[PATCH] imx: remove woodburn board
Board is not longer used, remove it.
Signed-off-by: Stefano Babic sbabic@denx.de --- arch/arm/Kconfig | 10 -- board/woodburn/Kconfig | 25 --- board/woodburn/MAINTAINERS | 12 -- board/woodburn/Makefile | 8 - board/woodburn/imximage.cfg | 4 - board/woodburn/lowlevel_init.S | 24 --- board/woodburn/woodburn.c | 251 ------------------------------ configs/woodburn_defconfig | 51 ------ configs/woodburn_sd_defconfig | 63 -------- include/configs/woodburn.h | 18 --- include/configs/woodburn_common.h | 195 ----------------------- include/configs/woodburn_sd.h | 30 ---- 12 files changed, 691 deletions(-) delete mode 100644 board/woodburn/Kconfig delete mode 100644 board/woodburn/MAINTAINERS delete mode 100644 board/woodburn/Makefile delete mode 100644 board/woodburn/imximage.cfg delete mode 100644 board/woodburn/lowlevel_init.S delete mode 100644 board/woodburn/woodburn.c delete mode 100644 configs/woodburn_defconfig delete mode 100644 configs/woodburn_sd_defconfig delete mode 100644 include/configs/woodburn.h delete mode 100644 include/configs/woodburn_common.h delete mode 100644 include/configs/woodburn_sd.h
diff --git a/arch/arm/Kconfig b/arch/arm/Kconfig index 8d9f7fcce7..3d3d070223 100644 --- a/arch/arm/Kconfig +++ b/arch/arm/Kconfig @@ -598,15 +598,6 @@ config TARGET_X600 select PL011_SERIAL select SUPPORT_SPL
-config TARGET_WOODBURN - bool "Support woodburn" - select CPU_ARM1136 - -config TARGET_WOODBURN_SD - bool "Support woodburn_sd" - select CPU_ARM1136 - select SUPPORT_SPL - config TARGET_FLEA3 bool "Support flea3" select CPU_ARM1136 @@ -1880,7 +1871,6 @@ source "board/birdland/bav335x/Kconfig" source "board/toradex/colibri_pxa270/Kconfig" source "board/variscite/dart_6ul/Kconfig" source "board/vscom/baltos/Kconfig" -source "board/woodburn/Kconfig" source "board/xilinx/Kconfig" source "board/xilinx/zynq/Kconfig" source "board/xilinx/zynqmp/Kconfig" diff --git a/board/woodburn/Kconfig b/board/woodburn/Kconfig deleted file mode 100644 index 4699526cfd..0000000000 --- a/board/woodburn/Kconfig +++ /dev/null @@ -1,25 +0,0 @@ -if TARGET_WOODBURN - -config SYS_BOARD - default "woodburn" - -config SYS_SOC - default "mx35" - -config SYS_CONFIG_NAME - default "woodburn" - -endif - -if TARGET_WOODBURN_SD - -config SYS_BOARD - default "woodburn" - -config SYS_SOC - default "mx35" - -config SYS_CONFIG_NAME - default "woodburn_sd" - -endif diff --git a/board/woodburn/MAINTAINERS b/board/woodburn/MAINTAINERS deleted file mode 100644 index 4fbf6bb88b..0000000000 --- a/board/woodburn/MAINTAINERS +++ /dev/null @@ -1,12 +0,0 @@ -WOODBURN BOARD -M: Stefano Babic sbabic@denx.de -S: Maintained -F: board/woodburn/ -F: include/configs/woodburn.h -F: configs/woodburn_defconfig - -WOODBURN_SD BOARD -#M: - -S: Maintained -F: include/configs/woodburn_sd.h -F: configs/woodburn_sd_defconfig diff --git a/board/woodburn/Makefile b/board/woodburn/Makefile deleted file mode 100644 index 9c3cd6934a..0000000000 --- a/board/woodburn/Makefile +++ /dev/null @@ -1,8 +0,0 @@ -# SPDX-License-Identifier: GPL-2.0+ -# -# Copyright (C) 2007, Guennadi Liakhovetski lg@denx.de -# -# (C) Copyright 2008-2009 Freescale Semiconductor, Inc. - -obj-y := woodburn.o -obj-y += lowlevel_init.o diff --git a/board/woodburn/imximage.cfg b/board/woodburn/imximage.cfg deleted file mode 100644 index ba42a5e7d5..0000000000 --- a/board/woodburn/imximage.cfg +++ /dev/null @@ -1,4 +0,0 @@ -BOOT_FROM sd - -/* DDR2 init */ -DATA 4 0xB8001010 0x00000304 diff --git a/board/woodburn/lowlevel_init.S b/board/woodburn/lowlevel_init.S deleted file mode 100644 index 8186b3922b..0000000000 --- a/board/woodburn/lowlevel_init.S +++ /dev/null @@ -1,24 +0,0 @@ -/* SPDX-License-Identifier: GPL-2.0+ */ -/* - * Copyright (C) 2007, Guennadi Liakhovetski lg@denx.de - * - * (C) Copyright 2008-2010 Freescale Semiconductor, Inc. - * - * Copyright (C) 2011, Stefano Babic sbabic@denx.de - */ - -#include <config.h> -#include <asm/arch/lowlevel_macro.S> - -.globl lowlevel_init -lowlevel_init: - - core_init - - init_aips - - init_max - - init_m3if - - mov pc, lr diff --git a/board/woodburn/woodburn.c b/board/woodburn/woodburn.c deleted file mode 100644 index c69df6c7bf..0000000000 --- a/board/woodburn/woodburn.c +++ /dev/null @@ -1,251 +0,0 @@ -// SPDX-License-Identifier: GPL-2.0+ -/* - * Copyright (C) 2012, Stefano Babic sbabic@denx.de - * - * Based on flea3.c and mx35pdk.c - */ - -#include <common.h> -#include <init.h> -#include <asm/io.h> -#include <linux/errno.h> -#include <asm/arch/imx-regs.h> -#include <asm/arch/crm_regs.h> -#include <asm/arch/clock.h> -#include <asm/arch/iomux-mx35.h> -#include <i2c.h> -#include <power/pmic.h> -#include <fsl_pmic.h> -#include <mc13892.h> -#include <mmc.h> -#include <fsl_esdhc_imx.h> -#include <linux/types.h> -#include <asm/gpio.h> -#include <asm/arch/sys_proto.h> -#include <netdev.h> -#include <spl.h> - -#define CCM_CCMR_CONFIG 0x003F4208 - -#define ESDCTL_DDR2_CONFIG 0x007FFC3F - -/* For MMC */ -#define GPIO_MMC_CD 7 -#define GPIO_MMC_WP 8 - -DECLARE_GLOBAL_DATA_PTR; - -int dram_init(void) -{ - gd->ram_size = get_ram_size((long *)PHYS_SDRAM_1, - PHYS_SDRAM_1_SIZE); - - return 0; -} - -static void board_setup_sdram(void) -{ - struct esdc_regs *esdc = (struct esdc_regs *)ESDCTL_BASE_ADDR; - - /* Initialize with default values both CSD0/1 */ - writel(0x2000, &esdc->esdctl0); - writel(0x2000, &esdc->esdctl1); - - mx3_setup_sdram_bank(CSD0_BASE_ADDR, ESDCTL_DDR2_CONFIG, - 13, 10, 2, 0x8080); -} - -static void setup_iomux_fec(void) -{ - static const iomux_v3_cfg_t fec_pads[] = { - MX35_PAD_FEC_TX_CLK__FEC_TX_CLK, - MX35_PAD_FEC_RX_CLK__FEC_RX_CLK, - MX35_PAD_FEC_RX_DV__FEC_RX_DV, - MX35_PAD_FEC_COL__FEC_COL, - MX35_PAD_FEC_RDATA0__FEC_RDATA_0, - MX35_PAD_FEC_TDATA0__FEC_TDATA_0, - MX35_PAD_FEC_TX_EN__FEC_TX_EN, - MX35_PAD_FEC_MDC__FEC_MDC, - MX35_PAD_FEC_MDIO__FEC_MDIO, - MX35_PAD_FEC_TX_ERR__FEC_TX_ERR, - MX35_PAD_FEC_RX_ERR__FEC_RX_ERR, - MX35_PAD_FEC_CRS__FEC_CRS, - MX35_PAD_FEC_RDATA1__FEC_RDATA_1, - MX35_PAD_FEC_TDATA1__FEC_TDATA_1, - MX35_PAD_FEC_RDATA2__FEC_RDATA_2, - MX35_PAD_FEC_TDATA2__FEC_TDATA_2, - MX35_PAD_FEC_RDATA3__FEC_RDATA_3, - MX35_PAD_FEC_TDATA3__FEC_TDATA_3, - }; - - /* setup pins for FEC */ - imx_iomux_v3_setup_multiple_pads(fec_pads, ARRAY_SIZE(fec_pads)); -} - -int woodburn_init(void) -{ - struct ccm_regs *ccm = - (struct ccm_regs *)IMX_CCM_BASE; - - /* initialize PLL and clock configuration */ - writel(CCM_CCMR_CONFIG, &ccm->ccmr); - - /* Set-up RAM */ - board_setup_sdram(); - - /* enable clocks */ - writel(readl(&ccm->cgr0) | - MXC_CCM_CGR0_EMI_MASK | - MXC_CCM_CGR0_EDIO_MASK | - MXC_CCM_CGR0_EPIT1_MASK, - &ccm->cgr0); - - writel(readl(&ccm->cgr1) | - MXC_CCM_CGR1_FEC_MASK | - MXC_CCM_CGR1_GPIO1_MASK | - MXC_CCM_CGR1_GPIO2_MASK | - MXC_CCM_CGR1_GPIO3_MASK | - MXC_CCM_CGR1_I2C1_MASK | - MXC_CCM_CGR1_I2C2_MASK | - MXC_CCM_CGR1_I2C3_MASK, - &ccm->cgr1); - - /* Set-up NAND */ - __raw_writel(readl(&ccm->rcsr) | MXC_CCM_RCSR_NFC_FMS, &ccm->rcsr); - - /* Set pinmux for the required peripherals */ - setup_iomux_fec(); - - /* setup GPIO1_4 FEC_ENABLE signal */ - imx_iomux_v3_setup_pad(MX35_PAD_SCKR__GPIO1_4); - gpio_direction_output(4, 1); - imx_iomux_v3_setup_pad(MX35_PAD_HCKT__GPIO1_9); - gpio_direction_output(9, 1); - - return 0; -} - -#if defined(CONFIG_SPL_BUILD) -void board_init_f(ulong dummy) -{ - /* Set the stack pointer. */ - asm volatile("mov sp, %0\n" : : "r"(CONFIG_SPL_STACK)); - - /* Initialize MUX and SDRAM */ - woodburn_init(); - - /* Clear the BSS. */ - memset(__bss_start, 0, __bss_end - __bss_start); - - preloader_console_init(); - timer_init(); - - board_init_r(NULL, 0); -} - -void spl_board_init(void) -{ -} - -#endif - - -/* Booting from NOR in external mode */ -int board_early_init_f(void) -{ - return woodburn_init(); -} - - -int board_init(void) -{ - struct pmic *p; - u32 val; - int ret; - - /* address of boot parameters */ - gd->bd->bi_boot_params = PHYS_SDRAM_1 + 0x100; - - ret = pmic_init(I2C_PMIC); - if (ret) - return ret; - - p = pmic_get("FSL_PMIC"); - - /* - * Set switchers in Auto in NORMAL mode & STANDBY mode - * Setup the switcher mode for SW1 & SW2 - */ - pmic_reg_read(p, REG_SW_4, &val); - val = (val & ~((SWMODE_MASK << SWMODE1_SHIFT) | - (SWMODE_MASK << SWMODE2_SHIFT))); - val |= (SWMODE_AUTO_AUTO << SWMODE1_SHIFT) | - (SWMODE_AUTO_AUTO << SWMODE2_SHIFT); - /* Set SWILIMB */ - val |= (1 << 22); - pmic_reg_write(p, REG_SW_4, val); - - /* Setup the switcher mode for SW3 & SW4 */ - pmic_reg_read(p, REG_SW_5, &val); - val &= ~((SWMODE_MASK << SWMODE4_SHIFT) | - (SWMODE_MASK << SWMODE3_SHIFT)); - val |= (SWMODE_AUTO_AUTO << SWMODE4_SHIFT) | - (SWMODE_AUTO_AUTO << SWMODE3_SHIFT); - pmic_reg_write(p, REG_SW_5, val); - - /* Set VGEN1 to 3.15V */ - pmic_reg_read(p, REG_SETTING_0, &val); - val &= ~(VGEN1_MASK); - val |= VGEN1_3_15; - pmic_reg_write(p, REG_SETTING_0, val); - - pmic_reg_read(p, REG_MODE_0, &val); - val |= VGEN1EN; - pmic_reg_write(p, REG_MODE_0, val); - udelay(2000); - - return 0; -} - -#if defined(CONFIG_FSL_ESDHC_IMX) -struct fsl_esdhc_cfg esdhc_cfg = {MMC_SDHC1_BASE_ADDR}; - -int board_mmc_init(bd_t *bis) -{ - static const iomux_v3_cfg_t sdhc1_pads[] = { - MX35_PAD_SD1_CMD__ESDHC1_CMD, - MX35_PAD_SD1_CLK__ESDHC1_CLK, - MX35_PAD_SD1_DATA0__ESDHC1_DAT0, - MX35_PAD_SD1_DATA1__ESDHC1_DAT1, - MX35_PAD_SD1_DATA2__ESDHC1_DAT2, - MX35_PAD_SD1_DATA3__ESDHC1_DAT3, - }; - - /* configure pins for SDHC1 only */ - imx_iomux_v3_setup_multiple_pads(sdhc1_pads, ARRAY_SIZE(sdhc1_pads)); - - /* MMC Card Detect on GPIO1_7 */ - imx_iomux_v3_setup_pad(MX35_PAD_SCKT__GPIO1_7); - gpio_direction_input(GPIO_MMC_CD); - - /* MMC Write Protection on GPIO1_8 */ - imx_iomux_v3_setup_pad(MX35_PAD_FST__GPIO1_8); - gpio_direction_input(GPIO_MMC_WP); - - esdhc_cfg.sdhc_clk = mxc_get_clock(MXC_ESDHC1_CLK); - - return fsl_esdhc_initialize(bis, &esdhc_cfg); -} - -int board_mmc_getcd(struct mmc *mmc) -{ - return !gpio_get_value(GPIO_MMC_CD); -} -#endif - -u32 get_board_rev(void) -{ - int rev = 0; - - return (get_cpu_rev() & ~(0xF << 8)) | (rev & 0xF) << 8; -} diff --git a/configs/woodburn_defconfig b/configs/woodburn_defconfig deleted file mode 100644 index 2898564e95..0000000000 --- a/configs/woodburn_defconfig +++ /dev/null @@ -1,51 +0,0 @@ -CONFIG_ARM=y -CONFIG_SYS_DCACHE_OFF=y -CONFIG_TARGET_WOODBURN=y -CONFIG_SYS_TEXT_BASE=0xA0000000 -CONFIG_ENV_SIZE=0x20000 -CONFIG_ENV_SECT_SIZE=0x20000 -CONFIG_NR_DRAM_BANKS=1 -CONFIG_BOOTDELAY=3 -# CONFIG_DISPLAY_BOARDINFO is not set -CONFIG_BOARD_EARLY_INIT_F=y -CONFIG_HUSH_PARSER=y -CONFIG_SYS_PROMPT="woodburn U-Boot > " -CONFIG_CMD_IMLS=y -CONFIG_CMD_GPIO=y -CONFIG_CMD_I2C=y -CONFIG_CMD_MMC=y -CONFIG_CMD_SPI=y -# CONFIG_CMD_SETEXPR is not set -CONFIG_CMD_DHCP=y -CONFIG_CMD_MII=y -CONFIG_CMD_PING=y -CONFIG_CMD_CACHE=y -CONFIG_CMD_DATE=y -CONFIG_CMD_EXT2=y -CONFIG_CMD_FAT=y -CONFIG_CMD_MTDPARTS=y -CONFIG_MTDIDS_DEFAULT="nand0=mxc_nand,nor0=physmap-flash.0" -CONFIG_MTDPARTS_DEFAULT="mtdparts=mxc_nand:50m(root1),32m(rootfb),64m(pcache),64m(app1),10m(app2),-(spool);physmap-flash.0:512k(u-boot),64k(env1),64k(env2),3776k(kernel1),3776k(kernel2)" -CONFIG_EFI_PARTITION=y -# CONFIG_PARTITION_UUIDS is not set -CONFIG_ENV_IS_IN_FLASH=y -CONFIG_SYS_REDUNDAND_ENVIRONMENT=y -CONFIG_ENV_ADDR=0xA0080000 -CONFIG_ENV_ADDR_REDUND=0xA00A0000 -CONFIG_MXC_GPIO=y -CONFIG_FSL_ESDHC_IMX=y -CONFIG_MTD=y -CONFIG_MTD_NOR_FLASH=y -CONFIG_FLASH_CFI_DRIVER=y -CONFIG_SYS_FLASH_USE_BUFFER_WRITE=y -CONFIG_FLASH_CFI_MTD=y -CONFIG_SYS_FLASH_PROTECTION=y -CONFIG_SYS_FLASH_CFI=y -CONFIG_MTD_RAW_NAND=y -CONFIG_NAND_MXC=y -CONFIG_PHYLIB=y -CONFIG_PHY_MICREL=y -CONFIG_PHY_MICREL_KSZ8XXX=y -CONFIG_MII=y -CONFIG_SPI=y -CONFIG_MXC_SPI=y diff --git a/configs/woodburn_sd_defconfig b/configs/woodburn_sd_defconfig deleted file mode 100644 index 99675054f0..0000000000 --- a/configs/woodburn_sd_defconfig +++ /dev/null @@ -1,63 +0,0 @@ -CONFIG_ARM=y -CONFIG_SYS_DCACHE_OFF=y -CONFIG_TARGET_WOODBURN_SD=y -CONFIG_SYS_TEXT_BASE=0x82000000 -CONFIG_SPL_GPIO_SUPPORT=y -CONFIG_SPL_LIBCOMMON_SUPPORT=y -CONFIG_SPL_LIBGENERIC_SUPPORT=y -CONFIG_ENV_SIZE=0x20000 -CONFIG_ENV_SECT_SIZE=0x20000 -CONFIG_SPL_MMC_SUPPORT=y -CONFIG_SPL_SERIAL_SUPPORT=y -CONFIG_NR_DRAM_BANKS=1 -CONFIG_SPL=y -CONFIG_SPL_LIBDISK_SUPPORT=y -CONFIG_SPL_TEXT_BASE=0x10002300 -CONFIG_SYS_EXTRA_OPTIONS="IMX_CONFIG=board/woodburn/imximage.cfg" -CONFIG_BOOTDELAY=3 -# CONFIG_DISPLAY_BOARDINFO is not set -CONFIG_SPL_BOARD_INIT=y -CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_USE_SECTOR=y -CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_SECTOR=0x100 -CONFIG_HUSH_PARSER=y -CONFIG_SYS_PROMPT="woodburn U-Boot > " -CONFIG_CMD_IMLS=y -CONFIG_CMD_GPIO=y -CONFIG_CMD_I2C=y -CONFIG_CMD_MMC=y -CONFIG_CMD_SPI=y -# CONFIG_CMD_SETEXPR is not set -CONFIG_CMD_DHCP=y -CONFIG_CMD_MII=y -CONFIG_CMD_PING=y -CONFIG_CMD_CACHE=y -CONFIG_CMD_DATE=y -CONFIG_CMD_EXT2=y -CONFIG_CMD_FAT=y -CONFIG_CMD_MTDPARTS=y -CONFIG_MTDIDS_DEFAULT="nand0=mxc_nand,nor0=physmap-flash.0" -CONFIG_MTDPARTS_DEFAULT="mtdparts=mxc_nand:50m(root1),32m(rootfb),64m(pcache),64m(app1),10m(app2),-(spool);physmap-flash.0:512k(u-boot),64k(env1),64k(env2),3776k(kernel1),3776k(kernel2)" -CONFIG_EFI_PARTITION=y -# CONFIG_PARTITION_UUIDS is not set -# CONFIG_SPL_PARTITION_UUIDS is not set -CONFIG_ENV_IS_IN_FLASH=y -CONFIG_SYS_REDUNDAND_ENVIRONMENT=y -CONFIG_ENV_ADDR=0xA0080000 -CONFIG_ENV_ADDR_REDUND=0xA00A0000 -CONFIG_MXC_GPIO=y -CONFIG_FSL_ESDHC_IMX=y -CONFIG_MTD=y -CONFIG_MTD_NOR_FLASH=y -CONFIG_FLASH_CFI_DRIVER=y -CONFIG_SYS_FLASH_USE_BUFFER_WRITE=y -CONFIG_FLASH_CFI_MTD=y -CONFIG_SYS_FLASH_PROTECTION=y -CONFIG_SYS_FLASH_CFI=y -CONFIG_MTD_RAW_NAND=y -CONFIG_NAND_MXC=y -CONFIG_PHYLIB=y -CONFIG_PHY_MICREL=y -CONFIG_PHY_MICREL_KSZ8XXX=y -CONFIG_MII=y -CONFIG_SPI=y -CONFIG_MXC_SPI=y diff --git a/include/configs/woodburn.h b/include/configs/woodburn.h deleted file mode 100644 index 7f9ddb5b8e..0000000000 --- a/include/configs/woodburn.h +++ /dev/null @@ -1,18 +0,0 @@ -/* SPDX-License-Identifier: GPL-2.0+ */ -/* - * (C) Copyright 2011, Stefano Babic sbabic@denx.de - * - * (C) Copyright 2008-2010 Freescale Semiconductor, Inc. - * - * Configuration for the woodburn board. - */ - -#ifndef __CONFIG_H -#define __CONFIG_H - -#include <asm/arch/imx-regs.h> -#include "woodburn_common.h" - -/* Set TEXT at the beginning of the NOR flash */ - -#endif /* __CONFIG_H */ diff --git a/include/configs/woodburn_common.h b/include/configs/woodburn_common.h deleted file mode 100644 index 194e43ecc6..0000000000 --- a/include/configs/woodburn_common.h +++ /dev/null @@ -1,195 +0,0 @@ -/* SPDX-License-Identifier: GPL-2.0+ */ -/* - * (C) Copyright 2011, Stefano Babic sbabic@denx.de - * - * (C) Copyright 2008-2010 Freescale Semiconductor, Inc. - * - * Configuration for the woodburn board. - */ - -#ifndef __WOODBURN_COMMON_CONFIG_H -#define __WOODBURN_COMMON_CONFIG_H - -#include <asm/arch/imx-regs.h> - - /* High Level Configuration Options */ -#define CONFIG_MX35 -#define CONFIG_MX35_HCLK_FREQ 24000000 -#define CONFIG_SYS_FSL_CLK - -#define CONFIG_MACH_TYPE MACH_TYPE_FLEA3 - -/* This is required to setup the ESDC controller */ - -#define CONFIG_CMDLINE_TAG /* enable passing of ATAGs */ -#define CONFIG_REVISION_TAG -#define CONFIG_SETUP_MEMORY_TAGS -#define CONFIG_INITRD_TAG - -/* - * Size of malloc() pool - */ -#define CONFIG_SYS_MALLOC_LEN (CONFIG_ENV_SIZE + 1024 * 1024) - -/* - * Hardware drivers - */ -#define CONFIG_SYS_I2C -#define CONFIG_SYS_I2C_MXC -#define CONFIG_SYS_I2C_MXC_I2C1 /* enable I2C bus 1 */ -#define CONFIG_SYS_I2C_MXC_I2C2 /* enable I2C bus 2 */ -#define CONFIG_SYS_I2C_MXC_I2C3 /* enable I2C bus 3 */ -#define CONFIG_SYS_SPD_BUS_NUM 0 - -/* PMIC Controller */ -#define CONFIG_POWER -#define CONFIG_POWER_I2C -#define CONFIG_POWER_FSL -#define CONFIG_POWER_FSL_MC13892 -#define CONFIG_SYS_FSL_PMIC_I2C_ADDR 0x8 -#define CONFIG_RTC_MC13XXX - -/* mmc driver */ -#define CONFIG_SYS_FSL_ESDHC_ADDR 0 -#define CONFIG_SYS_FSL_ESDHC_NUM 1 - -/* - * UART (console) - */ -#define CONFIG_MXC_UART -#define CONFIG_MXC_UART_BASE UART1_BASE - -/* allow to overwrite serial and ethaddr */ -#define CONFIG_ENV_OVERWRITE - -/* - * Command definition - */ - -#define CONFIG_NET_RETRY_COUNT 100 - - -#define CONFIG_LOADADDR 0x80800000 /* loadaddr env var */ - -/* - * Ethernet on SOC (FEC) - */ -#define CONFIG_FEC_MXC -#define IMX_FEC_BASE FEC_BASE_ADDR -#define CONFIG_FEC_MXC_PHYADDR 0x1 - -#define CONFIG_DISCOVER_PHY - -#define CONFIG_ARP_TIMEOUT 200UL - -/* - * Miscellaneous configurable options - */ - -#define CONFIG_SYS_MEMTEST_START 0 /* memtest works on */ -#define CONFIG_SYS_MEMTEST_END 0x10000 - -#define CONFIG_SYS_LOAD_ADDR CONFIG_LOADADDR - -/* - * Physical Memory Map - */ -#define PHYS_SDRAM_1 CSD0_BASE_ADDR -#define PHYS_SDRAM_1_SIZE (256 * 1024 * 1024) - -#define CONFIG_SYS_SDRAM_BASE CSD0_BASE_ADDR - -#define CONFIG_SYS_GBL_DATA_OFFSET (LOW_LEVEL_SRAM_STACK - \ - IRAM_BASE_ADDR - \ - GENERATED_GBL_DATA_SIZE) -#define CONFIG_SYS_INIT_SP_ADDR (IRAM_BASE_ADDR + \ - CONFIG_SYS_GBL_DATA_OFFSET) - -/* - * MTD Command for mtdparts - */ - -/* - * FLASH and environment organization - */ -#define CONFIG_SYS_FLASH_BASE CS0_BASE_ADDR -#define CONFIG_SYS_MAX_FLASH_BANKS 1 /* max number of memory banks */ -#define CONFIG_SYS_MAX_FLASH_SECT 512 /* max number of sectors on one chip */ -/* Monitor at beginning of flash */ -#define CONFIG_SYS_MONITOR_BASE CONFIG_SYS_FLASH_BASE -#define CONFIG_SYS_MONITOR_LEN (512 * 1024) - -/* Address and size of Redundant Environment Sector */ - -/* - * CFI FLASH driver setup - */ - -/* A non-standard buffered write algorithm */ - -/* - * NAND FLASH driver setup - */ -#define CONFIG_NAND_MXC_V1_1 -#define CONFIG_MXC_NAND_REGS_BASE (NFC_BASE_ADDR) -#define CONFIG_SYS_MAX_NAND_DEVICE 1 -#define CONFIG_SYS_NAND_BASE (NFC_BASE_ADDR) -#define CONFIG_MXC_NAND_HWECC -#define CONFIG_SYS_NAND_LARGEPAGE - -#define CONFIG_SYS_NAND_ONFI_DETECTION - -/* - * Default environment and default scripts - * to update uboot and load kernel - */ - -#define CONFIG_HOSTNAME "woodburn" -#define CONFIG_EXTRA_ENV_SETTINGS \ - "netdev=eth0\0" \ - "nfsargs=setenv bootargs root=/dev/nfs rw " \ - "nfsroot=${serverip}:${rootpath}\0" \ - "ramargs=setenv bootargs root=/dev/ram rw\0" \ - "addip_sta=setenv bootargs ${bootargs} " \ - "ip=${ipaddr}:${serverip}:${gatewayip}:${netmask}" \ - ":${hostname}:${netdev}:off panic=1\0" \ - "addip_dyn=setenv bootargs ${bootargs} ip=dhcp\0" \ - "addip=if test -n ${ipdyn};then run addip_dyn;" \ - "else run addip_sta;fi\0" \ - "addmtd=setenv bootargs ${bootargs} ${mtdparts}\0" \ - "addtty=setenv bootargs ${bootargs}" \ - " console=ttymxc0,${baudrate}\0" \ - "addmisc=setenv bootargs ${bootargs} ${misc}\0" \ - "loadaddr=80800000\0" \ - "kernel_addr_r=80800000\0" \ - "hostname=" CONFIG_HOSTNAME "\0" \ - "bootfile=" CONFIG_HOSTNAME "/uImage\0" \ - "ramdisk_file=" CONFIG_HOSTNAME "/uRamdisk\0" \ - "flash_self=run ramargs addip addtty addmtd addmisc;" \ - "bootm ${kernel_addr} ${ramdisk_addr}\0" \ - "flash_nfs=run nfsargs addip addtty addmtd addmisc;" \ - "bootm ${kernel_addr}\0" \ - "net_nfs=tftp ${kernel_addr_r} ${bootfile}; " \ - "run nfsargs addip addtty addmtd addmisc;" \ - "bootm ${kernel_addr_r}\0" \ - "net_self_load=tftp ${kernel_addr_r} ${bootfile};" \ - "tftp ${ramdisk_addr_r} ${ramdisk_file};\0" \ - "net_self=if run net_self_load;then " \ - "run ramargs addip addtty addmtd addmisc;" \ - "bootm ${kernel_addr_r} ${ramdisk_addr_r};" \ - "else echo Images not loades;fi\0" \ - "u-boot=" CONFIG_HOSTNAME "/u-boot.bin\0" \ - "load=tftp ${loadaddr} ${u-boot}\0" \ - "uboot_addr=" __stringify(CONFIG_SYS_MONITOR_BASE) "\0" \ - "update=protect off ${uboot_addr} +80000;" \ - "erase ${uboot_addr} +80000;" \ - "cp.b ${loadaddr} ${uboot_addr} ${filesize}\0" \ - "upd=if run load;then echo Updating u-boot;if run update;" \ - "then echo U-Boot updated;" \ - "else echo Error updating u-boot !;" \ - "echo Board without bootloader !!;" \ - "fi;" \ - "else echo U-Boot not downloaded..exiting;fi\0" \ - "bootcmd=run net_nfs\0" - -#endif /* __CONFIG_H */ diff --git a/include/configs/woodburn_sd.h b/include/configs/woodburn_sd.h deleted file mode 100644 index 60d8a4b8c3..0000000000 --- a/include/configs/woodburn_sd.h +++ /dev/null @@ -1,30 +0,0 @@ -/* SPDX-License-Identifier: GPL-2.0+ */ -/* - * (C) Copyright 2011, Stefano Babic sbabic@denx.de - * - * (C) Copyright 2008-2010 Freescale Semiconductor, Inc. - * - * Configuration for the woodburn board. - */ - -#ifndef __CONFIG_H -#define __CONFIG_H - -#include <asm/arch/imx-regs.h> -#include "woodburn_common.h" - -/* Set TEXT in RAM */ - -/* - * SPL - */ - -#define CONFIG_SPL_MAX_SIZE (64 * 1024) /* 8 KB for stack */ -#define CONFIG_SPL_STACK LOW_LEVEL_SRAM_STACK - -#define CONFIG_SYS_SPL_MALLOC_START 0x8f000000 -#define CONFIG_SYS_SPL_MALLOC_SIZE 0x80000 -#define CONFIG_SPL_BSS_START_ADDR 0x8f080000 /* end of RAM */ -#define CONFIG_SPL_BSS_MAX_SIZE 0x80000 - -#endif /* __CONFIG_H */
Board is not longer used, remove it. Signed-off-by: Stefano Babic sbabic@denx.de
Best regards, Stefano Babic
sbabic@denx.de
Stefano Babic
