Re: [PATCH v3 2/6] sifive: fu540: Add Booting from SPI
Hi Jagan
From: Bin Meng [mailto:bmeng.cn@gmail.com] Sent: Monday, June 22, 2020 9:53 PM To: Jagan Teki Cc: Rick Jian-Zhi Chen(陳建志); Atish Patra; Palmer Dabbelt; Paul Walmsley; Anup Patel; Sagar Kadam; U-Boot Mailing List; linux-amarula Subject: Re: [PATCH v3 2/6] sifive: fu540: Add Booting from SPI
On Fri, Jun 5, 2020 at 4:40 AM Jagan Teki jagan@amarulasolutions.com wrote:
Add booting from SPI for SiFive Unleashed board.
Signed-off-by: Jagan Teki jagan@amarulasolutions.com
Changes for v3:
- updated based on master
arch/riscv/cpu/fu540/Kconfig | 2 + .../dts/hifive-unleashed-a00-u-boot.dtsi | 12 ++++++ configs/sifive_fu540_defconfig | 4 ++ doc/board/sifive/fu540.rst | 41 +++++++++++++++++++ 4 files changed, 59 insertions(+)
diff --git a/arch/riscv/cpu/fu540/Kconfig b/arch/riscv/cpu/fu540/Kconfig index e9302e87c0..7a813a9ac8 100644 --- a/arch/riscv/cpu/fu540/Kconfig +++ b/arch/riscv/cpu/fu540/Kconfig @@ -5,6 +5,8 @@ config SIFIVE_FU540 bool select ARCH_EARLY_INIT_R
imply BOARD
imply BOARD_FU540
These 2 are not needed in v3.
How is your opinion here ?
imply CPU imply CPU_RISCV imply RISCV_TIMER
diff --git a/arch/riscv/dts/hifive-unleashed-a00-u-boot.dtsi b/arch/riscv/dts/hifive-unleashed-a00-u-boot.dtsi index 303806454b..4b2b242deb 100644 --- a/arch/riscv/dts/hifive-unleashed-a00-u-boot.dtsi +++ b/arch/riscv/dts/hifive-unleashed-a00-u-boot.dtsi @@ -12,6 +12,10 @@ spi2 = &qspi2; };
config {
u-boot,spl-payload-offset = <0x105000>; /* loader2 @1044KB */
hfclk { u-boot,dm-spl; };
@@ -22,6 +26,14 @@
+&qspi0 {
u-boot,dm-spl;
flash@0 {
u-boot,dm-spl;
&qspi2 { mmc@0 { u-boot,dm-spl;
Other than above, Reviewed-by: Bin Meng bin.meng@windriver.com Tested-by: Bin Meng bin.meng@windriver.com
Rick Chen
