[U-Boot-Users] Write buffer programming for AMD flash chips
Hi Alex,
I had a look at your patch and I believe that it does almost the same than mine. From a point of readability and extendability I would prefer it, whereas my patch would save some memory.
A missing part in your patch is checking whether data to be written are aligned with the flash chips write buffer. This is done with the following hunk for the write_buff function:
buffered_size = (info->portwidth / info->chipwidth); buffered_size *= info->buffer_size; while (cnt >= info->portwidth) { - i = buffered_size > cnt ? cnt : buffered_size; + /* write buffer until next buffered_size aligned boundary */ + i = buffered_size - (wp % buffered_size); + if (i>cnt) + i = cnt; if ((rc = flash_write_cfibuffer (info, wp, src, i)) != ERR_OK) return rc; i -= (i % info->portwidth);
In our case, the lack of this code lead to errors when writing the environment to flash. The reason is that environment writing is done in 3 steps and this results in not buffer-aligned write cycles. The code above calculates the correct buffer size (i) depending on the first address (wp) to be written
Thomas Schäfer
E-mail: thomas.schaefer@kontron.com
Thomas Schäfer
