias
- Declaring the arm_ffa driver under UCLASS_FFA
.id = UCLASS_FFA,
.probe = ffa_probe,
- ffa_copy_runtime_data - copy the private data structure to the runtime area
- This boot time function copies the arm_ffa driver data structures including
- partitions data to the EFI runtime data section.
- Return:
prvdata_pages,
return efi_ret;
descs_pages,
&runtime_descs);
return efi_ret;
if (!runtime_descs)
- This header is public. It can be used by clients to access
- data structures and definitions they need
- Macros for displaying logs
- The driver operations success error code
- struct ffa_partition_info - Partition information descriptor
- @id: Partition ID
- @exec_ctxt: Execution context count
- @properties: Partition properties
- Data structure containing information about partitions instantiated in the system
- This structure is filled with the data queried by FFA_PARTITION_INFO_GET
u16 id;
u16 exec_ctxt;
u32 properties;
- struct ffa_send_direct_data - Data structure hosting the data
- @data0-4: Data read/written from/to x3-x7 registers
- Data structure containing the data to be sent by FFA_MSG_SEND_DIRECT_REQ
- or read from FFA_MSG_SEND_DIRECT_RESP
- __ffa_runtime - controls whether functions are
- available after calling the EFI ExitBootServices service.
- Functions tagged with these keywords are resident (available at boot time and
- at runtime)
+#else
- The FF-A driver is independent from EFI
- struct ffa_bus_ops - The driver operations structure
- @partition_info_get: callback for the FFA_PARTITION_INFO_GET
- @sync_send_receive: callback for the FFA_MSG_SEND_DIRECT_REQ
- @rxtx_unmap: callback for the FFA_RXTX_UNMAP
- The data structure providing all the operations supported by the driver.
- This structure is EFI runtime resident.
- The device driver and the Uclass driver public functions
- ffa_bus_ops_get - driver operations getter
- ffa_bus_discover - discover FF-A bus and probes the arm_ffa device
- ffa_copy_runtime_data - copy the private data structure and the SPs data to the runtime area
- ffa_uuid_str_to_bin - Converts a big endian UUID string to a little endian buffer
int ffa_ret;
EFI_ENTRY("%p, %zx", image_handle, map_key); /* Check that the caller has read the current memory map */
if (ffa_ret)
else
- Copyright 2011 Calxeda, Inc.
- Copyright 2022 ARM Limited
- @uuid_str: UUID string in big endian format (36 bytes wide + '/0')
- @uuid_bin: preallocated 16 bytes UUID buffer in little endian format
- UUID string is 36 characters (36 bytes):
- xxxxxxxx-xxxx-xxxx-xxxx-xxxxxxxxxxxx
- be be be be be
- where x is a hexadecimal character. Fields are separated by '-'s.
- When converting to a binary UUID, these endianness rules apply:
- Return:
- uuid_bin filled with little endian UUID data
- On success 0 is returned. Otherwise, failure code.
u16 tmp16 = 0;
u32 tmp32 = 0;
u64 tmp64 = 0;
return -EINVAL;
+} +#endif
- uuid_bin_to_str() - convert big endian binary data to string UUID or GUID.
-- 2.17.1
On Fri, Aug 12, 2022 at 10:39:23AM +0300, Ilias Apalodimas wrote:
Hi Abdellatif,
Add the driver implementing Arm Firmware Framework for Armv8-A v1.0
The Firmware Framework for Arm A-profile processors (FF-A) describes interfaces (ABIs) that standardize communication between the Secure World and Normal World leveraging TrustZone technology.
This driver uses 64-bit registers as per SMCCCv1.2 spec and comes on top of the SMCCC layer. The driver provides the FF-A ABIs needed for querying the FF-A framework from the secure world.
32-bit version of the ABIs is supported and 64-bit version of FFA_RXTX_MAP and FFA_MSG_SEND_DIRECT_{REQ, RESP}.
In u-boot FF-A design, FF-A is considered as a discoverable bus. The Secure World is considered as one entity to communicate with using the FF-A bus. FF-A communication is handled by one device and one instance (the bus). This FF-A driver takes care of all the interactions between Normal world and Secure World.
The driver exports its operations to be used by upper layers.
Exported operations:
- partition_info_get
- sync_send_receive
- rxtx_unmap
This implementation provides an optional feature to copy the driver data to EFI runtime area.
+config ARM_FFA_TRANSPORT
bool "Enable Arm Firmware Framework for Armv8-A driver"
depends on DM && ARM64
select ARM_SMCCC
select LIB_UUID
select DEVRES
help
technology.
This driver is based on FF-A specification v1.0 and uses SMC32
calling convention.
FF-A specification:
https://developer.arm.com/documentation/den0077/a/?lang=en
using the FF-A bus.
and Secure World.
+config ARM_FFA_EFI_RUNTIME_MODE
bool "Enable EFI runtime support for FF-A data and code "
depends on ARM_FFA_TRANSPORT && EFI_LOADER
help
Allows FF-A driver data structures and code to be accessible at EFI runtime
Yes, we agreed that FF-A driver needs to be independent from EFI. This is reflected in the v4 patchset. The intent is to be able to compile the core driver without EFI support. When using EFI, FF-A core driver data needs to be copied to the EFI runtime section so it can be accessed at runtime. For that specific case, CONFIG_ARM_FFA_EFI_RUNTIME_MODE has been created to enable the feature of copying the data to the runtime section. The code that copies the data is provided by drivers/firmware/arm-ffa/efi_ffa_runtime_data_mgr.c When EFI is needed CONFIG_ARM_FFA_EFI_RUNTIME_MODE should be turned on. If no EFI needed the FF-A driver can still be used independently.
+/* Endpoint ID mask (u-boot endpoint ID) */
+#define GET_SELF_ENDPOINT_ID_MASK GENMASK(15, 0) +#define GET_SELF_ENDPOINT_ID(x) \
((u16)(FIELD_GET(GET_SELF_ENDPOINT_ID_MASK, (x))))
+#define PREP_SELF_ENDPOINT_ID_MASK GENMASK(31, 16) +#define PREP_SELF_ENDPOINT_ID(x) \
(FIELD_PREP(PREP_SELF_ENDPOINT_ID_MASK, (x)))
+/* Partition endpoint ID mask (partition with which u-boot communicates with) */
+#define PREP_PART_ENDPOINT_ID_MASK GENMASK(15, 0) +#define PREP_PART_ENDPOINT_ID(x) \
(FIELD_PREP(PREP_PART_ENDPOINT_ID_MASK, (x)))
+#define FFA_SMC(calling_convention, func_num) \
ARM_SMCCC_CALL_VAL(ARM_SMCCC_FAST_CALL, (calling_convention), \
ARM_SMCCC_OWNER_STANDARD, (func_num))
+#define FFA_SMC_32(func_num) FFA_SMC(ARM_SMCCC_SMC_32, (func_num)) +#define FFA_SMC_64(func_num) FFA_SMC(ARM_SMCCC_SMC_64, (func_num))
+#define FFA_VERSION FFA_SMC_32(0x63) +#define FFA_ID_GET FFA_SMC_32(0x69) +#define FFA_FEATURES FFA_SMC_32(0x64) +#define FFA_PARTITION_INFO_GET FFA_SMC_32(0x68) +#define FFA_RXTX_UNMAP FFA_SMC_32(0x67) +#define FFA_RX_RELEASE FFA_SMC_32(0x65) +#define FFA_RUN FFA_SMC_32(0x6D) +#define FFA_ERROR FFA_SMC_32(0x60) +#define FFA_SUCCESS FFA_SMC_32(0x61) +#define FFA_INTERRUPT FFA_SMC_32(0x62) +#define FFA_RXTX_MAP FFA_SMC_64(0x66) +#define FFA_MSG_SEND_DIRECT_REQ FFA_SMC_64(0x6F) +#define FFA_MSG_SEND_DIRECT_RESP FFA_SMC_64(0x70)
+/* The FF-A SMC function definitions */
+typedef struct arm_smccc_1_2_regs ffa_value_t; +typedef void (*invoke_ffa_fn_t)(ffa_value_t args, ffa_value_t *res);
+/* FF-A error codes */ +#define FFA_ERR_STAT_NOT_SUPPORTED (-1) +#define FFA_ERR_STAT_INVALID_PARAMETERS (-2) +#define FFA_ERR_STAT_NO_MEMORY (-3) +#define FFA_ERR_STAT_BUSY (-4) +#define FFA_ERR_STAT_INTERRUPTED (-5) +#define FFA_ERR_STAT_DENIED (-6) +#define FFA_ERR_STAT_RETRY (-7) +#define FFA_ERR_STAT_ABORTED (-8)
+/* UUID data size */ +#define UUID_SIZE (16)
transmitted by FFA_PARTITION_INFO_GET
u32 a1; /* w1 */
u32 a2; /* w2 */
u32 a3; /* w3 */
u32 a4; /* w4 */
} words;
removed in v4. Please see https://lore.kernel.org/all/20220926101723.9965-5-abdellatif.elkhlifi@arm.co...
Done in v4.
u32 count;
u32 fwk_version;
u16 id;
In v4 the core driver is no longer dependent on EFI. The intent is to be able to compile it without EFI support. So, we can't use __efi_runtime* in the FFA driver when EFI is off.
__ffa_runtime* keywords are created in include/arm_ffa.h
Based on wether CONFIG_ARM_FFA_EFI_RUNTIME_MODE is on or off __ffa_runtime* are set to __efi_runtime* or kept empty if the config is off.
- Return:
int ret;
FFA_DRV_NAME,
NULL,
ofnode_null(),
&dev);
if (ret)
return ret;
if (ret) {
return ret;
Error handling and panics have been addressed in v4 patchset. As stated in the v3 cover letter, error handling and panics will be addressed in v4.
Please refer to this patch for the latest work: https://lore.kernel.org/all/20220926101723.9965-5-abdellatif.elkhlifi@arm.co...
buffers
- Return:
int ret;
return ret;
.a0 = FFA_RXTX_MAP,
.a3 = buf_4k_pages,
}, &res);
switch (res.a0) {
case FFA_ERROR:
ret = -EPERM;
break;
ret = -ENOMEM;
break;
ret = -EACCES;
break;
ret = -EOPNOTSUPP;
break;
default:
((int)res.a2));
ret = -EINVAL;
break;
case FFA_SUCCESS:
default:
res.a0);
ret = -EINVAL;
return ret;
Regards /Ilias
.id = UCLASS_FFA,
.probe = ffa_probe,
- Return:
prvdata_pages,
return efi_ret;
descs_pages,
&runtime_descs);
return efi_ret;
if (!runtime_descs)
- @id: Partition ID
u16 id;
u16 exec_ctxt;
u32 properties;
- at runtime)
+#else
int ffa_ret;
if (ffa_ret)
else
- be be be be be
- Return:
u16 tmp16 = 0;
u32 tmp32 = 0;
u64 tmp64 = 0;
return -EINVAL;
+} +#endif
-- 2.17.1
Hi Abdellatif,
On Mon, 1 Aug 2022 at 11:21, Abdellatif El Khlifi abdellatif.elkhlifi@arm.com wrote:
- sync_send_receive
- rxtx_unmap
This is v2 but I don't see a change list?
Signed-off-by: Abdellatif El Khlifi abdellatif.elkhlifi@arm.com Cc: Tom Rini trini@konsulko.com Cc: Ilias Apalodimas ilias.apalodimas@linaro.org Cc: Jens Wiklander jens.wiklander@linaro.org
MAINTAINERS | 6 + common/board_r.c | 7 + drivers/Kconfig | 2 + drivers/Makefile | 1 + drivers/arm-ffa/Kconfig | 33 + drivers/arm-ffa/Makefile | 7 + drivers/arm-ffa/arm-ffa-uclass.c | 16 + drivers/arm-ffa/arm_ffa_prv.h | 219 ++++ drivers/arm-ffa/core.c | 1338 ++++++++++++++++++++ drivers/arm-ffa/efi_ffa_runtime_data_mgr.c | 94 ++ include/arm_ffa.h | 132 ++ include/dm/uclass-id.h | 1 + include/uuid.h | 8 + lib/efi_loader/efi_boottime.c | 17 + lib/uuid.c | 65 + 15 files changed, 1946 insertions(+) create mode 100644 drivers/arm-ffa/Kconfig create mode 100644 drivers/arm-ffa/Makefile create mode 100644 drivers/arm-ffa/arm-ffa-uclass.c create mode 100644 drivers/arm-ffa/arm_ffa_prv.h create mode 100644 drivers/arm-ffa/core.c create mode 100644 drivers/arm-ffa/efi_ffa_runtime_data_mgr.c create mode 100644 include/arm_ffa.h
I think this should be in an existing directory, or perhaps drivers/firmware.
On Fri, Aug 12, 2022 at 08:21:02PM -0600, Simon Glass wrote:
Hi Abdellatif,
- sync_send_receive
- rxtx_unmap
Sorry for not including that in the cover letter. Here is the changelog for v2 [1].
From v3 upwards the changelog is included in the cover letter.
[1] https://lore.kernel.org/all/20220509105514.GA4201@e121910.cambridge.arm.com/
Done in v4 (under drivers/firmware).
- sync_send_receive
- rxtx_unmap
MAINTAINERS | 6 + common/board_r.c | 7 + drivers/Kconfig | 2 + drivers/Makefile | 1 + drivers/arm-ffa/Kconfig | 33 + drivers/arm-ffa/Makefile | 7 + drivers/arm-ffa/arm-ffa-uclass.c | 16 + drivers/arm-ffa/arm_ffa_prv.h | 219 ++++ drivers/arm-ffa/core.c | 1338 ++++++++++++++++++++ drivers/arm-ffa/efi_ffa_runtime_data_mgr.c | 94 ++ include/arm_ffa.h | 132 ++ include/dm/uclass-id.h | 1 + include/uuid.h | 8 + lib/efi_loader/efi_boottime.c | 17 + lib/uuid.c | 65 + 15 files changed, 1946 insertions(+) create mode 100644 drivers/arm-ffa/Kconfig create mode 100644 drivers/arm-ffa/Makefile create mode 100644 drivers/arm-ffa/arm-ffa-uclass.c create mode 100644 drivers/arm-ffa/arm_ffa_prv.h create mode 100644 drivers/arm-ffa/core.c create mode 100644 drivers/arm-ffa/.c create mode 100644 include/arm_ffa.h
Please add something to doc/ so people know what this is.
Since you are adding a new uclass you need a sandbox driver and tests.
The driver appears to have no operations, but there is a bus_ops. The ops should go in the driver, I suspect, and should pass the device as the first arg.
Can FFA_ERR_STAT_SUCCESS be 0 so you don't have to sprinkle the code with it?
Why is it using EFI things? Can this driver only be used with UEFI? I hope not, if it is an official way of updating firmware.
Please don't add more things to board_r.c - we are trying to remove this init over time. If it is a device it should be probed as needed.
Is there a device tree binding?
Also should this go in drivers/misc instead of creating a whole new subdir?
- sync_send_receive
- rxtx_unmap
Hi Simon, thanks for reviewing.
All the above comments have already been addressed in the new versions of the patchset. Please refer to the latest version v7 [1].
By the way I'd like to highlight the following:
- The FF-A driver documentation is at doc/arch/arm64.ffa.rst, please refer to it since it provides helpful details about the FF-A support in U-Boot - The patchset comes with Sandbox driver and tests [2] - The driver has operations defined in struct ffa_bus_ops (include/arm_ffa.h). ffa_bus_ops_get() gets the ops. All these are in the driver (drivers/firmware/arm-ffa/core.c) - The FF-A bus has only 1 device. No multiple instances. So passing the device doesn't make sense in our case - FFA_ERR_STAT_SUCCESS has been removed and replaced with 0 - The driver is independent from EFI and can be compiled without EFI - FF-A bus discovery has been removed from the initcall level (board_r.c) Discovery is done on demand. Clients can call ffa_bus_discover() when they want to use the FF-A bus. As an example of how clients initiate discovery please refer to the FF-A MM comms client [3]. - As done in the Linux kernel, the FF-A bus doesn't have a device tree binding since there is no peripheral associated with FF-A. At the early stages of this patchset, we double checked with the device tree maintainer and the decision was no device tree for FF-A - The links below are from the U-Boot mailing list mirror in lore.kernel.org
Cheers.
[1]: https://lore.kernel.org/all/20221107192055.21669-1-abdellatif.elkhlifi@arm.c... [2]: https://lore.kernel.org/all/20221107192055.21669-7-abdellatif.elkhlifi@arm.c... https://lore.kernel.org/all/20221107192055.21669-8-abdellatif.elkhlifi@arm.c... https://lore.kernel.org/all/20221107192055.21669-9-abdellatif.elkhlifi@arm.c... [3]: https://lore.kernel.org/all/20221107192055.21669-10-abdellatif.elkhlifi@arm....
On Wed, 16 Nov 2022 at 06:03, Abdellatif El Khlifi abdellatif.elkhlifi@arm.com wrote:
- sync_send_receive
- rxtx_unmap
OK
OK I suppose I saw that previously and forgot.
Can you please push a tree somewhere so I can look?
It must still pass the device.
OK
Oh, so what is ffa_copy_runtime_data() for?
Good.
Is there a command to do this?
Sorry, but you must add one.
Cheers.
https://lore.kernel.org/all/20221107192055.21669-8-abdellatif.elkhlifi@arm.com/ https://lore.kernel.org/all/20221107192055.21669-9-abdellatif.elkhlifi@arm.com/
- sync_send_receive
- rxtx_unmap
OK
OK, I'll share the link to a public branch so you can refer to once it's created.
I added this feature in patchset v8. Please refer to the latest patchset when reviewing [1].
[1]: https://lore.kernel.org/all/20221122131751.22747-1-abdellatif.elkhlifi@arm.c...
OK
This has already been dropped in newer versions of the pachset. Could you please refer to the latest ? (v8)
Good.
If you mean whether there is a command to showcase this, yes.
I already created the armffa command as an example of how to use the FF-A bus and how clients can discover it.
Please refer to this commit [1].
[1]: https://lore.kernel.org/all/20221122131751.22747-6-abdellatif.elkhlifi@arm.c...
We had a discussion on this on April 2022 with Rob Herring. We decided to do the same as the FF-A kernel driver: no device tree, we perform a manual bus discovery.
Rob Herring stated the following:
- There is not a 'kernel device tree' and a 'u-boot device tree'. There is only 1 - The FFA DT binding was rejected in favor of making FFA discoverable. The FFA spec was amended to address that. DT is only for what we failed to make discoverable. For hardware, we're stuck with it. We shouldn't repeat that for software interfaces.
For more details please refer to [1].
[1]: https://lore.kernel.org/all/CAL_Jsq+dwHqwDdALTAwU-VYW2=2kYCyHpv7mUP0zR04CwH1...
Cheers.
Hi Abdellatif,
On Tue, 22 Nov 2022 at 06:50, Abdellatif El Khlifi abdellatif.elkhlifi@arm.com wrote:
- sync_send_receive
- rxtx_unmap
OK
OK I will take a look at the latest.
Good.
OK. Rob and I will need to discuss this, but in the meantime, we should hold off on this series.
I am certainly not saying there should be two device trees. But there needs to be a binding for this thing.
Cheers.
Provide armffa command showcasing the use of the FF-A driver
The armffa command allows to query secure partitions data from the secure world and exchanging messages with the partitions.
Signed-off-by: Abdellatif El Khlifi abdellatif.elkhlifi@arm.com Cc: Tom Rini trini@konsulko.com Cc: Ilias Apalodimas ilias.apalodimas@linaro.org Cc: Jens Wiklander jens.wiklander@linaro.org --- MAINTAINERS | 1 + cmd/Kconfig | 10 ++ cmd/Makefile | 2 + cmd/armffa.c | 246 ++++++++++++++++++++++++++++++++++++++++ drivers/arm-ffa/Kconfig | 1 + 5 files changed, 260 insertions(+) create mode 100644 cmd/armffa.c
diff --git a/MAINTAINERS b/MAINTAINERS index 93a57f4df2..b0fbc027c2 100644 --- a/MAINTAINERS +++ b/MAINTAINERS @@ -251,6 +251,7 @@ F: configs/cortina_presidio-asic-pnand_defconfig ARM FF-A M: Abdellatif El Khlifi abdellatif.elkhlifi@arm.com S: Maintained +F: cmd/armffa.c F: drivers/arm-ffa/ F: include/arm_ffa.h
diff --git a/cmd/Kconfig b/cmd/Kconfig index a8260aa170..22f85188ff 100644 --- a/cmd/Kconfig +++ b/cmd/Kconfig @@ -902,6 +902,16 @@ endmenu
menu "Device access commands"
+config CMD_ARMFFA + bool "Arm FF-A test command" + depends on ARM_FFA_TRANSPORT + help + Provides a test command for the Arm FF-A driver + supported options: + - Listing the partition(s) info + - Sending a data pattern to the specified partition + - Displaying the arm_ffa device info + config CMD_ARMFLASH #depends on FLASH_CFI_DRIVER bool "armflash" diff --git a/cmd/Makefile b/cmd/Makefile index 5e43a1e022..e40f52f1e4 100644 --- a/cmd/Makefile +++ b/cmd/Makefile @@ -12,6 +12,8 @@ obj-y += panic.o obj-y += version.o
# command + +obj-$(CONFIG_CMD_ARMFFA) += armffa.o obj-$(CONFIG_CMD_ACPI) += acpi.o obj-$(CONFIG_CMD_ADDRMAP) += addrmap.o obj-$(CONFIG_CMD_AES) += aes.o diff --git a/cmd/armffa.c b/cmd/armffa.c new file mode 100644 index 0000000000..cb8a3d40aa --- /dev/null +++ b/cmd/armffa.c @@ -0,0 +1,246 @@ +// SPDX-License-Identifier: GPL-2.0+ +/* + * (C) Copyright 2022 ARM Limited + * Abdellatif El Khlifi abdellatif.elkhlifi@arm.com + */ + +#include <arm_ffa.h> +#include <asm/io.h> +#include <common.h> +#include <command.h> +#include <dm.h> +#include <mapmem.h> +#include <stdlib.h> + +/** + * do_ffa_get_singular_partition_info - implementation of the getpart subcommand + * @cmdtp: Command Table + * @flag: flags + * @argc: number of arguments + * @argv: arguments + * + * This function queries the secure partition information which the UUID is provided + * as an argument. The function uses the arm_ffa driver partition_info_get operation + * to retrieve the data. + * The input UUID string is expected to be in big endian format. + * + * Return: + * + * CMD_RET_SUCCESS: on success, otherwise failure + */ +static int do_ffa_get_singular_partition_info(struct cmd_tbl *cmdtp, int flag, int argc, + char *const argv[]) +{ + u32 count = 0, size = 0; + int ret; + struct ffa_partition_info *parts_info; + u32 info_idx; + + if (argc != 1) + return -EINVAL; + + /* Mode 1: getting the number of secure partitions */ + ret = ffa_bus_ops_get()->partition_info_get(argv[0], &count, NULL); + if (ret != FFA_ERR_STAT_SUCCESS) { + ffa_err("Failure in querying partitions count (error code: %d)", ret); + return ret; + } + + if (!count) { + ffa_info("No secure partition found"); + return ret; + } + + /* + * pre-allocate a buffer to be filled by the driver + * with ffa_partition_info structs + */ + + ffa_info("Pre-allocating %d partition(s) info structures", count); + + parts_info = calloc(count, sizeof(struct ffa_partition_info)); + if (!parts_info) + return -EINVAL; + + size = count * sizeof(struct ffa_partition_info); + + /* + * ask the driver to fill the buffer with the SPs info + */ + + ret = ffa_bus_ops_get()->partition_info_get(argv[0], &size, parts_info); + if (ret != FFA_ERR_STAT_SUCCESS) { + ffa_err("Failure in querying partition(s) info (error code: %d)", ret); + free(parts_info); + return ret; + } + + /* + * SPs found , show the partition information + */ + for (info_idx = 0; info_idx < count ; info_idx++) { + ffa_info("Partition: id = 0x%x , exec_ctxt 0x%x , properties 0x%x", + parts_info[info_idx].id, + parts_info[info_idx].exec_ctxt, + parts_info[info_idx].properties); + } + + free(parts_info); + + return 0; +} + +/** + * do_ffa_msg_send_direct_req - implementation of the ping subcommand + * @cmdtp: Command Table + * @flag: flags + * @argc: number of arguments + * @argv: arguments + * + * This function sends data to the secure partition which the ID is provided + * as an argument. The function uses the arm_ffa driver sync_send_receive operation + * to send data. + * + * Return: + * + * CMD_RET_SUCCESS: on success, otherwise failure + */ +int do_ffa_msg_send_direct_req(struct cmd_tbl *cmdtp, int flag, int argc, + char *const argv[]) +{ + struct ffa_send_direct_data msg = {0}; + u64 pattern = 0xaabbccddaabbccd0; + u16 part_id; + int ret; + + if (argc != 1) + return -EINVAL; + + errno = 0; + part_id = strtoul(argv[0], NULL, 16); + + if (errno) { + ffa_err("Invalid partition ID"); + return -EINVAL; + } + + /* + * filling the message data + */ + msg.data0 = ++pattern; + msg.data1 = ++pattern; + msg.data2 = ++pattern; + msg.data3 = ++pattern; + msg.data4 = ++pattern; + + ret = ffa_bus_ops_get()->sync_send_receive(part_id, &msg); + if (ret == FFA_ERR_STAT_SUCCESS) { + u8 cnt; + + ffa_info("SP response:\n[LSB]"); + for (cnt = 0; + cnt < sizeof(struct ffa_send_direct_data) / sizeof(u64); + cnt++) + ffa_info("0x%llx", ((u64 *)&msg)[cnt]); + } else { + ffa_err("Sending direct request error (%d)", ret); + } + + return ret; +} + +/** + *do_ffa_dev_list - implementation of the devlist subcommand + * @cmdtp: [in] Command Table + * @flag: flags + * @argc: number of arguments + * @argv: arguments + * + * This function queries the devices belonging to the UCLASS_FFA + * class. Currently, one device is expected to show up: the arm_ffa device + * + * Return: + * + * CMD_RET_SUCCESS: on success, otherwise failure + */ +int do_ffa_dev_list(struct cmd_tbl *cmdtp, int flag, int argc, char *const argv[]) +{ + struct udevice *dev = NULL; + int i, ret; + + ffa_info("arm_ffa uclass entries:"); + + for (i = 0, ret = uclass_first_device(UCLASS_FFA, &dev); + dev; + ret = uclass_next_device(&dev), i++) { + if (ret) + break; + + ffa_info("entry %d - instance %08x, ops %08x, plat %08x", + i, + (u32)map_to_sysmem(dev), + (u32)map_to_sysmem(dev->driver->ops), + (u32)map_to_sysmem(dev_get_plat(dev))); + } + + return cmd_process_error(cmdtp, ret); +} + +static struct cmd_tbl armffa_commands[] = { + U_BOOT_CMD_MKENT(getpart, 1, 1, do_ffa_get_singular_partition_info, "", ""), + U_BOOT_CMD_MKENT(ping, 1, 1, do_ffa_msg_send_direct_req, "", ""), + U_BOOT_CMD_MKENT(devlist, 0, 1, do_ffa_dev_list, "", ""), +}; + +/** + * do_armffa - the armffa command main function + * @cmdtp: Command Table + * @flag: flags + * @argc: number of arguments + * @argv: arguments + * + * This function identifies which armffa subcommand to run. + * Then, it makes sure the arm_ffa device is probed and + * ready for use. + * Then, it runs the subcommand. + * + * Return: + * + * CMD_RET_SUCCESS: on success, otherwise failure + */ +static int do_armffa(struct cmd_tbl *cmdtp, int flag, int argc, char *const argv[]) +{ + struct cmd_tbl *armffa_cmd; + int ret; + + if (argc < 2) + return CMD_RET_USAGE; + + armffa_cmd = find_cmd_tbl(argv[1], armffa_commands, ARRAY_SIZE(armffa_commands)); + + argc -= 2; + argv += 2; + + if (!armffa_cmd || argc > armffa_cmd->maxargs) + return CMD_RET_USAGE; + + ret = ffa_bus_discover(); + if (ret != FFA_ERR_STAT_SUCCESS) + return cmd_process_error(cmdtp, ret); + + if (!ffa_bus_ops_get()) + return -EINVAL; + + ret = armffa_cmd->cmd(armffa_cmd, flag, argc, argv); + + return cmd_process_error(armffa_cmd, ret); +} + +U_BOOT_CMD(armffa, 4, 1, do_armffa, + "Arm FF-A operations test command", + "getpart <partition UUID>\n" + " - lists the partition(s) info\n" + "ping <partition ID>\n" + " - sends a data pattern to the specified partition\n" + "devlist\n" + " - displays the arm_ffa device info\n"); diff --git a/drivers/arm-ffa/Kconfig b/drivers/arm-ffa/Kconfig index 882ffde90f..25816b479b 100644 --- a/drivers/arm-ffa/Kconfig +++ b/drivers/arm-ffa/Kconfig @@ -4,6 +4,7 @@ config ARM_FFA_TRANSPORT bool "Enable Arm Firmware Framework for Armv8-A driver" depends on DM && ARM64 select ARM_SMCCC + select CMD_ARMFFA select LIB_UUID select DEVRES help
This new version of the patchset provides improvements to the FF-A support and updates for the Sandbox test cases.
Please refer to the changelog below for a list of the major changes made.
Please refer to the changelog in the commit logs for a detailed view of the changes including the minor changes.
All previous review comments have been addressed.
I'll reply to the individual review comments after the submission of this v4 patchset.
Please find at [4] an example of the expected boot logs when enabling FF-A support for a platform. In this example the platform is Corstone1000. But it can be any Arm 64-bit platform.
Changelog of the major changes: ===========================
v4:
* add FF-A support README (doc/README.ffa.drv) * improving error handling by mapping the FF-A errors to standard errors and logs * replacing panics with an error log * align sandbox driver and tests with the new FF-A driver interfaces and new way of error handling * use the new FF-A driver interfaces for MM communication * discover MM partitions at runtime * copy FF-A driver private data to EFI runtime section at ExitBootServices() * moving the FF-A driver work to drivers/firmware/arm-ffa * improving features discovery in FFA_FEATURES * add remove/bind functions to the FF-A core device * improve how the driver behaves when bus discovery is done more than once * move clearing x0-x17 registers code into a new macro like done in the linux kernel * enable EFI MM communication for the Corstone1000 platform
v3: [3]
* port x0-x17 registers support from linux kernel as defined by SMCCCv1.2 * align the interfaces of the u-boot FF-A driver with those in the linux FF-A driver * remove the FF-A helper layer * make the u-boot FF-A driver independent from EFI * provide an optional config that enables copying the driver data to EFI runtime section at ExitBootServices service * use 64-bit version of FFA_RXTX_MAP, FFA_MSG_SEND_DIRECT_{REQ, RESP} * update armffa command with the new driver interfaces
v2 [2]:
* make FF-A bus discoverable using device_{bind, probe} APIs * remove device tree support
v1 [1]:
* introduce FF-A bus driver with device tree support * introduce armffa command * introduce FF-A Sandbox driver * add FF-A Sandbox test cases * introduce FF-A MM communication
Cheers, Abdellatif
[1]: https://lore.kernel.org/all/20220329151659.16894-1-abdellatif.elkhlifi@arm.c... [2]: https://lore.kernel.org/all/20220415122803.16666-1-abdellatif.elkhlifi@arm.c... [3]: https://lore.kernel.org/all/20220801172053.20163-1-abdellatif.elkhlifi@arm.c... [4]: example of boot logs when enabling FF-A
``` U-Boot 2022.07 (Jul 11 2022 - 13:42:58 +0000) corstone1000 aarch64 ... [FFA] Conduit is SMC [FFA] FF-A driver 1.0 FF-A framework 1.0 [FFA] Versions are compatible [FFA] endpoint ID is 0 [FFA] Using 1 4KB page(s) for RX/TX buffers size [FFA] RX buffer at virtual address 0xfdf18000 [FFA] TX buffer at virtual address 0xfdf1a000 [FFA] RX/TX buffers mapped [FFA] Reading partitions data from the RX buffer [FFA] Partition ID 8001 : info cached [FFA] Partition ID 8002 : info cached [FFA] Partition ID 8003 : info cached [FFA] 3 partition(s) found and cached Hit any key to stop autoboot: 0 ... [FFA] Preparing for checking partitions count [FFA] Searching partitions using the provided UUID [FFA] No partition found. Querying framework ... [FFA] Reading partitions data from the RX buffer [FFA] Number of partition(s) found matching the UUID: 1 EFI: Pre-allocating 1 partition(s) info structures [FFA] Preparing for filling partitions info [FFA] Searching partitions using the provided UUID [FFA] Partition ID 8003 matches the provided UUID EFI: MM partition ID 0x8003 ... EFI stub: Booting Linux Kernel... EFI stub: Using DTB from configuration table EFI stub: Exiting boot services... [FFA] Freeing RX/TX buffers INFO: EFI: FFA: prv data area at 0xfff2f768 INFO: EFI: FFA: runtime data area at 0xfcef4000 INFO: EFI: FFA: SPs runtime area at 0xfcef3000 INFO: EFI: FFA: runtime prv data now at 0xfcef4000 , SPs count 3 INFO: EFI: FFA: runtime data copied Booting Linux on physical CPU 0x0000000000 [0x410fd040] ```
Cc: Tom Rini trini@konsulko.com Cc: Simon Glass sjg@chromium.org Cc: Ilias Apalodimas ilias.apalodimas@linaro.org Cc: Jens Wiklander jens.wiklander@linaro.org Cc: Achin Gupta achin.gupta@arm.com Cc: Vishnu Banavath vishnu.banavath@arm.com Cc: Xueliang Zhong Xueliang.Zhong@arm.com
Abdellatif El Khlifi (10): arm64: smccc: add support for SMCCCv1.2 x0-x17 registers arm64: smccc: clear the Xn registers after SMC calls lib: uuid: introduce be_uuid_str_to_le_bin function arm_ffa: introduce Arm FF-A low-level driver arm_ffa: introduce armffa command arm_ffa: introduce the FF-A Sandbox driver arm_ffa: introduce Sandbox test cases for UCLASS_FFA arm_ffa: introduce armffa command Sandbox test arm_ffa: introduce FF-A MM communication arm_ffa: corstone1000: enable EFI MM communication
MAINTAINERS | 11 + arch/arm/cpu/armv8/cache.S | 19 + arch/arm/cpu/armv8/cache_v8.c | 6 +- arch/arm/cpu/armv8/smccc-call.S | 62 + arch/arm/lib/asm-offsets.c | 14 + cmd/Kconfig | 10 + cmd/Makefile | 2 + cmd/armffa.c | 242 +++ common/board_r.c | 9 + configs/corstone1000_defconfig | 4 + configs/sandbox64_defconfig | 2 + configs/sandbox_defconfig | 2 + doc/README.ffa.drv | 160 ++ doc/arch/sandbox.rst | 1 + drivers/Kconfig | 2 + drivers/Makefile | 1 + drivers/firmware/arm-ffa/Kconfig | 46 + drivers/firmware/arm-ffa/Makefile | 8 + drivers/firmware/arm-ffa/arm-ffa-uclass.c | 16 + drivers/firmware/arm-ffa/arm_ffa_prv.h | 201 +++ drivers/firmware/arm-ffa/core.c | 1358 +++++++++++++++++ .../arm-ffa/efi_ffa_runtime_data_mgr.c | 94 ++ drivers/firmware/arm-ffa/sandbox.c | 659 ++++++++ .../firmware/arm-ffa/sandbox_arm_ffa_prv.h | 144 ++ include/arm_ffa.h | 127 ++ include/configs/corstone1000.h | 9 + include/dm/uclass-id.h | 4 + include/linux/arm-smccc.h | 43 + include/mm_communication.h | 9 +- include/sandbox_arm_ffa.h | 91 ++ include/uuid.h | 8 + lib/efi_loader/Kconfig | 14 +- lib/efi_loader/efi_boottime.c | 22 + lib/efi_loader/efi_variable_tee.c | 263 +++- lib/uuid.c | 64 + test/cmd/Makefile | 2 + test/cmd/armffa.c | 40 + test/dm/Makefile | 2 + test/dm/ffa.c | 394 +++++ 39 files changed, 4156 insertions(+), 9 deletions(-) create mode 100644 cmd/armffa.c create mode 100644 doc/README.ffa.drv create mode 100644 drivers/firmware/arm-ffa/Kconfig create mode 100644 drivers/firmware/arm-ffa/Makefile create mode 100644 drivers/firmware/arm-ffa/arm-ffa-uclass.c create mode 100644 drivers/firmware/arm-ffa/arm_ffa_prv.h create mode 100644 drivers/firmware/arm-ffa/core.c create mode 100644 drivers/firmware/arm-ffa/efi_ffa_runtime_data_mgr.c create mode 100644 drivers/firmware/arm-ffa/sandbox.c create mode 100644 drivers/firmware/arm-ffa/sandbox_arm_ffa_prv.h create mode 100644 include/arm_ffa.h create mode 100644 include/sandbox_arm_ffa.h create mode 100644 test/cmd/armffa.c create mode 100644 test/dm/ffa.c
add support for x0-x17 registers used by the SMC calls
In SMCCC v1.2 [1] arguments are passed in registers x1-x17. Results are returned in x0-x17.
This work is inspired from the following kernel commit:
arm64: smccc: Add support for SMCCCv1.2 extended input/output registers
[1]: https://documentation-service.arm.com/static/5f8edaeff86e16515cdbe4c6?token=
Changelog: ===============
v4:
* rename the commit title and improve description new commit title: the current
v3:
* port x0-x17 registers support from linux kernel as defined by SMCCCv1.2 commit title: arm64: smccc: add Xn registers support used by SMC calls
Signed-off-by: Abdellatif El Khlifi abdellatif.elkhlifi@arm.com Cc: Tom Rini trini@konsulko.com Cc: Simon Glass sjg@chromium.org Cc: Ilias Apalodimas ilias.apalodimas@linaro.org Cc: Jens Wiklander jens.wiklander@linaro.org --- arch/arm/cpu/armv8/smccc-call.S | 53 +++++++++++++++++++++++++++++++++ arch/arm/lib/asm-offsets.c | 14 +++++++++ include/linux/arm-smccc.h | 43 ++++++++++++++++++++++++++ 3 files changed, 110 insertions(+)
diff --git a/arch/arm/cpu/armv8/smccc-call.S b/arch/arm/cpu/armv8/smccc-call.S index dc92b28777..ec6f299bc9 100644 --- a/arch/arm/cpu/armv8/smccc-call.S +++ b/arch/arm/cpu/armv8/smccc-call.S @@ -1,6 +1,8 @@ /* SPDX-License-Identifier: GPL-2.0 */ /* * Copyright (c) 2015, Linaro Limited + * (C) Copyright 2022 ARM Limited + * Abdellatif El Khlifi abdellatif.elkhlifi@arm.com */ #include <linux/linkage.h> #include <linux/arm-smccc.h> @@ -45,3 +47,54 @@ ENDPROC(__arm_smccc_smc) ENTRY(__arm_smccc_hvc) SMCCC hvc ENDPROC(__arm_smccc_hvc) + +#ifdef CONFIG_ARM64 + + .macro SMCCC_1_2 instr + /* Save `res` and free a GPR that won't be clobbered */ + stp x1, x19, [sp, #-16]! + + /* Ensure `args` won't be clobbered while loading regs in next step */ + mov x19, x0 + + /* Load the registers x0 - x17 from the struct arm_smccc_1_2_regs */ + ldp x0, x1, [x19, #ARM_SMCCC_1_2_REGS_X0_OFFS] + ldp x2, x3, [x19, #ARM_SMCCC_1_2_REGS_X2_OFFS] + ldp x4, x5, [x19, #ARM_SMCCC_1_2_REGS_X4_OFFS] + ldp x6, x7, [x19, #ARM_SMCCC_1_2_REGS_X6_OFFS] + ldp x8, x9, [x19, #ARM_SMCCC_1_2_REGS_X8_OFFS] + ldp x10, x11, [x19, #ARM_SMCCC_1_2_REGS_X10_OFFS] + ldp x12, x13, [x19, #ARM_SMCCC_1_2_REGS_X12_OFFS] + ldp x14, x15, [x19, #ARM_SMCCC_1_2_REGS_X14_OFFS] + ldp x16, x17, [x19, #ARM_SMCCC_1_2_REGS_X16_OFFS] + + \instr #0 + + /* Load the `res` from the stack */ + ldr x19, [sp] + + /* Store the registers x0 - x17 into the result structure */ + stp x0, x1, [x19, #ARM_SMCCC_1_2_REGS_X0_OFFS] + stp x2, x3, [x19, #ARM_SMCCC_1_2_REGS_X2_OFFS] + stp x4, x5, [x19, #ARM_SMCCC_1_2_REGS_X4_OFFS] + stp x6, x7, [x19, #ARM_SMCCC_1_2_REGS_X6_OFFS] + stp x8, x9, [x19, #ARM_SMCCC_1_2_REGS_X8_OFFS] + stp x10, x11, [x19, #ARM_SMCCC_1_2_REGS_X10_OFFS] + stp x12, x13, [x19, #ARM_SMCCC_1_2_REGS_X12_OFFS] + stp x14, x15, [x19, #ARM_SMCCC_1_2_REGS_X14_OFFS] + stp x16, x17, [x19, #ARM_SMCCC_1_2_REGS_X16_OFFS] + + /* Restore original x19 */ + ldp xzr, x19, [sp], #16 + ret + .endm + +/* + * void arm_smccc_1_2_smc(const struct arm_smccc_1_2_regs *args, + * struct arm_smccc_1_2_regs *res); + */ +ENTRY(arm_smccc_1_2_smc) + SMCCC_1_2 smc +ENDPROC(arm_smccc_1_2_smc) + +#endif diff --git a/arch/arm/lib/asm-offsets.c b/arch/arm/lib/asm-offsets.c index 22fd541f9a..1bc2d90faa 100644 --- a/arch/arm/lib/asm-offsets.c +++ b/arch/arm/lib/asm-offsets.c @@ -9,6 +9,9 @@ * generate asm statements containing #defines, * compile this file to assembler, and then extract the * #defines from the assembly-language output. + * + * (C) Copyright 2022 ARM Limited + * Abdellatif El Khlifi abdellatif.elkhlifi@arm.com */
#include <common.h> @@ -117,6 +120,17 @@ int main(void) DEFINE(ARM_SMCCC_RES_X2_OFFS, offsetof(struct arm_smccc_res, a2)); DEFINE(ARM_SMCCC_QUIRK_ID_OFFS, offsetof(struct arm_smccc_quirk, id)); DEFINE(ARM_SMCCC_QUIRK_STATE_OFFS, offsetof(struct arm_smccc_quirk, state)); + #ifdef CONFIG_ARM64 + DEFINE(ARM_SMCCC_1_2_REGS_X0_OFFS, offsetof(struct arm_smccc_1_2_regs, a0)); + DEFINE(ARM_SMCCC_1_2_REGS_X2_OFFS, offsetof(struct arm_smccc_1_2_regs, a2)); + DEFINE(ARM_SMCCC_1_2_REGS_X4_OFFS, offsetof(struct arm_smccc_1_2_regs, a4)); + DEFINE(ARM_SMCCC_1_2_REGS_X6_OFFS, offsetof(struct arm_smccc_1_2_regs, a6)); + DEFINE(ARM_SMCCC_1_2_REGS_X8_OFFS, offsetof(struct arm_smccc_1_2_regs, a8)); + DEFINE(ARM_SMCCC_1_2_REGS_X10_OFFS, offsetof(struct arm_smccc_1_2_regs, a10)); + DEFINE(ARM_SMCCC_1_2_REGS_X12_OFFS, offsetof(struct arm_smccc_1_2_regs, a12)); + DEFINE(ARM_SMCCC_1_2_REGS_X14_OFFS, offsetof(struct arm_smccc_1_2_regs, a14)); + DEFINE(ARM_SMCCC_1_2_REGS_X16_OFFS, offsetof(struct arm_smccc_1_2_regs, a16)); + #endif #endif
return 0; diff --git a/include/linux/arm-smccc.h b/include/linux/arm-smccc.h index e1d09884a1..9105031d55 100644 --- a/include/linux/arm-smccc.h +++ b/include/linux/arm-smccc.h @@ -1,6 +1,8 @@ /* SPDX-License-Identifier: GPL-2.0 */ /* * Copyright (c) 2015, Linaro Limited + * (C) Copyright 2022 ARM Limited + * Abdellatif El Khlifi abdellatif.elkhlifi@arm.com */ #ifndef __LINUX_ARM_SMCCC_H #define __LINUX_ARM_SMCCC_H @@ -70,6 +72,47 @@ struct arm_smccc_res { unsigned long a3; };
+#ifdef CONFIG_ARM64 +/** + * struct arm_smccc_1_2_regs - Arguments for or Results from SMC call + * @a0-a17 argument values from registers 0 to 17 + */ +struct arm_smccc_1_2_regs { + unsigned long a0; + unsigned long a1; + unsigned long a2; + unsigned long a3; + unsigned long a4; + unsigned long a5; + unsigned long a6; + unsigned long a7; + unsigned long a8; + unsigned long a9; + unsigned long a10; + unsigned long a11; + unsigned long a12; + unsigned long a13; + unsigned long a14; + unsigned long a15; + unsigned long a16; + unsigned long a17; +}; + +/** + * arm_smccc_1_2_smc() - make SMC calls + * @args: arguments passed via struct arm_smccc_1_2_regs + * @res: result values via struct arm_smccc_1_2_regs + * + * This function is used to make SMC calls following SMC Calling Convention + * v1.2 or above. The content of the supplied param are copied from the + * structure to registers prior to the SMC instruction. The return values + * are updated with the content from registers on return from the SMC + * instruction. + */ +asmlinkage void arm_smccc_1_2_smc(const struct arm_smccc_1_2_regs *args, + struct arm_smccc_1_2_regs *res); +#endif + /** * struct arm_smccc_quirk - Contains quirk information * @id: quirk identification
set to zero the x0-x17 registers
As per the SMCCC v1.2 spec, unused result and scratch registers can leak information after an SMC call. We can mitigate against this risk by returning zero in each register.
The leakage we are referring to is data leakage across exception levels. The intent is to prevent lower exception levels (EL1/EL0) from reading the SMC data exchanged at EL2.
v4:
* move the clearing code into a new macro: clear_gp_regs
v3:
* clear the Xn registers after SMC calls
Signed-off-by: Abdellatif El Khlifi abdellatif.elkhlifi@arm.com Cc: Tom Rini trini@konsulko.com Cc: Simon Glass sjg@chromium.org Cc: Ilias Apalodimas ilias.apalodimas@linaro.org Cc: Jens Wiklander jens.wiklander@linaro.org --- arch/arm/cpu/armv8/smccc-call.S | 9 +++++++++ 1 file changed, 9 insertions(+)
diff --git a/arch/arm/cpu/armv8/smccc-call.S b/arch/arm/cpu/armv8/smccc-call.S index ec6f299bc9..32f3eb8eeb 100644 --- a/arch/arm/cpu/armv8/smccc-call.S +++ b/arch/arm/cpu/armv8/smccc-call.S @@ -50,6 +50,12 @@ ENDPROC(__arm_smccc_hvc)
#ifdef CONFIG_ARM64
+ .macro clear_gp_regs + .irp n,0,1,2,3,4,5,6,7,8,9,10,11,12,13,14,15,16,17 + mov x\n, xzr + .endr + .endm + .macro SMCCC_1_2 instr /* Save `res` and free a GPR that won't be clobbered */ stp x1, x19, [sp, #-16]! @@ -84,6 +90,9 @@ ENDPROC(__arm_smccc_hvc) stp x14, x15, [x19, #ARM_SMCCC_1_2_REGS_X14_OFFS] stp x16, x17, [x19, #ARM_SMCCC_1_2_REGS_X16_OFFS]
+ /* x0-x17 registers can leak information after an SMC or HVC call. Let's clear them */ + clear_gp_regs + /* Restore original x19 */ ldp xzr, x19, [sp], #16 ret
convert big endian UUID string to little endian buffer
v4:
* rename ffa_uuid_str_to_bin to be_uuid_str_to_le_bin and put in a standalone commit (the current)
v3:
* introduce ffa_uuid_str_to_bin (provided by arm_ffa: introduce Arm FF-A low-level driver)
Signed-off-by: Abdellatif El Khlifi abdellatif.elkhlifi@arm.com Cc: Tom Rini trini@konsulko.com Cc: Simon Glass sjg@chromium.org Cc: Ilias Apalodimas ilias.apalodimas@linaro.org Cc: Jens Wiklander jens.wiklander@linaro.org --- include/uuid.h | 8 +++++++ lib/uuid.c | 64 ++++++++++++++++++++++++++++++++++++++++++++++++++ 2 files changed, 72 insertions(+)
diff --git a/include/uuid.h b/include/uuid.h index 4a4883d3b5..ad3af350f9 100644 --- a/include/uuid.h +++ b/include/uuid.h @@ -2,6 +2,8 @@ /* * Copyright (C) 2014 Samsung Electronics * Przemyslaw Marczak p.marczak@samsung.com + * (C) Copyright 2022 ARM Limited + * Abdellatif El Khlifi abdellatif.elkhlifi@arm.com */ #ifndef __UUID_H__ #define __UUID_H__ @@ -44,4 +46,10 @@ int uuid_guid_get_bin(const char *guid_str, unsigned char *guid_bin); const char *uuid_guid_get_str(const unsigned char *guid_bin); void gen_rand_uuid(unsigned char *uuid_bin); void gen_rand_uuid_str(char *uuid_str, int str_format); + +/** + * be_uuid_str_to_le_bin - Converts a big endian UUID string to a little endian buffer + */ +int be_uuid_str_to_le_bin(const char *uuid_str, unsigned char *uuid_bin); + #endif diff --git a/lib/uuid.c b/lib/uuid.c index 465e1ac38f..15a9ab49d5 100644 --- a/lib/uuid.c +++ b/lib/uuid.c @@ -1,6 +1,8 @@ // SPDX-License-Identifier: GPL-2.0+ /* * Copyright 2011 Calxeda, Inc. + * (C) Copyright 2022 ARM Limited + * Abdellatif El Khlifi abdellatif.elkhlifi@arm.com */
#include <common.h> @@ -346,6 +348,68 @@ int uuid_str_to_bin(const char *uuid_str, unsigned char *uuid_bin, return 0; }
+/** + * be_uuid_str_to_le_bin - Converts a big endian UUID string to a little endian buffer + * @uuid_str: UUID string in big endian format (36 bytes wide + '/0') + * @uuid_bin: preallocated 16 bytes UUID buffer in little endian format + * + * UUID string is 36 characters (36 bytes): + * + * xxxxxxxx-xxxx-xxxx-xxxx-xxxxxxxxxxxx + * be be be be be + * + * where x is a hexadecimal character. Fields are separated by '-'s. + * When converting to a binary UUID, these endianness rules apply: + * be: means the field in the string is considered a big endian hex number + * and should be converted to little endian binary format + * + * Return: + * + * uuid_bin filled with little endian UUID data + * On success 0 is returned. Otherwise, failure code. + */ +int be_uuid_str_to_le_bin(const char *uuid_str, unsigned char *uuid_bin) +{ + u16 tmp16 = 0; + u32 tmp32 = 0; + u64 tmp64 = 0; + + if (!uuid_str_valid(uuid_str) || !uuid_bin) + return -EINVAL; + + /* + * reverse bytes from big to little endian + */ + tmp32 = simple_strtoul(uuid_str, NULL, 16); + memcpy(uuid_bin, &tmp32, 4); + + /* + * reverse bytes from big to little endian + */ + tmp16 = simple_strtoul(uuid_str + 9, NULL, 16); + memcpy(uuid_bin + 4, &tmp16, 2); + + /* + * reverse bytes from big to little endian + */ + tmp16 = simple_strtoul(uuid_str + 14, NULL, 16); + memcpy(uuid_bin + 6, &tmp16, 2); + + /* + * reverse bytes from big to little endian + */ + tmp16 = simple_strtoul(uuid_str + 19, NULL, 16); + memcpy(uuid_bin + 8, &tmp16, 2); + + /* + * reverse bytes from big to little endian + */ + tmp64 = simple_strtoull(uuid_str + 24, NULL, 16); + memcpy(uuid_bin + 10, (char *)&tmp64, 6); + + return 0; +} + /* * uuid_bin_to_str() - convert big endian binary data to string UUID or GUID. *
The Firmware Framework for Arm A-profile processors (FF-A v1.0) [1] describes interfaces (ABIs) that standardize communication between the Secure World and Normal World leveraging TrustZone technology.
- partition_info_get - sync_send_receive - rxtx_unmap
[1]: https://developer.arm.com/documentation/den0077/latest/
v4:
* add doc/README.ffa.drv * moving the FF-A driver work to drivers/firmware/arm-ffa * use less #ifdefs in lib/efi_loader/efi_boottime.c and replace #if defined by #if CONFIG_IS_ENABLED * improving error handling by mapping the FF-A errors to standard errors and logs * replacing panics with an error log and returning an error code * improving features discovery in FFA_FEATURES by introducing rxtx_min_pages private data field * add ffa_remove and ffa_bind functions * improve how the driver behaves when bus discovery is done more than once
v3:
v2:
v1:
Signed-off-by: Abdellatif El Khlifi abdellatif.elkhlifi@arm.com Cc: Tom Rini trini@konsulko.com Cc: Simon Glass sjg@chromium.org Cc: Ilias Apalodimas ilias.apalodimas@linaro.org Cc: Jens Wiklander jens.wiklander@linaro.org --- MAINTAINERS | 7 + common/board_r.c | 9 + doc/README.ffa.drv | 160 ++ drivers/Kconfig | 2 + drivers/Makefile | 1 + drivers/firmware/arm-ffa/Kconfig | 39 + drivers/firmware/arm-ffa/Makefile | 7 + drivers/firmware/arm-ffa/arm-ffa-uclass.c | 16 + drivers/firmware/arm-ffa/arm_ffa_prv.h | 196 +++ drivers/firmware/arm-ffa/core.c | 1344 +++++++++++++++++ .../arm-ffa/efi_ffa_runtime_data_mgr.c | 94 ++ include/arm_ffa.h | 127 ++ include/dm/uclass-id.h | 4 + lib/efi_loader/efi_boottime.c | 15 + 14 files changed, 2021 insertions(+) create mode 100644 doc/README.ffa.drv create mode 100644 drivers/firmware/arm-ffa/Kconfig create mode 100644 drivers/firmware/arm-ffa/Makefile create mode 100644 drivers/firmware/arm-ffa/arm-ffa-uclass.c create mode 100644 drivers/firmware/arm-ffa/arm_ffa_prv.h create mode 100644 drivers/firmware/arm-ffa/core.c create mode 100644 drivers/firmware/arm-ffa/efi_ffa_runtime_data_mgr.c create mode 100644 include/arm_ffa.h
diff --git a/MAINTAINERS b/MAINTAINERS index 83346183ee..02b84d5074 100644 --- a/MAINTAINERS +++ b/MAINTAINERS @@ -248,6 +248,13 @@ F: drivers/net/cortina_ni.h F: drivers/net/phy/ca_phy.c F: configs/cortina_presidio-asic-pnand_defconfig
+ARM FF-A +M: Abdellatif El Khlifi abdellatif.elkhlifi@arm.com +S: Maintained +F: doc/README.ffa.drv +F: drivers/firmware/arm-ffa/ +F: include/arm_ffa.h + ARM FREESCALE IMX M: Stefano Babic sbabic@denx.de M: Fabio Estevam festevam@gmail.com diff --git a/common/board_r.c b/common/board_r.c index 56eb60fa27..8c99faddfd 100644 --- a/common/board_r.c +++ b/common/board_r.c @@ -7,6 +7,8 @@ * (C) Copyright 2002 * Sysgo Real-Time Solutions, GmbH <www.elinos.com> * Marius Groeger mgroeger@sysgo.de + * + * (C) Copyright 2022 ARM Limited */
#include <common.h> @@ -66,6 +68,10 @@ #include <efi_loader.h> #include <relocate.h>
+#ifdef CONFIG_ARM_FFA_TRANSPORT +#include <arm_ffa.h> +#endif + DECLARE_GLOBAL_DATA_PTR;
ulong monitor_flash_len; @@ -770,6 +776,9 @@ static init_fnc_t init_sequence_r[] = { INIT_FUNC_WATCHDOG_RESET initr_net, #endif +#ifdef CONFIG_ARM_FFA_TRANSPORT + ffa_bus_discover, +#endif #ifdef CONFIG_POST initr_post, #endif diff --git a/doc/README.ffa.drv b/doc/README.ffa.drv new file mode 100644 index 0000000000..1c0a33deb8 --- /dev/null +++ b/doc/README.ffa.drv @@ -0,0 +1,160 @@ +Arm FF-A Driver +==================== + +Introduction +-------------------- + +FF-A stands for Firmware Framework for Arm A-profile processors. + +FF-A specifies interfaces that enable a pair of software sandboxes to communicate with each other. A sandbox aka partition could +be a VM in the Normal or Secure world, an application in S-EL0, or a Trusted OS in S-EL1. + +This FF-A driver implements the interfaces to communicate with partitions in the Secure world aka Secure partitions (SPs). + +The driver specifically focuses on communicating with SPs that isolate portions of EFI runtime services that must run in a +protected environment which is inaccessible by the Host OS or Hypervisor. Examples of such services are set/get variables. + +FF-A driver uses the SMC ABIs defined by the FF-A specification to: + +- Discover the presence of SPs of interest. +- Access an SP's service through communication protocols e.g. EFI MM communication protocol. + +FF-A and SMC specifications +------------------------------------------- + +The current implementation of the driver relies on FF-A specification v1.0 and uses SMC32 calling convention. + +The driver has been tested with Optee OS which supports SMC32 for most of the SMC ABIs. + +For more details please refer to: https://developer.arm.com/documentation/den0077/a/?lang=en + +The FF-A driver uses 64-bit registers as per SMCCCv1.2 specification. + +For more details please refer to: https://documentation-service.arm.com/static/5f8edaeff86e16515cdbe4c6?token= + +Supported hardware +-------------------------------- + +Aarch64 plaforms + +Configuration +---------------------- + +CONFIG_ARM_FFA_TRANSPORT + Enables the FF-A bus driver. Turn this on if you want to use FF-A communication. + +CONFIG_ARM_FFA_EFI_RUNTIME_MODE + Optional config that enables EFI runtime support for FF-A data and code. + ffa_copy_runtime_data allows to copy the FF-A driver data structures to EFI runtime data section. + Turning the config on makes ffa_copy_runtime_data available for use and the driver code placed at EFI runtime code section. + Call ffa_copy_runtime_data at the event on which you want the FF-A data to be copied (example: at ExitBootServices). + +CONFIG_SANDBOX_FFA + Enables FF-A Sandbox driver. This emulates the FF-A ABIs handling under Sandbox and provides + functional tests for FF-A. + +FF-A ABIs under the hood +--------------------------------------- + +Invoking an FF-A ABI involves providing to the secure world/hypervisor the expected arguments from the ABI. + +The ABI arguments are stored in x0 to x7 registers. Then, an SMC instruction is executed. + +At the secure side level or hypervisor the ABI is handled at a higher exception level and the arguments are read and processed. + +The response is put back through x0 to x7 registers and control is giving back to the u-boot FF-A driver (non secure world). + +The driver reads the response and processes it accordingly. + +This methodology applies to all the FF-A ABIs in the driver. + +FF-A bus discovery in u-boot +------------------------------------------- + +When CONFIG_ARM_FFA_TRANSPORT is enabled, the FF-A bus is automatically discovered at initcall level (after u-boot relocation). + +The function that triggers the discovery process is ffa_bus_discover. + +ffa_bus_discover creates, binds and probes the arm_ffa device using device_{bind, probe} APIs. + +When the device is probed, ffa_probe is called which tries to communicate with the secure world or hypervisor. + +The FF-A bus is usable when these checks succeed: + +- querying the FF-A framework version +- querying from secure world the u-boot endpoint ID +- querying from secure world the supported features of the specified FF-A calls +- mapping the RX/TX buffers +- querying from secure world all the partitions information + +Probing fails when any of these operations fail. The FF-A bus discovery succeeds when probing is successful. + +When discovery fails the arm_ffa device is destroyed. + +The bus driver layer +------------------------------ + +The driver comes on top of the SMCCC layer and is implemented in drivers/firmware/arm-ffa/core.c + +The driver provides the following features: + +- Support for the 32-bit version of the following ABIs: + +FFA_VERSION +FFA_ID_GET +FFA_FEATURES +FFA_PARTITION_INFO_GET +FFA_RXTX_UNMAP +FFA_RX_RELEASE +FFA_RUN +FFA_ERROR +FFA_SUCCESS +FFA_INTERRUPT + +- Support for the 64-bit version of the following ABIs: + +FFA_RXTX_MAP +FFA_MSG_SEND_DIRECT_REQ +FFA_MSG_SEND_DIRECT_RESP + +- Processing the received data from the secure world/hypervisor and caching it + +- Hiding from upper layers the FF-A protocol and registers details. Upper layers focus on exchanged data, +the driver takes care of how to transport that to the secure world/hypervisor using FF-A. + +- The driver provides callbacks to be used by clients to access the FF-A bus: + +partition_info_get +sync_send_receive +rxtx_unmap + +- FF-A bus discovery at initcalls level (after u-boot relocation). The bus is up and running if the FF-A framework is responsive and compatible with the driver. + +- When EFI is enabled, unmap the RX/TX buffers at ExitBootServices() level. + +- When CONFIG_ARM_FFA_EFI_RUNTIME_MODE enabled, ffa_copy_runtime_data function is available for use. + +Using armffa command +----------------------------------- + +armffa is a command showcasing how to use the FF-A driver and how to invoke its operations. + +This provides a guidance to the client developers on how to call the FF-A bus interfaces. + +Usage: + +armffa <sub-command> <arguments> + +sub-commands: + + getpart <partition UUID> + + lists the partition(s) info + + ping <partition ID> + + sends a data pattern to the specified partition + + devlist + + displays the arm_ffa device info diff --git a/drivers/Kconfig b/drivers/Kconfig index 8b6fead351..b06b1ae481 100644 --- a/drivers/Kconfig +++ b/drivers/Kconfig @@ -6,6 +6,8 @@ source "drivers/core/Kconfig"
source "drivers/adc/Kconfig"
+source "drivers/firmware/arm-ffa/Kconfig" + source "drivers/ata/Kconfig"
source "drivers/axi/Kconfig" diff --git a/drivers/Makefile b/drivers/Makefile index eba9940231..c3bfad94ac 100644 --- a/drivers/Makefile +++ b/drivers/Makefile @@ -110,6 +110,7 @@ obj-y += iommu/ obj-y += smem/ obj-y += thermal/ obj-$(CONFIG_TEE) += tee/ +obj-$(CONFIG_ARM_FFA_TRANSPORT) += firmware/arm-ffa/ obj-y += axi/ obj-y += ufs/ obj-$(CONFIG_W1) += w1/ diff --git a/drivers/firmware/arm-ffa/Kconfig b/drivers/firmware/arm-ffa/Kconfig new file mode 100644 index 0000000000..aceb61cf49 --- /dev/null +++ b/drivers/firmware/arm-ffa/Kconfig @@ -0,0 +1,39 @@ +# SPDX-License-Identifier: GPL-2.0 + +config ARM_FFA_TRANSPORT + bool "Enable Arm Firmware Framework for Armv8-A driver" + depends on DM && ARM64 + select ARM_SMCCC + select LIB_UUID + select DEVRES + help + The Firmware Framework for Arm A-profile processors (FF-A) + describes interfaces (ABIs) that standardize communication + between the Secure World and Normal World leveraging TrustZone + technology. + + This driver is based on FF-A specification v1.0 and uses SMC32 + calling convention. + + FF-A specification: + + https://developer.arm.com/documentation/den0077/a/?lang=en + + In u-boot FF-A design, FF-A is considered as a discoverable bus. + The Secure World is considered as one entity to communicate with + using the FF-A bus. + FF-A communication is handled by one device and one instance (the bus). + This FF-A driver takes care of all the interactions between Normal world + and Secure World. + + For more details about the FF-A driver, please refer to doc/README.ffa.drv + +config ARM_FFA_EFI_RUNTIME_MODE + bool "Enable EFI runtime support for FF-A data and code" + depends on ARM_FFA_TRANSPORT && EFI_LOADER + help + Allows FF-A driver data structures and code to be accessible at EFI runtime. + FF-A data is copied by ffa_copy_runtime_data function. + The driver Code needed at runtime is placed at EFI runtime code section. + Turning this on makes ffa_copy_runtime_data available for use and the driver + code placed at EFI runtime code section. diff --git a/drivers/firmware/arm-ffa/Makefile b/drivers/firmware/arm-ffa/Makefile new file mode 100644 index 0000000000..0b9b0a61b4 --- /dev/null +++ b/drivers/firmware/arm-ffa/Makefile @@ -0,0 +1,7 @@ +# SPDX-License-Identifier: GPL-2.0+ +# +# (C) Copyright 2022 Abdellatif El Khlifi abdellatif.elkhlifi@arm.com +# + +obj-y += arm-ffa-uclass.o core.o +obj-$(CONFIG_ARM_FFA_EFI_RUNTIME_MODE) += efi_ffa_runtime_data_mgr.o diff --git a/drivers/firmware/arm-ffa/arm-ffa-uclass.c b/drivers/firmware/arm-ffa/arm-ffa-uclass.c new file mode 100644 index 0000000000..7d9695d289 --- /dev/null +++ b/drivers/firmware/arm-ffa/arm-ffa-uclass.c @@ -0,0 +1,16 @@ +// SPDX-License-Identifier: GPL-2.0+ +/* + * (C) Copyright 2022 ARM Limited + * Abdellatif El Khlifi abdellatif.elkhlifi@arm.com + */ + +#include <common.h> +#include <dm.h> +#include <asm/global_data.h> + +DECLARE_GLOBAL_DATA_PTR; + +UCLASS_DRIVER(ffa) = { + .name = "ffa", + .id = UCLASS_FFA, +}; diff --git a/drivers/firmware/arm-ffa/arm_ffa_prv.h b/drivers/firmware/arm-ffa/arm_ffa_prv.h new file mode 100644 index 0000000000..7bc90f7f66 --- /dev/null +++ b/drivers/firmware/arm-ffa/arm_ffa_prv.h @@ -0,0 +1,196 @@ +/* SPDX-License-Identifier: GPL-2.0+ */ +/* + * (C) Copyright 2022 ARM Limited + * Abdellatif El Khlifi abdellatif.elkhlifi@arm.com + */ + +#ifndef __ARM_FFA_PRV_H +#define __ARM_FFA_PRV_H + +#include <arm_ffa.h> +#include <linux/bitfield.h> +#include <linux/bitops.h> +#include <linux/arm-smccc.h> + +/* + * This header is private. It is exclusively used by the FF-A driver + */ + +/* FF-A core driver name */ +#define FFA_DRV_NAME "arm_ffa" + +/* FF-A driver version definitions */ + +#define MAJOR_VERSION_MASK GENMASK(30, 16) +#define MINOR_VERSION_MASK GENMASK(15, 0) +#define GET_FFA_MAJOR_VERSION(x) \ + ((u16)(FIELD_GET(MAJOR_VERSION_MASK, (x)))) +#define GET_FFA_MINOR_VERSION(x) \ + ((u16)(FIELD_GET(MINOR_VERSION_MASK, (x)))) +#define PACK_VERSION_INFO(major, minor) \ + (FIELD_PREP(MAJOR_VERSION_MASK, (major)) | \ + FIELD_PREP(MINOR_VERSION_MASK, (minor))) + +#define FFA_MAJOR_VERSION (1) +#define FFA_MINOR_VERSION (0) +#define FFA_VERSION_1_0 \ + PACK_VERSION_INFO(FFA_MAJOR_VERSION, FFA_MINOR_VERSION) + +/* Endpoint ID mask (u-boot endpoint ID) */ + +#define GET_SELF_ENDPOINT_ID_MASK GENMASK(15, 0) +#define GET_SELF_ENDPOINT_ID(x) \ + ((u16)(FIELD_GET(GET_SELF_ENDPOINT_ID_MASK, (x)))) + +#define PREP_SELF_ENDPOINT_ID_MASK GENMASK(31, 16) +#define PREP_SELF_ENDPOINT_ID(x) \ + (FIELD_PREP(PREP_SELF_ENDPOINT_ID_MASK, (x))) + +/* Partition endpoint ID mask (partition with which u-boot communicates with) */ + +#define PREP_PART_ENDPOINT_ID_MASK GENMASK(15, 0) +#define PREP_PART_ENDPOINT_ID(x) \ + (FIELD_PREP(PREP_PART_ENDPOINT_ID_MASK, (x))) + +/* + * Definitions of the Arm FF-A interfaces supported by the Arm FF-A driver + */ + +#define FFA_SMC(calling_convention, func_num) \ + ARM_SMCCC_CALL_VAL(ARM_SMCCC_FAST_CALL, (calling_convention), \ + ARM_SMCCC_OWNER_STANDARD, (func_num)) + +#define FFA_SMC_32(func_num) FFA_SMC(ARM_SMCCC_SMC_32, (func_num)) +#define FFA_SMC_64(func_num) FFA_SMC(ARM_SMCCC_SMC_64, (func_num)) + +enum ffa_abis { + FFA_ERROR = 0x60, + FFA_SUCCESS = 0x61, + FFA_INTERRUPT = 0x62, + FFA_VERSION = 0x63, + FFA_FEATURES = 0x64, + FFA_RX_RELEASE = 0x65, + FFA_RXTX_MAP = 0x66, + FFA_RXTX_UNMAP = 0x67, + FFA_PARTITION_INFO_GET = 0x68, + FFA_ID_GET = 0x69, + FFA_RUN = 0x6D, + FFA_MSG_SEND_DIRECT_REQ = 0x6F, + FFA_MSG_SEND_DIRECT_RESP = 0x70, + + /* to be updated when adding new FFA IDs */ + FFA_FIRST_ID = FFA_ERROR, /* lowest number ID*/ + FFA_LAST_ID = FFA_MSG_SEND_DIRECT_RESP, /* highest number ID*/ +}; + +/* number of the errors supported by the FF-A specification */ +#define MAX_NUMBER_FFA_ERR 9 + +/* container structure and helper macros to map between an FF-A error and relevant error log */ +struct ffa_abi_errmap { + char *err_str[MAX_NUMBER_FFA_ERR]; +}; + +#define FFA_ERRMAP_COUNT (FFA_LAST_ID - FFA_FIRST_ID + 1) +#define FFA_ID_TO_ERRMAP_ID(ffa_id) ((ffa_id) - FFA_FIRST_ID) + +/* The FF-A SMC function definitions */ + +typedef struct arm_smccc_1_2_regs ffa_value_t; +typedef void (*invoke_ffa_fn_t)(ffa_value_t args, ffa_value_t *res); + +/* + * struct ffa_partition_uuid - 16 bytes UUID transmitted by FFA_PARTITION_INFO_GET + * @a1-4: 32-bit words access to the UUID data + * + */ +struct ffa_partition_uuid { + u32 a1; /* w1 */ + u32 a2; /* w2 */ + u32 a3; /* w3 */ + u32 a4; /* w4 */ +}; + +/** + * enum ffa_rxtx_buf_sizes - minimum sizes supported + * for the RX/TX buffers + */ +enum ffa_rxtx_buf_sizes { + RXTX_4K, + RXTX_64K, + RXTX_16K +}; + +/** + * struct ffa_rxtxpair - structure hosting the RX/TX buffers virtual addresses + * @rxbuf: virtual address of the RX buffer + * @txbuf: virtual address of the TX buffer + * @rxtx_min_pages: RX/TX buffers minimum size in pages + * + * Data structure hosting the virtual addresses of the mapped RX/TX buffers + * These addresses are used by the FF-A functions that use the RX/TX buffers + */ +struct ffa_rxtxpair { + u64 rxbuf; /* virtual address */ + u64 txbuf; /* virtual address */ + size_t rxtx_min_pages; /* minimum number of pages in each of the RX/TX buffers */ +}; + +/** + * struct ffa_partition_desc - the secure partition descriptor + * @info: partition information + * @sp_uuid: the secure partition UUID + * + * Each partition has its descriptor containing the partitions information and the UUID + */ +struct ffa_partition_desc { + struct ffa_partition_info info; + struct ffa_partition_uuid sp_uuid; +}; + +/** + * struct ffa_partitions - descriptors for all secure partitions + * @count: The number of partitions descriptors + * @descs The partitions descriptors table + * + * This data structure contains the partitions descriptors table + */ +struct ffa_partitions { + u32 count; + struct ffa_partition_desc *descs; /* virtual address */ +}; + +/** + * struct ffa_prvdata - the driver private data structure + * + * @dev: The arm_ffa device under u-boot driver model + * @ffa_ops: The driver operations structure + * @fwk_version: FF-A framework version + * @id: u-boot endpoint ID + * @partitions: The partitions descriptors structure + * @pair: The RX/TX buffers pair + * @invoke_ffa_fn: The function executing the FF-A function + * + * The driver data structure hosting all resident data. + */ +struct ffa_prvdata { + struct udevice *dev; + struct ffa_bus_ops ffa_ops; + u32 fwk_version; + u16 id; + struct ffa_partitions partitions; + struct ffa_rxtxpair pair; + invoke_ffa_fn_t invoke_ffa_fn; +}; + +/** + * ffa_device_get - create, bind and probe the arm_ffa device + */ +int ffa_device_get(void); + +/** + * ffa_bus_prvdata_get - bus driver private data getter + */ +struct ffa_prvdata **ffa_bus_prvdata_get(void); + +#endif diff --git a/drivers/firmware/arm-ffa/core.c b/drivers/firmware/arm-ffa/core.c new file mode 100644 index 0000000000..41c7b96e68 --- /dev/null +++ b/drivers/firmware/arm-ffa/core.c @@ -0,0 +1,1344 @@ +// SPDX-License-Identifier: GPL-2.0+ +/* + * (C) Copyright 2022 ARM Limited + * Abdellatif El Khlifi abdellatif.elkhlifi@arm.com + */ + +#include "arm_ffa_prv.h" +#include <asm/global_data.h> +#include <common.h> +#include <dm.h> +#include <dm/device-internal.h> +#include <dm/devres.h> +#include <dm/root.h> +#include <linux/errno.h> +#include <linux/sizes.h> +#include <log.h> +#include <malloc.h> +#include <string.h> +#include <uuid.h> + +DECLARE_GLOBAL_DATA_PTR; + +/** + * The device private data structure containing all the resident + * data read from secure world + */ +__ffa_runtime_data struct ffa_prvdata *ffa_priv_data; + +/* Error mapping declarations */ + +__ffa_runtime_data int ffa_to_std_errmap[MAX_NUMBER_FFA_ERR] = { + 0, + -EOPNOTSUPP, /* NOT_SUPPORTED */ + -EINVAL, /* INVALID_PARAMETERS */ + -ENOMEM, /* NO_MEMORY */ + -EBUSY, /* BUSY */ + -EINTR, /* INTERRUPTED */ + -EACCES, /* DENIED */ + -EAGAIN, /* RETRY */ + -ECANCELED, /* ABORTED */ +}; + +struct ffa_abi_errmap err_msg_map[FFA_ERRMAP_COUNT] = { + [FFA_ID_TO_ERRMAP_ID(FFA_VERSION)] = { + { + "", + "NOT_SUPPORTED: A Firmware Framework implementation does not exist", + "", /* INVALID_PARAMETERS */ + "", /* NO_MEMORY */ + "", /* BUSY */ + "", /* INTERRUPTED */ + "", /* DENIED */ + "", /* RETRY */ + "", /* ABORTED */ + }, + }, + [FFA_ID_TO_ERRMAP_ID(FFA_ID_GET)] = { + { + "", + "NOT_SUPPORTED: This function is not implemented at this FF-A instance", + "", /* INVALID_PARAMETERS */ + "", /* NO_MEMORY */ + "", /* BUSY */ + "", /* INTERRUPTED */ + "", /* DENIED */ + "", /* RETRY */ + "", /* ABORTED */ + }, + }, + [FFA_ID_TO_ERRMAP_ID(FFA_FEATURES)] = { + { + "", + "NOT_SUPPORTED: FFA_RXTX_MAP is not implemented at this FF-A instance", + "", /* INVALID_PARAMETERS */ + "", /* NO_MEMORY */ + "", /* BUSY */ + "", /* INTERRUPTED */ + "", /* DENIED */ + "", /* RETRY */ + "", /* ABORTED */ + }, + }, + [FFA_ID_TO_ERRMAP_ID(FFA_PARTITION_INFO_GET)] = { + { + "", + "NOT_SUPPORTED: This function is not implemented at this FF-A instance", + "INVALID_PARAMETERS: Unrecognized UUID", + "NO_MEMORY: Results cannot fit in RX buffer of the caller", + "BUSY: RX buffer of the caller is not free", + "", /* INTERRUPTED */ + "DENIED: Callee is not in a state to handle this request", + "", /* RETRY */ + "", /* ABORTED */ + }, + }, + [FFA_ID_TO_ERRMAP_ID(FFA_RXTX_UNMAP)] = { + { + "", + "NOT_SUPPORTED: FFA_RXTX_UNMAP is not implemented at this FF-A instance", + "INVALID_PARAMETERS: No buffer pair registered on behalf of the caller", + "", /* NO_MEMORY */ + "", /* BUSY */ + "", /* INTERRUPTED */ + "", /* DENIED */ + "", /* RETRY */ + "", /* ABORTED */ + }, + }, + [FFA_ID_TO_ERRMAP_ID(FFA_RX_RELEASE)] = { + { + "", + "NOT_SUPPORTED: FFA_RX_RELEASE is not implemented at this FF-A instance", + "", /* INVALID_PARAMETERS */ + "", /* NO_MEMORY */ + "", /* BUSY */ + "", /* INTERRUPTED */ + "DENIED: Caller did not have ownership of the RX buffer", + "", /* RETRY */ + "", /* ABORTED */ + }, + }, + [FFA_ID_TO_ERRMAP_ID(FFA_RXTX_MAP)] = { + { + "", + "NOT_SUPPORTED: This function is not implemented at this FF-A instance", + "INVALID_PARAMETERS: Field(s) in input parameters incorrectly encoded", + "NO_MEMORY: Not enough memory", + "", /* BUSY */ + "", /* INTERRUPTED */ + "DENIED: Buffer pair already registered", + "", /* RETRY */ + "", /* ABORTED */ + }, + }, +}; + +/** + * ffa_to_std_errno - convert FF-A error code to standard error code + * @ffa_errno: Error code returned by the FF-A ABI + * + * This runtime function maps the given FF-A error code as specified + * by the spec to a u-boot standard error code. + * + * Return: + * + * The standard error code on success. . Otherwise, failure + */ +__ffa_runtime int ffa_to_std_errno(int ffa_errno) +{ + int err_idx = -ffa_errno; + + /* map the FF-A error code to the standard u-boot error code */ + if (err_idx > 0 && err_idx < MAX_NUMBER_FFA_ERR) + return ffa_to_std_errmap[err_idx]; + return -EINVAL; +} + +/** + * ffa_print_error_log - print the error log corresponding to the selected FF-A ABI + * @ffa_id: FF-A ABI ID + * @ffa_errno: Error code returned by the FF-A ABI + * + * This boot time function maps the FF-A error code to the error log relevant to the + * selected FF-A ABI. Then the error log is printed. + * + * Return: + * + * 0 on success. . Otherwise, failure + */ +int ffa_print_error_log(u32 ffa_id, int ffa_errno) +{ + int err_idx = -ffa_errno, abi_idx = 0; + + /* map the FF-A error code to the corresponding error log */ + + if (err_idx <= 0 || err_idx >= MAX_NUMBER_FFA_ERR) + return -EINVAL; + + if (ffa_id < FFA_FIRST_ID || ffa_id > FFA_LAST_ID) + return -EINVAL; + + abi_idx = FFA_ID_TO_ERRMAP_ID(ffa_id); + if (abi_idx < 0 || abi_idx >= FFA_ERRMAP_COUNT) + return -EINVAL; + + if (!err_msg_map[abi_idx].err_str || !err_msg_map[abi_idx].err_str[err_idx]) + return -EINVAL; + + ffa_err("%s", err_msg_map[abi_idx].err_str[err_idx]); + + return 0; +} + +/* + * Driver core functions + */ + +/** + * ffa_remove_device - removes the arm_ffa device + * @dev: the device to be removed + * + * This boot time function makes sure the arm_ffa device is removed + * No need to free the kmalloced data when the device is destroyed. + * It's automatically done by devm management by + * device_remove() -> device_free() -> devres_release_probe(). + * + * Return: + * + * 0 on success. Otherwise, failure + */ +int ffa_remove_device(struct udevice *dev) +{ + int ret; + + if (!dev) { + ffa_err("no udevice found"); + return -ENODEV; + } + + ret = device_remove(dev, DM_REMOVE_NORMAL); + if (ret) { + ffa_err("unable to remove. err:%d\n", ret); + return ret; + } + + ffa_info("device removed and freed"); + + ret = device_unbind(dev); + if (ret) { + ffa_err("unable to unbind. err:%d\n", ret); + return ret; + } + + ffa_info("device unbound"); + + return 0; +} + +/** + * ffa_device_get - create, bind and probe the arm_ffa device + * + * This boot time function makes sure the arm_ffa device is + * created, bound to this driver, probed and ready to use. + * Arm FF-A transport is implemented through a single u-boot + * device managing the FF-A bus (arm_ffa). + * + * Return: + * + * 0 on success. Otherwise, failure + */ +int ffa_device_get(void) +{ + int ret; + struct udevice *dev = NULL; + + ret = device_bind(dm_root(), + DM_DRIVER_GET(arm_ffa), + FFA_DRV_NAME, + NULL, + ofnode_null(), + &dev); + if (ret) + return ret; + + /* The FF-A bus discovery succeeds when probing is successful */ + ret = device_probe(dev); + if (ret) { + ffa_err("arm_ffa device probing failed"); + ffa_remove_device(dev); + return ret; + } + + return 0; +} + +/** + * ffa_get_version - FFA_VERSION handler function + * + * This is the boot time function that implements FFA_VERSION FF-A function + * to get from the secure world the FF-A framework version + * + * Return: + * + * 0 on success. Otherwise, failure + */ +static int ffa_get_version(void) +{ + u16 major, minor; + ffa_value_t res = {0}; + int ffa_errno; + + ffa_priv_data->invoke_ffa_fn((ffa_value_t){ + .a0 = FFA_SMC_32(FFA_VERSION), + .a1 = FFA_VERSION_1_0, .a2 = 0, .a3 = 0, .a4 = 0, .a5 = 0, .a6 = 0, .a7 = 0, + }, &res); + + ffa_errno = (int)res.a0; + if (ffa_errno < 0) { + ffa_print_error_log(FFA_VERSION, ffa_errno); + return ffa_to_std_errno(ffa_errno); + } + + major = GET_FFA_MAJOR_VERSION((u32)res.a0); + minor = GET_FFA_MINOR_VERSION((u32)res.a0); + + ffa_info("FF-A driver %d.%d\nFF-A framework %d.%d", + FFA_MAJOR_VERSION, FFA_MINOR_VERSION, major, minor); + + if ((major == FFA_MAJOR_VERSION && minor >= FFA_MINOR_VERSION)) { + ffa_info("Versions are compatible "); + + ffa_priv_data->fwk_version = (u32)res.a0; + + return 0; + } + + ffa_err("versions are incompatible\nExpected: %d.%d , Found: %d.%d\n", + FFA_MAJOR_VERSION, FFA_MINOR_VERSION, major, minor); + + return -EPROTONOSUPPORT; +} + +/** + * ffa_get_endpoint_id - FFA_ID_GET handler function + * + * This is the boot time function that implements FFA_ID_GET FF-A function + * to get from the secure world u-boot endpoint ID + * + * Return: + * + * 0 on success. Otherwise, failure + */ +static int ffa_get_endpoint_id(void) +{ + ffa_value_t res = {0}; + int ffa_errno; + + ffa_priv_data->invoke_ffa_fn((ffa_value_t){ + .a0 = FFA_SMC_32(FFA_ID_GET), + .a1 = 0, .a2 = 0, .a3 = 0, .a4 = 0, .a5 = 0, .a6 = 0, .a7 = 0, + }, &res); + + if (res.a0 == FFA_SMC_32(FFA_SUCCESS)) { + ffa_priv_data->id = GET_SELF_ENDPOINT_ID((u32)res.a2); + ffa_info("endpoint ID is %u", ffa_priv_data->id); + + return 0; + } + + ffa_errno = (int)res.a2; + + ffa_print_error_log(FFA_ID_GET, ffa_errno); + + return ffa_to_std_errno(ffa_errno); +} + +/** + * ffa_set_rxtx_buffers_pages_cnt - sets the minimum number of pages in each of the RX/TX buffers + * @prop_field: properties field obtained from FFA_FEATURES ABI + * + * This boot time function sets the minimum number of pages + * in each of the RX/TX buffers in the private data structure + * + * Return: + * + * buf_4k_pages points to the returned number of pages + * 0 on success. Otherwise, failure + */ +static int ffa_set_rxtx_buffers_pages_cnt(u32 prop_field) +{ + if (!ffa_priv_data) + return -EINVAL; + + switch (prop_field) { + case RXTX_4K: + ffa_priv_data->pair.rxtx_min_pages = 1; + break; + case RXTX_16K: + ffa_priv_data->pair.rxtx_min_pages = 4; + break; + case RXTX_64K: + ffa_priv_data->pair.rxtx_min_pages = 16; + break; + default: + ffa_err("RX/TX buffer size not supported"); + return -EINVAL; + } + + return 0; +} + +/** + * ffa_get_rxtx_map_features - FFA_FEATURES handler function with FFA_RXTX_MAP argument + * + * This is the boot time function that implements FFA_FEATURES FF-A function + * to retrieve the FFA_RXTX_MAP features + * + * Return: + * + * 0 on success. Otherwise, failure + */ +static int ffa_get_rxtx_map_features(void) +{ + ffa_value_t res = {0}; + int ffa_errno; + + ffa_priv_data->invoke_ffa_fn((ffa_value_t){ + .a0 = FFA_SMC_32(FFA_FEATURES), + .a1 = FFA_SMC_64(FFA_RXTX_MAP), + .a2 = 0, .a3 = 0, .a4 = 0, .a5 = 0, .a6 = 0, .a7 = 0, + }, &res); + + if (res.a0 == FFA_SMC_32(FFA_SUCCESS)) + return ffa_set_rxtx_buffers_pages_cnt((u32)res.a2); + + ffa_errno = (int)res.a2; + ffa_print_error_log(FFA_FEATURES, ffa_errno); + + return ffa_to_std_errno(ffa_errno); +} + +/** + * ffa_free_rxtx_buffers - frees the RX/TX buffers + * + * This is the boot time function used to free the RX/TX buffers + * + */ +static void ffa_free_rxtx_buffers(void) +{ + ffa_info("Freeing RX/TX buffers"); + + if (ffa_priv_data->pair.rxbuf) { + free((void *)ffa_priv_data->pair.rxbuf); + ffa_priv_data->pair.rxbuf = 0; + } + + if (ffa_priv_data->pair.txbuf) { + free((void *)ffa_priv_data->pair.txbuf); + ffa_priv_data->pair.txbuf = 0; + } +} + +/** + * ffa_alloc_rxtx_buffers - allocates the RX/TX buffers + * + * This is the boot time function used by ffa_map_rxtx_buffers to allocate + * the RX/TX buffers before mapping them. The allocated memory is physically + * contiguous since memalign ends up calling malloc which allocates + * contiguous memory in u-boot. + * + * Return: + * + * 0 on success. Otherwise, failure + */ +static int ffa_alloc_rxtx_buffers(void) +{ + u64 bytes; + + ffa_info("Using %lu 4KB page(s) for RX/TX buffers size", + ffa_priv_data->pair.rxtx_min_pages); + + bytes = ffa_priv_data->pair.rxtx_min_pages * SZ_4K; + + /* RX/TX buffers addresses should be PAGE_SIZE aligned */ + + ffa_priv_data->pair.rxbuf = (u64)memalign(PAGE_SIZE, bytes); + if (!ffa_priv_data->pair.rxbuf) { + ffa_err("failure to allocate RX buffer"); + return -ENOBUFS; + } + + ffa_info("RX buffer at virtual address 0x%llx", ffa_priv_data->pair.rxbuf); + + ffa_priv_data->pair.txbuf = (u64)memalign(PAGE_SIZE, bytes); + if (!ffa_priv_data->pair.txbuf) { + free((void *)ffa_priv_data->pair.rxbuf); + ffa_priv_data->pair.rxbuf = 0; + ffa_err("failure to allocate the TX buffer"); + return -ENOBUFS; + } + + ffa_info("TX buffer at virtual address 0x%llx", ffa_priv_data->pair.txbuf); + + /* + * make sure the buffers are cleared before use + */ + memset((void *)ffa_priv_data->pair.rxbuf, 0, bytes); + memset((void *)ffa_priv_data->pair.txbuf, 0, bytes); + + return 0; +} + +/** + * ffa_map_rxtx_buffers - FFA_RXTX_MAP handler function + * + * This is the boot time function that implements FFA_RXTX_MAP FF-A function + * to map the RX/TX buffers + * + * Return: + * + * 0 on success. Otherwise, failure + */ +static int ffa_map_rxtx_buffers(void) +{ + int ret; + ffa_value_t res = {0}; + int ffa_errno; + + ret = ffa_alloc_rxtx_buffers(); + if (ret) + return ret; + + /* + * we need to pass the physical addresses of the RX/TX buffers + * in u-boot physical/virtual mapping is 1:1 + *no need to convert from virtual to physical + */ + + ffa_priv_data->invoke_ffa_fn((ffa_value_t){ + .a0 = FFA_SMC_64(FFA_RXTX_MAP), + .a1 = ffa_priv_data->pair.txbuf, + .a2 = ffa_priv_data->pair.rxbuf, + .a3 = ffa_priv_data->pair.rxtx_min_pages, + .a4 = 0, .a5 = 0, .a6 = 0, .a7 = 0, + }, &res); + + if (res.a0 == FFA_SMC_32(FFA_SUCCESS)) { + ffa_info("RX/TX buffers mapped"); + return 0; + } + + ffa_errno = (int)res.a2; + ffa_print_error_log(FFA_RXTX_MAP, ffa_errno); + + ffa_free_rxtx_buffers(); + + return ffa_to_std_errno(ffa_errno); +} + +/** + * ffa_unmap_rxtx_buffers - FFA_RXTX_UNMAP handler function + * + * This is the boot time function that implements FFA_RXTX_UNMAP FF-A function + * to unmap the RX/TX buffers + * + * Return: + * + * 0 on success. Otherwise, failure + */ +static int ffa_unmap_rxtx_buffers(void) +{ + ffa_value_t res = {0}; + int ffa_errno; + + ffa_priv_data->invoke_ffa_fn((ffa_value_t){ + .a0 = FFA_SMC_32(FFA_RXTX_UNMAP), + .a1 = PREP_SELF_ENDPOINT_ID(ffa_priv_data->id), + .a2 = 0, .a3 = 0, .a4 = 0, .a5 = 0, .a6 = 0, .a7 = 0, + }, &res); + + if (res.a0 == FFA_SMC_32(FFA_SUCCESS)) { + ffa_free_rxtx_buffers(); + return 0; + } + + ffa_errno = (int)res.a2; + ffa_print_error_log(FFA_RXTX_UNMAP, ffa_errno); + + return ffa_to_std_errno(ffa_errno); +} + +/** + * ffa_release_rx_buffer - FFA_RX_RELEASE handler function + * + * This is the boot time function that invokes FFA_RX_RELEASE FF-A function + * to release the ownership of the RX buffer + * + * Return: + * + * 0 on success. Otherwise, failure + */ +static int ffa_release_rx_buffer(void) +{ + ffa_value_t res = {0}; + int ffa_errno; + + ffa_priv_data->invoke_ffa_fn((ffa_value_t){ + .a0 = FFA_SMC_32(FFA_RX_RELEASE), + .a1 = 0, .a2 = 0, .a3 = 0, .a4 = 0, .a5 = 0, .a6 = 0, .a7 = 0, + }, &res); + + if (res.a0 == FFA_SMC_32(FFA_SUCCESS)) + return 0; + + ffa_errno = (int)res.a2; + ffa_print_error_log(FFA_RX_RELEASE, ffa_errno); + + return ffa_to_std_errno(ffa_errno); +} + +/** + * ffa_uuid_are_identical - checks whether two given UUIDs are identical + * @uuid1: first UUID + * @uuid2: second UUID + * + * This is a boot time function used by ffa_read_partitions_info to search + * for a UUID in the partitions descriptors table + * + * Return: + * + * 1 when UUIDs match. Otherwise, 0 + */ +int ffa_uuid_are_identical(const struct ffa_partition_uuid *uuid1, + const struct ffa_partition_uuid *uuid2) +{ + if (!uuid1 || !uuid2) + return 0; + + return (!memcmp(uuid1, uuid2, sizeof(struct ffa_partition_uuid))); +} + +/** + * ffa_read_partitions_info - reads the data queried by FFA_PARTITION_INFO_GET + * and saves it in the private structure + * @count: The number of partitions queried + * @part_uuid: Pointer to the partition(s) UUID + * + * This is the boot time function that reads the partitions information + * returned by the FFA_PARTITION_INFO_GET and saves it in the private + * data structure. + * + * Return: + * + * The private data structure is updated with the partition(s) information + * 0 is returned on success. Otherwise, failure + */ +static int ffa_read_partitions_info(u32 count, struct ffa_partition_uuid *part_uuid) +{ + if (!count) { + ffa_err("no partition detected"); + return -ENODATA; + } + + ffa_info("Reading partitions data from the RX buffer"); + + if (!part_uuid) { + /* + * querying information of all partitions + */ + u64 buf_bytes; + u64 data_bytes; + u32 desc_idx; + struct ffa_partition_info *parts_info; + + data_bytes = count * sizeof(struct ffa_partition_desc); + + buf_bytes = ffa_priv_data->pair.rxtx_min_pages * SZ_4K; + + if (data_bytes > buf_bytes) { + ffa_err("partitions data size exceeds the RX buffer size:"); + ffa_err(" sizes in bytes: data %llu , RX buffer %llu ", + data_bytes, + buf_bytes); + + return -ENOMEM; + } + + ffa_priv_data->partitions.descs = (struct ffa_partition_desc *) + devm_kmalloc(ffa_priv_data->dev, data_bytes, __GFP_ZERO); + if (!ffa_priv_data->partitions.descs) { + ffa_err("cannot allocate partitions data buffer"); + return -ENOMEM; + } + + parts_info = (struct ffa_partition_info *)ffa_priv_data->pair.rxbuf; + + for (desc_idx = 0 ; desc_idx < count ; desc_idx++) { + ffa_priv_data->partitions.descs[desc_idx].info = + parts_info[desc_idx]; + + ffa_info("Partition ID %x : info cached", + ffa_priv_data->partitions.descs[desc_idx].info.id); + } + + ffa_priv_data->partitions.count = count; + + ffa_info("%d partition(s) found and cached", count); + + } else { + u32 rx_desc_idx, cached_desc_idx; + struct ffa_partition_info *parts_info; + u8 desc_found; + + parts_info = (struct ffa_partition_info *)ffa_priv_data->pair.rxbuf; + + /* + * search for the SP IDs read from the RX buffer + * in the already cached SPs. + * Update the UUID when ID found. + */ + for (rx_desc_idx = 0; rx_desc_idx < count ; rx_desc_idx++) { + desc_found = 0; + + /* + * search the current ID in the cached partitions + */ + for (cached_desc_idx = 0; + cached_desc_idx < ffa_priv_data->partitions.count; + cached_desc_idx++) { + /* + * save the UUID + */ + if (ffa_priv_data->partitions.descs[cached_desc_idx].info.id == + parts_info[rx_desc_idx].id) { + ffa_priv_data->partitions.descs[cached_desc_idx].sp_uuid = + *part_uuid; + + desc_found = 1; + break; + } + } + + if (!desc_found) + return -ENODATA; + } + } + + return 0; +} + +/** + * ffa_query_partitions_info - invokes FFA_PARTITION_INFO_GET and saves partitions data + * + * @part_uuid: Pointer to the partition(s) UUID + * @pcount: Pointer to the number of partitions variable filled when querying + * + * This is the boot time function that executes the FFA_PARTITION_INFO_GET + * to query the partitions data. Then, it calls ffa_read_partitions_info + * to save the data in the private data structure. + * + * After reading the data the RX buffer is released using ffa_release_rx_buffer + * + * Return: + * + * When part_uuid is NULL, all partitions data are retrieved from secure world + * When part_uuid is non NULL, data for partitions matching the given UUID are + * retrieved and the number of partitions is returned + * 0 is returned on success. Otherwise, failure + */ +static int ffa_query_partitions_info(struct ffa_partition_uuid *part_uuid, + u32 *pcount) +{ + struct ffa_partition_uuid query_uuid = {0}; + ffa_value_t res = {0}; + int ffa_errno; + + /* + * If a UUID is specified. Information for one or more + * partitions in the system is queried. Otherwise, information + * for all installed partitions is queried + */ + + if (part_uuid) { + if (!pcount) + return -EINVAL; + + query_uuid = *part_uuid; + } else if (pcount) { + return -EINVAL; + } + + ffa_priv_data->invoke_ffa_fn((ffa_value_t){ + .a0 = FFA_SMC_32(FFA_PARTITION_INFO_GET), + .a1 = query_uuid.a1, + .a2 = query_uuid.a2, + .a3 = query_uuid.a3, + .a4 = query_uuid.a4, + .a5 = 0, + .a6 = 0, + .a7 = 0, + }, &res); + + if (res.a0 == FFA_SMC_32(FFA_SUCCESS)) { + int ret; + + /* + * res.a2 contains the count of partition information descriptors + * populated in the RX buffer + */ + if (res.a2) { + ret = ffa_read_partitions_info((u32)res.a2, part_uuid); + if (ret) { + ffa_err("failed to read partition(s) data , error (%d)", ret); + ffa_release_rx_buffer(); + return -EINVAL; + } + } + + /* + * return the SP count (when querying using a UUID) + */ + if (pcount) + *pcount = (u32)res.a2; + + /* + * After calling FFA_PARTITION_INFO_GET the buffer ownership + * is assigned to the consumer (u-boot). So, we need to give + * the ownership back to the SPM or hypervisor + */ + ret = ffa_release_rx_buffer(); + + return ret; + } + + ffa_errno = (int)res.a2; + ffa_print_error_log(FFA_PARTITION_INFO_GET, ffa_errno); + + return ffa_to_std_errno(ffa_errno); +} + +/** + * ffa_get_partitions_info - FFA_PARTITION_INFO_GET handler function + * + * The passed arguments: + * Mode 1: When getting from the driver the number of + * secure partitions: + * @uuid_str: pointer to the UUID string + * @parts_size: pointer to the variable that contains the number of partitions + * The variable will be set by the driver + * @buffer: NULL + * + * Mode 2: When requesting the driver to return the + * partitions information: + * @uuid_str: pointer to the UUID string + * @parts_size: pointer to the size of the SPs information buffer in bytes + * @buffer: pointer to SPs information buffer + * (allocated by the client). + * The buffer will be filled by the driver + * + * This is the boot time function that queries the secure partition data from + * the private data structure. If not found, it invokes FFA_PARTITION_INFO_GET + * FF-A function to query the partition information from secure world. + * + * A client of the FF-A driver should know the UUID of the service it wants to + * access. It should use the UUID to request the FF-A driver to provide the + * partition(s) information of the service. The FF-A driver uses + * PARTITION_INFO_GET to obtain this information. This is implemented through + * ffa_get_partitions_info function. + * A new FFA_PARTITION_INFO_GET call is issued (first one performed through + * ffa_cache_partitions_info) allowing to retrieve the partition(s) information. + * They are not saved (already done). We only update the UUID in the cached area. + * This assumes that partitions data does not change in the secure world. + * Otherwise u-boot will have an outdated partition data. The benefit of caching + * the information in the FF-A driver is to accommodate discovery after + * ExitBootServices(). + * + * When invoked through a client request, ffa_get_partitions_info should be + * called twice. First call is to get from the driver the number of secure + * partitions (SPs) associated to a particular UUID. + * Then, the caller (client) allocates the buffer to host the SPs data and + * issues a 2nd call. Then, the driver fills the SPs data in the pre-allocated + * buffer. + * + * To achieve the mechanism described above, ffa_get_partitions_info uses the + * following functions: + * ffa_read_partitions_info + * ffa_query_partitions_info + * + * Return: + * + * @parts_size: When pointing to the number of partitions variable, the number is + * set by the driver. + * When pointing to the partitions information buffer size, the buffer will be + * filled by the driver. + * + * On success 0 is returned. Otherwise, failure + */ +static int ffa_get_partitions_info(const char *uuid_str, + u32 *parts_size, struct ffa_partition_info *buffer) +{ + /* + * fill_data: + * 0: return the SP count + * 1: fill SP data and return it to the caller + * -1: undefined mode + */ + int fill_data = -1; + u32 desc_idx, client_desc_idx; + struct ffa_partition_uuid part_uuid = {0}; + u32 client_desc_max_cnt; + u32 parts_found = 0; + + if (!ffa_priv_data->partitions.count || !ffa_priv_data->partitions.descs) { + ffa_err("no partition installed"); + return -EINVAL; + } + + if (!uuid_str) { + ffa_err("no UUID provided"); + return -EINVAL; + } + + if (!parts_size) { + ffa_err("no size/count provided"); + return -EINVAL; + } + + if (be_uuid_str_to_le_bin(uuid_str, (unsigned char *)&part_uuid)) { + ffa_err("invalid UUID"); + return -EINVAL; + } + + if (!buffer) { + /* Mode 1: getting the number of secure partitions */ + + fill_data = 0; + + ffa_info("Preparing for checking partitions count"); + + } else if ((*parts_size >= sizeof(struct ffa_partition_info)) && + !(*parts_size % sizeof(struct ffa_partition_info))) { + /* Mode 2: retrieving the partitions information */ + + fill_data = 1; + + client_desc_idx = 0; + + /* + * number of empty descriptors preallocated by the caller + */ + client_desc_max_cnt = *parts_size / sizeof(struct ffa_partition_info); + + ffa_info("Preparing for filling partitions info"); + + } else { + ffa_err("invalid function arguments provided"); + return -EINVAL; + } + + ffa_info("Searching partitions using the provided UUID"); + + /* + * search in the cached partitions + */ + for (desc_idx = 0; + desc_idx < ffa_priv_data->partitions.count; + desc_idx++) { + if (ffa_uuid_are_identical(&ffa_priv_data->partitions.descs[desc_idx].sp_uuid, + &part_uuid)) { + ffa_info("Partition ID %x matches the provided UUID", + ffa_priv_data->partitions.descs[desc_idx].info.id); + + parts_found++; + + if (fill_data) { + /* + * trying to fill the partition info in the input buffer + */ + + if (client_desc_idx < client_desc_max_cnt) { + buffer[client_desc_idx++] = + ffa_priv_data->partitions.descs[desc_idx].info; + continue; + } + + ffa_err("failed to fill the current descriptor client buffer full"); + return -ENOBUFS; + } + } + } + + if (!parts_found) { + int ret; + + ffa_info("No partition found. Querying framework ..."); + + ret = ffa_query_partitions_info(&part_uuid, &parts_found); + + if (ret == 0) { + if (!fill_data) { + *parts_size = parts_found; + + ffa_info("Number of partition(s) found matching the UUID: %d", + parts_found); + } else { + /* + * If SPs data detected, they are already in the private data + * structure, retry searching SP data again to return them + * to the caller + */ + if (parts_found) + ret = ffa_get_partitions_info(uuid_str, parts_size, buffer); + else + ret = -ENODATA; + } + } + + return ret; + } + + /* partition(s) found */ + if (!fill_data) + *parts_size = parts_found; + + return 0; +} + +/** + * ffa_cache_partitions_info - Queries and saves all secure partitions data + * + * This is a boot time function that invokes FFA_PARTITION_INFO_GET FF-A + * function to query from secure world all partitions information. + * + * The FFA_PARTITION_INFO_GET call is issued with nil UUID as an argument. + * All installed partitions information are returned. We cache them in the + * resident private data structure and we keep the UUID field empty + * (in FF-A 1.0 UUID is not provided by the partition descriptor) + * + * This function is called at the device probing level. + * ffa_cache_partitions_info uses ffa_query_partitions_info to get the data + * + * Return: + * + * 0 on success. Otherwise, failure + */ +static int ffa_cache_partitions_info(void) +{ + return ffa_query_partitions_info(NULL, NULL); +} + +/** + * ffa_msg_send_direct_req - FFA_MSG_SEND_DIRECT_{REQ,RESP} handler function + * @dst_part_id: destination partition ID + * @msg: pointer to the message data preallocated by the client (in/out) + * + * This is the runtime function that implements FFA_MSG_SEND_DIRECT_{REQ,RESP} + * FF-A functions. + * + * FFA_MSG_SEND_DIRECT_REQ is used to send the data to the secure partition. + * The response from the secure partition is handled by reading the + * FFA_MSG_SEND_DIRECT_RESP arguments. + * + * The maximum size of the data that can be exchanged is 40 bytes which is + * sizeof(struct ffa_send_direct_data) as defined by the FF-A specification 1.0 + * in the section relevant to FFA_MSG_SEND_DIRECT_{REQ,RESP} + * + * Return: + * + * 0 on success. Otherwise, failure + */ +static int __ffa_runtime ffa_msg_send_direct_req(u16 dst_part_id, struct ffa_send_direct_data *msg) +{ + ffa_value_t res = {0}; + int ffa_errno; + + if (!ffa_priv_data || !ffa_priv_data->invoke_ffa_fn) + return -EINVAL; + + /* No partition installed */ + if (!ffa_priv_data->partitions.count || !ffa_priv_data->partitions.descs) + return -ENODEV; + + ffa_priv_data->invoke_ffa_fn((ffa_value_t){ + .a0 = FFA_SMC_64(FFA_MSG_SEND_DIRECT_REQ), + .a1 = PREP_SELF_ENDPOINT_ID(ffa_priv_data->id) | + PREP_PART_ENDPOINT_ID(dst_part_id), + .a2 = 0, + .a3 = msg->data0, + .a4 = msg->data1, + .a5 = msg->data2, + .a6 = msg->data3, + .a7 = msg->data4, + }, &res); + + while (res.a0 == FFA_SMC_32(FFA_INTERRUPT)) + ffa_priv_data->invoke_ffa_fn((ffa_value_t){ + .a0 = FFA_SMC_32(FFA_RUN), + .a1 = res.a1, .a2 = 0, .a3 = 0, .a4 = 0, .a5 = 0, .a6 = 0, .a7 = 0, + }, &res); + + if (res.a0 == FFA_SMC_32(FFA_SUCCESS)) { + /* Message sent with no response */ + return 0; + } + + if (res.a0 == FFA_SMC_64(FFA_MSG_SEND_DIRECT_RESP)) { + /* + * Message sent with response + * extract the return data + */ + msg->data0 = res.a3; + msg->data1 = res.a4; + msg->data2 = res.a5; + msg->data3 = res.a6; + msg->data4 = res.a7; + + return 0; + } + + ffa_errno = (int)res.a2; + return ffa_to_std_errno(ffa_errno); +} + +/** + * __arm_ffa_fn_smc - SMC wrapper + * @args: FF-A ABI arguments to be copied to Xn registers + * @res: FF-A ABI return data to be copied from Xn registers + * + * Calls low level SMC assembly function + * + * Return: void + */ +void __ffa_runtime __arm_ffa_fn_smc(ffa_value_t args, ffa_value_t *res) +{ + arm_smccc_1_2_smc(&args, res); +} + +/** + * ffa_set_smc_conduit - Set the SMC conduit + * + * This boot time function selects the SMC conduit by setting the driver invoke function + * to SMC assembly function + * + * Return: + * + * 0 on success. Otherwise, failure + */ +static int ffa_set_smc_conduit(void) +{ + ffa_priv_data->invoke_ffa_fn = __arm_ffa_fn_smc; + + if (!ffa_priv_data->invoke_ffa_fn) { + ffa_err("failure to set the invoke function"); + return -EINVAL; + } + + ffa_info("Conduit is SMC"); + + return 0; +} + +/** + * ffa_set_bus_ops - Set the bus driver operations + * + * Setting the driver callbacks. + * + */ +static void ffa_set_bus_ops(void) +{ + ffa_priv_data->ffa_ops.partition_info_get = ffa_get_partitions_info; + ffa_priv_data->ffa_ops.sync_send_receive = ffa_msg_send_direct_req; + ffa_priv_data->ffa_ops.rxtx_unmap = ffa_unmap_rxtx_buffers; +} + +/** + * ffa_alloc_prvdata - allocate the driver main data structure and sets the device + * @dev: the arm_ffa device + * + * This boot time function creates the main data structure embedding all the driver data. + * + * Return: + * + * 0 on success. Otherwise, failure + */ +static int ffa_alloc_prvdata(struct udevice *dev) +{ + if (!dev) { + ffa_err("no udevice found"); + return -ENODEV; + } + + /* The device is registered with the DM. Let's create the driver main data structure*/ + + ffa_priv_data = devm_kmalloc(dev, sizeof(struct ffa_prvdata), __GFP_ZERO); + if (!ffa_priv_data) { + ffa_err("can not allocate the driver main data structure"); + return -ENOMEM; + } + + ffa_priv_data->dev = dev; + + return 0; +} + +/** + * ffa_probe - The driver probe function + * @dev: the arm_ffa device + * + * Probing is done at boot time and triggered by the uclass device discovery. + * At probe level the following actions are done: + * - setting the conduit + * - querying the FF-A framework version + * - querying from secure world the u-boot endpoint ID + * - querying from secure world the supported features of FFA_RXTX_MAP + * - mapping the RX/TX buffers + * - querying from secure world all the partitions information + * + * All data queried from secure world is saved in the resident private data structure. + * + * The probe will fail if either FF-A framework is not detected or the + * FF-A requests are not behaving correctly. This ensures that the + * driver is not installed and its operations are not exported to the clients. + * + * Return: + * + * 0 on success. Otherwise, failure + */ +static int ffa_probe(struct udevice *dev) +{ + int ret; + + ret = ffa_alloc_prvdata(dev); + if (ret != 0) + return ret; + + ffa_set_bus_ops(); + + ret = ffa_set_smc_conduit(); + if (ret != 0) + return ret; + + ret = ffa_get_version(); + if (ret != 0) + return ret; + + ret = ffa_get_endpoint_id(); + if (ret != 0) + return ret; + + ret = ffa_get_rxtx_map_features(); + if (ret != 0) + return ret; + + ret = ffa_map_rxtx_buffers(); + if (ret != 0) + return ret; + + ret = ffa_cache_partitions_info(); + if (ret != 0) { + ffa_free_rxtx_buffers(); + return ret; + } + + return 0; +} + +/** + * ffa_remove - The driver remove function + * @dev: the arm_ffa device + * When the device is about to be removed , unmap the RX/TX buffers and free the memory + * Return: + * + * 0 on success. + */ +static int ffa_remove(struct udevice *dev) +{ + ffa_info("removing the device"); + + ffa_unmap_rxtx_buffers(); + + if (ffa_priv_data->pair.rxbuf || ffa_priv_data->pair.txbuf) + ffa_free_rxtx_buffers(); + + return 0; +} + +/** + * ffa_unbind - The driver unbind function + * @dev: the arm_ffa device + * After the device is removed and memory freed the device is unbound + * Return: + * + * 0 on success. + */ +static int ffa_unbind(struct udevice *dev) +{ + ffa_info("unbinding the device , private data already released"); + + ffa_priv_data = NULL; + + return 0; +} + +/** + * ffa_bus_ops_get - bus driver operations getter + * + * Return: + * This runtime function returns a pointer to the driver operations structure + */ +const struct ffa_bus_ops * __ffa_runtime ffa_bus_ops_get(void) +{ + return &ffa_priv_data->ffa_ops; +} + +/** + * ffa_bus_prvdata_get - bus driver private data getter + * + * Return: + * This boot time function returns a pointer to the main private data structure + */ +struct ffa_prvdata **ffa_bus_prvdata_get(void) +{ + return &ffa_priv_data; +} + +/** + * ffa_bus_discover - discover FF-A bus and probe the arm_ffa device + * + * This boot time function makes sure the FF-A bus is discoverable. + * Then, the arm_ffa device is probed and ready to use. + * This function is called automatically at initcalls + * level (after u-boot relocation). + * + * When the bus was already discovered successfully the discovery will not run again. + * + * Arm FF-A transport is implemented through arm_ffa u-boot device managing the FF-A + * communication. + * All FF-A clients should use the arm_ffa device to use the FF-A transport. + * + * Return: + * + * 0 on success. Otherwise, failure + */ +int ffa_bus_discover(void) +{ + int ret = 0; + + if (!ffa_priv_data) + ret = ffa_device_get(); + + return ret; +} + +/** + * Declaring the arm_ffa driver under UCLASS_FFA + */ + +U_BOOT_DRIVER(arm_ffa) = { + .name = FFA_DRV_NAME, + .id = UCLASS_FFA, + .probe = ffa_probe, + .remove = ffa_remove, + .unbind = ffa_unbind, +}; diff --git a/drivers/firmware/arm-ffa/efi_ffa_runtime_data_mgr.c b/drivers/firmware/arm-ffa/efi_ffa_runtime_data_mgr.c new file mode 100644 index 0000000000..c76cf2147b --- /dev/null +++ b/drivers/firmware/arm-ffa/efi_ffa_runtime_data_mgr.c @@ -0,0 +1,94 @@ +// SPDX-License-Identifier: GPL-2.0+ +/* + * (C) Copyright 2022 ARM Limited + * Abdellatif El Khlifi abdellatif.elkhlifi@arm.com + */ + +#include "arm_ffa_prv.h" + +/** + * ffa_copy_runtime_data - copy the private data structure to the runtime area + * + * This boot time function copies the arm_ffa driver data structures including + * partitions data to the EFI runtime data section. + * + * Return: + * + * 0 on success. Otherwise, failure + */ +efi_status_t ffa_copy_runtime_data(void) +{ + efi_status_t efi_ret; + efi_uintn_t prvdata_pages; + efi_uintn_t descs_pages; + struct ffa_prvdata **prvdata = NULL; /* Pointer to the current structure */ + struct ffa_prvdata *runtime_prvdata = NULL; /* Pointer to the structure runtime copy */ + u64 runtime_descs = 0; + + prvdata = ffa_bus_prvdata_get(); + + printf("INFO: EFI: FFA: prv data area at 0x%llx\n", (u64)prvdata); + + /* allocate private data runtime area */ + + prvdata_pages = efi_size_in_pages(sizeof(struct ffa_prvdata)); + efi_ret = efi_allocate_pages(EFI_ALLOCATE_ANY_PAGES, + EFI_RUNTIME_SERVICES_DATA, + prvdata_pages, + (u64 *)&runtime_prvdata); + + if (efi_ret != EFI_SUCCESS) { + printf("ERROR: EFI: FFA: allocating runtime data (err: 0x%lx, addr 0x%llx)\n", + efi_ret, (u64)runtime_prvdata); + + return efi_ret; + } + + printf("INFO: EFI: FFA: runtime data area at 0x%llx\n", (u64)runtime_prvdata); + + if (!runtime_prvdata) + return EFI_INVALID_PARAMETER; + + /* allocate the partition data runtime area */ + + descs_pages = efi_size_in_pages((*prvdata)->partitions.count * + sizeof(struct ffa_partition_desc)); + efi_ret = efi_allocate_pages(EFI_ALLOCATE_ANY_PAGES, + EFI_RUNTIME_SERVICES_DATA, + descs_pages, + &runtime_descs); + + if (efi_ret != EFI_SUCCESS) { + printf("ERROR: EFI: FFA: allocating runtime SPs data (err: 0x%lx, addr 0x%llx)\n", + efi_ret, runtime_descs); + + efi_free_pages((u64)runtime_prvdata, prvdata_pages); + + return efi_ret; + } + + printf("INFO: EFI: FFA: SPs runtime area at 0x%llx\n", (u64)runtime_descs); + + if (!runtime_descs) + return EFI_INVALID_PARAMETER; + + *runtime_prvdata = **prvdata; + + runtime_prvdata->dev = NULL; + runtime_prvdata->ffa_ops.partition_info_get = NULL; + runtime_prvdata->ffa_ops.rxtx_unmap = NULL; + runtime_prvdata->partitions.descs = (struct ffa_partition_desc *)runtime_descs; + runtime_prvdata->pair.rxbuf = 0; + runtime_prvdata->pair.txbuf = 0; + + /* + * Update the private data structure pointer in the driver + * no need to free the old structure. devm takes care of that + */ + *prvdata = runtime_prvdata; + + printf("INFO: EFI: FFA: runtime prv data now at 0x%llx , SPs count %d\n", + (u64)*prvdata, (*prvdata)->partitions.count); + + return 0; +} diff --git a/include/arm_ffa.h b/include/arm_ffa.h new file mode 100644 index 0000000000..f17b100497 --- /dev/null +++ b/include/arm_ffa.h @@ -0,0 +1,127 @@ +/* SPDX-License-Identifier: GPL-2.0+ */ +/* + * (C) Copyright 2022 ARM Limited + * Abdellatif El Khlifi abdellatif.elkhlifi@arm.com + */ + +#ifndef __ARM_FFA_H +#define __ARM_FFA_H + +#include <linux/printk.h> + +/* + * This header is public. It can be used by clients to access + * data structures and definitions they need + */ + +/* + * Macros for displaying logs + */ + +#define ffa_info(fmt, ...) pr_info("[FFA] " fmt "\n", ##__VA_ARGS__) +#define ffa_err(fmt, ...) pr_err("[FFA] " fmt "\n", ##__VA_ARGS__) + +/* + * struct ffa_partition_info - Partition information descriptor + * @id: Partition ID + * @exec_ctxt: Execution context count + * @properties: Partition properties + * + * Data structure containing information about partitions instantiated in the system + * This structure is filled with the data queried by FFA_PARTITION_INFO_GET + */ +struct __packed ffa_partition_info { + u16 id; + u16 exec_ctxt; +/* partition supports receipt of direct requests */ +#define FFA_PARTITION_DIRECT_RECV BIT(0) +/* partition can send direct requests. */ +#define FFA_PARTITION_DIRECT_SEND BIT(1) +/* partition can send and receive indirect messages. */ +#define FFA_PARTITION_INDIRECT_MSG BIT(2) + u32 properties; +}; + +/* + * struct ffa_send_direct_data - Data structure hosting the data + * used by FFA_MSG_SEND_DIRECT_{REQ,RESP} + * @data0-4: Data read/written from/to x3-x7 registers + * + * Data structure containing the data to be sent by FFA_MSG_SEND_DIRECT_REQ + * or read from FFA_MSG_SEND_DIRECT_RESP + */ + +/* For use with FFA_MSG_SEND_DIRECT_{REQ,RESP} which pass data via registers */ +struct __packed ffa_send_direct_data { + unsigned long data0; /* w3/x3 */ + unsigned long data1; /* w4/x4 */ + unsigned long data2; /* w5/x5 */ + unsigned long data3; /* w6/x6 */ + unsigned long data4; /* w7/x7 */ +}; + +#if CONFIG_IS_ENABLED(ARM_FFA_EFI_RUNTIME_MODE) + +#include <efi_loader.h> + +/* + * __ffa_runtime - controls whether functions are + * available after calling the EFI ExitBootServices service. + * Functions tagged with these keywords are resident (available at boot time and + * at runtime) + */ + +#define __ffa_runtime_data __efi_runtime_data +#define __ffa_runtime __efi_runtime + +#else + +/* + * The FF-A driver is independent from EFI + */ + +#define __ffa_runtime_data +#define __ffa_runtime + +#endif + +/** + * struct ffa_bus_ops - The driver operations structure + * @partition_info_get: callback for the FFA_PARTITION_INFO_GET + * @sync_send_receive: callback for the FFA_MSG_SEND_DIRECT_REQ + * @rxtx_unmap: callback for the FFA_RXTX_UNMAP + * + * The data structure providing all the operations supported by the driver. + * This structure is EFI runtime resident. + */ +struct ffa_bus_ops { + int (*partition_info_get)(const char *uuid_str, + u32 *parts_size, struct ffa_partition_info *buffer); + int (*sync_send_receive)(u16 dst_part_id, struct ffa_send_direct_data *msg); + int (*rxtx_unmap)(void); +}; + +/** + * The device driver and the Uclass driver public functions + */ + +/** + * ffa_bus_ops_get - driver operations getter + */ +const struct ffa_bus_ops * __ffa_runtime ffa_bus_ops_get(void); + +/** + * ffa_bus_discover - discover FF-A bus and probes the arm_ffa device + */ +int ffa_bus_discover(void); + +#if CONFIG_IS_ENABLED(ARM_FFA_EFI_RUNTIME_MODE) + +/** + * ffa_copy_runtime_data - copy the private data structure and the SPs data to the runtime area + */ +efi_status_t ffa_copy_runtime_data(void); + +#endif + +#endif diff --git a/include/dm/uclass-id.h b/include/dm/uclass-id.h index a432e43871..5dd698b7a9 100644 --- a/include/dm/uclass-id.h +++ b/include/dm/uclass-id.h @@ -4,6 +4,9 @@ * * (C) Copyright 2012 * Pavel Herrmann morpheus.ibis@gmail.com + * + * (C) Copyright 2022 ARM Limited + * Abdellatif El Khlifi abdellatif.elkhlifi@arm.com */
#ifndef _DM_UCLASS_ID_H @@ -55,6 +58,7 @@ enum uclass_id { UCLASS_EFI_MEDIA, /* Devices provided by UEFI firmware */ UCLASS_ETH, /* Ethernet device */ UCLASS_ETH_PHY, /* Ethernet PHY device */ + UCLASS_FFA, /* Arm Firmware Framework for Armv8-A */ UCLASS_FIRMWARE, /* Firmware */ UCLASS_FUZZING_ENGINE, /* Fuzzing engine */ UCLASS_FS_FIRMWARE_LOADER, /* Generic loader */ diff --git a/lib/efi_loader/efi_boottime.c b/lib/efi_loader/efi_boottime.c index 6f7333638a..af0b0f3db1 100644 --- a/lib/efi_loader/efi_boottime.c +++ b/lib/efi_loader/efi_boottime.c @@ -3,6 +3,9 @@ * EFI application boot time services * * Copyright (c) 2016 Alexander Graf + * + * (C) Copyright 2022 ARM Limited + * Abdellatif El Khlifi abdellatif.elkhlifi@arm.com */
#include <common.h> @@ -23,6 +26,10 @@ #include <asm/setjmp.h> #include <linux/libfdt_env.h>
+#if CONFIG_IS_ENABLED(ARM_FFA_TRANSPORT) +#include <arm_ffa.h> +#endif + DECLARE_GLOBAL_DATA_PTR;
/* Task priority level */ @@ -2178,6 +2185,14 @@ static efi_status_t EFIAPI efi_exit_boot_services(efi_handle_t image_handle, dm_remove_devices_flags(DM_REMOVE_ACTIVE_ALL); }
+#if CONFIG_IS_ENABLED(ARM_FFA_TRANSPORT) + /* unmap FF-A RX/TX buffers */ + if (ffa_bus_ops_get()->rxtx_unmap()) + debug("[efi_boottime][ERROR]: can not unmap FF-A RX/TX buffers\n"); + else + debug("[efi_boottime][INFO]: FF-A RX/TX buffers unmapped\n"); +#endif + /* Patch out unsupported runtime function */ efi_runtime_detach();
Provide armffa command showcasing the use of the FF-A driver
The armffa command allows to query secure partitions data from the secure world and exchanging messages with the partitions.
Changelog: ===============
v4:
* remove pattern data in do_ffa_msg_send_direct_req
v3:
* use the new driver interfaces (partition_info_get, sync_send_receive) in armffa command
v2:
* replace use of ffa_helper_init_device function by ffa_helper_bus_discover
v1:
* introduce armffa command
Signed-off-by: Abdellatif El Khlifi abdellatif.elkhlifi@arm.com Cc: Tom Rini trini@konsulko.com Cc: Simon Glass sjg@chromium.org Cc: Ilias Apalodimas ilias.apalodimas@linaro.org Cc: Jens Wiklander jens.wiklander@linaro.org --- MAINTAINERS | 1 + cmd/Kconfig | 10 ++ cmd/Makefile | 2 + cmd/armffa.c | 242 +++++++++++++++++++++++++++++++ drivers/firmware/arm-ffa/Kconfig | 1 + 5 files changed, 256 insertions(+) create mode 100644 cmd/armffa.c
diff --git a/MAINTAINERS b/MAINTAINERS index 02b84d5074..fd3b2c4263 100644 --- a/MAINTAINERS +++ b/MAINTAINERS @@ -251,6 +251,7 @@ F: configs/cortina_presidio-asic-pnand_defconfig ARM FF-A M: Abdellatif El Khlifi abdellatif.elkhlifi@arm.com S: Maintained +F: cmd/armffa.c F: doc/README.ffa.drv F: drivers/firmware/arm-ffa/ F: include/arm_ffa.h diff --git a/cmd/Kconfig b/cmd/Kconfig index 0e0be94f41..013d4c3da7 100644 --- a/cmd/Kconfig +++ b/cmd/Kconfig @@ -912,6 +912,16 @@ endmenu
menu "Device access commands"
+config CMD_ARMFFA + bool "Arm FF-A test command" + depends on ARM_FFA_TRANSPORT + help + Provides a test command for the Arm FF-A driver + supported options: + - Listing the partition(s) info + - Sending a data pattern to the specified partition + - Displaying the arm_ffa device info + config CMD_ARMFLASH #depends on FLASH_CFI_DRIVER bool "armflash" diff --git a/cmd/Makefile b/cmd/Makefile index 6e87522b62..979c6d59df 100644 --- a/cmd/Makefile +++ b/cmd/Makefile @@ -12,6 +12,8 @@ obj-y += panic.o obj-y += version.o
# command + +obj-$(CONFIG_CMD_ARMFFA) += armffa.o obj-$(CONFIG_CMD_ACPI) += acpi.o obj-$(CONFIG_CMD_ADDRMAP) += addrmap.o obj-$(CONFIG_CMD_AES) += aes.o diff --git a/cmd/armffa.c b/cmd/armffa.c new file mode 100644 index 0000000000..9b56e8a830 --- /dev/null +++ b/cmd/armffa.c @@ -0,0 +1,242 @@ +// SPDX-License-Identifier: GPL-2.0+ +/* + * (C) Copyright 2022 ARM Limited + * Abdellatif El Khlifi abdellatif.elkhlifi@arm.com + */ + +#include <arm_ffa.h> +#include <asm/io.h> +#include <common.h> +#include <command.h> +#include <dm.h> +#include <mapmem.h> +#include <stdlib.h> + +/** + * do_ffa_get_singular_partition_info - implementation of the getpart subcommand + * @cmdtp: Command Table + * @flag: flags + * @argc: number of arguments + * @argv: arguments + * + * This function queries the secure partition information which the UUID is provided + * as an argument. The function uses the arm_ffa driver partition_info_get operation + * to retrieve the data. + * The input UUID string is expected to be in big endian format. + * + * Return: + * + * CMD_RET_SUCCESS: on success, otherwise failure + */ +static int do_ffa_get_singular_partition_info(struct cmd_tbl *cmdtp, int flag, int argc, + char *const argv[]) +{ + u32 count = 0, size = 0; + int ret; + struct ffa_partition_info *parts_info; + u32 info_idx; + + if (argc != 1) + return -EINVAL; + + /* Mode 1: getting the number of secure partitions */ + ret = ffa_bus_ops_get()->partition_info_get(argv[0], &count, NULL); + if (ret != 0) { + ffa_err("Failure in querying partitions count (error code: %d)", ret); + return ret; + } + + if (!count) { + ffa_info("No secure partition found"); + return ret; + } + + /* + * pre-allocate a buffer to be filled by the driver + * with ffa_partition_info structs + */ + + ffa_info("Pre-allocating %d partition(s) info structures", count); + + parts_info = calloc(count, sizeof(struct ffa_partition_info)); + if (!parts_info) + return -EINVAL; + + size = count * sizeof(struct ffa_partition_info); + + /* + * ask the driver to fill the buffer with the SPs info + */ + + ret = ffa_bus_ops_get()->partition_info_get(argv[0], &size, parts_info); + if (ret != 0) { + ffa_err("Failure in querying partition(s) info (error code: %d)", ret); + free(parts_info); + return ret; + } + + /* + * SPs found , show the partition information + */ + for (info_idx = 0; info_idx < count ; info_idx++) { + ffa_info("Partition: id = 0x%x , exec_ctxt 0x%x , properties 0x%x", + parts_info[info_idx].id, + parts_info[info_idx].exec_ctxt, + parts_info[info_idx].properties); + } + + free(parts_info); + + return 0; +} + +/** + * do_ffa_msg_send_direct_req - implementation of the ping subcommand + * @cmdtp: Command Table + * @flag: flags + * @argc: number of arguments + * @argv: arguments + * + * This function sends data to the secure partition which the ID is provided + * as an argument. The function uses the arm_ffa driver sync_send_receive operation + * to send data. + * + * Return: + * + * CMD_RET_SUCCESS: on success, otherwise failure + */ +int do_ffa_msg_send_direct_req(struct cmd_tbl *cmdtp, int flag, int argc, + char *const argv[]) +{ + struct ffa_send_direct_data msg = { + .data0 = 0xaaaaaaaa, + .data1 = 0xbbbbbbbb, + .data2 = 0xcccccccc, + .data3 = 0xdddddddd, + .data4 = 0xeeeeeeee, + }; + u16 part_id; + int ret; + + if (argc != 1) + return -EINVAL; + + errno = 0; + part_id = strtoul(argv[0], NULL, 16); + + if (errno) { + ffa_err("Invalid partition ID"); + return -EINVAL; + } + + ret = ffa_bus_ops_get()->sync_send_receive(part_id, &msg); + if (ret == 0) { + u8 cnt; + + ffa_info("SP response:\n[LSB]"); + for (cnt = 0; + cnt < sizeof(struct ffa_send_direct_data) / sizeof(u64); + cnt++) + ffa_info("0x%llx", ((u64 *)&msg)[cnt]); + } else { + ffa_err("Sending direct request error (%d)", ret); + } + + return ret; +} + +/** + *do_ffa_dev_list - implementation of the devlist subcommand + * @cmdtp: [in] Command Table + * @flag: flags + * @argc: number of arguments + * @argv: arguments + * + * This function queries the devices belonging to the UCLASS_FFA + * class. Currently, one device is expected to show up: the arm_ffa device + * + * Return: + * + * CMD_RET_SUCCESS: on success, otherwise failure + */ +int do_ffa_dev_list(struct cmd_tbl *cmdtp, int flag, int argc, char *const argv[]) +{ + struct udevice *dev = NULL; + int i, ret; + + ffa_info("arm_ffa uclass entries:"); + + for (i = 0, ret = uclass_first_device(UCLASS_FFA, &dev); + dev; + ret = uclass_next_device(&dev), i++) { + if (ret) + break; + + ffa_info("entry %d - instance %08x, ops %08x, plat %08x", + i, + (u32)map_to_sysmem(dev), + (u32)map_to_sysmem(dev->driver->ops), + (u32)map_to_sysmem(dev_get_plat(dev))); + } + + return cmd_process_error(cmdtp, ret); +} + +static struct cmd_tbl armffa_commands[] = { + U_BOOT_CMD_MKENT(getpart, 1, 1, do_ffa_get_singular_partition_info, "", ""), + U_BOOT_CMD_MKENT(ping, 1, 1, do_ffa_msg_send_direct_req, "", ""), + U_BOOT_CMD_MKENT(devlist, 0, 1, do_ffa_dev_list, "", ""), +}; + +/** + * do_armffa - the armffa command main function + * @cmdtp: Command Table + * @flag: flags + * @argc: number of arguments + * @argv: arguments + * + * This function identifies which armffa subcommand to run. + * Then, it makes sure the arm_ffa device is probed and + * ready for use. + * Then, it runs the subcommand. + * + * Return: + * + * CMD_RET_SUCCESS: on success, otherwise failure + */ +static int do_armffa(struct cmd_tbl *cmdtp, int flag, int argc, char *const argv[]) +{ + struct cmd_tbl *armffa_cmd; + int ret; + + if (argc < 2) + return CMD_RET_USAGE; + + armffa_cmd = find_cmd_tbl(argv[1], armffa_commands, ARRAY_SIZE(armffa_commands)); + + argc -= 2; + argv += 2; + + if (!armffa_cmd || argc > armffa_cmd->maxargs) + return CMD_RET_USAGE; + + ret = ffa_bus_discover(); + if (ret != 0) + return cmd_process_error(cmdtp, ret); + + if (!ffa_bus_ops_get()) + return -EINVAL; + + ret = armffa_cmd->cmd(armffa_cmd, flag, argc, argv); + + return cmd_process_error(armffa_cmd, ret); +} + +U_BOOT_CMD(armffa, 4, 1, do_armffa, + "Arm FF-A operations test command", + "getpart <partition UUID>\n" + " - lists the partition(s) info\n" + "ping <partition ID>\n" + " - sends a data pattern to the specified partition\n" + "devlist\n" + " - displays the arm_ffa device info\n"); diff --git a/drivers/firmware/arm-ffa/Kconfig b/drivers/firmware/arm-ffa/Kconfig index aceb61cf49..40b467b0a5 100644 --- a/drivers/firmware/arm-ffa/Kconfig +++ b/drivers/firmware/arm-ffa/Kconfig @@ -4,6 +4,7 @@ config ARM_FFA_TRANSPORT bool "Enable Arm Firmware Framework for Armv8-A driver" depends on DM && ARM64 select ARM_SMCCC + select CMD_ARMFFA select LIB_UUID select DEVRES help
Provide a Sandbox driver to emulate the FF-A ABIs
The emulated ABIs are those supported by the FF-A core driver and according to FF-A specification v1.0.
The Sandbox driver provides operations allowing the test application to read the status of all the inspected ABIs and perform functional tests based on that.
v4: align sandbox driver with the new FF-A driver interfaces and new way of error handling
v1: introduce the sandbox driver --- MAINTAINERS | 1 + common/board_r.c | 2 +- configs/sandbox64_defconfig | 2 + configs/sandbox_defconfig | 2 + doc/arch/sandbox.rst | 1 + drivers/firmware/arm-ffa/Kconfig | 10 +- drivers/firmware/arm-ffa/Makefile | 1 + drivers/firmware/arm-ffa/arm_ffa_prv.h | 15 +- drivers/firmware/arm-ffa/core.c | 24 +- drivers/firmware/arm-ffa/sandbox.c | 659 ++++++++++++++++++ .../firmware/arm-ffa/sandbox_arm_ffa_prv.h | 144 ++++ include/arm_ffa.h | 2 +- include/sandbox_arm_ffa.h | 91 +++ lib/efi_loader/efi_boottime.c | 2 +- 14 files changed, 941 insertions(+), 15 deletions(-) create mode 100644 drivers/firmware/arm-ffa/sandbox.c create mode 100644 drivers/firmware/arm-ffa/sandbox_arm_ffa_prv.h create mode 100644 include/sandbox_arm_ffa.h
diff --git a/MAINTAINERS b/MAINTAINERS index fd3b2c4263..6f01002e34 100644 --- a/MAINTAINERS +++ b/MAINTAINERS @@ -255,6 +255,7 @@ F: cmd/armffa.c F: doc/README.ffa.drv F: drivers/firmware/arm-ffa/ F: include/arm_ffa.h +F: include/sandbox_arm_ffa.h
ARM FREESCALE IMX M: Stefano Babic sbabic@denx.de diff --git a/common/board_r.c b/common/board_r.c index 8c99faddfd..7f1eae65df 100644 --- a/common/board_r.c +++ b/common/board_r.c @@ -776,7 +776,7 @@ static init_fnc_t init_sequence_r[] = { INIT_FUNC_WATCHDOG_RESET initr_net, #endif -#ifdef CONFIG_ARM_FFA_TRANSPORT +#if defined(CONFIG_ARM_FFA_TRANSPORT) && !defined(CONFIG_SANDBOX_FFA) ffa_bus_discover, #endif #ifdef CONFIG_POST diff --git a/configs/sandbox64_defconfig b/configs/sandbox64_defconfig index 290d1506c2..36e6448968 100644 --- a/configs/sandbox64_defconfig +++ b/configs/sandbox64_defconfig @@ -248,3 +248,5 @@ CONFIG_TEST_FDTDEC=y CONFIG_UNIT_TEST=y CONFIG_UT_TIME=y CONFIG_UT_DM=y +CONFIG_ARM_FFA_TRANSPORT=y +CONFIG_SANDBOX_FFA=y \ No newline at end of file diff --git a/configs/sandbox_defconfig b/configs/sandbox_defconfig index ab5d3f19bf..8bf3848788 100644 --- a/configs/sandbox_defconfig +++ b/configs/sandbox_defconfig @@ -328,3 +328,5 @@ CONFIG_TEST_FDTDEC=y CONFIG_UNIT_TEST=y CONFIG_UT_TIME=y CONFIG_UT_DM=y +CONFIG_ARM_FFA_TRANSPORT=y +CONFIG_SANDBOX_FFA=y \ No newline at end of file diff --git a/doc/arch/sandbox.rst b/doc/arch/sandbox.rst index 068d4a3be4..5d7e1b2c48 100644 --- a/doc/arch/sandbox.rst +++ b/doc/arch/sandbox.rst @@ -203,6 +203,7 @@ Supported Drivers
U-Boot sandbox supports these emulations:
+- Arm FF-A - Block devices - Chrome OS EC - GPIO diff --git a/drivers/firmware/arm-ffa/Kconfig b/drivers/firmware/arm-ffa/Kconfig index 40b467b0a5..263481de96 100644 --- a/drivers/firmware/arm-ffa/Kconfig +++ b/drivers/firmware/arm-ffa/Kconfig @@ -2,8 +2,8 @@
config ARM_FFA_TRANSPORT bool "Enable Arm Firmware Framework for Armv8-A driver" - depends on DM && ARM64 - select ARM_SMCCC + depends on DM && (ARM64 || SANDBOX) + select ARM_SMCCC if !SANDBOX select CMD_ARMFFA select LIB_UUID select DEVRES @@ -38,3 +38,9 @@ config ARM_FFA_EFI_RUNTIME_MODE The driver Code needed at runtime is placed at EFI runtime code section. Turning this on makes ffa_copy_runtime_data available for use and the driver code placed at EFI runtime code section. + +config SANDBOX_FFA + bool "FF-A Sandbox driver" + depends on ARM_FFA_TRANSPORT && SANDBOX + help + This emulates the FF-A handling under Sandbox and allows to test the FF-A driver diff --git a/drivers/firmware/arm-ffa/Makefile b/drivers/firmware/arm-ffa/Makefile index 0b9b0a61b4..d50060b836 100644 --- a/drivers/firmware/arm-ffa/Makefile +++ b/drivers/firmware/arm-ffa/Makefile @@ -5,3 +5,4 @@
obj-y += arm-ffa-uclass.o core.o obj-$(CONFIG_ARM_FFA_EFI_RUNTIME_MODE) += efi_ffa_runtime_data_mgr.o +obj-$(CONFIG_SANDBOX_FFA) += sandbox.o diff --git a/drivers/firmware/arm-ffa/arm_ffa_prv.h b/drivers/firmware/arm-ffa/arm_ffa_prv.h index 7bc90f7f66..3e0d4c112c 100644 --- a/drivers/firmware/arm-ffa/arm_ffa_prv.h +++ b/drivers/firmware/arm-ffa/arm_ffa_prv.h @@ -19,6 +19,16 @@ /* FF-A core driver name */ #define FFA_DRV_NAME "arm_ffa"
+/* The FF-A SMC function definitions */ + +#if CONFIG_IS_ENABLED(SANDBOX_FFA) +#include "sandbox_arm_ffa.h" +#else +typedef struct arm_smccc_1_2_regs ffa_value_t; +#endif + +typedef void (*invoke_ffa_fn_t)(ffa_value_t args, ffa_value_t *res); + /* FF-A driver version definitions */
#define MAJOR_VERSION_MASK GENMASK(30, 16) @@ -94,11 +104,6 @@ struct ffa_abi_errmap { #define FFA_ERRMAP_COUNT (FFA_LAST_ID - FFA_FIRST_ID + 1) #define FFA_ID_TO_ERRMAP_ID(ffa_id) ((ffa_id) - FFA_FIRST_ID)
-/* The FF-A SMC function definitions */ - -typedef struct arm_smccc_1_2_regs ffa_value_t; -typedef void (*invoke_ffa_fn_t)(ffa_value_t args, ffa_value_t *res); - /* * struct ffa_partition_uuid - 16 bytes UUID transmitted by FFA_PARTITION_INFO_GET * @a1-4: 32-bit words access to the UUID data diff --git a/drivers/firmware/arm-ffa/core.c b/drivers/firmware/arm-ffa/core.c index 41c7b96e68..caba10caae 100644 --- a/drivers/firmware/arm-ffa/core.c +++ b/drivers/firmware/arm-ffa/core.c @@ -1101,6 +1101,7 @@ static int __ffa_runtime ffa_msg_send_direct_req(u16 dst_part_id, struct ffa_sen return ffa_to_std_errno(ffa_errno); }
+#if !CONFIG_IS_ENABLED(SANDBOX_FFA) /** * __arm_ffa_fn_smc - SMC wrapper * @args: FF-A ABI arguments to be copied to Xn registers @@ -1114,6 +1115,7 @@ void __ffa_runtime __arm_ffa_fn_smc(ffa_value_t args, ffa_value_t *res) { arm_smccc_1_2_smc(&args, res); } +#endif
/** * ffa_set_smc_conduit - Set the SMC conduit @@ -1127,7 +1129,12 @@ void __ffa_runtime __arm_ffa_fn_smc(ffa_value_t args, ffa_value_t *res) */ static int ffa_set_smc_conduit(void) { - ffa_priv_data->invoke_ffa_fn = __arm_ffa_fn_smc; +#if CONFIG_IS_ENABLED(SANDBOX_FFA) + ffa_priv_data->invoke_ffa_fn = sandbox_arm_ffa_smccc_smc; + ffa_info("Using SMC emulation"); +#else + ffa_priv_data->invoke_ffa_fn = __arm_ffa_fn_smc; +#endif
if (!ffa_priv_data->invoke_ffa_fn) { ffa_err("failure to set the invoke function"); @@ -1304,17 +1311,18 @@ struct ffa_prvdata **ffa_bus_prvdata_get(void) }
/** - * ffa_bus_discover - discover FF-A bus and probe the arm_ffa device + * ffa_bus_discover - discover FF-A bus and probe arm_ffa and sandbox_arm_ffa devices * * This boot time function makes sure the FF-A bus is discoverable. - * Then, the arm_ffa device is probed and ready to use. + * Then, the arm_ffa and sandbox_arm_ffa devices are ready to use. + * * This function is called automatically at initcalls * level (after u-boot relocation). * * When the bus was already discovered successfully the discovery will not run again. * * Arm FF-A transport is implemented through arm_ffa u-boot device managing the FF-A - * communication. + * communication. In Sandbox mode sandbox_arm_ffa is used to test arm_ffa driver. * All FF-A clients should use the arm_ffa device to use the FF-A transport. * * Return: @@ -1325,9 +1333,15 @@ int ffa_bus_discover(void) { int ret = 0;
- if (!ffa_priv_data) + if (!ffa_priv_data) { ret = ffa_device_get();
+#if CONFIG_IS_ENABLED(SANDBOX_FFA) + if (ret == 0) + ret = sandbox_ffa_device_get(); +#endif + } + return ret; }
diff --git a/drivers/firmware/arm-ffa/sandbox.c b/drivers/firmware/arm-ffa/sandbox.c new file mode 100644 index 0000000000..16e1fdc809 --- /dev/null +++ b/drivers/firmware/arm-ffa/sandbox.c @@ -0,0 +1,659 @@ +// SPDX-License-Identifier: GPL-2.0+ +/* + * (C) Copyright 2022 ARM Limited + * Abdellatif El Khlifi abdellatif.elkhlifi@arm.com + */ + +#include "sandbox_arm_ffa_prv.h" +#include <asm/global_data.h> +#include <common.h> +#include <dm.h> +#include <dm/device-internal.h> +#include <dm/root.h> +#include <linux/errno.h> +#include <linux/sizes.h> +#include <mapmem.h> +#include <string.h> + +DECLARE_GLOBAL_DATA_PTR; + +/** + * The device private data structure containing all the emulated secure world data + */ +static struct sandbox_ffa_prvdata sandbox_ffa_priv_data = {0}; + +/* The partitions (SPs) table */ +static struct ffa_partition_desc sandbox_partitions[SANDBOX_PARTITIONS_CNT] = { + { + .info = { .id = SANDBOX_SP1_ID, .exec_ctxt = 0x5687, .properties = 0x89325621 }, + .sp_uuid = { + .a1 = SANDBOX_SERVICE1_UUID_A1, + .a2 = SANDBOX_SERVICE1_UUID_A2, + .a3 = SANDBOX_SERVICE1_UUID_A3, + .a4 = SANDBOX_SERVICE1_UUID_A4, + } + }, + { + .info = { .id = SANDBOX_SP2_ID, .exec_ctxt = 0x9587, .properties = 0x45325621 }, + .sp_uuid = { + .a1 = SANDBOX_SERVICE2_UUID_A1, + .a2 = SANDBOX_SERVICE2_UUID_A2, + .a3 = SANDBOX_SERVICE2_UUID_A3, + .a4 = SANDBOX_SERVICE2_UUID_A4, + } + }, + { + .info = { .id = SANDBOX_SP3_ID, .exec_ctxt = 0x7687, .properties = 0x23325621 }, + .sp_uuid = { + .a1 = SANDBOX_SERVICE1_UUID_A1, + .a2 = SANDBOX_SERVICE1_UUID_A2, + .a3 = SANDBOX_SERVICE1_UUID_A3, + .a4 = SANDBOX_SERVICE1_UUID_A4, + } + }, + { + .info = { .id = SANDBOX_SP4_ID, .exec_ctxt = 0x1487, .properties = 0x70325621 }, + .sp_uuid = { + .a1 = SANDBOX_SERVICE2_UUID_A1, + .a2 = SANDBOX_SERVICE2_UUID_A2, + .a3 = SANDBOX_SERVICE2_UUID_A3, + .a4 = SANDBOX_SERVICE2_UUID_A4, + } + } + +}; + +/* + * Driver functions + */ + +/** + * sandbox_ffa_get_device - probes the sandbox_arm_ffa device + * + * This function makes sure the sandbox_arm_ffa device is probed + * This function makes sure the sandbox_arm_ffa device is + * created, bound to this driver, probed and ready to use. + * + * sandbox_arm_ffa depends on arm_ffa device. This dependency is + * handled by ffa_bus_discover function. arm_ffa is probed first then + * sandbox_arm_ffa. + * + * Return: + * + * 0 on success. Otherwise, failure + */ +int sandbox_ffa_device_get(void) +{ + int ret; + + if (sandbox_ffa_priv_data.dev) + return 0; + + ret = device_bind(dm_root(), + DM_DRIVER_GET(sandbox_arm_ffa), + FFA_SANDBOX_DRV_NAME, + NULL, + ofnode_null(), + &sandbox_ffa_priv_data.dev); + if (ret) { + sandbox_ffa_priv_data.dev = NULL; + return ret; + } + + ret = device_probe(sandbox_ffa_priv_data.dev); + if (ret) { + ffa_err("[Sandbox] can not probe the device"); + device_unbind(sandbox_ffa_priv_data.dev); + sandbox_ffa_priv_data.dev = NULL; + return ret; + } + + return 0; +} + +/** + * sandbox_ffa_version - Emulated FFA_VERSION handler function + * @{a0-a7} , res: The SMC call arguments and return structure. + * + * This is the function that emulates FFA_VERSION FF-A function. + * + * Return: + * + * 0 on success. Otherwise, failure + */ +SANDBOX_SMC_FFA_ABI(ffa_version) +{ + sandbox_ffa_priv_data.fwk_version = FFA_VERSION_1_0; + res->a0 = sandbox_ffa_priv_data.fwk_version; + + /* x1-x7 MBZ */ + memset(FFA_X1X7_MBZ_REG_START, 0, FFA_X1X7_MBZ_CNT * sizeof(unsigned long)); + + return 0; +} + +/** + * sandbox_ffa_id_get - Emulated FFA_ID_GET handler function + * @{a0-a7} , res: The SMC call arguments and return structure. + * + * This is the function that emulates FFA_ID_GET FF-A function. + * + * Return: + * + * 0 on success. Otherwise, failure + */ +SANDBOX_SMC_FFA_ABI(ffa_id_get) +{ + res->a0 = FFA_SMC_32(FFA_SUCCESS); + res->a1 = 0; + + sandbox_ffa_priv_data.id = NS_PHYS_ENDPOINT_ID; + res->a2 = sandbox_ffa_priv_data.id; + + /* x3-x7 MBZ */ + memset(FFA_X3_MBZ_REG_START, 0, FFA_X3X7_MBZ_CNT * sizeof(unsigned long)); + + return 0; +} + +/** + * sandbox_ffa_features - Emulated FFA_FEATURES handler function + * @{a0-a7} , res: The SMC call arguments and return structure. + * + * This is the function that emulates FFA_FEATURES FF-A function. + * + * Return: + * + * 0 on success. Otherwise, failure + */ +SANDBOX_SMC_FFA_ABI(ffa_features) +{ + if (pargs->a1 == FFA_SMC_64(FFA_RXTX_MAP)) { + res->a0 = FFA_SMC_32(FFA_SUCCESS); + res->a2 = RXTX_BUFFERS_MIN_SIZE; + res->a3 = 0; + /* x4-x7 MBZ */ + memset(FFA_X4X7_MBZ_REG_START, + 0, FFA_X4X7_MBZ_CNT * sizeof(unsigned long)); + } else { + res->a0 = FFA_SMC_32(FFA_ERROR); + res->a2 = FFA_ERR_STAT_NOT_SUPPORTED; + /* x3-x7 MBZ */ + memset(FFA_X3_MBZ_REG_START, + 0, FFA_X3X7_MBZ_CNT * sizeof(unsigned long)); + ffa_err("[Sandbox] FF-A interface 0x%lx not implemented", pargs->a1); + } + + res->a1 = 0; + + return 0; +} + +/** + * sandbox_ffa_partition_info_get - Emulated FFA_PARTITION_INFO_GET handler function + * @{a0-a7} , res: The SMC call arguments and return structure. + * + * This is the function that emulates FFA_PARTITION_INFO_GET FF-A function. + * + * Return: + * + * 0 on success. Otherwise, failure + */ +SANDBOX_SMC_FFA_ABI(ffa_partition_info_get) +{ + struct ffa_partition_info *rxbuf_desc_info = NULL; + u32 descs_cnt; + u32 descs_size_bytes; + + res->a0 = FFA_SMC_32(FFA_ERROR); + + if (!sandbox_ffa_priv_data.pair.rxbuf) { + res->a2 = FFA_ERR_STAT_DENIED; + goto cleanup; + } + + if (sandbox_ffa_priv_data.pair_info.rxbuf_owned) { + res->a2 = FFA_ERR_STAT_BUSY; + goto cleanup; + } + + if (!sandbox_ffa_priv_data.partitions.descs) { + sandbox_ffa_priv_data.partitions.descs = sandbox_partitions; + sandbox_ffa_priv_data.partitions.count = SANDBOX_PARTITIONS_CNT; + } + + descs_size_bytes = SANDBOX_PARTITIONS_CNT * sizeof(struct ffa_partition_desc); + + /* Abort if the RX buffer size is smaller than the descriptors buffer size */ + if ((sandbox_ffa_priv_data.pair_info.rxtx_buf_size * SZ_4K) < descs_size_bytes) { + res->a2 = FFA_ERR_STAT_NO_MEMORY; + goto cleanup; + } + + rxbuf_desc_info = (struct ffa_partition_info *)sandbox_ffa_priv_data.pair.rxbuf; + + /* No UUID specified. Return the information of all partitions */ + if (!pargs->a1 && !pargs->a2 && !pargs->a3 && !pargs->a4) { + for (descs_cnt = 0 ; descs_cnt < SANDBOX_PARTITIONS_CNT ; descs_cnt++) + *(rxbuf_desc_info++) = + sandbox_ffa_priv_data.partitions.descs[descs_cnt].info; + + res->a0 = FFA_SMC_32(FFA_SUCCESS); + res->a2 = SANDBOX_PARTITIONS_CNT; + /* transfer ownership to the consumer: the non secure world */ + sandbox_ffa_priv_data.pair_info.rxbuf_owned = 1; + + goto cleanup; + } + + /* + * A UUID is specified. Return the information of all partitions matching + * the UUID + */ + + for (descs_cnt = 0 ; descs_cnt < SANDBOX_PARTITIONS_CNT ; descs_cnt++) + if (pargs->a1 == sandbox_ffa_priv_data.partitions.descs[descs_cnt].sp_uuid.a1 && + pargs->a2 == sandbox_ffa_priv_data.partitions.descs[descs_cnt].sp_uuid.a2 && + pargs->a3 == sandbox_ffa_priv_data.partitions.descs[descs_cnt].sp_uuid.a3 && + pargs->a4 == sandbox_ffa_priv_data.partitions.descs[descs_cnt].sp_uuid.a4) { + *(rxbuf_desc_info++) = + sandbox_ffa_priv_data.partitions.descs[descs_cnt].info; + } + + if (rxbuf_desc_info != ((struct ffa_partition_info *)sandbox_ffa_priv_data.pair.rxbuf)) { + res->a0 = FFA_SMC_32(FFA_SUCCESS); + /* store the partitions count */ + res->a2 = (unsigned long) + (rxbuf_desc_info - (struct ffa_partition_info *) + sandbox_ffa_priv_data.pair.rxbuf); + + /* transfer ownership to the consumer: the non secure world */ + sandbox_ffa_priv_data.pair_info.rxbuf_owned = 1; + } else { + /* Unrecognized UUID */ + res->a2 = FFA_ERR_STAT_INVALID_PARAMETERS; + } + +cleanup: + + ffa_err("[Sandbox] FFA_PARTITION_INFO_GET (%ld)", res->a2); + + res->a1 = 0; + + /* x3-x7 MBZ */ + memset(FFA_X3_MBZ_REG_START, 0, FFA_X3X7_MBZ_CNT * sizeof(unsigned long)); + + return 0; +} + +/** + * sandbox_ffa_rxtx_map - Emulated FFA_RXTX_MAP handler function + * @{a0-a7} , res: The SMC call arguments and return structure. + * + * This is the function that emulates FFA_RXTX_MAP FF-A function. + * + * Return: + * + * 0 on success. Otherwise, failure + */ +SANDBOX_SMC_FFA_ABI(ffa_rxtx_map) +{ + res->a0 = FFA_SMC_32(FFA_ERROR); + + if (sandbox_ffa_priv_data.pair.txbuf && sandbox_ffa_priv_data.pair.rxbuf) { + res->a2 = FFA_ERR_STAT_DENIED; + goto feedback; + } + + if (pargs->a3 >= RXTX_BUFFERS_MIN_PAGES && pargs->a1 && pargs->a2) { + sandbox_ffa_priv_data.pair.txbuf = pargs->a1; + sandbox_ffa_priv_data.pair.rxbuf = pargs->a2; + sandbox_ffa_priv_data.pair_info.rxtx_buf_size = pargs->a3; + sandbox_ffa_priv_data.pair_info.rxbuf_mapped = 1; + res->a0 = FFA_SMC_32(FFA_SUCCESS); + res->a2 = 0; + goto feedback; + } + + if (!pargs->a1 || !pargs->a2) + res->a2 = FFA_ERR_STAT_INVALID_PARAMETERS; + else + res->a2 = FFA_ERR_STAT_NO_MEMORY; + + ffa_err("[Sandbox] error in FFA_RXTX_MAP arguments (%d)", (int)res->a2); + +feedback: + + res->a1 = 0; + + /* x3-x7 MBZ */ + memset(FFA_X3_MBZ_REG_START, + 0, FFA_X3X7_MBZ_CNT * sizeof(unsigned long)); + + return 0; +} + +/** + * sandbox_ffa_rxtx_unmap - Emulated FFA_RXTX_UNMAP handler function + * @{a0-a7} , res: The SMC call arguments and return structure. + * + * This is the function that emulates FFA_RXTX_UNMAP FF-A function. + * + * Return: + * + * 0 on success. Otherwise, failure + */ +SANDBOX_SMC_FFA_ABI(ffa_rxtx_unmap) +{ + res->a0 = FFA_SMC_32(FFA_ERROR); + res->a2 = FFA_ERR_STAT_INVALID_PARAMETERS; + + if (GET_NS_PHYS_ENDPOINT_ID(pargs->a1) != sandbox_ffa_priv_data.id) + goto feedback; + + if (sandbox_ffa_priv_data.pair.txbuf && sandbox_ffa_priv_data.pair.rxbuf) { + sandbox_ffa_priv_data.pair.txbuf = 0; + sandbox_ffa_priv_data.pair.rxbuf = 0; + sandbox_ffa_priv_data.pair_info.rxtx_buf_size = 0; + sandbox_ffa_priv_data.pair_info.rxbuf_mapped = 0; + res->a0 = FFA_SMC_32(FFA_SUCCESS); + res->a2 = 0; + goto feedback; + } + + ffa_err("[Sandbox] No buffer pair registered on behalf of the caller"); + +feedback: + + res->a1 = 0; + + /* x3-x7 MBZ */ + memset(FFA_X3_MBZ_REG_START, + 0, FFA_X3X7_MBZ_CNT * sizeof(unsigned long)); + + return 0; +} + +/** + * sandbox_ffa_rx_release - Emulated FFA_RX_RELEASE handler function + * @{a0-a7} , res: The SMC call arguments and return structure. + * + * This is the function that emulates FFA_RX_RELEASE FF-A function. + * + * Return: + * + * 0 on success. Otherwise, failure + */ +SANDBOX_SMC_FFA_ABI(ffa_rx_release) +{ + if (!sandbox_ffa_priv_data.pair_info.rxbuf_owned) { + res->a0 = FFA_SMC_32(FFA_ERROR); + res->a2 = FFA_ERR_STAT_DENIED; + } else { + sandbox_ffa_priv_data.pair_info.rxbuf_owned = 0; + res->a0 = FFA_SMC_32(FFA_SUCCESS); + res->a2 = 0; + } + + res->a1 = 0; + + /* x3-x7 MBZ */ + memset(FFA_X3_MBZ_REG_START, + 0, FFA_X3X7_MBZ_CNT * sizeof(unsigned long)); + + return 0; +} + +/** + * sandbox_ffa_sp_valid - Checks SP validity + * @part_id: partition ID to check + * + * This is the function searches the input ID in the descriptors table. + * + * Return: + * + * 1 on success (Partition found). Otherwise, failure + */ +static int sandbox_ffa_sp_valid(u16 part_id) +{ + u32 descs_cnt; + + for (descs_cnt = 0 ; descs_cnt < SANDBOX_PARTITIONS_CNT ; descs_cnt++) + if (sandbox_ffa_priv_data.partitions.descs[descs_cnt].info.id == part_id) + return 1; + + return 0; +} + +/** + * sandbox_ffa_msg_send_direct_req - Emulated FFA_MSG_SEND_DIRECT_{REQ,RESP} handler function + * @{a0-a7} , res: The SMC call arguments and return structure. + * + * This is the function that emulates FFA_MSG_SEND_DIRECT_{REQ,RESP} + * FF-A functions. + * + * Emulating interrupts is not supported. So, FFA_RUN and FFA_INTERRUPT are not supported. + * In case of success FFA_MSG_SEND_DIRECT_RESP is returned with default pattern data (0xff). + * + * Return: + * + * 0 on success. Otherwise, failure + */ +SANDBOX_SMC_FFA_ABI(ffa_msg_send_direct_req) +{ + u16 part_id; + + part_id = GET_DST_SP_ID(pargs->a1); + + if ((GET_NS_PHYS_ENDPOINT_ID(pargs->a1) != sandbox_ffa_priv_data.id) || + !sandbox_ffa_sp_valid(part_id) || + pargs->a2) { + res->a0 = FFA_SMC_32(FFA_ERROR); + res->a1 = 0; + res->a2 = FFA_ERR_STAT_INVALID_PARAMETERS; + + /* x3-x7 MBZ */ + memset(FFA_X3_MBZ_REG_START, + 0, FFA_X3X7_MBZ_CNT * sizeof(unsigned long)); + + return 0; + } + + res->a0 = FFA_SMC_64(FFA_MSG_SEND_DIRECT_RESP); + + res->a1 = PREP_SRC_SP_ID(part_id) | + PREP_NS_PHYS_ENDPOINT_ID(sandbox_ffa_priv_data.id); + + res->a2 = 0; + + /* + * return 0xff bytes as a response + */ + res->a3 = 0xffffffffffffffff; + res->a4 = 0xffffffffffffffff; + res->a5 = 0xffffffffffffffff; + res->a6 = 0xffffffffffffffff; + res->a7 = 0xffffffffffffffff; + + return 0; +} + +/** + * sandbox_ffa_get_prv_data - Returns the pointer to FF-A core pivate data + * @func_data: Pointer to the FF-A function arguments container structure + * + * This is the handler that returns the address of the FF-A core pivate data. + * + * Return: + * + * 0 on success. Otherwise, failure + */ +static int sandbox_ffa_get_prv_data(struct ffa_sandbox_data *func_data) +{ + if (!func_data) + return -EINVAL; + + if (!func_data->data0 || func_data->data0_size != sizeof(struct ffa_prvdata **)) + return -EINVAL; + + if (!func_data->data1 || func_data->data1_size != sizeof(struct sandbox_ffa_prvdata **)) + return -EINVAL; + + *((struct ffa_prvdata **)func_data->data0) = *(ffa_bus_prvdata_get()); + *((struct sandbox_ffa_prvdata **)func_data->data1) = &sandbox_ffa_priv_data; + + return 0; +} + +/** + * sandbox_ffa_get_rxbuf_flags - Reading the mapping/ownership flags + * @queried_func_id: The FF-A function to be queried + * @func_data: Pointer to the FF-A function arguments container structure + * + * This is the handler that queries the status flags of the following emulated ABIs: + * FFA_RXTX_MAP, FFA_RXTX_UNMAP, FFA_RX_RELEASE + * + * Return: + * + * 0 on success. Otherwise, failure + */ +static int sandbox_ffa_get_rxbuf_flags(u32 queried_func_id, struct ffa_sandbox_data *func_data) +{ + if (!func_data) + return -EINVAL; + + if (!func_data->data0 || func_data->data0_size != sizeof(u8)) + return -EINVAL; + + switch (queried_func_id) { + case FFA_RXTX_MAP: + case FFA_RXTX_UNMAP: + *((u8 *)func_data->data0) = sandbox_ffa_priv_data.pair_info.rxbuf_mapped; + return 0; + case FFA_RX_RELEASE: + *((u8 *)func_data->data0) = sandbox_ffa_priv_data.pair_info.rxbuf_owned; + return 0; + default: + ffa_err("[Sandbox] The querried FF-A interface flag (%d) undefined", + queried_func_id); + return -EINVAL; + } +} + +/** + * sandbox_ffa_query_core_state - The driver dispatcher function + * @queried_func_id: The FF-A function to be queried + * @func_data: Pointer to the FF-A function arguments container structure + * + * Queries the status of FF-A ABI specified in the input argument. + * + * Return: + * + * 0 on success. Otherwise, failure + */ +int sandbox_ffa_query_core_state(u32 queried_func_id, struct ffa_sandbox_data *func_data) +{ + switch (queried_func_id) { + case FFA_VERSION: + case FFA_ID_GET: + case FFA_FEATURES: + return sandbox_ffa_get_prv_data(func_data); + case FFA_RXTX_MAP: + case FFA_RXTX_UNMAP: + case FFA_RX_RELEASE: + return sandbox_ffa_get_rxbuf_flags(queried_func_id, func_data); + default: + ffa_err("[Sandbox] The querried FF-A interface (%d) undefined", queried_func_id); + return -EINVAL; + } +} + +/** + * sandbox_arm_ffa_smccc_smc - FF-A SMC call emulation + * @args: the SMC call arguments + * @res: the SMC call returned data + * + * Sandbox driver emulates the FF-A ABIs SMC call using this function. + * The emulated FF-A ABI is identified and invoked. + * FF-A emulation is based on the FF-A specification 1.0 + * + * Return: + * + * 0 on success. Otherwise, failure. + * FF-A protocol error codes are returned using the registers arguments as described + * by the specification + */ +void sandbox_arm_ffa_smccc_smc(ffa_value_t args, ffa_value_t *res) +{ + int ret = 0; + + switch (args.a0) { + case FFA_SMC_32(FFA_VERSION): + ret = sandbox_ffa_version(&args, res); + break; + case FFA_SMC_32(FFA_PARTITION_INFO_GET): + ret = sandbox_ffa_partition_info_get(&args, res); + break; + case FFA_SMC_32(FFA_RXTX_UNMAP): + ret = sandbox_ffa_rxtx_unmap(&args, res); + break; + case FFA_SMC_64(FFA_MSG_SEND_DIRECT_REQ): + ret = sandbox_ffa_msg_send_direct_req(&args, res); + break; + case FFA_SMC_32(FFA_ID_GET): + ret = sandbox_ffa_id_get(&args, res); + break; + case FFA_SMC_32(FFA_FEATURES): + ret = sandbox_ffa_features(&args, res); + break; + case FFA_SMC_64(FFA_RXTX_MAP): + ret = sandbox_ffa_rxtx_map(&args, res); + break; + case FFA_SMC_32(FFA_RX_RELEASE): + ret = sandbox_ffa_rx_release(&args, res); + break; + default: + ffa_err("[Sandbox] Undefined FF-A interface (0x%lx)", args.a0); + } + + if (ret != 0) + ffa_err("[Sandbox] FF-A ABI internal failure (%d)", ret); +} + +/** + * sandbox_ffa_probe - The driver probe function + * @dev: the sandbox_arm_ffa device + * + * Return: + * + * 0 on success. Otherwise, failure + */ +static int sandbox_ffa_probe(struct udevice *dev) +{ + return 0; +} + +/** + * sandbox_ffa_remove - The driver remove function + * @dev: the sandbox_arm_ffa device + * + * Return: + * + * 0 on success. Otherwise, failure + */ +static int sandbox_ffa_remove(struct udevice *dev) +{ + ffa_info("[Sandbox] removing the device"); + memset(&sandbox_ffa_priv_data, 0, sizeof(sandbox_ffa_priv_data)); + return 0; +} + +/** + * Declaring the sandbox_arm_ffa driver under UCLASS_FFA + */ +U_BOOT_DRIVER(sandbox_arm_ffa) = { + .name = FFA_SANDBOX_DRV_NAME, + .id = UCLASS_FFA, + .probe = sandbox_ffa_probe, + .remove = sandbox_ffa_remove, +}; diff --git a/drivers/firmware/arm-ffa/sandbox_arm_ffa_prv.h b/drivers/firmware/arm-ffa/sandbox_arm_ffa_prv.h new file mode 100644 index 0000000000..4db57f5092 --- /dev/null +++ b/drivers/firmware/arm-ffa/sandbox_arm_ffa_prv.h @@ -0,0 +1,144 @@ +/* SPDX-License-Identifier: GPL-2.0+ */ +/* + * (C) Copyright 2022 ARM Limited + * Abdellatif El Khlifi abdellatif.elkhlifi@arm.com + */ + +#ifndef __SANDBOX_ARM_FFA_PRV_H +#define __SANDBOX_ARM_FFA_PRV_H + +#include "arm_ffa_prv.h" +#include <sandbox_arm_ffa.h> + +/* + * This header is private. It is exclusively used by the Sandbox FF-A driver + */ + +/* FF-A core driver name */ +#define FFA_SANDBOX_DRV_NAME "sandbox_arm_ffa" + +/* FF-A ABIs internal error codes (as defined by the spec) */ + +#define FFA_ERR_STAT_NOT_SUPPORTED -1 +#define FFA_ERR_STAT_INVALID_PARAMETERS -2 +#define FFA_ERR_STAT_NO_MEMORY -3 +#define FFA_ERR_STAT_BUSY -4 +#define FFA_ERR_STAT_DENIED -6 + +/* Providing Arm SMCCC declarations to sandbox */ + +#define ARM_SMCCC_FAST_CALL 1UL +#define ARM_SMCCC_OWNER_STANDARD 4 +#define ARM_SMCCC_SMC_32 0 +#define ARM_SMCCC_SMC_64 1 +#define ARM_SMCCC_TYPE_SHIFT 31 +#define ARM_SMCCC_CALL_CONV_SHIFT 30 +#define ARM_SMCCC_OWNER_MASK 0x3F +#define ARM_SMCCC_OWNER_SHIFT 24 +#define ARM_SMCCC_FUNC_MASK 0xFFFF + +#define ARM_SMCCC_CALL_VAL(type, calling_convention, owner, func_num) \ + (((type) << ARM_SMCCC_TYPE_SHIFT) | \ + ((calling_convention) << ARM_SMCCC_CALL_CONV_SHIFT) | \ + (((owner) & ARM_SMCCC_OWNER_MASK) << ARM_SMCCC_OWNER_SHIFT) | \ + ((func_num) & ARM_SMCCC_FUNC_MASK)) + +/* Non-secure physical FF-A instance */ +#define NS_PHYS_ENDPOINT_ID (0) + +#define GET_NS_PHYS_ENDPOINT_ID_MASK GENMASK(31, 16) +#define GET_NS_PHYS_ENDPOINT_ID(x) \ + ((u16)(FIELD_GET(GET_NS_PHYS_ENDPOINT_ID_MASK, (x)))) + +/* Helper macro for reading the destination partition ID */ +#define GET_DST_SP_ID_MASK GENMASK(15, 0) +#define GET_DST_SP_ID(x) \ + ((u16)(FIELD_GET(GET_DST_SP_ID_MASK, (x)))) + +/* Helper macro for setting the source partition ID */ +#define PREP_SRC_SP_ID_MASK GENMASK(31, 16) +#define PREP_SRC_SP_ID(x) \ + (FIELD_PREP(PREP_SRC_SP_ID_MASK, (x))) + +/* Helper macro for setting the destination endpoint ID */ +#define PREP_NS_PHYS_ENDPOINT_ID_MASK GENMASK(15, 0) +#define PREP_NS_PHYS_ENDPOINT_ID(x) \ + (FIELD_PREP(PREP_NS_PHYS_ENDPOINT_ID_MASK, (x))) + +/* RX/TX buffers minimum size */ +#define RXTX_BUFFERS_MIN_SIZE (RXTX_4K) +#define RXTX_BUFFERS_MIN_PAGES (1) + +/* MBZ registers info */ + +/* x1-x7 MBZ */ +#define FFA_X1X7_MBZ_CNT (7) +#define FFA_X1X7_MBZ_REG_START (&res->a1) + +/* x4-x7 MBZ */ +#define FFA_X4X7_MBZ_CNT (4) +#define FFA_X4X7_MBZ_REG_START (&res->a4) + +/* x3-x7 MBZ */ +#define FFA_X3X7_MBZ_CNT (5) +#define FFA_X3_MBZ_REG_START (&res->a3) + +/* secure partitions count */ +#define SANDBOX_PARTITIONS_CNT (4) + +/* service 1 UUID binary data (little-endian format) */ +#define SANDBOX_SERVICE1_UUID_A1 0xed32d533 +#define SANDBOX_SERVICE1_UUID_A2 0x99e64209 +#define SANDBOX_SERVICE1_UUID_A3 0x9cc02d72 +#define SANDBOX_SERVICE1_UUID_A4 0xcdd998a7 + +/* service 2 UUID binary data (little-endian format) */ +#define SANDBOX_SERVICE2_UUID_A1 0xed32d544 +#define SANDBOX_SERVICE2_UUID_A2 0x99e64209 +#define SANDBOX_SERVICE2_UUID_A3 0x9cc02d72 +#define SANDBOX_SERVICE2_UUID_A4 0xcdd998a7 + +/** + * struct ffa_rxtxpair_info - structure hosting the RX/TX buffers flags + * @rxbuf_owned: RX buffer ownership flag (the owner is non secure world: the consumer) + * @rxbuf_mapped: RX buffer mapping flag + * @txbuf_owned TX buffer ownership flag + * @txbuf_mapped: TX buffer mapping flag + * @rxtx_buf_size: RX/TX buffers size as set by the FF-A core driver + * + * Data structure hosting the ownership/mapping flags of the RX/TX buffers + * When a buffer is owned/mapped its corresponding flag is set to 1 otherwise 0. + */ +struct ffa_rxtxpair_info { + u8 rxbuf_owned; + u8 rxbuf_mapped; + u8 txbuf_owned; + u8 txbuf_mapped; + u32 rxtx_buf_size; +}; + +/** + * struct sandbox_ffa_prvdata - the driver private data structure + * + * @dev: The arm_ffa device under u-boot driver model + * @fwk_version: FF-A framework version + * @id: u-boot endpoint ID + * @partitions: The partitions descriptors structure + * @pair: The RX/TX buffers pair + * @pair_info: The RX/TX buffers pair flags and size + * @conduit: The selected conduit + * + * The driver data structure hosting all the emulated secure world data. + */ +struct sandbox_ffa_prvdata { + struct udevice *dev; + u32 fwk_version; + u16 id; + struct ffa_partitions partitions; + struct ffa_rxtxpair pair; + struct ffa_rxtxpair_info pair_info; +}; + +#define SANDBOX_SMC_FFA_ABI(ffabi) static int sandbox_##ffabi(ffa_value_t *pargs, ffa_value_t *res) + +#endif diff --git a/include/arm_ffa.h b/include/arm_ffa.h index f17b100497..665413a0c5 100644 --- a/include/arm_ffa.h +++ b/include/arm_ffa.h @@ -111,7 +111,7 @@ struct ffa_bus_ops { const struct ffa_bus_ops * __ffa_runtime ffa_bus_ops_get(void);
/** - * ffa_bus_discover - discover FF-A bus and probes the arm_ffa device + * ffa_bus_discover - discover FF-A bus and probes the arm_ffa and sandbox_arm_ffa devices */ int ffa_bus_discover(void);
diff --git a/include/sandbox_arm_ffa.h b/include/sandbox_arm_ffa.h new file mode 100644 index 0000000000..d5df16f282 --- /dev/null +++ b/include/sandbox_arm_ffa.h @@ -0,0 +1,91 @@ +/* SPDX-License-Identifier: GPL-2.0+ */ +/* + * (C) Copyright 2022 ARM Limited + * Abdellatif El Khlifi abdellatif.elkhlifi@arm.com + */ + +#ifndef __SANDBOX_ARM_FFA_H +#define __SANDBOX_ARM_FFA_H + +#include <arm_ffa.h> + +/** + * struct sandbox_smccc_1_2_regs - Arguments for or Results from emulated SMC call + * @a0-a17 argument values from registers 0 to 17 + */ +struct sandbox_smccc_1_2_regs { + unsigned long a0; + unsigned long a1; + unsigned long a2; + unsigned long a3; + unsigned long a4; + unsigned long a5; + unsigned long a6; + unsigned long a7; + unsigned long a8; + unsigned long a9; + unsigned long a10; + unsigned long a11; + unsigned long a12; + unsigned long a13; + unsigned long a14; + unsigned long a15; + unsigned long a16; + unsigned long a17; +}; + +typedef struct sandbox_smccc_1_2_regs ffa_value_t; + +/* UUIDs of services supported by the sandbox driver */ +#define SANDBOX_SERVICE1_UUID "ed32d533-4209-99e6-2d72-cdd998a79cc0" +#define SANDBOX_SERVICE2_UUID "ed32d544-4209-99e6-2d72-cdd998a79cc0" +#define SANDBOX_SP1_ID 0x1245 +#define SANDBOX_SP2_ID 0x9836 +#define SANDBOX_SP3_ID 0x6452 +#define SANDBOX_SP4_ID 0x7814 + +/* invalid service UUID (no matching SP) */ +#define SANDBOX_SERVICE3_UUID "55d532ed-0942-e699-722d-c09ca798d9cd" + +/* invalid service UUID (invalid UUID string format) */ +#define SANDBOX_SERVICE4_UUID "32ed-0942-e699-722d-c09ca798d9cd" + +#define SANDBOX_SP_COUNT_PER_VALID_SERVICE 2 + +/** + * struct ffa_sandbox_data - generic data structure used to exchange + * data between test cases and the sandbox driver + * @data0_size: size of the first argument + * @data0: pointer to the first argument + * @data1_size>: size of the second argument + * @data1: pointer to the second argument + * + * Using this structure sandbox test cases can pass various types of data with different sizes. + */ +struct ffa_sandbox_data { + u32 data0_size; /* size of the first argument */ + void *data0; /* pointer to the first argument */ + u32 data1_size; /* size of the second argument */ + void *data1; /* pointer to the second argument */ +}; + +/** + * The sandbox driver public functions + */ + +/** + * sandbox_ffa_query_core_state - Queries the status of FF-A ABIs + */ +int sandbox_ffa_query_core_state(u32 queried_func_id, struct ffa_sandbox_data *func_data); + +/** + * sandbox_ffa_get_device - create, bind and probe the sandbox_arm_ffa device + */ +int sandbox_ffa_device_get(void); + +/** + * sandbox_arm_ffa_smccc_smc - FF-A SMC call emulation + */ +void sandbox_arm_ffa_smccc_smc(ffa_value_t args, ffa_value_t *res); + +#endif diff --git a/lib/efi_loader/efi_boottime.c b/lib/efi_loader/efi_boottime.c index af0b0f3db1..d404343a7d 100644 --- a/lib/efi_loader/efi_boottime.c +++ b/lib/efi_loader/efi_boottime.c @@ -2185,7 +2185,7 @@ static efi_status_t EFIAPI efi_exit_boot_services(efi_handle_t image_handle, dm_remove_devices_flags(DM_REMOVE_ACTIVE_ALL); }
-#if CONFIG_IS_ENABLED(ARM_FFA_TRANSPORT) +#if CONFIG_IS_ENABLED(ARM_FFA_TRANSPORT) && !CONFIG_IS_ENABLED(SANDBOX_FFA) /* unmap FF-A RX/TX buffers */ if (ffa_bus_ops_get()->rxtx_unmap()) debug("[efi_boottime][ERROR]: can not unmap FF-A RX/TX buffers\n");
Add functional test cases for the FF-A core driver
These tests rely on the FF-A Sandbox driver which helps in inspecting the FF-A core driver.
v4: align sandbox tests with the new FF-A driver interfaces and new way of error handling
v1: introduce sandbox tests --- MAINTAINERS | 1 + test/dm/Makefile | 2 + test/dm/ffa.c | 394 +++++++++++++++++++++++++++++++++++++++++++++++ 3 files changed, 397 insertions(+) create mode 100644 test/dm/ffa.c
diff --git a/MAINTAINERS b/MAINTAINERS index 6f01002e34..8c0dfff5f8 100644 --- a/MAINTAINERS +++ b/MAINTAINERS @@ -256,6 +256,7 @@ F: doc/README.ffa.drv F: drivers/firmware/arm-ffa/ F: include/arm_ffa.h F: include/sandbox_arm_ffa.h +F: test/dm/ffa.c
ARM FREESCALE IMX M: Stefano Babic sbabic@denx.de diff --git a/test/dm/Makefile b/test/dm/Makefile index 7543df8823..e5a791768e 100644 --- a/test/dm/Makefile +++ b/test/dm/Makefile @@ -1,6 +1,7 @@ # SPDX-License-Identifier: GPL-2.0+ # # Copyright (c) 2013 Google, Inc +# (C) Copyright 2022 ARM Limited
obj-$(CONFIG_UT_DM) += test-dm.o
@@ -81,6 +82,7 @@ obj-$(CONFIG_POWER_DOMAIN) += power-domain.o obj-$(CONFIG_ACPI_PMC) += pmc.o obj-$(CONFIG_DM_PMIC) += pmic.o obj-$(CONFIG_DM_PWM) += pwm.o +obj-$(CONFIG_SANDBOX_FFA) += ffa.o obj-$(CONFIG_QFW) += qfw.o obj-$(CONFIG_RAM) += ram.o obj-y += regmap.o diff --git a/test/dm/ffa.c b/test/dm/ffa.c new file mode 100644 index 0000000000..052d5fc3f4 --- /dev/null +++ b/test/dm/ffa.c @@ -0,0 +1,394 @@ +// SPDX-License-Identifier: GPL-2.0+ +/* + * Functional tests for UCLASS_FFA class + * + * (C) Copyright 2022 ARM Limited + * Abdellatif El Khlifi abdellatif.elkhlifi@arm.com + */ + +#include <common.h> +#include <console.h> +#include <dm.h> +#include <dm/test.h> +#include "../../drivers/firmware/arm-ffa/sandbox_arm_ffa_prv.h" +#include <sandbox_arm_ffa.h> +#include <test/test.h> +#include <test/ut.h> + +/* Macros */ + +#define LOG_MSG_SZ (100) +#define LOG_CMD_SZ (LOG_MSG_SZ * 2) + +/* Functional tests for the UCLASS_FFA */ + +static int dm_test_ffa_log(struct unit_test_state *uts, char *msg) +{ + char cmd[LOG_CMD_SZ] = {0}; + + console_record_reset(); + + snprintf(cmd, LOG_CMD_SZ, "echo "%s"", msg); + run_command(cmd, 0); + + ut_assert_console_end(); + + return CMD_RET_SUCCESS; +} + +static int check_fwk_version(struct ffa_prvdata *prvdata, struct sandbox_ffa_prvdata *sdx_prvdata, + struct unit_test_state *uts) +{ + if (prvdata->fwk_version != sdx_prvdata->fwk_version) { + char msg[LOG_MSG_SZ] = {0}; + + snprintf(msg, LOG_MSG_SZ, + "[%s]: Error: framework version: core = 0x%x , sandbox = 0x%x", __func__, + prvdata->fwk_version, + sdx_prvdata->fwk_version); + + dm_test_ffa_log(uts, msg); + return CMD_RET_FAILURE; + } + return CMD_RET_SUCCESS; +} + +static int check_endpoint_id(struct ffa_prvdata *prvdata, struct unit_test_state *uts) +{ + if (prvdata->id) { + char msg[LOG_MSG_SZ] = {0}; + + snprintf(msg, LOG_MSG_SZ, + "[%s]: Error: endpoint id: core = 0x%x", __func__, prvdata->id); + dm_test_ffa_log(uts, msg); + return CMD_RET_FAILURE; + } + return CMD_RET_SUCCESS; +} + +static int check_core_dev(struct ffa_prvdata *prvdata, struct unit_test_state *uts) +{ + if (!prvdata->dev) { + char msg[LOG_MSG_SZ] = {0}; + + snprintf(msg, LOG_MSG_SZ, "[%s]: Error: core device NULL", __func__); + dm_test_ffa_log(uts, msg); + return CMD_RET_FAILURE; + } + return CMD_RET_SUCCESS; +} + +static int check_sandbox_dev(struct sandbox_ffa_prvdata *sdx_prvdata, struct unit_test_state *uts) +{ + if (!sdx_prvdata->dev) { + char msg[LOG_MSG_SZ] = {0}; + + snprintf(msg, LOG_MSG_SZ, "[%s]: Error: sandbox device NULL", __func__); + dm_test_ffa_log(uts, msg); + return CMD_RET_FAILURE; + } + return CMD_RET_SUCCESS; +} + +static int check_rxtxbuf(struct ffa_prvdata *prvdata, struct unit_test_state *uts) +{ + if (!prvdata->pair.rxbuf && prvdata->pair.txbuf) { + char msg[LOG_MSG_SZ] = {0}; + + snprintf(msg, LOG_MSG_SZ, "[%s]: Error: rxbuf = 0x%llx txbuf = 0x%llx", __func__, + prvdata->pair.rxbuf, + prvdata->pair.txbuf); + dm_test_ffa_log(uts, msg); + return CMD_RET_FAILURE; + } + return CMD_RET_SUCCESS; +} + +static int check_features(struct ffa_prvdata *prvdata, struct unit_test_state *uts) +{ + char msg[LOG_MSG_SZ] = {0}; + + if (prvdata->pair.rxtx_min_pages != RXTX_4K && + prvdata->pair.rxtx_min_pages != RXTX_16K && + prvdata->pair.rxtx_min_pages != RXTX_64K) { + snprintf(msg, + LOG_MSG_SZ, + "[%s]: Error: FFA_RXTX_MAP features = 0x%lx", + __func__, + prvdata->pair.rxtx_min_pages); + dm_test_ffa_log(uts, msg); + return CMD_RET_FAILURE; + } + + return CMD_RET_SUCCESS; +} + +static int check_rxbuf_mapped_flag(u32 queried_func_id, + u8 rxbuf_mapped, + struct unit_test_state *uts) +{ + char msg[LOG_MSG_SZ] = {0}; + + switch (queried_func_id) { + case FFA_RXTX_MAP: + { + if (rxbuf_mapped) + return CMD_RET_SUCCESS; + break; + } + case FFA_RXTX_UNMAP: + { + if (!rxbuf_mapped) + return CMD_RET_SUCCESS; + break; + } + default: + return CMD_RET_FAILURE; + } + + snprintf(msg, LOG_MSG_SZ, "[%s]: Error: %s mapping issue", __func__, + (queried_func_id == FFA_RXTX_MAP ? "FFA_RXTX_MAP" : "FFA_RXTX_UNMAP")); + dm_test_ffa_log(uts, msg); + + return CMD_RET_FAILURE; +} + +static int check_rxbuf_release_flag(u8 rxbuf_owned, struct unit_test_state *uts) +{ + if (rxbuf_owned) { + char msg[LOG_MSG_SZ] = {0}; + + snprintf(msg, LOG_MSG_SZ, "[%s]: Error: RX buffer not released", __func__); + dm_test_ffa_log(uts, msg); + return CMD_RET_FAILURE; + } + return CMD_RET_SUCCESS; +} + +static int test_ffa_msg_send_direct_req(u16 part_id, struct unit_test_state *uts) +{ + struct ffa_send_direct_data msg = {0}; + u8 cnt; + + ut_assertok(ffa_bus_ops_get()->sync_send_receive(part_id, &msg)); + + for (cnt = 0; cnt < sizeof(struct ffa_send_direct_data) / sizeof(u64); cnt++) + ut_assertok(((u64 *)&msg)[cnt] != 0xffffffffffffffff); + + return CMD_RET_SUCCESS; +} + +static int test_partitions_and_comms(const char *service_uuid, + struct sandbox_ffa_prvdata *sdx_prvdata, + struct unit_test_state *uts) +{ + u32 count = 0, size = 0; + struct ffa_partition_info *parts_info; + u32 info_idx, exp_info_idx; + int ret; + + /* + * get from the driver the count of the SPs matching the UUID + */ + ret = ffa_bus_ops_get()->partition_info_get(service_uuid, &count, NULL); + /* make sure partitions are detected */ + ut_assertok(ret != 0); + ut_assertok(count != SANDBOX_SP_COUNT_PER_VALID_SERVICE); + + /* + * pre-allocate a buffer to be filled by the driver + * with ffa_partition_info structs + */ + + parts_info = calloc(count, sizeof(struct ffa_partition_info)); + ut_assertok(!parts_info); + + size = count * sizeof(struct ffa_partition_info); + + /* + * ask the driver to fill the buffer with the SPs info + */ + ret = ffa_bus_ops_get()->partition_info_get(service_uuid, &size, parts_info); + if (ret != 0) { + free(parts_info); + ut_assertok(ret != 0); + } + + /* + * SPs found , verify the partitions information + */ + + ret = CMD_RET_FAILURE; + + for (info_idx = 0; info_idx < count ; info_idx++) { + for (exp_info_idx = 0; + exp_info_idx < sdx_prvdata->partitions.count; + exp_info_idx++) { + if (parts_info[info_idx].id == + sdx_prvdata->partitions.descs[exp_info_idx].info.id) { + ret = memcmp(&parts_info[info_idx], + &sdx_prvdata->partitions.descs[exp_info_idx] + .info, + sizeof(struct ffa_partition_info)); + if (ret) + free(parts_info); + ut_assertok(ret != 0); + /* send and receive data from the current partition */ + test_ffa_msg_send_direct_req(parts_info[info_idx].id, uts); + } + ret = CMD_RET_SUCCESS; + } + } + + free(parts_info); + + /* Verify expected partitions found in the emulated secure world*/ + ut_assertok(ret != CMD_RET_SUCCESS); + + return CMD_RET_SUCCESS; +} + +static int dm_test_ffa_ack(struct unit_test_state *uts) +{ + struct ffa_prvdata *prvdata = NULL; + struct sandbox_ffa_prvdata *sdx_prvdata = NULL; + struct ffa_sandbox_data func_data = {0}; + u8 rxbuf_flag = 0; + const char *svc1_uuid = SANDBOX_SERVICE1_UUID; + const char *svc2_uuid = SANDBOX_SERVICE2_UUID; + int ret; + + /* test probing FF-A devices */ + ut_assertok(ffa_bus_discover()); + + /* get a pointer to the FF-A core and sandbox drivers private data */ + func_data.data0 = &prvdata; + func_data.data0_size = sizeof(prvdata); + func_data.data1 = &sdx_prvdata; + func_data.data1_size = sizeof(sdx_prvdata); + + ut_assertok(sandbox_ffa_query_core_state(FFA_VERSION, &func_data)); + + /* make sure private data pointers are retrieved */ + ut_assertok(prvdata == 0); + ut_assertok(sdx_prvdata == 0); + + /* make sure dev devices created */ + ut_assertok(check_core_dev(prvdata, uts)); + ut_assertok(check_sandbox_dev(sdx_prvdata, uts)); + + /* test FFA_VERSION */ + ut_assertok(check_fwk_version(prvdata, sdx_prvdata, uts)); + + /* test FFA_ID_GET */ + ut_assertok(check_endpoint_id(prvdata, uts)); + + /* test FFA_FEATURES */ + ut_assertok(check_features(prvdata, uts)); + + /* test core RX/TX buffers */ + ut_assertok(check_rxtxbuf(prvdata, uts)); + + /* test FFA_RXTX_MAP */ + func_data.data0 = &rxbuf_flag; + func_data.data0_size = sizeof(rxbuf_flag); + + rxbuf_flag = 0; + ut_assertok(sandbox_ffa_query_core_state(FFA_RXTX_MAP, &func_data)); + ut_assertok(check_rxbuf_mapped_flag(FFA_RXTX_MAP, rxbuf_flag, uts)); + + /* FFA_PARTITION_INFO_GET / FFA_MSG_SEND_DIRECT_REQ */ + ret = test_partitions_and_comms(svc1_uuid, sdx_prvdata, uts); + ut_assertok(ret != CMD_RET_SUCCESS); + + /* test FFA_RX_RELEASE */ + rxbuf_flag = 1; + ut_assertok(sandbox_ffa_query_core_state(FFA_RX_RELEASE, &func_data)); + ut_assertok(check_rxbuf_release_flag(rxbuf_flag, uts)); + + /* FFA_PARTITION_INFO_GET / FFA_MSG_SEND_DIRECT_REQ */ + ret = test_partitions_and_comms(svc2_uuid, sdx_prvdata, uts); + ut_assertok(ret != CMD_RET_SUCCESS); + + /* test FFA_RX_RELEASE */ + rxbuf_flag = 1; + ut_assertok(sandbox_ffa_query_core_state(FFA_RX_RELEASE, &func_data)); + ut_assertok(check_rxbuf_release_flag(rxbuf_flag, uts)); + + /* test FFA_RXTX_UNMAP */ + ut_assertok(ffa_bus_ops_get()->rxtx_unmap()); + + rxbuf_flag = 1; + ut_assertok(sandbox_ffa_query_core_state(FFA_RXTX_UNMAP, &func_data)); + ut_assertok(check_rxbuf_mapped_flag(FFA_RXTX_UNMAP, rxbuf_flag, uts)); + + return CMD_RET_SUCCESS; +} + +DM_TEST(dm_test_ffa_ack, UT_TESTF_SCAN_FDT | UT_TESTF_CONSOLE_REC); + +static int dm_test_ffa_nack(struct unit_test_state *uts) +{ + struct ffa_prvdata *prvdata = NULL; + struct sandbox_ffa_prvdata *sdx_prvdata = NULL; + struct ffa_sandbox_data func_data = {0}; + const char *valid_svc_uuid = SANDBOX_SERVICE1_UUID; + const char *unvalid_svc_uuid = SANDBOX_SERVICE3_UUID; + const char *unvalid_svc_uuid_str = SANDBOX_SERVICE4_UUID; + struct ffa_send_direct_data msg = {0}; + int ret; + u32 count = 0; + u16 part_id = 0; + + /* test probing FF-A devices */ + ut_assertok(ffa_bus_discover()); + + /* get a pointer to the FF-A core and sandbox drivers private data */ + func_data.data0 = &prvdata; + func_data.data0_size = sizeof(prvdata); + func_data.data1 = &sdx_prvdata; + func_data.data1_size = sizeof(sdx_prvdata); + + ut_assertok(sandbox_ffa_query_core_state(FFA_VERSION, &func_data)); + + /* make sure private data pointers are retrieved */ + ut_assertok(prvdata == 0); + ut_assertok(sdx_prvdata == 0); + + /* make sure dev devices created */ + ut_assertok(check_core_dev(prvdata, uts)); + ut_assertok(check_sandbox_dev(sdx_prvdata, uts)); + + /* query partitions count using invalid arguments */ + ret = ffa_bus_ops_get()->partition_info_get(unvalid_svc_uuid, NULL, NULL); + ut_assertok(ret != -EINVAL); + + /* query partitions count using an invalid UUID string */ + ret = ffa_bus_ops_get()->partition_info_get(unvalid_svc_uuid_str, &count, NULL); + ut_assertok(ret != -EINVAL); + + /* query partitions count using an invalid UUID (no matching SP) */ + count = 0; + ret = ffa_bus_ops_get()->partition_info_get(unvalid_svc_uuid, &count, NULL); + ut_assertok(count != 0); + + /* query partitions count using a valid UUID */ + count = 0; + ret = ffa_bus_ops_get()->partition_info_get(valid_svc_uuid, &count, NULL); + /* make sure partitions are detected */ + ut_assertok(ret != 0); + ut_assertok(count != SANDBOX_SP_COUNT_PER_VALID_SERVICE); + + /* send data to an invalid partition */ + ret = ffa_bus_ops_get()->sync_send_receive(part_id, &msg); + ut_assertok(ret != -EINVAL); + + /* send data to a valid partition */ + part_id = prvdata->partitions.descs[0].info.id; + ret = ffa_bus_ops_get()->sync_send_receive(part_id, &msg); + ut_assertok(ret != 0); + + return CMD_RET_SUCCESS; +} + +DM_TEST(dm_test_ffa_nack, UT_TESTF_SCAN_FDT | UT_TESTF_CONSOLE_REC);
Add Sandbox test for the armffa command
v4: drop use of helper APIs
v1: introduce armffa command sandbox test --- MAINTAINERS | 1 + test/cmd/Makefile | 2 ++ test/cmd/armffa.c | 40 ++++++++++++++++++++++++++++++++++++++++ 3 files changed, 43 insertions(+) create mode 100644 test/cmd/armffa.c
diff --git a/MAINTAINERS b/MAINTAINERS index 8c0dfff5f8..8ed94da4c8 100644 --- a/MAINTAINERS +++ b/MAINTAINERS @@ -256,6 +256,7 @@ F: doc/README.ffa.drv F: drivers/firmware/arm-ffa/ F: include/arm_ffa.h F: include/sandbox_arm_ffa.h +F: test/cmd/armffa.c F: test/dm/ffa.c
ARM FREESCALE IMX diff --git a/test/cmd/Makefile b/test/cmd/Makefile index c331757425..19e9d0a995 100644 --- a/test/cmd/Makefile +++ b/test/cmd/Makefile @@ -1,6 +1,7 @@ # SPDX-License-Identifier: GPL-2.0+ # # Copyright (c) 2013 Google, Inc +# (C) Copyright 2022 ARM Limited
ifdef CONFIG_HUSH_PARSER obj-$(CONFIG_CONSOLE_RECORD) += test_echo.o @@ -13,3 +14,4 @@ obj-$(CONFIG_CMD_MEM_SEARCH) += mem_search.o obj-$(CONFIG_CMD_PINMUX) += pinmux.o obj-$(CONFIG_CMD_PWM) += pwm.o obj-$(CONFIG_CMD_SETEXPR) += setexpr.o +obj-$(CONFIG_SANDBOX_FFA) += armffa.o diff --git a/test/cmd/armffa.c b/test/cmd/armffa.c new file mode 100644 index 0000000000..531f82066e --- /dev/null +++ b/test/cmd/armffa.c @@ -0,0 +1,40 @@ +// SPDX-License-Identifier: GPL-2.0+ +/* + * Test for armffa command + * + * (C) Copyright 2022 ARM Limited + * Abdellatif El Khlifi abdellatif.elkhlifi@arm.com + */ + +#include <common.h> +#include <dm.h> +#include <dm/test.h> +#include <sandbox_arm_ffa.h> +#include <string.h> +#include <test/test.h> +#include <test/ut.h> + +#define PING_CMD_SIZE 19 + +/* Basic test of 'armffa' command */ +static int dm_test_armffa_cmd(struct unit_test_state *uts) +{ + char ping_cmd[PING_CMD_SIZE] = {0}; + + ut_assertok(ffa_bus_discover()); + + /* armffa getpart <UUID> */ + ut_assertok(run_command("armffa getpart " SANDBOX_SERVICE1_UUID, 0)); + + snprintf(ping_cmd, PING_CMD_SIZE, "armffa ping 0x%x", SANDBOX_SP1_ID); + + /* armffa ping <ID> */ + ut_assertok(run_command(ping_cmd, 0)); + + /* armffa devlist */ + ut_assertok(run_command("armffa devlist", 0)); + + return CMD_RET_SUCCESS; +} + +DM_TEST(dm_test_armffa_cmd, UT_TESTF_SCAN_FDT | UT_TESTF_CONSOLE_REC);
Add MM communication support using FF-A transport
This feature allows accessing MM partitions services through EFI MM communication protocol. MM partitions such as StandAlonneMM or smm-gateway secure partitions which reside in secure world.
An MM shared buffer and a door bell event are used to exchange the data.
The data is used by EFI services such as GetVariable()/SetVariable() and copied from the communication buffer to the MM shared buffer.
The secure partition is notified about availability of data in the MM shared buffer by an FF-A message (door bell).
On such event, MM SP can read the data and updates the MM shared buffer with the response data.
The response data is copied back to the communication buffer and consumed by the EFI subsystem.
FF-A driver private data is copied to EFI runtime section at ExitBootServices(). This garantees secure world partitions data are available at EFI runtime level.
Signed-off-by: Abdellatif El Khlifi abdellatif.elkhlifi@arm.com Signed-off-by: Gowtham Suresh Kumar gowtham.sureshkumar@arm.com Cc: Tom Rini trini@konsulko.com Cc: Simon Glass sjg@chromium.org Cc: Ilias Apalodimas ilias.apalodimas@linaro.org Cc: Jens Wiklander jens.wiklander@linaro.org
v4:
* use the new FF-A driver interfaces * discover MM partitions at runtime * copy FF-A driver private data to EFI runtime section at ExitBootServices() * drop use of FFA_ERR_STAT_SUCCESS error code * replace EFI_BUFFER_TOO_SMALL with EFI_OUT_OF_RESOURCES in ffa_mm_communicate(). No need for efi_memcpy_runtime() anymore * revert the error log in mm_communicate() in case of failure * remove packed attribute from efi_mm_communicate_header and smm_variable_communicate_header
v2:
* set default values to 0 for FFA_SHARED_MM_BUFFER_SIZE, FFA_SHARED_MM_BUFFER_ADDR and MM_SP_UUID_DATA and add warnings
v1:
* introduce FF-A MM communication --- arch/arm/cpu/armv8/cache.S | 19 +++ arch/arm/cpu/armv8/cache_v8.c | 6 +- include/mm_communication.h | 9 +- lib/efi_loader/Kconfig | 14 +- lib/efi_loader/efi_boottime.c | 7 + lib/efi_loader/efi_variable_tee.c | 263 +++++++++++++++++++++++++++++- 6 files changed, 309 insertions(+), 9 deletions(-)
diff --git a/arch/arm/cpu/armv8/cache.S b/arch/arm/cpu/armv8/cache.S index d1cee23437..91b7c73c17 100644 --- a/arch/arm/cpu/armv8/cache.S +++ b/arch/arm/cpu/armv8/cache.S @@ -3,6 +3,9 @@ * (C) Copyright 2013 * David Feng fenghua@phytium.com.cn * + * (C) Copyright 2022 ARM Limited + * Abdellatif El Khlifi abdellatif.elkhlifi@arm.com + * * This file is based on sample code from ARMv8 ARM. */
@@ -21,7 +24,11 @@ * x1: 0 clean & invalidate, 1 invalidate only * x2~x9: clobbered */ +#ifdef CONFIG_EFI_LOADER +.pushsection .text.efi_runtime, "ax" +#else .pushsection .text.__asm_dcache_level, "ax" +#endif ENTRY(__asm_dcache_level) lsl x12, x0, #1 msr csselr_el1, x12 /* select cache level */ @@ -65,7 +72,11 @@ ENDPROC(__asm_dcache_level) * * flush or invalidate all data cache by SET/WAY. */ +#ifdef CONFIG_EFI_LOADER +.pushsection .text.efi_runtime, "ax" +#else .pushsection .text.__asm_dcache_all, "ax" +#endif ENTRY(__asm_dcache_all) mov x1, x0 dsb sy @@ -109,7 +120,11 @@ ENTRY(__asm_flush_dcache_all) ENDPROC(__asm_flush_dcache_all) .popsection
+#ifdef CONFIG_EFI_LOADER +.pushsection .text.efi_runtime, "ax" +#else .pushsection .text.__asm_invalidate_dcache_all, "ax" +#endif ENTRY(__asm_invalidate_dcache_all) mov x0, #0x1 b __asm_dcache_all @@ -182,7 +197,11 @@ ENTRY(__asm_invalidate_icache_all) ENDPROC(__asm_invalidate_icache_all) .popsection
+#ifdef CONFIG_EFI_LOADER +.pushsection .text.efi_runtime, "ax" +#else .pushsection .text.__asm_invalidate_l3_dcache, "ax" +#endif WEAK(__asm_invalidate_l3_dcache) mov x0, #0 /* return status as success */ ret diff --git a/arch/arm/cpu/armv8/cache_v8.c b/arch/arm/cpu/armv8/cache_v8.c index e4736e5643..45f57372c2 100644 --- a/arch/arm/cpu/armv8/cache_v8.c +++ b/arch/arm/cpu/armv8/cache_v8.c @@ -5,10 +5,14 @@ * * (C) Copyright 2016 * Alexander Graf agraf@suse.de + * + * (C) Copyright 2022 ARM Limited + * Abdellatif El Khlifi abdellatif.elkhlifi@arm.com */
#include <common.h> #include <cpu_func.h> +#include <efi_loader.h> #include <hang.h> #include <log.h> #include <asm/cache.h> @@ -445,7 +449,7 @@ __weak void mmu_setup(void) /* * Performs a invalidation of the entire data cache at all levels */ -void invalidate_dcache_all(void) +void __efi_runtime invalidate_dcache_all(void) { __asm_invalidate_dcache_all(); __asm_invalidate_l3_dcache(); diff --git a/include/mm_communication.h b/include/mm_communication.h index e65fbde60d..fe9104c56d 100644 --- a/include/mm_communication.h +++ b/include/mm_communication.h @@ -6,6 +6,8 @@ * Copyright (c) 2017, Intel Corporation. All rights reserved. * Copyright (C) 2020 Linaro Ltd. sughosh.ganu@linaro.org * Copyright (C) 2020 Linaro Ltd. ilias.apalodimas@linaro.org + * (C) Copyright 2022 ARM Limited + * Abdellatif El Khlifi abdellatif.elkhlifi@arm.com */
#ifndef _MM_COMMUNICATION_H_ @@ -13,6 +15,9 @@
#include <part_efi.h>
+/* MM service UUID string (big-endian format). This UUID is common across all MM SPs */ +#define MM_SP_UUID "33d532ed-e699-0942-c09c-a798d9cd722d" + /* * Interface to the pseudo Trusted Application (TA), which provides a * communication channel with the Standalone MM (Management Mode) @@ -43,7 +48,7 @@ * To avoid confusion in interpreting frames, the communication buffer should * always begin with efi_mm_communicate_header. */ -struct __packed efi_mm_communicate_header { +struct efi_mm_communicate_header { efi_guid_t header_guid; size_t message_len; u8 data[]; @@ -145,7 +150,7 @@ struct smm_variable_communicate_header { * Defined in EDK2 as SMM_VARIABLE_COMMUNICATE_ACCESS_VARIABLE. * */ -struct smm_variable_access { +struct __packed smm_variable_access { efi_guid_t guid; efi_uintn_t data_size; efi_uintn_t name_size; diff --git a/lib/efi_loader/Kconfig b/lib/efi_loader/Kconfig index b8fb2701a7..d292f57244 100644 --- a/lib/efi_loader/Kconfig +++ b/lib/efi_loader/Kconfig @@ -61,13 +61,23 @@ config EFI_VARIABLE_FILE_STORE stored as file /ubootefi.var on the EFI system partition.
config EFI_MM_COMM_TEE - bool "UEFI variables storage service via OP-TEE" - depends on OPTEE + bool "UEFI variables storage service via the trusted world" + depends on OPTEE || ARM_FFA_TRANSPORT help + Allowing access to the MM SP services (SPs such as StandAlonneMM, smm-gateway). + When using the u-boot OP-TEE driver, StandAlonneMM is supported. + When using the u-boot FF-A driver any MM SP is supported. + If OP-TEE is present and running StandAloneMM, dispatch all UEFI variable related operations to that. The application will verify, authenticate and store the variables on an RPMB.
+ When ARM_FFA_TRANSPORT is used, dispatch all UEFI variable related + operations to the MM SP running in the secure world. + A door bell mechanism is used to notify the SP when there is data in the shared + MM buffer. The data is copied by u-boot to the shared buffer before issuing + the door bell event. + config EFI_VARIABLE_NO_STORE bool "Don't persist non-volatile UEFI variables" help diff --git a/lib/efi_loader/efi_boottime.c b/lib/efi_loader/efi_boottime.c index d404343a7d..8a397ea21b 100644 --- a/lib/efi_loader/efi_boottime.c +++ b/lib/efi_loader/efi_boottime.c @@ -2193,6 +2193,13 @@ static efi_status_t EFIAPI efi_exit_boot_services(efi_handle_t image_handle, debug("[efi_boottime][INFO]: FF-A RX/TX buffers unmapped\n"); #endif
+#if CONFIG_IS_ENABLED(ARM_FFA_EFI_RUNTIME_MODE) && !CONFIG_IS_ENABLED(SANDBOX_FFA) + if (ffa_copy_runtime_data()) + printf("ERROR: EFI: FFA: copying runtime data\n"); + else + printf("INFO: EFI: FFA: runtime data copied\n"); +#endif + /* Patch out unsupported runtime function */ efi_runtime_detach();
diff --git a/lib/efi_loader/efi_variable_tee.c b/lib/efi_loader/efi_variable_tee.c index dfef18435d..d6f24f85bd 100644 --- a/lib/efi_loader/efi_variable_tee.c +++ b/lib/efi_loader/efi_variable_tee.c @@ -4,6 +4,8 @@ * * Copyright (C) 2019 Linaro Ltd. sughosh.ganu@linaro.org * Copyright (C) 2019 Linaro Ltd. ilias.apalodimas@linaro.org + * Copyright (C) 2022 ARM Limited + * Abdellatif El Khlifi abdellatif.elkhlifi@arm.com */
#include <common.h> @@ -15,6 +17,36 @@ #include <malloc.h> #include <mm_communication.h>
+#if (IS_ENABLED(CONFIG_ARM_FFA_TRANSPORT)) + +#include <arm_ffa.h> +#include <cpu_func.h> +#include <mapmem.h> + +#ifndef FFA_SHARED_MM_BUFFER_SIZE +#warning "FFA_SHARED_MM_BUFFER_SIZE must be defined in include/configs/<board>.h" +#define FFA_SHARED_MM_BUFFER_SIZE 0 +#endif + +#ifndef FFA_SHARED_MM_BUFFER_OFFSET +#warning "FFA_SHARED_MM_BUFFER_OFFSET must be defined in include/configs/<board>.h" +#define FFA_SHARED_MM_BUFFER_OFFSET 0 +#endif + +#ifndef FFA_SHARED_MM_BUFFER_ADDR +#warning "FFA_SHARED_MM_BUFFER_ADDR must be defined in include/configs/<board>.h" +#define FFA_SHARED_MM_BUFFER_ADDR 0 +#endif + +/* MM return codes */ +#define MM_SUCCESS (0) + +const char *mm_sp_svc_uuid = MM_SP_UUID; + +static __efi_runtime_data u16 mm_sp_id; + +#endif + extern struct efi_var_file __efi_runtime_data *efi_var_buf; static efi_uintn_t max_buffer_size; /* comm + var + func + data */ static efi_uintn_t max_payload_size; /* func + data */ @@ -24,6 +56,7 @@ struct mm_connection { u32 session; };
+#if (IS_ENABLED(CONFIG_OPTEE)) /** * get_connection() - Retrieve OP-TEE session for a specific UUID. * @@ -143,16 +176,227 @@ static efi_status_t optee_mm_communicate(void *comm_buf, ulong dsize)
return ret; } +#endif + +#if (IS_ENABLED(CONFIG_ARM_FFA_TRANSPORT))
/** - * mm_communicate() - Adjust the cmonnucation buffer to StandAlonneMM and send + * ffa_notify_mm_sp() - Announce there is data in the shared buffer + * + * Notifies the MM partition in the trusted world that + * data is available in the shared buffer. + * This is a blocking call during which trusted world has exclusive access + * to the MM shared buffer. + * + * Return: + * + * 0 on success + */ +static int __efi_runtime ffa_notify_mm_sp(void) +{ + struct ffa_send_direct_data msg = {0}; + int ret; + int sp_event_ret = -1; + + if (!ffa_bus_ops_get()) + return -EINVAL; + + msg.data0 = FFA_SHARED_MM_BUFFER_OFFSET; /* x3 */ + + ret = ffa_bus_ops_get()->sync_send_receive(mm_sp_id, &msg); + if (ret != 0) + return ret; + + sp_event_ret = msg.data0; /* x3 */ + + if (sp_event_ret == MM_SUCCESS) + return 0; + + /* + * Failure to notify the MM SP + */ + + return -EACCES; +} + +/** + * ffa_discover_mm_sp_id() - Query the MM partition ID + * + * Use the FF-A driver to get the MM partition ID. + * If multiple partitions are found, use the first one. + * This is a boot time function. + * + * Return: + * + * 0 on success + */ +static int ffa_discover_mm_sp_id(void) +{ + u32 count = 0, size = 0; + int ret; + struct ffa_partition_info *parts_info; + + if (!ffa_bus_ops_get()) + return -EINVAL; + + /* + * get from the driver the count of the SPs matching the UUID + */ + ret = ffa_bus_ops_get()->partition_info_get(mm_sp_svc_uuid, &count, NULL); + if (ret != 0) { + log_err("EFI: Failure in querying partitions count (error code: %d)\n", ret); + return ret; + } + + if (!count) { + log_info("EFI: No MM partition found\n"); + return ret; + } + + /* + * pre-allocate a buffer to be filled by the driver + * with ffa_partition_info structs + */ + + log_info("EFI: Pre-allocating %d partition(s) info structures\n", count); + + parts_info = calloc(count, sizeof(struct ffa_partition_info)); + if (!parts_info) + return -EINVAL; + + size = count * sizeof(struct ffa_partition_info); + + /* + * ask the driver to fill the + * buffer with the SPs info + */ + ret = ffa_bus_ops_get()->partition_info_get(mm_sp_svc_uuid, &size, parts_info); + if (ret != 0) { + log_err("EFI: Failure in querying partition(s) info (error code: %d)\n", ret); + free(parts_info); + return ret; + } + + /* + * MM SPs found , use the first one + */ + + mm_sp_id = parts_info[0].id; + + log_info("EFI: MM partition ID 0x%x\n", mm_sp_id); + + free(parts_info); + + return 0; +} + +/** + * ffa_mm_communicate() - Exchange EFI services data with the MM partition using FF-A + * @comm_buf: locally allocated communication buffer used for rx/tx + * @dsize: communication buffer size + * + * Issues a door bell event to notify the MM partition (SP) running in OP-TEE + * that there is data to read from the shared buffer. + * Communication with the MM SP is performed using FF-A transport. + * On the event, MM SP can read the data from the buffer and + * update the MM shared buffer with response data. + * The response data is copied back to the communication buffer. + * + * Return: + * + * EFI status code + */ +static efi_status_t __efi_runtime ffa_mm_communicate(void *comm_buf, ulong comm_buf_size) +{ + ulong tx_data_size; + int ffa_ret; + struct efi_mm_communicate_header *mm_hdr; + void *virt_shared_buf; + + if (!comm_buf) + return EFI_INVALID_PARAMETER; + + /* Discover MM partition ID at boot time */ + if (!mm_sp_id && ffa_discover_mm_sp_id() != 0) { + log_err("EFI: Failure to discover MM partition ID at boot time\n"); + return EFI_UNSUPPORTED; + } + + mm_hdr = (struct efi_mm_communicate_header *)comm_buf; + tx_data_size = mm_hdr->message_len + sizeof(efi_guid_t) + sizeof(size_t); + + if (comm_buf_size != tx_data_size || tx_data_size > FFA_SHARED_MM_BUFFER_SIZE) + return EFI_INVALID_PARAMETER; + + /* Copy the data to the shared buffer */ + + virt_shared_buf = (void *)map_sysmem((phys_addr_t)FFA_SHARED_MM_BUFFER_ADDR, 0); + efi_memcpy_runtime(virt_shared_buf, comm_buf, tx_data_size); + + /* + * The secure world might have cache disabled for + * the device region used for shared buffer (which is the case for Optee). + * In this case, the secure world reads the data from DRAM. + * Let's flush the cache so the DRAM is updated with the latest data. + */ + #ifdef CONFIG_ARM64 + invalidate_dcache_all(); + #endif + + /* Announce there is data in the shared buffer */ + + ffa_ret = ffa_notify_mm_sp(); + if (ffa_ret) + unmap_sysmem(virt_shared_buf); + + switch (ffa_ret) { + case 0: + { + ulong rx_data_size; + /* Copy the MM SP response from the shared buffer to the communication buffer */ + rx_data_size = ((struct efi_mm_communicate_header *)virt_shared_buf)->message_len + + sizeof(efi_guid_t) + + sizeof(size_t); + + if (rx_data_size > comm_buf_size) { + unmap_sysmem(virt_shared_buf); + return EFI_OUT_OF_RESOURCES; + } + + efi_memcpy_runtime(comm_buf, virt_shared_buf, rx_data_size); + unmap_sysmem(virt_shared_buf); + + return EFI_SUCCESS; + } + case -EINVAL: + return EFI_DEVICE_ERROR; + case -EPERM: + return EFI_INVALID_PARAMETER; + case -EACCES: + return EFI_ACCESS_DENIED; + case -EBUSY: + return EFI_OUT_OF_RESOURCES; + default: + return EFI_ACCESS_DENIED; + } +} +#endif + +/** + * mm_communicate() - Adjust the communication buffer to the MM SP and send * it to OP-TEE * - * @comm_buf: locally allocted communcation buffer + * @comm_buf: locally allocated communication buffer * @dsize: buffer size + * + * The MM SP (also called partition) can be StandAlonneMM or smm-gateway. + * The comm_buf format is the same for both partitions. + * When using the u-boot OP-TEE driver, StandAlonneMM is supported. + * When using the u-boot FF-A driver, StandAlonneMM and smm-gateway are supported. + * * Return: status code */ -static efi_status_t mm_communicate(u8 *comm_buf, efi_uintn_t dsize) +static efi_status_t __efi_runtime mm_communicate(u8 *comm_buf, efi_uintn_t dsize) { efi_status_t ret; struct efi_mm_communicate_header *mm_hdr; @@ -162,7 +406,11 @@ static efi_status_t mm_communicate(u8 *comm_buf, efi_uintn_t dsize) mm_hdr = (struct efi_mm_communicate_header *)comm_buf; var_hdr = (struct smm_variable_communicate_header *)mm_hdr->data;
+ #if (IS_ENABLED(CONFIG_OPTEE)) ret = optee_mm_communicate(comm_buf, dsize); + #elif (IS_ENABLED(CONFIG_ARM_FFA_TRANSPORT)) + ret = ffa_mm_communicate(comm_buf, dsize); + #endif if (ret != EFI_SUCCESS) { log_err("%s failed!\n", __func__); return ret; @@ -258,6 +506,13 @@ efi_status_t EFIAPI get_max_payload(efi_uintn_t *size) goto out; } *size = var_payload->size; + + #if (IS_ENABLED(CONFIG_ARM_FFA_TRANSPORT)) + if (*size > FFA_SHARED_MM_BUFFER_SIZE) + *size = FFA_SHARED_MM_BUFFER_SIZE - MM_COMMUNICATE_HEADER_SIZE - + MM_VARIABLE_COMMUNICATE_SIZE; + #endif + /* * There seems to be a bug in EDK2 miscalculating the boundaries and * size checks, so deduct 2 more bytes to fulfill this requirement. Fix @@ -697,7 +952,7 @@ void efi_variables_boot_exit_notify(void) ret = EFI_NOT_FOUND;
if (ret != EFI_SUCCESS) - log_err("Unable to notify StMM for ExitBootServices\n"); + log_err("Unable to notify the MM partition for ExitBootServices\n"); free(comm_buf);
turn on EFI MM communication
On corstone1000 platform MM communication between u-boot and the secure world (Optee) is done using the FF-A bus.
Signed-off-by: Abdellatif El Khlifi abdellatif.elkhlifi@arm.com Cc: Tom Rini trini@konsulko.com Cc: Simon Glass sjg@chromium.org Cc: Ilias Apalodimas ilias.apalodimas@linaro.org Cc: Jens Wiklander jens.wiklander@linaro.org --- configs/corstone1000_defconfig | 4 ++++ include/configs/corstone1000.h | 9 +++++++++ 2 files changed, 13 insertions(+)
diff --git a/configs/corstone1000_defconfig b/configs/corstone1000_defconfig index ed2e0fe70a..5028c746c5 100644 --- a/configs/corstone1000_defconfig +++ b/configs/corstone1000_defconfig @@ -52,3 +52,7 @@ CONFIG_DM_SERIAL=y CONFIG_USB=y CONFIG_USB_ISP1760=y CONFIG_ERRNO_STR=y +CONFIG_EFI_MM_COMM_TEE=y +# CONFIG_OPTEE is not set +CONFIG_ARM_FFA_TRANSPORT=y +CONFIG_ARM_FFA_EFI_RUNTIME_MODE=y diff --git a/include/configs/corstone1000.h b/include/configs/corstone1000.h index 8e0230c135..997d0bebaf 100644 --- a/include/configs/corstone1000.h +++ b/include/configs/corstone1000.h @@ -14,6 +14,15 @@
+#define FFA_SHARED_MM_BUFFER_SIZE SZ_4K /* 4 KB */ + +/* + * shared buffer physical address used for communication between + * u-boot and the MM SP + */ +#define FFA_SHARED_MM_BUFFER_ADDR (0x023F8000) +#define FFA_SHARED_MM_BUFFER_OFFSET (0) + #define V2M_BASE 0x80000000
#define CONFIG_PL011_CLOCK 50000000
Moving the changelogs in each commit to the changes section.
No code change in v5.
Changelog of the major changes: ===========================
v5:
* move changelogs in each commit to the changes section
v4: [4]
* add FF-A support README (doc/README.ffa.drv) * improving error handling by mapping the FF-A errors to standard errors and logs * replacing panics with an error log * align sandbox driver and tests with the new FF-A driver interfaces and new way of error handling * use the new FF-A driver interfaces for MM communication * discover MM partitions at runtime * copy FF-A driver private data to EFI runtime section at ExitBootServices() * moving the FF-A driver work to drivers/firmware/arm-ffa * improving features discovery in FFA_FEATURES * add remove/bind functions to the FF-A core device * improve how the driver behaves when bus discovery is done more than once * move clearing x0-x17 registers code into a new macro like done in the linux kernel * enable EFI MM communication for the Corstone1000 platform
v3: [3]
* port x0-x17 registers support from linux kernel as defined by SMCCCv1.2 * align the interfaces of the u-boot FF-A driver with those in the linux FF-A driver * remove the FF-A helper layer * make the u-boot FF-A driver independent from EFI * provide an optional config that enables copying the driver data to EFI runtime section at ExitBootServices service * use 64-bit version of FFA_RXTX_MAP, FFA_MSG_SEND_DIRECT_{REQ, RESP} * update armffa command with the new driver interfaces
v2 [2]:
* make FF-A bus discoverable using device_{bind, probe} APIs * remove device tree support
v1 [1]:
* introduce FF-A bus driver with device tree support * introduce armffa command * introduce FF-A Sandbox driver * add FF-A Sandbox test cases * introduce FF-A MM communication
Cheers, Abdellatif
[1]: https://lore.kernel.org/all/20220329151659.16894-1-abdellatif.elkhlifi@arm.c... [2]: https://lore.kernel.org/all/20220415122803.16666-1-abdellatif.elkhlifi@arm.c... [3]: https://lore.kernel.org/all/20220801172053.20163-1-abdellatif.elkhlifi@arm.c... [4]: https://lore.kernel.org/all/20220926101723.9965-1-abdellatif.elkhlifi@arm.co...
Cc: Tom Rini trini@konsulko.com Cc: Simon Glass sjg@chromium.org Cc: Ilias Apalodimas ilias.apalodimas@linaro.org Cc: Jens Wiklander jens.wiklander@linaro.org Cc: Achin Gupta achin.gupta@arm.com Cc: Vishnu Banavath vishnu.banavath@arm.com Cc: Xueliang Zhong Xueliang.Zhong@arm.com
Abdellatif El Khlifi (10): arm64: smccc: add support for SMCCCv1.2 x0-x17 registers arm64: smccc: clear the Xn registers after SMC calls lib: uuid: introduce be_uuid_str_to_le_bin function arm_ffa: introduce Arm FF-A low-level driver arm_ffa: introduce armffa command arm_ffa: introduce the FF-A Sandbox driver arm_ffa: introduce Sandbox test cases for UCLASS_FFA arm_ffa: introduce armffa command Sandbox test arm_ffa: introduce FF-A MM communication arm_ffa: corstone1000: enable EFI MM communication
MAINTAINERS | 11 + arch/arm/cpu/armv8/cache.S | 19 + arch/arm/cpu/armv8/cache_v8.c | 6 +- arch/arm/cpu/armv8/smccc-call.S | 62 + arch/arm/lib/asm-offsets.c | 14 + cmd/Kconfig | 10 + cmd/Makefile | 2 + cmd/armffa.c | 242 +++ common/board_r.c | 9 + configs/corstone1000_defconfig | 4 + configs/sandbox64_defconfig | 2 + configs/sandbox_defconfig | 2 + doc/README.ffa.drv | 160 ++ doc/arch/sandbox.rst | 1 + drivers/Kconfig | 2 + drivers/Makefile | 1 + drivers/firmware/arm-ffa/Kconfig | 46 + drivers/firmware/arm-ffa/Makefile | 8 + drivers/firmware/arm-ffa/arm-ffa-uclass.c | 16 + drivers/firmware/arm-ffa/arm_ffa_prv.h | 201 +++ drivers/firmware/arm-ffa/core.c | 1358 +++++++++++++++++ .../arm-ffa/efi_ffa_runtime_data_mgr.c | 94 ++ drivers/firmware/arm-ffa/sandbox.c | 659 ++++++++ .../firmware/arm-ffa/sandbox_arm_ffa_prv.h | 144 ++ include/arm_ffa.h | 127 ++ include/configs/corstone1000.h | 9 + include/dm/uclass-id.h | 4 + include/linux/arm-smccc.h | 43 + include/mm_communication.h | 9 +- include/sandbox_arm_ffa.h | 91 ++ include/uuid.h | 8 + lib/efi_loader/Kconfig | 14 +- lib/efi_loader/efi_boottime.c | 22 + lib/efi_loader/efi_variable_tee.c | 263 +++- lib/uuid.c | 64 + test/cmd/Makefile | 2 + test/cmd/armffa.c | 40 + test/dm/Makefile | 2 + test/dm/ffa.c | 394 +++++ 39 files changed, 4156 insertions(+), 9 deletions(-) create mode 100644 cmd/armffa.c create mode 100644 doc/README.ffa.drv create mode 100644 drivers/firmware/arm-ffa/Kconfig create mode 100644 drivers/firmware/arm-ffa/Makefile create mode 100644 drivers/firmware/arm-ffa/arm-ffa-uclass.c create mode 100644 drivers/firmware/arm-ffa/arm_ffa_prv.h create mode 100644 drivers/firmware/arm-ffa/core.c create mode 100644 drivers/firmware/arm-ffa/efi_ffa_runtime_data_mgr.c create mode 100644 drivers/firmware/arm-ffa/sandbox.c create mode 100644 drivers/firmware/arm-ffa/sandbox_arm_ffa_prv.h create mode 100644 include/arm_ffa.h create mode 100644 include/sandbox_arm_ffa.h create mode 100644 test/cmd/armffa.c create mode 100644 test/dm/ffa.c
add support for x0-x17 registers used by the SMC calls
In SMCCC v1.2 [1] arguments are passed in registers x1-x17. Results are returned in x0-x17.
This work is inspired from the following kernel commit:
arm64: smccc: Add support for SMCCCv1.2 extended input/output registers
[1]: https://documentation-service.arm.com/static/5f8edaeff86e16515cdbe4c6?token=
Changelog: ===============
v4:
* rename the commit title and improve description new commit title: the current
v3:
* port x0-x17 registers support from linux kernel as defined by SMCCCv1.2 commit title: arm64: smccc: add Xn registers support used by SMC calls
arch/arm/cpu/armv8/smccc-call.S | 53 +++++++++++++++++++++++++++++++++ arch/arm/lib/asm-offsets.c | 14 +++++++++ include/linux/arm-smccc.h | 43 ++++++++++++++++++++++++++ 3 files changed, 110 insertions(+)
diff --git a/arch/arm/cpu/armv8/smccc-call.S b/arch/arm/cpu/armv8/smccc-call.S index dc92b28777..ec6f299bc9 100644 --- a/arch/arm/cpu/armv8/smccc-call.S +++ b/arch/arm/cpu/armv8/smccc-call.S @@ -1,6 +1,8 @@ /* SPDX-License-Identifier: GPL-2.0 */ /* * Copyright (c) 2015, Linaro Limited + * (C) Copyright 2022 ARM Limited + * Abdellatif El Khlifi abdellatif.elkhlifi@arm.com */ #include <linux/linkage.h> #include <linux/arm-smccc.h> @@ -45,3 +47,54 @@ ENDPROC(__arm_smccc_smc) ENTRY(__arm_smccc_hvc) SMCCC hvc ENDPROC(__arm_smccc_hvc) + +#ifdef CONFIG_ARM64 + + .macro SMCCC_1_2 instr + /* Save `res` and free a GPR that won't be clobbered */ + stp x1, x19, [sp, #-16]! + + /* Ensure `args` won't be clobbered while loading regs in next step */ + mov x19, x0 + + /* Load the registers x0 - x17 from the struct arm_smccc_1_2_regs */ + ldp x0, x1, [x19, #ARM_SMCCC_1_2_REGS_X0_OFFS] + ldp x2, x3, [x19, #ARM_SMCCC_1_2_REGS_X2_OFFS] + ldp x4, x5, [x19, #ARM_SMCCC_1_2_REGS_X4_OFFS] + ldp x6, x7, [x19, #ARM_SMCCC_1_2_REGS_X6_OFFS] + ldp x8, x9, [x19, #ARM_SMCCC_1_2_REGS_X8_OFFS] + ldp x10, x11, [x19, #ARM_SMCCC_1_2_REGS_X10_OFFS] + ldp x12, x13, [x19, #ARM_SMCCC_1_2_REGS_X12_OFFS] + ldp x14, x15, [x19, #ARM_SMCCC_1_2_REGS_X14_OFFS] + ldp x16, x17, [x19, #ARM_SMCCC_1_2_REGS_X16_OFFS] + + \instr #0 + + /* Load the `res` from the stack */ + ldr x19, [sp] + + /* Store the registers x0 - x17 into the result structure */ + stp x0, x1, [x19, #ARM_SMCCC_1_2_REGS_X0_OFFS] + stp x2, x3, [x19, #ARM_SMCCC_1_2_REGS_X2_OFFS] + stp x4, x5, [x19, #ARM_SMCCC_1_2_REGS_X4_OFFS] + stp x6, x7, [x19, #ARM_SMCCC_1_2_REGS_X6_OFFS] + stp x8, x9, [x19, #ARM_SMCCC_1_2_REGS_X8_OFFS] + stp x10, x11, [x19, #ARM_SMCCC_1_2_REGS_X10_OFFS] + stp x12, x13, [x19, #ARM_SMCCC_1_2_REGS_X12_OFFS] + stp x14, x15, [x19, #ARM_SMCCC_1_2_REGS_X14_OFFS] + stp x16, x17, [x19, #ARM_SMCCC_1_2_REGS_X16_OFFS] + + /* Restore original x19 */ + ldp xzr, x19, [sp], #16 + ret + .endm + +/* + * void arm_smccc_1_2_smc(const struct arm_smccc_1_2_regs *args, + * struct arm_smccc_1_2_regs *res); + */ +ENTRY(arm_smccc_1_2_smc) + SMCCC_1_2 smc +ENDPROC(arm_smccc_1_2_smc) + +#endif diff --git a/arch/arm/lib/asm-offsets.c b/arch/arm/lib/asm-offsets.c index 22fd541f9a..1bc2d90faa 100644 --- a/arch/arm/lib/asm-offsets.c +++ b/arch/arm/lib/asm-offsets.c @@ -9,6 +9,9 @@ * generate asm statements containing #defines, * compile this file to assembler, and then extract the * #defines from the assembly-language output. + * + * (C) Copyright 2022 ARM Limited + * Abdellatif El Khlifi abdellatif.elkhlifi@arm.com */
#include <common.h> @@ -117,6 +120,17 @@ int main(void) DEFINE(ARM_SMCCC_RES_X2_OFFS, offsetof(struct arm_smccc_res, a2)); DEFINE(ARM_SMCCC_QUIRK_ID_OFFS, offsetof(struct arm_smccc_quirk, id)); DEFINE(ARM_SMCCC_QUIRK_STATE_OFFS, offsetof(struct arm_smccc_quirk, state)); + #ifdef CONFIG_ARM64 + DEFINE(ARM_SMCCC_1_2_REGS_X0_OFFS, offsetof(struct arm_smccc_1_2_regs, a0)); + DEFINE(ARM_SMCCC_1_2_REGS_X2_OFFS, offsetof(struct arm_smccc_1_2_regs, a2)); + DEFINE(ARM_SMCCC_1_2_REGS_X4_OFFS, offsetof(struct arm_smccc_1_2_regs, a4)); + DEFINE(ARM_SMCCC_1_2_REGS_X6_OFFS, offsetof(struct arm_smccc_1_2_regs, a6)); + DEFINE(ARM_SMCCC_1_2_REGS_X8_OFFS, offsetof(struct arm_smccc_1_2_regs, a8)); + DEFINE(ARM_SMCCC_1_2_REGS_X10_OFFS, offsetof(struct arm_smccc_1_2_regs, a10)); + DEFINE(ARM_SMCCC_1_2_REGS_X12_OFFS, offsetof(struct arm_smccc_1_2_regs, a12)); + DEFINE(ARM_SMCCC_1_2_REGS_X14_OFFS, offsetof(struct arm_smccc_1_2_regs, a14)); + DEFINE(ARM_SMCCC_1_2_REGS_X16_OFFS, offsetof(struct arm_smccc_1_2_regs, a16)); + #endif #endif
return 0; diff --git a/include/linux/arm-smccc.h b/include/linux/arm-smccc.h index e1d09884a1..9105031d55 100644 --- a/include/linux/arm-smccc.h +++ b/include/linux/arm-smccc.h @@ -1,6 +1,8 @@ /* SPDX-License-Identifier: GPL-2.0 */ /* * Copyright (c) 2015, Linaro Limited + * (C) Copyright 2022 ARM Limited + * Abdellatif El Khlifi abdellatif.elkhlifi@arm.com */ #ifndef __LINUX_ARM_SMCCC_H #define __LINUX_ARM_SMCCC_H @@ -70,6 +72,47 @@ struct arm_smccc_res { unsigned long a3; };
+#ifdef CONFIG_ARM64 +/** + * struct arm_smccc_1_2_regs - Arguments for or Results from SMC call + * @a0-a17 argument values from registers 0 to 17 + */ +struct arm_smccc_1_2_regs { + unsigned long a0; + unsigned long a1; + unsigned long a2; + unsigned long a3; + unsigned long a4; + unsigned long a5; + unsigned long a6; + unsigned long a7; + unsigned long a8; + unsigned long a9; + unsigned long a10; + unsigned long a11; + unsigned long a12; + unsigned long a13; + unsigned long a14; + unsigned long a15; + unsigned long a16; + unsigned long a17; +}; + +/** + * arm_smccc_1_2_smc() - make SMC calls + * @args: arguments passed via struct arm_smccc_1_2_regs + * @res: result values via struct arm_smccc_1_2_regs + * + * This function is used to make SMC calls following SMC Calling Convention + * v1.2 or above. The content of the supplied param are copied from the + * structure to registers prior to the SMC instruction. The return values + * are updated with the content from registers on return from the SMC + * instruction. + */ +asmlinkage void arm_smccc_1_2_smc(const struct arm_smccc_1_2_regs *args, + struct arm_smccc_1_2_regs *res); +#endif + /** * struct arm_smccc_quirk - Contains quirk information * @id: quirk identification
set to zero the x0-x17 registers
As per the SMCCC v1.2 spec, unused result and scratch registers can leak information after an SMC call. We can mitigate against this risk by returning zero in each register.
The leakage we are referring to is data leakage across exception levels. The intent is to prevent lower exception levels (EL1/EL0) from reading the SMC data exchanged at EL2.
v4:
* move the clearing code into a new macro: clear_gp_regs
v3:
* clear the Xn registers after SMC calls
arch/arm/cpu/armv8/smccc-call.S | 9 +++++++++ 1 file changed, 9 insertions(+)
diff --git a/arch/arm/cpu/armv8/smccc-call.S b/arch/arm/cpu/armv8/smccc-call.S index ec6f299bc9..32f3eb8eeb 100644 --- a/arch/arm/cpu/armv8/smccc-call.S +++ b/arch/arm/cpu/armv8/smccc-call.S @@ -50,6 +50,12 @@ ENDPROC(__arm_smccc_hvc)
#ifdef CONFIG_ARM64
+ .macro clear_gp_regs + .irp n,0,1,2,3,4,5,6,7,8,9,10,11,12,13,14,15,16,17 + mov x\n, xzr + .endr + .endm + .macro SMCCC_1_2 instr /* Save `res` and free a GPR that won't be clobbered */ stp x1, x19, [sp, #-16]! @@ -84,6 +90,9 @@ ENDPROC(__arm_smccc_hvc) stp x14, x15, [x19, #ARM_SMCCC_1_2_REGS_X14_OFFS] stp x16, x17, [x19, #ARM_SMCCC_1_2_REGS_X16_OFFS]
+ /* x0-x17 registers can leak information after an SMC or HVC call. Let's clear them */ + clear_gp_regs + /* Restore original x19 */ ldp xzr, x19, [sp], #16 ret
Changelog:
v4:
- move the clearing code into a new macro: clear_gp_regs
v3:
- clear the Xn registers after SMC calls
#ifdef CONFIG_ARM64
- .macro clear_gp_regs
- .irp n,0,1,2,3,4,5,6,7,8,9,10,11,12,13,14,15,16,17
- mov x\n, xzr
- .endr
- .endm
- .macro SMCCC_1_2 instr /* Save `res` and free a GPR that won't be clobbered */ stp x1, x19, [sp, #-16]!
- /* x0-x17 registers can leak information after an SMC or HVC call. Let's clear them */
- clear_gp_regs
This should in my opinion not be needed. The higher exception level should only return what it indends to return and certainly not rely on lower exception levels to try to hide eventual unintentionally revealed secrets.
In an earlier conversation you said:
The leakage we are referring to is data leakage across exception levels. The intent is to prevent lower exception levels (EL1/EL0) to read the data exchanged at EL2.
The linux kernel clears the general purpose registers before switching to EL0. As far as I know u-boot doesn't.
So, the code above makes sure the registers are cleared.
U-Boot is as far as I know not changing to EL0. Do you have a real example where this cleaning actually would be needed? If it's needed I'd expect the cleaning to be done just before changing exception level.
Cheers, Jens
/* Restore original x19 */ ldp xzr, x19, [sp], #16 ret -- 2.17.1
Changelog:
v4:
v3:
#ifdef CONFIG_ARM64
- mov x\n, xzr
- .endr
- .endm
- clear_gp_regs
No real example for that. But I tried to follow the spec as much as possible. Since, no real need for this I'm happy to remove the commit and this has been done in patchset v6. Thanks.
Cheers, Jens
convert big endian UUID string to little endian buffer
v4:
* rename ffa_uuid_str_to_bin to be_uuid_str_to_le_bin and put in a standalone commit (the current)
v3:
* introduce ffa_uuid_str_to_bin (provided by arm_ffa: introduce Arm FF-A low-level driver)
include/uuid.h | 8 +++++++ lib/uuid.c | 64 ++++++++++++++++++++++++++++++++++++++++++++++++++ 2 files changed, 72 insertions(+)
diff --git a/include/uuid.h b/include/uuid.h index 4a4883d3b5..ad3af350f9 100644 --- a/include/uuid.h +++ b/include/uuid.h @@ -2,6 +2,8 @@ /* * Copyright (C) 2014 Samsung Electronics * Przemyslaw Marczak p.marczak@samsung.com + * (C) Copyright 2022 ARM Limited + * Abdellatif El Khlifi abdellatif.elkhlifi@arm.com */ #ifndef __UUID_H__ #define __UUID_H__ @@ -44,4 +46,10 @@ int uuid_guid_get_bin(const char *guid_str, unsigned char *guid_bin); const char *uuid_guid_get_str(const unsigned char *guid_bin); void gen_rand_uuid(unsigned char *uuid_bin); void gen_rand_uuid_str(char *uuid_str, int str_format); + +/** + * be_uuid_str_to_le_bin - Converts a big endian UUID string to a little endian buffer + */ +int be_uuid_str_to_le_bin(const char *uuid_str, unsigned char *uuid_bin); + #endif diff --git a/lib/uuid.c b/lib/uuid.c index 465e1ac38f..15a9ab49d5 100644 --- a/lib/uuid.c +++ b/lib/uuid.c @@ -1,6 +1,8 @@ // SPDX-License-Identifier: GPL-2.0+ /* * Copyright 2011 Calxeda, Inc. + * (C) Copyright 2022 ARM Limited + * Abdellatif El Khlifi abdellatif.elkhlifi@arm.com */
#include <common.h> @@ -346,6 +348,68 @@ int uuid_str_to_bin(const char *uuid_str, unsigned char *uuid_bin, return 0; }
+/** + * be_uuid_str_to_le_bin - Converts a big endian UUID string to a little endian buffer + * @uuid_str: UUID string in big endian format (36 bytes wide + '/0') + * @uuid_bin: preallocated 16 bytes UUID buffer in little endian format + * + * UUID string is 36 characters (36 bytes): + * + * xxxxxxxx-xxxx-xxxx-xxxx-xxxxxxxxxxxx + * be be be be be + * + * where x is a hexadecimal character. Fields are separated by '-'s. + * When converting to a binary UUID, these endianness rules apply: + * be: means the field in the string is considered a big endian hex number + * and should be converted to little endian binary format + * + * Return: + * + * uuid_bin filled with little endian UUID data + * On success 0 is returned. Otherwise, failure code. + */ +int be_uuid_str_to_le_bin(const char *uuid_str, unsigned char *uuid_bin) +{ + u16 tmp16 = 0; + u32 tmp32 = 0; + u64 tmp64 = 0; + + if (!uuid_str_valid(uuid_str) || !uuid_bin) + return -EINVAL; + + /* + * reverse bytes from big to little endian + */ + tmp32 = simple_strtoul(uuid_str, NULL, 16); + memcpy(uuid_bin, &tmp32, 4); + + /* + * reverse bytes from big to little endian + */ + tmp16 = simple_strtoul(uuid_str + 9, NULL, 16); + memcpy(uuid_bin + 4, &tmp16, 2); + + /* + * reverse bytes from big to little endian + */ + tmp16 = simple_strtoul(uuid_str + 14, NULL, 16); + memcpy(uuid_bin + 6, &tmp16, 2); + + /* + * reverse bytes from big to little endian + */ + tmp16 = simple_strtoul(uuid_str + 19, NULL, 16); + memcpy(uuid_bin + 8, &tmp16, 2); + + /* + * reverse bytes from big to little endian + */ + tmp64 = simple_strtoull(uuid_str + 24, NULL, 16); + memcpy(uuid_bin + 10, (char *)&tmp64, 6); + + return 0; +} + /* * uuid_bin_to_str() - convert big endian binary data to string UUID or GUID. *
Add the driver implementing Arm Firmware Framework for Armv8-A v1.0
The Firmware Framework for Arm A-profile processors (FF-A v1.0) [1] describes interfaces (ABIs) that standardize communication between the Secure World and Normal World leveraging TrustZone technology.
This driver uses 64-bit registers as per SMCCCv1.2 spec and comes on top of the SMCCC layer. The driver provides the FF-A ABIs needed for querying the FF-A framework from the secure world.
32-bit version of the ABIs is supported and 64-bit version of FFA_RXTX_MAP and FFA_MSG_SEND_DIRECT_{REQ, RESP}.
In u-boot FF-A design, FF-A is considered as a discoverable bus. The Secure World is considered as one entity to communicate with using the FF-A bus. FF-A communication is handled by one device and one instance (the bus). This FF-A driver takes care of all the interactions between Normal world and Secure World.
The driver exports its operations to be used by upper layers.
Exported operations:
- partition_info_get - sync_send_receive - rxtx_unmap
This implementation provides an optional feature to copy the driver data to EFI runtime area.
[1]: https://developer.arm.com/documentation/den0077/latest/
v4:
* add doc/README.ffa.drv * moving the FF-A driver work to drivers/firmware/arm-ffa * use less #ifdefs in lib/efi_loader/efi_boottime.c and replace #if defined by #if CONFIG_IS_ENABLED * improving error handling by mapping the FF-A errors to standard errors and logs * replacing panics with an error log and returning an error code * improving features discovery in FFA_FEATURES by introducing rxtx_min_pages private data field * add ffa_remove and ffa_bind functions * improve how the driver behaves when bus discovery is done more than once
v3:
v2:
v1:
MAINTAINERS | 7 + common/board_r.c | 9 + doc/README.ffa.drv | 160 ++ drivers/Kconfig | 2 + drivers/Makefile | 1 + drivers/firmware/arm-ffa/Kconfig | 39 + drivers/firmware/arm-ffa/Makefile | 7 + drivers/firmware/arm-ffa/arm-ffa-uclass.c | 16 + drivers/firmware/arm-ffa/arm_ffa_prv.h | 196 +++ drivers/firmware/arm-ffa/core.c | 1344 +++++++++++++++++ .../arm-ffa/efi_ffa_runtime_data_mgr.c | 94 ++ include/arm_ffa.h | 127 ++ include/dm/uclass-id.h | 4 + lib/efi_loader/efi_boottime.c | 15 + 14 files changed, 2021 insertions(+) create mode 100644 doc/README.ffa.drv create mode 100644 drivers/firmware/arm-ffa/Kconfig create mode 100644 drivers/firmware/arm-ffa/Makefile create mode 100644 drivers/firmware/arm-ffa/arm-ffa-uclass.c create mode 100644 drivers/firmware/arm-ffa/arm_ffa_prv.h create mode 100644 drivers/firmware/arm-ffa/core.c create mode 100644 drivers/firmware/arm-ffa/efi_ffa_runtime_data_mgr.c create mode 100644 include/arm_ffa.h
diff --git a/MAINTAINERS b/MAINTAINERS index 83346183ee..02b84d5074 100644 --- a/MAINTAINERS +++ b/MAINTAINERS @@ -248,6 +248,13 @@ F: drivers/net/cortina_ni.h F: drivers/net/phy/ca_phy.c F: configs/cortina_presidio-asic-pnand_defconfig
+ARM FF-A +M: Abdellatif El Khlifi abdellatif.elkhlifi@arm.com +S: Maintained +F: doc/README.ffa.drv +F: drivers/firmware/arm-ffa/ +F: include/arm_ffa.h + ARM FREESCALE IMX M: Stefano Babic sbabic@denx.de M: Fabio Estevam festevam@gmail.com diff --git a/common/board_r.c b/common/board_r.c index 56eb60fa27..8c99faddfd 100644 --- a/common/board_r.c +++ b/common/board_r.c @@ -7,6 +7,8 @@ * (C) Copyright 2002 * Sysgo Real-Time Solutions, GmbH <www.elinos.com> * Marius Groeger mgroeger@sysgo.de + * + * (C) Copyright 2022 ARM Limited */
#include <common.h> @@ -66,6 +68,10 @@ #include <efi_loader.h> #include <relocate.h>
+#ifdef CONFIG_ARM_FFA_TRANSPORT +#include <arm_ffa.h> +#endif + DECLARE_GLOBAL_DATA_PTR;
ulong monitor_flash_len; @@ -770,6 +776,9 @@ static init_fnc_t init_sequence_r[] = { INIT_FUNC_WATCHDOG_RESET initr_net, #endif +#ifdef CONFIG_ARM_FFA_TRANSPORT + ffa_bus_discover, +#endif #ifdef CONFIG_POST initr_post, #endif diff --git a/doc/README.ffa.drv b/doc/README.ffa.drv new file mode 100644 index 0000000000..1c0a33deb8 --- /dev/null +++ b/doc/README.ffa.drv @@ -0,0 +1,160 @@ +Arm FF-A Driver +==================== + +Introduction +-------------------- + +FF-A stands for Firmware Framework for Arm A-profile processors. + +FF-A specifies interfaces that enable a pair of software sandboxes to communicate with each other. A sandbox aka partition could +be a VM in the Normal or Secure world, an application in S-EL0, or a Trusted OS in S-EL1. + +This FF-A driver implements the interfaces to communicate with partitions in the Secure world aka Secure partitions (SPs). + +The driver specifically focuses on communicating with SPs that isolate portions of EFI runtime services that must run in a +protected environment which is inaccessible by the Host OS or Hypervisor. Examples of such services are set/get variables. + +FF-A driver uses the SMC ABIs defined by the FF-A specification to: + +- Discover the presence of SPs of interest. +- Access an SP's service through communication protocols e.g. EFI MM communication protocol. + +FF-A and SMC specifications +------------------------------------------- + +The current implementation of the driver relies on FF-A specification v1.0 and uses SMC32 calling convention. + +The driver has been tested with Optee OS which supports SMC32 for most of the SMC ABIs. + +For more details please refer to: https://developer.arm.com/documentation/den0077/a/?lang=en + +The FF-A driver uses 64-bit registers as per SMCCCv1.2 specification. + +For more details please refer to: https://documentation-service.arm.com/static/5f8edaeff86e16515cdbe4c6?token= + +Supported hardware +-------------------------------- + +Aarch64 plaforms + +Configuration +---------------------- + +CONFIG_ARM_FFA_TRANSPORT + Enables the FF-A bus driver. Turn this on if you want to use FF-A communication. + +CONFIG_ARM_FFA_EFI_RUNTIME_MODE + Optional config that enables EFI runtime support for FF-A data and code. + ffa_copy_runtime_data allows to copy the FF-A driver data structures to EFI runtime data section. + Turning the config on makes ffa_copy_runtime_data available for use and the driver code placed at EFI runtime code section. + Call ffa_copy_runtime_data at the event on which you want the FF-A data to be copied (example: at ExitBootServices). + +CONFIG_SANDBOX_FFA + Enables FF-A Sandbox driver. This emulates the FF-A ABIs handling under Sandbox and provides + functional tests for FF-A. + +FF-A ABIs under the hood +--------------------------------------- + +Invoking an FF-A ABI involves providing to the secure world/hypervisor the expected arguments from the ABI. + +The ABI arguments are stored in x0 to x7 registers. Then, an SMC instruction is executed. + +At the secure side level or hypervisor the ABI is handled at a higher exception level and the arguments are read and processed. + +The response is put back through x0 to x7 registers and control is giving back to the u-boot FF-A driver (non secure world). + +The driver reads the response and processes it accordingly. + +This methodology applies to all the FF-A ABIs in the driver. + +FF-A bus discovery in u-boot +------------------------------------------- + +When CONFIG_ARM_FFA_TRANSPORT is enabled, the FF-A bus is automatically discovered at initcall level (after u-boot relocation). + +The function that triggers the discovery process is ffa_bus_discover. + +ffa_bus_discover creates, binds and probes the arm_ffa device using device_{bind, probe} APIs. + +When the device is probed, ffa_probe is called which tries to communicate with the secure world or hypervisor. + +The FF-A bus is usable when these checks succeed: + +- querying the FF-A framework version +- querying from secure world the u-boot endpoint ID +- querying from secure world the supported features of the specified FF-A calls +- mapping the RX/TX buffers +- querying from secure world all the partitions information + +Probing fails when any of these operations fail. The FF-A bus discovery succeeds when probing is successful. + +When discovery fails the arm_ffa device is destroyed. + +The bus driver layer +------------------------------ + +The driver comes on top of the SMCCC layer and is implemented in drivers/firmware/arm-ffa/core.c + +The driver provides the following features: + +- Support for the 32-bit version of the following ABIs: + +FFA_VERSION +FFA_ID_GET +FFA_FEATURES +FFA_PARTITION_INFO_GET +FFA_RXTX_UNMAP +FFA_RX_RELEASE +FFA_RUN +FFA_ERROR +FFA_SUCCESS +FFA_INTERRUPT + +- Support for the 64-bit version of the following ABIs: + +FFA_RXTX_MAP +FFA_MSG_SEND_DIRECT_REQ +FFA_MSG_SEND_DIRECT_RESP + +- Processing the received data from the secure world/hypervisor and caching it + +- Hiding from upper layers the FF-A protocol and registers details. Upper layers focus on exchanged data, +the driver takes care of how to transport that to the secure world/hypervisor using FF-A. + +- The driver provides callbacks to be used by clients to access the FF-A bus: + +partition_info_get +sync_send_receive +rxtx_unmap + +- FF-A bus discovery at initcalls level (after u-boot relocation). The bus is up and running if the FF-A framework is responsive and compatible with the driver. + +- When EFI is enabled, unmap the RX/TX buffers at ExitBootServices() level. + +- When CONFIG_ARM_FFA_EFI_RUNTIME_MODE enabled, ffa_copy_runtime_data function is available for use. + +Using armffa command +----------------------------------- + +armffa is a command showcasing how to use the FF-A driver and how to invoke its operations. + +This provides a guidance to the client developers on how to call the FF-A bus interfaces. + +Usage: + +armffa <sub-command> <arguments> + +sub-commands: + + getpart <partition UUID> + + lists the partition(s) info + + ping <partition ID> + + sends a data pattern to the specified partition + + devlist + + displays the arm_ffa device info diff --git a/drivers/Kconfig b/drivers/Kconfig index 8b6fead351..b06b1ae481 100644 --- a/drivers/Kconfig +++ b/drivers/Kconfig @@ -6,6 +6,8 @@ source "drivers/core/Kconfig"
source "drivers/adc/Kconfig"
+source "drivers/firmware/arm-ffa/Kconfig" + source "drivers/ata/Kconfig"
source "drivers/axi/Kconfig" diff --git a/drivers/Makefile b/drivers/Makefile index eba9940231..c3bfad94ac 100644 --- a/drivers/Makefile +++ b/drivers/Makefile @@ -110,6 +110,7 @@ obj-y += iommu/ obj-y += smem/ obj-y += thermal/ obj-$(CONFIG_TEE) += tee/ +obj-$(CONFIG_ARM_FFA_TRANSPORT) += firmware/arm-ffa/ obj-y += axi/ obj-y += ufs/ obj-$(CONFIG_W1) += w1/ diff --git a/drivers/firmware/arm-ffa/Kconfig b/drivers/firmware/arm-ffa/Kconfig new file mode 100644 index 0000000000..aceb61cf49 --- /dev/null +++ b/drivers/firmware/arm-ffa/Kconfig @@ -0,0 +1,39 @@ +# SPDX-License-Identifier: GPL-2.0 + +config ARM_FFA_TRANSPORT + bool "Enable Arm Firmware Framework for Armv8-A driver" + depends on DM && ARM64 + select ARM_SMCCC + select LIB_UUID + select DEVRES + help + The Firmware Framework for Arm A-profile processors (FF-A) + describes interfaces (ABIs) that standardize communication + between the Secure World and Normal World leveraging TrustZone + technology. + + This driver is based on FF-A specification v1.0 and uses SMC32 + calling convention. + + FF-A specification: + + https://developer.arm.com/documentation/den0077/a/?lang=en + + In u-boot FF-A design, FF-A is considered as a discoverable bus. + The Secure World is considered as one entity to communicate with + using the FF-A bus. + FF-A communication is handled by one device and one instance (the bus). + This FF-A driver takes care of all the interactions between Normal world + and Secure World. + + For more details about the FF-A driver, please refer to doc/README.ffa.drv + +config ARM_FFA_EFI_RUNTIME_MODE + bool "Enable EFI runtime support for FF-A data and code" + depends on ARM_FFA_TRANSPORT && EFI_LOADER + help + Allows FF-A driver data structures and code to be accessible at EFI runtime. + FF-A data is copied by ffa_copy_runtime_data function. + The driver Code needed at runtime is placed at EFI runtime code section. + Turning this on makes ffa_copy_runtime_data available for use and the driver + code placed at EFI runtime code section. diff --git a/drivers/firmware/arm-ffa/Makefile b/drivers/firmware/arm-ffa/Makefile new file mode 100644 index 0000000000..0b9b0a61b4 --- /dev/null +++ b/drivers/firmware/arm-ffa/Makefile @@ -0,0 +1,7 @@ +# SPDX-License-Identifier: GPL-2.0+ +# +# (C) Copyright 2022 Abdellatif El Khlifi abdellatif.elkhlifi@arm.com +# + +obj-y += arm-ffa-uclass.o core.o +obj-$(CONFIG_ARM_FFA_EFI_RUNTIME_MODE) += efi_ffa_runtime_data_mgr.o diff --git a/drivers/firmware/arm-ffa/arm-ffa-uclass.c b/drivers/firmware/arm-ffa/arm-ffa-uclass.c new file mode 100644 index 0000000000..7d9695d289 --- /dev/null +++ b/drivers/firmware/arm-ffa/arm-ffa-uclass.c @@ -0,0 +1,16 @@ +// SPDX-License-Identifier: GPL-2.0+ +/* + * (C) Copyright 2022 ARM Limited + * Abdellatif El Khlifi abdellatif.elkhlifi@arm.com + */ + +#include <common.h> +#include <dm.h> +#include <asm/global_data.h> + +DECLARE_GLOBAL_DATA_PTR; + +UCLASS_DRIVER(ffa) = { + .name = "ffa", + .id = UCLASS_FFA, +}; diff --git a/drivers/firmware/arm-ffa/arm_ffa_prv.h b/drivers/firmware/arm-ffa/arm_ffa_prv.h new file mode 100644 index 0000000000..7bc90f7f66 --- /dev/null +++ b/drivers/firmware/arm-ffa/arm_ffa_prv.h @@ -0,0 +1,196 @@ +/* SPDX-License-Identifier: GPL-2.0+ */ +/* + * (C) Copyright 2022 ARM Limited + * Abdellatif El Khlifi abdellatif.elkhlifi@arm.com + */ + +#ifndef __ARM_FFA_PRV_H +#define __ARM_FFA_PRV_H + +#include <arm_ffa.h> +#include <linux/bitfield.h> +#include <linux/bitops.h> +#include <linux/arm-smccc.h> + +/* + * This header is private. It is exclusively used by the FF-A driver + */ + +/* FF-A core driver name */ +#define FFA_DRV_NAME "arm_ffa" + +/* FF-A driver version definitions */ + +#define MAJOR_VERSION_MASK GENMASK(30, 16) +#define MINOR_VERSION_MASK GENMASK(15, 0) +#define GET_FFA_MAJOR_VERSION(x) \ + ((u16)(FIELD_GET(MAJOR_VERSION_MASK, (x)))) +#define GET_FFA_MINOR_VERSION(x) \ + ((u16)(FIELD_GET(MINOR_VERSION_MASK, (x)))) +#define PACK_VERSION_INFO(major, minor) \ + (FIELD_PREP(MAJOR_VERSION_MASK, (major)) | \ + FIELD_PREP(MINOR_VERSION_MASK, (minor))) + +#define FFA_MAJOR_VERSION (1) +#define FFA_MINOR_VERSION (0) +#define FFA_VERSION_1_0 \ + PACK_VERSION_INFO(FFA_MAJOR_VERSION, FFA_MINOR_VERSION) + +/* Endpoint ID mask (u-boot endpoint ID) */ + +#define GET_SELF_ENDPOINT_ID_MASK GENMASK(15, 0) +#define GET_SELF_ENDPOINT_ID(x) \ + ((u16)(FIELD_GET(GET_SELF_ENDPOINT_ID_MASK, (x)))) + +#define PREP_SELF_ENDPOINT_ID_MASK GENMASK(31, 16) +#define PREP_SELF_ENDPOINT_ID(x) \ + (FIELD_PREP(PREP_SELF_ENDPOINT_ID_MASK, (x))) + +/* Partition endpoint ID mask (partition with which u-boot communicates with) */ + +#define PREP_PART_ENDPOINT_ID_MASK GENMASK(15, 0) +#define PREP_PART_ENDPOINT_ID(x) \ + (FIELD_PREP(PREP_PART_ENDPOINT_ID_MASK, (x))) + +/* + * Definitions of the Arm FF-A interfaces supported by the Arm FF-A driver + */ + +#define FFA_SMC(calling_convention, func_num) \ + ARM_SMCCC_CALL_VAL(ARM_SMCCC_FAST_CALL, (calling_convention), \ + ARM_SMCCC_OWNER_STANDARD, (func_num)) + +#define FFA_SMC_32(func_num) FFA_SMC(ARM_SMCCC_SMC_32, (func_num)) +#define FFA_SMC_64(func_num) FFA_SMC(ARM_SMCCC_SMC_64, (func_num)) + +enum ffa_abis { + FFA_ERROR = 0x60, + FFA_SUCCESS = 0x61, + FFA_INTERRUPT = 0x62, + FFA_VERSION = 0x63, + FFA_FEATURES = 0x64, + FFA_RX_RELEASE = 0x65, + FFA_RXTX_MAP = 0x66, + FFA_RXTX_UNMAP = 0x67, + FFA_PARTITION_INFO_GET = 0x68, + FFA_ID_GET = 0x69, + FFA_RUN = 0x6D, + FFA_MSG_SEND_DIRECT_REQ = 0x6F, + FFA_MSG_SEND_DIRECT_RESP = 0x70, + + /* to be updated when adding new FFA IDs */ + FFA_FIRST_ID = FFA_ERROR, /* lowest number ID*/ + FFA_LAST_ID = FFA_MSG_SEND_DIRECT_RESP, /* highest number ID*/ +}; + +/* number of the errors supported by the FF-A specification */ +#define MAX_NUMBER_FFA_ERR 9 + +/* container structure and helper macros to map between an FF-A error and relevant error log */ +struct ffa_abi_errmap { + char *err_str[MAX_NUMBER_FFA_ERR]; +}; + +#define FFA_ERRMAP_COUNT (FFA_LAST_ID - FFA_FIRST_ID + 1) +#define FFA_ID_TO_ERRMAP_ID(ffa_id) ((ffa_id) - FFA_FIRST_ID) + +/* The FF-A SMC function definitions */ + +typedef struct arm_smccc_1_2_regs ffa_value_t; +typedef void (*invoke_ffa_fn_t)(ffa_value_t args, ffa_value_t *res); + +/* + * struct ffa_partition_uuid - 16 bytes UUID transmitted by FFA_PARTITION_INFO_GET + * @a1-4: 32-bit words access to the UUID data + * + */ +struct ffa_partition_uuid { + u32 a1; /* w1 */ + u32 a2; /* w2 */ + u32 a3; /* w3 */ + u32 a4; /* w4 */ +}; + +/** + * enum ffa_rxtx_buf_sizes - minimum sizes supported + * for the RX/TX buffers + */ +enum ffa_rxtx_buf_sizes { + RXTX_4K, + RXTX_64K, + RXTX_16K +}; + +/** + * struct ffa_rxtxpair - structure hosting the RX/TX buffers virtual addresses + * @rxbuf: virtual address of the RX buffer + * @txbuf: virtual address of the TX buffer + * @rxtx_min_pages: RX/TX buffers minimum size in pages + * + * Data structure hosting the virtual addresses of the mapped RX/TX buffers + * These addresses are used by the FF-A functions that use the RX/TX buffers + */ +struct ffa_rxtxpair { + u64 rxbuf; /* virtual address */ + u64 txbuf; /* virtual address */ + size_t rxtx_min_pages; /* minimum number of pages in each of the RX/TX buffers */ +}; + +/** + * struct ffa_partition_desc - the secure partition descriptor + * @info: partition information + * @sp_uuid: the secure partition UUID + * + * Each partition has its descriptor containing the partitions information and the UUID + */ +struct ffa_partition_desc { + struct ffa_partition_info info; + struct ffa_partition_uuid sp_uuid; +}; + +/** + * struct ffa_partitions - descriptors for all secure partitions + * @count: The number of partitions descriptors + * @descs The partitions descriptors table + * + * This data structure contains the partitions descriptors table + */ +struct ffa_partitions { + u32 count; + struct ffa_partition_desc *descs; /* virtual address */ +}; + +/** + * struct ffa_prvdata - the driver private data structure + * + * @dev: The arm_ffa device under u-boot driver model + * @ffa_ops: The driver operations structure + * @fwk_version: FF-A framework version + * @id: u-boot endpoint ID + * @partitions: The partitions descriptors structure + * @pair: The RX/TX buffers pair + * @invoke_ffa_fn: The function executing the FF-A function + * + * The driver data structure hosting all resident data. + */ +struct ffa_prvdata { + struct udevice *dev; + struct ffa_bus_ops ffa_ops; + u32 fwk_version; + u16 id; + struct ffa_partitions partitions; + struct ffa_rxtxpair pair; + invoke_ffa_fn_t invoke_ffa_fn; +}; + +/** + * ffa_device_get - create, bind and probe the arm_ffa device + */ +int ffa_device_get(void); + +/** + * ffa_bus_prvdata_get - bus driver private data getter + */ +struct ffa_prvdata **ffa_bus_prvdata_get(void); + +#endif diff --git a/drivers/firmware/arm-ffa/core.c b/drivers/firmware/arm-ffa/core.c new file mode 100644 index 0000000000..41c7b96e68 --- /dev/null +++ b/drivers/firmware/arm-ffa/core.c @@ -0,0 +1,1344 @@ +// SPDX-License-Identifier: GPL-2.0+ +/* + * (C) Copyright 2022 ARM Limited + * Abdellatif El Khlifi abdellatif.elkhlifi@arm.com + */ + +#include "arm_ffa_prv.h" +#include <asm/global_data.h> +#include <common.h> +#include <dm.h> +#include <dm/device-internal.h> +#include <dm/devres.h> +#include <dm/root.h> +#include <linux/errno.h> +#include <linux/sizes.h> +#include <log.h> +#include <malloc.h> +#include <string.h> +#include <uuid.h> + +DECLARE_GLOBAL_DATA_PTR; + +/** + * The device private data structure containing all the resident + * data read from secure world + */ +__ffa_runtime_data struct ffa_prvdata *ffa_priv_data; + +/* Error mapping declarations */ + +__ffa_runtime_data int ffa_to_std_errmap[MAX_NUMBER_FFA_ERR] = { + 0, + -EOPNOTSUPP, /* NOT_SUPPORTED */ + -EINVAL, /* INVALID_PARAMETERS */ + -ENOMEM, /* NO_MEMORY */ + -EBUSY, /* BUSY */ + -EINTR, /* INTERRUPTED */ + -EACCES, /* DENIED */ + -EAGAIN, /* RETRY */ + -ECANCELED, /* ABORTED */ +}; + +struct ffa_abi_errmap err_msg_map[FFA_ERRMAP_COUNT] = { + [FFA_ID_TO_ERRMAP_ID(FFA_VERSION)] = { + { + "", + "NOT_SUPPORTED: A Firmware Framework implementation does not exist", + "", /* INVALID_PARAMETERS */ + "", /* NO_MEMORY */ + "", /* BUSY */ + "", /* INTERRUPTED */ + "", /* DENIED */ + "", /* RETRY */ + "", /* ABORTED */ + }, + }, + [FFA_ID_TO_ERRMAP_ID(FFA_ID_GET)] = { + { + "", + "NOT_SUPPORTED: This function is not implemented at this FF-A instance", + "", /* INVALID_PARAMETERS */ + "", /* NO_MEMORY */ + "", /* BUSY */ + "", /* INTERRUPTED */ + "", /* DENIED */ + "", /* RETRY */ + "", /* ABORTED */ + }, + }, + [FFA_ID_TO_ERRMAP_ID(FFA_FEATURES)] = { + { + "", + "NOT_SUPPORTED: FFA_RXTX_MAP is not implemented at this FF-A instance", + "", /* INVALID_PARAMETERS */ + "", /* NO_MEMORY */ + "", /* BUSY */ + "", /* INTERRUPTED */ + "", /* DENIED */ + "", /* RETRY */ + "", /* ABORTED */ + }, + }, + [FFA_ID_TO_ERRMAP_ID(FFA_PARTITION_INFO_GET)] = { + { + "", + "NOT_SUPPORTED: This function is not implemented at this FF-A instance", + "INVALID_PARAMETERS: Unrecognized UUID", + "NO_MEMORY: Results cannot fit in RX buffer of the caller", + "BUSY: RX buffer of the caller is not free", + "", /* INTERRUPTED */ + "DENIED: Callee is not in a state to handle this request", + "", /* RETRY */ + "", /* ABORTED */ + }, + }, + [FFA_ID_TO_ERRMAP_ID(FFA_RXTX_UNMAP)] = { + { + "", + "NOT_SUPPORTED: FFA_RXTX_UNMAP is not implemented at this FF-A instance", + "INVALID_PARAMETERS: No buffer pair registered on behalf of the caller", + "", /* NO_MEMORY */ + "", /* BUSY */ + "", /* INTERRUPTED */ + "", /* DENIED */ + "", /* RETRY */ + "", /* ABORTED */ + }, + }, + [FFA_ID_TO_ERRMAP_ID(FFA_RX_RELEASE)] = { + { + "", + "NOT_SUPPORTED: FFA_RX_RELEASE is not implemented at this FF-A instance", + "", /* INVALID_PARAMETERS */ + "", /* NO_MEMORY */ + "", /* BUSY */ + "", /* INTERRUPTED */ + "DENIED: Caller did not have ownership of the RX buffer", + "", /* RETRY */ + "", /* ABORTED */ + }, + }, + [FFA_ID_TO_ERRMAP_ID(FFA_RXTX_MAP)] = { + { + "", + "NOT_SUPPORTED: This function is not implemented at this FF-A instance", + "INVALID_PARAMETERS: Field(s) in input parameters incorrectly encoded", + "NO_MEMORY: Not enough memory", + "", /* BUSY */ + "", /* INTERRUPTED */ + "DENIED: Buffer pair already registered", + "", /* RETRY */ + "", /* ABORTED */ + }, + }, +}; + +/** + * ffa_to_std_errno - convert FF-A error code to standard error code + * @ffa_errno: Error code returned by the FF-A ABI + * + * This runtime function maps the given FF-A error code as specified + * by the spec to a u-boot standard error code. + * + * Return: + * + * The standard error code on success. . Otherwise, failure + */ +__ffa_runtime int ffa_to_std_errno(int ffa_errno) +{ + int err_idx = -ffa_errno; + + /* map the FF-A error code to the standard u-boot error code */ + if (err_idx > 0 && err_idx < MAX_NUMBER_FFA_ERR) + return ffa_to_std_errmap[err_idx]; + return -EINVAL; +} + +/** + * ffa_print_error_log - print the error log corresponding to the selected FF-A ABI + * @ffa_id: FF-A ABI ID + * @ffa_errno: Error code returned by the FF-A ABI + * + * This boot time function maps the FF-A error code to the error log relevant to the + * selected FF-A ABI. Then the error log is printed. + * + * Return: + * + * 0 on success. . Otherwise, failure + */ +int ffa_print_error_log(u32 ffa_id, int ffa_errno) +{ + int err_idx = -ffa_errno, abi_idx = 0; + + /* map the FF-A error code to the corresponding error log */ + + if (err_idx <= 0 || err_idx >= MAX_NUMBER_FFA_ERR) + return -EINVAL; + + if (ffa_id < FFA_FIRST_ID || ffa_id > FFA_LAST_ID) + return -EINVAL; + + abi_idx = FFA_ID_TO_ERRMAP_ID(ffa_id); + if (abi_idx < 0 || abi_idx >= FFA_ERRMAP_COUNT) + return -EINVAL; + + if (!err_msg_map[abi_idx].err_str || !err_msg_map[abi_idx].err_str[err_idx]) + return -EINVAL; + + ffa_err("%s", err_msg_map[abi_idx].err_str[err_idx]); + + return 0; +} + +/* + * Driver core functions + */ + +/** + * ffa_remove_device - removes the arm_ffa device + * @dev: the device to be removed + * + * This boot time function makes sure the arm_ffa device is removed + * No need to free the kmalloced data when the device is destroyed. + * It's automatically done by devm management by + * device_remove() -> device_free() -> devres_release_probe(). + * + * Return: + * + * 0 on success. Otherwise, failure + */ +int ffa_remove_device(struct udevice *dev) +{ + int ret; + + if (!dev) { + ffa_err("no udevice found"); + return -ENODEV; + } + + ret = device_remove(dev, DM_REMOVE_NORMAL); + if (ret) { + ffa_err("unable to remove. err:%d\n", ret); + return ret; + } + + ffa_info("device removed and freed"); + + ret = device_unbind(dev); + if (ret) { + ffa_err("unable to unbind. err:%d\n", ret); + return ret; + } + + ffa_info("device unbound"); + + return 0; +} + +/** + * ffa_device_get - create, bind and probe the arm_ffa device + * + * This boot time function makes sure the arm_ffa device is + * created, bound to this driver, probed and ready to use. + * Arm FF-A transport is implemented through a single u-boot + * device managing the FF-A bus (arm_ffa). + * + * Return: + * + * 0 on success. Otherwise, failure + */ +int ffa_device_get(void) +{ + int ret; + struct udevice *dev = NULL; + + ret = device_bind(dm_root(), + DM_DRIVER_GET(arm_ffa), + FFA_DRV_NAME, + NULL, + ofnode_null(), + &dev); + if (ret) + return ret; + + /* The FF-A bus discovery succeeds when probing is successful */ + ret = device_probe(dev); + if (ret) { + ffa_err("arm_ffa device probing failed"); + ffa_remove_device(dev); + return ret; + } + + return 0; +} + +/** + * ffa_get_version - FFA_VERSION handler function + * + * This is the boot time function that implements FFA_VERSION FF-A function + * to get from the secure world the FF-A framework version + * + * Return: + * + * 0 on success. Otherwise, failure + */ +static int ffa_get_version(void) +{ + u16 major, minor; + ffa_value_t res = {0}; + int ffa_errno; + + ffa_priv_data->invoke_ffa_fn((ffa_value_t){ + .a0 = FFA_SMC_32(FFA_VERSION), + .a1 = FFA_VERSION_1_0, .a2 = 0, .a3 = 0, .a4 = 0, .a5 = 0, .a6 = 0, .a7 = 0, + }, &res); + + ffa_errno = (int)res.a0; + if (ffa_errno < 0) { + ffa_print_error_log(FFA_VERSION, ffa_errno); + return ffa_to_std_errno(ffa_errno); + } + + major = GET_FFA_MAJOR_VERSION((u32)res.a0); + minor = GET_FFA_MINOR_VERSION((u32)res.a0); + + ffa_info("FF-A driver %d.%d\nFF-A framework %d.%d", + FFA_MAJOR_VERSION, FFA_MINOR_VERSION, major, minor); + + if ((major == FFA_MAJOR_VERSION && minor >= FFA_MINOR_VERSION)) { + ffa_info("Versions are compatible "); + + ffa_priv_data->fwk_version = (u32)res.a0; + + return 0; + } + + ffa_err("versions are incompatible\nExpected: %d.%d , Found: %d.%d\n", + FFA_MAJOR_VERSION, FFA_MINOR_VERSION, major, minor); + + return -EPROTONOSUPPORT; +} + +/** + * ffa_get_endpoint_id - FFA_ID_GET handler function + * + * This is the boot time function that implements FFA_ID_GET FF-A function + * to get from the secure world u-boot endpoint ID + * + * Return: + * + * 0 on success. Otherwise, failure + */ +static int ffa_get_endpoint_id(void) +{ + ffa_value_t res = {0}; + int ffa_errno; + + ffa_priv_data->invoke_ffa_fn((ffa_value_t){ + .a0 = FFA_SMC_32(FFA_ID_GET), + .a1 = 0, .a2 = 0, .a3 = 0, .a4 = 0, .a5 = 0, .a6 = 0, .a7 = 0, + }, &res); + + if (res.a0 == FFA_SMC_32(FFA_SUCCESS)) { + ffa_priv_data->id = GET_SELF_ENDPOINT_ID((u32)res.a2); + ffa_info("endpoint ID is %u", ffa_priv_data->id); + + return 0; + } + + ffa_errno = (int)res.a2; + + ffa_print_error_log(FFA_ID_GET, ffa_errno); + + return ffa_to_std_errno(ffa_errno); +} + +/** + * ffa_set_rxtx_buffers_pages_cnt - sets the minimum number of pages in each of the RX/TX buffers + * @prop_field: properties field obtained from FFA_FEATURES ABI + * + * This boot time function sets the minimum number of pages + * in each of the RX/TX buffers in the private data structure + * + * Return: + * + * buf_4k_pages points to the returned number of pages + * 0 on success. Otherwise, failure + */ +static int ffa_set_rxtx_buffers_pages_cnt(u32 prop_field) +{ + if (!ffa_priv_data) + return -EINVAL; + + switch (prop_field) { + case RXTX_4K: + ffa_priv_data->pair.rxtx_min_pages = 1; + break; + case RXTX_16K: + ffa_priv_data->pair.rxtx_min_pages = 4; + break; + case RXTX_64K: + ffa_priv_data->pair.rxtx_min_pages = 16; + break; + default: + ffa_err("RX/TX buffer size not supported"); + return -EINVAL; + } + + return 0; +} + +/** + * ffa_get_rxtx_map_features - FFA_FEATURES handler function with FFA_RXTX_MAP argument + * + * This is the boot time function that implements FFA_FEATURES FF-A function + * to retrieve the FFA_RXTX_MAP features + * + * Return: + * + * 0 on success. Otherwise, failure + */ +static int ffa_get_rxtx_map_features(void) +{ + ffa_value_t res = {0}; + int ffa_errno; + + ffa_priv_data->invoke_ffa_fn((ffa_value_t){ + .a0 = FFA_SMC_32(FFA_FEATURES), + .a1 = FFA_SMC_64(FFA_RXTX_MAP), + .a2 = 0, .a3 = 0, .a4 = 0, .a5 = 0, .a6 = 0, .a7 = 0, + }, &res); + + if (res.a0 == FFA_SMC_32(FFA_SUCCESS)) + return ffa_set_rxtx_buffers_pages_cnt((u32)res.a2); + + ffa_errno = (int)res.a2; + ffa_print_error_log(FFA_FEATURES, ffa_errno); + + return ffa_to_std_errno(ffa_errno); +} + +/** + * ffa_free_rxtx_buffers - frees the RX/TX buffers + * + * This is the boot time function used to free the RX/TX buffers + * + */ +static void ffa_free_rxtx_buffers(void) +{ + ffa_info("Freeing RX/TX buffers"); + + if (ffa_priv_data->pair.rxbuf) { + free((void *)ffa_priv_data->pair.rxbuf); + ffa_priv_data->pair.rxbuf = 0; + } + + if (ffa_priv_data->pair.txbuf) { + free((void *)ffa_priv_data->pair.txbuf); + ffa_priv_data->pair.txbuf = 0; + } +} + +/** + * ffa_alloc_rxtx_buffers - allocates the RX/TX buffers + * + * This is the boot time function used by ffa_map_rxtx_buffers to allocate + * the RX/TX buffers before mapping them. The allocated memory is physically + * contiguous since memalign ends up calling malloc which allocates + * contiguous memory in u-boot. + * + * Return: + * + * 0 on success. Otherwise, failure + */ +static int ffa_alloc_rxtx_buffers(void) +{ + u64 bytes; + + ffa_info("Using %lu 4KB page(s) for RX/TX buffers size", + ffa_priv_data->pair.rxtx_min_pages); + + bytes = ffa_priv_data->pair.rxtx_min_pages * SZ_4K; + + /* RX/TX buffers addresses should be PAGE_SIZE aligned */ + + ffa_priv_data->pair.rxbuf = (u64)memalign(PAGE_SIZE, bytes); + if (!ffa_priv_data->pair.rxbuf) { + ffa_err("failure to allocate RX buffer"); + return -ENOBUFS; + } + + ffa_info("RX buffer at virtual address 0x%llx", ffa_priv_data->pair.rxbuf); + + ffa_priv_data->pair.txbuf = (u64)memalign(PAGE_SIZE, bytes); + if (!ffa_priv_data->pair.txbuf) { + free((void *)ffa_priv_data->pair.rxbuf); + ffa_priv_data->pair.rxbuf = 0; + ffa_err("failure to allocate the TX buffer"); + return -ENOBUFS; + } + + ffa_info("TX buffer at virtual address 0x%llx", ffa_priv_data->pair.txbuf); + + /* + * make sure the buffers are cleared before use + */ + memset((void *)ffa_priv_data->pair.rxbuf, 0, bytes); + memset((void *)ffa_priv_data->pair.txbuf, 0, bytes); + + return 0; +} + +/** + * ffa_map_rxtx_buffers - FFA_RXTX_MAP handler function + * + * This is the boot time function that implements FFA_RXTX_MAP FF-A function + * to map the RX/TX buffers + * + * Return: + * + * 0 on success. Otherwise, failure + */ +static int ffa_map_rxtx_buffers(void) +{ + int ret; + ffa_value_t res = {0}; + int ffa_errno; + + ret = ffa_alloc_rxtx_buffers(); + if (ret) + return ret; + + /* + * we need to pass the physical addresses of the RX/TX buffers + * in u-boot physical/virtual mapping is 1:1 + *no need to convert from virtual to physical + */ + + ffa_priv_data->invoke_ffa_fn((ffa_value_t){ + .a0 = FFA_SMC_64(FFA_RXTX_MAP), + .a1 = ffa_priv_data->pair.txbuf, + .a2 = ffa_priv_data->pair.rxbuf, + .a3 = ffa_priv_data->pair.rxtx_min_pages, + .a4 = 0, .a5 = 0, .a6 = 0, .a7 = 0, + }, &res); + + if (res.a0 == FFA_SMC_32(FFA_SUCCESS)) { + ffa_info("RX/TX buffers mapped"); + return 0; + } + + ffa_errno = (int)res.a2; + ffa_print_error_log(FFA_RXTX_MAP, ffa_errno); + + ffa_free_rxtx_buffers(); + + return ffa_to_std_errno(ffa_errno); +} + +/** + * ffa_unmap_rxtx_buffers - FFA_RXTX_UNMAP handler function + * + * This is the boot time function that implements FFA_RXTX_UNMAP FF-A function + * to unmap the RX/TX buffers + * + * Return: + * + * 0 on success. Otherwise, failure + */ +static int ffa_unmap_rxtx_buffers(void) +{ + ffa_value_t res = {0}; + int ffa_errno; + + ffa_priv_data->invoke_ffa_fn((ffa_value_t){ + .a0 = FFA_SMC_32(FFA_RXTX_UNMAP), + .a1 = PREP_SELF_ENDPOINT_ID(ffa_priv_data->id), + .a2 = 0, .a3 = 0, .a4 = 0, .a5 = 0, .a6 = 0, .a7 = 0, + }, &res); + + if (res.a0 == FFA_SMC_32(FFA_SUCCESS)) { + ffa_free_rxtx_buffers(); + return 0; + } + + ffa_errno = (int)res.a2; + ffa_print_error_log(FFA_RXTX_UNMAP, ffa_errno); + + return ffa_to_std_errno(ffa_errno); +} + +/** + * ffa_release_rx_buffer - FFA_RX_RELEASE handler function + * + * This is the boot time function that invokes FFA_RX_RELEASE FF-A function + * to release the ownership of the RX buffer + * + * Return: + * + * 0 on success. Otherwise, failure + */ +static int ffa_release_rx_buffer(void) +{ + ffa_value_t res = {0}; + int ffa_errno; + + ffa_priv_data->invoke_ffa_fn((ffa_value_t){ + .a0 = FFA_SMC_32(FFA_RX_RELEASE), + .a1 = 0, .a2 = 0, .a3 = 0, .a4 = 0, .a5 = 0, .a6 = 0, .a7 = 0, + }, &res); + + if (res.a0 == FFA_SMC_32(FFA_SUCCESS)) + return 0; + + ffa_errno = (int)res.a2; + ffa_print_error_log(FFA_RX_RELEASE, ffa_errno); + + return ffa_to_std_errno(ffa_errno); +} + +/** + * ffa_uuid_are_identical - checks whether two given UUIDs are identical + * @uuid1: first UUID + * @uuid2: second UUID + * + * This is a boot time function used by ffa_read_partitions_info to search + * for a UUID in the partitions descriptors table + * + * Return: + * + * 1 when UUIDs match. Otherwise, 0 + */ +int ffa_uuid_are_identical(const struct ffa_partition_uuid *uuid1, + const struct ffa_partition_uuid *uuid2) +{ + if (!uuid1 || !uuid2) + return 0; + + return (!memcmp(uuid1, uuid2, sizeof(struct ffa_partition_uuid))); +} + +/** + * ffa_read_partitions_info - reads the data queried by FFA_PARTITION_INFO_GET + * and saves it in the private structure + * @count: The number of partitions queried + * @part_uuid: Pointer to the partition(s) UUID + * + * This is the boot time function that reads the partitions information + * returned by the FFA_PARTITION_INFO_GET and saves it in the private + * data structure. + * + * Return: + * + * The private data structure is updated with the partition(s) information + * 0 is returned on success. Otherwise, failure + */ +static int ffa_read_partitions_info(u32 count, struct ffa_partition_uuid *part_uuid) +{ + if (!count) { + ffa_err("no partition detected"); + return -ENODATA; + } + + ffa_info("Reading partitions data from the RX buffer"); + + if (!part_uuid) { + /* + * querying information of all partitions + */ + u64 buf_bytes; + u64 data_bytes; + u32 desc_idx; + struct ffa_partition_info *parts_info; + + data_bytes = count * sizeof(struct ffa_partition_desc); + + buf_bytes = ffa_priv_data->pair.rxtx_min_pages * SZ_4K; + + if (data_bytes > buf_bytes) { + ffa_err("partitions data size exceeds the RX buffer size:"); + ffa_err(" sizes in bytes: data %llu , RX buffer %llu ", + data_bytes, + buf_bytes); + + return -ENOMEM; + } + + ffa_priv_data->partitions.descs = (struct ffa_partition_desc *) + devm_kmalloc(ffa_priv_data->dev, data_bytes, __GFP_ZERO); + if (!ffa_priv_data->partitions.descs) { + ffa_err("cannot allocate partitions data buffer"); + return -ENOMEM; + } + + parts_info = (struct ffa_partition_info *)ffa_priv_data->pair.rxbuf; + + for (desc_idx = 0 ; desc_idx < count ; desc_idx++) { + ffa_priv_data->partitions.descs[desc_idx].info = + parts_info[desc_idx]; + + ffa_info("Partition ID %x : info cached", + ffa_priv_data->partitions.descs[desc_idx].info.id); + } + + ffa_priv_data->partitions.count = count; + + ffa_info("%d partition(s) found and cached", count); + + } else { + u32 rx_desc_idx, cached_desc_idx; + struct ffa_partition_info *parts_info; + u8 desc_found; + + parts_info = (struct ffa_partition_info *)ffa_priv_data->pair.rxbuf; + + /* + * search for the SP IDs read from the RX buffer + * in the already cached SPs. + * Update the UUID when ID found. + */ + for (rx_desc_idx = 0; rx_desc_idx < count ; rx_desc_idx++) { + desc_found = 0; + + /* + * search the current ID in the cached partitions + */ + for (cached_desc_idx = 0; + cached_desc_idx < ffa_priv_data->partitions.count; + cached_desc_idx++) { + /* + * save the UUID + */ + if (ffa_priv_data->partitions.descs[cached_desc_idx].info.id == + parts_info[rx_desc_idx].id) { + ffa_priv_data->partitions.descs[cached_desc_idx].sp_uuid = + *part_uuid; + + desc_found = 1; + break; + } + } + + if (!desc_found) + return -ENODATA; + } + } + + return 0; +} + +/** + * ffa_query_partitions_info - invokes FFA_PARTITION_INFO_GET and saves partitions data + * + * @part_uuid: Pointer to the partition(s) UUID + * @pcount: Pointer to the number of partitions variable filled when querying + * + * This is the boot time function that executes the FFA_PARTITION_INFO_GET + * to query the partitions data. Then, it calls ffa_read_partitions_info + * to save the data in the private data structure. + * + * After reading the data the RX buffer is released using ffa_release_rx_buffer + * + * Return: + * + * When part_uuid is NULL, all partitions data are retrieved from secure world + * When part_uuid is non NULL, data for partitions matching the given UUID are + * retrieved and the number of partitions is returned + * 0 is returned on success. Otherwise, failure + */ +static int ffa_query_partitions_info(struct ffa_partition_uuid *part_uuid, + u32 *pcount) +{ + struct ffa_partition_uuid query_uuid = {0}; + ffa_value_t res = {0}; + int ffa_errno; + + /* + * If a UUID is specified. Information for one or more + * partitions in the system is queried. Otherwise, information + * for all installed partitions is queried + */ + + if (part_uuid) { + if (!pcount) + return -EINVAL; + + query_uuid = *part_uuid; + } else if (pcount) { + return -EINVAL; + } + + ffa_priv_data->invoke_ffa_fn((ffa_value_t){ + .a0 = FFA_SMC_32(FFA_PARTITION_INFO_GET), + .a1 = query_uuid.a1, + .a2 = query_uuid.a2, + .a3 = query_uuid.a3, + .a4 = query_uuid.a4, + .a5 = 0, + .a6 = 0, + .a7 = 0, + }, &res); + + if (res.a0 == FFA_SMC_32(FFA_SUCCESS)) { + int ret; + + /* + * res.a2 contains the count of partition information descriptors + * populated in the RX buffer + */ + if (res.a2) { + ret = ffa_read_partitions_info((u32)res.a2, part_uuid); + if (ret) { + ffa_err("failed to read partition(s) data , error (%d)", ret); + ffa_release_rx_buffer(); + return -EINVAL; + } + } + + /* + * return the SP count (when querying using a UUID) + */ + if (pcount) + *pcount = (u32)res.a2; + + /* + * After calling FFA_PARTITION_INFO_GET the buffer ownership + * is assigned to the consumer (u-boot). So, we need to give + * the ownership back to the SPM or hypervisor + */ + ret = ffa_release_rx_buffer(); + + return ret; + } + + ffa_errno = (int)res.a2; + ffa_print_error_log(FFA_PARTITION_INFO_GET, ffa_errno); + + return ffa_to_std_errno(ffa_errno); +} + +/** + * ffa_get_partitions_info - FFA_PARTITION_INFO_GET handler function + * + * The passed arguments: + * Mode 1: When getting from the driver the number of + * secure partitions: + * @uuid_str: pointer to the UUID string + * @parts_size: pointer to the variable that contains the number of partitions + * The variable will be set by the driver + * @buffer: NULL + * + * Mode 2: When requesting the driver to return the + * partitions information: + * @uuid_str: pointer to the UUID string + * @parts_size: pointer to the size of the SPs information buffer in bytes + * @buffer: pointer to SPs information buffer + * (allocated by the client). + * The buffer will be filled by the driver + * + * This is the boot time function that queries the secure partition data from + * the private data structure. If not found, it invokes FFA_PARTITION_INFO_GET + * FF-A function to query the partition information from secure world. + * + * A client of the FF-A driver should know the UUID of the service it wants to + * access. It should use the UUID to request the FF-A driver to provide the + * partition(s) information of the service. The FF-A driver uses + * PARTITION_INFO_GET to obtain this information. This is implemented through + * ffa_get_partitions_info function. + * A new FFA_PARTITION_INFO_GET call is issued (first one performed through + * ffa_cache_partitions_info) allowing to retrieve the partition(s) information. + * They are not saved (already done). We only update the UUID in the cached area. + * This assumes that partitions data does not change in the secure world. + * Otherwise u-boot will have an outdated partition data. The benefit of caching + * the information in the FF-A driver is to accommodate discovery after + * ExitBootServices(). + * + * When invoked through a client request, ffa_get_partitions_info should be + * called twice. First call is to get from the driver the number of secure + * partitions (SPs) associated to a particular UUID. + * Then, the caller (client) allocates the buffer to host the SPs data and + * issues a 2nd call. Then, the driver fills the SPs data in the pre-allocated + * buffer. + * + * To achieve the mechanism described above, ffa_get_partitions_info uses the + * following functions: + * ffa_read_partitions_info + * ffa_query_partitions_info + * + * Return: + * + * @parts_size: When pointing to the number of partitions variable, the number is + * set by the driver. + * When pointing to the partitions information buffer size, the buffer will be + * filled by the driver. + * + * On success 0 is returned. Otherwise, failure + */ +static int ffa_get_partitions_info(const char *uuid_str, + u32 *parts_size, struct ffa_partition_info *buffer) +{ + /* + * fill_data: + * 0: return the SP count + * 1: fill SP data and return it to the caller + * -1: undefined mode + */ + int fill_data = -1; + u32 desc_idx, client_desc_idx; + struct ffa_partition_uuid part_uuid = {0}; + u32 client_desc_max_cnt; + u32 parts_found = 0; + + if (!ffa_priv_data->partitions.count || !ffa_priv_data->partitions.descs) { + ffa_err("no partition installed"); + return -EINVAL; + } + + if (!uuid_str) { + ffa_err("no UUID provided"); + return -EINVAL; + } + + if (!parts_size) { + ffa_err("no size/count provided"); + return -EINVAL; + } + + if (be_uuid_str_to_le_bin(uuid_str, (unsigned char *)&part_uuid)) { + ffa_err("invalid UUID"); + return -EINVAL; + } + + if (!buffer) { + /* Mode 1: getting the number of secure partitions */ + + fill_data = 0; + + ffa_info("Preparing for checking partitions count"); + + } else if ((*parts_size >= sizeof(struct ffa_partition_info)) && + !(*parts_size % sizeof(struct ffa_partition_info))) { + /* Mode 2: retrieving the partitions information */ + + fill_data = 1; + + client_desc_idx = 0; + + /* + * number of empty descriptors preallocated by the caller + */ + client_desc_max_cnt = *parts_size / sizeof(struct ffa_partition_info); + + ffa_info("Preparing for filling partitions info"); + + } else { + ffa_err("invalid function arguments provided"); + return -EINVAL; + } + + ffa_info("Searching partitions using the provided UUID"); + + /* + * search in the cached partitions + */ + for (desc_idx = 0; + desc_idx < ffa_priv_data->partitions.count; + desc_idx++) { + if (ffa_uuid_are_identical(&ffa_priv_data->partitions.descs[desc_idx].sp_uuid, + &part_uuid)) { + ffa_info("Partition ID %x matches the provided UUID", + ffa_priv_data->partitions.descs[desc_idx].info.id); + + parts_found++; + + if (fill_data) { + /* + * trying to fill the partition info in the input buffer + */ + + if (client_desc_idx < client_desc_max_cnt) { + buffer[client_desc_idx++] = + ffa_priv_data->partitions.descs[desc_idx].info; + continue; + } + + ffa_err("failed to fill the current descriptor client buffer full"); + return -ENOBUFS; + } + } + } + + if (!parts_found) { + int ret; + + ffa_info("No partition found. Querying framework ..."); + + ret = ffa_query_partitions_info(&part_uuid, &parts_found); + + if (ret == 0) { + if (!fill_data) { + *parts_size = parts_found; + + ffa_info("Number of partition(s) found matching the UUID: %d", + parts_found); + } else { + /* + * If SPs data detected, they are already in the private data + * structure, retry searching SP data again to return them + * to the caller + */ + if (parts_found) + ret = ffa_get_partitions_info(uuid_str, parts_size, buffer); + else + ret = -ENODATA; + } + } + + return ret; + } + + /* partition(s) found */ + if (!fill_data) + *parts_size = parts_found; + + return 0; +} + +/** + * ffa_cache_partitions_info - Queries and saves all secure partitions data + * + * This is a boot time function that invokes FFA_PARTITION_INFO_GET FF-A + * function to query from secure world all partitions information. + * + * The FFA_PARTITION_INFO_GET call is issued with nil UUID as an argument. + * All installed partitions information are returned. We cache them in the + * resident private data structure and we keep the UUID field empty + * (in FF-A 1.0 UUID is not provided by the partition descriptor) + * + * This function is called at the device probing level. + * ffa_cache_partitions_info uses ffa_query_partitions_info to get the data + * + * Return: + * + * 0 on success. Otherwise, failure + */ +static int ffa_cache_partitions_info(void) +{ + return ffa_query_partitions_info(NULL, NULL); +} + +/** + * ffa_msg_send_direct_req - FFA_MSG_SEND_DIRECT_{REQ,RESP} handler function + * @dst_part_id: destination partition ID + * @msg: pointer to the message data preallocated by the client (in/out) + * + * This is the runtime function that implements FFA_MSG_SEND_DIRECT_{REQ,RESP} + * FF-A functions. + * + * FFA_MSG_SEND_DIRECT_REQ is used to send the data to the secure partition. + * The response from the secure partition is handled by reading the + * FFA_MSG_SEND_DIRECT_RESP arguments. + * + * The maximum size of the data that can be exchanged is 40 bytes which is + * sizeof(struct ffa_send_direct_data) as defined by the FF-A specification 1.0 + * in the section relevant to FFA_MSG_SEND_DIRECT_{REQ,RESP} + * + * Return: + * + * 0 on success. Otherwise, failure + */ +static int __ffa_runtime ffa_msg_send_direct_req(u16 dst_part_id, struct ffa_send_direct_data *msg) +{ + ffa_value_t res = {0}; + int ffa_errno; + + if (!ffa_priv_data || !ffa_priv_data->invoke_ffa_fn) + return -EINVAL; + + /* No partition installed */ + if (!ffa_priv_data->partitions.count || !ffa_priv_data->partitions.descs) + return -ENODEV; + + ffa_priv_data->invoke_ffa_fn((ffa_value_t){ + .a0 = FFA_SMC_64(FFA_MSG_SEND_DIRECT_REQ), + .a1 = PREP_SELF_ENDPOINT_ID(ffa_priv_data->id) | + PREP_PART_ENDPOINT_ID(dst_part_id), + .a2 = 0, + .a3 = msg->data0, + .a4 = msg->data1, + .a5 = msg->data2, + .a6 = msg->data3, + .a7 = msg->data4, + }, &res); + + while (res.a0 == FFA_SMC_32(FFA_INTERRUPT)) + ffa_priv_data->invoke_ffa_fn((ffa_value_t){ + .a0 = FFA_SMC_32(FFA_RUN), + .a1 = res.a1, .a2 = 0, .a3 = 0, .a4 = 0, .a5 = 0, .a6 = 0, .a7 = 0, + }, &res); + + if (res.a0 == FFA_SMC_32(FFA_SUCCESS)) { + /* Message sent with no response */ + return 0; + } + + if (res.a0 == FFA_SMC_64(FFA_MSG_SEND_DIRECT_RESP)) { + /* + * Message sent with response + * extract the return data + */ + msg->data0 = res.a3; + msg->data1 = res.a4; + msg->data2 = res.a5; + msg->data3 = res.a6; + msg->data4 = res.a7; + + return 0; + } + + ffa_errno = (int)res.a2; + return ffa_to_std_errno(ffa_errno); +} + +/** + * __arm_ffa_fn_smc - SMC wrapper + * @args: FF-A ABI arguments to be copied to Xn registers + * @res: FF-A ABI return data to be copied from Xn registers + * + * Calls low level SMC assembly function + * + * Return: void + */ +void __ffa_runtime __arm_ffa_fn_smc(ffa_value_t args, ffa_value_t *res) +{ + arm_smccc_1_2_smc(&args, res); +} + +/** + * ffa_set_smc_conduit - Set the SMC conduit + * + * This boot time function selects the SMC conduit by setting the driver invoke function + * to SMC assembly function + * + * Return: + * + * 0 on success. Otherwise, failure + */ +static int ffa_set_smc_conduit(void) +{ + ffa_priv_data->invoke_ffa_fn = __arm_ffa_fn_smc; + + if (!ffa_priv_data->invoke_ffa_fn) { + ffa_err("failure to set the invoke function"); + return -EINVAL; + } + + ffa_info("Conduit is SMC"); + + return 0; +} + +/** + * ffa_set_bus_ops - Set the bus driver operations + * + * Setting the driver callbacks. + * + */ +static void ffa_set_bus_ops(void) +{ + ffa_priv_data->ffa_ops.partition_info_get = ffa_get_partitions_info; + ffa_priv_data->ffa_ops.sync_send_receive = ffa_msg_send_direct_req; + ffa_priv_data->ffa_ops.rxtx_unmap = ffa_unmap_rxtx_buffers; +} + +/** + * ffa_alloc_prvdata - allocate the driver main data structure and sets the device + * @dev: the arm_ffa device + * + * This boot time function creates the main data structure embedding all the driver data. + * + * Return: + * + * 0 on success. Otherwise, failure + */ +static int ffa_alloc_prvdata(struct udevice *dev) +{ + if (!dev) { + ffa_err("no udevice found"); + return -ENODEV; + } + + /* The device is registered with the DM. Let's create the driver main data structure*/ + + ffa_priv_data = devm_kmalloc(dev, sizeof(struct ffa_prvdata), __GFP_ZERO); + if (!ffa_priv_data) { + ffa_err("can not allocate the driver main data structure"); + return -ENOMEM; + } + + ffa_priv_data->dev = dev; + + return 0; +} + +/** + * ffa_probe - The driver probe function + * @dev: the arm_ffa device + * + * Probing is done at boot time and triggered by the uclass device discovery. + * At probe level the following actions are done: + * - setting the conduit + * - querying the FF-A framework version + * - querying from secure world the u-boot endpoint ID + * - querying from secure world the supported features of FFA_RXTX_MAP + * - mapping the RX/TX buffers + * - querying from secure world all the partitions information + * + * All data queried from secure world is saved in the resident private data structure. + * + * The probe will fail if either FF-A framework is not detected or the + * FF-A requests are not behaving correctly. This ensures that the + * driver is not installed and its operations are not exported to the clients. + * + * Return: + * + * 0 on success. Otherwise, failure + */ +static int ffa_probe(struct udevice *dev) +{ + int ret; + + ret = ffa_alloc_prvdata(dev); + if (ret != 0) + return ret; + + ffa_set_bus_ops(); + + ret = ffa_set_smc_conduit(); + if (ret != 0) + return ret; + + ret = ffa_get_version(); + if (ret != 0) + return ret; + + ret = ffa_get_endpoint_id(); + if (ret != 0) + return ret; + + ret = ffa_get_rxtx_map_features(); + if (ret != 0) + return ret; + + ret = ffa_map_rxtx_buffers(); + if (ret != 0) + return ret; + + ret = ffa_cache_partitions_info(); + if (ret != 0) { + ffa_free_rxtx_buffers(); + return ret; + } + + return 0; +} + +/** + * ffa_remove - The driver remove function + * @dev: the arm_ffa device + * When the device is about to be removed , unmap the RX/TX buffers and free the memory + * Return: + * + * 0 on success. + */ +static int ffa_remove(struct udevice *dev) +{ + ffa_info("removing the device"); + + ffa_unmap_rxtx_buffers(); + + if (ffa_priv_data->pair.rxbuf || ffa_priv_data->pair.txbuf) + ffa_free_rxtx_buffers(); + + return 0; +} + +/** + * ffa_unbind - The driver unbind function + * @dev: the arm_ffa device + * After the device is removed and memory freed the device is unbound + * Return: + * + * 0 on success. + */ +static int ffa_unbind(struct udevice *dev) +{ + ffa_info("unbinding the device , private data already released"); + + ffa_priv_data = NULL; + + return 0; +} + +/** + * ffa_bus_ops_get - bus driver operations getter + * + * Return: + * This runtime function returns a pointer to the driver operations structure + */ +const struct ffa_bus_ops * __ffa_runtime ffa_bus_ops_get(void) +{ + return &ffa_priv_data->ffa_ops; +} + +/** + * ffa_bus_prvdata_get - bus driver private data getter + * + * Return: + * This boot time function returns a pointer to the main private data structure + */ +struct ffa_prvdata **ffa_bus_prvdata_get(void) +{ + return &ffa_priv_data; +} + +/** + * ffa_bus_discover - discover FF-A bus and probe the arm_ffa device + * + * This boot time function makes sure the FF-A bus is discoverable. + * Then, the arm_ffa device is probed and ready to use. + * This function is called automatically at initcalls + * level (after u-boot relocation). + * + * When the bus was already discovered successfully the discovery will not run again. + * + * Arm FF-A transport is implemented through arm_ffa u-boot device managing the FF-A + * communication. + * All FF-A clients should use the arm_ffa device to use the FF-A transport. + * + * Return: + * + * 0 on success. Otherwise, failure + */ +int ffa_bus_discover(void) +{ + int ret = 0; + + if (!ffa_priv_data) + ret = ffa_device_get(); + + return ret; +} + +/** + * Declaring the arm_ffa driver under UCLASS_FFA + */ + +U_BOOT_DRIVER(arm_ffa) = { + .name = FFA_DRV_NAME, + .id = UCLASS_FFA, + .probe = ffa_probe, + .remove = ffa_remove, + .unbind = ffa_unbind, +}; diff --git a/drivers/firmware/arm-ffa/efi_ffa_runtime_data_mgr.c b/drivers/firmware/arm-ffa/efi_ffa_runtime_data_mgr.c new file mode 100644 index 0000000000..c76cf2147b --- /dev/null +++ b/drivers/firmware/arm-ffa/efi_ffa_runtime_data_mgr.c @@ -0,0 +1,94 @@ +// SPDX-License-Identifier: GPL-2.0+ +/* + * (C) Copyright 2022 ARM Limited + * Abdellatif El Khlifi abdellatif.elkhlifi@arm.com + */ + +#include "arm_ffa_prv.h" + +/** + * ffa_copy_runtime_data - copy the private data structure to the runtime area + * + * This boot time function copies the arm_ffa driver data structures including + * partitions data to the EFI runtime data section. + * + * Return: + * + * 0 on success. Otherwise, failure + */ +efi_status_t ffa_copy_runtime_data(void) +{ + efi_status_t efi_ret; + efi_uintn_t prvdata_pages; + efi_uintn_t descs_pages; + struct ffa_prvdata **prvdata = NULL; /* Pointer to the current structure */ + struct ffa_prvdata *runtime_prvdata = NULL; /* Pointer to the structure runtime copy */ + u64 runtime_descs = 0; + + prvdata = ffa_bus_prvdata_get(); + + printf("INFO: EFI: FFA: prv data area at 0x%llx\n", (u64)prvdata); + + /* allocate private data runtime area */ + + prvdata_pages = efi_size_in_pages(sizeof(struct ffa_prvdata)); + efi_ret = efi_allocate_pages(EFI_ALLOCATE_ANY_PAGES, + EFI_RUNTIME_SERVICES_DATA, + prvdata_pages, + (u64 *)&runtime_prvdata); + + if (efi_ret != EFI_SUCCESS) { + printf("ERROR: EFI: FFA: allocating runtime data (err: 0x%lx, addr 0x%llx)\n", + efi_ret, (u64)runtime_prvdata); + + return efi_ret; + } + + printf("INFO: EFI: FFA: runtime data area at 0x%llx\n", (u64)runtime_prvdata); + + if (!runtime_prvdata) + return EFI_INVALID_PARAMETER; + + /* allocate the partition data runtime area */ + + descs_pages = efi_size_in_pages((*prvdata)->partitions.count * + sizeof(struct ffa_partition_desc)); + efi_ret = efi_allocate_pages(EFI_ALLOCATE_ANY_PAGES, + EFI_RUNTIME_SERVICES_DATA, + descs_pages, + &runtime_descs); + + if (efi_ret != EFI_SUCCESS) { + printf("ERROR: EFI: FFA: allocating runtime SPs data (err: 0x%lx, addr 0x%llx)\n", + efi_ret, runtime_descs); + + efi_free_pages((u64)runtime_prvdata, prvdata_pages); + + return efi_ret; + } + + printf("INFO: EFI: FFA: SPs runtime area at 0x%llx\n", (u64)runtime_descs); + + if (!runtime_descs) + return EFI_INVALID_PARAMETER; + + *runtime_prvdata = **prvdata; + + runtime_prvdata->dev = NULL; + runtime_prvdata->ffa_ops.partition_info_get = NULL; + runtime_prvdata->ffa_ops.rxtx_unmap = NULL; + runtime_prvdata->partitions.descs = (struct ffa_partition_desc *)runtime_descs; + runtime_prvdata->pair.rxbuf = 0; + runtime_prvdata->pair.txbuf = 0; + + /* + * Update the private data structure pointer in the driver + * no need to free the old structure. devm takes care of that + */ + *prvdata = runtime_prvdata; + + printf("INFO: EFI: FFA: runtime prv data now at 0x%llx , SPs count %d\n", + (u64)*prvdata, (*prvdata)->partitions.count); + + return 0; +} diff --git a/include/arm_ffa.h b/include/arm_ffa.h new file mode 100644 index 0000000000..f17b100497 --- /dev/null +++ b/include/arm_ffa.h @@ -0,0 +1,127 @@ +/* SPDX-License-Identifier: GPL-2.0+ */ +/* + * (C) Copyright 2022 ARM Limited + * Abdellatif El Khlifi abdellatif.elkhlifi@arm.com + */ + +#ifndef __ARM_FFA_H +#define __ARM_FFA_H + +#include <linux/printk.h> + +/* + * This header is public. It can be used by clients to access + * data structures and definitions they need + */ + +/* + * Macros for displaying logs + */ + +#define ffa_info(fmt, ...) pr_info("[FFA] " fmt "\n", ##__VA_ARGS__) +#define ffa_err(fmt, ...) pr_err("[FFA] " fmt "\n", ##__VA_ARGS__) + +/* + * struct ffa_partition_info - Partition information descriptor + * @id: Partition ID + * @exec_ctxt: Execution context count + * @properties: Partition properties + * + * Data structure containing information about partitions instantiated in the system + * This structure is filled with the data queried by FFA_PARTITION_INFO_GET + */ +struct __packed ffa_partition_info { + u16 id; + u16 exec_ctxt; +/* partition supports receipt of direct requests */ +#define FFA_PARTITION_DIRECT_RECV BIT(0) +/* partition can send direct requests. */ +#define FFA_PARTITION_DIRECT_SEND BIT(1) +/* partition can send and receive indirect messages. */ +#define FFA_PARTITION_INDIRECT_MSG BIT(2) + u32 properties; +}; + +/* + * struct ffa_send_direct_data - Data structure hosting the data + * used by FFA_MSG_SEND_DIRECT_{REQ,RESP} + * @data0-4: Data read/written from/to x3-x7 registers + * + * Data structure containing the data to be sent by FFA_MSG_SEND_DIRECT_REQ + * or read from FFA_MSG_SEND_DIRECT_RESP + */ + +/* For use with FFA_MSG_SEND_DIRECT_{REQ,RESP} which pass data via registers */ +struct __packed ffa_send_direct_data { + unsigned long data0; /* w3/x3 */ + unsigned long data1; /* w4/x4 */ + unsigned long data2; /* w5/x5 */ + unsigned long data3; /* w6/x6 */ + unsigned long data4; /* w7/x7 */ +}; + +#if CONFIG_IS_ENABLED(ARM_FFA_EFI_RUNTIME_MODE) + +#include <efi_loader.h> + +/* + * __ffa_runtime - controls whether functions are + * available after calling the EFI ExitBootServices service. + * Functions tagged with these keywords are resident (available at boot time and + * at runtime) + */ + +#define __ffa_runtime_data __efi_runtime_data +#define __ffa_runtime __efi_runtime + +#else + +/* + * The FF-A driver is independent from EFI + */ + +#define __ffa_runtime_data +#define __ffa_runtime + +#endif + +/** + * struct ffa_bus_ops - The driver operations structure + * @partition_info_get: callback for the FFA_PARTITION_INFO_GET + * @sync_send_receive: callback for the FFA_MSG_SEND_DIRECT_REQ + * @rxtx_unmap: callback for the FFA_RXTX_UNMAP + * + * The data structure providing all the operations supported by the driver. + * This structure is EFI runtime resident. + */ +struct ffa_bus_ops { + int (*partition_info_get)(const char *uuid_str, + u32 *parts_size, struct ffa_partition_info *buffer); + int (*sync_send_receive)(u16 dst_part_id, struct ffa_send_direct_data *msg); + int (*rxtx_unmap)(void); +}; + +/** + * The device driver and the Uclass driver public functions + */ + +/** + * ffa_bus_ops_get - driver operations getter + */ +const struct ffa_bus_ops * __ffa_runtime ffa_bus_ops_get(void); + +/** + * ffa_bus_discover - discover FF-A bus and probes the arm_ffa device + */ +int ffa_bus_discover(void); + +#if CONFIG_IS_ENABLED(ARM_FFA_EFI_RUNTIME_MODE) + +/** + * ffa_copy_runtime_data - copy the private data structure and the SPs data to the runtime area + */ +efi_status_t ffa_copy_runtime_data(void); + +#endif + +#endif diff --git a/include/dm/uclass-id.h b/include/dm/uclass-id.h index a432e43871..5dd698b7a9 100644 --- a/include/dm/uclass-id.h +++ b/include/dm/uclass-id.h @@ -4,6 +4,9 @@ * * (C) Copyright 2012 * Pavel Herrmann morpheus.ibis@gmail.com + * + * (C) Copyright 2022 ARM Limited + * Abdellatif El Khlifi abdellatif.elkhlifi@arm.com */
#ifndef _DM_UCLASS_ID_H @@ -55,6 +58,7 @@ enum uclass_id { UCLASS_EFI_MEDIA, /* Devices provided by UEFI firmware */ UCLASS_ETH, /* Ethernet device */ UCLASS_ETH_PHY, /* Ethernet PHY device */ + UCLASS_FFA, /* Arm Firmware Framework for Armv8-A */ UCLASS_FIRMWARE, /* Firmware */ UCLASS_FUZZING_ENGINE, /* Fuzzing engine */ UCLASS_FS_FIRMWARE_LOADER, /* Generic loader */ diff --git a/lib/efi_loader/efi_boottime.c b/lib/efi_loader/efi_boottime.c index 6f7333638a..af0b0f3db1 100644 --- a/lib/efi_loader/efi_boottime.c +++ b/lib/efi_loader/efi_boottime.c @@ -3,6 +3,9 @@ * EFI application boot time services * * Copyright (c) 2016 Alexander Graf + * + * (C) Copyright 2022 ARM Limited + * Abdellatif El Khlifi abdellatif.elkhlifi@arm.com */
#include <common.h> @@ -23,6 +26,10 @@ #include <asm/setjmp.h> #include <linux/libfdt_env.h>
+#if CONFIG_IS_ENABLED(ARM_FFA_TRANSPORT) +#include <arm_ffa.h> +#endif + DECLARE_GLOBAL_DATA_PTR;
/* Task priority level */ @@ -2178,6 +2185,14 @@ static efi_status_t EFIAPI efi_exit_boot_services(efi_handle_t image_handle, dm_remove_devices_flags(DM_REMOVE_ACTIVE_ALL); }
+#if CONFIG_IS_ENABLED(ARM_FFA_TRANSPORT) + /* unmap FF-A RX/TX buffers */ + if (ffa_bus_ops_get()->rxtx_unmap()) + debug("[efi_boottime][ERROR]: can not unmap FF-A RX/TX buffers\n"); + else + debug("[efi_boottime][INFO]: FF-A RX/TX buffers unmapped\n"); +#endif + /* Patch out unsupported runtime function */ efi_runtime_detach();
On Mon, Sep 26, 2022 at 03:08:21PM +0100, Abdellatif El Khlifi wrote:
Add the driver implementing Arm Firmware Framework for Armv8-A v1.0
The Firmware Framework for Arm A-profile processors (FF-A v1.0) [1] describes interfaces (ABIs) that standardize communication between the Secure World and Normal World leveraging TrustZone technology.
This driver uses 64-bit registers as per SMCCCv1.2 spec and comes on top of the SMCCC layer. The driver provides the FF-A ABIs needed for querying the FF-A framework from the secure world.
32-bit version of the ABIs is supported and 64-bit version of FFA_RXTX_MAP and FFA_MSG_SEND_DIRECT_{REQ, RESP}.
In u-boot FF-A design, FF-A is considered as a discoverable bus. The Secure World is considered as one entity to communicate with using the FF-A bus. FF-A communication is handled by one device and one instance (the bus). This FF-A driver takes care of all the interactions between Normal world and Secure World.
The driver exports its operations to be used by upper layers.
Exported operations:
- partition_info_get
- sync_send_receive
- rxtx_unmap
This implementation provides an optional feature to copy the driver data to EFI runtime area.
Signed-off-by: Abdellatif El Khlifi abdellatif.elkhlifi@arm.com Cc: Tom Rini trini@konsulko.com Cc: Simon Glass sjg@chromium.org Cc: Ilias Apalodimas ilias.apalodimas@linaro.org Cc: Jens Wiklander jens.wiklander@linaro.org
Changelog:
v4:
- add doc/README.ffa.drv
- moving the FF-A driver work to drivers/firmware/arm-ffa
- use less #ifdefs in lib/efi_loader/efi_boottime.c and replace #if defined by #if CONFIG_IS_ENABLED
- improving error handling by mapping the FF-A errors to standard errors and logs
- replacing panics with an error log and returning an error code
- improving features discovery in FFA_FEATURES by introducing rxtx_min_pages private data field
- add ffa_remove and ffa_bind functions
- improve how the driver behaves when bus discovery is done more than once
v3:
- align the interfaces of the u-boot FF-A driver with those in the linux FF-A driver
- remove the FF-A helper layer
- make the u-boot FF-A driver independent from EFI
- provide an optional config that enables copying the driver data to EFI runtime section at ExitBootServices service
- use 64-bit version of FFA_RXTX_MAP, FFA_MSG_SEND_DIRECT_{REQ, RESP}
v2:
- make FF-A bus discoverable using device_{bind, probe} APIs
- remove device tree support
v1:
- introduce FF-A bus driver with device tree support
MAINTAINERS | 7 + common/board_r.c | 9 + doc/README.ffa.drv | 160 ++ drivers/Kconfig | 2 + drivers/Makefile | 1 + drivers/firmware/arm-ffa/Kconfig | 39 + drivers/firmware/arm-ffa/Makefile | 7 + drivers/firmware/arm-ffa/arm-ffa-uclass.c | 16 + drivers/firmware/arm-ffa/arm_ffa_prv.h | 196 +++ drivers/firmware/arm-ffa/core.c | 1344 +++++++++++++++++ .../arm-ffa/efi_ffa_runtime_data_mgr.c | 94 ++ include/arm_ffa.h | 127 ++ include/dm/uclass-id.h | 4 + lib/efi_loader/efi_boottime.c | 15 + 14 files changed, 2021 insertions(+) create mode 100644 doc/README.ffa.drv create mode 100644 drivers/firmware/arm-ffa/Kconfig create mode 100644 drivers/firmware/arm-ffa/Makefile create mode 100644 drivers/firmware/arm-ffa/arm-ffa-uclass.c create mode 100644 drivers/firmware/arm-ffa/arm_ffa_prv.h create mode 100644 drivers/firmware/arm-ffa/core.c create mode 100644 drivers/firmware/arm-ffa/efi_ffa_runtime_data_mgr.c create mode 100644 include/arm_ffa.h
diff --git a/MAINTAINERS b/MAINTAINERS index 83346183ee..02b84d5074 100644 --- a/MAINTAINERS +++ b/MAINTAINERS @@ -248,6 +248,13 @@ F: drivers/net/cortina_ni.h F: drivers/net/phy/ca_phy.c F: configs/cortina_presidio-asic-pnand_defconfig
+ARM FF-A +M: Abdellatif El Khlifi abdellatif.elkhlifi@arm.com +S: Maintained +F: doc/README.ffa.drv +F: drivers/firmware/arm-ffa/ +F: include/arm_ffa.h
ARM FREESCALE IMX M: Stefano Babic sbabic@denx.de M: Fabio Estevam festevam@gmail.com diff --git a/common/board_r.c b/common/board_r.c index 56eb60fa27..8c99faddfd 100644 --- a/common/board_r.c +++ b/common/board_r.c @@ -7,6 +7,8 @@
- (C) Copyright 2002
- Sysgo Real-Time Solutions, GmbH <www.elinos.com>
- Marius Groeger mgroeger@sysgo.de
- (C) Copyright 2022 ARM Limited
#include <common.h> @@ -66,6 +68,10 @@ #include <efi_loader.h> #include <relocate.h>
+#ifdef CONFIG_ARM_FFA_TRANSPORT +#include <arm_ffa.h> +#endif
ulong monitor_flash_len; @@ -770,6 +776,9 @@ static init_fnc_t init_sequence_r[] = { INIT_FUNC_WATCHDOG_RESET initr_net, #endif +#ifdef CONFIG_ARM_FFA_TRANSPORT
- ffa_bus_discover,
+#endif #ifdef CONFIG_POST initr_post, #endif diff --git a/doc/README.ffa.drv b/doc/README.ffa.drv new file mode 100644 index 0000000000..1c0a33deb8 --- /dev/null +++ b/doc/README.ffa.drv @@ -0,0 +1,160 @@ +Arm FF-A Driver +====================
+Introduction +--------------------
+FF-A stands for Firmware Framework for Arm A-profile processors.
+FF-A specifies interfaces that enable a pair of software sandboxes to communicate with each other. A sandbox aka partition could +be a VM in the Normal or Secure world, an application in S-EL0, or a Trusted OS in S-EL1.
These lines are a bit long, from the coding guide lines: The preferred limit on the length of a single line is 80 columns.
+This FF-A driver implements the interfaces to communicate with partitions in the Secure world aka Secure partitions (SPs).
+The driver specifically focuses on communicating with SPs that isolate portions of EFI runtime services that must run in a +protected environment which is inaccessible by the Host OS or Hypervisor. Examples of such services are set/get variables.
+FF-A driver uses the SMC ABIs defined by the FF-A specification to:
+- Discover the presence of SPs of interest. +- Access an SP's service through communication protocols e.g. EFI MM communication protocol.
+FF-A and SMC specifications +-------------------------------------------
+The current implementation of the driver relies on FF-A specification v1.0 and uses SMC32 calling convention.
+The driver has been tested with Optee OS which supports SMC32 for most of the SMC ABIs.
+For more details please refer to: https://developer.arm.com/documentation/den0077/a/?lang=en
+The FF-A driver uses 64-bit registers as per SMCCCv1.2 specification.
+For more details please refer to: https://documentation-service.arm.com/static/5f8edaeff86e16515cdbe4c6?token=
+Supported hardware +--------------------------------
+Aarch64 plaforms
+Configuration +----------------------
+CONFIG_ARM_FFA_TRANSPORT
- Enables the FF-A bus driver. Turn this on if you want to use FF-A communication.
+CONFIG_ARM_FFA_EFI_RUNTIME_MODE
- Optional config that enables EFI runtime support for FF-A data and code.
- ffa_copy_runtime_data allows to copy the FF-A driver data structures to EFI runtime data section.
- Turning the config on makes ffa_copy_runtime_data available for use and the driver code placed at EFI runtime code section.
- Call ffa_copy_runtime_data at the event on which you want the FF-A data to be copied (example: at ExitBootServices).
+CONFIG_SANDBOX_FFA
- Enables FF-A Sandbox driver. This emulates the FF-A ABIs handling under Sandbox and provides
- functional tests for FF-A.
+FF-A ABIs under the hood +---------------------------------------
+Invoking an FF-A ABI involves providing to the secure world/hypervisor the expected arguments from the ABI.
+The ABI arguments are stored in x0 to x7 registers. Then, an SMC instruction is executed.
+At the secure side level or hypervisor the ABI is handled at a higher exception level and the arguments are read and processed.
+The response is put back through x0 to x7 registers and control is giving back to the u-boot FF-A driver (non secure world).
U-Boot, non-secure
+The driver reads the response and processes it accordingly.
+This methodology applies to all the FF-A ABIs in the driver.
+FF-A bus discovery in u-boot
U-Boot, you might as well search and replace.
+When CONFIG_ARM_FFA_TRANSPORT is enabled, the FF-A bus is automatically discovered at initcall level (after u-boot relocation).
+The function that triggers the discovery process is ffa_bus_discover.
+ffa_bus_discover creates, binds and probes the arm_ffa device using device_{bind, probe} APIs.
+When the device is probed, ffa_probe is called which tries to communicate with the secure world or hypervisor.
+The FF-A bus is usable when these checks succeed:
+- querying the FF-A framework version +- querying from secure world the u-boot endpoint ID +- querying from secure world the supported features of the specified FF-A calls +- mapping the RX/TX buffers +- querying from secure world all the partitions information
+Probing fails when any of these operations fail. The FF-A bus discovery succeeds when probing is successful.
+When discovery fails the arm_ffa device is destroyed.
+The bus driver layer +------------------------------
+The driver comes on top of the SMCCC layer and is implemented in drivers/firmware/arm-ffa/core.c
+The driver provides the following features:
+- Support for the 32-bit version of the following ABIs:
+FFA_VERSION +FFA_ID_GET +FFA_FEATURES +FFA_PARTITION_INFO_GET +FFA_RXTX_UNMAP +FFA_RX_RELEASE +FFA_RUN +FFA_ERROR +FFA_SUCCESS +FFA_INTERRUPT
+- Support for the 64-bit version of the following ABIs:
+FFA_RXTX_MAP +FFA_MSG_SEND_DIRECT_REQ +FFA_MSG_SEND_DIRECT_RESP
+- Processing the received data from the secure world/hypervisor and caching it
+- Hiding from upper layers the FF-A protocol and registers details. Upper layers focus on exchanged data, +the driver takes care of how to transport that to the secure world/hypervisor using FF-A.
+- The driver provides callbacks to be used by clients to access the FF-A bus:
+partition_info_get +sync_send_receive +rxtx_unmap
+- FF-A bus discovery at initcalls level (after u-boot relocation). The bus is up and running if the FF-A framework is responsive and compatible with the driver.
+- When EFI is enabled, unmap the RX/TX buffers at ExitBootServices() level.
+- When CONFIG_ARM_FFA_EFI_RUNTIME_MODE enabled, ffa_copy_runtime_data function is available for use.
+Using armffa command +-----------------------------------
+armffa is a command showcasing how to use the FF-A driver and how to invoke its operations.
+This provides a guidance to the client developers on how to call the FF-A bus interfaces.
+Usage:
+armffa <sub-command> <arguments>
+sub-commands:
getpart <partition UUID>
lists the partition(s) info
ping <partition ID>
sends a data pattern to the specified partition
devlist
displays the arm_ffa device info
diff --git a/drivers/Kconfig b/drivers/Kconfig index 8b6fead351..b06b1ae481 100644 --- a/drivers/Kconfig +++ b/drivers/Kconfig @@ -6,6 +6,8 @@ source "drivers/core/Kconfig"
source "drivers/adc/Kconfig"
+source "drivers/firmware/arm-ffa/Kconfig"
source "drivers/ata/Kconfig"
source "drivers/axi/Kconfig" diff --git a/drivers/Makefile b/drivers/Makefile index eba9940231..c3bfad94ac 100644 --- a/drivers/Makefile +++ b/drivers/Makefile @@ -110,6 +110,7 @@ obj-y += iommu/ obj-y += smem/ obj-y += thermal/ obj-$(CONFIG_TEE) += tee/ +obj-$(CONFIG_ARM_FFA_TRANSPORT) += firmware/arm-ffa/ obj-y += axi/ obj-y += ufs/ obj-$(CONFIG_W1) += w1/ diff --git a/drivers/firmware/arm-ffa/Kconfig b/drivers/firmware/arm-ffa/Kconfig new file mode 100644 index 0000000000..aceb61cf49 --- /dev/null +++ b/drivers/firmware/arm-ffa/Kconfig @@ -0,0 +1,39 @@ +# SPDX-License-Identifier: GPL-2.0
+config ARM_FFA_TRANSPORT
- bool "Enable Arm Firmware Framework for Armv8-A driver"
- depends on DM && ARM64
- select ARM_SMCCC
- select LIB_UUID
- select DEVRES
- help
The Firmware Framework for Arm A-profile processors (FF-A)
technology.
This driver is based on FF-A specification v1.0 and uses SMC32
calling convention.
FF-A specification:
using the FF-A bus.
and Secure World.
For more details about the FF-A driver, please refer to doc/README.ffa.drv
+config ARM_FFA_EFI_RUNTIME_MODE
- bool "Enable EFI runtime support for FF-A data and code"
- depends on ARM_FFA_TRANSPORT && EFI_LOADER
- help
Allows FF-A driver data structures and code to be accessible at EFI runtime.
FF-A data is copied by ffa_copy_runtime_data function.
The driver Code needed at runtime is placed at EFI runtime code section.
Turning this on makes ffa_copy_runtime_data available for use and the driver
diff --git a/drivers/firmware/arm-ffa/Makefile b/drivers/firmware/arm-ffa/Makefile new file mode 100644 index 0000000000..0b9b0a61b4 --- /dev/null +++ b/drivers/firmware/arm-ffa/Makefile @@ -0,0 +1,7 @@ +# SPDX-License-Identifier: GPL-2.0+ +# +# (C) Copyright 2022 Abdellatif El Khlifi abdellatif.elkhlifi@arm.com +#
+obj-y += arm-ffa-uclass.o core.o +obj-$(CONFIG_ARM_FFA_EFI_RUNTIME_MODE) += efi_ffa_runtime_data_mgr.o diff --git a/drivers/firmware/arm-ffa/arm-ffa-uclass.c b/drivers/firmware/arm-ffa/arm-ffa-uclass.c new file mode 100644 index 0000000000..7d9695d289 --- /dev/null +++ b/drivers/firmware/arm-ffa/arm-ffa-uclass.c @@ -0,0 +1,16 @@ +// SPDX-License-Identifier: GPL-2.0+ +/*
- Abdellatif El Khlifi abdellatif.elkhlifi@arm.com
+#include <common.h> +#include <dm.h> +#include <asm/global_data.h>
+UCLASS_DRIVER(ffa) = {
- .name = "ffa",
- .id = UCLASS_FFA,
+}; diff --git a/drivers/firmware/arm-ffa/arm_ffa_prv.h b/drivers/firmware/arm-ffa/arm_ffa_prv.h new file mode 100644 index 0000000000..7bc90f7f66 --- /dev/null +++ b/drivers/firmware/arm-ffa/arm_ffa_prv.h @@ -0,0 +1,196 @@ +/* SPDX-License-Identifier: GPL-2.0+ */ +/*
+#ifndef __ARM_FFA_PRV_H +#define __ARM_FFA_PRV_H
+#include <arm_ffa.h> +#include <linux/bitfield.h> +#include <linux/bitops.h> +#include <linux/arm-smccc.h>
- This header is private. It is exclusively used by the FF-A driver
+/* FF-A core driver name */ +#define FFA_DRV_NAME "arm_ffa"
+/* FF-A driver version definitions */
+#define MAJOR_VERSION_MASK GENMASK(30, 16) +#define MINOR_VERSION_MASK GENMASK(15, 0) +#define GET_FFA_MAJOR_VERSION(x) \
((u16)(FIELD_GET(MAJOR_VERSION_MASK, (x))))
+#define GET_FFA_MINOR_VERSION(x) \
((u16)(FIELD_GET(MINOR_VERSION_MASK, (x))))
+#define PACK_VERSION_INFO(major, minor) \
- (FIELD_PREP(MAJOR_VERSION_MASK, (major)) | \
FIELD_PREP(MINOR_VERSION_MASK, (minor)))
+#define FFA_MAJOR_VERSION (1) +#define FFA_MINOR_VERSION (0) +#define FFA_VERSION_1_0 \
PACK_VERSION_INFO(FFA_MAJOR_VERSION, FFA_MINOR_VERSION)
+/* Endpoint ID mask (u-boot endpoint ID) */
+#define GET_SELF_ENDPOINT_ID_MASK GENMASK(15, 0) +#define GET_SELF_ENDPOINT_ID(x) \
((u16)(FIELD_GET(GET_SELF_ENDPOINT_ID_MASK, (x))))
+#define PREP_SELF_ENDPOINT_ID_MASK GENMASK(31, 16) +#define PREP_SELF_ENDPOINT_ID(x) \
(FIELD_PREP(PREP_SELF_ENDPOINT_ID_MASK, (x)))
+/* Partition endpoint ID mask (partition with which u-boot communicates with) */
+#define PREP_PART_ENDPOINT_ID_MASK GENMASK(15, 0) +#define PREP_PART_ENDPOINT_ID(x) \
(FIELD_PREP(PREP_PART_ENDPOINT_ID_MASK, (x)))
- Definitions of the Arm FF-A interfaces supported by the Arm FF-A driver
+#define FFA_SMC(calling_convention, func_num) \
- ARM_SMCCC_CALL_VAL(ARM_SMCCC_FAST_CALL, (calling_convention), \
ARM_SMCCC_OWNER_STANDARD, (func_num))
+#define FFA_SMC_32(func_num) FFA_SMC(ARM_SMCCC_SMC_32, (func_num)) +#define FFA_SMC_64(func_num) FFA_SMC(ARM_SMCCC_SMC_64, (func_num))
+enum ffa_abis {
- FFA_ERROR = 0x60,
- FFA_SUCCESS = 0x61,
- FFA_INTERRUPT = 0x62,
- FFA_VERSION = 0x63,
- FFA_FEATURES = 0x64,
- FFA_RX_RELEASE = 0x65,
- FFA_RXTX_MAP = 0x66,
- FFA_RXTX_UNMAP = 0x67,
- FFA_PARTITION_INFO_GET = 0x68,
- FFA_ID_GET = 0x69,
- FFA_RUN = 0x6D,
- FFA_MSG_SEND_DIRECT_REQ = 0x6F,
- FFA_MSG_SEND_DIRECT_RESP = 0x70,
- /* to be updated when adding new FFA IDs */
- FFA_FIRST_ID = FFA_ERROR, /* lowest number ID*/
- FFA_LAST_ID = FFA_MSG_SEND_DIRECT_RESP, /* highest number ID*/
+/* number of the errors supported by the FF-A specification */ +#define MAX_NUMBER_FFA_ERR 9
+/* container structure and helper macros to map between an FF-A error and relevant error log */ +struct ffa_abi_errmap {
- char *err_str[MAX_NUMBER_FFA_ERR];
+#define FFA_ERRMAP_COUNT (FFA_LAST_ID - FFA_FIRST_ID + 1) +#define FFA_ID_TO_ERRMAP_ID(ffa_id) ((ffa_id) - FFA_FIRST_ID)
+/* The FF-A SMC function definitions */
+typedef struct arm_smccc_1_2_regs ffa_value_t; +typedef void (*invoke_ffa_fn_t)(ffa_value_t args, ffa_value_t *res);
- struct ffa_partition_uuid - 16 bytes UUID transmitted by FFA_PARTITION_INFO_GET
- @a1-4: 32-bit words access to the UUID data
+struct ffa_partition_uuid {
- u32 a1; /* w1 */
- u32 a2; /* w2 */
- u32 a3; /* w3 */
- u32 a4; /* w4 */
- enum ffa_rxtx_buf_sizes - minimum sizes supported
- for the RX/TX buffers
+enum ffa_rxtx_buf_sizes {
- RXTX_4K,
- RXTX_64K,
- RXTX_16K
- struct ffa_rxtxpair - structure hosting the RX/TX buffers virtual addresses
- @rxbuf: virtual address of the RX buffer
- @txbuf: virtual address of the TX buffer
- @rxtx_min_pages: RX/TX buffers minimum size in pages
- Data structure hosting the virtual addresses of the mapped RX/TX buffers
- These addresses are used by the FF-A functions that use the RX/TX buffers
+struct ffa_rxtxpair {
- u64 rxbuf; /* virtual address */
- u64 txbuf; /* virtual address */
- size_t rxtx_min_pages; /* minimum number of pages in each of the RX/TX buffers */
- struct ffa_partition_desc - the secure partition descriptor
- @info: partition information
- @sp_uuid: the secure partition UUID
- Each partition has its descriptor containing the partitions information and the UUID
+struct ffa_partition_desc {
- struct ffa_partition_info info;
- struct ffa_partition_uuid sp_uuid;
- struct ffa_partitions - descriptors for all secure partitions
- @count: The number of partitions descriptors
- @descs The partitions descriptors table
- This data structure contains the partitions descriptors table
+struct ffa_partitions {
- u32 count;
- struct ffa_partition_desc *descs; /* virtual address */
- struct ffa_prvdata - the driver private data structure
- @dev: The arm_ffa device under u-boot driver model
- @ffa_ops: The driver operations structure
- @fwk_version: FF-A framework version
- @id: u-boot endpoint ID
- @partitions: The partitions descriptors structure
- @pair: The RX/TX buffers pair
- @invoke_ffa_fn: The function executing the FF-A function
- The driver data structure hosting all resident data.
+struct ffa_prvdata {
- struct udevice *dev;
- struct ffa_bus_ops ffa_ops;
- u32 fwk_version;
- u16 id;
- struct ffa_partitions partitions;
- struct ffa_rxtxpair pair;
- invoke_ffa_fn_t invoke_ffa_fn;
- ffa_device_get - create, bind and probe the arm_ffa device
+int ffa_device_get(void);
- ffa_bus_prvdata_get - bus driver private data getter
+struct ffa_prvdata **ffa_bus_prvdata_get(void);
+#endif diff --git a/drivers/firmware/arm-ffa/core.c b/drivers/firmware/arm-ffa/core.c new file mode 100644 index 0000000000..41c7b96e68 --- /dev/null +++ b/drivers/firmware/arm-ffa/core.c @@ -0,0 +1,1344 @@ +// SPDX-License-Identifier: GPL-2.0+ +/*
+#include "arm_ffa_prv.h" +#include <asm/global_data.h> +#include <common.h> +#include <dm.h> +#include <dm/device-internal.h> +#include <dm/devres.h> +#include <dm/root.h> +#include <linux/errno.h> +#include <linux/sizes.h> +#include <log.h> +#include <malloc.h> +#include <string.h> +#include <uuid.h>
+DECLARE_GLOBAL_DATA_PTR;
- The device private data structure containing all the resident
- data read from secure world
+__ffa_runtime_data struct ffa_prvdata *ffa_priv_data;
+/* Error mapping declarations */
+__ffa_runtime_data int ffa_to_std_errmap[MAX_NUMBER_FFA_ERR] = {
- 0,
- -EOPNOTSUPP, /* NOT_SUPPORTED */
- -EINVAL, /* INVALID_PARAMETERS */
- -ENOMEM, /* NO_MEMORY */
- -EBUSY, /* BUSY */
- -EINTR, /* INTERRUPTED */
- -EACCES, /* DENIED */
- -EAGAIN, /* RETRY */
- -ECANCELED, /* ABORTED */
+struct ffa_abi_errmap err_msg_map[FFA_ERRMAP_COUNT] = {
- [FFA_ID_TO_ERRMAP_ID(FFA_VERSION)] = {
"NOT_SUPPORTED: A Firmware Framework implementation does not exist",
"", /* NO_MEMORY */
"", /* BUSY */
"", /* DENIED */
"", /* RETRY */
"", /* ABORTED */
- [FFA_ID_TO_ERRMAP_ID(FFA_ID_GET)] = {
"", /* NO_MEMORY */
"", /* BUSY */
"", /* DENIED */
"", /* RETRY */
"", /* ABORTED */
- [FFA_ID_TO_ERRMAP_ID(FFA_FEATURES)] = {
"NOT_SUPPORTED: FFA_RXTX_MAP is not implemented at this FF-A instance",
"", /* NO_MEMORY */
"", /* BUSY */
"", /* DENIED */
"", /* RETRY */
"", /* ABORTED */
- [FFA_ID_TO_ERRMAP_ID(FFA_PARTITION_INFO_GET)] = {
"INVALID_PARAMETERS: Unrecognized UUID",
"NO_MEMORY: Results cannot fit in RX buffer of the caller",
"BUSY: RX buffer of the caller is not free",
"DENIED: Callee is not in a state to handle this request",
"", /* RETRY */
"", /* ABORTED */
- [FFA_ID_TO_ERRMAP_ID(FFA_RXTX_UNMAP)] = {
"NOT_SUPPORTED: FFA_RXTX_UNMAP is not implemented at this FF-A instance",
"INVALID_PARAMETERS: No buffer pair registered on behalf of the caller",
"", /* NO_MEMORY */
"", /* BUSY */
"", /* INTERRUPTED */
"", /* DENIED */
"", /* RETRY */
"", /* ABORTED */
- [FFA_ID_TO_ERRMAP_ID(FFA_RX_RELEASE)] = {
"NOT_SUPPORTED: FFA_RX_RELEASE is not implemented at this FF-A instance",
"", /* INVALID_PARAMETERS */
"", /* NO_MEMORY */
"", /* BUSY */
"DENIED: Caller did not have ownership of the RX buffer",
"", /* RETRY */
"", /* ABORTED */
- [FFA_ID_TO_ERRMAP_ID(FFA_RXTX_MAP)] = {
"NOT_SUPPORTED: This function is not implemented at this FF-A instance",
"INVALID_PARAMETERS: Field(s) in input parameters incorrectly encoded",
"NO_MEMORY: Not enough memory",
"", /* BUSY */
"DENIED: Buffer pair already registered",
"", /* RETRY */
"", /* ABORTED */
- ffa_to_std_errno - convert FF-A error code to standard error code
- @ffa_errno: Error code returned by the FF-A ABI
- This runtime function maps the given FF-A error code as specified
- by the spec to a u-boot standard error code.
- Return:
- The standard error code on success. . Otherwise, failure
+__ffa_runtime int ffa_to_std_errno(int ffa_errno) +{
- int err_idx = -ffa_errno;
- /* map the FF-A error code to the standard u-boot error code */
- if (err_idx > 0 && err_idx < MAX_NUMBER_FFA_ERR)
return ffa_to_std_errmap[err_idx];
- return -EINVAL;
- ffa_print_error_log - print the error log corresponding to the selected FF-A ABI
- @ffa_id: FF-A ABI ID
- This boot time function maps the FF-A error code to the error log relevant to the
- selected FF-A ABI. Then the error log is printed.
- Return:
- 0 on success. . Otherwise, failure
+int ffa_print_error_log(u32 ffa_id, int ffa_errno) +{
- int err_idx = -ffa_errno, abi_idx = 0;
- /* map the FF-A error code to the corresponding error log */
- if (err_idx <= 0 || err_idx >= MAX_NUMBER_FFA_ERR)
return -EINVAL;
- if (ffa_id < FFA_FIRST_ID || ffa_id > FFA_LAST_ID)
return -EINVAL;
- abi_idx = FFA_ID_TO_ERRMAP_ID(ffa_id);
- if (abi_idx < 0 || abi_idx >= FFA_ERRMAP_COUNT)
return -EINVAL;
- if (!err_msg_map[abi_idx].err_str || !err_msg_map[abi_idx].err_str[err_idx])
return -EINVAL;
- ffa_err("%s", err_msg_map[abi_idx].err_str[err_idx]);
- Driver core functions
- ffa_remove_device - removes the arm_ffa device
- @dev: the device to be removed
- This boot time function makes sure the arm_ffa device is removed
- No need to free the kmalloced data when the device is destroyed.
- It's automatically done by devm management by
- device_remove() -> device_free() -> devres_release_probe().
- Return:
- 0 on success. Otherwise, failure
+int ffa_remove_device(struct udevice *dev) +{
- int ret;
- if (!dev) {
return -ENODEV;
- ret = device_remove(dev, DM_REMOVE_NORMAL);
- if (ret) {
ffa_err("unable to remove. err:%d\n", ret);
return ret;
- ffa_info("device removed and freed");
- ret = device_unbind(dev);
- if (ret) {
ffa_err("unable to unbind. err:%d\n", ret);
return ret;
- ffa_info("device unbound");
- created, bound to this driver, probed and ready to use.
- Arm FF-A transport is implemented through a single u-boot
- device managing the FF-A bus (arm_ffa).
- Return:
+int ffa_device_get(void) +{
- int ret;
- struct udevice *dev = NULL;
- ret = device_bind(dm_root(),
DM_DRIVER_GET(arm_ffa),
FFA_DRV_NAME,
NULL,
ofnode_null(),
&dev);
- if (ret)
return ret;
- /* The FF-A bus discovery succeeds when probing is successful */
- ret = device_probe(dev);
- if (ret) {
ffa_err("arm_ffa device probing failed");
ffa_remove_device(dev);
return ret;
- ffa_get_version - FFA_VERSION handler function
- This is the boot time function that implements FFA_VERSION FF-A function
- to get from the secure world the FF-A framework version
- Return:
+static int ffa_get_version(void) +{
- u16 major, minor;
- ffa_value_t res = {0};
- int ffa_errno;
- ffa_priv_data->invoke_ffa_fn((ffa_value_t){
.a0 = FFA_SMC_32(FFA_VERSION),
.a1 = FFA_VERSION_1_0, .a2 = 0, .a3 = 0, .a4 = 0, .a5 = 0, .a6 = 0, .a7 = 0,
Why not support the latest version, 1.1?
The zero initializations are done implicitly so you could just as well remove them.
}, &res);
- ffa_errno = (int)res.a0;
Is this cast needed, or any of the other casts below in this function?
- if (ffa_errno < 0) {
ffa_print_error_log(FFA_VERSION, ffa_errno);
- major = GET_FFA_MAJOR_VERSION((u32)res.a0);
- minor = GET_FFA_MINOR_VERSION((u32)res.a0);
- ffa_info("FF-A driver %d.%d\nFF-A framework %d.%d",
- if ((major == FFA_MAJOR_VERSION && minor >= FFA_MINOR_VERSION)) {
ffa_info("Versions are compatible ");
ffa_priv_data->fwk_version = (u32)res.a0;
- ffa_err("versions are incompatible\nExpected: %d.%d , Found: %d.%d\n",
FFA_MAJOR_VERSION, FFA_MINOR_VERSION, major, minor);
- return -EPROTONOSUPPORT;
- ffa_get_endpoint_id - FFA_ID_GET handler function
- This is the boot time function that implements FFA_ID_GET FF-A function
- to get from the secure world u-boot endpoint ID
- Return:
+static int ffa_get_endpoint_id(void) +{
- int ffa_errno;
}, &res);
- if (res.a0 == FFA_SMC_32(FFA_SUCCESS)) {
- ffa_errno = (int)res.a2;
- ffa_print_error_log(FFA_ID_GET, ffa_errno);
- return ffa_to_std_errno(ffa_errno);
- ffa_set_rxtx_buffers_pages_cnt - sets the minimum number of pages in each of the RX/TX buffers
- @prop_field: properties field obtained from FFA_FEATURES ABI
- This boot time function sets the minimum number of pages
- in each of the RX/TX buffers in the private data structure
- Return:
- buf_4k_pages points to the returned number of pages
- if (!ffa_priv_data)
return -EINVAL;
- switch (prop_field) {
- case RXTX_4K:
break;
- case RXTX_16K:
break;
- case RXTX_64K:
break;
- default:
return -EINVAL;
- ffa_get_rxtx_map_features - FFA_FEATURES handler function with FFA_RXTX_MAP argument
- This is the boot time function that implements FFA_FEATURES FF-A function
- to retrieve the FFA_RXTX_MAP features
- Return:
- int ffa_errno;
}, &res);
- ffa_print_error_log(FFA_FEATURES, ffa_errno);
- ffa_free_rxtx_buffers - frees the RX/TX buffers
- This is the boot time function used to free the RX/TX buffers
- ffa_info("Freeing RX/TX buffers");
- if (ffa_priv_data->pair.rxbuf) {
- if (ffa_priv_data->pair.txbuf) {
- ffa_alloc_rxtx_buffers - allocates the RX/TX buffers
- This is the boot time function used by ffa_map_rxtx_buffers to allocate
- the RX/TX buffers before mapping them. The allocated memory is physically
- contiguous since memalign ends up calling malloc which allocates
- contiguous memory in u-boot.
- Return:
- u64 bytes;
- ffa_info("Using %lu 4KB page(s) for RX/TX buffers size",
- bytes = ffa_priv_data->pair.rxtx_min_pages * SZ_4K;
- /* RX/TX buffers addresses should be PAGE_SIZE aligned */
- ffa_priv_data->pair.rxbuf = (u64)memalign(PAGE_SIZE, bytes);
Shouldn't this be "bytes" aligned too? Same below with the TX buffer.
- if (!ffa_priv_data->pair.rxbuf) {
return -ENOBUFS;
- ffa_info("RX buffer at virtual address 0x%llx", ffa_priv_data->pair.rxbuf);
- ffa_priv_data->pair.txbuf = (u64)memalign(PAGE_SIZE, bytes);
- if (!ffa_priv_data->pair.txbuf) {
return -ENOBUFS;
- ffa_info("TX buffer at virtual address 0x%llx", ffa_priv_data->pair.txbuf);
- memset((void *)ffa_priv_data->pair.rxbuf, 0, bytes);
- memset((void *)ffa_priv_data->pair.txbuf, 0, bytes);
- ffa_map_rxtx_buffers - FFA_RXTX_MAP handler function
- This is the boot time function that implements FFA_RXTX_MAP FF-A function
- to map the RX/TX buffers
- Return:
- int ret;
- int ffa_errno;
- ret = ffa_alloc_rxtx_buffers();
- if (ret)
return ret;
}, &res);
- ffa_print_error_log(FFA_RXTX_MAP, ffa_errno);
- ffa_free_rxtx_buffers();
- ffa_unmap_rxtx_buffers - FFA_RXTX_UNMAP handler function
- This is the boot time function that implements FFA_RXTX_UNMAP FF-A function
- to unmap the RX/TX buffers
- Return:
- int ffa_errno;
}, &res);
- ffa_print_error_log(FFA_RXTX_UNMAP, ffa_errno);
- ffa_release_rx_buffer - FFA_RX_RELEASE handler function
- This is the boot time function that invokes FFA_RX_RELEASE FF-A function
- to release the ownership of the RX buffer
- Return:
- int ffa_errno;
}, &res);
- ffa_print_error_log(FFA_RX_RELEASE, ffa_errno);
- ffa_uuid_are_identical - checks whether two given UUIDs are identical
- @uuid1: first UUID
- @uuid2: second UUID
- This is a boot time function used by ffa_read_partitions_info to search
- for a UUID in the partitions descriptors table
- Return:
- 1 when UUIDs match. Otherwise, 0
- if (!uuid1 || !uuid2)
- return (!memcmp(uuid1, uuid2, sizeof(struct ffa_partition_uuid)));
Please drop the outer ().
- ffa_read_partitions_info - reads the data queried by FFA_PARTITION_INFO_GET
- @count: The number of partitions queried
- @part_uuid: Pointer to the partition(s) UUID
- This is the boot time function that reads the partitions information
- returned by the FFA_PARTITION_INFO_GET and saves it in the private
- data structure.
- Return:
- The private data structure is updated with the partition(s) information
- 0 is returned on success. Otherwise, failure
- if (!count) {
return -ENODATA;
- ffa_info("Reading partitions data from the RX buffer");
- if (!part_uuid) {
u64 buf_bytes;
u64 data_bytes;
u32 desc_idx;
data_bytes,
buf_bytes);
return -ENOMEM;
There's no need to cast the void pointer.
return -ENOMEM;
- } else {
u8 desc_found;
desc_found = 0;
* save the UUID
*part_uuid;
desc_found = 1;
break;
if (!desc_found)
return -ENODATA;
- ffa_query_partitions_info - invokes FFA_PARTITION_INFO_GET and saves partitions data
- @pcount: Pointer to the number of partitions variable filled when querying
- This is the boot time function that executes the FFA_PARTITION_INFO_GET
- to query the partitions data. Then, it calls ffa_read_partitions_info
- to save the data in the private data structure.
- After reading the data the RX buffer is released using ffa_release_rx_buffer
- Return:
- When part_uuid is NULL, all partitions data are retrieved from secure world
- When part_uuid is non NULL, data for partitions matching the given UUID are
- retrieved and the number of partitions is returned
u32 *pcount)
- struct ffa_partition_uuid query_uuid = {0};
- int ffa_errno;
- if (part_uuid) {
if (!pcount)
return -EINVAL;
- } else if (pcount) {
return -EINVAL;
.a5 = 0,
.a6 = 0,
.a7 = 0,
}, &res);
int ret;
if (res.a2) {
if (ret) {
return -EINVAL;
if (pcount)
return ret;
- ffa_print_error_log(FFA_PARTITION_INFO_GET, ffa_errno);
- ffa_get_partitions_info - FFA_PARTITION_INFO_GET handler function
- The passed arguments:
- Mode 1: When getting from the driver the number of
- secure partitions:
- @uuid_str: pointer to the UUID string
- @parts_size: pointer to the variable that contains the number of partitions
- @buffer: NULL
- Mode 2: When requesting the driver to return the
- partitions information:
- @parts_size: pointer to the size of the SPs information buffer in bytes
- @buffer: pointer to SPs information buffer
- This is the boot time function that queries the secure partition data from
- the private data structure. If not found, it invokes FFA_PARTITION_INFO_GET
- FF-A function to query the partition information from secure world.
- A client of the FF-A driver should know the UUID of the service it wants to
- access. It should use the UUID to request the FF-A driver to provide the
- partition(s) information of the service. The FF-A driver uses
- PARTITION_INFO_GET to obtain this information. This is implemented through
- ffa_get_partitions_info function.
- A new FFA_PARTITION_INFO_GET call is issued (first one performed through
- ffa_cache_partitions_info) allowing to retrieve the partition(s) information.
- They are not saved (already done). We only update the UUID in the cached area.
- This assumes that partitions data does not change in the secure world.
- Otherwise u-boot will have an outdated partition data. The benefit of caching
- the information in the FF-A driver is to accommodate discovery after
- ExitBootServices().
- When invoked through a client request, ffa_get_partitions_info should be
- called twice. First call is to get from the driver the number of secure
- partitions (SPs) associated to a particular UUID.
- Then, the caller (client) allocates the buffer to host the SPs data and
- issues a 2nd call. Then, the driver fills the SPs data in the pre-allocated
- buffer.
- To achieve the mechanism described above, ffa_get_partitions_info uses the
- following functions:
- Return:
- @parts_size: When pointing to the number of partitions variable, the number is
- set by the driver.
- When pointing to the partitions information buffer size, the buffer will be
- filled by the driver.
- On success 0 is returned. Otherwise, failure
* fill_data:
- int fill_data = -1;
- u32 desc_idx, client_desc_idx;
- struct ffa_partition_uuid part_uuid = {0};
- u32 client_desc_max_cnt;
- u32 parts_found = 0;
- if (!ffa_priv_data->partitions.count || !ffa_priv_data->partitions.descs) {
return -EINVAL;
- if (!uuid_str) {
return -EINVAL;
- if (!parts_size) {
return -EINVAL;
- if (be_uuid_str_to_le_bin(uuid_str, (unsigned char *)&part_uuid)) {
return -EINVAL;
- if (!buffer) {
fill_data = 0;
- } else if ((*parts_size >= sizeof(struct ffa_partition_info)) &&
fill_data = 1;
- } else {
return -EINVAL;
- ffa_info("Searching partitions using the provided UUID");
- for (desc_idx = 0;
desc_idx++) {
&part_uuid)) {
parts_found++;
if (fill_data) {
continue;
return -ENOBUFS;
- if (!parts_found) {
int ret;
if (ret == 0) {
if (!fill_data) {
parts_found);
} else {
* to the caller
if (parts_found)
else
ret = -ENODATA;
return ret;
- /* partition(s) found */
- if (!fill_data)
- ffa_cache_partitions_info - Queries and saves all secure partitions data
- This is a boot time function that invokes FFA_PARTITION_INFO_GET FF-A
- function to query from secure world all partitions information.
- The FFA_PARTITION_INFO_GET call is issued with nil UUID as an argument.
- All installed partitions information are returned. We cache them in the
- resident private data structure and we keep the UUID field empty
- (in FF-A 1.0 UUID is not provided by the partition descriptor)
- This function is called at the device probing level.
- ffa_cache_partitions_info uses ffa_query_partitions_info to get the data
- Return:
- return ffa_query_partitions_info(NULL, NULL);
- ffa_msg_send_direct_req - FFA_MSG_SEND_DIRECT_{REQ,RESP} handler function
- @dst_part_id: destination partition ID
- @msg: pointer to the message data preallocated by the client (in/out)
- This is the runtime function that implements FFA_MSG_SEND_DIRECT_{REQ,RESP}
- FF-A functions.
- FFA_MSG_SEND_DIRECT_REQ is used to send the data to the secure partition.
- The response from the secure partition is handled by reading the
- FFA_MSG_SEND_DIRECT_RESP arguments.
- The maximum size of the data that can be exchanged is 40 bytes which is
- sizeof(struct ffa_send_direct_data) as defined by the FF-A specification 1.0
- in the section relevant to FFA_MSG_SEND_DIRECT_{REQ,RESP}
- Return:
- int ffa_errno;
- if (!ffa_priv_data || !ffa_priv_data->invoke_ffa_fn)
return -EINVAL;
- /* No partition installed */
return -ENODEV;
.a2 = 0,
.a3 = msg->data0,
.a4 = msg->data1,
.a5 = msg->data2,
.a6 = msg->data3,
.a7 = msg->data4,
}, &res);
- while (res.a0 == FFA_SMC_32(FFA_INTERRUPT))
}, &res);
How can the caller tell this response apart from a FFA_MSG_SEND_DIRECT_RESP?
- if (res.a0 == FFA_SMC_64(FFA_MSG_SEND_DIRECT_RESP)) {
- __arm_ffa_fn_smc - SMC wrapper
- @args: FF-A ABI arguments to be copied to Xn registers
- @res: FF-A ABI return data to be copied from Xn registers
- Calls low level SMC assembly function
- Return: void
- arm_smccc_1_2_smc(&args, res);
- ffa_set_smc_conduit - Set the SMC conduit
- This boot time function selects the SMC conduit by setting the driver invoke function
- to SMC assembly function
- Return:
- ffa_priv_data->invoke_ffa_fn = __arm_ffa_fn_smc;
- if (!ffa_priv_data->invoke_ffa_fn) {
return -EINVAL;
- ffa_info("Conduit is SMC");
- ffa_set_bus_ops - Set the bus driver operations
- Setting the driver callbacks.
- ffa_priv_data->ffa_ops.partition_info_get = ffa_get_partitions_info;
- ffa_priv_data->ffa_ops.sync_send_receive = ffa_msg_send_direct_req;
- ffa_priv_data->ffa_ops.rxtx_unmap = ffa_unmap_rxtx_buffers;
- ffa_alloc_prvdata - allocate the driver main data structure and sets the device
- @dev: the arm_ffa device
- This boot time function creates the main data structure embedding all the driver data.
- Return:
- if (!dev) {
return -ENODEV;
- /* The device is registered with the DM. Let's create the driver main data structure*/
- ffa_priv_data = devm_kmalloc(dev, sizeof(struct ffa_prvdata), __GFP_ZERO);
- if (!ffa_priv_data) {
return -ENOMEM;
- ffa_priv_data->dev = dev;
- ffa_probe - The driver probe function
- Probing is done at boot time and triggered by the uclass device discovery.
- At probe level the following actions are done:
- All data queried from secure world is saved in the resident private data structure.
- The probe will fail if either FF-A framework is not detected or the
- FF-A requests are not behaving correctly. This ensures that the
- driver is not installed and its operations are not exported to the clients.
- Return:
- int ret;
- ret = ffa_alloc_prvdata(dev);
- if (ret != 0)
return ret;
- ffa_set_bus_ops();
- ret = ffa_set_smc_conduit();
What if there's a hypervisor involved and HVC would be expected intead?
- if (ret != 0)
return ret;
- ret = ffa_get_version();
- if (ret != 0)
return ret;
- ret = ffa_get_endpoint_id();
- if (ret != 0)
return ret;
- ret = ffa_get_rxtx_map_features();
- if (ret != 0)
return ret;
- ret = ffa_map_rxtx_buffers();
- if (ret != 0)
return ret;
- ret = ffa_cache_partitions_info();
Why are we saving all the found partitions in a cache? It seems that FFA_PARTITION_INFO_GET could be called each time when needed instead without any noticeable overhead. Or is the result cached for some other reason?
- if (ret != 0) {
return ret;
- ffa_remove - The driver remove function
- When the device is about to be removed , unmap the RX/TX buffers and free the memory
- Return:
- 0 on success.
- ffa_info("removing the device");
- ffa_unmap_rxtx_buffers();
- if (ffa_priv_data->pair.rxbuf || ffa_priv_data->pair.txbuf)
- ffa_unbind - The driver unbind function
- After the device is removed and memory freed the device is unbound
- Return:
- 0 on success.
- ffa_info("unbinding the device , private data already released");
- ffa_priv_data = NULL;
- ffa_bus_ops_get - bus driver operations getter
- Return:
- This runtime function returns a pointer to the driver operations structure
- return &ffa_priv_data->ffa_ops;
- Return:
- This boot time function returns a pointer to the main private data structure
- return &ffa_priv_data;
- ffa_bus_discover - discover FF-A bus and probe the arm_ffa device
- This boot time function makes sure the FF-A bus is discoverable.
- Then, the arm_ffa device is probed and ready to use.
- This function is called automatically at initcalls
- level (after u-boot relocation).
- When the bus was already discovered successfully the discovery will not run again.
- Arm FF-A transport is implemented through arm_ffa u-boot device managing the FF-A
- communication.
- All FF-A clients should use the arm_ffa device to use the FF-A transport.
- Return:
- int ret = 0;
- return ret;
- Declaring the arm_ffa driver under UCLASS_FFA
- .name = FFA_DRV_NAME,
- .id = UCLASS_FFA,
- .probe = ffa_probe,
- .remove = ffa_remove,
- .unbind = ffa_unbind,
- ffa_copy_runtime_data - copy the private data structure to the runtime area
- This boot time function copies the arm_ffa driver data structures including
- partitions data to the EFI runtime data section.
- Return:
- efi_status_t efi_ret;
- efi_uintn_t prvdata_pages;
- efi_uintn_t descs_pages;
- struct ffa_prvdata **prvdata = NULL; /* Pointer to the current structure */
- struct ffa_prvdata *runtime_prvdata = NULL; /* Pointer to the structure runtime copy */
- u64 runtime_descs = 0;
- prvdata = ffa_bus_prvdata_get();
- printf("INFO: EFI: FFA: prv data area at 0x%llx\n", (u64)prvdata);
- /* allocate private data runtime area */
- prvdata_pages = efi_size_in_pages(sizeof(struct ffa_prvdata));
- efi_ret = efi_allocate_pages(EFI_ALLOCATE_ANY_PAGES,
prvdata_pages,
Better to use a temporary u64 instead of casting the pointer.
- if (efi_ret != EFI_SUCCESS) {
return efi_ret;
- printf("INFO: EFI: FFA: runtime data area at 0x%llx\n", (u64)runtime_prvdata);
- if (!runtime_prvdata)
- /* allocate the partition data runtime area */
- descs_pages = efi_size_in_pages((*prvdata)->partitions.count *
descs_pages,
&runtime_descs);
return efi_ret;
- printf("INFO: EFI: FFA: SPs runtime area at 0x%llx\n", (u64)runtime_descs);
- if (!runtime_descs)
- *runtime_prvdata = **prvdata;
With this you copy fwk_versien. This field will become out of data if the kernel driver negotiates a different framework version.
- runtime_prvdata->dev = NULL;
- runtime_prvdata->ffa_ops.partition_info_get = NULL;
- runtime_prvdata->ffa_ops.rxtx_unmap = NULL;
- runtime_prvdata->partitions.descs = (struct ffa_partition_desc *)runtime_descs;
- runtime_prvdata->pair.rxbuf = 0;
- runtime_prvdata->pair.txbuf = 0;
- *prvdata = runtime_prvdata;
- printf("INFO: EFI: FFA: runtime prv data now at 0x%llx , SPs count %d\n",
- This header is public. It can be used by clients to access
- data structures and definitions they need
- Macros for displaying logs
- struct ffa_partition_info - Partition information descriptor
- @id: Partition ID
- @exec_ctxt: Execution context count
- @properties: Partition properties
- Data structure containing information about partitions instantiated in the system
- This structure is filled with the data queried by FFA_PARTITION_INFO_GET
- u16 id;
- u16 exec_ctxt;
- u32 properties;
- struct ffa_send_direct_data - Data structure hosting the data
- @data0-4: Data read/written from/to x3-x7 registers
- Data structure containing the data to be sent by FFA_MSG_SEND_DIRECT_REQ
- or read from FFA_MSG_SEND_DIRECT_RESP
- unsigned long data0; /* w3/x3 */
- unsigned long data1; /* w4/x4 */
- unsigned long data2; /* w5/x5 */
- unsigned long data3; /* w6/x6 */
- unsigned long data4; /* w7/x7 */
- __ffa_runtime - controls whether functions are
- available after calling the EFI ExitBootServices service.
- Functions tagged with these keywords are resident (available at boot time and
- at runtime)
+#else
- The FF-A driver is independent from EFI
- struct ffa_bus_ops - The driver operations structure
- @partition_info_get: callback for the FFA_PARTITION_INFO_GET
- @sync_send_receive: callback for the FFA_MSG_SEND_DIRECT_REQ
- @rxtx_unmap: callback for the FFA_RXTX_UNMAP
- The data structure providing all the operations supported by the driver.
- This structure is EFI runtime resident.
- int (*partition_info_get)(const char *uuid_str,
- int (*sync_send_receive)(u16 dst_part_id, struct ffa_send_direct_data *msg);
- int (*rxtx_unmap)(void);
- The device driver and the Uclass driver public functions
- ffa_bus_ops_get - driver operations getter
- ffa_bus_discover - discover FF-A bus and probes the arm_ffa device
- ffa_copy_runtime_data - copy the private data structure and the SPs data to the runtime area
- (C) Copyright 2012
- Pavel Herrmann morpheus.ibis@gmail.com
- UCLASS_FFA, /* Arm Firmware Framework for Armv8-A */ UCLASS_FIRMWARE, /* Firmware */ UCLASS_FUZZING_ENGINE, /* Fuzzing engine */ UCLASS_FS_FIRMWARE_LOADER, /* Generic loader */
- EFI application boot time services
- Copyright (c) 2016 Alexander Graf
else
- /* Patch out unsupported runtime function */ efi_runtime_detach();
-- 2.17.1
[snip]
Line length isn't a huge problem, we follow what the linux kernel allows these days. But, this needs to be in proper sphinx format, under doc/arch perhaps (unless Heinrich has another idea) and 'make htmldocs' must pass (I see a lot of formatting errors that will get tripped up on and fail).
[snip]
In patchset v6, FF-A documentation is at doc/arch/arm64.ffa.rst and comes with Sphinx format. 'make htmldocs' passes.
-- Tom
- sync_send_receive
- rxtx_unmap
Changelog:
v4:
v3:
v2:
v1:
- ffa_bus_discover,
+Aarch64 plaforms
+CONFIG_SANDBOX_FFA
U-Boot, non-secure
+Usage:
+sub-commands:
ping <partition ID>
devlist
- select ARM_SMCCC
- select LIB_UUID
- select DEVRES
- help
technology.
calling convention.
FF-A specification:
using the FF-A bus.
and Secure World.
- help
- .name = "ffa",
- .id = UCLASS_FFA,
+enum ffa_abis {
- FFA_ERROR = 0x60,
- FFA_RUN = 0x6D,
- u32 a1; /* w1 */
- u32 a2; /* w2 */
- u32 a3; /* w3 */
- u32 a4; /* w4 */
- RXTX_4K,
- RXTX_64K,
- RXTX_16K
- u32 count;
- u32 fwk_version;
- u16 id;
- 0,
"", /* NO_MEMORY */
"", /* BUSY */
"", /* DENIED */
"", /* RETRY */
"", /* ABORTED */
"", /* NO_MEMORY */
"", /* BUSY */
"", /* DENIED */
"", /* RETRY */
"", /* ABORTED */
"", /* NO_MEMORY */
"", /* BUSY */
"", /* DENIED */
"", /* RETRY */
"", /* ABORTED */
"", /* RETRY */
"", /* ABORTED */
"", /* NO_MEMORY */
"", /* BUSY */
"", /* DENIED */
"", /* RETRY */
"", /* ABORTED */
"", /* NO_MEMORY */
"", /* BUSY */
"", /* RETRY */
"", /* ABORTED */
"", /* BUSY */
"", /* RETRY */
"", /* ABORTED */
- Return:
- return -EINVAL;
- Return:
return -EINVAL;
return -EINVAL;
return -EINVAL;
return -EINVAL;
- Return:
- int ret;
- if (!dev) {
return -ENODEV;
- if (ret) {
return ret;
- if (ret) {
return ret;
- Return:
- int ret;
FFA_DRV_NAME,
NULL,
ofnode_null(),
&dev);
- if (ret)
return ret;
- if (ret) {
return ret;
- Return:
- u16 major, minor;
- int ffa_errno;
We only need the v1.0 features.
Regarding all the code comments made in this patch, they have been addressed in patchset v6. Thanks.
}, &res);
- Return:
- int ffa_errno;
.a0 = FFA_SMC_32(FFA_ID_GET),
.a1 = 0, .a2 = 0, .a3 = 0, .a4 = 0, .a5 = 0, .a6 = 0, .a7 = 0,
}, &res);
ffa_priv_data->id = GET_SELF_ENDPOINT_ID((u32)res.a2);
ffa_info("endpoint ID is %u", ffa_priv_data->id);
- Return:
+static int ffa_set_rxtx_buffers_pages_cnt(u32 prop_field) +{
return -EINVAL;
- case RXTX_4K:
ffa_priv_data->pair.rxtx_min_pages = 1;
break;
- case RXTX_16K:
ffa_priv_data->pair.rxtx_min_pages = 4;
break;
- case RXTX_64K:
ffa_priv_data->pair.rxtx_min_pages = 16;
break;
- default:
ffa_err("RX/TX buffer size not supported");
return -EINVAL;
- Return:
+static int ffa_get_rxtx_map_features(void) +{
- int ffa_errno;
.a0 = FFA_SMC_32(FFA_FEATURES),
.a1 = FFA_SMC_64(FFA_RXTX_MAP),
}, &res);
return ffa_set_rxtx_buffers_pages_cnt((u32)res.a2);
+static void ffa_free_rxtx_buffers(void) +{
free((void *)ffa_priv_data->pair.rxbuf);
ffa_priv_data->pair.rxbuf = 0;
free((void *)ffa_priv_data->pair.txbuf);
ffa_priv_data->pair.txbuf = 0;
- Return:
+static int ffa_alloc_rxtx_buffers(void) +{
- u64 bytes;
ffa_priv_data->pair.rxtx_min_pages);
ffa_err("failure to allocate RX buffer");
return -ENOBUFS;
ffa_err("failure to allocate the TX buffer");
return -ENOBUFS;
* make sure the buffers are cleared before use
- Return:
+static int ffa_map_rxtx_buffers(void) +{
- int ret;
- int ffa_errno;
- if (ret)
return ret;
* we need to pass the physical addresses of the RX/TX buffers
* in u-boot physical/virtual mapping is 1:1
*no need to convert from virtual to physical
.a0 = FFA_SMC_64(FFA_RXTX_MAP),
.a1 = ffa_priv_data->pair.txbuf,
.a2 = ffa_priv_data->pair.rxbuf,
.a3 = ffa_priv_data->pair.rxtx_min_pages,
}, &res);
ffa_info("RX/TX buffers mapped");
- Return:
+static int ffa_unmap_rxtx_buffers(void) +{
- int ffa_errno;
.a0 = FFA_SMC_32(FFA_RXTX_UNMAP),
.a1 = PREP_SELF_ENDPOINT_ID(ffa_priv_data->id),
}, &res);
- Return:
+static int ffa_release_rx_buffer(void) +{
- int ffa_errno;
.a0 = FFA_SMC_32(FFA_RX_RELEASE),
}, &res);
- Return:
+int ffa_uuid_are_identical(const struct ffa_partition_uuid *uuid1,
const struct ffa_partition_uuid *uuid2)
and saves it in the private structure
- data structure.
- Return:
+static int ffa_read_partitions_info(u32 count, struct ffa_partition_uuid *part_uuid) +{
- if (!count) {
ffa_err("no partition detected");
return -ENODATA;
- if (!part_uuid) {
* querying information of all partitions
u64 buf_bytes;
u64 data_bytes;
u32 desc_idx;
struct ffa_partition_info *parts_info;
data_bytes = count * sizeof(struct ffa_partition_desc);
buf_bytes = ffa_priv_data->pair.rxtx_min_pages * SZ_4K;
if (data_bytes > buf_bytes) {
ffa_err("partitions data size exceeds the RX buffer size:");
ffa_err(" sizes in bytes: data %llu , RX buffer %llu ",
data_bytes,
buf_bytes);
return -ENOMEM;
ffa_priv_data->partitions.descs = (struct ffa_partition_desc *)
devm_kmalloc(ffa_priv_data->dev, data_bytes, __GFP_ZERO);
if (!ffa_priv_data->partitions.descs) {
ffa_err("cannot allocate partitions data buffer");
return -ENOMEM;
parts_info = (struct ffa_partition_info *)ffa_priv_data->pair.rxbuf;
for (desc_idx = 0 ; desc_idx < count ; desc_idx++) {
ffa_priv_data->partitions.descs[desc_idx].info =
parts_info[desc_idx];
ffa_info("Partition ID %x : info cached",
ffa_priv_data->partitions.descs[desc_idx].info.id);
ffa_priv_data->partitions.count = count;
ffa_info("%d partition(s) found and cached", count);
- } else {
u32 rx_desc_idx, cached_desc_idx;
u8 desc_found;
* search for the SP IDs read from the RX buffer
* in the already cached SPs.
* Update the UUID when ID found.
for (rx_desc_idx = 0; rx_desc_idx < count ; rx_desc_idx++) {
desc_found = 0;
* search the current ID in the cached partitions
for (cached_desc_idx = 0;
cached_desc_idx < ffa_priv_data->partitions.count;
cached_desc_idx++) {
* save the UUID
if (ffa_priv_data->partitions.descs[cached_desc_idx].info.id ==
parts_info[rx_desc_idx].id) {
ffa_priv_data->partitions.descs[cached_desc_idx].sp_uuid =
*part_uuid;
desc_found = 1;
break;
if (!desc_found)
return -ENODATA;
- Return:
+static int ffa_query_partitions_info(struct ffa_partition_uuid *part_uuid,
u32 *pcount)
- int ffa_errno;
* If a UUID is specified. Information for one or more
* partitions in the system is queried. Otherwise, information
* for all installed partitions is queried
- if (part_uuid) {
if (!pcount)
return -EINVAL;
query_uuid = *part_uuid;
return -EINVAL;
.a0 = FFA_SMC_32(FFA_PARTITION_INFO_GET),
.a1 = query_uuid.a1,
.a2 = query_uuid.a2,
.a3 = query_uuid.a3,
.a4 = query_uuid.a4,
.a5 = 0,
.a6 = 0,
.a7 = 0,
}, &res);
int ret;
* res.a2 contains the count of partition information descriptors
* populated in the RX buffer
if (res.a2) {
ret = ffa_read_partitions_info((u32)res.a2, part_uuid);
if (ret) {
ffa_err("failed to read partition(s) data , error (%d)", ret);
ffa_release_rx_buffer();
return -EINVAL;
* return the SP count (when querying using a UUID)
if (pcount)
*pcount = (u32)res.a2;
* After calling FFA_PARTITION_INFO_GET the buffer ownership
* is assigned to the consumer (u-boot). So, we need to give
* the ownership back to the SPM or hypervisor
ret = ffa_release_rx_buffer();
return ret;
The variable will be set by the driver
- @buffer: NULL
(allocated by the client).
The buffer will be filled by the driver
- buffer.
- Return:
+static int ffa_get_partitions_info(const char *uuid_str,
* fill_data:
* 0: return the SP count
* 1: fill SP data and return it to the caller
* -1: undefined mode
ffa_err("no partition installed");
return -EINVAL;
- if (!uuid_str) {
ffa_err("no UUID provided");
return -EINVAL;
ffa_err("no size/count provided");
return -EINVAL;
ffa_err("invalid UUID");
return -EINVAL;
- if (!buffer) {
/* Mode 1: getting the number of secure partitions */
fill_data = 0;
ffa_info("Preparing for checking partitions count");
!(*parts_size % sizeof(struct ffa_partition_info))) {
/* Mode 2: retrieving the partitions information */
fill_data = 1;
client_desc_idx = 0;
* number of empty descriptors preallocated by the caller
client_desc_max_cnt = *parts_size / sizeof(struct ffa_partition_info);
ffa_info("Preparing for filling partitions info");
- } else {
ffa_err("invalid function arguments provided");
return -EINVAL;
* search in the cached partitions
desc_idx++) {
if (ffa_uuid_are_identical(&ffa_priv_data->partitions.descs[desc_idx].sp_uuid,
&part_uuid)) {
ffa_info("Partition ID %x matches the provided UUID",
parts_found++;
if (fill_data) {
* trying to fill the partition info in the input buffer
if (client_desc_idx < client_desc_max_cnt) {
buffer[client_desc_idx++] =
ffa_priv_data->partitions.descs[desc_idx].info;
continue;
ffa_err("failed to fill the current descriptor client buffer full");
return -ENOBUFS;
int ret;
ffa_info("No partition found. Querying framework ...");
ret = ffa_query_partitions_info(&part_uuid, &parts_found);
if (ret == 0) {
if (!fill_data) {
*parts_size = parts_found;
ffa_info("Number of partition(s) found matching the UUID: %d",
parts_found);
} else {
* If SPs data detected, they are already in the private data
* structure, retry searching SP data again to return them
* to the caller
if (parts_found)
ret = ffa_get_partitions_info(uuid_str, parts_size, buffer);
else
ret = -ENODATA;
return ret;
- if (!fill_data)
- Return:
+static int ffa_cache_partitions_info(void) +{
- FF-A functions.
- Return:
+static int __ffa_runtime ffa_msg_send_direct_req(u16 dst_part_id, struct ffa_send_direct_data *msg) +{
- int ffa_errno;
return -EINVAL;
return -ENODEV;
.a0 = FFA_SMC_64(FFA_MSG_SEND_DIRECT_REQ),
.a1 = PREP_SELF_ENDPOINT_ID(ffa_priv_data->id) |
PREP_PART_ENDPOINT_ID(dst_part_id),
.a2 = 0,
.a3 = msg->data0,
.a4 = msg->data1,
.a5 = msg->data2,
.a6 = msg->data3,
.a7 = msg->data4,
}, &res);
.a0 = FFA_SMC_32(FFA_RUN),
.a1 = res.a1, .a2 = 0, .a3 = 0, .a4 = 0, .a5 = 0, .a6 = 0, .a7 = 0,
}, &res);
According to the FF-A 1.0 spec, paragraph 10.2:
Successful completion of FFA_MSG_SEND_DIRECT_REQ is indicated through an invocation of the following interfaces by the callee: FFA_MSG_SEND_DIRECT_RESP, FFA_INTERRUPT, FFA_SUCCESS, FFA_ERROR.
All these are supported by the u-boot FF-A driver.
/* Message sent with no response */
* Message sent with response
* extract the return data
msg->data0 = res.a3;
msg->data1 = res.a4;
msg->data2 = res.a5;
msg->data3 = res.a6;
msg->data4 = res.a7;
- Return: void
+void __ffa_runtime __arm_ffa_fn_smc(ffa_value_t args, ffa_value_t *res) +{
- Return:
+static int ffa_set_smc_conduit(void) +{
ffa_err("failure to set the invoke function");
return -EINVAL;
+static void ffa_set_bus_ops(void) +{
- Return:
+static int ffa_alloc_prvdata(struct udevice *dev) +{
- if (!dev) {
ffa_err("no udevice found");
return -ENODEV;
ffa_err("can not allocate the driver main data structure");
return -ENOMEM;
- setting the conduit
- querying from secure world the supported features of FFA_RXTX_MAP
- Return:
+static int ffa_probe(struct udevice *dev) +{
- int ret;
- if (ret != 0)
return ret;
At this stage of development, we only support a Hypervisor that can trap an SMC if the need arises.
- if (ret != 0)
return ret;
- if (ret != 0)
return ret;
- if (ret != 0)
return ret;
- if (ret != 0)
return ret;
- if (ret != 0)
return ret;
The RX/TX buffers are only available at EFI boot time. Querying partitions is done at EFI boot time and data is cached for future use including EFI runtime use. RX/TX buffers are unmapped before EFI runtime mode starts. If we would allow RX/TX buffers created by u-boot to be available at EFI runtime, secure world will get confused about RX/TX buffers ownership (owned by the kernel ? By u-boot ? ).
- if (ret != 0) {
return ret;
- Return:
- 0 on success.
+static int ffa_remove(struct udevice *dev) +{
- Return:
- 0 on success.
+static int ffa_unbind(struct udevice *dev) +{
- Return:
+const struct ffa_bus_ops * __ffa_runtime ffa_bus_ops_get(void) +{
- Return:
+struct ffa_prvdata **ffa_bus_prvdata_get(void) +{
- communication.
- Return:
+int ffa_bus_discover(void) +{
- int ret = 0;
ret = ffa_device_get();
- return ret;
+U_BOOT_DRIVER(arm_ffa) = {
- .id = UCLASS_FFA,
+}; diff --git a/drivers/firmware/arm-ffa/efi_ffa_runtime_data_mgr.c b/drivers/firmware/arm-ffa/efi_ffa_runtime_data_mgr.c new file mode 100644 index 0000000000..c76cf2147b --- /dev/null +++ b/drivers/firmware/arm-ffa/efi_ffa_runtime_data_mgr.c @@ -0,0 +1,94 @@ +// SPDX-License-Identifier: GPL-2.0+ +/*
- Return:
+efi_status_t ffa_copy_runtime_data(void) +{
EFI_RUNTIME_SERVICES_DATA,
prvdata_pages,
(u64 *)&runtime_prvdata);
printf("ERROR: EFI: FFA: allocating runtime data (err: 0x%lx, addr 0x%llx)\n",
efi_ret, (u64)runtime_prvdata);
return efi_ret;
return EFI_INVALID_PARAMETER;
sizeof(struct ffa_partition_desc));
descs_pages,
&runtime_descs);
printf("ERROR: EFI: FFA: allocating runtime SPs data (err: 0x%lx, addr 0x%llx)\n",
efi_ret, runtime_descs);
efi_free_pages((u64)runtime_prvdata, prvdata_pages);
return efi_ret;
Very valid point thanks. The version can be negotiated as per the spec. However, v1.1 is backwards compatible with v1.0. So even if the kernel negotiates, EFI RT FFA_MSG_SEND_DIRECT_REQ calls should work. The problematic ABIs would be the memory management ABIs and FFA_PARTITION_INFO_GET (See v1.1 spec paragraph 18.6). But we do not use any of these ABIs in EFI RT.
So, no need to copy that framework version to the RT structure.
Ilias advised to remove EFI RT support from the patchset and adding it later when needed. When it's decided to add RT support back again, we will not copy the framework version to the RT structure.
This has been addressed in patchset v6.
* Update the private data structure pointer in the driver
* no need to free the old structure. devm takes care of that
(u64)*prvdata, (*prvdata)->partitions.count);
+} diff --git a/include/arm_ffa.h b/include/arm_ffa.h new file mode 100644 index 0000000000..f17b100497 --- /dev/null +++ b/include/arm_ffa.h @@ -0,0 +1,127 @@ +/* SPDX-License-Identifier: GPL-2.0+ */ +/*
+#ifndef __ARM_FFA_H +#define __ARM_FFA_H
+#include <linux/printk.h>
+#define ffa_info(fmt, ...) pr_info("[FFA] " fmt "\n", ##__VA_ARGS__) +#define ffa_err(fmt, ...) pr_err("[FFA] " fmt "\n", ##__VA_ARGS__)
- @id: Partition ID
+struct __packed ffa_partition_info {
- u16 id;
- u16 exec_ctxt;
+/* partition supports receipt of direct requests */ +#define FFA_PARTITION_DIRECT_RECV BIT(0) +/* partition can send direct requests. */ +#define FFA_PARTITION_DIRECT_SEND BIT(1) +/* partition can send and receive indirect messages. */ +#define FFA_PARTITION_INDIRECT_MSG BIT(2)
- u32 properties;
used by FFA_MSG_SEND_DIRECT_{REQ,RESP}
+/* For use with FFA_MSG_SEND_DIRECT_{REQ,RESP} which pass data via registers */ +struct __packed ffa_send_direct_data {
+#if CONFIG_IS_ENABLED(ARM_FFA_EFI_RUNTIME_MODE)
+#include <efi_loader.h>
- at runtime)
+#define __ffa_runtime_data __efi_runtime_data +#define __ffa_runtime __efi_runtime
+#else
+#define __ffa_runtime_data +#define __ffa_runtime
+struct ffa_bus_ops {
u32 *parts_size, struct ffa_partition_info *buffer);
+const struct ffa_bus_ops * __ffa_runtime ffa_bus_ops_get(void);
+int ffa_bus_discover(void);
+efi_status_t ffa_copy_runtime_data(void);
+#endif diff --git a/include/dm/uclass-id.h b/include/dm/uclass-id.h index a432e43871..5dd698b7a9 100644 --- a/include/dm/uclass-id.h +++ b/include/dm/uclass-id.h @@ -4,6 +4,9 @@
#ifndef _DM_UCLASS_ID_H @@ -55,6 +58,7 @@ enum uclass_id { UCLASS_EFI_MEDIA, /* Devices provided by UEFI firmware */ UCLASS_ETH, /* Ethernet device */ UCLASS_ETH_PHY, /* Ethernet PHY device */
diff --git a/lib/efi_loader/efi_boottime.c b/lib/efi_loader/efi_boottime.c index 6f7333638a..af0b0f3db1 100644 --- a/lib/efi_loader/efi_boottime.c +++ b/lib/efi_loader/efi_boottime.c @@ -3,6 +3,9 @@
#include <common.h> @@ -23,6 +26,10 @@ #include <asm/setjmp.h> #include <linux/libfdt_env.h>
+#if CONFIG_IS_ENABLED(ARM_FFA_TRANSPORT) +#include <arm_ffa.h> +#endif
/* Task priority level */ @@ -2178,6 +2185,14 @@ static efi_status_t EFIAPI efi_exit_boot_services(efi_handle_t image_handle, dm_remove_devices_flags(DM_REMOVE_ACTIVE_ALL); }
/* unmap FF-A RX/TX buffers */
if (ffa_bus_ops_get()->rxtx_unmap())
debug("[efi_boottime][ERROR]: can not unmap FF-A RX/TX buffers\n");
else
debug("[efi_boottime][INFO]: FF-A RX/TX buffers unmapped\n");
-- 2.17.1
Provide armffa command showcasing the use of the FF-A driver
The armffa command allows to query secure partitions data from the secure world and exchanging messages with the partitions.
Signed-off-by: Abdellatif El Khlifi abdellatif.elkhlifi@arm.com Cc: Tom Rini trini@konsulko.com Cc: Simon Glass sjg@chromium.org Cc: Ilias Apalodimas ilias.apalodimas@linaro.org Cc: Jens Wiklander jens.wiklander@linaro.org ---
Changelog: ===============
v4:
* remove pattern data in do_ffa_msg_send_direct_req
v3:
* use the new driver interfaces (partition_info_get, sync_send_receive) in armffa command
v2:
* replace use of ffa_helper_init_device function by ffa_helper_bus_discover
v1:
* introduce armffa command
MAINTAINERS | 1 + cmd/Kconfig | 10 ++ cmd/Makefile | 2 + cmd/armffa.c | 242 +++++++++++++++++++++++++++++++ drivers/firmware/arm-ffa/Kconfig | 1 + 5 files changed, 256 insertions(+) create mode 100644 cmd/armffa.c
diff --git a/MAINTAINERS b/MAINTAINERS index 02b84d5074..fd3b2c4263 100644 --- a/MAINTAINERS +++ b/MAINTAINERS @@ -251,6 +251,7 @@ F: configs/cortina_presidio-asic-pnand_defconfig ARM FF-A M: Abdellatif El Khlifi abdellatif.elkhlifi@arm.com S: Maintained +F: cmd/armffa.c F: doc/README.ffa.drv F: drivers/firmware/arm-ffa/ F: include/arm_ffa.h diff --git a/cmd/Kconfig b/cmd/Kconfig index 0e0be94f41..013d4c3da7 100644 --- a/cmd/Kconfig +++ b/cmd/Kconfig @@ -912,6 +912,16 @@ endmenu
menu "Device access commands"
+config CMD_ARMFFA + bool "Arm FF-A test command" + depends on ARM_FFA_TRANSPORT + help + Provides a test command for the Arm FF-A driver + supported options: + - Listing the partition(s) info + - Sending a data pattern to the specified partition + - Displaying the arm_ffa device info + config CMD_ARMFLASH #depends on FLASH_CFI_DRIVER bool "armflash" diff --git a/cmd/Makefile b/cmd/Makefile index 6e87522b62..979c6d59df 100644 --- a/cmd/Makefile +++ b/cmd/Makefile @@ -12,6 +12,8 @@ obj-y += panic.o obj-y += version.o
# command + +obj-$(CONFIG_CMD_ARMFFA) += armffa.o obj-$(CONFIG_CMD_ACPI) += acpi.o obj-$(CONFIG_CMD_ADDRMAP) += addrmap.o obj-$(CONFIG_CMD_AES) += aes.o diff --git a/cmd/armffa.c b/cmd/armffa.c new file mode 100644 index 0000000000..9b56e8a830 --- /dev/null +++ b/cmd/armffa.c @@ -0,0 +1,242 @@ +// SPDX-License-Identifier: GPL-2.0+ +/* + * (C) Copyright 2022 ARM Limited + * Abdellatif El Khlifi abdellatif.elkhlifi@arm.com + */ + +#include <arm_ffa.h> +#include <asm/io.h> +#include <common.h> +#include <command.h> +#include <dm.h> +#include <mapmem.h> +#include <stdlib.h> + +/** + * do_ffa_get_singular_partition_info - implementation of the getpart subcommand + * @cmdtp: Command Table + * @flag: flags + * @argc: number of arguments + * @argv: arguments + * + * This function queries the secure partition information which the UUID is provided + * as an argument. The function uses the arm_ffa driver partition_info_get operation + * to retrieve the data. + * The input UUID string is expected to be in big endian format. + * + * Return: + * + * CMD_RET_SUCCESS: on success, otherwise failure + */ +static int do_ffa_get_singular_partition_info(struct cmd_tbl *cmdtp, int flag, int argc, + char *const argv[]) +{ + u32 count = 0, size = 0; + int ret; + struct ffa_partition_info *parts_info; + u32 info_idx; + + if (argc != 1) + return -EINVAL; + + /* Mode 1: getting the number of secure partitions */ + ret = ffa_bus_ops_get()->partition_info_get(argv[0], &count, NULL); + if (ret != 0) { + ffa_err("Failure in querying partitions count (error code: %d)", ret); + return ret; + } + + if (!count) { + ffa_info("No secure partition found"); + return ret; + } + + /* + * pre-allocate a buffer to be filled by the driver + * with ffa_partition_info structs + */ + + ffa_info("Pre-allocating %d partition(s) info structures", count); + + parts_info = calloc(count, sizeof(struct ffa_partition_info)); + if (!parts_info) + return -EINVAL; + + size = count * sizeof(struct ffa_partition_info); + + /* + * ask the driver to fill the buffer with the SPs info + */ + + ret = ffa_bus_ops_get()->partition_info_get(argv[0], &size, parts_info); + if (ret != 0) { + ffa_err("Failure in querying partition(s) info (error code: %d)", ret); + free(parts_info); + return ret; + } + + /* + * SPs found , show the partition information + */ + for (info_idx = 0; info_idx < count ; info_idx++) { + ffa_info("Partition: id = 0x%x , exec_ctxt 0x%x , properties 0x%x", + parts_info[info_idx].id, + parts_info[info_idx].exec_ctxt, + parts_info[info_idx].properties); + } + + free(parts_info); + + return 0; +} + +/** + * do_ffa_msg_send_direct_req - implementation of the ping subcommand + * @cmdtp: Command Table + * @flag: flags + * @argc: number of arguments + * @argv: arguments + * + * This function sends data to the secure partition which the ID is provided + * as an argument. The function uses the arm_ffa driver sync_send_receive operation + * to send data. + * + * Return: + * + * CMD_RET_SUCCESS: on success, otherwise failure + */ +int do_ffa_msg_send_direct_req(struct cmd_tbl *cmdtp, int flag, int argc, + char *const argv[]) +{ + struct ffa_send_direct_data msg = { + .data0 = 0xaaaaaaaa, + .data1 = 0xbbbbbbbb, + .data2 = 0xcccccccc, + .data3 = 0xdddddddd, + .data4 = 0xeeeeeeee, + }; + u16 part_id; + int ret; + + if (argc != 1) + return -EINVAL; + + errno = 0; + part_id = strtoul(argv[0], NULL, 16); + + if (errno) { + ffa_err("Invalid partition ID"); + return -EINVAL; + } + + ret = ffa_bus_ops_get()->sync_send_receive(part_id, &msg); + if (ret == 0) { + u8 cnt; + + ffa_info("SP response:\n[LSB]"); + for (cnt = 0; + cnt < sizeof(struct ffa_send_direct_data) / sizeof(u64); + cnt++) + ffa_info("0x%llx", ((u64 *)&msg)[cnt]); + } else { + ffa_err("Sending direct request error (%d)", ret); + } + + return ret; +} + +/** + *do_ffa_dev_list - implementation of the devlist subcommand + * @cmdtp: [in] Command Table + * @flag: flags + * @argc: number of arguments + * @argv: arguments + * + * This function queries the devices belonging to the UCLASS_FFA + * class. Currently, one device is expected to show up: the arm_ffa device + * + * Return: + * + * CMD_RET_SUCCESS: on success, otherwise failure + */ +int do_ffa_dev_list(struct cmd_tbl *cmdtp, int flag, int argc, char *const argv[]) +{ + struct udevice *dev = NULL; + int i, ret; + + ffa_info("arm_ffa uclass entries:"); + + for (i = 0, ret = uclass_first_device(UCLASS_FFA, &dev); + dev; + ret = uclass_next_device(&dev), i++) { + if (ret) + break; + + ffa_info("entry %d - instance %08x, ops %08x, plat %08x", + i, + (u32)map_to_sysmem(dev), + (u32)map_to_sysmem(dev->driver->ops), + (u32)map_to_sysmem(dev_get_plat(dev))); + } + + return cmd_process_error(cmdtp, ret); +} + +static struct cmd_tbl armffa_commands[] = { + U_BOOT_CMD_MKENT(getpart, 1, 1, do_ffa_get_singular_partition_info, "", ""), + U_BOOT_CMD_MKENT(ping, 1, 1, do_ffa_msg_send_direct_req, "", ""), + U_BOOT_CMD_MKENT(devlist, 0, 1, do_ffa_dev_list, "", ""), +}; + +/** + * do_armffa - the armffa command main function + * @cmdtp: Command Table + * @flag: flags + * @argc: number of arguments + * @argv: arguments + * + * This function identifies which armffa subcommand to run. + * Then, it makes sure the arm_ffa device is probed and + * ready for use. + * Then, it runs the subcommand. + * + * Return: + * + * CMD_RET_SUCCESS: on success, otherwise failure + */ +static int do_armffa(struct cmd_tbl *cmdtp, int flag, int argc, char *const argv[]) +{ + struct cmd_tbl *armffa_cmd; + int ret; + + if (argc < 2) + return CMD_RET_USAGE; + + armffa_cmd = find_cmd_tbl(argv[1], armffa_commands, ARRAY_SIZE(armffa_commands)); + + argc -= 2; + argv += 2; + + if (!armffa_cmd || argc > armffa_cmd->maxargs) + return CMD_RET_USAGE; + + ret = ffa_bus_discover(); + if (ret != 0) + return cmd_process_error(cmdtp, ret); + + if (!ffa_bus_ops_get()) + return -EINVAL; + + ret = armffa_cmd->cmd(armffa_cmd, flag, argc, argv); + + return cmd_process_error(armffa_cmd, ret); +} + +U_BOOT_CMD(armffa, 4, 1, do_armffa, + "Arm FF-A operations test command", + "getpart <partition UUID>\n" + " - lists the partition(s) info\n" + "ping <partition ID>\n" + " - sends a data pattern to the specified partition\n" + "devlist\n" + " - displays the arm_ffa device info\n"); diff --git a/drivers/firmware/arm-ffa/Kconfig b/drivers/firmware/arm-ffa/Kconfig index aceb61cf49..40b467b0a5 100644 --- a/drivers/firmware/arm-ffa/Kconfig +++ b/drivers/firmware/arm-ffa/Kconfig @@ -4,6 +4,7 @@ config ARM_FFA_TRANSPORT bool "Enable Arm Firmware Framework for Armv8-A driver" depends on DM && ARM64 select ARM_SMCCC + select CMD_ARMFFA select LIB_UUID select DEVRES help
Provide a Sandbox driver to emulate the FF-A ABIs
The emulated ABIs are those supported by the FF-A core driver and according to FF-A specification v1.0.
The Sandbox driver provides operations allowing the test application to read the status of all the inspected ABIs and perform functional tests based on that.
v4: align sandbox driver with the new FF-A driver interfaces and new way of error handling
v1: introduce the sandbox driver
MAINTAINERS | 1 + common/board_r.c | 2 +- configs/sandbox64_defconfig | 2 + configs/sandbox_defconfig | 2 + doc/arch/sandbox.rst | 1 + drivers/firmware/arm-ffa/Kconfig | 10 +- drivers/firmware/arm-ffa/Makefile | 1 + drivers/firmware/arm-ffa/arm_ffa_prv.h | 15 +- drivers/firmware/arm-ffa/core.c | 24 +- drivers/firmware/arm-ffa/sandbox.c | 659 ++++++++++++++++++ .../firmware/arm-ffa/sandbox_arm_ffa_prv.h | 144 ++++ include/arm_ffa.h | 2 +- include/sandbox_arm_ffa.h | 91 +++ lib/efi_loader/efi_boottime.c | 2 +- 14 files changed, 941 insertions(+), 15 deletions(-) create mode 100644 drivers/firmware/arm-ffa/sandbox.c create mode 100644 drivers/firmware/arm-ffa/sandbox_arm_ffa_prv.h create mode 100644 include/sandbox_arm_ffa.h
diff --git a/MAINTAINERS b/MAINTAINERS index fd3b2c4263..6f01002e34 100644 --- a/MAINTAINERS +++ b/MAINTAINERS @@ -255,6 +255,7 @@ F: cmd/armffa.c F: doc/README.ffa.drv F: drivers/firmware/arm-ffa/ F: include/arm_ffa.h +F: include/sandbox_arm_ffa.h
ARM FREESCALE IMX M: Stefano Babic sbabic@denx.de diff --git a/common/board_r.c b/common/board_r.c index 8c99faddfd..7f1eae65df 100644 --- a/common/board_r.c +++ b/common/board_r.c @@ -776,7 +776,7 @@ static init_fnc_t init_sequence_r[] = { INIT_FUNC_WATCHDOG_RESET initr_net, #endif -#ifdef CONFIG_ARM_FFA_TRANSPORT +#if defined(CONFIG_ARM_FFA_TRANSPORT) && !defined(CONFIG_SANDBOX_FFA) ffa_bus_discover, #endif #ifdef CONFIG_POST diff --git a/configs/sandbox64_defconfig b/configs/sandbox64_defconfig index 290d1506c2..36e6448968 100644 --- a/configs/sandbox64_defconfig +++ b/configs/sandbox64_defconfig @@ -248,3 +248,5 @@ CONFIG_TEST_FDTDEC=y CONFIG_UNIT_TEST=y CONFIG_UT_TIME=y CONFIG_UT_DM=y +CONFIG_ARM_FFA_TRANSPORT=y +CONFIG_SANDBOX_FFA=y \ No newline at end of file diff --git a/configs/sandbox_defconfig b/configs/sandbox_defconfig index ab5d3f19bf..8bf3848788 100644 --- a/configs/sandbox_defconfig +++ b/configs/sandbox_defconfig @@ -328,3 +328,5 @@ CONFIG_TEST_FDTDEC=y CONFIG_UNIT_TEST=y CONFIG_UT_TIME=y CONFIG_UT_DM=y +CONFIG_ARM_FFA_TRANSPORT=y +CONFIG_SANDBOX_FFA=y \ No newline at end of file diff --git a/doc/arch/sandbox.rst b/doc/arch/sandbox.rst index 068d4a3be4..5d7e1b2c48 100644 --- a/doc/arch/sandbox.rst +++ b/doc/arch/sandbox.rst @@ -203,6 +203,7 @@ Supported Drivers
U-Boot sandbox supports these emulations:
+- Arm FF-A - Block devices - Chrome OS EC - GPIO diff --git a/drivers/firmware/arm-ffa/Kconfig b/drivers/firmware/arm-ffa/Kconfig index 40b467b0a5..263481de96 100644 --- a/drivers/firmware/arm-ffa/Kconfig +++ b/drivers/firmware/arm-ffa/Kconfig @@ -2,8 +2,8 @@
config ARM_FFA_TRANSPORT bool "Enable Arm Firmware Framework for Armv8-A driver" - depends on DM && ARM64 - select ARM_SMCCC + depends on DM && (ARM64 || SANDBOX) + select ARM_SMCCC if !SANDBOX select CMD_ARMFFA select LIB_UUID select DEVRES @@ -38,3 +38,9 @@ config ARM_FFA_EFI_RUNTIME_MODE The driver Code needed at runtime is placed at EFI runtime code section. Turning this on makes ffa_copy_runtime_data available for use and the driver code placed at EFI runtime code section. + +config SANDBOX_FFA + bool "FF-A Sandbox driver" + depends on ARM_FFA_TRANSPORT && SANDBOX + help + This emulates the FF-A handling under Sandbox and allows to test the FF-A driver diff --git a/drivers/firmware/arm-ffa/Makefile b/drivers/firmware/arm-ffa/Makefile index 0b9b0a61b4..d50060b836 100644 --- a/drivers/firmware/arm-ffa/Makefile +++ b/drivers/firmware/arm-ffa/Makefile @@ -5,3 +5,4 @@
obj-y += arm-ffa-uclass.o core.o obj-$(CONFIG_ARM_FFA_EFI_RUNTIME_MODE) += efi_ffa_runtime_data_mgr.o +obj-$(CONFIG_SANDBOX_FFA) += sandbox.o diff --git a/drivers/firmware/arm-ffa/arm_ffa_prv.h b/drivers/firmware/arm-ffa/arm_ffa_prv.h index 7bc90f7f66..3e0d4c112c 100644 --- a/drivers/firmware/arm-ffa/arm_ffa_prv.h +++ b/drivers/firmware/arm-ffa/arm_ffa_prv.h @@ -19,6 +19,16 @@ /* FF-A core driver name */ #define FFA_DRV_NAME "arm_ffa"
+/* The FF-A SMC function definitions */ + +#if CONFIG_IS_ENABLED(SANDBOX_FFA) +#include "sandbox_arm_ffa.h" +#else +typedef struct arm_smccc_1_2_regs ffa_value_t; +#endif + +typedef void (*invoke_ffa_fn_t)(ffa_value_t args, ffa_value_t *res); + /* FF-A driver version definitions */
#define MAJOR_VERSION_MASK GENMASK(30, 16) @@ -94,11 +104,6 @@ struct ffa_abi_errmap { #define FFA_ERRMAP_COUNT (FFA_LAST_ID - FFA_FIRST_ID + 1) #define FFA_ID_TO_ERRMAP_ID(ffa_id) ((ffa_id) - FFA_FIRST_ID)
-/* The FF-A SMC function definitions */ - -typedef struct arm_smccc_1_2_regs ffa_value_t; -typedef void (*invoke_ffa_fn_t)(ffa_value_t args, ffa_value_t *res); - /* * struct ffa_partition_uuid - 16 bytes UUID transmitted by FFA_PARTITION_INFO_GET * @a1-4: 32-bit words access to the UUID data diff --git a/drivers/firmware/arm-ffa/core.c b/drivers/firmware/arm-ffa/core.c index 41c7b96e68..caba10caae 100644 --- a/drivers/firmware/arm-ffa/core.c +++ b/drivers/firmware/arm-ffa/core.c @@ -1101,6 +1101,7 @@ static int __ffa_runtime ffa_msg_send_direct_req(u16 dst_part_id, struct ffa_sen return ffa_to_std_errno(ffa_errno); }
+#if !CONFIG_IS_ENABLED(SANDBOX_FFA) /** * __arm_ffa_fn_smc - SMC wrapper * @args: FF-A ABI arguments to be copied to Xn registers @@ -1114,6 +1115,7 @@ void __ffa_runtime __arm_ffa_fn_smc(ffa_value_t args, ffa_value_t *res) { arm_smccc_1_2_smc(&args, res); } +#endif
/** * ffa_set_smc_conduit - Set the SMC conduit @@ -1127,7 +1129,12 @@ void __ffa_runtime __arm_ffa_fn_smc(ffa_value_t args, ffa_value_t *res) */ static int ffa_set_smc_conduit(void) { - ffa_priv_data->invoke_ffa_fn = __arm_ffa_fn_smc; +#if CONFIG_IS_ENABLED(SANDBOX_FFA) + ffa_priv_data->invoke_ffa_fn = sandbox_arm_ffa_smccc_smc; + ffa_info("Using SMC emulation"); +#else + ffa_priv_data->invoke_ffa_fn = __arm_ffa_fn_smc; +#endif
if (!ffa_priv_data->invoke_ffa_fn) { ffa_err("failure to set the invoke function"); @@ -1304,17 +1311,18 @@ struct ffa_prvdata **ffa_bus_prvdata_get(void) }
/** - * ffa_bus_discover - discover FF-A bus and probe the arm_ffa device + * ffa_bus_discover - discover FF-A bus and probe arm_ffa and sandbox_arm_ffa devices * * This boot time function makes sure the FF-A bus is discoverable. - * Then, the arm_ffa device is probed and ready to use. + * Then, the arm_ffa and sandbox_arm_ffa devices are ready to use. + * * This function is called automatically at initcalls * level (after u-boot relocation). * * When the bus was already discovered successfully the discovery will not run again. * * Arm FF-A transport is implemented through arm_ffa u-boot device managing the FF-A - * communication. + * communication. In Sandbox mode sandbox_arm_ffa is used to test arm_ffa driver. * All FF-A clients should use the arm_ffa device to use the FF-A transport. * * Return: @@ -1325,9 +1333,15 @@ int ffa_bus_discover(void) { int ret = 0;
- if (!ffa_priv_data) + if (!ffa_priv_data) { ret = ffa_device_get();
+#if CONFIG_IS_ENABLED(SANDBOX_FFA) + if (ret == 0) + ret = sandbox_ffa_device_get(); +#endif + } + return ret; }
diff --git a/drivers/firmware/arm-ffa/sandbox.c b/drivers/firmware/arm-ffa/sandbox.c new file mode 100644 index 0000000000..16e1fdc809 --- /dev/null +++ b/drivers/firmware/arm-ffa/sandbox.c @@ -0,0 +1,659 @@ +// SPDX-License-Identifier: GPL-2.0+ +/* + * (C) Copyright 2022 ARM Limited + * Abdellatif El Khlifi abdellatif.elkhlifi@arm.com + */ + +#include "sandbox_arm_ffa_prv.h" +#include <asm/global_data.h> +#include <common.h> +#include <dm.h> +#include <dm/device-internal.h> +#include <dm/root.h> +#include <linux/errno.h> +#include <linux/sizes.h> +#include <mapmem.h> +#include <string.h> + +DECLARE_GLOBAL_DATA_PTR; + +/** + * The device private data structure containing all the emulated secure world data + */ +static struct sandbox_ffa_prvdata sandbox_ffa_priv_data = {0}; + +/* The partitions (SPs) table */ +static struct ffa_partition_desc sandbox_partitions[SANDBOX_PARTITIONS_CNT] = { + { + .info = { .id = SANDBOX_SP1_ID, .exec_ctxt = 0x5687, .properties = 0x89325621 }, + .sp_uuid = { + .a1 = SANDBOX_SERVICE1_UUID_A1, + .a2 = SANDBOX_SERVICE1_UUID_A2, + .a3 = SANDBOX_SERVICE1_UUID_A3, + .a4 = SANDBOX_SERVICE1_UUID_A4, + } + }, + { + .info = { .id = SANDBOX_SP2_ID, .exec_ctxt = 0x9587, .properties = 0x45325621 }, + .sp_uuid = { + .a1 = SANDBOX_SERVICE2_UUID_A1, + .a2 = SANDBOX_SERVICE2_UUID_A2, + .a3 = SANDBOX_SERVICE2_UUID_A3, + .a4 = SANDBOX_SERVICE2_UUID_A4, + } + }, + { + .info = { .id = SANDBOX_SP3_ID, .exec_ctxt = 0x7687, .properties = 0x23325621 }, + .sp_uuid = { + .a1 = SANDBOX_SERVICE1_UUID_A1, + .a2 = SANDBOX_SERVICE1_UUID_A2, + .a3 = SANDBOX_SERVICE1_UUID_A3, + .a4 = SANDBOX_SERVICE1_UUID_A4, + } + }, + { + .info = { .id = SANDBOX_SP4_ID, .exec_ctxt = 0x1487, .properties = 0x70325621 }, + .sp_uuid = { + .a1 = SANDBOX_SERVICE2_UUID_A1, + .a2 = SANDBOX_SERVICE2_UUID_A2, + .a3 = SANDBOX_SERVICE2_UUID_A3, + .a4 = SANDBOX_SERVICE2_UUID_A4, + } + } + +}; + +/* + * Driver functions + */ + +/** + * sandbox_ffa_get_device - probes the sandbox_arm_ffa device + * + * This function makes sure the sandbox_arm_ffa device is probed + * This function makes sure the sandbox_arm_ffa device is + * created, bound to this driver, probed and ready to use. + * + * sandbox_arm_ffa depends on arm_ffa device. This dependency is + * handled by ffa_bus_discover function. arm_ffa is probed first then + * sandbox_arm_ffa. + * + * Return: + * + * 0 on success. Otherwise, failure + */ +int sandbox_ffa_device_get(void) +{ + int ret; + + if (sandbox_ffa_priv_data.dev) + return 0; + + ret = device_bind(dm_root(), + DM_DRIVER_GET(sandbox_arm_ffa), + FFA_SANDBOX_DRV_NAME, + NULL, + ofnode_null(), + &sandbox_ffa_priv_data.dev); + if (ret) { + sandbox_ffa_priv_data.dev = NULL; + return ret; + } + + ret = device_probe(sandbox_ffa_priv_data.dev); + if (ret) { + ffa_err("[Sandbox] can not probe the device"); + device_unbind(sandbox_ffa_priv_data.dev); + sandbox_ffa_priv_data.dev = NULL; + return ret; + } + + return 0; +} + +/** + * sandbox_ffa_version - Emulated FFA_VERSION handler function + * @{a0-a7} , res: The SMC call arguments and return structure. + * + * This is the function that emulates FFA_VERSION FF-A function. + * + * Return: + * + * 0 on success. Otherwise, failure + */ +SANDBOX_SMC_FFA_ABI(ffa_version) +{ + sandbox_ffa_priv_data.fwk_version = FFA_VERSION_1_0; + res->a0 = sandbox_ffa_priv_data.fwk_version; + + /* x1-x7 MBZ */ + memset(FFA_X1X7_MBZ_REG_START, 0, FFA_X1X7_MBZ_CNT * sizeof(unsigned long)); + + return 0; +} + +/** + * sandbox_ffa_id_get - Emulated FFA_ID_GET handler function + * @{a0-a7} , res: The SMC call arguments and return structure. + * + * This is the function that emulates FFA_ID_GET FF-A function. + * + * Return: + * + * 0 on success. Otherwise, failure + */ +SANDBOX_SMC_FFA_ABI(ffa_id_get) +{ + res->a0 = FFA_SMC_32(FFA_SUCCESS); + res->a1 = 0; + + sandbox_ffa_priv_data.id = NS_PHYS_ENDPOINT_ID; + res->a2 = sandbox_ffa_priv_data.id; + + /* x3-x7 MBZ */ + memset(FFA_X3_MBZ_REG_START, 0, FFA_X3X7_MBZ_CNT * sizeof(unsigned long)); + + return 0; +} + +/** + * sandbox_ffa_features - Emulated FFA_FEATURES handler function + * @{a0-a7} , res: The SMC call arguments and return structure. + * + * This is the function that emulates FFA_FEATURES FF-A function. + * + * Return: + * + * 0 on success. Otherwise, failure + */ +SANDBOX_SMC_FFA_ABI(ffa_features) +{ + if (pargs->a1 == FFA_SMC_64(FFA_RXTX_MAP)) { + res->a0 = FFA_SMC_32(FFA_SUCCESS); + res->a2 = RXTX_BUFFERS_MIN_SIZE; + res->a3 = 0; + /* x4-x7 MBZ */ + memset(FFA_X4X7_MBZ_REG_START, + 0, FFA_X4X7_MBZ_CNT * sizeof(unsigned long)); + } else { + res->a0 = FFA_SMC_32(FFA_ERROR); + res->a2 = FFA_ERR_STAT_NOT_SUPPORTED; + /* x3-x7 MBZ */ + memset(FFA_X3_MBZ_REG_START, + 0, FFA_X3X7_MBZ_CNT * sizeof(unsigned long)); + ffa_err("[Sandbox] FF-A interface 0x%lx not implemented", pargs->a1); + } + + res->a1 = 0; + + return 0; +} + +/** + * sandbox_ffa_partition_info_get - Emulated FFA_PARTITION_INFO_GET handler function + * @{a0-a7} , res: The SMC call arguments and return structure. + * + * This is the function that emulates FFA_PARTITION_INFO_GET FF-A function. + * + * Return: + * + * 0 on success. Otherwise, failure + */ +SANDBOX_SMC_FFA_ABI(ffa_partition_info_get) +{ + struct ffa_partition_info *rxbuf_desc_info = NULL; + u32 descs_cnt; + u32 descs_size_bytes; + + res->a0 = FFA_SMC_32(FFA_ERROR); + + if (!sandbox_ffa_priv_data.pair.rxbuf) { + res->a2 = FFA_ERR_STAT_DENIED; + goto cleanup; + } + + if (sandbox_ffa_priv_data.pair_info.rxbuf_owned) { + res->a2 = FFA_ERR_STAT_BUSY; + goto cleanup; + } + + if (!sandbox_ffa_priv_data.partitions.descs) { + sandbox_ffa_priv_data.partitions.descs = sandbox_partitions; + sandbox_ffa_priv_data.partitions.count = SANDBOX_PARTITIONS_CNT; + } + + descs_size_bytes = SANDBOX_PARTITIONS_CNT * sizeof(struct ffa_partition_desc); + + /* Abort if the RX buffer size is smaller than the descriptors buffer size */ + if ((sandbox_ffa_priv_data.pair_info.rxtx_buf_size * SZ_4K) < descs_size_bytes) { + res->a2 = FFA_ERR_STAT_NO_MEMORY; + goto cleanup; + } + + rxbuf_desc_info = (struct ffa_partition_info *)sandbox_ffa_priv_data.pair.rxbuf; + + /* No UUID specified. Return the information of all partitions */ + if (!pargs->a1 && !pargs->a2 && !pargs->a3 && !pargs->a4) { + for (descs_cnt = 0 ; descs_cnt < SANDBOX_PARTITIONS_CNT ; descs_cnt++) + *(rxbuf_desc_info++) = + sandbox_ffa_priv_data.partitions.descs[descs_cnt].info; + + res->a0 = FFA_SMC_32(FFA_SUCCESS); + res->a2 = SANDBOX_PARTITIONS_CNT; + /* transfer ownership to the consumer: the non secure world */ + sandbox_ffa_priv_data.pair_info.rxbuf_owned = 1; + + goto cleanup; + } + + /* + * A UUID is specified. Return the information of all partitions matching + * the UUID + */ + + for (descs_cnt = 0 ; descs_cnt < SANDBOX_PARTITIONS_CNT ; descs_cnt++) + if (pargs->a1 == sandbox_ffa_priv_data.partitions.descs[descs_cnt].sp_uuid.a1 && + pargs->a2 == sandbox_ffa_priv_data.partitions.descs[descs_cnt].sp_uuid.a2 && + pargs->a3 == sandbox_ffa_priv_data.partitions.descs[descs_cnt].sp_uuid.a3 && + pargs->a4 == sandbox_ffa_priv_data.partitions.descs[descs_cnt].sp_uuid.a4) { + *(rxbuf_desc_info++) = + sandbox_ffa_priv_data.partitions.descs[descs_cnt].info; + } + + if (rxbuf_desc_info != ((struct ffa_partition_info *)sandbox_ffa_priv_data.pair.rxbuf)) { + res->a0 = FFA_SMC_32(FFA_SUCCESS); + /* store the partitions count */ + res->a2 = (unsigned long) + (rxbuf_desc_info - (struct ffa_partition_info *) + sandbox_ffa_priv_data.pair.rxbuf); + + /* transfer ownership to the consumer: the non secure world */ + sandbox_ffa_priv_data.pair_info.rxbuf_owned = 1; + } else { + /* Unrecognized UUID */ + res->a2 = FFA_ERR_STAT_INVALID_PARAMETERS; + } + +cleanup: + + ffa_err("[Sandbox] FFA_PARTITION_INFO_GET (%ld)", res->a2); + + res->a1 = 0; + + /* x3-x7 MBZ */ + memset(FFA_X3_MBZ_REG_START, 0, FFA_X3X7_MBZ_CNT * sizeof(unsigned long)); + + return 0; +} + +/** + * sandbox_ffa_rxtx_map - Emulated FFA_RXTX_MAP handler function + * @{a0-a7} , res: The SMC call arguments and return structure. + * + * This is the function that emulates FFA_RXTX_MAP FF-A function. + * + * Return: + * + * 0 on success. Otherwise, failure + */ +SANDBOX_SMC_FFA_ABI(ffa_rxtx_map) +{ + res->a0 = FFA_SMC_32(FFA_ERROR); + + if (sandbox_ffa_priv_data.pair.txbuf && sandbox_ffa_priv_data.pair.rxbuf) { + res->a2 = FFA_ERR_STAT_DENIED; + goto feedback; + } + + if (pargs->a3 >= RXTX_BUFFERS_MIN_PAGES && pargs->a1 && pargs->a2) { + sandbox_ffa_priv_data.pair.txbuf = pargs->a1; + sandbox_ffa_priv_data.pair.rxbuf = pargs->a2; + sandbox_ffa_priv_data.pair_info.rxtx_buf_size = pargs->a3; + sandbox_ffa_priv_data.pair_info.rxbuf_mapped = 1; + res->a0 = FFA_SMC_32(FFA_SUCCESS); + res->a2 = 0; + goto feedback; + } + + if (!pargs->a1 || !pargs->a2) + res->a2 = FFA_ERR_STAT_INVALID_PARAMETERS; + else + res->a2 = FFA_ERR_STAT_NO_MEMORY; + + ffa_err("[Sandbox] error in FFA_RXTX_MAP arguments (%d)", (int)res->a2); + +feedback: + + res->a1 = 0; + + /* x3-x7 MBZ */ + memset(FFA_X3_MBZ_REG_START, + 0, FFA_X3X7_MBZ_CNT * sizeof(unsigned long)); + + return 0; +} + +/** + * sandbox_ffa_rxtx_unmap - Emulated FFA_RXTX_UNMAP handler function + * @{a0-a7} , res: The SMC call arguments and return structure. + * + * This is the function that emulates FFA_RXTX_UNMAP FF-A function. + * + * Return: + * + * 0 on success. Otherwise, failure + */ +SANDBOX_SMC_FFA_ABI(ffa_rxtx_unmap) +{ + res->a0 = FFA_SMC_32(FFA_ERROR); + res->a2 = FFA_ERR_STAT_INVALID_PARAMETERS; + + if (GET_NS_PHYS_ENDPOINT_ID(pargs->a1) != sandbox_ffa_priv_data.id) + goto feedback; + + if (sandbox_ffa_priv_data.pair.txbuf && sandbox_ffa_priv_data.pair.rxbuf) { + sandbox_ffa_priv_data.pair.txbuf = 0; + sandbox_ffa_priv_data.pair.rxbuf = 0; + sandbox_ffa_priv_data.pair_info.rxtx_buf_size = 0; + sandbox_ffa_priv_data.pair_info.rxbuf_mapped = 0; + res->a0 = FFA_SMC_32(FFA_SUCCESS); + res->a2 = 0; + goto feedback; + } + + ffa_err("[Sandbox] No buffer pair registered on behalf of the caller"); + +feedback: + + res->a1 = 0; + + /* x3-x7 MBZ */ + memset(FFA_X3_MBZ_REG_START, + 0, FFA_X3X7_MBZ_CNT * sizeof(unsigned long)); + + return 0; +} + +/** + * sandbox_ffa_rx_release - Emulated FFA_RX_RELEASE handler function + * @{a0-a7} , res: The SMC call arguments and return structure. + * + * This is the function that emulates FFA_RX_RELEASE FF-A function. + * + * Return: + * + * 0 on success. Otherwise, failure + */ +SANDBOX_SMC_FFA_ABI(ffa_rx_release) +{ + if (!sandbox_ffa_priv_data.pair_info.rxbuf_owned) { + res->a0 = FFA_SMC_32(FFA_ERROR); + res->a2 = FFA_ERR_STAT_DENIED; + } else { + sandbox_ffa_priv_data.pair_info.rxbuf_owned = 0; + res->a0 = FFA_SMC_32(FFA_SUCCESS); + res->a2 = 0; + } + + res->a1 = 0; + + /* x3-x7 MBZ */ + memset(FFA_X3_MBZ_REG_START, + 0, FFA_X3X7_MBZ_CNT * sizeof(unsigned long)); + + return 0; +} + +/** + * sandbox_ffa_sp_valid - Checks SP validity + * @part_id: partition ID to check + * + * This is the function searches the input ID in the descriptors table. + * + * Return: + * + * 1 on success (Partition found). Otherwise, failure + */ +static int sandbox_ffa_sp_valid(u16 part_id) +{ + u32 descs_cnt; + + for (descs_cnt = 0 ; descs_cnt < SANDBOX_PARTITIONS_CNT ; descs_cnt++) + if (sandbox_ffa_priv_data.partitions.descs[descs_cnt].info.id == part_id) + return 1; + + return 0; +} + +/** + * sandbox_ffa_msg_send_direct_req - Emulated FFA_MSG_SEND_DIRECT_{REQ,RESP} handler function + * @{a0-a7} , res: The SMC call arguments and return structure. + * + * This is the function that emulates FFA_MSG_SEND_DIRECT_{REQ,RESP} + * FF-A functions. + * + * Emulating interrupts is not supported. So, FFA_RUN and FFA_INTERRUPT are not supported. + * In case of success FFA_MSG_SEND_DIRECT_RESP is returned with default pattern data (0xff). + * + * Return: + * + * 0 on success. Otherwise, failure + */ +SANDBOX_SMC_FFA_ABI(ffa_msg_send_direct_req) +{ + u16 part_id; + + part_id = GET_DST_SP_ID(pargs->a1); + + if ((GET_NS_PHYS_ENDPOINT_ID(pargs->a1) != sandbox_ffa_priv_data.id) || + !sandbox_ffa_sp_valid(part_id) || + pargs->a2) { + res->a0 = FFA_SMC_32(FFA_ERROR); + res->a1 = 0; + res->a2 = FFA_ERR_STAT_INVALID_PARAMETERS; + + /* x3-x7 MBZ */ + memset(FFA_X3_MBZ_REG_START, + 0, FFA_X3X7_MBZ_CNT * sizeof(unsigned long)); + + return 0; + } + + res->a0 = FFA_SMC_64(FFA_MSG_SEND_DIRECT_RESP); + + res->a1 = PREP_SRC_SP_ID(part_id) | + PREP_NS_PHYS_ENDPOINT_ID(sandbox_ffa_priv_data.id); + + res->a2 = 0; + + /* + * return 0xff bytes as a response + */ + res->a3 = 0xffffffffffffffff; + res->a4 = 0xffffffffffffffff; + res->a5 = 0xffffffffffffffff; + res->a6 = 0xffffffffffffffff; + res->a7 = 0xffffffffffffffff; + + return 0; +} + +/** + * sandbox_ffa_get_prv_data - Returns the pointer to FF-A core pivate data + * @func_data: Pointer to the FF-A function arguments container structure + * + * This is the handler that returns the address of the FF-A core pivate data. + * + * Return: + * + * 0 on success. Otherwise, failure + */ +static int sandbox_ffa_get_prv_data(struct ffa_sandbox_data *func_data) +{ + if (!func_data) + return -EINVAL; + + if (!func_data->data0 || func_data->data0_size != sizeof(struct ffa_prvdata **)) + return -EINVAL; + + if (!func_data->data1 || func_data->data1_size != sizeof(struct sandbox_ffa_prvdata **)) + return -EINVAL; + + *((struct ffa_prvdata **)func_data->data0) = *(ffa_bus_prvdata_get()); + *((struct sandbox_ffa_prvdata **)func_data->data1) = &sandbox_ffa_priv_data; + + return 0; +} + +/** + * sandbox_ffa_get_rxbuf_flags - Reading the mapping/ownership flags + * @queried_func_id: The FF-A function to be queried + * @func_data: Pointer to the FF-A function arguments container structure + * + * This is the handler that queries the status flags of the following emulated ABIs: + * FFA_RXTX_MAP, FFA_RXTX_UNMAP, FFA_RX_RELEASE + * + * Return: + * + * 0 on success. Otherwise, failure + */ +static int sandbox_ffa_get_rxbuf_flags(u32 queried_func_id, struct ffa_sandbox_data *func_data) +{ + if (!func_data) + return -EINVAL; + + if (!func_data->data0 || func_data->data0_size != sizeof(u8)) + return -EINVAL; + + switch (queried_func_id) { + case FFA_RXTX_MAP: + case FFA_RXTX_UNMAP: + *((u8 *)func_data->data0) = sandbox_ffa_priv_data.pair_info.rxbuf_mapped; + return 0; + case FFA_RX_RELEASE: + *((u8 *)func_data->data0) = sandbox_ffa_priv_data.pair_info.rxbuf_owned; + return 0; + default: + ffa_err("[Sandbox] The querried FF-A interface flag (%d) undefined", + queried_func_id); + return -EINVAL; + } +} + +/** + * sandbox_ffa_query_core_state - The driver dispatcher function + * @queried_func_id: The FF-A function to be queried + * @func_data: Pointer to the FF-A function arguments container structure + * + * Queries the status of FF-A ABI specified in the input argument. + * + * Return: + * + * 0 on success. Otherwise, failure + */ +int sandbox_ffa_query_core_state(u32 queried_func_id, struct ffa_sandbox_data *func_data) +{ + switch (queried_func_id) { + case FFA_VERSION: + case FFA_ID_GET: + case FFA_FEATURES: + return sandbox_ffa_get_prv_data(func_data); + case FFA_RXTX_MAP: + case FFA_RXTX_UNMAP: + case FFA_RX_RELEASE: + return sandbox_ffa_get_rxbuf_flags(queried_func_id, func_data); + default: + ffa_err("[Sandbox] The querried FF-A interface (%d) undefined", queried_func_id); + return -EINVAL; + } +} + +/** + * sandbox_arm_ffa_smccc_smc - FF-A SMC call emulation + * @args: the SMC call arguments + * @res: the SMC call returned data + * + * Sandbox driver emulates the FF-A ABIs SMC call using this function. + * The emulated FF-A ABI is identified and invoked. + * FF-A emulation is based on the FF-A specification 1.0 + * + * Return: + * + * 0 on success. Otherwise, failure. + * FF-A protocol error codes are returned using the registers arguments as described + * by the specification + */ +void sandbox_arm_ffa_smccc_smc(ffa_value_t args, ffa_value_t *res) +{ + int ret = 0; + + switch (args.a0) { + case FFA_SMC_32(FFA_VERSION): + ret = sandbox_ffa_version(&args, res); + break; + case FFA_SMC_32(FFA_PARTITION_INFO_GET): + ret = sandbox_ffa_partition_info_get(&args, res); + break; + case FFA_SMC_32(FFA_RXTX_UNMAP): + ret = sandbox_ffa_rxtx_unmap(&args, res); + break; + case FFA_SMC_64(FFA_MSG_SEND_DIRECT_REQ): + ret = sandbox_ffa_msg_send_direct_req(&args, res); + break; + case FFA_SMC_32(FFA_ID_GET): + ret = sandbox_ffa_id_get(&args, res); + break; + case FFA_SMC_32(FFA_FEATURES): + ret = sandbox_ffa_features(&args, res); + break; + case FFA_SMC_64(FFA_RXTX_MAP): + ret = sandbox_ffa_rxtx_map(&args, res); + break; + case FFA_SMC_32(FFA_RX_RELEASE): + ret = sandbox_ffa_rx_release(&args, res); + break; + default: + ffa_err("[Sandbox] Undefined FF-A interface (0x%lx)", args.a0); + } + + if (ret != 0) + ffa_err("[Sandbox] FF-A ABI internal failure (%d)", ret); +} + +/** + * sandbox_ffa_probe - The driver probe function + * @dev: the sandbox_arm_ffa device + * + * Return: + * + * 0 on success. Otherwise, failure + */ +static int sandbox_ffa_probe(struct udevice *dev) +{ + return 0; +} + +/** + * sandbox_ffa_remove - The driver remove function + * @dev: the sandbox_arm_ffa device + * + * Return: + * + * 0 on success. Otherwise, failure + */ +static int sandbox_ffa_remove(struct udevice *dev) +{ + ffa_info("[Sandbox] removing the device"); + memset(&sandbox_ffa_priv_data, 0, sizeof(sandbox_ffa_priv_data)); + return 0; +} + +/** + * Declaring the sandbox_arm_ffa driver under UCLASS_FFA + */ +U_BOOT_DRIVER(sandbox_arm_ffa) = { + .name = FFA_SANDBOX_DRV_NAME, + .id = UCLASS_FFA, + .probe = sandbox_ffa_probe, + .remove = sandbox_ffa_remove, +}; diff --git a/drivers/firmware/arm-ffa/sandbox_arm_ffa_prv.h b/drivers/firmware/arm-ffa/sandbox_arm_ffa_prv.h new file mode 100644 index 0000000000..4db57f5092 --- /dev/null +++ b/drivers/firmware/arm-ffa/sandbox_arm_ffa_prv.h @@ -0,0 +1,144 @@ +/* SPDX-License-Identifier: GPL-2.0+ */ +/* + * (C) Copyright 2022 ARM Limited + * Abdellatif El Khlifi abdellatif.elkhlifi@arm.com + */ + +#ifndef __SANDBOX_ARM_FFA_PRV_H +#define __SANDBOX_ARM_FFA_PRV_H + +#include "arm_ffa_prv.h" +#include <sandbox_arm_ffa.h> + +/* + * This header is private. It is exclusively used by the Sandbox FF-A driver + */ + +/* FF-A core driver name */ +#define FFA_SANDBOX_DRV_NAME "sandbox_arm_ffa" + +/* FF-A ABIs internal error codes (as defined by the spec) */ + +#define FFA_ERR_STAT_NOT_SUPPORTED -1 +#define FFA_ERR_STAT_INVALID_PARAMETERS -2 +#define FFA_ERR_STAT_NO_MEMORY -3 +#define FFA_ERR_STAT_BUSY -4 +#define FFA_ERR_STAT_DENIED -6 + +/* Providing Arm SMCCC declarations to sandbox */ + +#define ARM_SMCCC_FAST_CALL 1UL +#define ARM_SMCCC_OWNER_STANDARD 4 +#define ARM_SMCCC_SMC_32 0 +#define ARM_SMCCC_SMC_64 1 +#define ARM_SMCCC_TYPE_SHIFT 31 +#define ARM_SMCCC_CALL_CONV_SHIFT 30 +#define ARM_SMCCC_OWNER_MASK 0x3F +#define ARM_SMCCC_OWNER_SHIFT 24 +#define ARM_SMCCC_FUNC_MASK 0xFFFF + +#define ARM_SMCCC_CALL_VAL(type, calling_convention, owner, func_num) \ + (((type) << ARM_SMCCC_TYPE_SHIFT) | \ + ((calling_convention) << ARM_SMCCC_CALL_CONV_SHIFT) | \ + (((owner) & ARM_SMCCC_OWNER_MASK) << ARM_SMCCC_OWNER_SHIFT) | \ + ((func_num) & ARM_SMCCC_FUNC_MASK)) + +/* Non-secure physical FF-A instance */ +#define NS_PHYS_ENDPOINT_ID (0) + +#define GET_NS_PHYS_ENDPOINT_ID_MASK GENMASK(31, 16) +#define GET_NS_PHYS_ENDPOINT_ID(x) \ + ((u16)(FIELD_GET(GET_NS_PHYS_ENDPOINT_ID_MASK, (x)))) + +/* Helper macro for reading the destination partition ID */ +#define GET_DST_SP_ID_MASK GENMASK(15, 0) +#define GET_DST_SP_ID(x) \ + ((u16)(FIELD_GET(GET_DST_SP_ID_MASK, (x)))) + +/* Helper macro for setting the source partition ID */ +#define PREP_SRC_SP_ID_MASK GENMASK(31, 16) +#define PREP_SRC_SP_ID(x) \ + (FIELD_PREP(PREP_SRC_SP_ID_MASK, (x))) + +/* Helper macro for setting the destination endpoint ID */ +#define PREP_NS_PHYS_ENDPOINT_ID_MASK GENMASK(15, 0) +#define PREP_NS_PHYS_ENDPOINT_ID(x) \ + (FIELD_PREP(PREP_NS_PHYS_ENDPOINT_ID_MASK, (x))) + +/* RX/TX buffers minimum size */ +#define RXTX_BUFFERS_MIN_SIZE (RXTX_4K) +#define RXTX_BUFFERS_MIN_PAGES (1) + +/* MBZ registers info */ + +/* x1-x7 MBZ */ +#define FFA_X1X7_MBZ_CNT (7) +#define FFA_X1X7_MBZ_REG_START (&res->a1) + +/* x4-x7 MBZ */ +#define FFA_X4X7_MBZ_CNT (4) +#define FFA_X4X7_MBZ_REG_START (&res->a4) + +/* x3-x7 MBZ */ +#define FFA_X3X7_MBZ_CNT (5) +#define FFA_X3_MBZ_REG_START (&res->a3) + +/* secure partitions count */ +#define SANDBOX_PARTITIONS_CNT (4) + +/* service 1 UUID binary data (little-endian format) */ +#define SANDBOX_SERVICE1_UUID_A1 0xed32d533 +#define SANDBOX_SERVICE1_UUID_A2 0x99e64209 +#define SANDBOX_SERVICE1_UUID_A3 0x9cc02d72 +#define SANDBOX_SERVICE1_UUID_A4 0xcdd998a7 + +/* service 2 UUID binary data (little-endian format) */ +#define SANDBOX_SERVICE2_UUID_A1 0xed32d544 +#define SANDBOX_SERVICE2_UUID_A2 0x99e64209 +#define SANDBOX_SERVICE2_UUID_A3 0x9cc02d72 +#define SANDBOX_SERVICE2_UUID_A4 0xcdd998a7 + +/** + * struct ffa_rxtxpair_info - structure hosting the RX/TX buffers flags + * @rxbuf_owned: RX buffer ownership flag (the owner is non secure world: the consumer) + * @rxbuf_mapped: RX buffer mapping flag + * @txbuf_owned TX buffer ownership flag + * @txbuf_mapped: TX buffer mapping flag + * @rxtx_buf_size: RX/TX buffers size as set by the FF-A core driver + * + * Data structure hosting the ownership/mapping flags of the RX/TX buffers + * When a buffer is owned/mapped its corresponding flag is set to 1 otherwise 0. + */ +struct ffa_rxtxpair_info { + u8 rxbuf_owned; + u8 rxbuf_mapped; + u8 txbuf_owned; + u8 txbuf_mapped; + u32 rxtx_buf_size; +}; + +/** + * struct sandbox_ffa_prvdata - the driver private data structure + * + * @dev: The arm_ffa device under u-boot driver model + * @fwk_version: FF-A framework version + * @id: u-boot endpoint ID + * @partitions: The partitions descriptors structure + * @pair: The RX/TX buffers pair + * @pair_info: The RX/TX buffers pair flags and size + * @conduit: The selected conduit + * + * The driver data structure hosting all the emulated secure world data. + */ +struct sandbox_ffa_prvdata { + struct udevice *dev; + u32 fwk_version; + u16 id; + struct ffa_partitions partitions; + struct ffa_rxtxpair pair; + struct ffa_rxtxpair_info pair_info; +}; + +#define SANDBOX_SMC_FFA_ABI(ffabi) static int sandbox_##ffabi(ffa_value_t *pargs, ffa_value_t *res) + +#endif diff --git a/include/arm_ffa.h b/include/arm_ffa.h index f17b100497..665413a0c5 100644 --- a/include/arm_ffa.h +++ b/include/arm_ffa.h @@ -111,7 +111,7 @@ struct ffa_bus_ops { const struct ffa_bus_ops * __ffa_runtime ffa_bus_ops_get(void);
/** - * ffa_bus_discover - discover FF-A bus and probes the arm_ffa device + * ffa_bus_discover - discover FF-A bus and probes the arm_ffa and sandbox_arm_ffa devices */ int ffa_bus_discover(void);
diff --git a/include/sandbox_arm_ffa.h b/include/sandbox_arm_ffa.h new file mode 100644 index 0000000000..d5df16f282 --- /dev/null +++ b/include/sandbox_arm_ffa.h @@ -0,0 +1,91 @@ +/* SPDX-License-Identifier: GPL-2.0+ */ +/* + * (C) Copyright 2022 ARM Limited + * Abdellatif El Khlifi abdellatif.elkhlifi@arm.com + */ + +#ifndef __SANDBOX_ARM_FFA_H +#define __SANDBOX_ARM_FFA_H + +#include <arm_ffa.h> + +/** + * struct sandbox_smccc_1_2_regs - Arguments for or Results from emulated SMC call + * @a0-a17 argument values from registers 0 to 17 + */ +struct sandbox_smccc_1_2_regs { + unsigned long a0; + unsigned long a1; + unsigned long a2; + unsigned long a3; + unsigned long a4; + unsigned long a5; + unsigned long a6; + unsigned long a7; + unsigned long a8; + unsigned long a9; + unsigned long a10; + unsigned long a11; + unsigned long a12; + unsigned long a13; + unsigned long a14; + unsigned long a15; + unsigned long a16; + unsigned long a17; +}; + +typedef struct sandbox_smccc_1_2_regs ffa_value_t; + +/* UUIDs of services supported by the sandbox driver */ +#define SANDBOX_SERVICE1_UUID "ed32d533-4209-99e6-2d72-cdd998a79cc0" +#define SANDBOX_SERVICE2_UUID "ed32d544-4209-99e6-2d72-cdd998a79cc0" +#define SANDBOX_SP1_ID 0x1245 +#define SANDBOX_SP2_ID 0x9836 +#define SANDBOX_SP3_ID 0x6452 +#define SANDBOX_SP4_ID 0x7814 + +/* invalid service UUID (no matching SP) */ +#define SANDBOX_SERVICE3_UUID "55d532ed-0942-e699-722d-c09ca798d9cd" + +/* invalid service UUID (invalid UUID string format) */ +#define SANDBOX_SERVICE4_UUID "32ed-0942-e699-722d-c09ca798d9cd" + +#define SANDBOX_SP_COUNT_PER_VALID_SERVICE 2 + +/** + * struct ffa_sandbox_data - generic data structure used to exchange + * data between test cases and the sandbox driver + * @data0_size: size of the first argument + * @data0: pointer to the first argument + * @data1_size>: size of the second argument + * @data1: pointer to the second argument + * + * Using this structure sandbox test cases can pass various types of data with different sizes. + */ +struct ffa_sandbox_data { + u32 data0_size; /* size of the first argument */ + void *data0; /* pointer to the first argument */ + u32 data1_size; /* size of the second argument */ + void *data1; /* pointer to the second argument */ +}; + +/** + * The sandbox driver public functions + */ + +/** + * sandbox_ffa_query_core_state - Queries the status of FF-A ABIs + */ +int sandbox_ffa_query_core_state(u32 queried_func_id, struct ffa_sandbox_data *func_data); + +/** + * sandbox_ffa_get_device - create, bind and probe the sandbox_arm_ffa device + */ +int sandbox_ffa_device_get(void); + +/** + * sandbox_arm_ffa_smccc_smc - FF-A SMC call emulation + */ +void sandbox_arm_ffa_smccc_smc(ffa_value_t args, ffa_value_t *res); + +#endif diff --git a/lib/efi_loader/efi_boottime.c b/lib/efi_loader/efi_boottime.c index af0b0f3db1..d404343a7d 100644 --- a/lib/efi_loader/efi_boottime.c +++ b/lib/efi_loader/efi_boottime.c @@ -2185,7 +2185,7 @@ static efi_status_t EFIAPI efi_exit_boot_services(efi_handle_t image_handle, dm_remove_devices_flags(DM_REMOVE_ACTIVE_ALL); }
-#if CONFIG_IS_ENABLED(ARM_FFA_TRANSPORT) +#if CONFIG_IS_ENABLED(ARM_FFA_TRANSPORT) && !CONFIG_IS_ENABLED(SANDBOX_FFA) /* unmap FF-A RX/TX buffers */ if (ffa_bus_ops_get()->rxtx_unmap()) debug("[efi_boottime][ERROR]: can not unmap FF-A RX/TX buffers\n");
Add functional test cases for the FF-A core driver
These tests rely on the FF-A Sandbox driver which helps in inspecting the FF-A core driver.
v4: align sandbox tests with the new FF-A driver interfaces and new way of error handling
v1: introduce sandbox tests
MAINTAINERS | 1 + test/dm/Makefile | 2 + test/dm/ffa.c | 394 +++++++++++++++++++++++++++++++++++++++++++++++ 3 files changed, 397 insertions(+) create mode 100644 test/dm/ffa.c
diff --git a/MAINTAINERS b/MAINTAINERS index 6f01002e34..8c0dfff5f8 100644 --- a/MAINTAINERS +++ b/MAINTAINERS @@ -256,6 +256,7 @@ F: doc/README.ffa.drv F: drivers/firmware/arm-ffa/ F: include/arm_ffa.h F: include/sandbox_arm_ffa.h +F: test/dm/ffa.c
ARM FREESCALE IMX M: Stefano Babic sbabic@denx.de diff --git a/test/dm/Makefile b/test/dm/Makefile index 7543df8823..e5a791768e 100644 --- a/test/dm/Makefile +++ b/test/dm/Makefile @@ -1,6 +1,7 @@ # SPDX-License-Identifier: GPL-2.0+ # # Copyright (c) 2013 Google, Inc +# (C) Copyright 2022 ARM Limited
obj-$(CONFIG_UT_DM) += test-dm.o
@@ -81,6 +82,7 @@ obj-$(CONFIG_POWER_DOMAIN) += power-domain.o obj-$(CONFIG_ACPI_PMC) += pmc.o obj-$(CONFIG_DM_PMIC) += pmic.o obj-$(CONFIG_DM_PWM) += pwm.o +obj-$(CONFIG_SANDBOX_FFA) += ffa.o obj-$(CONFIG_QFW) += qfw.o obj-$(CONFIG_RAM) += ram.o obj-y += regmap.o diff --git a/test/dm/ffa.c b/test/dm/ffa.c new file mode 100644 index 0000000000..052d5fc3f4 --- /dev/null +++ b/test/dm/ffa.c @@ -0,0 +1,394 @@ +// SPDX-License-Identifier: GPL-2.0+ +/* + * Functional tests for UCLASS_FFA class + * + * (C) Copyright 2022 ARM Limited + * Abdellatif El Khlifi abdellatif.elkhlifi@arm.com + */ + +#include <common.h> +#include <console.h> +#include <dm.h> +#include <dm/test.h> +#include "../../drivers/firmware/arm-ffa/sandbox_arm_ffa_prv.h" +#include <sandbox_arm_ffa.h> +#include <test/test.h> +#include <test/ut.h> + +/* Macros */ + +#define LOG_MSG_SZ (100) +#define LOG_CMD_SZ (LOG_MSG_SZ * 2) + +/* Functional tests for the UCLASS_FFA */ + +static int dm_test_ffa_log(struct unit_test_state *uts, char *msg) +{ + char cmd[LOG_CMD_SZ] = {0}; + + console_record_reset(); + + snprintf(cmd, LOG_CMD_SZ, "echo "%s"", msg); + run_command(cmd, 0); + + ut_assert_console_end(); + + return CMD_RET_SUCCESS; +} + +static int check_fwk_version(struct ffa_prvdata *prvdata, struct sandbox_ffa_prvdata *sdx_prvdata, + struct unit_test_state *uts) +{ + if (prvdata->fwk_version != sdx_prvdata->fwk_version) { + char msg[LOG_MSG_SZ] = {0}; + + snprintf(msg, LOG_MSG_SZ, + "[%s]: Error: framework version: core = 0x%x , sandbox = 0x%x", __func__, + prvdata->fwk_version, + sdx_prvdata->fwk_version); + + dm_test_ffa_log(uts, msg); + return CMD_RET_FAILURE; + } + return CMD_RET_SUCCESS; +} + +static int check_endpoint_id(struct ffa_prvdata *prvdata, struct unit_test_state *uts) +{ + if (prvdata->id) { + char msg[LOG_MSG_SZ] = {0}; + + snprintf(msg, LOG_MSG_SZ, + "[%s]: Error: endpoint id: core = 0x%x", __func__, prvdata->id); + dm_test_ffa_log(uts, msg); + return CMD_RET_FAILURE; + } + return CMD_RET_SUCCESS; +} + +static int check_core_dev(struct ffa_prvdata *prvdata, struct unit_test_state *uts) +{ + if (!prvdata->dev) { + char msg[LOG_MSG_SZ] = {0}; + + snprintf(msg, LOG_MSG_SZ, "[%s]: Error: core device NULL", __func__); + dm_test_ffa_log(uts, msg); + return CMD_RET_FAILURE; + } + return CMD_RET_SUCCESS; +} + +static int check_sandbox_dev(struct sandbox_ffa_prvdata *sdx_prvdata, struct unit_test_state *uts) +{ + if (!sdx_prvdata->dev) { + char msg[LOG_MSG_SZ] = {0}; + + snprintf(msg, LOG_MSG_SZ, "[%s]: Error: sandbox device NULL", __func__); + dm_test_ffa_log(uts, msg); + return CMD_RET_FAILURE; + } + return CMD_RET_SUCCESS; +} + +static int check_rxtxbuf(struct ffa_prvdata *prvdata, struct unit_test_state *uts) +{ + if (!prvdata->pair.rxbuf && prvdata->pair.txbuf) { + char msg[LOG_MSG_SZ] = {0}; + + snprintf(msg, LOG_MSG_SZ, "[%s]: Error: rxbuf = 0x%llx txbuf = 0x%llx", __func__, + prvdata->pair.rxbuf, + prvdata->pair.txbuf); + dm_test_ffa_log(uts, msg); + return CMD_RET_FAILURE; + } + return CMD_RET_SUCCESS; +} + +static int check_features(struct ffa_prvdata *prvdata, struct unit_test_state *uts) +{ + char msg[LOG_MSG_SZ] = {0}; + + if (prvdata->pair.rxtx_min_pages != RXTX_4K && + prvdata->pair.rxtx_min_pages != RXTX_16K && + prvdata->pair.rxtx_min_pages != RXTX_64K) { + snprintf(msg, + LOG_MSG_SZ, + "[%s]: Error: FFA_RXTX_MAP features = 0x%lx", + __func__, + prvdata->pair.rxtx_min_pages); + dm_test_ffa_log(uts, msg); + return CMD_RET_FAILURE; + } + + return CMD_RET_SUCCESS; +} + +static int check_rxbuf_mapped_flag(u32 queried_func_id, + u8 rxbuf_mapped, + struct unit_test_state *uts) +{ + char msg[LOG_MSG_SZ] = {0}; + + switch (queried_func_id) { + case FFA_RXTX_MAP: + { + if (rxbuf_mapped) + return CMD_RET_SUCCESS; + break; + } + case FFA_RXTX_UNMAP: + { + if (!rxbuf_mapped) + return CMD_RET_SUCCESS; + break; + } + default: + return CMD_RET_FAILURE; + } + + snprintf(msg, LOG_MSG_SZ, "[%s]: Error: %s mapping issue", __func__, + (queried_func_id == FFA_RXTX_MAP ? "FFA_RXTX_MAP" : "FFA_RXTX_UNMAP")); + dm_test_ffa_log(uts, msg); + + return CMD_RET_FAILURE; +} + +static int check_rxbuf_release_flag(u8 rxbuf_owned, struct unit_test_state *uts) +{ + if (rxbuf_owned) { + char msg[LOG_MSG_SZ] = {0}; + + snprintf(msg, LOG_MSG_SZ, "[%s]: Error: RX buffer not released", __func__); + dm_test_ffa_log(uts, msg); + return CMD_RET_FAILURE; + } + return CMD_RET_SUCCESS; +} + +static int test_ffa_msg_send_direct_req(u16 part_id, struct unit_test_state *uts) +{ + struct ffa_send_direct_data msg = {0}; + u8 cnt; + + ut_assertok(ffa_bus_ops_get()->sync_send_receive(part_id, &msg)); + + for (cnt = 0; cnt < sizeof(struct ffa_send_direct_data) / sizeof(u64); cnt++) + ut_assertok(((u64 *)&msg)[cnt] != 0xffffffffffffffff); + + return CMD_RET_SUCCESS; +} + +static int test_partitions_and_comms(const char *service_uuid, + struct sandbox_ffa_prvdata *sdx_prvdata, + struct unit_test_state *uts) +{ + u32 count = 0, size = 0; + struct ffa_partition_info *parts_info; + u32 info_idx, exp_info_idx; + int ret; + + /* + * get from the driver the count of the SPs matching the UUID + */ + ret = ffa_bus_ops_get()->partition_info_get(service_uuid, &count, NULL); + /* make sure partitions are detected */ + ut_assertok(ret != 0); + ut_assertok(count != SANDBOX_SP_COUNT_PER_VALID_SERVICE); + + /* + * pre-allocate a buffer to be filled by the driver + * with ffa_partition_info structs + */ + + parts_info = calloc(count, sizeof(struct ffa_partition_info)); + ut_assertok(!parts_info); + + size = count * sizeof(struct ffa_partition_info); + + /* + * ask the driver to fill the buffer with the SPs info + */ + ret = ffa_bus_ops_get()->partition_info_get(service_uuid, &size, parts_info); + if (ret != 0) { + free(parts_info); + ut_assertok(ret != 0); + } + + /* + * SPs found , verify the partitions information + */ + + ret = CMD_RET_FAILURE; + + for (info_idx = 0; info_idx < count ; info_idx++) { + for (exp_info_idx = 0; + exp_info_idx < sdx_prvdata->partitions.count; + exp_info_idx++) { + if (parts_info[info_idx].id == + sdx_prvdata->partitions.descs[exp_info_idx].info.id) { + ret = memcmp(&parts_info[info_idx], + &sdx_prvdata->partitions.descs[exp_info_idx] + .info, + sizeof(struct ffa_partition_info)); + if (ret) + free(parts_info); + ut_assertok(ret != 0); + /* send and receive data from the current partition */ + test_ffa_msg_send_direct_req(parts_info[info_idx].id, uts); + } + ret = CMD_RET_SUCCESS; + } + } + + free(parts_info); + + /* Verify expected partitions found in the emulated secure world*/ + ut_assertok(ret != CMD_RET_SUCCESS); + + return CMD_RET_SUCCESS; +} + +static int dm_test_ffa_ack(struct unit_test_state *uts) +{ + struct ffa_prvdata *prvdata = NULL; + struct sandbox_ffa_prvdata *sdx_prvdata = NULL; + struct ffa_sandbox_data func_data = {0}; + u8 rxbuf_flag = 0; + const char *svc1_uuid = SANDBOX_SERVICE1_UUID; + const char *svc2_uuid = SANDBOX_SERVICE2_UUID; + int ret; + + /* test probing FF-A devices */ + ut_assertok(ffa_bus_discover()); + + /* get a pointer to the FF-A core and sandbox drivers private data */ + func_data.data0 = &prvdata; + func_data.data0_size = sizeof(prvdata); + func_data.data1 = &sdx_prvdata; + func_data.data1_size = sizeof(sdx_prvdata); + + ut_assertok(sandbox_ffa_query_core_state(FFA_VERSION, &func_data)); + + /* make sure private data pointers are retrieved */ + ut_assertok(prvdata == 0); + ut_assertok(sdx_prvdata == 0); + + /* make sure dev devices created */ + ut_assertok(check_core_dev(prvdata, uts)); + ut_assertok(check_sandbox_dev(sdx_prvdata, uts)); + + /* test FFA_VERSION */ + ut_assertok(check_fwk_version(prvdata, sdx_prvdata, uts)); + + /* test FFA_ID_GET */ + ut_assertok(check_endpoint_id(prvdata, uts)); + + /* test FFA_FEATURES */ + ut_assertok(check_features(prvdata, uts)); + + /* test core RX/TX buffers */ + ut_assertok(check_rxtxbuf(prvdata, uts)); + + /* test FFA_RXTX_MAP */ + func_data.data0 = &rxbuf_flag; + func_data.data0_size = sizeof(rxbuf_flag); + + rxbuf_flag = 0; + ut_assertok(sandbox_ffa_query_core_state(FFA_RXTX_MAP, &func_data)); + ut_assertok(check_rxbuf_mapped_flag(FFA_RXTX_MAP, rxbuf_flag, uts)); + + /* FFA_PARTITION_INFO_GET / FFA_MSG_SEND_DIRECT_REQ */ + ret = test_partitions_and_comms(svc1_uuid, sdx_prvdata, uts); + ut_assertok(ret != CMD_RET_SUCCESS); + + /* test FFA_RX_RELEASE */ + rxbuf_flag = 1; + ut_assertok(sandbox_ffa_query_core_state(FFA_RX_RELEASE, &func_data)); + ut_assertok(check_rxbuf_release_flag(rxbuf_flag, uts)); + + /* FFA_PARTITION_INFO_GET / FFA_MSG_SEND_DIRECT_REQ */ + ret = test_partitions_and_comms(svc2_uuid, sdx_prvdata, uts); + ut_assertok(ret != CMD_RET_SUCCESS); + + /* test FFA_RX_RELEASE */ + rxbuf_flag = 1; + ut_assertok(sandbox_ffa_query_core_state(FFA_RX_RELEASE, &func_data)); + ut_assertok(check_rxbuf_release_flag(rxbuf_flag, uts)); + + /* test FFA_RXTX_UNMAP */ + ut_assertok(ffa_bus_ops_get()->rxtx_unmap()); + + rxbuf_flag = 1; + ut_assertok(sandbox_ffa_query_core_state(FFA_RXTX_UNMAP, &func_data)); + ut_assertok(check_rxbuf_mapped_flag(FFA_RXTX_UNMAP, rxbuf_flag, uts)); + + return CMD_RET_SUCCESS; +} + +DM_TEST(dm_test_ffa_ack, UT_TESTF_SCAN_FDT | UT_TESTF_CONSOLE_REC); + +static int dm_test_ffa_nack(struct unit_test_state *uts) +{ + struct ffa_prvdata *prvdata = NULL; + struct sandbox_ffa_prvdata *sdx_prvdata = NULL; + struct ffa_sandbox_data func_data = {0}; + const char *valid_svc_uuid = SANDBOX_SERVICE1_UUID; + const char *unvalid_svc_uuid = SANDBOX_SERVICE3_UUID; + const char *unvalid_svc_uuid_str = SANDBOX_SERVICE4_UUID; + struct ffa_send_direct_data msg = {0}; + int ret; + u32 count = 0; + u16 part_id = 0; + + /* test probing FF-A devices */ + ut_assertok(ffa_bus_discover()); + + /* get a pointer to the FF-A core and sandbox drivers private data */ + func_data.data0 = &prvdata; + func_data.data0_size = sizeof(prvdata); + func_data.data1 = &sdx_prvdata; + func_data.data1_size = sizeof(sdx_prvdata); + + ut_assertok(sandbox_ffa_query_core_state(FFA_VERSION, &func_data)); + + /* make sure private data pointers are retrieved */ + ut_assertok(prvdata == 0); + ut_assertok(sdx_prvdata == 0); + + /* make sure dev devices created */ + ut_assertok(check_core_dev(prvdata, uts)); + ut_assertok(check_sandbox_dev(sdx_prvdata, uts)); + + /* query partitions count using invalid arguments */ + ret = ffa_bus_ops_get()->partition_info_get(unvalid_svc_uuid, NULL, NULL); + ut_assertok(ret != -EINVAL); + + /* query partitions count using an invalid UUID string */ + ret = ffa_bus_ops_get()->partition_info_get(unvalid_svc_uuid_str, &count, NULL); + ut_assertok(ret != -EINVAL); + + /* query partitions count using an invalid UUID (no matching SP) */ + count = 0; + ret = ffa_bus_ops_get()->partition_info_get(unvalid_svc_uuid, &count, NULL); + ut_assertok(count != 0); + + /* query partitions count using a valid UUID */ + count = 0; + ret = ffa_bus_ops_get()->partition_info_get(valid_svc_uuid, &count, NULL); + /* make sure partitions are detected */ + ut_assertok(ret != 0); + ut_assertok(count != SANDBOX_SP_COUNT_PER_VALID_SERVICE); + + /* send data to an invalid partition */ + ret = ffa_bus_ops_get()->sync_send_receive(part_id, &msg); + ut_assertok(ret != -EINVAL); + + /* send data to a valid partition */ + part_id = prvdata->partitions.descs[0].info.id; + ret = ffa_bus_ops_get()->sync_send_receive(part_id, &msg); + ut_assertok(ret != 0); + + return CMD_RET_SUCCESS; +} + +DM_TEST(dm_test_ffa_nack, UT_TESTF_SCAN_FDT | UT_TESTF_CONSOLE_REC);
Add Sandbox test for the armffa command
v4: drop use of helper APIs
v1: introduce armffa command sandbox test
MAINTAINERS | 1 + test/cmd/Makefile | 2 ++ test/cmd/armffa.c | 40 ++++++++++++++++++++++++++++++++++++++++ 3 files changed, 43 insertions(+) create mode 100644 test/cmd/armffa.c
diff --git a/MAINTAINERS b/MAINTAINERS index 8c0dfff5f8..8ed94da4c8 100644 --- a/MAINTAINERS +++ b/MAINTAINERS @@ -256,6 +256,7 @@ F: doc/README.ffa.drv F: drivers/firmware/arm-ffa/ F: include/arm_ffa.h F: include/sandbox_arm_ffa.h +F: test/cmd/armffa.c F: test/dm/ffa.c
ARM FREESCALE IMX diff --git a/test/cmd/Makefile b/test/cmd/Makefile index c331757425..19e9d0a995 100644 --- a/test/cmd/Makefile +++ b/test/cmd/Makefile @@ -1,6 +1,7 @@ # SPDX-License-Identifier: GPL-2.0+ # # Copyright (c) 2013 Google, Inc +# (C) Copyright 2022 ARM Limited
ifdef CONFIG_HUSH_PARSER obj-$(CONFIG_CONSOLE_RECORD) += test_echo.o @@ -13,3 +14,4 @@ obj-$(CONFIG_CMD_MEM_SEARCH) += mem_search.o obj-$(CONFIG_CMD_PINMUX) += pinmux.o obj-$(CONFIG_CMD_PWM) += pwm.o obj-$(CONFIG_CMD_SETEXPR) += setexpr.o +obj-$(CONFIG_SANDBOX_FFA) += armffa.o diff --git a/test/cmd/armffa.c b/test/cmd/armffa.c new file mode 100644 index 0000000000..531f82066e --- /dev/null +++ b/test/cmd/armffa.c @@ -0,0 +1,40 @@ +// SPDX-License-Identifier: GPL-2.0+ +/* + * Test for armffa command + * + * (C) Copyright 2022 ARM Limited + * Abdellatif El Khlifi abdellatif.elkhlifi@arm.com + */ + +#include <common.h> +#include <dm.h> +#include <dm/test.h> +#include <sandbox_arm_ffa.h> +#include <string.h> +#include <test/test.h> +#include <test/ut.h> + +#define PING_CMD_SIZE 19 + +/* Basic test of 'armffa' command */ +static int dm_test_armffa_cmd(struct unit_test_state *uts) +{ + char ping_cmd[PING_CMD_SIZE] = {0}; + + ut_assertok(ffa_bus_discover()); + + /* armffa getpart <UUID> */ + ut_assertok(run_command("armffa getpart " SANDBOX_SERVICE1_UUID, 0)); + + snprintf(ping_cmd, PING_CMD_SIZE, "armffa ping 0x%x", SANDBOX_SP1_ID); + + /* armffa ping <ID> */ + ut_assertok(run_command(ping_cmd, 0)); + + /* armffa devlist */ + ut_assertok(run_command("armffa devlist", 0)); + + return CMD_RET_SUCCESS; +} + +DM_TEST(dm_test_armffa_cmd, UT_TESTF_SCAN_FDT | UT_TESTF_CONSOLE_REC);
Add MM communication support using FF-A transport
This feature allows accessing MM partitions services through EFI MM communication protocol. MM partitions such as StandAlonneMM or smm-gateway secure partitions which reside in secure world.
An MM shared buffer and a door bell event are used to exchange the data.
The data is used by EFI services such as GetVariable()/SetVariable() and copied from the communication buffer to the MM shared buffer.
The secure partition is notified about availability of data in the MM shared buffer by an FF-A message (door bell).
On such event, MM SP can read the data and updates the MM shared buffer with the response data.
The response data is copied back to the communication buffer and consumed by the EFI subsystem.
FF-A driver private data is copied to EFI runtime section at ExitBootServices(). This garantees secure world partitions data are available at EFI runtime level.
Signed-off-by: Abdellatif El Khlifi abdellatif.elkhlifi@arm.com Signed-off-by: Gowtham Suresh Kumar gowtham.sureshkumar@arm.com Cc: Tom Rini trini@konsulko.com Cc: Simon Glass sjg@chromium.org Cc: Ilias Apalodimas ilias.apalodimas@linaro.org Cc: Jens Wiklander jens.wiklander@linaro.org
v4:
* use the new FF-A driver interfaces * discover MM partitions at runtime * copy FF-A driver private data to EFI runtime section at ExitBootServices() * drop use of FFA_ERR_STAT_SUCCESS error code * replace EFI_BUFFER_TOO_SMALL with EFI_OUT_OF_RESOURCES in ffa_mm_communicate(). No need for efi_memcpy_runtime() anymore * revert the error log in mm_communicate() in case of failure * remove packed attribute from efi_mm_communicate_header and smm_variable_communicate_header
v2:
* set default values to 0 for FFA_SHARED_MM_BUFFER_SIZE, FFA_SHARED_MM_BUFFER_ADDR and MM_SP_UUID_DATA and add warnings
v1:
* introduce FF-A MM communication
arch/arm/cpu/armv8/cache.S | 19 +++ arch/arm/cpu/armv8/cache_v8.c | 6 +- include/mm_communication.h | 9 +- lib/efi_loader/Kconfig | 14 +- lib/efi_loader/efi_boottime.c | 7 + lib/efi_loader/efi_variable_tee.c | 263 +++++++++++++++++++++++++++++- 6 files changed, 309 insertions(+), 9 deletions(-)
diff --git a/arch/arm/cpu/armv8/cache.S b/arch/arm/cpu/armv8/cache.S index d1cee23437..91b7c73c17 100644 --- a/arch/arm/cpu/armv8/cache.S +++ b/arch/arm/cpu/armv8/cache.S @@ -3,6 +3,9 @@ * (C) Copyright 2013 * David Feng fenghua@phytium.com.cn * + * (C) Copyright 2022 ARM Limited + * Abdellatif El Khlifi abdellatif.elkhlifi@arm.com + * * This file is based on sample code from ARMv8 ARM. */
@@ -21,7 +24,11 @@ * x1: 0 clean & invalidate, 1 invalidate only * x2~x9: clobbered */ +#ifdef CONFIG_EFI_LOADER +.pushsection .text.efi_runtime, "ax" +#else .pushsection .text.__asm_dcache_level, "ax" +#endif ENTRY(__asm_dcache_level) lsl x12, x0, #1 msr csselr_el1, x12 /* select cache level */ @@ -65,7 +72,11 @@ ENDPROC(__asm_dcache_level) * * flush or invalidate all data cache by SET/WAY. */ +#ifdef CONFIG_EFI_LOADER +.pushsection .text.efi_runtime, "ax" +#else .pushsection .text.__asm_dcache_all, "ax" +#endif ENTRY(__asm_dcache_all) mov x1, x0 dsb sy @@ -109,7 +120,11 @@ ENTRY(__asm_flush_dcache_all) ENDPROC(__asm_flush_dcache_all) .popsection
+#ifdef CONFIG_EFI_LOADER +.pushsection .text.efi_runtime, "ax" +#else .pushsection .text.__asm_invalidate_dcache_all, "ax" +#endif ENTRY(__asm_invalidate_dcache_all) mov x0, #0x1 b __asm_dcache_all @@ -182,7 +197,11 @@ ENTRY(__asm_invalidate_icache_all) ENDPROC(__asm_invalidate_icache_all) .popsection
+#ifdef CONFIG_EFI_LOADER +.pushsection .text.efi_runtime, "ax" +#else .pushsection .text.__asm_invalidate_l3_dcache, "ax" +#endif WEAK(__asm_invalidate_l3_dcache) mov x0, #0 /* return status as success */ ret diff --git a/arch/arm/cpu/armv8/cache_v8.c b/arch/arm/cpu/armv8/cache_v8.c index e4736e5643..45f57372c2 100644 --- a/arch/arm/cpu/armv8/cache_v8.c +++ b/arch/arm/cpu/armv8/cache_v8.c @@ -5,10 +5,14 @@ * * (C) Copyright 2016 * Alexander Graf agraf@suse.de + * + * (C) Copyright 2022 ARM Limited + * Abdellatif El Khlifi abdellatif.elkhlifi@arm.com */
#include <common.h> #include <cpu_func.h> +#include <efi_loader.h> #include <hang.h> #include <log.h> #include <asm/cache.h> @@ -445,7 +449,7 @@ __weak void mmu_setup(void) /* * Performs a invalidation of the entire data cache at all levels */ -void invalidate_dcache_all(void) +void __efi_runtime invalidate_dcache_all(void) { __asm_invalidate_dcache_all(); __asm_invalidate_l3_dcache(); diff --git a/include/mm_communication.h b/include/mm_communication.h index e65fbde60d..fe9104c56d 100644 --- a/include/mm_communication.h +++ b/include/mm_communication.h @@ -6,6 +6,8 @@ * Copyright (c) 2017, Intel Corporation. All rights reserved. * Copyright (C) 2020 Linaro Ltd. sughosh.ganu@linaro.org * Copyright (C) 2020 Linaro Ltd. ilias.apalodimas@linaro.org + * (C) Copyright 2022 ARM Limited + * Abdellatif El Khlifi abdellatif.elkhlifi@arm.com */
#ifndef _MM_COMMUNICATION_H_ @@ -13,6 +15,9 @@
#include <part_efi.h>
+/* MM service UUID string (big-endian format). This UUID is common across all MM SPs */ +#define MM_SP_UUID "33d532ed-e699-0942-c09c-a798d9cd722d" + /* * Interface to the pseudo Trusted Application (TA), which provides a * communication channel with the Standalone MM (Management Mode) @@ -43,7 +48,7 @@ * To avoid confusion in interpreting frames, the communication buffer should * always begin with efi_mm_communicate_header. */ -struct __packed efi_mm_communicate_header { +struct efi_mm_communicate_header { efi_guid_t header_guid; size_t message_len; u8 data[]; @@ -145,7 +150,7 @@ struct smm_variable_communicate_header { * Defined in EDK2 as SMM_VARIABLE_COMMUNICATE_ACCESS_VARIABLE. * */ -struct smm_variable_access { +struct __packed smm_variable_access { efi_guid_t guid; efi_uintn_t data_size; efi_uintn_t name_size; diff --git a/lib/efi_loader/Kconfig b/lib/efi_loader/Kconfig index b8fb2701a7..d292f57244 100644 --- a/lib/efi_loader/Kconfig +++ b/lib/efi_loader/Kconfig @@ -61,13 +61,23 @@ config EFI_VARIABLE_FILE_STORE stored as file /ubootefi.var on the EFI system partition.
config EFI_MM_COMM_TEE - bool "UEFI variables storage service via OP-TEE" - depends on OPTEE + bool "UEFI variables storage service via the trusted world" + depends on OPTEE || ARM_FFA_TRANSPORT help + Allowing access to the MM SP services (SPs such as StandAlonneMM, smm-gateway). + When using the u-boot OP-TEE driver, StandAlonneMM is supported. + When using the u-boot FF-A driver any MM SP is supported. + If OP-TEE is present and running StandAloneMM, dispatch all UEFI variable related operations to that. The application will verify, authenticate and store the variables on an RPMB.
+ When ARM_FFA_TRANSPORT is used, dispatch all UEFI variable related + operations to the MM SP running in the secure world. + A door bell mechanism is used to notify the SP when there is data in the shared + MM buffer. The data is copied by u-boot to the shared buffer before issuing + the door bell event. + config EFI_VARIABLE_NO_STORE bool "Don't persist non-volatile UEFI variables" help diff --git a/lib/efi_loader/efi_boottime.c b/lib/efi_loader/efi_boottime.c index d404343a7d..8a397ea21b 100644 --- a/lib/efi_loader/efi_boottime.c +++ b/lib/efi_loader/efi_boottime.c @@ -2193,6 +2193,13 @@ static efi_status_t EFIAPI efi_exit_boot_services(efi_handle_t image_handle, debug("[efi_boottime][INFO]: FF-A RX/TX buffers unmapped\n"); #endif
+#if CONFIG_IS_ENABLED(ARM_FFA_EFI_RUNTIME_MODE) && !CONFIG_IS_ENABLED(SANDBOX_FFA) + if (ffa_copy_runtime_data()) + printf("ERROR: EFI: FFA: copying runtime data\n"); + else + printf("INFO: EFI: FFA: runtime data copied\n"); +#endif + /* Patch out unsupported runtime function */ efi_runtime_detach();
diff --git a/lib/efi_loader/efi_variable_tee.c b/lib/efi_loader/efi_variable_tee.c index dfef18435d..d6f24f85bd 100644 --- a/lib/efi_loader/efi_variable_tee.c +++ b/lib/efi_loader/efi_variable_tee.c @@ -4,6 +4,8 @@ * * Copyright (C) 2019 Linaro Ltd. sughosh.ganu@linaro.org * Copyright (C) 2019 Linaro Ltd. ilias.apalodimas@linaro.org + * Copyright (C) 2022 ARM Limited + * Abdellatif El Khlifi abdellatif.elkhlifi@arm.com */
#include <common.h> @@ -15,6 +17,36 @@ #include <malloc.h> #include <mm_communication.h>
+#if (IS_ENABLED(CONFIG_ARM_FFA_TRANSPORT)) + +#include <arm_ffa.h> +#include <cpu_func.h> +#include <mapmem.h> + +#ifndef FFA_SHARED_MM_BUFFER_SIZE +#warning "FFA_SHARED_MM_BUFFER_SIZE must be defined in include/configs/<board>.h" +#define FFA_SHARED_MM_BUFFER_SIZE 0 +#endif + +#ifndef FFA_SHARED_MM_BUFFER_OFFSET +#warning "FFA_SHARED_MM_BUFFER_OFFSET must be defined in include/configs/<board>.h" +#define FFA_SHARED_MM_BUFFER_OFFSET 0 +#endif + +#ifndef FFA_SHARED_MM_BUFFER_ADDR +#warning "FFA_SHARED_MM_BUFFER_ADDR must be defined in include/configs/<board>.h" +#define FFA_SHARED_MM_BUFFER_ADDR 0 +#endif + +/* MM return codes */ +#define MM_SUCCESS (0) + +const char *mm_sp_svc_uuid = MM_SP_UUID; + +static __efi_runtime_data u16 mm_sp_id; + +#endif + extern struct efi_var_file __efi_runtime_data *efi_var_buf; static efi_uintn_t max_buffer_size; /* comm + var + func + data */ static efi_uintn_t max_payload_size; /* func + data */ @@ -24,6 +56,7 @@ struct mm_connection { u32 session; };
+#if (IS_ENABLED(CONFIG_OPTEE)) /** * get_connection() - Retrieve OP-TEE session for a specific UUID. * @@ -143,16 +176,227 @@ static efi_status_t optee_mm_communicate(void *comm_buf, ulong dsize)
return ret; } +#endif + +#if (IS_ENABLED(CONFIG_ARM_FFA_TRANSPORT))
/** - * mm_communicate() - Adjust the cmonnucation buffer to StandAlonneMM and send + * ffa_notify_mm_sp() - Announce there is data in the shared buffer + * + * Notifies the MM partition in the trusted world that + * data is available in the shared buffer. + * This is a blocking call during which trusted world has exclusive access + * to the MM shared buffer. + * + * Return: + * + * 0 on success + */ +static int __efi_runtime ffa_notify_mm_sp(void) +{ + struct ffa_send_direct_data msg = {0}; + int ret; + int sp_event_ret = -1; + + if (!ffa_bus_ops_get()) + return -EINVAL; + + msg.data0 = FFA_SHARED_MM_BUFFER_OFFSET; /* x3 */ + + ret = ffa_bus_ops_get()->sync_send_receive(mm_sp_id, &msg); + if (ret != 0) + return ret; + + sp_event_ret = msg.data0; /* x3 */ + + if (sp_event_ret == MM_SUCCESS) + return 0; + + /* + * Failure to notify the MM SP + */ + + return -EACCES; +} + +/** + * ffa_discover_mm_sp_id() - Query the MM partition ID + * + * Use the FF-A driver to get the MM partition ID. + * If multiple partitions are found, use the first one. + * This is a boot time function. + * + * Return: + * + * 0 on success + */ +static int ffa_discover_mm_sp_id(void) +{ + u32 count = 0, size = 0; + int ret; + struct ffa_partition_info *parts_info; + + if (!ffa_bus_ops_get()) + return -EINVAL; + + /* + * get from the driver the count of the SPs matching the UUID + */ + ret = ffa_bus_ops_get()->partition_info_get(mm_sp_svc_uuid, &count, NULL); + if (ret != 0) { + log_err("EFI: Failure in querying partitions count (error code: %d)\n", ret); + return ret; + } + + if (!count) { + log_info("EFI: No MM partition found\n"); + return ret; + } + + /* + * pre-allocate a buffer to be filled by the driver + * with ffa_partition_info structs + */ + + log_info("EFI: Pre-allocating %d partition(s) info structures\n", count); + + parts_info = calloc(count, sizeof(struct ffa_partition_info)); + if (!parts_info) + return -EINVAL; + + size = count * sizeof(struct ffa_partition_info); + + /* + * ask the driver to fill the + * buffer with the SPs info + */ + ret = ffa_bus_ops_get()->partition_info_get(mm_sp_svc_uuid, &size, parts_info); + if (ret != 0) { + log_err("EFI: Failure in querying partition(s) info (error code: %d)\n", ret); + free(parts_info); + return ret; + } + + /* + * MM SPs found , use the first one + */ + + mm_sp_id = parts_info[0].id; + + log_info("EFI: MM partition ID 0x%x\n", mm_sp_id); + + free(parts_info); + + return 0; +} + +/** + * ffa_mm_communicate() - Exchange EFI services data with the MM partition using FF-A + * @comm_buf: locally allocated communication buffer used for rx/tx + * @dsize: communication buffer size + * + * Issues a door bell event to notify the MM partition (SP) running in OP-TEE + * that there is data to read from the shared buffer. + * Communication with the MM SP is performed using FF-A transport. + * On the event, MM SP can read the data from the buffer and + * update the MM shared buffer with response data. + * The response data is copied back to the communication buffer. + * + * Return: + * + * EFI status code + */ +static efi_status_t __efi_runtime ffa_mm_communicate(void *comm_buf, ulong comm_buf_size) +{ + ulong tx_data_size; + int ffa_ret; + struct efi_mm_communicate_header *mm_hdr; + void *virt_shared_buf; + + if (!comm_buf) + return EFI_INVALID_PARAMETER; + + /* Discover MM partition ID at boot time */ + if (!mm_sp_id && ffa_discover_mm_sp_id() != 0) { + log_err("EFI: Failure to discover MM partition ID at boot time\n"); + return EFI_UNSUPPORTED; + } + + mm_hdr = (struct efi_mm_communicate_header *)comm_buf; + tx_data_size = mm_hdr->message_len + sizeof(efi_guid_t) + sizeof(size_t); + + if (comm_buf_size != tx_data_size || tx_data_size > FFA_SHARED_MM_BUFFER_SIZE) + return EFI_INVALID_PARAMETER; + + /* Copy the data to the shared buffer */ + + virt_shared_buf = (void *)map_sysmem((phys_addr_t)FFA_SHARED_MM_BUFFER_ADDR, 0); + efi_memcpy_runtime(virt_shared_buf, comm_buf, tx_data_size); + + /* + * The secure world might have cache disabled for + * the device region used for shared buffer (which is the case for Optee). + * In this case, the secure world reads the data from DRAM. + * Let's flush the cache so the DRAM is updated with the latest data. + */ + #ifdef CONFIG_ARM64 + invalidate_dcache_all(); + #endif + + /* Announce there is data in the shared buffer */ + + ffa_ret = ffa_notify_mm_sp(); + if (ffa_ret) + unmap_sysmem(virt_shared_buf); + + switch (ffa_ret) { + case 0: + { + ulong rx_data_size; + /* Copy the MM SP response from the shared buffer to the communication buffer */ + rx_data_size = ((struct efi_mm_communicate_header *)virt_shared_buf)->message_len + + sizeof(efi_guid_t) + + sizeof(size_t); + + if (rx_data_size > comm_buf_size) { + unmap_sysmem(virt_shared_buf); + return EFI_OUT_OF_RESOURCES; + } + + efi_memcpy_runtime(comm_buf, virt_shared_buf, rx_data_size); + unmap_sysmem(virt_shared_buf); + + return EFI_SUCCESS; + } + case -EINVAL: + return EFI_DEVICE_ERROR; + case -EPERM: + return EFI_INVALID_PARAMETER; + case -EACCES: + return EFI_ACCESS_DENIED; + case -EBUSY: + return EFI_OUT_OF_RESOURCES; + default: + return EFI_ACCESS_DENIED; + } +} +#endif + +/** + * mm_communicate() - Adjust the communication buffer to the MM SP and send * it to OP-TEE * - * @comm_buf: locally allocted communcation buffer + * @comm_buf: locally allocated communication buffer * @dsize: buffer size + * + * The MM SP (also called partition) can be StandAlonneMM or smm-gateway. + * The comm_buf format is the same for both partitions. + * When using the u-boot OP-TEE driver, StandAlonneMM is supported. + * When using the u-boot FF-A driver, StandAlonneMM and smm-gateway are supported. + * * Return: status code */ -static efi_status_t mm_communicate(u8 *comm_buf, efi_uintn_t dsize) +static efi_status_t __efi_runtime mm_communicate(u8 *comm_buf, efi_uintn_t dsize) { efi_status_t ret; struct efi_mm_communicate_header *mm_hdr; @@ -162,7 +406,11 @@ static efi_status_t mm_communicate(u8 *comm_buf, efi_uintn_t dsize) mm_hdr = (struct efi_mm_communicate_header *)comm_buf; var_hdr = (struct smm_variable_communicate_header *)mm_hdr->data;
+ #if (IS_ENABLED(CONFIG_OPTEE)) ret = optee_mm_communicate(comm_buf, dsize); + #elif (IS_ENABLED(CONFIG_ARM_FFA_TRANSPORT)) + ret = ffa_mm_communicate(comm_buf, dsize); + #endif if (ret != EFI_SUCCESS) { log_err("%s failed!\n", __func__); return ret; @@ -258,6 +506,13 @@ efi_status_t EFIAPI get_max_payload(efi_uintn_t *size) goto out; } *size = var_payload->size; + + #if (IS_ENABLED(CONFIG_ARM_FFA_TRANSPORT)) + if (*size > FFA_SHARED_MM_BUFFER_SIZE) + *size = FFA_SHARED_MM_BUFFER_SIZE - MM_COMMUNICATE_HEADER_SIZE - + MM_VARIABLE_COMMUNICATE_SIZE; + #endif + /* * There seems to be a bug in EDK2 miscalculating the boundaries and * size checks, so deduct 2 more bytes to fulfill this requirement. Fix @@ -697,7 +952,7 @@ void efi_variables_boot_exit_notify(void) ret = EFI_NOT_FOUND;
if (ret != EFI_SUCCESS) - log_err("Unable to notify StMM for ExitBootServices\n"); + log_err("Unable to notify the MM partition for ExitBootServices\n"); free(comm_buf);
Hi Abdellatif,
- (C) Copyright 2013
- David Feng fenghua@phytium.com.cn
- (C) Copyright 2022 ARM Limited
- Abdellatif El Khlifi abdellatif.elkhlifi@arm.com
- This file is based on sample code from ARMv8 ARM.
@@ -21,7 +24,11 @@
- x1: 0 clean & invalidate, 1 invalidate only
- x2~x9: clobbered
Maybe we discussed this in the past and I forgot, but why would you need __asm_dcache_level, __asm_dcache_all, __asm_invalidate_dcache_alla etc in the runtime section ?
- flush or invalidate all data cache by SET/WAY.
- (C) Copyright 2016
- Alexander Graf agraf@suse.de
- Performs a invalidation of the entire data cache at all levels
- always begin with efi_mm_communicate_header.
- Defined in EDK2 as SMM_VARIABLE_COMMUNICATE_ACCESS_VARIABLE.
You are randomly adding and deleting __packed cwin both structs. But you can't do that. Those structs are defined in StandAloneMM. This is the reason each struct description has the corresponding EDK2 definition.
- depends on OPTEE
- bool "UEFI variables storage service via the trusted world"
- depends on OPTEE || ARM_FFA_TRANSPORT
I think we discussed this in the past. I don't want ifdefs in the code for that. FF-A is a discoverable bus. So I think what we should do here, is fire up the variable access driver -> probe for FF-A -> decide what to use.
So it looks something like ************************** **** Variable Driver ***** ************************** | | | *************************** ****** Discover FF-A ****** *************************** | | | yes | No | |
Use SP Use OP-TEE
help
else
- /* Patch out unsupported runtime function */ efi_runtime_detach();
- Copyright (C) 2019 Linaro Ltd. sughosh.ganu@linaro.org
- Copyright (C) 2019 Linaro Ltd. ilias.apalodimas@linaro.org
- Copyright (C) 2022 ARM Limited
- get_connection() - Retrieve OP-TEE session for a specific UUID.
- mm_communicate() - Adjust the cmonnucation buffer to StandAlonneMM and send
- ffa_notify_mm_sp() - Announce there is data in the shared buffer
- Notifies the MM partition in the trusted world that
- data is available in the shared buffer.
- This is a blocking call during which trusted world has exclusive access
- to the MM shared buffer.
- Return:
- 0 on success
- struct ffa_send_direct_data msg = {0};
- int ret;
- int sp_event_ret = -1;
- if (!ffa_bus_ops_get())
return -EINVAL;
- msg.data0 = FFA_SHARED_MM_BUFFER_OFFSET; /* x3 */
- ret = ffa_bus_ops_get()->sync_send_receive(mm_sp_id, &msg);
- if (ret != 0)
return ret;
- sp_event_ret = msg.data0; /* x3 */
- if (sp_event_ret == MM_SUCCESS)
- return -EACCES;
- ffa_discover_mm_sp_id() - Query the MM partition ID
- Use the FF-A driver to get the MM partition ID.
- If multiple partitions are found, use the first one.
- This is a boot time function.
- Return:
- 0 on success
- u32 count = 0, size = 0;
- int ret;
- struct ffa_partition_info *parts_info;
return -EINVAL;
- ret = ffa_bus_ops_get()->partition_info_get(mm_sp_svc_uuid, &count, NULL);
- if (ret != 0) {
return ret;
- if (!count) {
return ret;
- log_info("EFI: Pre-allocating %d partition(s) info structures\n", count);
- parts_info = calloc(count, sizeof(struct ffa_partition_info));
- if (!parts_info)
return -EINVAL;
- size = count * sizeof(struct ffa_partition_info);
- ret = ffa_bus_ops_get()->partition_info_get(mm_sp_svc_uuid, &size, parts_info);
- if (ret != 0) {
free(parts_info);
return ret;
- mm_sp_id = parts_info[0].id;
- log_info("EFI: MM partition ID 0x%x\n", mm_sp_id);
- free(parts_info);
- ffa_mm_communicate() - Exchange EFI services data with the MM partition using FF-A
- @comm_buf: locally allocated communication buffer used for rx/tx
- @dsize: communication buffer size
- Issues a door bell event to notify the MM partition (SP) running in OP-TEE
- that there is data to read from the shared buffer.
- Communication with the MM SP is performed using FF-A transport.
- On the event, MM SP can read the data from the buffer and
- update the MM shared buffer with response data.
- The response data is copied back to the communication buffer.
- Return:
- EFI status code
If you are registering this as a *runtime* service you should also tweak the RT_PROPERTIES TABLE and enable runtime services (e.g SetVariable). Otherwise having as runtime makes little sense. To be honest I'd much prefer this whole patchset without the runtime parts. It's much easier to review and reason about and we can always add runtime later.
- ulong tx_data_size;
- int ffa_ret;
- struct efi_mm_communicate_header *mm_hdr;
- void *virt_shared_buf;
- if (!comm_buf)
- /* Discover MM partition ID at boot time */
- if (!mm_sp_id && ffa_discover_mm_sp_id() != 0) {
- mm_hdr = (struct efi_mm_communicate_header *)comm_buf;
- tx_data_size = mm_hdr->message_len + sizeof(efi_guid_t) + sizeof(size_t);
- if (comm_buf_size != tx_data_size || tx_data_size > FFA_SHARED_MM_BUFFER_SIZE)
- /* Copy the data to the shared buffer */
- virt_shared_buf = (void *)map_sysmem((phys_addr_t)FFA_SHARED_MM_BUFFER_ADDR, 0);
- efi_memcpy_runtime(virt_shared_buf, comm_buf, tx_data_size);
- #ifdef CONFIG_ARM64
- invalidate_dcache_all();
- #endif
- /* Announce there is data in the shared buffer */
- ffa_ret = ffa_notify_mm_sp();
- if (ffa_ret)
- switch (ffa_ret) {
- case 0:
ulong rx_data_size;
sizeof(size_t);
return EFI_SUCCESS;
- case -EINVAL:
- case -EPERM:
- case -EACCES:
- case -EBUSY:
- default:
+} +#endif
- mm_communicate() - Adjust the communication buffer to the MM SP and send
- it to OP-TEE
- @comm_buf: locally allocted communcation buffer
- @dsize: buffer size
- The MM SP (also called partition) can be StandAlonneMM or smm-gateway.
- The comm_buf format is the same for both partitions.
- When using the u-boot OP-TEE driver, StandAlonneMM is supported.
- When using the u-boot FF-A driver, StandAlonneMM and smm-gateway are supported.
- Return: status code
The optee version of the function can't be on the efi_runtime section. The reason is that almost the entire of the OP-TEE subsystem is not marked as runtime, which will lead to a crash if we ever take that path.
- #if (IS_ENABLED(CONFIG_OPTEE)) ret = optee_mm_communicate(comm_buf, dsize);
- #elif (IS_ENABLED(CONFIG_ARM_FFA_TRANSPORT))
- ret = ffa_mm_communicate(comm_buf, dsize);
If we enable runtime discovery of optee vs ffa, we can get rid of that and just pass an extra argument to mm_communicate
Thanks /Ilias
- #endif if (ret != EFI_SUCCESS) { log_err("%s failed!\n", __func__); return ret;
- #if (IS_ENABLED(CONFIG_ARM_FFA_TRANSPORT))
- #endif
- There seems to be a bug in EDK2 miscalculating the boundaries and
- size checks, so deduct 2 more bytes to fulfill this requirement. Fix
free(comm_buf);
-- 2.17.1
On Thu, Sep 29, 2022 at 12:32:42PM +0300, Ilias Apalodimas wrote:
Hi Abdellatif,
@@ -21,7 +24,11 @@
- x2~x9: clobbered
Because cache invalidation needs to be done at ffa_mm_communicate() level (v4 patchset). That code is runtime compatible so all the called functions must be under .text.efi_runtime
However, since we agreed to drop EFI runtime support from the patchset, v6 patchset takes care of that.
Thanks for the comment.
However, we are not setting randomly the __packed keyword. There is a good reason for that. It has been explained before in this reply [1]. Basically it's because of data padding issues breaking the communication between u-boot and secure world (Optee).
When upgrading Optee to v3.18, no issues anymore.
The __packed changes have been dropped in patchset v6.
[1]: https://lore.kernel.org/all/20220926105620.GA22382@e121910.cambridge.arm.com...
- depends on OPTEE
| yes | No | |
Use SP Use OP-TEE
In patchset v6, FF-A discovery is done at runtime and on demand. In our case at the MM Variable Driver as you recommended. Thanks.
help
else
- Return:
- 0 on success
- int ret;
return -EINVAL;
- if (ret != 0)
return ret;
- return -EACCES;
- Return:
- 0 on success
- int ret;
return -EINVAL;
- if (ret != 0) {
return ret;
- if (!count) {
return ret;
- if (!parts_info)
return -EINVAL;
- if (ret != 0) {
free(parts_info);
return ret;
- free(parts_info);
- Return:
- EFI status code
EFI runtime support removed from the FF-A work in patchset v6.
- int ffa_ret;
- if (!comm_buf)
- #endif
- if (ffa_ret)
- case 0:
ulong rx_data_size;
sizeof(size_t);
return EFI_SUCCESS;
- case -EINVAL:
- case -EPERM:
- case -EACCES:
- case -EBUSY:
- default:
+} +#endif
- it to OP-TEE
Thanks /Ilias
- #endif
free(comm_buf);
-- 2.17.1
On Fri, 14 Oct 2022 at 04:38, Abdellatif El Khlifi abdellatif.elkhlifi@arm.com wrote:
Hi Abdellatif,
@@ -21,7 +24,11 @@
- x2~x9: clobbered
That is the Linux mailing list. I cannot see any reason to add __packed to this struct as it is already set up that way.
Also efi_mm_communicate_header is really long. I suggest efi_mm_hdr or efi_mm_comms_hdr
Why are you using SMM on ARM? Isn't that an Intel thing?
Regards, SImon
Hi Simon,
This is due to the fact that we run StandAloneMM, which is a specific EDK2 'package' to handle the variables in Arm secure world. There's a really long explanation on how that works here [0] in case you are interested. The naming is a bit unfortunate, but since we have to read it and reason about the EDK2 API in future versions, I suggest keeping it as close to the original as possible. Alternatively we could just add a comment with the EDK2 equivalent, but in any case, the change you are request is out of scope for this patchset.
[0] https://www.linaro.org/blog/protected-uefi-variables-with-u-boot/
Regards /Ilias
Regards, SImon
Hi Abdellatif,
@@ -21,7 +24,11 @@
- x2~x9: clobbered
Thanks Simon. The link above is not part of the linux mailing list. It points to the mirror of the u-boot mailing list under lore.kernel.org
Regards, SImon
turn on EFI MM communication
On corstone1000 platform MM communication between u-boot and the secure world (Optee) is done using the FF-A bus.
Signed-off-by: Abdellatif El Khlifi abdellatif.elkhlifi@arm.com Cc: Tom Rini trini@konsulko.com Cc: Simon Glass sjg@chromium.org Cc: Ilias Apalodimas ilias.apalodimas@linaro.org Cc: Jens Wiklander jens.wiklander@linaro.org --- configs/corstone1000_defconfig | 4 ++++ include/configs/corstone1000.h | 9 +++++++++ 2 files changed, 13 insertions(+)
diff --git a/configs/corstone1000_defconfig b/configs/corstone1000_defconfig index ed2e0fe70a..5028c746c5 100644 --- a/configs/corstone1000_defconfig +++ b/configs/corstone1000_defconfig @@ -52,3 +52,7 @@ CONFIG_DM_SERIAL=y CONFIG_USB=y CONFIG_USB_ISP1760=y CONFIG_ERRNO_STR=y +CONFIG_EFI_MM_COMM_TEE=y +# CONFIG_OPTEE is not set +CONFIG_ARM_FFA_TRANSPORT=y +CONFIG_ARM_FFA_EFI_RUNTIME_MODE=y diff --git a/include/configs/corstone1000.h b/include/configs/corstone1000.h index 8e0230c135..997d0bebaf 100644 --- a/include/configs/corstone1000.h +++ b/include/configs/corstone1000.h @@ -14,6 +14,15 @@
#include <linux/sizes.h>
+#define FFA_SHARED_MM_BUFFER_SIZE SZ_4K /* 4 KB */ + +/* + * shared buffer physical address used for communication between + * u-boot and the MM SP + */ +#define FFA_SHARED_MM_BUFFER_ADDR (0x023F8000) +#define FFA_SHARED_MM_BUFFER_OFFSET (0) + #define V2M_BASE 0x80000000
#define CONFIG_PL011_CLOCK 50000000
Adding support for Arm FF-A v1.0 (Arm Firmware Framework for Armv8-A) [6].
FF-A describes interfaces (ABIs) that standardize communication between the Secure World and Normal World. These interfaces enable a pair of software sandboxes to communicate with each other. A sandbox aka partition could be a VM in the Normal or Secure world, an application in S-EL0, or a Trusted OS in S-EL1.
The FF-A transport is implemented as a data bus and a core driver is provided.
The FF-A driver uses the SMC ABIs defined by the FF-A specification to:
- Discover the presence of secure partitions (SPs) of interest - Access an SP's service through communication protocols e.g. EFI MM communication protocol
The FF-A support provides the following features:
- Being generic by design and can be used by any Arm 64-bit platform - The FF-A core driver - The FF-A bus is discoverable on demand at runtime - The driver provides callbacks to be used by clients to access the FF-A bus - FF-A driver can be compiled and used without EFI - Support for SMCCCv1.2 x0-x17 registers - A new command called armffa is provided as an example of how to access the FF-A bus - An FF-A Sandbox driver is provided with test cases - Support for FF-A MM communication - Enabling FF-A and MM communication in Corstone1000 platform
For more details about the FF-A core driver please refer to [7].
Please find at [8] an example of the expected boot logs when enabling FF-A support for a platform. In this example the platform is Corstone1000. But it can be any Arm 64-bit platform.
Changelog of the major changes: ===========================
v6:
* remove clearing x0-x17 registers after SMC calls * drop use of EFI runtime support for FF-A (We decided with Linaro to add this later) * drop discovery from initcalls (discovery will be on demand by FF-A users) * add FF-A runtime discovery at MM communication level * update the documentation and move it to doc/arch/arm64.ffa.rst
v5: [5]
* move changelogs in each commit to the changes section
v4: [4]
* add FF-A support README (doc/README.ffa.drv) * improving error handling by mapping the FF-A errors to standard errors and logs * replacing panics with an error log * align sandbox driver and tests with the new FF-A driver interfaces and new way of error handling * use the new FF-A driver interfaces for MM communication * discover MM partitions at runtime * copy FF-A driver private data to EFI runtime section at ExitBootServices() * moving the FF-A driver work to drivers/firmware/arm-ffa * improving features discovery in FFA_FEATURES * add remove/unbind functions to the FF-A core device * improve how the driver behaves when bus discovery is done more than once * move clearing x0-x17 registers code into a new macro like done in the linux kernel * enable EFI MM communication for the Corstone1000 platform
v3: [3]
* port x0-x17 registers support from linux kernel as defined by SMCCCv1.2 * align the interfaces of the u-boot FF-A driver with those in the linux FF-A driver * remove the FF-A helper layer * make the u-boot FF-A driver independent from EFI * provide an optional config that enables copying the driver data to EFI runtime section at ExitBootServices service * use 64-bit version of FFA_RXTX_MAP, FFA_MSG_SEND_DIRECT_{REQ, RESP} * update armffa command with the new driver interfaces
v2 [2]:
* make FF-A bus discoverable using device_{bind, probe} APIs * remove device tree support
v1 [1]:
* introduce FF-A bus driver with device tree support * introduce armffa command * introduce FF-A Sandbox driver * add FF-A Sandbox test cases * introduce FF-A MM communication
Cheers, Abdellatif
[1]: https://lore.kernel.org/all/20220329151659.16894-1-abdellatif.elkhlifi@arm.c... [2]: https://lore.kernel.org/all/20220415122803.16666-1-abdellatif.elkhlifi@arm.c... [3]: https://lore.kernel.org/all/20220801172053.20163-1-abdellatif.elkhlifi@arm.c... [4]: https://lore.kernel.org/all/20220926101723.9965-1-abdellatif.elkhlifi@arm.co... [5]: https://lore.kernel.org/all/20220926140827.15125-1-abdellatif.elkhlifi@arm.c... [6]: https://developer.arm.com/documentation/den0077/latest/ [7]: doc/arch/arm64.ffa.rst [8]: example of boot logs when enabling FF-A
``` U-Boot 2022.07 (Jul 11 2022 - 13:42:58 +0000) corstone1000 aarch64 ... Hit any key to stop autoboot: 0 ... [FFA] Conduit is SMC [FFA] FF-A driver 1.0 FF-A framework 1.0 [FFA] Versions are compatible [FFA] endpoint ID is 0 [FFA] Using 1 4KB page(s) for RX/TX buffers size [FFA] RX buffer at virtual address 0xfdf1b000 [FFA] TX buffer at virtual address 0xfdf1d000 [FFA] RX/TX buffers mapped [FFA] Reading partitions data from the RX buffer [FFA] Partition ID 8001 : info cached [FFA] Partition ID 8002 : info cached [FFA] Partition ID 8003 : info cached [FFA] 3 partition(s) found and cached [FFA] Preparing for checking partitions count [FFA] Searching partitions using the provided UUID [FFA] No partition found. Querying framework ... [FFA] Reading partitions data from the RX buffer [FFA] Number of partition(s) found matching the UUID: 1 EFI: Pre-allocating 1 partition(s) info structures [FFA] Preparing for filling partitions info [FFA] Searching partitions using the provided UUID [FFA] Partition ID 8003 matches the provided UUID EFI: MM partition ID 0x8003 ... EFI stub: Booting Linux Kernel... ... EFI stub: Exiting boot services... [FFA] Freeing RX/TX buffers Booting Linux on physical CPU 0x0000000000 [0x411fd040] ```
Cc: Tom Rini trini@konsulko.com Cc: Simon Glass sjg@chromium.org Cc: Ilias Apalodimas ilias.apalodimas@linaro.org Cc: Jens Wiklander jens.wiklander@linaro.org Cc: Achin Gupta achin.gupta@arm.com Cc: Drew Reed Drew.Reed@arm.com Cc: Vishnu Banavath vishnu.banavath@arm.com Cc: Xueliang Zhong Xueliang.Zhong@arm.com
Abdellatif El Khlifi (10): arm64: smccc: add support for SMCCCv1.2 x0-x17 registers lib: uuid: introduce be_uuid_str_to_le_bin function arm_ffa: introduce Arm FF-A low-level driver arm_ffa: efi: unmap RX/TX buffers arm_ffa: introduce armffa command arm_ffa: introduce the FF-A Sandbox driver arm_ffa: introduce Sandbox test cases for UCLASS_FFA arm_ffa: introduce armffa command Sandbox test arm_ffa: efi: introduce FF-A MM communication arm_ffa: efi: corstone1000: enable MM communication
MAINTAINERS | 11 + arch/arm/cpu/armv8/smccc-call.S | 53 + arch/arm/lib/asm-offsets.c | 14 + cmd/Kconfig | 10 + cmd/Makefile | 2 + cmd/armffa.c | 242 +++ configs/corstone1000_defconfig | 4 + configs/sandbox64_defconfig | 2 + configs/sandbox_defconfig | 2 + doc/arch/arm64.ffa.rst | 207 +++ doc/arch/index.rst | 1 + doc/arch/sandbox.rst | 1 + drivers/Kconfig | 2 + drivers/Makefile | 1 + drivers/firmware/arm-ffa/Kconfig | 36 + drivers/firmware/arm-ffa/Makefile | 7 + drivers/firmware/arm-ffa/arm-ffa-uclass.c | 16 + drivers/firmware/arm-ffa/arm_ffa_prv.h | 201 +++ drivers/firmware/arm-ffa/core.c | 1351 +++++++++++++++++ drivers/firmware/arm-ffa/sandbox.c | 659 ++++++++ .../firmware/arm-ffa/sandbox_arm_ffa_prv.h | 144 ++ include/arm_ffa.h | 93 ++ include/configs/corstone1000.h | 9 + include/dm/uclass-id.h | 4 + include/linux/arm-smccc.h | 43 + include/mm_communication.h | 5 + include/sandbox_arm_ffa.h | 91 ++ include/uuid.h | 8 + lib/efi_loader/Kconfig | 14 +- lib/efi_loader/efi_boottime.c | 15 + lib/efi_loader/efi_variable_tee.c | 264 +++- lib/uuid.c | 64 + test/cmd/Makefile | 2 + test/cmd/armffa.c | 40 + test/dm/Makefile | 2 + test/dm/ffa.c | 394 +++++ 36 files changed, 4008 insertions(+), 6 deletions(-) create mode 100644 cmd/armffa.c create mode 100644 doc/arch/arm64.ffa.rst create mode 100644 drivers/firmware/arm-ffa/Kconfig create mode 100644 drivers/firmware/arm-ffa/Makefile create mode 100644 drivers/firmware/arm-ffa/arm-ffa-uclass.c create mode 100644 drivers/firmware/arm-ffa/arm_ffa_prv.h create mode 100644 drivers/firmware/arm-ffa/core.c create mode 100644 drivers/firmware/arm-ffa/sandbox.c create mode 100644 drivers/firmware/arm-ffa/sandbox_arm_ffa_prv.h create mode 100644 include/arm_ffa.h create mode 100644 include/sandbox_arm_ffa.h create mode 100644 test/cmd/armffa.c create mode 100644 test/dm/ffa.c
add support for x0-x17 registers used by the SMC calls
In SMCCC v1.2 [1] arguments are passed in registers x1-x17. Results are returned in x0-x17.
This work is inspired from the following kernel commit:
arm64: smccc: Add support for SMCCCv1.2 extended input/output registers
[1]: https://documentation-service.arm.com/static/5f8edaeff86e16515cdbe4c6?token=
Changelog: ===============
v4:
* rename the commit title and improve description new commit title: the current
v3:
* port x0-x17 registers support from linux kernel as defined by SMCCCv1.2 commit title: arm64: smccc: add Xn registers support used by SMC calls
arch/arm/cpu/armv8/smccc-call.S | 53 +++++++++++++++++++++++++++++++++ arch/arm/lib/asm-offsets.c | 14 +++++++++ include/linux/arm-smccc.h | 43 ++++++++++++++++++++++++++ 3 files changed, 110 insertions(+)
diff --git a/arch/arm/cpu/armv8/smccc-call.S b/arch/arm/cpu/armv8/smccc-call.S index dc92b28777..ec6f299bc9 100644 --- a/arch/arm/cpu/armv8/smccc-call.S +++ b/arch/arm/cpu/armv8/smccc-call.S @@ -1,6 +1,8 @@ /* SPDX-License-Identifier: GPL-2.0 */ /* * Copyright (c) 2015, Linaro Limited + * (C) Copyright 2022 ARM Limited + * Abdellatif El Khlifi abdellatif.elkhlifi@arm.com */ #include <linux/linkage.h> #include <linux/arm-smccc.h> @@ -45,3 +47,54 @@ ENDPROC(__arm_smccc_smc) ENTRY(__arm_smccc_hvc) SMCCC hvc ENDPROC(__arm_smccc_hvc) + +#ifdef CONFIG_ARM64 + + .macro SMCCC_1_2 instr + /* Save `res` and free a GPR that won't be clobbered */ + stp x1, x19, [sp, #-16]! + + /* Ensure `args` won't be clobbered while loading regs in next step */ + mov x19, x0 + + /* Load the registers x0 - x17 from the struct arm_smccc_1_2_regs */ + ldp x0, x1, [x19, #ARM_SMCCC_1_2_REGS_X0_OFFS] + ldp x2, x3, [x19, #ARM_SMCCC_1_2_REGS_X2_OFFS] + ldp x4, x5, [x19, #ARM_SMCCC_1_2_REGS_X4_OFFS] + ldp x6, x7, [x19, #ARM_SMCCC_1_2_REGS_X6_OFFS] + ldp x8, x9, [x19, #ARM_SMCCC_1_2_REGS_X8_OFFS] + ldp x10, x11, [x19, #ARM_SMCCC_1_2_REGS_X10_OFFS] + ldp x12, x13, [x19, #ARM_SMCCC_1_2_REGS_X12_OFFS] + ldp x14, x15, [x19, #ARM_SMCCC_1_2_REGS_X14_OFFS] + ldp x16, x17, [x19, #ARM_SMCCC_1_2_REGS_X16_OFFS] + + \instr #0 + + /* Load the `res` from the stack */ + ldr x19, [sp] + + /* Store the registers x0 - x17 into the result structure */ + stp x0, x1, [x19, #ARM_SMCCC_1_2_REGS_X0_OFFS] + stp x2, x3, [x19, #ARM_SMCCC_1_2_REGS_X2_OFFS] + stp x4, x5, [x19, #ARM_SMCCC_1_2_REGS_X4_OFFS] + stp x6, x7, [x19, #ARM_SMCCC_1_2_REGS_X6_OFFS] + stp x8, x9, [x19, #ARM_SMCCC_1_2_REGS_X8_OFFS] + stp x10, x11, [x19, #ARM_SMCCC_1_2_REGS_X10_OFFS] + stp x12, x13, [x19, #ARM_SMCCC_1_2_REGS_X12_OFFS] + stp x14, x15, [x19, #ARM_SMCCC_1_2_REGS_X14_OFFS] + stp x16, x17, [x19, #ARM_SMCCC_1_2_REGS_X16_OFFS] + + /* Restore original x19 */ + ldp xzr, x19, [sp], #16 + ret + .endm + +/* + * void arm_smccc_1_2_smc(const struct arm_smccc_1_2_regs *args, + * struct arm_smccc_1_2_regs *res); + */ +ENTRY(arm_smccc_1_2_smc) + SMCCC_1_2 smc +ENDPROC(arm_smccc_1_2_smc) + +#endif diff --git a/arch/arm/lib/asm-offsets.c b/arch/arm/lib/asm-offsets.c index 22fd541f9a..1bc2d90faa 100644 --- a/arch/arm/lib/asm-offsets.c +++ b/arch/arm/lib/asm-offsets.c @@ -9,6 +9,9 @@ * generate asm statements containing #defines, * compile this file to assembler, and then extract the * #defines from the assembly-language output. + * + * (C) Copyright 2022 ARM Limited + * Abdellatif El Khlifi abdellatif.elkhlifi@arm.com */
#include <common.h> @@ -117,6 +120,17 @@ int main(void) DEFINE(ARM_SMCCC_RES_X2_OFFS, offsetof(struct arm_smccc_res, a2)); DEFINE(ARM_SMCCC_QUIRK_ID_OFFS, offsetof(struct arm_smccc_quirk, id)); DEFINE(ARM_SMCCC_QUIRK_STATE_OFFS, offsetof(struct arm_smccc_quirk, state)); + #ifdef CONFIG_ARM64 + DEFINE(ARM_SMCCC_1_2_REGS_X0_OFFS, offsetof(struct arm_smccc_1_2_regs, a0)); + DEFINE(ARM_SMCCC_1_2_REGS_X2_OFFS, offsetof(struct arm_smccc_1_2_regs, a2)); + DEFINE(ARM_SMCCC_1_2_REGS_X4_OFFS, offsetof(struct arm_smccc_1_2_regs, a4)); + DEFINE(ARM_SMCCC_1_2_REGS_X6_OFFS, offsetof(struct arm_smccc_1_2_regs, a6)); + DEFINE(ARM_SMCCC_1_2_REGS_X8_OFFS, offsetof(struct arm_smccc_1_2_regs, a8)); + DEFINE(ARM_SMCCC_1_2_REGS_X10_OFFS, offsetof(struct arm_smccc_1_2_regs, a10)); + DEFINE(ARM_SMCCC_1_2_REGS_X12_OFFS, offsetof(struct arm_smccc_1_2_regs, a12)); + DEFINE(ARM_SMCCC_1_2_REGS_X14_OFFS, offsetof(struct arm_smccc_1_2_regs, a14)); + DEFINE(ARM_SMCCC_1_2_REGS_X16_OFFS, offsetof(struct arm_smccc_1_2_regs, a16)); + #endif #endif
return 0; diff --git a/include/linux/arm-smccc.h b/include/linux/arm-smccc.h index e1d09884a1..9105031d55 100644 --- a/include/linux/arm-smccc.h +++ b/include/linux/arm-smccc.h @@ -1,6 +1,8 @@ /* SPDX-License-Identifier: GPL-2.0 */ /* * Copyright (c) 2015, Linaro Limited + * (C) Copyright 2022 ARM Limited + * Abdellatif El Khlifi abdellatif.elkhlifi@arm.com */ #ifndef __LINUX_ARM_SMCCC_H #define __LINUX_ARM_SMCCC_H @@ -70,6 +72,47 @@ struct arm_smccc_res { unsigned long a3; };
+#ifdef CONFIG_ARM64 +/** + * struct arm_smccc_1_2_regs - Arguments for or Results from SMC call + * @a0-a17 argument values from registers 0 to 17 + */ +struct arm_smccc_1_2_regs { + unsigned long a0; + unsigned long a1; + unsigned long a2; + unsigned long a3; + unsigned long a4; + unsigned long a5; + unsigned long a6; + unsigned long a7; + unsigned long a8; + unsigned long a9; + unsigned long a10; + unsigned long a11; + unsigned long a12; + unsigned long a13; + unsigned long a14; + unsigned long a15; + unsigned long a16; + unsigned long a17; +}; + +/** + * arm_smccc_1_2_smc() - make SMC calls + * @args: arguments passed via struct arm_smccc_1_2_regs + * @res: result values via struct arm_smccc_1_2_regs + * + * This function is used to make SMC calls following SMC Calling Convention + * v1.2 or above. The content of the supplied param are copied from the + * structure to registers prior to the SMC instruction. The return values + * are updated with the content from registers on return from the SMC + * instruction. + */ +asmlinkage void arm_smccc_1_2_smc(const struct arm_smccc_1_2_regs *args, + struct arm_smccc_1_2_regs *res); +#endif + /** * struct arm_smccc_quirk - Contains quirk information * @id: quirk identification
Changelog:
v4:
- rename the commit title and improve description new commit title: the current
v3:
- port x0-x17 registers support from linux kernel as defined by SMCCCv1.2 commit title: arm64: smccc: add Xn registers support used by SMC calls
- Copyright (c) 2015, Linaro Limited
- .macro SMCCC_1_2 instr
- /* Save `res` and free a GPR that won't be clobbered */
- stp x1, x19, [sp, #-16]!
- /* Ensure `args` won't be clobbered while loading regs in next step */
- mov x19, x0
- /* Load the registers x0 - x17 from the struct arm_smccc_1_2_regs */
- ldp x0, x1, [x19, #ARM_SMCCC_1_2_REGS_X0_OFFS]
- ldp x2, x3, [x19, #ARM_SMCCC_1_2_REGS_X2_OFFS]
- ldp x4, x5, [x19, #ARM_SMCCC_1_2_REGS_X4_OFFS]
- ldp x6, x7, [x19, #ARM_SMCCC_1_2_REGS_X6_OFFS]
- ldp x8, x9, [x19, #ARM_SMCCC_1_2_REGS_X8_OFFS]
- ldp x10, x11, [x19, #ARM_SMCCC_1_2_REGS_X10_OFFS]
- ldp x12, x13, [x19, #ARM_SMCCC_1_2_REGS_X12_OFFS]
- ldp x14, x15, [x19, #ARM_SMCCC_1_2_REGS_X14_OFFS]
- ldp x16, x17, [x19, #ARM_SMCCC_1_2_REGS_X16_OFFS]
- \instr #0
- /* Load the `res` from the stack */
- ldr x19, [sp]
- /* Store the registers x0 - x17 into the result structure */
- stp x0, x1, [x19, #ARM_SMCCC_1_2_REGS_X0_OFFS]
- stp x2, x3, [x19, #ARM_SMCCC_1_2_REGS_X2_OFFS]
- stp x4, x5, [x19, #ARM_SMCCC_1_2_REGS_X4_OFFS]
- stp x6, x7, [x19, #ARM_SMCCC_1_2_REGS_X6_OFFS]
- stp x8, x9, [x19, #ARM_SMCCC_1_2_REGS_X8_OFFS]
- stp x10, x11, [x19, #ARM_SMCCC_1_2_REGS_X10_OFFS]
- stp x12, x13, [x19, #ARM_SMCCC_1_2_REGS_X12_OFFS]
- stp x14, x15, [x19, #ARM_SMCCC_1_2_REGS_X14_OFFS]
- stp x16, x17, [x19, #ARM_SMCCC_1_2_REGS_X16_OFFS]
- /* Restore original x19 */
- ldp xzr, x19, [sp], #16
- ret
- .endm
- void arm_smccc_1_2_smc(const struct arm_smccc_1_2_regs *args,
- SMCCC_1_2 smc
- generate asm statements containing #defines,
- compile this file to assembler, and then extract the
- #defines from the assembly-language output.
- #endif
We don't need another level of indentation here, please follow the established style in this file.
With that fixed please add Reviewed-by: Jens Wiklander jens.wiklander@linaro.org
Cheers, Jens
#endif
- struct arm_smccc_1_2_regs - Arguments for or Results from SMC call
- @a0-a17 argument values from registers 0 to 17
- unsigned long a0;
- unsigned long a1;
- unsigned long a2;
- unsigned long a3;
- unsigned long a4;
- unsigned long a5;
- unsigned long a6;
- unsigned long a7;
- unsigned long a8;
- unsigned long a9;
- unsigned long a10;
- unsigned long a11;
- unsigned long a12;
- unsigned long a13;
- unsigned long a14;
- unsigned long a15;
- unsigned long a16;
- unsigned long a17;
- arm_smccc_1_2_smc() - make SMC calls
- @args: arguments passed via struct arm_smccc_1_2_regs
- @res: result values via struct arm_smccc_1_2_regs
- This function is used to make SMC calls following SMC Calling Convention
- v1.2 or above. The content of the supplied param are copied from the
- structure to registers prior to the SMC instruction. The return values
- are updated with the content from registers on return from the SMC
- instruction.
- struct arm_smccc_quirk - Contains quirk information
- @id: quirk identification
-- 2.17.1
Changelog:
v4:
v3:
- mov x19, x0
- \instr #0
- ldr x19, [sp]
- ret
- .endm
- SMCCC_1_2 smc
- #endif
Thanks, done in v7.
Cheers, Jens
#endif
- unsigned long a0;
- unsigned long a1;
- unsigned long a2;
- unsigned long a3;
- unsigned long a4;
- unsigned long a5;
- unsigned long a6;
- unsigned long a7;
- unsigned long a8;
- unsigned long a9;
- instruction.
-- 2.17.1
convert big endian UUID string to little endian buffer
v4:
* rename ffa_uuid_str_to_bin to be_uuid_str_to_le_bin and put in a standalone commit (the current)
v3:
* introduce ffa_uuid_str_to_bin (provided by arm_ffa: introduce Arm FF-A low-level driver)
include/uuid.h | 8 +++++++ lib/uuid.c | 64 ++++++++++++++++++++++++++++++++++++++++++++++++++ 2 files changed, 72 insertions(+)
diff --git a/include/uuid.h b/include/uuid.h index 4a4883d3b5..ad3af350f9 100644 --- a/include/uuid.h +++ b/include/uuid.h @@ -2,6 +2,8 @@ /* * Copyright (C) 2014 Samsung Electronics * Przemyslaw Marczak p.marczak@samsung.com + * (C) Copyright 2022 ARM Limited + * Abdellatif El Khlifi abdellatif.elkhlifi@arm.com */ #ifndef __UUID_H__ #define __UUID_H__ @@ -44,4 +46,10 @@ int uuid_guid_get_bin(const char *guid_str, unsigned char *guid_bin); const char *uuid_guid_get_str(const unsigned char *guid_bin); void gen_rand_uuid(unsigned char *uuid_bin); void gen_rand_uuid_str(char *uuid_str, int str_format); + +/** + * be_uuid_str_to_le_bin - Converts a big endian UUID string to a little endian buffer + */ +int be_uuid_str_to_le_bin(const char *uuid_str, unsigned char *uuid_bin); + #endif diff --git a/lib/uuid.c b/lib/uuid.c index 465e1ac38f..15a9ab49d5 100644 --- a/lib/uuid.c +++ b/lib/uuid.c @@ -1,6 +1,8 @@ // SPDX-License-Identifier: GPL-2.0+ /* * Copyright 2011 Calxeda, Inc. + * (C) Copyright 2022 ARM Limited + * Abdellatif El Khlifi abdellatif.elkhlifi@arm.com */
#include <common.h> @@ -346,6 +348,68 @@ int uuid_str_to_bin(const char *uuid_str, unsigned char *uuid_bin, return 0; }
+/** + * be_uuid_str_to_le_bin - Converts a big endian UUID string to a little endian buffer + * @uuid_str: UUID string in big endian format (36 bytes wide + '/0') + * @uuid_bin: preallocated 16 bytes UUID buffer in little endian format + * + * UUID string is 36 characters (36 bytes): + * + * xxxxxxxx-xxxx-xxxx-xxxx-xxxxxxxxxxxx + * be be be be be + * + * where x is a hexadecimal character. Fields are separated by '-'s. + * When converting to a binary UUID, these endianness rules apply: + * be: means the field in the string is considered a big endian hex number + * and should be converted to little endian binary format + * + * Return: + * + * uuid_bin filled with little endian UUID data + * On success 0 is returned. Otherwise, failure code. + */ +int be_uuid_str_to_le_bin(const char *uuid_str, unsigned char *uuid_bin) +{ + u16 tmp16 = 0; + u32 tmp32 = 0; + u64 tmp64 = 0; + + if (!uuid_str_valid(uuid_str) || !uuid_bin) + return -EINVAL; + + /* + * reverse bytes from big to little endian + */ + tmp32 = simple_strtoul(uuid_str, NULL, 16); + memcpy(uuid_bin, &tmp32, 4); + + /* + * reverse bytes from big to little endian + */ + tmp16 = simple_strtoul(uuid_str + 9, NULL, 16); + memcpy(uuid_bin + 4, &tmp16, 2); + + /* + * reverse bytes from big to little endian + */ + tmp16 = simple_strtoul(uuid_str + 14, NULL, 16); + memcpy(uuid_bin + 6, &tmp16, 2); + + /* + * reverse bytes from big to little endian + */ + tmp16 = simple_strtoul(uuid_str + 19, NULL, 16); + memcpy(uuid_bin + 8, &tmp16, 2); + + /* + * reverse bytes from big to little endian + */ + tmp64 = simple_strtoull(uuid_str + 24, NULL, 16); + memcpy(uuid_bin + 10, (char *)&tmp64, 6); + + return 0; +} + /* * uuid_bin_to_str() - convert big endian binary data to string UUID or GUID. *
Hi Abdellatif,
You don't really need the be_ suffix on the declaration, endianness doesn't apply to strings. Can't we do something similar to uuid_str_to_bin() and just convert to LE?
Thanks /Ilias
Changelog:
v4:
- rename ffa_uuid_str_to_bin to be_uuid_str_to_le_bin and put in a standalone commit (the current)
v3:
- introduce ffa_uuid_str_to_bin (provided by arm_ffa: introduce Arm FF-A low-level driver)
- Copyright (C) 2014 Samsung Electronics
- Przemyslaw Marczak p.marczak@samsung.com
- be_uuid_str_to_le_bin - Converts a big endian UUID string to a little endian buffer
- Copyright 2011 Calxeda, Inc.
- @uuid_str: UUID string in big endian format (36 bytes wide + '/0')
- @uuid_bin: preallocated 16 bytes UUID buffer in little endian format
- UUID string is 36 characters (36 bytes):
- xxxxxxxx-xxxx-xxxx-xxxx-xxxxxxxxxxxx
- be be be be be
- where x is a hexadecimal character. Fields are separated by '-'s.
- When converting to a binary UUID, these endianness rules apply:
- Return:
- uuid_bin filled with little endian UUID data
- On success 0 is returned. Otherwise, failure code.
- u16 tmp16 = 0;
- u32 tmp32 = 0;
- u64 tmp64 = 0;
- if (!uuid_str_valid(uuid_str) || !uuid_bin)
return -EINVAL;
- tmp32 = simple_strtoul(uuid_str, NULL, 16);
- memcpy(uuid_bin, &tmp32, 4);
- tmp16 = simple_strtoul(uuid_str + 9, NULL, 16);
- memcpy(uuid_bin + 4, &tmp16, 2);
- tmp16 = simple_strtoul(uuid_str + 14, NULL, 16);
- memcpy(uuid_bin + 6, &tmp16, 2);
- tmp16 = simple_strtoul(uuid_str + 19, NULL, 16);
- memcpy(uuid_bin + 8, &tmp16, 2);
- tmp64 = simple_strtoull(uuid_str + 24, NULL, 16);
- memcpy(uuid_bin + 10, (char *)&tmp64, 6);
- uuid_bin_to_str() - convert big endian binary data to string UUID or GUID.
-- 2.17.1
On Mon, Oct 24, 2022 at 03:07:35PM +0300, Ilias Apalodimas wrote:
Hi Abdellatif,
Thanks, done in v7 [1]. Please have a look.
[1]: https://lore.kernel.org/all/20221107192055.21669-3-abdellatif.elkhlifi@arm.c...
Thanks /Ilias
Changelog:
v4:
v3:
- be be be be be
- Return:
- u16 tmp16 = 0;
- u32 tmp32 = 0;
- u64 tmp64 = 0;
return -EINVAL;
-- 2.17.1
Add the core driver implementing Arm Firmware Framework for Armv8-A v1.0
The Firmware Framework for Arm A-profile processors (FF-A v1.0) [1] describes interfaces (ABIs) that standardize communication between the Secure World and Normal World leveraging TrustZone technology.
This driver uses 64-bit registers as per SMCCCv1.2 spec and comes on top of the SMCCC layer. The driver provides the FF-A ABIs needed for querying the FF-A framework from the secure world.
32-bit version of the ABIs is supported and 64-bit version of FFA_RXTX_MAP and FFA_MSG_SEND_DIRECT_{REQ, RESP}.
In u-boot FF-A design, FF-A is considered as a discoverable bus. The Secure World is considered as one entity to communicate with using the FF-A bus. FF-A communication is handled by one device and one instance (the bus). This FF-A driver takes care of all the interactions between Normal world and Secure World.
The driver exports its operations to be used by upper layers.
Exported operations:
- partition_info_get - sync_send_receive - rxtx_unmap
[1]: https://developer.arm.com/documentation/den0077/latest/
v6:
* drop use of EFI runtime support (We decided with Linaro to add this later) * drop discovery from initcalls (discovery will be on demand by FF-A users) * set the alignment of the RX/TX buffers to the larger translation granule size * move FF-A RX/TX buffers unmapping at ExitBootServices() to a separate commit * update the documentation and move it to doc/arch/arm64.ffa.rst
v4:
* add doc/README.ffa.drv * moving the FF-A driver work to drivers/firmware/arm-ffa * use less #ifdefs in lib/efi_loader/efi_boottime.c and replace #if defined by #if CONFIG_IS_ENABLED * improving error handling by mapping the FF-A errors to standard errors and logs * replacing panics with an error log and returning an error code * improving features discovery in FFA_FEATURES by introducing rxtx_min_pages private data field * add ffa_remove and ffa_unbind functions * improve how the driver behaves when bus discovery is done more than once
v3:
v2:
v1:
MAINTAINERS | 7 + doc/arch/arm64.ffa.rst | 207 ++++ doc/arch/index.rst | 1 + drivers/Kconfig | 2 + drivers/Makefile | 1 + drivers/firmware/arm-ffa/Kconfig | 30 + drivers/firmware/arm-ffa/Makefile | 6 + drivers/firmware/arm-ffa/arm-ffa-uclass.c | 16 + drivers/firmware/arm-ffa/arm_ffa_prv.h | 196 +++ drivers/firmware/arm-ffa/core.c | 1337 +++++++++++++++++++++ include/arm_ffa.h | 93 ++ include/dm/uclass-id.h | 4 + 12 files changed, 1900 insertions(+) create mode 100644 doc/arch/arm64.ffa.rst create mode 100644 drivers/firmware/arm-ffa/Kconfig create mode 100644 drivers/firmware/arm-ffa/Makefile create mode 100644 drivers/firmware/arm-ffa/arm-ffa-uclass.c create mode 100644 drivers/firmware/arm-ffa/arm_ffa_prv.h create mode 100644 drivers/firmware/arm-ffa/core.c create mode 100644 include/arm_ffa.h
diff --git a/MAINTAINERS b/MAINTAINERS index a26b36c7c2..496f47a516 100644 --- a/MAINTAINERS +++ b/MAINTAINERS @@ -248,6 +248,13 @@ F: drivers/net/cortina_ni.h F: drivers/net/phy/ca_phy.c F: configs/cortina_presidio-asic-pnand_defconfig
+ARM FF-A +M: Abdellatif El Khlifi abdellatif.elkhlifi@arm.com +S: Maintained +F: doc/arch/arm64.ffa.rst +F: drivers/firmware/arm-ffa/ +F: include/arm_ffa.h + ARM FREESCALE IMX M: Stefano Babic sbabic@denx.de M: Fabio Estevam festevam@gmail.com diff --git a/doc/arch/arm64.ffa.rst b/doc/arch/arm64.ffa.rst new file mode 100644 index 0000000000..e98d2cf2b3 --- /dev/null +++ b/doc/arch/arm64.ffa.rst @@ -0,0 +1,207 @@ +.. SPDX-License-Identifier: GPL-2.0+ + +Arm FF-A Driver +=============== + +Summary +------- + +FF-A stands for Firmware Framework for Arm A-profile processors. + +FF-A specifies interfaces that enable a pair of software sandboxes to +communicate with each other. A sandbox aka partition could +be a VM in the Normal or Secure world, an application in S-EL0, or a +Trusted OS in S-EL1. + +This FF-A driver implements the interfaces to communicate with partitions in +the Secure world aka Secure partitions (SPs). + +The driver specifically focuses on communicating with SPs that isolate portions +of EFI runtime services that must run in a protected environment which is +inaccessible by the Host OS or Hypervisor. Examples of such services are +set/get variables. + +FF-A driver uses the SMC ABIs defined by the FF-A specification to: + +- Discover the presence of SPs of interest +- Access an SP's service through communication protocols + e.g. EFI MM communication protocol + +FF-A and SMC specifications +------------------------------------------- + +The current implementation of the driver relies on FF-A specification v1.0 +and uses SMC32 calling convention. + +At this stage we only need the FF-A v1.0 features. + +The driver has been tested with Optee OS which supports SMC32 for most of +the SMC ABIs. + +For more details please refer to the FF-A v1.0 spec: +https://documentation-service.arm.com/static/5fb7e8a6ca04df4095c1d65e?token= + +Hypervisors are supported if they are configured to trap SMC calls. + +The FF-A driver uses 64-bit registers as per SMCCCv1.2 specification. + +For more details please refer to the SMC Calling Convention v1.2 spec: +https://documentation-service.arm.com/static/5f8edaeff86e16515cdbe4c6?token= + +Supported hardware +-------------------------------- + +Aarch64 plaforms + +Configuration +---------------------- + +CONFIG_ARM_FFA_TRANSPORT + Enables the FF-A bus driver. Turn this on if you want to use FF-A + communication. + +CONFIG_SANDBOX_FFA + Enables FF-A Sandbox driver. This emulates the FF-A ABIs handling under + Sandbox and provides functional tests for FF-A. + +FF-A ABIs under the hood +--------------------------------------- + +Invoking an FF-A ABI involves providing to the secure world/hypervisor the +expected arguments from the ABI. + +The ABI arguments are stored in x0 to x7 registers. Then, an SMC instruction +is executed. + +At the secure side level or hypervisor the ABI is handled at a higher exception +level and the arguments are read and processed. + +The response is put back through x0 to x7 registers and control is given back +to the U-boot FF-A driver (non-secure world). + +The driver reads the response and processes it accordingly. + +This methodology applies to all the FF-A ABIs in the driver. + +FF-A bus discovery in U-boot +------------------------------------------- + +When CONFIG_ARM_FFA_TRANSPORT is enabled, the FF-A bus is discovered on +demand by the clients (users). + +Clients can discover the FF-A bus using ffa_bus_discover() API which triggers the +discovery process. + +ffa_bus_discover() creates, binds and probes the arm_ffa device using +device_{bind, probe} APIs. + +The discovery process consists in communicating with secure world (or hypervisor) +and querying specific data. + +The discovery process takes place during the arm_ffa device probing which is +handled by ffa_probe(). + +The FF-A bus discovery is successful and the bus is ready for use when these +operations succeed: + +- querying the FF-A framework version +- querying from secure world the U-boot endpoint ID +- querying from secure world the RX/TX mapping features +- mapping the RX/TX buffers +- querying from secure world all the partitions information + +Discovery failure results in a probing failure and the arm_ffa device is +destroyed. + +Requirements for clients +------------------------------------- + +When using the FF-A bus with EFI, clients must: + +- Query SPs in EFI boot time mode using the service UUID. +- Unmap RX/TX buffers before EFI runtime mode starts. + +The RX/TX buffers are only available at EFI boot time. Querying partitions is +done at boot time and data is cached for future use. + +RX/TX buffers should be unmapped by the user before EFI runtime mode +starts. The driver provides a bus operation for that: rxtx_unmap() + +If RX/TX buffers created by U-boot are not unmapped and by +consequence becoming available at EFI runtime, secure world will get confused +about RX/TX buffers ownership (U-boot vs kernel). + +The bus driver layer +------------------------------ + +The driver comes on top of the SMCCC layer and is implemented in +drivers/firmware/arm-ffa/core.c + +The driver provides the following features: + +- Support for the 32-bit version of the following ABIs: + +FFA_VERSION +FFA_ID_GET +FFA_FEATURES +FFA_PARTITION_INFO_GET +FFA_RXTX_UNMAP +FFA_RX_RELEASE +FFA_RUN +FFA_ERROR +FFA_SUCCESS +FFA_INTERRUPT + +- Support for the 64-bit version of the following ABIs: + +FFA_RXTX_MAP +FFA_MSG_SEND_DIRECT_REQ +FFA_MSG_SEND_DIRECT_RESP + +- Processing the received data from the secure world/hypervisor and caching it + +- Hiding from upper layers the FF-A protocol and registers details. Upper + layers focus on exchanged data, the driver takes care of how to transport + that to the secure world/hypervisor using FF-A + +- The driver provides callbacks to be used by clients to access the FF-A bus: + +partition_info_get +sync_send_receive +rxtx_unmap + +- FF-A bus discovery makes sure FF-A framework is responsive and compatible + with the driver + +- FF-A bus can be compiled and used without EFI + +Using armffa command +----------------------------------- + +armffa is a command showcasing how to use the FF-A driver and how to invoke +its operations. + +This provides a guidance to the client developers on how to call the FF-A bus +interfaces. + +Usage: + +armffa <sub-command> <arguments> + +sub-commands: + + getpart <partition UUID> + + lists the partition(s) info + + ping <partition ID> + + sends a data pattern to the specified partition + + devlist + + displays the arm_ffa device info + +Contributors +------------ + * Abdellatif El Khlifi abdellatif.elkhlifi@arm.com diff --git a/doc/arch/index.rst b/doc/arch/index.rst index 792d9182c3..8d1ab0ad4e 100644 --- a/doc/arch/index.rst +++ b/doc/arch/index.rst @@ -8,6 +8,7 @@ Architecture-specific doc
arc arm64 + arm64.ffa m68k mips nios2 diff --git a/drivers/Kconfig b/drivers/Kconfig index 8b6fead351..b06b1ae481 100644 --- a/drivers/Kconfig +++ b/drivers/Kconfig @@ -6,6 +6,8 @@ source "drivers/core/Kconfig"
source "drivers/adc/Kconfig"
+source "drivers/firmware/arm-ffa/Kconfig" + source "drivers/ata/Kconfig"
source "drivers/axi/Kconfig" diff --git a/drivers/Makefile b/drivers/Makefile index 9d9f69a3c9..bf8d7b8cfc 100644 --- a/drivers/Makefile +++ b/drivers/Makefile @@ -111,6 +111,7 @@ obj-y += iommu/ obj-y += smem/ obj-y += thermal/ obj-$(CONFIG_TEE) += tee/ +obj-$(CONFIG_ARM_FFA_TRANSPORT) += firmware/arm-ffa/ obj-y += axi/ obj-y += ufs/ obj-$(CONFIG_W1) += w1/ diff --git a/drivers/firmware/arm-ffa/Kconfig b/drivers/firmware/arm-ffa/Kconfig new file mode 100644 index 0000000000..f1427535f9 --- /dev/null +++ b/drivers/firmware/arm-ffa/Kconfig @@ -0,0 +1,30 @@ +# SPDX-License-Identifier: GPL-2.0 + +config ARM_FFA_TRANSPORT + bool "Enable Arm Firmware Framework for Armv8-A driver" + depends on DM && ARM64 + select ARM_SMCCC + select LIB_UUID + select DEVRES + help + The Firmware Framework for Arm A-profile processors (FF-A) + describes interfaces (ABIs) that standardize communication + between the Secure World and Normal World leveraging TrustZone + technology. + + This driver is based on FF-A specification v1.0 and uses SMC32 + calling convention. + + FF-A specification: + + https://developer.arm.com/documentation/den0077/a/?lang=en + + In u-boot FF-A design, FF-A is considered as a discoverable bus. + The Secure World is considered as one entity to communicate with + using the FF-A bus. + FF-A communication is handled by one device and one instance (the bus). + This FF-A driver takes care of all the interactions between Normal world + and Secure World. + + For more details about the FF-A driver, please refer to doc/README.ffa.drv + diff --git a/drivers/firmware/arm-ffa/Makefile b/drivers/firmware/arm-ffa/Makefile new file mode 100644 index 0000000000..043a8915be --- /dev/null +++ b/drivers/firmware/arm-ffa/Makefile @@ -0,0 +1,6 @@ +# SPDX-License-Identifier: GPL-2.0+ +# +# (C) Copyright 2022 +# Abdellatif El Khlifi, Arm Limited, abdellatif.elkhlifi@arm.com. + +obj-y += arm-ffa-uclass.o core.o diff --git a/drivers/firmware/arm-ffa/arm-ffa-uclass.c b/drivers/firmware/arm-ffa/arm-ffa-uclass.c new file mode 100644 index 0000000000..7d9695d289 --- /dev/null +++ b/drivers/firmware/arm-ffa/arm-ffa-uclass.c @@ -0,0 +1,16 @@ +// SPDX-License-Identifier: GPL-2.0+ +/* + * (C) Copyright 2022 ARM Limited + * Abdellatif El Khlifi abdellatif.elkhlifi@arm.com + */ + +#include <common.h> +#include <dm.h> +#include <asm/global_data.h> + +DECLARE_GLOBAL_DATA_PTR; + +UCLASS_DRIVER(ffa) = { + .name = "ffa", + .id = UCLASS_FFA, +}; diff --git a/drivers/firmware/arm-ffa/arm_ffa_prv.h b/drivers/firmware/arm-ffa/arm_ffa_prv.h new file mode 100644 index 0000000000..7bc90f7f66 --- /dev/null +++ b/drivers/firmware/arm-ffa/arm_ffa_prv.h @@ -0,0 +1,196 @@ +/* SPDX-License-Identifier: GPL-2.0+ */ +/* + * (C) Copyright 2022 ARM Limited + * Abdellatif El Khlifi abdellatif.elkhlifi@arm.com + */ + +#ifndef __ARM_FFA_PRV_H +#define __ARM_FFA_PRV_H + +#include <arm_ffa.h> +#include <linux/bitfield.h> +#include <linux/bitops.h> +#include <linux/arm-smccc.h> + +/* + * This header is private. It is exclusively used by the FF-A driver + */ + +/* FF-A core driver name */ +#define FFA_DRV_NAME "arm_ffa" + +/* FF-A driver version definitions */ + +#define MAJOR_VERSION_MASK GENMASK(30, 16) +#define MINOR_VERSION_MASK GENMASK(15, 0) +#define GET_FFA_MAJOR_VERSION(x) \ + ((u16)(FIELD_GET(MAJOR_VERSION_MASK, (x)))) +#define GET_FFA_MINOR_VERSION(x) \ + ((u16)(FIELD_GET(MINOR_VERSION_MASK, (x)))) +#define PACK_VERSION_INFO(major, minor) \ + (FIELD_PREP(MAJOR_VERSION_MASK, (major)) | \ + FIELD_PREP(MINOR_VERSION_MASK, (minor))) + +#define FFA_MAJOR_VERSION (1) +#define FFA_MINOR_VERSION (0) +#define FFA_VERSION_1_0 \ + PACK_VERSION_INFO(FFA_MAJOR_VERSION, FFA_MINOR_VERSION) + +/* Endpoint ID mask (u-boot endpoint ID) */ + +#define GET_SELF_ENDPOINT_ID_MASK GENMASK(15, 0) +#define GET_SELF_ENDPOINT_ID(x) \ + ((u16)(FIELD_GET(GET_SELF_ENDPOINT_ID_MASK, (x)))) + +#define PREP_SELF_ENDPOINT_ID_MASK GENMASK(31, 16) +#define PREP_SELF_ENDPOINT_ID(x) \ + (FIELD_PREP(PREP_SELF_ENDPOINT_ID_MASK, (x))) + +/* Partition endpoint ID mask (partition with which u-boot communicates with) */ + +#define PREP_PART_ENDPOINT_ID_MASK GENMASK(15, 0) +#define PREP_PART_ENDPOINT_ID(x) \ + (FIELD_PREP(PREP_PART_ENDPOINT_ID_MASK, (x))) + +/* + * Definitions of the Arm FF-A interfaces supported by the Arm FF-A driver + */ + +#define FFA_SMC(calling_convention, func_num) \ + ARM_SMCCC_CALL_VAL(ARM_SMCCC_FAST_CALL, (calling_convention), \ + ARM_SMCCC_OWNER_STANDARD, (func_num)) + +#define FFA_SMC_32(func_num) FFA_SMC(ARM_SMCCC_SMC_32, (func_num)) +#define FFA_SMC_64(func_num) FFA_SMC(ARM_SMCCC_SMC_64, (func_num)) + +enum ffa_abis { + FFA_ERROR = 0x60, + FFA_SUCCESS = 0x61, + FFA_INTERRUPT = 0x62, + FFA_VERSION = 0x63, + FFA_FEATURES = 0x64, + FFA_RX_RELEASE = 0x65, + FFA_RXTX_MAP = 0x66, + FFA_RXTX_UNMAP = 0x67, + FFA_PARTITION_INFO_GET = 0x68, + FFA_ID_GET = 0x69, + FFA_RUN = 0x6D, + FFA_MSG_SEND_DIRECT_REQ = 0x6F, + FFA_MSG_SEND_DIRECT_RESP = 0x70, + + /* to be updated when adding new FFA IDs */ + FFA_FIRST_ID = FFA_ERROR, /* lowest number ID*/ + FFA_LAST_ID = FFA_MSG_SEND_DIRECT_RESP, /* highest number ID*/ +}; + +/* number of the errors supported by the FF-A specification */ +#define MAX_NUMBER_FFA_ERR 9 + +/* container structure and helper macros to map between an FF-A error and relevant error log */ +struct ffa_abi_errmap { + char *err_str[MAX_NUMBER_FFA_ERR]; +}; + +#define FFA_ERRMAP_COUNT (FFA_LAST_ID - FFA_FIRST_ID + 1) +#define FFA_ID_TO_ERRMAP_ID(ffa_id) ((ffa_id) - FFA_FIRST_ID) + +/* The FF-A SMC function definitions */ + +typedef struct arm_smccc_1_2_regs ffa_value_t; +typedef void (*invoke_ffa_fn_t)(ffa_value_t args, ffa_value_t *res); + +/* + * struct ffa_partition_uuid - 16 bytes UUID transmitted by FFA_PARTITION_INFO_GET + * @a1-4: 32-bit words access to the UUID data + * + */ +struct ffa_partition_uuid { + u32 a1; /* w1 */ + u32 a2; /* w2 */ + u32 a3; /* w3 */ + u32 a4; /* w4 */ +}; + +/** + * enum ffa_rxtx_buf_sizes - minimum sizes supported + * for the RX/TX buffers + */ +enum ffa_rxtx_buf_sizes { + RXTX_4K, + RXTX_64K, + RXTX_16K +}; + +/** + * struct ffa_rxtxpair - structure hosting the RX/TX buffers virtual addresses + * @rxbuf: virtual address of the RX buffer + * @txbuf: virtual address of the TX buffer + * @rxtx_min_pages: RX/TX buffers minimum size in pages + * + * Data structure hosting the virtual addresses of the mapped RX/TX buffers + * These addresses are used by the FF-A functions that use the RX/TX buffers + */ +struct ffa_rxtxpair { + u64 rxbuf; /* virtual address */ + u64 txbuf; /* virtual address */ + size_t rxtx_min_pages; /* minimum number of pages in each of the RX/TX buffers */ +}; + +/** + * struct ffa_partition_desc - the secure partition descriptor + * @info: partition information + * @sp_uuid: the secure partition UUID + * + * Each partition has its descriptor containing the partitions information and the UUID + */ +struct ffa_partition_desc { + struct ffa_partition_info info; + struct ffa_partition_uuid sp_uuid; +}; + +/** + * struct ffa_partitions - descriptors for all secure partitions + * @count: The number of partitions descriptors + * @descs The partitions descriptors table + * + * This data structure contains the partitions descriptors table + */ +struct ffa_partitions { + u32 count; + struct ffa_partition_desc *descs; /* virtual address */ +}; + +/** + * struct ffa_prvdata - the driver private data structure + * + * @dev: The arm_ffa device under u-boot driver model + * @ffa_ops: The driver operations structure + * @fwk_version: FF-A framework version + * @id: u-boot endpoint ID + * @partitions: The partitions descriptors structure + * @pair: The RX/TX buffers pair + * @invoke_ffa_fn: The function executing the FF-A function + * + * The driver data structure hosting all resident data. + */ +struct ffa_prvdata { + struct udevice *dev; + struct ffa_bus_ops ffa_ops; + u32 fwk_version; + u16 id; + struct ffa_partitions partitions; + struct ffa_rxtxpair pair; + invoke_ffa_fn_t invoke_ffa_fn; +}; + +/** + * ffa_device_get - create, bind and probe the arm_ffa device + */ +int ffa_device_get(void); + +/** + * ffa_bus_prvdata_get - bus driver private data getter + */ +struct ffa_prvdata **ffa_bus_prvdata_get(void); + +#endif diff --git a/drivers/firmware/arm-ffa/core.c b/drivers/firmware/arm-ffa/core.c new file mode 100644 index 0000000000..324367d12b --- /dev/null +++ b/drivers/firmware/arm-ffa/core.c @@ -0,0 +1,1337 @@ +// SPDX-License-Identifier: GPL-2.0+ +/* + * (C) Copyright 2022 ARM Limited + * Abdellatif El Khlifi abdellatif.elkhlifi@arm.com + */ + +#include "arm_ffa_prv.h" +#include <asm/global_data.h> +#include <common.h> +#include <dm.h> +#include <dm/device-internal.h> +#include <dm/devres.h> +#include <dm/root.h> +#include <linux/errno.h> +#include <linux/sizes.h> +#include <log.h> +#include <malloc.h> +#include <string.h> +#include <uuid.h> + +DECLARE_GLOBAL_DATA_PTR; + +/** + * The device private data structure containing all the + * data read from secure world + */ +struct ffa_prvdata *ffa_priv_data; + +/* Error mapping declarations */ + +int ffa_to_std_errmap[MAX_NUMBER_FFA_ERR] = { + 0, + -EOPNOTSUPP, /* NOT_SUPPORTED */ + -EINVAL, /* INVALID_PARAMETERS */ + -ENOMEM, /* NO_MEMORY */ + -EBUSY, /* BUSY */ + -EINTR, /* INTERRUPTED */ + -EACCES, /* DENIED */ + -EAGAIN, /* RETRY */ + -ECANCELED, /* ABORTED */ +}; + +struct ffa_abi_errmap err_msg_map[FFA_ERRMAP_COUNT] = { + [FFA_ID_TO_ERRMAP_ID(FFA_VERSION)] = { + { + "", + "NOT_SUPPORTED: A Firmware Framework implementation does not exist", + "", /* INVALID_PARAMETERS */ + "", /* NO_MEMORY */ + "", /* BUSY */ + "", /* INTERRUPTED */ + "", /* DENIED */ + "", /* RETRY */ + "", /* ABORTED */ + }, + }, + [FFA_ID_TO_ERRMAP_ID(FFA_ID_GET)] = { + { + "", + "NOT_SUPPORTED: This function is not implemented at this FF-A instance", + "", /* INVALID_PARAMETERS */ + "", /* NO_MEMORY */ + "", /* BUSY */ + "", /* INTERRUPTED */ + "", /* DENIED */ + "", /* RETRY */ + "", /* ABORTED */ + }, + }, + [FFA_ID_TO_ERRMAP_ID(FFA_FEATURES)] = { + { + "", + "NOT_SUPPORTED: FFA_RXTX_MAP is not implemented at this FF-A instance", + "", /* INVALID_PARAMETERS */ + "", /* NO_MEMORY */ + "", /* BUSY */ + "", /* INTERRUPTED */ + "", /* DENIED */ + "", /* RETRY */ + "", /* ABORTED */ + }, + }, + [FFA_ID_TO_ERRMAP_ID(FFA_PARTITION_INFO_GET)] = { + { + "", + "NOT_SUPPORTED: This function is not implemented at this FF-A instance", + "INVALID_PARAMETERS: Unrecognized UUID", + "NO_MEMORY: Results cannot fit in RX buffer of the caller", + "BUSY: RX buffer of the caller is not free", + "", /* INTERRUPTED */ + "DENIED: Callee is not in a state to handle this request", + "", /* RETRY */ + "", /* ABORTED */ + }, + }, + [FFA_ID_TO_ERRMAP_ID(FFA_RXTX_UNMAP)] = { + { + "", + "NOT_SUPPORTED: FFA_RXTX_UNMAP is not implemented at this FF-A instance", + "INVALID_PARAMETERS: No buffer pair registered on behalf of the caller", + "", /* NO_MEMORY */ + "", /* BUSY */ + "", /* INTERRUPTED */ + "", /* DENIED */ + "", /* RETRY */ + "", /* ABORTED */ + }, + }, + [FFA_ID_TO_ERRMAP_ID(FFA_RX_RELEASE)] = { + { + "", + "NOT_SUPPORTED: FFA_RX_RELEASE is not implemented at this FF-A instance", + "", /* INVALID_PARAMETERS */ + "", /* NO_MEMORY */ + "", /* BUSY */ + "", /* INTERRUPTED */ + "DENIED: Caller did not have ownership of the RX buffer", + "", /* RETRY */ + "", /* ABORTED */ + }, + }, + [FFA_ID_TO_ERRMAP_ID(FFA_RXTX_MAP)] = { + { + "", + "NOT_SUPPORTED: This function is not implemented at this FF-A instance", + "INVALID_PARAMETERS: Field(s) in input parameters incorrectly encoded", + "NO_MEMORY: Not enough memory", + "", /* BUSY */ + "", /* INTERRUPTED */ + "DENIED: Buffer pair already registered", + "", /* RETRY */ + "", /* ABORTED */ + }, + }, +}; + +/** + * ffa_to_std_errno - convert FF-A error code to standard error code + * @ffa_errno: Error code returned by the FF-A ABI + * + * This function maps the given FF-A error code as specified + * by the spec to a u-boot standard error code. + * + * Return: + * + * The standard error code on success. . Otherwise, failure + */ +int ffa_to_std_errno(int ffa_errno) +{ + int err_idx = -ffa_errno; + + /* map the FF-A error code to the standard u-boot error code */ + if (err_idx > 0 && err_idx < MAX_NUMBER_FFA_ERR) + return ffa_to_std_errmap[err_idx]; + return -EINVAL; +} + +/** + * ffa_print_error_log - print the error log corresponding to the selected FF-A ABI + * @ffa_id: FF-A ABI ID + * @ffa_errno: Error code returned by the FF-A ABI + * + * This function maps the FF-A error code to the error log relevant to the + * selected FF-A ABI. Then the error log is printed. + * + * Return: + * + * 0 on success. . Otherwise, failure + */ +int ffa_print_error_log(u32 ffa_id, int ffa_errno) +{ + int err_idx = -ffa_errno, abi_idx = 0; + + /* map the FF-A error code to the corresponding error log */ + + if (err_idx <= 0 || err_idx >= MAX_NUMBER_FFA_ERR) + return -EINVAL; + + if (ffa_id < FFA_FIRST_ID || ffa_id > FFA_LAST_ID) + return -EINVAL; + + abi_idx = FFA_ID_TO_ERRMAP_ID(ffa_id); + if (abi_idx < 0 || abi_idx >= FFA_ERRMAP_COUNT) + return -EINVAL; + + if (!err_msg_map[abi_idx].err_str || !err_msg_map[abi_idx].err_str[err_idx]) + return -EINVAL; + + ffa_err("%s", err_msg_map[abi_idx].err_str[err_idx]); + + return 0; +} + +/* + * Driver core functions + */ + +/** + * ffa_remove_device - removes the arm_ffa device + * @dev: the device to be removed + * + * This function makes sure the arm_ffa device is removed + * No need to free the kmalloced data when the device is destroyed. + * It's automatically done by devm management by + * device_remove() -> device_free() -> devres_release_probe(). + * + * Return: + * + * 0 on success. Otherwise, failure + */ +int ffa_remove_device(struct udevice *dev) +{ + int ret; + + if (!dev) { + ffa_err("no udevice found"); + return -ENODEV; + } + + ret = device_remove(dev, DM_REMOVE_NORMAL); + if (ret) { + ffa_err("unable to remove. err:%d\n", ret); + return ret; + } + + ffa_info("device removed and freed"); + + ret = device_unbind(dev); + if (ret) { + ffa_err("unable to unbind. err:%d\n", ret); + return ret; + } + + ffa_info("device unbound"); + + return 0; +} + +/** + * ffa_device_get - create, bind and probe the arm_ffa device + * + * This function makes sure the arm_ffa device is + * created, bound to this driver, probed and ready to use. + * Arm FF-A transport is implemented through a single u-boot + * device managing the FF-A bus (arm_ffa). + * + * Return: + * + * 0 on success. Otherwise, failure + */ +int ffa_device_get(void) +{ + int ret; + struct udevice *dev = NULL; + + ret = device_bind(dm_root(), + DM_DRIVER_GET(arm_ffa), + FFA_DRV_NAME, + NULL, + ofnode_null(), + &dev); + if (ret) + return ret; + + /* The FF-A bus discovery succeeds when probing is successful */ + ret = device_probe(dev); + if (ret) { + ffa_err("arm_ffa device probing failed"); + ffa_remove_device(dev); + return ret; + } + + return 0; +} + +/** + * ffa_get_version - FFA_VERSION handler function + * + * This function implements FFA_VERSION FF-A function + * to get from the secure world the FF-A framework version + * + * Return: + * + * 0 on success. Otherwise, failure + */ +static int ffa_get_version(void) +{ + u16 major, minor; + ffa_value_t res = {0}; + int ffa_errno; + + ffa_priv_data->invoke_ffa_fn((ffa_value_t){ + .a0 = FFA_SMC_32(FFA_VERSION), + .a1 = FFA_VERSION_1_0 + }, &res); + + ffa_errno = res.a0; + if (ffa_errno < 0) { + ffa_print_error_log(FFA_VERSION, ffa_errno); + return ffa_to_std_errno(ffa_errno); + } + + major = GET_FFA_MAJOR_VERSION(res.a0); + minor = GET_FFA_MINOR_VERSION(res.a0); + + ffa_info("FF-A driver %d.%d\nFF-A framework %d.%d", + FFA_MAJOR_VERSION, FFA_MINOR_VERSION, major, minor); + + if ((major == FFA_MAJOR_VERSION && minor >= FFA_MINOR_VERSION)) { + ffa_info("Versions are compatible "); + + ffa_priv_data->fwk_version = res.a0; + + return 0; + } + + ffa_err("versions are incompatible\nExpected: %d.%d , Found: %d.%d\n", + FFA_MAJOR_VERSION, FFA_MINOR_VERSION, major, minor); + + return -EPROTONOSUPPORT; +} + +/** + * ffa_get_endpoint_id - FFA_ID_GET handler function + * + * This function implements FFA_ID_GET FF-A function + * to get from the secure world u-boot endpoint ID + * + * Return: + * + * 0 on success. Otherwise, failure + */ +static int ffa_get_endpoint_id(void) +{ + ffa_value_t res = {0}; + int ffa_errno; + + ffa_priv_data->invoke_ffa_fn((ffa_value_t){ + .a0 = FFA_SMC_32(FFA_ID_GET) + }, &res); + + if (res.a0 == FFA_SMC_32(FFA_SUCCESS)) { + ffa_priv_data->id = GET_SELF_ENDPOINT_ID((u32)res.a2); + ffa_info("endpoint ID is %u", ffa_priv_data->id); + + return 0; + } + + ffa_errno = res.a2; + + ffa_print_error_log(FFA_ID_GET, ffa_errno); + + return ffa_to_std_errno(ffa_errno); +} + +/** + * ffa_set_rxtx_buffers_pages_cnt - sets the minimum number of pages in each of the RX/TX buffers + * @prop_field: properties field obtained from FFA_FEATURES ABI + * + * This function sets the minimum number of pages + * in each of the RX/TX buffers in the private data structure + * + * Return: + * + * buf_4k_pages points to the returned number of pages + * 0 on success. Otherwise, failure + */ +static int ffa_set_rxtx_buffers_pages_cnt(u32 prop_field) +{ + if (!ffa_priv_data) + return -EINVAL; + + switch (prop_field) { + case RXTX_4K: + ffa_priv_data->pair.rxtx_min_pages = 1; + break; + case RXTX_16K: + ffa_priv_data->pair.rxtx_min_pages = 4; + break; + case RXTX_64K: + ffa_priv_data->pair.rxtx_min_pages = 16; + break; + default: + ffa_err("RX/TX buffer size not supported"); + return -EINVAL; + } + + return 0; +} + +/** + * ffa_get_rxtx_map_features - FFA_FEATURES handler function with FFA_RXTX_MAP argument + * + * This function implements FFA_FEATURES FF-A function + * to retrieve the FFA_RXTX_MAP features + * + * Return: + * + * 0 on success. Otherwise, failure + */ +static int ffa_get_rxtx_map_features(void) +{ + ffa_value_t res = {0}; + int ffa_errno; + + ffa_priv_data->invoke_ffa_fn((ffa_value_t){ + .a0 = FFA_SMC_32(FFA_FEATURES), + .a1 = FFA_SMC_64(FFA_RXTX_MAP) + }, &res); + + if (res.a0 == FFA_SMC_32(FFA_SUCCESS)) + return ffa_set_rxtx_buffers_pages_cnt((u32)res.a2); + + ffa_errno = res.a2; + ffa_print_error_log(FFA_FEATURES, ffa_errno); + + return ffa_to_std_errno(ffa_errno); +} + +/** + * ffa_free_rxtx_buffers - frees the RX/TX buffers + * + * This function frees the RX/TX buffers + * + */ +static void ffa_free_rxtx_buffers(void) +{ + ffa_info("Freeing RX/TX buffers"); + + if (ffa_priv_data->pair.rxbuf) { + free((void *)ffa_priv_data->pair.rxbuf); + ffa_priv_data->pair.rxbuf = 0; + } + + if (ffa_priv_data->pair.txbuf) { + free((void *)ffa_priv_data->pair.txbuf); + ffa_priv_data->pair.txbuf = 0; + } +} + +/** + * ffa_alloc_rxtx_buffers - allocates the RX/TX buffers + * + * This function is used by ffa_map_rxtx_buffers to allocate + * the RX/TX buffers before mapping them. The allocated memory is physically + * contiguous since memalign ends up calling malloc which allocates + * contiguous memory in u-boot. + * + * Return: + * + * 0 on success. Otherwise, failure + */ +static int ffa_alloc_rxtx_buffers(void) +{ + u64 bytes; + + ffa_info("Using %lu 4KB page(s) for RX/TX buffers size", + ffa_priv_data->pair.rxtx_min_pages); + + bytes = ffa_priv_data->pair.rxtx_min_pages * SZ_4K; + + /* + * The alignment of the RX and TX buffers must be equal + * to the larger translation granule size + */ + + ffa_priv_data->pair.rxbuf = (u64)memalign(bytes, bytes); + if (!ffa_priv_data->pair.rxbuf) { + ffa_err("failure to allocate RX buffer"); + return -ENOBUFS; + } + + ffa_info("RX buffer at virtual address 0x%llx", ffa_priv_data->pair.rxbuf); + + ffa_priv_data->pair.txbuf = (u64)memalign(bytes, bytes); + if (!ffa_priv_data->pair.txbuf) { + free((void *)ffa_priv_data->pair.rxbuf); + ffa_priv_data->pair.rxbuf = 0; + ffa_err("failure to allocate the TX buffer"); + return -ENOBUFS; + } + + ffa_info("TX buffer at virtual address 0x%llx", ffa_priv_data->pair.txbuf); + + /* + * make sure the buffers are cleared before use + */ + memset((void *)ffa_priv_data->pair.rxbuf, 0, bytes); + memset((void *)ffa_priv_data->pair.txbuf, 0, bytes); + + return 0; +} + +/** + * ffa_map_rxtx_buffers - FFA_RXTX_MAP handler function + * + * This function implements FFA_RXTX_MAP FF-A function + * to map the RX/TX buffers + * + * Return: + * + * 0 on success. Otherwise, failure + */ +static int ffa_map_rxtx_buffers(void) +{ + int ret; + ffa_value_t res = {0}; + int ffa_errno; + + ret = ffa_alloc_rxtx_buffers(); + if (ret) + return ret; + + /* + * we need to pass the physical addresses of the RX/TX buffers + * in u-boot physical/virtual mapping is 1:1 + *no need to convert from virtual to physical + */ + + ffa_priv_data->invoke_ffa_fn((ffa_value_t){ + .a0 = FFA_SMC_64(FFA_RXTX_MAP), + .a1 = ffa_priv_data->pair.txbuf, + .a2 = ffa_priv_data->pair.rxbuf, + .a3 = ffa_priv_data->pair.rxtx_min_pages, + }, &res); + + if (res.a0 == FFA_SMC_32(FFA_SUCCESS)) { + ffa_info("RX/TX buffers mapped"); + return 0; + } + + ffa_errno = res.a2; + ffa_print_error_log(FFA_RXTX_MAP, ffa_errno); + + ffa_free_rxtx_buffers(); + + return ffa_to_std_errno(ffa_errno); +} + +/** + * ffa_unmap_rxtx_buffers - FFA_RXTX_UNMAP handler function + * + * This function implements FFA_RXTX_UNMAP FF-A function + * to unmap the RX/TX buffers + * + * Return: + * + * 0 on success. Otherwise, failure + */ +static int ffa_unmap_rxtx_buffers(void) +{ + ffa_value_t res = {0}; + int ffa_errno; + + ffa_priv_data->invoke_ffa_fn((ffa_value_t){ + .a0 = FFA_SMC_32(FFA_RXTX_UNMAP), + .a1 = PREP_SELF_ENDPOINT_ID(ffa_priv_data->id) + }, &res); + + if (res.a0 == FFA_SMC_32(FFA_SUCCESS)) { + ffa_free_rxtx_buffers(); + return 0; + } + + ffa_errno = res.a2; + ffa_print_error_log(FFA_RXTX_UNMAP, ffa_errno); + + return ffa_to_std_errno(ffa_errno); +} + +/** + * ffa_release_rx_buffer - FFA_RX_RELEASE handler function + * + * This function invokes FFA_RX_RELEASE FF-A function + * to release the ownership of the RX buffer + * + * Return: + * + * 0 on success. Otherwise, failure + */ +static int ffa_release_rx_buffer(void) +{ + ffa_value_t res = {0}; + int ffa_errno; + + ffa_priv_data->invoke_ffa_fn((ffa_value_t){ + .a0 = FFA_SMC_32(FFA_RX_RELEASE) + }, &res); + + if (res.a0 == FFA_SMC_32(FFA_SUCCESS)) + return 0; + + ffa_errno = res.a2; + ffa_print_error_log(FFA_RX_RELEASE, ffa_errno); + + return ffa_to_std_errno(ffa_errno); +} + +/** + * ffa_uuid_are_identical - checks whether two given UUIDs are identical + * @uuid1: first UUID + * @uuid2: second UUID + * + * This function is used by ffa_read_partitions_info to search + * for a UUID in the partitions descriptors table + * + * Return: + * + * 1 when UUIDs match. Otherwise, 0 + */ +int ffa_uuid_are_identical(const struct ffa_partition_uuid *uuid1, + const struct ffa_partition_uuid *uuid2) +{ + if (!uuid1 || !uuid2) + return 0; + + return !memcmp(uuid1, uuid2, sizeof(struct ffa_partition_uuid)); +} + +/** + * ffa_read_partitions_info - reads the data queried by FFA_PARTITION_INFO_GET + * and saves it in the private structure + * @count: The number of partitions queried + * @part_uuid: Pointer to the partition(s) UUID + * + * This function reads the partitions information + * returned by the FFA_PARTITION_INFO_GET and saves it in the private + * data structure. + * + * Return: + * + * The private data structure is updated with the partition(s) information + * 0 is returned on success. Otherwise, failure + */ +static int ffa_read_partitions_info(u32 count, struct ffa_partition_uuid *part_uuid) +{ + if (!count) { + ffa_err("no partition detected"); + return -ENODATA; + } + + ffa_info("Reading partitions data from the RX buffer"); + + if (!part_uuid) { + /* + * querying information of all partitions + */ + u64 buf_bytes; + u64 data_bytes; + u32 desc_idx; + struct ffa_partition_info *parts_info; + + data_bytes = count * sizeof(struct ffa_partition_desc); + + buf_bytes = ffa_priv_data->pair.rxtx_min_pages * SZ_4K; + + if (data_bytes > buf_bytes) { + ffa_err("partitions data size exceeds the RX buffer size:"); + ffa_err(" sizes in bytes: data %llu , RX buffer %llu ", + data_bytes, + buf_bytes); + + return -ENOMEM; + } + + ffa_priv_data->partitions.descs = devm_kmalloc(ffa_priv_data->dev, data_bytes, + __GFP_ZERO); + if (!ffa_priv_data->partitions.descs) { + ffa_err("cannot allocate partitions data buffer"); + return -ENOMEM; + } + + parts_info = (struct ffa_partition_info *)ffa_priv_data->pair.rxbuf; + + for (desc_idx = 0 ; desc_idx < count ; desc_idx++) { + ffa_priv_data->partitions.descs[desc_idx].info = + parts_info[desc_idx]; + + ffa_info("Partition ID %x : info cached", + ffa_priv_data->partitions.descs[desc_idx].info.id); + } + + ffa_priv_data->partitions.count = count; + + ffa_info("%d partition(s) found and cached", count); + + } else { + u32 rx_desc_idx, cached_desc_idx; + struct ffa_partition_info *parts_info; + u8 desc_found; + + parts_info = (struct ffa_partition_info *)ffa_priv_data->pair.rxbuf; + + /* + * search for the SP IDs read from the RX buffer + * in the already cached SPs. + * Update the UUID when ID found. + */ + for (rx_desc_idx = 0; rx_desc_idx < count ; rx_desc_idx++) { + desc_found = 0; + + /* + * search the current ID in the cached partitions + */ + for (cached_desc_idx = 0; + cached_desc_idx < ffa_priv_data->partitions.count; + cached_desc_idx++) { + /* + * save the UUID + */ + if (ffa_priv_data->partitions.descs[cached_desc_idx].info.id == + parts_info[rx_desc_idx].id) { + ffa_priv_data->partitions.descs[cached_desc_idx].sp_uuid = + *part_uuid; + + desc_found = 1; + break; + } + } + + if (!desc_found) + return -ENODATA; + } + } + + return 0; +} + +/** + * ffa_query_partitions_info - invokes FFA_PARTITION_INFO_GET and saves partitions data + * + * @part_uuid: Pointer to the partition(s) UUID + * @pcount: Pointer to the number of partitions variable filled when querying + * + * This function executes the FFA_PARTITION_INFO_GET + * to query the partitions data. Then, it calls ffa_read_partitions_info + * to save the data in the private data structure. + * + * After reading the data the RX buffer is released using ffa_release_rx_buffer + * + * Return: + * + * When part_uuid is NULL, all partitions data are retrieved from secure world + * When part_uuid is non NULL, data for partitions matching the given UUID are + * retrieved and the number of partitions is returned + * 0 is returned on success. Otherwise, failure + */ +static int ffa_query_partitions_info(struct ffa_partition_uuid *part_uuid, + u32 *pcount) +{ + struct ffa_partition_uuid query_uuid = {0}; + ffa_value_t res = {0}; + int ffa_errno; + + /* + * If a UUID is specified. Information for one or more + * partitions in the system is queried. Otherwise, information + * for all installed partitions is queried + */ + + if (part_uuid) { + if (!pcount) + return -EINVAL; + + query_uuid = *part_uuid; + } else if (pcount) { + return -EINVAL; + } + + ffa_priv_data->invoke_ffa_fn((ffa_value_t){ + .a0 = FFA_SMC_32(FFA_PARTITION_INFO_GET), + .a1 = query_uuid.a1, + .a2 = query_uuid.a2, + .a3 = query_uuid.a3, + .a4 = query_uuid.a4 + }, &res); + + if (res.a0 == FFA_SMC_32(FFA_SUCCESS)) { + int ret; + + /* + * res.a2 contains the count of partition information descriptors + * populated in the RX buffer + */ + if (res.a2) { + ret = ffa_read_partitions_info((u32)res.a2, part_uuid); + if (ret) { + ffa_err("failed to read partition(s) data , error (%d)", ret); + ffa_release_rx_buffer(); + return -EINVAL; + } + } + + /* + * return the SP count (when querying using a UUID) + */ + if (pcount) + *pcount = (u32)res.a2; + + /* + * After calling FFA_PARTITION_INFO_GET the buffer ownership + * is assigned to the consumer (u-boot). So, we need to give + * the ownership back to the SPM or hypervisor + */ + ret = ffa_release_rx_buffer(); + + return ret; + } + + ffa_errno = res.a2; + ffa_print_error_log(FFA_PARTITION_INFO_GET, ffa_errno); + + return ffa_to_std_errno(ffa_errno); +} + +/** + * ffa_get_partitions_info - FFA_PARTITION_INFO_GET handler function + * + * The passed arguments: + * Mode 1: When getting from the driver the number of + * secure partitions: + * @uuid_str: pointer to the UUID string + * @parts_size: pointer to the variable that contains the number of partitions + * The variable will be set by the driver + * @buffer: NULL + * + * Mode 2: When requesting the driver to return the + * partitions information: + * @uuid_str: pointer to the UUID string + * @parts_size: pointer to the size of the SPs information buffer in bytes + * @buffer: pointer to SPs information buffer + * (allocated by the client). + * The buffer will be filled by the driver + * + * This function queries the secure partition data from + * the private data structure. If not found, it invokes FFA_PARTITION_INFO_GET + * FF-A function to query the partition information from secure world. + * + * A client of the FF-A driver should know the UUID of the service it wants to + * access. It should use the UUID to request the FF-A driver to provide the + * partition(s) information of the service. The FF-A driver uses + * PARTITION_INFO_GET to obtain this information. This is implemented through + * ffa_get_partitions_info function. + * A new FFA_PARTITION_INFO_GET call is issued (first one performed through + * ffa_cache_partitions_info) allowing to retrieve the partition(s) information. + * They are not saved (already done). We only update the UUID in the cached area. + * This assumes that partitions data does not change in the secure world. + * Otherwise u-boot will have an outdated partition data. The benefit of caching + * the information in the FF-A driver is to accommodate discovery after + * ExitBootServices(). + * + * When invoked through a client request, ffa_get_partitions_info should be + * called twice. First call is to get from the driver the number of secure + * partitions (SPs) associated to a particular UUID. + * Then, the caller (client) allocates the buffer to host the SPs data and + * issues a 2nd call. Then, the driver fills the SPs data in the pre-allocated + * buffer. + * + * To achieve the mechanism described above, ffa_get_partitions_info uses the + * following functions: + * ffa_read_partitions_info + * ffa_query_partitions_info + * + * Return: + * + * @parts_size: When pointing to the number of partitions variable, the number is + * set by the driver. + * When pointing to the partitions information buffer size, the buffer will be + * filled by the driver. + * + * On success 0 is returned. Otherwise, failure + */ +static int ffa_get_partitions_info(const char *uuid_str, + u32 *parts_size, struct ffa_partition_info *buffer) +{ + /* + * fill_data: + * 0: return the SP count + * 1: fill SP data and return it to the caller + * -1: undefined mode + */ + int fill_data = -1; + u32 desc_idx, client_desc_idx; + struct ffa_partition_uuid part_uuid = {0}; + u32 client_desc_max_cnt; + u32 parts_found = 0; + + if (!ffa_priv_data->partitions.count || !ffa_priv_data->partitions.descs) { + ffa_err("no partition installed"); + return -EINVAL; + } + + if (!uuid_str) { + ffa_err("no UUID provided"); + return -EINVAL; + } + + if (!parts_size) { + ffa_err("no size/count provided"); + return -EINVAL; + } + + if (be_uuid_str_to_le_bin(uuid_str, (unsigned char *)&part_uuid)) { + ffa_err("invalid UUID"); + return -EINVAL; + } + + if (!buffer) { + /* Mode 1: getting the number of secure partitions */ + + fill_data = 0; + + ffa_info("Preparing for checking partitions count"); + + } else if ((*parts_size >= sizeof(struct ffa_partition_info)) && + !(*parts_size % sizeof(struct ffa_partition_info))) { + /* Mode 2: retrieving the partitions information */ + + fill_data = 1; + + client_desc_idx = 0; + + /* + * number of empty descriptors preallocated by the caller + */ + client_desc_max_cnt = *parts_size / sizeof(struct ffa_partition_info); + + ffa_info("Preparing for filling partitions info"); + + } else { + ffa_err("invalid function arguments provided"); + return -EINVAL; + } + + ffa_info("Searching partitions using the provided UUID"); + + /* + * search in the cached partitions + */ + for (desc_idx = 0; + desc_idx < ffa_priv_data->partitions.count; + desc_idx++) { + if (ffa_uuid_are_identical(&ffa_priv_data->partitions.descs[desc_idx].sp_uuid, + &part_uuid)) { + ffa_info("Partition ID %x matches the provided UUID", + ffa_priv_data->partitions.descs[desc_idx].info.id); + + parts_found++; + + if (fill_data) { + /* + * trying to fill the partition info in the input buffer + */ + + if (client_desc_idx < client_desc_max_cnt) { + buffer[client_desc_idx++] = + ffa_priv_data->partitions.descs[desc_idx].info; + continue; + } + + ffa_err("failed to fill the current descriptor client buffer full"); + return -ENOBUFS; + } + } + } + + if (!parts_found) { + int ret; + + ffa_info("No partition found. Querying framework ..."); + + ret = ffa_query_partitions_info(&part_uuid, &parts_found); + + if (ret == 0) { + if (!fill_data) { + *parts_size = parts_found; + + ffa_info("Number of partition(s) found matching the UUID: %d", + parts_found); + } else { + /* + * If SPs data detected, they are already in the private data + * structure, retry searching SP data again to return them + * to the caller + */ + if (parts_found) + ret = ffa_get_partitions_info(uuid_str, parts_size, buffer); + else + ret = -ENODATA; + } + } + + return ret; + } + + /* partition(s) found */ + if (!fill_data) + *parts_size = parts_found; + + return 0; +} + +/** + * ffa_cache_partitions_info - Queries and saves all secure partitions data + * + * This function invokes FFA_PARTITION_INFO_GET FF-A + * function to query from secure world all partitions information. + * + * The FFA_PARTITION_INFO_GET call is issued with nil UUID as an argument. + * All installed partitions information are returned. We cache them in the + * resident private data structure and we keep the UUID field empty + * (in FF-A 1.0 UUID is not provided by the partition descriptor) + * + * This function is called at the device probing level. + * ffa_cache_partitions_info uses ffa_query_partitions_info to get the data + * + * Return: + * + * 0 on success. Otherwise, failure + */ +static int ffa_cache_partitions_info(void) +{ + return ffa_query_partitions_info(NULL, NULL); +} + +/** + * ffa_msg_send_direct_req - FFA_MSG_SEND_DIRECT_{REQ,RESP} handler function + * @dst_part_id: destination partition ID + * @msg: pointer to the message data preallocated by the client (in/out) + * + * This function implements FFA_MSG_SEND_DIRECT_{REQ,RESP} + * FF-A functions. + * + * FFA_MSG_SEND_DIRECT_REQ is used to send the data to the secure partition. + * The response from the secure partition is handled by reading the + * FFA_MSG_SEND_DIRECT_RESP arguments. + * + * The maximum size of the data that can be exchanged is 40 bytes which is + * sizeof(struct ffa_send_direct_data) as defined by the FF-A specification 1.0 + * in the section relevant to FFA_MSG_SEND_DIRECT_{REQ,RESP} + * + * Return: + * + * 0 on success. Otherwise, failure + */ +static int ffa_msg_send_direct_req(u16 dst_part_id, struct ffa_send_direct_data *msg) +{ + ffa_value_t res = {0}; + int ffa_errno; + + if (!ffa_priv_data || !ffa_priv_data->invoke_ffa_fn) + return -EINVAL; + + /* No partition installed */ + if (!ffa_priv_data->partitions.count || !ffa_priv_data->partitions.descs) + return -ENODEV; + + ffa_priv_data->invoke_ffa_fn((ffa_value_t){ + .a0 = FFA_SMC_64(FFA_MSG_SEND_DIRECT_REQ), + .a1 = PREP_SELF_ENDPOINT_ID(ffa_priv_data->id) | + PREP_PART_ENDPOINT_ID(dst_part_id), + .a2 = 0, + .a3 = msg->data0, + .a4 = msg->data1, + .a5 = msg->data2, + .a6 = msg->data3, + .a7 = msg->data4, + }, &res); + + while (res.a0 == FFA_SMC_32(FFA_INTERRUPT)) + ffa_priv_data->invoke_ffa_fn((ffa_value_t){ + .a0 = FFA_SMC_32(FFA_RUN), + .a1 = res.a1 + }, &res); + + if (res.a0 == FFA_SMC_32(FFA_SUCCESS)) { + /* Message sent with no response */ + return 0; + } + + if (res.a0 == FFA_SMC_64(FFA_MSG_SEND_DIRECT_RESP)) { + /* + * Message sent with response + * extract the return data + */ + msg->data0 = res.a3; + msg->data1 = res.a4; + msg->data2 = res.a5; + msg->data3 = res.a6; + msg->data4 = res.a7; + + return 0; + } + + ffa_errno = res.a2; + return ffa_to_std_errno(ffa_errno); +} + +/** + * __arm_ffa_fn_smc - SMC wrapper + * @args: FF-A ABI arguments to be copied to Xn registers + * @res: FF-A ABI return data to be copied from Xn registers + * + * Calls low level SMC assembly function + * + * Return: void + */ +void __arm_ffa_fn_smc(ffa_value_t args, ffa_value_t *res) +{ + arm_smccc_1_2_smc(&args, res); +} + +/** + * ffa_set_smc_conduit - Set the SMC conduit + * + * This function selects the SMC conduit by setting the driver invoke function + * to SMC assembly function + * + * Return: + * + * 0 on success. Otherwise, failure + */ +static int ffa_set_smc_conduit(void) +{ + ffa_priv_data->invoke_ffa_fn = __arm_ffa_fn_smc; + + if (!ffa_priv_data->invoke_ffa_fn) { + ffa_err("failure to set the invoke function"); + return -EINVAL; + } + + ffa_info("Conduit is SMC"); + + return 0; +} + +/** + * ffa_set_bus_ops - Set the bus driver operations + * + * Setting the driver callbacks. + * + */ +static void ffa_set_bus_ops(void) +{ + ffa_priv_data->ffa_ops.partition_info_get = ffa_get_partitions_info; + ffa_priv_data->ffa_ops.sync_send_receive = ffa_msg_send_direct_req; + ffa_priv_data->ffa_ops.rxtx_unmap = ffa_unmap_rxtx_buffers; +} + +/** + * ffa_alloc_prvdata - allocate the driver main data structure and sets the device + * @dev: the arm_ffa device + * + * This function creates the main data structure embedding all the driver data. + * + * Return: + * + * 0 on success. Otherwise, failure + */ +static int ffa_alloc_prvdata(struct udevice *dev) +{ + if (!dev) { + ffa_err("no udevice found"); + return -ENODEV; + } + + /* The device is registered with the DM. Let's create the driver main data structure*/ + + ffa_priv_data = devm_kmalloc(dev, sizeof(struct ffa_prvdata), __GFP_ZERO); + if (!ffa_priv_data) { + ffa_err("can not allocate the driver main data structure"); + return -ENOMEM; + } + + ffa_priv_data->dev = dev; + + return 0; +} + +/** + * ffa_probe - The driver probe function + * @dev: the arm_ffa device + * + * Probing is done at boot time and triggered by the uclass device discovery. + * At probe level the following actions are done: + * - setting the conduit + * - querying the FF-A framework version + * - querying from secure world the u-boot endpoint ID + * - querying from secure world the supported features of FFA_RXTX_MAP + * - mapping the RX/TX buffers + * - querying from secure world all the partitions information + * + * All data queried from secure world is saved in the resident private data structure. + * + * The probe will fail if either FF-A framework is not detected or the + * FF-A requests are not behaving correctly. This ensures that the + * driver is not installed and its operations are not exported to the clients. + * + * Return: + * + * 0 on success. Otherwise, failure + */ +static int ffa_probe(struct udevice *dev) +{ + int ret; + + ret = ffa_alloc_prvdata(dev); + if (ret != 0) + return ret; + + ffa_set_bus_ops(); + + ret = ffa_set_smc_conduit(); + if (ret != 0) + return ret; + + ret = ffa_get_version(); + if (ret != 0) + return ret; + + ret = ffa_get_endpoint_id(); + if (ret != 0) + return ret; + + ret = ffa_get_rxtx_map_features(); + if (ret != 0) + return ret; + + ret = ffa_map_rxtx_buffers(); + if (ret != 0) + return ret; + + ret = ffa_cache_partitions_info(); + if (ret != 0) { + ffa_free_rxtx_buffers(); + return ret; + } + + return 0; +} + +/** + * ffa_remove - The driver remove function + * @dev: the arm_ffa device + * When the device is about to be removed , unmap the RX/TX buffers and free the memory + * Return: + * + * 0 on success. + */ +static int ffa_remove(struct udevice *dev) +{ + ffa_info("removing the device"); + + ffa_unmap_rxtx_buffers(); + + if (ffa_priv_data->pair.rxbuf || ffa_priv_data->pair.txbuf) + ffa_free_rxtx_buffers(); + + return 0; +} + +/** + * ffa_unbind - The driver unbind function + * @dev: the arm_ffa device + * After the device is removed and memory freed the device is unbound + * Return: + * + * 0 on success. + */ +static int ffa_unbind(struct udevice *dev) +{ + ffa_info("unbinding the device , private data already released"); + + ffa_priv_data = NULL; + + return 0; +} + +/** + * ffa_bus_ops_get - bus driver operations getter + * + * Return: + * This function returns a pointer to the driver operations structure + */ +const struct ffa_bus_ops *ffa_bus_ops_get(void) +{ + return &ffa_priv_data->ffa_ops; +} + +/** + * ffa_bus_prvdata_get - bus driver private data getter + * + * Return: + * This function returns a pointer to the main private data structure + */ +struct ffa_prvdata **ffa_bus_prvdata_get(void) +{ + return &ffa_priv_data; +} + +/** + * ffa_bus_discover - discover FF-A bus and probe the arm_ffa device + * + * This function makes sure the FF-A bus is discoverable. + * When probing succeeds FF-A discovery is done. The arm_ffa device is ready to use. + * + * When the bus was already discovered successfully the discovery will not run again. + * + * Arm FF-A transport is implemented through arm_ffa u-boot device managing the FF-A + * communication. + * All FF-A clients should use the arm_ffa device to use the FF-A transport. + * + * Return: + * + * 0 on success. Otherwise, failure + */ +int ffa_bus_discover(void) +{ + int ret = 0; + + if (!ffa_priv_data) + ret = ffa_device_get(); + + return ret; +} + +/** + * Declaring the arm_ffa driver under UCLASS_FFA + */ + +U_BOOT_DRIVER(arm_ffa) = { + .name = FFA_DRV_NAME, + .id = UCLASS_FFA, + .probe = ffa_probe, + .remove = ffa_remove, + .unbind = ffa_unbind, +}; diff --git a/include/arm_ffa.h b/include/arm_ffa.h new file mode 100644 index 0000000000..d146e7b328 --- /dev/null +++ b/include/arm_ffa.h @@ -0,0 +1,93 @@ +/* SPDX-License-Identifier: GPL-2.0+ */ +/* + * (C) Copyright 2022 ARM Limited + * Abdellatif El Khlifi abdellatif.elkhlifi@arm.com + */ + +#ifndef __ARM_FFA_H +#define __ARM_FFA_H + +#include <linux/printk.h> + +/* + * This header is public. It can be used by clients to access + * data structures and definitions they need + */ + +/* + * Macros for displaying logs + */ + +#define ffa_info(fmt, ...) pr_info("[FFA] " fmt "\n", ##__VA_ARGS__) +#define ffa_err(fmt, ...) pr_err("[FFA] " fmt "\n", ##__VA_ARGS__) + +/* + * struct ffa_partition_info - Partition information descriptor + * @id: Partition ID + * @exec_ctxt: Execution context count + * @properties: Partition properties + * + * Data structure containing information about partitions instantiated in the system + * This structure is filled with the data queried by FFA_PARTITION_INFO_GET + */ +struct __packed ffa_partition_info { + u16 id; + u16 exec_ctxt; +/* partition supports receipt of direct requests */ +#define FFA_PARTITION_DIRECT_RECV BIT(0) +/* partition can send direct requests. */ +#define FFA_PARTITION_DIRECT_SEND BIT(1) +/* partition can send and receive indirect messages. */ +#define FFA_PARTITION_INDIRECT_MSG BIT(2) + u32 properties; +}; + +/* + * struct ffa_send_direct_data - Data structure hosting the data + * used by FFA_MSG_SEND_DIRECT_{REQ,RESP} + * @data0-4: Data read/written from/to x3-x7 registers + * + * Data structure containing the data to be sent by FFA_MSG_SEND_DIRECT_REQ + * or read from FFA_MSG_SEND_DIRECT_RESP + */ + +/* For use with FFA_MSG_SEND_DIRECT_{REQ,RESP} which pass data via registers */ +struct __packed ffa_send_direct_data { + unsigned long data0; /* w3/x3 */ + unsigned long data1; /* w4/x4 */ + unsigned long data2; /* w5/x5 */ + unsigned long data3; /* w6/x6 */ + unsigned long data4; /* w7/x7 */ +}; + +/** + * struct ffa_bus_ops - The driver operations structure + * @partition_info_get: callback for the FFA_PARTITION_INFO_GET + * @sync_send_receive: callback for the FFA_MSG_SEND_DIRECT_REQ + * @rxtx_unmap: callback for the FFA_RXTX_UNMAP + * + * The data structure providing all the operations supported by the driver. + * This structure is EFI runtime resident. + */ +struct ffa_bus_ops { + int (*partition_info_get)(const char *uuid_str, + u32 *parts_size, struct ffa_partition_info *buffer); + int (*sync_send_receive)(u16 dst_part_id, struct ffa_send_direct_data *msg); + int (*rxtx_unmap)(void); +}; + +/** + * The device driver and the Uclass driver public functions + */ + +/** + * ffa_bus_ops_get - driver operations getter + */ +const struct ffa_bus_ops *ffa_bus_ops_get(void); + +/** + * ffa_bus_discover - discover FF-A bus and probes the arm_ffa device + */ +int ffa_bus_discover(void); + +#endif diff --git a/include/dm/uclass-id.h b/include/dm/uclass-id.h index a432e43871..5dd698b7a9 100644 --- a/include/dm/uclass-id.h +++ b/include/dm/uclass-id.h @@ -4,6 +4,9 @@ * * (C) Copyright 2012 * Pavel Herrmann morpheus.ibis@gmail.com + * + * (C) Copyright 2022 ARM Limited + * Abdellatif El Khlifi abdellatif.elkhlifi@arm.com */
#ifndef _DM_UCLASS_ID_H @@ -55,6 +58,7 @@ enum uclass_id { UCLASS_EFI_MEDIA, /* Devices provided by UEFI firmware */ UCLASS_ETH, /* Ethernet device */ UCLASS_ETH_PHY, /* Ethernet PHY device */ + UCLASS_FFA, /* Arm Firmware Framework for Armv8-A */ UCLASS_FIRMWARE, /* Firmware */ UCLASS_FUZZING_ENGINE, /* Fuzzing engine */ UCLASS_FS_FIRMWARE_LOADER, /* Generic loader */
U-Boot
- sync_send_receive
- rxtx_unmap
Signed-off-by: Abdellatif El Khlifi abdellatif.elkhlifi@arm.com Cc: Tom Rini trini@konsulko.com Cc: Simon Glass sjg@chromium.org Cc: Ilias Apalodimas ilias.apalodimas@linaro.org Cc: Jens Wiklander jens.wiklander@linaro.org
Changelog:
v6:
- drop use of EFI runtime support (We decided with Linaro to add this later)
- drop discovery from initcalls (discovery will be on demand by FF-A users)
- set the alignment of the RX/TX buffers to the larger translation granule size
- move FF-A RX/TX buffers unmapping at ExitBootServices() to a separate commit
- update the documentation and move it to doc/arch/arm64.ffa.rst
v4:
- add doc/README.ffa.drv
- moving the FF-A driver work to drivers/firmware/arm-ffa
- use less #ifdefs in lib/efi_loader/efi_boottime.c and replace #if defined by #if CONFIG_IS_ENABLED
- improving error handling by mapping the FF-A errors to standard errors and logs
- replacing panics with an error log and returning an error code
- improving features discovery in FFA_FEATURES by introducing rxtx_min_pages private data field
- add ffa_remove and ffa_unbind functions
- improve how the driver behaves when bus discovery is done more than once
v3:
- align the interfaces of the u-boot FF-A driver with those in the linux FF-A driver
- remove the FF-A helper layer
- make the u-boot FF-A driver independent from EFI
- provide an optional config that enables copying the driver data to EFI runtime section at ExitBootServices service
- use 64-bit version of FFA_RXTX_MAP, FFA_MSG_SEND_DIRECT_{REQ, RESP}
v2:
- make FF-A bus discoverable using device_{bind, probe} APIs
- remove device tree support
v1:
- introduce FF-A bus driver with device tree support
+Summary +-------
- e.g. EFI MM communication protocol
s/Optee OS/OP-TEE/
+the SMC ABIs.
+Aarch64 plaforms
- Enables the FF-A bus driver. Turn this on if you want to use FF-A
- communication.
+CONFIG_SANDBOX_FFA
- Enables FF-A Sandbox driver. This emulates the FF-A ABIs handling under
- Sandbox and provides functional tests for FF-A.
U-Boot, please search and replace.
- layers focus on exchanged data, the driver takes care of how to transport
- that to the secure world/hypervisor using FF-A
- with the driver
+Usage:
+sub-commands:
ping <partition ID>
It may be worth mentioning that this is an implementation defined command.
devlist
- Abdellatif El Khlifi abdellatif.elkhlifi@arm.com
arc arm64
- arm64.ffa m68k mips nios2
- bool "Enable Arm Firmware Framework for Armv8-A driver"
- depends on DM && ARM64
- select ARM_SMCCC
- select LIB_UUID
- select DEVRES
- help
technology.
calling convention.
FF-A specification:
U-Boot
using the FF-A bus.
and Secure World.
Not doc/arch/arm64.ffa.rst?
- (C) Copyright 2022 ARM Limited
- .name = "ffa",
- .id = UCLASS_FFA,
- This header is private. It is exclusively used by the FF-A driver
- (FIELD_PREP(MAJOR_VERSION_MASK, (major)) | \
- Definitions of the Arm FF-A interfaces supported by the Arm FF-A driver
- ARM_SMCCC_CALL_VAL(ARM_SMCCC_FAST_CALL, (calling_convention), \
+enum ffa_abis {
- FFA_ERROR = 0x60,
- FFA_SUCCESS = 0x61,
- FFA_INTERRUPT = 0x62,
- FFA_VERSION = 0x63,
- FFA_FEATURES = 0x64,
- FFA_RX_RELEASE = 0x65,
- FFA_RXTX_MAP = 0x66,
- FFA_RXTX_UNMAP = 0x67,
- FFA_PARTITION_INFO_GET = 0x68,
- FFA_ID_GET = 0x69,
- FFA_RUN = 0x6D,
- FFA_MSG_SEND_DIRECT_REQ = 0x6F,
- FFA_MSG_SEND_DIRECT_RESP = 0x70,
- /* to be updated when adding new FFA IDs */
- FFA_FIRST_ID = FFA_ERROR, /* lowest number ID*/
- FFA_LAST_ID = FFA_MSG_SEND_DIRECT_RESP, /* highest number ID*/
- char *err_str[MAX_NUMBER_FFA_ERR];
- struct ffa_partition_uuid - 16 bytes UUID transmitted by FFA_PARTITION_INFO_GET
- @a1-4: 32-bit words access to the UUID data
- u32 a1; /* w1 */
- u32 a2; /* w2 */
- u32 a3; /* w3 */
- u32 a4; /* w4 */
- enum ffa_rxtx_buf_sizes - minimum sizes supported
- for the RX/TX buffers
- RXTX_4K,
- RXTX_64K,
- RXTX_16K
- struct ffa_rxtxpair - structure hosting the RX/TX buffers virtual addresses
- @rxbuf: virtual address of the RX buffer
- @txbuf: virtual address of the TX buffer
- @rxtx_min_pages: RX/TX buffers minimum size in pages
- Data structure hosting the virtual addresses of the mapped RX/TX buffers
- These addresses are used by the FF-A functions that use the RX/TX buffers
- u64 rxbuf; /* virtual address */
- u64 txbuf; /* virtual address */
- size_t rxtx_min_pages; /* minimum number of pages in each of the RX/TX buffers */
- struct ffa_partition_desc - the secure partition descriptor
- @info: partition information
- @sp_uuid: the secure partition UUID
- Each partition has its descriptor containing the partitions information and the UUID
- struct ffa_partition_info info;
- struct ffa_partition_uuid sp_uuid;
- struct ffa_partitions - descriptors for all secure partitions
- @count: The number of partitions descriptors
- @descs The partitions descriptors table
- This data structure contains the partitions descriptors table
- u32 count;
- struct ffa_partition_desc *descs; /* virtual address */
- struct ffa_prvdata - the driver private data structure
- @dev: The arm_ffa device under u-boot driver model
- @ffa_ops: The driver operations structure
- @fwk_version: FF-A framework version
- @id: u-boot endpoint ID
- @partitions: The partitions descriptors structure
- @pair: The RX/TX buffers pair
- @invoke_ffa_fn: The function executing the FF-A function
- The driver data structure hosting all resident data.
- struct udevice *dev;
- struct ffa_bus_ops ffa_ops;
- u32 fwk_version;
- u16 id;
- struct ffa_partitions partitions;
- struct ffa_rxtxpair pair;
- invoke_ffa_fn_t invoke_ffa_fn;
- ffa_device_get - create, bind and probe the arm_ffa device
- ffa_bus_prvdata_get - bus driver private data getter
- The device private data structure containing all the
- data read from secure world
- 0,
- -EOPNOTSUPP, /* NOT_SUPPORTED */
- -EINVAL, /* INVALID_PARAMETERS */
- -ENOMEM, /* NO_MEMORY */
- -EBUSY, /* BUSY */
- -EINTR, /* INTERRUPTED */
- -EACCES, /* DENIED */
- -EAGAIN, /* RETRY */
- -ECANCELED, /* ABORTED */
- [FFA_ID_TO_ERRMAP_ID(FFA_VERSION)] = {
Shouldn't all these empty strings be NULL instead? Given that's that what you check for in ffa_print_error_log() below.
You could save a few lines by using designated initializers for only the used elements in err_str for each FF-A function ID.
"", /* NO_MEMORY */
"", /* BUSY */
"", /* DENIED */
"", /* RETRY */
"", /* ABORTED */
- [FFA_ID_TO_ERRMAP_ID(FFA_ID_GET)] = {
"", /* NO_MEMORY */
"", /* BUSY */
"", /* DENIED */
"", /* RETRY */
"", /* ABORTED */
- [FFA_ID_TO_ERRMAP_ID(FFA_FEATURES)] = {
"", /* NO_MEMORY */
"", /* BUSY */
"", /* DENIED */
"", /* RETRY */
"", /* ABORTED */
- [FFA_ID_TO_ERRMAP_ID(FFA_PARTITION_INFO_GET)] = {
"", /* RETRY */
"", /* ABORTED */
- [FFA_ID_TO_ERRMAP_ID(FFA_RXTX_UNMAP)] = {
"", /* NO_MEMORY */
"", /* BUSY */
"", /* DENIED */
"", /* RETRY */
"", /* ABORTED */
- [FFA_ID_TO_ERRMAP_ID(FFA_RX_RELEASE)] = {
"", /* NO_MEMORY */
"", /* BUSY */
"", /* RETRY */
"", /* ABORTED */
- [FFA_ID_TO_ERRMAP_ID(FFA_RXTX_MAP)] = {
"", /* BUSY */
"", /* RETRY */
"", /* ABORTED */
- ffa_to_std_errno - convert FF-A error code to standard error code
- @ffa_errno: Error code returned by the FF-A ABI
- This function maps the given FF-A error code as specified
- by the spec to a u-boot standard error code.
- Return:
- The standard error code on success. . Otherwise, failure
- int err_idx = -ffa_errno;
- /* map the FF-A error code to the standard u-boot error code */
- if (err_idx > 0 && err_idx < MAX_NUMBER_FFA_ERR)
- return -EINVAL;
- ffa_print_error_log - print the error log corresponding to the selected FF-A ABI
- @ffa_id: FF-A ABI ID
- This function maps the FF-A error code to the error log relevant to the
- selected FF-A ABI. Then the error log is printed.
- Return:
- 0 on success. . Otherwise, failure
- int err_idx = -ffa_errno, abi_idx = 0;
- /* map the FF-A error code to the corresponding error log */
- if (err_idx <= 0 || err_idx >= MAX_NUMBER_FFA_ERR)
return -EINVAL;
- if (ffa_id < FFA_FIRST_ID || ffa_id > FFA_LAST_ID)
return -EINVAL;
- abi_idx = FFA_ID_TO_ERRMAP_ID(ffa_id);
- if (abi_idx < 0 || abi_idx >= FFA_ERRMAP_COUNT)
return -EINVAL;
- if (!err_msg_map[abi_idx].err_str || !err_msg_map[abi_idx].err_str[err_idx])
err_str can't be NULL since it's an array in the struct ffa_abi_errmap.
return -EINVAL;
- ffa_err("%s", err_msg_map[abi_idx].err_str[err_idx]);
- Driver core functions
- ffa_remove_device - removes the arm_ffa device
- @dev: the device to be removed
- This function makes sure the arm_ffa device is removed
- No need to free the kmalloced data when the device is destroyed.
- It's automatically done by devm management by
- device_remove() -> device_free() -> devres_release_probe().
- Return:
- 0 on success. Otherwise, failure
- int ret;
- if (!dev) {
return -ENODEV;
- ret = device_remove(dev, DM_REMOVE_NORMAL);
- if (ret) {
return ret;
- ffa_info("device removed and freed");
- ret = device_unbind(dev);
- if (ret) {
return ret;
- ffa_info("device unbound");
- created, bound to this driver, probed and ready to use.
- Arm FF-A transport is implemented through a single u-boot
- device managing the FF-A bus (arm_ffa).
- Return:
- int ret;
- struct udevice *dev = NULL;
- ret = device_bind(dm_root(),
FFA_DRV_NAME,
NULL,
ofnode_null(),
&dev);
There's no need for separate lines for each argument, please fold up a bit.
- if (ret)
return ret;
- /* The FF-A bus discovery succeeds when probing is successful */
- ret = device_probe(dev);
- if (ret) {
return ret;
- ffa_get_version - FFA_VERSION handler function
- This function implements FFA_VERSION FF-A function
- to get from the secure world the FF-A framework version
- Return:
- u16 major, minor;
- ffa_value_t res = {0};
- int ffa_errno;
- ffa_priv_data->invoke_ffa_fn((ffa_value_t){
It's generally preferred to have comma after the last initializer too.
It could also be worth comparing with the style (alignment and folding up where possible) of the corresponding driver in the Linux kernel which I find a bit easier to read. However, checkpatch seems happy enough so I guess it's not a big deal.
I asked earlier why you're not supporting the latest version, 1.1, but you never answered that.
}, &res);
- ffa_errno = res.a0;
- if (ffa_errno < 0) {
- major = GET_FFA_MAJOR_VERSION(res.a0);
- minor = GET_FFA_MINOR_VERSION(res.a0);
- ffa_info("FF-A driver %d.%d\nFF-A framework %d.%d",
- if ((major == FFA_MAJOR_VERSION && minor >= FFA_MINOR_VERSION)) {
- ffa_err("versions are incompatible\nExpected: %d.%d , Found: %d.%d\n",
- return -EPROTONOSUPPORT;
- ffa_get_endpoint_id - FFA_ID_GET handler function
- This function implements FFA_ID_GET FF-A function
- to get from the secure world u-boot endpoint ID
- Return:
- int ffa_errno;
}, &res);
- if (res.a0 == FFA_SMC_32(FFA_SUCCESS)) {
- ffa_errno = res.a2;
- ffa_print_error_log(FFA_ID_GET, ffa_errno);
- return ffa_to_std_errno(ffa_errno);
- ffa_set_rxtx_buffers_pages_cnt - sets the minimum number of pages in each of the RX/TX buffers
- @prop_field: properties field obtained from FFA_FEATURES ABI
- This function sets the minimum number of pages
- in each of the RX/TX buffers in the private data structure
- Return:
- buf_4k_pages points to the returned number of pages
- if (!ffa_priv_data)
return -EINVAL;
- switch (prop_field) {
- case RXTX_4K:
break;
- case RXTX_16K:
break;
- case RXTX_64K:
break;
- default:
return -EINVAL;
- ffa_get_rxtx_map_features - FFA_FEATURES handler function with FFA_RXTX_MAP argument
- This function implements FFA_FEATURES FF-A function
- to retrieve the FFA_RXTX_MAP features
- Return:
- int ffa_errno;
}, &res);
The cast isn't needed.
- ffa_print_error_log(FFA_FEATURES, ffa_errno);
- ffa_free_rxtx_buffers - frees the RX/TX buffers
- This function frees the RX/TX buffers
- ffa_info("Freeing RX/TX buffers");
- if (ffa_priv_data->pair.rxbuf) {
- if (ffa_priv_data->pair.txbuf) {
- ffa_alloc_rxtx_buffers - allocates the RX/TX buffers
- This function is used by ffa_map_rxtx_buffers to allocate
- the RX/TX buffers before mapping them. The allocated memory is physically
- contiguous since memalign ends up calling malloc which allocates
- contiguous memory in u-boot.
- Return:
- u64 bytes;
- ffa_info("Using %lu 4KB page(s) for RX/TX buffers size",
- bytes = ffa_priv_data->pair.rxtx_min_pages * SZ_4K;
- ffa_priv_data->pair.rxbuf = (u64)memalign(bytes, bytes);
- if (!ffa_priv_data->pair.rxbuf) {
return -ENOBUFS;
- ffa_info("RX buffer at virtual address 0x%llx", ffa_priv_data->pair.rxbuf);
- ffa_priv_data->pair.txbuf = (u64)memalign(bytes, bytes);
- if (!ffa_priv_data->pair.txbuf) {
return -ENOBUFS;
- ffa_info("TX buffer at virtual address 0x%llx", ffa_priv_data->pair.txbuf);
- memset((void *)ffa_priv_data->pair.rxbuf, 0, bytes);
- memset((void *)ffa_priv_data->pair.txbuf, 0, bytes);
- ffa_map_rxtx_buffers - FFA_RXTX_MAP handler function
- This function implements FFA_RXTX_MAP FF-A function
- to map the RX/TX buffers
- Return:
- int ret;
- int ffa_errno;
- ret = ffa_alloc_rxtx_buffers();
- if (ret)
return ret;
A space is missing after the '*'.
}, &res);
- ffa_print_error_log(FFA_RXTX_MAP, ffa_errno);
- ffa_free_rxtx_buffers();
- ffa_unmap_rxtx_buffers - FFA_RXTX_UNMAP handler function
- This function implements FFA_RXTX_UNMAP FF-A function
- to unmap the RX/TX buffers
- Return:
- int ffa_errno;
}, &res);
- ffa_print_error_log(FFA_RXTX_UNMAP, ffa_errno);
- ffa_release_rx_buffer - FFA_RX_RELEASE handler function
- This function invokes FFA_RX_RELEASE FF-A function
- to release the ownership of the RX buffer
- Return:
- int ffa_errno;
}, &res);
- ffa_print_error_log(FFA_RX_RELEASE, ffa_errno);
- ffa_uuid_are_identical - checks whether two given UUIDs are identical
- @uuid1: first UUID
- @uuid2: second UUID
- This function is used by ffa_read_partitions_info to search
- for a UUID in the partitions descriptors table
- Return:
- 1 when UUIDs match. Otherwise, 0
Would it make sense to use the bool type instead?
- if (!uuid1 || !uuid2)
- return !memcmp(uuid1, uuid2, sizeof(struct ffa_partition_uuid));
- ffa_read_partitions_info - reads the data queried by FFA_PARTITION_INFO_GET
- @count: The number of partitions queried
- @part_uuid: Pointer to the partition(s) UUID
- This function reads the partitions information
- returned by the FFA_PARTITION_INFO_GET and saves it in the private
- data structure.
- Return:
- The private data structure is updated with the partition(s) information
- 0 is returned on success. Otherwise, failure
- if (!count) {
return -ENODATA;
- ffa_info("Reading partitions data from the RX buffer");
- if (!part_uuid) {
u64 buf_bytes;
u64 data_bytes;
u32 desc_idx;
data_bytes,
buf_bytes);
return -ENOMEM;
__GFP_ZERO);
return -ENOMEM;
- } else {
u8 desc_found;
desc_found = 0;
* save the UUID
*part_uuid;
desc_found = 1;
break;
if (!desc_found)
return -ENODATA;
- ffa_query_partitions_info - invokes FFA_PARTITION_INFO_GET and saves partitions data
- @pcount: Pointer to the number of partitions variable filled when querying
- This function executes the FFA_PARTITION_INFO_GET
- to query the partitions data. Then, it calls ffa_read_partitions_info
- to save the data in the private data structure.
- After reading the data the RX buffer is released using ffa_release_rx_buffer
- Return:
- When part_uuid is NULL, all partitions data are retrieved from secure world
- When part_uuid is non NULL, data for partitions matching the given UUID are
- retrieved and the number of partitions is returned
u32 *pcount)
- struct ffa_partition_uuid query_uuid = {0};
- int ffa_errno;
- if (part_uuid) {
if (!pcount)
return -EINVAL;
- } else if (pcount) {
return -EINVAL;
.a4 = query_uuid.a4
}, &res);
int ret;
if (res.a2) {
if (ret) {
return -EINVAL;
if (pcount)
return ret;
- ffa_print_error_log(FFA_PARTITION_INFO_GET, ffa_errno);
- ffa_get_partitions_info - FFA_PARTITION_INFO_GET handler function
- The passed arguments:
- Mode 1: When getting from the driver the number of
- secure partitions:
- @uuid_str: pointer to the UUID string
- @parts_size: pointer to the variable that contains the number of partitions
- @buffer: NULL
- Mode 2: When requesting the driver to return the
- partitions information:
- @parts_size: pointer to the size of the SPs information buffer in bytes
- @buffer: pointer to SPs information buffer
- This function queries the secure partition data from
- the private data structure. If not found, it invokes FFA_PARTITION_INFO_GET
- FF-A function to query the partition information from secure world.
- A client of the FF-A driver should know the UUID of the service it wants to
- access. It should use the UUID to request the FF-A driver to provide the
- partition(s) information of the service. The FF-A driver uses
- PARTITION_INFO_GET to obtain this information. This is implemented through
- ffa_get_partitions_info function.
- A new FFA_PARTITION_INFO_GET call is issued (first one performed through
- ffa_cache_partitions_info) allowing to retrieve the partition(s) information.
- They are not saved (already done). We only update the UUID in the cached area.
- This assumes that partitions data does not change in the secure world.
- Otherwise u-boot will have an outdated partition data. The benefit of caching
- the information in the FF-A driver is to accommodate discovery after
- ExitBootServices().
- When invoked through a client request, ffa_get_partitions_info should be
- called twice. First call is to get from the driver the number of secure
- partitions (SPs) associated to a particular UUID.
- Then, the caller (client) allocates the buffer to host the SPs data and
- issues a 2nd call. Then, the driver fills the SPs data in the pre-allocated
- buffer.
- To achieve the mechanism described above, ffa_get_partitions_info uses the
- following functions:
- Return:
- @parts_size: When pointing to the number of partitions variable, the number is
- set by the driver.
- When pointing to the partitions information buffer size, the buffer will be
- filled by the driver.
- On success 0 is returned. Otherwise, failure
* fill_data:
- int fill_data = -1;
- u32 desc_idx, client_desc_idx;
- struct ffa_partition_uuid part_uuid = {0};
- u32 client_desc_max_cnt;
- u32 parts_found = 0;
- if (!ffa_priv_data->partitions.count || !ffa_priv_data->partitions.descs) {
return -EINVAL;
- if (!uuid_str) {
return -EINVAL;
- if (!parts_size) {
return -EINVAL;
- if (be_uuid_str_to_le_bin(uuid_str, (unsigned char *)&part_uuid)) {
return -EINVAL;
- if (!buffer) {
fill_data = 0;
- } else if ((*parts_size >= sizeof(struct ffa_partition_info)) &&
fill_data = 1;
- } else {
return -EINVAL;
- ffa_info("Searching partitions using the provided UUID");
- for (desc_idx = 0;
desc_idx++) {
&part_uuid)) {
parts_found++;
if (fill_data) {
continue;
return -ENOBUFS;
- if (!parts_found) {
int ret;
if (ret == 0) {
if (!fill_data) {
parts_found);
} else {
* to the caller
if (parts_found)
else
ret = -ENODATA;
return ret;
- /* partition(s) found */
- if (!fill_data)
- ffa_cache_partitions_info - Queries and saves all secure partitions data
- This function invokes FFA_PARTITION_INFO_GET FF-A
- function to query from secure world all partitions information.
- The FFA_PARTITION_INFO_GET call is issued with nil UUID as an argument.
- All installed partitions information are returned. We cache them in the
- resident private data structure and we keep the UUID field empty
- (in FF-A 1.0 UUID is not provided by the partition descriptor)
- This function is called at the device probing level.
- ffa_cache_partitions_info uses ffa_query_partitions_info to get the data
- Return:
- return ffa_query_partitions_info(NULL, NULL);
- ffa_msg_send_direct_req - FFA_MSG_SEND_DIRECT_{REQ,RESP} handler function
- @dst_part_id: destination partition ID
- @msg: pointer to the message data preallocated by the client (in/out)
- This function implements FFA_MSG_SEND_DIRECT_{REQ,RESP}
- FF-A functions.
- FFA_MSG_SEND_DIRECT_REQ is used to send the data to the secure partition.
- The response from the secure partition is handled by reading the
- FFA_MSG_SEND_DIRECT_RESP arguments.
- The maximum size of the data that can be exchanged is 40 bytes which is
- sizeof(struct ffa_send_direct_data) as defined by the FF-A specification 1.0
- in the section relevant to FFA_MSG_SEND_DIRECT_{REQ,RESP}
- Return:
- int ffa_errno;
- if (!ffa_priv_data || !ffa_priv_data->invoke_ffa_fn)
return -EINVAL;
- /* No partition installed */
return -ENODEV;
.a2 = 0,
.a3 = msg->data0,
.a4 = msg->data1,
.a5 = msg->data2,
.a6 = msg->data3,
.a7 = msg->data4,
}, &res);
- while (res.a0 == FFA_SMC_32(FFA_INTERRUPT))
.a1 = res.a1
}, &res);
- if (res.a0 == FFA_SMC_64(FFA_MSG_SEND_DIRECT_RESP)) {
- __arm_ffa_fn_smc - SMC wrapper
- @args: FF-A ABI arguments to be copied to Xn registers
- @res: FF-A ABI return data to be copied from Xn registers
- Calls low level SMC assembly function
- Return: void
- arm_smccc_1_2_smc(&args, res);
- ffa_set_smc_conduit - Set the SMC conduit
- This function selects the SMC conduit by setting the driver invoke function
- to SMC assembly function
- Return:
- ffa_priv_data->invoke_ffa_fn = __arm_ffa_fn_smc;
- if (!ffa_priv_data->invoke_ffa_fn) {
return -EINVAL;
- ffa_info("Conduit is SMC");
- ffa_set_bus_ops - Set the bus driver operations
- Setting the driver callbacks.
- ffa_priv_data->ffa_ops.partition_info_get = ffa_get_partitions_info;
- ffa_priv_data->ffa_ops.sync_send_receive = ffa_msg_send_direct_req;
- ffa_priv_data->ffa_ops.rxtx_unmap = ffa_unmap_rxtx_buffers;
- ffa_alloc_prvdata - allocate the driver main data structure and sets the device
- @dev: the arm_ffa device
- This function creates the main data structure embedding all the driver data.
- Return:
- if (!dev) {
return -ENODEV;
- /* The device is registered with the DM. Let's create the driver main data structure*/
- ffa_priv_data = devm_kmalloc(dev, sizeof(struct ffa_prvdata), __GFP_ZERO);
- if (!ffa_priv_data) {
return -ENOMEM;
- ffa_priv_data->dev = dev;
- ffa_probe - The driver probe function
- Probing is done at boot time and triggered by the uclass device discovery.
- At probe level the following actions are done:
- All data queried from secure world is saved in the resident private data structure.
- The probe will fail if either FF-A framework is not detected or the
- FF-A requests are not behaving correctly. This ensures that the
- driver is not installed and its operations are not exported to the clients.
- Return:
- int ret;
- ret = ffa_alloc_prvdata(dev);
- if (ret != 0)
return ret;
- ffa_set_bus_ops();
- ret = ffa_set_smc_conduit();
- if (ret != 0)
return ret;
- ret = ffa_get_version();
- if (ret != 0)
return ret;
- ret = ffa_get_endpoint_id();
- if (ret != 0)
return ret;
- ret = ffa_get_rxtx_map_features();
- if (ret != 0)
return ret;
- ret = ffa_map_rxtx_buffers();
- if (ret != 0)
return ret;
- ret = ffa_cache_partitions_info();
I've asked this before, but never got an answer: Why are we saving all the found partitions in a cache? It seems that FFA_PARTITION_INFO_GET could be called each time when needed instead without any noticeable overhead. Or is the result cached for some other reason?
Cheers, Jens
- if (ret != 0) {
return ret;
- ffa_remove - The driver remove function
- When the device is about to be removed , unmap the RX/TX buffers and free the memory
- Return:
- 0 on success.
- ffa_info("removing the device");
- ffa_unmap_rxtx_buffers();
- if (ffa_priv_data->pair.rxbuf || ffa_priv_data->pair.txbuf)
- ffa_unbind - The driver unbind function
- After the device is removed and memory freed the device is unbound
- Return:
- 0 on success.
- ffa_info("unbinding the device , private data already released");
- ffa_priv_data = NULL;
- ffa_bus_ops_get - bus driver operations getter
- Return:
- This function returns a pointer to the driver operations structure
- return &ffa_priv_data->ffa_ops;
- Return:
- This function returns a pointer to the main private data structure
- return &ffa_priv_data;
- ffa_bus_discover - discover FF-A bus and probe the arm_ffa device
- This function makes sure the FF-A bus is discoverable.
- When probing succeeds FF-A discovery is done. The arm_ffa device is ready to use.
- When the bus was already discovered successfully the discovery will not run again.
- Arm FF-A transport is implemented through arm_ffa u-boot device managing the FF-A
- communication.
- All FF-A clients should use the arm_ffa device to use the FF-A transport.
- Return:
- int ret = 0;
- return ret;
- Declaring the arm_ffa driver under UCLASS_FFA
- .name = FFA_DRV_NAME,
- .id = UCLASS_FFA,
- .probe = ffa_probe,
- .remove = ffa_remove,
- .unbind = ffa_unbind,
- This header is public. It can be used by clients to access
- data structures and definitions they need
- Macros for displaying logs
- struct ffa_partition_info - Partition information descriptor
- @id: Partition ID
- @exec_ctxt: Execution context count
- @properties: Partition properties
- Data structure containing information about partitions instantiated in the system
- This structure is filled with the data queried by FFA_PARTITION_INFO_GET
- u16 id;
- u16 exec_ctxt;
- u32 properties;
- struct ffa_send_direct_data - Data structure hosting the data
- @data0-4: Data read/written from/to x3-x7 registers
- Data structure containing the data to be sent by FFA_MSG_SEND_DIRECT_REQ
- or read from FFA_MSG_SEND_DIRECT_RESP
- unsigned long data0; /* w3/x3 */
- unsigned long data1; /* w4/x4 */
- unsigned long data2; /* w5/x5 */
- unsigned long data3; /* w6/x6 */
- unsigned long data4; /* w7/x7 */
- struct ffa_bus_ops - The driver operations structure
- @partition_info_get: callback for the FFA_PARTITION_INFO_GET
- @sync_send_receive: callback for the FFA_MSG_SEND_DIRECT_REQ
- @rxtx_unmap: callback for the FFA_RXTX_UNMAP
- The data structure providing all the operations supported by the driver.
- This structure is EFI runtime resident.
- int (*partition_info_get)(const char *uuid_str,
- int (*sync_send_receive)(u16 dst_part_id, struct ffa_send_direct_data *msg);
- int (*rxtx_unmap)(void);
- The device driver and the Uclass driver public functions
- ffa_bus_ops_get - driver operations getter
- ffa_bus_discover - discover FF-A bus and probes the arm_ffa device
- (C) Copyright 2012
- Pavel Herrmann morpheus.ibis@gmail.com
- UCLASS_FFA, /* Arm Firmware Framework for Armv8-A */ UCLASS_FIRMWARE, /* Firmware */ UCLASS_FUZZING_ENGINE, /* Fuzzing engine */ UCLASS_FS_FIRMWARE_LOADER, /* Generic loader */
-- 2.17.1
Add the core driver implementing Arm Firmware Framework for Armv8-A v1.0
The Firmware Framework for Arm A-profile processors (FF-A v1.0) [1] describes interfaces (ABIs) that standardize communication between the Secure World and Normal World leveraging TrustZone technology.
This driver uses 64-bit registers as per SMCCCv1.2 spec and comes on top of the SMCCC layer. The driver provides the FF-A ABIs needed for querying the FF-A framework from the secure world.
32-bit version of the ABIs is supported and 64-bit version of FFA_RXTX_MAP and FFA_MSG_SEND_DIRECT_{REQ, RESP}.
In u-boot FF-A design, FF-A is considered as a discoverable bus.
U-Boot
The Secure World is considered as one entity to communicate with using the FF-A bus. FF-A communication is handled by one device and one instance (the bus). This FF-A driver takes care of all the interactions between Normal world and Secure World.
The driver exports its operations to be used by upper layers.
Exported operations:
- partition_info_get
- sync_send_receive
- rxtx_unmap
Changelog:
v6:
v4:
v3:
v2:
v1:
MAINTAINERS | 7 + doc/arch/arm64.ffa.rst | 207 ++++ doc/arch/index.rst | 1 + drivers/Kconfig | 2 + drivers/Makefile | 1 + drivers/firmware/arm-ffa/Kconfig | 30 + drivers/firmware/arm-ffa/Makefile | 6 + drivers/firmware/arm-ffa/arm-ffa-uclass.c | 16 + drivers/firmware/arm-ffa/arm_ffa_prv.h | 196 +++ drivers/firmware/arm-ffa/core.c | 1337 +++++++++++++++++++++ include/arm_ffa.h | 93 ++ include/dm/uclass-id.h | 4 + 12 files changed, 1900 insertions(+) create mode 100644 doc/arch/arm64.ffa.rst create mode 100644 drivers/firmware/arm-ffa/Kconfig create mode 100644 drivers/firmware/arm-ffa/Makefile create mode 100644 drivers/firmware/arm-ffa/arm-ffa-uclass.c create mode 100644 drivers/firmware/arm-ffa/arm_ffa_prv.h create mode 100644 drivers/firmware/arm-ffa/core.c create mode 100644 include/arm_ffa.h
diff --git a/MAINTAINERS b/MAINTAINERS index a26b36c7c2..496f47a516 100644 --- a/MAINTAINERS +++ b/MAINTAINERS @@ -248,6 +248,13 @@ F: drivers/net/cortina_ni.h F: drivers/net/phy/ca_phy.c F: configs/cortina_presidio-asic-pnand_defconfig
+ARM FF-A +M: Abdellatif El Khlifi abdellatif.elkhlifi@arm.com +S: Maintained +F: doc/arch/arm64.ffa.rst +F: drivers/firmware/arm-ffa/ +F: include/arm_ffa.h
ARM FREESCALE IMX M: Stefano Babic sbabic@denx.de M: Fabio Estevam festevam@gmail.com diff --git a/doc/arch/arm64.ffa.rst b/doc/arch/arm64.ffa.rst new file mode 100644 index 0000000000..e98d2cf2b3 --- /dev/null +++ b/doc/arch/arm64.ffa.rst @@ -0,0 +1,207 @@ +.. SPDX-License-Identifier: GPL-2.0+
+Arm FF-A Driver +===============
+Summary +-------
+FF-A stands for Firmware Framework for Arm A-profile processors.
+FF-A specifies interfaces that enable a pair of software sandboxes to +communicate with each other. A sandbox aka partition could +be a VM in the Normal or Secure world, an application in S-EL0, or a +Trusted OS in S-EL1.
+This FF-A driver implements the interfaces to communicate with partitions in +the Secure world aka Secure partitions (SPs).
+The driver specifically focuses on communicating with SPs that isolate portions +of EFI runtime services that must run in a protected environment which is +inaccessible by the Host OS or Hypervisor. Examples of such services are +set/get variables.
+FF-A driver uses the SMC ABIs defined by the FF-A specification to:
+- Discover the presence of SPs of interest +- Access an SP's service through communication protocols
+FF-A and SMC specifications +-------------------------------------------
+The current implementation of the driver relies on FF-A specification v1.0 +and uses SMC32 calling convention.
+At this stage we only need the FF-A v1.0 features.
+The driver has been tested with Optee OS which supports SMC32 for most of
s/Optee OS/OP-TEE/
+the SMC ABIs.
+For more details please refer to the FF-A v1.0 spec: +https://documentation-service.arm.com/static/5fb7e8a6ca04df4095c1d65e?token=
+Hypervisors are supported if they are configured to trap SMC calls.
+The FF-A driver uses 64-bit registers as per SMCCCv1.2 specification.
+For more details please refer to the SMC Calling Convention v1.2 spec: +https://documentation-service.arm.com/static/5f8edaeff86e16515cdbe4c6?token=
+Supported hardware +--------------------------------
+Aarch64 plaforms
+Configuration +----------------------
+CONFIG_ARM_FFA_TRANSPORT
- communication.
+CONFIG_SANDBOX_FFA
+FF-A ABIs under the hood +---------------------------------------
+Invoking an FF-A ABI involves providing to the secure world/hypervisor the +expected arguments from the ABI.
+The ABI arguments are stored in x0 to x7 registers. Then, an SMC instruction +is executed.
+At the secure side level or hypervisor the ABI is handled at a higher exception +level and the arguments are read and processed.
+The response is put back through x0 to x7 registers and control is given back +to the U-boot FF-A driver (non-secure world).
+The driver reads the response and processes it accordingly.
+This methodology applies to all the FF-A ABIs in the driver.
+FF-A bus discovery in U-boot
+When CONFIG_ARM_FFA_TRANSPORT is enabled, the FF-A bus is discovered on +demand by the clients (users).
+Clients can discover the FF-A bus using ffa_bus_discover() API which triggers the +discovery process.
+ffa_bus_discover() creates, binds and probes the arm_ffa device using +device_{bind, probe} APIs.
+The discovery process consists in communicating with secure world (or hypervisor) +and querying specific data.
+The discovery process takes place during the arm_ffa device probing which is +handled by ffa_probe().
+The FF-A bus discovery is successful and the bus is ready for use when these +operations succeed:
+- querying the FF-A framework version +- querying from secure world the U-boot endpoint ID +- querying from secure world the RX/TX mapping features +- mapping the RX/TX buffers +- querying from secure world all the partitions information
+Discovery failure results in a probing failure and the arm_ffa device is +destroyed.
+Requirements for clients +-------------------------------------
+When using the FF-A bus with EFI, clients must:
+- Query SPs in EFI boot time mode using the service UUID. +- Unmap RX/TX buffers before EFI runtime mode starts.
+The RX/TX buffers are only available at EFI boot time. Querying partitions is +done at boot time and data is cached for future use.
+RX/TX buffers should be unmapped by the user before EFI runtime mode +starts. The driver provides a bus operation for that: rxtx_unmap()
+If RX/TX buffers created by U-boot are not unmapped and by +consequence becoming available at EFI runtime, secure world will get confused +about RX/TX buffers ownership (U-boot vs kernel).
+The bus driver layer +------------------------------
+The driver comes on top of the SMCCC layer and is implemented in +drivers/firmware/arm-ffa/core.c
+The driver provides the following features:
+- Support for the 32-bit version of the following ABIs:
+FFA_VERSION +FFA_ID_GET +FFA_FEATURES +FFA_PARTITION_INFO_GET +FFA_RXTX_UNMAP +FFA_RX_RELEASE +FFA_RUN +FFA_ERROR +FFA_SUCCESS +FFA_INTERRUPT
+- Support for the 64-bit version of the following ABIs:
+FFA_RXTX_MAP +FFA_MSG_SEND_DIRECT_REQ +FFA_MSG_SEND_DIRECT_RESP
+- Processing the received data from the secure world/hypervisor and caching it
+- Hiding from upper layers the FF-A protocol and registers details. Upper
+- The driver provides callbacks to be used by clients to access the FF-A bus:
+partition_info_get +sync_send_receive +rxtx_unmap
+- FF-A bus discovery makes sure FF-A framework is responsive and compatible
- with the driver
+- FF-A bus can be compiled and used without EFI
+Using armffa command +-----------------------------------
+armffa is a command showcasing how to use the FF-A driver and how to invoke +its operations.
+This provides a guidance to the client developers on how to call the FF-A bus +interfaces.
+Usage:
+armffa <sub-command> <arguments>
+sub-commands:
getpart <partition UUID>
lists the partition(s) info
ping <partition ID>
sends a data pattern to the specified partition
devlist
displays the arm_ffa device info
+Contributors +------------
diff --git a/doc/arch/index.rst b/doc/arch/index.rst index 792d9182c3..8d1ab0ad4e 100644 --- a/doc/arch/index.rst +++ b/doc/arch/index.rst @@ -8,6 +8,7 @@ Architecture-specific doc
arc arm64
diff --git a/drivers/Kconfig b/drivers/Kconfig index 8b6fead351..b06b1ae481 100644 --- a/drivers/Kconfig +++ b/drivers/Kconfig @@ -6,6 +6,8 @@ source "drivers/core/Kconfig"
source "drivers/adc/Kconfig"
+source "drivers/firmware/arm-ffa/Kconfig"
source "drivers/ata/Kconfig"
source "drivers/axi/Kconfig" diff --git a/drivers/Makefile b/drivers/Makefile index 9d9f69a3c9..bf8d7b8cfc 100644 --- a/drivers/Makefile +++ b/drivers/Makefile @@ -111,6 +111,7 @@ obj-y += iommu/ obj-y += smem/ obj-y += thermal/ obj-$(CONFIG_TEE) += tee/ +obj-$(CONFIG_ARM_FFA_TRANSPORT) += firmware/arm-ffa/ obj-y += axi/ obj-y += ufs/ obj-$(CONFIG_W1) += w1/ diff --git a/drivers/firmware/arm-ffa/Kconfig b/drivers/firmware/arm-ffa/Kconfig new file mode 100644 index 0000000000..f1427535f9 --- /dev/null +++ b/drivers/firmware/arm-ffa/Kconfig @@ -0,0 +1,30 @@ +# SPDX-License-Identifier: GPL-2.0
+config ARM_FFA_TRANSPORT
- select ARM_SMCCC
- select LIB_UUID
- select DEVRES
- help
The Firmware Framework for Arm A-profile processors (FF-A)
technology.
This driver is based on FF-A specification v1.0 and uses SMC32
calling convention.
FF-A specification:
https://developer.arm.com/documentation/den0077/a/?lang=en
U-Boot
using the FF-A bus.
and Secure World.
For more details about the FF-A driver, please refer to doc/README.ffa.drv
diff --git a/drivers/firmware/arm-ffa/Makefile b/drivers/firmware/arm-ffa/Makefile new file mode 100644 index 0000000000..043a8915be --- /dev/null +++ b/drivers/firmware/arm-ffa/Makefile @@ -0,0 +1,6 @@ +# SPDX-License-Identifier: GPL-2.0+ +# +# (C) Copyright 2022 +# Abdellatif El Khlifi, Arm Limited, abdellatif.elkhlifi@arm.com.
+obj-y += arm-ffa-uclass.o core.o diff --git a/drivers/firmware/arm-ffa/arm-ffa-uclass.c b/drivers/firmware/arm-ffa/arm-ffa-uclass.c new file mode 100644 index 0000000000..7d9695d289 --- /dev/null +++ b/drivers/firmware/arm-ffa/arm-ffa-uclass.c @@ -0,0 +1,16 @@ +// SPDX-License-Identifier: GPL-2.0+ +/*
+#include <common.h> +#include <dm.h> +#include <asm/global_data.h>
+DECLARE_GLOBAL_DATA_PTR;
+UCLASS_DRIVER(ffa) = {
- .name = "ffa",
- .id = UCLASS_FFA,
+}; diff --git a/drivers/firmware/arm-ffa/arm_ffa_prv.h b/drivers/firmware/arm-ffa/arm_ffa_prv.h new file mode 100644 index 0000000000..7bc90f7f66 --- /dev/null +++ b/drivers/firmware/arm-ffa/arm_ffa_prv.h @@ -0,0 +1,196 @@ +/* SPDX-License-Identifier: GPL-2.0+ */ +/*
+#ifndef __ARM_FFA_PRV_H +#define __ARM_FFA_PRV_H
+#include <arm_ffa.h> +#include <linux/bitfield.h> +#include <linux/bitops.h> +#include <linux/arm-smccc.h>
+/* FF-A core driver name */ +#define FFA_DRV_NAME "arm_ffa"
+/* FF-A driver version definitions */
+#define MAJOR_VERSION_MASK GENMASK(30, 16) +#define MINOR_VERSION_MASK GENMASK(15, 0) +#define GET_FFA_MAJOR_VERSION(x) \
((u16)(FIELD_GET(MAJOR_VERSION_MASK, (x))))
+#define GET_FFA_MINOR_VERSION(x) \
((u16)(FIELD_GET(MINOR_VERSION_MASK, (x))))
+#define PACK_VERSION_INFO(major, minor) \
FIELD_PREP(MINOR_VERSION_MASK, (minor)))
+#define FFA_MAJOR_VERSION (1) +#define FFA_MINOR_VERSION (0) +#define FFA_VERSION_1_0 \
PACK_VERSION_INFO(FFA_MAJOR_VERSION, FFA_MINOR_VERSION)
+/* Endpoint ID mask (u-boot endpoint ID) */
+#define GET_SELF_ENDPOINT_ID_MASK GENMASK(15, 0) +#define GET_SELF_ENDPOINT_ID(x) \
((u16)(FIELD_GET(GET_SELF_ENDPOINT_ID_MASK, (x))))
+#define PREP_SELF_ENDPOINT_ID_MASK GENMASK(31, 16) +#define PREP_SELF_ENDPOINT_ID(x) \
(FIELD_PREP(PREP_SELF_ENDPOINT_ID_MASK, (x)))
+/* Partition endpoint ID mask (partition with which u-boot communicates with) */
+#define PREP_PART_ENDPOINT_ID_MASK GENMASK(15, 0) +#define PREP_PART_ENDPOINT_ID(x) \
(FIELD_PREP(PREP_PART_ENDPOINT_ID_MASK, (x)))
+#define FFA_SMC(calling_convention, func_num) \
ARM_SMCCC_OWNER_STANDARD, (func_num))
+#define FFA_SMC_32(func_num) FFA_SMC(ARM_SMCCC_SMC_32, (func_num)) +#define FFA_SMC_64(func_num) FFA_SMC(ARM_SMCCC_SMC_64, (func_num))
+enum ffa_abis {
- FFA_ERROR = 0x60,
- FFA_RUN = 0x6D,
+/* number of the errors supported by the FF-A specification */ +#define MAX_NUMBER_FFA_ERR 9
+/* container structure and helper macros to map between an FF-A error and relevant error log */ +struct ffa_abi_errmap {
+#define FFA_ERRMAP_COUNT (FFA_LAST_ID - FFA_FIRST_ID + 1) +#define FFA_ID_TO_ERRMAP_ID(ffa_id) ((ffa_id) - FFA_FIRST_ID)
+/* The FF-A SMC function definitions */
+typedef struct arm_smccc_1_2_regs ffa_value_t; +typedef void (*invoke_ffa_fn_t)(ffa_value_t args, ffa_value_t *res);
+struct ffa_partition_uuid {
- u32 a1; /* w1 */
- u32 a2; /* w2 */
- u32 a3; /* w3 */
- u32 a4; /* w4 */
+enum ffa_rxtx_buf_sizes {
- RXTX_4K,
- RXTX_64K,
- RXTX_16K
+struct ffa_rxtxpair {
+struct ffa_partition_desc {
+struct ffa_partitions {
- u32 count;
+struct ffa_prvdata {
- u32 fwk_version;
- u16 id;
+int ffa_device_get(void);
+struct ffa_prvdata **ffa_bus_prvdata_get(void);
+#endif diff --git a/drivers/firmware/arm-ffa/core.c b/drivers/firmware/arm-ffa/core.c new file mode 100644 index 0000000000..324367d12b --- /dev/null +++ b/drivers/firmware/arm-ffa/core.c @@ -0,0 +1,1337 @@ +// SPDX-License-Identifier: GPL-2.0+ +/*
+#include "arm_ffa_prv.h" +#include <asm/global_data.h> +#include <common.h> +#include <dm.h> +#include <dm/device-internal.h> +#include <dm/devres.h> +#include <dm/root.h> +#include <linux/errno.h> +#include <linux/sizes.h> +#include <log.h> +#include <malloc.h> +#include <string.h> +#include <uuid.h>
+struct ffa_prvdata *ffa_priv_data;
+/* Error mapping declarations */
+int ffa_to_std_errmap[MAX_NUMBER_FFA_ERR] = {
- 0,
+struct ffa_abi_errmap err_msg_map[FFA_ERRMAP_COUNT] = {
"NOT_SUPPORTED: A Firmware Framework implementation does not exist",
"", /* INVALID_PARAMETERS */
"", /* NO_MEMORY */
"", /* BUSY */
"", /* INTERRUPTED */
"", /* DENIED */
"", /* RETRY */
"", /* ABORTED */
"NOT_SUPPORTED: This function is not implemented at this FF-A instance",
"", /* NO_MEMORY */
"", /* BUSY */
"", /* DENIED */
"", /* RETRY */
"", /* ABORTED */
"NOT_SUPPORTED: FFA_RXTX_MAP is not implemented at this FF-A instance",
"", /* NO_MEMORY */
"", /* BUSY */
"", /* DENIED */
"", /* RETRY */
"", /* ABORTED */
"INVALID_PARAMETERS: Unrecognized UUID",
"NO_MEMORY: Results cannot fit in RX buffer of the caller",
"BUSY: RX buffer of the caller is not free",
"DENIED: Callee is not in a state to handle this request",
"", /* RETRY */
"", /* ABORTED */
"NOT_SUPPORTED: FFA_RXTX_UNMAP is not implemented at this FF-A instance",
"INVALID_PARAMETERS: No buffer pair registered on behalf of the caller",
"", /* NO_MEMORY */
"", /* BUSY */
"", /* DENIED */
"", /* RETRY */
"", /* ABORTED */
"NOT_SUPPORTED: FFA_RX_RELEASE is not implemented at this FF-A instance",
"", /* NO_MEMORY */
"", /* BUSY */
"DENIED: Caller did not have ownership of the RX buffer",
"", /* RETRY */
"", /* ABORTED */
"INVALID_PARAMETERS: Field(s) in input parameters incorrectly encoded",
"NO_MEMORY: Not enough memory",
"", /* BUSY */
"DENIED: Buffer pair already registered",
"", /* RETRY */
"", /* ABORTED */
- Return:
+int ffa_to_std_errno(int ffa_errno) +{
return ffa_to_std_errmap[err_idx];
- return -EINVAL;
- Return:
+int ffa_print_error_log(u32 ffa_id, int ffa_errno) +{
return -EINVAL;
return -EINVAL;
return -EINVAL;
return -EINVAL;
- Return:
+int ffa_remove_device(struct udevice *dev) +{
- int ret;
- if (!dev) {
return -ENODEV;
- if (ret) {
ffa_err("unable to remove. err:%d\n", ret);
return ret;
- if (ret) {
ffa_err("unable to unbind. err:%d\n", ret);
return ret;
- Return:
+int ffa_device_get(void) +{
- int ret;
DM_DRIVER_GET(arm_ffa),
FFA_DRV_NAME,
NULL,
ofnode_null(),
&dev);
- if (ret)
return ret;
- if (ret) {
ffa_err("arm_ffa device probing failed");
ffa_remove_device(dev);
return ret;
- Return:
+static int ffa_get_version(void) +{
- u16 major, minor;
- int ffa_errno;
.a0 = FFA_SMC_32(FFA_VERSION),
.a1 = FFA_VERSION_1_0
Thanks for all the new comments. I'll address these in v7.
Regarding you older comments, I already replied here [1]. Please have a look.
[1]: https://lore.kernel.org/all/20221014102849.GA14576@e121910.cambridge.arm.com...
}, &res);
ffa_print_error_log(FFA_VERSION, ffa_errno);
FFA_MAJOR_VERSION, FFA_MINOR_VERSION, major, minor);
ffa_info("Versions are compatible ");
ffa_priv_data->fwk_version = res.a0;
- Return:
+static int ffa_get_endpoint_id(void) +{
- int ffa_errno;
.a0 = FFA_SMC_32(FFA_ID_GET)
}, &res);
ffa_priv_data->id = GET_SELF_ENDPOINT_ID((u32)res.a2);
ffa_info("endpoint ID is %u", ffa_priv_data->id);
- Return:
+static int ffa_set_rxtx_buffers_pages_cnt(u32 prop_field) +{
return -EINVAL;
- case RXTX_4K:
ffa_priv_data->pair.rxtx_min_pages = 1;
break;
- case RXTX_16K:
ffa_priv_data->pair.rxtx_min_pages = 4;
break;
- case RXTX_64K:
ffa_priv_data->pair.rxtx_min_pages = 16;
break;
- default:
ffa_err("RX/TX buffer size not supported");
return -EINVAL;
- Return:
+static int ffa_get_rxtx_map_features(void) +{
- int ffa_errno;
.a0 = FFA_SMC_32(FFA_FEATURES),
.a1 = FFA_SMC_64(FFA_RXTX_MAP)
}, &res);
return ffa_set_rxtx_buffers_pages_cnt((u32)res.a2);
+static void ffa_free_rxtx_buffers(void) +{
free((void *)ffa_priv_data->pair.rxbuf);
ffa_priv_data->pair.rxbuf = 0;
free((void *)ffa_priv_data->pair.txbuf);
ffa_priv_data->pair.txbuf = 0;
- Return:
+static int ffa_alloc_rxtx_buffers(void) +{
- u64 bytes;
ffa_priv_data->pair.rxtx_min_pages);
* The alignment of the RX and TX buffers must be equal
* to the larger translation granule size
ffa_err("failure to allocate RX buffer");
return -ENOBUFS;
ffa_err("failure to allocate the TX buffer");
return -ENOBUFS;
* make sure the buffers are cleared before use
- Return:
+static int ffa_map_rxtx_buffers(void) +{
- int ret;
- int ffa_errno;
- if (ret)
return ret;
* we need to pass the physical addresses of the RX/TX buffers
* in u-boot physical/virtual mapping is 1:1
*no need to convert from virtual to physical
.a0 = FFA_SMC_64(FFA_RXTX_MAP),
.a1 = ffa_priv_data->pair.txbuf,
.a2 = ffa_priv_data->pair.rxbuf,
.a3 = ffa_priv_data->pair.rxtx_min_pages,
}, &res);
ffa_info("RX/TX buffers mapped");
- Return:
+static int ffa_unmap_rxtx_buffers(void) +{
- int ffa_errno;
.a0 = FFA_SMC_32(FFA_RXTX_UNMAP),
}, &res);
- Return:
+static int ffa_release_rx_buffer(void) +{
- int ffa_errno;
.a0 = FFA_SMC_32(FFA_RX_RELEASE)
}, &res);
- Return:
+int ffa_uuid_are_identical(const struct ffa_partition_uuid *uuid1,
const struct ffa_partition_uuid *uuid2)
and saves it in the private structure
- data structure.
- Return:
+static int ffa_read_partitions_info(u32 count, struct ffa_partition_uuid *part_uuid) +{
- if (!count) {
ffa_err("no partition detected");
return -ENODATA;
- if (!part_uuid) {
* querying information of all partitions
u64 buf_bytes;
u64 data_bytes;
u32 desc_idx;
struct ffa_partition_info *parts_info;
data_bytes = count * sizeof(struct ffa_partition_desc);
buf_bytes = ffa_priv_data->pair.rxtx_min_pages * SZ_4K;
if (data_bytes > buf_bytes) {
ffa_err("partitions data size exceeds the RX buffer size:");
ffa_err(" sizes in bytes: data %llu , RX buffer %llu ",
data_bytes,
buf_bytes);
return -ENOMEM;
ffa_priv_data->partitions.descs = devm_kmalloc(ffa_priv_data->dev, data_bytes,
__GFP_ZERO);
if (!ffa_priv_data->partitions.descs) {
ffa_err("cannot allocate partitions data buffer");
return -ENOMEM;
parts_info = (struct ffa_partition_info *)ffa_priv_data->pair.rxbuf;
for (desc_idx = 0 ; desc_idx < count ; desc_idx++) {
ffa_priv_data->partitions.descs[desc_idx].info =
parts_info[desc_idx];
ffa_info("Partition ID %x : info cached",
ffa_priv_data->partitions.count = count;
ffa_info("%d partition(s) found and cached", count);
- } else {
u32 rx_desc_idx, cached_desc_idx;
u8 desc_found;
* search for the SP IDs read from the RX buffer
* in the already cached SPs.
* Update the UUID when ID found.
for (rx_desc_idx = 0; rx_desc_idx < count ; rx_desc_idx++) {
desc_found = 0;
* search the current ID in the cached partitions
for (cached_desc_idx = 0;
cached_desc_idx < ffa_priv_data->partitions.count;
cached_desc_idx++) {
* save the UUID
if (ffa_priv_data->partitions.descs[cached_desc_idx].info.id ==
parts_info[rx_desc_idx].id) {
ffa_priv_data->partitions.descs[cached_desc_idx].sp_uuid =
*part_uuid;
desc_found = 1;
break;
if (!desc_found)
return -ENODATA;
- Return:
+static int ffa_query_partitions_info(struct ffa_partition_uuid *part_uuid,
u32 *pcount)
- int ffa_errno;
* If a UUID is specified. Information for one or more
* partitions in the system is queried. Otherwise, information
* for all installed partitions is queried
- if (part_uuid) {
if (!pcount)
return -EINVAL;
query_uuid = *part_uuid;
return -EINVAL;
.a0 = FFA_SMC_32(FFA_PARTITION_INFO_GET),
.a1 = query_uuid.a1,
.a2 = query_uuid.a2,
.a3 = query_uuid.a3,
.a4 = query_uuid.a4
}, &res);
int ret;
* res.a2 contains the count of partition information descriptors
* populated in the RX buffer
if (res.a2) {
ret = ffa_read_partitions_info((u32)res.a2, part_uuid);
if (ret) {
ffa_err("failed to read partition(s) data , error (%d)", ret);
ffa_release_rx_buffer();
return -EINVAL;
* return the SP count (when querying using a UUID)
if (pcount)
*pcount = (u32)res.a2;
* After calling FFA_PARTITION_INFO_GET the buffer ownership
* is assigned to the consumer (u-boot). So, we need to give
* the ownership back to the SPM or hypervisor
ret = ffa_release_rx_buffer();
return ret;
The variable will be set by the driver
- @buffer: NULL
(allocated by the client).
The buffer will be filled by the driver
- buffer.
- Return:
+static int ffa_get_partitions_info(const char *uuid_str,
* fill_data:
* 0: return the SP count
* 1: fill SP data and return it to the caller
* -1: undefined mode
ffa_err("no partition installed");
return -EINVAL;
- if (!uuid_str) {
ffa_err("no UUID provided");
return -EINVAL;
ffa_err("no size/count provided");
return -EINVAL;
ffa_err("invalid UUID");
return -EINVAL;
- if (!buffer) {
/* Mode 1: getting the number of secure partitions */
fill_data = 0;
ffa_info("Preparing for checking partitions count");
!(*parts_size % sizeof(struct ffa_partition_info))) {
/* Mode 2: retrieving the partitions information */
fill_data = 1;
client_desc_idx = 0;
* number of empty descriptors preallocated by the caller
client_desc_max_cnt = *parts_size / sizeof(struct ffa_partition_info);
ffa_info("Preparing for filling partitions info");
- } else {
ffa_err("invalid function arguments provided");
return -EINVAL;
* search in the cached partitions
desc_idx++) {
if (ffa_uuid_are_identical(&ffa_priv_data->partitions.descs[desc_idx].sp_uuid,
&part_uuid)) {
ffa_info("Partition ID %x matches the provided UUID",
ffa_priv_data->partitions.descs[desc_idx].info.id);
parts_found++;
if (fill_data) {
* trying to fill the partition info in the input buffer
if (client_desc_idx < client_desc_max_cnt) {
buffer[client_desc_idx++] =
ffa_priv_data->partitions.descs[desc_idx].info;
continue;
ffa_err("failed to fill the current descriptor client buffer full");
return -ENOBUFS;
int ret;
ffa_info("No partition found. Querying framework ...");
ret = ffa_query_partitions_info(&part_uuid, &parts_found);
if (ret == 0) {
if (!fill_data) {
*parts_size = parts_found;
ffa_info("Number of partition(s) found matching the UUID: %d",
parts_found);
} else {
* If SPs data detected, they are already in the private data
* structure, retry searching SP data again to return them
* to the caller
if (parts_found)
ret = ffa_get_partitions_info(uuid_str, parts_size, buffer);
else
ret = -ENODATA;
return ret;
- if (!fill_data)
- Return:
+static int ffa_cache_partitions_info(void) +{
- FF-A functions.
- Return:
+static int ffa_msg_send_direct_req(u16 dst_part_id, struct ffa_send_direct_data *msg) +{
- int ffa_errno;
return -EINVAL;
return -ENODEV;
.a0 = FFA_SMC_64(FFA_MSG_SEND_DIRECT_REQ),
.a1 = PREP_SELF_ENDPOINT_ID(ffa_priv_data->id) |
PREP_PART_ENDPOINT_ID(dst_part_id),
.a2 = 0,
.a3 = msg->data0,
.a4 = msg->data1,
.a5 = msg->data2,
.a6 = msg->data3,
.a7 = msg->data4,
}, &res);
.a0 = FFA_SMC_32(FFA_RUN),
.a1 = res.a1
}, &res);
/* Message sent with no response */
* Message sent with response
* extract the return data
msg->data0 = res.a3;
msg->data1 = res.a4;
msg->data2 = res.a5;
msg->data3 = res.a6;
msg->data4 = res.a7;
- Return: void
+void __arm_ffa_fn_smc(ffa_value_t args, ffa_value_t *res) +{
- Return:
return -EINVAL;
- Return:
- if (!dev) {
return -ENODEV;
return -ENOMEM;
- Return:
- int ret;
- if (ret != 0)
return ret;
- if (ret != 0)
return ret;
- if (ret != 0)
return ret;
- if (ret != 0)
return ret;
- if (ret != 0)
return ret;
- if (ret != 0)
return ret;
Cheers, Jens
- if (ret != 0) {
return ret;
- Return:
- 0 on success.
- Return:
- 0 on success.
- Return:
- Return:
- communication.
- Return:
- int ret = 0;
- return ret;
- .id = UCLASS_FFA,
- @id: Partition ID
- u16 id;
- u16 exec_ctxt;
- u32 properties;
-- 2.17.1
U-Boot
All comments in this patch are addressed in v7, thanks.
- sync_send_receive
- rxtx_unmap
Changelog:
v6:
v4:
v3:
v2:
v1:
+Summary +-------
s/Optee OS/OP-TEE/
+the SMC ABIs.
+Aarch64 plaforms
- communication.
+CONFIG_SANDBOX_FFA
- with the driver
+Usage:
+sub-commands:
ping <partition ID>
devlist
arc arm64
- select ARM_SMCCC
- select LIB_UUID
- select DEVRES
- help
technology.
calling convention.
FF-A specification:
U-Boot
using the FF-A bus.
and Secure World.
- .name = "ffa",
- .id = UCLASS_FFA,
+enum ffa_abis {
- FFA_ERROR = 0x60,
- FFA_RUN = 0x6D,
- u32 a1; /* w1 */
- u32 a2; /* w2 */
- u32 a3; /* w3 */
- u32 a4; /* w4 */
- RXTX_4K,
- RXTX_64K,
- RXTX_16K
- u32 count;
- u32 fwk_version;
- u16 id;
- 0,
"", /* NO_MEMORY */
"", /* BUSY */
"", /* DENIED */
"", /* RETRY */
"", /* ABORTED */
"", /* NO_MEMORY */
"", /* BUSY */
"", /* DENIED */
"", /* RETRY */
"", /* ABORTED */
"", /* NO_MEMORY */
"", /* BUSY */
"", /* DENIED */
"", /* RETRY */
"", /* ABORTED */
"", /* RETRY */
"", /* ABORTED */
"", /* NO_MEMORY */
"", /* BUSY */
"", /* DENIED */
"", /* RETRY */
"", /* ABORTED */
"", /* NO_MEMORY */
"", /* BUSY */
"", /* RETRY */
"", /* ABORTED */
"", /* BUSY */
"", /* RETRY */
"", /* ABORTED */
- Return:
- return -EINVAL;
- Return:
return -EINVAL;
return -EINVAL;
return -EINVAL;
return -EINVAL;
- Return:
- int ret;
- if (!dev) {
ffa_err("no udevice found");
return -ENODEV;
- if (ret) {
return ret;
- if (ret) {
return ret;
- Return:
- int ret;
FFA_DRV_NAME,
NULL,
ofnode_null(),
&dev);
- if (ret)
return ret;
- if (ret) {
return ret;
- Return:
- u16 major, minor;
- int ffa_errno;
}, &res);
- Return:
- int ffa_errno;
}, &res);
- Return:
return -EINVAL;
- case RXTX_4K:
break;
- case RXTX_16K:
break;
- case RXTX_64K:
break;
- default:
return -EINVAL;
- Return:
- int ffa_errno;
}, &res);
- Return:
- u64 bytes;
return -ENOBUFS;
return -ENOBUFS;
- Return:
- int ret;
- int ffa_errno;
- if (ret)
return ret;
}, &res);
- Return:
- int ffa_errno;
}, &res);
- Return:
- int ffa_errno;
}, &res);
- Return:
- data structure.
- Return:
- if (!count) {
return -ENODATA;
- if (!part_uuid) {
u64 buf_bytes;
u64 data_bytes;
u32 desc_idx;
data_bytes,
buf_bytes);
return -ENOMEM;
__GFP_ZERO);
return -ENOMEM;
- } else {
u8 desc_found;
desc_found = 0;
* save the UUID
*part_uuid;
desc_found = 1;
break;
if (!desc_found)
return -ENODATA;
- Return:
u32 *pcount)
- int ffa_errno;
- if (part_uuid) {
if (!pcount)
return -EINVAL;
return -EINVAL;
.a4 = query_uuid.a4
}, &res);
int ret;
if (res.a2) {
if (ret) {
return -EINVAL;
if (pcount)
return ret;
- @buffer: NULL
- buffer.
- Return:
* fill_data:
return -EINVAL;
- if (!uuid_str) {
return -EINVAL;
return -EINVAL;
return -EINVAL;
- if (!buffer) {
fill_data = 0;
fill_data = 1;
- } else {
return -EINVAL;
desc_idx++) {
&part_uuid)) {
parts_found++;
if (fill_data) {
continue;
return -ENOBUFS;
int ret;
if (ret == 0) {
if (!fill_data) {
parts_found);
} else {
* to the caller
if (parts_found)
else
ret = -ENODATA;
return ret;
- if (!fill_data)
- Return:
- FF-A functions.
- Return:
- int ffa_errno;
return -EINVAL;
return -ENODEV;
.a2 = 0,
.a3 = msg->data0,
.a4 = msg->data1,
.a5 = msg->data2,
.a6 = msg->data3,
.a7 = msg->data4,
}, &res);
.a1 = res.a1
}, &res);
- Return: void
- Return:
+static int ffa_set_smc_conduit(void) +{
ffa_err("failure to set the invoke function");
return -EINVAL;
+static void ffa_set_bus_ops(void) +{
- Return:
+static int ffa_alloc_prvdata(struct udevice *dev) +{
- if (!dev) {
return -ENODEV;
ffa_err("can not allocate the driver main data structure");
return -ENOMEM;
- setting the conduit
- querying from secure world the u-boot endpoint ID
- querying from secure world the supported features of FFA_RXTX_MAP
- Return:
+static int ffa_probe(struct udevice *dev) +{
- int ret;
- if (ret != 0)
return ret;
- if (ret != 0)
return ret;
- if (ret != 0)
return ret;
- if (ret != 0)
return ret;
- if (ret != 0)
return ret;
- if (ret != 0)
return ret;
Cheers, Jens
- if (ret != 0) {
return ret;
- Return:
- 0 on success.
+static int ffa_remove(struct udevice *dev) +{
- Return:
- 0 on success.
+static int ffa_unbind(struct udevice *dev) +{
- Return:
+const struct ffa_bus_ops *ffa_bus_ops_get(void) +{
- Return:
+struct ffa_prvdata **ffa_bus_prvdata_get(void) +{
- communication.
- Return:
+int ffa_bus_discover(void) +{
- int ret = 0;
ret = ffa_device_get();
- return ret;
+U_BOOT_DRIVER(arm_ffa) = {
- .id = UCLASS_FFA,
+}; diff --git a/include/arm_ffa.h b/include/arm_ffa.h new file mode 100644 index 0000000000..d146e7b328 --- /dev/null +++ b/include/arm_ffa.h @@ -0,0 +1,93 @@ +/* SPDX-License-Identifier: GPL-2.0+ */ +/*
+#ifndef __ARM_FFA_H +#define __ARM_FFA_H
+#include <linux/printk.h>
- @id: Partition ID
- u16 id;
- u16 exec_ctxt;
- u32 properties;
-- 2.17.1
unmap RX/TX buffers at ExitBootServices()
Unmapping the RX/TX buffers created by u-boot is needed before EFI runtime.
At EFI runtime the linux kernel takes care of allocating its own RX/TX buffers and registering them with the secure world.
Secure world should be using the RX/TX buffers created by the kernel. So, RX/TX buffers created by u-boot must be unmapped.
Signed-off-by: Abdellatif El Khlifi abdellatif.elkhlifi@arm.com Cc: Tom Rini trini@konsulko.com Cc: Simon Glass sjg@chromium.org Cc: Ilias Apalodimas ilias.apalodimas@linaro.org Cc: Jens Wiklander jens.wiklander@linaro.org --- lib/efi_loader/efi_boottime.c | 15 +++++++++++++++ 1 file changed, 15 insertions(+)
diff --git a/lib/efi_loader/efi_boottime.c b/lib/efi_loader/efi_boottime.c index a56021559b..2054b33568 100644 --- a/lib/efi_loader/efi_boottime.c +++ b/lib/efi_loader/efi_boottime.c @@ -3,6 +3,9 @@ * EFI application boot time services * * Copyright (c) 2016 Alexander Graf + * + * (C) Copyright 2022 ARM Limited + * Abdellatif El Khlifi abdellatif.elkhlifi@arm.com */
#include <common.h> @@ -23,6 +26,10 @@ #include <asm/setjmp.h> #include <linux/libfdt_env.h>
+#if CONFIG_IS_ENABLED(ARM_FFA_TRANSPORT) +#include <arm_ffa.h> +#endif + DECLARE_GLOBAL_DATA_PTR;
/* Task priority level */ @@ -2178,6 +2185,14 @@ static efi_status_t EFIAPI efi_exit_boot_services(efi_handle_t image_handle, dm_remove_devices_flags(DM_REMOVE_ACTIVE_ALL); }
+#if CONFIG_IS_ENABLED(ARM_FFA_TRANSPORT) + /* unmap FF-A RX/TX buffers */ + if (ffa_bus_ops_get()->rxtx_unmap()) + debug("[efi_boottime][ERROR]: can not unmap FF-A RX/TX buffers\n"); + else + debug("[efi_boottime][INFO]: FF-A RX/TX buffers unmapped\n"); +#endif + /* Patch out unsupported runtime function */ efi_runtime_detach();
- EFI application boot time services
- Copyright (c) 2016 Alexander Graf
Just do log_err() here and get rid of the else
else
- /* Patch out unsupported runtime function */ efi_runtime_detach();
-- 2.17.1
Thanks /Ilias
Thanks. Done in v7.
else
-- 2.17.1
Thanks /Ilias
Provide armffa command showcasing the use of the FF-A driver
The armffa command allows to query secure partitions data from the secure world and exchanging messages with the partitions.
Changelog: ===============
v4:
* remove pattern data in do_ffa_msg_send_direct_req
v3:
* use the new driver interfaces (partition_info_get, sync_send_receive) in armffa command
v2:
* replace use of ffa_helper_init_device function by ffa_helper_bus_discover
v1:
* introduce armffa command
MAINTAINERS | 1 + cmd/Kconfig | 10 ++ cmd/Makefile | 2 + cmd/armffa.c | 242 +++++++++++++++++++++++++++++++ drivers/firmware/arm-ffa/Kconfig | 1 + 5 files changed, 256 insertions(+) create mode 100644 cmd/armffa.c
diff --git a/MAINTAINERS b/MAINTAINERS index 496f47a516..663e2abccd 100644 --- a/MAINTAINERS +++ b/MAINTAINERS @@ -251,6 +251,7 @@ F: configs/cortina_presidio-asic-pnand_defconfig ARM FF-A M: Abdellatif El Khlifi abdellatif.elkhlifi@arm.com S: Maintained +F: cmd/armffa.c F: doc/arch/arm64.ffa.rst F: drivers/firmware/arm-ffa/ F: include/arm_ffa.h diff --git a/cmd/Kconfig b/cmd/Kconfig index 6f00bd9307..6b1ffee3cf 100644 --- a/cmd/Kconfig +++ b/cmd/Kconfig @@ -912,6 +912,16 @@ endmenu
menu "Device access commands"
+config CMD_ARMFFA + bool "Arm FF-A test command" + depends on ARM_FFA_TRANSPORT + help + Provides a test command for the Arm FF-A driver + supported options: + - Listing the partition(s) info + - Sending a data pattern to the specified partition + - Displaying the arm_ffa device info + config CMD_ARMFLASH #depends on FLASH_CFI_DRIVER bool "armflash" diff --git a/cmd/Makefile b/cmd/Makefile index cf6ce1bd6f..7d806817b1 100644 --- a/cmd/Makefile +++ b/cmd/Makefile @@ -12,6 +12,8 @@ obj-y += panic.o obj-y += version.o
# command + +obj-$(CONFIG_CMD_ARMFFA) += armffa.o obj-$(CONFIG_CMD_ACPI) += acpi.o obj-$(CONFIG_CMD_ADDRMAP) += addrmap.o obj-$(CONFIG_CMD_AES) += aes.o diff --git a/cmd/armffa.c b/cmd/armffa.c new file mode 100644 index 0000000000..9b56e8a830 --- /dev/null +++ b/cmd/armffa.c @@ -0,0 +1,242 @@ +// SPDX-License-Identifier: GPL-2.0+ +/* + * (C) Copyright 2022 ARM Limited + * Abdellatif El Khlifi abdellatif.elkhlifi@arm.com + */ + +#include <arm_ffa.h> +#include <asm/io.h> +#include <common.h> +#include <command.h> +#include <dm.h> +#include <mapmem.h> +#include <stdlib.h> + +/** + * do_ffa_get_singular_partition_info - implementation of the getpart subcommand + * @cmdtp: Command Table + * @flag: flags + * @argc: number of arguments + * @argv: arguments + * + * This function queries the secure partition information which the UUID is provided + * as an argument. The function uses the arm_ffa driver partition_info_get operation + * to retrieve the data. + * The input UUID string is expected to be in big endian format. + * + * Return: + * + * CMD_RET_SUCCESS: on success, otherwise failure + */ +static int do_ffa_get_singular_partition_info(struct cmd_tbl *cmdtp, int flag, int argc, + char *const argv[]) +{ + u32 count = 0, size = 0; + int ret; + struct ffa_partition_info *parts_info; + u32 info_idx; + + if (argc != 1) + return -EINVAL; + + /* Mode 1: getting the number of secure partitions */ + ret = ffa_bus_ops_get()->partition_info_get(argv[0], &count, NULL); + if (ret != 0) { + ffa_err("Failure in querying partitions count (error code: %d)", ret); + return ret; + } + + if (!count) { + ffa_info("No secure partition found"); + return ret; + } + + /* + * pre-allocate a buffer to be filled by the driver + * with ffa_partition_info structs + */ + + ffa_info("Pre-allocating %d partition(s) info structures", count); + + parts_info = calloc(count, sizeof(struct ffa_partition_info)); + if (!parts_info) + return -EINVAL; + + size = count * sizeof(struct ffa_partition_info); + + /* + * ask the driver to fill the buffer with the SPs info + */ + + ret = ffa_bus_ops_get()->partition_info_get(argv[0], &size, parts_info); + if (ret != 0) { + ffa_err("Failure in querying partition(s) info (error code: %d)", ret); + free(parts_info); + return ret; + } + + /* + * SPs found , show the partition information + */ + for (info_idx = 0; info_idx < count ; info_idx++) { + ffa_info("Partition: id = 0x%x , exec_ctxt 0x%x , properties 0x%x", + parts_info[info_idx].id, + parts_info[info_idx].exec_ctxt, + parts_info[info_idx].properties); + } + + free(parts_info); + + return 0; +} + +/** + * do_ffa_msg_send_direct_req - implementation of the ping subcommand + * @cmdtp: Command Table + * @flag: flags + * @argc: number of arguments + * @argv: arguments + * + * This function sends data to the secure partition which the ID is provided + * as an argument. The function uses the arm_ffa driver sync_send_receive operation + * to send data. + * + * Return: + * + * CMD_RET_SUCCESS: on success, otherwise failure + */ +int do_ffa_msg_send_direct_req(struct cmd_tbl *cmdtp, int flag, int argc, + char *const argv[]) +{ + struct ffa_send_direct_data msg = { + .data0 = 0xaaaaaaaa, + .data1 = 0xbbbbbbbb, + .data2 = 0xcccccccc, + .data3 = 0xdddddddd, + .data4 = 0xeeeeeeee, + }; + u16 part_id; + int ret; + + if (argc != 1) + return -EINVAL; + + errno = 0; + part_id = strtoul(argv[0], NULL, 16); + + if (errno) { + ffa_err("Invalid partition ID"); + return -EINVAL; + } + + ret = ffa_bus_ops_get()->sync_send_receive(part_id, &msg); + if (ret == 0) { + u8 cnt; + + ffa_info("SP response:\n[LSB]"); + for (cnt = 0; + cnt < sizeof(struct ffa_send_direct_data) / sizeof(u64); + cnt++) + ffa_info("0x%llx", ((u64 *)&msg)[cnt]); + } else { + ffa_err("Sending direct request error (%d)", ret); + } + + return ret; +} + +/** + *do_ffa_dev_list - implementation of the devlist subcommand + * @cmdtp: [in] Command Table + * @flag: flags + * @argc: number of arguments + * @argv: arguments + * + * This function queries the devices belonging to the UCLASS_FFA + * class. Currently, one device is expected to show up: the arm_ffa device + * + * Return: + * + * CMD_RET_SUCCESS: on success, otherwise failure + */ +int do_ffa_dev_list(struct cmd_tbl *cmdtp, int flag, int argc, char *const argv[]) +{ + struct udevice *dev = NULL; + int i, ret; + + ffa_info("arm_ffa uclass entries:"); + + for (i = 0, ret = uclass_first_device(UCLASS_FFA, &dev); + dev; + ret = uclass_next_device(&dev), i++) { + if (ret) + break; + + ffa_info("entry %d - instance %08x, ops %08x, plat %08x", + i, + (u32)map_to_sysmem(dev), + (u32)map_to_sysmem(dev->driver->ops), + (u32)map_to_sysmem(dev_get_plat(dev))); + } + + return cmd_process_error(cmdtp, ret); +} + +static struct cmd_tbl armffa_commands[] = { + U_BOOT_CMD_MKENT(getpart, 1, 1, do_ffa_get_singular_partition_info, "", ""), + U_BOOT_CMD_MKENT(ping, 1, 1, do_ffa_msg_send_direct_req, "", ""), + U_BOOT_CMD_MKENT(devlist, 0, 1, do_ffa_dev_list, "", ""), +}; + +/** + * do_armffa - the armffa command main function + * @cmdtp: Command Table + * @flag: flags + * @argc: number of arguments + * @argv: arguments + * + * This function identifies which armffa subcommand to run. + * Then, it makes sure the arm_ffa device is probed and + * ready for use. + * Then, it runs the subcommand. + * + * Return: + * + * CMD_RET_SUCCESS: on success, otherwise failure + */ +static int do_armffa(struct cmd_tbl *cmdtp, int flag, int argc, char *const argv[]) +{ + struct cmd_tbl *armffa_cmd; + int ret; + + if (argc < 2) + return CMD_RET_USAGE; + + armffa_cmd = find_cmd_tbl(argv[1], armffa_commands, ARRAY_SIZE(armffa_commands)); + + argc -= 2; + argv += 2; + + if (!armffa_cmd || argc > armffa_cmd->maxargs) + return CMD_RET_USAGE; + + ret = ffa_bus_discover(); + if (ret != 0) + return cmd_process_error(cmdtp, ret); + + if (!ffa_bus_ops_get()) + return -EINVAL; + + ret = armffa_cmd->cmd(armffa_cmd, flag, argc, argv); + + return cmd_process_error(armffa_cmd, ret); +} + +U_BOOT_CMD(armffa, 4, 1, do_armffa, + "Arm FF-A operations test command", + "getpart <partition UUID>\n" + " - lists the partition(s) info\n" + "ping <partition ID>\n" + " - sends a data pattern to the specified partition\n" + "devlist\n" + " - displays the arm_ffa device info\n"); diff --git a/drivers/firmware/arm-ffa/Kconfig b/drivers/firmware/arm-ffa/Kconfig index f1427535f9..624e834b1f 100644 --- a/drivers/firmware/arm-ffa/Kconfig +++ b/drivers/firmware/arm-ffa/Kconfig @@ -4,6 +4,7 @@ config ARM_FFA_TRANSPORT bool "Enable Arm Firmware Framework for Armv8-A driver" depends on DM && ARM64 select ARM_SMCCC + select CMD_ARMFFA select LIB_UUID select DEVRES help
Provide a Sandbox driver to emulate the FF-A ABIs
The emulated ABIs are those supported by the FF-A core driver and according to FF-A specification v1.0.
The Sandbox driver provides operations allowing the test application to read the status of all the inspected ABIs and perform functional tests based on that.
v4: align sandbox driver with the new FF-A driver interfaces and new way of error handling
v1: introduce the sandbox driver
MAINTAINERS | 1 + configs/sandbox64_defconfig | 2 + configs/sandbox_defconfig | 2 + doc/arch/sandbox.rst | 1 + drivers/firmware/arm-ffa/Kconfig | 9 +- drivers/firmware/arm-ffa/Makefile | 1 + drivers/firmware/arm-ffa/arm_ffa_prv.h | 15 +- drivers/firmware/arm-ffa/core.c | 24 +- drivers/firmware/arm-ffa/sandbox.c | 659 ++++++++++++++++++ .../firmware/arm-ffa/sandbox_arm_ffa_prv.h | 144 ++++ include/arm_ffa.h | 2 +- include/sandbox_arm_ffa.h | 91 +++ lib/efi_loader/efi_boottime.c | 2 +- 13 files changed, 939 insertions(+), 14 deletions(-) create mode 100644 drivers/firmware/arm-ffa/sandbox.c create mode 100644 drivers/firmware/arm-ffa/sandbox_arm_ffa_prv.h create mode 100644 include/sandbox_arm_ffa.h
diff --git a/MAINTAINERS b/MAINTAINERS index 663e2abccd..598ae76e16 100644 --- a/MAINTAINERS +++ b/MAINTAINERS @@ -255,6 +255,7 @@ F: cmd/armffa.c F: doc/arch/arm64.ffa.rst F: drivers/firmware/arm-ffa/ F: include/arm_ffa.h +F: include/sandbox_arm_ffa.h
ARM FREESCALE IMX M: Stefano Babic sbabic@denx.de diff --git a/configs/sandbox64_defconfig b/configs/sandbox64_defconfig index b20b181ab1..cd5575ce61 100644 --- a/configs/sandbox64_defconfig +++ b/configs/sandbox64_defconfig @@ -250,3 +250,5 @@ CONFIG_TEST_FDTDEC=y CONFIG_UNIT_TEST=y CONFIG_UT_TIME=y CONFIG_UT_DM=y +CONFIG_ARM_FFA_TRANSPORT=y +CONFIG_SANDBOX_FFA=y \ No newline at end of file diff --git a/configs/sandbox_defconfig b/configs/sandbox_defconfig index df6a28ef24..27eb2f7ab3 100644 --- a/configs/sandbox_defconfig +++ b/configs/sandbox_defconfig @@ -327,3 +327,5 @@ CONFIG_TEST_FDTDEC=y CONFIG_UNIT_TEST=y CONFIG_UT_TIME=y CONFIG_UT_DM=y +CONFIG_ARM_FFA_TRANSPORT=y +CONFIG_SANDBOX_FFA=y \ No newline at end of file diff --git a/doc/arch/sandbox.rst b/doc/arch/sandbox.rst index 068d4a3be4..5d7e1b2c48 100644 --- a/doc/arch/sandbox.rst +++ b/doc/arch/sandbox.rst @@ -203,6 +203,7 @@ Supported Drivers
U-Boot sandbox supports these emulations:
+- Arm FF-A - Block devices - Chrome OS EC - GPIO diff --git a/drivers/firmware/arm-ffa/Kconfig b/drivers/firmware/arm-ffa/Kconfig index 624e834b1f..343f6499d0 100644 --- a/drivers/firmware/arm-ffa/Kconfig +++ b/drivers/firmware/arm-ffa/Kconfig @@ -2,8 +2,8 @@
config ARM_FFA_TRANSPORT bool "Enable Arm Firmware Framework for Armv8-A driver" - depends on DM && ARM64 - select ARM_SMCCC + depends on DM && (ARM64 || SANDBOX) + select ARM_SMCCC if !SANDBOX select CMD_ARMFFA select LIB_UUID select DEVRES @@ -29,3 +29,8 @@ config ARM_FFA_TRANSPORT
+config SANDBOX_FFA + bool "FF-A Sandbox driver" + depends on ARM_FFA_TRANSPORT && SANDBOX + help + This emulates the FF-A handling under Sandbox and allows to test the FF-A driver diff --git a/drivers/firmware/arm-ffa/Makefile b/drivers/firmware/arm-ffa/Makefile index 043a8915be..0d21d6b47a 100644 --- a/drivers/firmware/arm-ffa/Makefile +++ b/drivers/firmware/arm-ffa/Makefile @@ -4,3 +4,4 @@ # Abdellatif El Khlifi, Arm Limited, abdellatif.elkhlifi@arm.com.
obj-y += arm-ffa-uclass.o core.o +obj-$(CONFIG_SANDBOX_FFA) += sandbox.o diff --git a/drivers/firmware/arm-ffa/arm_ffa_prv.h b/drivers/firmware/arm-ffa/arm_ffa_prv.h index 7bc90f7f66..3e0d4c112c 100644 --- a/drivers/firmware/arm-ffa/arm_ffa_prv.h +++ b/drivers/firmware/arm-ffa/arm_ffa_prv.h @@ -19,6 +19,16 @@ /* FF-A core driver name */ #define FFA_DRV_NAME "arm_ffa"
+/* The FF-A SMC function definitions */ + +#if CONFIG_IS_ENABLED(SANDBOX_FFA) +#include "sandbox_arm_ffa.h" +#else +typedef struct arm_smccc_1_2_regs ffa_value_t; +#endif + +typedef void (*invoke_ffa_fn_t)(ffa_value_t args, ffa_value_t *res); + /* FF-A driver version definitions */
#define MAJOR_VERSION_MASK GENMASK(30, 16) @@ -94,11 +104,6 @@ struct ffa_abi_errmap { #define FFA_ERRMAP_COUNT (FFA_LAST_ID - FFA_FIRST_ID + 1) #define FFA_ID_TO_ERRMAP_ID(ffa_id) ((ffa_id) - FFA_FIRST_ID)
-/* The FF-A SMC function definitions */ - -typedef struct arm_smccc_1_2_regs ffa_value_t; -typedef void (*invoke_ffa_fn_t)(ffa_value_t args, ffa_value_t *res); - /* * struct ffa_partition_uuid - 16 bytes UUID transmitted by FFA_PARTITION_INFO_GET * @a1-4: 32-bit words access to the UUID data diff --git a/drivers/firmware/arm-ffa/core.c b/drivers/firmware/arm-ffa/core.c index 324367d12b..2810e4a636 100644 --- a/drivers/firmware/arm-ffa/core.c +++ b/drivers/firmware/arm-ffa/core.c @@ -1096,6 +1096,7 @@ static int ffa_msg_send_direct_req(u16 dst_part_id, struct ffa_send_direct_data return ffa_to_std_errno(ffa_errno); }
+#if !CONFIG_IS_ENABLED(SANDBOX_FFA) /** * __arm_ffa_fn_smc - SMC wrapper * @args: FF-A ABI arguments to be copied to Xn registers @@ -1109,6 +1110,7 @@ void __arm_ffa_fn_smc(ffa_value_t args, ffa_value_t *res) { arm_smccc_1_2_smc(&args, res); } +#endif
/** * ffa_set_smc_conduit - Set the SMC conduit @@ -1122,7 +1124,12 @@ void __arm_ffa_fn_smc(ffa_value_t args, ffa_value_t *res) */ static int ffa_set_smc_conduit(void) { - ffa_priv_data->invoke_ffa_fn = __arm_ffa_fn_smc; +#if CONFIG_IS_ENABLED(SANDBOX_FFA) + ffa_priv_data->invoke_ffa_fn = sandbox_arm_ffa_smccc_smc; + ffa_info("Using SMC emulation"); +#else + ffa_priv_data->invoke_ffa_fn = __arm_ffa_fn_smc; +#endif
if (!ffa_priv_data->invoke_ffa_fn) { ffa_err("failure to set the invoke function"); @@ -1299,15 +1306,16 @@ struct ffa_prvdata **ffa_bus_prvdata_get(void) }
/** - * ffa_bus_discover - discover FF-A bus and probe the arm_ffa device + * ffa_bus_discover - discover FF-A bus and probe arm_ffa and sandbox_arm_ffa devices * * This function makes sure the FF-A bus is discoverable. - * When probing succeeds FF-A discovery is done. The arm_ffa device is ready to use. + * When probing succeeds FF-A discovery is done. The arm_ffa and sandbox_arm_ffa devices + * are ready to use. * * When the bus was already discovered successfully the discovery will not run again. * * Arm FF-A transport is implemented through arm_ffa u-boot device managing the FF-A - * communication. + * communication. In Sandbox mode sandbox_arm_ffa is used to test arm_ffa driver. * All FF-A clients should use the arm_ffa device to use the FF-A transport. * * Return: @@ -1318,9 +1326,15 @@ int ffa_bus_discover(void) { int ret = 0;
- if (!ffa_priv_data) + if (!ffa_priv_data) { ret = ffa_device_get();
+#if CONFIG_IS_ENABLED(SANDBOX_FFA) + if (ret == 0) + ret = sandbox_ffa_device_get(); +#endif + } + return ret; }
diff --git a/drivers/firmware/arm-ffa/sandbox.c b/drivers/firmware/arm-ffa/sandbox.c new file mode 100644 index 0000000000..16e1fdc809 --- /dev/null +++ b/drivers/firmware/arm-ffa/sandbox.c @@ -0,0 +1,659 @@ +// SPDX-License-Identifier: GPL-2.0+ +/* + * (C) Copyright 2022 ARM Limited + * Abdellatif El Khlifi abdellatif.elkhlifi@arm.com + */ + +#include "sandbox_arm_ffa_prv.h" +#include <asm/global_data.h> +#include <common.h> +#include <dm.h> +#include <dm/device-internal.h> +#include <dm/root.h> +#include <linux/errno.h> +#include <linux/sizes.h> +#include <mapmem.h> +#include <string.h> + +DECLARE_GLOBAL_DATA_PTR; + +/** + * The device private data structure containing all the emulated secure world data + */ +static struct sandbox_ffa_prvdata sandbox_ffa_priv_data = {0}; + +/* The partitions (SPs) table */ +static struct ffa_partition_desc sandbox_partitions[SANDBOX_PARTITIONS_CNT] = { + { + .info = { .id = SANDBOX_SP1_ID, .exec_ctxt = 0x5687, .properties = 0x89325621 }, + .sp_uuid = { + .a1 = SANDBOX_SERVICE1_UUID_A1, + .a2 = SANDBOX_SERVICE1_UUID_A2, + .a3 = SANDBOX_SERVICE1_UUID_A3, + .a4 = SANDBOX_SERVICE1_UUID_A4, + } + }, + { + .info = { .id = SANDBOX_SP2_ID, .exec_ctxt = 0x9587, .properties = 0x45325621 }, + .sp_uuid = { + .a1 = SANDBOX_SERVICE2_UUID_A1, + .a2 = SANDBOX_SERVICE2_UUID_A2, + .a3 = SANDBOX_SERVICE2_UUID_A3, + .a4 = SANDBOX_SERVICE2_UUID_A4, + } + }, + { + .info = { .id = SANDBOX_SP3_ID, .exec_ctxt = 0x7687, .properties = 0x23325621 }, + .sp_uuid = { + .a1 = SANDBOX_SERVICE1_UUID_A1, + .a2 = SANDBOX_SERVICE1_UUID_A2, + .a3 = SANDBOX_SERVICE1_UUID_A3, + .a4 = SANDBOX_SERVICE1_UUID_A4, + } + }, + { + .info = { .id = SANDBOX_SP4_ID, .exec_ctxt = 0x1487, .properties = 0x70325621 }, + .sp_uuid = { + .a1 = SANDBOX_SERVICE2_UUID_A1, + .a2 = SANDBOX_SERVICE2_UUID_A2, + .a3 = SANDBOX_SERVICE2_UUID_A3, + .a4 = SANDBOX_SERVICE2_UUID_A4, + } + } + +}; + +/* + * Driver functions + */ + +/** + * sandbox_ffa_get_device - probes the sandbox_arm_ffa device + * + * This function makes sure the sandbox_arm_ffa device is probed + * This function makes sure the sandbox_arm_ffa device is + * created, bound to this driver, probed and ready to use. + * + * sandbox_arm_ffa depends on arm_ffa device. This dependency is + * handled by ffa_bus_discover function. arm_ffa is probed first then + * sandbox_arm_ffa. + * + * Return: + * + * 0 on success. Otherwise, failure + */ +int sandbox_ffa_device_get(void) +{ + int ret; + + if (sandbox_ffa_priv_data.dev) + return 0; + + ret = device_bind(dm_root(), + DM_DRIVER_GET(sandbox_arm_ffa), + FFA_SANDBOX_DRV_NAME, + NULL, + ofnode_null(), + &sandbox_ffa_priv_data.dev); + if (ret) { + sandbox_ffa_priv_data.dev = NULL; + return ret; + } + + ret = device_probe(sandbox_ffa_priv_data.dev); + if (ret) { + ffa_err("[Sandbox] can not probe the device"); + device_unbind(sandbox_ffa_priv_data.dev); + sandbox_ffa_priv_data.dev = NULL; + return ret; + } + + return 0; +} + +/** + * sandbox_ffa_version - Emulated FFA_VERSION handler function + * @{a0-a7} , res: The SMC call arguments and return structure. + * + * This is the function that emulates FFA_VERSION FF-A function. + * + * Return: + * + * 0 on success. Otherwise, failure + */ +SANDBOX_SMC_FFA_ABI(ffa_version) +{ + sandbox_ffa_priv_data.fwk_version = FFA_VERSION_1_0; + res->a0 = sandbox_ffa_priv_data.fwk_version; + + /* x1-x7 MBZ */ + memset(FFA_X1X7_MBZ_REG_START, 0, FFA_X1X7_MBZ_CNT * sizeof(unsigned long)); + + return 0; +} + +/** + * sandbox_ffa_id_get - Emulated FFA_ID_GET handler function + * @{a0-a7} , res: The SMC call arguments and return structure. + * + * This is the function that emulates FFA_ID_GET FF-A function. + * + * Return: + * + * 0 on success. Otherwise, failure + */ +SANDBOX_SMC_FFA_ABI(ffa_id_get) +{ + res->a0 = FFA_SMC_32(FFA_SUCCESS); + res->a1 = 0; + + sandbox_ffa_priv_data.id = NS_PHYS_ENDPOINT_ID; + res->a2 = sandbox_ffa_priv_data.id; + + /* x3-x7 MBZ */ + memset(FFA_X3_MBZ_REG_START, 0, FFA_X3X7_MBZ_CNT * sizeof(unsigned long)); + + return 0; +} + +/** + * sandbox_ffa_features - Emulated FFA_FEATURES handler function + * @{a0-a7} , res: The SMC call arguments and return structure. + * + * This is the function that emulates FFA_FEATURES FF-A function. + * + * Return: + * + * 0 on success. Otherwise, failure + */ +SANDBOX_SMC_FFA_ABI(ffa_features) +{ + if (pargs->a1 == FFA_SMC_64(FFA_RXTX_MAP)) { + res->a0 = FFA_SMC_32(FFA_SUCCESS); + res->a2 = RXTX_BUFFERS_MIN_SIZE; + res->a3 = 0; + /* x4-x7 MBZ */ + memset(FFA_X4X7_MBZ_REG_START, + 0, FFA_X4X7_MBZ_CNT * sizeof(unsigned long)); + } else { + res->a0 = FFA_SMC_32(FFA_ERROR); + res->a2 = FFA_ERR_STAT_NOT_SUPPORTED; + /* x3-x7 MBZ */ + memset(FFA_X3_MBZ_REG_START, + 0, FFA_X3X7_MBZ_CNT * sizeof(unsigned long)); + ffa_err("[Sandbox] FF-A interface 0x%lx not implemented", pargs->a1); + } + + res->a1 = 0; + + return 0; +} + +/** + * sandbox_ffa_partition_info_get - Emulated FFA_PARTITION_INFO_GET handler function + * @{a0-a7} , res: The SMC call arguments and return structure. + * + * This is the function that emulates FFA_PARTITION_INFO_GET FF-A function. + * + * Return: + * + * 0 on success. Otherwise, failure + */ +SANDBOX_SMC_FFA_ABI(ffa_partition_info_get) +{ + struct ffa_partition_info *rxbuf_desc_info = NULL; + u32 descs_cnt; + u32 descs_size_bytes; + + res->a0 = FFA_SMC_32(FFA_ERROR); + + if (!sandbox_ffa_priv_data.pair.rxbuf) { + res->a2 = FFA_ERR_STAT_DENIED; + goto cleanup; + } + + if (sandbox_ffa_priv_data.pair_info.rxbuf_owned) { + res->a2 = FFA_ERR_STAT_BUSY; + goto cleanup; + } + + if (!sandbox_ffa_priv_data.partitions.descs) { + sandbox_ffa_priv_data.partitions.descs = sandbox_partitions; + sandbox_ffa_priv_data.partitions.count = SANDBOX_PARTITIONS_CNT; + } + + descs_size_bytes = SANDBOX_PARTITIONS_CNT * sizeof(struct ffa_partition_desc); + + /* Abort if the RX buffer size is smaller than the descriptors buffer size */ + if ((sandbox_ffa_priv_data.pair_info.rxtx_buf_size * SZ_4K) < descs_size_bytes) { + res->a2 = FFA_ERR_STAT_NO_MEMORY; + goto cleanup; + } + + rxbuf_desc_info = (struct ffa_partition_info *)sandbox_ffa_priv_data.pair.rxbuf; + + /* No UUID specified. Return the information of all partitions */ + if (!pargs->a1 && !pargs->a2 && !pargs->a3 && !pargs->a4) { + for (descs_cnt = 0 ; descs_cnt < SANDBOX_PARTITIONS_CNT ; descs_cnt++) + *(rxbuf_desc_info++) = + sandbox_ffa_priv_data.partitions.descs[descs_cnt].info; + + res->a0 = FFA_SMC_32(FFA_SUCCESS); + res->a2 = SANDBOX_PARTITIONS_CNT; + /* transfer ownership to the consumer: the non secure world */ + sandbox_ffa_priv_data.pair_info.rxbuf_owned = 1; + + goto cleanup; + } + + /* + * A UUID is specified. Return the information of all partitions matching + * the UUID + */ + + for (descs_cnt = 0 ; descs_cnt < SANDBOX_PARTITIONS_CNT ; descs_cnt++) + if (pargs->a1 == sandbox_ffa_priv_data.partitions.descs[descs_cnt].sp_uuid.a1 && + pargs->a2 == sandbox_ffa_priv_data.partitions.descs[descs_cnt].sp_uuid.a2 && + pargs->a3 == sandbox_ffa_priv_data.partitions.descs[descs_cnt].sp_uuid.a3 && + pargs->a4 == sandbox_ffa_priv_data.partitions.descs[descs_cnt].sp_uuid.a4) { + *(rxbuf_desc_info++) = + sandbox_ffa_priv_data.partitions.descs[descs_cnt].info; + } + + if (rxbuf_desc_info != ((struct ffa_partition_info *)sandbox_ffa_priv_data.pair.rxbuf)) { + res->a0 = FFA_SMC_32(FFA_SUCCESS); + /* store the partitions count */ + res->a2 = (unsigned long) + (rxbuf_desc_info - (struct ffa_partition_info *) + sandbox_ffa_priv_data.pair.rxbuf); + + /* transfer ownership to the consumer: the non secure world */ + sandbox_ffa_priv_data.pair_info.rxbuf_owned = 1; + } else { + /* Unrecognized UUID */ + res->a2 = FFA_ERR_STAT_INVALID_PARAMETERS; + } + +cleanup: + + ffa_err("[Sandbox] FFA_PARTITION_INFO_GET (%ld)", res->a2); + + res->a1 = 0; + + /* x3-x7 MBZ */ + memset(FFA_X3_MBZ_REG_START, 0, FFA_X3X7_MBZ_CNT * sizeof(unsigned long)); + + return 0; +} + +/** + * sandbox_ffa_rxtx_map - Emulated FFA_RXTX_MAP handler function + * @{a0-a7} , res: The SMC call arguments and return structure. + * + * This is the function that emulates FFA_RXTX_MAP FF-A function. + * + * Return: + * + * 0 on success. Otherwise, failure + */ +SANDBOX_SMC_FFA_ABI(ffa_rxtx_map) +{ + res->a0 = FFA_SMC_32(FFA_ERROR); + + if (sandbox_ffa_priv_data.pair.txbuf && sandbox_ffa_priv_data.pair.rxbuf) { + res->a2 = FFA_ERR_STAT_DENIED; + goto feedback; + } + + if (pargs->a3 >= RXTX_BUFFERS_MIN_PAGES && pargs->a1 && pargs->a2) { + sandbox_ffa_priv_data.pair.txbuf = pargs->a1; + sandbox_ffa_priv_data.pair.rxbuf = pargs->a2; + sandbox_ffa_priv_data.pair_info.rxtx_buf_size = pargs->a3; + sandbox_ffa_priv_data.pair_info.rxbuf_mapped = 1; + res->a0 = FFA_SMC_32(FFA_SUCCESS); + res->a2 = 0; + goto feedback; + } + + if (!pargs->a1 || !pargs->a2) + res->a2 = FFA_ERR_STAT_INVALID_PARAMETERS; + else + res->a2 = FFA_ERR_STAT_NO_MEMORY; + + ffa_err("[Sandbox] error in FFA_RXTX_MAP arguments (%d)", (int)res->a2); + +feedback: + + res->a1 = 0; + + /* x3-x7 MBZ */ + memset(FFA_X3_MBZ_REG_START, + 0, FFA_X3X7_MBZ_CNT * sizeof(unsigned long)); + + return 0; +} + +/** + * sandbox_ffa_rxtx_unmap - Emulated FFA_RXTX_UNMAP handler function + * @{a0-a7} , res: The SMC call arguments and return structure. + * + * This is the function that emulates FFA_RXTX_UNMAP FF-A function. + * + * Return: + * + * 0 on success. Otherwise, failure + */ +SANDBOX_SMC_FFA_ABI(ffa_rxtx_unmap) +{ + res->a0 = FFA_SMC_32(FFA_ERROR); + res->a2 = FFA_ERR_STAT_INVALID_PARAMETERS; + + if (GET_NS_PHYS_ENDPOINT_ID(pargs->a1) != sandbox_ffa_priv_data.id) + goto feedback; + + if (sandbox_ffa_priv_data.pair.txbuf && sandbox_ffa_priv_data.pair.rxbuf) { + sandbox_ffa_priv_data.pair.txbuf = 0; + sandbox_ffa_priv_data.pair.rxbuf = 0; + sandbox_ffa_priv_data.pair_info.rxtx_buf_size = 0; + sandbox_ffa_priv_data.pair_info.rxbuf_mapped = 0; + res->a0 = FFA_SMC_32(FFA_SUCCESS); + res->a2 = 0; + goto feedback; + } + + ffa_err("[Sandbox] No buffer pair registered on behalf of the caller"); + +feedback: + + res->a1 = 0; + + /* x3-x7 MBZ */ + memset(FFA_X3_MBZ_REG_START, + 0, FFA_X3X7_MBZ_CNT * sizeof(unsigned long)); + + return 0; +} + +/** + * sandbox_ffa_rx_release - Emulated FFA_RX_RELEASE handler function + * @{a0-a7} , res: The SMC call arguments and return structure. + * + * This is the function that emulates FFA_RX_RELEASE FF-A function. + * + * Return: + * + * 0 on success. Otherwise, failure + */ +SANDBOX_SMC_FFA_ABI(ffa_rx_release) +{ + if (!sandbox_ffa_priv_data.pair_info.rxbuf_owned) { + res->a0 = FFA_SMC_32(FFA_ERROR); + res->a2 = FFA_ERR_STAT_DENIED; + } else { + sandbox_ffa_priv_data.pair_info.rxbuf_owned = 0; + res->a0 = FFA_SMC_32(FFA_SUCCESS); + res->a2 = 0; + } + + res->a1 = 0; + + /* x3-x7 MBZ */ + memset(FFA_X3_MBZ_REG_START, + 0, FFA_X3X7_MBZ_CNT * sizeof(unsigned long)); + + return 0; +} + +/** + * sandbox_ffa_sp_valid - Checks SP validity + * @part_id: partition ID to check + * + * This is the function searches the input ID in the descriptors table. + * + * Return: + * + * 1 on success (Partition found). Otherwise, failure + */ +static int sandbox_ffa_sp_valid(u16 part_id) +{ + u32 descs_cnt; + + for (descs_cnt = 0 ; descs_cnt < SANDBOX_PARTITIONS_CNT ; descs_cnt++) + if (sandbox_ffa_priv_data.partitions.descs[descs_cnt].info.id == part_id) + return 1; + + return 0; +} + +/** + * sandbox_ffa_msg_send_direct_req - Emulated FFA_MSG_SEND_DIRECT_{REQ,RESP} handler function + * @{a0-a7} , res: The SMC call arguments and return structure. + * + * This is the function that emulates FFA_MSG_SEND_DIRECT_{REQ,RESP} + * FF-A functions. + * + * Emulating interrupts is not supported. So, FFA_RUN and FFA_INTERRUPT are not supported. + * In case of success FFA_MSG_SEND_DIRECT_RESP is returned with default pattern data (0xff). + * + * Return: + * + * 0 on success. Otherwise, failure + */ +SANDBOX_SMC_FFA_ABI(ffa_msg_send_direct_req) +{ + u16 part_id; + + part_id = GET_DST_SP_ID(pargs->a1); + + if ((GET_NS_PHYS_ENDPOINT_ID(pargs->a1) != sandbox_ffa_priv_data.id) || + !sandbox_ffa_sp_valid(part_id) || + pargs->a2) { + res->a0 = FFA_SMC_32(FFA_ERROR); + res->a1 = 0; + res->a2 = FFA_ERR_STAT_INVALID_PARAMETERS; + + /* x3-x7 MBZ */ + memset(FFA_X3_MBZ_REG_START, + 0, FFA_X3X7_MBZ_CNT * sizeof(unsigned long)); + + return 0; + } + + res->a0 = FFA_SMC_64(FFA_MSG_SEND_DIRECT_RESP); + + res->a1 = PREP_SRC_SP_ID(part_id) | + PREP_NS_PHYS_ENDPOINT_ID(sandbox_ffa_priv_data.id); + + res->a2 = 0; + + /* + * return 0xff bytes as a response + */ + res->a3 = 0xffffffffffffffff; + res->a4 = 0xffffffffffffffff; + res->a5 = 0xffffffffffffffff; + res->a6 = 0xffffffffffffffff; + res->a7 = 0xffffffffffffffff; + + return 0; +} + +/** + * sandbox_ffa_get_prv_data - Returns the pointer to FF-A core pivate data + * @func_data: Pointer to the FF-A function arguments container structure + * + * This is the handler that returns the address of the FF-A core pivate data. + * + * Return: + * + * 0 on success. Otherwise, failure + */ +static int sandbox_ffa_get_prv_data(struct ffa_sandbox_data *func_data) +{ + if (!func_data) + return -EINVAL; + + if (!func_data->data0 || func_data->data0_size != sizeof(struct ffa_prvdata **)) + return -EINVAL; + + if (!func_data->data1 || func_data->data1_size != sizeof(struct sandbox_ffa_prvdata **)) + return -EINVAL; + + *((struct ffa_prvdata **)func_data->data0) = *(ffa_bus_prvdata_get()); + *((struct sandbox_ffa_prvdata **)func_data->data1) = &sandbox_ffa_priv_data; + + return 0; +} + +/** + * sandbox_ffa_get_rxbuf_flags - Reading the mapping/ownership flags + * @queried_func_id: The FF-A function to be queried + * @func_data: Pointer to the FF-A function arguments container structure + * + * This is the handler that queries the status flags of the following emulated ABIs: + * FFA_RXTX_MAP, FFA_RXTX_UNMAP, FFA_RX_RELEASE + * + * Return: + * + * 0 on success. Otherwise, failure + */ +static int sandbox_ffa_get_rxbuf_flags(u32 queried_func_id, struct ffa_sandbox_data *func_data) +{ + if (!func_data) + return -EINVAL; + + if (!func_data->data0 || func_data->data0_size != sizeof(u8)) + return -EINVAL; + + switch (queried_func_id) { + case FFA_RXTX_MAP: + case FFA_RXTX_UNMAP: + *((u8 *)func_data->data0) = sandbox_ffa_priv_data.pair_info.rxbuf_mapped; + return 0; + case FFA_RX_RELEASE: + *((u8 *)func_data->data0) = sandbox_ffa_priv_data.pair_info.rxbuf_owned; + return 0; + default: + ffa_err("[Sandbox] The querried FF-A interface flag (%d) undefined", + queried_func_id); + return -EINVAL; + } +} + +/** + * sandbox_ffa_query_core_state - The driver dispatcher function + * @queried_func_id: The FF-A function to be queried + * @func_data: Pointer to the FF-A function arguments container structure + * + * Queries the status of FF-A ABI specified in the input argument. + * + * Return: + * + * 0 on success. Otherwise, failure + */ +int sandbox_ffa_query_core_state(u32 queried_func_id, struct ffa_sandbox_data *func_data) +{ + switch (queried_func_id) { + case FFA_VERSION: + case FFA_ID_GET: + case FFA_FEATURES: + return sandbox_ffa_get_prv_data(func_data); + case FFA_RXTX_MAP: + case FFA_RXTX_UNMAP: + case FFA_RX_RELEASE: + return sandbox_ffa_get_rxbuf_flags(queried_func_id, func_data); + default: + ffa_err("[Sandbox] The querried FF-A interface (%d) undefined", queried_func_id); + return -EINVAL; + } +} + +/** + * sandbox_arm_ffa_smccc_smc - FF-A SMC call emulation + * @args: the SMC call arguments + * @res: the SMC call returned data + * + * Sandbox driver emulates the FF-A ABIs SMC call using this function. + * The emulated FF-A ABI is identified and invoked. + * FF-A emulation is based on the FF-A specification 1.0 + * + * Return: + * + * 0 on success. Otherwise, failure. + * FF-A protocol error codes are returned using the registers arguments as described + * by the specification + */ +void sandbox_arm_ffa_smccc_smc(ffa_value_t args, ffa_value_t *res) +{ + int ret = 0; + + switch (args.a0) { + case FFA_SMC_32(FFA_VERSION): + ret = sandbox_ffa_version(&args, res); + break; + case FFA_SMC_32(FFA_PARTITION_INFO_GET): + ret = sandbox_ffa_partition_info_get(&args, res); + break; + case FFA_SMC_32(FFA_RXTX_UNMAP): + ret = sandbox_ffa_rxtx_unmap(&args, res); + break; + case FFA_SMC_64(FFA_MSG_SEND_DIRECT_REQ): + ret = sandbox_ffa_msg_send_direct_req(&args, res); + break; + case FFA_SMC_32(FFA_ID_GET): + ret = sandbox_ffa_id_get(&args, res); + break; + case FFA_SMC_32(FFA_FEATURES): + ret = sandbox_ffa_features(&args, res); + break; + case FFA_SMC_64(FFA_RXTX_MAP): + ret = sandbox_ffa_rxtx_map(&args, res); + break; + case FFA_SMC_32(FFA_RX_RELEASE): + ret = sandbox_ffa_rx_release(&args, res); + break; + default: + ffa_err("[Sandbox] Undefined FF-A interface (0x%lx)", args.a0); + } + + if (ret != 0) + ffa_err("[Sandbox] FF-A ABI internal failure (%d)", ret); +} + +/** + * sandbox_ffa_probe - The driver probe function + * @dev: the sandbox_arm_ffa device + * + * Return: + * + * 0 on success. Otherwise, failure + */ +static int sandbox_ffa_probe(struct udevice *dev) +{ + return 0; +} + +/** + * sandbox_ffa_remove - The driver remove function + * @dev: the sandbox_arm_ffa device + * + * Return: + * + * 0 on success. Otherwise, failure + */ +static int sandbox_ffa_remove(struct udevice *dev) +{ + ffa_info("[Sandbox] removing the device"); + memset(&sandbox_ffa_priv_data, 0, sizeof(sandbox_ffa_priv_data)); + return 0; +} + +/** + * Declaring the sandbox_arm_ffa driver under UCLASS_FFA + */ +U_BOOT_DRIVER(sandbox_arm_ffa) = { + .name = FFA_SANDBOX_DRV_NAME, + .id = UCLASS_FFA, + .probe = sandbox_ffa_probe, + .remove = sandbox_ffa_remove, +}; diff --git a/drivers/firmware/arm-ffa/sandbox_arm_ffa_prv.h b/drivers/firmware/arm-ffa/sandbox_arm_ffa_prv.h new file mode 100644 index 0000000000..4db57f5092 --- /dev/null +++ b/drivers/firmware/arm-ffa/sandbox_arm_ffa_prv.h @@ -0,0 +1,144 @@ +/* SPDX-License-Identifier: GPL-2.0+ */ +/* + * (C) Copyright 2022 ARM Limited + * Abdellatif El Khlifi abdellatif.elkhlifi@arm.com + */ + +#ifndef __SANDBOX_ARM_FFA_PRV_H +#define __SANDBOX_ARM_FFA_PRV_H + +#include "arm_ffa_prv.h" +#include <sandbox_arm_ffa.h> + +/* + * This header is private. It is exclusively used by the Sandbox FF-A driver + */ + +/* FF-A core driver name */ +#define FFA_SANDBOX_DRV_NAME "sandbox_arm_ffa" + +/* FF-A ABIs internal error codes (as defined by the spec) */ + +#define FFA_ERR_STAT_NOT_SUPPORTED -1 +#define FFA_ERR_STAT_INVALID_PARAMETERS -2 +#define FFA_ERR_STAT_NO_MEMORY -3 +#define FFA_ERR_STAT_BUSY -4 +#define FFA_ERR_STAT_DENIED -6 + +/* Providing Arm SMCCC declarations to sandbox */ + +#define ARM_SMCCC_FAST_CALL 1UL +#define ARM_SMCCC_OWNER_STANDARD 4 +#define ARM_SMCCC_SMC_32 0 +#define ARM_SMCCC_SMC_64 1 +#define ARM_SMCCC_TYPE_SHIFT 31 +#define ARM_SMCCC_CALL_CONV_SHIFT 30 +#define ARM_SMCCC_OWNER_MASK 0x3F +#define ARM_SMCCC_OWNER_SHIFT 24 +#define ARM_SMCCC_FUNC_MASK 0xFFFF + +#define ARM_SMCCC_CALL_VAL(type, calling_convention, owner, func_num) \ + (((type) << ARM_SMCCC_TYPE_SHIFT) | \ + ((calling_convention) << ARM_SMCCC_CALL_CONV_SHIFT) | \ + (((owner) & ARM_SMCCC_OWNER_MASK) << ARM_SMCCC_OWNER_SHIFT) | \ + ((func_num) & ARM_SMCCC_FUNC_MASK)) + +/* Non-secure physical FF-A instance */ +#define NS_PHYS_ENDPOINT_ID (0) + +#define GET_NS_PHYS_ENDPOINT_ID_MASK GENMASK(31, 16) +#define GET_NS_PHYS_ENDPOINT_ID(x) \ + ((u16)(FIELD_GET(GET_NS_PHYS_ENDPOINT_ID_MASK, (x)))) + +/* Helper macro for reading the destination partition ID */ +#define GET_DST_SP_ID_MASK GENMASK(15, 0) +#define GET_DST_SP_ID(x) \ + ((u16)(FIELD_GET(GET_DST_SP_ID_MASK, (x)))) + +/* Helper macro for setting the source partition ID */ +#define PREP_SRC_SP_ID_MASK GENMASK(31, 16) +#define PREP_SRC_SP_ID(x) \ + (FIELD_PREP(PREP_SRC_SP_ID_MASK, (x))) + +/* Helper macro for setting the destination endpoint ID */ +#define PREP_NS_PHYS_ENDPOINT_ID_MASK GENMASK(15, 0) +#define PREP_NS_PHYS_ENDPOINT_ID(x) \ + (FIELD_PREP(PREP_NS_PHYS_ENDPOINT_ID_MASK, (x))) + +/* RX/TX buffers minimum size */ +#define RXTX_BUFFERS_MIN_SIZE (RXTX_4K) +#define RXTX_BUFFERS_MIN_PAGES (1) + +/* MBZ registers info */ + +/* x1-x7 MBZ */ +#define FFA_X1X7_MBZ_CNT (7) +#define FFA_X1X7_MBZ_REG_START (&res->a1) + +/* x4-x7 MBZ */ +#define FFA_X4X7_MBZ_CNT (4) +#define FFA_X4X7_MBZ_REG_START (&res->a4) + +/* x3-x7 MBZ */ +#define FFA_X3X7_MBZ_CNT (5) +#define FFA_X3_MBZ_REG_START (&res->a3) + +/* secure partitions count */ +#define SANDBOX_PARTITIONS_CNT (4) + +/* service 1 UUID binary data (little-endian format) */ +#define SANDBOX_SERVICE1_UUID_A1 0xed32d533 +#define SANDBOX_SERVICE1_UUID_A2 0x99e64209 +#define SANDBOX_SERVICE1_UUID_A3 0x9cc02d72 +#define SANDBOX_SERVICE1_UUID_A4 0xcdd998a7 + +/* service 2 UUID binary data (little-endian format) */ +#define SANDBOX_SERVICE2_UUID_A1 0xed32d544 +#define SANDBOX_SERVICE2_UUID_A2 0x99e64209 +#define SANDBOX_SERVICE2_UUID_A3 0x9cc02d72 +#define SANDBOX_SERVICE2_UUID_A4 0xcdd998a7 + +/** + * struct ffa_rxtxpair_info - structure hosting the RX/TX buffers flags + * @rxbuf_owned: RX buffer ownership flag (the owner is non secure world: the consumer) + * @rxbuf_mapped: RX buffer mapping flag + * @txbuf_owned TX buffer ownership flag + * @txbuf_mapped: TX buffer mapping flag + * @rxtx_buf_size: RX/TX buffers size as set by the FF-A core driver + * + * Data structure hosting the ownership/mapping flags of the RX/TX buffers + * When a buffer is owned/mapped its corresponding flag is set to 1 otherwise 0. + */ +struct ffa_rxtxpair_info { + u8 rxbuf_owned; + u8 rxbuf_mapped; + u8 txbuf_owned; + u8 txbuf_mapped; + u32 rxtx_buf_size; +}; + +/** + * struct sandbox_ffa_prvdata - the driver private data structure + * + * @dev: The arm_ffa device under u-boot driver model + * @fwk_version: FF-A framework version + * @id: u-boot endpoint ID + * @partitions: The partitions descriptors structure + * @pair: The RX/TX buffers pair + * @pair_info: The RX/TX buffers pair flags and size + * @conduit: The selected conduit + * + * The driver data structure hosting all the emulated secure world data. + */ +struct sandbox_ffa_prvdata { + struct udevice *dev; + u32 fwk_version; + u16 id; + struct ffa_partitions partitions; + struct ffa_rxtxpair pair; + struct ffa_rxtxpair_info pair_info; +}; + +#define SANDBOX_SMC_FFA_ABI(ffabi) static int sandbox_##ffabi(ffa_value_t *pargs, ffa_value_t *res) + +#endif diff --git a/include/arm_ffa.h b/include/arm_ffa.h index d146e7b328..6fa097d4ed 100644 --- a/include/arm_ffa.h +++ b/include/arm_ffa.h @@ -86,7 +86,7 @@ struct ffa_bus_ops { const struct ffa_bus_ops *ffa_bus_ops_get(void);
/** - * ffa_bus_discover - discover FF-A bus and probes the arm_ffa device + * ffa_bus_discover - discover FF-A bus and probes the arm_ffa and sandbox_arm_ffa devices */ int ffa_bus_discover(void);
diff --git a/include/sandbox_arm_ffa.h b/include/sandbox_arm_ffa.h new file mode 100644 index 0000000000..d5df16f282 --- /dev/null +++ b/include/sandbox_arm_ffa.h @@ -0,0 +1,91 @@ +/* SPDX-License-Identifier: GPL-2.0+ */ +/* + * (C) Copyright 2022 ARM Limited + * Abdellatif El Khlifi abdellatif.elkhlifi@arm.com + */ + +#ifndef __SANDBOX_ARM_FFA_H +#define __SANDBOX_ARM_FFA_H + +#include <arm_ffa.h> + +/** + * struct sandbox_smccc_1_2_regs - Arguments for or Results from emulated SMC call + * @a0-a17 argument values from registers 0 to 17 + */ +struct sandbox_smccc_1_2_regs { + unsigned long a0; + unsigned long a1; + unsigned long a2; + unsigned long a3; + unsigned long a4; + unsigned long a5; + unsigned long a6; + unsigned long a7; + unsigned long a8; + unsigned long a9; + unsigned long a10; + unsigned long a11; + unsigned long a12; + unsigned long a13; + unsigned long a14; + unsigned long a15; + unsigned long a16; + unsigned long a17; +}; + +typedef struct sandbox_smccc_1_2_regs ffa_value_t; + +/* UUIDs of services supported by the sandbox driver */ +#define SANDBOX_SERVICE1_UUID "ed32d533-4209-99e6-2d72-cdd998a79cc0" +#define SANDBOX_SERVICE2_UUID "ed32d544-4209-99e6-2d72-cdd998a79cc0" +#define SANDBOX_SP1_ID 0x1245 +#define SANDBOX_SP2_ID 0x9836 +#define SANDBOX_SP3_ID 0x6452 +#define SANDBOX_SP4_ID 0x7814 + +/* invalid service UUID (no matching SP) */ +#define SANDBOX_SERVICE3_UUID "55d532ed-0942-e699-722d-c09ca798d9cd" + +/* invalid service UUID (invalid UUID string format) */ +#define SANDBOX_SERVICE4_UUID "32ed-0942-e699-722d-c09ca798d9cd" + +#define SANDBOX_SP_COUNT_PER_VALID_SERVICE 2 + +/** + * struct ffa_sandbox_data - generic data structure used to exchange + * data between test cases and the sandbox driver + * @data0_size: size of the first argument + * @data0: pointer to the first argument + * @data1_size>: size of the second argument + * @data1: pointer to the second argument + * + * Using this structure sandbox test cases can pass various types of data with different sizes. + */ +struct ffa_sandbox_data { + u32 data0_size; /* size of the first argument */ + void *data0; /* pointer to the first argument */ + u32 data1_size; /* size of the second argument */ + void *data1; /* pointer to the second argument */ +}; + +/** + * The sandbox driver public functions + */ + +/** + * sandbox_ffa_query_core_state - Queries the status of FF-A ABIs + */ +int sandbox_ffa_query_core_state(u32 queried_func_id, struct ffa_sandbox_data *func_data); + +/** + * sandbox_ffa_get_device - create, bind and probe the sandbox_arm_ffa device + */ +int sandbox_ffa_device_get(void); + +/** + * sandbox_arm_ffa_smccc_smc - FF-A SMC call emulation + */ +void sandbox_arm_ffa_smccc_smc(ffa_value_t args, ffa_value_t *res); + +#endif diff --git a/lib/efi_loader/efi_boottime.c b/lib/efi_loader/efi_boottime.c index 2054b33568..bea7ad7608 100644 --- a/lib/efi_loader/efi_boottime.c +++ b/lib/efi_loader/efi_boottime.c @@ -2185,7 +2185,7 @@ static efi_status_t EFIAPI efi_exit_boot_services(efi_handle_t image_handle, dm_remove_devices_flags(DM_REMOVE_ACTIVE_ALL); }
-#if CONFIG_IS_ENABLED(ARM_FFA_TRANSPORT) +#if CONFIG_IS_ENABLED(ARM_FFA_TRANSPORT) && !CONFIG_IS_ENABLED(SANDBOX_FFA) /* unmap FF-A RX/TX buffers */ if (ffa_bus_ops_get()->rxtx_unmap()) debug("[efi_boottime][ERROR]: can not unmap FF-A RX/TX buffers\n");
Add functional test cases for the FF-A core driver
These tests rely on the FF-A Sandbox driver which helps in inspecting the FF-A core driver.
v4: align sandbox tests with the new FF-A driver interfaces and new way of error handling
v1: introduce sandbox tests
MAINTAINERS | 1 + test/dm/Makefile | 2 + test/dm/ffa.c | 394 +++++++++++++++++++++++++++++++++++++++++++++++ 3 files changed, 397 insertions(+) create mode 100644 test/dm/ffa.c
diff --git a/MAINTAINERS b/MAINTAINERS index 598ae76e16..bf198f4ce1 100644 --- a/MAINTAINERS +++ b/MAINTAINERS @@ -256,6 +256,7 @@ F: doc/arch/arm64.ffa.rst F: drivers/firmware/arm-ffa/ F: include/arm_ffa.h F: include/sandbox_arm_ffa.h +F: test/dm/ffa.c
ARM FREESCALE IMX M: Stefano Babic sbabic@denx.de diff --git a/test/dm/Makefile b/test/dm/Makefile index 5178daa7cf..e5bc4b4bd6 100644 --- a/test/dm/Makefile +++ b/test/dm/Makefile @@ -1,6 +1,7 @@ # SPDX-License-Identifier: GPL-2.0+ # # Copyright (c) 2013 Google, Inc +# (C) Copyright 2022 ARM Limited
obj-$(CONFIG_UT_DM) += test-dm.o
@@ -81,6 +82,7 @@ obj-$(CONFIG_POWER_DOMAIN) += power-domain.o obj-$(CONFIG_ACPI_PMC) += pmc.o obj-$(CONFIG_DM_PMIC) += pmic.o obj-$(CONFIG_DM_PWM) += pwm.o +obj-$(CONFIG_SANDBOX_FFA) += ffa.o obj-$(CONFIG_QFW) += qfw.o obj-$(CONFIG_RAM) += ram.o obj-y += regmap.o diff --git a/test/dm/ffa.c b/test/dm/ffa.c new file mode 100644 index 0000000000..052d5fc3f4 --- /dev/null +++ b/test/dm/ffa.c @@ -0,0 +1,394 @@ +// SPDX-License-Identifier: GPL-2.0+ +/* + * Functional tests for UCLASS_FFA class + * + * (C) Copyright 2022 ARM Limited + * Abdellatif El Khlifi abdellatif.elkhlifi@arm.com + */ + +#include <common.h> +#include <console.h> +#include <dm.h> +#include <dm/test.h> +#include "../../drivers/firmware/arm-ffa/sandbox_arm_ffa_prv.h" +#include <sandbox_arm_ffa.h> +#include <test/test.h> +#include <test/ut.h> + +/* Macros */ + +#define LOG_MSG_SZ (100) +#define LOG_CMD_SZ (LOG_MSG_SZ * 2) + +/* Functional tests for the UCLASS_FFA */ + +static int dm_test_ffa_log(struct unit_test_state *uts, char *msg) +{ + char cmd[LOG_CMD_SZ] = {0}; + + console_record_reset(); + + snprintf(cmd, LOG_CMD_SZ, "echo "%s"", msg); + run_command(cmd, 0); + + ut_assert_console_end(); + + return CMD_RET_SUCCESS; +} + +static int check_fwk_version(struct ffa_prvdata *prvdata, struct sandbox_ffa_prvdata *sdx_prvdata, + struct unit_test_state *uts) +{ + if (prvdata->fwk_version != sdx_prvdata->fwk_version) { + char msg[LOG_MSG_SZ] = {0}; + + snprintf(msg, LOG_MSG_SZ, + "[%s]: Error: framework version: core = 0x%x , sandbox = 0x%x", __func__, + prvdata->fwk_version, + sdx_prvdata->fwk_version); + + dm_test_ffa_log(uts, msg); + return CMD_RET_FAILURE; + } + return CMD_RET_SUCCESS; +} + +static int check_endpoint_id(struct ffa_prvdata *prvdata, struct unit_test_state *uts) +{ + if (prvdata->id) { + char msg[LOG_MSG_SZ] = {0}; + + snprintf(msg, LOG_MSG_SZ, + "[%s]: Error: endpoint id: core = 0x%x", __func__, prvdata->id); + dm_test_ffa_log(uts, msg); + return CMD_RET_FAILURE; + } + return CMD_RET_SUCCESS; +} + +static int check_core_dev(struct ffa_prvdata *prvdata, struct unit_test_state *uts) +{ + if (!prvdata->dev) { + char msg[LOG_MSG_SZ] = {0}; + + snprintf(msg, LOG_MSG_SZ, "[%s]: Error: core device NULL", __func__); + dm_test_ffa_log(uts, msg); + return CMD_RET_FAILURE; + } + return CMD_RET_SUCCESS; +} + +static int check_sandbox_dev(struct sandbox_ffa_prvdata *sdx_prvdata, struct unit_test_state *uts) +{ + if (!sdx_prvdata->dev) { + char msg[LOG_MSG_SZ] = {0}; + + snprintf(msg, LOG_MSG_SZ, "[%s]: Error: sandbox device NULL", __func__); + dm_test_ffa_log(uts, msg); + return CMD_RET_FAILURE; + } + return CMD_RET_SUCCESS; +} + +static int check_rxtxbuf(struct ffa_prvdata *prvdata, struct unit_test_state *uts) +{ + if (!prvdata->pair.rxbuf && prvdata->pair.txbuf) { + char msg[LOG_MSG_SZ] = {0}; + + snprintf(msg, LOG_MSG_SZ, "[%s]: Error: rxbuf = 0x%llx txbuf = 0x%llx", __func__, + prvdata->pair.rxbuf, + prvdata->pair.txbuf); + dm_test_ffa_log(uts, msg); + return CMD_RET_FAILURE; + } + return CMD_RET_SUCCESS; +} + +static int check_features(struct ffa_prvdata *prvdata, struct unit_test_state *uts) +{ + char msg[LOG_MSG_SZ] = {0}; + + if (prvdata->pair.rxtx_min_pages != RXTX_4K && + prvdata->pair.rxtx_min_pages != RXTX_16K && + prvdata->pair.rxtx_min_pages != RXTX_64K) { + snprintf(msg, + LOG_MSG_SZ, + "[%s]: Error: FFA_RXTX_MAP features = 0x%lx", + __func__, + prvdata->pair.rxtx_min_pages); + dm_test_ffa_log(uts, msg); + return CMD_RET_FAILURE; + } + + return CMD_RET_SUCCESS; +} + +static int check_rxbuf_mapped_flag(u32 queried_func_id, + u8 rxbuf_mapped, + struct unit_test_state *uts) +{ + char msg[LOG_MSG_SZ] = {0}; + + switch (queried_func_id) { + case FFA_RXTX_MAP: + { + if (rxbuf_mapped) + return CMD_RET_SUCCESS; + break; + } + case FFA_RXTX_UNMAP: + { + if (!rxbuf_mapped) + return CMD_RET_SUCCESS; + break; + } + default: + return CMD_RET_FAILURE; + } + + snprintf(msg, LOG_MSG_SZ, "[%s]: Error: %s mapping issue", __func__, + (queried_func_id == FFA_RXTX_MAP ? "FFA_RXTX_MAP" : "FFA_RXTX_UNMAP")); + dm_test_ffa_log(uts, msg); + + return CMD_RET_FAILURE; +} + +static int check_rxbuf_release_flag(u8 rxbuf_owned, struct unit_test_state *uts) +{ + if (rxbuf_owned) { + char msg[LOG_MSG_SZ] = {0}; + + snprintf(msg, LOG_MSG_SZ, "[%s]: Error: RX buffer not released", __func__); + dm_test_ffa_log(uts, msg); + return CMD_RET_FAILURE; + } + return CMD_RET_SUCCESS; +} + +static int test_ffa_msg_send_direct_req(u16 part_id, struct unit_test_state *uts) +{ + struct ffa_send_direct_data msg = {0}; + u8 cnt; + + ut_assertok(ffa_bus_ops_get()->sync_send_receive(part_id, &msg)); + + for (cnt = 0; cnt < sizeof(struct ffa_send_direct_data) / sizeof(u64); cnt++) + ut_assertok(((u64 *)&msg)[cnt] != 0xffffffffffffffff); + + return CMD_RET_SUCCESS; +} + +static int test_partitions_and_comms(const char *service_uuid, + struct sandbox_ffa_prvdata *sdx_prvdata, + struct unit_test_state *uts) +{ + u32 count = 0, size = 0; + struct ffa_partition_info *parts_info; + u32 info_idx, exp_info_idx; + int ret; + + /* + * get from the driver the count of the SPs matching the UUID + */ + ret = ffa_bus_ops_get()->partition_info_get(service_uuid, &count, NULL); + /* make sure partitions are detected */ + ut_assertok(ret != 0); + ut_assertok(count != SANDBOX_SP_COUNT_PER_VALID_SERVICE); + + /* + * pre-allocate a buffer to be filled by the driver + * with ffa_partition_info structs + */ + + parts_info = calloc(count, sizeof(struct ffa_partition_info)); + ut_assertok(!parts_info); + + size = count * sizeof(struct ffa_partition_info); + + /* + * ask the driver to fill the buffer with the SPs info + */ + ret = ffa_bus_ops_get()->partition_info_get(service_uuid, &size, parts_info); + if (ret != 0) { + free(parts_info); + ut_assertok(ret != 0); + } + + /* + * SPs found , verify the partitions information + */ + + ret = CMD_RET_FAILURE; + + for (info_idx = 0; info_idx < count ; info_idx++) { + for (exp_info_idx = 0; + exp_info_idx < sdx_prvdata->partitions.count; + exp_info_idx++) { + if (parts_info[info_idx].id == + sdx_prvdata->partitions.descs[exp_info_idx].info.id) { + ret = memcmp(&parts_info[info_idx], + &sdx_prvdata->partitions.descs[exp_info_idx] + .info, + sizeof(struct ffa_partition_info)); + if (ret) + free(parts_info); + ut_assertok(ret != 0); + /* send and receive data from the current partition */ + test_ffa_msg_send_direct_req(parts_info[info_idx].id, uts); + } + ret = CMD_RET_SUCCESS; + } + } + + free(parts_info); + + /* Verify expected partitions found in the emulated secure world*/ + ut_assertok(ret != CMD_RET_SUCCESS); + + return CMD_RET_SUCCESS; +} + +static int dm_test_ffa_ack(struct unit_test_state *uts) +{ + struct ffa_prvdata *prvdata = NULL; + struct sandbox_ffa_prvdata *sdx_prvdata = NULL; + struct ffa_sandbox_data func_data = {0}; + u8 rxbuf_flag = 0; + const char *svc1_uuid = SANDBOX_SERVICE1_UUID; + const char *svc2_uuid = SANDBOX_SERVICE2_UUID; + int ret; + + /* test probing FF-A devices */ + ut_assertok(ffa_bus_discover()); + + /* get a pointer to the FF-A core and sandbox drivers private data */ + func_data.data0 = &prvdata; + func_data.data0_size = sizeof(prvdata); + func_data.data1 = &sdx_prvdata; + func_data.data1_size = sizeof(sdx_prvdata); + + ut_assertok(sandbox_ffa_query_core_state(FFA_VERSION, &func_data)); + + /* make sure private data pointers are retrieved */ + ut_assertok(prvdata == 0); + ut_assertok(sdx_prvdata == 0); + + /* make sure dev devices created */ + ut_assertok(check_core_dev(prvdata, uts)); + ut_assertok(check_sandbox_dev(sdx_prvdata, uts)); + + /* test FFA_VERSION */ + ut_assertok(check_fwk_version(prvdata, sdx_prvdata, uts)); + + /* test FFA_ID_GET */ + ut_assertok(check_endpoint_id(prvdata, uts)); + + /* test FFA_FEATURES */ + ut_assertok(check_features(prvdata, uts)); + + /* test core RX/TX buffers */ + ut_assertok(check_rxtxbuf(prvdata, uts)); + + /* test FFA_RXTX_MAP */ + func_data.data0 = &rxbuf_flag; + func_data.data0_size = sizeof(rxbuf_flag); + + rxbuf_flag = 0; + ut_assertok(sandbox_ffa_query_core_state(FFA_RXTX_MAP, &func_data)); + ut_assertok(check_rxbuf_mapped_flag(FFA_RXTX_MAP, rxbuf_flag, uts)); + + /* FFA_PARTITION_INFO_GET / FFA_MSG_SEND_DIRECT_REQ */ + ret = test_partitions_and_comms(svc1_uuid, sdx_prvdata, uts); + ut_assertok(ret != CMD_RET_SUCCESS); + + /* test FFA_RX_RELEASE */ + rxbuf_flag = 1; + ut_assertok(sandbox_ffa_query_core_state(FFA_RX_RELEASE, &func_data)); + ut_assertok(check_rxbuf_release_flag(rxbuf_flag, uts)); + + /* FFA_PARTITION_INFO_GET / FFA_MSG_SEND_DIRECT_REQ */ + ret = test_partitions_and_comms(svc2_uuid, sdx_prvdata, uts); + ut_assertok(ret != CMD_RET_SUCCESS); + + /* test FFA_RX_RELEASE */ + rxbuf_flag = 1; + ut_assertok(sandbox_ffa_query_core_state(FFA_RX_RELEASE, &func_data)); + ut_assertok(check_rxbuf_release_flag(rxbuf_flag, uts)); + + /* test FFA_RXTX_UNMAP */ + ut_assertok(ffa_bus_ops_get()->rxtx_unmap()); + + rxbuf_flag = 1; + ut_assertok(sandbox_ffa_query_core_state(FFA_RXTX_UNMAP, &func_data)); + ut_assertok(check_rxbuf_mapped_flag(FFA_RXTX_UNMAP, rxbuf_flag, uts)); + + return CMD_RET_SUCCESS; +} + +DM_TEST(dm_test_ffa_ack, UT_TESTF_SCAN_FDT | UT_TESTF_CONSOLE_REC); + +static int dm_test_ffa_nack(struct unit_test_state *uts) +{ + struct ffa_prvdata *prvdata = NULL; + struct sandbox_ffa_prvdata *sdx_prvdata = NULL; + struct ffa_sandbox_data func_data = {0}; + const char *valid_svc_uuid = SANDBOX_SERVICE1_UUID; + const char *unvalid_svc_uuid = SANDBOX_SERVICE3_UUID; + const char *unvalid_svc_uuid_str = SANDBOX_SERVICE4_UUID; + struct ffa_send_direct_data msg = {0}; + int ret; + u32 count = 0; + u16 part_id = 0; + + /* test probing FF-A devices */ + ut_assertok(ffa_bus_discover()); + + /* get a pointer to the FF-A core and sandbox drivers private data */ + func_data.data0 = &prvdata; + func_data.data0_size = sizeof(prvdata); + func_data.data1 = &sdx_prvdata; + func_data.data1_size = sizeof(sdx_prvdata); + + ut_assertok(sandbox_ffa_query_core_state(FFA_VERSION, &func_data)); + + /* make sure private data pointers are retrieved */ + ut_assertok(prvdata == 0); + ut_assertok(sdx_prvdata == 0); + + /* make sure dev devices created */ + ut_assertok(check_core_dev(prvdata, uts)); + ut_assertok(check_sandbox_dev(sdx_prvdata, uts)); + + /* query partitions count using invalid arguments */ + ret = ffa_bus_ops_get()->partition_info_get(unvalid_svc_uuid, NULL, NULL); + ut_assertok(ret != -EINVAL); + + /* query partitions count using an invalid UUID string */ + ret = ffa_bus_ops_get()->partition_info_get(unvalid_svc_uuid_str, &count, NULL); + ut_assertok(ret != -EINVAL); + + /* query partitions count using an invalid UUID (no matching SP) */ + count = 0; + ret = ffa_bus_ops_get()->partition_info_get(unvalid_svc_uuid, &count, NULL); + ut_assertok(count != 0); + + /* query partitions count using a valid UUID */ + count = 0; + ret = ffa_bus_ops_get()->partition_info_get(valid_svc_uuid, &count, NULL); + /* make sure partitions are detected */ + ut_assertok(ret != 0); + ut_assertok(count != SANDBOX_SP_COUNT_PER_VALID_SERVICE); + + /* send data to an invalid partition */ + ret = ffa_bus_ops_get()->sync_send_receive(part_id, &msg); + ut_assertok(ret != -EINVAL); + + /* send data to a valid partition */ + part_id = prvdata->partitions.descs[0].info.id; + ret = ffa_bus_ops_get()->sync_send_receive(part_id, &msg); + ut_assertok(ret != 0); + + return CMD_RET_SUCCESS; +} + +DM_TEST(dm_test_ffa_nack, UT_TESTF_SCAN_FDT | UT_TESTF_CONSOLE_REC);
Hi Abdellatif On Thu, Oct 13, 2022 at 11:38:54AM +0100, Abdellatif El Khlifi wrote:
This looks ok from me, but I'd prefer Simon having a quick look, since I am not an expert when it comes to sandbox and testing
Thanks /Ilias
Changelog:
- Functional tests for UCLASS_FFA class
- (C) Copyright 2022 ARM Limited
- Abdellatif El Khlifi abdellatif.elkhlifi@arm.com
+/* Macros */
- char cmd[LOG_CMD_SZ] = {0};
- console_record_reset();
- snprintf(cmd, LOG_CMD_SZ, "echo "%s"", msg);
- run_command(cmd, 0);
- ut_assert_console_end();
- return CMD_RET_SUCCESS;
- if (prvdata->fwk_version != sdx_prvdata->fwk_version) {
- if (prvdata->id) {
- if (!prvdata->dev) {
- if (!sdx_prvdata->dev) {
- if (!prvdata->pair.rxbuf && prvdata->pair.txbuf) {
- char msg[LOG_MSG_SZ] = {0};
- if (prvdata->pair.rxtx_min_pages != RXTX_4K &&
snprintf(msg,
LOG_MSG_SZ,
__func__,
u8 rxbuf_mapped,
- switch (queried_func_id) {
- case FFA_RXTX_MAP:
if (rxbuf_mapped)
break;
- case FFA_RXTX_UNMAP:
if (!rxbuf_mapped)
break;
- default:
- snprintf(msg, LOG_MSG_SZ, "[%s]: Error: %s mapping issue", __func__,
- dm_test_ffa_log(uts, msg);
- return CMD_RET_FAILURE;
- if (rxbuf_owned) {
- struct ffa_send_direct_data msg = {0};
- u8 cnt;
- ut_assertok(ffa_bus_ops_get()->sync_send_receive(part_id, &msg));
- for (cnt = 0; cnt < sizeof(struct ffa_send_direct_data) / sizeof(u64); cnt++)
- u32 count = 0, size = 0;
- struct ffa_partition_info *parts_info;
- u32 info_idx, exp_info_idx;
- int ret;
- ret = ffa_bus_ops_get()->partition_info_get(service_uuid, &count, NULL);
- /* make sure partitions are detected */
- ut_assertok(ret != 0);
- ut_assertok(count != SANDBOX_SP_COUNT_PER_VALID_SERVICE);
- parts_info = calloc(count, sizeof(struct ffa_partition_info));
- ut_assertok(!parts_info);
- size = count * sizeof(struct ffa_partition_info);
- ret = ffa_bus_ops_get()->partition_info_get(service_uuid, &size, parts_info);
- if (ret != 0) {
free(parts_info);
- ret = CMD_RET_FAILURE;
- for (info_idx = 0; info_idx < count ; info_idx++) {
exp_info_idx++) {
.info,
if (ret)
free(parts_info);
- free(parts_info);
- /* Verify expected partitions found in the emulated secure world*/
- ut_assertok(ret != CMD_RET_SUCCESS);
- struct ffa_prvdata *prvdata = NULL;
- struct sandbox_ffa_prvdata *sdx_prvdata = NULL;
- struct ffa_sandbox_data func_data = {0};
- u8 rxbuf_flag = 0;
- const char *svc1_uuid = SANDBOX_SERVICE1_UUID;
- const char *svc2_uuid = SANDBOX_SERVICE2_UUID;
- int ret;
- /* test probing FF-A devices */
- ut_assertok(ffa_bus_discover());
- /* get a pointer to the FF-A core and sandbox drivers private data */
- func_data.data0 = &prvdata;
- func_data.data0_size = sizeof(prvdata);
- func_data.data1 = &sdx_prvdata;
- func_data.data1_size = sizeof(sdx_prvdata);
- ut_assertok(sandbox_ffa_query_core_state(FFA_VERSION, &func_data));
- /* make sure private data pointers are retrieved */
- ut_assertok(prvdata == 0);
- ut_assertok(sdx_prvdata == 0);
- /* make sure dev devices created */
- ut_assertok(check_core_dev(prvdata, uts));
- ut_assertok(check_sandbox_dev(sdx_prvdata, uts));
- /* test FFA_VERSION */
- ut_assertok(check_fwk_version(prvdata, sdx_prvdata, uts));
- /* test FFA_ID_GET */
- ut_assertok(check_endpoint_id(prvdata, uts));
- /* test FFA_FEATURES */
- ut_assertok(check_features(prvdata, uts));
- /* test core RX/TX buffers */
- ut_assertok(check_rxtxbuf(prvdata, uts));
- /* test FFA_RXTX_MAP */
- func_data.data0 = &rxbuf_flag;
- func_data.data0_size = sizeof(rxbuf_flag);
- rxbuf_flag = 0;
- ut_assertok(sandbox_ffa_query_core_state(FFA_RXTX_MAP, &func_data));
- ut_assertok(check_rxbuf_mapped_flag(FFA_RXTX_MAP, rxbuf_flag, uts));
- /* FFA_PARTITION_INFO_GET / FFA_MSG_SEND_DIRECT_REQ */
- ret = test_partitions_and_comms(svc1_uuid, sdx_prvdata, uts);
- /* test FFA_RX_RELEASE */
- rxbuf_flag = 1;
- ut_assertok(sandbox_ffa_query_core_state(FFA_RX_RELEASE, &func_data));
- ut_assertok(check_rxbuf_release_flag(rxbuf_flag, uts));
- ret = test_partitions_and_comms(svc2_uuid, sdx_prvdata, uts);
- rxbuf_flag = 1;
- /* test FFA_RXTX_UNMAP */
- ut_assertok(ffa_bus_ops_get()->rxtx_unmap());
- rxbuf_flag = 1;
- ut_assertok(sandbox_ffa_query_core_state(FFA_RXTX_UNMAP, &func_data));
- ut_assertok(check_rxbuf_mapped_flag(FFA_RXTX_UNMAP, rxbuf_flag, uts));
- const char *valid_svc_uuid = SANDBOX_SERVICE1_UUID;
- const char *unvalid_svc_uuid = SANDBOX_SERVICE3_UUID;
- const char *unvalid_svc_uuid_str = SANDBOX_SERVICE4_UUID;
- int ret;
- u32 count = 0;
- u16 part_id = 0;
- /* query partitions count using invalid arguments */
- ret = ffa_bus_ops_get()->partition_info_get(unvalid_svc_uuid, NULL, NULL);
- ut_assertok(ret != -EINVAL);
- /* query partitions count using an invalid UUID string */
- ret = ffa_bus_ops_get()->partition_info_get(unvalid_svc_uuid_str, &count, NULL);
- /* query partitions count using an invalid UUID (no matching SP) */
- count = 0;
- ret = ffa_bus_ops_get()->partition_info_get(unvalid_svc_uuid, &count, NULL);
- ut_assertok(count != 0);
- /* query partitions count using a valid UUID */
- count = 0;
- ret = ffa_bus_ops_get()->partition_info_get(valid_svc_uuid, &count, NULL);
- /* send data to an invalid partition */
- ret = ffa_bus_ops_get()->sync_send_receive(part_id, &msg);
- /* send data to a valid partition */
- part_id = prvdata->partitions.descs[0].info.id;
2.17.1
Thanks for the feedback Ilias.
Simon, could you please provide a feedback about the Sandbox part ?
Thanks /Ilias
Signed-off-by: Abdellatif El Khlifi abdellatif.elkhlifi@arm.com Cc: Tom Rini trini@konsulko.com Cc: Simon Glass sjg@chromium.org Cc: Ilias Apalodimas ilias.apalodimas@linaro.org Cc: Jens Wiklander jens.wiklander@linaro.org
Changelog:
+/* Macros */
snprintf(msg,
LOG_MSG_SZ,
__func__,
u8 rxbuf_mapped,
if (rxbuf_mapped)
break;
if (!rxbuf_mapped)
break;
- default:
- u8 cnt;
- int ret;
- if (ret != 0) {
free(parts_info);
exp_info_idx++) {
.info,
if (ret)
free(parts_info);
- free(parts_info);
- int ret;
- rxbuf_flag = 0;
- rxbuf_flag = 1;
- rxbuf_flag = 1;
- rxbuf_flag = 1;
- int ret;
- u32 count = 0;
- u16 part_id = 0;
- count = 0;
- count = 0;
2.17.1
Add Sandbox test for the armffa command
v4: drop use of helper APIs
v1: introduce armffa command sandbox test
MAINTAINERS | 1 + test/cmd/Makefile | 2 ++ test/cmd/armffa.c | 40 ++++++++++++++++++++++++++++++++++++++++ 3 files changed, 43 insertions(+) create mode 100644 test/cmd/armffa.c
diff --git a/MAINTAINERS b/MAINTAINERS index bf198f4ce1..9a90826954 100644 --- a/MAINTAINERS +++ b/MAINTAINERS @@ -256,6 +256,7 @@ F: doc/arch/arm64.ffa.rst F: drivers/firmware/arm-ffa/ F: include/arm_ffa.h F: include/sandbox_arm_ffa.h +F: test/cmd/armffa.c F: test/dm/ffa.c
ARM FREESCALE IMX diff --git a/test/cmd/Makefile b/test/cmd/Makefile index 1bb02d93a2..9a04ea7b9b 100644 --- a/test/cmd/Makefile +++ b/test/cmd/Makefile @@ -1,6 +1,7 @@ # SPDX-License-Identifier: GPL-2.0+ # # Copyright (c) 2013 Google, Inc +# (C) Copyright 2022 ARM Limited
ifdef CONFIG_HUSH_PARSER obj-$(CONFIG_CONSOLE_RECORD) += test_echo.o @@ -16,3 +17,4 @@ obj-$(CONFIG_CMD_MEM_SEARCH) += mem_search.o obj-$(CONFIG_CMD_PINMUX) += pinmux.o obj-$(CONFIG_CMD_PWM) += pwm.o obj-$(CONFIG_CMD_SETEXPR) += setexpr.o +obj-$(CONFIG_SANDBOX_FFA) += armffa.o diff --git a/test/cmd/armffa.c b/test/cmd/armffa.c new file mode 100644 index 0000000000..531f82066e --- /dev/null +++ b/test/cmd/armffa.c @@ -0,0 +1,40 @@ +// SPDX-License-Identifier: GPL-2.0+ +/* + * Test for armffa command + * + * (C) Copyright 2022 ARM Limited + * Abdellatif El Khlifi abdellatif.elkhlifi@arm.com + */ + +#include <common.h> +#include <dm.h> +#include <dm/test.h> +#include <sandbox_arm_ffa.h> +#include <string.h> +#include <test/test.h> +#include <test/ut.h> + +#define PING_CMD_SIZE 19 + +/* Basic test of 'armffa' command */ +static int dm_test_armffa_cmd(struct unit_test_state *uts) +{ + char ping_cmd[PING_CMD_SIZE] = {0}; + + ut_assertok(ffa_bus_discover()); + + /* armffa getpart <UUID> */ + ut_assertok(run_command("armffa getpart " SANDBOX_SERVICE1_UUID, 0)); + + snprintf(ping_cmd, PING_CMD_SIZE, "armffa ping 0x%x", SANDBOX_SP1_ID); + + /* armffa ping <ID> */ + ut_assertok(run_command(ping_cmd, 0)); + + /* armffa devlist */ + ut_assertok(run_command("armffa devlist", 0)); + + return CMD_RET_SUCCESS; +} + +DM_TEST(dm_test_armffa_cmd, UT_TESTF_SCAN_FDT | UT_TESTF_CONSOLE_REC);
Add MM communication support using FF-A transport
This feature allows accessing MM partitions services through EFI MM communication protocol. MM partitions such as StandAlonneMM or smm-gateway secure partitions which reside in secure world.
An MM shared buffer and a door bell event are used to exchange the data.
The data is used by EFI services such as GetVariable()/SetVariable() and copied from the communication buffer to the MM shared buffer.
The secure partition is notified about availability of data in the MM shared buffer by an FF-A message (door bell).
On such event, MM SP can read the data and updates the MM shared buffer with the response data.
The response data is copied back to the communication buffer and consumed by the EFI subsystem.
Signed-off-by: Abdellatif El Khlifi abdellatif.elkhlifi@arm.com Signed-off-by: Gowtham Suresh Kumar gowtham.sureshkumar@arm.com Cc: Tom Rini trini@konsulko.com Cc: Simon Glass sjg@chromium.org Cc: Ilias Apalodimas ilias.apalodimas@linaro.org Cc: Jens Wiklander jens.wiklander@linaro.org
Changelog: ===============
v6:
* add FF-A runtime discovery at MM communication level * drop EFI runtime support for FF-A MM communication * revert the changes in include/mm_communication.h for efi_mm_communicate_header and smm_variable_access structures
v4:
* use the new FF-A driver interfaces * discover MM partitions at runtime * copy FF-A driver private data to EFI runtime section at ExitBootServices() * drop use of FFA_ERR_STAT_SUCCESS error code * replace EFI_BUFFER_TOO_SMALL with EFI_OUT_OF_RESOURCES in ffa_mm_communicate(). No need for efi_memcpy_runtime() anymore * revert the error log in mm_communicate() in case of failure * remove packed attribute from efi_mm_communicate_header and smm_variable_communicate_header
v2:
* set default values to 0 for FFA_SHARED_MM_BUFFER_SIZE, FFA_SHARED_MM_BUFFER_ADDR and MM_SP_UUID_DATA and add warnings
v1:
* introduce FF-A MM communication
include/mm_communication.h | 5 + lib/efi_loader/Kconfig | 14 +- lib/efi_loader/efi_variable_tee.c | 264 +++++++++++++++++++++++++++++- 3 files changed, 277 insertions(+), 6 deletions(-)
diff --git a/include/mm_communication.h b/include/mm_communication.h index e65fbde60d..d409bed777 100644 --- a/include/mm_communication.h +++ b/include/mm_communication.h @@ -6,6 +6,8 @@ * Copyright (c) 2017, Intel Corporation. All rights reserved. * Copyright (C) 2020 Linaro Ltd. sughosh.ganu@linaro.org * Copyright (C) 2020 Linaro Ltd. ilias.apalodimas@linaro.org + * (C) Copyright 2022 ARM Limited + * Abdellatif El Khlifi abdellatif.elkhlifi@arm.com */
#ifndef _MM_COMMUNICATION_H_ @@ -13,6 +15,9 @@
#include <part_efi.h>
+/* MM service UUID string (big-endian format). This UUID is common across all MM SPs */ +#define MM_SP_UUID "33d532ed-e699-0942-c09c-a798d9cd722d" + /* * Interface to the pseudo Trusted Application (TA), which provides a * communication channel with the Standalone MM (Management Mode) diff --git a/lib/efi_loader/Kconfig b/lib/efi_loader/Kconfig index 41756ea539..f0d843d5ca 100644 --- a/lib/efi_loader/Kconfig +++ b/lib/efi_loader/Kconfig @@ -60,13 +60,23 @@ config EFI_VARIABLE_FILE_STORE stored as file /ubootefi.var on the EFI system partition.
config EFI_MM_COMM_TEE - bool "UEFI variables storage service via OP-TEE" - depends on OPTEE + bool "UEFI variables storage service via the trusted world" + depends on OPTEE && ARM_FFA_TRANSPORT help + Allowing access to the MM SP services (SPs such as StandAlonneMM, smm-gateway). + When using the u-boot OP-TEE driver, StandAlonneMM is supported. + When using the u-boot FF-A driver any MM SP is supported. + If OP-TEE is present and running StandAloneMM, dispatch all UEFI variable related operations to that. The application will verify, authenticate and store the variables on an RPMB.
+ When ARM_FFA_TRANSPORT is used, dispatch all UEFI variable related + operations to the MM SP running in the secure world. + A door bell mechanism is used to notify the SP when there is data in the shared + MM buffer. The data is copied by u-boot to the shared buffer before issuing + the door bell event. + config EFI_VARIABLE_NO_STORE bool "Don't persist non-volatile UEFI variables" help diff --git a/lib/efi_loader/efi_variable_tee.c b/lib/efi_loader/efi_variable_tee.c index dfef18435d..04e990880d 100644 --- a/lib/efi_loader/efi_variable_tee.c +++ b/lib/efi_loader/efi_variable_tee.c @@ -4,6 +4,8 @@ * * Copyright (C) 2019 Linaro Ltd. sughosh.ganu@linaro.org * Copyright (C) 2019 Linaro Ltd. ilias.apalodimas@linaro.org + * Copyright (C) 2022 ARM Limited + * Abdellatif El Khlifi abdellatif.elkhlifi@arm.com */
#include <common.h> @@ -15,6 +17,36 @@ #include <malloc.h> #include <mm_communication.h>
+#if (IS_ENABLED(CONFIG_ARM_FFA_TRANSPORT)) + +#include <arm_ffa.h> +#include <cpu_func.h> +#include <mapmem.h> + +#ifndef FFA_SHARED_MM_BUFFER_SIZE +#warning "FFA_SHARED_MM_BUFFER_SIZE must be defined in include/configs/<board>.h" +#define FFA_SHARED_MM_BUFFER_SIZE 0 +#endif + +#ifndef FFA_SHARED_MM_BUFFER_OFFSET +#warning "FFA_SHARED_MM_BUFFER_OFFSET must be defined in include/configs/<board>.h" +#define FFA_SHARED_MM_BUFFER_OFFSET 0 +#endif + +#ifndef FFA_SHARED_MM_BUFFER_ADDR +#warning "FFA_SHARED_MM_BUFFER_ADDR must be defined in include/configs/<board>.h" +#define FFA_SHARED_MM_BUFFER_ADDR 0 +#endif + +/* MM return codes */ +#define MM_SUCCESS (0) + +const char *mm_sp_svc_uuid = MM_SP_UUID; + +static u16 mm_sp_id; + +#endif + extern struct efi_var_file __efi_runtime_data *efi_var_buf; static efi_uintn_t max_buffer_size; /* comm + var + func + data */ static efi_uintn_t max_payload_size; /* func + data */ @@ -24,6 +56,7 @@ struct mm_connection { u32 session; };
+#if (IS_ENABLED(CONFIG_OPTEE)) /** * get_connection() - Retrieve OP-TEE session for a specific UUID. * @@ -143,13 +176,224 @@ static efi_status_t optee_mm_communicate(void *comm_buf, ulong dsize)
return ret; } +#endif + +#if (IS_ENABLED(CONFIG_ARM_FFA_TRANSPORT)) + +/** + * ffa_notify_mm_sp() - Announce there is data in the shared buffer + * + * Notifies the MM partition in the trusted world that + * data is available in the shared buffer. + * This is a blocking call during which trusted world has exclusive access + * to the MM shared buffer. + * + * Return: + * + * 0 on success + */ +static int ffa_notify_mm_sp(void) +{ + struct ffa_send_direct_data msg = {0}; + int ret; + int sp_event_ret = -1; + + if (!ffa_bus_ops_get()) + return -EINVAL; + + msg.data0 = FFA_SHARED_MM_BUFFER_OFFSET; /* x3 */ + + ret = ffa_bus_ops_get()->sync_send_receive(mm_sp_id, &msg); + if (ret != 0) + return ret; + + sp_event_ret = msg.data0; /* x3 */ + + if (sp_event_ret == MM_SUCCESS) + return 0; + + /* + * Failure to notify the MM SP + */ + + return -EACCES; +}
/** - * mm_communicate() - Adjust the cmonnucation buffer to StandAlonneMM and send + * ffa_discover_mm_sp_id() - Query the MM partition ID + * + * Use the FF-A driver to get the MM partition ID. + * If multiple partitions are found, use the first one. + * This is a boot time function. + * + * Return: + * + * 0 on success + */ +static int ffa_discover_mm_sp_id(void) +{ + u32 count = 0, size = 0; + int ret; + struct ffa_partition_info *parts_info; + + if (!ffa_bus_ops_get()) + return -EINVAL; + + /* + * get from the driver the count of the SPs matching the UUID + */ + ret = ffa_bus_ops_get()->partition_info_get(mm_sp_svc_uuid, &count, NULL); + if (ret != 0) { + log_err("EFI: Failure in querying partitions count (error code: %d)\n", ret); + return ret; + } + + if (!count) { + log_info("EFI: No MM partition found\n"); + return ret; + } + + /* + * pre-allocate a buffer to be filled by the driver + * with ffa_partition_info structs + */ + + log_info("EFI: Pre-allocating %d partition(s) info structures\n", count); + + parts_info = calloc(count, sizeof(struct ffa_partition_info)); + if (!parts_info) + return -EINVAL; + + size = count * sizeof(struct ffa_partition_info); + + /* + * ask the driver to fill the + * buffer with the SPs info + */ + ret = ffa_bus_ops_get()->partition_info_get(mm_sp_svc_uuid, &size, parts_info); + if (ret != 0) { + log_err("EFI: Failure in querying partition(s) info (error code: %d)\n", ret); + free(parts_info); + return ret; + } + + /* + * MM SPs found , use the first one + */ + + mm_sp_id = parts_info[0].id; + + log_info("EFI: MM partition ID 0x%x\n", mm_sp_id); + + free(parts_info); + + return 0; +} + +/** + * ffa_mm_communicate() - Exchange EFI services data with the MM partition using FF-A + * @comm_buf: locally allocated communication buffer used for rx/tx + * @dsize: communication buffer size + * + * Issues a door bell event to notify the MM partition (SP) running in OP-TEE + * that there is data to read from the shared buffer. + * Communication with the MM SP is performed using FF-A transport. + * On the event, MM SP can read the data from the buffer and + * update the MM shared buffer with response data. + * The response data is copied back to the communication buffer. + * + * Return: + * + * EFI status code + */ +static efi_status_t ffa_mm_communicate(void *comm_buf, ulong comm_buf_size) +{ + ulong tx_data_size; + int ffa_ret; + struct efi_mm_communicate_header *mm_hdr; + void *virt_shared_buf; + + if (!comm_buf) + return EFI_INVALID_PARAMETER; + + /* Discover MM partition ID at boot time */ + if (!mm_sp_id && ffa_discover_mm_sp_id() != 0) { + log_err("EFI: Failure to discover MM partition ID at boot time\n"); + return EFI_UNSUPPORTED; + } + + mm_hdr = (struct efi_mm_communicate_header *)comm_buf; + tx_data_size = mm_hdr->message_len + sizeof(efi_guid_t) + sizeof(size_t); + + if (comm_buf_size != tx_data_size || tx_data_size > FFA_SHARED_MM_BUFFER_SIZE) + return EFI_INVALID_PARAMETER; + + /* Copy the data to the shared buffer */ + + virt_shared_buf = (void *)map_sysmem((phys_addr_t)FFA_SHARED_MM_BUFFER_ADDR, 0); + memcpy(virt_shared_buf, comm_buf, tx_data_size); + + /* + * The secure world might have cache disabled for + * the device region used for shared buffer (which is the case for Optee). + * In this case, the secure world reads the data from DRAM. + * Let's flush the cache so the DRAM is updated with the latest data. + */ + #ifdef CONFIG_ARM64 + invalidate_dcache_all(); + #endif + + /* Announce there is data in the shared buffer */ + + ffa_ret = ffa_notify_mm_sp(); + if (ffa_ret) + unmap_sysmem(virt_shared_buf); + + switch (ffa_ret) { + case 0: + { + ulong rx_data_size; + /* Copy the MM SP response from the shared buffer to the communication buffer */ + rx_data_size = ((struct efi_mm_communicate_header *)virt_shared_buf)->message_len + + sizeof(efi_guid_t) + + sizeof(size_t); + + if (rx_data_size > comm_buf_size) { + unmap_sysmem(virt_shared_buf); + return EFI_OUT_OF_RESOURCES; + } + + memcpy(comm_buf, virt_shared_buf, rx_data_size); + unmap_sysmem(virt_shared_buf); + + return EFI_SUCCESS; + } + case -EINVAL: + return EFI_DEVICE_ERROR; + case -EPERM: + return EFI_INVALID_PARAMETER; + case -EACCES: + return EFI_ACCESS_DENIED; + case -EBUSY: + return EFI_OUT_OF_RESOURCES; + default: + return EFI_ACCESS_DENIED; + } +} +#endif + +/** + * mm_communicate() - Adjust the communication buffer to the MM SP and send * it to OP-TEE * - * @comm_buf: locally allocted communcation buffer + * @comm_buf: locally allocated communication buffer * @dsize: buffer size + * + * The SP (also called partition) can be any MM SP such as StandAlonneMM or smm-gateway. + * The comm_buf format is the same for both partitions. + * When using the u-boot OP-TEE driver, StandAlonneMM is supported. + * When using the u-boot FF-A driver, any MM SP is supported. + * * Return: status code */ static efi_status_t mm_communicate(u8 *comm_buf, efi_uintn_t dsize) @@ -162,7 +406,12 @@ static efi_status_t mm_communicate(u8 *comm_buf, efi_uintn_t dsize) mm_hdr = (struct efi_mm_communicate_header *)comm_buf; var_hdr = (struct smm_variable_communicate_header *)mm_hdr->data;
- ret = optee_mm_communicate(comm_buf, dsize); + ret = ffa_bus_discover(); + if (ret != 0) + ret = optee_mm_communicate(comm_buf, dsize); + else + ret = ffa_mm_communicate(comm_buf, dsize); + if (ret != EFI_SUCCESS) { log_err("%s failed!\n", __func__); return ret; @@ -258,6 +507,13 @@ efi_status_t EFIAPI get_max_payload(efi_uintn_t *size) goto out; } *size = var_payload->size; + + #if (IS_ENABLED(CONFIG_ARM_FFA_TRANSPORT)) + if (*size > FFA_SHARED_MM_BUFFER_SIZE) + *size = FFA_SHARED_MM_BUFFER_SIZE - MM_COMMUNICATE_HEADER_SIZE - + MM_VARIABLE_COMMUNICATE_SIZE; + #endif + /* * There seems to be a bug in EDK2 miscalculating the boundaries and * size checks, so deduct 2 more bytes to fulfill this requirement. Fix @@ -697,7 +953,7 @@ void efi_variables_boot_exit_notify(void) ret = EFI_NOT_FOUND;
if (ret != EFI_SUCCESS) - log_err("Unable to notify StMM for ExitBootServices\n"); + log_err("Unable to notify the MM partition for ExitBootServices\n"); free(comm_buf);
Hi Abdellatif,
Is the device going to work with these defaults? I am assuming not, so isn't better to treat this as compile time errors?
static ?
- get_connection() - Retrieve OP-TEE session for a specific UUID.
- ffa_notify_mm_sp() - Announce there is data in the shared buffer
- Notifies the MM partition in the trusted world that
- data is available in the shared buffer.
- This is a blocking call during which trusted world has exclusive access
- to the MM shared buffer.
- Return:
- 0 on success
- int ret;
- int sp_event_ret = -1;
- if (!ffa_bus_ops_get())
return -EINVAL;
- msg.data0 = FFA_SHARED_MM_BUFFER_OFFSET; /* x3 */
- ret = ffa_bus_ops_get()->sync_send_receive(mm_sp_id, &msg);
- if (ret != 0)
return ret;
- sp_event_ret = msg.data0; /* x3 */
- if (sp_event_ret == MM_SUCCESS)
- return -EACCES;
- mm_communicate() - Adjust the cmonnucation buffer to StandAlonneMM and send
- ffa_discover_mm_sp_id() - Query the MM partition ID
- Use the FF-A driver to get the MM partition ID.
- If multiple partitions are found, use the first one.
- This is a boot time function.
- Return:
- 0 on success
- int ret;
return -EINVAL;
- ret = ffa_bus_ops_get()->partition_info_get(mm_sp_svc_uuid, &count, NULL);
- if (ret != 0) {
return ret;
- if (!count) {
return ret;
- log_info("EFI: Pre-allocating %d partition(s) info structures\n", count);
- if (!parts_info)
return -EINVAL;
-ENOMEM here is more accurate
- ret = ffa_bus_ops_get()->partition_info_get(mm_sp_svc_uuid, &size, parts_info);
- if (ret != 0) {
free(parts_info);
return ret;
- mm_sp_id = parts_info[0].id;
- log_info("EFI: MM partition ID 0x%x\n", mm_sp_id);
- free(parts_info);
- ffa_mm_communicate() - Exchange EFI services data with the MM partition using FF-A
- @comm_buf: locally allocated communication buffer used for rx/tx
- @dsize: communication buffer size
- Issues a door bell event to notify the MM partition (SP) running in OP-TEE
- that there is data to read from the shared buffer.
- Communication with the MM SP is performed using FF-A transport.
- On the event, MM SP can read the data from the buffer and
- update the MM shared buffer with response data.
- The response data is copied back to the communication buffer.
- Return:
- EFI status code
- ulong tx_data_size;
- int ffa_ret;
- struct efi_mm_communicate_header *mm_hdr;
- void *virt_shared_buf;
- if (!comm_buf)
- /* Discover MM partition ID at boot time */
- if (!mm_sp_id && ffa_discover_mm_sp_id() != 0) {
- mm_hdr = (struct efi_mm_communicate_header *)comm_buf;
- tx_data_size = mm_hdr->message_len + sizeof(efi_guid_t) + sizeof(size_t);
- if (comm_buf_size != tx_data_size || tx_data_size > FFA_SHARED_MM_BUFFER_SIZE)
- /* Copy the data to the shared buffer */
- virt_shared_buf = (void *)map_sysmem((phys_addr_t)FFA_SHARED_MM_BUFFER_ADDR, 0);
- memcpy(virt_shared_buf, comm_buf, tx_data_size);
- #ifdef CONFIG_ARM64
- invalidate_dcache_all();
Is this only for arm64?
- #endif
- /* Announce there is data in the shared buffer */
- ffa_ret = ffa_notify_mm_sp();
- if (ffa_ret)
This is a bit confusing handled in different places, can't we just move the check at the end of the switch cases and remote unmap_sysmem() from case 0?
- switch (ffa_ret) {
- case 0:
ulong rx_data_size;
sizeof(size_t);
return EFI_SUCCESS;
- case -EINVAL:
- case -EPERM:
- case -EACCES:
- case -EBUSY:
- default:
+} +#endif
- mm_communicate() - Adjust the communication buffer to the MM SP and send
- it to OP-TEE
- @comm_buf: locally allocted communcation buffer
- @dsize: buffer size
- The SP (also called partition) can be any MM SP such as StandAlonneMM or smm-gateway.
- The comm_buf format is the same for both partitions.
- When using the u-boot OP-TEE driver, StandAlonneMM is supported.
- When using the u-boot FF-A driver, any MM SP is supported.
- Return: status code
- ret = ffa_bus_discover();
- if (ret != 0)
- else
- if (ret != EFI_SUCCESS) { log_err("%s failed!\n", __func__); return ret;
- #if (IS_ENABLED(CONFIG_ARM_FFA_TRANSPORT))
- #endif
- There seems to be a bug in EDK2 miscalculating the boundaries and
- size checks, so deduct 2 more bytes to fulfill this requirement. Fix
free(comm_buf);
-- 2.17.1
Thanks /Ilias
On Mon, Oct 24, 2022 at 03:30:11PM +0300, Ilias Apalodimas wrote:
Hi Abdellatif,
Thanks. Done in v7.
static ?
- Return:
- 0 on success
- int ret;
return -EINVAL;
- if (ret != 0)
return ret;
- return -EACCES;
- Return:
- 0 on success
- int ret;
return -EINVAL;
- if (ret != 0) {
return ret;
- if (!count) {
return ret;
- if (!parts_info)
return -EINVAL;
- if (ret != 0) {
free(parts_info);
return ret;
- free(parts_info);
- Return:
- EFI status code
- int ffa_ret;
- if (!comm_buf)
Yes, currently we only support Aarch64 which we currently need. Same done for the FF-A Linux kernel driver [1].
[1]: https://elixir.bootlin.com/linux/v6.1-rc3/source/drivers/firmware/arm_ffa/Kc...
- #endif
- if (ffa_ret)
Done in v7.
- case 0:
ulong rx_data_size;
sizeof(size_t);
return EFI_SUCCESS;
- case -EINVAL:
- case -EPERM:
- case -EACCES:
- case -EBUSY:
- default:
+} +#endif
- it to OP-TEE
- if (ret != 0)
- else
- #endif
free(comm_buf);
-- 2.17.1
Thanks /Ilias
turn on EFI MM communication
On corstone1000 platform MM communication between u-boot and the secure world (Optee) is done using the FF-A bus.
v6:
* corstone-1000: enable optee driver * corstone-1000: remove CONFIG_ARM_FFA_EFI_RUNTIME_MODE from the defconfig
v4:
* corstone-1000: turn on EFI MM communication
configs/corstone1000_defconfig | 4 ++++ include/configs/corstone1000.h | 9 +++++++++ 2 files changed, 13 insertions(+)
diff --git a/configs/corstone1000_defconfig b/configs/corstone1000_defconfig index ed2e0fe70a..4c9ed9fb71 100644 --- a/configs/corstone1000_defconfig +++ b/configs/corstone1000_defconfig @@ -52,3 +52,7 @@ CONFIG_DM_SERIAL=y CONFIG_USB=y CONFIG_USB_ISP1760=y CONFIG_ERRNO_STR=y +CONFIG_EFI_MM_COMM_TEE=y +CONFIG_TEE=y +CONFIG_OPTEE=y +CONFIG_ARM_FFA_TRANSPORT=y diff --git a/include/configs/corstone1000.h b/include/configs/corstone1000.h index 8e0230c135..997d0bebaf 100644 --- a/include/configs/corstone1000.h +++ b/include/configs/corstone1000.h @@ -14,6 +14,15 @@
#include <linux/sizes.h>
+#define FFA_SHARED_MM_BUFFER_SIZE SZ_4K /* 4 KB */ + +/* + * shared buffer physical address used for communication between + * u-boot and the MM SP + */ +#define FFA_SHARED_MM_BUFFER_ADDR (0x023F8000) +#define FFA_SHARED_MM_BUFFER_OFFSET (0) + #define V2M_BASE 0x80000000
#define CONFIG_PL011_CLOCK 50000000
Changelog:
v6:
- corstone-1000: enable optee driver
- corstone-1000: remove CONFIG_ARM_FFA_EFI_RUNTIME_MODE from the defconfig
v4:
- corstone-1000: turn on EFI MM communication
- shared buffer physical address used for communication between
- u-boot and the MM SP
The rest of the declarations on this file don't have () so please remove them. Also is FFA_SHARED_MM_BUFFER_ADDR used anywhere that would justify UL in the suffix?
Thanks /Ilias
2.17.1
Changelog:
v6:
v4:
Done in v7.
Thanks /Ilias
2.17.1
Hi Abdellatif,
On Thu, Oct 13, 2022 at 11:38:47AM +0100, Abdellatif El Khlifi wrote:
Adding support for Arm FF-A v1.0 (Arm Firmware Framework for Armv8-A) [6].
FF-A describes interfaces (ABIs) that standardize communication between the Secure World and Normal World. These interfaces enable a pair of software sandboxes to communicate with each other. A sandbox aka partition could be a VM in the Normal or Secure world, an application in S-EL0, or a Trusted OS in S-EL1.
The FF-A transport is implemented as a data bus and a core driver is provided.
The FF-A driver uses the SMC ABIs defined by the FF-A specification to:
- Discover the presence of secure partitions (SPs) of interest
- Access an SP's service through communication protocols e.g. EFI MM communication protocol
The FF-A support provides the following features:
- Being generic by design and can be used by any Arm 64-bit platform
- The FF-A core driver
- The FF-A bus is discoverable on demand at runtime
- The driver provides callbacks to be used by clients to access the FF-A bus
- FF-A driver can be compiled and used without EFI
- Support for SMCCCv1.2 x0-x17 registers
- A new command called armffa is provided as an example of how to access the FF-A bus
- An FF-A Sandbox driver is provided with test cases
- Support for FF-A MM communication
- Enabling FF-A and MM communication in Corstone1000 platform
For more details about the FF-A core driver please refer to [7].
Please find at [8] an example of the expected boot logs when enabling FF-A support for a platform. In this example the platform is Corstone1000. But it can be any Arm 64-bit platform.
Changelog of the major changes:
v6:
- remove clearing x0-x17 registers after SMC calls
- drop use of EFI runtime support for FF-A (We decided with Linaro to add this later)
Thanks! This makes the whole process way way easier. I am bit overloaded atm but I'll try squeezing in reviewing these patches
- drop discovery from initcalls (discovery will be on demand by FF-A users)
- add FF-A runtime discovery at MM communication level
- update the documentation and move it to doc/arch/arm64.ffa.rst
v5: [5]
- move changelogs in each commit to the changes section
v4: [4]
- add FF-A support README (doc/README.ffa.drv)
- improving error handling by mapping the FF-A errors to standard errors and logs
- replacing panics with an error log
- align sandbox driver and tests with the new FF-A driver interfaces
Thanks /Ilias
On Thu, Oct 13, 2022 at 03:07:39PM +0300, Ilias Apalodimas wrote:
Hi Abdellatif,
v6:
You're welcome! Happy to improve the patchset :)
v5: [5]
v4: [4]
Thanks /Ilias
Adding support for Arm FF-A v1.0 (Arm Firmware Framework for Armv8-A) [7].
This implementation of the specification provides support for Aarch64.
- Discover the presence of secure partitions (SPs) of interest - Access an SP's service through communication protocols e.g. EFI MM communication protocol
- Being generic by design and can be used by any Arm 64-bit platform - The FF-A core driver - The FF-A bus is discoverable on demand at runtime - The driver provides driver operations to be used by clients to access the FF-A bus - FF-A driver can be compiled and used without EFI - Support for SMCCCv1.2 x0-x17 registers - Support for SMC32 calling convention - Support for 32-bit and 64-bit FF-A direct messaging - A new command called armffa is provided as an example of how to access the FF-A bus - An FF-A Sandbox driver is provided with test cases - Support for FF-A MM communication (compatible with EFI boot time) - Enabling FF-A and MM communication in Corstone1000 platform
For more details about the FF-A core driver please refer to [8].
Please find at [9] an example of the expected boot logs when enabling FF-A support for a platform. In this example the platform is Corstone1000. But it can be any Arm 64-bit platform.
Changelog of the major changes: ===========================
v7:
* add support for 32-bit direct messaging (now we have 32-bit and 64-bit support) * set the MM door bell event to use 64-bit direct messaging * issue a compile time error when one of these macros are not found : FFA_SHARED_MM_BUFFER_SIZE, FFA_SHARED_MM_BUFFER_OFFSET, FFA_SHARED_MM_BUFFER_ADDR * make uuid_str_to_le_bin() implementation similar to uuid_str_to_bin() by using same APIs
v6: [6]
* remove clearing x0-x17 registers after SMC calls * drop use of EFI runtime support for FF-A (We decided with Linaro to add this later) * drop discovery from initcalls (discovery will be on demand by FF-A users) * add FF-A runtime discovery at MM communication level * update the documentation and move it to doc/arch/arm64.ffa.rst
v5: [5]
* move changelogs in each commit to the changes section
v4: [4]
* add FF-A support README (doc/README.ffa.drv) * improving error handling by mapping the FF-A errors to standard errors and logs * replacing panics with an error log * align sandbox driver and tests with the new FF-A driver interfaces and new way of error handling * use the new FF-A driver interfaces for MM communication * discover MM partitions at runtime * copy FF-A driver private data to EFI runtime section at ExitBootServices() * moving the FF-A driver work to drivers/firmware/arm-ffa * improving features discovery in FFA_FEATURES * add remove/unbind functions to the FF-A core device * improve how the driver behaves when bus discovery is done more than once * move clearing x0-x17 registers code into a new macro like done in the linux kernel * enable EFI MM communication for the Corstone1000 platform
v3: [3]
* port x0-x17 registers support from linux kernel as defined by SMCCCv1.2 * align the interfaces of the u-boot FF-A driver with those in the linux FF-A driver * remove the FF-A helper layer * make the u-boot FF-A driver independent from EFI * provide an optional config that enables copying the driver data to EFI runtime section at ExitBootServices service * use 64-bit version of FFA_RXTX_MAP, FFA_MSG_SEND_DIRECT_{REQ, RESP} * update armffa command with the new driver interfaces
v2 [2]:
* make FF-A bus discoverable using device_{bind, probe} APIs * remove device tree support
v1 [1]:
* introduce FF-A bus driver with device tree support * introduce armffa command * introduce FF-A Sandbox driver * add FF-A Sandbox test cases * introduce FF-A MM communication
Cheers, Abdellatif
[1]: https://lore.kernel.org/all/20220329151659.16894-1-abdellatif.elkhlifi@arm.c... [2]: https://lore.kernel.org/all/20220415122803.16666-1-abdellatif.elkhlifi@arm.c... [3]: https://lore.kernel.org/all/20220801172053.20163-1-abdellatif.elkhlifi@arm.c... [4]: https://lore.kernel.org/all/20220926101723.9965-1-abdellatif.elkhlifi@arm.co... [5]: https://lore.kernel.org/all/20220926140827.15125-1-abdellatif.elkhlifi@arm.c... [6]: https://lore.kernel.org/all/20221013103857.614-1-abdellatif.elkhlifi@arm.com... [7]: https://developer.arm.com/documentation/den0077/latest/ [8]: doc/arch/arm64.ffa.rst [9]: example of boot logs when enabling FF-A
``` U-Boot 2022.07 (Jul 11 2022 - 13:42:58 +0000) corstone1000 aarch64 ... [FFA] Conduit is SMC [FFA] FF-A driver 1.0 FF-A framework 1.0 [FFA] Versions are compatible [FFA] endpoint ID is 0 [FFA] Using 1 4KB page(s) for RX/TX buffers size [FFA] RX buffer at virtual address 0xfdf18000 [FFA] TX buffer at virtual address 0xfdf1a000 [FFA] RX/TX buffers mapped [FFA] Reading partitions data from the RX buffer [FFA] Partition ID 8001 : info cached [FFA] Partition ID 8002 : info cached [FFA] Partition ID 8003 : info cached [FFA] 3 partition(s) found and cached [FFA] Preparing for checking partitions count [FFA] Searching partitions using the provided UUID [FFA] No partition found. Querying framework ... [FFA] Reading partitions data from the RX buffer [FFA] Number of partition(s) found matching the UUID: 1 EFI: Pre-allocating 1 partition(s) info structures [FFA] Preparing for filling partitions info [FFA] Searching partitions using the provided UUID [FFA] Partition ID 8003 matches the provided UUID EFI: MM partition ID 0x8003 ... Booting /MemoryMapped(0x0,0x88200000,0xf00000) EFI stub: Booting Linux Kernel... EFI stub: Using DTB from configuration table EFI stub: Exiting boot services... [FFA] Freeing RX/TX buffers Booting Linux on physical CPU 0x0000000000 [0x410fd040] Linux version 5.19.9-yocto-standard (oe-user@oe-host) (aarch64-poky-linux-musl-gcc (GCC) 12.2.0, GNU ld (GNU Binutils) 2.39.0.20220819) #1 SMP PREEMPT Wed Sep 21 20:11:18 UTC 2022 ```
Cc: Tom Rini trini@konsulko.com Cc: Simon Glass sjg@chromium.org Cc: Ilias Apalodimas ilias.apalodimas@linaro.org Cc: Jens Wiklander jens.wiklander@linaro.org Cc: Achin Gupta achin.gupta@arm.com Cc: Drew Reed Drew.Reed@arm.com Cc: Vishnu Banavath vishnu.banavath@arm.com Cc: Xueliang Zhong Xueliang.Zhong@arm.com
Abdellatif El Khlifi (10): arm64: smccc: add support for SMCCCv1.2 x0-x17 registers lib: uuid: introduce uuid_str_to_le_bin function arm_ffa: introduce Arm FF-A low-level driver arm_ffa: efi: unmap RX/TX buffers arm_ffa: introduce armffa command arm_ffa: introduce the FF-A Sandbox driver arm_ffa: introduce Sandbox test cases for UCLASS_FFA arm_ffa: introduce armffa command Sandbox test arm_ffa: efi: introduce FF-A MM communication arm_ffa: efi: corstone1000: enable MM communication
MAINTAINERS | 11 + arch/arm/cpu/armv8/smccc-call.S | 53 + arch/arm/lib/asm-offsets.c | 14 + cmd/Kconfig | 10 + cmd/Makefile | 2 + cmd/armffa.c | 239 +++ configs/corstone1000_defconfig | 4 + configs/sandbox64_defconfig | 2 + configs/sandbox_defconfig | 2 + doc/arch/arm64.ffa.rst | 218 +++ doc/arch/index.rst | 1 + doc/arch/sandbox.rst | 1 + drivers/Kconfig | 2 + drivers/Makefile | 1 + drivers/firmware/arm-ffa/Kconfig | 36 + drivers/firmware/arm-ffa/Makefile | 7 + drivers/firmware/arm-ffa/arm-ffa-uclass.c | 16 + drivers/firmware/arm-ffa/arm_ffa_prv.h | 210 +++ drivers/firmware/arm-ffa/core.c | 1324 +++++++++++++++++ drivers/firmware/arm-ffa/sandbox.c | 659 ++++++++ .../firmware/arm-ffa/sandbox_arm_ffa_prv.h | 144 ++ include/arm_ffa.h | 93 ++ include/configs/corstone1000.h | 9 + include/dm/uclass-id.h | 4 + include/linux/arm-smccc.h | 43 + include/mm_communication.h | 5 + include/sandbox_arm_ffa.h | 91 ++ include/uuid.h | 8 + lib/efi_loader/Kconfig | 14 +- lib/efi_loader/efi_boottime.c | 13 + lib/efi_loader/efi_variable_tee.c | 269 +++- lib/uuid.c | 46 + test/cmd/Makefile | 2 + test/cmd/armffa.c | 40 + test/dm/Makefile | 2 + test/dm/ffa.c | 394 +++++ 36 files changed, 3983 insertions(+), 6 deletions(-) create mode 100644 cmd/armffa.c create mode 100644 doc/arch/arm64.ffa.rst create mode 100644 drivers/firmware/arm-ffa/Kconfig create mode 100644 drivers/firmware/arm-ffa/Makefile create mode 100644 drivers/firmware/arm-ffa/arm-ffa-uclass.c create mode 100644 drivers/firmware/arm-ffa/arm_ffa_prv.h create mode 100644 drivers/firmware/arm-ffa/core.c create mode 100644 drivers/firmware/arm-ffa/sandbox.c create mode 100644 drivers/firmware/arm-ffa/sandbox_arm_ffa_prv.h create mode 100644 include/arm_ffa.h create mode 100644 include/sandbox_arm_ffa.h create mode 100644 test/cmd/armffa.c create mode 100644 test/dm/ffa.c
add support for x0-x17 registers used by the SMC calls
In SMCCC v1.2 [1] arguments are passed in registers x1-x17. Results are returned in x0-x17.
This work is inspired from the following kernel commit:
arm64: smccc: Add support for SMCCCv1.2 extended input/output registers
[1]: https://documentation-service.arm.com/static/5f8edaeff86e16515cdbe4c6?token=
Signed-off-by: Abdellatif El Khlifi abdellatif.elkhlifi@arm.com Reviewed-by: Jens Wiklander jens.wiklander@linaro.org Cc: Tom Rini trini@konsulko.com Cc: Simon Glass sjg@chromium.org Cc: Ilias Apalodimas ilias.apalodimas@linaro.org
v7:
* improve indentation of ARM_SMCCC_1_2_REGS_Xn_OFFS
v4:
* rename the commit title and improve description new commit title: the current
v3:
* port x0-x17 registers support from linux kernel as defined by SMCCCv1.2 commit title: arm64: smccc: add Xn registers support used by SMC calls
arch/arm/cpu/armv8/smccc-call.S | 53 +++++++++++++++++++++++++++++++++ arch/arm/lib/asm-offsets.c | 14 +++++++++ include/linux/arm-smccc.h | 43 ++++++++++++++++++++++++++ 3 files changed, 110 insertions(+)
diff --git a/arch/arm/cpu/armv8/smccc-call.S b/arch/arm/cpu/armv8/smccc-call.S index dc92b28777..ec6f299bc9 100644 --- a/arch/arm/cpu/armv8/smccc-call.S +++ b/arch/arm/cpu/armv8/smccc-call.S @@ -1,6 +1,8 @@ /* SPDX-License-Identifier: GPL-2.0 */ /* * Copyright (c) 2015, Linaro Limited + * (C) Copyright 2022 ARM Limited + * Abdellatif El Khlifi abdellatif.elkhlifi@arm.com */ #include <linux/linkage.h> #include <linux/arm-smccc.h> @@ -45,3 +47,54 @@ ENDPROC(__arm_smccc_smc) ENTRY(__arm_smccc_hvc) SMCCC hvc ENDPROC(__arm_smccc_hvc) + +#ifdef CONFIG_ARM64 + + .macro SMCCC_1_2 instr + /* Save `res` and free a GPR that won't be clobbered */ + stp x1, x19, [sp, #-16]! + + /* Ensure `args` won't be clobbered while loading regs in next step */ + mov x19, x0 + + /* Load the registers x0 - x17 from the struct arm_smccc_1_2_regs */ + ldp x0, x1, [x19, #ARM_SMCCC_1_2_REGS_X0_OFFS] + ldp x2, x3, [x19, #ARM_SMCCC_1_2_REGS_X2_OFFS] + ldp x4, x5, [x19, #ARM_SMCCC_1_2_REGS_X4_OFFS] + ldp x6, x7, [x19, #ARM_SMCCC_1_2_REGS_X6_OFFS] + ldp x8, x9, [x19, #ARM_SMCCC_1_2_REGS_X8_OFFS] + ldp x10, x11, [x19, #ARM_SMCCC_1_2_REGS_X10_OFFS] + ldp x12, x13, [x19, #ARM_SMCCC_1_2_REGS_X12_OFFS] + ldp x14, x15, [x19, #ARM_SMCCC_1_2_REGS_X14_OFFS] + ldp x16, x17, [x19, #ARM_SMCCC_1_2_REGS_X16_OFFS] + + \instr #0 + + /* Load the `res` from the stack */ + ldr x19, [sp] + + /* Store the registers x0 - x17 into the result structure */ + stp x0, x1, [x19, #ARM_SMCCC_1_2_REGS_X0_OFFS] + stp x2, x3, [x19, #ARM_SMCCC_1_2_REGS_X2_OFFS] + stp x4, x5, [x19, #ARM_SMCCC_1_2_REGS_X4_OFFS] + stp x6, x7, [x19, #ARM_SMCCC_1_2_REGS_X6_OFFS] + stp x8, x9, [x19, #ARM_SMCCC_1_2_REGS_X8_OFFS] + stp x10, x11, [x19, #ARM_SMCCC_1_2_REGS_X10_OFFS] + stp x12, x13, [x19, #ARM_SMCCC_1_2_REGS_X12_OFFS] + stp x14, x15, [x19, #ARM_SMCCC_1_2_REGS_X14_OFFS] + stp x16, x17, [x19, #ARM_SMCCC_1_2_REGS_X16_OFFS] + + /* Restore original x19 */ + ldp xzr, x19, [sp], #16 + ret + .endm + +/* + * void arm_smccc_1_2_smc(const struct arm_smccc_1_2_regs *args, + * struct arm_smccc_1_2_regs *res); + */ +ENTRY(arm_smccc_1_2_smc) + SMCCC_1_2 smc +ENDPROC(arm_smccc_1_2_smc) + +#endif diff --git a/arch/arm/lib/asm-offsets.c b/arch/arm/lib/asm-offsets.c index 22fd541f9a..db6d7ed234 100644 --- a/arch/arm/lib/asm-offsets.c +++ b/arch/arm/lib/asm-offsets.c @@ -9,6 +9,9 @@ * generate asm statements containing #defines, * compile this file to assembler, and then extract the * #defines from the assembly-language output. + * + * (C) Copyright 2022 ARM Limited + * Abdellatif El Khlifi abdellatif.elkhlifi@arm.com */
#include <common.h> @@ -117,6 +120,17 @@ int main(void) DEFINE(ARM_SMCCC_RES_X2_OFFS, offsetof(struct arm_smccc_res, a2)); DEFINE(ARM_SMCCC_QUIRK_ID_OFFS, offsetof(struct arm_smccc_quirk, id)); DEFINE(ARM_SMCCC_QUIRK_STATE_OFFS, offsetof(struct arm_smccc_quirk, state)); +#ifdef CONFIG_ARM64 + DEFINE(ARM_SMCCC_1_2_REGS_X0_OFFS, offsetof(struct arm_smccc_1_2_regs, a0)); + DEFINE(ARM_SMCCC_1_2_REGS_X2_OFFS, offsetof(struct arm_smccc_1_2_regs, a2)); + DEFINE(ARM_SMCCC_1_2_REGS_X4_OFFS, offsetof(struct arm_smccc_1_2_regs, a4)); + DEFINE(ARM_SMCCC_1_2_REGS_X6_OFFS, offsetof(struct arm_smccc_1_2_regs, a6)); + DEFINE(ARM_SMCCC_1_2_REGS_X8_OFFS, offsetof(struct arm_smccc_1_2_regs, a8)); + DEFINE(ARM_SMCCC_1_2_REGS_X10_OFFS, offsetof(struct arm_smccc_1_2_regs, a10)); + DEFINE(ARM_SMCCC_1_2_REGS_X12_OFFS, offsetof(struct arm_smccc_1_2_regs, a12)); + DEFINE(ARM_SMCCC_1_2_REGS_X14_OFFS, offsetof(struct arm_smccc_1_2_regs, a14)); + DEFINE(ARM_SMCCC_1_2_REGS_X16_OFFS, offsetof(struct arm_smccc_1_2_regs, a16)); +#endif #endif
return 0; diff --git a/include/linux/arm-smccc.h b/include/linux/arm-smccc.h index e1d09884a1..9105031d55 100644 --- a/include/linux/arm-smccc.h +++ b/include/linux/arm-smccc.h @@ -1,6 +1,8 @@ /* SPDX-License-Identifier: GPL-2.0 */ /* * Copyright (c) 2015, Linaro Limited + * (C) Copyright 2022 ARM Limited + * Abdellatif El Khlifi abdellatif.elkhlifi@arm.com */ #ifndef __LINUX_ARM_SMCCC_H #define __LINUX_ARM_SMCCC_H @@ -70,6 +72,47 @@ struct arm_smccc_res { unsigned long a3; };
+#ifdef CONFIG_ARM64 +/** + * struct arm_smccc_1_2_regs - Arguments for or Results from SMC call + * @a0-a17 argument values from registers 0 to 17 + */ +struct arm_smccc_1_2_regs { + unsigned long a0; + unsigned long a1; + unsigned long a2; + unsigned long a3; + unsigned long a4; + unsigned long a5; + unsigned long a6; + unsigned long a7; + unsigned long a8; + unsigned long a9; + unsigned long a10; + unsigned long a11; + unsigned long a12; + unsigned long a13; + unsigned long a14; + unsigned long a15; + unsigned long a16; + unsigned long a17; +}; + +/** + * arm_smccc_1_2_smc() - make SMC calls + * @args: arguments passed via struct arm_smccc_1_2_regs + * @res: result values via struct arm_smccc_1_2_regs + * + * This function is used to make SMC calls following SMC Calling Convention + * v1.2 or above. The content of the supplied param are copied from the + * structure to registers prior to the SMC instruction. The return values + * are updated with the content from registers on return from the SMC + * instruction. + */ +asmlinkage void arm_smccc_1_2_smc(const struct arm_smccc_1_2_regs *args, + struct arm_smccc_1_2_regs *res); +#endif + /** * struct arm_smccc_quirk - Contains quirk information * @id: quirk identification
convert UUID string to little endian binary data
v7:
* rename be_uuid_str_to_le_bin() to uuid_str_to_le_bin() * make uuid_str_to_le_bin() implementation similar to uuid_str_to_bin() by using same APIs
v4:
* rename ffa_uuid_str_to_bin to be_uuid_str_to_le_bin and put in a standalone commit (the current)
v3:
* introduce ffa_uuid_str_to_bin (provided by arm_ffa: introduce Arm FF-A low-level driver)
include/uuid.h | 8 ++++++++ lib/uuid.c | 46 ++++++++++++++++++++++++++++++++++++++++++++++ 2 files changed, 54 insertions(+)
diff --git a/include/uuid.h b/include/uuid.h index 4a4883d3b5..293a8eb0a5 100644 --- a/include/uuid.h +++ b/include/uuid.h @@ -2,6 +2,8 @@ /* * Copyright (C) 2014 Samsung Electronics * Przemyslaw Marczak p.marczak@samsung.com + * (C) Copyright 2022 ARM Limited + * Abdellatif El Khlifi abdellatif.elkhlifi@arm.com */ #ifndef __UUID_H__ #define __UUID_H__ @@ -44,4 +46,10 @@ int uuid_guid_get_bin(const char *guid_str, unsigned char *guid_bin); const char *uuid_guid_get_str(const unsigned char *guid_bin); void gen_rand_uuid(unsigned char *uuid_bin); void gen_rand_uuid_str(char *uuid_str, int str_format); + +/** + * uuid_str_to_le_bin - Converts a UUID string to little endian binary data + */ +int uuid_str_to_le_bin(const char *uuid_str, unsigned char *uuid_bin); + #endif diff --git a/lib/uuid.c b/lib/uuid.c index 465e1ac38f..cde5ae2bb7 100644 --- a/lib/uuid.c +++ b/lib/uuid.c @@ -1,6 +1,8 @@ // SPDX-License-Identifier: GPL-2.0+ /* * Copyright 2011 Calxeda, Inc. + * (C) Copyright 2022 ARM Limited + * Abdellatif El Khlifi abdellatif.elkhlifi@arm.com */
#include <common.h> @@ -346,6 +348,50 @@ int uuid_str_to_bin(const char *uuid_str, unsigned char *uuid_bin, return 0; }
+/** + * uuid_str_to_le_bin() - Convert string UUID to little endian binary data. + * @uuid_str: pointer to UUID string + * @uuid_bin: pointer to allocated array for little endian output [16B] + * + * UUID string is 36 characters (36 bytes): + * + * xxxxxxxx-xxxx-xxxx-xxxx-xxxxxxxxxxxx + * + * where x is a hexadecimal character. Fields are separated by '-'s. + * When converting to a little endian binary UUID, the string fields are reversed. + * + * Return: + * + * uuid_bin filled with little endian UUID data + * On success 0 is returned. Otherwise, failure code. + */ +int uuid_str_to_le_bin(const char *uuid_str, unsigned char *uuid_bin) +{ + u16 tmp16; + u32 tmp32; + u64 tmp64; + + if (!uuid_str_valid(uuid_str) || !uuid_bin) + return -EINVAL; + + tmp32 = cpu_to_le32(hextoul(uuid_str, NULL)); + memcpy(uuid_bin, &tmp32, 4); + + tmp16 = cpu_to_le16(hextoul(uuid_str + 9, NULL)); + memcpy(uuid_bin + 4, &tmp16, 2); + + tmp16 = cpu_to_le16(hextoul(uuid_str + 14, NULL)); + memcpy(uuid_bin + 6, &tmp16, 2); + + tmp16 = cpu_to_le16(hextoul(uuid_str + 19, NULL)); + memcpy(uuid_bin + 8, &tmp16, 2); + + tmp64 = cpu_to_le64(hextoul(uuid_str + 24, NULL)); + memcpy(uuid_bin + 10, (char *)&tmp64, 6); + + return 0; +} + /* * uuid_bin_to_str() - convert big endian binary data to string UUID or GUID. *
Hi Abdellatif,
Changelog:
v7:
- rename be_uuid_str_to_le_bin() to uuid_str_to_le_bin()
- make uuid_str_to_le_bin() implementation similar to uuid_str_to_bin() by using same APIs
v4:
- rename ffa_uuid_str_to_bin to be_uuid_str_to_le_bin and put in a standalone commit (the current)
v3:
- introduce ffa_uuid_str_to_bin (provided by arm_ffa: introduce Arm FF-A low-level driver)
- Copyright (C) 2014 Samsung Electronics
- Przemyslaw Marczak p.marczak@samsung.com
- uuid_str_to_le_bin - Converts a UUID string to little endian binary data
- Copyright 2011 Calxeda, Inc.
- uuid_str_to_le_bin() - Convert string UUID to little endian binary data.
- @uuid_str: pointer to UUID string
- @uuid_bin: pointer to allocated array for little endian output [16B]
- UUID string is 36 characters (36 bytes):
- xxxxxxxx-xxxx-xxxx-xxxx-xxxxxxxxxxxx
- where x is a hexadecimal character. Fields are separated by '-'s.
- When converting to a little endian binary UUID, the string fields are reversed.
- Return:
- uuid_bin filled with little endian UUID data
- On success 0 is returned. Otherwise, failure code.
- u16 tmp16;
- u32 tmp32;
- u64 tmp64;
- if (!uuid_str_valid(uuid_str) || !uuid_bin)
return -EINVAL;
- tmp32 = cpu_to_le32(hextoul(uuid_str, NULL));
- memcpy(uuid_bin, &tmp32, 4);
- tmp16 = cpu_to_le16(hextoul(uuid_str + 9, NULL));
- memcpy(uuid_bin + 4, &tmp16, 2);
- tmp16 = cpu_to_le16(hextoul(uuid_str + 14, NULL));
- memcpy(uuid_bin + 6, &tmp16, 2);
- tmp16 = cpu_to_le16(hextoul(uuid_str + 19, NULL));
- memcpy(uuid_bin + 8, &tmp16, 2);
- tmp64 = cpu_to_le64(hextoul(uuid_str + 24, NULL));
- memcpy(uuid_bin + 10, (char *)&tmp64, 6);
The cast isn't needed here
- uuid_bin_to_str() - convert big endian binary data to string UUID or GUID.
-- 2.17.1
On Tue, Nov 08, 2022 at 03:47:46PM +0200, Ilias Apalodimas wrote:
Hi Abdellatif,
Changelog:
v7:
v4:
v3:
- Return:
- u16 tmp16;
- u32 tmp32;
- u64 tmp64;
return -EINVAL;
A good catch , thanks for pointing out :) I'll fix that in v8.
-- 2.17.1
On Fri, 11 Nov 2022 at 14:32, Abdellatif El Khlifi abdellatif.elkhlifi@arm.com wrote:
Hi Abdellatif,
Changelog:
v7:
v4:
v3:
- Return:
- u16 tmp16;
- u32 tmp32;
- u64 tmp64;
return -EINVAL;
Sure, don't rush v8. I'll go through the remaining either today or Monday
Thanks /Ilias
-- 2.17.1
Hi Abdel,
From: U-Boot u-boot-bounces@lists.denx.de on behalf of Abdellatif El Khlifi abdellatif.elkhlifi@arm.com Date: Monday, 7 November 2022 at 19:22 To: Abdellatif El Khlifi Abdellatif.ElKhlifi@arm.com Cc: Drew Reed Drew.Reed@arm.com, Achin Gupta Achin.Gupta@arm.com, ilias.apalodimas@linaro.org ilias.apalodimas@linaro.org, jens.wiklander@linaro.org jens.wiklander@linaro.org, nd nd@arm.com, sjg@chromium.org sjg@chromium.org, trini@konsulko.com trini@konsulko.com, u-boot@lists.denx.de u-boot@lists.denx.de, Vishnu Banavath Vishnu.Banavath@arm.com, Xueliang Zhong Xueliang.Zhong@arm.com Subject: [PATCH v7 02/10] lib: uuid: introduce uuid_str_to_le_bin function convert UUID string to little endian binary data
v7:
v4:
v3:
I think we might risk overflow here on platforms where “ulong” happens to be 32 bits.
+ + return 0; +} + /* * uuid_bin_to_str() - convert big endian binary data to string UUID or GUID. * -- 2.17.1
On Fri, Nov 11, 2022 at 05:02:26PM +0000, Anders Dellien wrote:
Hi Abdel,
Changelog:
v7:
v4:
v3:
- Return:
u16 tmp16;
u32 tmp32;
u64 tmp64;
return -EINVAL;
Thanks Anders, a very valid point.
I will use simple_strtoull() in place of hextoul()
I'll make the change in v8.
-- 2.17.1
Add the core driver implementing Arm Firmware Framework for Armv8-A v1.0
The Firmware Framework for Arm A-profile processors (FF-A v1.0) [1] describes interfaces (ABIs) that standardize communication between the Secure World and Normal World leveraging TrustZone technology.
This driver uses 64-bit registers as per SMCCCv1.2 spec and comes on top of the SMCCC layer. The driver provides the FF-A ABIs needed for querying the FF-A framework from the secure world.
The driver uses SMC32 calling convention which means using the first 32-bit data of the Xn registers.
All supported ABIs come with their 32-bit version except FFA_RXTX_MAP which has 64-bit version supported.
Both 32-bit and 64-bit direct messaging are supported which allows both 32-bit and 64-bit clients to use the FF-A bus.
In U-Boot FF-A design, FF-A is considered as a discoverable bus. The Secure World is considered as one entity to communicate with using the FF-A bus. FF-A communication is handled by one device and one instance (the bus). This FF-A driver takes care of all the interactions between Normal world and Secure World.
The driver exports its operations to be used by upper layers.
Exported operations:
- partition_info_get - sync_send_receive - rxtx_unmap
For more details please refer to the driver documentation [2].
[1]: https://developer.arm.com/documentation/den0077/latest/ [2]: doc/arch/arm64.ffa.rst
v7:
* add support for 32-bit direct messaging * rename be_uuid_str_to_le_bin() to uuid_str_to_le_bin() * improve the declaration of error handling mapping * stating in doc/arch/arm64.ffa.rst that EFI runtime is not supported
v6:
* drop use of EFI runtime support (We decided with Linaro to add this later) * drop discovery from initcalls (discovery will be on demand by FF-A users) * set the alignment of the RX/TX buffers to the larger translation granule size * move FF-A RX/TX buffers unmapping at ExitBootServices() to a separate commit * update the documentation and move it to doc/arch/arm64.ffa.rst
v4:
* add doc/README.ffa.drv * moving the FF-A driver work to drivers/firmware/arm-ffa * use less #ifdefs in lib/efi_loader/efi_boottime.c and replace #if defined by #if CONFIG_IS_ENABLED * improving error handling by mapping the FF-A errors to standard errors and logs * replacing panics with an error log and returning an error code * improving features discovery in FFA_FEATURES by introducing rxtx_min_pages private data field * add ffa_remove and ffa_unbind functions * improve how the driver behaves when bus discovery is done more than once
v3:
* align the interfaces of the U-Boot FF-A driver with those in the linux FF-A driver * remove the FF-A helper layer * make the U-Boot FF-A driver independent from EFI * provide an optional config that enables copying the driver data to EFI runtime section at ExitBootServices service * use 64-bit version of FFA_RXTX_MAP, FFA_MSG_SEND_DIRECT_{REQ, RESP}
v2:
v1:
MAINTAINERS | 7 + doc/arch/arm64.ffa.rst | 218 ++++ doc/arch/index.rst | 1 + drivers/Kconfig | 2 + drivers/Makefile | 1 + drivers/firmware/arm-ffa/Kconfig | 30 + drivers/firmware/arm-ffa/Makefile | 6 + drivers/firmware/arm-ffa/arm-ffa-uclass.c | 16 + drivers/firmware/arm-ffa/arm_ffa_prv.h | 205 ++++ drivers/firmware/arm-ffa/core.c | 1310 +++++++++++++++++++++ include/arm_ffa.h | 93 ++ include/dm/uclass-id.h | 4 + 12 files changed, 1893 insertions(+) create mode 100644 doc/arch/arm64.ffa.rst create mode 100644 drivers/firmware/arm-ffa/Kconfig create mode 100644 drivers/firmware/arm-ffa/Makefile create mode 100644 drivers/firmware/arm-ffa/arm-ffa-uclass.c create mode 100644 drivers/firmware/arm-ffa/arm_ffa_prv.h create mode 100644 drivers/firmware/arm-ffa/core.c create mode 100644 include/arm_ffa.h
diff --git a/MAINTAINERS b/MAINTAINERS index 1cf99c1393..450b5725ce 100644 --- a/MAINTAINERS +++ b/MAINTAINERS @@ -263,6 +263,13 @@ F: drivers/net/cortina_ni.h F: drivers/net/phy/ca_phy.c F: configs/cortina_presidio-asic-pnand_defconfig
+ARM FF-A +M: Abdellatif El Khlifi abdellatif.elkhlifi@arm.com +S: Maintained +F: doc/arch/arm64.ffa.rst +F: drivers/firmware/arm-ffa/ +F: include/arm_ffa.h + ARM FREESCALE IMX M: Stefano Babic sbabic@denx.de M: Fabio Estevam festevam@gmail.com diff --git a/doc/arch/arm64.ffa.rst b/doc/arch/arm64.ffa.rst new file mode 100644 index 0000000000..dfcec82e45 --- /dev/null +++ b/doc/arch/arm64.ffa.rst @@ -0,0 +1,218 @@ +.. SPDX-License-Identifier: GPL-2.0+ + +Arm FF-A Driver +=============== + +Summary +------- + +FF-A stands for Firmware Framework for Arm A-profile processors. + +FF-A specifies interfaces that enable a pair of software sandboxes to +communicate with each other. A sandbox aka partition could +be a VM in the Normal or Secure world, an application in S-EL0, or a +Trusted OS in S-EL1. + +This FF-A driver implements the interfaces to communicate with partitions in +the Secure world aka Secure partitions (SPs). + +The driver specifically focuses on communicating with SPs that isolate portions +of EFI runtime services that must run in a protected environment which is +inaccessible by the Host OS or Hypervisor. Examples of such services are +set/get variables. + +FF-A driver uses the SMC ABIs defined by the FF-A specification to: + +- Discover the presence of SPs of interest +- Access an SP's service through communication protocols + e.g. EFI MM communication protocol + +At this stage of development the FF-A driver supports EFI boot time only. + +Runtime support will be added in future developments. + +FF-A and SMC specifications +------------------------------------------- + +The current implementation of the driver relies on FF-A specification v1.0 +and uses SMC32 calling convention which means using the first 32-bit data of the +Xn registers. + +At this stage we only need the FF-A v1.0 features. + +The driver has been tested with OP-TEE which supports SMC32 calling convention. + +For more details please refer to the FF-A v1.0 spec: +https://documentation-service.arm.com/static/5fb7e8a6ca04df4095c1d65e?token= + +Hypervisors are supported if they are configured to trap SMC calls. + +The FF-A driver uses 64-bit registers as per SMCCCv1.2 specification. + +For more details please refer to the SMC Calling Convention v1.2 spec: +https://documentation-service.arm.com/static/5f8edaeff86e16515cdbe4c6?token= + +Supported hardware +-------------------------------- + +Aarch64 plaforms + +Configuration +---------------------- + +CONFIG_ARM_FFA_TRANSPORT + Enables the FF-A bus driver. Turn this on if you want to use FF-A + communication. + +CONFIG_SANDBOX_FFA + Enables FF-A Sandbox driver. This emulates the FF-A ABIs handling under + Sandbox and provides functional tests for FF-A. + +FF-A ABIs under the hood +--------------------------------------- + +Invoking an FF-A ABI involves providing to the secure world/hypervisor the +expected arguments from the ABI. + +The ABI arguments are stored in x0 to x7 registers. Then, an SMC instruction +is executed. + +At the secure side level or hypervisor the ABI is handled at a higher exception +level and the arguments are read and processed. + +The response is put back through x0 to x7 registers and control is given back +to the U-Boot FF-A driver (non-secure world). + +The driver reads the response and processes it accordingly. + +This methodology applies to all the FF-A ABIs in the driver. + +FF-A bus discovery in U-Boot +------------------------------------------- + +When CONFIG_ARM_FFA_TRANSPORT is enabled, the FF-A bus is discovered on +demand by the clients (users). + +Clients can discover the FF-A bus using ffa_bus_discover() API which triggers the +discovery process. + +ffa_bus_discover() creates, binds and probes the arm_ffa device using +device_{bind, probe} APIs. + +The discovery process consists in communicating with secure world (or hypervisor) +and querying specific data. + +The discovery process takes place during the arm_ffa device probing which is +handled by ffa_probe(). + +The FF-A bus discovery is successful and the bus is ready for use when these +operations succeed: + +- querying the FF-A framework version +- querying from secure world the U-Boot endpoint ID +- querying from secure world the RX/TX mapping features +- mapping the RX/TX buffers +- querying from secure world all the partitions information + +Discovery failure results in a probing failure and the arm_ffa device is +destroyed. + +Requirements for clients +------------------------------------- + +When using the FF-A bus with EFI, clients must: + +- Query SPs in EFI boot time mode using the service UUID. +- Unmap RX/TX buffers before EFI runtime mode starts. + +The RX/TX buffers are only available at EFI boot time. Querying partitions is +done at boot time and data is cached for future use. + +RX/TX buffers should be unmapped by the user before EFI runtime mode +starts. The driver provides a bus operation for that: rxtx_unmap() + +If RX/TX buffers created by U-Boot are not unmapped and by +consequence becoming available at EFI runtime, secure world will get confused +about RX/TX buffers ownership (U-Boot vs kernel). + +When invoking FF-A direct messaging, clients should specify which ABI protocol +they want to use (32-bit vs 64-bit). Selecting the protocol means using +the 32-bit or 64-bit version of FFA_MSG_SEND_DIRECT_{REQ, RESP}. +The calling convention stays the same: SMC32. + +The bus driver layer +------------------------------ + +The driver comes on top of the SMCCC layer and is implemented in +drivers/firmware/arm-ffa/core.c + +The driver provides the following features: + +- Support for the 32-bit version of the following ABIs: + +FFA_VERSION +FFA_ID_GET +FFA_FEATURES +FFA_PARTITION_INFO_GET +FFA_RXTX_UNMAP +FFA_RX_RELEASE +FFA_RUN +FFA_ERROR +FFA_SUCCESS +FFA_INTERRUPT +FFA_MSG_SEND_DIRECT_REQ +FFA_MSG_SEND_DIRECT_RESP + +- Support for the 64-bit version of the following ABIs: + +FFA_RXTX_MAP +FFA_MSG_SEND_DIRECT_REQ +FFA_MSG_SEND_DIRECT_RESP + +- Processing the received data from the secure world/hypervisor and caching it + +- Hiding from upper layers the FF-A protocol and registers details. Upper + layers focus on exchanged data, the driver takes care of how to transport + that to the secure world/hypervisor using FF-A + +- The driver provides callbacks to be used by clients to access the FF-A bus: + +partition_info_get +sync_send_receive +rxtx_unmap + +- FF-A bus discovery makes sure FF-A framework is responsive and compatible + with the driver + +- FF-A bus can be compiled and used without EFI + +Using armffa command +----------------------------------- + +armffa is an implementation defined command showcasing how to use the FF-A driver and how to invoke +its operations. + +This provides a guidance to the client developers on how to call the FF-A bus +interfaces. + +Usage: + +armffa <sub-command> <arguments> + +sub-commands: + + getpart <partition UUID> + + lists the partition(s) info + + ping <partition ID> + + sends a data pattern to the specified partition + + devlist + + displays the arm_ffa device info + +Contributors +------------ + * Abdellatif El Khlifi abdellatif.elkhlifi@arm.com diff --git a/doc/arch/index.rst b/doc/arch/index.rst index 792d9182c3..8d1ab0ad4e 100644 --- a/doc/arch/index.rst +++ b/doc/arch/index.rst @@ -8,6 +8,7 @@ Architecture-specific doc
arc arm64 + arm64.ffa m68k mips nios2 diff --git a/drivers/Kconfig b/drivers/Kconfig index 8b6fead351..b06b1ae481 100644 --- a/drivers/Kconfig +++ b/drivers/Kconfig @@ -6,6 +6,8 @@ source "drivers/core/Kconfig"
source "drivers/adc/Kconfig"
+source "drivers/firmware/arm-ffa/Kconfig" + source "drivers/ata/Kconfig"
source "drivers/axi/Kconfig" diff --git a/drivers/Makefile b/drivers/Makefile index a1700c819d..b86c1d2a42 100644 --- a/drivers/Makefile +++ b/drivers/Makefile @@ -111,6 +111,7 @@ obj-y += iommu/ obj-y += smem/ obj-y += thermal/ obj-$(CONFIG_TEE) += tee/ +obj-$(CONFIG_ARM_FFA_TRANSPORT) += firmware/arm-ffa/ obj-y += axi/ obj-y += ufs/ obj-$(CONFIG_W1) += w1/ diff --git a/drivers/firmware/arm-ffa/Kconfig b/drivers/firmware/arm-ffa/Kconfig new file mode 100644 index 0000000000..e4914b9bc7 --- /dev/null +++ b/drivers/firmware/arm-ffa/Kconfig @@ -0,0 +1,30 @@ +# SPDX-License-Identifier: GPL-2.0 + +config ARM_FFA_TRANSPORT + bool "Enable Arm Firmware Framework for Armv8-A driver" + depends on DM && ARM64 + select ARM_SMCCC + select LIB_UUID + select DEVRES + help + The Firmware Framework for Arm A-profile processors (FF-A) + describes interfaces (ABIs) that standardize communication + between the Secure World and Normal World leveraging TrustZone + technology. + + This driver is based on FF-A specification v1.0 and uses SMC32 + calling convention. + + FF-A specification: + + https://developer.arm.com/documentation/den0077/a/?lang=en + + In U-Boot FF-A design, FF-A is considered as a discoverable bus. + The Secure World is considered as one entity to communicate with + using the FF-A bus. + FF-A communication is handled by one device and one instance (the bus). + This FF-A driver takes care of all the interactions between Normal world + and Secure World. + + For more details about the FF-A driver, please refer to doc/arch/arm64.ffa.rst + diff --git a/drivers/firmware/arm-ffa/Makefile b/drivers/firmware/arm-ffa/Makefile new file mode 100644 index 0000000000..043a8915be --- /dev/null +++ b/drivers/firmware/arm-ffa/Makefile @@ -0,0 +1,6 @@ +# SPDX-License-Identifier: GPL-2.0+ +# +# (C) Copyright 2022 +# Abdellatif El Khlifi, Arm Limited, abdellatif.elkhlifi@arm.com. + +obj-y += arm-ffa-uclass.o core.o diff --git a/drivers/firmware/arm-ffa/arm-ffa-uclass.c b/drivers/firmware/arm-ffa/arm-ffa-uclass.c new file mode 100644 index 0000000000..7d9695d289 --- /dev/null +++ b/drivers/firmware/arm-ffa/arm-ffa-uclass.c @@ -0,0 +1,16 @@ +// SPDX-License-Identifier: GPL-2.0+ +/* + * (C) Copyright 2022 ARM Limited + * Abdellatif El Khlifi abdellatif.elkhlifi@arm.com + */ + +#include <common.h> +#include <dm.h> +#include <asm/global_data.h> + +DECLARE_GLOBAL_DATA_PTR; + +UCLASS_DRIVER(ffa) = { + .name = "ffa", + .id = UCLASS_FFA, +}; diff --git a/drivers/firmware/arm-ffa/arm_ffa_prv.h b/drivers/firmware/arm-ffa/arm_ffa_prv.h new file mode 100644 index 0000000000..ad7430ada9 --- /dev/null +++ b/drivers/firmware/arm-ffa/arm_ffa_prv.h @@ -0,0 +1,205 @@ +/* SPDX-License-Identifier: GPL-2.0+ */ +/* + * (C) Copyright 2022 ARM Limited + * Abdellatif El Khlifi abdellatif.elkhlifi@arm.com + */ + +#ifndef __ARM_FFA_PRV_H +#define __ARM_FFA_PRV_H + +#include <arm_ffa.h> +#include <linux/bitfield.h> +#include <linux/bitops.h> +#include <linux/arm-smccc.h> + +/* + * This header is private. It is exclusively used by the FF-A driver + */ + +/* FF-A core driver name */ +#define FFA_DRV_NAME "arm_ffa" + +/* FF-A driver version definitions */ + +#define MAJOR_VERSION_MASK GENMASK(30, 16) +#define MINOR_VERSION_MASK GENMASK(15, 0) +#define GET_FFA_MAJOR_VERSION(x) \ + ((u16)(FIELD_GET(MAJOR_VERSION_MASK, (x)))) +#define GET_FFA_MINOR_VERSION(x) \ + ((u16)(FIELD_GET(MINOR_VERSION_MASK, (x)))) +#define PACK_VERSION_INFO(major, minor) \ + (FIELD_PREP(MAJOR_VERSION_MASK, (major)) | \ + FIELD_PREP(MINOR_VERSION_MASK, (minor))) + +#define FFA_MAJOR_VERSION (1) +#define FFA_MINOR_VERSION (0) +#define FFA_VERSION_1_0 \ + PACK_VERSION_INFO(FFA_MAJOR_VERSION, FFA_MINOR_VERSION) + +/* Endpoint ID mask (u-boot endpoint ID) */ + +#define GET_SELF_ENDPOINT_ID_MASK GENMASK(15, 0) +#define GET_SELF_ENDPOINT_ID(x) \ + ((u16)(FIELD_GET(GET_SELF_ENDPOINT_ID_MASK, (x)))) + +#define PREP_SELF_ENDPOINT_ID_MASK GENMASK(31, 16) +#define PREP_SELF_ENDPOINT_ID(x) \ + (FIELD_PREP(PREP_SELF_ENDPOINT_ID_MASK, (x))) + +/* Partition endpoint ID mask (partition with which u-boot communicates with) */ + +#define PREP_PART_ENDPOINT_ID_MASK GENMASK(15, 0) +#define PREP_PART_ENDPOINT_ID(x) \ + (FIELD_PREP(PREP_PART_ENDPOINT_ID_MASK, (x))) + +/* + * Definitions of the Arm FF-A interfaces supported by the Arm FF-A driver + */ + +#define FFA_SMC(calling_convention, func_num) \ + ARM_SMCCC_CALL_VAL(ARM_SMCCC_FAST_CALL, (calling_convention), \ + ARM_SMCCC_OWNER_STANDARD, (func_num)) + +#define FFA_SMC_32(func_num) FFA_SMC(ARM_SMCCC_SMC_32, (func_num)) +#define FFA_SMC_64(func_num) FFA_SMC(ARM_SMCCC_SMC_64, (func_num)) + +enum ffa_abis { + FFA_ERROR = 0x60, + FFA_SUCCESS = 0x61, + FFA_INTERRUPT = 0x62, + FFA_VERSION = 0x63, + FFA_FEATURES = 0x64, + FFA_RX_RELEASE = 0x65, + FFA_RXTX_MAP = 0x66, + FFA_RXTX_UNMAP = 0x67, + FFA_PARTITION_INFO_GET = 0x68, + FFA_ID_GET = 0x69, + FFA_RUN = 0x6D, + FFA_MSG_SEND_DIRECT_REQ = 0x6F, + FFA_MSG_SEND_DIRECT_RESP = 0x70, + + /* to be updated when adding new FFA IDs */ + FFA_FIRST_ID = FFA_ERROR, /* lowest number ID*/ + FFA_LAST_ID = FFA_MSG_SEND_DIRECT_RESP, /* highest number ID*/ +}; + +enum ffa_abi_errcode { + NOT_SUPPORTED = 1, + INVALID_PARAMETERS, + NO_MEMORY, + BUSY, + INTERRUPTED, + DENIED, + RETRY, + ABORTED, + MAX_NUMBER_FFA_ERR +}; + +/* container structure and helper macros to map between an FF-A error and relevant error log */ +struct ffa_abi_errmap { + char *err_str[MAX_NUMBER_FFA_ERR]; +}; + +#define FFA_ERRMAP_COUNT (FFA_LAST_ID - FFA_FIRST_ID + 1) +#define FFA_ID_TO_ERRMAP_ID(ffa_id) ((ffa_id) - FFA_FIRST_ID) + +/* The FF-A SMC function definitions */ + +typedef struct arm_smccc_1_2_regs ffa_value_t; +typedef void (*invoke_ffa_fn_t)(ffa_value_t args, ffa_value_t *res); + +/* + * struct ffa_partition_uuid - 16 bytes UUID transmitted by FFA_PARTITION_INFO_GET + * @a1-4: 32-bit words access to the UUID data + * + */ +struct ffa_partition_uuid { + u32 a1; /* w1 */ + u32 a2; /* w2 */ + u32 a3; /* w3 */ + u32 a4; /* w4 */ +}; + +/** + * enum ffa_rxtx_buf_sizes - minimum sizes supported + * for the RX/TX buffers + */ +enum ffa_rxtx_buf_sizes { + RXTX_4K, + RXTX_64K, + RXTX_16K +}; + +/** + * struct ffa_rxtxpair - structure hosting the RX/TX buffers virtual addresses + * @rxbuf: virtual address of the RX buffer + * @txbuf: virtual address of the TX buffer + * @rxtx_min_pages: RX/TX buffers minimum size in pages + * + * Data structure hosting the virtual addresses of the mapped RX/TX buffers + * These addresses are used by the FF-A functions that use the RX/TX buffers + */ +struct ffa_rxtxpair { + u64 rxbuf; /* virtual address */ + u64 txbuf; /* virtual address */ + size_t rxtx_min_pages; /* minimum number of pages in each of the RX/TX buffers */ +}; + +/** + * struct ffa_partition_desc - the secure partition descriptor + * @info: partition information + * @sp_uuid: the secure partition UUID + * + * Each partition has its descriptor containing the partitions information and the UUID + */ +struct ffa_partition_desc { + struct ffa_partition_info info; + struct ffa_partition_uuid sp_uuid; +}; + +/** + * struct ffa_partitions - descriptors for all secure partitions + * @count: The number of partitions descriptors + * @descs The partitions descriptors table + * + * This data structure contains the partitions descriptors table + */ +struct ffa_partitions { + u32 count; + struct ffa_partition_desc *descs; /* virtual address */ +}; + +/** + * struct ffa_prvdata - the driver private data structure + * + * @dev: The arm_ffa device under u-boot driver model + * @ffa_ops: The driver operations structure + * @fwk_version: FF-A framework version + * @id: u-boot endpoint ID + * @partitions: The partitions descriptors structure + * @pair: The RX/TX buffers pair + * @invoke_ffa_fn: The function executing the FF-A function + * + * The driver data structure hosting all resident data. + */ +struct ffa_prvdata { + struct udevice *dev; + struct ffa_bus_ops ffa_ops; + u32 fwk_version; + u16 id; + struct ffa_partitions partitions; + struct ffa_rxtxpair pair; + invoke_ffa_fn_t invoke_ffa_fn; +}; + +/** + * ffa_device_get - create, bind and probe the arm_ffa device + */ +int ffa_device_get(void); + +/** + * ffa_bus_prvdata_get - bus driver private data getter + */ +struct ffa_prvdata **ffa_bus_prvdata_get(void); + +#endif diff --git a/drivers/firmware/arm-ffa/core.c b/drivers/firmware/arm-ffa/core.c new file mode 100644 index 0000000000..b955e5187b --- /dev/null +++ b/drivers/firmware/arm-ffa/core.c @@ -0,0 +1,1310 @@ +// SPDX-License-Identifier: GPL-2.0+ +/* + * (C) Copyright 2022 ARM Limited + * Abdellatif El Khlifi abdellatif.elkhlifi@arm.com + */ + +#include "arm_ffa_prv.h" +#include <asm/global_data.h> +#include <common.h> +#include <dm.h> +#include <dm/device-internal.h> +#include <dm/devres.h> +#include <dm/root.h> +#include <linux/errno.h> +#include <linux/sizes.h> +#include <log.h> +#include <malloc.h> +#include <string.h> +#include <uuid.h> + +DECLARE_GLOBAL_DATA_PTR; + +/** + * The device private data structure containing all the + * data read from secure world + */ +struct ffa_prvdata *ffa_priv_data; + +/* Error mapping declarations */ + +int ffa_to_std_errmap[MAX_NUMBER_FFA_ERR] = { + [NOT_SUPPORTED] = -EOPNOTSUPP, + [INVALID_PARAMETERS] = -EINVAL, + [NO_MEMORY] = -ENOMEM, + [BUSY] = -EBUSY, + [INTERRUPTED] = -EINTR, + [DENIED] = -EACCES, + [RETRY] = -EAGAIN, + [ABORTED] = -ECANCELED, +}; + +struct ffa_abi_errmap err_msg_map[FFA_ERRMAP_COUNT] = { + [FFA_ID_TO_ERRMAP_ID(FFA_VERSION)] = { + { + [NOT_SUPPORTED] = + "NOT_SUPPORTED: A Firmware Framework implementation does not exist", + }, + }, + [FFA_ID_TO_ERRMAP_ID(FFA_ID_GET)] = { + { + [NOT_SUPPORTED] = + "NOT_SUPPORTED: This function is not implemented at this FF-A instance", + }, + }, + [FFA_ID_TO_ERRMAP_ID(FFA_FEATURES)] = { + { + [NOT_SUPPORTED] = + "NOT_SUPPORTED: FFA_RXTX_MAP is not implemented at this FF-A instance", + }, + }, + [FFA_ID_TO_ERRMAP_ID(FFA_PARTITION_INFO_GET)] = { + { + [NOT_SUPPORTED] = + "NOT_SUPPORTED: This function is not implemented at this FF-A instance", + [INVALID_PARAMETERS] = + "INVALID_PARAMETERS: Unrecognized UUID", + [NO_MEMORY] = + "NO_MEMORY: Results cannot fit in RX buffer of the caller", + [BUSY] = + "BUSY: RX buffer of the caller is not free", + [DENIED] = + "DENIED: Callee is not in a state to handle this request", + }, + }, + [FFA_ID_TO_ERRMAP_ID(FFA_RXTX_UNMAP)] = { + { + [NOT_SUPPORTED] = + "NOT_SUPPORTED: FFA_RXTX_UNMAP is not implemented at this FF-A instance", + [INVALID_PARAMETERS] = + "INVALID_PARAMETERS: No buffer pair registered on behalf of the caller", + }, + }, + [FFA_ID_TO_ERRMAP_ID(FFA_RX_RELEASE)] = { + { + [NOT_SUPPORTED] = + "NOT_SUPPORTED: FFA_RX_RELEASE is not implemented at this FF-A instance", + [DENIED] = + "DENIED: Caller did not have ownership of the RX buffer", + }, + }, + [FFA_ID_TO_ERRMAP_ID(FFA_RXTX_MAP)] = { + { + [NOT_SUPPORTED] = + "NOT_SUPPORTED: This function is not implemented at this FF-A instance", + [INVALID_PARAMETERS] = + "INVALID_PARAMETERS: Field(s) in input parameters incorrectly encoded", + [NO_MEMORY] = + "NO_MEMORY: Not enough memory", + [DENIED] = + "DENIED: Buffer pair already registered", + }, + }, +}; + +/** + * ffa_to_std_errno - convert FF-A error code to standard error code + * @ffa_errno: Error code returned by the FF-A ABI + * + * This function maps the given FF-A error code as specified + * by the spec to a u-boot standard error code. + * + * Return: + * + * The standard error code on success. . Otherwise, failure + */ +int ffa_to_std_errno(int ffa_errno) +{ + int err_idx = -ffa_errno; + + /* map the FF-A error code to the standard u-boot error code */ + if (err_idx > 0 && err_idx < MAX_NUMBER_FFA_ERR) + return ffa_to_std_errmap[err_idx]; + return -EINVAL; +} + +/** + * ffa_print_error_log - print the error log corresponding to the selected FF-A ABI + * @ffa_id: FF-A ABI ID + * @ffa_errno: Error code returned by the FF-A ABI + * + * This function maps the FF-A error code to the error log relevant to the + * selected FF-A ABI. Then the error log is printed. + * + * Return: + * + * 0 on success. . Otherwise, failure + */ +int ffa_print_error_log(u32 ffa_id, int ffa_errno) +{ + int err_idx = -ffa_errno, abi_idx = 0; + + /* map the FF-A error code to the corresponding error log */ + + if (err_idx <= 0 || err_idx >= MAX_NUMBER_FFA_ERR) + return -EINVAL; + + if (ffa_id < FFA_FIRST_ID || ffa_id > FFA_LAST_ID) + return -EINVAL; + + abi_idx = FFA_ID_TO_ERRMAP_ID(ffa_id); + if (abi_idx < 0 || abi_idx >= FFA_ERRMAP_COUNT) + return -EINVAL; + + if (!err_msg_map[abi_idx].err_str[err_idx]) + return -EINVAL; + + ffa_err("%s", err_msg_map[abi_idx].err_str[err_idx]); + + return 0; +} + +/* + * Driver core functions + */ + +/** + * ffa_remove_device - removes the arm_ffa device + * @dev: the device to be removed + * + * This function makes sure the arm_ffa device is removed + * No need to free the kmalloced data when the device is destroyed. + * It's automatically done by devm management by + * device_remove() -> device_free() -> devres_release_probe(). + * + * Return: + * + * 0 on success. Otherwise, failure + */ +int ffa_remove_device(struct udevice *dev) +{ + int ret; + + if (!dev) { + ffa_err("no udevice found"); + return -ENODEV; + } + + ret = device_remove(dev, DM_REMOVE_NORMAL); + if (ret) { + ffa_err("unable to remove. err:%d\n", ret); + return ret; + } + + ffa_info("device removed and freed"); + + ret = device_unbind(dev); + if (ret) { + ffa_err("unable to unbind. err:%d\n", ret); + return ret; + } + + ffa_info("device unbound"); + + return 0; +} + +/** + * ffa_device_get - create, bind and probe the arm_ffa device + * + * This function makes sure the arm_ffa device is + * created, bound to this driver, probed and ready to use. + * Arm FF-A transport is implemented through a single u-boot + * device managing the FF-A bus (arm_ffa). + * + * Return: + * + * 0 on success. Otherwise, failure + */ +int ffa_device_get(void) +{ + int ret; + struct udevice *dev = NULL; + + ret = device_bind(dm_root(), DM_DRIVER_GET(arm_ffa), FFA_DRV_NAME, NULL, ofnode_null(), + &dev); + if (ret) + return ret; + + /* The FF-A bus discovery succeeds when probing is successful */ + ret = device_probe(dev); + if (ret) { + ffa_err("arm_ffa device probing failed"); + ffa_remove_device(dev); + return ret; + } + + return 0; +} + +/** + * ffa_get_version - FFA_VERSION handler function + * + * This function implements FFA_VERSION FF-A function + * to get from the secure world the FF-A framework version + * + * Return: + * + * 0 on success. Otherwise, failure + */ +static int ffa_get_version(void) +{ + u16 major, minor; + ffa_value_t res = {0}; + int ffa_errno; + + ffa_priv_data->invoke_ffa_fn((ffa_value_t){ + .a0 = FFA_SMC_32(FFA_VERSION), .a1 = FFA_VERSION_1_0, + }, &res); + + ffa_errno = res.a0; + if (ffa_errno < 0) { + ffa_print_error_log(FFA_VERSION, ffa_errno); + return ffa_to_std_errno(ffa_errno); + } + + major = GET_FFA_MAJOR_VERSION(res.a0); + minor = GET_FFA_MINOR_VERSION(res.a0); + + ffa_info("FF-A driver %d.%d\nFF-A framework %d.%d", + FFA_MAJOR_VERSION, FFA_MINOR_VERSION, major, minor); + + if ((major == FFA_MAJOR_VERSION && minor >= FFA_MINOR_VERSION)) { + ffa_info("Versions are compatible "); + + ffa_priv_data->fwk_version = res.a0; + + return 0; + } + + ffa_err("versions are incompatible\nExpected: %d.%d , Found: %d.%d\n", + FFA_MAJOR_VERSION, FFA_MINOR_VERSION, major, minor); + + return -EPROTONOSUPPORT; +} + +/** + * ffa_get_endpoint_id - FFA_ID_GET handler function + * + * This function implements FFA_ID_GET FF-A function + * to get from the secure world u-boot endpoint ID + * + * Return: + * + * 0 on success. Otherwise, failure + */ +static int ffa_get_endpoint_id(void) +{ + ffa_value_t res = {0}; + int ffa_errno; + + ffa_priv_data->invoke_ffa_fn((ffa_value_t){ + .a0 = FFA_SMC_32(FFA_ID_GET), + }, &res); + + if (res.a0 == FFA_SMC_32(FFA_SUCCESS)) { + ffa_priv_data->id = GET_SELF_ENDPOINT_ID((u32)res.a2); + ffa_info("endpoint ID is %u", ffa_priv_data->id); + + return 0; + } + + ffa_errno = res.a2; + + ffa_print_error_log(FFA_ID_GET, ffa_errno); + + return ffa_to_std_errno(ffa_errno); +} + +/** + * ffa_set_rxtx_buffers_pages_cnt - sets the minimum number of pages in each of the RX/TX buffers + * @prop_field: properties field obtained from FFA_FEATURES ABI + * + * This function sets the minimum number of pages + * in each of the RX/TX buffers in the private data structure + * + * Return: + * + * buf_4k_pages points to the returned number of pages + * 0 on success. Otherwise, failure + */ +static int ffa_set_rxtx_buffers_pages_cnt(u32 prop_field) +{ + if (!ffa_priv_data) + return -EINVAL; + + switch (prop_field) { + case RXTX_4K: + ffa_priv_data->pair.rxtx_min_pages = 1; + break; + case RXTX_16K: + ffa_priv_data->pair.rxtx_min_pages = 4; + break; + case RXTX_64K: + ffa_priv_data->pair.rxtx_min_pages = 16; + break; + default: + ffa_err("RX/TX buffer size not supported"); + return -EINVAL; + } + + return 0; +} + +/** + * ffa_get_rxtx_map_features - FFA_FEATURES handler function with FFA_RXTX_MAP argument + * + * This function implements FFA_FEATURES FF-A function + * to retrieve the FFA_RXTX_MAP features + * + * Return: + * + * 0 on success. Otherwise, failure + */ +static int ffa_get_rxtx_map_features(void) +{ + ffa_value_t res = {0}; + int ffa_errno; + + ffa_priv_data->invoke_ffa_fn((ffa_value_t){ + .a0 = FFA_SMC_32(FFA_FEATURES), + .a1 = FFA_SMC_64(FFA_RXTX_MAP), + }, &res); + + if (res.a0 == FFA_SMC_32(FFA_SUCCESS)) + return ffa_set_rxtx_buffers_pages_cnt(res.a2); + + ffa_errno = res.a2; + ffa_print_error_log(FFA_FEATURES, ffa_errno); + + return ffa_to_std_errno(ffa_errno); +} + +/** + * ffa_free_rxtx_buffers - frees the RX/TX buffers + * + * This function frees the RX/TX buffers + * + */ +static void ffa_free_rxtx_buffers(void) +{ + ffa_info("Freeing RX/TX buffers"); + + if (ffa_priv_data->pair.rxbuf) { + free((void *)ffa_priv_data->pair.rxbuf); + ffa_priv_data->pair.rxbuf = 0; + } + + if (ffa_priv_data->pair.txbuf) { + free((void *)ffa_priv_data->pair.txbuf); + ffa_priv_data->pair.txbuf = 0; + } +} + +/** + * ffa_alloc_rxtx_buffers - allocates the RX/TX buffers + * + * This function is used by ffa_map_rxtx_buffers to allocate + * the RX/TX buffers before mapping them. The allocated memory is physically + * contiguous since memalign ends up calling malloc which allocates + * contiguous memory in u-boot. + * + * Return: + * + * 0 on success. Otherwise, failure + */ +static int ffa_alloc_rxtx_buffers(void) +{ + u64 bytes; + + ffa_info("Using %lu 4KB page(s) for RX/TX buffers size", + ffa_priv_data->pair.rxtx_min_pages); + + bytes = ffa_priv_data->pair.rxtx_min_pages * SZ_4K; + + /* + * The alignment of the RX and TX buffers must be equal + * to the larger translation granule size + */ + + ffa_priv_data->pair.rxbuf = (u64)memalign(bytes, bytes); + if (!ffa_priv_data->pair.rxbuf) { + ffa_err("failure to allocate RX buffer"); + return -ENOBUFS; + } + + ffa_info("RX buffer at virtual address 0x%llx", ffa_priv_data->pair.rxbuf); + + ffa_priv_data->pair.txbuf = (u64)memalign(bytes, bytes); + if (!ffa_priv_data->pair.txbuf) { + free((void *)ffa_priv_data->pair.rxbuf); + ffa_priv_data->pair.rxbuf = 0; + ffa_err("failure to allocate the TX buffer"); + return -ENOBUFS; + } + + ffa_info("TX buffer at virtual address 0x%llx", ffa_priv_data->pair.txbuf); + + /* + * make sure the buffers are cleared before use + */ + memset((void *)ffa_priv_data->pair.rxbuf, 0, bytes); + memset((void *)ffa_priv_data->pair.txbuf, 0, bytes); + + return 0; +} + +/** + * ffa_map_rxtx_buffers - FFA_RXTX_MAP handler function + * + * This function implements FFA_RXTX_MAP FF-A function + * to map the RX/TX buffers + * + * Return: + * + * 0 on success. Otherwise, failure + */ +static int ffa_map_rxtx_buffers(void) +{ + int ret; + ffa_value_t res = {0}; + int ffa_errno; + + ret = ffa_alloc_rxtx_buffers(); + if (ret) + return ret; + + /* + * we need to pass the physical addresses of the RX/TX buffers + * in u-boot physical/virtual mapping is 1:1 + * no need to convert from virtual to physical + */ + + ffa_priv_data->invoke_ffa_fn((ffa_value_t){ + .a0 = FFA_SMC_64(FFA_RXTX_MAP), + .a1 = ffa_priv_data->pair.txbuf, + .a2 = ffa_priv_data->pair.rxbuf, + .a3 = ffa_priv_data->pair.rxtx_min_pages, + }, &res); + + if (res.a0 == FFA_SMC_32(FFA_SUCCESS)) { + ffa_info("RX/TX buffers mapped"); + return 0; + } + + ffa_errno = res.a2; + ffa_print_error_log(FFA_RXTX_MAP, ffa_errno); + + ffa_free_rxtx_buffers(); + + return ffa_to_std_errno(ffa_errno); +} + +/** + * ffa_unmap_rxtx_buffers - FFA_RXTX_UNMAP handler function + * + * This function implements FFA_RXTX_UNMAP FF-A function + * to unmap the RX/TX buffers + * + * Return: + * + * 0 on success. Otherwise, failure + */ +static int ffa_unmap_rxtx_buffers(void) +{ + ffa_value_t res = {0}; + int ffa_errno; + + ffa_priv_data->invoke_ffa_fn((ffa_value_t){ + .a0 = FFA_SMC_32(FFA_RXTX_UNMAP), + .a1 = PREP_SELF_ENDPOINT_ID(ffa_priv_data->id), + }, &res); + + if (res.a0 == FFA_SMC_32(FFA_SUCCESS)) { + ffa_free_rxtx_buffers(); + return 0; + } + + ffa_errno = res.a2; + ffa_print_error_log(FFA_RXTX_UNMAP, ffa_errno); + + return ffa_to_std_errno(ffa_errno); +} + +/** + * ffa_release_rx_buffer - FFA_RX_RELEASE handler function + * + * This function invokes FFA_RX_RELEASE FF-A function + * to release the ownership of the RX buffer + * + * Return: + * + * 0 on success. Otherwise, failure + */ +static int ffa_release_rx_buffer(void) +{ + ffa_value_t res = {0}; + int ffa_errno; + + ffa_priv_data->invoke_ffa_fn((ffa_value_t){ + .a0 = FFA_SMC_32(FFA_RX_RELEASE), + }, &res); + + if (res.a0 == FFA_SMC_32(FFA_SUCCESS)) + return 0; + + ffa_errno = res.a2; + ffa_print_error_log(FFA_RX_RELEASE, ffa_errno); + + return ffa_to_std_errno(ffa_errno); +} + +/** + * ffa_uuid_are_identical - checks whether two given UUIDs are identical + * @uuid1: first UUID + * @uuid2: second UUID + * + * This function is used by ffa_read_partitions_info to search + * for a UUID in the partitions descriptors table + * + * Return: + * + * 1 when UUIDs match. Otherwise, 0 + */ +bool ffa_uuid_are_identical(const struct ffa_partition_uuid *uuid1, + const struct ffa_partition_uuid *uuid2) +{ + if (!uuid1 || !uuid2) + return 0; + + return !memcmp(uuid1, uuid2, sizeof(struct ffa_partition_uuid)); +} + +/** + * ffa_read_partitions_info - reads the data queried by FFA_PARTITION_INFO_GET + * and saves it in the private structure + * @count: The number of partitions queried + * @part_uuid: Pointer to the partition(s) UUID + * + * This function reads the partitions information + * returned by the FFA_PARTITION_INFO_GET and saves it in the private + * data structure. + * + * Return: + * + * The private data structure is updated with the partition(s) information + * 0 is returned on success. Otherwise, failure + */ +static int ffa_read_partitions_info(u32 count, struct ffa_partition_uuid *part_uuid) +{ + if (!count) { + ffa_err("no partition detected"); + return -ENODATA; + } + + ffa_info("Reading partitions data from the RX buffer"); + + if (!part_uuid) { + /* + * querying information of all partitions + */ + u64 buf_bytes; + u64 data_bytes; + u32 desc_idx; + struct ffa_partition_info *parts_info; + + data_bytes = count * sizeof(struct ffa_partition_desc); + + buf_bytes = ffa_priv_data->pair.rxtx_min_pages * SZ_4K; + + if (data_bytes > buf_bytes) { + ffa_err("partitions data size exceeds the RX buffer size:"); + ffa_err(" sizes in bytes: data %llu , RX buffer %llu ", + data_bytes, + buf_bytes); + + return -ENOMEM; + } + + ffa_priv_data->partitions.descs = devm_kmalloc(ffa_priv_data->dev, data_bytes, + __GFP_ZERO); + if (!ffa_priv_data->partitions.descs) { + ffa_err("cannot allocate partitions data buffer"); + return -ENOMEM; + } + + parts_info = (struct ffa_partition_info *)ffa_priv_data->pair.rxbuf; + + for (desc_idx = 0 ; desc_idx < count ; desc_idx++) { + ffa_priv_data->partitions.descs[desc_idx].info = + parts_info[desc_idx]; + + ffa_info("Partition ID %x : info cached", + ffa_priv_data->partitions.descs[desc_idx].info.id); + } + + ffa_priv_data->partitions.count = count; + + ffa_info("%d partition(s) found and cached", count); + + } else { + u32 rx_desc_idx, cached_desc_idx; + struct ffa_partition_info *parts_info; + u8 desc_found; + + parts_info = (struct ffa_partition_info *)ffa_priv_data->pair.rxbuf; + + /* + * search for the SP IDs read from the RX buffer + * in the already cached SPs. + * Update the UUID when ID found. + */ + for (rx_desc_idx = 0; rx_desc_idx < count ; rx_desc_idx++) { + desc_found = 0; + + /* + * search the current ID in the cached partitions + */ + for (cached_desc_idx = 0; + cached_desc_idx < ffa_priv_data->partitions.count; + cached_desc_idx++) { + /* + * save the UUID + */ + if (ffa_priv_data->partitions.descs[cached_desc_idx].info.id == + parts_info[rx_desc_idx].id) { + ffa_priv_data->partitions.descs[cached_desc_idx].sp_uuid = + *part_uuid; + + desc_found = 1; + break; + } + } + + if (!desc_found) + return -ENODATA; + } + } + + return 0; +} + +/** + * ffa_query_partitions_info - invokes FFA_PARTITION_INFO_GET and saves partitions data + * + * @part_uuid: Pointer to the partition(s) UUID + * @pcount: Pointer to the number of partitions variable filled when querying + * + * This function executes the FFA_PARTITION_INFO_GET + * to query the partitions data. Then, it calls ffa_read_partitions_info + * to save the data in the private data structure. + * + * After reading the data the RX buffer is released using ffa_release_rx_buffer + * + * Return: + * + * When part_uuid is NULL, all partitions data are retrieved from secure world + * When part_uuid is non NULL, data for partitions matching the given UUID are + * retrieved and the number of partitions is returned + * 0 is returned on success. Otherwise, failure + */ +static int ffa_query_partitions_info(struct ffa_partition_uuid *part_uuid, + u32 *pcount) +{ + struct ffa_partition_uuid query_uuid = {0}; + ffa_value_t res = {0}; + int ffa_errno; + + /* + * If a UUID is specified. Information for one or more + * partitions in the system is queried. Otherwise, information + * for all installed partitions is queried + */ + + if (part_uuid) { + if (!pcount) + return -EINVAL; + + query_uuid = *part_uuid; + } else if (pcount) { + return -EINVAL; + } + + ffa_priv_data->invoke_ffa_fn((ffa_value_t){ + .a0 = FFA_SMC_32(FFA_PARTITION_INFO_GET), + .a1 = query_uuid.a1, + .a2 = query_uuid.a2, + .a3 = query_uuid.a3, + .a4 = query_uuid.a4, + }, &res); + + if (res.a0 == FFA_SMC_32(FFA_SUCCESS)) { + int ret; + + /* + * res.a2 contains the count of partition information descriptors + * populated in the RX buffer + */ + if (res.a2) { + ret = ffa_read_partitions_info((u32)res.a2, part_uuid); + if (ret) { + ffa_err("failed to read partition(s) data , error (%d)", ret); + ffa_release_rx_buffer(); + return -EINVAL; + } + } + + /* + * return the SP count (when querying using a UUID) + */ + if (pcount) + *pcount = (u32)res.a2; + + /* + * After calling FFA_PARTITION_INFO_GET the buffer ownership + * is assigned to the consumer (u-boot). So, we need to give + * the ownership back to the SPM or hypervisor + */ + ret = ffa_release_rx_buffer(); + + return ret; + } + + ffa_errno = res.a2; + ffa_print_error_log(FFA_PARTITION_INFO_GET, ffa_errno); + + return ffa_to_std_errno(ffa_errno); +} + +/** + * ffa_get_partitions_info - FFA_PARTITION_INFO_GET handler function + * + * The passed arguments: + * Mode 1: When getting from the driver the number of + * secure partitions: + * @uuid_str: pointer to the UUID string + * @parts_size: pointer to the variable that contains the number of partitions + * The variable will be set by the driver + * @buffer: NULL + * + * Mode 2: When requesting the driver to return the + * partitions information: + * @uuid_str: pointer to the UUID string + * @parts_size: pointer to the size of the SPs information buffer in bytes + * @buffer: pointer to SPs information buffer + * (allocated by the client). + * The buffer will be filled by the driver + * + * This function queries the secure partition data from + * the private data structure. If not found, it invokes FFA_PARTITION_INFO_GET + * FF-A function to query the partition information from secure world. + * + * A client of the FF-A driver should know the UUID of the service it wants to + * access. It should use the UUID to request the FF-A driver to provide the + * partition(s) information of the service. The FF-A driver uses + * PARTITION_INFO_GET to obtain this information. This is implemented through + * ffa_get_partitions_info function. + * A new FFA_PARTITION_INFO_GET call is issued (first one performed through + * ffa_cache_partitions_info) allowing to retrieve the partition(s) information. + * They are not saved (already done). We only update the UUID in the cached area. + * This assumes that partitions data does not change in the secure world. + * Otherwise u-boot will have an outdated partition data. The benefit of caching + * the information in the FF-A driver is to accommodate discovery after + * ExitBootServices(). + * + * When invoked through a client request, ffa_get_partitions_info should be + * called twice. First call is to get from the driver the number of secure + * partitions (SPs) associated to a particular UUID. + * Then, the caller (client) allocates the buffer to host the SPs data and + * issues a 2nd call. Then, the driver fills the SPs data in the pre-allocated + * buffer. + * + * To achieve the mechanism described above, ffa_get_partitions_info uses the + * following functions: + * ffa_read_partitions_info + * ffa_query_partitions_info + * + * Return: + * + * @parts_size: When pointing to the number of partitions variable, the number is + * set by the driver. + * When pointing to the partitions information buffer size, the buffer will be + * filled by the driver. + * + * On success 0 is returned. Otherwise, failure + */ +static int ffa_get_partitions_info(const char *uuid_str, + u32 *parts_size, struct ffa_partition_info *buffer) +{ + /* + * fill_data: + * 0: return the SP count + * 1: fill SP data and return it to the caller + * -1: undefined mode + */ + int fill_data = -1; + u32 desc_idx, client_desc_idx; + struct ffa_partition_uuid part_uuid = {0}; + u32 client_desc_max_cnt; + u32 parts_found = 0; + + if (!ffa_priv_data->partitions.count || !ffa_priv_data->partitions.descs) { + ffa_err("no partition installed"); + return -EINVAL; + } + + if (!uuid_str) { + ffa_err("no UUID provided"); + return -EINVAL; + } + + if (!parts_size) { + ffa_err("no size/count provided"); + return -EINVAL; + } + + if (uuid_str_to_le_bin(uuid_str, (unsigned char *)&part_uuid)) { + ffa_err("invalid UUID"); + return -EINVAL; + } + + if (!buffer) { + /* Mode 1: getting the number of secure partitions */ + + fill_data = 0; + + ffa_info("Preparing for checking partitions count"); + + } else if ((*parts_size >= sizeof(struct ffa_partition_info)) && + !(*parts_size % sizeof(struct ffa_partition_info))) { + /* Mode 2: retrieving the partitions information */ + + fill_data = 1; + + client_desc_idx = 0; + + /* + * number of empty descriptors preallocated by the caller + */ + client_desc_max_cnt = *parts_size / sizeof(struct ffa_partition_info); + + ffa_info("Preparing for filling partitions info"); + + } else { + ffa_err("invalid function arguments provided"); + return -EINVAL; + } + + ffa_info("Searching partitions using the provided UUID"); + + /* + * search in the cached partitions + */ + for (desc_idx = 0; + desc_idx < ffa_priv_data->partitions.count; + desc_idx++) { + if (ffa_uuid_are_identical(&ffa_priv_data->partitions.descs[desc_idx].sp_uuid, + &part_uuid)) { + ffa_info("Partition ID %x matches the provided UUID", + ffa_priv_data->partitions.descs[desc_idx].info.id); + + parts_found++; + + if (fill_data) { + /* + * trying to fill the partition info in the input buffer + */ + + if (client_desc_idx < client_desc_max_cnt) { + buffer[client_desc_idx++] = + ffa_priv_data->partitions.descs[desc_idx].info; + continue; + } + + ffa_err("failed to fill the current descriptor client buffer full"); + return -ENOBUFS; + } + } + } + + if (!parts_found) { + int ret; + + ffa_info("No partition found. Querying framework ..."); + + ret = ffa_query_partitions_info(&part_uuid, &parts_found); + + if (ret == 0) { + if (!fill_data) { + *parts_size = parts_found; + + ffa_info("Number of partition(s) found matching the UUID: %d", + parts_found); + } else { + /* + * If SPs data detected, they are already in the private data + * structure, retry searching SP data again to return them + * to the caller + */ + if (parts_found) + ret = ffa_get_partitions_info(uuid_str, parts_size, buffer); + else + ret = -ENODATA; + } + } + + return ret; + } + + /* partition(s) found */ + if (!fill_data) + *parts_size = parts_found; + + return 0; +} + +/** + * ffa_cache_partitions_info - Queries and saves all secure partitions data + * + * This function invokes FFA_PARTITION_INFO_GET FF-A + * function to query from secure world all partitions information. + * + * The FFA_PARTITION_INFO_GET call is issued with nil UUID as an argument. + * All installed partitions information are returned. We cache them in the + * resident private data structure and we keep the UUID field empty + * (in FF-A 1.0 UUID is not provided by the partition descriptor) + * + * This function is called at the device probing level. + * ffa_cache_partitions_info uses ffa_query_partitions_info to get the data + * + * Return: + * + * 0 on success. Otherwise, failure + */ +static int ffa_cache_partitions_info(void) +{ + return ffa_query_partitions_info(NULL, NULL); +} + +/** + * ffa_msg_send_direct_req - FFA_MSG_SEND_DIRECT_{REQ,RESP} handler function + * @dst_part_id: destination partition ID + * @msg: pointer to the message data preallocated by the client (in/out) + * @is_smc64: select 64-bit or 32-bit FF-A ABI + * + * This function implements FFA_MSG_SEND_DIRECT_{REQ,RESP} + * FF-A functions. + * + * FFA_MSG_SEND_DIRECT_REQ is used to send the data to the secure partition. + * The response from the secure partition is handled by reading the + * FFA_MSG_SEND_DIRECT_RESP arguments. + * + * The maximum size of the data that can be exchanged is 40 bytes which is + * sizeof(struct ffa_send_direct_data) as defined by the FF-A specification 1.0 + * in the section relevant to FFA_MSG_SEND_DIRECT_{REQ,RESP} + * + * Return: + * + * 0 on success. Otherwise, failure + */ +static int ffa_msg_send_direct_req(u16 dst_part_id, struct ffa_send_direct_data *msg, bool is_smc64) +{ + ffa_value_t res = {0}; + int ffa_errno; + u64 req_mode, resp_mode; + + if (!ffa_priv_data || !ffa_priv_data->invoke_ffa_fn) + return -EINVAL; + + /* No partition installed */ + if (!ffa_priv_data->partitions.count || !ffa_priv_data->partitions.descs) + return -ENODEV; + + if (is_smc64) { + req_mode = FFA_SMC_64(FFA_MSG_SEND_DIRECT_REQ); + resp_mode = FFA_SMC_64(FFA_MSG_SEND_DIRECT_RESP); + } else { + req_mode = FFA_SMC_32(FFA_MSG_SEND_DIRECT_REQ); + resp_mode = FFA_SMC_32(FFA_MSG_SEND_DIRECT_RESP); + } + + ffa_priv_data->invoke_ffa_fn((ffa_value_t){ + .a0 = req_mode, + .a1 = PREP_SELF_ENDPOINT_ID(ffa_priv_data->id) | + PREP_PART_ENDPOINT_ID(dst_part_id), + .a2 = 0, + .a3 = msg->data0, + .a4 = msg->data1, + .a5 = msg->data2, + .a6 = msg->data3, + .a7 = msg->data4, + }, &res); + + while (res.a0 == FFA_SMC_32(FFA_INTERRUPT)) + ffa_priv_data->invoke_ffa_fn((ffa_value_t){ + .a0 = FFA_SMC_32(FFA_RUN), + .a1 = res.a1, + }, &res); + + if (res.a0 == FFA_SMC_32(FFA_SUCCESS)) { + /* Message sent with no response */ + return 0; + } + + if (res.a0 == resp_mode) { + /* + * Message sent with response + * extract the return data + */ + msg->data0 = res.a3; + msg->data1 = res.a4; + msg->data2 = res.a5; + msg->data3 = res.a6; + msg->data4 = res.a7; + + return 0; + } + + ffa_errno = res.a2; + return ffa_to_std_errno(ffa_errno); +} + +/** + * __arm_ffa_fn_smc - SMC wrapper + * @args: FF-A ABI arguments to be copied to Xn registers + * @res: FF-A ABI return data to be copied from Xn registers + * + * Calls low level SMC assembly function + * + * Return: void + */ +void __arm_ffa_fn_smc(ffa_value_t args, ffa_value_t *res) +{ + arm_smccc_1_2_smc(&args, res); +} + +/** + * ffa_set_smc_conduit - Set the SMC conduit + * + * This function selects the SMC conduit by setting the driver invoke function + * to SMC assembly function + * + * Return: + * + * 0 on success. Otherwise, failure + */ +static int ffa_set_smc_conduit(void) +{ + ffa_priv_data->invoke_ffa_fn = __arm_ffa_fn_smc; + + if (!ffa_priv_data->invoke_ffa_fn) { + ffa_err("failure to set the invoke function"); + return -EINVAL; + } + + ffa_info("Conduit is SMC"); + + return 0; +} + +/** + * ffa_set_bus_ops - Set the bus driver operations + * + * Setting the driver callbacks. + * + */ +static void ffa_set_bus_ops(void) +{ + ffa_priv_data->ffa_ops.partition_info_get = ffa_get_partitions_info; + ffa_priv_data->ffa_ops.sync_send_receive = ffa_msg_send_direct_req; + ffa_priv_data->ffa_ops.rxtx_unmap = ffa_unmap_rxtx_buffers; +} + +/** + * ffa_alloc_prvdata - allocate the driver main data structure and sets the device + * @dev: the arm_ffa device + * + * This function creates the main data structure embedding all the driver data. + * + * Return: + * + * 0 on success. Otherwise, failure + */ +static int ffa_alloc_prvdata(struct udevice *dev) +{ + if (!dev) { + ffa_err("no udevice found"); + return -ENODEV; + } + + /* The device is registered with the DM. Let's create the driver main data structure*/ + + ffa_priv_data = devm_kmalloc(dev, sizeof(struct ffa_prvdata), __GFP_ZERO); + if (!ffa_priv_data) { + ffa_err("can not allocate the driver main data structure"); + return -ENOMEM; + } + + ffa_priv_data->dev = dev; + + return 0; +} + +/** + * ffa_probe - The driver probe function + * @dev: the arm_ffa device + * + * Probing is done at boot time and triggered by the uclass device discovery. + * At probe level the following actions are done: + * - setting the conduit + * - querying the FF-A framework version + * - querying from secure world the u-boot endpoint ID + * - querying from secure world the supported features of FFA_RXTX_MAP + * - mapping the RX/TX buffers + * - querying from secure world all the partitions information + * + * All data queried from secure world is saved in the resident private data structure. + * + * The probe will fail if either FF-A framework is not detected or the + * FF-A requests are not behaving correctly. This ensures that the + * driver is not installed and its operations are not exported to the clients. + * + * Return: + * + * 0 on success. Otherwise, failure + */ +static int ffa_probe(struct udevice *dev) +{ + int ret; + + ret = ffa_alloc_prvdata(dev); + if (ret != 0) + return ret; + + ffa_set_bus_ops(); + + ret = ffa_set_smc_conduit(); + if (ret != 0) + return ret; + + ret = ffa_get_version(); + if (ret != 0) + return ret; + + ret = ffa_get_endpoint_id(); + if (ret != 0) + return ret; + + ret = ffa_get_rxtx_map_features(); + if (ret != 0) + return ret; + + ret = ffa_map_rxtx_buffers(); + if (ret != 0) + return ret; + + ret = ffa_cache_partitions_info(); + if (ret != 0) { + ffa_free_rxtx_buffers(); + return ret; + } + + return 0; +} + +/** + * ffa_remove - The driver remove function + * @dev: the arm_ffa device + * When the device is about to be removed , unmap the RX/TX buffers and free the memory + * Return: + * + * 0 on success. + */ +static int ffa_remove(struct udevice *dev) +{ + ffa_info("removing the device"); + + ffa_unmap_rxtx_buffers(); + + if (ffa_priv_data->pair.rxbuf || ffa_priv_data->pair.txbuf) + ffa_free_rxtx_buffers(); + + return 0; +} + +/** + * ffa_unbind - The driver unbind function + * @dev: the arm_ffa device + * After the device is removed and memory freed the device is unbound + * Return: + * + * 0 on success. + */ +static int ffa_unbind(struct udevice *dev) +{ + ffa_info("unbinding the device , private data already released"); + + ffa_priv_data = NULL; + + return 0; +} + +/** + * ffa_bus_ops_get - bus driver operations getter + * + * Return: + * This function returns a pointer to the driver operations structure + */ +const struct ffa_bus_ops *ffa_bus_ops_get(void) +{ + return &ffa_priv_data->ffa_ops; +} + +/** + * ffa_bus_prvdata_get - bus driver private data getter + * + * Return: + * This function returns a pointer to the main private data structure + */ +struct ffa_prvdata **ffa_bus_prvdata_get(void) +{ + return &ffa_priv_data; +} + +/** + * ffa_bus_discover - discover FF-A bus and probe the arm_ffa device + * + * This function makes sure the FF-A bus is discoverable. + * When probing succeeds FF-A discovery is done. The arm_ffa device is ready to use. + * + * When the bus was already discovered successfully the discovery will not run again. + * + * Arm FF-A transport is implemented through arm_ffa u-boot device managing the FF-A + * communication. + * All FF-A clients should use the arm_ffa device to use the FF-A transport. + * + * Return: + * + * 0 on success. Otherwise, failure + */ +int ffa_bus_discover(void) +{ + int ret = 0; + + if (!ffa_priv_data) + ret = ffa_device_get(); + + return ret; +} + +/** + * Declaring the arm_ffa driver under UCLASS_FFA + */ + +U_BOOT_DRIVER(arm_ffa) = { + .name = FFA_DRV_NAME, + .id = UCLASS_FFA, + .probe = ffa_probe, + .remove = ffa_remove, + .unbind = ffa_unbind, +}; diff --git a/include/arm_ffa.h b/include/arm_ffa.h new file mode 100644 index 0000000000..b0c8a18926 --- /dev/null +++ b/include/arm_ffa.h @@ -0,0 +1,93 @@ +/* SPDX-License-Identifier: GPL-2.0+ */ +/* + * (C) Copyright 2022 ARM Limited + * Abdellatif El Khlifi abdellatif.elkhlifi@arm.com + */ + +#ifndef __ARM_FFA_H +#define __ARM_FFA_H + +#include <linux/printk.h> + +/* + * This header is public. It can be used by clients to access + * data structures and definitions they need + */ + +/* + * Macros for displaying logs + */ + +#define ffa_info(fmt, ...) pr_info("[FFA] " fmt "\n", ##__VA_ARGS__) +#define ffa_err(fmt, ...) pr_err("[FFA] " fmt "\n", ##__VA_ARGS__) + +/* + * struct ffa_partition_info - Partition information descriptor + * @id: Partition ID + * @exec_ctxt: Execution context count + * @properties: Partition properties + * + * Data structure containing information about partitions instantiated in the system + * This structure is filled with the data queried by FFA_PARTITION_INFO_GET + */ +struct __packed ffa_partition_info { + u16 id; + u16 exec_ctxt; +/* partition supports receipt of direct requests */ +#define FFA_PARTITION_DIRECT_RECV BIT(0) +/* partition can send direct requests. */ +#define FFA_PARTITION_DIRECT_SEND BIT(1) +/* partition can send and receive indirect messages. */ +#define FFA_PARTITION_INDIRECT_MSG BIT(2) + u32 properties; +}; + +/* + * struct ffa_send_direct_data - Data structure hosting the data + * used by FFA_MSG_SEND_DIRECT_{REQ,RESP} + * @data0-4: Data read/written from/to x3-x7 registers + * + * Data structure containing the data to be sent by FFA_MSG_SEND_DIRECT_REQ + * or read from FFA_MSG_SEND_DIRECT_RESP + */ + +/* For use with FFA_MSG_SEND_DIRECT_{REQ,RESP} which pass data via registers */ +struct __packed ffa_send_direct_data { + unsigned long data0; /* w3/x3 */ + unsigned long data1; /* w4/x4 */ + unsigned long data2; /* w5/x5 */ + unsigned long data3; /* w6/x6 */ + unsigned long data4; /* w7/x7 */ +}; + +/** + * struct ffa_bus_ops - The driver operations structure + * @partition_info_get: callback for the FFA_PARTITION_INFO_GET + * @sync_send_receive: callback for the FFA_MSG_SEND_DIRECT_REQ + * @rxtx_unmap: callback for the FFA_RXTX_UNMAP + * + * The data structure providing all the operations supported by the driver. + * This structure is EFI runtime resident. + */ +struct ffa_bus_ops { + int (*partition_info_get)(const char *uuid_str, + u32 *parts_size, struct ffa_partition_info *buffer); + int (*sync_send_receive)(u16 dst_part_id, struct ffa_send_direct_data *msg, bool is_smc64); + int (*rxtx_unmap)(void); +}; + +/** + * The device driver and the Uclass driver public functions + */ + +/** + * ffa_bus_ops_get - driver operations getter + */ +const struct ffa_bus_ops *ffa_bus_ops_get(void); + +/** + * ffa_bus_discover - discover FF-A bus and probes the arm_ffa device + */ +int ffa_bus_discover(void); + +#endif diff --git a/include/dm/uclass-id.h b/include/dm/uclass-id.h index 4b2c323452..fb59d4f356 100644 --- a/include/dm/uclass-id.h +++ b/include/dm/uclass-id.h @@ -4,6 +4,9 @@ * * (C) Copyright 2012 * Pavel Herrmann morpheus.ibis@gmail.com + * + * (C) Copyright 2022 ARM Limited + * Abdellatif El Khlifi abdellatif.elkhlifi@arm.com */
#ifndef _DM_UCLASS_ID_H @@ -55,6 +58,7 @@ enum uclass_id { UCLASS_EFI_MEDIA, /* Devices provided by UEFI firmware */ UCLASS_ETH, /* Ethernet device */ UCLASS_ETH_PHY, /* Ethernet PHY device */ + UCLASS_FFA, /* Arm Firmware Framework for Armv8-A */ UCLASS_FIRMWARE, /* Firmware */ UCLASS_FPGA, /* FPGA device */ UCLASS_FUZZING_ENGINE, /* Fuzzing engine */
- sync_send_receive
- rxtx_unmap
Signed-off-by: Abdellatif El Khlifi abdellatif.elkhlifi@arm.com Cc: Tom Rini trini@konsulko.com Cc: Simon Glass sjg@chromium.org Cc: Ilias Apalodimas ilias.apalodimas@linaro.org Cc: Jens Wiklander jens.wiklander@linaro.org
Changelog:
v7:
- add support for 32-bit direct messaging
- rename be_uuid_str_to_le_bin() to uuid_str_to_le_bin()
- improve the declaration of error handling mapping
- stating in doc/arch/arm64.ffa.rst that EFI runtime is not supported
v6:
- drop use of EFI runtime support (We decided with Linaro to add this later)
- drop discovery from initcalls (discovery will be on demand by FF-A users)
- set the alignment of the RX/TX buffers to the larger translation granule size
- move FF-A RX/TX buffers unmapping at ExitBootServices() to a separate commit
- update the documentation and move it to doc/arch/arm64.ffa.rst
v4:
- add doc/README.ffa.drv
- moving the FF-A driver work to drivers/firmware/arm-ffa
- use less #ifdefs in lib/efi_loader/efi_boottime.c and replace #if defined by #if CONFIG_IS_ENABLED
- improving error handling by mapping the FF-A errors to standard errors and logs
- replacing panics with an error log and returning an error code
- improving features discovery in FFA_FEATURES by introducing rxtx_min_pages private data field
- add ffa_remove and ffa_unbind functions
- improve how the driver behaves when bus discovery is done more than once
v3:
- align the interfaces of the U-Boot FF-A driver with those in the linux FF-A driver
- remove the FF-A helper layer
- make the U-Boot FF-A driver independent from EFI
- provide an optional config that enables copying the driver data to EFI runtime section at ExitBootServices service
- use 64-bit version of FFA_RXTX_MAP, FFA_MSG_SEND_DIRECT_{REQ, RESP}
v2:
- make FF-A bus discoverable using device_{bind, probe} APIs
- remove device tree support
v1:
- introduce FF-A bus driver with device tree support
+Summary +-------
- e.g. EFI MM communication protocol
+Aarch64 plaforms
- Enables the FF-A bus driver. Turn this on if you want to use FF-A
- communication.
+CONFIG_SANDBOX_FFA
- Enables FF-A Sandbox driver. This emulates the FF-A ABIs handling under
- Sandbox and provides functional tests for FF-A.
- layers focus on exchanged data, the driver takes care of how to transport
- that to the secure world/hypervisor using FF-A
- with the driver
+Usage:
+sub-commands:
ping <partition ID>
devlist
- Abdellatif El Khlifi abdellatif.elkhlifi@arm.com
arc arm64
- arm64.ffa m68k mips nios2
- bool "Enable Arm Firmware Framework for Armv8-A driver"
- depends on DM && ARM64
- select ARM_SMCCC
- select LIB_UUID
- select DEVRES
- help
technology.
calling convention.
FF-A specification:
using the FF-A bus.
and Secure World.
- (C) Copyright 2022 ARM Limited
- .name = "ffa",
- .id = UCLASS_FFA,
- This header is private. It is exclusively used by the FF-A driver
- (FIELD_PREP(MAJOR_VERSION_MASK, (major)) | \
- Definitions of the Arm FF-A interfaces supported by the Arm FF-A driver
- ARM_SMCCC_CALL_VAL(ARM_SMCCC_FAST_CALL, (calling_convention), \
+enum ffa_abis {
- FFA_ERROR = 0x60,
- FFA_SUCCESS = 0x61,
- FFA_INTERRUPT = 0x62,
- FFA_VERSION = 0x63,
- FFA_FEATURES = 0x64,
- FFA_RX_RELEASE = 0x65,
- FFA_RXTX_MAP = 0x66,
- FFA_RXTX_UNMAP = 0x67,
- FFA_PARTITION_INFO_GET = 0x68,
- FFA_ID_GET = 0x69,
- FFA_RUN = 0x6D,
- FFA_MSG_SEND_DIRECT_REQ = 0x6F,
- FFA_MSG_SEND_DIRECT_RESP = 0x70,
Strange indentation above.
- /* to be updated when adding new FFA IDs */
- FFA_FIRST_ID = FFA_ERROR, /* lowest number ID*/
- FFA_LAST_ID = FFA_MSG_SEND_DIRECT_RESP, /* highest number ID*/
- NOT_SUPPORTED = 1,
- INVALID_PARAMETERS,
- NO_MEMORY,
- BUSY,
- INTERRUPTED,
- DENIED,
- RETRY,
- ABORTED,
- MAX_NUMBER_FFA_ERR
- char *err_str[MAX_NUMBER_FFA_ERR];
- struct ffa_partition_uuid - 16 bytes UUID transmitted by FFA_PARTITION_INFO_GET
- @a1-4: 32-bit words access to the UUID data
- u32 a1; /* w1 */
- u32 a2; /* w2 */
- u32 a3; /* w3 */
- u32 a4; /* w4 */
- enum ffa_rxtx_buf_sizes - minimum sizes supported
- for the RX/TX buffers
- RXTX_4K,
- RXTX_64K,
- RXTX_16K
- struct ffa_rxtxpair - structure hosting the RX/TX buffers virtual addresses
- @rxbuf: virtual address of the RX buffer
- @txbuf: virtual address of the TX buffer
- @rxtx_min_pages: RX/TX buffers minimum size in pages
- Data structure hosting the virtual addresses of the mapped RX/TX buffers
- These addresses are used by the FF-A functions that use the RX/TX buffers
- u64 rxbuf; /* virtual address */
- u64 txbuf; /* virtual address */
- size_t rxtx_min_pages; /* minimum number of pages in each of the RX/TX buffers */
- struct ffa_partition_desc - the secure partition descriptor
- @info: partition information
- @sp_uuid: the secure partition UUID
- Each partition has its descriptor containing the partitions information and the UUID
- struct ffa_partition_info info;
- struct ffa_partition_uuid sp_uuid;
- struct ffa_partitions - descriptors for all secure partitions
- @count: The number of partitions descriptors
- @descs The partitions descriptors table
- This data structure contains the partitions descriptors table
- u32 count;
- struct ffa_partition_desc *descs; /* virtual address */
- struct ffa_prvdata - the driver private data structure
- @dev: The arm_ffa device under u-boot driver model
- @ffa_ops: The driver operations structure
- @fwk_version: FF-A framework version
- @id: u-boot endpoint ID
- @partitions: The partitions descriptors structure
- @pair: The RX/TX buffers pair
- @invoke_ffa_fn: The function executing the FF-A function
- The driver data structure hosting all resident data.
- struct udevice *dev;
- struct ffa_bus_ops ffa_ops;
- u32 fwk_version;
- u16 id;
- struct ffa_partitions partitions;
- struct ffa_rxtxpair pair;
- invoke_ffa_fn_t invoke_ffa_fn;
- ffa_device_get - create, bind and probe the arm_ffa device
- ffa_bus_prvdata_get - bus driver private data getter
- The device private data structure containing all the
- data read from secure world
- [NOT_SUPPORTED] = -EOPNOTSUPP,
- [INVALID_PARAMETERS] = -EINVAL,
- [NO_MEMORY] = -ENOMEM,
- [BUSY] = -EBUSY,
- [INTERRUPTED] = -EINTR,
- [DENIED] = -EACCES,
- [RETRY] = -EAGAIN,
- [ABORTED] = -ECANCELED,
- [FFA_ID_TO_ERRMAP_ID(FFA_VERSION)] = {
[NOT_SUPPORTED] =
- [FFA_ID_TO_ERRMAP_ID(FFA_ID_GET)] = {
[NOT_SUPPORTED] =
- [FFA_ID_TO_ERRMAP_ID(FFA_FEATURES)] = {
[NOT_SUPPORTED] =
- [FFA_ID_TO_ERRMAP_ID(FFA_PARTITION_INFO_GET)] = {
[NOT_SUPPORTED] =
[NO_MEMORY] =
[BUSY] =
[DENIED] =
- [FFA_ID_TO_ERRMAP_ID(FFA_RXTX_UNMAP)] = {
[NOT_SUPPORTED] =
- [FFA_ID_TO_ERRMAP_ID(FFA_RX_RELEASE)] = {
[NOT_SUPPORTED] =
[DENIED] =
- [FFA_ID_TO_ERRMAP_ID(FFA_RXTX_MAP)] = {
[NOT_SUPPORTED] =
[NO_MEMORY] =
[DENIED] =
Indentation above looks strange and inconsistent in some places. This entire approach is in my opinion a bit complicated, no big deal, if no one else complains I suppose it's OK.
- ffa_to_std_errno - convert FF-A error code to standard error code
- @ffa_errno: Error code returned by the FF-A ABI
- This function maps the given FF-A error code as specified
- by the spec to a u-boot standard error code.
- Return:
- The standard error code on success. . Otherwise, failure
- int err_idx = -ffa_errno;
- /* map the FF-A error code to the standard u-boot error code */
- if (err_idx > 0 && err_idx < MAX_NUMBER_FFA_ERR)
- return -EINVAL;
- ffa_print_error_log - print the error log corresponding to the selected FF-A ABI
- @ffa_id: FF-A ABI ID
- This function maps the FF-A error code to the error log relevant to the
- selected FF-A ABI. Then the error log is printed.
- Return:
- 0 on success. . Otherwise, failure
- int err_idx = -ffa_errno, abi_idx = 0;
- /* map the FF-A error code to the corresponding error log */
- if (err_idx <= 0 || err_idx >= MAX_NUMBER_FFA_ERR)
return -EINVAL;
- if (ffa_id < FFA_FIRST_ID || ffa_id > FFA_LAST_ID)
return -EINVAL;
- abi_idx = FFA_ID_TO_ERRMAP_ID(ffa_id);
- if (abi_idx < 0 || abi_idx >= FFA_ERRMAP_COUNT)
return -EINVAL;
- if (!err_msg_map[abi_idx].err_str[err_idx])
return -EINVAL;
- ffa_err("%s", err_msg_map[abi_idx].err_str[err_idx]);
- Driver core functions
- ffa_remove_device - removes the arm_ffa device
- @dev: the device to be removed
- This function makes sure the arm_ffa device is removed
- No need to free the kmalloced data when the device is destroyed.
- It's automatically done by devm management by
- device_remove() -> device_free() -> devres_release_probe().
- Return:
- 0 on success. Otherwise, failure
- int ret;
- if (!dev) {
return -ENODEV;
- ret = device_remove(dev, DM_REMOVE_NORMAL);
- if (ret) {
return ret;
- ffa_info("device removed and freed");
- ret = device_unbind(dev);
- if (ret) {
return ret;
- ffa_info("device unbound");
- created, bound to this driver, probed and ready to use.
- Arm FF-A transport is implemented through a single u-boot
- device managing the FF-A bus (arm_ffa).
- Return:
- int ret;
- struct udevice *dev = NULL;
- ret = device_bind(dm_root(), DM_DRIVER_GET(arm_ffa), FFA_DRV_NAME, NULL, ofnode_null(),
&dev);
- if (ret)
return ret;
- /* The FF-A bus discovery succeeds when probing is successful */
- ret = device_probe(dev);
- if (ret) {
return ret;
- ffa_get_version - FFA_VERSION handler function
- This function implements FFA_VERSION FF-A function
- to get from the secure world the FF-A framework version
- Return:
- u16 major, minor;
- ffa_value_t res = {0};
- int ffa_errno;
- ffa_priv_data->invoke_ffa_fn((ffa_value_t){
}, &res);
- ffa_errno = res.a0;
- if (ffa_errno < 0) {
- major = GET_FFA_MAJOR_VERSION(res.a0);
- minor = GET_FFA_MINOR_VERSION(res.a0);
- ffa_info("FF-A driver %d.%d\nFF-A framework %d.%d",
- if ((major == FFA_MAJOR_VERSION && minor >= FFA_MINOR_VERSION)) {
- ffa_err("versions are incompatible\nExpected: %d.%d , Found: %d.%d\n",
- return -EPROTONOSUPPORT;
- ffa_get_endpoint_id - FFA_ID_GET handler function
- This function implements FFA_ID_GET FF-A function
- to get from the secure world u-boot endpoint ID
- Return:
- int ffa_errno;
}, &res);
- if (res.a0 == FFA_SMC_32(FFA_SUCCESS)) {
- ffa_errno = res.a2;
- ffa_print_error_log(FFA_ID_GET, ffa_errno);
- return ffa_to_std_errno(ffa_errno);
- ffa_set_rxtx_buffers_pages_cnt - sets the minimum number of pages in each of the RX/TX buffers
- @prop_field: properties field obtained from FFA_FEATURES ABI
- This function sets the minimum number of pages
- in each of the RX/TX buffers in the private data structure
- Return:
- buf_4k_pages points to the returned number of pages
- if (!ffa_priv_data)
return -EINVAL;
- switch (prop_field) {
- case RXTX_4K:
break;
- case RXTX_16K:
break;
- case RXTX_64K:
break;
- default:
return -EINVAL;
- ffa_get_rxtx_map_features - FFA_FEATURES handler function with FFA_RXTX_MAP argument
- This function implements FFA_FEATURES FF-A function
- to retrieve the FFA_RXTX_MAP features
- Return:
- int ffa_errno;
}, &res);
- ffa_print_error_log(FFA_FEATURES, ffa_errno);
- ffa_free_rxtx_buffers - frees the RX/TX buffers
- This function frees the RX/TX buffers
- ffa_info("Freeing RX/TX buffers");
- if (ffa_priv_data->pair.rxbuf) {
- if (ffa_priv_data->pair.txbuf) {
- ffa_alloc_rxtx_buffers - allocates the RX/TX buffers
- This function is used by ffa_map_rxtx_buffers to allocate
- the RX/TX buffers before mapping them. The allocated memory is physically
- contiguous since memalign ends up calling malloc which allocates
- contiguous memory in u-boot.
- Return:
- u64 bytes;
- ffa_info("Using %lu 4KB page(s) for RX/TX buffers size",
- bytes = ffa_priv_data->pair.rxtx_min_pages * SZ_4K;
- ffa_priv_data->pair.rxbuf = (u64)memalign(bytes, bytes);
- if (!ffa_priv_data->pair.rxbuf) {
return -ENOBUFS;
- ffa_info("RX buffer at virtual address 0x%llx", ffa_priv_data->pair.rxbuf);
- ffa_priv_data->pair.txbuf = (u64)memalign(bytes, bytes);
- if (!ffa_priv_data->pair.txbuf) {
return -ENOBUFS;
- ffa_info("TX buffer at virtual address 0x%llx", ffa_priv_data->pair.txbuf);
- memset((void *)ffa_priv_data->pair.rxbuf, 0, bytes);
- memset((void *)ffa_priv_data->pair.txbuf, 0, bytes);
- ffa_map_rxtx_buffers - FFA_RXTX_MAP handler function
- This function implements FFA_RXTX_MAP FF-A function
- to map the RX/TX buffers
- Return:
- int ret;
- int ffa_errno;
- ret = ffa_alloc_rxtx_buffers();
- if (ret)
return ret;
}, &res);
- ffa_print_error_log(FFA_RXTX_MAP, ffa_errno);
- ffa_free_rxtx_buffers();
- ffa_unmap_rxtx_buffers - FFA_RXTX_UNMAP handler function
- This function implements FFA_RXTX_UNMAP FF-A function
- to unmap the RX/TX buffers
- Return:
- int ffa_errno;
}, &res);
- ffa_print_error_log(FFA_RXTX_UNMAP, ffa_errno);
- ffa_release_rx_buffer - FFA_RX_RELEASE handler function
- This function invokes FFA_RX_RELEASE FF-A function
- to release the ownership of the RX buffer
- Return:
- int ffa_errno;
}, &res);
- ffa_print_error_log(FFA_RX_RELEASE, ffa_errno);
- ffa_uuid_are_identical - checks whether two given UUIDs are identical
- @uuid1: first UUID
- @uuid2: second UUID
- This function is used by ffa_read_partitions_info to search
- for a UUID in the partitions descriptors table
- Return:
- 1 when UUIDs match. Otherwise, 0
- if (!uuid1 || !uuid2)
- return !memcmp(uuid1, uuid2, sizeof(struct ffa_partition_uuid));
- ffa_read_partitions_info - reads the data queried by FFA_PARTITION_INFO_GET
- @count: The number of partitions queried
- @part_uuid: Pointer to the partition(s) UUID
- This function reads the partitions information
- returned by the FFA_PARTITION_INFO_GET and saves it in the private
- data structure.
- Return:
- The private data structure is updated with the partition(s) information
- 0 is returned on success. Otherwise, failure
- if (!count) {
return -ENODATA;
- ffa_info("Reading partitions data from the RX buffer");
- if (!part_uuid) {
u64 buf_bytes;
u64 data_bytes;
u32 desc_idx;
data_bytes,
buf_bytes);
return -ENOMEM;
__GFP_ZERO);
return -ENOMEM;
- } else {
u8 desc_found;
desc_found = 0;
* save the UUID
*part_uuid;
desc_found = 1;
break;
if (!desc_found)
return -ENODATA;
- ffa_query_partitions_info - invokes FFA_PARTITION_INFO_GET and saves partitions data
- @pcount: Pointer to the number of partitions variable filled when querying
- This function executes the FFA_PARTITION_INFO_GET
- to query the partitions data. Then, it calls ffa_read_partitions_info
- to save the data in the private data structure.
- After reading the data the RX buffer is released using ffa_release_rx_buffer
- Return:
- When part_uuid is NULL, all partitions data are retrieved from secure world
- When part_uuid is non NULL, data for partitions matching the given UUID are
- retrieved and the number of partitions is returned
u32 *pcount)
- struct ffa_partition_uuid query_uuid = {0};
- int ffa_errno;
- if (part_uuid) {
if (!pcount)
return -EINVAL;
- } else if (pcount) {
return -EINVAL;
}, &res);
int ret;
if (res.a2) {
if (ret) {
return -EINVAL;
if (pcount)
return ret;
- ffa_print_error_log(FFA_PARTITION_INFO_GET, ffa_errno);
- ffa_get_partitions_info - FFA_PARTITION_INFO_GET handler function
- The passed arguments:
- Mode 1: When getting from the driver the number of
- secure partitions:
- @uuid_str: pointer to the UUID string
- @parts_size: pointer to the variable that contains the number of partitions
- @buffer: NULL
- Mode 2: When requesting the driver to return the
- partitions information:
- @parts_size: pointer to the size of the SPs information buffer in bytes
- @buffer: pointer to SPs information buffer
- This function queries the secure partition data from
- the private data structure. If not found, it invokes FFA_PARTITION_INFO_GET
- FF-A function to query the partition information from secure world.
- A client of the FF-A driver should know the UUID of the service it wants to
- access. It should use the UUID to request the FF-A driver to provide the
- partition(s) information of the service. The FF-A driver uses
- PARTITION_INFO_GET to obtain this information. This is implemented through
- ffa_get_partitions_info function.
- A new FFA_PARTITION_INFO_GET call is issued (first one performed through
- ffa_cache_partitions_info) allowing to retrieve the partition(s) information.
- They are not saved (already done). We only update the UUID in the cached area.
- This assumes that partitions data does not change in the secure world.
- Otherwise u-boot will have an outdated partition data. The benefit of caching
- the information in the FF-A driver is to accommodate discovery after
- ExitBootServices().
- When invoked through a client request, ffa_get_partitions_info should be
- called twice. First call is to get from the driver the number of secure
- partitions (SPs) associated to a particular UUID.
- Then, the caller (client) allocates the buffer to host the SPs data and
- issues a 2nd call. Then, the driver fills the SPs data in the pre-allocated
- buffer.
- To achieve the mechanism described above, ffa_get_partitions_info uses the
- following functions:
- Return:
- @parts_size: When pointing to the number of partitions variable, the number is
- set by the driver.
- When pointing to the partitions information buffer size, the buffer will be
- filled by the driver.
This is confusing, it's better if you use the same unit all the time. Since you below require the size to be an even multiple of sizeof(struct ffa_partition_info) you should perhaps use that unit.
- On success 0 is returned. Otherwise, failure
* fill_data:
- int fill_data = -1;
In the code below this is treated as a bool, it's never tested for -1, so you could as well make this a bool.
- u32 desc_idx, client_desc_idx;
- struct ffa_partition_uuid part_uuid = {0};
- u32 client_desc_max_cnt;
- u32 parts_found = 0;
- if (!ffa_priv_data->partitions.count || !ffa_priv_data->partitions.descs) {
return -EINVAL;
- if (!uuid_str) {
return -EINVAL;
- if (!parts_size) {
return -EINVAL;
- if (uuid_str_to_le_bin(uuid_str, (unsigned char *)&part_uuid)) {
return -EINVAL;
- if (!buffer) {
fill_data = 0;
- } else if ((*parts_size >= sizeof(struct ffa_partition_info)) &&
fill_data = 1;
- } else {
return -EINVAL;
- ffa_info("Searching partitions using the provided UUID");
- for (desc_idx = 0;
desc_idx++) {
&part_uuid)) {
parts_found++;
if (fill_data) {
continue;
return -ENOBUFS;
- if (!parts_found) {
By asking for a UUID never found ffa_query_partitions_info() will be called again, even if the rx/tx buffers needed are not available any longer. Since you populate the cache in ffa_probe() below, perhaps it would be better to only rely on the cache after that point.
int ret;
if (ret == 0) {
if (!fill_data) {
parts_found);
} else {
* to the caller
if (parts_found)
else
ret = -ENODATA;
return ret;
- /* partition(s) found */
- if (!fill_data)
- ffa_cache_partitions_info - Queries and saves all secure partitions data
- This function invokes FFA_PARTITION_INFO_GET FF-A
- function to query from secure world all partitions information.
- The FFA_PARTITION_INFO_GET call is issued with nil UUID as an argument.
- All installed partitions information are returned. We cache them in the
- resident private data structure and we keep the UUID field empty
- (in FF-A 1.0 UUID is not provided by the partition descriptor)
- This function is called at the device probing level.
- ffa_cache_partitions_info uses ffa_query_partitions_info to get the data
- Return:
- return ffa_query_partitions_info(NULL, NULL);
- ffa_msg_send_direct_req - FFA_MSG_SEND_DIRECT_{REQ,RESP} handler function
- @dst_part_id: destination partition ID
- @msg: pointer to the message data preallocated by the client (in/out)
- @is_smc64: select 64-bit or 32-bit FF-A ABI
- This function implements FFA_MSG_SEND_DIRECT_{REQ,RESP}
- FF-A functions.
- FFA_MSG_SEND_DIRECT_REQ is used to send the data to the secure partition.
- The response from the secure partition is handled by reading the
- FFA_MSG_SEND_DIRECT_RESP arguments.
- The maximum size of the data that can be exchanged is 40 bytes which is
- sizeof(struct ffa_send_direct_data) as defined by the FF-A specification 1.0
- in the section relevant to FFA_MSG_SEND_DIRECT_{REQ,RESP}
- Return:
- int ffa_errno;
- u64 req_mode, resp_mode;
- if (!ffa_priv_data || !ffa_priv_data->invoke_ffa_fn)
return -EINVAL;
- /* No partition installed */
return -ENODEV;
This check isn't needed. What if the partition ID is known by other means?
- if (is_smc64) {
- } else {
.a0 = req_mode,
.a2 = 0,
.a3 = msg->data0,
.a4 = msg->data1,
.a5 = msg->data2,
.a6 = msg->data3,
.a7 = msg->data4,
}, &res);
- while (res.a0 == FFA_SMC_32(FFA_INTERRUPT))
.a1 = res.a1,
}, &res);
- if (res.a0 == resp_mode) {
- __arm_ffa_fn_smc - SMC wrapper
- @args: FF-A ABI arguments to be copied to Xn registers
- @res: FF-A ABI return data to be copied from Xn registers
- Calls low level SMC assembly function
- Return: void
- arm_smccc_1_2_smc(&args, res);
- ffa_set_smc_conduit - Set the SMC conduit
- This function selects the SMC conduit by setting the driver invoke function
- to SMC assembly function
- Return:
- ffa_priv_data->invoke_ffa_fn = __arm_ffa_fn_smc;
- if (!ffa_priv_data->invoke_ffa_fn) {
return -EINVAL;
- ffa_info("Conduit is SMC");
- ffa_set_bus_ops - Set the bus driver operations
- Setting the driver callbacks.
- ffa_priv_data->ffa_ops.partition_info_get = ffa_get_partitions_info;
- ffa_priv_data->ffa_ops.sync_send_receive = ffa_msg_send_direct_req;
- ffa_priv_data->ffa_ops.rxtx_unmap = ffa_unmap_rxtx_buffers;
- ffa_alloc_prvdata - allocate the driver main data structure and sets the device
- @dev: the arm_ffa device
- This function creates the main data structure embedding all the driver data.
- Return:
- if (!dev) {
return -ENODEV;
- /* The device is registered with the DM. Let's create the driver main data structure*/
- ffa_priv_data = devm_kmalloc(dev, sizeof(struct ffa_prvdata), __GFP_ZERO);
- if (!ffa_priv_data) {
return -ENOMEM;
- ffa_priv_data->dev = dev;
- ffa_probe - The driver probe function
- Probing is done at boot time and triggered by the uclass device discovery.
- At probe level the following actions are done:
- All data queried from secure world is saved in the resident private data structure.
- The probe will fail if either FF-A framework is not detected or the
- FF-A requests are not behaving correctly. This ensures that the
- driver is not installed and its operations are not exported to the clients.
- Return:
- int ret;
- ret = ffa_alloc_prvdata(dev);
- if (ret != 0)
return ret;
- ffa_set_bus_ops();
- ret = ffa_set_smc_conduit();
- if (ret != 0)
return ret;
- ret = ffa_get_version();
- if (ret != 0)
return ret;
- ret = ffa_get_endpoint_id();
- if (ret != 0)
return ret;
- ret = ffa_get_rxtx_map_features();
- if (ret != 0)
return ret;
- ret = ffa_map_rxtx_buffers();
- if (ret != 0)
return ret;
- ret = ffa_cache_partitions_info();
- if (ret != 0) {
return ret;
- ffa_remove - The driver remove function
- When the device is about to be removed , unmap the RX/TX buffers and free the memory
- Return:
- 0 on success.
- ffa_info("removing the device");
- ffa_unmap_rxtx_buffers();
- if (ffa_priv_data->pair.rxbuf || ffa_priv_data->pair.txbuf)
- ffa_unbind - The driver unbind function
- After the device is removed and memory freed the device is unbound
- Return:
- 0 on success.
- ffa_info("unbinding the device , private data already released");
- ffa_priv_data = NULL;
- ffa_bus_ops_get - bus driver operations getter
- Return:
- This function returns a pointer to the driver operations structure
- return &ffa_priv_data->ffa_ops;
- Return:
- This function returns a pointer to the main private data structure
Why a pointer to a pointer, isn't "struct ffa_prvdata *" enough?
- return &ffa_priv_data;
- ffa_bus_discover - discover FF-A bus and probe the arm_ffa device
- This function makes sure the FF-A bus is discoverable.
- When probing succeeds FF-A discovery is done. The arm_ffa device is ready to use.
- When the bus was already discovered successfully the discovery will not run again.
- Arm FF-A transport is implemented through arm_ffa u-boot device managing the FF-A
- communication.
- All FF-A clients should use the arm_ffa device to use the FF-A transport.
- Return:
- int ret = 0;
- return ret;
- Declaring the arm_ffa driver under UCLASS_FFA
- .name = FFA_DRV_NAME,
- .id = UCLASS_FFA,
- .probe = ffa_probe,
- .remove = ffa_remove,
- .unbind = ffa_unbind,
- This header is public. It can be used by clients to access
- data structures and definitions they need
- Macros for displaying logs
- struct ffa_partition_info - Partition information descriptor
- @id: Partition ID
- @exec_ctxt: Execution context count
- @properties: Partition properties
- Data structure containing information about partitions instantiated in the system
- This structure is filled with the data queried by FFA_PARTITION_INFO_GET
- u16 id;
- u16 exec_ctxt;
- u32 properties;
Perhaps this has been discussed before. Why is this packed? Is it to allow unaligned access or to be sure that there is not implicitly added padding? The Linux kernel does seem to need it.
- struct ffa_send_direct_data - Data structure hosting the data
- @data0-4: Data read/written from/to x3-x7 registers
- Data structure containing the data to be sent by FFA_MSG_SEND_DIRECT_REQ
- or read from FFA_MSG_SEND_DIRECT_RESP
- unsigned long data0; /* w3/x3 */
- unsigned long data1; /* w4/x4 */
- unsigned long data2; /* w5/x5 */
- unsigned long data3; /* w6/x6 */
- unsigned long data4; /* w7/x7 */
Why is this __packed? It seems unnecessary.
Cheers, Jens
- struct ffa_bus_ops - The driver operations structure
- @partition_info_get: callback for the FFA_PARTITION_INFO_GET
- @sync_send_receive: callback for the FFA_MSG_SEND_DIRECT_REQ
- @rxtx_unmap: callback for the FFA_RXTX_UNMAP
- The data structure providing all the operations supported by the driver.
- This structure is EFI runtime resident.
- int (*partition_info_get)(const char *uuid_str,
- int (*sync_send_receive)(u16 dst_part_id, struct ffa_send_direct_data *msg, bool is_smc64);
- int (*rxtx_unmap)(void);
- The device driver and the Uclass driver public functions
- ffa_bus_ops_get - driver operations getter
- ffa_bus_discover - discover FF-A bus and probes the arm_ffa device
- (C) Copyright 2012
- Pavel Herrmann morpheus.ibis@gmail.com
- UCLASS_FFA, /* Arm Firmware Framework for Armv8-A */ UCLASS_FIRMWARE, /* Firmware */ UCLASS_FPGA, /* FPGA device */ UCLASS_FUZZING_ENGINE, /* Fuzzing engine */
-- 2.17.1
Add the core driver implementing Arm Firmware Framework for Armv8-A v1.0
The Firmware Framework for Arm A-profile processors (FF-A v1.0) [1] describes interfaces (ABIs) that standardize communication between the Secure World and Normal World leveraging TrustZone technology.
This driver uses 64-bit registers as per SMCCCv1.2 spec and comes on top of the SMCCC layer. The driver provides the FF-A ABIs needed for querying the FF-A framework from the secure world.
The driver uses SMC32 calling convention which means using the first 32-bit data of the Xn registers.
All supported ABIs come with their 32-bit version except FFA_RXTX_MAP which has 64-bit version supported.
Both 32-bit and 64-bit direct messaging are supported which allows both 32-bit and 64-bit clients to use the FF-A bus.
In U-Boot FF-A design, FF-A is considered as a discoverable bus. The Secure World is considered as one entity to communicate with using the FF-A bus. FF-A communication is handled by one device and one instance (the bus). This FF-A driver takes care of all the interactions between Normal world and Secure World.
The driver exports its operations to be used by upper layers.
Exported operations:
- partition_info_get
- sync_send_receive
- rxtx_unmap
For more details please refer to the driver documentation [2].
Changelog:
v7:
v6:
v4:
v3:
v2:
v1:
MAINTAINERS | 7 + doc/arch/arm64.ffa.rst | 218 ++++ doc/arch/index.rst | 1 + drivers/Kconfig | 2 + drivers/Makefile | 1 + drivers/firmware/arm-ffa/Kconfig | 30 + drivers/firmware/arm-ffa/Makefile | 6 + drivers/firmware/arm-ffa/arm-ffa-uclass.c | 16 + drivers/firmware/arm-ffa/arm_ffa_prv.h | 205 ++++ drivers/firmware/arm-ffa/core.c | 1310 +++++++++++++++++++++ include/arm_ffa.h | 93 ++ include/dm/uclass-id.h | 4 + 12 files changed, 1893 insertions(+) create mode 100644 doc/arch/arm64.ffa.rst create mode 100644 drivers/firmware/arm-ffa/Kconfig create mode 100644 drivers/firmware/arm-ffa/Makefile create mode 100644 drivers/firmware/arm-ffa/arm-ffa-uclass.c create mode 100644 drivers/firmware/arm-ffa/arm_ffa_prv.h create mode 100644 drivers/firmware/arm-ffa/core.c create mode 100644 include/arm_ffa.h
diff --git a/MAINTAINERS b/MAINTAINERS index 1cf99c1393..450b5725ce 100644 --- a/MAINTAINERS +++ b/MAINTAINERS @@ -263,6 +263,13 @@ F: drivers/net/cortina_ni.h F: drivers/net/phy/ca_phy.c F: configs/cortina_presidio-asic-pnand_defconfig
+ARM FF-A +M: Abdellatif El Khlifi abdellatif.elkhlifi@arm.com +S: Maintained +F: doc/arch/arm64.ffa.rst +F: drivers/firmware/arm-ffa/ +F: include/arm_ffa.h
ARM FREESCALE IMX M: Stefano Babic sbabic@denx.de M: Fabio Estevam festevam@gmail.com diff --git a/doc/arch/arm64.ffa.rst b/doc/arch/arm64.ffa.rst new file mode 100644 index 0000000000..dfcec82e45 --- /dev/null +++ b/doc/arch/arm64.ffa.rst @@ -0,0 +1,218 @@ +.. SPDX-License-Identifier: GPL-2.0+
+Arm FF-A Driver +===============
+Summary +-------
+FF-A stands for Firmware Framework for Arm A-profile processors.
+FF-A specifies interfaces that enable a pair of software sandboxes to +communicate with each other. A sandbox aka partition could +be a VM in the Normal or Secure world, an application in S-EL0, or a +Trusted OS in S-EL1.
+This FF-A driver implements the interfaces to communicate with partitions in +the Secure world aka Secure partitions (SPs).
+The driver specifically focuses on communicating with SPs that isolate portions +of EFI runtime services that must run in a protected environment which is +inaccessible by the Host OS or Hypervisor. Examples of such services are +set/get variables.
+FF-A driver uses the SMC ABIs defined by the FF-A specification to:
+- Discover the presence of SPs of interest +- Access an SP's service through communication protocols
+At this stage of development the FF-A driver supports EFI boot time only.
+Runtime support will be added in future developments.
+FF-A and SMC specifications +-------------------------------------------
+The current implementation of the driver relies on FF-A specification v1.0 +and uses SMC32 calling convention which means using the first 32-bit data of the +Xn registers.
+At this stage we only need the FF-A v1.0 features.
+The driver has been tested with OP-TEE which supports SMC32 calling convention.
+For more details please refer to the FF-A v1.0 spec: +https://documentation-service.arm.com/static/5fb7e8a6ca04df4095c1d65e?token=
+Hypervisors are supported if they are configured to trap SMC calls.
+The FF-A driver uses 64-bit registers as per SMCCCv1.2 specification.
+For more details please refer to the SMC Calling Convention v1.2 spec: +https://documentation-service.arm.com/static/5f8edaeff86e16515cdbe4c6?token=
+Supported hardware +--------------------------------
+Aarch64 plaforms
+Configuration +----------------------
+CONFIG_ARM_FFA_TRANSPORT
- communication.
+CONFIG_SANDBOX_FFA
+FF-A ABIs under the hood +---------------------------------------
+Invoking an FF-A ABI involves providing to the secure world/hypervisor the +expected arguments from the ABI.
+The ABI arguments are stored in x0 to x7 registers. Then, an SMC instruction +is executed.
+At the secure side level or hypervisor the ABI is handled at a higher exception +level and the arguments are read and processed.
+The response is put back through x0 to x7 registers and control is given back +to the U-Boot FF-A driver (non-secure world).
+The driver reads the response and processes it accordingly.
+This methodology applies to all the FF-A ABIs in the driver.
+FF-A bus discovery in U-Boot +-------------------------------------------
+When CONFIG_ARM_FFA_TRANSPORT is enabled, the FF-A bus is discovered on +demand by the clients (users).
+Clients can discover the FF-A bus using ffa_bus_discover() API which triggers the +discovery process.
+ffa_bus_discover() creates, binds and probes the arm_ffa device using +device_{bind, probe} APIs.
+The discovery process consists in communicating with secure world (or hypervisor) +and querying specific data.
+The discovery process takes place during the arm_ffa device probing which is +handled by ffa_probe().
+The FF-A bus discovery is successful and the bus is ready for use when these +operations succeed:
+- querying the FF-A framework version +- querying from secure world the U-Boot endpoint ID +- querying from secure world the RX/TX mapping features +- mapping the RX/TX buffers +- querying from secure world all the partitions information
+Discovery failure results in a probing failure and the arm_ffa device is +destroyed.
+Requirements for clients +-------------------------------------
+When using the FF-A bus with EFI, clients must:
+- Query SPs in EFI boot time mode using the service UUID. +- Unmap RX/TX buffers before EFI runtime mode starts.
+The RX/TX buffers are only available at EFI boot time. Querying partitions is +done at boot time and data is cached for future use.
+RX/TX buffers should be unmapped by the user before EFI runtime mode +starts. The driver provides a bus operation for that: rxtx_unmap()
+If RX/TX buffers created by U-Boot are not unmapped and by +consequence becoming available at EFI runtime, secure world will get confused +about RX/TX buffers ownership (U-Boot vs kernel).
+When invoking FF-A direct messaging, clients should specify which ABI protocol +they want to use (32-bit vs 64-bit). Selecting the protocol means using +the 32-bit or 64-bit version of FFA_MSG_SEND_DIRECT_{REQ, RESP}. +The calling convention stays the same: SMC32.
+The bus driver layer +------------------------------
+The driver comes on top of the SMCCC layer and is implemented in +drivers/firmware/arm-ffa/core.c
+The driver provides the following features:
+- Support for the 32-bit version of the following ABIs:
+FFA_VERSION +FFA_ID_GET +FFA_FEATURES +FFA_PARTITION_INFO_GET +FFA_RXTX_UNMAP +FFA_RX_RELEASE +FFA_RUN +FFA_ERROR +FFA_SUCCESS +FFA_INTERRUPT +FFA_MSG_SEND_DIRECT_REQ +FFA_MSG_SEND_DIRECT_RESP
+- Support for the 64-bit version of the following ABIs:
+FFA_RXTX_MAP +FFA_MSG_SEND_DIRECT_REQ +FFA_MSG_SEND_DIRECT_RESP
+- Processing the received data from the secure world/hypervisor and caching it
+- Hiding from upper layers the FF-A protocol and registers details. Upper
+- The driver provides callbacks to be used by clients to access the FF-A bus:
+partition_info_get +sync_send_receive +rxtx_unmap
+- FF-A bus discovery makes sure FF-A framework is responsive and compatible
- with the driver
+- FF-A bus can be compiled and used without EFI
+Using armffa command +-----------------------------------
+armffa is an implementation defined command showcasing how to use the FF-A driver and how to invoke +its operations.
+This provides a guidance to the client developers on how to call the FF-A bus +interfaces.
+Usage:
+armffa <sub-command> <arguments>
+sub-commands:
getpart <partition UUID>
lists the partition(s) info
ping <partition ID>
sends a data pattern to the specified partition
devlist
displays the arm_ffa device info
+Contributors +------------
diff --git a/doc/arch/index.rst b/doc/arch/index.rst index 792d9182c3..8d1ab0ad4e 100644 --- a/doc/arch/index.rst +++ b/doc/arch/index.rst @@ -8,6 +8,7 @@ Architecture-specific doc
arc arm64
diff --git a/drivers/Kconfig b/drivers/Kconfig index 8b6fead351..b06b1ae481 100644 --- a/drivers/Kconfig +++ b/drivers/Kconfig @@ -6,6 +6,8 @@ source "drivers/core/Kconfig"
source "drivers/adc/Kconfig"
+source "drivers/firmware/arm-ffa/Kconfig"
source "drivers/ata/Kconfig"
source "drivers/axi/Kconfig" diff --git a/drivers/Makefile b/drivers/Makefile index a1700c819d..b86c1d2a42 100644 --- a/drivers/Makefile +++ b/drivers/Makefile @@ -111,6 +111,7 @@ obj-y += iommu/ obj-y += smem/ obj-y += thermal/ obj-$(CONFIG_TEE) += tee/ +obj-$(CONFIG_ARM_FFA_TRANSPORT) += firmware/arm-ffa/ obj-y += axi/ obj-y += ufs/ obj-$(CONFIG_W1) += w1/ diff --git a/drivers/firmware/arm-ffa/Kconfig b/drivers/firmware/arm-ffa/Kconfig new file mode 100644 index 0000000000..e4914b9bc7 --- /dev/null +++ b/drivers/firmware/arm-ffa/Kconfig @@ -0,0 +1,30 @@ +# SPDX-License-Identifier: GPL-2.0
+config ARM_FFA_TRANSPORT
- select ARM_SMCCC
- select LIB_UUID
- select DEVRES
- help
The Firmware Framework for Arm A-profile processors (FF-A)
technology.
This driver is based on FF-A specification v1.0 and uses SMC32
calling convention.
FF-A specification:
https://developer.arm.com/documentation/den0077/a/?lang=en
using the FF-A bus.
and Secure World.
For more details about the FF-A driver, please refer to doc/arch/arm64.ffa.rst
diff --git a/drivers/firmware/arm-ffa/Makefile b/drivers/firmware/arm-ffa/Makefile new file mode 100644 index 0000000000..043a8915be --- /dev/null +++ b/drivers/firmware/arm-ffa/Makefile @@ -0,0 +1,6 @@ +# SPDX-License-Identifier: GPL-2.0+ +# +# (C) Copyright 2022 +# Abdellatif El Khlifi, Arm Limited, abdellatif.elkhlifi@arm.com.
+obj-y += arm-ffa-uclass.o core.o diff --git a/drivers/firmware/arm-ffa/arm-ffa-uclass.c b/drivers/firmware/arm-ffa/arm-ffa-uclass.c new file mode 100644 index 0000000000..7d9695d289 --- /dev/null +++ b/drivers/firmware/arm-ffa/arm-ffa-uclass.c @@ -0,0 +1,16 @@ +// SPDX-License-Identifier: GPL-2.0+ +/*
+#include <common.h> +#include <dm.h> +#include <asm/global_data.h>
+DECLARE_GLOBAL_DATA_PTR;
+UCLASS_DRIVER(ffa) = {
- .name = "ffa",
- .id = UCLASS_FFA,
+}; diff --git a/drivers/firmware/arm-ffa/arm_ffa_prv.h b/drivers/firmware/arm-ffa/arm_ffa_prv.h new file mode 100644 index 0000000000..ad7430ada9 --- /dev/null +++ b/drivers/firmware/arm-ffa/arm_ffa_prv.h @@ -0,0 +1,205 @@ +/* SPDX-License-Identifier: GPL-2.0+ */ +/*
+#ifndef __ARM_FFA_PRV_H +#define __ARM_FFA_PRV_H
+#include <arm_ffa.h> +#include <linux/bitfield.h> +#include <linux/bitops.h> +#include <linux/arm-smccc.h>
+/* FF-A core driver name */ +#define FFA_DRV_NAME "arm_ffa"
+/* FF-A driver version definitions */
+#define MAJOR_VERSION_MASK GENMASK(30, 16) +#define MINOR_VERSION_MASK GENMASK(15, 0) +#define GET_FFA_MAJOR_VERSION(x) \
((u16)(FIELD_GET(MAJOR_VERSION_MASK, (x))))
+#define GET_FFA_MINOR_VERSION(x) \
((u16)(FIELD_GET(MINOR_VERSION_MASK, (x))))
+#define PACK_VERSION_INFO(major, minor) \
FIELD_PREP(MINOR_VERSION_MASK, (minor)))
+#define FFA_MAJOR_VERSION (1) +#define FFA_MINOR_VERSION (0) +#define FFA_VERSION_1_0 \
PACK_VERSION_INFO(FFA_MAJOR_VERSION, FFA_MINOR_VERSION)
+/* Endpoint ID mask (u-boot endpoint ID) */
+#define GET_SELF_ENDPOINT_ID_MASK GENMASK(15, 0) +#define GET_SELF_ENDPOINT_ID(x) \
((u16)(FIELD_GET(GET_SELF_ENDPOINT_ID_MASK, (x))))
+#define PREP_SELF_ENDPOINT_ID_MASK GENMASK(31, 16) +#define PREP_SELF_ENDPOINT_ID(x) \
(FIELD_PREP(PREP_SELF_ENDPOINT_ID_MASK, (x)))
+/* Partition endpoint ID mask (partition with which u-boot communicates with) */
+#define PREP_PART_ENDPOINT_ID_MASK GENMASK(15, 0) +#define PREP_PART_ENDPOINT_ID(x) \
(FIELD_PREP(PREP_PART_ENDPOINT_ID_MASK, (x)))
+#define FFA_SMC(calling_convention, func_num) \
ARM_SMCCC_OWNER_STANDARD, (func_num))
+#define FFA_SMC_32(func_num) FFA_SMC(ARM_SMCCC_SMC_32, (func_num)) +#define FFA_SMC_64(func_num) FFA_SMC(ARM_SMCCC_SMC_64, (func_num))
+enum ffa_abis {
- FFA_ERROR = 0x60,
- FFA_RUN = 0x6D,
+enum ffa_abi_errcode {
- NO_MEMORY,
- BUSY,
- INTERRUPTED,
- DENIED,
- RETRY,
- ABORTED,
+/* container structure and helper macros to map between an FF-A error and relevant error log */ +struct ffa_abi_errmap {
+#define FFA_ERRMAP_COUNT (FFA_LAST_ID - FFA_FIRST_ID + 1) +#define FFA_ID_TO_ERRMAP_ID(ffa_id) ((ffa_id) - FFA_FIRST_ID)
+/* The FF-A SMC function definitions */
+typedef struct arm_smccc_1_2_regs ffa_value_t; +typedef void (*invoke_ffa_fn_t)(ffa_value_t args, ffa_value_t *res);
+struct ffa_partition_uuid {
- u32 a1; /* w1 */
- u32 a2; /* w2 */
- u32 a3; /* w3 */
- u32 a4; /* w4 */
+enum ffa_rxtx_buf_sizes {
- RXTX_4K,
- RXTX_64K,
- RXTX_16K
+struct ffa_rxtxpair {
+struct ffa_partition_desc {
+struct ffa_partitions {
- u32 count;
+struct ffa_prvdata {
- u32 fwk_version;
- u16 id;
+int ffa_device_get(void);
+struct ffa_prvdata **ffa_bus_prvdata_get(void);
+#endif diff --git a/drivers/firmware/arm-ffa/core.c b/drivers/firmware/arm-ffa/core.c new file mode 100644 index 0000000000..b955e5187b --- /dev/null +++ b/drivers/firmware/arm-ffa/core.c @@ -0,0 +1,1310 @@ +// SPDX-License-Identifier: GPL-2.0+ +/*
+#include "arm_ffa_prv.h" +#include <asm/global_data.h> +#include <common.h> +#include <dm.h> +#include <dm/device-internal.h> +#include <dm/devres.h> +#include <dm/root.h> +#include <linux/errno.h> +#include <linux/sizes.h> +#include <log.h> +#include <malloc.h> +#include <string.h> +#include <uuid.h>
+struct ffa_prvdata *ffa_priv_data;
+/* Error mapping declarations */
+int ffa_to_std_errmap[MAX_NUMBER_FFA_ERR] = {
- [BUSY] = -EBUSY,
+struct ffa_abi_errmap err_msg_map[FFA_ERRMAP_COUNT] = {
[NOT_SUPPORTED] =
"NOT_SUPPORTED: A Firmware Framework implementation does not exist",
[NOT_SUPPORTED] =
"NOT_SUPPORTED: This function is not implemented at this FF-A instance",
[NOT_SUPPORTED] =
"NOT_SUPPORTED: FFA_RXTX_MAP is not implemented at this FF-A instance",
[NOT_SUPPORTED] =
"INVALID_PARAMETERS: Unrecognized UUID",
[NO_MEMORY] =
"NO_MEMORY: Results cannot fit in RX buffer of the caller",
[BUSY] =
"BUSY: RX buffer of the caller is not free",
[DENIED] =
"DENIED: Callee is not in a state to handle this request",
[NOT_SUPPORTED] =
"NOT_SUPPORTED: FFA_RXTX_UNMAP is not implemented at this FF-A instance",
"INVALID_PARAMETERS: No buffer pair registered on behalf of the caller",
[NOT_SUPPORTED] =
"NOT_SUPPORTED: FFA_RX_RELEASE is not implemented at this FF-A instance",
[DENIED] =
"DENIED: Caller did not have ownership of the RX buffer",
[NOT_SUPPORTED] =
"INVALID_PARAMETERS: Field(s) in input parameters incorrectly encoded",
[NO_MEMORY] =
"NO_MEMORY: Not enough memory",
[DENIED] =
"DENIED: Buffer pair already registered",
- Return:
+int ffa_to_std_errno(int ffa_errno) +{
return ffa_to_std_errmap[err_idx];
- return -EINVAL;
- Return:
+int ffa_print_error_log(u32 ffa_id, int ffa_errno) +{
return -EINVAL;
return -EINVAL;
return -EINVAL;
return -EINVAL;
- Return:
+int ffa_remove_device(struct udevice *dev) +{
- int ret;
- if (!dev) {
return -ENODEV;
- if (ret) {
ffa_err("unable to remove. err:%d\n", ret);
return ret;
- if (ret) {
ffa_err("unable to unbind. err:%d\n", ret);
return ret;
- Return:
+int ffa_device_get(void) +{
- int ret;
&dev);
- if (ret)
return ret;
- if (ret) {
ffa_err("arm_ffa device probing failed");
ffa_remove_device(dev);
return ret;
- Return:
+static int ffa_get_version(void) +{
- u16 major, minor;
- int ffa_errno;
.a0 = FFA_SMC_32(FFA_VERSION), .a1 = FFA_VERSION_1_0,
}, &res);
ffa_print_error_log(FFA_VERSION, ffa_errno);
FFA_MAJOR_VERSION, FFA_MINOR_VERSION, major, minor);
ffa_info("Versions are compatible ");
ffa_priv_data->fwk_version = res.a0;
- Return:
+static int ffa_get_endpoint_id(void) +{
- int ffa_errno;
.a0 = FFA_SMC_32(FFA_ID_GET),
}, &res);
ffa_priv_data->id = GET_SELF_ENDPOINT_ID((u32)res.a2);
ffa_info("endpoint ID is %u", ffa_priv_data->id);
- Return:
+static int ffa_set_rxtx_buffers_pages_cnt(u32 prop_field) +{
return -EINVAL;
- case RXTX_4K:
ffa_priv_data->pair.rxtx_min_pages = 1;
break;
- case RXTX_16K:
ffa_priv_data->pair.rxtx_min_pages = 4;
break;
- case RXTX_64K:
ffa_priv_data->pair.rxtx_min_pages = 16;
break;
- default:
ffa_err("RX/TX buffer size not supported");
return -EINVAL;
- Return:
+static int ffa_get_rxtx_map_features(void) +{
- int ffa_errno;
.a0 = FFA_SMC_32(FFA_FEATURES),
.a1 = FFA_SMC_64(FFA_RXTX_MAP),
}, &res);
return ffa_set_rxtx_buffers_pages_cnt(res.a2);
+static void ffa_free_rxtx_buffers(void) +{
free((void *)ffa_priv_data->pair.rxbuf);
ffa_priv_data->pair.rxbuf = 0;
free((void *)ffa_priv_data->pair.txbuf);
ffa_priv_data->pair.txbuf = 0;
- Return:
+static int ffa_alloc_rxtx_buffers(void) +{
- u64 bytes;
ffa_priv_data->pair.rxtx_min_pages);
* The alignment of the RX and TX buffers must be equal
* to the larger translation granule size
ffa_err("failure to allocate RX buffer");
return -ENOBUFS;
ffa_err("failure to allocate the TX buffer");
return -ENOBUFS;
* make sure the buffers are cleared before use
- Return:
+static int ffa_map_rxtx_buffers(void) +{
- int ret;
- int ffa_errno;
- if (ret)
return ret;
* we need to pass the physical addresses of the RX/TX buffers
* in u-boot physical/virtual mapping is 1:1
* no need to convert from virtual to physical
.a0 = FFA_SMC_64(FFA_RXTX_MAP),
.a1 = ffa_priv_data->pair.txbuf,
.a2 = ffa_priv_data->pair.rxbuf,
.a3 = ffa_priv_data->pair.rxtx_min_pages,
}, &res);
ffa_info("RX/TX buffers mapped");
- Return:
+static int ffa_unmap_rxtx_buffers(void) +{
- int ffa_errno;
.a0 = FFA_SMC_32(FFA_RXTX_UNMAP),
.a1 = PREP_SELF_ENDPOINT_ID(ffa_priv_data->id),
}, &res);
- Return:
+static int ffa_release_rx_buffer(void) +{
- int ffa_errno;
.a0 = FFA_SMC_32(FFA_RX_RELEASE),
}, &res);
- Return:
+bool ffa_uuid_are_identical(const struct ffa_partition_uuid *uuid1,
const struct ffa_partition_uuid *uuid2)
and saves it in the private structure
- data structure.
- Return:
+static int ffa_read_partitions_info(u32 count, struct ffa_partition_uuid *part_uuid) +{
- if (!count) {
ffa_err("no partition detected");
return -ENODATA;
- if (!part_uuid) {
* querying information of all partitions
u64 buf_bytes;
u64 data_bytes;
u32 desc_idx;
struct ffa_partition_info *parts_info;
data_bytes = count * sizeof(struct ffa_partition_desc);
buf_bytes = ffa_priv_data->pair.rxtx_min_pages * SZ_4K;
if (data_bytes > buf_bytes) {
ffa_err("partitions data size exceeds the RX buffer size:");
ffa_err(" sizes in bytes: data %llu , RX buffer %llu ",
data_bytes,
buf_bytes);
return -ENOMEM;
ffa_priv_data->partitions.descs = devm_kmalloc(ffa_priv_data->dev, data_bytes,
__GFP_ZERO);
if (!ffa_priv_data->partitions.descs) {
ffa_err("cannot allocate partitions data buffer");
return -ENOMEM;
parts_info = (struct ffa_partition_info *)ffa_priv_data->pair.rxbuf;
for (desc_idx = 0 ; desc_idx < count ; desc_idx++) {
ffa_priv_data->partitions.descs[desc_idx].info =
parts_info[desc_idx];
ffa_info("Partition ID %x : info cached",
ffa_priv_data->partitions.count = count;
ffa_info("%d partition(s) found and cached", count);
- } else {
u32 rx_desc_idx, cached_desc_idx;
u8 desc_found;
* search for the SP IDs read from the RX buffer
* in the already cached SPs.
* Update the UUID when ID found.
for (rx_desc_idx = 0; rx_desc_idx < count ; rx_desc_idx++) {
desc_found = 0;
* search the current ID in the cached partitions
for (cached_desc_idx = 0;
cached_desc_idx < ffa_priv_data->partitions.count;
cached_desc_idx++) {
* save the UUID
if (ffa_priv_data->partitions.descs[cached_desc_idx].info.id ==
parts_info[rx_desc_idx].id) {
ffa_priv_data->partitions.descs[cached_desc_idx].sp_uuid =
*part_uuid;
desc_found = 1;
break;
if (!desc_found)
return -ENODATA;
- Return:
+static int ffa_query_partitions_info(struct ffa_partition_uuid *part_uuid,
u32 *pcount)
- int ffa_errno;
* If a UUID is specified. Information for one or more
* partitions in the system is queried. Otherwise, information
* for all installed partitions is queried
- if (part_uuid) {
if (!pcount)
return -EINVAL;
query_uuid = *part_uuid;
return -EINVAL;
.a0 = FFA_SMC_32(FFA_PARTITION_INFO_GET),
.a1 = query_uuid.a1,
.a2 = query_uuid.a2,
.a3 = query_uuid.a3,
.a4 = query_uuid.a4,
}, &res);
int ret;
* res.a2 contains the count of partition information descriptors
* populated in the RX buffer
if (res.a2) {
ret = ffa_read_partitions_info((u32)res.a2, part_uuid);
if (ret) {
ffa_err("failed to read partition(s) data , error (%d)", ret);
ffa_release_rx_buffer();
return -EINVAL;
* return the SP count (when querying using a UUID)
if (pcount)
*pcount = (u32)res.a2;
* After calling FFA_PARTITION_INFO_GET the buffer ownership
* is assigned to the consumer (u-boot). So, we need to give
* the ownership back to the SPM or hypervisor
ret = ffa_release_rx_buffer();
return ret;
The variable will be set by the driver
- @buffer: NULL
(allocated by the client).
The buffer will be filled by the driver
- buffer.
- Return:
+static int ffa_get_partitions_info(const char *uuid_str,
* fill_data:
* 0: return the SP count
* 1: fill SP data and return it to the caller
* -1: undefined mode
ffa_err("no partition installed");
return -EINVAL;
- if (!uuid_str) {
ffa_err("no UUID provided");
return -EINVAL;
ffa_err("no size/count provided");
return -EINVAL;
ffa_err("invalid UUID");
return -EINVAL;
- if (!buffer) {
/* Mode 1: getting the number of secure partitions */
fill_data = 0;
ffa_info("Preparing for checking partitions count");
!(*parts_size % sizeof(struct ffa_partition_info))) {
/* Mode 2: retrieving the partitions information */
fill_data = 1;
client_desc_idx = 0;
* number of empty descriptors preallocated by the caller
client_desc_max_cnt = *parts_size / sizeof(struct ffa_partition_info);
ffa_info("Preparing for filling partitions info");
- } else {
ffa_err("invalid function arguments provided");
return -EINVAL;
* search in the cached partitions
desc_idx++) {
if (ffa_uuid_are_identical(&ffa_priv_data->partitions.descs[desc_idx].sp_uuid,
&part_uuid)) {
ffa_info("Partition ID %x matches the provided UUID",
ffa_priv_data->partitions.descs[desc_idx].info.id);
parts_found++;
if (fill_data) {
* trying to fill the partition info in the input buffer
if (client_desc_idx < client_desc_max_cnt) {
buffer[client_desc_idx++] =
ffa_priv_data->partitions.descs[desc_idx].info;
continue;
ffa_err("failed to fill the current descriptor client buffer full");
return -ENOBUFS;
Thanks for pointing out this.
As stated in the documentation under "Requirements for clients" paragraph:
Clients must:
- Query SPs in EFI boot time mode using the service UUID. - Unmap RX/TX buffers before EFI runtime mode starts.
The RX/TX buffers are only available at EFI boot time. Querying partitions is done at boot time and data is cached for future use.
So, when the RX/TX buffers are no longer available, we are at EFI runtime. At that level querying is not allowed and ffa_get_partitions_info() is not available. Only direct messaging is available.
At boot time, when an SP is queryed ffa_get_partitions_info() looks at the cached information first. If the UUID is not found, it will communicate with secure world to try getting the information.
By the way, all the previous comments on this v7 patch will be addressed in v8.
Thanks.
int ret;
ffa_info("No partition found. Querying framework ...");
ret = ffa_query_partitions_info(&part_uuid, &parts_found);
if (ret == 0) {
if (!fill_data) {
*parts_size = parts_found;
ffa_info("Number of partition(s) found matching the UUID: %d",
parts_found);
} else {
* If SPs data detected, they are already in the private data
* structure, retry searching SP data again to return them
* to the caller
if (parts_found)
ret = ffa_get_partitions_info(uuid_str, parts_size, buffer);
else
ret = -ENODATA;
return ret;
- if (!fill_data)
- Return:
+static int ffa_cache_partitions_info(void) +{
- FF-A functions.
- Return:
+static int ffa_msg_send_direct_req(u16 dst_part_id, struct ffa_send_direct_data *msg, bool is_smc64) +{
- int ffa_errno;
return -EINVAL;
return -ENODEV;
I'm happy to remove this check. I'd like to add a comment explaining what the other means are. Could you please explain what are they ?
- if (is_smc64) {
req_mode = FFA_SMC_64(FFA_MSG_SEND_DIRECT_REQ);
resp_mode = FFA_SMC_64(FFA_MSG_SEND_DIRECT_RESP);
- } else {
req_mode = FFA_SMC_32(FFA_MSG_SEND_DIRECT_REQ);
resp_mode = FFA_SMC_32(FFA_MSG_SEND_DIRECT_RESP);
.a0 = req_mode,
.a1 = PREP_SELF_ENDPOINT_ID(ffa_priv_data->id) |
PREP_PART_ENDPOINT_ID(dst_part_id),
.a2 = 0,
.a3 = msg->data0,
.a4 = msg->data1,
.a5 = msg->data2,
.a6 = msg->data3,
.a7 = msg->data4,
}, &res);
.a0 = FFA_SMC_32(FFA_RUN),
.a1 = res.a1,
}, &res);
/* Message sent with no response */
* Message sent with response
* extract the return data
msg->data0 = res.a3;
msg->data1 = res.a4;
msg->data2 = res.a5;
msg->data3 = res.a6;
msg->data4 = res.a7;
- Return: void
+void __arm_ffa_fn_smc(ffa_value_t args, ffa_value_t *res) +{
- Return:
+static int ffa_set_smc_conduit(void) +{
ffa_err("failure to set the invoke function");
return -EINVAL;
+static void ffa_set_bus_ops(void) +{
- Return:
+static int ffa_alloc_prvdata(struct udevice *dev) +{
- if (!dev) {
ffa_err("no udevice found");
return -ENODEV;
ffa_err("can not allocate the driver main data structure");
return -ENOMEM;
- setting the conduit
- Return:
- int ret;
- if (ret != 0)
return ret;
- if (ret != 0)
return ret;
- if (ret != 0)
return ret;
- if (ret != 0)
return ret;
- if (ret != 0)
return ret;
- if (ret != 0)
return ret;
- if (ret != 0) {
return ret;
- Return:
- 0 on success.
- Return:
- 0 on success.
- Return:
- Return:
Because ffa_priv_data is a pointer. ffa_bus_prvdata_get() returns an address of a pointer so the returned type should be struct ffa_prvdata **
Otherwise, a compiler warning:
drivers/firmware/arm-ffa/core.c: In function ‘ffa_bus_prvdata_get’: drivers/firmware/arm-ffa/core.c:1278:9: warning: return from incompatible pointer type [-Wincompatible-pointer-types] return &ffa_priv_data; ^~~~~~~~~~~~~~
- communication.
- Return:
- int ret = 0;
- return ret;
- .id = UCLASS_FFA,
- @id: Partition ID
- u16 id;
- u16 exec_ctxt;
- u32 properties;
When not using __packed the compiler will add paddings. ffa_partition_info structure is used for reading SP information from the secure world.
The issue arises when the non secure world and the secure world have different architectures (Aarch64 vs Aarch32) or different endianess. In these cases, the data will be corrupted.
I think we need to use __packed for all the comms structures.
I'm aware ffa_partition_info in the kernel is not packed. I'm happy to remove __packed from here to align it with Linux.
But please share your thoughts about the padding issues when working with different architecures/endianess.
Thanks.
Yes, in this specific case packing is not necessary. I'll remove this in v8.
Cheers, Jens
-- 2.17.1
[snip]
- FF-A functions.
- Return:
- int ffa_errno;
return -EINVAL;
return -ENODEV;
In some systems perhaps you have well known partition ids reserved for certain services.
- if (is_smc64) {
- } else {
.a0 = req_mode,
.a2 = 0,
.a3 = msg->data0,
.a4 = msg->data1,
.a5 = msg->data2,
.a6 = msg->data3,
.a7 = msg->data4,
}, &res);
.a1 = res.a1,
}, &res);
[snip]
- Return:
Why not return ffa_priv_data instead?
[snip]
- @id: Partition ID
- u16 id;
- u16 exec_ctxt;
- u32 properties;
__packed doesn't help with endianess, besides if I remember correctly these are always expected to be little endian. But I guess that could be a problem for another day.
I believe the layout of these structs are designed in a way that a reasonable compiler wouldn't add padding on AArch32 or AArch64. Note that packed does more than just force generation of inefficient code on Arm (unaligned access), it also makes it invalid to take the address of a member inside such a struct.
Cheers, Jens
[snip]
- FF-A functions.
- Return:
- int ffa_errno;
return -EINVAL;
return -ENODEV;
I double checked with Achin about this.
FFA_PARTITION_INFO_GET provides the partitions information for all partitions including the reserved ones. The driver will cache the information of all the partitions. Not finding any partition cached before a direct request means: there is no partition in the system. I think we need to keep the check.
- if (is_smc64) {
- } else {
.a0 = req_mode,
.a2 = 0,
.a3 = msg->data0,
.a4 = msg->data1,
.a5 = msg->data2,
.a6 = msg->data3,
.a7 = msg->data4,
}, &res);
.a1 = res.a1,
}, &res);
[snip]
- Return:
Thanks, addressed in v8 patchset.
[snip]
- @id: Partition ID
- u16 id;
- u16 exec_ctxt;
- u32 properties;
Packing removed from ffa_partition_info and ffa_send_direct_data structures in v8 patchset.
Cheers, Jens
- sync_send_receive
- rxtx_unmap
Changelog:
v7:
v6:
v4:
v3:
v2:
v1:
+Summary +-------
+Aarch64 plaforms
- communication.
+CONFIG_SANDBOX_FFA
- with the driver
+Usage:
+sub-commands:
ping <partition ID>
devlist
arc arm64
- select ARM_SMCCC
- select LIB_UUID
- select DEVRES
- help
technology.
calling convention.
FF-A specification:
using the FF-A bus.
and Secure World.
- .name = "ffa",
- .id = UCLASS_FFA,
+enum ffa_abis {
- FFA_ERROR = 0x60,
- FFA_RUN = 0x6D,
- NO_MEMORY,
- BUSY,
- INTERRUPTED,
- DENIED,
- RETRY,
- ABORTED,
- u32 a1; /* w1 */
- u32 a2; /* w2 */
- u32 a3; /* w3 */
- u32 a4; /* w4 */
- RXTX_4K,
- RXTX_64K,
- RXTX_16K
- u32 count;
- u32 fwk_version;
- u16 id;
- [BUSY] = -EBUSY,
[NOT_SUPPORTED] =
[NOT_SUPPORTED] =
[NOT_SUPPORTED] =
[NOT_SUPPORTED] =
[NO_MEMORY] =
[BUSY] =
[DENIED] =
[NOT_SUPPORTED] =
[NOT_SUPPORTED] =
[DENIED] =
[NOT_SUPPORTED] =
[NO_MEMORY] =
[DENIED] =
Addressed in v8 patchset.
- Return:
- return -EINVAL;
- Return:
return -EINVAL;
return -EINVAL;
return -EINVAL;
return -EINVAL;
- Return:
- int ret;
- if (!dev) {
return -ENODEV;
- if (ret) {
return ret;
- if (ret) {
return ret;
- Return:
- int ret;
&dev);
- if (ret)
return ret;
- if (ret) {
return ret;
- Return:
- u16 major, minor;
- int ffa_errno;
}, &res);
- Return:
- int ffa_errno;
}, &res);
- Return:
return -EINVAL;
- case RXTX_4K:
break;
- case RXTX_16K:
break;
- case RXTX_64K:
break;
- default:
return -EINVAL;
- Return:
- int ffa_errno;
}, &res);
- Return:
- u64 bytes;
return -ENOBUFS;
return -ENOBUFS;
- Return:
- int ret;
- int ffa_errno;
- if (ret)
return ret;
}, &res);
- Return:
- int ffa_errno;
}, &res);
- Return:
- int ffa_errno;
}, &res);
- Return:
- data structure.
- Return:
- if (!count) {
return -ENODATA;
- if (!part_uuid) {
u64 buf_bytes;
u64 data_bytes;
u32 desc_idx;
data_bytes,
buf_bytes);
return -ENOMEM;
__GFP_ZERO);
return -ENOMEM;
- } else {
u8 desc_found;
desc_found = 0;
* save the UUID
*part_uuid;
desc_found = 1;
break;
if (!desc_found)
return -ENODATA;
- Return:
u32 *pcount)
- int ffa_errno;
- if (part_uuid) {
if (!pcount)
return -EINVAL;
return -EINVAL;
}, &res);
int ret;
if (res.a2) {
if (ret) {
return -EINVAL;
if (pcount)
return ret;
- @buffer: NULL
- buffer.
- Return:
u32 *parts_size, struct ffa_partition_info *buffer)
* fill_data:
return -EINVAL;
- if (!uuid_str) {
return -EINVAL;
return -EINVAL;
return -EINVAL;
- if (!buffer) {
fill_data = 0;
fill_data = 1;
- } else {
return -EINVAL;
desc_idx++) {
&part_uuid)) {
parts_found++;
if (fill_data) {
continue;
return -ENOBUFS;
int ret;
if (ret == 0) {
if (!fill_data) {
parts_found);
} else {
* to the caller
if (parts_found)
else
ret = -ENODATA;
return ret;
- if (!fill_data)
- Return:
- FF-A functions.
- Return:
- int ffa_errno;
return -EINVAL;
return -ENODEV;
- if (is_smc64) {
- } else {
.a0 = req_mode,
.a2 = 0,
.a3 = msg->data0,
.a4 = msg->data1,
.a5 = msg->data2,
.a6 = msg->data3,
.a7 = msg->data4,
}, &res);
.a1 = res.a1,
}, &res);
- Return: void
- Return:
return -EINVAL;
- Return:
- if (!dev) {
return -ENODEV;
return -ENOMEM;
- querying from secure world the u-boot endpoint ID
- querying from secure world the supported features of FFA_RXTX_MAP
- Return:
+static int ffa_probe(struct udevice *dev) +{
- int ret;
- if (ret != 0)
return ret;
- if (ret != 0)
return ret;
- if (ret != 0)
return ret;
- if (ret != 0)
return ret;
- if (ret != 0)
return ret;
- if (ret != 0)
return ret;
- if (ret != 0) {
return ret;
- Return:
- 0 on success.
+static int ffa_remove(struct udevice *dev) +{
- Return:
- 0 on success.
+static int ffa_unbind(struct udevice *dev) +{
- Return:
+const struct ffa_bus_ops *ffa_bus_ops_get(void) +{
- Return:
- communication.
- Return:
+int ffa_bus_discover(void) +{
- int ret = 0;
ret = ffa_device_get();
- return ret;
+U_BOOT_DRIVER(arm_ffa) = {
- .id = UCLASS_FFA,
+}; diff --git a/include/arm_ffa.h b/include/arm_ffa.h new file mode 100644 index 0000000000..b0c8a18926 --- /dev/null +++ b/include/arm_ffa.h @@ -0,0 +1,93 @@ +/* SPDX-License-Identifier: GPL-2.0+ */ +/*
+#ifndef __ARM_FFA_H +#define __ARM_FFA_H
+#include <linux/printk.h>
+#define ffa_info(fmt, ...) pr_info("[FFA] " fmt "\n", ##__VA_ARGS__) +#define ffa_err(fmt, ...) pr_err("[FFA] " fmt "\n", ##__VA_ARGS__)
- @id: Partition ID
+struct __packed ffa_partition_info {
- u16 id;
- u16 exec_ctxt;
+/* partition supports receipt of direct requests */ +#define FFA_PARTITION_DIRECT_RECV BIT(0) +/* partition can send direct requests. */ +#define FFA_PARTITION_DIRECT_SEND BIT(1) +/* partition can send and receive indirect messages. */ +#define FFA_PARTITION_INDIRECT_MSG BIT(2)
- u32 properties;
used by FFA_MSG_SEND_DIRECT_{REQ,RESP}
+/* For use with FFA_MSG_SEND_DIRECT_{REQ,RESP} which pass data via registers */ +struct __packed ffa_send_direct_data {
Cheers, Jens
+struct ffa_bus_ops {
u32 *parts_size, struct ffa_partition_info *buffer);
+const struct ffa_bus_ops *ffa_bus_ops_get(void);
+int ffa_bus_discover(void);
+#endif diff --git a/include/dm/uclass-id.h b/include/dm/uclass-id.h index 4b2c323452..fb59d4f356 100644 --- a/include/dm/uclass-id.h +++ b/include/dm/uclass-id.h @@ -4,6 +4,9 @@
#ifndef _DM_UCLASS_ID_H @@ -55,6 +58,7 @@ enum uclass_id { UCLASS_EFI_MEDIA, /* Devices provided by UEFI firmware */ UCLASS_ETH, /* Ethernet device */ UCLASS_ETH_PHY, /* Ethernet PHY device */
-- 2.17.1
unmap RX/TX buffers at ExitBootServices()
Unmapping the RX/TX buffers created by u-boot is needed before EFI runtime.
At EFI runtime the linux kernel takes care of allocating its own RX/TX buffers and registering them with the secure world.
Secure world should be using the RX/TX buffers created by the kernel. So, RX/TX buffers created by u-boot must be unmapped.
Signed-off-by: Abdellatif El Khlifi abdellatif.elkhlifi@arm.com Cc: Tom Rini trini@konsulko.com Cc: Simon Glass sjg@chromium.org Cc: Ilias Apalodimas ilias.apalodimas@linaro.org Cc: Jens Wiklander jens.wiklander@linaro.org
Changelog: ===============
v7: replace debug() by log_err()
lib/efi_loader/efi_boottime.c | 13 +++++++++++++ 1 file changed, 13 insertions(+)
diff --git a/lib/efi_loader/efi_boottime.c b/lib/efi_loader/efi_boottime.c index a56021559b..b0b61bc812 100644 --- a/lib/efi_loader/efi_boottime.c +++ b/lib/efi_loader/efi_boottime.c @@ -3,6 +3,9 @@ * EFI application boot time services * * Copyright (c) 2016 Alexander Graf + * + * (C) Copyright 2022 ARM Limited + * Abdellatif El Khlifi abdellatif.elkhlifi@arm.com */
#include <common.h> @@ -23,6 +26,10 @@ #include <asm/setjmp.h> #include <linux/libfdt_env.h>
+#if CONFIG_IS_ENABLED(ARM_FFA_TRANSPORT) +#include <arm_ffa.h> +#endif + DECLARE_GLOBAL_DATA_PTR;
/* Task priority level */ @@ -2178,6 +2185,12 @@ static efi_status_t EFIAPI efi_exit_boot_services(efi_handle_t image_handle, dm_remove_devices_flags(DM_REMOVE_ACTIVE_ALL); }
+#if CONFIG_IS_ENABLED(ARM_FFA_TRANSPORT) + /* unmap FF-A RX/TX buffers */ + if (ffa_bus_ops_get()->rxtx_unmap()) + log_err("Can't unmap FF-A RX/TX buffers\n"); +#endif + /* Patch out unsupported runtime function */ efi_runtime_detach();
Provide armffa command showcasing the use of the FF-A driver
The armffa command allows to query secure partitions data from the secure world and exchanging messages with the partitions using 64-bit FF-A direct messaging.
v7:
* adapt do_ffa_dev_list() following the recent update on uclass_first_device/uclass_next_device functions (they return void now) * set armffa command to use 64-bit direct messaging
v4:
* remove pattern data in do_ffa_msg_send_direct_req
v3:
* use the new driver interfaces (partition_info_get, sync_send_receive) in armffa command
v2:
* replace use of ffa_helper_init_device function by ffa_helper_bus_discover
v1:
* introduce armffa command
MAINTAINERS | 1 + cmd/Kconfig | 10 ++ cmd/Makefile | 2 + cmd/armffa.c | 239 +++++++++++++++++++++++++++++++ drivers/firmware/arm-ffa/Kconfig | 1 + 5 files changed, 253 insertions(+) create mode 100644 cmd/armffa.c
diff --git a/MAINTAINERS b/MAINTAINERS index 450b5725ce..e86ba068ad 100644 --- a/MAINTAINERS +++ b/MAINTAINERS @@ -266,6 +266,7 @@ F: configs/cortina_presidio-asic-pnand_defconfig ARM FF-A M: Abdellatif El Khlifi abdellatif.elkhlifi@arm.com S: Maintained +F: cmd/armffa.c F: doc/arch/arm64.ffa.rst F: drivers/firmware/arm-ffa/ F: include/arm_ffa.h diff --git a/cmd/Kconfig b/cmd/Kconfig index 3f6bc70d43..16505361d5 100644 --- a/cmd/Kconfig +++ b/cmd/Kconfig @@ -918,6 +918,16 @@ endmenu
menu "Device access commands"
+config CMD_ARMFFA + bool "Arm FF-A test command" + depends on ARM_FFA_TRANSPORT + help + Provides a test command for the Arm FF-A driver + supported options: + - Listing the partition(s) info + - Sending a data pattern to the specified partition + - Displaying the arm_ffa device info + config CMD_ARMFLASH #depends on FLASH_CFI_DRIVER bool "armflash" diff --git a/cmd/Makefile b/cmd/Makefile index ca9ed1054d..adb4728b65 100644 --- a/cmd/Makefile +++ b/cmd/Makefile @@ -12,6 +12,8 @@ obj-y += panic.o obj-y += version.o
# command + +obj-$(CONFIG_CMD_ARMFFA) += armffa.o obj-$(CONFIG_CMD_ACPI) += acpi.o obj-$(CONFIG_CMD_ADDRMAP) += addrmap.o obj-$(CONFIG_CMD_AES) += aes.o diff --git a/cmd/armffa.c b/cmd/armffa.c new file mode 100644 index 0000000000..964a5e1b34 --- /dev/null +++ b/cmd/armffa.c @@ -0,0 +1,239 @@ +// SPDX-License-Identifier: GPL-2.0+ +/* + * (C) Copyright 2022 ARM Limited + * Abdellatif El Khlifi abdellatif.elkhlifi@arm.com + */ + +#include <arm_ffa.h> +#include <asm/io.h> +#include <common.h> +#include <command.h> +#include <dm.h> +#include <mapmem.h> +#include <stdlib.h> + +/** + * do_ffa_get_singular_partition_info - implementation of the getpart subcommand + * @cmdtp: Command Table + * @flag: flags + * @argc: number of arguments + * @argv: arguments + * + * This function queries the secure partition information which the UUID is provided + * as an argument. The function uses the arm_ffa driver partition_info_get operation + * to retrieve the data. + * The input UUID string is expected to be in big endian format. + * + * Return: + * + * CMD_RET_SUCCESS: on success, otherwise failure + */ +static int do_ffa_get_singular_partition_info(struct cmd_tbl *cmdtp, int flag, int argc, + char *const argv[]) +{ + u32 count = 0, size = 0; + int ret; + struct ffa_partition_info *parts_info; + u32 info_idx; + + if (argc != 1) + return -EINVAL; + + /* Mode 1: getting the number of secure partitions */ + ret = ffa_bus_ops_get()->partition_info_get(argv[0], &count, NULL); + if (ret != 0) { + ffa_err("Failure in querying partitions count (error code: %d)", ret); + return ret; + } + + if (!count) { + ffa_info("No secure partition found"); + return ret; + } + + /* + * pre-allocate a buffer to be filled by the driver + * with ffa_partition_info structs + */ + + ffa_info("Pre-allocating %d partition(s) info structures", count); + + parts_info = calloc(count, sizeof(struct ffa_partition_info)); + if (!parts_info) + return -EINVAL; + + size = count * sizeof(struct ffa_partition_info); + + /* + * ask the driver to fill the buffer with the SPs info + */ + + ret = ffa_bus_ops_get()->partition_info_get(argv[0], &size, parts_info); + if (ret != 0) { + ffa_err("Failure in querying partition(s) info (error code: %d)", ret); + free(parts_info); + return ret; + } + + /* + * SPs found , show the partition information + */ + for (info_idx = 0; info_idx < count ; info_idx++) { + ffa_info("Partition: id = 0x%x , exec_ctxt 0x%x , properties 0x%x", + parts_info[info_idx].id, + parts_info[info_idx].exec_ctxt, + parts_info[info_idx].properties); + } + + free(parts_info); + + return 0; +} + +/** + * do_ffa_msg_send_direct_req - implementation of the ping subcommand + * @cmdtp: Command Table + * @flag: flags + * @argc: number of arguments + * @argv: arguments + * + * This function sends data to the secure partition which the ID is provided + * as an argument. The function uses the arm_ffa driver sync_send_receive operation + * to send data. + * + * Return: + * + * CMD_RET_SUCCESS: on success, otherwise failure + */ +int do_ffa_msg_send_direct_req(struct cmd_tbl *cmdtp, int flag, int argc, + char *const argv[]) +{ + struct ffa_send_direct_data msg = { + .data0 = 0xaaaaaaaa, + .data1 = 0xbbbbbbbb, + .data2 = 0xcccccccc, + .data3 = 0xdddddddd, + .data4 = 0xeeeeeeee, + }; + u16 part_id; + int ret; + + if (argc != 1) + return -EINVAL; + + errno = 0; + part_id = strtoul(argv[0], NULL, 16); + + if (errno) { + ffa_err("Invalid partition ID"); + return -EINVAL; + } + + ret = ffa_bus_ops_get()->sync_send_receive(part_id, &msg, 1); + if (ret == 0) { + u8 cnt; + + ffa_info("SP response:\n[LSB]"); + for (cnt = 0; + cnt < sizeof(struct ffa_send_direct_data) / sizeof(u64); + cnt++) + ffa_info("0x%llx", ((u64 *)&msg)[cnt]); + } else { + ffa_err("Sending direct request error (%d)", ret); + } + + return ret; +} + +/** + *do_ffa_dev_list - implementation of the devlist subcommand + * @cmdtp: [in] Command Table + * @flag: flags + * @argc: number of arguments + * @argv: arguments + * + * This function queries the devices belonging to the UCLASS_FFA + * class. Currently, one device is expected to show up: the arm_ffa device + * + * Return: + * + * CMD_RET_SUCCESS: on success, otherwise failure + */ +int do_ffa_dev_list(struct cmd_tbl *cmdtp, int flag, int argc, char *const argv[]) +{ + struct udevice *dev = NULL; + int i; + + ffa_info("arm_ffa uclass entries:"); + + for (i = 0, uclass_first_device(UCLASS_FFA, &dev); + dev; + uclass_next_device(&dev), i++) { + ffa_info("entry %d - instance %08x, ops %08x, plat %08x", + i, + (u32)map_to_sysmem(dev), + (u32)map_to_sysmem(dev->driver->ops), + (u32)map_to_sysmem(dev_get_plat(dev))); + } + + return 0; +} + +static struct cmd_tbl armffa_commands[] = { + U_BOOT_CMD_MKENT(getpart, 1, 1, do_ffa_get_singular_partition_info, "", ""), + U_BOOT_CMD_MKENT(ping, 1, 1, do_ffa_msg_send_direct_req, "", ""), + U_BOOT_CMD_MKENT(devlist, 0, 1, do_ffa_dev_list, "", ""), +}; + +/** + * do_armffa - the armffa command main function + * @cmdtp: Command Table + * @flag: flags + * @argc: number of arguments + * @argv: arguments + * + * This function identifies which armffa subcommand to run. + * Then, it makes sure the arm_ffa device is probed and + * ready for use. + * Then, it runs the subcommand. + * + * Return: + * + * CMD_RET_SUCCESS: on success, otherwise failure + */ +static int do_armffa(struct cmd_tbl *cmdtp, int flag, int argc, char *const argv[]) +{ + struct cmd_tbl *armffa_cmd; + int ret; + + if (argc < 2) + return CMD_RET_USAGE; + + armffa_cmd = find_cmd_tbl(argv[1], armffa_commands, ARRAY_SIZE(armffa_commands)); + + argc -= 2; + argv += 2; + + if (!armffa_cmd || argc > armffa_cmd->maxargs) + return CMD_RET_USAGE; + + ret = ffa_bus_discover(); + if (ret != 0) + return cmd_process_error(cmdtp, ret); + + if (!ffa_bus_ops_get()) + return -EINVAL; + + ret = armffa_cmd->cmd(armffa_cmd, flag, argc, argv); + + return cmd_process_error(armffa_cmd, ret); +} + +U_BOOT_CMD(armffa, 4, 1, do_armffa, + "Arm FF-A operations test command", + "getpart <partition UUID>\n" + " - lists the partition(s) info\n" + "ping <partition ID>\n" + " - sends a data pattern to the specified partition\n" + "devlist\n" + " - displays the arm_ffa device info\n"); diff --git a/drivers/firmware/arm-ffa/Kconfig b/drivers/firmware/arm-ffa/Kconfig index e4914b9bc7..be4df89d23 100644 --- a/drivers/firmware/arm-ffa/Kconfig +++ b/drivers/firmware/arm-ffa/Kconfig @@ -4,6 +4,7 @@ config ARM_FFA_TRANSPORT bool "Enable Arm Firmware Framework for Armv8-A driver" depends on DM && ARM64 select ARM_SMCCC + select CMD_ARMFFA select LIB_UUID select DEVRES help
Provide a Sandbox driver to emulate the FF-A ABIs
The emulated ABIs are those supported by the FF-A core driver and according to FF-A specification v1.0.
The Sandbox driver provides operations allowing the test application to read the status of all the inspected ABIs and perform functional tests based on that.
sandbox driver supports only 64-bit direct messaging.
v7: state that sandbox driver supports only 64-bit direct messaging
v4: align sandbox driver with the new FF-A driver interfaces and new way of error handling
v1: introduce the sandbox driver
MAINTAINERS | 1 + configs/sandbox64_defconfig | 2 + configs/sandbox_defconfig | 2 + doc/arch/sandbox.rst | 1 + drivers/firmware/arm-ffa/Kconfig | 9 +- drivers/firmware/arm-ffa/Makefile | 1 + drivers/firmware/arm-ffa/arm_ffa_prv.h | 15 +- drivers/firmware/arm-ffa/core.c | 24 +- drivers/firmware/arm-ffa/sandbox.c | 659 ++++++++++++++++++ .../firmware/arm-ffa/sandbox_arm_ffa_prv.h | 144 ++++ include/arm_ffa.h | 2 +- include/sandbox_arm_ffa.h | 91 +++ lib/efi_loader/efi_boottime.c | 2 +- 13 files changed, 939 insertions(+), 14 deletions(-) create mode 100644 drivers/firmware/arm-ffa/sandbox.c create mode 100644 drivers/firmware/arm-ffa/sandbox_arm_ffa_prv.h create mode 100644 include/sandbox_arm_ffa.h
diff --git a/MAINTAINERS b/MAINTAINERS index e86ba068ad..1d745b175d 100644 --- a/MAINTAINERS +++ b/MAINTAINERS @@ -270,6 +270,7 @@ F: cmd/armffa.c F: doc/arch/arm64.ffa.rst F: drivers/firmware/arm-ffa/ F: include/arm_ffa.h +F: include/sandbox_arm_ffa.h
ARM FREESCALE IMX M: Stefano Babic sbabic@denx.de diff --git a/configs/sandbox64_defconfig b/configs/sandbox64_defconfig index af2ce34174..01f3b6456f 100644 --- a/configs/sandbox64_defconfig +++ b/configs/sandbox64_defconfig @@ -256,3 +256,5 @@ CONFIG_TEST_FDTDEC=y CONFIG_UNIT_TEST=y CONFIG_UT_TIME=y CONFIG_UT_DM=y +CONFIG_ARM_FFA_TRANSPORT=y +CONFIG_SANDBOX_FFA=y \ No newline at end of file diff --git a/configs/sandbox_defconfig b/configs/sandbox_defconfig index f12d0a4f51..f7e8d73f75 100644 --- a/configs/sandbox_defconfig +++ b/configs/sandbox_defconfig @@ -334,3 +334,5 @@ CONFIG_TEST_FDTDEC=y CONFIG_UNIT_TEST=y CONFIG_UT_TIME=y CONFIG_UT_DM=y +CONFIG_ARM_FFA_TRANSPORT=y +CONFIG_SANDBOX_FFA=y \ No newline at end of file diff --git a/doc/arch/sandbox.rst b/doc/arch/sandbox.rst index ed66f70f61..9a3d362dfc 100644 --- a/doc/arch/sandbox.rst +++ b/doc/arch/sandbox.rst @@ -203,6 +203,7 @@ Supported Drivers
U-Boot sandbox supports these emulations:
+- Arm FF-A - Block devices - Chrome OS EC - GPIO diff --git a/drivers/firmware/arm-ffa/Kconfig b/drivers/firmware/arm-ffa/Kconfig index be4df89d23..b86f16d778 100644 --- a/drivers/firmware/arm-ffa/Kconfig +++ b/drivers/firmware/arm-ffa/Kconfig @@ -2,8 +2,8 @@
config ARM_FFA_TRANSPORT bool "Enable Arm Firmware Framework for Armv8-A driver" - depends on DM && ARM64 - select ARM_SMCCC + depends on DM && (ARM64 || SANDBOX) + select ARM_SMCCC if !SANDBOX select CMD_ARMFFA select LIB_UUID select DEVRES @@ -29,3 +29,8 @@ config ARM_FFA_TRANSPORT
+config SANDBOX_FFA + bool "FF-A Sandbox driver" + depends on ARM_FFA_TRANSPORT && SANDBOX + help + This emulates the FF-A handling under Sandbox and allows to test the FF-A driver diff --git a/drivers/firmware/arm-ffa/Makefile b/drivers/firmware/arm-ffa/Makefile index 043a8915be..0d21d6b47a 100644 --- a/drivers/firmware/arm-ffa/Makefile +++ b/drivers/firmware/arm-ffa/Makefile @@ -4,3 +4,4 @@ # Abdellatif El Khlifi, Arm Limited, abdellatif.elkhlifi@arm.com.
obj-y += arm-ffa-uclass.o core.o +obj-$(CONFIG_SANDBOX_FFA) += sandbox.o diff --git a/drivers/firmware/arm-ffa/arm_ffa_prv.h b/drivers/firmware/arm-ffa/arm_ffa_prv.h index ad7430ada9..a16536c2be 100644 --- a/drivers/firmware/arm-ffa/arm_ffa_prv.h +++ b/drivers/firmware/arm-ffa/arm_ffa_prv.h @@ -19,6 +19,16 @@ /* FF-A core driver name */ #define FFA_DRV_NAME "arm_ffa"
+/* The FF-A SMC function definitions */ + +#if CONFIG_IS_ENABLED(SANDBOX_FFA) +#include "sandbox_arm_ffa.h" +#else +typedef struct arm_smccc_1_2_regs ffa_value_t; +#endif + +typedef void (*invoke_ffa_fn_t)(ffa_value_t args, ffa_value_t *res); + /* FF-A driver version definitions */
#define MAJOR_VERSION_MASK GENMASK(30, 16) @@ -103,11 +113,6 @@ struct ffa_abi_errmap { #define FFA_ERRMAP_COUNT (FFA_LAST_ID - FFA_FIRST_ID + 1) #define FFA_ID_TO_ERRMAP_ID(ffa_id) ((ffa_id) - FFA_FIRST_ID)
-/* The FF-A SMC function definitions */ - -typedef struct arm_smccc_1_2_regs ffa_value_t; -typedef void (*invoke_ffa_fn_t)(ffa_value_t args, ffa_value_t *res); - /* * struct ffa_partition_uuid - 16 bytes UUID transmitted by FFA_PARTITION_INFO_GET * @a1-4: 32-bit words access to the UUID data diff --git a/drivers/firmware/arm-ffa/core.c b/drivers/firmware/arm-ffa/core.c index b955e5187b..4e1535abac 100644 --- a/drivers/firmware/arm-ffa/core.c +++ b/drivers/firmware/arm-ffa/core.c @@ -1069,6 +1069,7 @@ static int ffa_msg_send_direct_req(u16 dst_part_id, struct ffa_send_direct_data return ffa_to_std_errno(ffa_errno); }
+#if !CONFIG_IS_ENABLED(SANDBOX_FFA) /** * __arm_ffa_fn_smc - SMC wrapper * @args: FF-A ABI arguments to be copied to Xn registers @@ -1082,6 +1083,7 @@ void __arm_ffa_fn_smc(ffa_value_t args, ffa_value_t *res) { arm_smccc_1_2_smc(&args, res); } +#endif
/** * ffa_set_smc_conduit - Set the SMC conduit @@ -1095,7 +1097,12 @@ void __arm_ffa_fn_smc(ffa_value_t args, ffa_value_t *res) */ static int ffa_set_smc_conduit(void) { - ffa_priv_data->invoke_ffa_fn = __arm_ffa_fn_smc; +#if CONFIG_IS_ENABLED(SANDBOX_FFA) + ffa_priv_data->invoke_ffa_fn = sandbox_arm_ffa_smccc_smc; + ffa_info("Using SMC emulation"); +#else + ffa_priv_data->invoke_ffa_fn = __arm_ffa_fn_smc; +#endif
if (!ffa_priv_data->invoke_ffa_fn) { ffa_err("failure to set the invoke function"); @@ -1272,15 +1279,16 @@ struct ffa_prvdata **ffa_bus_prvdata_get(void) }
/** - * ffa_bus_discover - discover FF-A bus and probe the arm_ffa device + * ffa_bus_discover - discover FF-A bus and probe arm_ffa and sandbox_arm_ffa devices * * This function makes sure the FF-A bus is discoverable. - * When probing succeeds FF-A discovery is done. The arm_ffa device is ready to use. + * When probing succeeds FF-A discovery is done. The arm_ffa and sandbox_arm_ffa devices + * are ready to use. * * When the bus was already discovered successfully the discovery will not run again. * * Arm FF-A transport is implemented through arm_ffa u-boot device managing the FF-A - * communication. + * communication. In Sandbox mode sandbox_arm_ffa is used to test arm_ffa driver. * All FF-A clients should use the arm_ffa device to use the FF-A transport. * * Return: @@ -1291,9 +1299,15 @@ int ffa_bus_discover(void) { int ret = 0;
- if (!ffa_priv_data) + if (!ffa_priv_data) { ret = ffa_device_get();
+#if CONFIG_IS_ENABLED(SANDBOX_FFA) + if (ret == 0) + ret = sandbox_ffa_device_get(); +#endif + } + return ret; }
diff --git a/drivers/firmware/arm-ffa/sandbox.c b/drivers/firmware/arm-ffa/sandbox.c new file mode 100644 index 0000000000..8e8549441d --- /dev/null +++ b/drivers/firmware/arm-ffa/sandbox.c @@ -0,0 +1,659 @@ +// SPDX-License-Identifier: GPL-2.0+ +/* + * (C) Copyright 2022 ARM Limited + * Abdellatif El Khlifi abdellatif.elkhlifi@arm.com + */ + +#include "sandbox_arm_ffa_prv.h" +#include <asm/global_data.h> +#include <common.h> +#include <dm.h> +#include <dm/device-internal.h> +#include <dm/root.h> +#include <linux/errno.h> +#include <linux/sizes.h> +#include <mapmem.h> +#include <string.h> + +DECLARE_GLOBAL_DATA_PTR; + +/** + * The device private data structure containing all the emulated secure world data + */ +static struct sandbox_ffa_prvdata sandbox_ffa_priv_data = {0}; + +/* The partitions (SPs) table */ +static struct ffa_partition_desc sandbox_partitions[SANDBOX_PARTITIONS_CNT] = { + { + .info = { .id = SANDBOX_SP1_ID, .exec_ctxt = 0x5687, .properties = 0x89325621 }, + .sp_uuid = { + .a1 = SANDBOX_SERVICE1_UUID_A1, + .a2 = SANDBOX_SERVICE1_UUID_A2, + .a3 = SANDBOX_SERVICE1_UUID_A3, + .a4 = SANDBOX_SERVICE1_UUID_A4, + } + }, + { + .info = { .id = SANDBOX_SP2_ID, .exec_ctxt = 0x9587, .properties = 0x45325621 }, + .sp_uuid = { + .a1 = SANDBOX_SERVICE2_UUID_A1, + .a2 = SANDBOX_SERVICE2_UUID_A2, + .a3 = SANDBOX_SERVICE2_UUID_A3, + .a4 = SANDBOX_SERVICE2_UUID_A4, + } + }, + { + .info = { .id = SANDBOX_SP3_ID, .exec_ctxt = 0x7687, .properties = 0x23325621 }, + .sp_uuid = { + .a1 = SANDBOX_SERVICE1_UUID_A1, + .a2 = SANDBOX_SERVICE1_UUID_A2, + .a3 = SANDBOX_SERVICE1_UUID_A3, + .a4 = SANDBOX_SERVICE1_UUID_A4, + } + }, + { + .info = { .id = SANDBOX_SP4_ID, .exec_ctxt = 0x1487, .properties = 0x70325621 }, + .sp_uuid = { + .a1 = SANDBOX_SERVICE2_UUID_A1, + .a2 = SANDBOX_SERVICE2_UUID_A2, + .a3 = SANDBOX_SERVICE2_UUID_A3, + .a4 = SANDBOX_SERVICE2_UUID_A4, + } + } + +}; + +/* + * Driver functions + */ + +/** + * sandbox_ffa_get_device - probes the sandbox_arm_ffa device + * + * This function makes sure the sandbox_arm_ffa device is probed + * This function makes sure the sandbox_arm_ffa device is + * created, bound to this driver, probed and ready to use. + * + * sandbox_arm_ffa depends on arm_ffa device. This dependency is + * handled by ffa_bus_discover function. arm_ffa is probed first then + * sandbox_arm_ffa. + * + * Return: + * + * 0 on success. Otherwise, failure + */ +int sandbox_ffa_device_get(void) +{ + int ret; + + if (sandbox_ffa_priv_data.dev) + return 0; + + ret = device_bind(dm_root(), + DM_DRIVER_GET(sandbox_arm_ffa), + FFA_SANDBOX_DRV_NAME, + NULL, + ofnode_null(), + &sandbox_ffa_priv_data.dev); + if (ret) { + sandbox_ffa_priv_data.dev = NULL; + return ret; + } + + ret = device_probe(sandbox_ffa_priv_data.dev); + if (ret) { + ffa_err("[Sandbox] can not probe the device"); + device_unbind(sandbox_ffa_priv_data.dev); + sandbox_ffa_priv_data.dev = NULL; + return ret; + } + + return 0; +} + +/** + * sandbox_ffa_version - Emulated FFA_VERSION handler function + * @{a0-a7} , res: The SMC call arguments and return structure. + * + * This is the function that emulates FFA_VERSION FF-A function. + * + * Return: + * + * 0 on success. Otherwise, failure + */ +SANDBOX_SMC_FFA_ABI(ffa_version) +{ + sandbox_ffa_priv_data.fwk_version = FFA_VERSION_1_0; + res->a0 = sandbox_ffa_priv_data.fwk_version; + + /* x1-x7 MBZ */ + memset(FFA_X1X7_MBZ_REG_START, 0, FFA_X1X7_MBZ_CNT * sizeof(unsigned long)); + + return 0; +} + +/** + * sandbox_ffa_id_get - Emulated FFA_ID_GET handler function + * @{a0-a7} , res: The SMC call arguments and return structure. + * + * This is the function that emulates FFA_ID_GET FF-A function. + * + * Return: + * + * 0 on success. Otherwise, failure + */ +SANDBOX_SMC_FFA_ABI(ffa_id_get) +{ + res->a0 = FFA_SMC_32(FFA_SUCCESS); + res->a1 = 0; + + sandbox_ffa_priv_data.id = NS_PHYS_ENDPOINT_ID; + res->a2 = sandbox_ffa_priv_data.id; + + /* x3-x7 MBZ */ + memset(FFA_X3_MBZ_REG_START, 0, FFA_X3X7_MBZ_CNT * sizeof(unsigned long)); + + return 0; +} + +/** + * sandbox_ffa_features - Emulated FFA_FEATURES handler function + * @{a0-a7} , res: The SMC call arguments and return structure. + * + * This is the function that emulates FFA_FEATURES FF-A function. + * + * Return: + * + * 0 on success. Otherwise, failure + */ +SANDBOX_SMC_FFA_ABI(ffa_features) +{ + if (pargs->a1 == FFA_SMC_64(FFA_RXTX_MAP)) { + res->a0 = FFA_SMC_32(FFA_SUCCESS); + res->a2 = RXTX_BUFFERS_MIN_SIZE; + res->a3 = 0; + /* x4-x7 MBZ */ + memset(FFA_X4X7_MBZ_REG_START, + 0, FFA_X4X7_MBZ_CNT * sizeof(unsigned long)); + } else { + res->a0 = FFA_SMC_32(FFA_ERROR); + res->a2 = FFA_ERR_STAT_NOT_SUPPORTED; + /* x3-x7 MBZ */ + memset(FFA_X3_MBZ_REG_START, + 0, FFA_X3X7_MBZ_CNT * sizeof(unsigned long)); + ffa_err("[Sandbox] FF-A interface 0x%lx not implemented", pargs->a1); + } + + res->a1 = 0; + + return 0; +} + +/** + * sandbox_ffa_partition_info_get - Emulated FFA_PARTITION_INFO_GET handler function + * @{a0-a7} , res: The SMC call arguments and return structure. + * + * This is the function that emulates FFA_PARTITION_INFO_GET FF-A function. + * + * Return: + * + * 0 on success. Otherwise, failure + */ +SANDBOX_SMC_FFA_ABI(ffa_partition_info_get) +{ + struct ffa_partition_info *rxbuf_desc_info = NULL; + u32 descs_cnt; + u32 descs_size_bytes; + + res->a0 = FFA_SMC_32(FFA_ERROR); + + if (!sandbox_ffa_priv_data.pair.rxbuf) { + res->a2 = FFA_ERR_STAT_DENIED; + goto cleanup; + } + + if (sandbox_ffa_priv_data.pair_info.rxbuf_owned) { + res->a2 = FFA_ERR_STAT_BUSY; + goto cleanup; + } + + if (!sandbox_ffa_priv_data.partitions.descs) { + sandbox_ffa_priv_data.partitions.descs = sandbox_partitions; + sandbox_ffa_priv_data.partitions.count = SANDBOX_PARTITIONS_CNT; + } + + descs_size_bytes = SANDBOX_PARTITIONS_CNT * sizeof(struct ffa_partition_desc); + + /* Abort if the RX buffer size is smaller than the descriptors buffer size */ + if ((sandbox_ffa_priv_data.pair_info.rxtx_buf_size * SZ_4K) < descs_size_bytes) { + res->a2 = FFA_ERR_STAT_NO_MEMORY; + goto cleanup; + } + + rxbuf_desc_info = (struct ffa_partition_info *)sandbox_ffa_priv_data.pair.rxbuf; + + /* No UUID specified. Return the information of all partitions */ + if (!pargs->a1 && !pargs->a2 && !pargs->a3 && !pargs->a4) { + for (descs_cnt = 0 ; descs_cnt < SANDBOX_PARTITIONS_CNT ; descs_cnt++) + *(rxbuf_desc_info++) = + sandbox_ffa_priv_data.partitions.descs[descs_cnt].info; + + res->a0 = FFA_SMC_32(FFA_SUCCESS); + res->a2 = SANDBOX_PARTITIONS_CNT; + /* transfer ownership to the consumer: the non secure world */ + sandbox_ffa_priv_data.pair_info.rxbuf_owned = 1; + + goto cleanup; + } + + /* + * A UUID is specified. Return the information of all partitions matching + * the UUID + */ + + for (descs_cnt = 0 ; descs_cnt < SANDBOX_PARTITIONS_CNT ; descs_cnt++) + if (pargs->a1 == sandbox_ffa_priv_data.partitions.descs[descs_cnt].sp_uuid.a1 && + pargs->a2 == sandbox_ffa_priv_data.partitions.descs[descs_cnt].sp_uuid.a2 && + pargs->a3 == sandbox_ffa_priv_data.partitions.descs[descs_cnt].sp_uuid.a3 && + pargs->a4 == sandbox_ffa_priv_data.partitions.descs[descs_cnt].sp_uuid.a4) { + *(rxbuf_desc_info++) = + sandbox_ffa_priv_data.partitions.descs[descs_cnt].info; + } + + if (rxbuf_desc_info != ((struct ffa_partition_info *)sandbox_ffa_priv_data.pair.rxbuf)) { + res->a0 = FFA_SMC_32(FFA_SUCCESS); + /* store the partitions count */ + res->a2 = (unsigned long) + (rxbuf_desc_info - (struct ffa_partition_info *) + sandbox_ffa_priv_data.pair.rxbuf); + + /* transfer ownership to the consumer: the non secure world */ + sandbox_ffa_priv_data.pair_info.rxbuf_owned = 1; + } else { + /* Unrecognized UUID */ + res->a2 = FFA_ERR_STAT_INVALID_PARAMETERS; + } + +cleanup: + + ffa_err("[Sandbox] FFA_PARTITION_INFO_GET (%ld)", res->a2); + + res->a1 = 0; + + /* x3-x7 MBZ */ + memset(FFA_X3_MBZ_REG_START, 0, FFA_X3X7_MBZ_CNT * sizeof(unsigned long)); + + return 0; +} + +/** + * sandbox_ffa_rxtx_map - Emulated FFA_RXTX_MAP handler function + * @{a0-a7} , res: The SMC call arguments and return structure. + * + * This is the function that emulates FFA_RXTX_MAP FF-A function. + * + * Return: + * + * 0 on success. Otherwise, failure + */ +SANDBOX_SMC_FFA_ABI(ffa_rxtx_map) +{ + res->a0 = FFA_SMC_32(FFA_ERROR); + + if (sandbox_ffa_priv_data.pair.txbuf && sandbox_ffa_priv_data.pair.rxbuf) { + res->a2 = FFA_ERR_STAT_DENIED; + goto feedback; + } + + if (pargs->a3 >= RXTX_BUFFERS_MIN_PAGES && pargs->a1 && pargs->a2) { + sandbox_ffa_priv_data.pair.txbuf = pargs->a1; + sandbox_ffa_priv_data.pair.rxbuf = pargs->a2; + sandbox_ffa_priv_data.pair_info.rxtx_buf_size = pargs->a3; + sandbox_ffa_priv_data.pair_info.rxbuf_mapped = 1; + res->a0 = FFA_SMC_32(FFA_SUCCESS); + res->a2 = 0; + goto feedback; + } + + if (!pargs->a1 || !pargs->a2) + res->a2 = FFA_ERR_STAT_INVALID_PARAMETERS; + else + res->a2 = FFA_ERR_STAT_NO_MEMORY; + + ffa_err("[Sandbox] error in FFA_RXTX_MAP arguments (%d)", (int)res->a2); + +feedback: + + res->a1 = 0; + + /* x3-x7 MBZ */ + memset(FFA_X3_MBZ_REG_START, + 0, FFA_X3X7_MBZ_CNT * sizeof(unsigned long)); + + return 0; +} + +/** + * sandbox_ffa_rxtx_unmap - Emulated FFA_RXTX_UNMAP handler function + * @{a0-a7} , res: The SMC call arguments and return structure. + * + * This is the function that emulates FFA_RXTX_UNMAP FF-A function. + * + * Return: + * + * 0 on success. Otherwise, failure + */ +SANDBOX_SMC_FFA_ABI(ffa_rxtx_unmap) +{ + res->a0 = FFA_SMC_32(FFA_ERROR); + res->a2 = FFA_ERR_STAT_INVALID_PARAMETERS; + + if (GET_NS_PHYS_ENDPOINT_ID(pargs->a1) != sandbox_ffa_priv_data.id) + goto feedback; + + if (sandbox_ffa_priv_data.pair.txbuf && sandbox_ffa_priv_data.pair.rxbuf) { + sandbox_ffa_priv_data.pair.txbuf = 0; + sandbox_ffa_priv_data.pair.rxbuf = 0; + sandbox_ffa_priv_data.pair_info.rxtx_buf_size = 0; + sandbox_ffa_priv_data.pair_info.rxbuf_mapped = 0; + res->a0 = FFA_SMC_32(FFA_SUCCESS); + res->a2 = 0; + goto feedback; + } + + ffa_err("[Sandbox] No buffer pair registered on behalf of the caller"); + +feedback: + + res->a1 = 0; + + /* x3-x7 MBZ */ + memset(FFA_X3_MBZ_REG_START, + 0, FFA_X3X7_MBZ_CNT * sizeof(unsigned long)); + + return 0; +} + +/** + * sandbox_ffa_rx_release - Emulated FFA_RX_RELEASE handler function + * @{a0-a7} , res: The SMC call arguments and return structure. + * + * This is the function that emulates FFA_RX_RELEASE FF-A function. + * + * Return: + * + * 0 on success. Otherwise, failure + */ +SANDBOX_SMC_FFA_ABI(ffa_rx_release) +{ + if (!sandbox_ffa_priv_data.pair_info.rxbuf_owned) { + res->a0 = FFA_SMC_32(FFA_ERROR); + res->a2 = FFA_ERR_STAT_DENIED; + } else { + sandbox_ffa_priv_data.pair_info.rxbuf_owned = 0; + res->a0 = FFA_SMC_32(FFA_SUCCESS); + res->a2 = 0; + } + + res->a1 = 0; + + /* x3-x7 MBZ */ + memset(FFA_X3_MBZ_REG_START, + 0, FFA_X3X7_MBZ_CNT * sizeof(unsigned long)); + + return 0; +} + +/** + * sandbox_ffa_sp_valid - Checks SP validity + * @part_id: partition ID to check + * + * This is the function searches the input ID in the descriptors table. + * + * Return: + * + * 1 on success (Partition found). Otherwise, failure + */ +static int sandbox_ffa_sp_valid(u16 part_id) +{ + u32 descs_cnt; + + for (descs_cnt = 0 ; descs_cnt < SANDBOX_PARTITIONS_CNT ; descs_cnt++) + if (sandbox_ffa_priv_data.partitions.descs[descs_cnt].info.id == part_id) + return 1; + + return 0; +} + +/** + * sandbox_ffa_msg_send_direct_req - Emulated FFA_MSG_SEND_DIRECT_{REQ,RESP} handler function + * @{a0-a7} , res: The SMC call arguments and return structure. + * + * This is the function that emulates FFA_MSG_SEND_DIRECT_{REQ,RESP} + * FF-A functions. Only SMC 64-bit is supported in Sandbox. + * + * Emulating interrupts is not supported. So, FFA_RUN and FFA_INTERRUPT are not supported. + * In case of success FFA_MSG_SEND_DIRECT_RESP is returned with default pattern data (0xff). + * + * Return: + * + * 0 on success. Otherwise, failure + */ +SANDBOX_SMC_FFA_ABI(ffa_msg_send_direct_req) +{ + u16 part_id; + + part_id = GET_DST_SP_ID(pargs->a1); + + if ((GET_NS_PHYS_ENDPOINT_ID(pargs->a1) != sandbox_ffa_priv_data.id) || + !sandbox_ffa_sp_valid(part_id) || + pargs->a2) { + res->a0 = FFA_SMC_32(FFA_ERROR); + res->a1 = 0; + res->a2 = FFA_ERR_STAT_INVALID_PARAMETERS; + + /* x3-x7 MBZ */ + memset(FFA_X3_MBZ_REG_START, + 0, FFA_X3X7_MBZ_CNT * sizeof(unsigned long)); + + return 0; + } + + res->a0 = FFA_SMC_64(FFA_MSG_SEND_DIRECT_RESP); + + res->a1 = PREP_SRC_SP_ID(part_id) | + PREP_NS_PHYS_ENDPOINT_ID(sandbox_ffa_priv_data.id); + + res->a2 = 0; + + /* + * return 0xff bytes as a response + */ + res->a3 = 0xffffffffffffffff; + res->a4 = 0xffffffffffffffff; + res->a5 = 0xffffffffffffffff; + res->a6 = 0xffffffffffffffff; + res->a7 = 0xffffffffffffffff; + + return 0; +} + +/** + * sandbox_ffa_get_prv_data - Returns the pointer to FF-A core pivate data + * @func_data: Pointer to the FF-A function arguments container structure + * + * This is the handler that returns the address of the FF-A core pivate data. + * + * Return: + * + * 0 on success. Otherwise, failure + */ +static int sandbox_ffa_get_prv_data(struct ffa_sandbox_data *func_data) +{ + if (!func_data) + return -EINVAL; + + if (!func_data->data0 || func_data->data0_size != sizeof(struct ffa_prvdata **)) + return -EINVAL; + + if (!func_data->data1 || func_data->data1_size != sizeof(struct sandbox_ffa_prvdata **)) + return -EINVAL; + + *((struct ffa_prvdata **)func_data->data0) = *(ffa_bus_prvdata_get()); + *((struct sandbox_ffa_prvdata **)func_data->data1) = &sandbox_ffa_priv_data; + + return 0; +} + +/** + * sandbox_ffa_get_rxbuf_flags - Reading the mapping/ownership flags + * @queried_func_id: The FF-A function to be queried + * @func_data: Pointer to the FF-A function arguments container structure + * + * This is the handler that queries the status flags of the following emulated ABIs: + * FFA_RXTX_MAP, FFA_RXTX_UNMAP, FFA_RX_RELEASE + * + * Return: + * + * 0 on success. Otherwise, failure + */ +static int sandbox_ffa_get_rxbuf_flags(u32 queried_func_id, struct ffa_sandbox_data *func_data) +{ + if (!func_data) + return -EINVAL; + + if (!func_data->data0 || func_data->data0_size != sizeof(u8)) + return -EINVAL; + + switch (queried_func_id) { + case FFA_RXTX_MAP: + case FFA_RXTX_UNMAP: + *((u8 *)func_data->data0) = sandbox_ffa_priv_data.pair_info.rxbuf_mapped; + return 0; + case FFA_RX_RELEASE: + *((u8 *)func_data->data0) = sandbox_ffa_priv_data.pair_info.rxbuf_owned; + return 0; + default: + ffa_err("[Sandbox] The querried FF-A interface flag (%d) undefined", + queried_func_id); + return -EINVAL; + } +} + +/** + * sandbox_ffa_query_core_state - The driver dispatcher function + * @queried_func_id: The FF-A function to be queried + * @func_data: Pointer to the FF-A function arguments container structure + * + * Queries the status of FF-A ABI specified in the input argument. + * + * Return: + * + * 0 on success. Otherwise, failure + */ +int sandbox_ffa_query_core_state(u32 queried_func_id, struct ffa_sandbox_data *func_data) +{ + switch (queried_func_id) { + case FFA_VERSION: + case FFA_ID_GET: + case FFA_FEATURES: + return sandbox_ffa_get_prv_data(func_data); + case FFA_RXTX_MAP: + case FFA_RXTX_UNMAP: + case FFA_RX_RELEASE: + return sandbox_ffa_get_rxbuf_flags(queried_func_id, func_data); + default: + ffa_err("[Sandbox] The querried FF-A interface (%d) undefined", queried_func_id); + return -EINVAL; + } +} + +/** + * sandbox_arm_ffa_smccc_smc - FF-A SMC call emulation + * @args: the SMC call arguments + * @res: the SMC call returned data + * + * Sandbox driver emulates the FF-A ABIs SMC call using this function. + * The emulated FF-A ABI is identified and invoked. + * FF-A emulation is based on the FF-A specification 1.0 + * + * Return: + * + * 0 on success. Otherwise, failure. + * FF-A protocol error codes are returned using the registers arguments as described + * by the specification + */ +void sandbox_arm_ffa_smccc_smc(ffa_value_t args, ffa_value_t *res) +{ + int ret = 0; + + switch (args.a0) { + case FFA_SMC_32(FFA_VERSION): + ret = sandbox_ffa_version(&args, res); + break; + case FFA_SMC_32(FFA_PARTITION_INFO_GET): + ret = sandbox_ffa_partition_info_get(&args, res); + break; + case FFA_SMC_32(FFA_RXTX_UNMAP): + ret = sandbox_ffa_rxtx_unmap(&args, res); + break; + case FFA_SMC_64(FFA_MSG_SEND_DIRECT_REQ): + ret = sandbox_ffa_msg_send_direct_req(&args, res); + break; + case FFA_SMC_32(FFA_ID_GET): + ret = sandbox_ffa_id_get(&args, res); + break; + case FFA_SMC_32(FFA_FEATURES): + ret = sandbox_ffa_features(&args, res); + break; + case FFA_SMC_64(FFA_RXTX_MAP): + ret = sandbox_ffa_rxtx_map(&args, res); + break; + case FFA_SMC_32(FFA_RX_RELEASE): + ret = sandbox_ffa_rx_release(&args, res); + break; + default: + ffa_err("[Sandbox] Undefined FF-A interface (0x%lx)", args.a0); + } + + if (ret != 0) + ffa_err("[Sandbox] FF-A ABI internal failure (%d)", ret); +} + +/** + * sandbox_ffa_probe - The driver probe function + * @dev: the sandbox_arm_ffa device + * + * Return: + * + * 0 on success. Otherwise, failure + */ +static int sandbox_ffa_probe(struct udevice *dev) +{ + return 0; +} + +/** + * sandbox_ffa_remove - The driver remove function + * @dev: the sandbox_arm_ffa device + * + * Return: + * + * 0 on success. Otherwise, failure + */ +static int sandbox_ffa_remove(struct udevice *dev) +{ + ffa_info("[Sandbox] removing the device"); + memset(&sandbox_ffa_priv_data, 0, sizeof(sandbox_ffa_priv_data)); + return 0; +} + +/** + * Declaring the sandbox_arm_ffa driver under UCLASS_FFA + */ +U_BOOT_DRIVER(sandbox_arm_ffa) = { + .name = FFA_SANDBOX_DRV_NAME, + .id = UCLASS_FFA, + .probe = sandbox_ffa_probe, + .remove = sandbox_ffa_remove, +}; diff --git a/drivers/firmware/arm-ffa/sandbox_arm_ffa_prv.h b/drivers/firmware/arm-ffa/sandbox_arm_ffa_prv.h new file mode 100644 index 0000000000..4db57f5092 --- /dev/null +++ b/drivers/firmware/arm-ffa/sandbox_arm_ffa_prv.h @@ -0,0 +1,144 @@ +/* SPDX-License-Identifier: GPL-2.0+ */ +/* + * (C) Copyright 2022 ARM Limited + * Abdellatif El Khlifi abdellatif.elkhlifi@arm.com + */ + +#ifndef __SANDBOX_ARM_FFA_PRV_H +#define __SANDBOX_ARM_FFA_PRV_H + +#include "arm_ffa_prv.h" +#include <sandbox_arm_ffa.h> + +/* + * This header is private. It is exclusively used by the Sandbox FF-A driver + */ + +/* FF-A core driver name */ +#define FFA_SANDBOX_DRV_NAME "sandbox_arm_ffa" + +/* FF-A ABIs internal error codes (as defined by the spec) */ + +#define FFA_ERR_STAT_NOT_SUPPORTED -1 +#define FFA_ERR_STAT_INVALID_PARAMETERS -2 +#define FFA_ERR_STAT_NO_MEMORY -3 +#define FFA_ERR_STAT_BUSY -4 +#define FFA_ERR_STAT_DENIED -6 + +/* Providing Arm SMCCC declarations to sandbox */ + +#define ARM_SMCCC_FAST_CALL 1UL +#define ARM_SMCCC_OWNER_STANDARD 4 +#define ARM_SMCCC_SMC_32 0 +#define ARM_SMCCC_SMC_64 1 +#define ARM_SMCCC_TYPE_SHIFT 31 +#define ARM_SMCCC_CALL_CONV_SHIFT 30 +#define ARM_SMCCC_OWNER_MASK 0x3F +#define ARM_SMCCC_OWNER_SHIFT 24 +#define ARM_SMCCC_FUNC_MASK 0xFFFF + +#define ARM_SMCCC_CALL_VAL(type, calling_convention, owner, func_num) \ + (((type) << ARM_SMCCC_TYPE_SHIFT) | \ + ((calling_convention) << ARM_SMCCC_CALL_CONV_SHIFT) | \ + (((owner) & ARM_SMCCC_OWNER_MASK) << ARM_SMCCC_OWNER_SHIFT) | \ + ((func_num) & ARM_SMCCC_FUNC_MASK)) + +/* Non-secure physical FF-A instance */ +#define NS_PHYS_ENDPOINT_ID (0) + +#define GET_NS_PHYS_ENDPOINT_ID_MASK GENMASK(31, 16) +#define GET_NS_PHYS_ENDPOINT_ID(x) \ + ((u16)(FIELD_GET(GET_NS_PHYS_ENDPOINT_ID_MASK, (x)))) + +/* Helper macro for reading the destination partition ID */ +#define GET_DST_SP_ID_MASK GENMASK(15, 0) +#define GET_DST_SP_ID(x) \ + ((u16)(FIELD_GET(GET_DST_SP_ID_MASK, (x)))) + +/* Helper macro for setting the source partition ID */ +#define PREP_SRC_SP_ID_MASK GENMASK(31, 16) +#define PREP_SRC_SP_ID(x) \ + (FIELD_PREP(PREP_SRC_SP_ID_MASK, (x))) + +/* Helper macro for setting the destination endpoint ID */ +#define PREP_NS_PHYS_ENDPOINT_ID_MASK GENMASK(15, 0) +#define PREP_NS_PHYS_ENDPOINT_ID(x) \ + (FIELD_PREP(PREP_NS_PHYS_ENDPOINT_ID_MASK, (x))) + +/* RX/TX buffers minimum size */ +#define RXTX_BUFFERS_MIN_SIZE (RXTX_4K) +#define RXTX_BUFFERS_MIN_PAGES (1) + +/* MBZ registers info */ + +/* x1-x7 MBZ */ +#define FFA_X1X7_MBZ_CNT (7) +#define FFA_X1X7_MBZ_REG_START (&res->a1) + +/* x4-x7 MBZ */ +#define FFA_X4X7_MBZ_CNT (4) +#define FFA_X4X7_MBZ_REG_START (&res->a4) + +/* x3-x7 MBZ */ +#define FFA_X3X7_MBZ_CNT (5) +#define FFA_X3_MBZ_REG_START (&res->a3) + +/* secure partitions count */ +#define SANDBOX_PARTITIONS_CNT (4) + +/* service 1 UUID binary data (little-endian format) */ +#define SANDBOX_SERVICE1_UUID_A1 0xed32d533 +#define SANDBOX_SERVICE1_UUID_A2 0x99e64209 +#define SANDBOX_SERVICE1_UUID_A3 0x9cc02d72 +#define SANDBOX_SERVICE1_UUID_A4 0xcdd998a7 + +/* service 2 UUID binary data (little-endian format) */ +#define SANDBOX_SERVICE2_UUID_A1 0xed32d544 +#define SANDBOX_SERVICE2_UUID_A2 0x99e64209 +#define SANDBOX_SERVICE2_UUID_A3 0x9cc02d72 +#define SANDBOX_SERVICE2_UUID_A4 0xcdd998a7 + +/** + * struct ffa_rxtxpair_info - structure hosting the RX/TX buffers flags + * @rxbuf_owned: RX buffer ownership flag (the owner is non secure world: the consumer) + * @rxbuf_mapped: RX buffer mapping flag + * @txbuf_owned TX buffer ownership flag + * @txbuf_mapped: TX buffer mapping flag + * @rxtx_buf_size: RX/TX buffers size as set by the FF-A core driver + * + * Data structure hosting the ownership/mapping flags of the RX/TX buffers + * When a buffer is owned/mapped its corresponding flag is set to 1 otherwise 0. + */ +struct ffa_rxtxpair_info { + u8 rxbuf_owned; + u8 rxbuf_mapped; + u8 txbuf_owned; + u8 txbuf_mapped; + u32 rxtx_buf_size; +}; + +/** + * struct sandbox_ffa_prvdata - the driver private data structure + * + * @dev: The arm_ffa device under u-boot driver model + * @fwk_version: FF-A framework version + * @id: u-boot endpoint ID + * @partitions: The partitions descriptors structure + * @pair: The RX/TX buffers pair + * @pair_info: The RX/TX buffers pair flags and size + * @conduit: The selected conduit + * + * The driver data structure hosting all the emulated secure world data. + */ +struct sandbox_ffa_prvdata { + struct udevice *dev; + u32 fwk_version; + u16 id; + struct ffa_partitions partitions; + struct ffa_rxtxpair pair; + struct ffa_rxtxpair_info pair_info; +}; + +#define SANDBOX_SMC_FFA_ABI(ffabi) static int sandbox_##ffabi(ffa_value_t *pargs, ffa_value_t *res) + +#endif diff --git a/include/arm_ffa.h b/include/arm_ffa.h index b0c8a18926..f51e826d47 100644 --- a/include/arm_ffa.h +++ b/include/arm_ffa.h @@ -86,7 +86,7 @@ struct ffa_bus_ops { const struct ffa_bus_ops *ffa_bus_ops_get(void);
/** - * ffa_bus_discover - discover FF-A bus and probes the arm_ffa device + * ffa_bus_discover - discover FF-A bus and probes the arm_ffa and sandbox_arm_ffa devices */ int ffa_bus_discover(void);
diff --git a/include/sandbox_arm_ffa.h b/include/sandbox_arm_ffa.h new file mode 100644 index 0000000000..d5df16f282 --- /dev/null +++ b/include/sandbox_arm_ffa.h @@ -0,0 +1,91 @@ +/* SPDX-License-Identifier: GPL-2.0+ */ +/* + * (C) Copyright 2022 ARM Limited + * Abdellatif El Khlifi abdellatif.elkhlifi@arm.com + */ + +#ifndef __SANDBOX_ARM_FFA_H +#define __SANDBOX_ARM_FFA_H + +#include <arm_ffa.h> + +/** + * struct sandbox_smccc_1_2_regs - Arguments for or Results from emulated SMC call + * @a0-a17 argument values from registers 0 to 17 + */ +struct sandbox_smccc_1_2_regs { + unsigned long a0; + unsigned long a1; + unsigned long a2; + unsigned long a3; + unsigned long a4; + unsigned long a5; + unsigned long a6; + unsigned long a7; + unsigned long a8; + unsigned long a9; + unsigned long a10; + unsigned long a11; + unsigned long a12; + unsigned long a13; + unsigned long a14; + unsigned long a15; + unsigned long a16; + unsigned long a17; +}; + +typedef struct sandbox_smccc_1_2_regs ffa_value_t; + +/* UUIDs of services supported by the sandbox driver */ +#define SANDBOX_SERVICE1_UUID "ed32d533-4209-99e6-2d72-cdd998a79cc0" +#define SANDBOX_SERVICE2_UUID "ed32d544-4209-99e6-2d72-cdd998a79cc0" +#define SANDBOX_SP1_ID 0x1245 +#define SANDBOX_SP2_ID 0x9836 +#define SANDBOX_SP3_ID 0x6452 +#define SANDBOX_SP4_ID 0x7814 + +/* invalid service UUID (no matching SP) */ +#define SANDBOX_SERVICE3_UUID "55d532ed-0942-e699-722d-c09ca798d9cd" + +/* invalid service UUID (invalid UUID string format) */ +#define SANDBOX_SERVICE4_UUID "32ed-0942-e699-722d-c09ca798d9cd" + +#define SANDBOX_SP_COUNT_PER_VALID_SERVICE 2 + +/** + * struct ffa_sandbox_data - generic data structure used to exchange + * data between test cases and the sandbox driver + * @data0_size: size of the first argument + * @data0: pointer to the first argument + * @data1_size>: size of the second argument + * @data1: pointer to the second argument + * + * Using this structure sandbox test cases can pass various types of data with different sizes. + */ +struct ffa_sandbox_data { + u32 data0_size; /* size of the first argument */ + void *data0; /* pointer to the first argument */ + u32 data1_size; /* size of the second argument */ + void *data1; /* pointer to the second argument */ +}; + +/** + * The sandbox driver public functions + */ + +/** + * sandbox_ffa_query_core_state - Queries the status of FF-A ABIs + */ +int sandbox_ffa_query_core_state(u32 queried_func_id, struct ffa_sandbox_data *func_data); + +/** + * sandbox_ffa_get_device - create, bind and probe the sandbox_arm_ffa device + */ +int sandbox_ffa_device_get(void); + +/** + * sandbox_arm_ffa_smccc_smc - FF-A SMC call emulation + */ +void sandbox_arm_ffa_smccc_smc(ffa_value_t args, ffa_value_t *res); + +#endif diff --git a/lib/efi_loader/efi_boottime.c b/lib/efi_loader/efi_boottime.c index b0b61bc812..8f18d16173 100644 --- a/lib/efi_loader/efi_boottime.c +++ b/lib/efi_loader/efi_boottime.c @@ -2185,7 +2185,7 @@ static efi_status_t EFIAPI efi_exit_boot_services(efi_handle_t image_handle, dm_remove_devices_flags(DM_REMOVE_ACTIVE_ALL); }
-#if CONFIG_IS_ENABLED(ARM_FFA_TRANSPORT) +#if CONFIG_IS_ENABLED(ARM_FFA_TRANSPORT) && !CONFIG_IS_ENABLED(SANDBOX_FFA) /* unmap FF-A RX/TX buffers */ if (ffa_bus_ops_get()->rxtx_unmap()) log_err("Can't unmap FF-A RX/TX buffers\n");
Add functional test cases for the FF-A core driver
These tests rely on the FF-A Sandbox driver which helps in inspecting the FF-A core driver.
v7: set the tests to use 64-bit direct messaging
v4: align sandbox tests with the new FF-A driver interfaces and new way of error handling
v1: introduce sandbox tests
MAINTAINERS | 1 + test/dm/Makefile | 2 + test/dm/ffa.c | 394 +++++++++++++++++++++++++++++++++++++++++++++++ 3 files changed, 397 insertions(+) create mode 100644 test/dm/ffa.c
diff --git a/MAINTAINERS b/MAINTAINERS index 1d745b175d..d87f1865b5 100644 --- a/MAINTAINERS +++ b/MAINTAINERS @@ -271,6 +271,7 @@ F: doc/arch/arm64.ffa.rst F: drivers/firmware/arm-ffa/ F: include/arm_ffa.h F: include/sandbox_arm_ffa.h +F: test/dm/ffa.c
ARM FREESCALE IMX M: Stefano Babic sbabic@denx.de diff --git a/test/dm/Makefile b/test/dm/Makefile index cc3cc454f7..9691821f81 100644 --- a/test/dm/Makefile +++ b/test/dm/Makefile @@ -1,6 +1,7 @@ # SPDX-License-Identifier: GPL-2.0+ # # Copyright (c) 2013 Google, Inc +# (C) Copyright 2022 ARM Limited
obj-$(CONFIG_UT_DM) += test-dm.o
@@ -83,6 +84,7 @@ obj-$(CONFIG_POWER_DOMAIN) += power-domain.o obj-$(CONFIG_ACPI_PMC) += pmc.o obj-$(CONFIG_DM_PMIC) += pmic.o obj-$(CONFIG_DM_PWM) += pwm.o +obj-$(CONFIG_SANDBOX_FFA) += ffa.o obj-$(CONFIG_QFW) += qfw.o obj-$(CONFIG_RAM) += ram.o obj-y += regmap.o diff --git a/test/dm/ffa.c b/test/dm/ffa.c new file mode 100644 index 0000000000..14b19cf71e --- /dev/null +++ b/test/dm/ffa.c @@ -0,0 +1,394 @@ +// SPDX-License-Identifier: GPL-2.0+ +/* + * Functional tests for UCLASS_FFA class + * + * (C) Copyright 2022 ARM Limited + * Abdellatif El Khlifi abdellatif.elkhlifi@arm.com + */ + +#include <common.h> +#include <console.h> +#include <dm.h> +#include <dm/test.h> +#include "../../drivers/firmware/arm-ffa/sandbox_arm_ffa_prv.h" +#include <sandbox_arm_ffa.h> +#include <test/test.h> +#include <test/ut.h> + +/* Macros */ + +#define LOG_MSG_SZ (100) +#define LOG_CMD_SZ (LOG_MSG_SZ * 2) + +/* Functional tests for the UCLASS_FFA */ + +static int dm_test_ffa_log(struct unit_test_state *uts, char *msg) +{ + char cmd[LOG_CMD_SZ] = {0}; + + console_record_reset(); + + snprintf(cmd, LOG_CMD_SZ, "echo "%s"", msg); + run_command(cmd, 0); + + ut_assert_console_end(); + + return CMD_RET_SUCCESS; +} + +static int check_fwk_version(struct ffa_prvdata *prvdata, struct sandbox_ffa_prvdata *sdx_prvdata, + struct unit_test_state *uts) +{ + if (prvdata->fwk_version != sdx_prvdata->fwk_version) { + char msg[LOG_MSG_SZ] = {0}; + + snprintf(msg, LOG_MSG_SZ, + "[%s]: Error: framework version: core = 0x%x , sandbox = 0x%x", __func__, + prvdata->fwk_version, + sdx_prvdata->fwk_version); + + dm_test_ffa_log(uts, msg); + return CMD_RET_FAILURE; + } + return CMD_RET_SUCCESS; +} + +static int check_endpoint_id(struct ffa_prvdata *prvdata, struct unit_test_state *uts) +{ + if (prvdata->id) { + char msg[LOG_MSG_SZ] = {0}; + + snprintf(msg, LOG_MSG_SZ, + "[%s]: Error: endpoint id: core = 0x%x", __func__, prvdata->id); + dm_test_ffa_log(uts, msg); + return CMD_RET_FAILURE; + } + return CMD_RET_SUCCESS; +} + +static int check_core_dev(struct ffa_prvdata *prvdata, struct unit_test_state *uts) +{ + if (!prvdata->dev) { + char msg[LOG_MSG_SZ] = {0}; + + snprintf(msg, LOG_MSG_SZ, "[%s]: Error: core device NULL", __func__); + dm_test_ffa_log(uts, msg); + return CMD_RET_FAILURE; + } + return CMD_RET_SUCCESS; +} + +static int check_sandbox_dev(struct sandbox_ffa_prvdata *sdx_prvdata, struct unit_test_state *uts) +{ + if (!sdx_prvdata->dev) { + char msg[LOG_MSG_SZ] = {0}; + + snprintf(msg, LOG_MSG_SZ, "[%s]: Error: sandbox device NULL", __func__); + dm_test_ffa_log(uts, msg); + return CMD_RET_FAILURE; + } + return CMD_RET_SUCCESS; +} + +static int check_rxtxbuf(struct ffa_prvdata *prvdata, struct unit_test_state *uts) +{ + if (!prvdata->pair.rxbuf && prvdata->pair.txbuf) { + char msg[LOG_MSG_SZ] = {0}; + + snprintf(msg, LOG_MSG_SZ, "[%s]: Error: rxbuf = 0x%llx txbuf = 0x%llx", __func__, + prvdata->pair.rxbuf, + prvdata->pair.txbuf); + dm_test_ffa_log(uts, msg); + return CMD_RET_FAILURE; + } + return CMD_RET_SUCCESS; +} + +static int check_features(struct ffa_prvdata *prvdata, struct unit_test_state *uts) +{ + char msg[LOG_MSG_SZ] = {0}; + + if (prvdata->pair.rxtx_min_pages != RXTX_4K && + prvdata->pair.rxtx_min_pages != RXTX_16K && + prvdata->pair.rxtx_min_pages != RXTX_64K) { + snprintf(msg, + LOG_MSG_SZ, + "[%s]: Error: FFA_RXTX_MAP features = 0x%lx", + __func__, + prvdata->pair.rxtx_min_pages); + dm_test_ffa_log(uts, msg); + return CMD_RET_FAILURE; + } + + return CMD_RET_SUCCESS; +} + +static int check_rxbuf_mapped_flag(u32 queried_func_id, + u8 rxbuf_mapped, + struct unit_test_state *uts) +{ + char msg[LOG_MSG_SZ] = {0}; + + switch (queried_func_id) { + case FFA_RXTX_MAP: + { + if (rxbuf_mapped) + return CMD_RET_SUCCESS; + break; + } + case FFA_RXTX_UNMAP: + { + if (!rxbuf_mapped) + return CMD_RET_SUCCESS; + break; + } + default: + return CMD_RET_FAILURE; + } + + snprintf(msg, LOG_MSG_SZ, "[%s]: Error: %s mapping issue", __func__, + (queried_func_id == FFA_RXTX_MAP ? "FFA_RXTX_MAP" : "FFA_RXTX_UNMAP")); + dm_test_ffa_log(uts, msg); + + return CMD_RET_FAILURE; +} + +static int check_rxbuf_release_flag(u8 rxbuf_owned, struct unit_test_state *uts) +{ + if (rxbuf_owned) { + char msg[LOG_MSG_SZ] = {0}; + + snprintf(msg, LOG_MSG_SZ, "[%s]: Error: RX buffer not released", __func__); + dm_test_ffa_log(uts, msg); + return CMD_RET_FAILURE; + } + return CMD_RET_SUCCESS; +} + +static int test_ffa_msg_send_direct_req(u16 part_id, struct unit_test_state *uts) +{ + struct ffa_send_direct_data msg = {0}; + u8 cnt; + + ut_assertok(ffa_bus_ops_get()->sync_send_receive(part_id, &msg, 1)); + + for (cnt = 0; cnt < sizeof(struct ffa_send_direct_data) / sizeof(u64); cnt++) + ut_assertok(((u64 *)&msg)[cnt] != 0xffffffffffffffff); + + return CMD_RET_SUCCESS; +} + +static int test_partitions_and_comms(const char *service_uuid, + struct sandbox_ffa_prvdata *sdx_prvdata, + struct unit_test_state *uts) +{ + u32 count = 0, size = 0; + struct ffa_partition_info *parts_info; + u32 info_idx, exp_info_idx; + int ret; + + /* + * get from the driver the count of the SPs matching the UUID + */ + ret = ffa_bus_ops_get()->partition_info_get(service_uuid, &count, NULL); + /* make sure partitions are detected */ + ut_assertok(ret != 0); + ut_assertok(count != SANDBOX_SP_COUNT_PER_VALID_SERVICE); + + /* + * pre-allocate a buffer to be filled by the driver + * with ffa_partition_info structs + */ + + parts_info = calloc(count, sizeof(struct ffa_partition_info)); + ut_assertok(!parts_info); + + size = count * sizeof(struct ffa_partition_info); + + /* + * ask the driver to fill the buffer with the SPs info + */ + ret = ffa_bus_ops_get()->partition_info_get(service_uuid, &size, parts_info); + if (ret != 0) { + free(parts_info); + ut_assertok(ret != 0); + } + + /* + * SPs found , verify the partitions information + */ + + ret = CMD_RET_FAILURE; + + for (info_idx = 0; info_idx < count ; info_idx++) { + for (exp_info_idx = 0; + exp_info_idx < sdx_prvdata->partitions.count; + exp_info_idx++) { + if (parts_info[info_idx].id == + sdx_prvdata->partitions.descs[exp_info_idx].info.id) { + ret = memcmp(&parts_info[info_idx], + &sdx_prvdata->partitions.descs[exp_info_idx] + .info, + sizeof(struct ffa_partition_info)); + if (ret) + free(parts_info); + ut_assertok(ret != 0); + /* send and receive data from the current partition */ + test_ffa_msg_send_direct_req(parts_info[info_idx].id, uts); + } + ret = CMD_RET_SUCCESS; + } + } + + free(parts_info); + + /* Verify expected partitions found in the emulated secure world*/ + ut_assertok(ret != CMD_RET_SUCCESS); + + return CMD_RET_SUCCESS; +} + +static int dm_test_ffa_ack(struct unit_test_state *uts) +{ + struct ffa_prvdata *prvdata = NULL; + struct sandbox_ffa_prvdata *sdx_prvdata = NULL; + struct ffa_sandbox_data func_data = {0}; + u8 rxbuf_flag = 0; + const char *svc1_uuid = SANDBOX_SERVICE1_UUID; + const char *svc2_uuid = SANDBOX_SERVICE2_UUID; + int ret; + + /* test probing FF-A devices */ + ut_assertok(ffa_bus_discover()); + + /* get a pointer to the FF-A core and sandbox drivers private data */ + func_data.data0 = &prvdata; + func_data.data0_size = sizeof(prvdata); + func_data.data1 = &sdx_prvdata; + func_data.data1_size = sizeof(sdx_prvdata); + + ut_assertok(sandbox_ffa_query_core_state(FFA_VERSION, &func_data)); + + /* make sure private data pointers are retrieved */ + ut_assertok(prvdata == 0); + ut_assertok(sdx_prvdata == 0); + + /* make sure dev devices created */ + ut_assertok(check_core_dev(prvdata, uts)); + ut_assertok(check_sandbox_dev(sdx_prvdata, uts)); + + /* test FFA_VERSION */ + ut_assertok(check_fwk_version(prvdata, sdx_prvdata, uts)); + + /* test FFA_ID_GET */ + ut_assertok(check_endpoint_id(prvdata, uts)); + + /* test FFA_FEATURES */ + ut_assertok(check_features(prvdata, uts)); + + /* test core RX/TX buffers */ + ut_assertok(check_rxtxbuf(prvdata, uts)); + + /* test FFA_RXTX_MAP */ + func_data.data0 = &rxbuf_flag; + func_data.data0_size = sizeof(rxbuf_flag); + + rxbuf_flag = 0; + ut_assertok(sandbox_ffa_query_core_state(FFA_RXTX_MAP, &func_data)); + ut_assertok(check_rxbuf_mapped_flag(FFA_RXTX_MAP, rxbuf_flag, uts)); + + /* FFA_PARTITION_INFO_GET / FFA_MSG_SEND_DIRECT_REQ */ + ret = test_partitions_and_comms(svc1_uuid, sdx_prvdata, uts); + ut_assertok(ret != CMD_RET_SUCCESS); + + /* test FFA_RX_RELEASE */ + rxbuf_flag = 1; + ut_assertok(sandbox_ffa_query_core_state(FFA_RX_RELEASE, &func_data)); + ut_assertok(check_rxbuf_release_flag(rxbuf_flag, uts)); + + /* FFA_PARTITION_INFO_GET / FFA_MSG_SEND_DIRECT_REQ */ + ret = test_partitions_and_comms(svc2_uuid, sdx_prvdata, uts); + ut_assertok(ret != CMD_RET_SUCCESS); + + /* test FFA_RX_RELEASE */ + rxbuf_flag = 1; + ut_assertok(sandbox_ffa_query_core_state(FFA_RX_RELEASE, &func_data)); + ut_assertok(check_rxbuf_release_flag(rxbuf_flag, uts)); + + /* test FFA_RXTX_UNMAP */ + ut_assertok(ffa_bus_ops_get()->rxtx_unmap()); + + rxbuf_flag = 1; + ut_assertok(sandbox_ffa_query_core_state(FFA_RXTX_UNMAP, &func_data)); + ut_assertok(check_rxbuf_mapped_flag(FFA_RXTX_UNMAP, rxbuf_flag, uts)); + + return CMD_RET_SUCCESS; +} + +DM_TEST(dm_test_ffa_ack, UT_TESTF_SCAN_FDT | UT_TESTF_CONSOLE_REC); + +static int dm_test_ffa_nack(struct unit_test_state *uts) +{ + struct ffa_prvdata *prvdata = NULL; + struct sandbox_ffa_prvdata *sdx_prvdata = NULL; + struct ffa_sandbox_data func_data = {0}; + const char *valid_svc_uuid = SANDBOX_SERVICE1_UUID; + const char *unvalid_svc_uuid = SANDBOX_SERVICE3_UUID; + const char *unvalid_svc_uuid_str = SANDBOX_SERVICE4_UUID; + struct ffa_send_direct_data msg = {0}; + int ret; + u32 count = 0; + u16 part_id = 0; + + /* test probing FF-A devices */ + ut_assertok(ffa_bus_discover()); + + /* get a pointer to the FF-A core and sandbox drivers private data */ + func_data.data0 = &prvdata; + func_data.data0_size = sizeof(prvdata); + func_data.data1 = &sdx_prvdata; + func_data.data1_size = sizeof(sdx_prvdata); + + ut_assertok(sandbox_ffa_query_core_state(FFA_VERSION, &func_data)); + + /* make sure private data pointers are retrieved */ + ut_assertok(prvdata == 0); + ut_assertok(sdx_prvdata == 0); + + /* make sure dev devices created */ + ut_assertok(check_core_dev(prvdata, uts)); + ut_assertok(check_sandbox_dev(sdx_prvdata, uts)); + + /* query partitions count using invalid arguments */ + ret = ffa_bus_ops_get()->partition_info_get(unvalid_svc_uuid, NULL, NULL); + ut_assertok(ret != -EINVAL); + + /* query partitions count using an invalid UUID string */ + ret = ffa_bus_ops_get()->partition_info_get(unvalid_svc_uuid_str, &count, NULL); + ut_assertok(ret != -EINVAL); + + /* query partitions count using an invalid UUID (no matching SP) */ + count = 0; + ret = ffa_bus_ops_get()->partition_info_get(unvalid_svc_uuid, &count, NULL); + ut_assertok(count != 0); + + /* query partitions count using a valid UUID */ + count = 0; + ret = ffa_bus_ops_get()->partition_info_get(valid_svc_uuid, &count, NULL); + /* make sure partitions are detected */ + ut_assertok(ret != 0); + ut_assertok(count != SANDBOX_SP_COUNT_PER_VALID_SERVICE); + + /* send data to an invalid partition */ + ret = ffa_bus_ops_get()->sync_send_receive(part_id, &msg, 1); + ut_assertok(ret != -EINVAL); + + /* send data to a valid partition */ + part_id = prvdata->partitions.descs[0].info.id; + ret = ffa_bus_ops_get()->sync_send_receive(part_id, &msg, 1); + ut_assertok(ret != 0); + + return CMD_RET_SUCCESS; +} + +DM_TEST(dm_test_ffa_nack, UT_TESTF_SCAN_FDT | UT_TESTF_CONSOLE_REC);
Add Sandbox test for the armffa command
v4: drop use of helper APIs
v1: introduce armffa command sandbox test
MAINTAINERS | 1 + test/cmd/Makefile | 2 ++ test/cmd/armffa.c | 40 ++++++++++++++++++++++++++++++++++++++++ 3 files changed, 43 insertions(+) create mode 100644 test/cmd/armffa.c
diff --git a/MAINTAINERS b/MAINTAINERS index d87f1865b5..729e11a69f 100644 --- a/MAINTAINERS +++ b/MAINTAINERS @@ -271,6 +271,7 @@ F: doc/arch/arm64.ffa.rst F: drivers/firmware/arm-ffa/ F: include/arm_ffa.h F: include/sandbox_arm_ffa.h +F: test/cmd/armffa.c F: test/dm/ffa.c
ARM FREESCALE IMX diff --git a/test/cmd/Makefile b/test/cmd/Makefile index 6dd6e81875..4c40aefb3b 100644 --- a/test/cmd/Makefile +++ b/test/cmd/Makefile @@ -1,6 +1,7 @@ # SPDX-License-Identifier: GPL-2.0+ # # Copyright (c) 2013 Google, Inc +# (C) Copyright 2022 ARM Limited
ifdef CONFIG_HUSH_PARSER obj-$(CONFIG_CONSOLE_RECORD) += test_echo.o @@ -18,5 +19,6 @@ obj-$(CONFIG_CMD_PINMUX) += pinmux.o obj-$(CONFIG_CMD_PWM) += pwm.o ifdef CONFIG_SANDBOX obj-$(CONFIG_CMD_SETEXPR) += setexpr.o +obj-$(CONFIG_SANDBOX_FFA) += armffa.o endif obj-$(CONFIG_CMD_TEMPERATURE) += temperature.o diff --git a/test/cmd/armffa.c b/test/cmd/armffa.c new file mode 100644 index 0000000000..531f82066e --- /dev/null +++ b/test/cmd/armffa.c @@ -0,0 +1,40 @@ +// SPDX-License-Identifier: GPL-2.0+ +/* + * Test for armffa command + * + * (C) Copyright 2022 ARM Limited + * Abdellatif El Khlifi abdellatif.elkhlifi@arm.com + */ + +#include <common.h> +#include <dm.h> +#include <dm/test.h> +#include <sandbox_arm_ffa.h> +#include <string.h> +#include <test/test.h> +#include <test/ut.h> + +#define PING_CMD_SIZE 19 + +/* Basic test of 'armffa' command */ +static int dm_test_armffa_cmd(struct unit_test_state *uts) +{ + char ping_cmd[PING_CMD_SIZE] = {0}; + + ut_assertok(ffa_bus_discover()); + + /* armffa getpart <UUID> */ + ut_assertok(run_command("armffa getpart " SANDBOX_SERVICE1_UUID, 0)); + + snprintf(ping_cmd, PING_CMD_SIZE, "armffa ping 0x%x", SANDBOX_SP1_ID); + + /* armffa ping <ID> */ + ut_assertok(run_command(ping_cmd, 0)); + + /* armffa devlist */ + ut_assertok(run_command("armffa devlist", 0)); + + return CMD_RET_SUCCESS; +} + +DM_TEST(dm_test_armffa_cmd, UT_TESTF_SCAN_FDT | UT_TESTF_CONSOLE_REC);
Add MM communication support using FF-A transport
This feature allows accessing MM partitions services through EFI MM communication protocol. MM partitions such as StandAlonneMM or smm-gateway secure partitions which reside in secure world.
An MM shared buffer and a door bell event are used to exchange the data.
The data is used by EFI services such as GetVariable()/SetVariable() and copied from the communication buffer to the MM shared buffer.
The secure partition is notified about availability of data in the MM shared buffer by an FF-A message (door bell).
On such event, MM SP can read the data and updates the MM shared buffer with the response data.
The response data is copied back to the communication buffer and consumed by the EFI subsystem.
MM communication protocol supports FF-A 64-bit direct messaging.
Signed-off-by: Abdellatif El Khlifi abdellatif.elkhlifi@arm.com Signed-off-by: Gowtham Suresh Kumar gowtham.sureshkumar@arm.com Cc: Tom Rini trini@konsulko.com Cc: Simon Glass sjg@chromium.org Cc: Ilias Apalodimas ilias.apalodimas@linaro.org Cc: Jens Wiklander jens.wiklander@linaro.org
v7:
* set the MM door bell event to use 64-bit direct messaging * issue a compile time error when one of these macros are not found : FFA_SHARED_MM_BUFFER_SIZE, FFA_SHARED_MM_BUFFER_OFFSET, FFA_SHARED_MM_BUFFER_ADDR * make mm_sp_svc_uuid static * replace EINVAL with ENOMEM in ffa_discover_mm_sp_id() when calloc() fails * improve use of unmap_sysmem() in ffa_mm_communicate()
v6:
* add FF-A runtime discovery at MM communication level * drop EFI runtime support for FF-A MM communication * revert the changes in include/mm_communication.h for efi_mm_communicate_header and smm_variable_access structures
v4:
* use the new FF-A driver interfaces * discover MM partitions at runtime * copy FF-A driver private data to EFI runtime section at ExitBootServices() * drop use of FFA_ERR_STAT_SUCCESS error code * replace EFI_BUFFER_TOO_SMALL with EFI_OUT_OF_RESOURCES in ffa_mm_communicate(). No need for efi_memcpy_runtime() anymore * revert the error log in mm_communicate() in case of failure * remove packed attribute from efi_mm_communicate_header and smm_variable_communicate_header
v2:
* set default values to 0 for FFA_SHARED_MM_BUFFER_SIZE, FFA_SHARED_MM_BUFFER_ADDR and MM_SP_UUID_DATA and add warnings
v1:
* introduce FF-A MM communication
include/mm_communication.h | 5 + lib/efi_loader/Kconfig | 14 +- lib/efi_loader/efi_variable_tee.c | 269 +++++++++++++++++++++++++++++- 3 files changed, 282 insertions(+), 6 deletions(-)
diff --git a/include/mm_communication.h b/include/mm_communication.h index e65fbde60d..d409bed777 100644 --- a/include/mm_communication.h +++ b/include/mm_communication.h @@ -6,6 +6,8 @@ * Copyright (c) 2017, Intel Corporation. All rights reserved. * Copyright (C) 2020 Linaro Ltd. sughosh.ganu@linaro.org * Copyright (C) 2020 Linaro Ltd. ilias.apalodimas@linaro.org + * (C) Copyright 2022 ARM Limited + * Abdellatif El Khlifi abdellatif.elkhlifi@arm.com */
#ifndef _MM_COMMUNICATION_H_ @@ -13,6 +15,9 @@
#include <part_efi.h>
+/* MM service UUID string (big-endian format). This UUID is common across all MM SPs */ +#define MM_SP_UUID "33d532ed-e699-0942-c09c-a798d9cd722d" + /* * Interface to the pseudo Trusted Application (TA), which provides a * communication channel with the Standalone MM (Management Mode) diff --git a/lib/efi_loader/Kconfig b/lib/efi_loader/Kconfig index 41756ea539..f0d843d5ca 100644 --- a/lib/efi_loader/Kconfig +++ b/lib/efi_loader/Kconfig @@ -60,13 +60,23 @@ config EFI_VARIABLE_FILE_STORE stored as file /ubootefi.var on the EFI system partition.
config EFI_MM_COMM_TEE - bool "UEFI variables storage service via OP-TEE" - depends on OPTEE + bool "UEFI variables storage service via the trusted world" + depends on OPTEE && ARM_FFA_TRANSPORT help + Allowing access to the MM SP services (SPs such as StandAlonneMM, smm-gateway). + When using the u-boot OP-TEE driver, StandAlonneMM is supported. + When using the u-boot FF-A driver any MM SP is supported. + If OP-TEE is present and running StandAloneMM, dispatch all UEFI variable related operations to that. The application will verify, authenticate and store the variables on an RPMB.
+ When ARM_FFA_TRANSPORT is used, dispatch all UEFI variable related + operations to the MM SP running in the secure world. + A door bell mechanism is used to notify the SP when there is data in the shared + MM buffer. The data is copied by u-boot to the shared buffer before issuing + the door bell event. + config EFI_VARIABLE_NO_STORE bool "Don't persist non-volatile UEFI variables" help diff --git a/lib/efi_loader/efi_variable_tee.c b/lib/efi_loader/efi_variable_tee.c index dfef18435d..ec5ea4fd63 100644 --- a/lib/efi_loader/efi_variable_tee.c +++ b/lib/efi_loader/efi_variable_tee.c @@ -4,6 +4,8 @@ * * Copyright (C) 2019 Linaro Ltd. sughosh.ganu@linaro.org * Copyright (C) 2019 Linaro Ltd. ilias.apalodimas@linaro.org + * Copyright (C) 2022 ARM Limited + * Abdellatif El Khlifi abdellatif.elkhlifi@arm.com */
#include <common.h> @@ -15,6 +17,36 @@ #include <malloc.h> #include <mm_communication.h>
+#if (IS_ENABLED(CONFIG_ARM_FFA_TRANSPORT)) + +#include <arm_ffa.h> +#include <cpu_func.h> +#include <mapmem.h> + +#ifndef FFA_SHARED_MM_BUFFER_SIZE +#error "FFA_SHARED_MM_BUFFER_SIZE must be defined in include/configs/<board>.h" +#define FFA_SHARED_MM_BUFFER_SIZE 0 +#endif + +#ifndef FFA_SHARED_MM_BUFFER_OFFSET +#error "FFA_SHARED_MM_BUFFER_OFFSET must be defined in include/configs/<board>.h" +#define FFA_SHARED_MM_BUFFER_OFFSET 0 +#endif + +#ifndef FFA_SHARED_MM_BUFFER_ADDR +#error "FFA_SHARED_MM_BUFFER_ADDR must be defined in include/configs/<board>.h" +#define FFA_SHARED_MM_BUFFER_ADDR 0 +#endif + +/* MM return codes */ +#define MM_SUCCESS (0) + +static const char *mm_sp_svc_uuid = MM_SP_UUID; + +static u16 mm_sp_id; + +#endif + extern struct efi_var_file __efi_runtime_data *efi_var_buf; static efi_uintn_t max_buffer_size; /* comm + var + func + data */ static efi_uintn_t max_payload_size; /* func + data */ @@ -24,6 +56,7 @@ struct mm_connection { u32 session; };
+#if (IS_ENABLED(CONFIG_OPTEE)) /** * get_connection() - Retrieve OP-TEE session for a specific UUID. * @@ -143,13 +176,229 @@ static efi_status_t optee_mm_communicate(void *comm_buf, ulong dsize)
return ret; } +#endif + +#if (IS_ENABLED(CONFIG_ARM_FFA_TRANSPORT)) + +/** + * ffa_notify_mm_sp() - Announce there is data in the shared buffer + * + * Notifies the MM partition in the trusted world that + * data is available in the shared buffer. + * This is a blocking call during which trusted world has exclusive access + * to the MM shared buffer. + * + * Return: + * + * 0 on success + */ +static int ffa_notify_mm_sp(void) +{ + struct ffa_send_direct_data msg = {0}; + int ret; + int sp_event_ret = -1; + + if (!ffa_bus_ops_get()) + return -EINVAL; + + msg.data0 = FFA_SHARED_MM_BUFFER_OFFSET; /* x3 */ + + ret = ffa_bus_ops_get()->sync_send_receive(mm_sp_id, &msg, 1); + if (ret != 0) + return ret; + + sp_event_ret = msg.data0; /* x3 */ + + if (sp_event_ret == MM_SUCCESS) + return 0; + + /* + * Failure to notify the MM SP + */ + + return -EACCES; +} + +/** + * ffa_discover_mm_sp_id() - Query the MM partition ID + * + * Use the FF-A driver to get the MM partition ID. + * If multiple partitions are found, use the first one. + * This is a boot time function. + * + * Return: + * + * 0 on success + */ +static int ffa_discover_mm_sp_id(void) +{ + u32 count = 0, size = 0; + int ret; + struct ffa_partition_info *parts_info; + + if (!ffa_bus_ops_get()) + return -EINVAL; + + /* + * get from the driver the count of the SPs matching the UUID + */ + ret = ffa_bus_ops_get()->partition_info_get(mm_sp_svc_uuid, &count, NULL); + if (ret != 0) { + log_err("EFI: Failure in querying partitions count (error code: %d)\n", ret); + return ret; + } + + if (!count) { + log_info("EFI: No MM partition found\n"); + return ret; + } + + /* + * pre-allocate a buffer to be filled by the driver + * with ffa_partition_info structs + */ + + log_info("EFI: Pre-allocating %d partition(s) info structures\n", count); + + parts_info = calloc(count, sizeof(struct ffa_partition_info)); + if (!parts_info) + return -ENOMEM; + + size = count * sizeof(struct ffa_partition_info); + + /* + * ask the driver to fill the + * buffer with the SPs info + */ + ret = ffa_bus_ops_get()->partition_info_get(mm_sp_svc_uuid, &size, parts_info); + if (ret != 0) { + log_err("EFI: Failure in querying partition(s) info (error code: %d)\n", ret); + free(parts_info); + return ret; + } + + /* + * MM SPs found , use the first one + */ + + mm_sp_id = parts_info[0].id; + + log_info("EFI: MM partition ID 0x%x\n", mm_sp_id); + + free(parts_info); + + return 0; +}
/** - * mm_communicate() - Adjust the cmonnucation buffer to StandAlonneMM and send + * ffa_mm_communicate() - Exchange EFI services data with the MM partition using FF-A + * @comm_buf: locally allocated communication buffer used for rx/tx + * @dsize: communication buffer size + * + * Issues a door bell event to notify the MM partition (SP) running in OP-TEE + * that there is data to read from the shared buffer. + * Communication with the MM SP is performed using FF-A transport. + * On the event, MM SP can read the data from the buffer and + * update the MM shared buffer with response data. + * The response data is copied back to the communication buffer. + * + * Return: + * + * EFI status code + */ +static efi_status_t ffa_mm_communicate(void *comm_buf, ulong comm_buf_size) +{ + ulong tx_data_size; + int ffa_ret; + efi_status_t efi_ret; + struct efi_mm_communicate_header *mm_hdr; + void *virt_shared_buf; + + if (!comm_buf) + return EFI_INVALID_PARAMETER; + + /* Discover MM partition ID at boot time */ + if (!mm_sp_id && ffa_discover_mm_sp_id() != 0) { + log_err("EFI: Failure to discover MM partition ID at boot time\n"); + return EFI_UNSUPPORTED; + } + + mm_hdr = (struct efi_mm_communicate_header *)comm_buf; + tx_data_size = mm_hdr->message_len + sizeof(efi_guid_t) + sizeof(size_t); + + if (comm_buf_size != tx_data_size || tx_data_size > FFA_SHARED_MM_BUFFER_SIZE) + return EFI_INVALID_PARAMETER; + + /* Copy the data to the shared buffer */ + + virt_shared_buf = (void *)map_sysmem((phys_addr_t)FFA_SHARED_MM_BUFFER_ADDR, 0); + memcpy(virt_shared_buf, comm_buf, tx_data_size); + + /* + * The secure world might have cache disabled for + * the device region used for shared buffer (which is the case for Optee). + * In this case, the secure world reads the data from DRAM. + * Let's flush the cache so the DRAM is updated with the latest data. + */ + #ifdef CONFIG_ARM64 + invalidate_dcache_all(); + #endif + + /* Announce there is data in the shared buffer */ + + ffa_ret = ffa_notify_mm_sp(); + + switch (ffa_ret) { + case 0: + { + ulong rx_data_size; + /* Copy the MM SP response from the shared buffer to the communication buffer */ + rx_data_size = ((struct efi_mm_communicate_header *)virt_shared_buf)->message_len + + sizeof(efi_guid_t) + + sizeof(size_t); + + if (rx_data_size > comm_buf_size) { + efi_ret = EFI_OUT_OF_RESOURCES; + break; + } + + memcpy(comm_buf, virt_shared_buf, rx_data_size); + efi_ret = EFI_SUCCESS; + break; + } + case -EINVAL: + efi_ret = EFI_DEVICE_ERROR; + break; + case -EPERM: + efi_ret = EFI_INVALID_PARAMETER; + break; + case -EACCES: + efi_ret = EFI_ACCESS_DENIED; + break; + case -EBUSY: + efi_ret = EFI_OUT_OF_RESOURCES; + break; + default: + efi_ret = EFI_ACCESS_DENIED; + } + + unmap_sysmem(virt_shared_buf); + return efi_ret; +} +#endif + +/** + * mm_communicate() - Adjust the communication buffer to the MM SP and send * it to OP-TEE * - * @comm_buf: locally allocted communcation buffer + * @comm_buf: locally allocated communication buffer * @dsize: buffer size + * + * The SP (also called partition) can be any MM SP such as StandAlonneMM or smm-gateway. + * The comm_buf format is the same for both partitions. + * When using the u-boot OP-TEE driver, StandAlonneMM is supported. + * When using the u-boot FF-A driver, any MM SP is supported. + * * Return: status code */ static efi_status_t mm_communicate(u8 *comm_buf, efi_uintn_t dsize) @@ -162,7 +411,12 @@ static efi_status_t mm_communicate(u8 *comm_buf, efi_uintn_t dsize) mm_hdr = (struct efi_mm_communicate_header *)comm_buf; var_hdr = (struct smm_variable_communicate_header *)mm_hdr->data;
- ret = optee_mm_communicate(comm_buf, dsize); + ret = ffa_bus_discover(); + if (ret != 0) + ret = optee_mm_communicate(comm_buf, dsize); + else + ret = ffa_mm_communicate(comm_buf, dsize); + if (ret != EFI_SUCCESS) { log_err("%s failed!\n", __func__); return ret; @@ -258,6 +512,13 @@ efi_status_t EFIAPI get_max_payload(efi_uintn_t *size) goto out; } *size = var_payload->size; + + #if (IS_ENABLED(CONFIG_ARM_FFA_TRANSPORT)) + if (*size > FFA_SHARED_MM_BUFFER_SIZE) + *size = FFA_SHARED_MM_BUFFER_SIZE - MM_COMMUNICATE_HEADER_SIZE - + MM_VARIABLE_COMMUNICATE_SIZE; + #endif + /* * There seems to be a bug in EDK2 miscalculating the boundaries and * size checks, so deduct 2 more bytes to fulfill this requirement. Fix @@ -697,7 +958,7 @@ void efi_variables_boot_exit_notify(void) ret = EFI_NOT_FOUND;
if (ret != EFI_SUCCESS) - log_err("Unable to notify StMM for ExitBootServices\n"); + log_err("Unable to notify the MM partition for ExitBootServices\n"); free(comm_buf);
Hi Abdellatif
- depends on OPTEE
- bool "UEFI variables storage service via the trusted world"
- depends on OPTEE && ARM_FFA_TRANSPORT
This shouldn't rely on both. It's either OP-TEE or FF-A
This separation is a bit problematic. A user can configure bot OP-TEE and FF-A. Those are not mutually exclusive, but for the EFI variables case they are. We need a better way to isolate the compilation choices. Why don't we make ffa_bus_discover() return -1 if FF-A isn't compiled in?
- get_connection() - Retrieve OP-TEE session for a specific UUID.
- ffa_notify_mm_sp() - Announce there is data in the shared buffer
- Notifies the MM partition in the trusted world that
- data is available in the shared buffer.
- This is a blocking call during which trusted world has exclusive access
- to the MM shared buffer.
- Return:
- 0 on success
- struct ffa_send_direct_data msg = {0};
- int ret;
- int sp_event_ret = -1;
- if (!ffa_bus_ops_get())
return -EINVAL;
- msg.data0 = FFA_SHARED_MM_BUFFER_OFFSET; /* x3 */
- ret = ffa_bus_ops_get()->sync_send_receive(mm_sp_id, &msg, 1);
- if (ret != 0)
return ret;
- sp_event_ret = msg.data0; /* x3 */
- if (sp_event_ret == MM_SUCCESS)
- return -EACCES;
- ffa_discover_mm_sp_id() - Query the MM partition ID
- Use the FF-A driver to get the MM partition ID.
- If multiple partitions are found, use the first one.
- This is a boot time function.
- Return:
- 0 on success
- u32 count = 0, size = 0;
- int ret;
- struct ffa_partition_info *parts_info;
return -EINVAL;
- ret = ffa_bus_ops_get()->partition_info_get(mm_sp_svc_uuid, &count, NULL);
- if (ret != 0) {
return ret;
- if (!count) {
return ret;
- log_info("EFI: Pre-allocating %d partition(s) info structures\n", count);
- parts_info = calloc(count, sizeof(struct ffa_partition_info));
I prefer sizeof(*parts_info). Same goes for all sizeof() calls.
- if (!parts_info)
return -ENOMEM;
- size = count * sizeof(struct ffa_partition_info);
- ret = ffa_bus_ops_get()->partition_info_get(mm_sp_svc_uuid, &size, parts_info);
- if (ret != 0) {
if (!ret)
Thanks /Ilias
On Tue, Nov 15, 2022 at 11:03:51AM +0200, Ilias Apalodimas wrote:
Hi Abdellatif
- depends on OPTEE
Thanks. Addressed in v8 patchset.
I agree, this is addressed in v8 patchset.
- Return:
- 0 on success
- int ret;
return -EINVAL;
- if (ret != 0)
return ret;
- return -EACCES;
- Return:
- 0 on success
- int ret;
return -EINVAL;
- if (ret != 0) {
return ret;
- if (!count) {
return ret;
- if (!parts_info)
return -ENOMEM;
- if (ret != 0) {
if (!ret)
Thanks /Ilias
turn on EFI MM communication
On corstone1000 platform MM communication between u-boot and the secure world (Optee) is done using the FF-A bus.
Signed-off-by: Abdellatif El Khlifi abdellatif.elkhlifi@arm.com Cc: Tom Rini trini@konsulko.com Cc: Simon Glass sjg@chromium.org Cc: Ilias Apalodimas ilias.apalodimas@linaro.org Cc: Jens Wiklander jens.wiklander@linaro.org
Changelog: ===============
v7:
* improve the definition of FFA_SHARED_MM_BUFFER_ADDR and FFA_SHARED_MM_BUFFER_OFFSET * update FFA_SHARED_MM_BUFFER_ADDR value
v6:
* corstone-1000: enable optee driver * corstone-1000: remove CONFIG_ARM_FFA_EFI_RUNTIME_MODE from the defconfig
v4:
* corstone-1000: turn on EFI MM communication
configs/corstone1000_defconfig | 4 ++++ include/configs/corstone1000.h | 9 +++++++++ 2 files changed, 13 insertions(+)
diff --git a/configs/corstone1000_defconfig b/configs/corstone1000_defconfig index dddfa27507..d827dd72f1 100644 --- a/configs/corstone1000_defconfig +++ b/configs/corstone1000_defconfig @@ -52,3 +52,7 @@ CONFIG_DM_SERIAL=y CONFIG_USB=y CONFIG_USB_ISP1760=y CONFIG_ERRNO_STR=y +CONFIG_EFI_MM_COMM_TEE=y +CONFIG_TEE=y +CONFIG_OPTEE=y +CONFIG_ARM_FFA_TRANSPORT=y diff --git a/include/configs/corstone1000.h b/include/configs/corstone1000.h index 8e0230c135..0362d29ac2 100644 --- a/include/configs/corstone1000.h +++ b/include/configs/corstone1000.h @@ -14,6 +14,15 @@
+#define FFA_SHARED_MM_BUFFER_SIZE SZ_4K /* 4 KB */ + +/* + * shared buffer physical address used for communication between + * u-boot and the MM SP + */ +#define FFA_SHARED_MM_BUFFER_ADDR 0x02000000UL +#define FFA_SHARED_MM_BUFFER_OFFSET 0 + #define V2M_BASE 0x80000000
#define CONFIG_PL011_CLOCK 50000000
On Mon, Nov 07, 2022 at 07:20:45PM +0000, Abdellatif El Khlifi wrote:
Adding support for Arm FF-A v1.0 (Arm Firmware Framework for Armv8-A) [7].
FF-A describes interfaces (ABIs) that standardize communication between the Secure World and Normal World. These interfaces enable a pair of software sandboxes to communicate with each other. A sandbox aka partition could be a VM in the Normal or Secure world, an application in S-EL0, or a Trusted OS in S-EL1.
The FF-A transport is implemented as a data bus and a core driver is provided.
This implementation of the specification provides support for Aarch64.
The FF-A driver uses the SMC ABIs defined by the FF-A specification to:
- Discover the presence of secure partitions (SPs) of interest - Access an SP's service through communication protocols e.g. EFI MM communication protocol
The FF-A support provides the following features:
- Being generic by design and can be used by any Arm 64-bit platform - The FF-A core driver - The FF-A bus is discoverable on demand at runtime - The driver provides driver operations to be used by clients to access the FF-A bus - FF-A driver can be compiled and used without EFI - Support for SMCCCv1.2 x0-x17 registers - Support for SMC32 calling convention - Support for 32-bit and 64-bit FF-A direct messaging - A new command called armffa is provided as an example of how to access the FF-A bus - An FF-A Sandbox driver is provided with test cases - Support for FF-A MM communication (compatible with EFI boot time) - Enabling FF-A and MM communication in Corstone1000 platform
For more details about the FF-A core driver please refer to [8].
Please find at [9] an example of the expected boot logs when enabling FF-A support for a platform. In this example the platform is Corstone1000. But it can be any Arm 64-bit platform.
Changelog of the major changes:
v7:
- add support for 32-bit direct messaging (now we have 32-bit and 64-bit support)
- set the MM door bell event to use 64-bit direct messaging
- issue a compile time error when one of these macros are not found : FFA_SHARED_MM_BUFFER_SIZE, FFA_SHARED_MM_BUFFER_OFFSET, FFA_SHARED_MM_BUFFER_ADDR
- make uuid_str_to_le_bin() implementation similar to uuid_str_to_bin() by using same APIs
Hi Ilias, Jens,
After addressing your current comments for v7 patchset, which patches are you happy with so I could add the Reviewed-by: to the commits logs ?
Cheers
v6: [6]
- remove clearing x0-x17 registers after SMC calls
- drop use of EFI runtime support for FF-A (We decided with Linaro to add this later)
- drop discovery from initcalls (discovery will be on demand by FF-A users)
- add FF-A runtime discovery at MM communication level
- update the documentation and move it to doc/arch/arm64.ffa.rst
v5: [5]
- move changelogs in each commit to the changes section
v4: [4]
- add FF-A support README (doc/README.ffa.drv)
- improving error handling by mapping the FF-A errors to standard errors and logs
- replacing panics with an error log
- align sandbox driver and tests with the new FF-A driver interfaces
- use the new FF-A driver interfaces for MM communication
- discover MM partitions at runtime
- copy FF-A driver private data to EFI runtime section at ExitBootServices()
- moving the FF-A driver work to drivers/firmware/arm-ffa
- improving features discovery in FFA_FEATURES
- add remove/unbind functions to the FF-A core device
- improve how the driver behaves when bus discovery is done more than once
- move clearing x0-x17 registers code into a new macro like done in the linux kernel
- enable EFI MM communication for the Corstone1000 platform
v3: [3]
- port x0-x17 registers support from linux kernel as defined by SMCCCv1.2
- align the interfaces of the u-boot FF-A driver with those in the linux FF-A driver
- remove the FF-A helper layer
- make the u-boot FF-A driver independent from EFI
- provide an optional config that enables copying the driver data to EFI runtime section at ExitBootServices service
- use 64-bit version of FFA_RXTX_MAP, FFA_MSG_SEND_DIRECT_{REQ, RESP}
- update armffa command with the new driver interfaces
v2 [2]:
- make FF-A bus discoverable using device_{bind, probe} APIs
- remove device tree support
v1 [1]:
- introduce FF-A bus driver with device tree support
- introduce armffa command
- introduce FF-A Sandbox driver
- add FF-A Sandbox test cases
- introduce FF-A MM communication
Cheers, Abdellatif
[9]: example of boot logs when enabling FF-A
U-Boot 2022.07 (Jul 11 2022 - 13:42:58 +0000) corstone1000 aarch64 ... [FFA] Conduit is SMC [FFA] FF-A driver 1.0 FF-A framework 1.0 [FFA] Versions are compatible [FFA] endpoint ID is 0 [FFA] Using 1 4KB page(s) for RX/TX buffers size [FFA] RX buffer at virtual address 0xfdf18000 [FFA] TX buffer at virtual address 0xfdf1a000 [FFA] RX/TX buffers mapped [FFA] Reading partitions data from the RX buffer [FFA] Partition ID 8001 : info cached [FFA] Partition ID 8002 : info cached [FFA] Partition ID 8003 : info cached [FFA] 3 partition(s) found and cached [FFA] Preparing for checking partitions count [FFA] Searching partitions using the provided UUID [FFA] No partition found. Querying framework ... [FFA] Reading partitions data from the RX buffer [FFA] Number of partition(s) found matching the UUID: 1 EFI: Pre-allocating 1 partition(s) info structures [FFA] Preparing for filling partitions info [FFA] Searching partitions using the provided UUID [FFA] Partition ID 8003 matches the provided UUID EFI: MM partition ID 0x8003 ... Booting /MemoryMapped(0x0,0x88200000,0xf00000) EFI stub: Booting Linux Kernel... EFI stub: Using DTB from configuration table EFI stub: Exiting boot services... [FFA] Freeing RX/TX buffers Booting Linux on physical CPU 0x0000000000 [0x410fd040] Linux version 5.19.9-yocto-standard (oe-user@oe-host) (aarch64-poky-linux-musl-gcc (GCC) 12.2.0, GNU ld (GNU Binutils) 2.39.0.20220819) #1 SMP PREEMPT Wed Sep 21 20:11:18 UTC 2022
Cc: Tom Rini trini@konsulko.com Cc: Simon Glass sjg@chromium.org Cc: Ilias Apalodimas ilias.apalodimas@linaro.org Cc: Jens Wiklander jens.wiklander@linaro.org Cc: Achin Gupta achin.gupta@arm.com Cc: Drew Reed Drew.Reed@arm.com Cc: Vishnu Banavath vishnu.banavath@arm.com Cc: Xueliang Zhong Xueliang.Zhong@arm.com
Abdellatif El Khlifi (10): arm64: smccc: add support for SMCCCv1.2 x0-x17 registers lib: uuid: introduce uuid_str_to_le_bin function arm_ffa: introduce Arm FF-A low-level driver arm_ffa: efi: unmap RX/TX buffers arm_ffa: introduce armffa command arm_ffa: introduce the FF-A Sandbox driver arm_ffa: introduce Sandbox test cases for UCLASS_FFA arm_ffa: introduce armffa command Sandbox test arm_ffa: efi: introduce FF-A MM communication arm_ffa: efi: corstone1000: enable MM communication
MAINTAINERS | 11 + arch/arm/cpu/armv8/smccc-call.S | 53 + arch/arm/lib/asm-offsets.c | 14 + cmd/Kconfig | 10 + cmd/Makefile | 2 + cmd/armffa.c | 239 +++ configs/corstone1000_defconfig | 4 + configs/sandbox64_defconfig | 2 + configs/sandbox_defconfig | 2 + doc/arch/arm64.ffa.rst | 218 +++ doc/arch/index.rst | 1 + doc/arch/sandbox.rst | 1 + drivers/Kconfig | 2 + drivers/Makefile | 1 + drivers/firmware/arm-ffa/Kconfig | 36 + drivers/firmware/arm-ffa/Makefile | 7 + drivers/firmware/arm-ffa/arm-ffa-uclass.c | 16 + drivers/firmware/arm-ffa/arm_ffa_prv.h | 210 +++ drivers/firmware/arm-ffa/core.c | 1324 +++++++++++++++++ drivers/firmware/arm-ffa/sandbox.c | 659 ++++++++ .../firmware/arm-ffa/sandbox_arm_ffa_prv.h | 144 ++ include/arm_ffa.h | 93 ++ include/configs/corstone1000.h | 9 + include/dm/uclass-id.h | 4 + include/linux/arm-smccc.h | 43 + include/mm_communication.h | 5 + include/sandbox_arm_ffa.h | 91 ++ include/uuid.h | 8 + lib/efi_loader/Kconfig | 14 +- lib/efi_loader/efi_boottime.c | 13 + lib/efi_loader/efi_variable_tee.c | 269 +++- lib/uuid.c | 46 + test/cmd/Makefile | 2 + test/cmd/armffa.c | 40 + test/dm/Makefile | 2 + test/dm/ffa.c | 394 +++++ 36 files changed, 3983 insertions(+), 6 deletions(-) create mode 100644 cmd/armffa.c create mode 100644 doc/arch/arm64.ffa.rst create mode 100644 drivers/firmware/arm-ffa/Kconfig create mode 100644 drivers/firmware/arm-ffa/Makefile create mode 100644 drivers/firmware/arm-ffa/arm-ffa-uclass.c create mode 100644 drivers/firmware/arm-ffa/arm_ffa_prv.h create mode 100644 drivers/firmware/arm-ffa/core.c create mode 100644 drivers/firmware/arm-ffa/sandbox.c create mode 100644 drivers/firmware/arm-ffa/sandbox_arm_ffa_prv.h create mode 100644 include/arm_ffa.h create mode 100644 include/sandbox_arm_ffa.h create mode 100644 test/cmd/armffa.c create mode 100644 test/dm/ffa.c
-- 2.17.1
Adding support for Arm FF-A v1.0 (Arm Firmware Framework for Armv8-A) [A].
- Being generic by design and can be used by any Arm 64-bit platform - The FF-A core driver - The FF-A bus is discoverable on demand at runtime - The driver provides driver operations to be used by clients to access the FF-A bus - FF-A driver can be compiled and used without EFI - Support for SMCCCv1.2 x0-x17 registers - Support for SMC32 calling convention - Support for 32-bit and 64-bit FF-A direct messaging - A new command called armffa is provided as an example of how to access the FF-A bus - An FF-A Sandbox driver is provided with test cases - Support for FF-A MM communication (compatible with EFI boot time) - Enabling FF-A and MM communication in Corstone1000 platform as a use case
For more details about the FF-A core driver please refer to [B].
Please find at [C] an example of the expected boot logs when enabling FF-A support for a platform. In this example the platform is Corstone1000. But it can be any Arm 64-bit platform.
Changelog of the major changes: ===========================
v8:
* pass the FF-A bus device to the bus operations * isolate the compilation choices between FF-A and OP-TEE * drop OP-TEE configs from Corstone-1000 defconfig * make ffa_get_partitions_info() second argument to be an SP count in both modes
v7: [7]
* add support for 32-bit direct messaging (now we have 32-bit and 64-bit support) * set the MM door bell event to use 64-bit direct messaging * issue a compile time error when one of these macros are not found : FFA_SHARED_MM_BUFFER_SIZE, FFA_SHARED_MM_BUFFER_OFFSET, FFA_SHARED_MM_BUFFER_ADDR * make uuid_str_to_le_bin() implementation similar to uuid_str_to_bin() by using same APIs
v6: [6]
* remove clearing x0-x17 registers after SMC calls * drop use of EFI runtime support for FF-A (We decided with Linaro to add this later) * drop discovery from initcalls (discovery will be on demand by FF-A users) * add FF-A runtime discovery at MM communication level * update the documentation and move it to doc/arch/arm64.ffa.rst
v5: [5]
* move changelogs in each commit to the changes section
v4: [4]
* add FF-A support README (doc/README.ffa.drv) * improving error handling by mapping the FF-A errors to standard errors and logs * replacing panics with an error log * align sandbox driver and tests with the new FF-A driver interfaces and new way of error handling * use the new FF-A driver interfaces for MM communication * discover MM partitions at runtime * copy FF-A driver private data to EFI runtime section at ExitBootServices() * moving the FF-A driver work to drivers/firmware/arm-ffa * improving features discovery in FFA_FEATURES * add remove/unbind functions to the FF-A core device * improve how the driver behaves when bus discovery is done more than once * move clearing x0-x17 registers code into a new macro like done in the linux kernel * enable EFI MM communication for the Corstone1000 platform
v3: [3]
* port x0-x17 registers support from linux kernel as defined by SMCCCv1.2 * align the interfaces of the u-boot FF-A driver with those in the linux FF-A driver * remove the FF-A helper layer * make the u-boot FF-A driver independent from EFI * provide an optional config that enables copying the driver data to EFI runtime section at ExitBootServices service * use 64-bit version of FFA_RXTX_MAP, FFA_MSG_SEND_DIRECT_{REQ, RESP} * update armffa command with the new driver interfaces
v2 [2]:
* make FF-A bus discoverable using device_{bind, probe} APIs * remove device tree support
v1 [1]:
* introduce FF-A bus driver with device tree support * introduce armffa command * introduce FF-A Sandbox driver * add FF-A Sandbox test cases * introduce FF-A MM communication
Cheers, Abdellatif
List of previous patches:
[1]: https://lore.kernel.org/all/20220329151659.16894-1-abdellatif.elkhlifi@arm.c... [2]: https://lore.kernel.org/all/20220415122803.16666-1-abdellatif.elkhlifi@arm.c... [3]: https://lore.kernel.org/all/20220801172053.20163-1-abdellatif.elkhlifi@arm.c... [4]: https://lore.kernel.org/all/20220926101723.9965-1-abdellatif.elkhlifi@arm.co... [5]: https://lore.kernel.org/all/20220926140827.15125-1-abdellatif.elkhlifi@arm.c... [6]: https://lore.kernel.org/all/20221013103857.614-1-abdellatif.elkhlifi@arm.com... [7]: https://lore.kernel.org/all/20221107192055.21669-1-abdellatif.elkhlifi@arm.c...
More details:
[A]: https://developer.arm.com/documentation/den0077/latest/ [B]: doc/arch/arm64.ffa.rst [C]: example of boot logs when enabling FF-A
``` U-Boot 2022.07 (Jul 11 2022 - 13:42:58 +0000) corstone1000 aarch64 ... [FFA] Conduit is SMC [FFA] FF-A driver 1.0 FF-A framework 1.0 [FFA] Versions are compatible [FFA] endpoint ID is 0 [FFA] Using 1 4KB page(s) for RX/TX buffers size [FFA] RX buffer at virtual address 0xfdf18000 [FFA] TX buffer at virtual address 0xfdf1a000 [FFA] RX/TX buffers mapped [FFA] Reading partitions data from the RX buffer [FFA] Partition ID 8001 : info cached [FFA] Partition ID 8002 : info cached [FFA] Partition ID 8003 : info cached [FFA] 3 partition(s) found and cached [FFA] Preparing for checking partitions count [FFA] Searching partitions using the provided UUID [FFA] No partition found. Querying framework ... [FFA] Reading partitions data from the RX buffer [FFA] Number of partition(s) found matching the UUID: 1 EFI: Pre-allocating 1 partition(s) info structures [FFA] Preparing for filling partitions info [FFA] Searching partitions using the provided UUID [FFA] Partition ID 8003 matches the provided UUID EFI: MM partition ID 0x8003 ... Booting /MemoryMapped(0x0,0x88200000,0xf00000) EFI stub: Booting Linux Kernel... EFI stub: Using DTB from configuration table EFI stub: Exiting boot services... [FFA] Freeing RX/TX buffers Booting Linux on physical CPU 0x0000000000 [0x410fd040] Linux version 5.19.9-yocto-standard (oe-user@oe-host) (aarch64-poky-linux-musl-gcc (GCC) 12.2.0, GNU ld (GNU Binutils) 2.39.0.20220819) #1 SMP PREEMPT Wed Sep 21 20:11:18 UTC 2022 ```
MAINTAINERS | 11 + arch/arm/cpu/armv8/smccc-call.S | 53 + arch/arm/lib/asm-offsets.c | 14 + cmd/Kconfig | 10 + cmd/Makefile | 2 + cmd/armffa.c | 237 +++ configs/corstone1000_defconfig | 2 + configs/sandbox64_defconfig | 2 + configs/sandbox_defconfig | 2 + doc/arch/arm64.ffa.rst | 218 +++ doc/arch/index.rst | 1 + doc/arch/sandbox/sandbox.rst | 1 + drivers/Kconfig | 2 + drivers/Makefile | 1 + drivers/firmware/arm-ffa/Kconfig | 36 + drivers/firmware/arm-ffa/Makefile | 7 + drivers/firmware/arm-ffa/arm-ffa-uclass.c | 16 + drivers/firmware/arm-ffa/arm_ffa_prv.h | 205 +++ drivers/firmware/arm-ffa/core.c | 1329 +++++++++++++++++ drivers/firmware/arm-ffa/sandbox.c | 659 ++++++++ .../firmware/arm-ffa/sandbox_arm_ffa_prv.h | 144 ++ include/arm_ffa.h | 97 ++ include/configs/corstone1000.h | 9 + include/dm/uclass-id.h | 4 + include/linux/arm-smccc.h | 43 + include/mm_communication.h | 5 + include/sandbox_arm_ffa.h | 91 ++ include/uuid.h | 8 + lib/efi_loader/Kconfig | 14 +- lib/efi_loader/efi_boottime.c | 13 + lib/efi_loader/efi_variable_tee.c | 294 +++- lib/uuid.c | 46 + test/cmd/Makefile | 2 + test/cmd/armffa.c | 39 + test/dm/Makefile | 2 + test/dm/ffa.c | 392 +++++ 36 files changed, 4005 insertions(+), 6 deletions(-) create mode 100644 cmd/armffa.c create mode 100644 doc/arch/arm64.ffa.rst create mode 100644 drivers/firmware/arm-ffa/Kconfig create mode 100644 drivers/firmware/arm-ffa/Makefile create mode 100644 drivers/firmware/arm-ffa/arm-ffa-uclass.c create mode 100644 drivers/firmware/arm-ffa/arm_ffa_prv.h create mode 100644 drivers/firmware/arm-ffa/core.c create mode 100644 drivers/firmware/arm-ffa/sandbox.c create mode 100644 drivers/firmware/arm-ffa/sandbox_arm_ffa_prv.h create mode 100644 include/arm_ffa.h create mode 100644 include/sandbox_arm_ffa.h create mode 100644 test/cmd/armffa.c create mode 100644 test/dm/ffa.c
add support for x0-x17 registers used by the SMC calls
In SMCCC v1.2 [1] arguments are passed in registers x1-x17. Results are returned in x0-x17.
This work is inspired from the following kernel commit:
arm64: smccc: Add support for SMCCCv1.2 extended input/output registers
[1]: https://documentation-service.arm.com/static/5f8edaeff86e16515cdbe4c6?token=
Signed-off-by: Abdellatif El Khlifi abdellatif.elkhlifi@arm.com Reviewed-by: Jens Wiklander jens.wiklander@linaro.org Cc: Tom Rini trini@konsulko.com Cc: Simon Glass sjg@chromium.org Cc: Ilias Apalodimas ilias.apalodimas@linaro.org
v7:
* improve indentation of ARM_SMCCC_1_2_REGS_Xn_OFFS
v4:
* rename the commit title and improve description new commit title: the current
v3:
* port x0-x17 registers support from linux kernel as defined by SMCCCv1.2 commit title: arm64: smccc: add Xn registers support used by SMC calls
arch/arm/cpu/armv8/smccc-call.S | 53 +++++++++++++++++++++++++++++++++ arch/arm/lib/asm-offsets.c | 14 +++++++++ include/linux/arm-smccc.h | 43 ++++++++++++++++++++++++++ 3 files changed, 110 insertions(+)
diff --git a/arch/arm/cpu/armv8/smccc-call.S b/arch/arm/cpu/armv8/smccc-call.S index dc92b28777..ec6f299bc9 100644 --- a/arch/arm/cpu/armv8/smccc-call.S +++ b/arch/arm/cpu/armv8/smccc-call.S @@ -1,6 +1,8 @@ /* SPDX-License-Identifier: GPL-2.0 */ /* * Copyright (c) 2015, Linaro Limited + * (C) Copyright 2022 ARM Limited + * Abdellatif El Khlifi abdellatif.elkhlifi@arm.com */ #include <linux/linkage.h> #include <linux/arm-smccc.h> @@ -45,3 +47,54 @@ ENDPROC(__arm_smccc_smc) ENTRY(__arm_smccc_hvc) SMCCC hvc ENDPROC(__arm_smccc_hvc) + +#ifdef CONFIG_ARM64 + + .macro SMCCC_1_2 instr + /* Save `res` and free a GPR that won't be clobbered */ + stp x1, x19, [sp, #-16]! + + /* Ensure `args` won't be clobbered while loading regs in next step */ + mov x19, x0 + + /* Load the registers x0 - x17 from the struct arm_smccc_1_2_regs */ + ldp x0, x1, [x19, #ARM_SMCCC_1_2_REGS_X0_OFFS] + ldp x2, x3, [x19, #ARM_SMCCC_1_2_REGS_X2_OFFS] + ldp x4, x5, [x19, #ARM_SMCCC_1_2_REGS_X4_OFFS] + ldp x6, x7, [x19, #ARM_SMCCC_1_2_REGS_X6_OFFS] + ldp x8, x9, [x19, #ARM_SMCCC_1_2_REGS_X8_OFFS] + ldp x10, x11, [x19, #ARM_SMCCC_1_2_REGS_X10_OFFS] + ldp x12, x13, [x19, #ARM_SMCCC_1_2_REGS_X12_OFFS] + ldp x14, x15, [x19, #ARM_SMCCC_1_2_REGS_X14_OFFS] + ldp x16, x17, [x19, #ARM_SMCCC_1_2_REGS_X16_OFFS] + + \instr #0 + + /* Load the `res` from the stack */ + ldr x19, [sp] + + /* Store the registers x0 - x17 into the result structure */ + stp x0, x1, [x19, #ARM_SMCCC_1_2_REGS_X0_OFFS] + stp x2, x3, [x19, #ARM_SMCCC_1_2_REGS_X2_OFFS] + stp x4, x5, [x19, #ARM_SMCCC_1_2_REGS_X4_OFFS] + stp x6, x7, [x19, #ARM_SMCCC_1_2_REGS_X6_OFFS] + stp x8, x9, [x19, #ARM_SMCCC_1_2_REGS_X8_OFFS] + stp x10, x11, [x19, #ARM_SMCCC_1_2_REGS_X10_OFFS] + stp x12, x13, [x19, #ARM_SMCCC_1_2_REGS_X12_OFFS] + stp x14, x15, [x19, #ARM_SMCCC_1_2_REGS_X14_OFFS] + stp x16, x17, [x19, #ARM_SMCCC_1_2_REGS_X16_OFFS] + + /* Restore original x19 */ + ldp xzr, x19, [sp], #16 + ret + .endm + +/* + * void arm_smccc_1_2_smc(const struct arm_smccc_1_2_regs *args, + * struct arm_smccc_1_2_regs *res); + */ +ENTRY(arm_smccc_1_2_smc) + SMCCC_1_2 smc +ENDPROC(arm_smccc_1_2_smc) + +#endif diff --git a/arch/arm/lib/asm-offsets.c b/arch/arm/lib/asm-offsets.c index 22fd541f9a..db6d7ed234 100644 --- a/arch/arm/lib/asm-offsets.c +++ b/arch/arm/lib/asm-offsets.c @@ -9,6 +9,9 @@ * generate asm statements containing #defines, * compile this file to assembler, and then extract the * #defines from the assembly-language output. + * + * (C) Copyright 2022 ARM Limited + * Abdellatif El Khlifi abdellatif.elkhlifi@arm.com */
#include <common.h> @@ -117,6 +120,17 @@ int main(void) DEFINE(ARM_SMCCC_RES_X2_OFFS, offsetof(struct arm_smccc_res, a2)); DEFINE(ARM_SMCCC_QUIRK_ID_OFFS, offsetof(struct arm_smccc_quirk, id)); DEFINE(ARM_SMCCC_QUIRK_STATE_OFFS, offsetof(struct arm_smccc_quirk, state)); +#ifdef CONFIG_ARM64 + DEFINE(ARM_SMCCC_1_2_REGS_X0_OFFS, offsetof(struct arm_smccc_1_2_regs, a0)); + DEFINE(ARM_SMCCC_1_2_REGS_X2_OFFS, offsetof(struct arm_smccc_1_2_regs, a2)); + DEFINE(ARM_SMCCC_1_2_REGS_X4_OFFS, offsetof(struct arm_smccc_1_2_regs, a4)); + DEFINE(ARM_SMCCC_1_2_REGS_X6_OFFS, offsetof(struct arm_smccc_1_2_regs, a6)); + DEFINE(ARM_SMCCC_1_2_REGS_X8_OFFS, offsetof(struct arm_smccc_1_2_regs, a8)); + DEFINE(ARM_SMCCC_1_2_REGS_X10_OFFS, offsetof(struct arm_smccc_1_2_regs, a10)); + DEFINE(ARM_SMCCC_1_2_REGS_X12_OFFS, offsetof(struct arm_smccc_1_2_regs, a12)); + DEFINE(ARM_SMCCC_1_2_REGS_X14_OFFS, offsetof(struct arm_smccc_1_2_regs, a14)); + DEFINE(ARM_SMCCC_1_2_REGS_X16_OFFS, offsetof(struct arm_smccc_1_2_regs, a16)); +#endif #endif
return 0; diff --git a/include/linux/arm-smccc.h b/include/linux/arm-smccc.h index e1d09884a1..9105031d55 100644 --- a/include/linux/arm-smccc.h +++ b/include/linux/arm-smccc.h @@ -1,6 +1,8 @@ /* SPDX-License-Identifier: GPL-2.0 */ /* * Copyright (c) 2015, Linaro Limited + * (C) Copyright 2022 ARM Limited + * Abdellatif El Khlifi abdellatif.elkhlifi@arm.com */ #ifndef __LINUX_ARM_SMCCC_H #define __LINUX_ARM_SMCCC_H @@ -70,6 +72,47 @@ struct arm_smccc_res { unsigned long a3; };
+#ifdef CONFIG_ARM64 +/** + * struct arm_smccc_1_2_regs - Arguments for or Results from SMC call + * @a0-a17 argument values from registers 0 to 17 + */ +struct arm_smccc_1_2_regs { + unsigned long a0; + unsigned long a1; + unsigned long a2; + unsigned long a3; + unsigned long a4; + unsigned long a5; + unsigned long a6; + unsigned long a7; + unsigned long a8; + unsigned long a9; + unsigned long a10; + unsigned long a11; + unsigned long a12; + unsigned long a13; + unsigned long a14; + unsigned long a15; + unsigned long a16; + unsigned long a17; +}; + +/** + * arm_smccc_1_2_smc() - make SMC calls + * @args: arguments passed via struct arm_smccc_1_2_regs + * @res: result values via struct arm_smccc_1_2_regs + * + * This function is used to make SMC calls following SMC Calling Convention + * v1.2 or above. The content of the supplied param are copied from the + * structure to registers prior to the SMC instruction. The return values + * are updated with the content from registers on return from the SMC + * instruction. + */ +asmlinkage void arm_smccc_1_2_smc(const struct arm_smccc_1_2_regs *args, + struct arm_smccc_1_2_regs *res); +#endif + /** * struct arm_smccc_quirk - Contains quirk information * @id: quirk identification
convert UUID string to little endian binary data
v8:
* use simple_strtoull() in uuid_str_to_le_bin() to support 32-bit platforms
v7:
* rename be_uuid_str_to_le_bin() to uuid_str_to_le_bin() * make uuid_str_to_le_bin() implementation similar to uuid_str_to_bin() by using same APIs
v4:
* rename ffa_uuid_str_to_bin to be_uuid_str_to_le_bin and put in a standalone commit (the current)
v3:
* introduce ffa_uuid_str_to_bin (provided by arm_ffa: introduce Arm FF-A low-level driver)
include/uuid.h | 8 ++++++++ lib/uuid.c | 46 ++++++++++++++++++++++++++++++++++++++++++++++ 2 files changed, 54 insertions(+)
diff --git a/include/uuid.h b/include/uuid.h index 4a4883d3b5..293a8eb0a5 100644 --- a/include/uuid.h +++ b/include/uuid.h @@ -2,6 +2,8 @@ /* * Copyright (C) 2014 Samsung Electronics * Przemyslaw Marczak p.marczak@samsung.com + * (C) Copyright 2022 ARM Limited + * Abdellatif El Khlifi abdellatif.elkhlifi@arm.com */ #ifndef __UUID_H__ #define __UUID_H__ @@ -44,4 +46,10 @@ int uuid_guid_get_bin(const char *guid_str, unsigned char *guid_bin); const char *uuid_guid_get_str(const unsigned char *guid_bin); void gen_rand_uuid(unsigned char *uuid_bin); void gen_rand_uuid_str(char *uuid_str, int str_format); + +/** + * uuid_str_to_le_bin - Converts a UUID string to little endian binary data + */ +int uuid_str_to_le_bin(const char *uuid_str, unsigned char *uuid_bin); + #endif diff --git a/lib/uuid.c b/lib/uuid.c index 465e1ac38f..d29f561a70 100644 --- a/lib/uuid.c +++ b/lib/uuid.c @@ -1,6 +1,8 @@ // SPDX-License-Identifier: GPL-2.0+ /* * Copyright 2011 Calxeda, Inc. + * (C) Copyright 2022 ARM Limited + * Abdellatif El Khlifi abdellatif.elkhlifi@arm.com */
#include <common.h> @@ -346,6 +348,50 @@ int uuid_str_to_bin(const char *uuid_str, unsigned char *uuid_bin, return 0; }
+/** + * uuid_str_to_le_bin() - Convert string UUID to little endian binary data. + * @uuid_str: pointer to UUID string + * @uuid_bin: pointer to allocated array for little endian output [16B] + * + * UUID string is 36 characters (36 bytes): + * + * xxxxxxxx-xxxx-xxxx-xxxx-xxxxxxxxxxxx + * + * where x is a hexadecimal character. Fields are separated by '-'s. + * When converting to a little endian binary UUID, the string fields are reversed. + * + * Return: + * + * uuid_bin filled with little endian UUID data + * On success 0 is returned. Otherwise, failure code. + */ +int uuid_str_to_le_bin(const char *uuid_str, unsigned char *uuid_bin) +{ + u16 tmp16; + u32 tmp32; + u64 tmp64; + + if (!uuid_str_valid(uuid_str) || !uuid_bin) + return -EINVAL; + + tmp32 = cpu_to_le32(hextoul(uuid_str, NULL)); + memcpy(uuid_bin, &tmp32, 4); + + tmp16 = cpu_to_le16(hextoul(uuid_str + 9, NULL)); + memcpy(uuid_bin + 4, &tmp16, 2); + + tmp16 = cpu_to_le16(hextoul(uuid_str + 14, NULL)); + memcpy(uuid_bin + 6, &tmp16, 2); + + tmp16 = cpu_to_le16(hextoul(uuid_str + 19, NULL)); + memcpy(uuid_bin + 8, &tmp16, 2); + + tmp64 = cpu_to_le64(simple_strtoull(uuid_str + 24, NULL, 16)); + memcpy(uuid_bin + 10, &tmp64, 6); + + return 0; +} + /* * uuid_bin_to_str() - convert big endian binary data to string UUID or GUID. *
Hi Abdellatif,
On Tue, 22 Nov 2022 at 06:18, Abdellatif El Khlifi abdellatif.elkhlifi@arm.com wrote:
Changelog:
v8:
- use simple_strtoull() in uuid_str_to_le_bin() to support 32-bit platforms
v7:
- rename be_uuid_str_to_le_bin() to uuid_str_to_le_bin()
v4:
- rename ffa_uuid_str_to_bin to be_uuid_str_to_le_bin and put in a standalone commit (the current)
v3:
- introduce ffa_uuid_str_to_bin (provided by arm_ffa: introduce Arm FF-A low-level driver)
Can you please add a full function comment in the header and also a test, perhaps in test/lib/uuid.c ?
REgards, Simon
Add the core driver implementing Arm Firmware Framework for Armv8-A v1.0
The Firmware Framework for Arm A-profile processors (FF-A v1.0) [1] describes interfaces (ABIs) that standardize communication between the Secure World and Normal World leveraging TrustZone technology.
This driver uses 64-bit registers as per SMCCCv1.2 spec and comes on top of the SMCCC layer. The driver provides the FF-A ABIs needed for querying the FF-A framework from the secure world.
The driver uses SMC32 calling convention which means using the first 32-bit data of the Xn registers.
All supported ABIs come with their 32-bit version except FFA_RXTX_MAP which has 64-bit version supported.
Both 32-bit and 64-bit direct messaging are supported which allows both 32-bit and 64-bit clients to use the FF-A bus.
In U-Boot FF-A design, FF-A is considered as a discoverable bus. The Secure World is considered as one entity to communicate with using the FF-A bus. FF-A communication is handled by one device and one instance (the bus). This FF-A driver takes care of all the interactions between Normal world and Secure World.
The driver exports its operations to be used by upper layers.
Exported operations:
- partition_info_get - sync_send_receive - rxtx_unmap
For more details please refer to the driver documentation [2].
[1]: https://developer.arm.com/documentation/den0077/latest/ [2]: doc/arch/arm64.ffa.rst
v8:
* make ffa_get_partitions_info() second argument to be an SP count in both modes * update ffa_bus_prvdata_get() to return a pointer rather than a pointer address * remove packing from ffa_partition_info and ffa_send_direct_data structures * pass the FF-A bus device to the bus operations
v7:
* add support for 32-bit direct messaging * rename be_uuid_str_to_le_bin() to uuid_str_to_le_bin() * improve the declaration of error handling mapping * stating in doc/arch/arm64.ffa.rst that EFI runtime is not supported
v6:
* drop use of EFI runtime support (We decided with Linaro to add this later) * drop discovery from initcalls (discovery will be on demand by FF-A users) * set the alignment of the RX/TX buffers to the larger translation granule size * move FF-A RX/TX buffers unmapping at ExitBootServices() to a separate commit * update the documentation and move it to doc/arch/arm64.ffa.rst
v4:
* add doc/README.ffa.drv * moving the FF-A driver work to drivers/firmware/arm-ffa * use less #ifdefs in lib/efi_loader/efi_boottime.c and replace #if defined by #if CONFIG_IS_ENABLED * improving error handling by mapping the FF-A errors to standard errors and logs * replacing panics with an error log and returning an error code * improving features discovery in FFA_FEATURES by introducing rxtx_min_pages private data field * add ffa_remove and ffa_unbind functions * improve how the driver behaves when bus discovery is done more than once
v3:
* align the interfaces of the U-Boot FF-A driver with those in the linux FF-A driver * remove the FF-A helper layer * make the U-Boot FF-A driver independent from EFI * provide an optional config that enables copying the driver data to EFI runtime section at ExitBootServices service * use 64-bit version of FFA_RXTX_MAP, FFA_MSG_SEND_DIRECT_{REQ, RESP}
v2:
v1:
MAINTAINERS | 7 + doc/arch/arm64.ffa.rst | 218 ++++ doc/arch/index.rst | 1 + drivers/Kconfig | 2 + drivers/Makefile | 1 + drivers/firmware/arm-ffa/Kconfig | 30 + drivers/firmware/arm-ffa/Makefile | 6 + drivers/firmware/arm-ffa/arm-ffa-uclass.c | 16 + drivers/firmware/arm-ffa/arm_ffa_prv.h | 200 ++++ drivers/firmware/arm-ffa/core.c | 1315 +++++++++++++++++++++ include/arm_ffa.h | 97 ++ include/dm/uclass-id.h | 4 + 12 files changed, 1897 insertions(+) create mode 100644 doc/arch/arm64.ffa.rst create mode 100644 drivers/firmware/arm-ffa/Kconfig create mode 100644 drivers/firmware/arm-ffa/Makefile create mode 100644 drivers/firmware/arm-ffa/arm-ffa-uclass.c create mode 100644 drivers/firmware/arm-ffa/arm_ffa_prv.h create mode 100644 drivers/firmware/arm-ffa/core.c create mode 100644 include/arm_ffa.h
diff --git a/MAINTAINERS b/MAINTAINERS index 97b2f69f65..dcd32cf83a 100644 --- a/MAINTAINERS +++ b/MAINTAINERS @@ -263,6 +263,13 @@ F: drivers/net/cortina_ni.h F: drivers/net/phy/ca_phy.c F: configs/cortina_presidio-asic-pnand_defconfig
+ARM FF-A +M: Abdellatif El Khlifi abdellatif.elkhlifi@arm.com +S: Maintained +F: doc/arch/arm64.ffa.rst +F: drivers/firmware/arm-ffa/ +F: include/arm_ffa.h + ARM FREESCALE IMX M: Stefano Babic sbabic@denx.de M: Fabio Estevam festevam@gmail.com diff --git a/doc/arch/arm64.ffa.rst b/doc/arch/arm64.ffa.rst new file mode 100644 index 0000000000..dfcec82e45 --- /dev/null +++ b/doc/arch/arm64.ffa.rst @@ -0,0 +1,218 @@ +.. SPDX-License-Identifier: GPL-2.0+ + +Arm FF-A Driver +=============== + +Summary +------- + +FF-A stands for Firmware Framework for Arm A-profile processors. + +FF-A specifies interfaces that enable a pair of software sandboxes to +communicate with each other. A sandbox aka partition could +be a VM in the Normal or Secure world, an application in S-EL0, or a +Trusted OS in S-EL1. + +This FF-A driver implements the interfaces to communicate with partitions in +the Secure world aka Secure partitions (SPs). + +The driver specifically focuses on communicating with SPs that isolate portions +of EFI runtime services that must run
