[PATCH] u-boot: Ensure we use BFD as linker even if using GCC for it
If we are using 'ld-is-gold' as DISTRO_FEATURE, the U-Boot Makefile has mechanisms to ensure that we use BFD as linker. However, this does not work for the GCC when it is used as linking tool.
To support that, we added explicit BFD use whenever we have the DISTRO_FEATURE feature enabled.
Signed-off-by: Otavio Salvador otavio@ossystems.com.br ---
meta/recipes-bsp/u-boot/u-boot.inc | 3 ++- 1 file changed, 2 insertions(+), 1 deletion(-)
diff --git a/meta/recipes-bsp/u-boot/u-boot.inc b/meta/recipes-bsp/u-boot/u-boot.inc index 5a7bd6703f..ed3822784e 100644 --- a/meta/recipes-bsp/u-boot/u-boot.inc +++ b/meta/recipes-bsp/u-boot/u-boot.inc @@ -9,7 +9,8 @@ inherit uboot-config uboot-extlinux-config uboot-sign deploy python3native kerne
DEPENDS += "swig-native"
-EXTRA_OEMAKE = 'CROSS_COMPILE=${TARGET_PREFIX} CC="${TARGET_PREFIX}gcc ${TOOLCHAIN_OPTIONS} ${DEBUG_PREFIX_MAP}" V=1' +EXTRA_OEMAKE = 'CROSS_COMPILE=${TARGET_PREFIX} V=1' +EXTRA_OEMAKE += 'CC="${TARGET_PREFIX}gcc ${TOOLCHAIN_OPTIONS} ${@bb.utils.contains('DISTRO_FEATURES', 'ld-is-gold', ' -fuse-ld=bfd ', '', d)} ${DEBUG_PREFIX_MAP}"' EXTRA_OEMAKE += 'HOSTCC="${BUILD_CC} ${BUILD_CFLAGS} ${BUILD_LDFLAGS}"' EXTRA_OEMAKE += 'STAGING_INCDIR=${STAGING_INCDIR_NATIVE} STAGING_LIBDIR=${STAGING_LIBDIR_NATIVE}'
Otavio Salvador
