[U-Boot] [PATCH] config.mk: Remove unused HPATH
This variable is not unused anywhere.
Signed-off-by: Shinya Kuribayashi skuribay@pobox.com --- config.mk | 2 +- 1 files changed, 1 insertions(+), 1 deletions(-)
diff --git a/config.mk b/config.mk index f2c2c6c..a9973a4 100644 --- a/config.mk +++ b/config.mk @@ -196,7 +196,7 @@ endif
-export HPATH HOSTCC HOSTCFLAGS CROSS_COMPILE \ +export HOSTCC HOSTCFLAGS CROSS_COMPILE \ AS LD CC CPP AR NM STRIP OBJCOPY OBJDUMP MAKE export TEXT_BASE PLATFORM_CPPFLAGS PLATFORM_RELFLAGS CPPFLAGS CFLAGS AFLAGS
Hi Shinya,
Makes my brain twist and after carefully applying boolean equivalence operations contradicts the title ;)
Cheers Detlev
Dear Shinya Kuribayashi,
Applied, thanks.
Detlev Zundel
Shinya Kuribayashi
